RTEMS  5.1
ide_ctrl_cfg.h
1 /*
2  * ide_ctrl_cfg.h
3  *
4  * LibChip library IDE controller header file - structures used for
5  * configuration and plugin interface definition.
6  *
7  * Copyright (C) 2002 OKTET Ltd., St.-Petersburg, Russia
8  * Author: Eugeny S. Mints <Eugeny.Mints@oktet.ru>
9  *
10  * The license and distribution terms for this file may be
11  * found in the file LICENSE in this distribution or at
12  * http://www.rtems.org/license/LICENSE.
13  */
14 #ifndef __IDE_CTRL_CFG_H__
15 #define __IDE_CTRL_CFG_H__
16
17 #include <rtems/blkdev.h>
18
19 #ifdef __cplusplus
20 extern "C" {
21 #endif
22
23 /*
24  * Avaible drivers for IDE controllers
25  */
26 typedef enum {
27  IDE_STD,
28  IDE_CUSTOM /* BSP specific driver */
29 } ide_ctrl_devs_t;
30
31 /* ATA modes: bit masks used in ctrl_config_io_speed call */
32 #define ATA_MODES_PIO3 0x001
33 #define ATA_MODES_PIO4 0x002
34
35 #define ATA_MODES_PIO 0x003
36
37 #define ATA_MODES_DMA0 0x004
38 #define ATA_MODES_DMA1 0x008
39 #define ATA_MODES_DMA2 0x010
40
41 #define ATA_MODES_UDMA0 0x020
42 #define ATA_MODES_UDMA1 0x040
43 #define ATA_MODES_UDMA2 0x080
44 #define ATA_MODES_UDMA3 0x100
45 #define ATA_MODES_UDMA4 0x200
46 #define ATA_MODES_UDMA5 0x400
47
48 #define ATA_MODES_UDMA 0x7e0
49 #define ATA_MODES_DMA 0x7fc
50
51
52 /*
53  * Each driver for a particular controller have to provide following
54  * functions in such a structure. The only field which should not be NULL
55  * is contInit.
56  */
57 typedef struct ide_ctrl_fns_s {
58  bool (*ctrl_probe)(int minor); /* probe routine */
59  void (*ctrl_initialize)(int minor);
60  int (*ctrl_control)(int minor, uint32_t command,
61  void *arg);
62  /*
63  * Functions which allow read/write registers of a particular controller.
64  * (these functions may be used from ide_controller_read_register,
65  * ide_controller_write_register)
66  */
67  void (*ctrl_reg_read)(int minor, int regist, uint16_t *value);
68  void (*ctrl_reg_write)(int minor, int regist, uint16_t value);
69
70  /*
71  * The function allows to escape overhead for read/write register
72  * functions calls
73  */
74  void (*ctrl_read_block)(int minor, uint32_t block_size,
75  rtems_blkdev_sg_buffer *bufs, uint32_t *cbuf,
76  uint32_t *pos);
77  void (*ctrl_write_block)(int minor, uint32_t block_size,
78  rtems_blkdev_sg_buffer *bufs, uint32_t *cbuf,
79  uint32_t *pos);
80
81  rtems_status_code (*ctrl_config_io_speed)(int minor,
82  uint16_t modes_available);
84
85 /*
86  * IDE Controller configuration. Table of such configurations is provided
87  * by BSP
88  */
90  char *name; /* device name */
91  ide_ctrl_devs_t type; /* chip type */
92  ide_ctrl_fns_t *fns; /* pointer to the set of driver routines */
93  bool (*probe)(int minor); /* general probe routine */
94  uint8_t status; /* initialized/non initialized. Should be set
95  * to zero by static initialization
96  */
97  uint32_t port1; /* port number for the port of the device */
98  bool int_driven; /* interrupt/poll driven */
99  rtems_vector_number int_vec; /* the interrupt vector of the device */
100  void *params; /* contains either device specific data or a
101  * pointer to s device specific information
102  * table
103  */
105
106 /* IDE controllers Table */
107 extern ide_controller_bsp_table_t IDE_Controller_Table[];
108
109 /* Number of rows in IDE_Controller_Table */
110 extern unsigned long IDE_Controller_Count;
111
112
113 #define IDE_CTRL_MAX_MINOR_NUMBER 4
114
115 #define IDE_CTRL_NON_INITIALIZED 0
116 #define IDE_CTRL_INITIALIZED 1
117
118 #ifdef __cplusplus
119 }
120 #endif
121
122
123 #endif /* __IDE_CTRL_CFG_H__ */
Definition: ide_ctrl_cfg.h:89
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
rtems_status_code
Classic API Status.
Definition: status.h:43
Block device scatter or gather buffer structure.
Definition: blkdev.h:68
Definition: ide_ctrl_cfg.h:57
Block Device Management.
