RTEMS  5.1
i2cmst.h
1
6 /*
7  * COPYRIGHT (c) 2007 Cobham Gaisler AB
8  * with parts from the RTEMS MPC83xx I2C driver (c) 2007 Embedded Brains GmbH.
9  *
10  * The license and distribution terms for this file may be
11  * found in the file LICENSE in this distribution or at
12  * http://www.rtems.org/license/LICENSE.
13  */
14
15 #ifndef _I2CMST_H
16 #define _I2CMST_H
17
28 #include <rtems/libi2c.h>
29 #include "ambapp.h"
30
31 #ifdef __cplusplus
32 extern "C" {
33 #endif
34
35 /* I2C-master operational registers */
36
37 typedef struct gr_i2cmst_regs {
38  volatile unsigned int prescl; /* Prescale register */
39  volatile unsigned int ctrl; /* Control register */
40  volatile unsigned int tdrd; /* Transmit and Receive registers */
41  volatile unsigned int cmdsts; /* Command and Status registers */
43
44 /* Control (CTRL) register */
45 #define GRI2C_CTRL_EN 0x00000080 /* Enable core */
46 #define GRI2C_CTRL_IEN 0x00000040 /* Interrupt enable */
47
48 /* Command (CMD) register */
49 #define GRI2C_CMD_STA 0x00000080 /* Generate START condition */
50 #define GRI2C_CMD_STO 0x00000040 /* Generate STOP condition */
51 #define GRI2C_CMD_RD 0x00000020 /* Read from slave */
52 #define GRI2C_CMD_WR 0x00000010 /* Write to slave */
53 #define GRI2C_CMD_ACK 0x00000008 /* Acknowledge */
54 #define GRI2C_CMD_IACK 0x00000001 /* Interrupt acknowledge */
55
56 /* Status (STS) register */
57 #define GRI2C_STS_RXACK 0x00000080 /* Receive acknowledge */
58 #define GRI2C_STS_BUSY 0x00000040 /* I2C-bus busy */
59 #define GRI2C_STS_AL 0x00000020 /* Arbitration lost */
60 #define GRI2C_STS_TIP 0x00000002 /* Transfer in progress */
61 #define GRI2C_STS_IF 0x00000001 /* Interrupt flag */
62
63 #define GRI2C_STATUS_IDLE 0x00000000
64
65 /* Register I2CMST driver to Driver Manager */
66 void i2cmst_register_drv (void);
67
68 #ifdef __cplusplus
69 }
70 #endif
71
74 #endif /* _I2CMST_H */
Definition: i2cmst.h:37
Legacy I2C Library.
