RTEMS  5.1
gtm.h
1
7 /*
8  * Copyright (c) 2008
9  * Embedded Brains GmbH
10  * Obere Lagerstr. 30
11  * D-82178 Puchheim
12  * Germany
13  * rtems@embedded-brains.de
14  *
15  * The license and distribution terms for this file may be
16  * found in the file LICENSE in this distribution or at
17  * http://www.rtems.org/license/LICENSE.
18  */
19
20 #ifndef LIBBSP_POWERPC_MPC83XX_TIMER_H
21 #define LIBBSP_POWERPC_MPC83XX_TIMER_H
22
23 #include <stdint.h>
24 #include <stdbool.h>
25
26 #include <rtems.h>
27
28 #define MPC83XX_GTM_NUMBER 8
29
30 #define MPC83XX_GTM_CLOCK_CASCADED 0x0000
31 #define MPC83XX_GTM_CLOCK_SYSTEM 0x0002
32 #define MPC83XX_GTM_CLOCK_SYSTEM_SLOW 0x0004
33 #define MPC83XX_GTM_CLOCK_EXTERN 0x0006
34
35 rtems_status_code mpc83xx_gtm_initialize( int timer, int clock);
36
37 rtems_status_code mpc83xx_gtm_enable_restart( int timer, bool enable);
38
39 rtems_status_code mpc83xx_gtm_set_clock( int timer, int clock);
40
41 rtems_status_code mpc83xx_gtm_get_clock( int timer, int *clock);
42
43 rtems_status_code mpc83xx_gtm_start( int timer);
44
45 rtems_status_code mpc83xx_gtm_stop( int timer);
46
47 rtems_status_code mpc83xx_gtm_set_value( int timer, uint16_t value);
48
49 rtems_status_code mpc83xx_gtm_get_value( int timer, uint16_t *value);
50
51 rtems_status_code mpc83xx_gtm_set_reference( int timer, uint16_t reference);
52
53 rtems_status_code mpc83xx_gtm_get_reference( int timer, uint16_t *reference);
54
55 rtems_status_code mpc83xx_gtm_set_prescale( int timer, uint8_t prescale);
56
57 rtems_status_code mpc83xx_gtm_get_prescale( int timer, uint8_t *prescale);
58
59 rtems_status_code mpc83xx_gtm_interrupt_get_vector( int timer, rtems_vector_number *vector);
60
61 rtems_status_code mpc83xx_gtm_interrupt_enable( int timer);
62
63 rtems_status_code mpc83xx_gtm_interrupt_disable( int timer);
64
65 rtems_status_code mpc83xx_gtm_interrupt_clear( int timer);
66
67 #endif /* LIBBSP_POWERPC_MPC83XX_TIMER_H */
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
rtems_status_code
Classic API Status.
Definition: status.h:43
