RTEMS  5.1
icm7170.h
1 /*
2  * This file contains the definitions for the following real-time clocks:
3  *
4  * + Harris Semiconduction ICM7170
5  *
6  * COPYRIGHT (c) 1989-1999.
7  * On-Line Applications Research Corporation (OAR).
8  *
9  * The license and distribution terms for this file may be
10  * found in the file LICENSE in this distribution or at
11  * http://www.rtems.org/license/LICENSE.
12  */
13
14 #ifndef __LIBCHIP_ICM7170_h
15 #define __LIBCHIP_ICM7170_h
16
17 /*
18  * Register indices
19  */
20
21 #define ICM7170_CONTROL 0x11
22
23
24 #define ICM7170_COUNTER_HUNDREDTHS 0x00
25 #define ICM7170_HOUR 0x01
26 #define ICM7170_MINUTE 0x02
27 #define ICM7170_SECOND 0x03
28 #define ICM7170_MONTH 0x04
29 #define ICM7170_DATE 0x05
30 #define ICM7170_YEAR 0x06
31 #define ICM7170_DAY_OF_WEEK 0x07
32
33 /*
34  * Configuration information in the parameters field
35  */
36
37 #define ICM7170_AT_32_KHZ 0x00
38 #define ICM7170_AT_1_MHZ 0x01
39 #define ICM7170_AT_2_MHZ 0x02
40 #define ICM7170_AT_4_MHZ 0x03
41
42 /*
43  * Driver function table
44  */
45
46 extern rtc_fns icm7170_fns;
47
48 /*
49  * Default register access routines
50  */
51
52 uint32_t icm7170_get_register( /* registers are at 1 byte boundaries */
53  uintptr_t ulCtrlPort, /* and accessed as bytes */
54  uint8_t ucRegNum
55 );
56
57 void icm7170_set_register(
58  uintptr_t ulCtrlPort,
59  uint8_t ucRegNum,
60  uint32_t ucData
61 );
62
63 uint32_t icm7170_get_register_2( /* registers are at 2 byte boundaries */
64  uintptr_t ulCtrlPort, /* and accessed as bytes */
65  uint8_t ucRegNum
66 );
67
68 void icm7170_set_register_2(
69  uintptr_t ulCtrlPort,
70  uint8_t ucRegNum,
71  uint32_t ucData
72 );
73
74 uint32_t icm7170_get_register_4( /* registers are at 4 byte boundaries */
75  uintptr_t ulCtrlPort, /* and accessed as bytes */
76  uint8_t ucRegNum
77 );
78
79 void icm7170_set_register_4(
80  uintptr_t ulCtrlPort,
81  uint8_t ucRegNum,
82  uint32_t ucData
83 );
84
85 uint32_t icm7170_get_register_8( /* registers are at 8 byte boundaries */
86  uintptr_t ulCtrlPort, /* and accessed as bytes */
87  uint8_t ucRegNum
88 );
89
90 void icm7170_set_register_8(
91  uintptr_t ulCtrlPort,
92  uint8_t ucRegNum,
93  uint32_t ucData
94 );
95
96 #endif
97 /* end of include file */
Definition: rtc.h:27
