RTEMS  5.1
irq-generic.h File Reference
Generic BSP interrupt support API. More...
#include <stdbool.h>
#include <rtems/irq-extension.h>
#include <bsp/irq.h>
struct  bsp_interrupt_handler_entry
#define BSP_INTERRUPT_VECTOR_NUMBER   (BSP_INTERRUPT_VECTOR_MAX - BSP_INTERRUPT_VECTOR_MIN + 1)
#define BSP_INTERRUPT_HANDLER_TABLE_SIZE   BSP_INTERRUPT_VECTOR_NUMBER
#define bsp_interrupt_disable(level)   rtems_interrupt_disable(level)
#define bsp_interrupt_enable(level)   rtems_interrupt_enable(level)
#define bsp_interrupt_fence(order)   do { } while (0)
#define bsp_interrupt_assert(e)   _Assert(e)
typedef struct bsp_interrupt_handler_entry bsp_interrupt_handler_entry
void bsp_interrupt_handler_default (rtems_vector_number vector)
 Default interrupt handler. More...
void bsp_interrupt_initialize (void)
 Initialize BSP interrupt support. More...
rtems_status_code bsp_interrupt_facility_initialize (void)
 BSP specific initialization. More...
void bsp_interrupt_vector_enable (rtems_vector_number vector)
 Enables the interrupt vector with number vector. More...
void bsp_interrupt_vector_disable (rtems_vector_number vector)
 Disables the interrupt vector with number vector. More...
bool bsp_interrupt_handler_is_empty (rtems_vector_number vector)
 Is interrupt handler empty. More...
void bsp_interrupt_lock (void)
void bsp_interrupt_unlock (void)
bsp_interrupt_handler_entry bsp_interrupt_handler_table []
