RTEMS  5.1
idt.h
1 /*
2  * Copyright (c) 2018.
3  * Amaan Cheval <amaan.cheval@gmail.com>
4  *
5  * Redistribution and use in source and binary forms, with or without
6  * modification, are permitted provided that the following conditions
7  * are met:
8  * 1. Redistributions of source code must retain the above copyright
9  * notice, this list of conditions and the following disclaimer.
10  * 2. Redistributions in binary form must reproduce the above copyright
11  * notice, this list of conditions and the following disclaimer in the
12  * documentation and/or other materials provided with the distribution.
13  *
14  * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
15  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
16  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
17  * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
18  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
19  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
20  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
21  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
22  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
23  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
24  * SUCH DAMAGE.
25  */
26
27 #ifndef _RTEMS_SCORE_IDT_H
28 #define _RTEMS_SCORE_IDT_H
29
30 #include <rtems/score/basedefs.h>
31 #include <rtems/rtems/intr.h>
32
33 #ifdef __cplusplus
34 extern "C" {
35 #endif
36
37 #define IDT_INTERRUPT_GATE (0b1110)
38 #define IDT_PRESENT (0b10000000)
39
40 /*
41  * XXX: The IDT size should be smaller given that we likely won't map all 256
42  * vectors, but for simplicity, this works better.
43  */
44 #define IDT_SIZE 256
45
46 /* Target vector number for spurious IRQs */
47 #define BSP_VECTOR_SPURIOUS 0xFF
48 /* Target vector number for the APIC timer */
49 #define BSP_VECTOR_APIC_TIMER 32
50
51 typedef struct _interrupt_descriptor {
52  uint16_t offset_0; // bits 0-15
53  uint16_t segment_selector; // a segment selector in the GDT or LDT
54  /* bits 0-2 are the offset into the IST, stored in the TSS */
55  uint8_t interrupt_stack_table;
56  uint8_t type_and_attributes;
57  uint16_t offset_1; // bits 16-31
58  uint32_t offset_2; // bits 32-63
59  uint32_t reserved_zero;
61
62 extern interrupt_descriptor amd64_idt[IDT_SIZE];
63
64 struct idt_record {
65  uint16_t limit; /* Size of IDT array - 1 */
66  uintptr_t base; /* Pointer to IDT array */
67 } RTEMS_PACKED;
68
69 RTEMS_STATIC_ASSERT(
70  sizeof(struct idt_record) == 10,
71  "IDT pointer must be exactly 10 bytes"
72 );
73
74 void lidt(struct idt_record *idtr);
75
76 interrupt_descriptor amd64_create_interrupt_descriptor(
77  uintptr_t handler, uint8_t types_and_attributes
78 );
79
80 uintptr_t amd64_get_handler_from_idt(uint32_t vector);
81
82 void amd64_install_raw_interrupt(
83  uint32_t vector, uintptr_t new_handler, uintptr_t *old_handler
84 );
85
86 /*
87  * Called by _ISR_Handler to dispatch "RTEMS interrupts", i.e. call the
88  * registered RTEMS ISR.
89  */
90 void amd64_dispatch_isr(rtems_vector_number vector);
91
92 /* Defined in isr_handler.S */
93 extern void rtems_irq_prologue_0(void);
94 extern void rtems_irq_prologue_1(void);
95 extern void rtems_irq_prologue_2(void);
96 extern void rtems_irq_prologue_3(void);
97 extern void rtems_irq_prologue_4(void);
98 extern void rtems_irq_prologue_5(void);
99 extern void rtems_irq_prologue_6(void);
100 extern void rtems_irq_prologue_7(void);
101 extern void rtems_irq_prologue_8(void);
102 extern void rtems_irq_prologue_9(void);
103 extern void rtems_irq_prologue_10(void);
104 extern void rtems_irq_prologue_11(void);
105 extern void rtems_irq_prologue_12(void);
106 extern void rtems_irq_prologue_13(void);
107 extern void rtems_irq_prologue_14(void);
108 extern void rtems_irq_prologue_15(void);
109 extern void rtems_irq_prologue_16(void);
110 extern void rtems_irq_prologue_17(void);
111 extern void rtems_irq_prologue_18(void);
112 extern void rtems_irq_prologue_19(void);
113 extern void rtems_irq_prologue_20(void);
114 extern void rtems_irq_prologue_21(void);
115 extern void rtems_irq_prologue_22(void);
116 extern void rtems_irq_prologue_23(void);
117 extern void rtems_irq_prologue_24(void);
118 extern void rtems_irq_prologue_25(void);
119 extern void rtems_irq_prologue_26(void);
120 extern void rtems_irq_prologue_27(void);
121 extern void rtems_irq_prologue_28(void);
122 extern void rtems_irq_prologue_29(void);
123 extern void rtems_irq_prologue_30(void);
124 extern void rtems_irq_prologue_31(void);
125 extern void rtems_irq_prologue_32(void);
126
127 #ifdef __cplusplus
128 }
129 #endif
130
131 #endif
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
#define RTEMS_PACKED
Definition: basedefs.h:187
Definition: idt.h:64
Definition: idt.h:51
Basic Definitions.
