RTEMS  5.1
lpc-ethernet-config.h
1
9 /*
10  * Copyright (c) 2009-2012 embedded brains GmbH. All rights reserved.
11  *
12  * embedded brains GmbH
13  * Obere Lagerstr. 30
14  * 82178 Puchheim
15  * Germany
16  * <rtems@embedded-brains.de>
17  *
18  * The license and distribution terms for this file may be
19  * found in the file LICENSE in this distribution or at
20  * http://www.rtems.org/license/LICENSE.
21  */
22
23 #ifndef LIBBSP_ARM_LPC24XX_LPC_ETHERNET_CONFIG_H
24 #define LIBBSP_ARM_LPC24XX_LPC_ETHERNET_CONFIG_H
25
26 #include <bsp.h>
27 #include <bsp/io.h>
28 #include <bsp/lpc24xx.h>
29
30 #include <limits.h>
31
32 #ifdef __cplusplus
33 extern "C" {
34 #endif /* __cplusplus */
35
36 #define LPC_ETH_CONFIG_INTERRUPT LPC24XX_IRQ_ETHERNET
37
38 #define LPC_ETH_CONFIG_REG_BASE MAC_BASE_ADDR
39
40 #ifdef ARM_MULTILIB_ARCH_V4
41  #define LPC_ETH_CONFIG_RX_UNIT_COUNT_DEFAULT 16
42  #define LPC_ETH_CONFIG_RX_UNIT_COUNT_MAX 54
43
44  #define LPC_ETH_CONFIG_TX_UNIT_COUNT_DEFAULT 10
45  #define LPC_ETH_CONFIG_TX_UNIT_COUNT_MAX 10
46
47  #define LPC_ETH_CONFIG_UNIT_MULTIPLE 1U
48
49  #define LPC24XX_ETH_RAM_BEGIN 0x7fe00000U
50  #define LPC24XX_ETH_RAM_SIZE (16U * 1024U)
51 #else
52  #define LPC_ETH_CONFIG_RX_UNIT_COUNT_DEFAULT 16
53  #define LPC_ETH_CONFIG_RX_UNIT_COUNT_MAX INT_MAX
54
55  #define LPC_ETH_CONFIG_TX_UNIT_COUNT_DEFAULT 32
56  #define LPC_ETH_CONFIG_TX_UNIT_COUNT_MAX INT_MAX
57
58  #define LPC_ETH_CONFIG_UNIT_MULTIPLE 8U
59
60  #define LPC_ETH_CONFIG_USE_TRANSMIT_DMA
61
62  #define LPC24XX_ETH_RAM_BEGIN 0x20000000U
63  #define LPC24XX_ETH_RAM_SIZE (32U * 1024U)
64 #endif
65
66 #ifdef LPC24XX_ETHERNET_RMII
67  #define LPC_ETH_CONFIG_RMII
68
69  static void lpc_eth_config_module_enable(void)
70  {
71  static const lpc24xx_pin_range pins [] = {
72  #ifdef LPC24XX_PIN_ETHERNET_POWER_DOWN
73  LPC24XX_PIN_ETHERNET_POWER_DOWN,
74  #endif
75  LPC24XX_PIN_ETHERNET_RMII_0,
76  LPC24XX_PIN_ETHERNET_RMII_1,
77  LPC24XX_PIN_ETHERNET_RMII_2,
78  LPC24XX_PIN_ETHERNET_RMII_3,
79  LPC24XX_PIN_TERMINAL
80  };
81
82  lpc24xx_module_enable(LPC24XX_MODULE_ETHERNET, LPC24XX_MODULE_PCLK_DEFAULT);
84
85  #ifdef LPC24XX_PIN_ETHERNET_POWER_DOWN
86  {
87  unsigned pin = lpc24xx_pin_get_first_index(&pins[0]);
88
89  lpc24xx_gpio_config(pin, LPC24XX_GPIO_OUTPUT);
90  lpc24xx_gpio_set(pin);
91  }
92  #endif
93  }
94 #else
95  static void lpc_eth_config_module_enable(void)
96  {
97  static const lpc24xx_pin_range pins [] = {
98  LPC24XX_PIN_ETHERNET_MII,
99  LPC24XX_PIN_TERMINAL
100  };
101
102  lpc24xx_module_enable(LPC24XX_MODULE_ETHERNET, LPC24XX_MODULE_PCLK_DEFAULT);
104  }
105 #endif
106
107 static void lpc_eth_config_module_disable(void)
108 {
109  lpc24xx_module_disable(LPC24XX_MODULE_ETHERNET);
110 }
111
112 static char *lpc_eth_config_alloc_table_area(size_t size)
113 {
114  if (size < LPC24XX_ETH_RAM_SIZE) {
115  return (char *) LPC24XX_ETH_RAM_BEGIN;
116  } else {
117  return NULL;
118  }
119 }
120
121 static void lpc_eth_config_free_table_area(char *table_area)
122 {
123  /* Do nothing */
124 }
125
126 #ifdef __cplusplus
127 }
128 #endif /* __cplusplus */
129
130 #endif /* LIBBSP_ARM_LPC24XX_LPC_ETHERNET_CONFIG_H */
Register definitions.
Definition: io.h:224
Sets the pin function.
Definition: io.h:206
rtems_status_code lpc24xx_pin_config(const lpc24xx_pin_range *pins, lpc24xx_pin_action action)
Performs the action with the pins.
Definition: io.c:517
unsigned size
Definition: tte.h:74
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
