RTEMS  5.1
if_mve_pub.h
1 #ifndef RTEMS_BSDNET_IF_MVE_PUBLIC_SYMBOLS_H
2 #define RTEMS_BSDNET_IF_MVE_PUBLIC_SYMBOLS_H
3
4 /*
5  * Authorship
6  * ----------
7  * This software ('beatnik' RTEMS BSP for MVME6100 and MVME5500) was
8  * created by Till Straumann <strauman@slac.stanford.edu>, 2005-2007,
9  * Stanford Linear Accelerator Center, Stanford University.
10  *
11  * Acknowledgement of sponsorship
12  * ------------------------------
13  * The 'beatnik' BSP was produced by
14  * the Stanford Linear Accelerator Center, Stanford University,
15  * under Contract DE-AC03-76SFO0515 with the Department of Energy.
16  *
17  * Government disclaimer of liability
18  * ----------------------------------
19  * Neither the United States nor the United States Department of Energy,
20  * nor any of their employees, makes any warranty, express or implied, or
21  * assumes any legal liability or responsibility for the accuracy,
22  * completeness, or usefulness of any data, apparatus, product, or process
23  * disclosed, or represents that its use would not infringe privately owned
24  * rights.
25  *
26  * Stanford disclaimer of liability
27  * --------------------------------
28  * Stanford University makes no representations or warranties, express or
29  * implied, nor assumes any liability for the use of this software.
30  *
31  * Stanford disclaimer of copyright
32  * --------------------------------
33  * Stanford University, owner of the copyright, hereby disclaims its
34  * copyright and all other rights in this software. Hence, anyone may
35  * freely use it for any purpose without restriction.
36  *
37  * Maintenance of notices
38  * ----------------------
39  * In the interest of clarity regarding the origin and status of this
40  * SLAC software, this and all the preceding Stanford University notices
41  * are to remain affixed to any copy or derivative of this software made
42  * or distributed by the recipient and are to be affixed to any copy of
43  * software made or distributed by the recipient that contains a copy or
44  * derivative of this software.
45  *
46  * ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
47  */
48 #include <rtems.h>
49 #include <rtems/rtems_bsdnet.h>
50 #include <bsp/early_enet_link_status.h>
51 #include <stdint.h>
52
53 #ifdef __cplusplus
54  extern "C" {
55 #endif
56
57 extern int rtems_mve_attach(struct rtems_bsdnet_ifconfig *, int);
58 extern rtems_bsdnet_early_link_check_ops rtems_mve_early_link_check_ops;
59
60 /* Low-level Driver API.
61  * This provides driver access to applications that want to use e.g., the second
62  * ethernet interface w/o running the BSD TCP/IP stack.
63  */
64
65 /* Opaque handle */
66 struct mveth_private;
67
68 /* Direct assignment of MVE flags to user API relies on irqs and x-irqs not overlapping */
69 #define BSP_MVE_IRQ_RX (1<<2)
70 #define BSP_MVE_IRQ_TX (1<<0)
71 #define BSP_MVE_IRQ_LINK (1<<16)
72
73 /* Setup an interface.
74  * Allocates resources for descriptor rings and sets up the driver software structure.
75  *
76  * Arguments:
77  * unit:
78  * interface # (1..2). The interface must not be attached to BSD.
79  *
80  * driver_tid:
81  * ISR posts RTEMS event # ('unit' - 1) to task with ID 'driver_tid' and disables interrupts
82  * from this interface.
83  *
84  * void (*cleanup_txbuf)(void *user_buf, void *cleanup_txbuf_arg, int error_on_tx_occurred):
85  * Pointer to user-supplied callback to release a buffer that had been sent
86  * by BSP_mve_send_buf() earlier. The callback is passed 'cleanup_txbuf_arg'
87  * and a flag indicating whether the send had been successful.
88  * The driver no longer accesses 'user_buf' after invoking this callback.
89  * CONTEXT: This callback is executed either by BSP_mve_swipe_tx() or
90  * BSP_mve_send_buf(), BSP_mve_init_hw(), BSP_mve_stop_hw() (the latter
91  * ones calling BSP_mve_swipe_tx()).
92  * void *cleanup_txbuf_arg:
93  * Closure argument that is passed on to 'cleanup_txbuf()' callback;
94  *
95  * void *(*alloc_rxbuf)(int *p_size, unsigned long *p_data_addr),
96  * Pointer to user-supplied callback to allocate a buffer for subsequent
97  * insertion into the RX ring by the driver.
98  * RETURNS: opaque handle to the buffer (which may be a more complex object
99  * such as an 'mbuf'). The handle is not used by the driver directly
100  * but passed back to the 'consume_rxbuf()' callback.
101  * Size of the available data area and pointer to buffer's data area
102  * in '*psize' and '*p_data_area', respectively.
103  * If no buffer is available, this routine should return NULL in which
104  * case the driver drops the last packet and re-uses the last buffer
105  * instead of handing it out to 'consume_rxbuf()'.
106  * CONTEXT: Called when initializing the RX ring (BSP_mve_init_hw()) or when
107  * swiping it (BSP_mve_swipe_rx()).
108  *
109  *
110  * void (*consume_rxbuf)(void *user_buf, void *consume_rxbuf_arg, int len);
111  * Pointer to user-supplied callback to pass a received buffer back to
112  * the user. The driver no longer accesses the buffer after invoking this
113  * callback (with 'len'>0, see below). 'user_buf' is the buffer handle
114  * previously generated by 'alloc_rxbuf()'.
115  * The callback is passed 'cleanup_rxbuf_arg' and a 'len'
116  * argument giving the number of bytes that were received.
117  * 'len' may be <=0 in which case the 'user_buf' argument is NULL.
118  * 'len' == 0 means that the last 'alloc_rxbuf()' had failed,
119  * 'len' < 0 indicates a receiver error. In both cases, the last packet
120  * was dropped/missed and the last buffer will be re-used by the driver.
121  * NOTE: the data are 'prefixed' with two bytes, i.e., the ethernet packet header
122  * is stored at offset 2 in the buffer's data area. Also, the FCS (4 bytes)
123  * is appended. 'len' accounts for both.
124  * CONTEXT: Called from BSP_mve_swipe_rx().
125  * void *cleanup_rxbuf_arg:
126  * Closure argument that is passed on to 'consume_rxbuf()' callback;
127  *
128  * rx_ring_size, tx_ring_size:
129  * How many big to make the RX and TX descriptor rings. Note that the sizes
130  * may be 0 in which case a reasonable default will be used.
131  * If either ring size is < 0 then the RX or TX will be disabled.
132  * Note that it is illegal in this case to use BSP_mve_swipe_rx() or
133  * BSP_mve_swipe_tx(), respectively.
134  *
135  * irq_mask:
136  * Interrupts to enable. OR of flags from above.
137  *
138  */
139 struct mveth_private *
140 BSP_mve_setup(
141  int unit,
142  rtems_id driver_tid,
143  void (*cleanup_txbuf)(void *user_buf, void *cleanup_txbuf_arg, int error_on_tx_occurred),
144  void *cleanup_txbuf_arg,
145  void *(*alloc_rxbuf)(int *p_size, uintptr_t *p_data_addr),
146  void (*consume_rxbuf)(void *user_buf, void *consume_rxbuf_arg, int len),
147  void *consume_rxbuf_arg,
148  int rx_ring_size,
149  int tx_ring_size,
150  int irq_mask
151 );
152
153 /*
154  * Alternate 'setup' routine allowing the user to install an ISR rather
155  * than a task ID.
156  * All parameters (other than 'isr' / 'isr_arg') and the return value
157  * are identical to the BSP_mve_setup() entry point.
158  */
159 struct mveth_private *
160 BSP_mve_setup_1(
161  int unit,
162  void (*isr)(void *isr_arg),
163  void *isr_arg,
164  void (*cleanup_txbuf)(void *user_buf, void *cleanup_txbuf_arg, int error_on_tx_occurred),
165  void *cleanup_txbuf_arg,
166  void *(*alloc_rxbuf)(int *p_size, uintptr_t *p_data_addr),
167  void (*consume_rxbuf)(void *user_buf, void *consume_rxbuf_arg, int len),
168  void *consume_rxbuf_arg,
169  int rx_ring_size,
170  int tx_ring_size,
171  int irq_mask
172 );
173
174
175 /*
176  * Initialize interface hardware
177  *
178  * 'mp' handle obtained by from BSP_mve_setup().
179  * 'promisc' whether to set promiscuous flag.
180  * 'enaddr' pointer to six bytes with MAC address. Read
181  * from the device if NULL.
182  *
183  * Note: Multicast filters are cleared by this routine.
184  * However, in promiscuous mode the mcast filters
185  * are programmed to accept all multicast frames.
186  */
187 void
188 BSP_mve_init_hw(struct mveth_private *mp, int promisc, unsigned char *enaddr);
189
190 /*
191  * Clear multicast hash filter. No multicast frames are accepted
192  * after executing this routine (unless the hardware was initialized
193  * in 'promiscuous' mode).
194  */
195 void
196 BSP_mve_mcast_filter_clear(struct mveth_private *mp);
197
198 /*
199  * Program multicast filter to accept all multicast frames
200  */
201 void
202 BSP_mve_mcast_filter_accept_all(struct mveth_private *mp);
203
204 /*
205  * Add a MAC address to the multicast filter.
206  * Existing entries are not changed but note that
207  * the filter is imperfect, i.e., multiple MAC addresses
208  * may alias to a single filter entry. Hence software
209  * filtering must still be performed.
210  *
211  * If a higher-level driver implements IP multicasting
212  * then multiple IP addresses may alias to the same MAC
213  * address. This driver maintains a 'reference-count'
214  * which is incremented every time the same MAC-address
215  * is passed to this routine; the address is only removed
216  * from the filter if BSP_mve_mcast_filter_accept_del()
217  * is called the same number of times (or by BSP_mve_mcast_filter_clear).
218  */
219 void
220 BSP_mve_mcast_filter_accept_add(struct mveth_private *mp, unsigned char *enaddr);
221
222 /*
223  * Remove a MAC address from the multicast filter.
224  * This routine decrements the reference count of the given
225  * MAC-address and removes it from the filter once the
226  * count reaches zero.
227  */
228 void
229 BSP_mve_mcast_filter_accept_del(struct mveth_private *mp, unsigned char *enaddr);
230
231 /*
232  * Shutdown hardware and clean out the rings
233  */
234 void
235 BSP_mve_stop_hw(struct mveth_private *mp);
236
237 /* calls BSP_mve_stop_hw(), releases all resources and marks the interface
238  * as unused.
239  * RETURNS 0 on success, nonzero on failure.
240  * NOTE: the handle MUST NOT be used after successful execution of this
241  * routine.
242  */
243 int
244 BSP_mve_detach(struct mveth_private *mp);
245
246 int
247 BSP_mve_send_buf_raw(struct mveth_private *mp, void *head_p, int h_len,
248  void *data_p, int d_len);
249
250 /*
251  * Enqueue a mbuf chain or a raw data buffer for transmission;
252  * RETURN: #bytes sent or -1 if there are not enough free descriptors
253  *
254  * If 'len' is <=0 then 'm_head' is assumed to point to a mbuf chain.
255  * OTOH, a raw data packet (or a different type of buffer)
256  * may be send (non-BSD driver) by pointing data_p to the start of
257  * the data and passing 'len' > 0.
258  * 'm_head' is passed back to the 'cleanup_txbuf()' callback.
259  *
260  * Comments: software cache-flushing incurs a penalty if the
261  * packet cannot be queued since it is flushed anyways.
262  * The algorithm is slightly more efficient in the normal
263  * case, though.
264  *
265  * RETURNS: # bytes enqueued to device for transmission or -1 if no
266  * space in the TX ring was available.
267  */
268 int
269 BSP_mve_send_buf(struct mveth_private *mp, void *m_head, void *data_p, int len);
270
271 /* Descriptor scavenger; cleanup the TX ring, passing all buffers
272  * that have been sent to the cleanup_tx() callback.
273  * This routine is called from BSP_mve_send_buf(), BSP_mve_init_hw(),
274  * BSP_mve_stop_hw().
275  *
276  * RETURNS: number of buffers processed.
277  */
278 int
279 BSP_mve_swipe_tx(struct mveth_private *mp);
280
281 /* Retrieve all received buffers from the RX ring, replacing them
282  * by fresh ones (obtained from the alloc_rxbuf() callback). The
283  * received buffers are passed to consume_rxbuf().
284  *
285  * RETURNS: number of buffers processed.
286  */
287 int
288 BSP_mve_swipe_rx(struct mveth_private *mp);
289
290 /* read ethernet address from hw to buffer */
291 void
292 BSP_mve_read_eaddr(struct mveth_private *mp, unsigned char *eaddr);
293
294 /* read/write media word.
295  * 'cmd': can be SIOCGIFMEDIA, SIOCSIFMEDIA, 0 or 1. The latter
296  * are aliased to the former for convenience.
297  * 'parg': pointer to media word.
298  *
299  * RETURNS: 0 on success, nonzero on error
300  *
301  * NOTE: This routine is thread-safe.
302  */
303 int
304 BSP_mve_media_ioctl(struct mveth_private *mp, int cmd, int *parg);
305
306 /* Interrupt related routines */
307
308 /* Note: the BSP_mve_enable/disable/ack_irqs() entry points
309  * are deprecated.
310  * The newer API where the user passes a mask allows
311  * for more selective control.
312  */
313
314 /* Enable all supported interrupts at device */
315 void
316 BSP_mve_enable_irqs(struct mveth_private *mp);
317
318 /* Disable all supported interrupts at device */
319 void
320 BSP_mve_disable_irqs(struct mveth_private *mp);
321
322 /* Acknowledge (and clear) all supported interrupts.
323  * RETURNS: interrupts that were raised.
324  */
325 uint32_t
326 BSP_mve_ack_irqs(struct mveth_private *mp);
327
328 /* Enable interrupts included in 'mask' (leaving
329  * already enabled interrupts on). If the mask
330  * includes bits that were not passed to the 'setup'
331  * routine then the behavior is undefined.
332  */
333 void
334 BSP_mve_enable_irq_mask(struct mveth_private *mp, uint32_t irq_mask);
335
336 /* Disable interrupts included in 'mask' (leaving
337  * other ones that are currently enabled on). If the
338  * mask includes bits that were not passed to the 'setup'
339  * routine then the behavior is undefined.
340  *
341  * RETURNS: Bitmask of interrupts that were enabled upon entry
342  * into this routine. This can be used to restore the
343  * previous state.
344  */
345 uint32_t
346 BSP_mve_disable_irq_mask(struct mveth_private *mp, uint32_t irq_mask);
347
348 /* Acknowledge and clear selected interrupts.
349  *
350  * RETURNS: All pending interrupts.
351  *
352  * NOTE: Only pending interrupts contained in 'mask'
353  * are cleared. Others are left pending.
354  *
355  * This routine can be used to check for pending
356  * interrupts (pass mask == 0) or to clear all
357  * interrupts (pass mask == -1).
358  */
359 uint32_t
360 BSP_mve_ack_irq_mask(struct mveth_private *mp, uint32_t mask);
361
362 /* If the PHY link status changes then some
363  * internal settings in the ethernet controller's
364  * serial port need to be updated to match the
365  * PHY settings. Use this routine to perform the
366  * necessary steps after a link change has been
367  * detected.
368  *
369  * RETURNS: 0 on success, -1 if the PHY state
370  * could not be determined.
371  *
372  * The current state of the media as read
373  * by BSP_mve_media_ioctl() is returned in
374  * *pmedia.
375  *
376  * NOTE: This routine calls BSP_mve_media_ioctl().
377  */
378 int
379 BSP_mve_ack_link_chg(struct mveth_private *mp, int *pmedia);
380
381 /* Retrieve the driver daemon TID that was passed to
382  * BSP_mve_setup().
383  */
384
385 rtems_id
386 BSP_mve_get_tid(struct mveth_private *mp);
387
388 /* Dump statistics to file (stdout if NULL)
389  *
390  * NOTE: this routine is not thread safe
391  */
392 void
393 BSP_mve_dump_stats(struct mveth_private *mp, FILE *f);
394
395 /*
396  *
397  * Example driver task loop (note: no synchronization of
398  * buffer access shown!).
399  * RTEMS_EVENTx = 0,1 or 2 depending on IF unit.
400  *
401  * / * setup (obtain handle) and initialize hw here * /
402  *
403  * do {
404  * / * ISR disables IRQs and posts event * /
405  * rtems_event_receive( RTEMS_EVENTx, RTEMS_WAIT | RTEMS_EVENT_ANY, RTEMS_NO_TIMEOUT, &evs );
406  * irqs = BSP_mve_ack_irqs(handle);
407  * if ( irqs & BSP_MVE_IRQ_TX ) {
408  * BSP_mve_swipe_tx(handle); / * cleanup_txbuf() callback executed * /
409  * }
410  * if ( irqs & BSP_MVE_IRQ_RX ) {
411  * BSP_mve_swipe_rx(handle); / * alloc_rxbuf() and consume_rxbuf() executed * /
412  * }
413  * if ( irqs & BSP_MVE_IRQ_LINK ) {
414  * / * update serial port settings from current link status * /
415  * BSP_mve_ack_link_chg(handle, 0);
416  * }
417  * BSP_mve_enable_irqs(handle);
418  * } while (1);
419  *
420  */
421
422 #ifdef __cplusplus
423  }
424 #endif
425
426 #endif
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
