RTEMS  5.1
ide_ctrl_io.h
1 /*
2  * ide_ctrl_io.h
3  *
4  * LibChip library IDE controller header file - IO operations defined for
5  * IDE controllers.
6  *
7  * Copyright (C) 2002 OKTET Ltd., St.-Petersburg, Russia
8  * Author: Eugeny S. Mints <Eugeny.Mints@oktet.ru>
9  *
10  * The license and distribution terms for this file may be
11  * found in the file LICENSE in this distribution or at
12  * http://www.rtems.org/license/LICENSE.
13  */
14 #ifndef __IDE_CTRL_IO_H__
15 #define __IDE_CTRL_IO_H__
16
17 #ifdef __cplusplus
18 extern "C" {
19 #endif
20
21 #include <rtems/blkdev.h>
22
23 /* Command Block Registers */
24 #define IDE_REGISTER_DATA 0
25 #define IDE_REGISTER_ERROR 1
26 #define IDE_REGISTER_FEATURES IDE_REGISTER_ERROR
27 #define IDE_REGISTER_SECTOR_COUNT 2
28 #define IDE_REGISTER_SECTOR_NUMBER 3
29 #define IDE_REGISTER_LBA0 IDE_REGISTER_SECTOR_NUMBER
30 #define IDE_REGISTER_CYLINDER_LOW 4
31 #define IDE_REGISTER_LBA1 IDE_REGISTER_CYLINDER_LOW
32 #define IDE_REGISTER_CYLINDER_HIGH 5
33 #define IDE_REGISTER_LBA2 IDE_REGISTER_CYLINDER_HIGH
34 #define IDE_REGISTER_DEVICE_HEAD 6
35 #define IDE_REGISTER_LBA3 IDE_REGISTER_DEVICE_HEAD
36 #define IDE_REGISTER_STATUS 7
37 #define IDE_REGISTER_COMMAND IDE_REGISTER_STATUS
38
39 /* Control Block Registers */
40 #define IDE_REGISTER_ALTERNATE_STATUS 6
41 #define IDE_REGISTER_DEVICE_CONTROL IDE_REGISTER_ALTERNATE_STATUS
42
43 /* offsets used to access registers */
44 #define IDE_REGISTER_DEVICE_CONTROL_OFFSET 8
45 #define IDE_REGISTER_ALTERNATE_STATUS_OFFSET IDE_REGISTER_DEVICE_CONTROL_OFFSET
46 #define IDE_REGISTER_DATA_BYTE 9
47 #define IDE_REGISTER_DATA_WORD 10
48
49 /*
50  * Registers bits
51  */
52 #define IDE_REGISTER_STATUS_BSY 0x80 /* Busy bit */
53 #define IDE_REGISTER_STATUS_DRDY 0x40 /* Device ready */
54 #define IDE_REGISTER_STATUS_DF 0x20 /* Device fault */
55 #define IDE_REGISTER_STATUS_DSC 0x10 /* Device seek complete-- */
56  /* obsolete */
57 #define IDE_REGISTER_STATUS_DRQ 0x08 /* Data request */
58 #define IDE_REGISTER_STATUS_CORR 0x04 /* Corrected data-- */
59  /* vendor specific--obsolete */
60 #define IDE_REGISTER_STATUS_IDX 0x02 /* Index-- */
61  /* vendor specific--obsolete */
62 #define IDE_REGISTER_STATUS_ERR 0x01 /* Error */
63
64 #define IDE_REGISTER_DEVICE_CONTROL_SRST 0x04 /* Host software reset bit */
65 #define IDE_REGISTER_DEVICE_CONTROL_nIEN 0x02 /* Negated interrupt enable */
66
67 #define IDE_REGISTER_DEVICE_HEAD_L 0x40 /* LBA mode bit */
68 #define IDE_REGISTER_DEVICE_HEAD_DEV 0x10 /* Device0/Device1 bit */
69 #define IDE_REGISTER_DEVICE_HEAD_DEV_POS 4 /* Dev0/Dev1 bit position */
70 #define IDE_REGISTER_DEVICE_HEAD_HS 0x0f /* Head/LBA24_27 bits */
71 #define IDE_REGISTER_LBA3_L 0x40
72 #define IDE_REGISTER_LBA3_DEV 0x10
73 #define IDE_REGISTER_LBA3_LBA 0x0f
74
75 #define IDE_REGISTER_ERROR_ICRC (1 << 7) /* Interface CRC error on */
76  /* UDMA data transfer */
77 #define IDE_REGISTER_ERROR_UNC (1 << 6) /* Uncorrectable data error */
78 #if CCJ_COULD_NOT_FIND_THIS_ERROR
79 #define IDE_REGISTER_ERROR_WP (1 << 6) /* Write protect */
80 #endif
81 #define IDE_REGISTER_ERROR_MC (1 << 5) /* Media changed */
82 #define IDE_REGISTER_ERROR_IDNF (1 << 4) /* Sector ID not found */
83 #define IDE_REGISTER_ERROR_MCR (1 << 3) /* Media change requested */
84  /* obsolette */
85 #define IDE_REGISTER_ERROR_ABRT (1 << 2) /* Aborted command */
86 #define IDE_REGISTER_ERROR_NM (1 << 1) /* No media, End of Media. */
87 #define IDE_REGISTER_ERROR_AMNF (1 << 0) /* Address mark not found */
88  /* --obsolette in ATA-4 */
89 #define IDE_REGISTER_ERROR_MED (1 << 0) /* Media error is detected */
90
91 /*
92  * ide_controller_read_data_block --
93  * Read data block via controller's data register
94  *
95  * PARAMETERS:
96  * minor - minor number of controller
97  * block_size - number of bytes to read
98  * bufs - set of buffers to store data
99  * cbuf - number of current buffer from the set
100  * pos - position inside current buffer 'cbuf'
101  *
102  * RETURNS:
103  * NONE
104  */
105 void
106 ide_controller_read_data_block(rtems_device_minor_number minor,
107  uint32_t block_size,
109  uint32_t *cbuf,
110  uint32_t *pos);
111
112 /*
113  * ide_controller_write_data_block --
114  * Write data block via controller's data register
115  *
116  * PARAMETERS:
117  * minor - minor number of controller
118  * block_size - number of bytes to write
119  * bufs - set of buffers which store data
120  * cbuf - number of current buffer from the set
121  * pos - position inside current buffer 'cbuf'
122  *
123  * RETURNS:
124  * NONE
125  */
126 void
127 ide_controller_write_data_block(rtems_device_minor_number minor,
128  uint32_t block_size,
130  uint32_t *cbuf,
131  uint32_t *pos);
132
133 /*
134  * ide_controller_read_register --
135  * Read controller's register
136  *
137  * PARAMETERS:
138  * minor - minor number of controller
139  * reg - register to read
140  * value - placeholder for result
141  *
142  * RETURNS
143  * NONE
144  */
145 void
146 ide_controller_read_register(rtems_device_minor_number minor,
147  int reg,
148  uint16_t *value);
149
150 /*
151  * ide_controller_write_register --
152  * Write controller's register
153  *
154  * PARAMETERS:
155  * minor - minor number of controller
156  * reg - register to write
157  * value - value to write
158  *
159  * RETURNS:
160  * NONE
161  */
162 void
163 ide_controller_write_register(rtems_device_minor_number minor,
164  int reg, uint16_t value);
165
166 /*
167  * ide_controller_config_io_speed --
168  * Set controller's speed of IO operations
169  *
170  * PARAMETERS:
171  * minor - minor number of controller
172  * modes_available - speeds available
173  *
174  * RETURNS:
175  * RTEMS_SUCCESSFUL on success, or error code if
176  * error occured
177  */
179 ide_controller_config_io_speed(int minor, uint16_t modes_available);
180
181 #ifdef __cplusplus
182 }
183 #endif
184
185
186 #endif /* __IDE_CTRL_IO_H__ */
rtems_status_code
Classic API Status.
Definition: status.h:43
Block device scatter or gather buffer structure.
Definition: blkdev.h:68
Block Device Management.
