RTEMS  5.1
leon2_amba_bus.h
1 /* LEON2 Hardcoded bus driver interface.
2  *
3  * COPYRIGHT (c) 2008.
4  * Cobham Gaisler AB.
5  *
6  * Bus driver for a hardcoded setup. LEON2 systems have some
7  * cores always present, here called "Standard Cores". In
8  * addtion to the standard cores there are often extra cores
9  * that can be defined using the "Custom Cores" mechanism.
10  *
11  * A Core is described by assigning a base register and
12  * IRQ0..IRQ15 using the leon2_core structure.
13  *
14  * The license and distribution terms for this file may be
15  * found in the file LICENSE in this distribution or at
16  * http://www.rtems.org/license/LICENSE.
17  */
18
19 #ifndef __LEON2_AMBA_BUS_H__
20 #define __LEON2_AMBA_BUS_H__
21
22 /*** Cores location and IRQs hardcoded ***/
23
24 #include <drvmgr/drvmgr.h>
25 #include <grlib/ambapp.h>
26
27 #ifdef __cplusplus
28 extern "C" {
29 #endif
30
31 /* LEON2 AMBA Driver ID generation */
32 #define DRIVER_LEON2_AMBA(id) DRIVER_ID(DRVMGR_BUS_TYPE_LEON2_AMBA, id)
33
34 /* LEON2 Cores (any unique 48-bit number will do) */
35 #define LEON2_AMBA_NONE_ID 0
36 #define LEON2_AMBA_TIMER_ID 1
37 #define LEON2_AMBA_UART_ID 2
38 #define LEON2_AMBA_GPIO_ID 3
39 #define LEON2_AMBA_IRQCTRL_ID 4
40
41 #define LEON2_AMBA_AT697PCI_ID 100
42 #define LEON2_AMBA_AMBAPP_ID 0xfff0
43
44 /* LEON2 driver IDs */
45 #define DRIVER_LEON2_AMBA_TIMER DRIVER_LEON2_AMBA(LEON2_AMBA_TIMER_ID)
46 #define DRIVER_LEON2_AMBA_UART DRIVER_LEON2_AMBA(LEON2_AMBA_UART_ID)
47 #define DRIVER_LEON2_AMBA_AT697PCI DRIVER_LEON2_AMBA(LEON2_AMBA_AT697PCI_ID)
48 #define DRIVER_LEON2_AMBA_AMBAPP DRIVER_LEON2_AMBA(LEON2_AMBA_AMBAPP_ID)
49
51  unsigned short core_id;
52 };
53
54 #define EMPTY_LEON2_CORE {{LEON2_AMBA_NONE_ID}, NULL, NULL}
55 struct leon2_core {
56  struct leon2_amba_dev_id id; /* Core ID */
57  char *name; /* Name of Core */
58  struct drvmgr_key *keys; /* Core setup (location, IRQs) */
59 };
60
61 struct leon2_bus {
62  struct leon2_core *std_cores; /* The LEON2 standard cores */
63  struct leon2_core *custom_cores; /* Custom cores on the same bus */
64  struct drvmgr_map_entry *maps_up; /* Memory map ip-stream */
65  struct drvmgr_map_entry *maps_down; /* Memory map down-stream */
66 };
67
68 extern struct leon2_core leon2_std_cores[];
69
70 /* Data structure drivers can access */
72  unsigned short core_id; /* Core ID */
73  unsigned int reg_base; /* Register base */
74  char irqs[16]; /* 16 irqs */
75 };
76
78  struct drvmgr_drv general; /* General bus info */
79  /* AMBA specific bus information */
80  struct leon2_amba_dev_id *ids; /* Supported hardware */
81 };
82
83 /* Initialize LEON2 bus with a configuration
84  * bus_config - What cores, their location and irqs
85  * resources - Driver configuration for the cores specified bus_config
86  */
87 int leon2_root_register(
88  struct leon2_bus *bus_config,
89  struct drvmgr_bus_res *resources);
90
91 #ifdef __cplusplus
92 }
93 #endif
94
95 #endif
Definition: leon2_amba_bus.h:77
Definition: drvmgr.h:198
Definition: drvmgr.h:214
Definition: drvmgr.h:225
Definition: leon2_amba_bus.h:55
Definition: leon2_amba_bus.h:71
Definition: leon2_amba_bus.h:61
Definition: leon2_amba_bus.h:50
Definition: drvmgr.h:305
