RTEMS  5.1
apic.h
1
7 /*
8  * Author: Erich Boleyn <erich@uruk.org>
9  * http://www.uruk.org/~erich/
10  *
11  * Copyright (c) 1997-2011 Erich Boleyn. All rights reserved.
12  *
13  * Redistribution and use in source and binary forms, with or without
14  * modification, are permitted provided that the following conditions
15  * are met:
16  * 1. Redistributions of source code must retain the above copyright
17  * notice, this list of conditions and the following disclaimer.
18  * 2. Redistributions in binary form must reproduce the above copyright
19  * notice, this list of conditions and the following disclaimer in the
20  * documentation and/or other materials provided with the distribution.
21  * 3. The name of the author may not be used to endorse or promote products
22  * derived from this software without specific prior written permission.
23  *
24  * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
25  * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
26  * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
27  * IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
28  * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
29  * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
30  * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
31  * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32  * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
33  * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34  */
35
43 /*
44  * Header file for Intel Architecture local and I/O APIC definitions.
45  *
46  * This file was created from information in the Intel Pentium Pro
47  * Family Developer's Manual, Volume 3: Operating System Writer's
48  * Manual, order number 242692-001, which can be ordered from the
49  * Intel literature center.
50  */
51
52 #ifndef _APIC_H
53 #define _APIC_H
54
55 /*
56  * APIC Defines.
57  */
58
59 /*
60  * Recommendation: Don't use this except for MSI interrupt delivery.
61  * In general, the "Destination Mode" can be used to control this, since
62  * it is DIFFERENT (0xF) for Pentium and P6, but not on the same APIC
63  * version for AMD Opteron.
64  */
65 #define APIC_BCAST_ID 0xFF
66
67 /*
68  * APIC register definitions
69  */
70
71 /*
72  * Shared defines for I/O and local APIC definitions
73  */
75 #define APIC_VERSION(x) ((x) & 0xFF)
76 #define APIC_MAXREDIR(x) (((x) >> 16) & 0xFF)
77
78 #define APIC_ID(x) ((x) >> 24)
79 #define APIC_VER_NEW 0x10
80
81 #define IOAPIC_REGSEL 0
82 #define IOAPIC_RW 0x10
83 #define IOAPIC_ID 0
84 #define IOAPIC_VER 1
85 #define IOAPIC_REDIR 0x10
86
87 #define LAPIC_ID 0x20
88 #define LAPIC_VER 0x30
89 #define LAPIC_TPR 0x80
90 #define LAPIC_APR 0x90
91 #define LAPIC_PPR 0xA0
92 #define LAPIC_EOI 0xB0
93 #define LAPIC_LDR 0xD0
94 #define LAPIC_DFR 0xE0
95 #define LAPIC_SPIV 0xF0
96 #define LAPIC_SPIV_ENABLE_APIC 0x100
97 #define LAPIC_ISR 0x100
98 #define LAPIC_TMR 0x180
99 #define LAPIC_IRR 0x200
100 #define LAPIC_ESR 0x280
101 #define LAPIC_ICR 0x300
102 #define LAPIC_ICR_DS_SELF 0x40000
103 #define LAPIC_ICR_DS_ALLINC 0x80000
104 #define LAPIC_ICR_DS_ALLEX 0xC0000
105 #define LAPIC_ICR_TM_LEVEL 0x8000
106 #define LAPIC_ICR_LEVELASSERT 0x4000
107 #define LAPIC_ICR_STATUS_PEND 0x1000
108 #define LAPIC_ICR_DM_LOGICAL 0x800
109 #define LAPIC_ICR_DM_LOWPRI 0x100
110 #define LAPIC_ICR_DM_SMI 0x200
111 #define LAPIC_ICR_DM_NMI 0x400
112 #define LAPIC_ICR_DM_INIT 0x500
113 #define LAPIC_ICR_DM_SIPI 0x600
114 #define LAPIC_LVTT 0x320
115 #define LAPIC_LVTPC 0x340
116 #define LAPIC_LVT0 0x350
117 #define LAPIC_LVT1 0x360
118 #define LAPIC_LVTE 0x370
119 #define LAPIC_TICR 0x380
120 #define LAPIC_TCCR 0x390
121 #define LAPIC_TDCR 0x3E0
122
123 #endif /* _APIC_H */
124
