RTEMS  5.1
ep7312.h File Reference
Register declarations. More...
#define EP7312_REG_BASE   0x80000000
#define EP7312_PADR   ((volatile uint8_t*)(EP7312_REG_BASE + 0x0000))
#define EP7312_PBDR   ((volatile uint8_t*)(EP7312_REG_BASE + 0x0001))
#define EP7312_PDDR   ((volatile uint8_t*)(EP7312_REG_BASE + 0x0003))
#define EP7312_PADDR   ((volatile uint8_t*)(EP7312_REG_BASE + 0x0040))
#define EP7312_PBDDR   ((volatile uint8_t*)(EP7312_REG_BASE + 0x0041))
#define EP7312_PDDDR   ((volatile uint8_t*)(EP7312_REG_BASE + 0x0043))
#define EP7312_PEDR   ((volatile uint8_t*)(EP7312_REG_BASE + 0x0080))
#define EP7312_PEDDR   ((volatile uint8_t*)(EP7312_REG_BASE + 0x00C0))
#define EP7312_SYSCON1   ((volatile uint32_t*)(EP7312_REG_BASE + 0x0100))
#define EP7312_SYSFLG1   ((volatile uint32_t*)(EP7312_REG_BASE + 0x0140))
#define EP7312_MEMCFG1   ((volatile uint32_t*)(EP7312_REG_BASE + 0x0180))
#define EP7312_MEMCFG2   ((volatile uint32_t*)(EP7312_REG_BASE + 0x01C0))
#define EP7312_INTSR1   ((volatile uint32_t*)(EP7312_REG_BASE + 0x0240))
#define EP7312_INTMR1   ((volatile uint32_t*)(EP7312_REG_BASE + 0x0280))
#define EP7312_LCDCON   ((volatile uint32_t*)(EP7312_REG_BASE + 0x02C0))
#define EP7312_TC1D   ((volatile uint32_t*)(EP7312_REG_BASE + 0x0300))
#define EP7312_TC2D   ((volatile uint32_t*)(EP7312_REG_BASE + 0x0340))
#define EP7312_RTCDR   ((volatile uint32_t*)(EP7312_REG_BASE + 0x0380))
#define EP7312_RTCMR   ((volatile uint32_t*)(EP7312_REG_BASE + 0x03C0))
#define EP7312_PMPCON   ((volatile uint32_t*)(EP7312_REG_BASE + 0x0400))
#define EP7312_CODR   ((volatile uint8_t*)(EP7312_REG_BASE + 0x0440))
#define EP7312_UARTDR1   ((volatile uint32_t*)(EP7312_REG_BASE + 0x0480))
#define EP7312_UARTCR1   ((volatile uint32_t*)(EP7312_REG_BASE + 0x04C0))
#define EP7312_SYNCIO   ((volatile uint32_t*)(EP7312_REG_BASE + 0x0500))
#define EP7312_PALLSW   ((volatile uint32_t*)(EP7312_REG_BASE + 0x0540))
#define EP7312_PALMSW   ((volatile uint32_t*)(EP7312_REG_BASE + 0x0580))
#define EP7312_STFCLR   ((volatile uint32_t*)(EP7312_REG_BASE + 0x05C0))
#define EP7312_BLEOI   ((volatile uint32_t*)(EP7312_REG_BASE + 0x0600))
#define EP7312_MCEOI   ((volatile uint32_t*)(EP7312_REG_BASE + 0x0640))
#define EP7312_TEOI   ((volatile uint32_t*)(EP7312_REG_BASE + 0x0680))
#define EP7312_TC1EOI   ((volatile uint32_t*)(EP7312_REG_BASE + 0x06C0))
#define EP7312_TC2EOI   ((volatile uint32_t*)(EP7312_REG_BASE + 0x0700))
#define EP7312_RTCEOI   ((volatile uint32_t*)(EP7312_REG_BASE + 0x0740))
#define EP7312_UMSEOI   ((volatile uint32_t*)(EP7312_REG_BASE + 0x0780))
#define EP7312_COEOI   ((volatile uint32_t*)(EP7312_REG_BASE + 0x07C0))
#define EP7312_HALT   ((volatile uint32_t*)(EP7312_REG_BASE + 0x0800))
#define EP7312_STDBY   ((volatile uint32_t*)(EP7312_REG_BASE + 0x0840))
#define EP7312_FBADDR   ((volatile uint8_t*)(EP7312_REG_BASE + 0x1000))
#define EP7312_SYSCON2   ((volatile uint32_t*)(EP7312_REG_BASE + 0x1100))
#define EP7312_SYSFLG2   ((volatile uint32_t*)(EP7312_REG_BASE + 0x1140))
#define EP7312_INTSR2   ((volatile uint32_t*)(EP7312_REG_BASE + 0x1240))
#define EP7312_INTMR2   ((volatile uint32_t*)(EP7312_REG_BASE + 0x1280))
#define EP7312_UARTDR2   ((volatile uint32_t*)(EP7312_REG_BASE + 0x1480))
#define EP7312_UARTCR2   ((volatile uint32_t*)(EP7312_REG_BASE + 0x14C0))
#define EP7312_SS2DR   ((volatile uint32_t*)(EP7312_REG_BASE + 0x1500))
#define EP7312_SRXEOF   ((volatile uint32_t*)(EP7312_REG_BASE + 0x1600))
#define EP7312_SS2POP   ((volatile uint32_t*)(EP7312_REG_BASE + 0x16C0))
#define EP7312_KBDEOI   ((volatile uint32_t*)(EP7312_REG_BASE + 0x1700))
#define EP7312_DAIR   ((volatile uint32_t*)(EP7312_REG_BASE + 0x2000))
#define EP7312_DAIDR0   ((volatile uint32_t*)(EP7312_REG_BASE + 0x2040))
#define EP7312_DAIDR1   ((volatile uint32_t*)(EP7312_REG_BASE + 0x2080))
#define EP7312_DAIDR2   ((volatile uint32_t*)(EP7312_REG_BASE + 0x20C0))
#define EP7312_DAISR   ((volatile uint32_t*)(EP7312_REG_BASE + 0x2100))
#define EP7312_SYSCON3   ((volatile uint32_t*)(EP7312_REG_BASE + 0x2200))
#define EP7312_INTSR3   ((volatile uint32_t*)(EP7312_REG_BASE + 0x2240))
#define EP7312_INTMR3   ((volatile uint8_t*)(EP7312_REG_BASE + 0x2280))
#define EP7312_LEDFLSH   ((volatile uint8_t*)(EP7312_REG_BASE + 0x22C0))
#define EP7312_SDCONF   ((volatile uint32_t*)(EP7312_REG_BASE + 0x2300))
#define EP7312_SDRFPR   ((volatile uint32_t*)(EP7312_REG_BASE + 0x2340))
#define EP7312_UNIQID   ((volatile uint32_t*)(EP7312_REG_BASE + 0x2440))
#define EP7312_DAI64Fs   ((volatile uint32_t*)(EP7312_REG_BASE + 0x2600))
#define EP7312_PLLW   ((volatile uint8_t*)(EP7312_REG_BASE + 0x2610))
#define EP7312_PLLR   ((volatile uint8_t*)(EP7312_REG_BASE + 0xA5A8))
#define EP7312_RANDID0   ((volatile uint32_t*)(EP7312_REG_BASE + 0x2700))
#define EP7312_RANDID1   ((volatile uint32_t*)(EP7312_REG_BASE + 0x2704))
#define EP7312_RANDID2   ((volatile uint32_t*)(EP7312_REG_BASE + 0x2708))
#define EP7312_RANDID3   ((volatile uint32_t*)(EP7312_REG_BASE + 0x270C))
BITS in UBRLCR1
#define EP7312_UART_WRDLEN5   0x00000000
#define EP7312_UART_WRDLEN6   0x00020000
#define EP7312_UART_WRDLEN7   0x00040000
#define EP7312_UART_WRDLEN8   0x00060000
#define EP7312_UART_FIFOEN   0x00010000
#define EP7312_UART_XSTOP   0x00008000
#define EP7312_UART_EVENPRT   0x00004000
#define EP7312_UART_PRTEN   0x00002000
#define EP7312_UART_BREAK   0x00001000
BITS in INTSR1
#define EP7312_UART_UTXINT1   0x00002000
#define EP7312_UART_URXINT1   0x00001000
BITS in UARTTDR1
#define EP7312_UART_FRMERR   0x00000100
#define EP7312_UART_PARERR   0x00000200
#define EP7312_UART_OVERR   0x00000400
BITS in system status flag register 1
#define EP7312_UART_UBUSY1   0x00000800
#define EP7312_UART_URXFE1   0x00400000
#define EP7312_UART_UTXFF1   0x00800000
BITS in SYSCON1
#define EP7312_SYSCON1_UART1EN   0x00000100
#define EP7312_SYSCON1_TC1_PRESCALE   0x00000010
#define EP7312_SYSCON1_TC1_512KHZ   0x00000020
#define EP7312_SYSCON1_TC2_PRESCALE   0x00000040
#define EP7312_SYSCON1_TC2_512KHZ   0x00000080
INTR1 (Interrupt 1) mask/status register bits
#define EP7312_INTR1_EXTFIQ   0x00000001
#define EP7312_INTR1_BLINT   0x00000002
#define EP7312_INTR1_WEINT   0x00000004
#define EP7312_INTR1_MCINT   0x00000008
#define EP7312_INTR1_CSINT   0x00000010
#define EP7312_INTR1_EINT1   0x00000020
#define EP7312_INTR1_EINT2   0x00000040
#define EP7312_INTR1_EINT3   0x00000080
#define EP7312_INTR1_TC1OI   0x00000100
#define EP7312_INTR1_TC2OI   0x00000200
#define EP7312_INTR1_RTCMI   0x00000400
#define EP7312_INTR1_TINT   0x00000800
#define EP7312_INTR1_URXINT1   0x00001000
#define EP7312_INTR1_UTXINT1   0x00002000
#define EP7312_INTR1_UMSINT   0x00004000
#define EP7312_INTR1_SSEOTI   0x00008000
INTR2 (Interrupt 2) mask/status register bits
#define EP7312_INTR2_KBDINT   0x00000001
#define EP7312_INTR2_SS2RX   0x00000002
#define EP7312_INTR2_SS2TX   0x00000004
#define EP7312_INTR2_URXINT2   0x00001000
#define EP7312_INTR2_UTXINT2   0x00002000
INTR3 (Interrupt 3) mask/status register bits
#define EP7312_INTR2_DAIINT   0x00000001
