RTEMS  5.1
inittask.h
1 /* SPDX-License-Identifier: BSD-2-Clause */
2
14 /*
15  * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
16  *
17  * Redistribution and use in source and binary forms, with or without
18  * modification, are permitted provided that the following conditions
19  * are met:
20  * 1. Redistributions of source code must retain the above copyright
21  * notice, this list of conditions and the following disclaimer.
22  * 2. Redistributions in binary form must reproduce the above copyright
23  * notice, this list of conditions and the following disclaimer in the
24  * documentation and/or other materials provided with the distribution.
25  *
26  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
27  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
28  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
29  * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
30  * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
31  * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
32  * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
33  * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
34  * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
35  * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
36  * POSSIBILITY OF SUCH DAMAGE.
37  */
38
39 #ifndef _RTEMS_CONFDEFS_INITTASK_H
40 #define _RTEMS_CONFDEFS_INITTASK_H
41
42 #ifndef __CONFIGURATION_TEMPLATE_h
43 #error "Do not include this file directly, use <rtems/confdefs.h> instead"
44 #endif
45
46 #ifdef CONFIGURE_INIT
47
48 #ifdef CONFIGURE_RTEMS_INIT_TASKS_TABLE
49
50 #include <rtems/confdefs/percpu.h>
51 #include <rtems/rtems/object.h>
52 #include <rtems/rtems/tasksdata.h>
53 #include <rtems/sysinit.h>
54
55 #ifndef CONFIGURE_INIT_TASK_ATTRIBUTES
56  #define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_DEFAULT_ATTRIBUTES
57 #endif
58
59 #ifndef CONFIGURE_INIT_TASK_INITIAL_MODES
60  #ifdef RTEMS_SMP
61  #define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_DEFAULT_MODES
62  #else
63  #define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_NO_PREEMPT
64  #endif
65 #endif
66
67 #ifndef CONFIGURE_INIT_TASK_NAME
68  #define CONFIGURE_INIT_TASK_NAME rtems_build_name( 'U', 'I', '1', ' ' )
69 #endif
70
71 #ifndef CONFIGURE_INIT_TASK_PRIORITY
72  #define CONFIGURE_INIT_TASK_PRIORITY 1
73 #endif
74
75 #ifndef CONFIGURE_INIT_TASK_STACK_SIZE
76  #define CONFIGURE_INIT_TASK_STACK_SIZE CONFIGURE_MINIMUM_TASK_STACK_SIZE
77 #endif
78
79 #if CONFIGURE_INIT_TASK_STACK_SIZE > CONFIGURE_MINIMUM_TASK_STACK_SIZE
80  #define _CONFIGURE_INIT_TASK_STACK_EXTRA \
81  ( CONFIGURE_INIT_TASK_STACK_SIZE - CONFIGURE_MINIMUM_TASK_STACK_SIZE )
82 #endif
83
84 #ifdef __cplusplus
85 extern "C" {
86 #endif
87
88 #ifndef CONFIGURE_INIT_TASK_ENTRY_POINT
90  #define CONFIGURE_INIT_TASK_ENTRY_POINT Init
91
92  #ifndef CONFIGURE_INIT_TASK_ARGUMENTS
93  extern const char *bsp_boot_cmdline;
94  #define CONFIGURE_INIT_TASK_ARGUMENTS \
95  ( (rtems_task_argument) &bsp_boot_cmdline )
96  #endif
97 #endif
98
99 #ifndef CONFIGURE_INIT_TASK_ARGUMENTS
100  #define CONFIGURE_INIT_TASK_ARGUMENTS 0
101 #endif
102
104  CONFIGURE_INIT_TASK_NAME,
105  CONFIGURE_INIT_TASK_STACK_SIZE,
106  CONFIGURE_INIT_TASK_PRIORITY,
107  CONFIGURE_INIT_TASK_ATTRIBUTES,
108  CONFIGURE_INIT_TASK_ENTRY_POINT,
109  CONFIGURE_INIT_TASK_INITIAL_MODES,
110  CONFIGURE_INIT_TASK_ARGUMENTS
111 };
112
113 RTEMS_SYSINIT_ITEM(
115  RTEMS_SYSINIT_CLASSIC_USER_TASKS,
116  RTEMS_SYSINIT_ORDER_MIDDLE
117 );
118
119 #ifdef __cplusplus
120 }
121 #endif
122
123 #endif /* CONFIGURE_RTEMS_INIT_TASKS_TABLE */
124
125 #ifndef _CONFIGURE_INIT_TASK_STACK_EXTRA
126  #define _CONFIGURE_INIT_TASK_STACK_EXTRA 0
127 #endif
128
129 #endif /* CONFIGURE_INIT */
130
131 #endif /* _RTEMS_CONFDEFS_INITTASK_H */
const char * bsp_boot_cmdline
Global pointer to the command line of boot_card().
Definition: bootcard.c:25
void _RTEMS_tasks_Initialize_user_task(void)
System initialization handler to create and start the first user task.
Definition: taskinitusers.c:27
void rtems_task
Definition: tasks.h:101
Evaluate Per-CPU Configuration Options.
CPU_Uint32ptr rtems_task_argument
Definition: tasks.h:106
Definition: tasks.h:121
const rtems_initialization_tasks_table _RTEMS_tasks_User_task_table
Initialization table for the first user task.
Definition: taskinitdefault.c:34
Classic Tasks Manager Data Structures.
