RTEMS
5.1
Definition of the interface between the stub and gdb,. More...
Files | |
file | gdb_if.h |
definition of the interface between the stub and gdb | |
struct | rtems_gdb_stub_thread_info |
#define | QM_MAX_THREADS (20) |
Max number of threads in qM response. | |
#define | LM32_EXCEPTION_RESET 0x0 |
Exception IDs. | |
#define | LM32_EXCEPTION_INST_BREAKPOINT 0x1 |
#define | LM32_EXCEPTION_INST_BUS_ERROR 0x2 |
#define | LM32_EXCEPTION_DATA_BREAKPOINT 0x3 |
#define | LM32_EXCEPTION_DATA_BUS_ERROR 0x4 |
#define | LM32_EXCEPTION_DIVIDE_BY_ZERO 0x5 |
#define | LM32_EXCEPTION_INTERRUPT 0x6 |
#define | LM32_EXCEPTION_SYSTEM_CALL 0x7 |
#define | LM32_BREAK 0xac000002UL |
Breakpoint instruction. | |
Enumerations | |
enum | lm32_regnames { LM32_REG_R0, LM32_REG_R1, LM32_REG_R2, LM32_REG_R3, LM32_REG_R4, LM32_REG_R5, LM32_REG_R6, LM32_REG_R7, LM32_REG_R8, LM32_REG_R9, LM32_REG_R10, LM32_REG_R11, LM32_REG_R12, LM32_REG_R13, LM32_REG_R14, LM32_REG_R15, LM32_REG_R16, LM32_REG_R17, LM32_REG_R18, LM32_REG_R19, LM32_REG_R20, LM32_REG_R21, LM32_REG_R22, LM32_REG_R23, LM32_REG_R24, LM32_REG_R25, LM32_REG_GP, LM32_REG_FP, LM32_REG_SP, LM32_REG_RA, LM32_REG_EA, LM32_REG_BA, LM32_REG_PC, LM32_REG_EID, LM32_REG_EBA, LM32_REG_DEBA, LM32_REG_IE, NUM_REGS } |
This numbering must be consistant with GDBs numbering in gdb/lm32-tdep.c. | |
enum | lm32_int_regnames { LM32_INT_REG_R1, LM32_INT_REG_R2, LM32_INT_REG_R3, LM32_INT_REG_R4, LM32_INT_REG_R5, LM32_INT_REG_R6, LM32_INT_REG_R7, LM32_INT_REG_R8, LM32_INT_REG_R9, LM32_INT_REG_R10, LM32_INT_REG_RA, LM32_INT_REG_EA, LM32_INT_REG_BA, LM32_INT_REG_R11, LM32_INT_REG_R12, LM32_INT_REG_R13, LM32_INT_REG_R14, LM32_INT_REG_R15, LM32_INT_REG_R16, LM32_INT_REG_R17, LM32_INT_REG_R18, LM32_INT_REG_R19, LM32_INT_REG_R20, LM32_INT_REG_R21, LM32_INT_REG_R22, LM32_INT_REG_R23, LM32_INT_REG_R24, LM32_INT_REG_R25, LM32_INT_REG_GP, LM32_INT_REG_FP, LM32_INT_REG_SP, LM32_INT_REG_PC, LM32_INT_REG_EID, LM32_INT_REG_EBA, LM32_INT_REG_DEBA, LM32_INT_REG_IE } |
int | parse_zbreak (const char *in, int *type, unsigned char **addr, int *len) |
char * | mem2hstr (char *buf, const unsigned char *mem, int count) |
int | hstr2mem (unsigned char *mem, const char *buf, int count) |
void | set_mem_err (void) |
unsigned char | get_byte (const unsigned char *ptr) |
void | set_byte (unsigned char *ptr, int val) |
char * | thread2vhstr (char *buf, int thread) |
char * | thread2fhstr (char *buf, int thread) |
const char * | fhstr2thread (const char *buf, int *thread) |
const char * | vhstr2thread (const char *buf, int *thread) |
char * | int2fhstr (char *buf, int val) |
char * | int2vhstr (char *buf, int vali) |
const char * | fhstr2int (const char *buf, int *ival) |
const char * | vhstr2int (const char *buf, int *ival) |
int | hstr2byte (const char *buf, int *bval) |
int | hstr2nibble (const char *buf, int *nibble) |
Thread_Control * | rtems_gdb_index_to_stub_id (int) |
int | rtems_gdb_stub_thread_support_ok (void) |
int | rtems_gdb_stub_get_current_thread (void) |
int | rtems_gdb_stub_get_next_thread (int) |
int | rtems_gdb_stub_get_offsets (unsigned char **text_addr, unsigned char **data_addr, unsigned char **bss_addr) |
int | rtems_gdb_stub_get_thread_regs (int thread, unsigned int *registers) |
int | rtems_gdb_stub_set_thread_regs (int thread, unsigned int *registers) |
void | rtems_gdb_process_query (char *inbuffer, char *outbuffer, int do_threads, int thread) |
