RTEMS  5.1
vectors.h
1 /*
2  * vectors.h Exception frame related contant and API.
3  *
4  * This include file describe the data structure and the functions implemented
5  * by rtems to handle exceptions.
6  *
7  *
8  * MPC5xx port sponsored by Defence Research and Development Canada - Suffield
9  * Copyright (C) 2004, Real-Time Systems Inc. (querbach@realtime.bc.ca)
10  *
11  * Derived from libbsp/powerpc/mbx8xx/vectors/vectors.h:
12  *
13  * CopyRight (C) 1999 valette@crf.canon.fr
14  *
15  * The license and distribution terms for this file may be
16  * found in the file LICENSE in this distribution or at
17  * http://www.rtems.org/license/LICENSE.
18  */
19 #ifndef _LIBCPU_VECTORS_H
20 #define _LIBCPU_VECTORS_H
21
22 #include <bsp/vectors.h>
23
24 /*
25  * Size of hardware vector table.
26  */
27 #define NUM_EXCEPTIONS 0x20
28
29 #ifndef ASM
30
31 /*
32  * default raw exception handlers
33  */
34
35 extern void default_exception_vector_code_prolog(void);
36 extern int default_exception_vector_code_prolog_size;
37 extern void initialize_exceptions(void);
38
39 typedef void rtems_exception_handler_t (CPU_Exception_frame* excPtr);
40
41 /*
42  * Exception handler table.
43  *
44  * This table contains pointers to assembly-language exception handlers.
45  * The common exception prologue in vectors.S looks up an entry in this
46  * table and jumps to it. No return address is saved, so the handlers in
47  * this table must return directly to the interrupted code.
48  *
49  * On entry to an exception handler, R1 points to a new exception stack
50  * frame in which R3, R4, and LR have been saved. R4 holds the exception
51  * number.
52  */
53 extern rtems_exception_handler_t* exception_handler_table[NUM_EXCEPTIONS];
54
55 #endif /* ASM */
56
57 #endif /* _LIBCPU_VECTORS_H */
PowerPC Exceptions API.
The set of registers that specifies the complete processor state.
Definition: cpu.h:629
