RTEMS  5.1
lpc24xx.h
1
9 /*
10  * Copyright (c) 2008-2011 embedded brains GmbH. All rights reserved.
11  *
12  * embedded brains GmbH
13  * Obere Lagerstr. 30
14  * 82178 Puchheim
15  * Germany
16  * <rtems@embedded-brains.de>
17  *
18  * The license and distribution terms for this file may be
19  * found in the file LICENSE in this distribution or at
20  * http://www.rtems.org/license/LICENSE.
21  */
22
23 #ifndef LIBBSP_ARM_LPC24XX_LPC24XX_H
24 #define LIBBSP_ARM_LPC24XX_LPC24XX_H
25
26 #include <rtems/score/cpu.h>
27 #include <bsp/utility.h>
28 #include <bsp/lpc-i2s.h>
29
30 #ifdef ARM_MULTILIB_ARCH_V7M
31  #include <bsp/lpc17xx.h>
32 #endif
33
44 #ifdef ARM_MULTILIB_ARCH_V4
45
46 /* Vectored Interrupt Controller (VIC) */
47 #define VIC_BASE_ADDR 0xFFFFF000
48 #define VICIRQStatus (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x000))
49 #define VICFIQStatus (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x004))
50 #define VICRawIntr (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x008))
51 #define VICIntSelect (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x00C))
52 #define VICIntEnable (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x010))
53 #define VICIntEnClear (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x014))
54 #define VICSoftInt (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x018))
55 #define VICSoftIntClear (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x01C))
56 #define VICProtection (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x020))
57 #define VICSWPrioMask (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x024))
58
59 #define VICVectAddrBase ((volatile uint32_t *) (VIC_BASE_ADDR + 0x100))
60 #define VICVectAddr0 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x100))
61 #define VICVectAddr1 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x104))
62 #define VICVectAddr2 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x108))
63 #define VICVectAddr3 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x10C))
64 #define VICVectAddr4 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x110))
65 #define VICVectAddr5 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x114))
66 #define VICVectAddr6 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x118))
67 #define VICVectAddr7 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x11C))
68 #define VICVectAddr8 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x120))
69 #define VICVectAddr9 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x124))
70 #define VICVectAddr10 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x128))
71 #define VICVectAddr11 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x12C))
72 #define VICVectAddr12 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x130))
73 #define VICVectAddr13 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x134))
74 #define VICVectAddr14 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x138))
75 #define VICVectAddr15 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x13C))
76 #define VICVectAddr16 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x140))
77 #define VICVectAddr17 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x144))
78 #define VICVectAddr18 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x148))
79 #define VICVectAddr19 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x14C))
80 #define VICVectAddr20 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x150))
81 #define VICVectAddr21 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x154))
82 #define VICVectAddr22 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x158))
83 #define VICVectAddr23 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x15C))
84 #define VICVectAddr24 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x160))
85 #define VICVectAddr25 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x164))
86 #define VICVectAddr26 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x168))
87 #define VICVectAddr27 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x16C))
88 #define VICVectAddr28 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x170))
89 #define VICVectAddr29 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x174))
90 #define VICVectAddr30 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x178))
91 #define VICVectAddr31 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x17C))
92
93 #define VICVectPriorityBase ((volatile uint32_t *) (VIC_BASE_ADDR + 0x200))
94 #define VICVectPriority0 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x200))
95 #define VICVectPriority1 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x204))
96 #define VICVectPriority2 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x208))
97 #define VICVectPriority3 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x20C))
98 #define VICVectPriority4 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x210))
99 #define VICVectPriority5 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x214))
100 #define VICVectPriority6 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x218))
101 #define VICVectPriority7 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x21C))
102 #define VICVectPriority8 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x220))
103 #define VICVectPriority9 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x224))
104 #define VICVectPriority10 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x228))
105 #define VICVectPriority11 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x22C))
106 #define VICVectPriority12 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x230))
107 #define VICVectPriority13 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x234))
108 #define VICVectPriority14 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x238))
109 #define VICVectPriority15 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x23C))
110 #define VICVectPriority16 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x240))
111 #define VICVectPriority17 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x244))
112 #define VICVectPriority18 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x248))
113 #define VICVectPriority19 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x24C))
114 #define VICVectPriority20 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x250))
115 #define VICVectPriority21 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x254))
116 #define VICVectPriority22 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x258))
117 #define VICVectPriority23 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x25C))
118 #define VICVectPriority24 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x260))
119 #define VICVectPriority25 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x264))
120 #define VICVectPriority26 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x268))
121 #define VICVectPriority27 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x26C))
122 #define VICVectPriority28 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x270))
123 #define VICVectPriority29 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x274))
124 #define VICVectPriority30 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x278))
125 #define VICVectPriority31 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x27C))
126
127 #define VICVectAddr (*(volatile uint32_t *) (VIC_BASE_ADDR + 0xF00))
128
129 #endif /* ARM_MULTILIB_ARCH_V4 */
130
131 /* Pin Connect Block */
132 #ifdef ARM_MULTILIB_ARCH_V4
133  #define PINSEL_BASE_ADDR 0xE002C000
134 #else
135  #define PINSEL_BASE_ADDR 0x4002C000
136 #endif
137
138 #ifdef ARM_MULTILIB_ARCH_V4
139
140 #define PINSEL0 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x00))
141 #define PINSEL1 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x04))
142 #define PINSEL2 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x08))
143 #define PINSEL3 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x0C))
144 #define PINSEL4 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x10))
145 #define PINSEL5 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x14))
146 #define PINSEL6 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x18))
147 #define PINSEL7 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x1C))
148 #define PINSEL8 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x20))
149 #define PINSEL9 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x24))
150 #define PINSEL10 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x28))
151 #define PINSEL11 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x2C))
152
153 #define PINMODE0 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x40))
154 #define PINMODE1 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x44))
155 #define PINMODE2 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x48))
156 #define PINMODE3 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x4C))
157 #define PINMODE4 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x50))
158 #define PINMODE5 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x54))
159 #define PINMODE6 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x58))
160 #define PINMODE7 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x5C))
161 #define PINMODE8 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x60))
162 #define PINMODE9 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x64))
163
164 #endif /* ARM_MULTILIB_ARCH_V4 */
165
166 /* General Purpose Input/Output (GPIO) */
167 #ifdef ARM_MULTILIB_ARCH_V4
168  #define GPIO_BASE_ADDR 0xE0028000
169 #else
170  #define GPIO_BASE_ADDR 0x40028000
171 #endif
172 #define IOPIN0 (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x00))
173 #define IOSET0 (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x04))
174 #define IODIR0 (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x08))
175 #define IOCLR0 (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x0C))
176 #define IOPIN1 (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x10))
177 #define IOSET1 (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x14))
178 #define IODIR1 (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x18))
179 #define IOCLR1 (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x1C))
180
181 /* GPIO Interrupt Registers */
182 #define IO0_INT_EN_R (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x90))
183 #define IO0_INT_EN_F (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x94))
184 #define IO0_INT_STAT_R (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x84))
185 #define IO0_INT_STAT_F (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x88))
186 #define IO0_INT_CLR (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x8C))
187
188 #define IO2_INT_EN_R (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0xB0))
189 #define IO2_INT_EN_F (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0xB4))
190 #define IO2_INT_STAT_R (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0xA4))
191 #define IO2_INT_STAT_F (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0xA8))
192 #define IO2_INT_CLR (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0xAC))
193
194 #define IO_INT_STAT (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x80))
195
196 #ifdef ARM_MULTILIB_ARCH_V4
197
198 #define PARTCFG_BASE_ADDR 0x3FFF8000
199 #define PARTCFG (*(volatile uint32_t *) (PARTCFG_BASE_ADDR + 0x00))
200
201 #endif /* ARM_MULTILIB_ARCH_V4 */
202
203 /* Fast I/O setup */
204 #ifdef ARM_MULTILIB_ARCH_V4
205  #define FIO_BASE_ADDR 0x3FFFC000
206 #else
207  #define FIO_BASE_ADDR 0x20098000
208 #endif
209 #define FIO0DIR (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x00))
210 #define FIO0MASK (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x10))
211 #define FIO0PIN (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x14))
212 #define FIO0SET (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x18))
213 #define FIO0CLR (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x1C))
214
215 #define FIO1DIR (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x20))
216 #define FIO1MASK (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x30))
217 #define FIO1PIN (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x34))
218 #define FIO1SET (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x38))
219 #define FIO1CLR (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x3C))
220
221 #define FIO2DIR (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x40))
222 #define FIO2MASK (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x50))
223 #define FIO2PIN (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x54))
224 #define FIO2SET (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x58))
225 #define FIO2CLR (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x5C))
226
227 #define FIO3DIR (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x60))
228 #define FIO3MASK (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x70))
229 #define FIO3PIN (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x74))
230 #define FIO3SET (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x78))
231 #define FIO3CLR (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x7C))
232
233 #define FIO4DIR (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x80))
234 #define FIO4MASK (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x90))
235 #define FIO4PIN (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x94))
236 #define FIO4SET (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x98))
237 #define FIO4CLR (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x9C))
238
239 #ifdef ARM_MULTILIB_ARCH_V7M
240
241 #define FIO5DIR (*(volatile uint32_t *) (FIO_BASE_ADDR + 0xa0))
242 #define FIO5MASK (*(volatile uint32_t *) (FIO_BASE_ADDR + 0xb0))
243 #define FIO5PIN (*(volatile uint32_t *) (FIO_BASE_ADDR + 0xb4))
244 #define FIO5SET (*(volatile uint32_t *) (FIO_BASE_ADDR + 0xb8))
245 #define FIO5CLR (*(volatile uint32_t *) (FIO_BASE_ADDR + 0xbC))
246
247 #endif /* ARM_MULTILIB_ARCH_V7M */
248
249 /* FIOs can be accessed through WORD, HALF-WORD or BYTE. */
250 #define FIO0DIR0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x00))
251 #define FIO1DIR0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x20))
252 #define FIO2DIR0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x40))
253 #define FIO3DIR0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x60))
254 #define FIO4DIR0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x80))
255
256 #define FIO0DIR1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x01))
257 #define FIO1DIR1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x21))
258 #define FIO2DIR1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x41))
259 #define FIO3DIR1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x61))
260 #define FIO4DIR1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x81))
261
262 #define FIO0DIR2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x02))
263 #define FIO1DIR2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x22))
264 #define FIO2DIR2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x42))
265 #define FIO3DIR2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x62))
266 #define FIO4DIR2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x82))
267
268 #define FIO0DIR3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x03))
269 #define FIO1DIR3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x23))
270 #define FIO2DIR3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x43))
271 #define FIO3DIR3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x63))
272 #define FIO4DIR3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x83))
273
274 #define FIO0DIRL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x00))
275 #define FIO1DIRL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x20))
276 #define FIO2DIRL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x40))
277 #define FIO3DIRL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x60))
278 #define FIO4DIRL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x80))
279
280 #define FIO0DIRU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x02))
281 #define FIO1DIRU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x22))
282 #define FIO2DIRU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x42))
283 #define FIO3DIRU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x62))
284 #define FIO4DIRU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x82))
285
286 #define FIO0MASK0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x10))
287 #define FIO1MASK0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x30))
288 #define FIO2MASK0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x50))
289 #define FIO3MASK0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x70))
290 #define FIO4MASK0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x90))
291
292 #define FIO0MASK1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x11))
293 #define FIO1MASK1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x21))
294 #define FIO2MASK1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x51))
295 #define FIO3MASK1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x71))
296 #define FIO4MASK1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x91))
297
298 #define FIO0MASK2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x12))
299 #define FIO1MASK2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x32))
300 #define FIO2MASK2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x52))
301 #define FIO3MASK2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x72))
302 #define FIO4MASK2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x92))
303
304 #define FIO0MASK3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x13))
305 #define FIO1MASK3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x33))
306 #define FIO2MASK3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x53))
307 #define FIO3MASK3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x73))
308 #define FIO4MASK3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x93))
309
310 #define FIO0MASKL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x10))
311 #define FIO1MASKL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x30))
312 #define FIO2MASKL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x50))
313 #define FIO3MASKL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x70))
314 #define FIO4MASKL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x90))
315
316 #define FIO0MASKU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x12))
317 #define FIO1MASKU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x32))
318 #define FIO2MASKU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x52))
319 #define FIO3MASKU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x72))
320 #define FIO4MASKU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x92))
321
322 #define FIO0PIN0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x14))
323 #define FIO1PIN0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x34))
324 #define FIO2PIN0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x54))
325 #define FIO3PIN0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x74))
326 #define FIO4PIN0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x94))
327
328 #define FIO0PIN1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x15))
329 #define FIO1PIN1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x25))
330 #define FIO2PIN1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x55))
331 #define FIO3PIN1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x75))
332 #define FIO4PIN1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x95))
333
334 #define FIO0PIN2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x16))
335 #define FIO1PIN2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x36))
336 #define FIO2PIN2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x56))
337 #define FIO3PIN2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x76))
338 #define FIO4PIN2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x96))
339
340 #define FIO0PIN3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x17))
341 #define FIO1PIN3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x37))
342 #define FIO2PIN3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x57))
343 #define FIO3PIN3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x77))
344 #define FIO4PIN3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x97))
345
346 #define FIO0PINL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x14))
347 #define FIO1PINL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x34))
348 #define FIO2PINL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x54))
349 #define FIO3PINL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x74))
350 #define FIO4PINL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x94))
351
352 #define FIO0PINU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x16))
353 #define FIO1PINU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x36))
354 #define FIO2PINU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x56))
355 #define FIO3PINU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x76))
356 #define FIO4PINU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x96))
357
358 #define FIO0SET0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x18))
359 #define FIO1SET0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x38))
360 #define FIO2SET0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x58))
361 #define FIO3SET0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x78))
362 #define FIO4SET0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x98))
363
364 #define FIO0SET1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x19))
365 #define FIO1SET1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x29))
366 #define FIO2SET1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x59))
367 #define FIO3SET1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x79))
368 #define FIO4SET1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x99))
369
370 #define FIO0SET2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x1A))
371 #define FIO1SET2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x3A))
372 #define FIO2SET2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x5A))
373 #define FIO3SET2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x7A))
374 #define FIO4SET2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x9A))
375
376 #define FIO0SET3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x1B))
377 #define FIO1SET3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x3B))
378 #define FIO2SET3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x5B))
379 #define FIO3SET3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x7B))
380 #define FIO4SET3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x9B))
381
382 #define FIO0SETL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x18))
383 #define FIO1SETL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x38))
384 #define FIO2SETL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x58))
385 #define FIO3SETL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x78))
386 #define FIO4SETL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x98))
387
388 #define FIO0SETU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x1A))
389 #define FIO1SETU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x3A))
390 #define FIO2SETU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x5A))
391 #define FIO3SETU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x7A))
392 #define FIO4SETU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x9A))
393
394 #define FIO0CLR0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x1C))
395 #define FIO1CLR0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x3C))
396 #define FIO2CLR0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x5C))
397 #define FIO3CLR0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x7C))
398 #define FIO4CLR0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x9C))
399
400 #define FIO0CLR1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x1D))
401 #define FIO1CLR1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x2D))
402 #define FIO2CLR1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x5D))
403 #define FIO3CLR1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x7D))
404 #define FIO4CLR1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x9D))
405
406 #define FIO0CLR2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x1E))
407 #define FIO1CLR2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x3E))
408 #define FIO2CLR2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x5E))
409 #define FIO3CLR2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x7E))
410 #define FIO4CLR2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x9E))
411
412 #define FIO0CLR3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x1F))
413 #define FIO1CLR3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x3F))
414 #define FIO2CLR3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x5F))
415 #define FIO3CLR3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x7F))
416 #define FIO4CLR3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x9F))
417
418 #define FIO0CLRL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x1C))
419 #define FIO1CLRL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x3C))
420 #define FIO2CLRL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x5C))
421 #define FIO3CLRL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x7C))
422 #define FIO4CLRL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x9C))
423
424 #define FIO0CLRU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x1E))
425 #define FIO1CLRU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x3E))
426 #define FIO2CLRU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x5E))
427 #define FIO3CLRU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x7E))
428 #define FIO4CLRU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x9E))
429
430 #ifdef ARM_MULTILIB_ARCH_V4
431
432 /* System Control Block(SCB) modules include Memory Accelerator Module,
433 Phase Locked Loop, VPB divider, Power Control, External Interrupt,
434 Reset, and Code Security/Debugging */
435 #define SCB_BASE_ADDR 0xE01FC000
436
437 /* Memory Accelerator Module (MAM) */
438 #define MAMCR (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x000))
439 #define MAMTIM (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x004))
440 #define MEMMAP (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x040))
441
442 /* Phase Locked Loop (PLL) */
443 #define PLLCON (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x080))
444 #define PLLCFG (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x084))
445 #define PLLSTAT (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x088))
446 #define PLLFEED (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x08C))
447
448 /* Power Control */
449 #define PCON (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x0C0))
450 #define PCONP (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x0C4))
451
452 /* Clock Divider */
453 // #define APBDIV (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x100))
454 #define CCLKCFG (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x104))
455 #define USBCLKCFG (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x108))
456 #define CLKSRCSEL (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x10C))
457 #define PCLKSEL0 (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x1A8))
458 #define PCLKSEL1 (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x1AC))
459
460 /* External Interrupts */
461 #define EXTINT (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x140))
462 #define INTWAKE (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x144))
463 #define EXTMODE (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x148))
464 #define EXTPOLAR (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x14C))
465
466 /* Reset, reset source identification */
467 #define RSIR (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x180))
468
469 /* RSID, code security protection */
470 #define CSPR (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x184))
471
472 /* AHB configuration */
473 #define AHBCFG1 (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x188))
474 #define AHBCFG2 (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x18C))
475
476 /* System Controls and Status */
477 #define SCS (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x1A0))
478
479 #endif /* ARM_MULTILIB_ARCH_V4 */
480
481 /* External Memory Controller (EMC) */
482 #ifdef ARM_MULTILIB_ARCH_V4
483  #define EMC_BASE_ADDR 0xFFE08000
484 #else
485  #define EMC_BASE_ADDR 0x2009c000
486 #endif
487 #define EMC_CTRL (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x000))
488 #define EMC_STAT (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x004))
489 #define EMC_CONFIG (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x008))
490
491 /* Dynamic RAM access registers */
492 #define EMC_DYN_CTRL (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x020))
493 #define EMC_DYN_RFSH (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x024))
494 #define EMC_DYN_RD_CFG (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x028))
495 #define EMC_DYN_RP (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x030))
496 #define EMC_DYN_RAS (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x034))
497 #define EMC_DYN_SREX (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x038))
498 #define EMC_DYN_APR (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x03C))
499 #define EMC_DYN_DAL (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x040))
500 #define EMC_DYN_WR (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x044))
501 #define EMC_DYN_RC (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x048))
502 #define EMC_DYN_RFC (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x04C))
503 #define EMC_DYN_XSR (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x050))
504 #define EMC_DYN_RRD (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x054))
505 #define EMC_DYN_MRD (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x058))
506
507 #define EMC_DYN_CFG0 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x100))
508 #define EMC_DYN_RASCAS0 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x104))
509 #define EMC_DYN_CFG1 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x140))
510 #define EMC_DYN_RASCAS1 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x144))
511 #define EMC_DYN_CFG2 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x160))
512 #define EMC_DYN_RASCAS2 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x164))
513 #define EMC_DYN_CFG3 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x180))
514 #define EMC_DYN_RASCAS3 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x184))
515
516 /* static RAM access registers */
517 #define EMC_STA_BASE_0 ((uint32_t *) (EMC_BASE_ADDR + 0x200))
518 #define EMC_STA_CFG0 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x200))
519 #define EMC_STA_WAITWEN0 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x204))
520 #define EMC_STA_WAITOEN0 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x208))
521 #define EMC_STA_WAITRD0 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x20C))
522 #define EMC_STA_WAITPAGE0 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x210))
523 #define EMC_STA_WAITWR0 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x214))
524 #define EMC_STA_WAITTURN0 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x218))
525
526 #define EMC_STA_BASE_1 ((uint32_t *) (EMC_BASE_ADDR + 0x220))
527 #define EMC_STA_CFG1 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x220))
528 #define EMC_STA_WAITWEN1 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x224))
529 #define EMC_STA_WAITOEN1 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x228))
530 #define EMC_STA_WAITRD1 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x22C))
531 #define EMC_STA_WAITPAGE1 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x230))
532 #define EMC_STA_WAITWR1 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x234))
533 #define EMC_STA_WAITTURN1 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x238))
534
535 #define EMC_STA_BASE_2 ((uint32_t *) (EMC_BASE_ADDR + 0x240))
536 #define EMC_STA_CFG2 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x240))
537 #define EMC_STA_WAITWEN2 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x244))
538 #define EMC_STA_WAITOEN2 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x248))
539 #define EMC_STA_WAITRD2 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x24C))
540 #define EMC_STA_WAITPAGE2 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x250))
541 #define EMC_STA_WAITWR2 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x254))
542 #define EMC_STA_WAITTURN2 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x258))
543
544 #define EMC_STA_BASE_3 ((uint32_t *) (EMC_BASE_ADDR + 0x260))
545 #define EMC_STA_CFG3 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x260))
546 #define EMC_STA_WAITWEN3 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x264))
547 #define EMC_STA_WAITOEN3 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x268))
548 #define EMC_STA_WAITRD3 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x26C))
549 #define EMC_STA_WAITPAGE3 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x270))
550 #define EMC_STA_WAITWR3 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x274))
551 #define EMC_STA_WAITTURN3 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x278))
552
553 #define EMC_STA_EXT_WAIT (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x880))
554
555
556 /* Timer 0 */
557 #ifdef ARM_MULTILIB_ARCH_V4
558  #define TMR0_BASE_ADDR 0xE0004000
559 #else
560  #define TMR0_BASE_ADDR 0x40004000
561 #endif
562 #define T0IR (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x00))
563 #define T0TCR (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x04))
564 #define T0TC (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x08))
565 #define T0PR (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x0C))
566 #define T0PC (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x10))
567 #define T0MCR (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x14))
568 #define T0MR0 (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x18))
569 #define T0MR1 (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x1C))
570 #define T0MR2 (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x20))
571 #define T0MR3 (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x24))
572 #define T0CCR (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x28))
573 #define T0CR0 (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x2C))
574 #define T0CR1 (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x30))
575 #define T0CR2 (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x34))
576 #define T0CR3 (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x38))
577 #define T0EMR (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x3C))
578 #define T0CTCR (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x70))
579
580 /* Timer 1 */
581 #ifdef ARM_MULTILIB_ARCH_V4
582  #define TMR1_BASE_ADDR 0xE0008000
583 #else
584  #define TMR1_BASE_ADDR 0x40008000
585 #endif
586 #define T1IR (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x00))
587 #define T1TCR (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x04))
588 #define T1TC (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x08))
589 #define T1PR (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x0C))
590 #define T1PC (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x10))
591 #define T1MCR (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x14))
592 #define T1MR0 (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x18))
593 #define T1MR1 (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x1C))
594 #define T1MR2 (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x20))
595 #define T1MR3 (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x24))
596 #define T1CCR (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x28))
597 #define T1CR0 (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x2C))
598 #define T1CR1 (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x30))
599 #define T1CR2 (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x34))
600 #define T1CR3 (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x38))
601 #define T1EMR (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x3C))
602 #define T1CTCR (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x70))
603
604 /* Timer 2 */
605 #ifdef ARM_MULTILIB_ARCH_V4
606  #define TMR2_BASE_ADDR 0xE0070000
607 #else
608  #define TMR2_BASE_ADDR 0x40090000
609 #endif
610 #define T2IR (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x00))
611 #define T2TCR (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x04))
612 #define T2TC (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x08))
613 #define T2PR (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x0C))
614 #define T2PC (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x10))
615 #define T2MCR (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x14))
616 #define T2MR0 (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x18))
617 #define T2MR1 (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x1C))
618 #define T2MR2 (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x20))
619 #define T2MR3 (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x24))
620 #define T2CCR (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x28))
621 #define T2CR0 (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x2C))
622 #define T2CR1 (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x30))
623 #define T2CR2 (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x34))
624 #define T2CR3 (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x38))
625 #define T2EMR (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x3C))
626 #define T2CTCR (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x70))
627
628 /* Timer 3 */
629 #ifdef ARM_MULTILIB_ARCH_V4
630  #define TMR3_BASE_ADDR 0xE0074000
631 #else
632  #define TMR3_BASE_ADDR 0x40094000
633 #endif
634 #define T3IR (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x00))
635 #define T3TCR (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x04))
636 #define T3TC (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x08))
637 #define T3PR (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x0C))
638 #define T3PC (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x10))
639 #define T3MCR (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x14))
640 #define T3MR0 (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x18))
641 #define T3MR1 (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x1C))
642 #define T3MR2 (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x20))
643 #define T3MR3 (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x24))
644 #define T3CCR (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x28))
645 #define T3CR0 (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x2C))
646 #define T3CR1 (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x30))
647 #define T3CR2 (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x34))
648 #define T3CR3 (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x38))
649 #define T3EMR (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x3C))
650 #define T3CTCR (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x70))
651
652
653 /* Pulse Width Modulator (PWM) */
654 #ifdef ARM_MULTILIB_ARCH_V4
655  #define PWM0_BASE_ADDR 0xE0014000
656 #else
657  #define PWM0_BASE_ADDR 0x40014000
658 #endif
659 #define PWM0IR (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x00))
660 #define PWM0TCR (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x04))
661 #define PWM0TC (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x08))
662 #define PWM0PR (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x0C))
663 #define PWM0PC (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x10))
664 #define PWM0MCR (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x14))
665 #define PWM0MR0 (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x18))
666 #define PWM0MR1 (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x1C))
667 #define PWM0MR2 (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x20))
668 #define PWM0MR3 (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x24))
669 #define PWM0CCR (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x28))
670 #define PWM0CR0 (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x2C))
671 #define PWM0CR1 (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x30))
672 #define PWM0CR2 (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x34))
673 #define PWM0CR3 (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x38))
674 #define PWM0EMR (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x3C))
675 #define PWM0MR4 (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x40))
676 #define PWM0MR5 (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x44))
677 #define PWM0MR6 (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x48))
678 #define PWM0PCR (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x4C))
679 #define PWM0LER (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x50))
680 #define PWM0CTCR (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x70))
681
682 #ifdef ARM_MULTILIB_ARCH_V4
683  #define PWM1_BASE_ADDR 0xE0018000
684 #else
685  #define PWM1_BASE_ADDR 0x40018000
686 #endif
687 #define PWM1IR (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x00))
688 #define PWM1TCR (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x04))
689 #define PWM1TC (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x08))
690 #define PWM1PR (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x0C))
691 #define PWM1PC (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x10))
692 #define PWM1MCR (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x14))
693 #define PWM1MR0 (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x18))
694 #define PWM1MR1 (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x1C))
695 #define PWM1MR2 (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x20))
696 #define PWM1MR3 (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x24))
697 #define PWM1CCR (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x28))
698 #define PWM1CR0 (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x2C))
699 #define PWM1CR1 (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x30))
700 #define PWM1CR2 (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x34))
701 #define PWM1CR3 (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x38))
702 #define PWM1EMR (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x3C))
703 #define PWM1MR4 (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x40))
704 #define PWM1MR5 (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x44))
705 #define PWM1MR6 (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x48))
706 #define PWM1PCR (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x4C))
707 #define PWM1LER (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x50))
708 #define PWM1CTCR (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x70))
709
710
711 /* Universal Asynchronous Receiver Transmitter 0 (UART0) */
712 #ifdef ARM_MULTILIB_ARCH_V4
713  #define UART0_BASE_ADDR 0xE000C000
714 #else
715  #define UART0_BASE_ADDR 0x4000C000
716 #endif
717 #define U0RBR (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x00))
718 #define U0THR (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x00))
719 #define U0DLL (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x00))
720 #define U0DLM (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x04))
721 #define U0IER (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x04))
722 #define U0IIR (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x08))
723 #define U0FCR (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x08))
724 #define U0LCR (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x0C))
725 #define U0LSR (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x14))
726 #define U0SCR (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x1C))
727 #define U0ACR (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x20))
728 #define U0ICR (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x24))
729 #define U0FDR (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x28))
730 #define U0TER (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x30))
731
732 /* Universal Asynchronous Receiver Transmitter 1 (UART1) */
733 #ifdef ARM_MULTILIB_ARCH_V4
734  #define UART1_BASE_ADDR 0xE0010000
735 #else
736  #define UART1_BASE_ADDR 0x40010000
737 #endif
738 #define U1RBR (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x00))
739 #define U1THR (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x00))
740 #define U1DLL (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x00))
741 #define U1DLM (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x04))
742 #define U1IER (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x04))
743 #define U1IIR (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x08))
744 #define U1FCR (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x08))
745 #define U1LCR (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x0C))
746 #define U1MCR (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x10))
747 #define U1LSR (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x14))
748 #define U1MSR (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x18))
749 #define U1SCR (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x1C))
750 #define U1ACR (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x20))
751 #define U1FDR (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x28))
752 #define U1TER (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x30))
753
754 /* Universal Asynchronous Receiver Transmitter 2 (UART2) */
755 #ifdef ARM_MULTILIB_ARCH_V4
756  #define UART2_BASE_ADDR 0xE0078000
757 #else
758  #define UART2_BASE_ADDR 0x40098000
759 #endif
760 #define U2RBR (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x00))
761 #define U2THR (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x00))
762 #define U2DLL (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x00))
763 #define U2DLM (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x04))
764 #define U2IER (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x04))
765 #define U2IIR (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x08))
766 #define U2FCR (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x08))
767 #define U2LCR (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x0C))
768 #define U2LSR (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x14))
769 #define U2SCR (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x1C))
770 #define U2ACR (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x20))
771 #define U2ICR (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x24))
772 #define U2FDR (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x28))
773 #define U2TER (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x30))
774
775 /* Universal Asynchronous Receiver Transmitter 3 (UART3) */
776 #ifdef ARM_MULTILIB_ARCH_V4
777  #define UART3_BASE_ADDR 0xE007C000
778 #else
779  #define UART3_BASE_ADDR 0x4009C000
780 #endif
781 #define U3RBR (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x00))
782 #define U3THR (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x00))
783 #define U3DLL (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x00))
784 #define U3DLM (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x04))
785 #define U3IER (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x04))
786 #define U3IIR (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x08))
787 #define U3FCR (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x08))
788 #define U3LCR (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x0C))
789 #define U3LSR (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x14))
790 #define U3SCR (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x1C))
791 #define U3ACR (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x20))
792 #define U3ICR (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x24))
793 #define U3FDR (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x28))
794 #define U3TER (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x30))
795
796 /* I2C Interface 0 */
797 #ifdef ARM_MULTILIB_ARCH_V4
798  #define I2C0_BASE_ADDR 0xE001C000
799 #else
800  #define I2C0_BASE_ADDR 0x4001C000
801 #endif
802 #define I20CONSET (*(volatile uint32_t *) (I2C0_BASE_ADDR + 0x00))
803 #define I20STAT (*(volatile uint32_t *) (I2C0_BASE_ADDR + 0x04))
804 #define I20DAT (*(volatile uint32_t *) (I2C0_BASE_ADDR + 0x08))
805 #define I20ADR (*(volatile uint32_t *) (I2C0_BASE_ADDR + 0x0C))
806 #define I20SCLH (*(volatile uint32_t *) (I2C0_BASE_ADDR + 0x10))
807 #define I20SCLL (*(volatile uint32_t *) (I2C0_BASE_ADDR + 0x14))
808 #define I20CONCLR (*(volatile uint32_t *) (I2C0_BASE_ADDR + 0x18))
809
810 /* I2C Interface 1 */
811 #ifdef ARM_MULTILIB_ARCH_V4
812  #define I2C1_BASE_ADDR 0xE005C000
813 #else
814  #define I2C1_BASE_ADDR 0x4005C000
815 #endif
816 #define I21CONSET (*(volatile uint32_t *) (I2C1_BASE_ADDR + 0x00))
817 #define I21STAT (*(volatile uint32_t *) (I2C1_BASE_ADDR + 0x04))
818 #define I21DAT (*(volatile uint32_t *) (I2C1_BASE_ADDR + 0x08))
819 #define I21ADR (*(volatile uint32_t *) (I2C1_BASE_ADDR + 0x0C))
820 #define I21SCLH (*(volatile uint32_t *) (I2C1_BASE_ADDR + 0x10))
821 #define I21SCLL (*(volatile uint32_t *) (I2C1_BASE_ADDR + 0x14))
822 #define I21CONCLR (*(volatile uint32_t *) (I2C1_BASE_ADDR + 0x18))
823
824 /* I2C Interface 2 */
825 #ifdef ARM_MULTILIB_ARCH_V4
826  #define I2C2_BASE_ADDR 0xE0080000
827 #else
828  #define I2C2_BASE_ADDR 0x400a0000
829 #endif
830 #define I22CONSET (*(volatile uint32_t *) (I2C2_BASE_ADDR + 0x00))
831 #define I22STAT (*(volatile uint32_t *) (I2C2_BASE_ADDR + 0x04))
832 #define I22DAT (*(volatile uint32_t *) (I2C2_BASE_ADDR + 0x08))
833 #define I22ADR (*(volatile uint32_t *) (I2C2_BASE_ADDR + 0x0C))
834 #define I22SCLH (*(volatile uint32_t *) (I2C2_BASE_ADDR + 0x10))
835 #define I22SCLL (*(volatile uint32_t *) (I2C2_BASE_ADDR + 0x14))
836 #define I22CONCLR (*(volatile uint32_t *) (I2C2_BASE_ADDR + 0x18))
837
838 /* SPI0 (Serial Peripheral Interface 0) */
839 #define SPI0_BASE_ADDR 0xE0020000
840 #define S0SPCR (*(volatile uint32_t *) (SPI0_BASE_ADDR + 0x00))
841 #define S0SPSR (*(volatile uint32_t *) (SPI0_BASE_ADDR + 0x04))
842 #define S0SPDR (*(volatile uint32_t *) (SPI0_BASE_ADDR + 0x08))
843 #define S0SPCCR (*(volatile uint32_t *) (SPI0_BASE_ADDR + 0x0C))
844 #define S0SPINT (*(volatile uint32_t *) (SPI0_BASE_ADDR + 0x1C))
845
846 /* SSP0 Controller */
847 #ifdef ARM_MULTILIB_ARCH_V4
848  #define SSP0_BASE_ADDR 0xE0068000
849 #else
850  #define SSP0_BASE_ADDR 0x40088000
851 #endif
852 #define SSP0CR0 (*(volatile uint32_t *) (SSP0_BASE_ADDR + 0x00))
853 #define SSP0CR1 (*(volatile uint32_t *) (SSP0_BASE_ADDR + 0x04))
854 #define SSP0DR (*(volatile uint32_t *) (SSP0_BASE_ADDR + 0x08))
855 #define SSP0SR (*(volatile uint32_t *) (SSP0_BASE_ADDR + 0x0C))
856 #define SSP0CPSR (*(volatile uint32_t *) (SSP0_BASE_ADDR + 0x10))
857 #define SSP0IMSC (*(volatile uint32_t *) (SSP0_BASE_ADDR + 0x14))
858 #define SSP0RIS (*(volatile uint32_t *) (SSP0_BASE_ADDR + 0x18))
859 #define SSP0MIS (*(volatile uint32_t *) (SSP0_BASE_ADDR + 0x1C))
860 #define SSP0ICR (*(volatile uint32_t *) (SSP0_BASE_ADDR + 0x20))
861 #define SSP0DMACR (*(volatile uint32_t *) (SSP0_BASE_ADDR + 0x24))
862
863 /* SSP1 Controller */
864 #ifdef ARM_MULTILIB_ARCH_V4
865  #define SSP1_BASE_ADDR 0xE0030000
866 #else
867  #define SSP1_BASE_ADDR 0x40030000
868 #endif
869 #define SSP1CR0 (*(volatile uint32_t *) (SSP1_BASE_ADDR + 0x00))
870 #define SSP1CR1 (*(volatile uint32_t *) (SSP1_BASE_ADDR + 0x04))
871 #define SSP1DR (*(volatile uint32_t *) (SSP1_BASE_ADDR + 0x08))
872 #define SSP1SR (*(volatile uint32_t *) (SSP1_BASE_ADDR + 0x0C))
873 #define SSP1CPSR (*(volatile uint32_t *) (SSP1_BASE_ADDR + 0x10))
874 #define SSP1IMSC (*(volatile uint32_t *) (SSP1_BASE_ADDR + 0x14))
875 #define SSP1RIS (*(volatile uint32_t *) (SSP1_BASE_ADDR + 0x18))
876 #define SSP1MIS (*(volatile uint32_t *) (SSP1_BASE_ADDR + 0x1C))
877 #define SSP1ICR (*(volatile uint32_t *) (SSP1_BASE_ADDR + 0x20))
878 #define SSP1DMACR (*(volatile uint32_t *) (SSP1_BASE_ADDR + 0x24))
879
880 #ifdef ARM_MULTILIB_ARCH_V7M
881
882 /* SSP2 Controller */
883 #define SSP2_BASE_ADDR 0x400ac000
884 #define SSP2CR0 (*(volatile uint32_t *) (SSP2_BASE_ADDR + 0x00))
885 #define SSP2CR1 (*(volatile uint32_t *) (SSP2_BASE_ADDR + 0x04))
886 #define SSP2DR (*(volatile uint32_t *) (SSP2_BASE_ADDR + 0x08))
887 #define SSP2SR (*(volatile uint32_t *) (SSP2_BASE_ADDR + 0x0C))
888 #define SSP2CPSR (*(volatile uint32_t *) (SSP2_BASE_ADDR + 0x10))
889 #define SSP2IMSC (*(volatile uint32_t *) (SSP2_BASE_ADDR + 0x14))
890 #define SSP2RIS (*(volatile uint32_t *) (SSP2_BASE_ADDR + 0x18))
891 #define SSP2MIS (*(volatile uint32_t *) (SSP2_BASE_ADDR + 0x1C))
892 #define SSP2ICR (*(volatile uint32_t *) (SSP2_BASE_ADDR + 0x20))
893 #define SSP2DMACR (*(volatile uint32_t *) (SSP2_BASE_ADDR + 0x24))
894
895 #endif /* ARM_MULTILIB_ARCH_V4 */
896
897 /* Real Time Clock */
898 #ifdef ARM_MULTILIB_ARCH_V4
899  #define RTC_BASE_ADDR 0xE0024000
900 #else
901  #define RTC_BASE_ADDR 0x40024000
902 #endif
903 #define RTC_ILR (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x00))
904 #define RTC_CTC (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x04))
905 #define RTC_CCR (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x08))
906 #define RTC_CIIR (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x0C))
907 #define RTC_AMR (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x10))
908 #define RTC_CTIME0 (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x14))
909 #define RTC_CTIME1 (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x18))
910 #define RTC_CTIME2 (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x1C))
911 #define RTC_SEC (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x20))
912 #define RTC_MIN (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x24))
913 #define RTC_HOUR (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x28))
914 #define RTC_DOM (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x2C))
915 #define RTC_DOW (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x30))
916 #define RTC_DOY (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x34))
917 #define RTC_MONTH (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x38))
918 #define RTC_YEAR (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x3C))
919 #define RTC_CISS (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x40))
920 #define RTC_ALSEC (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x60))
921 #define RTC_ALMIN (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x64))
922 #define RTC_ALHOUR (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x68))
923 #define RTC_ALDOM (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x6C))
924 #define RTC_ALDOW (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x70))
925 #define RTC_ALDOY (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x74))
926 #define RTC_ALMON (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x78))
927 #define RTC_ALYEAR (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x7C))
928 #define RTC_PREINT (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x80))
929 #define RTC_PREFRAC (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x84))
930
931
932 /* A/D Converter 0 (AD0) */
933 #ifdef ARM_MULTILIB_ARCH_V4
934  #define AD0_BASE_ADDR 0xE0034000
935 #else
936  #define AD0_BASE_ADDR 0x40034000
937 #endif
938 #define AD0CR (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x00))
939 #define AD0GDR (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x04))
940 #define AD0INTEN (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x0C))
941 #define AD0_DATA_START ((volatile uint32_t *) (AD0_BASE_ADDR + 0x10))
942 #define AD0DR0 (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x10))
943 #define AD0DR1 (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x14))
944 #define AD0DR2 (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x18))
945 #define AD0DR3 (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x1C))
946 #define AD0DR4 (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x20))
947 #define AD0DR5 (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x24))
948 #define AD0DR6 (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x28))
949 #define AD0DR7 (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x2C))
950 #define AD0STAT (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x30))
951
952
953 /* D/A Converter */
954 #ifdef ARM_MULTILIB_ARCH_V4
955  #define DAC_BASE_ADDR 0xE006C000
956 #else
957  #define DAC_BASE_ADDR 0x4008C000
958 #endif
959 #define DACR (*(volatile uint32_t *) (DAC_BASE_ADDR + 0x00))
960
961
962 /* Watchdog */
963 #ifdef ARM_MULTILIB_ARCH_V4
964  #define WDG_BASE_ADDR 0xE0000000
965 #else
966  #define WDG_BASE_ADDR 0x40000000
967 #endif
968 #define WDMOD (*(volatile uint32_t *) (WDG_BASE_ADDR + 0x00))
969 #define WDTC (*(volatile uint32_t *) (WDG_BASE_ADDR + 0x04))
970 #define WDFEED (*(volatile uint32_t *) (WDG_BASE_ADDR + 0x08))
971 #define WDTV (*(volatile uint32_t *) (WDG_BASE_ADDR + 0x0C))
972 #define WDCLKSEL (*(volatile uint32_t *) (WDG_BASE_ADDR + 0x10))
973
974 /* CAN CONTROLLERS AND ACCEPTANCE FILTER */
975 #ifdef ARM_MULTILIB_ARCH_V4
976  #define CAN_ACCEPT_BASE_ADDR 0xE003C000
977 #else
978  #define CAN_ACCEPT_BASE_ADDR 0x4003C000
979 #endif
980 #define CAN_AFMR (*(volatile uint32_t *) (CAN_ACCEPT_BASE_ADDR + 0x00))
981 #define CAN_SFF_SA (*(volatile uint32_t *) (CAN_ACCEPT_BASE_ADDR + 0x04))
982 #define CAN_SFF_GRP_SA (*(volatile uint32_t *) (CAN_ACCEPT_BASE_ADDR + 0x08))
983 #define CAN_EFF_SA (*(volatile uint32_t *) (CAN_ACCEPT_BASE_ADDR + 0x0C))
984 #define CAN_EFF_GRP_SA (*(volatile uint32_t *) (CAN_ACCEPT_BASE_ADDR + 0x10))
985 #define CAN_EOT (*(volatile uint32_t *) (CAN_ACCEPT_BASE_ADDR + 0x14))
986 #define CAN_LUT_ERR_ADR (*(volatile uint32_t *) (CAN_ACCEPT_BASE_ADDR + 0x18))
987 #define CAN_LUT_ERR (*(volatile uint32_t *) (CAN_ACCEPT_BASE_ADDR + 0x1C))
988
989 #ifdef ARM_MULTILIB_ARCH_V4
990  #define CAN_CENTRAL_BASE_ADDR 0xE0040000
991 #else
992  #define CAN_CENTRAL_BASE_ADDR 0x40040000
993 #endif
994 #define CAN_TX_SR (*(volatile uint32_t *) (CAN_CENTRAL_BASE_ADDR + 0x00))
995 #define CAN_RX_SR (*(volatile uint32_t *) (CAN_CENTRAL_BASE_ADDR + 0x04))
996 #define CAN_MSR (*(volatile uint32_t *) (CAN_CENTRAL_BASE_ADDR + 0x08))
997
998 #ifdef ARM_MULTILIB_ARCH_V4
999  #define CAN1_BASE_ADDR 0xE0044000
1000 #else
1001  #define CAN1_BASE_ADDR 0x40044000
1002 #endif
1003 #define CAN1MOD (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x00))
1004 #define CAN1CMR (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x04))
1005 #define CAN1GSR (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x08))
1006 #define CAN1ICR (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x0C))
1007 #define CAN1IER (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x10))
1008 #define CAN1BTR (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x14))
1009 #define CAN1EWL (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x18))
1010 #define CAN1SR (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x1C))
1011 #define CAN1RFS (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x20))
1012 #define CAN1RID (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x24))
1013 #define CAN1RDA (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x28))
1014 #define CAN1RDB (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x2C))
1015
1016 #define CAN1TFI1 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x30))
1017 #define CAN1TID1 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x34))
1018 #define CAN1TDA1 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x38))
1019 #define CAN1TDB1 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x3C))
1020 #define CAN1TFI2 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x40))
1021 #define CAN1TID2 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x44))
1022 #define CAN1TDA2 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x48))
1023 #define CAN1TDB2 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x4C))
1024 #define CAN1TFI3 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x50))
1025 #define CAN1TID3 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x54))
1026 #define CAN1TDA3 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x58))
1027 #define CAN1TDB3 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x5C))
1028
1029 #ifdef ARM_MULTILIB_ARCH_V4
1030  #define CAN2_BASE_ADDR 0xE0048000
1031 #else
1032  #define CAN2_BASE_ADDR 0x40048000
1033 #endif
1034 #define CAN2MOD (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x00))
1035 #define CAN2CMR (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x04))
1036 #define CAN2GSR (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x08))
1037 #define CAN2ICR (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x0C))
1038 #define CAN2IER (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x10))
1039 #define CAN2BTR (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x14))
1040 #define CAN2EWL (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x18))
1041 #define CAN2SR (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x1C))
1042 #define CAN2RFS (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x20))
1043 #define CAN2RID (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x24))
1044 #define CAN2RDA (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x28))
1045 #define CAN2RDB (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x2C))
1046
1047 #define CAN2TFI1 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x30))
1048 #define CAN2TID1 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x34))
1049 #define CAN2TDA1 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x38))
1050 #define CAN2TDB1 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x3C))
1051 #define CAN2TFI2 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x40))
1052 #define CAN2TID2 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x44))
1053 #define CAN2TDA2 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x48))
1054 #define CAN2TDB2 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x4C))
1055 #define CAN2TFI3 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x50))
1056 #define CAN2TID3 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x54))
1057 #define CAN2TDA3 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x58))
1058 #define CAN2TDB3 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x5C))
1059
1060
1061 /* MultiMedia Card Interface(MCI) Controller */
1062 #ifdef ARM_MULTILIB_ARCH_V4
1063  #define MCI_BASE_ADDR 0xE008C000
1064 #else
1065  #define MCI_BASE_ADDR 0x400c0000
1066 #endif
1067 #define MCI_POWER (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x00))
1068 #define MCI_CLOCK (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x04))
1069 #define MCI_ARGUMENT (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x08))
1070 #define MCI_COMMAND (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x0C))
1071 #define MCI_RESP_CMD (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x10))
1072 #define MCI_RESP0 (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x14))
1073 #define MCI_RESP1 (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x18))
1074 #define MCI_RESP2 (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x1C))
1075 #define MCI_RESP3 (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x20))
1076 #define MCI_DATA_TMR (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x24))
1077 #define MCI_DATA_LEN (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x28))
1078 #define MCI_DATA_CTRL (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x2C))
1079 #define MCI_DATA_CNT (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x30))
1080 #define MCI_STATUS (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x34))
1081 #define MCI_CLEAR (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x38))
1082 #define MCI_MASK0 (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x3C))
1083 #define MCI_MASK1 (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x40))
1084 #define MCI_FIFO_CNT (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x48))
1085 #define MCI_FIFO (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x80))
1086
1087
1088 /* I2S Interface Controller (I2S) */
1089 #ifdef ARM_MULTILIB_ARCH_V4
1090  #define I2S_BASE_ADDR 0xE0088000
1091 #else
1092  #define I2S_BASE_ADDR 0x400a8000
1093 #endif
1094 #define I2S_DAO (*(volatile uint32_t *) (I2S_BASE_ADDR + 0x00))
1095 #define I2S_DAI (*(volatile uint32_t *) (I2S_BASE_ADDR + 0x04))
1096 #define I2S_TX_FIFO (*(volatile uint32_t *) (I2S_BASE_ADDR + 0x08))
1097 #define I2S_RX_FIFO (*(volatile uint32_t *) (I2S_BASE_ADDR + 0x0C))
1098 #define I2S_STATE (*(volatile uint32_t *) (I2S_BASE_ADDR + 0x10))
1099 #define I2S_DMA1 (*(volatile uint32_t *) (I2S_BASE_ADDR + 0x14))
1100 #define I2S_DMA2 (*(volatile uint32_t *) (I2S_BASE_ADDR + 0x18))
1101 #define I2S_IRQ (*(volatile uint32_t *) (I2S_BASE_ADDR + 0x1C))
1102 #define I2S_TXRATE (*(volatile uint32_t *) (I2S_BASE_ADDR + 0x20))
1103 #define I2S_RXRATE (*(volatile uint32_t *) (I2S_BASE_ADDR + 0x24))
1104
1105
1106 /* General-purpose DMA Controller */
1107 #ifdef ARM_MULTILIB_ARCH_V4
1108  #define DMA_BASE_ADDR 0xFFE04000
1109 #else
1110  #define DMA_BASE_ADDR 0x20080000
1111 #endif
1112 #define GPDMA_INT_STAT (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x000))
1113 #define GPDMA_INT_TCSTAT (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x004))
1114 #define GPDMA_INT_TCCLR (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x008))
1115 #define GPDMA_INT_ERR_STAT (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x00C))
1116 #define GPDMA_INT_ERR_CLR (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x010))
1117 #define GPDMA_RAW_INT_TCSTAT (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x014))
1118 #define GPDMA_RAW_INT_ERR_STAT (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x018))
1119 #define GPDMA_ENABLED_CHNS (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x01C))
1120 #define GPDMA_SOFT_BREQ (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x020))
1121 #define GPDMA_SOFT_SREQ (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x024))
1122 #define GPDMA_SOFT_LBREQ (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x028))
1123 #define GPDMA_SOFT_LSREQ (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x02C))
1124 #define GPDMA_CONFIG (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x030))
1125 #define GPDMA_SYNC (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x034))
1126
1127 /* DMA channel 0 registers */
1128 #define GPDMA_CH0_BASE_ADDR (DMA_BASE_ADDR + 0x100)
1129 #define GPDMA_CH0_SRC (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x100))
1130 #define GPDMA_CH0_DEST (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x104))
1131 #define GPDMA_CH0_LLI (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x108))
1132 #define GPDMA_CH0_CTRL (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x10C))
1133 #define GPDMA_CH0_CFG (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x110))
1134
1135 /* DMA channel 1 registers */
1136 #define GPDMA_CH1_BASE_ADDR (DMA_BASE_ADDR + 0x120)
1137 #define GPDMA_CH1_SRC (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x120))
1138 #define GPDMA_CH1_DEST (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x124))
1139 #define GPDMA_CH1_LLI (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x128))
1140 #define GPDMA_CH1_CTRL (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x12C))
1141 #define GPDMA_CH1_CFG (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x130))
1142
1143 /* USB Controller */
1144 #ifdef ARM_MULTILIB_ARCH_V4
1145  #define USB_INT_BASE_ADDR 0xE01FC1C0
1146  #define USB_BASE_ADDR 0xFFE0C200 /* USB Base Address */
1147 #else
1148  #define USB_INT_BASE_ADDR 0x400fc1c0
1149  #define USB_BASE_ADDR 0x2008c200
1150 #endif
1151
1152 #define USB_INT_STAT (*(volatile uint32_t *) (USB_INT_BASE_ADDR + 0x00))
1153
1154 /* USB Device Interrupt Registers */
1155 #define DEV_INT_STAT (*(volatile uint32_t *) (USB_BASE_ADDR + 0x00))
1156 #define DEV_INT_EN (*(volatile uint32_t *) (USB_BASE_ADDR + 0x04))
1157 #define DEV_INT_CLR (*(volatile uint32_t *) (USB_BASE_ADDR + 0x08))
1158 #define DEV_INT_SET (*(volatile uint32_t *) (USB_BASE_ADDR + 0x0C))
1159 #define DEV_INT_PRIO (*(volatile uint32_t *) (USB_BASE_ADDR + 0x2C))
1160
1161 /* USB Device Endpoint Interrupt Registers */
1162 #define EP_INT_STAT (*(volatile uint32_t *) (USB_BASE_ADDR + 0x30))
1163 #define EP_INT_EN (*(volatile uint32_t *) (USB_BASE_ADDR + 0x34))
1164 #define EP_INT_CLR (*(volatile uint32_t *) (USB_BASE_ADDR + 0x38))
1165 #define EP_INT_SET (*(volatile uint32_t *) (USB_BASE_ADDR + 0x3C))
1166 #define EP_INT_PRIO (*(volatile uint32_t *) (USB_BASE_ADDR + 0x40))
1167
1168 /* USB Device Endpoint Realization Registers */
1169 #define REALIZE_EP (*(volatile uint32_t *) (USB_BASE_ADDR + 0x44))
1170 #define EP_INDEX (*(volatile uint32_t *) (USB_BASE_ADDR + 0x48))
1171 #define MAXPACKET_SIZE (*(volatile uint32_t *) (USB_BASE_ADDR + 0x4C))
1172
1173 /* USB Device Command Reagisters */
1174 #define CMD_CODE (*(volatile uint32_t *) (USB_BASE_ADDR + 0x10))
1175 #define CMD_DATA (*(volatile uint32_t *) (USB_BASE_ADDR + 0x14))
1176
1177 /* USB Device Data Transfer Registers */
1178 #define RX_DATA (*(volatile uint32_t *) (USB_BASE_ADDR + 0x18))
1179 #define TX_DATA (*(volatile uint32_t *) (USB_BASE_ADDR + 0x1C))
1180 #define RX_PLENGTH (*(volatile uint32_t *) (USB_BASE_ADDR + 0x20))
1181 #define TX_PLENGTH (*(volatile uint32_t *) (USB_BASE_ADDR + 0x24))
1182 #define USB_CTRL (*(volatile uint32_t *) (USB_BASE_ADDR + 0x28))
1183
1184 /* USB Device DMA Registers */
1185 #define DMA_REQ_STAT (*(volatile uint32_t *) (USB_BASE_ADDR + 0x50))
1186 #define DMA_REQ_CLR (*(volatile uint32_t *) (USB_BASE_ADDR + 0x54))
1187 #define DMA_REQ_SET (*(volatile uint32_t *) (USB_BASE_ADDR + 0x58))
1188 #define UDCA_HEAD (*(volatile uint32_t *) (USB_BASE_ADDR + 0x80))
1189 #define EP_DMA_STAT (*(volatile uint32_t *) (USB_BASE_ADDR + 0x84))
1190 #define EP_DMA_EN (*(volatile uint32_t *) (USB_BASE_ADDR + 0x88))
1191 #define EP_DMA_DIS (*(volatile uint32_t *) (USB_BASE_ADDR + 0x8C))
1192 #define DMA_INT_STAT (*(volatile uint32_t *) (USB_BASE_ADDR + 0x90))
1193 #define DMA_INT_EN (*(volatile uint32_t *) (USB_BASE_ADDR + 0x94))
1194 #define EOT_INT_STAT (*(volatile uint32_t *) (USB_BASE_ADDR + 0xA0))
1195 #define EOT_INT_CLR (*(volatile uint32_t *) (USB_BASE_ADDR + 0xA4))
1196 #define EOT_INT_SET (*(volatile uint32_t *) (USB_BASE_ADDR + 0xA8))
1197 #define NDD_REQ_INT_STAT (*(volatile uint32_t *) (USB_BASE_ADDR + 0xAC))
1198 #define NDD_REQ_INT_CLR (*(volatile uint32_t *) (USB_BASE_ADDR + 0xB0))
1199 #define NDD_REQ_INT_SET (*(volatile uint32_t *) (USB_BASE_ADDR + 0xB4))
1200 #define SYS_ERR_INT_STAT (*(volatile uint32_t *) (USB_BASE_ADDR + 0xB8))
1201 #define SYS_ERR_INT_CLR (*(volatile uint32_t *) (USB_BASE_ADDR + 0xBC))
1202 #define SYS_ERR_INT_SET (*(volatile uint32_t *) (USB_BASE_ADDR + 0xC0))
1203
1204 /* USB Host Controller */
1205 #ifdef ARM_MULTILIB_ARCH_V4
1206  #define USBHC_BASE_ADDR 0xFFE0C000
1207 #else
1208  #define USBHC_BASE_ADDR 0x2008c000
1209 #endif
1210 #define HC_REVISION (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x00))
1211 #define HC_CONTROL (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x04))
1212 #define HC_CMD_STAT (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x08))
1213 #define HC_INT_STAT (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x0C))
1214 #define HC_INT_EN (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x10))
1215 #define HC_INT_DIS (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x14))
1216 #define HC_HCCA (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x18))
1217 #define HC_PERIOD_CUR_ED (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x1C))
1218 #define HC_CTRL_HEAD_ED (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x20))
1219 #define HC_CTRL_CUR_ED (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x24))
1220 #define HC_BULK_HEAD_ED (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x28))
1221 #define HC_BULK_CUR_ED (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x2C))
1222 #define HC_DONE_HEAD (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x30))
1223 #define HC_FM_INTERVAL (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x34))
1224 #define HC_FM_REMAINING (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x38))
1225 #define HC_FM_NUMBER (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x3C))
1226 #define HC_PERIOD_START (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x40))
1227 #define HC_LS_THRHLD (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x44))
1228 #define HC_RH_DESCA (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x48))
1229 #define HC_RH_DESCB (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x4C))
1230 #define HC_RH_STAT (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x50))
1231 #define HC_RH_PORT_STAT1 (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x54))
1232 #define HC_RH_PORT_STAT2 (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x58))
1233
1234 /* USB OTG Controller */
1235 #ifdef ARM_MULTILIB_ARCH_V4
1236  #define USBOTG_BASE_ADDR 0xFFE0C100
1237 #else
1238  #define USBOTG_BASE_ADDR 0x2008c100
1239 #endif
1240 #define OTG_INT_STAT (*(volatile uint32_t *) (USBOTG_BASE_ADDR + 0x00))
1241 #define OTG_INT_EN (*(volatile uint32_t *) (USBOTG_BASE_ADDR + 0x04))
1242 #define OTG_INT_SET (*(volatile uint32_t *) (USBOTG_BASE_ADDR + 0x08))
1243 #define OTG_INT_CLR (*(volatile uint32_t *) (USBOTG_BASE_ADDR + 0x0C))
1244 #define OTG_STAT_CTRL (*(volatile uint32_t *) (USBOTG_BASE_ADDR + 0x10))
1245 #define OTG_TIMER (*(volatile uint32_t *) (USBOTG_BASE_ADDR + 0x14))
1246
1247 #ifdef ARM_MULTILIB_ARCH_V4
1248  #define USBOTG_I2C_BASE_ADDR 0xFFE0C300
1249 #else
1250  #define USBOTG_I2C_BASE_ADDR 0x2008c300
1251 #endif
1252 #define OTG_I2C_RX (*(volatile uint32_t *) (USBOTG_I2C_BASE_ADDR + 0x00))
1253 #define OTG_I2C_TX (*(volatile uint32_t *) (USBOTG_I2C_BASE_ADDR + 0x00))
1254 #define OTG_I2C_STS (*(volatile uint32_t *) (USBOTG_I2C_BASE_ADDR + 0x04))
1255 #define OTG_I2C_CTL (*(volatile uint32_t *) (USBOTG_I2C_BASE_ADDR + 0x08))
1256 #define OTG_I2C_CLKHI (*(volatile uint32_t *) (USBOTG_I2C_BASE_ADDR + 0x0C))
1257 #define OTG_I2C_CLKLO (*(volatile uint32_t *) (USBOTG_I2C_BASE_ADDR + 0x10))
1258
1259 #ifdef ARM_MULTILIB_ARCH_V4
1260  #define USBOTG_CLK_BASE_ADDR 0xFFE0CFF0
1261 #else
1262  #define USBOTG_CLK_BASE_ADDR 0x2008cff0
1263 #endif
1264 #define OTG_CLK_CTRL (*(volatile uint32_t *) (USBOTG_CLK_BASE_ADDR + 0x04))
1265 #define OTG_CLK_STAT (*(volatile uint32_t *) (USBOTG_CLK_BASE_ADDR + 0x08))
1266
1267 /* Ethernet MAC (32 bit data bus) -- all registers are RW unless indicated in parentheses */
1268 #ifdef ARM_MULTILIB_ARCH_V4
1269  #define MAC_BASE_ADDR 0xFFE00000 /* AHB Peripheral # 0 */
1270 #else
1271  #define MAC_BASE_ADDR 0x20084000
1272 #endif
1273 #define MAC_MAC1 (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x000)) /* MAC config reg 1 */
1274 #define MAC_MAC2 (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x004)) /* MAC config reg 2 */
1275 #define MAC_IPGT (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x008)) /* b2b InterPacketGap reg */
1276 #define MAC_IPGR (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x00C)) /* non b2b InterPacketGap reg */
1277 #define MAC_CLRT (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x010)) /* CoLlision window/ReTry reg */
1278 #define MAC_MAXF (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x014)) /* MAXimum Frame reg */
1279 #define MAC_SUPP (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x018)) /* PHY SUPPort reg */
1280 #define MAC_TEST (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x01C)) /* TEST reg */
1281 #define MAC_MCFG (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x020)) /* MII Mgmt ConFiG reg */
1282 #define MAC_MCMD (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x024)) /* MII Mgmt CoMmanD reg */
1283 #define MAC_MADR (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x028)) /* MII Mgmt ADdRess reg */
1284 #define MAC_MWTD (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x02C)) /* MII Mgmt WriTe Data reg (WO) */
1285 #define MAC_MRDD (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x030)) /* MII Mgmt ReaD Data reg (RO) */
1286 #define MAC_MIND (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x034)) /* MII Mgmt INDicators reg (RO) */
1287
1288 #define MAC_SA0 (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x040)) /* Station Address 0 reg */
1289 #define MAC_SA1 (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x044)) /* Station Address 1 reg */
1290 #define MAC_SA2 (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x048)) /* Station Address 2 reg */
1291
1292 #define MAC_COMMAND (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x100)) /* Command reg */
1293 #define MAC_STATUS (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x104)) /* Status reg (RO) */
1294 #define MAC_RXDESCRIPTOR (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x108)) /* Rx descriptor base address reg */
1295 #define MAC_RXSTATUS (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x10C)) /* Rx status base address reg */
1296 #define MAC_RXDESCRIPTORNUM (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x110)) /* Rx number of descriptors reg */
1297 #define MAC_RXPRODUCEINDEX (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x114)) /* Rx produce index reg (RO) */
1298 #define MAC_RXCONSUMEINDEX (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x118)) /* Rx consume index reg */
1299 #define MAC_TXDESCRIPTOR (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x11C)) /* Tx descriptor base address reg */
1300 #define MAC_TXSTATUS (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x120)) /* Tx status base address reg */
1301 #define MAC_TXDESCRIPTORNUM (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x124)) /* Tx number of descriptors reg */
1302 #define MAC_TXPRODUCEINDEX (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x128)) /* Tx produce index reg */
1303 #define MAC_TXCONSUMEINDEX (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x12C)) /* Tx consume index reg (RO) */
1304
1305 #define MAC_TSV0 (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x158)) /* Tx status vector 0 reg (RO) */
1306 #define MAC_TSV1 (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x15C)) /* Tx status vector 1 reg (RO) */
1307 #define MAC_RSV (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x160)) /* Rx status vector reg (RO) */
1308
1309 #define MAC_FLOWCONTROLCNT (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x170)) /* Flow control counter reg */
1310 #define MAC_FLOWCONTROLSTS (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x174)) /* Flow control status reg */
1311
1312 #define MAC_RXFILTERCTRL (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x200)) /* Rx filter ctrl reg */
1313 #define MAC_RXFILTERWOLSTS (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x204)) /* Rx filter WoL status reg (RO) */
1314 #define MAC_RXFILTERWOLCLR (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x208)) /* Rx filter WoL clear reg (WO) */
1315
1316 #define MAC_HASHFILTERL (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x210)) /* Hash filter LSBs reg */
1317 #define MAC_HASHFILTERH (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x214)) /* Hash filter MSBs reg */
1318
1319 #define MAC_INTSTATUS (*(volatile uint32_t *) (MAC_BASE_ADDR + 0xFE0)) /* Interrupt status reg (RO) */
1320 #define MAC_INTENABLE (*(volatile uint32_t *) (MAC_BASE_ADDR + 0xFE4)) /* Interrupt enable reg */
1321 #define MAC_INTCLEAR (*(volatile uint32_t *) (MAC_BASE_ADDR + 0xFE8)) /* Interrupt clear reg (WO) */
1322 #define MAC_INTSET (*(volatile uint32_t *) (MAC_BASE_ADDR + 0xFEC)) /* Interrupt set reg (WO) */
1323
1324 #define MAC_POWERDOWN (*(volatile uint32_t *) (MAC_BASE_ADDR + 0xFF4)) /* Power-down reg */
1325 #define MAC_MODULEID (*(volatile uint32_t *) (MAC_BASE_ADDR + 0xFFC)) /* Module ID reg (RO) */
1326
1327 /* LCD Controller */
1328
1329 #ifdef ARM_MULTILIB_ARCH_V4
1330  #define LCD_CFG (*(volatile uint32_t *) 0xE01FC1B8)
1331  #define LCD_BASE_ADDR 0xFFE10000
1332 #else
1333  #define LCD_CFG (*(volatile uint32_t *) 0x400FC1B8)
1334  #define LCD_BASE_ADDR 0x20088000
1335 #endif
1336 #define LCD_TIMH (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x000))
1337 #define LCD_TIMV (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x004))
1338 #define LCD_POL (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x008))
1339 #define LCD_LE (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x00C))
1340 #define LCD_UPBASE (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x010))
1341 #define LCD_LPBASE (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x014))
1342 #define LCD_CTRL (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x018))
1343 #define LCD_INTMSK (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x01C))
1344 #define LCD_INTRAW (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x020))
1345 #define LCD_INTSTAT (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x024))
1346 #define LCD_INTCLR (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x028))
1347 #define LCD_UPCURR (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x02C))
1348 #define LCD_LPCURR (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x030))
1349 #define LCD_PAL_ADDR (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x200))
1350 #define CRSR_IMG (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x800))
1351 #define CRSR_CTLR (*(volatile uint32_t *) (LCD_BASE_ADDR + 0xC00))
1352 #define CRSR_CFG (*(volatile uint32_t *) (LCD_BASE_ADDR + 0xC04))
1353 #define CRSR_PAL0 (*(volatile uint32_t *) (LCD_BASE_ADDR + 0xC08))
1354 #define CRSR_PAL1 (*(volatile uint32_t *) (LCD_BASE_ADDR + 0xC0C))
1355 #define CRSR_XY (*(volatile uint32_t *) (LCD_BASE_ADDR + 0xC10))
1356 #define CRSR_CLIP (*(volatile uint32_t *) (LCD_BASE_ADDR + 0xC14))
1357 #define CRSR_INTMSK (*(volatile uint32_t *) (LCD_BASE_ADDR + 0xC20))
1358 #define CRSR_INTCLR (*(volatile uint32_t *) (LCD_BASE_ADDR + 0xC24))
1359 #define CRSR_INTRAW (*(volatile uint32_t *) (LCD_BASE_ADDR + 0xC28))
1360 #define CRSR_INTSTAT (*(volatile uint32_t *) (LCD_BASE_ADDR + 0xC2C))
1361
1362 /* Register Fields */
1363
1364 #define GET_FIELD( val, mask, shift) \
1365  (((val) & (mask)) >> (shift))
1366
1367 #define SET_FIELD( val, field, mask, shift) \
1368  (((val) & ~(mask)) | (((field) << (shift)) & (mask)))
1369
1370 /* CLKSRCSEL */
1371
1372 #define CLKSRCSEL_CLKSRC_MASK 0x00000003U
1373
1374 #define GET_CLKSRCSEL_CLKSRC(reg) \
1375  GET_FIELD(reg, CLKSRCSEL_CLKSRC_MASK, 0)
1376
1377 #define SET_CLKSRCSEL_CLKSRC(reg, val) \
1378  SET_FIELD(reg, val, CLKSRCSEL_CLKSRC_MASK, 0)
1379
1380 /* PLLCON */
1381
1382 #define PLLCON_PLLE 0x00000001U
1383
1384 #define PLLCON_PLLC 0x00000002U
1385
1386 /* PLLCFG */
1387
1388 #define PLLCFG_MSEL_MASK 0x00007fffU
1389
1390 #define GET_PLLCFG_MSEL(reg) \
1391  GET_FIELD(reg, PLLCFG_MSEL_MASK, 0)
1392
1393 #define SET_PLLCFG_MSEL(reg, val) \
1394  SET_FIELD(reg, val, PLLCFG_MSEL_MASK, 0)
1395
1396 #define PLLCFG_NSEL_MASK 0x00ff0000U
1397
1398 #define GET_PLLCFG_NSEL(reg) \
1399  GET_FIELD(reg, PLLCFG_NSEL_MASK, 16)
1400
1401 #define SET_PLLCFG_NSEL(reg, val) \
1402  SET_FIELD(reg, val, PLLCFG_NSEL_MASK, 16)
1403
1404 /* PLLSTAT */
1405
1406 #define PLLSTAT_MSEL_MASK 0x00007fffU
1407
1408 #define GET_PLLSTAT_MSEL(reg) \
1409  GET_FIELD(reg, PLLSTAT_MSEL_MASK, 0)
1410
1411 #define SET_PLLSTAT_MSEL(reg, val) \
1412  SET_FIELD(reg, val, PLLSTAT_MSEL_MASK, 0)
1413
1414 #define PLLSTAT_NSEL_MASK 0x00ff0000U
1415
1416 #define GET_PLLSTAT_NSEL(reg) \
1417  GET_FIELD(reg, PLLSTAT_NSEL_MASK, 16)
1418
1419 #define SET_PLLSTAT_NSEL(reg, val) \
1420  SET_FIELD(reg, val, PLLSTAT_NSEL_MASK, 16)
1421
1422 #define PLLSTAT_PLLE 0x01000000U
1423
1424 #define PLLSTAT_PLLC 0x02000000U
1425
1426 #define PLLSTAT_PLOCK 0x04000000U
1427
1428 /* CCLKCFG */
1429
1430 #define CCLKCFG_CCLKSEL_MASK 0x000000ffU
1431
1432 #define GET_CCLKCFG_CCLKSEL(reg) \
1433  GET_FIELD(reg, CCLKCFG_CCLKSEL_MASK, 0)
1434
1435 #define SET_CCLKCFG_CCLKSEL(reg, val) \
1436  SET_FIELD(reg, val, CCLKCFG_CCLKSEL_MASK, 0)
1437
1438 /* MEMMAP */
1439
1440 #define MEMMAP_MAP_MASK 0x00000003U
1441
1442 #define GET_MEMMAP_MAP(reg) \
1443  GET_FIELD(reg, MEMMAP_MAP_MASK, 0)
1444
1445 #define SET_MEMMAP_MAP(reg, val) \
1446  SET_FIELD(reg, val, MEMMAP_MAP_MASK, 0)
1447
1448 /* TIR */
1449
1450 #define TIR_MR0 0x00000001U
1451
1452 #define TIR_MR1 0x00000002U
1453
1454 #define TIR_MR2 0x00000004U
1455
1456 #define TIR_MR3 0x00000008U
1457
1458 #define TIR_CR0 0x00000010U
1459
1460 #define TIR_CR1 0x00000020U
1461
1462 #define TIR_CR2 0x00000040U
1463
1464 #define TIR_CR3 0x00000080U
1465
1466 /* TCR */
1467
1468 #define TCR_EN 0x00000001U
1469
1470 #define TCR_RST 0x00000002U
1471
1472 /* TMCR */
1473
1474 #define TMCR_MR0I 0x00000001U
1475
1476 #define TMCR_MR0R 0x00000002U
1477
1478 #define TMCR_MR0S 0x00000004U
1479
1480 #define TMCR_MR1I 0x00000008U
1481
1482 #define TMCR_MR1R 0x00000010U
1483
1484 #define TMCR_MR1S 0x00000020U
1485
1486 #define TMCR_MR2I 0x00000040U
1487
1488 #define TMCR_MR2R 0x00000080U
1489
1490 #define TMCR_MR2S 0x00000100U
1491
1492 #define TMCR_MR3I 0x00000200U
1493
1494 #define TMCR_MR3R 0x00000400U
1495
1496 #define TMCR_MR3S 0x00000800U
1497
1498 /* PCLKSEL0 */
1499
1500 #define PCLKSEL0_PCLK_WDT_MASK 0x00000003U
1501
1502 #define GET_PCLKSEL0_PCLK_WDT(reg) \
1503  GET_FIELD(reg, PCLKSEL0_PCLK_WDT_MASK, 0)
1504
1505 #define SET_PCLKSEL0_PCLK_WDT(reg, val) \
1506  SET_FIELD(reg, val, PCLKSEL0_PCLK_WDT_MASK, 0)
1507
1508 #define PCLKSEL0_PCLK_TIMER0_MASK 0x0000000cU
1509
1510 #define GET_PCLKSEL0_PCLK_TIMER0(reg) \
1511  GET_FIELD(reg, PCLKSEL0_PCLK_TIMER0_MASK, 2)
1512
1513 #define SET_PCLKSEL0_PCLK_TIMER0(reg, val) \
1514  SET_FIELD(reg, val, PCLKSEL0_PCLK_TIMER0_MASK, 2)
1515
1516 #define PCLKSEL0_PCLK_TIMER1_MASK 0x00000030U
1517
1518 #define GET_PCLKSEL0_PCLK_TIMER1(reg) \
1519  GET_FIELD(reg, PCLKSEL0_PCLK_TIMER1_MASK, 4)
1520
1521 #define SET_PCLKSEL0_PCLK_TIMER1(reg, val) \
1522  SET_FIELD(reg, val, PCLKSEL0_PCLK_TIMER1_MASK, 4)
1523
1524 #define PCLKSEL0_PCLK_UART0_MASK 0x000000c0U
1525
1526 #define GET_PCLKSEL0_PCLK_UART0(reg) \
1527  GET_FIELD(reg, PCLKSEL0_PCLK_UART0_MASK, 6)
1528
1529 #define SET_PCLKSEL0_PCLK_UART0(reg, val) \
1530  SET_FIELD(reg, val, PCLKSEL0_PCLK_UART0_MASK, 6)
1531
1532 #define PCLKSEL0_PCLK_UART1_MASK 0x00000300U
1533
1534 #define GET_PCLKSEL0_PCLK_UART1(reg) \
1535  GET_FIELD(reg, PCLKSEL0_PCLK_UART1_MASK, 8)
1536
1537 #define SET_PCLKSEL0_PCLK_UART1(reg, val) \
1538  SET_FIELD(reg, val, PCLKSEL0_PCLK_UART1_MASK, 8)
1539
1540 #define PCLKSEL0_PCLK_PWM0_MASK 0x00000c00U
1541
1542 #define GET_PCLKSEL0_PCLK_PWM0(reg) \
1543  GET_FIELD(reg, PCLKSEL0_PCLK_PWM0_MASK, 10)
1544
1545 #define SET_PCLKSEL0_PCLK_PWM0(reg, val) \
1546  SET_FIELD(reg, val, PCLKSEL0_PCLK_PWM0_MASK, 10)
1547
1548 #define PCLKSEL0_PCLK_PWM1_MASK 0x00003000U
1549
1550 #define GET_PCLKSEL0_PCLK_PWM1(reg) \
1551  GET_FIELD(reg, PCLKSEL0_PCLK_PWM1_MASK, 12)
1552
1553 #define SET_PCLKSEL0_PCLK_PWM1(reg, val) \
1554  SET_FIELD(reg, val, PCLKSEL0_PCLK_PWM1_MASK, 12)
1555
1556 #define PCLKSEL0_PCLK_I2C0_MASK 0x0000c000U
1557
1558 #define GET_PCLKSEL0_PCLK_I2C0(reg) \
1559  GET_FIELD(reg, PCLKSEL0_PCLK_I2C0_MASK, 14)
1560
1561 #define SET_PCLKSEL0_PCLK_I2C0(reg, val) \
1562  SET_FIELD(reg, val, PCLKSEL0_PCLK_I2C0_MASK, 14)
1563
1564 #define PCLKSEL0_PCLK_SPI_MASK 0x00030000U
1565
1566 #define GET_PCLKSEL0_PCLK_SPI(reg) \
1567  GET_FIELD(reg, PCLKSEL0_PCLK_SPI_MASK, 16)
1568
1569 #define SET_PCLKSEL0_PCLK_SPI(reg, val) \
1570  SET_FIELD(reg, val, PCLKSEL0_PCLK_SPI_MASK, 16)
1571
1572 #define PCLKSEL0_PCLK_RTC_MASK 0x000c0000U
1573
1574 #define GET_PCLKSEL0_PCLK_RTC(reg) \
1575  GET_FIELD(reg, PCLKSEL0_PCLK_RTC_MASK, 18)
1576
1577 #define SET_PCLKSEL0_PCLK_RTC(reg, val) \
1578  SET_FIELD(reg, val, PCLKSEL0_PCLK_RTC_MASK, 18)
1579
1580 #define PCLKSEL0_PCLK_SSP1_MASK 0x00300000U
1581
1582 #define GET_PCLKSEL0_PCLK_SSP1(reg) \
1583  GET_FIELD(reg, PCLKSEL0_PCLK_SSP1_MASK, 20)
1584
1585 #define SET_PCLKSEL0_PCLK_SSP1(reg, val) \
1586  SET_FIELD(reg, val, PCLKSEL0_PCLK_SSP1_MASK, 20)
1587
1588 #define PCLKSEL0_PCLK_DAC_MASK 0x00c00000U
1589
1590 #define GET_PCLKSEL0_PCLK_DAC(reg) \
1591  GET_FIELD(reg, PCLKSEL0_PCLK_DAC_MASK, 22)
1592
1593 #define SET_PCLKSEL0_PCLK_DAC(reg, val) \
1594  SET_FIELD(reg, val, PCLKSEL0_PCLK_DAC_MASK, 22)
1595
1596 #define PCLKSEL0_PCLK_ADC_MASK 0x03000000U
1597
1598 #define GET_PCLKSEL0_PCLK_ADC(reg) \
1599  GET_FIELD(reg, PCLKSEL0_PCLK_ADC_MASK, 24)
1600
1601 #define SET_PCLKSEL0_PCLK_ADC(reg, val) \
1602  SET_FIELD(reg, val, PCLKSEL0_PCLK_ADC_MASK, 24)
1603
1604 #define PCLKSEL0_PCLK_CAN1_MASK 0x0c000000U
1605
1606 #define GET_PCLKSEL0_PCLK_CAN1(reg) \
1607  GET_FIELD(reg, PCLKSEL0_PCLK_CAN1_MASK, 26)
1608
1609 #define SET_PCLKSEL0_PCLK_CAN1(reg, val) \
1610  SET_FIELD(reg, val, PCLKSEL0_PCLK_CAN1_MASK, 26)
1611
1612 #define PCLKSEL0_PCLK_CAN2_MASK 0x30000000U
1613
1614 #define GET_PCLKSEL0_PCLK_CAN2(reg) \
1615  GET_FIELD(reg, PCLKSEL0_PCLK_CAN2_MASK, 28)
1616
1617 #define SET_PCLKSEL0_PCLK_CAN2(reg, val) \
1618  SET_FIELD(reg, val, PCLKSEL0_PCLK_CAN2_MASK, 28)
1619
1620 /* PCLKSEL1 */
1621
1622 #define PCLKSEL1_PCLK_BAT_RAM_MASK 0x00000003U
1623
1624 #define GET_PCLKSEL1_PCLK_BAT_RAM(reg) \
1625  GET_FIELD(reg, PCLKSEL1_PCLK_BAT_RAM_MASK, 0)
1626
1627 #define SET_PCLKSEL1_PCLK_BAT_RAM(reg, val) \
1628  SET_FIELD(reg, val, PCLKSEL1_PCLK_BAT_RAM_MASK, 0)
1629
1630 #define PCLKSEL1_PCLK_GPIO_MASK 0x0000000cU
1631
1632 #define GET_PCLKSEL1_PCLK_GPIO(reg) \
1633  GET_FIELD(reg, PCLKSEL1_PCLK_GPIO_MASK, 2)
1634
1635 #define SET_PCLKSEL1_PCLK_GPIO(reg, val) \
1636  SET_FIELD(reg, val, PCLKSEL1_PCLK_GPIO_MASK, 2)
1637
1638 #define PCLKSEL1_PCLK_PCB_MASK 0x00000030U
1639
1640 #define GET_PCLKSEL1_PCLK_PCB(reg) \
1641  GET_FIELD(reg, PCLKSEL1_PCLK_PCB_MASK, 4)
1642
1643 #define SET_PCLKSEL1_PCLK_PCB(reg, val) \
1644  SET_FIELD(reg, val, PCLKSEL1_PCLK_PCB_MASK, 4)
1645
1646 #define PCLKSEL1_PCLK_I2C1_MASK 0x000000c0U
1647
1648 #define GET_PCLKSEL1_PCLK_I2C1(reg) \
1649  GET_FIELD(reg, PCLKSEL1_PCLK_I2C1_MASK, 6)
1650
1651 #define SET_PCLKSEL1_PCLK_I2C1(reg, val) \
1652  SET_FIELD(reg, val, PCLKSEL1_PCLK_I2C1_MASK, 6)
1653
1654 #define PCLKSEL1_PCLK_SSP0_MASK 0x00000c00U
1655
1656 #define GET_PCLKSEL1_PCLK_SSP0(reg) \
1657  GET_FIELD(reg, PCLKSEL1_PCLK_SSP0_MASK, 10)
1658
1659 #define SET_PCLKSEL1_PCLK_SSP0(reg, val) \
1660  SET_FIELD(reg, val, PCLKSEL1_PCLK_SSP0_MASK, 10)
1661
1662 #define PCLKSEL1_PCLK_TIMER2_MASK 0x00003000U
1663
1664 #define GET_PCLKSEL1_PCLK_TIMER2(reg) \
1665  GET_FIELD(reg, PCLKSEL1_PCLK_TIMER2_MASK, 12)
1666
1667 #define SET_PCLKSEL1_PCLK_TIMER2(reg, val) \
1668  SET_FIELD(reg, val, PCLKSEL1_PCLK_TIMER2_MASK, 12)
1669
1670 #define PCLKSEL1_PCLK_TIMER3_MASK 0x0000c000U
1671
1672 #define GET_PCLKSEL1_PCLK_TIMER3(reg) \
1673  GET_FIELD(reg, PCLKSEL1_PCLK_TIMER3_MASK, 14)
1674
1675 #define SET_PCLKSEL1_PCLK_TIMER3(reg, val) \
1676  SET_FIELD(reg, val, PCLKSEL1_PCLK_TIMER3_MASK, 14)
1677
1678 #define PCLKSEL1_PCLK_UART2_MASK 0x00030000U
1679
1680 #define GET_PCLKSEL1_PCLK_UART2(reg) \
1681  GET_FIELD(reg, PCLKSEL1_PCLK_UART2_MASK, 16)
1682
1683 #define SET_PCLKSEL1_PCLK_UART2(reg, val) \
1684  SET_FIELD(reg, val, PCLKSEL1_PCLK_UART2_MASK, 16)
1685
1686 #define PCLKSEL1_PCLK_UART3_MASK 0x000c0000U
1687
1688 #define GET_PCLKSEL1_PCLK_UART3(reg) \
1689  GET_FIELD(reg, PCLKSEL1_PCLK_UART3_MASK, 18)
1690
1691 #define SET_PCLKSEL1_PCLK_UART3(reg, val) \
1692  SET_FIELD(reg, val, PCLKSEL1_PCLK_UART3_MASK, 18)
1693
1694 #define PCLKSEL1_PCLK_I2C2_MASK 0x00300000U
1695
1696 #define GET_PCLKSEL1_PCLK_I2C2(reg) \
1697  GET_FIELD(reg, PCLKSEL1_PCLK_I2C2_MASK, 20)
1698
1699 #define SET_PCLKSEL1_PCLK_I2C2(reg, val) \
1700  SET_FIELD(reg, val, PCLKSEL1_PCLK_I2C2_MASK, 20)
1701
1702 #define PCLKSEL1_PCLK_I2S_MASK 0x00c00000U
1703
1704 #define GET_PCLKSEL1_PCLK_I2S(reg) \
1705  GET_FIELD(reg, PCLKSEL1_PCLK_I2S_MASK, 22)
1706
1707 #define SET_PCLKSEL1_PCLK_I2S(reg, val) \
1708  SET_FIELD(reg, val, PCLKSEL1_PCLK_I2S_MASK, 22)
1709
1710 #define PCLKSEL1_PCLK_MCI_MASK 0x03000000U
1711
1712 #define GET_PCLKSEL1_PCLK_MCI(reg) \
1713  GET_FIELD(reg, PCLKSEL1_PCLK_MCI_MASK, 24)
1714
1715 #define SET_PCLKSEL1_PCLK_MCI(reg, val) \
1716  SET_FIELD(reg, val, PCLKSEL1_PCLK_MCI_MASK, 24)
1717
1718 #define PCLKSEL1_PCLK_SYSCON_MASK 0x30000000U
1719
1720 #define GET_PCLKSEL1_PCLK_SYSCON(reg) \
1721  GET_FIELD(reg, PCLKSEL1_PCLK_SYSCON_MASK, 28)
1722
1723 #define SET_PCLKSEL1_PCLK_SYSCON(reg, val) \
1724  SET_FIELD(reg, val, PCLKSEL1_PCLK_SYSCON_MASK, 28)
1725
1726 /* RTC_ILR */
1727
1728 #define RTC_ILR_RTCCIF 0x00000001U
1729
1730 #define RTC_ILR_RTCALF 0x00000002U
1731
1732 #define RTC_ILR_RTSSF 0x00000004U
1733
1734 /* RTC_CCR */
1735
1736 #define RTC_CCR_CLKEN 0x00000001U
1737
1738 #define RTC_CCR_CTCRST 0x00000002U
1739
1740 #define RTC_CCR_CLKSRC 0x00000010U
1741
1742 /* SSP */
1743
1744 typedef struct {
1745  uint32_t cr0;
1746  uint32_t cr1;
1747  uint32_t dr;
1748  uint32_t sr;
1749  uint32_t cpsr;
1750  uint32_t imsc;
1751  uint32_t ris;
1752  uint32_t mis;
1753  uint32_t icr;
1754  uint32_t dmacr;
1755 } lpc24xx_ssp;
1756
1757 /* SSP_CR0 */
1758
1759 #define SSP_CR0_DSS_MASK 0x0000000fU
1760
1761 #define GET_SSP_CR0_DSS(reg) \
1762  GET_FIELD(reg, SSP_CR0_DSS_MASK, 0)
1763
1764 #define SET_SSP_CR0_DSS(reg, val) \
1765  SET_FIELD(reg, val, SSP_CR0_DSS_MASK, 0)
1766
1767 #define SSP_CR0_FRF_MASK 0x00000030U
1768
1769 #define GET_SSP_CR0_FRF(reg) \
1770  GET_FIELD(reg, SSP_CR0_FRF_MASK, 4)
1771
1772 #define SET_SSP_CR0_FRF(reg, val) \
1773  SET_FIELD(reg, val, SSP_CR0_FRF_MASK, 4)
1774
1775 #define SSP_CR0_CPOL 0x00000040U
1776
1777 #define SSP_CR0_CPHA 0x00000080U
1778
1779 #define SSP_CR0_SCR_MASK 0x0000ff00U
1780
1781 #define GET_SSP_CR0_SCR(reg) \
1782  GET_FIELD(reg, SSP_CR0_SCR_MASK, 8)
1783
1784 #define SET_SSP_CR0_SCR(reg, val) \
1785  SET_FIELD(reg, val, SSP_CR0_SCR_MASK, 8)
1786
1787 /* SSP_CR1 */
1788
1789 #define SSP_CR1_LBM 0x00000001U
1790
1791 #define SSP_CR1_SSE 0x00000002U
1792
1793 #define SSP_CR1_MS 0x00000004U
1794
1795 #define SSP_CR1_SOD 0x00000008U
1796
1797 /* SSP_SR */
1798
1799 #define SSP_SR_TFE 0x00000001U
1800
1801 #define SSP_SR_TNF 0x00000002U
1802
1803 #define SSP_SR_RNE 0x00000004U
1804
1805 #define SSP_SR_RFF 0x00000008U
1806
1807 #define SSP_SR_BSY 0x00000010U
1808
1809 /* SSP_IMSC */
1810
1811 #define SSP_IMSC_RORIM 0x00000001U
1812
1813 #define SSP_IMSC_RTIM 0x00000002U
1814
1815 #define SSP_IMSC_RXIM 0x00000004U
1816
1817 #define SSP_IMSC_TXIM 0x00000008U
1818
1819 /* SSP_RIS */
1820
1821 #define SSP_RIS_RORRIS 0x00000001U
1822
1823 #define SSP_RIS_RTRIS 0x00000002U
1824
1825 #define SSP_RIS_RXRIS 0x00000004U
1826
1827 #define SSP_RIS_TXRIS 0x00000008U
1828
1829 /* SSP_MIS */
1830
1831 #define SSP_MIS_RORRIS 0x00000001U
1832
1833 #define SSP_MIS_RTRIS 0x00000002U
1834
1835 #define SSP_MIS_RXRIS 0x00000004U
1836
1837 #define SSP_MIS_TXRIS 0x00000008U
1838
1839 /* SSP_ICR */
1840
1841 #define SSP_ICR_RORRIS 0x00000001U
1842
1843 #define SSP_ICR_RTRIS 0x00000002U
1844
1845 #define SSP_ICR_RXRIS 0x00000004U
1846
1847 #define SSP_ICR_TXRIS 0x00000008U
1848
1849 /* SSP_DMACR */
1850
1851 #define SSP_DMACR_RXDMAE 0x00000001U
1852
1853 #define SSP_DMACR_TXDMAE 0x00000002U
1854
1855 /* GPDMA */
1856
1857 typedef struct {
1858  uint32_t src;
1859  uint32_t dest;
1860  uint32_t lli;
1861  uint32_t ctrl;
1863
1864 typedef struct {
1866  uint32_t cfg;
1868
1869 #define GPDMA_CH_NUMBER 2
1870
1871 #define GPDMA_STATUS_CH_0 0x00000001U
1872
1873 #define GPDMA_STATUS_CH_1 0x00000002U
1874
1875 #define GPDMA_CH_BASE_ADDR(i) \
1876  ((volatile lpc24xx_dma_channel *) \
1877  ((i) ? GPDMA_CH1_BASE_ADDR : GPDMA_CH0_BASE_ADDR))
1878
1879 /* GPDMA_CONFIG */
1880
1881 #define GPDMA_CONFIG_EN 0x00000001U
1882
1883 #define GPDMA_CONFIG_MODE 0x00000002U
1884
1885 /* GPDMA_ENABLED_CHNS */
1886
1887 #define GPDMA_ENABLED_CHNS_CH0 0x00000001U
1888
1889 #define GPDMA_ENABLED_CHNS_CH1 0x00000002U
1890
1891 /* GPDMA_CH_CTRL */
1892
1893 #define GPDMA_CH_CTRL_TSZ_MASK 0x00000fffU
1894
1895 #define GET_GPDMA_CH_CTRL_TSZ(reg) \
1896  GET_FIELD(reg, GPDMA_CH_CTRL_TSZ_MASK, 0)
1897
1898 #define SET_GPDMA_CH_CTRL_TSZ(reg, val) \
1899  SET_FIELD(reg, val, GPDMA_CH_CTRL_TSZ_MASK, 0)
1900
1901 #define GPDMA_CH_CTRL_TSZ_MAX 0x00000fffU
1902
1903 #define GPDMA_CH_CTRL_SBSZ_MASK 0x00007000U
1904
1905 #define GET_GPDMA_CH_CTRL_SBSZ(reg) \
1906  GET_FIELD(reg, GPDMA_CH_CTRL_SBSZ_MASK, 12)
1907
1908 #define SET_GPDMA_CH_CTRL_SBSZ(reg, val) \
1909  SET_FIELD(reg, val, GPDMA_CH_CTRL_SBSZ_MASK, 12)
1910
1911 #define GPDMA_CH_CTRL_DBSZ_MASK 0x00038000U
1912
1913 #define GET_GPDMA_CH_CTRL_DBSZ(reg) \
1914  GET_FIELD(reg, GPDMA_CH_CTRL_DBSZ_MASK, 15)
1915
1916 #define SET_GPDMA_CH_CTRL_DBSZ(reg, val) \
1917  SET_FIELD(reg, val, GPDMA_CH_CTRL_DBSZ_MASK, 15)
1918
1919 #define GPDMA_CH_CTRL_BSZ_1 0x00000000U
1920
1921 #define GPDMA_CH_CTRL_BSZ_4 0x00000001U
1922
1923 #define GPDMA_CH_CTRL_BSZ_8 0x00000002U
1924
1925 #define GPDMA_CH_CTRL_BSZ_16 0x00000003U
1926
1927 #define GPDMA_CH_CTRL_BSZ_32 0x00000004U
1928
1929 #define GPDMA_CH_CTRL_BSZ_64 0x00000005U
1930
1931 #define GPDMA_CH_CTRL_BSZ_128 0x00000006U
1932
1933 #define GPDMA_CH_CTRL_BSZ_256 0x00000007U
1934
1935 #define GPDMA_CH_CTRL_SW_MASK 0x001c0000U
1936
1937 #define GET_GPDMA_CH_CTRL_SW(reg) \
1938  GET_FIELD(reg, GPDMA_CH_CTRL_SW_MASK, 18)
1939
1940 #define SET_GPDMA_CH_CTRL_SW(reg, val) \
1941  SET_FIELD(reg, val, GPDMA_CH_CTRL_SW_MASK, 18)
1942
1943 #define GPDMA_CH_CTRL_DW_MASK 0x00e00000U
1944
1945 #define GET_GPDMA_CH_CTRL_DW(reg) \
1946  GET_FIELD(reg, GPDMA_CH_CTRL_DW_MASK, 21)
1947
1948 #define SET_GPDMA_CH_CTRL_DW(reg, val) \
1949  SET_FIELD(reg, val, GPDMA_CH_CTRL_DW_MASK, 21)
1950
1951 #define GPDMA_CH_CTRL_W_8 0x00000000U
1952
1953 #define GPDMA_CH_CTRL_W_16 0x00000001U
1954
1955 #define GPDMA_CH_CTRL_W_32 0x00000002U
1956
1957 #define GPDMA_CH_CTRL_SI 0x04000000U
1958
1959 #define GPDMA_CH_CTRL_DI 0x08000000U
1960
1961 #define GPDMA_CH_CTRL_PROT_MASK 0x70000000U
1962
1963 #define GET_GPDMA_CH_CTRL_PROT(reg) \
1964  GET_FIELD(reg, GPDMA_CH_CTRL_PROT_MASK, 28)
1965
1966 #define SET_GPDMA_CH_CTRL_PROT(reg, val) \
1967  SET_FIELD(reg, val, GPDMA_CH_CTRL_PROT_MASK, 28)
1968
1969 #define GPDMA_CH_CTRL_ITC 0x80000000U
1970
1971 /* GPDMA_CH_CFG */
1972
1973 #define GPDMA_CH_CFG_EN 0x00000001U
1974
1975 #define GPDMA_CH_CFG_SRCPER_MASK 0x0000001eU
1976
1977 #define GET_GPDMA_CH_CFG_SRCPER(reg) \
1978  GET_FIELD(reg, GPDMA_CH_CFG_SRCPER_MASK, 1)
1979
1980 #define SET_GPDMA_CH_CFG_SRCPER(reg, val) \
1981  SET_FIELD(reg, val, GPDMA_CH_CFG_SRCPER_MASK, 1)
1982
1983 #define GPDMA_CH_CFG_DESTPER_MASK 0x000003c0U
1984
1985 #define GET_GPDMA_CH_CFG_DESTPER(reg) \
1986  GET_FIELD(reg, GPDMA_CH_CFG_DESTPER_MASK, 6)
1987
1988 #define SET_GPDMA_CH_CFG_DESTPER(reg, val) \
1989  SET_FIELD(reg, val, GPDMA_CH_CFG_DESTPER_MASK, 6)
1990
1991 #define GPDMA_CH_CFG_PER_SSP0_TX 0x00000000U
1992
1993 #define GPDMA_CH_CFG_PER_SSP0_RX 0x00000001U
1994
1995 #define GPDMA_CH_CFG_PER_SSP1_TX 0x00000002U
1996
1997 #define GPDMA_CH_CFG_PER_SSP1_RX 0x00000003U
1998
1999 #define GPDMA_CH_CFG_PER_SD_MMC 0x00000004U
2000
2001 #define GPDMA_CH_CFG_PER_I2S_CH0 0x00000005U
2002
2003 #define GPDMA_CH_CFG_PER_I2S_CH1 0x00000006U
2004
2005 #define GPDMA_CH_CFG_FLOW_MASK 0x00003800U
2006
2007 #define GET_GPDMA_CH_CFG_FLOW(reg) \
2008  GET_FIELD(reg, GPDMA_CH_CFG_FLOW_MASK, 11)
2009
2010 #define SET_GPDMA_CH_CFG_FLOW(reg, val) \
2011  SET_FIELD(reg, val, GPDMA_CH_CFG_FLOW_MASK, 11)
2012
2013 #define GPDMA_CH_CFG_FLOW_MEM_TO_MEM_DMA 0x00000000U
2014
2015 #define GPDMA_CH_CFG_FLOW_MEM_TO_PER_DMA 0x00000001U
2016
2017 #define GPDMA_CH_CFG_FLOW_PER_TO_MEM_DMA 0x00000002U
2018
2019 #define GPDMA_CH_CFG_FLOW_PER_TO_PER_DMA 0x00000003U
2020
2021 #define GPDMA_CH_CFG_FLOW_PER_TO_PER_DEST 0x00000004U
2022
2023 #define GPDMA_CH_CFG_FLOW_MEM_TO_PER_PER 0x00000005U
2024
2025 #define GPDMA_CH_CFG_FLOW_PER_TO_MEM_PER 0x00000006U
2026
2027 #define GPDMA_CH_CFG_FLOW_PER_TO_PER_SRC 0x00000007U
2028
2029 #define GPDMA_CH_CFG_IE 0x00004000U
2030
2031 #define GPDMA_CH_CFG_ITC 0x00008000U
2032
2033 #define GPDMA_CH_CFG_LOCK 0x00010000U
2034
2035 #define GPDMA_CH_CFG_ACTIVE 0x00020000U
2036
2037 #define GPDMA_CH_CFG_HALT 0x00040000U
2038
2039 /* AHBCFG */
2040
2041 #define AHBCFG_SCHEDULER_UNIFORM 0x00000001U
2042
2043 #define AHBCFG_BREAK_BURST_MASK 0x00000006U
2044
2045 #define GET_AHBCFG_BREAK_BURST(reg) \
2046  GET_FIELD(reg, AHBCFG_BREAK_BURST_MASK, 1)
2047
2048 #define SET_AHBCFG_BREAK_BURST(reg, val) \
2049  SET_FIELD(reg, val, AHBCFG_BREAK_BURST_MASK, 1)
2050
2051 #define AHBCFG_QUANTUM_BUS_CYCLE 0x00000008U
2052
2053 #define AHBCFG_QUANTUM_SIZE_MASK 0x000000f0U
2054
2055 #define GET_AHBCFG_QUANTUM_SIZE(reg) \
2056  GET_FIELD(reg, AHBCFG_QUANTUM_SIZE_MASK, 4)
2057
2058 #define SET_AHBCFG_QUANTUM_SIZE(reg, val) \
2059  SET_FIELD(reg, val, AHBCFG_QUANTUM_SIZE_MASK, 4)
2060
2061 #define AHBCFG_DEFAULT_MASTER_MASK 0x00000700U
2062
2063 #define GET_AHBCFG_DEFAULT_MASTER(reg) \
2064  GET_FIELD(reg, AHBCFG_DEFAULT_MASTER_MASK, 8)
2065
2066 #define SET_AHBCFG_DEFAULT_MASTER(reg, val) \
2067  SET_FIELD(reg, val, AHBCFG_DEFAULT_MASTER_MASK, 8)
2068
2069 #define AHBCFG_EP1_MASK 0x00007000U
2070
2071 #define GET_AHBCFG_EP1(reg) \
2072  GET_FIELD(reg, AHBCFG_EP1_MASK, 12)
2073
2074 #define SET_AHBCFG_EP1(reg, val) \
2075  SET_FIELD(reg, val, AHBCFG_EP1_MASK, 12)
2076
2077 #define AHBCFG_EP2_MASK 0x00070000U
2078
2079 #define GET_AHBCFG_EP2(reg) \
2080  GET_FIELD(reg, AHBCFG_EP2_MASK, 16)
2081
2082 #define SET_AHBCFG_EP2(reg, val) \
2083  SET_FIELD(reg, val, AHBCFG_EP2_MASK, 16)
2084
2085 #define AHBCFG_EP3_MASK 0x00700000U
2086
2087 #define GET_AHBCFG_EP3(reg) \
2088  GET_FIELD(reg, AHBCFG_EP3_MASK, 20)
2089
2090 #define SET_AHBCFG_EP3(reg, val) \
2091  SET_FIELD(reg, val, AHBCFG_EP3_MASK, 20)
2092
2093 #define AHBCFG_EP4_MASK 0x07000000U
2094
2095 #define GET_AHBCFG_EP4(reg) \
2096  GET_FIELD(reg, AHBCFG_EP4_MASK, 24)
2097
2098 #define SET_AHBCFG_EP4(reg, val) \
2099  SET_FIELD(reg, val, AHBCFG_EP4_MASK, 24)
2100
2101 #define AHBCFG_EP5_MASK 0x70000000U
2102
2103 #define GET_AHBCFG_EP5(reg) \
2104  GET_FIELD(reg, AHBCFG_EP5_MASK, 28)
2105
2106 #define SET_AHBCFG_EP5(reg, val) \
2107  SET_FIELD(reg, val, AHBCFG_EP5_MASK, 28)
2108
2109 /* I2C */
2110
2111 typedef struct {
2112  uint32_t conset;
2113  uint32_t stat;
2114  uint32_t dat;
2115  uint32_t adr;
2116  uint32_t sclh;
2117  uint32_t scll;
2118  uint32_t conclr;
2119 } lpc24xx_i2c;
2120
2121 #define LPC24XX_I2C_AA (1U << 2U)
2122
2123 #define LPC24XX_I2C_SI (1U << 3U)
2124
2125 #define LPC24XX_I2C_STO (1U << 4U)
2126
2127 #define LPC24XX_I2C_STA (1U << 5U)
2128
2129 #define LPC24XX_I2C_EN (1U << 6U)
2130
2131 /* IO */
2132
2133 #ifdef ARM_MULTILIB_ARCH_V4
2134  #define LPC24XX_PINSEL ((volatile uint32_t *) &PINSEL0)
2135  #define LPC24XX_PINMODE ((volatile uint32_t *) &PINMODE0)
2136 #else
2137  #define IOCON_FUNC(val) BSP_FLD32(val, 0, 2)
2138  #define IOCON_FUNC_GET(reg) BSP_FLD32GET(reg, 0, 2)
2139  #define IOCON_FUNC_SET(reg, val) BSP_FLD32SET(reg, val, 0, 2)
2140  #define IOCON_MODE(val) BSP_FLD32(val, 3, 4)
2141  #define IOCON_MODE_GET(reg) BSP_FLD32GET(reg, 3, 4)
2142  #define IOCON_MODE_SET(reg, val) BSP_FLD32SET(reg, val, 3, 4)
2143  #define IOCON_HYS BSP_BIT32(5)
2144  #define IOCON_INV BSP_BIT32(6)
2145  #define IOCON_ADMODE BSP_BIT32(7)
2146  #define IOCON_FILTER BSP_BIT32(8)
2147  #define IOCON_HS BSP_BIT32(8)
2148  #define IOCON_SLEW BSP_BIT32(9)
2149  #define IOCON_HIDRIVE BSP_BIT32(9)
2150  #define IOCON_OD BSP_BIT32(10)
2151  #define IOCON_DACEN BSP_BIT32(16)
2152  #define LPC17XX_IOCON ((volatile uint32_t *) PINSEL_BASE_ADDR)
2153 #endif
2154
2155 typedef struct {
2156  uint32_t dir;
2157  uint32_t reserved [3];
2158  uint32_t mask;
2159  uint32_t pin;
2160  uint32_t set;
2161  uint32_t clr;
2162 } lpc24xx_fio;
2163
2164 #define LPC24XX_FIO ((volatile lpc24xx_fio *) FIO_BASE_ADDR)
2165
2166 #ifdef ARM_MULTILIB_ARCH_V4
2167
2168 /* PCONP */
2169
2170 #define PCONP_GPDMA (1U << 29)
2171 #define PCONP_ETHERNET (1U << 30)
2172 #define PCONP_USB (1U << 31)
2173
2174 #endif /* ARM_MULTILIB_ARCH_V4 */
2175
2176 /* I2S */
2177
2178 static volatile lpc_i2s *const lpc24xx_i2s = (lpc_i2s *) I2S_BASE_ADDR;
2179
2180 /* ADC */
2181
2182 #define ADC_CR_SEL(val) BSP_FLD32(val, 0, 7)
2183 #define ADC_CR_SEL_GET(val) BSP_FLD32GET(val, 0, 7)
2184 #define ADC_CR_SEL_SET(reg, val) BSP_FLD32SET(reg, val, 0, 7)
2185 #define ADC_CR_CLKDIV(val) BSP_FLD32(val, 8, 15)
2186 #define ADC_CR_CLKDIV_GET(reg) BSP_FLD32GET(reg, 8, 15)
2187 #define ADC_CR_CLKDIV_SET(reg, val) BSP_FLD32SET(reg, val, 8, 15)
2188 #define ADC_CR_BURST BSP_BIT32(16)
2189 #define ADC_CR_CLKS(val) BSP_FLD32(val, 17, 19)
2190 #define ADC_CR_PDN BSP_BIT32(21)
2191 #define ADC_CR_START(val) BSP_FLD32(val, 24, 26)
2192 #define ADC_CR_EDGE BSP_BIT32(27)
2193
2194 #define ADC_DR_VALUE(reg) BSP_FLD32GET(reg, 6, 15)
2195 #define ADC_DR_OVERRUN BSP_BIT32(30)
2196 #define ADC_DR_DONE BSP_BIT32(31)
2197
2198 /* DAC */
2199
2200 #define DAC_STEPS 1024
2201 #define DAC_VALUE(val) BSP_FLD32(val, 6, 15)
2202 #define DAC_BIAS BSP_BIT32(16)
2203
2206 #endif /* LIBBSP_ARM_LPC24XX_LPC24XX_H */
Definition: lpc24xx.h:2155
Definition: lpc24xx.h:1744
I2S control block.
Definition: lpc-i2s.h:46
Register definitions.
Utility macros.
Definition: lpc24xx.h:1864
I2S API.
Definition: lpc24xx.h:2111
Definition: lpc24xx.h:1857
