RTEMS  5.1
grspw_pkt.h
1 /*
2  * GRSPW/GRSPW2 SpaceWire Kernel Library Interface
3  *
4  * COPYRIGHT (c) 2011
5  * Cobham Gaisler AB
6  *
7  * The license and distribution terms for this file may be
8  * found in the file LICENSE in this distribution or at
9  * http://www.rtems.org/license/LICENSE.
10  */
11
12 #ifndef __GRSPW_PKT_H__
13 #define __GRSPW_PKT_H__
14
15 struct grspw_pkt;
16
17 /* Maximum number of GRSPW devices supported by driver */
18 #define GRSPW_MAX 32
19
20 /* Weak overridable variable the user can use to define the worker-task
21  * priority (0..255) or to disable (-1) the creation of the worker-task
22  * and the message queue to save space */
23 extern int grspw_work_task_priority;
24
25 #ifndef GRSPW_PKT_FLAGS
26 #define GRSPW_PKT_FLAGS
27 /*** TX Packet flags ***/
28
29 /* Enable IRQ generation */
30 #define TXPKT_FLAG_IE 0x0040
31
32 /* Enable Header CRC generation (if CRC is available in HW)
33  * Header CRC will be appended (one byte at end of header)
34  */
35 #define TXPKT_FLAG_HCRC 0x0100
36
37 /* Enable Data CRC generation (if CRC is available in HW)
38  * Data CRC will be appended (one or two byte at end of packet, depending on
39  * Data CRC type)
40  */
41 #define TXPKT_FLAG_DCRC 0x0200
42
43 /* Data CRC type */
44 #define TXPKT_FLAG_DCRCT_MASK 0x0c00
45 /* RMAP CRC. 1 byte */
46 #define TXPKT_FLAG_DCRCT_RMAP 0x0000
47 /* CCSDS/CCITT CRC-16. 2 byte */
48 #define TXPKT_FLAG_DCRCT_CCSDS 0x0400
49 /* 16-bit ISO-checksum (J.G. Fletcher, ISO 8473-1:1998). 2 byte */
50 #define TXPKT_FLAG_DCRCT_ISO16 0x0800
51
52 /* Control how many bytes the beginning of the Header
53  * the CRC should not be calculated for */
54 #define TXPKT_FLAG_NOCRC_MASK 0x0000000f
55 #define TXPKT_FLAG_NOCRC_LEN0 0x00000000
56 #define TXPKT_FLAG_NOCRC_LEN1 0x00000001
57 #define TXPKT_FLAG_NOCRC_LEN2 0x00000002
58 #define TXPKT_FLAG_NOCRC_LEN3 0x00000003
59 #define TXPKT_FLAG_NOCRC_LEN4 0x00000004
60 #define TXPKT_FLAG_NOCRC_LEN5 0x00000005
61 #define TXPKT_FLAG_NOCRC_LEN6 0x00000006
62 #define TXPKT_FLAG_NOCRC_LEN7 0x00000007
63 #define TXPKT_FLAG_NOCRC_LEN8 0x00000008
64 #define TXPKT_FLAG_NOCRC_LEN9 0x00000009
65 #define TXPKT_FLAG_NOCRC_LENa 0x0000000a
66 #define TXPKT_FLAG_NOCRC_LENb 0x0000000b
67 #define TXPKT_FLAG_NOCRC_LENc 0x0000000c
68 #define TXPKT_FLAG_NOCRC_LENd 0x0000000d
69 #define TXPKT_FLAG_NOCRC_LENe 0x0000000e
70 #define TXPKT_FLAG_NOCRC_LENf 0x0000000f
71
72 #define TXPKT_FLAG_INPUT_MASK (TXPKT_FLAG_NOCRC_MASK | TXPKT_FLAG_IE | \
73  TXPKT_FLAG_HCRC | TXPKT_FLAG_DCRC | \
74  TXPKT_FLAG_DCRCT_MASK)
75
76 /* Marks if packet was transmitted or not */
77 #define TXPKT_FLAG_TX 0x4000
78
79 /* Link Error */
80 #define TXPKT_FLAG_LINKERR 0x8000
81
82 #define TXPKT_FLAG_OUTPUT_MASK (TXPKT_FLAG_TX | TXPKT_FLAG_LINKERR)
83
84 /*** RX Packet Flags ***/
85
86 /* Enable IRQ generation */
87 #define RXPKT_FLAG_IE 0x0010
88
89 #define RXPKT_FLAG_INPUT_MASK (RXPKT_FLAG_IE)
90
91 /* Packet was truncated */
92 #define RXPKT_FLAG_TRUNK 0x0800
93 /* Data CRC error (only valid if RMAP CRC is enabled) */
94 #define RXPKT_FLAG_DCRC 0x0400
95 /* Header CRC error (only valid if RMAP CRC is enabled) */
96 #define RXPKT_FLAG_HCRC 0x0200
97 /* Error in End-of-Packet */
98 #define RXPKT_FLAG_EEOP 0x0100
99 /* Marks if packet was recevied or not */
100 #define RXPKT_FLAG_RX 0x8000
101
102 #define RXPKT_FLAG_OUTPUT_MASK (RXPKT_FLAG_TRUNK | RXPKT_FLAG_DCRC | \
103  RXPKT_FLAG_HCRC | RXPKT_FLAG_EEOP)
104
105 /*** General packet flag options ***/
106
107 /* Translate Hdr and/or Payload address */
108 #define PKT_FLAG_TR_DATA 0x1000
109 #define PKT_FLAG_TR_HDR 0x2000
110 /* All General options */
111 #define PKT_FLAG_MASK 0x3000
112
113 #endif
114 /* GRSPW RX/TX Packet structure.
115  *
116  * - For RX the 'hdr' and 'hlen' fields are not used, they are not written
117  * by driver.
118  *
119  * - The 'pkt_id' field is untouched by driver, it is intended for packet
120  * numbering or user-custom data.
121  *
122  * - The last packet in a list must have 'next' set to NULL.
123  *
124  * - data and hdr pointers are written without modification to hardware,
125  * this means that caller must do address translation to hardware
126  * address itself.
127  *
128  * - the 'flags' field are interpreted differently depending on transfer
129  * type (RX/TX). See XXPKT_FLAG_* options above.
130  */
131 struct grspw_pkt {
132  struct grspw_pkt *next; /* Next packet in list. NULL if last packet */
133  unsigned int pkt_id; /* User assigned ID (not touched by driver) */
134  unsigned short flags; /* RX/TX Options and status */
135  unsigned char reserved; /* Reserved, must be zero */
136  unsigned char hlen; /* Length of Header Buffer (only TX) */
137  unsigned int dlen; /* Length of Data Buffer */
138  void *data; /* 4-byte or byte aligned depends on HW */
139  void *hdr; /* 4-byte or byte aligned depends on HW (only TX) */
140 };
141
142 /* GRSPW SpaceWire Packet List */
143 struct grspw_list {
144  struct grspw_pkt *head;
145  struct grspw_pkt *tail;
146 };
147
148 /* SpaceWire Link State */
149 typedef enum {
150  SPW_LS_ERRRST = 0,
151  SPW_LS_ERRWAIT = 1,
152  SPW_LS_READY = 2,
153  SPW_LS_CONNECTING = 3,
154  SPW_LS_STARTED = 4,
155  SPW_LS_RUN = 5
156 } spw_link_state_t;
157
158 /* Address Configuration */
160  /* Ignore address field and put all received packets to first
161  * DMA channel.
162  */
163  int promiscuous;
164
165  /* Default Node Address and Mask */
166  unsigned char def_addr;
167  unsigned char def_mask;
168  /* DMA Channel custom Node Address and Mask */
169  struct {
170  char node_en; /* Enable Separate Addr */
171  unsigned char node_addr; /* Node address */
172  unsigned char node_mask; /* Node address mask */
173  } dma_nacfg[4];
174 };
175
176 /* Hardware Support in GRSPW Core */
177 struct grspw_hw_sup {
178  char rmap; /* If RMAP in HW is available */
179  char rmap_crc; /* If RMAP CRC is available */
180  char rx_unalign; /* RX unaligned (byte boundary) access allowed*/
181  char nports; /* Number of Ports (1 or 2) */
182  char ndma_chans; /* Number of DMA Channels (1..4) */
183  char strip_adr; /* Hardware can strip ADR from packet data */
184  char strip_pid; /* Hardware can strip PID from packet data */
185  int hw_version; /* GRSPW Hardware Version */
186  char reserved[2];
187  char irq; /* SpW Distributed Interrupt available if 1 */
188  char irq_num; /* Number of interrupts that can be generated */
189  char itmr_width; /* SpW Intr. ISR timers bit width. 0=no timer */
190  char ccsds_crc; /* CCSDS CRC-16 and 16-bit ISO is available */
191 };
192
194  int irq_cnt;
195  int err_credit;
196  int err_eeop;
197  int err_addr;
198  int err_parity;
199  int err_disconnect;
200  int err_escape;
201  int err_wsync; /* only in GRSPW1 */
202 };
203
204 /* grspw_link_ctrl() options */
205 #define LINKOPTS_ENABLE 0x0000
206 #define LINKOPTS_DISABLE 0x0001
207 #define LINKOPTS_START 0x0002
208 #define LINKOPTS_AUTOSTART 0x0004
209 #define LINKOPTS_DIS_ONERR 0x0008 /* Disable DMA transmitter on link error
210  * Controls LE bit in DMACTRL register.
211  */
212 #define LINKOPTS_DIS_ON_CE 0x0020000/* Disable Link on Credit error */
213 #define LINKOPTS_DIS_ON_ER 0x0040000/* Disable Link on Escape error */
214 #define LINKOPTS_DIS_ON_DE 0x0080000/* Disable Link on Disconnect error */
215 #define LINKOPTS_DIS_ON_PE 0x0100000/* Disable Link on Parity error */
216 #define LINKOPTS_DIS_ON_WE 0x0400000/* Disable Link on write synchonization
217  * error (GRSPW1 only)
218  */
219 #define LINKOPTS_DIS_ON_EE 0x1000000/* Disable Link on Early EOP/EEP error*/
220
221 /*#define LINKOPTS_TICK_OUT_IRQ 0x0100*//* Enable Tick-out IRQ */
222 #define LINKOPTS_EIRQ 0x0200 /* Enable Error Link IRQ */
223
224 #define LINKOPTS_MASK 0x15e020f/* All above options */
225 #define LINKOPTS_MASK_DIS_ON 0x15e0000/* All disable link on error options
226  * On a certain error the link disable
227  * bit will be written and the work
228  * task will call dma_stop() for all
229  * channels.
230  */
231
232 #define LINKSTS_CE 0x002 /* Credit error */
233 #define LINKSTS_ER 0x004 /* Escape error */
234 #define LINKSTS_DE 0x008 /* Disconnect error */
235 #define LINKSTS_PE 0x010 /* Parity error */
236 #define LINKSTS_WE 0x040 /* Write synchonization error (GRSPW1 only) */
237 #define LINKSTS_IA 0x080 /* Invalid address */
238 #define LINKSTS_EE 0x100 /* Early EOP/EEP */
239 #define LINKSTS_MASK 0x1de
240
241 /* grspw_tc_ctrl() options */
242 #define TCOPTS_EN_RXIRQ 0x0001 /* Tick-Out IRQ */
243 #define TCOPTS_EN_TX 0x0004
244 #define TCOPTS_EN_RX 0x0008
245
246 /* grspw_ic_ctrl() options:
247  * Corresponds code duplicatingly to GRSPW_CTRL_XX_BIT defines
248  */
249 #define ICOPTS_INTNUM (0x1f << 27)
250 #define ICOPTS_EN_SPWIRQ_ON_EE (1 << 24)
251 #define ICOPTS_EN_SPWIRQ_ON_IA (1 << 23)
252 #define ICOPTS_EN_PRIO (1 << 22)
253 #define ICOPTS_EN_TIMEOUTIRQ (1 << 20)
254 #define ICOPTS_EN_ACKIRQ (1 << 19)
255 #define ICOPTS_EN_TICKOUTIRQ (1 << 18)
256 #define ICOPTS_EN_RX (1 << 17)
257 #define ICOPTS_EN_TX (1 << 16)
258 #define ICOPTS_BASEIRQ (0x1f << 8)
259 #define ICOPTS_EN_FLAGFILTER (1 << 0) /* NOTE: Not in icctrl. CTRL.bit12 */
260
261 /* grspw_ic_rlisr() and grspw_ic_rlintack() */
262 #define ICRELOAD_EN (1 << 31)
263 #define ICRELOAD_MASK 0x7fffffff
264
265 /* grspw_rmap_ctrl() options */
266 #define RMAPOPTS_EN_RMAP 0x0001
267 #define RMAPOPTS_EN_BUF 0x0002
268
269 /* grspw_dma_config.flags options */
270 #define DMAFLAG_NO_SPILL 0x0001 /* See HW doc DMA-CTRL NS bit */
271 #define DMAFLAG_RESV1 0x0002 /* HAS NO EFFECT */
272 #define DMAFLAG_STRIP_ADR 0x0004 /* See HW doc DMA-CTRL SA bit */
273 #define DMAFLAG_STRIP_PID 0x0008 /* See HW doc DMA-CTRL SP bit */
274 #define DMAFLAG_RESV2 0x0010 /* HAS NO EFFECT */
275 #define DMAFLAG_MASK (DMAFLAG_NO_SPILL|DMAFLAG_STRIP_ADR|DMAFLAG_STRIP_PID)
276 /* grspw_dma_config.flags misc options (not shifted internally) */
277 #define DMAFLAG2_TXIE 0x00100000 /* See HW doc DMA-CTRL TI bit.
278  * Used to enable TX DMA interrupt
279  * when tx_irq_en_cnt=0.
280  */
281 #define DMAFLAG2_RXIE 0x00200000 /* See HW doc DMA-CTRL RI bit.
282  * Used to enable RX DMA interrupt
283  * when rx_irq_en_cnt=0.
284  */
285 /* Defines how the ISR will disable RX/TX DMA interrupt source when a DMA RX/TX
286  * interrupt has happended. DMA Error Interrupt always disables both RX/TX DMA
287  * interrupt. By default both RX/TX IRQs are disabled when either a RX, TX or
288  * both RX/TX DMA interrupt has been requested. The work-task, custom
289  * application handler or custom ISR handler is responsible to re-enable
290  * DMA interrupts.
291  */
292 #define DMAFLAG2_IRQD_SRC 0x01000000 /* Disable triggering RX/TX source */
293 #define DMAFLAG2_IRQD_NONE 0x00c00000 /* Never disable RX/TX IRQ in ISR */
294 #define DMAFLAG2_IRQD_BOTH 0x00000000 /* Always disable both RX/TX sources */
295 #define DMAFLAG2_IRQD_MASK 0x01c00000 /* Mask of options */
296 #define DMAFLAG2_IRQD_BIT 22
297
298 #define DMAFLAG2_MASK (DMAFLAG2_TXIE | DMAFLAG2_RXIE | DMAFLAG2_IRQD_MASK)
299
301  int flags; /* DMA config flags, see DMAFLAG1&2_* options */
302  int rxmaxlen; /* RX Max Packet Length */
303  int rx_irq_en_cnt; /* Enable RX IRQ every cnt descriptors */
304  int tx_irq_en_cnt; /* Enable TX IRQ every cnt descriptors */
305 };
306
307 /* Statistics per DMA channel */
309  /* IRQ Statistics */
310  int irq_cnt; /* Number of DMA IRQs generated by channel */
311
312  /* Descriptor Statistics */
313  int tx_pkts; /* Number of Transmitted packets */
314  int tx_err_link; /* Number of Transmitted packets with Link Error*/
315  int rx_pkts; /* Number of Received packets */
316  int rx_err_trunk; /* Number of Received Truncated packets */
317  int rx_err_endpkt; /* Number of Received packets with bad ending */
318
319  /* Diagnostics to help developers sizing their number buffers to avoid
320  * out-of-buffers or other phenomenons.
321  */
322  int send_cnt_min; /* Minimum number of packets in TX SEND Q */
323  int send_cnt_max; /* Maximum number of packets in TX SEND Q */
324  int tx_sched_cnt_min; /* Minimum number of packets in TX SCHED Q */
325  int tx_sched_cnt_max; /* Maximum number of packets in TX SCHED Q */
326  int sent_cnt_max; /* Maximum number of packets in TX SENT Q */
327  int tx_work_cnt; /* Times the work thread processed TX BDs */
328  int tx_work_enabled; /* No. RX BDs enabled by work thread */
329
330  int ready_cnt_min; /* Minimum number of packets in RX READY Q */
331  int ready_cnt_max; /* Maximum number of packets in RX READY Q */
332  int rx_sched_cnt_min; /* Minimum number of packets in RX SCHED Q */
333  int rx_sched_cnt_max; /* Maximum number of packets in RX SCHED Q */
334  int recv_cnt_max; /* Maximum number of packets in RX RECV Q */
335  int rx_work_cnt; /* Times the work thread processed RX BDs */
336  int rx_work_enabled; /* No. RX BDs enabled by work thread */
337 };
338
339 /* ISR message sending call back. Compatible with rtems_message_queue_send().
340  * The 'buf' parameter has a pointer to a WORK-TASK message defined by the
341  * WORK_* macros below. The message indicates what GRSPW device operations
342  * are pending, thus what caused the interrupt.
343  *
344  * \param data defined by grspw_work_config.msgisr_arg, default a rtems_id.
345  * \param buf Pointer to a 32-bit message word
346  * \param n Always 4 (byte size of buf).
347  */
348 typedef int (*grspw_msgqisr_t)(void *data, unsigned int *buf, unsigned int n);
349
350 /* Work message definitions, the int sent to *buf
351  * Bits 31..24: reserved.
352  * Bits 23..16: GRSPW device number message is associated with.
353  * Bit 15: reserved.
354  * Bit 14: work-task shall delete message queue on exit.
355  * Bit 13: work-task shall exit and delete itself.
356  * Bit 12: link error - shut down all DMA operations (stop DMA channels).
357  * Bit 11..8: Indicats DMA error on DMA channel 3..0.
358  * Bit 7..0: Indicats RX and/or TX packets completed on channel 3..0.
359  */
360 #define WORK_NONE 0
361 #define WORK_SHUTDOWN 0x1000 /* Signal shut down */
362 #define WORK_QUIT_TASK 0x2000 /* Work task shall exit (delete itself) */
363 #define WORK_FREE_MSGQ 0x4000 /* Delete MsgQ (valid when WORK_QUIT_TASK) */
364 #define WORK_DMA(chan, rxtx) (((rxtx) & 0x3) << ((chan) * 2))
365 #define WORK_DMA_TX(chan) WORK_DMA(chan, 1)
366 #define WORK_DMA_RX(chan) WORK_DMA(chan, 2)
367 #define WORK_DMA_ER(chan) (0x1 << ((chan) + 8))
368 #define WORK_DMA_MASK 0xfff /* max 4 channels all work */
369 #define WORK_DMA_TX_MASK 0x055 /* max 4 channels TX work */
370 #define WORK_DMA_RX_MASK 0x0aa /* max 4 channels RX work */
371 #define WORK_DMA_ER_MASK 0xf00 /* max 4 channels Error work */
372 #define WORK_DMA_CHAN_MASK(chan) (WORK_DMA_ER(chan) | WORK_DMA(chan, 0x3))
373 #define WORK_CORE_BIT 16
374 #define WORK_CORE_MASK 0x00ff0000
375 #define WORK_CORE(device) ((device) << WORK_CORE_BIT)
376
377 /* Message Q used to send messages to work task */
379  grspw_msgqisr_t msgisr;
380  void *msgisr_arg; /* example: rtems_id to Msg Q */
381 };
382
383 extern void grspw_initialize_user(
384  /* Callback every time a GRSPW device is found. Args: DeviceIndex */
385  void *(*devfound)(int),
386  /* Callback every time a GRSPW device is removed. Args:
387  * int = DeviceIndex
388  * void* = Return Value from devfound()
389  */
390  void (*devremove)(int,void*)
391  );
392
393 /* Creates a MsgQ (optional) and spawns a worker task associated with the
394  * message Q. The task can also be associated with a custom msgQ if *msgQ.
395  * is non-zero.
396  *
397  * \param prio Task priority, set to -1 for default.
398  * \param stack Task stack size, set to 0 for default.
399  * \param msgQ pMsgQ=NULL: illegal,
400  * pMsqQ==0: create new MsgQ with task and place in *pMsgQ,
401  * *pmsqQ!=0: pointer to MsgQ used for task.
402  * \param msgMax Maximum number of messages, set to 0 for default.
403  * \return 0 on failure, task id on success.
404  */
405 extern rtems_id grspw_work_spawn(int prio, int stack, rtems_id *pMsgQ, int msgMax);
406
407 /* Free task associated with message queue and optionally also the message
408  * queue itself. The message queue is deleted by the work task and is therefore
409  * delayed until it the work task resumes its execution.
410  */
411 extern rtems_status_code grspw_work_free(rtems_id msgQ, int freeMsgQ);
412
413 /* Configure a GRSPW device Work task and Message Q set up.
414  * This affects messages to:
415  * - DMA AHB error interrupt handling (mandatory)
416  * - Link status interrupt handling (optional)
417  * - RX DMA, defaults to common msgQ (configured per DMA channel)
418  */
419 extern void grspw_work_cfg(void *d, struct grspw_work_config *wc);
420
421 /* Work-task function, called only from the work task. The function is provided
422  * as a way for the user to create its own work tasks.
423  * The argument determines which message queue the task shall read its
424  * work jobs from.
425  *
426  * The messages are always 32-bit words and follows the format defined by the
427  * WORK_* macros above.
428  */
429 extern void grspw_work_func(rtems_id msgQ);
430
431 enum grspw_worktask_ev {
432  WORKTASK_EV_NONE = 0,
433  WORKTASK_EV_QUIT = 1,
434  WORKTASK_EV_SHUTDOWN = 2,
435  WORKTASK_EV_DMA_STOP = 3,
436 };
437
438 /* Weak function to let user override. Function called every time one of the
439  * events above is handled by the work-task. The message 'msg' is the current
440  * message being processed by the work-task.
441  * The user can for example add custom code to invoke on a DMA error, link
442  * error or monitor when the work-task exits after a call to grspw_work_free().
443  */
444 extern void grspw_work_event(enum grspw_worktask_ev ev, unsigned int msg);
445
446 #ifdef RTEMS_SMP
447 /* Set ISR interrupt affinity. The LEON IRQCtrl requires that the cpumask shall
448  * always have one bit set.
449  */
450 extern int grspw_isr_affinity(void *d, const cpu_set_t *cpus);
451 #endif
452
453 extern int grspw_dev_count(void);
454 extern void *grspw_open(int dev_no);
455 extern int grspw_close(void *d);
456 extern void grspw_hw_support(void *d, struct grspw_hw_sup *hw);
457 extern void grspw_stats_read(void *d, struct grspw_core_stats *sts);
458 extern void grspw_stats_clr(void *d);
459
460 /* Set and Read current node address configuration. The dma_nacfg[N] field
461  * represents the configuration for DMA Channel N.
462  *
463  * Set cfg->promiscous to -1 in order to only read current configuration.
464  */
465 extern void grspw_addr_ctrl(void *d, struct grspw_addr_config *cfg);
466
467 /*** Link Control interface ***/
468 /* Read Link State */
469 extern spw_link_state_t grspw_link_state(void *d);
470 /* options [in/out]: set to -1 to only read current config
471  *
472  * CLKDIV register contain:
473  * bits 7..0 : Clock Div RUN (only run-state)
474  * bits 15..8 : Clock Div During Startup (all link states except run-state)
475  */
476 extern void grspw_link_ctrl(void *d, int *options, int *stscfg, int *clkdiv);
477 /* Read the current value of the status register */
478 extern unsigned int grspw_link_status(void *d);
479 /* Clear bits in the status register */
480 extern void grspw_link_status_clr(void *d, unsigned int clearmask);
481
482 /*** Time Code Interface ***/
483 /* Generate Tick-In (increment Time Counter, Send Time Code) */
484 extern void grspw_tc_tx(void *d);
485 /* Control Timcode settings of core */
486 extern void grspw_tc_ctrl(void *d, int *options);
487 /* Assign ISR Function to TimeCode RX IRQ */
488 extern void grspw_tc_isr(void *d, void (*tcisr)(void *data, int tc), void *data);
489 /* Read/Write TCTRL and TIMECNT. Write if not -1, always read current value
490  * TCTRL = bits 7 and 6
491  * TIMECNT = bits 5 to 0
492  */
493 extern void grspw_tc_time(void *d, int *time);
494
495 /*** Interrupt-code Interface ***/
497  unsigned int tomask;
498  unsigned int aamask;
499  unsigned int scaler;
500  unsigned int isr_reload;
501  unsigned int ack_reload;
502 };
503 /* Function Interrupt-Code ISR callback prototype. Called when respective
504  * interrupt handling option has been enabled by grspw_ic_ctrl(), the
505  * arguments rxirq, rxack and intto are read from the registers of the
506  * GRSPW core read by the GRSPW ISR, they are individually valid only when
507  * repective handling been turned on.
508  *
509  * data - Custom data provided by user
510  * rxirq - Interrupt-Code Recevie register of the GRSPW core read by ISR
511  * (only defined if IQ bit enabled through grspw_ic_ctrl())
512  * rxack - Interrupt-Ack-Code Recevie register of the GRSPW core read by ISR
513  * (only defined if AQ bit enabled through grspw_ic_ctrl())
514  * intto - Interrupt Tick-out Recevie register of the GRSPW core read by ISR
515  * (only defined if TQ bit enabled through grspw_ic_ctrl())
516  */
517 typedef void (*spwpkt_ic_isr_t)(void *data, unsigned int rxirq,
518  unsigned int rxack, unsigned int intto);
519 /* Control Interrupt-code settings of core
520  * Write if 'options' not pointing to -1, always read current value
521  */
522 extern void grspw_ic_ctrl(void *d, unsigned int *options);
523 /* Write (rw&1 == 1) configuration parameters to registers and/or,
524  * Read (rw&2 == 1) configuration parameters from registers, in that sequence.
525  */
526 extern void grspw_ic_config(void *d, int rw, struct spwpkt_ic_config *cfg);
527 /* Read or Write Interrupt-code status registers.
528  * If pointer argument *ptr == 0 then only read, if *ptr != 0 then only write.
529  * If *ptr is NULL no operation.
530  */
531 extern void grspw_ic_sts(void *d, unsigned int *rxirq, unsigned int *rxack,
532  unsigned int *intto);
533 /* Generate Tick-In for the given Interrupt-code
534  * Returns zero on success and non-zero on failure
535  *
536  * Interrupt code bits (ic):
537  * Bit 5 - ACK if 1
538  * Bits 4-0 Interrupt-code number
539  */
540 extern int grspw_ic_tickin(void *d, int ic);
541 /* Assign handler function to Interrupt-code timeout IRQ */
542 extern void grspw_ic_isr(void *d, spwpkt_ic_isr_t handler, void *data);
543
544 /*** RMAP Control Interface ***/
545 /* Set (not -1) and/or read RMAP options. */
546 extern int grspw_rmap_ctrl(void *d, int *options, int *dstkey);
547 extern void grspw_rmap_support(void *d, char *rmap, char *rmap_crc);
548
549 /*** SpW Port Control Interface ***/
550
551 /* Select port, if
552  * -1=The current selected port is returned
553  * 0=Port 0
554  * 1=Port 1
555  * Other positive values=Both Port0 and Port1
556  */
557 extern int grspw_port_ctrl(void *d, int *port);
558 /* Returns Number ports available in hardware */
559 extern int grspw_port_count(void *d);
560 /* Returns the current active port */
561 extern int grspw_port_active(void *d);
562
563 /*** DMA Interface ***/
564 extern void *grspw_dma_open(void *d, int chan_no);
565 extern int grspw_dma_close(void *c);
566
567 extern int grspw_dma_start(void *c);
568 extern void grspw_dma_stop(void *c);
569
570 /* Enable interrupt manually */
571 extern unsigned int grspw_dma_enable_int(void *c, int rxtx, int force);
572
573 /* Return Current DMA Control & Status Register */
574 extern unsigned int grspw_dma_ctrlsts(void *c);
575
576 /* Schedule List of packets for transmission at some point in
577  * future.
578  *
579  * 1. Move transmitted packets to SENT List (SCHED->SENT)
580  * 2. Add the requested packets to the SEND List (USER->SEND)
581  * 3. Schedule as many packets as possible for transmission (SEND->SCHED)
582  *
583  * Call this function with pkts=NULL to just do step 1 and 3. This may be
584  * required in Polling-mode.
585  *
586  * The above steps 1 and 3 may be skipped by setting 'opts':
587  * bit0 = 1: Skip Step 1.
588  * bit1 = 1: Skip Step 3.
589  * Skipping both step 1 and 3 may be usefull when IRQ is enabled, then
590  * the work queue will be totaly responsible for handling descriptors.
591  *
592  * The fastest solution in retreiving sent TX packets and sending new frames
593  * is to call:
594  * A. grspw_dma_tx_reclaim(opts=0)
595  * B. grspw_dma_tx_send(opts=1)
596  *
597  * NOTE: the TXPKT_FLAG_TX flag must not be set.
598  *
599  * Return Code
600  * -1 Error
601  * 0 Successfully added pkts to send/sched list
602  * 1 DMA stopped. No operation.
603  */
604 extern int grspw_dma_tx_send(void *c, int opts, struct grspw_list *pkts, int count);
605
606 /* Reclaim TX packet buffers that has previously been scheduled for transmission
607  * with grspw_dma_tx_send().
608  *
609  * 1. Move transmitted packets to SENT List (SCHED->SENT)
610  * 2. Move all SENT List to pkts list (SENT->USER)
611  * 3. Schedule as many packets as possible for transmission (SEND->SCHED)
612  *
613  * The above steps 1 may be skipped by setting 'opts':
614  * bit0 = 1: Skip Step 1.
615  * bit1 = 1: Skip Step 3.
616  *
617  * The fastest solution in retreiving sent TX packets and sending new frames
618  * is to call:
619  * A. grspw_dma_tx_reclaim(opts=2) (Skip step 3)
620  * B. grspw_dma_tx_send(opts=1) (Skip step 1)
621  *
622  * Return Code
623  * -1 Error
624  * 0 Successful. pkts list filled with all packets from sent list
625  * 1 Same as 0, but indicates that DMA stopped
626  */
627 extern int grspw_dma_tx_reclaim(void *c, int opts, struct grspw_list *pkts, int *count);
628
629 /* Get current number of Packets in respective TX Queue. */
630 extern void grspw_dma_tx_count(void *c, int *send, int *sched, int *sent, int *hw);
631
632 #define GRSPW_OP_AND 0
633 #define GRSPW_OP_OR 1
634 /* Block until send_cnt or fewer packets are Queued in "Send and Scheduled" Q,
635  * op (AND or OR), sent_cnt or more packet "have been sent" (Sent Q) condition
636  * is met.
637  * If a link error occurs and the Stop on Link error is defined, this function
638  * will also return to caller.
639  * The timeout argument is used to return after timeout ticks, regardless of
640  * the other conditions. If timeout is zero, the function will wait forever
641  * until the condition is satisfied.
642  *
643  * NOTE: if IRQ of TX descriptors are not enabled conditions are never
644  * checked, this may hang infinitely unless a timeout has been specified
645  *
646  * Return Code
647  * -1 Error
648  * 0 Returing to caller because specified conditions are now fullfilled
649  * 1 DMA stopped
650  * 2 Timeout, conditions are not met
651  * 3 Another task is already waiting. Service is Busy.
652  */
653 extern int grspw_dma_tx_wait(void *c, int send_cnt, int op, int sent_cnt, int timeout);
654
655 /* Get received RX packet buffers that has previously been scheduled for
656  * reception with grspw_dma_rx_prepare().
657  *
658  * 1. Move Scheduled packets to RECV List (SCHED->RECV)
659  * 2. Move all RECV packet to the callers list (RECV->USER)
660  * 3. Schedule as many free packet buffers as possible (READY->SCHED)
661  *
662  * The above steps 1 may be skipped by setting 'opts':
663  * bit0 = 1: Skip Step 1.
664  * bit1 = 1: Skip Step 3.
665  *
666  * The fastest solution in retreiving received RX packets and preparing new
667  * packet buffers for future receive, is to call:
668  * A. grspw_dma_rx_recv(opts=2, &recvlist) (Skip step 3)
669  * B. grspw_dma_rx_prepare(opts=1, &freelist) (Skip step 1)
670  *
671  * Return Code
672  * -1 Error
673  * 0 Successfully filled pkts list with packets from recv list.
674  * 1 DMA stopped
675  */
676 extern int grspw_dma_rx_recv(void *c, int opts, struct grspw_list *pkts, int *count);
677
678 /* Add more RX packet buffers for future for reception. The received packets
679  * can later be read out with grspw_dma_rx_recv().
680  *
681  * 1. Move Received packets to RECV List (SCHED->RECV)
682  * 2. Add the "free/ready" packet buffers to the READY List (USER->READY)
683  * 3. Schedule as many packets as possible (READY->SCHED)
684  *
685  * The above steps 1 may be skipped by setting 'opts':
686  * bit0 = 1: Skip Step 1.
687  * bit1 = 1: Skip Step 3.
688  *
689  * The fastest solution in retreiving received RX packets and preparing new
690  * packet buffers for future receive, is to call:
691  * A. grspw_dma_rx_recv(opts=2, &recvlist) (Skip step 3)
692  * B. grspw_dma_rx_prepare(opts=1, &freelist) (Skip step 1)
693  *
694  * Return Code
695  * -1 Error
696  * 0 Successfully added packet buffers from pkt list into the ready queue
697  * 1 DMA stopped
698  */
699 extern int grspw_dma_rx_prepare(void *c, int opts, struct grspw_list *pkts, int count);
700
701 /* Get current number of Packets in respective RX Queue. */
702 extern void grspw_dma_rx_count(void *c, int *ready, int *sched, int *recv, int *hw);
703
704 /* Block until recv_cnt or more packets are Queued in RECV Q, op (AND or OR),
705  * ready_cnt or fewer packet buffers are available in the "READY and Scheduled" Q,
706  * condition is met.
707  * If a link error occurs and the Stop on Link error is defined, this function
708  * will also return to caller, however with an error.
709  * The timeout argument is used to return after timeout ticks, regardless of
710  * the other conditions. If timeout is zero, the function will wait forever
711  * until the condition is satisfied.
712  *
713  * NOTE: if IRQ of RX descriptors are not enabled conditions are never
714  * checked, this may hang infinitely unless a timeout has been specified
715  *
716  * Return Code
717  * -1 Error
718  * 0 Returing to caller because specified conditions are now fullfilled
719  * 1 DMA stopped
720  * 2 Timeout, conditions are not met
721  * 3 Another task is already waiting. Service is Busy.
722  */
723 extern int grspw_dma_rx_wait(void *c, int recv_cnt, int op, int ready_cnt, int timeout);
724
725 extern int grspw_dma_config(void *c, struct grspw_dma_config *cfg);
726 extern void grspw_dma_config_read(void *c, struct grspw_dma_config *cfg);
727
728 extern void grspw_dma_stats_read(void *c, struct grspw_dma_stats *sts);
729 extern void grspw_dma_stats_clr(void *c);
730
731 /* Register GRSPW packet driver to Driver Manager */
732 void grspw2_register_drv (void);
733
734 /*** GRSPW SpaceWire Packet List Handling Routines ***/
735
736 static inline void grspw_list_clr(struct grspw_list *list)
737 {
738  list->head = NULL;
739  list->tail = NULL;
740 }
741
742 static inline int grspw_list_is_empty(struct grspw_list *list)
743 {
744  return (list->head == NULL);
745 }
746
747 /* Return Number of entries in list */
748 static inline int grspw_list_cnt(struct grspw_list *list)
749 {
750  struct grspw_pkt *lastpkt = NULL, *pkt = list->head;
751  int cnt = 0;
752  while ( pkt ) {
753  cnt++;
754  lastpkt = pkt;
755  pkt = pkt->next;
756  }
757  if ( lastpkt && (list->tail != lastpkt) )
758  return -1;
759  return cnt;
760 }
761
762 static inline void
763 grspw_list_append(struct grspw_list *list, struct grspw_pkt *pkt)
764 {
765  pkt->next = NULL;
766  if ( list->tail == NULL ) {
767  list->head = pkt;
768  } else {
769  list->tail->next = pkt;
770  }
771  list->tail = pkt;
772 }
773
774 static inline void
775 grspw_list_prepend(struct grspw_list *list, struct grspw_pkt *pkt)
776 {
777  pkt->next = list->head;
778  if ( list->head == NULL ) {
779  list->tail = pkt;
780  }
781  list->head = pkt;
782 }
783
784 static inline void
785 grspw_list_append_list(struct grspw_list *list, struct grspw_list *alist)
786 {
787  if (grspw_list_is_empty(alist)) {
788  return;
789  }
790  alist->tail->next = NULL;
791  if ( list->tail == NULL ) {
792  list->head = alist->head;
793  } else {
794  list->tail->next = alist->head;
795  }
796  list->tail = alist->tail;
797 }
798
799 static inline void
800 grspw_list_prepend_list(struct grspw_list *list, struct grspw_list *alist)
801 {
802  if (grspw_list_is_empty(alist)) {
803  return;
804  }
805  if ( list->head == NULL ) {
806  list->tail = alist->tail;
807  alist->tail->next = NULL;
808  } else {
809  alist->tail->next = list->head;
810  }
811  list->head = alist->head;
812 }
813
814 /* Remove dlist (delete-list) from head of list */
815 static inline void
816 grspw_list_remove_head_list(struct grspw_list *list, struct grspw_list *dlist)
817 {
818  if (grspw_list_is_empty(dlist)) {
819  return;
820  }
821  list->head = dlist->tail->next;
822  if ( list->head == NULL ) {
823  list->tail = NULL;
824  }
825  dlist->tail->next = NULL;
826 }
827
828 /* Take A number of entries from head of list 'list' and put the entires
829  * to rlist (result list).
830  */
831 static inline int
832 grspw_list_take_head_list(struct grspw_list *list, struct grspw_list *rlist, int max)
833 {
834  int cnt;
835  struct grspw_pkt *pkt, *last;
836
837  pkt = list->head;
838
839  if ( (max < 1) || (pkt == NULL) ) {
840  grspw_list_clr(rlist);
841  return 0;
842  }
843
844  cnt = 0;
845  rlist->head = pkt;
846  last = pkt;
847  while ((cnt < max) && pkt) {
848  last = pkt;
849  pkt = pkt->next;
850  cnt++;
851  }
852  rlist->tail = last;
853  grspw_list_remove_head_list(list, rlist);
854  return cnt;
855 }
856
857 #endif
Definition: grspw_pkt.h:496
Definition: grspw_pkt.h:308
Definition: grspw_pkt.h:177
rtems_status_code
Classic API Status.
Definition: status.h:43
Definition: grspw_pkt.h:159
Definition: grspw_pkt.h:131
Definition: b1553brm.c:75
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
Definition: grspw_pkt.h:378
Definition: grspw_pkt.h:143
Definition: grspw_pkt.h:300
Definition: grspw_pkt.h:193
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
