#define | EP7312_PADR ((volatile uint8_t*)(EP7312_REG_BASE + 0x0000)) |
#define | EP7312_PBDR ((volatile uint8_t*)(EP7312_REG_BASE + 0x0001)) |
#define | EP7312_PDDR ((volatile uint8_t*)(EP7312_REG_BASE + 0x0003)) |
#define | EP7312_PADDR ((volatile uint8_t*)(EP7312_REG_BASE + 0x0040)) |
#define | EP7312_PBDDR ((volatile uint8_t*)(EP7312_REG_BASE + 0x0041)) |
#define | EP7312_PDDDR ((volatile uint8_t*)(EP7312_REG_BASE + 0x0043)) |
#define | EP7312_PEDR ((volatile uint8_t*)(EP7312_REG_BASE + 0x0080)) |
#define | EP7312_PEDDR ((volatile uint8_t*)(EP7312_REG_BASE + 0x00C0)) |
#define | EP7312_SYSCON1 ((volatile uint32_t*)(EP7312_REG_BASE + 0x0100)) |
#define | EP7312_SYSFLG1 ((volatile uint32_t*)(EP7312_REG_BASE + 0x0140)) |
#define | EP7312_MEMCFG1 ((volatile uint32_t*)(EP7312_REG_BASE + 0x0180)) |
#define | EP7312_MEMCFG2 ((volatile uint32_t*)(EP7312_REG_BASE + 0x01C0)) |
#define | EP7312_INTSR1 ((volatile uint32_t*)(EP7312_REG_BASE + 0x0240)) |
#define | EP7312_INTMR1 ((volatile uint32_t*)(EP7312_REG_BASE + 0x0280)) |
#define | EP7312_LCDCON ((volatile uint32_t*)(EP7312_REG_BASE + 0x02C0)) |
#define | EP7312_TC1D ((volatile uint32_t*)(EP7312_REG_BASE + 0x0300)) |
#define | EP7312_TC2D ((volatile uint32_t*)(EP7312_REG_BASE + 0x0340)) |
#define | EP7312_RTCDR ((volatile uint32_t*)(EP7312_REG_BASE + 0x0380)) |
#define | EP7312_RTCMR ((volatile uint32_t*)(EP7312_REG_BASE + 0x03C0)) |
#define | EP7312_PMPCON ((volatile uint32_t*)(EP7312_REG_BASE + 0x0400)) |
#define | EP7312_CODR ((volatile uint8_t*)(EP7312_REG_BASE + 0x0440)) |
#define | EP7312_UARTDR1 ((volatile uint32_t*)(EP7312_REG_BASE + 0x0480)) |
#define | EP7312_UARTCR1 ((volatile uint32_t*)(EP7312_REG_BASE + 0x04C0)) |
#define | EP7312_SYNCIO ((volatile uint32_t*)(EP7312_REG_BASE + 0x0500)) |
#define | EP7312_PALLSW ((volatile uint32_t*)(EP7312_REG_BASE + 0x0540)) |
#define | EP7312_PALMSW ((volatile uint32_t*)(EP7312_REG_BASE + 0x0580)) |
#define | EP7312_STFCLR ((volatile uint32_t*)(EP7312_REG_BASE + 0x05C0)) |
#define | EP7312_BLEOI ((volatile uint32_t*)(EP7312_REG_BASE + 0x0600)) |
#define | EP7312_MCEOI ((volatile uint32_t*)(EP7312_REG_BASE + 0x0640)) |
#define | EP7312_TEOI ((volatile uint32_t*)(EP7312_REG_BASE + 0x0680)) |
#define | EP7312_TC1EOI ((volatile uint32_t*)(EP7312_REG_BASE + 0x06C0)) |
#define | EP7312_TC2EOI ((volatile uint32_t*)(EP7312_REG_BASE + 0x0700)) |
#define | EP7312_RTCEOI ((volatile uint32_t*)(EP7312_REG_BASE + 0x0740)) |
#define | EP7312_UMSEOI ((volatile uint32_t*)(EP7312_REG_BASE + 0x0780)) |
#define | EP7312_COEOI ((volatile uint32_t*)(EP7312_REG_BASE + 0x07C0)) |
#define | EP7312_HALT ((volatile uint32_t*)(EP7312_REG_BASE + 0x0800)) |
#define | EP7312_STDBY ((volatile uint32_t*)(EP7312_REG_BASE + 0x0840)) |
#define | EP7312_FBADDR ((volatile uint8_t*)(EP7312_REG_BASE + 0x1000)) |
#define | EP7312_SYSCON2 ((volatile uint32_t*)(EP7312_REG_BASE + 0x1100)) |
#define | EP7312_SYSFLG2 ((volatile uint32_t*)(EP7312_REG_BASE + 0x1140)) |
#define | EP7312_INTSR2 ((volatile uint32_t*)(EP7312_REG_BASE + 0x1240)) |
#define | EP7312_INTMR2 ((volatile uint32_t*)(EP7312_REG_BASE + 0x1280)) |
#define | EP7312_UARTDR2 ((volatile uint32_t*)(EP7312_REG_BASE + 0x1480)) |
#define | EP7312_UARTCR2 ((volatile uint32_t*)(EP7312_REG_BASE + 0x14C0)) |
#define | EP7312_SS2DR ((volatile uint32_t*)(EP7312_REG_BASE + 0x1500)) |
#define | EP7312_SRXEOF ((volatile uint32_t*)(EP7312_REG_BASE + 0x1600)) |
#define | EP7312_SS2POP ((volatile uint32_t*)(EP7312_REG_BASE + 0x16C0)) |
#define | EP7312_KBDEOI ((volatile uint32_t*)(EP7312_REG_BASE + 0x1700)) |
#define | EP7312_DAIR ((volatile uint32_t*)(EP7312_REG_BASE + 0x2000)) |
#define | EP7312_DAIDR0 ((volatile uint32_t*)(EP7312_REG_BASE + 0x2040)) |
#define | EP7312_DAIDR1 ((volatile uint32_t*)(EP7312_REG_BASE + 0x2080)) |
#define | EP7312_DAIDR2 ((volatile uint32_t*)(EP7312_REG_BASE + 0x20C0)) |
#define | EP7312_DAISR ((volatile uint32_t*)(EP7312_REG_BASE + 0x2100)) |
#define | EP7312_SYSCON3 ((volatile uint32_t*)(EP7312_REG_BASE + 0x2200)) |
#define | EP7312_INTSR3 ((volatile uint32_t*)(EP7312_REG_BASE + 0x2240)) |
#define | EP7312_INTMR3 ((volatile uint8_t*)(EP7312_REG_BASE + 0x2280)) |
#define | EP7312_LEDFLSH ((volatile uint8_t*)(EP7312_REG_BASE + 0x22C0)) |
#define | EP7312_SDCONF ((volatile uint32_t*)(EP7312_REG_BASE + 0x2300)) |
#define | EP7312_SDRFPR ((volatile uint32_t*)(EP7312_REG_BASE + 0x2340)) |
#define | EP7312_UNIQID ((volatile uint32_t*)(EP7312_REG_BASE + 0x2440)) |
#define | EP7312_DAI64Fs ((volatile uint32_t*)(EP7312_REG_BASE + 0x2600)) |
#define | EP7312_PLLW ((volatile uint8_t*)(EP7312_REG_BASE + 0x2610)) |
#define | EP7312_PLLR ((volatile uint8_t*)(EP7312_REG_BASE + 0xA5A8)) |
#define | EP7312_RANDID0 ((volatile uint32_t*)(EP7312_REG_BASE + 0x2700)) |
#define | EP7312_RANDID1 ((volatile uint32_t*)(EP7312_REG_BASE + 0x2704)) |
#define | EP7312_RANDID2 ((volatile uint32_t*)(EP7312_REG_BASE + 0x2708)) |
#define | EP7312_RANDID3 ((volatile uint32_t*)(EP7312_REG_BASE + 0x270C)) |
#define | EP7312_INTR1_EXTFIQ 0x00000001 |
#define | EP7312_INTR1_BLINT 0x00000002 |
#define | EP7312_INTR1_WEINT 0x00000004 |
#define | EP7312_INTR1_MCINT 0x00000008 |
#define | EP7312_INTR1_CSINT 0x00000010 |
#define | EP7312_INTR1_EINT1 0x00000020 |
#define | EP7312_INTR1_EINT2 0x00000040 |
#define | EP7312_INTR1_EINT3 0x00000080 |
#define | EP7312_INTR1_TC1OI 0x00000100 |
#define | EP7312_INTR1_TC2OI 0x00000200 |
#define | EP7312_INTR1_RTCMI 0x00000400 |
#define | EP7312_INTR1_TINT 0x00000800 |
#define | EP7312_INTR1_URXINT1 0x00001000 |
#define | EP7312_INTR1_UTXINT1 0x00002000 |
#define | EP7312_INTR1_UMSINT 0x00004000 |
#define | EP7312_INTR1_SSEOTI 0x00008000 |
Cirrus EP7312 Register Definitions.
