RTEMS  5.1
lcd.h
1
9 /*
10  * Copyright (c) 2010-2012 embedded brains GmbH. All rights reserved.
11  *
12  * embedded brains GmbH
13  * Obere Lagerstr. 30
14  * 82178 Puchheim
15  * Germany
16  * <rtems@embedded-brains.de>
17  *
18  * The license and distribution terms for this file may be
19  * found in the file LICENSE in this distribution or at
20  * http://www.rtems.org/license/LICENSE.
21  */
22
23 #ifndef LIBBSP_ARM_LPC24XX_LCD_H
24 #define LIBBSP_ARM_LPC24XX_LCD_H
25
26 #include <rtems.h>
27
28 #include <bsp/io.h>
29
30 #ifdef __cplusplus
31 extern "C" {
32 #endif
33
44 typedef enum {
45  #ifdef ARM_MULTILIB_ARCH_V4
46  LCD_MODE_STN_4_BIT = 0,
47  LCD_MODE_STN_8_BIT,
48  LCD_MODE_STN_DUAL_PANEL_4_BIT,
49  LCD_MODE_STN_DUAL_PANEL_8_BIT,
50  LCD_MODE_TFT_12_BIT_4_4_4,
51  LCD_MODE_TFT_16_BIT_5_6_5,
52  LCD_MODE_TFT_16_BIT_1_5_5_5,
53  LCD_MODE_TFT_24_BIT,
54  LCD_MODE_DISABLED
55  #else
56  LCD_MODE_STN_4_BIT = 0x4,
57  LCD_MODE_STN_8_BIT = 0x6,
58  LCD_MODE_STN_DUAL_PANEL_4_BIT = 0x84,
59  LCD_MODE_STN_DUAL_PANEL_8_BIT = 0x86,
60  LCD_MODE_TFT_12_BIT_4_4_4 = 0x2e,
61  LCD_MODE_TFT_16_BIT_5_6_5 = 0x2c,
62  LCD_MODE_TFT_16_BIT_1_5_5_5 = 0x28,
63  LCD_MODE_TFT_24_BIT = 0x2a,
64  LCD_MODE_DISABLED = 0xff
65  #endif
66 } lpc24xx_lcd_mode;
67
79  lpc24xx_lcd_mode mode,
80  const lpc24xx_pin_range *pins
81 );
82
83 lpc24xx_lcd_mode lpc24xx_lcd_current_mode(void);
84
87 #ifdef __cplusplus
88 }
89 #endif /* __cplusplus */
90
91 #endif /* LIBBSP_ARM_LPC24XX_LCD_H */
Definition: io.h:224
rtems_status_code
Classic API Status.
Definition: status.h:43
rtems_status_code lpc24xx_lcd_set_mode(lpc24xx_lcd_mode mode, const lpc24xx_pin_range *pins)
Set the LCD mode.
Definition: lcd.c:35
