RTEMS
5.1
21 #ifndef __GEN83xx_HWREG_VALS_h 22 #define __GEN83xx_HWREG_VALS_h 24 #include <mpc83xx/mpc83xx.h> 27 #ifdef MPC83XX_HAS_NAND_LP_FLASH_ON_CS0 28 #define MPC83XX_RCWHR_BOOT_DEVICE (RCWHR_ROMLOC_LB08 | RCWHR_RLEXT_NAND) 30 #define MPC83XX_RCWHR_BOOT_DEVICE (RCWHR_ROMLOC_LB16 | RCWHR_RLEXT_LGCY) 36 #if defined(MPC83XX_BOARD_MPC8349EAMDS) 43 #define GEN83xx_DUART_AVAIL_MASK 0x03 46 #define NEED_LOW_LEVEL_INIT 50 #define BSP_CLKIN_FRQ 66000000L 51 #define RCFG_SYSPLL_MF 4 52 #define RCFG_COREPLL_MF 4 57 #define RESET_CONF_WRD_L (RCWLR_LBIUCM_1_1 | \ 59 RCWLR_SPMF(RCFG_SYSPLL_MF) | \ 60 RCWLR_COREPLL(RCFG_COREPLL_MF)) 62 #define RESET_CONF_WRD_H (RCWHR_PCI_HOST | \ 68 RCWHR_BOOTSEQ_NONE | \ 70 MPC83XX_RCWHR_BOOT_DEVICE | \ 76 #elif defined(MPC83XX_BOARD_HSC_CM01) 83 #define GEN83xx_DUART_AVAIL_MASK 0x01 86 #define NEED_LOW_LEVEL_INIT 90 #define BSP_CLKIN_FRQ 30000000L 91 #define RCFG_SYSPLL_MF 11 92 #define RCFG_COREPLL_MF 4 96 #define RESET_CONF_WRD_L (RCWLR_LBIUCM_1_1 | \ 98 RCWLR_SPMF(RCFG_SYSPLL_MF) | \ 99 RCWLR_COREPLL(RCFG_COREPLL_MF)) 101 #define RESET_CONF_WRD_H (RCWHR_PCI_HOST | \ 103 RCWHR_PCI1ARB_DIS | \ 104 RCWHR_PCI2ARB_DIS | \ 107 RCWHR_BOOTSEQ_NONE | \ 109 MPC83XX_RCWHR_BOOT_DEVICE | \ 110 RCWHR_TSEC1M_RGMII | \ 111 RCWHR_TSEC2M_GMII | \ 116 #elif defined(MPC83XX_BOARD_BR_UID) 123 #define GEN83xx_DUART_AVAIL_MASK 0x01 126 #define NEED_LOW_LEVEL_INIT 130 #define BSP_CLKIN_FRQ 25000000L 131 #define RCFG_SYSPLL_MF 5 132 #define RCFG_COREPLL_MF 5 136 #define RESET_CONF_WRD_L \ 139 | RCWLR_SPMF(RCFG_SYSPLL_MF) \ 140 | RCWLR_COREPLL(RCFG_COREPLL_MF) \ 145 #define RESET_CONF_WRD_H (RCWHR_PCI_HOST | \ 147 RCWHR_PCI1ARB_DIS | \ 150 RCWHR_BOOTSEQ_NONE | \ 152 MPC83XX_RCWHR_BOOT_DEVICE | \ 155 #elif defined( HAS_UBOOT) 161 #error "board type not defined" 165 #if defined(MPC83XX_BOARD_MPC8349EAMDS) 178 #define LBLAWBAR0_VAL 0xFE000000 179 #define LBLAWAR0_VAL 0x80000016 180 #define LBLAWBAR1_VAL 0xF8000000 181 #define LBLAWAR1_VAL 0x8000000E 182 #define LBLAWBAR2_VAL 0xF0000000 183 #define LBLAWAR2_VAL 0x80000019 184 #define DDRLAWBAR0_VAL 0x00000000 185 #define DDRLAWAR0_VAL 0x8000001B 190 #define BR0_VAL 0xFE001001 191 #define OR0_VAL 0xFF806FF7 192 #define BR1_VAL 0xF8000801 193 #define OR1_VAL 0xFFFFE8F0 194 #define BR2_VAL 0xF0001861 195 #define OR2_VAL 0xFC006901 200 #define MRPTR_VAL 0x20000000 201 #define LSRT_VAL 0x32000000 202 #define LSDMR_VAL 0x4062D733 203 #define LCRR_VAL 0x80000004 209 #define CS2_BNDS_VAL 0x00000007 210 #define CS3_BNDS_VAL 0x0008000F 211 #define CS2_CONFIG_VAL 0x80000101 212 #define CS3_CONFIG_VAL 0x80000101 213 #define TIMING_CFG_1_VAL 0x36333321 214 #define TIMING_CFG_2_VAL 0x00000800 215 #define DDR_SDRAM_CFG_VAL 0xC2000000 216 #define DDR_SDRAM_MODE_VAL 0x00000022 217 #define DDR_SDRAM_INTTVL_VAL 0x045B0100 218 #define DDR_SDRAM_CLK_CNTL_VAL 0x00000000 220 #elif defined(MPC83XX_BOARD_HSC_CM01) 230 #define FPGA_CONFIG_START 0xF8000000 231 #define FPGA_CONFIG_SIZE 0x01000000 233 #define FPGA_REGISTER_START 0xF9000000 234 #define FPGA_REGISTER_SIZE 0x00800000 236 #define FPGA_FIFO_START 0xF9800000 237 #define FPGA_FIFO_SIZE 0x00800000 239 #define FPGA_START (FPGA_CONFIG_START) 241 #define FPGA_SIZE (0x02000000) 242 #define FPGA_END (FPGA_START+FPGA_SIZE-1) 249 #define LBLAWBAR0_VAL bsp_rom_start 250 #define LBLAWAR0_VAL 0x80000018 251 #define LBLAWBAR1_VAL (FPGA_CONFIG_START) 252 #define LBLAWAR1_VAL 0x80000018 253 #define DDRLAWBAR0_VAL bsp_ram_start 254 #define DDRLAWAR0_VAL 0x8000001B 259 #define BR0_VAL (0xFE000000 | 0x01001) 260 #define OR0_VAL 0xFE000E54 262 #define BR2_VAL (FPGA_CONFIG_START | 0x01881) 263 #define OR2_VAL 0xFFFF9100 266 #define BR3_VAL (FPGA_REGISTER_START | 0x018A1) 267 #define OR3_VAL 0xFF801100 270 #define BR4_VAL (FPGA_FIFO_START | 0x018C1) 271 #define OR4_VAL 0xFF801100 276 #define MRPTR_VAL 0x20000000 277 #define LSRT_VAL 0x32000000 278 #define LSDMR_VAL 0x4062D733 279 #define LCRR_VAL 0x80010004 285 #define DDRCDR_VAL 0x00000001 286 #define CS0_BNDS_VAL 0x0000000F 287 #define CS0_CONFIG_VAL 0x80810102 288 #define TIMING_CFG_0_VAL 0x00420802 289 #define TIMING_CFG_1_VAL 0x3735A322 290 #define TIMING_CFG_2_VAL 0x2F9044C7 291 #define DDR_SDRAM_CFG_2_VAL 0x00401000 292 #define DDR_SDRAM_MODE_VAL 0x44521632 293 #define DDR_SDRAM_CLK_CNTL_VAL 0x01800000 294 #define DDR_SDRAM_CFG_VAL 0x63000008 296 #define DDR_ERR_DISABLE_VAL 0x0000008D 297 #define DDR_ERR_DISABLE_VAL2 0x00000089 298 #define DDR_SDRAM_DATA_INIT_VAL 0xC01DCAFE 299 #define DDR_SDRAM_INIT_ADDR_VAL 0 300 #define DDR_SDRAM_INTERVAL_VAL 0x05080000 302 #elif defined(MPC83XX_BOARD_BR_UID) 316 #define LBLAWBAR0_VAL bsp_rom_start 317 #define LBLAWAR0_VAL 0x80000018 318 #define DDRLAWBAR0_VAL bsp_ram_start 319 #define DDRLAWAR0_VAL 0x8000001B 327 #define LCRR_VAL 0x80010002 333 #define DDRCDR_VAL 0x00000001 334 #define CS0_BNDS_VAL 0x0000000F 335 #define CS0_CONFIG_VAL 0x80014202 336 #define TIMING_CFG_0_VAL 0x00220802 337 #define TIMING_CFG_1_VAL 0x26259222 338 #define TIMING_CFG_2_VAL 0x111048C7 339 #define DDR_SDRAM_CFG_2_VAL 0x00401000 340 #define DDR_SDRAM_MODE_VAL 0x200F1632 341 #define DDR_SDRAM_MODE_2_VAL 0x40006000 342 #define DDR_SDRAM_CLK_CNTL_VAL 0x01800000 343 #define DDR_SDRAM_CFG_VAL 0x43100008 345 #define DDR_ERR_DISABLE_VAL 0x0000008D 346 #define DDR_ERR_DISABLE_VAL2 0x00000089 347 #define DDR_SDRAM_DATA_INIT_VAL 0xC01DCAFE 348 #define DDR_SDRAM_INIT_ADDR_VAL 0 349 #define DDR_SDRAM_INTERVAL_VAL 0x01E8222E 351 #elif defined( HAS_UBOOT) 357 #error "board type not defined" 365 #if MPC83XX_CHIP_TYPE != 8309 366 #define BSP_SYSPLL_CKID (((mpc83xx.clk.spmr>>(31-8))&0x01)+1) 369 #define BSP_SYSPLL_CKID 1 372 #define BSP_SYSPLL_MF ((mpc83xx.clk.spmr>>(31-7))&0x0f) 374 #define BSP_COREPLL_MF ((mpc83xx.clk.spmr>>(31-15))&0x7f)
