RTEMS
5.1
Data Structure Index
Class Hierarchy
z
z
z
z
Pages
bsps
arm
lpc32xx
include
bsp
hsu.h
1
9
10
* Copyright (c) 2010-2014 embedded brains GmbH. All rights reserved.
11
12
* embedded brains GmbH
13
* Dornierstr. 4
14
* 82178 Puchheim
15
* Germany
16
* <rtems@embedded-brains.de>
17
18
* The license and distribution terms for this file may be
19
* found in the file LICENSE in this distribution or at
20
* http://www.rtems.org/license/LICENSE.
21
22
23
#ifndef LIBBSP_ARM_LPC32XX_HSU_H
24
#define LIBBSP_ARM_LPC32XX_HSU_H
25
26
rtems/termiostypes.h
27
28
#ifdef __cplusplus
29
extern
"C"
30
#endif
/* __cplusplus */
31
42
typedef
struct
43
uint32_t fifo;
44
uint32_t level;
45
uint32_t iir;
46
uint32_t ctrl;
47
uint32_t rate;
48
lpc32xx_hsu
49
50
typedef
struct
51
rtems_termios_device_context
base;
52
volatile
lpc32xx_hsu
*hsu;
53
size_t
chars_in_transmission;
54
rtems_vector_number
irq;
55
uint32_t initial_baud;
56
lpc32xx_hsu_context
57
58
extern
const
rtems_termios_device_handler
lpc32xx_hsu_fns;
59
60
bool
lpc32xx_hsu_probe(
*base);
61
64
#ifdef __cplusplus
65
66
#endif
/* __cplusplus */
67
68
#endif
/* LIBBSP_ARM_LPC32XX_HSU_H */
Termios device context.
Definition:
termiostypes.h:75
termiostypes.h
rtems_vector_number
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition:
intr.h:47
lpc32xx_hsu
Definition:
hsu.h:42
lpc32xx_hsu_context
Definition:
hsu.h:50
Termios device handler.
Definition:
termiostypes.h:141
