RTEMS  5.1
Data Structures | Macros
struct  GmacSa
 GmacSa hardware registers. More...
struct  GmacSt2Compare
 GmacSt2Compare hardware registers. More...
struct  Gmac
#define GMACSA_NUMBER   4
 Gmac hardware registers.
#define GMACST2COMPARE_NUMBER   24
#define GMAC_NCR_LBL   (0x1u << 1)
 (GMAC_NCR) Loop Back Local
#define GMAC_NCR_RXEN   (0x1u << 2)
 (GMAC_NCR) Receive Enable
#define GMAC_NCR_TXEN   (0x1u << 3)
 (GMAC_NCR) Transmit Enable
#define GMAC_NCR_MPE   (0x1u << 4)
 (GMAC_NCR) Management Port Enable
#define GMAC_NCR_CLRSTAT   (0x1u << 5)
 (GMAC_NCR) Clear Statistics Registers
#define GMAC_NCR_INCSTAT   (0x1u << 6)
 (GMAC_NCR) Increment Statistics Registers
#define GMAC_NCR_WESTAT   (0x1u << 7)
 (GMAC_NCR) Write Enable for Statistics Registers
#define GMAC_NCR_BP   (0x1u << 8)
 (GMAC_NCR) Back pressure
#define GMAC_NCR_TSTART   (0x1u << 9)
 (GMAC_NCR) Start Transmission
#define GMAC_NCR_THALT   (0x1u << 10)
 (GMAC_NCR) Transmit Halt
#define GMAC_NCR_TXPF   (0x1u << 11)
 (GMAC_NCR) Transmit Pause Frame
#define GMAC_NCR_TXZQPF   (0x1u << 12)
 (GMAC_NCR) Transmit Zero Quantum Pause Frame
#define GMAC_NCR_SRTSM   (0x1u << 15)
 (GMAC_NCR) Store Receive Time Stamp to Memory
#define GMAC_NCR_ENPBPR   (0x1u << 16)
 (GMAC_NCR) Enable PFC Priority-based Pause Reception
#define GMAC_NCR_TXPBPF   (0x1u << 17)
 (GMAC_NCR) Transmit PFC Priority-based Pause Frame
#define GMAC_NCR_FNP   (0x1u << 18)
 (GMAC_NCR) Flush Next Packet
#define GMAC_NCFGR_SPD   (0x1u << 0)
 (GMAC_NCFGR) Speed
#define GMAC_NCFGR_FD   (0x1u << 1)
 (GMAC_NCFGR) Full Duplex
#define GMAC_NCFGR_DNVLAN   (0x1u << 2)
 (GMAC_NCFGR) Discard Non-VLAN FRAMES
#define GMAC_NCFGR_JFRAME   (0x1u << 3)
 (GMAC_NCFGR) Jumbo Frame Size
#define GMAC_NCFGR_CAF   (0x1u << 4)
 (GMAC_NCFGR) Copy All Frames
#define GMAC_NCFGR_NBC   (0x1u << 5)
 (GMAC_NCFGR) No Broadcast
#define GMAC_NCFGR_MTIHEN   (0x1u << 6)
 (GMAC_NCFGR) Multicast Hash Enable
#define GMAC_NCFGR_UNIHEN   (0x1u << 7)
 (GMAC_NCFGR) Unicast Hash Enable
#define GMAC_NCFGR_MAXFS   (0x1u << 8)
 (GMAC_NCFGR) 1536 Maximum Frame Size
#define GMAC_NCFGR_RTY   (0x1u << 12)
 (GMAC_NCFGR) Retry Test
#define GMAC_NCFGR_PEN   (0x1u << 13)
 (GMAC_NCFGR) Pause Enable
#define GMAC_NCFGR_RXBUFO_Pos   14
#define GMAC_NCFGR_RXBUFO_Msk   (0x3u << GMAC_NCFGR_RXBUFO_Pos)
 (GMAC_NCFGR) Receive Buffer Offset
#define GMAC_NCFGR_RXBUFO(value)   ((GMAC_NCFGR_RXBUFO_Msk & ((value) << GMAC_NCFGR_RXBUFO_Pos)))
#define GMAC_NCFGR_LFERD   (0x1u << 16)
 (GMAC_NCFGR) Length Field Error Frame Discard
#define GMAC_NCFGR_RFCS   (0x1u << 17)
 (GMAC_NCFGR) Remove FCS
#define GMAC_NCFGR_CLK_Pos   18
#define GMAC_NCFGR_CLK_Msk   (0x7u << GMAC_NCFGR_CLK_Pos)
 (GMAC_NCFGR) MDC CLock Division
#define GMAC_NCFGR_CLK(value)   ((GMAC_NCFGR_CLK_Msk & ((value) << GMAC_NCFGR_CLK_Pos)))
#define GMAC_NCFGR_CLK_MCK_8   (0x0u << 18)
 (GMAC_NCFGR) MCK divided by 8 (MCK up to 20 MHz)
#define GMAC_NCFGR_CLK_MCK_16   (0x1u << 18)
 (GMAC_NCFGR) MCK divided by 16 (MCK up to 40 MHz)
#define GMAC_NCFGR_CLK_MCK_32   (0x2u << 18)
 (GMAC_NCFGR) MCK divided by 32 (MCK up to 80 MHz)
#define GMAC_NCFGR_CLK_MCK_48   (0x3u << 18)
 (GMAC_NCFGR) MCK divided by 48 (MCK up to 120 MHz)
#define GMAC_NCFGR_CLK_MCK_64   (0x4u << 18)
 (GMAC_NCFGR) MCK divided by 64 (MCK up to 160 MHz)
#define GMAC_NCFGR_CLK_MCK_96   (0x5u << 18)
 (GMAC_NCFGR) MCK divided by 96 (MCK up to 240 MHz)
#define GMAC_NCFGR_DBW_Pos   21
#define GMAC_NCFGR_DBW_Msk   (0x3u << GMAC_NCFGR_DBW_Pos)
 (GMAC_NCFGR) Data Bus Width
#define GMAC_NCFGR_DBW(value)   ((GMAC_NCFGR_DBW_Msk & ((value) << GMAC_NCFGR_DBW_Pos)))
#define GMAC_NCFGR_DCPF   (0x1u << 23)
 (GMAC_NCFGR) Disable Copy of Pause Frames
#define GMAC_NCFGR_RXCOEN   (0x1u << 24)
 (GMAC_NCFGR) Receive Checksum Offload Enable
#define GMAC_NCFGR_EFRHD   (0x1u << 25)
 (GMAC_NCFGR) Enable Frames Received in Half Duplex
#define GMAC_NCFGR_IRXFCS   (0x1u << 26)
 (GMAC_NCFGR) Ignore RX FCS
#define GMAC_NCFGR_IPGSEN   (0x1u << 28)
 (GMAC_NCFGR) IP Stretch Enable
#define GMAC_NCFGR_RXBP   (0x1u << 29)
 (GMAC_NCFGR) Receive Bad Preamble
#define GMAC_NCFGR_IRXER   (0x1u << 30)
 (GMAC_NCFGR) Ignore IPG GRXER
#define GMAC_NSR_MDIO   (0x1u << 1)
 (GMAC_NSR) MDIO Input Status
#define GMAC_NSR_IDLE   (0x1u << 2)
 (GMAC_NSR) PHY Management Logic Idle
#define GMAC_UR_RMII   (0x1u << 0)
 (GMAC_UR) Reduced MII Mode
#define GMAC_DCFGR_FBLDO_Pos   0
#define GMAC_DCFGR_FBLDO_Msk   (0x1fu << GMAC_DCFGR_FBLDO_Pos)
 (GMAC_DCFGR) Fixed Burst Length for DMA Data Operations:
#define GMAC_DCFGR_FBLDO(value)   ((GMAC_DCFGR_FBLDO_Msk & ((value) << GMAC_DCFGR_FBLDO_Pos)))
#define GMAC_DCFGR_FBLDO_SINGLE   (0x1u << 0)
 (GMAC_DCFGR) 00001: Always use SINGLE AHB bursts
#define GMAC_DCFGR_FBLDO_INCR4   (0x4u << 0)
 (GMAC_DCFGR) 001xx: Attempt to use INCR4 AHB bursts (Default)
#define GMAC_DCFGR_FBLDO_INCR8   (0x8u << 0)
 (GMAC_DCFGR) 01xxx: Attempt to use INCR8 AHB bursts
#define GMAC_DCFGR_FBLDO_INCR16   (0x10u << 0)
 (GMAC_DCFGR) 1xxxx: Attempt to use INCR16 AHB bursts
#define GMAC_DCFGR_ESMA   (0x1u << 6)
 (GMAC_DCFGR) Endian Swap Mode Enable for Management Descriptor Accesses
#define GMAC_DCFGR_ESPA   (0x1u << 7)
 (GMAC_DCFGR) Endian Swap Mode Enable for Packet Data Accesses
#define GMAC_DCFGR_RXBMS_Pos   8
#define GMAC_DCFGR_RXBMS_Msk   (0x3u << GMAC_DCFGR_RXBMS_Pos)
 (GMAC_DCFGR) Receiver Packet Buffer Memory Size Select
#define GMAC_DCFGR_RXBMS(value)   ((GMAC_DCFGR_RXBMS_Msk & ((value) << GMAC_DCFGR_RXBMS_Pos)))
#define GMAC_DCFGR_RXBMS_EIGHTH   (0x0u << 8)
 (GMAC_DCFGR) 4/8 Kbyte Memory Size
#define GMAC_DCFGR_RXBMS_QUARTER   (0x1u << 8)
 (GMAC_DCFGR) 4/4 Kbytes Memory Size
#define GMAC_DCFGR_RXBMS_HALF   (0x2u << 8)
 (GMAC_DCFGR) 4/2 Kbytes Memory Size
#define GMAC_DCFGR_RXBMS_FULL   (0x3u << 8)
 (GMAC_DCFGR) 4 Kbytes Memory Size
#define GMAC_DCFGR_TXPBMS   (0x1u << 10)
 (GMAC_DCFGR) Transmitter Packet Buffer Memory Size Select
#define GMAC_DCFGR_TXCOEN   (0x1u << 11)
 (GMAC_DCFGR) Transmitter Checksum Generation Offload Enable
#define GMAC_DCFGR_DRBS_Pos   16
#define GMAC_DCFGR_DRBS_Msk   (0xffu << GMAC_DCFGR_DRBS_Pos)
 (GMAC_DCFGR) DMA Receive Buffer Size
#define GMAC_DCFGR_DRBS(value)   ((GMAC_DCFGR_DRBS_Msk & ((value) << GMAC_DCFGR_DRBS_Pos)))
#define GMAC_DCFGR_DDRP   (0x1u << 24)
 (GMAC_DCFGR) DMA Discard Receive Packets
#define GMAC_TSR_UBR   (0x1u << 0)
 (GMAC_TSR) Used Bit Read
#define GMAC_TSR_COL   (0x1u << 1)
 (GMAC_TSR) Collision Occurred
#define GMAC_TSR_RLE   (0x1u << 2)
 (GMAC_TSR) Retry Limit Exceeded
#define GMAC_TSR_TXGO   (0x1u << 3)
 (GMAC_TSR) Transmit Go
#define GMAC_TSR_TFC   (0x1u << 4)
 (GMAC_TSR) Transmit Frame Corruption Due to AHB Error
#define GMAC_TSR_TXCOMP   (0x1u << 5)
 (GMAC_TSR) Transmit Complete
#define GMAC_TSR_HRESP   (0x1u << 8)
 (GMAC_TSR) HRESP Not OK
#define GMAC_RBQB_ADDR_Pos   2
#define GMAC_RBQB_ADDR_Msk   (0x3fffffffu << GMAC_RBQB_ADDR_Pos)
 (GMAC_RBQB) Receive Buffer Queue Base Address
#define GMAC_RBQB_ADDR(value)   ((GMAC_RBQB_ADDR_Msk & ((value) << GMAC_RBQB_ADDR_Pos)))
#define GMAC_TBQB_ADDR_Pos   2
#define GMAC_TBQB_ADDR_Msk   (0x3fffffffu << GMAC_TBQB_ADDR_Pos)
 (GMAC_TBQB) Transmit Buffer Queue Base Address
#define GMAC_TBQB_ADDR(value)   ((GMAC_TBQB_ADDR_Msk & ((value) << GMAC_TBQB_ADDR_Pos)))
#define GMAC_RSR_BNA   (0x1u << 0)
 (GMAC_RSR) Buffer Not Available
#define GMAC_RSR_REC   (0x1u << 1)
 (GMAC_RSR) Frame Received
#define GMAC_RSR_RXOVR   (0x1u << 2)
 (GMAC_RSR) Receive Overrun
#define GMAC_RSR_HNO   (0x1u << 3)
 (GMAC_RSR) HRESP Not OK
#define GMAC_ISR_MFS   (0x1u << 0)
 (GMAC_ISR) Management Frame Sent
#define GMAC_ISR_RCOMP   (0x1u << 1)
 (GMAC_ISR) Receive Complete
#define GMAC_ISR_RXUBR   (0x1u << 2)
 (GMAC_ISR) RX Used Bit Read
#define GMAC_ISR_TXUBR   (0x1u << 3)
 (GMAC_ISR) TX Used Bit Read
#define GMAC_ISR_TUR   (0x1u << 4)
 (GMAC_ISR) Transmit Underrun
#define GMAC_ISR_RLEX   (0x1u << 5)
 (GMAC_ISR) Retry Limit Exceeded
#define GMAC_ISR_TFC   (0x1u << 6)
 (GMAC_ISR) Transmit Frame Corruption Due to AHB Error
#define GMAC_ISR_TCOMP   (0x1u << 7)
 (GMAC_ISR) Transmit Complete
#define GMAC_ISR_ROVR   (0x1u << 10)
 (GMAC_ISR) Receive Overrun
#define GMAC_ISR_HRESP   (0x1u << 11)
 (GMAC_ISR) HRESP Not OK
#define GMAC_ISR_PFNZ   (0x1u << 12)
 (GMAC_ISR) Pause Frame with Non-zero Pause Quantum Received
#define GMAC_ISR_PTZ   (0x1u << 13)
 (GMAC_ISR) Pause Time Zero
#define GMAC_ISR_PFTR   (0x1u << 14)
 (GMAC_ISR) Pause Frame Transmitted
#define GMAC_ISR_DRQFR   (0x1u << 18)
 (GMAC_ISR) PTP Delay Request Frame Received
#define GMAC_ISR_SFR   (0x1u << 19)
 (GMAC_ISR) PTP Sync Frame Received
#define GMAC_ISR_DRQFT   (0x1u << 20)
 (GMAC_ISR) PTP Delay Request Frame Transmitted
#define GMAC_ISR_SFT   (0x1u << 21)
 (GMAC_ISR) PTP Sync Frame Transmitted
#define GMAC_ISR_PDRQFR   (0x1u << 22)
 (GMAC_ISR) PDelay Request Frame Received
#define GMAC_ISR_PDRSFR   (0x1u << 23)
 (GMAC_ISR) PDelay Response Frame Received
#define GMAC_ISR_PDRQFT   (0x1u << 24)
 (GMAC_ISR) PDelay Request Frame Transmitted
#define GMAC_ISR_PDRSFT   (0x1u << 25)
 (GMAC_ISR) PDelay Response Frame Transmitted
#define GMAC_ISR_SRI   (0x1u << 26)
 (GMAC_ISR) TSU Seconds Register Increment
#define GMAC_ISR_WOL   (0x1u << 28)
 (GMAC_ISR) Wake On LAN
#define GMAC_ISR_TSU   (0x1u << 29)
 (GMAC_ISR) TSU timer comparison interrupt
#define GMAC_IER_MFS   (0x1u << 0)
 (GMAC_IER) Management Frame Sent
#define GMAC_IER_RCOMP   (0x1u << 1)
 (GMAC_IER) Receive Complete
#define GMAC_IER_RXUBR   (0x1u << 2)
 (GMAC_IER) RX Used Bit Read
#define GMAC_IER_TXUBR   (0x1u << 3)
 (GMAC_IER) TX Used Bit Read
#define GMAC_IER_TUR   (0x1u << 4)
 (GMAC_IER) Transmit Underrun
#define GMAC_IER_RLEX   (0x1u << 5)
 (GMAC_IER) Retry Limit Exceeded or Late Collision
#define GMAC_IER_TFC   (0x1u << 6)
 (GMAC_IER) Transmit Frame Corruption Due to AHB Error
#define GMAC_IER_TCOMP   (0x1u << 7)
 (GMAC_IER) Transmit Complete
#define GMAC_IER_ROVR   (0x1u << 10)
 (GMAC_IER) Receive Overrun
#define GMAC_IER_HRESP   (0x1u << 11)
 (GMAC_IER) HRESP Not OK
#define GMAC_IER_PFNZ   (0x1u << 12)
 (GMAC_IER) Pause Frame with Non-zero Pause Quantum Received
#define GMAC_IER_PTZ   (0x1u << 13)
 (GMAC_IER) Pause Time Zero
#define GMAC_IER_PFTR   (0x1u << 14)
 (GMAC_IER) Pause Frame Transmitted
#define GMAC_IER_EXINT   (0x1u << 15)
 (GMAC_IER) External Interrupt
#define GMAC_IER_DRQFR   (0x1u << 18)
 (GMAC_IER) PTP Delay Request Frame Received
#define GMAC_IER_SFR   (0x1u << 19)
 (GMAC_IER) PTP Sync Frame Received
#define GMAC_IER_DRQFT   (0x1u << 20)
 (GMAC_IER) PTP Delay Request Frame Transmitted
#define GMAC_IER_SFT   (0x1u << 21)
 (GMAC_IER) PTP Sync Frame Transmitted
#define GMAC_IER_PDRQFR   (0x1u << 22)
 (GMAC_IER) PDelay Request Frame Received
#define GMAC_IER_PDRSFR   (0x1u << 23)
 (GMAC_IER) PDelay Response Frame Received
#define GMAC_IER_PDRQFT   (0x1u << 24)
 (GMAC_IER) PDelay Request Frame Transmitted
#define GMAC_IER_PDRSFT   (0x1u << 25)
 (GMAC_IER) PDelay Response Frame Transmitted
#define GMAC_IER_SRI   (0x1u << 26)
 (GMAC_IER) TSU Seconds Register Increment
#define GMAC_IER_WOL   (0x1u << 28)
 (GMAC_IER) Wake On LAN
#define GMAC_IDR_MFS   (0x1u << 0)
 (GMAC_IDR) Management Frame Sent
#define GMAC_IDR_RCOMP   (0x1u << 1)
 (GMAC_IDR) Receive Complete
#define GMAC_IDR_RXUBR   (0x1u << 2)
 (GMAC_IDR) RX Used Bit Read
#define GMAC_IDR_TXUBR   (0x1u << 3)
 (GMAC_IDR) TX Used Bit Read
#define GMAC_IDR_TUR   (0x1u << 4)
 (GMAC_IDR) Transmit Underrun
#define GMAC_IDR_RLEX   (0x1u << 5)
 (GMAC_IDR) Retry Limit Exceeded or Late Collision
#define GMAC_IDR_TFC   (0x1u << 6)
 (GMAC_IDR) Transmit Frame Corruption Due to AHB Error
#define GMAC_IDR_TCOMP   (0x1u << 7)
 (GMAC_IDR) Transmit Complete
#define GMAC_IDR_ROVR   (0x1u << 10)
 (GMAC_IDR) Receive Overrun
#define GMAC_IDR_HRESP   (0x1u << 11)
 (GMAC_IDR) HRESP Not OK
#define GMAC_IDR_PFNZ   (0x1u << 12)
 (GMAC_IDR) Pause Frame with Non-zero Pause Quantum Received
#define GMAC_IDR_PTZ   (0x1u << 13)
 (GMAC_IDR) Pause Time Zero
#define GMAC_IDR_PFTR   (0x1u << 14)
 (GMAC_IDR) Pause Frame Transmitted
#define GMAC_IDR_EXINT   (0x1u << 15)
 (GMAC_IDR) External Interrupt
#define GMAC_IDR_DRQFR   (0x1u << 18)
 (GMAC_IDR) PTP Delay Request Frame Received
#define GMAC_IDR_SFR   (0x1u << 19)
 (GMAC_IDR) PTP Sync Frame Received
#define GMAC_IDR_DRQFT   (0x1u << 20)
 (GMAC_IDR) PTP Delay Request Frame Transmitted
#define GMAC_IDR_SFT   (0x1u << 21)
 (GMAC_IDR) PTP Sync Frame Transmitted
#define GMAC_IDR_PDRQFR   (0x1u << 22)
 (GMAC_IDR) PDelay Request Frame Received
#define GMAC_IDR_PDRSFR   (0x1u << 23)
 (GMAC_IDR) PDelay Response Frame Received
#define GMAC_IDR_PDRQFT   (0x1u << 24)
 (GMAC_IDR) PDelay Request Frame Transmitted
#define GMAC_IDR_PDRSFT   (0x1u << 25)
 (GMAC_IDR) PDelay Response Frame Transmitted
#define GMAC_IDR_SRI   (0x1u << 26)
 (GMAC_IDR) TSU Seconds Register Increment
#define GMAC_IDR_WOL   (0x1u << 28)
 (GMAC_IDR) Wake On LAN
#define GMAC_IMR_MFS   (0x1u << 0)
 (GMAC_IMR) Management Frame Sent
#define GMAC_IMR_RCOMP   (0x1u << 1)
 (GMAC_IMR) Receive Complete
#define GMAC_IMR_RXUBR   (0x1u << 2)
 (GMAC_IMR) RX Used Bit Read
#define GMAC_IMR_TXUBR   (0x1u << 3)
 (GMAC_IMR) TX Used Bit Read
#define GMAC_IMR_TUR   (0x1u << 4)
 (GMAC_IMR) Transmit Underrun
#define GMAC_IMR_RLEX   (0x1u << 5)
 (GMAC_IMR) Retry Limit Exceeded
#define GMAC_IMR_TFC   (0x1u << 6)
 (GMAC_IMR) Transmit Frame Corruption Due to AHB Error
#define GMAC_IMR_TCOMP   (0x1u << 7)
 (GMAC_IMR) Transmit Complete
#define GMAC_IMR_ROVR   (0x1u << 10)
 (GMAC_IMR) Receive Overrun
#define GMAC_IMR_HRESP   (0x1u << 11)
 (GMAC_IMR) HRESP Not OK
#define GMAC_IMR_PFNZ   (0x1u << 12)
 (GMAC_IMR) Pause Frame with Non-zero Pause Quantum Received
#define GMAC_IMR_PTZ   (0x1u << 13)
 (GMAC_IMR) Pause Time Zero
#define GMAC_IMR_PFTR   (0x1u << 14)
 (GMAC_IMR) Pause Frame Transmitted
#define GMAC_IMR_EXINT   (0x1u << 15)
 (GMAC_IMR) External Interrupt
#define GMAC_IMR_DRQFR   (0x1u << 18)
 (GMAC_IMR) PTP Delay Request Frame Received
#define GMAC_IMR_SFR   (0x1u << 19)
 (GMAC_IMR) PTP Sync Frame Received
#define GMAC_IMR_DRQFT   (0x1u << 20)
 (GMAC_IMR) PTP Delay Request Frame Transmitted
#define GMAC_IMR_SFT   (0x1u << 21)
 (GMAC_IMR) PTP Sync Frame Transmitted
#define GMAC_IMR_PDRQFR   (0x1u << 22)
 (GMAC_IMR) PDelay Request Frame Received
#define GMAC_IMR_PDRSFR   (0x1u << 23)
 (GMAC_IMR) PDelay Response Frame Received
#define GMAC_IMR_PDRQFT   (0x1u << 24)
 (GMAC_IMR) PDelay Request Frame Transmitted
#define GMAC_IMR_PDRSFT   (0x1u << 25)
 (GMAC_IMR) PDelay Response Frame Transmitted
#define GMAC_MAN_DATA_Pos   0
#define GMAC_MAN_DATA_Msk   (0xffffu << GMAC_MAN_DATA_Pos)
 (GMAC_MAN) PHY Data
#define GMAC_MAN_DATA(value)   ((GMAC_MAN_DATA_Msk & ((value) << GMAC_MAN_DATA_Pos)))
#define GMAC_MAN_WTN_Pos   16
#define GMAC_MAN_WTN_Msk   (0x3u << GMAC_MAN_WTN_Pos)
 (GMAC_MAN) Write Ten
#define GMAC_MAN_WTN(value)   ((GMAC_MAN_WTN_Msk & ((value) << GMAC_MAN_WTN_Pos)))
#define GMAC_MAN_REGA_Pos   18
#define GMAC_MAN_REGA_Msk   (0x1fu << GMAC_MAN_REGA_Pos)
 (GMAC_MAN) Register Address
#define GMAC_MAN_REGA(value)   ((GMAC_MAN_REGA_Msk & ((value) << GMAC_MAN_REGA_Pos)))
#define GMAC_MAN_PHYA_Pos   23
#define GMAC_MAN_PHYA_Msk   (0x1fu << GMAC_MAN_PHYA_Pos)
 (GMAC_MAN) PHY Address
#define GMAC_MAN_PHYA(value)   ((GMAC_MAN_PHYA_Msk & ((value) << GMAC_MAN_PHYA_Pos)))
#define GMAC_MAN_OP_Pos   28
#define GMAC_MAN_OP_Msk   (0x3u << GMAC_MAN_OP_Pos)
 (GMAC_MAN) Operation
#define GMAC_MAN_OP(value)   ((GMAC_MAN_OP_Msk & ((value) << GMAC_MAN_OP_Pos)))
#define GMAC_MAN_CLTTO   (0x1u << 30)
 (GMAC_MAN) Clause 22 Operation
#define GMAC_MAN_WZO   (0x1u << 31)
 (GMAC_MAN) Write ZERO
#define GMAC_RPQ_RPQ_Pos   0
#define GMAC_RPQ_RPQ_Msk   (0xffffu << GMAC_RPQ_RPQ_Pos)
 (GMAC_RPQ) Received Pause Quantum
#define GMAC_TPQ_TPQ_Pos   0
#define GMAC_TPQ_TPQ_Msk   (0xffffu << GMAC_TPQ_TPQ_Pos)
 (GMAC_TPQ) Transmit Pause Quantum
#define GMAC_TPQ_TPQ(value)   ((GMAC_TPQ_TPQ_Msk & ((value) << GMAC_TPQ_TPQ_Pos)))
#define GMAC_TPSF_TPB1ADR_Pos   0
#define GMAC_TPSF_TPB1ADR_Msk   (0xfffu << GMAC_TPSF_TPB1ADR_Pos)
 (GMAC_TPSF) Transmit Partial Store and Forward Address
#define GMAC_TPSF_TPB1ADR(value)   ((GMAC_TPSF_TPB1ADR_Msk & ((value) << GMAC_TPSF_TPB1ADR_Pos)))
#define GMAC_TPSF_ENTXP   (0x1u << 31)
 (GMAC_TPSF) Enable TX Partial Store and Forward Operation
#define GMAC_RPSF_RPB1ADR_Pos   0
#define GMAC_RPSF_RPB1ADR_Msk   (0xfffu << GMAC_RPSF_RPB1ADR_Pos)
 (GMAC_RPSF) Receive Partial Store and Forward Address
#define GMAC_RPSF_RPB1ADR(value)   ((GMAC_RPSF_RPB1ADR_Msk & ((value) << GMAC_RPSF_RPB1ADR_Pos)))
#define GMAC_RPSF_ENRXP   (0x1u << 31)
 (GMAC_RPSF) Enable RX Partial Store and Forward Operation
#define GMAC_RJFML_FML_Pos   0
#define GMAC_RJFML_FML_Msk   (0x3fffu << GMAC_RJFML_FML_Pos)
 (GMAC_RJFML) Frame Max Length
#define GMAC_RJFML_FML(value)   ((GMAC_RJFML_FML_Msk & ((value) << GMAC_RJFML_FML_Pos)))
#define GMAC_HRB_ADDR_Pos   0
#define GMAC_HRB_ADDR_Msk   (0xffffffffu << GMAC_HRB_ADDR_Pos)
 (GMAC_HRB) Hash Address
#define GMAC_HRB_ADDR(value)   ((GMAC_HRB_ADDR_Msk & ((value) << GMAC_HRB_ADDR_Pos)))
#define GMAC_HRT_ADDR_Pos   0
#define GMAC_HRT_ADDR_Msk   (0xffffffffu << GMAC_HRT_ADDR_Pos)
 (GMAC_HRT) Hash Address
#define GMAC_HRT_ADDR(value)   ((GMAC_HRT_ADDR_Msk & ((value) << GMAC_HRT_ADDR_Pos)))
#define GMAC_SAB_ADDR_Pos   0
#define GMAC_SAB_ADDR_Msk   (0xffffffffu << GMAC_SAB_ADDR_Pos)
 (GMAC_SAB) Specific Address 1
#define GMAC_SAB_ADDR(value)   ((GMAC_SAB_ADDR_Msk & ((value) << GMAC_SAB_ADDR_Pos)))
#define GMAC_SAT_ADDR_Pos   0
#define GMAC_SAT_ADDR_Msk   (0xffffu << GMAC_SAT_ADDR_Pos)
 (GMAC_SAT) Specific Address 1
#define GMAC_SAT_ADDR(value)   ((GMAC_SAT_ADDR_Msk & ((value) << GMAC_SAT_ADDR_Pos)))
#define GMAC_TIDM1_TID_Pos   0
#define GMAC_TIDM1_TID_Msk   (0xffffu << GMAC_TIDM1_TID_Pos)
 (GMAC_TIDM1) Type ID Match 1
#define GMAC_TIDM1_TID(value)   ((GMAC_TIDM1_TID_Msk & ((value) << GMAC_TIDM1_TID_Pos)))
#define GMAC_TIDM1_ENID1   (0x1u << 31)
 (GMAC_TIDM1) Enable Copying of TID Matched Frames
#define GMAC_TIDM2_TID_Pos   0
#define GMAC_TIDM2_TID_Msk   (0xffffu << GMAC_TIDM2_TID_Pos)
 (GMAC_TIDM2) Type ID Match 2
#define GMAC_TIDM2_TID(value)   ((GMAC_TIDM2_TID_Msk & ((value) << GMAC_TIDM2_TID_Pos)))
#define GMAC_TIDM2_ENID2   (0x1u << 31)
 (GMAC_TIDM2) Enable Copying of TID Matched Frames
#define GMAC_TIDM3_TID_Pos   0
#define GMAC_TIDM3_TID_Msk   (0xffffu << GMAC_TIDM3_TID_Pos)
 (GMAC_TIDM3) Type ID Match 3
#define GMAC_TIDM3_TID(value)   ((GMAC_TIDM3_TID_Msk & ((value) << GMAC_TIDM3_TID_Pos)))
#define GMAC_TIDM3_ENID3   (0x1u << 31)
 (GMAC_TIDM3) Enable Copying of TID Matched Frames
#define GMAC_TIDM4_TID_Pos   0
#define GMAC_TIDM4_TID_Msk   (0xffffu << GMAC_TIDM4_TID_Pos)
 (GMAC_TIDM4) Type ID Match 4
#define GMAC_TIDM4_TID(value)   ((GMAC_TIDM4_TID_Msk & ((value) << GMAC_TIDM4_TID_Pos)))
#define GMAC_TIDM4_ENID4   (0x1u << 31)
 (GMAC_TIDM4) Enable Copying of TID Matched Frames
#define GMAC_WOL_IP_Pos   0
#define GMAC_WOL_IP_Msk   (0xffffu << GMAC_WOL_IP_Pos)
 (GMAC_WOL) ARP Request IP Address
#define GMAC_WOL_IP(value)   ((GMAC_WOL_IP_Msk & ((value) << GMAC_WOL_IP_Pos)))
#define GMAC_WOL_MAG   (0x1u << 16)
 (GMAC_WOL) Magic Packet Event Enable
#define GMAC_WOL_ARP   (0x1u << 17)
#define GMAC_WOL_SA1   (0x1u << 18)
 (GMAC_WOL) Specific Address Register 1 Event Enable
#define GMAC_WOL_MTI   (0x1u << 19)
 (GMAC_WOL) Multicast Hash Event Enable
#define GMAC_IPGS_FL_Pos   0
#define GMAC_IPGS_FL_Msk   (0xffffu << GMAC_IPGS_FL_Pos)
 (GMAC_IPGS) Frame Length
#define GMAC_IPGS_FL(value)   ((GMAC_IPGS_FL_Msk & ((value) << GMAC_IPGS_FL_Pos)))
#define GMAC_SVLAN_VLAN_TYPE_Pos   0
#define GMAC_SVLAN_VLAN_TYPE_Msk   (0xffffu << GMAC_SVLAN_VLAN_TYPE_Pos)
 (GMAC_SVLAN) User Defined VLAN_TYPE Field
#define GMAC_SVLAN_VLAN_TYPE(value)   ((GMAC_SVLAN_VLAN_TYPE_Msk & ((value) << GMAC_SVLAN_VLAN_TYPE_Pos)))
#define GMAC_SVLAN_ESVLAN   (0x1u << 31)
 (GMAC_SVLAN) Enable Stacked VLAN Processing Mode
#define GMAC_TPFCP_PEV_Pos   0
#define GMAC_TPFCP_PEV_Msk   (0xffu << GMAC_TPFCP_PEV_Pos)
 (GMAC_TPFCP) Priority Enable Vector
#define GMAC_TPFCP_PEV(value)   ((GMAC_TPFCP_PEV_Msk & ((value) << GMAC_TPFCP_PEV_Pos)))
#define GMAC_TPFCP_PQ_Pos   8
#define GMAC_TPFCP_PQ_Msk   (0xffu << GMAC_TPFCP_PQ_Pos)
 (GMAC_TPFCP) Pause Quantum
#define GMAC_TPFCP_PQ(value)   ((GMAC_TPFCP_PQ_Msk & ((value) << GMAC_TPFCP_PQ_Pos)))
#define GMAC_SAMB1_ADDR_Pos   0
#define GMAC_SAMB1_ADDR_Msk   (0xffffffffu << GMAC_SAMB1_ADDR_Pos)
 (GMAC_SAMB1) Specific Address 1 Mask
#define GMAC_SAMB1_ADDR(value)   ((GMAC_SAMB1_ADDR_Msk & ((value) << GMAC_SAMB1_ADDR_Pos)))
#define GMAC_SAMT1_ADDR_Pos   0
#define GMAC_SAMT1_ADDR_Msk   (0xffffu << GMAC_SAMT1_ADDR_Pos)
 (GMAC_SAMT1) Specific Address 1 Mask
#define GMAC_SAMT1_ADDR(value)   ((GMAC_SAMT1_ADDR_Msk & ((value) << GMAC_SAMT1_ADDR_Pos)))
#define GMAC_NSC_NANOSEC_Pos   0
#define GMAC_NSC_NANOSEC_Msk   (0x3fffffu << GMAC_NSC_NANOSEC_Pos)
 (GMAC_NSC) 1588 Timer Nanosecond Comparison Value
#define GMAC_NSC_NANOSEC(value)   ((GMAC_NSC_NANOSEC_Msk & ((value) << GMAC_NSC_NANOSEC_Pos)))
#define GMAC_SCL_SEC_Pos   0
#define GMAC_SCL_SEC_Msk   (0xffffffffu << GMAC_SCL_SEC_Pos)
 (GMAC_SCL) 1588 Timer Second Comparison Value
#define GMAC_SCL_SEC(value)   ((GMAC_SCL_SEC_Msk & ((value) << GMAC_SCL_SEC_Pos)))
#define GMAC_SCH_SEC_Pos   0
#define GMAC_SCH_SEC_Msk   (0xffffu << GMAC_SCH_SEC_Pos)
 (GMAC_SCH) 1588 Timer Second Comparison Value
#define GMAC_SCH_SEC(value)   ((GMAC_SCH_SEC_Msk & ((value) << GMAC_SCH_SEC_Pos)))
#define GMAC_EFTSH_RUD_Pos   0
#define GMAC_EFTSH_RUD_Msk   (0xffffu << GMAC_EFTSH_RUD_Pos)
 (GMAC_EFTSH) Register Update
#define GMAC_EFRSH_RUD_Pos   0
#define GMAC_EFRSH_RUD_Msk   (0xffffu << GMAC_EFRSH_RUD_Pos)
 (GMAC_EFRSH) Register Update
#define GMAC_PEFTSH_RUD_Pos   0
#define GMAC_PEFTSH_RUD_Msk   (0xffffu << GMAC_PEFTSH_RUD_Pos)
 (GMAC_PEFTSH) Register Update
#define GMAC_PEFRSH_RUD_Pos   0
#define GMAC_PEFRSH_RUD_Msk   (0xffffu << GMAC_PEFRSH_RUD_Pos)
 (GMAC_PEFRSH) Register Update
#define GMAC_MID_MREV_Pos   0
#define GMAC_MID_MREV_Msk   (0xffffu << GMAC_MID_MREV_Pos)
 (GMAC_MID) Module Revision
#define GMAC_MID_MID_Pos   16
#define GMAC_MID_MID_Msk   (0xffffu << GMAC_MID_MID_Pos)
 (GMAC_MID) Module Identification Number
#define GMAC_OTLO_TXO_Pos   0
#define GMAC_OTLO_TXO_Msk   (0xffffffffu << GMAC_OTLO_TXO_Pos)
 (GMAC_OTLO) Transmitted Octets
#define GMAC_OTHI_TXO_Pos   0
#define GMAC_OTHI_TXO_Msk   (0xffffu << GMAC_OTHI_TXO_Pos)
 (GMAC_OTHI) Transmitted Octets
#define GMAC_FT_FTX_Pos   0
#define GMAC_FT_FTX_Msk   (0xffffffffu << GMAC_FT_FTX_Pos)
 (GMAC_FT) Frames Transmitted without Error
#define GMAC_BCFT_BFTX_Pos   0
#define GMAC_BCFT_BFTX_Msk   (0xffffffffu << GMAC_BCFT_BFTX_Pos)
 (GMAC_BCFT) Broadcast Frames Transmitted without Error
#define GMAC_MFT_MFTX_Pos   0
#define GMAC_MFT_MFTX_Msk   (0xffffffffu << GMAC_MFT_MFTX_Pos)
 (GMAC_MFT) Multicast Frames Transmitted without Error
#define GMAC_PFT_PFTX_Pos   0
#define GMAC_PFT_PFTX_Msk   (0xffffu << GMAC_PFT_PFTX_Pos)
 (GMAC_PFT) Pause Frames Transmitted Register
#define GMAC_BFT64_NFTX_Pos   0
#define GMAC_BFT64_NFTX_Msk   (0xffffffffu << GMAC_BFT64_NFTX_Pos)
 (GMAC_BFT64) 64 Byte Frames Transmitted without Error
#define GMAC_TBFT127_NFTX_Pos   0
#define GMAC_TBFT127_NFTX_Msk   (0xffffffffu << GMAC_TBFT127_NFTX_Pos)
 (GMAC_TBFT127) 65 to 127 Byte Frames Transmitted without Error
#define GMAC_TBFT255_NFTX_Pos   0
#define GMAC_TBFT255_NFTX_Msk   (0xffffffffu << GMAC_TBFT255_NFTX_Pos)
 (GMAC_TBFT255) 128 to 255 Byte Frames Transmitted without Error
#define GMAC_TBFT511_NFTX_Pos   0
#define GMAC_TBFT511_NFTX_Msk   (0xffffffffu << GMAC_TBFT511_NFTX_Pos)
 (GMAC_TBFT511) 256 to 511 Byte Frames Transmitted without Error
#define GMAC_TBFT1023_NFTX_Pos   0
#define GMAC_TBFT1023_NFTX_Msk   (0xffffffffu << GMAC_TBFT1023_NFTX_Pos)
 (GMAC_TBFT1023) 512 to 1023 Byte Frames Transmitted without Error
#define GMAC_TBFT1518_NFTX_Pos   0
#define GMAC_TBFT1518_NFTX_Msk   (0xffffffffu << GMAC_TBFT1518_NFTX_Pos)
 (GMAC_TBFT1518) 1024 to 1518 Byte Frames Transmitted without Error
#define GMAC_GTBFT1518_NFTX_Pos   0
#define GMAC_GTBFT1518_NFTX_Msk   (0xffffffffu << GMAC_GTBFT1518_NFTX_Pos)
 (GMAC_GTBFT1518) Greater than 1518 Byte Frames Transmitted without Error
#define GMAC_TUR_TXUNR_Pos   0
#define GMAC_TUR_TXUNR_Msk   (0x3ffu << GMAC_TUR_TXUNR_Pos)
 (GMAC_TUR) Transmit Underruns
#define GMAC_SCF_SCOL_Pos   0
#define GMAC_SCF_SCOL_Msk   (0x3ffffu << GMAC_SCF_SCOL_Pos)
 (GMAC_SCF) Single Collision
#define GMAC_MCF_MCOL_Pos   0
#define GMAC_MCF_MCOL_Msk   (0x3ffffu << GMAC_MCF_MCOL_Pos)
 (GMAC_MCF) Multiple Collision
#define GMAC_EC_XCOL_Pos   0
#define GMAC_EC_XCOL_Msk   (0x3ffu << GMAC_EC_XCOL_Pos)
 (GMAC_EC) Excessive Collisions
#define GMAC_LC_LCOL_Pos   0
#define GMAC_LC_LCOL_Msk   (0x3ffu << GMAC_LC_LCOL_Pos)
 (GMAC_LC) Late Collisions
#define GMAC_DTF_DEFT_Pos   0
#define GMAC_DTF_DEFT_Msk   (0x3ffffu << GMAC_DTF_DEFT_Pos)
 (GMAC_DTF) Deferred Transmission
#define GMAC_CSE_CSR_Pos   0
#define GMAC_CSE_CSR_Msk   (0x3ffu << GMAC_CSE_CSR_Pos)
 (GMAC_CSE) Carrier Sense Error
#define GMAC_ORLO_RXO_Pos   0
#define GMAC_ORLO_RXO_Msk   (0xffffffffu << GMAC_ORLO_RXO_Pos)
 (GMAC_ORLO) Received Octets
#define GMAC_ORHI_RXO_Pos   0
#define GMAC_ORHI_RXO_Msk   (0xffffu << GMAC_ORHI_RXO_Pos)
 (GMAC_ORHI) Received Octets
#define GMAC_FR_FRX_Pos   0
#define GMAC_FR_FRX_Msk   (0xffffffffu << GMAC_FR_FRX_Pos)
 (GMAC_FR) Frames Received without Error
#define GMAC_BCFR_BFRX_Pos   0
#define GMAC_BCFR_BFRX_Msk   (0xffffffffu << GMAC_BCFR_BFRX_Pos)
 (GMAC_BCFR) Broadcast Frames Received without Error
#define GMAC_MFR_MFRX_Pos   0
#define GMAC_MFR_MFRX_Msk   (0xffffffffu << GMAC_MFR_MFRX_Pos)
 (GMAC_MFR) Multicast Frames Received without Error
#define GMAC_PFR_PFRX_Pos   0
#define GMAC_PFR_PFRX_Msk   (0xffffu << GMAC_PFR_PFRX_Pos)
 (GMAC_PFR) Pause Frames Received Register
#define GMAC_BFR64_NFRX_Pos   0
#define GMAC_BFR64_NFRX_Msk   (0xffffffffu << GMAC_BFR64_NFRX_Pos)
 (GMAC_BFR64) 64 Byte Frames Received without Error
#define GMAC_TBFR127_NFRX_Pos   0
#define GMAC_TBFR127_NFRX_Msk   (0xffffffffu << GMAC_TBFR127_NFRX_Pos)
 (GMAC_TBFR127) 65 to 127 Byte Frames Received without Error
#define GMAC_TBFR255_NFRX_Pos   0
#define GMAC_TBFR255_NFRX_Msk   (0xffffffffu << GMAC_TBFR255_NFRX_Pos)
 (GMAC_TBFR255) 128 to 255 Byte Frames Received without Error
#define GMAC_TBFR511_NFRX_Pos   0
#define GMAC_TBFR511_NFRX_Msk   (0xffffffffu << GMAC_TBFR511_NFRX_Pos)
 (GMAC_TBFR511) 256 to 511 Byte Frames Received without Error
#define GMAC_TBFR1023_NFRX_Pos   0
#define GMAC_TBFR1023_NFRX_Msk   (0xffffffffu << GMAC_TBFR1023_NFRX_Pos)
 (GMAC_TBFR1023) 512 to 1023 Byte Frames Received without Error
#define GMAC_TBFR1518_NFRX_Pos   0
#define GMAC_TBFR1518_NFRX_Msk   (0xffffffffu << GMAC_TBFR1518_NFRX_Pos)
 (GMAC_TBFR1518) 1024 to 1518 Byte Frames Received without Error
#define GMAC_TMXBFR_NFRX_Pos   0
#define GMAC_TMXBFR_NFRX_Msk   (0xffffffffu << GMAC_TMXBFR_NFRX_Pos)
 (GMAC_TMXBFR) 1519 to Maximum Byte Frames Received without Error
#define GMAC_UFR_UFRX_Pos   0
#define GMAC_UFR_UFRX_Msk   (0x3ffu << GMAC_UFR_UFRX_Pos)
 (GMAC_UFR) Undersize Frames Received
#define GMAC_OFR_OFRX_Pos   0
#define GMAC_OFR_OFRX_Msk   (0x3ffu << GMAC_OFR_OFRX_Pos)
 (GMAC_OFR) Oversized Frames Received
#define GMAC_JR_JRX_Pos   0
#define GMAC_JR_JRX_Msk   (0x3ffu << GMAC_JR_JRX_Pos)
 (GMAC_JR) Jabbers Received
#define GMAC_FCSE_FCKR_Pos   0
#define GMAC_FCSE_FCKR_Msk   (0x3ffu << GMAC_FCSE_FCKR_Pos)
 (GMAC_FCSE) Frame Check Sequence Errors
#define GMAC_LFFE_LFER_Pos   0
#define GMAC_LFFE_LFER_Msk   (0x3ffu << GMAC_LFFE_LFER_Pos)
 (GMAC_LFFE) Length Field Frame Errors
#define GMAC_RSE_RXSE_Pos   0
#define GMAC_RSE_RXSE_Msk   (0x3ffu << GMAC_RSE_RXSE_Pos)
 (GMAC_RSE) Receive Symbol Errors
#define GMAC_AE_AER_Pos   0
#define GMAC_AE_AER_Msk   (0x3ffu << GMAC_AE_AER_Pos)
 (GMAC_AE) Alignment Errors
#define GMAC_RRE_RXRER_Pos   0
#define GMAC_RRE_RXRER_Msk   (0x3ffffu << GMAC_RRE_RXRER_Pos)
 (GMAC_RRE) Receive Resource Errors
#define GMAC_ROE_RXOVR_Pos   0
#define GMAC_ROE_RXOVR_Msk   (0x3ffu << GMAC_ROE_RXOVR_Pos)
 (GMAC_ROE) Receive Overruns
#define GMAC_IHCE_HCKER_Pos   0
#define GMAC_IHCE_HCKER_Msk   (0xffu << GMAC_IHCE_HCKER_Pos)
 (GMAC_IHCE) IP Header Checksum Errors
#define GMAC_TCE_TCKER_Pos   0
#define GMAC_TCE_TCKER_Msk   (0xffu << GMAC_TCE_TCKER_Pos)
 (GMAC_TCE) TCP Checksum Errors
#define GMAC_UCE_UCKER_Pos   0
#define GMAC_UCE_UCKER_Msk   (0xffu << GMAC_UCE_UCKER_Pos)
 (GMAC_UCE) UDP Checksum Errors
#define GMAC_TISUBN_LSBTIR_Pos   0
#define GMAC_TISUBN_LSBTIR_Msk   (0xffffu << GMAC_TISUBN_LSBTIR_Pos)
 (GMAC_TISUBN) Lower Significant Bits of Timer Increment Register
#define GMAC_TISUBN_LSBTIR(value)   ((GMAC_TISUBN_LSBTIR_Msk & ((value) << GMAC_TISUBN_LSBTIR_Pos)))
#define GMAC_TSH_TCS_Pos   0
#define GMAC_TSH_TCS_Msk   (0xffffu << GMAC_TSH_TCS_Pos)
 (GMAC_TSH) Timer Count in Seconds
#define GMAC_TSH_TCS(value)   ((GMAC_TSH_TCS_Msk & ((value) << GMAC_TSH_TCS_Pos)))
#define GMAC_TSL_TCS_Pos   0
#define GMAC_TSL_TCS_Msk   (0xffffffffu << GMAC_TSL_TCS_Pos)
 (GMAC_TSL) Timer Count in Seconds
#define GMAC_TSL_TCS(value)   ((GMAC_TSL_TCS_Msk & ((value) << GMAC_TSL_TCS_Pos)))
#define GMAC_TN_TNS_Pos   0
#define GMAC_TN_TNS_Msk   (0x3fffffffu << GMAC_TN_TNS_Pos)
 (GMAC_TN) Timer Count in Nanoseconds
#define GMAC_TN_TNS(value)   ((GMAC_TN_TNS_Msk & ((value) << GMAC_TN_TNS_Pos)))
#define GMAC_TA_ITDT_Pos   0
#define GMAC_TA_ITDT_Msk   (0x3fffffffu << GMAC_TA_ITDT_Pos)
 (GMAC_TA) Increment/Decrement
#define GMAC_TA_ITDT(value)   ((GMAC_TA_ITDT_Msk & ((value) << GMAC_TA_ITDT_Pos)))
#define GMAC_TA_ADJ   (0x1u << 31)
 (GMAC_TA) Adjust 1588 Timer
#define GMAC_TI_CNS_Pos   0
#define GMAC_TI_CNS_Msk   (0xffu << GMAC_TI_CNS_Pos)
 (GMAC_TI) Count Nanoseconds
#define GMAC_TI_CNS(value)   ((GMAC_TI_CNS_Msk & ((value) << GMAC_TI_CNS_Pos)))
#define GMAC_TI_ACNS_Pos   8
#define GMAC_TI_ACNS_Msk   (0xffu << GMAC_TI_ACNS_Pos)
 (GMAC_TI) Alternative Count Nanoseconds
#define GMAC_TI_ACNS(value)   ((GMAC_TI_ACNS_Msk & ((value) << GMAC_TI_ACNS_Pos)))
#define GMAC_TI_NIT_Pos   16
#define GMAC_TI_NIT_Msk   (0xffu << GMAC_TI_NIT_Pos)
 (GMAC_TI) Number of Increments
#define GMAC_TI_NIT(value)   ((GMAC_TI_NIT_Msk & ((value) << GMAC_TI_NIT_Pos)))
#define GMAC_EFTSL_RUD_Pos   0
#define GMAC_EFTSL_RUD_Msk   (0xffffffffu << GMAC_EFTSL_RUD_Pos)
 (GMAC_EFTSL) Register Update
#define GMAC_EFTN_RUD_Pos   0
#define GMAC_EFTN_RUD_Msk   (0x3fffffffu << GMAC_EFTN_RUD_Pos)
 (GMAC_EFTN) Register Update
#define GMAC_EFRSL_RUD_Pos   0
#define GMAC_EFRSL_RUD_Msk   (0xffffffffu << GMAC_EFRSL_RUD_Pos)
 (GMAC_EFRSL) Register Update
#define GMAC_EFRN_RUD_Pos   0
#define GMAC_EFRN_RUD_Msk   (0x3fffffffu << GMAC_EFRN_RUD_Pos)
 (GMAC_EFRN) Register Update
#define GMAC_PEFTSL_RUD_Pos   0
#define GMAC_PEFTSL_RUD_Msk   (0xffffffffu << GMAC_PEFTSL_RUD_Pos)
 (GMAC_PEFTSL) Register Update
#define GMAC_PEFTN_RUD_Pos   0
#define GMAC_PEFTN_RUD_Msk   (0x3fffffffu << GMAC_PEFTN_RUD_Pos)
 (GMAC_PEFTN) Register Update
#define GMAC_PEFRSL_RUD_Pos   0
#define GMAC_PEFRSL_RUD_Msk   (0xffffffffu << GMAC_PEFRSL_RUD_Pos)
 (GMAC_PEFRSL) Register Update
#define GMAC_PEFRN_RUD_Pos   0
#define GMAC_PEFRN_RUD_Msk   (0x3fffffffu << GMAC_PEFRN_RUD_Pos)
 (GMAC_PEFRN) Register Update
#define GMAC_ISRPQ_RCOMP   (0x1u << 1)
 (GMAC_ISRPQ[2]) Receive Complete
#define GMAC_ISRPQ_RXUBR   (0x1u << 2)
 (GMAC_ISRPQ[2]) RX Used Bit Read
#define GMAC_ISRPQ_RLEX   (0x1u << 5)
 (GMAC_ISRPQ[2]) Retry Limit Exceeded or Late Collision
#define GMAC_ISRPQ_TFC   (0x1u << 6)
 (GMAC_ISRPQ[2]) Transmit Frame Corruption Due to AHB Error
#define GMAC_ISRPQ_TCOMP   (0x1u << 7)
 (GMAC_ISRPQ[2]) Transmit Complete
#define GMAC_ISRPQ_ROVR   (0x1u << 10)
 (GMAC_ISRPQ[2]) Receive Overrun
#define GMAC_ISRPQ_HRESP   (0x1u << 11)
 (GMAC_ISRPQ[2]) HRESP Not OK
#define GMAC_TBQBAPQ_TXBQBA_Pos   2
#define GMAC_TBQBAPQ_TXBQBA_Msk   (0x3fffffffu << GMAC_TBQBAPQ_TXBQBA_Pos)
 (GMAC_TBQBAPQ[2]) Transmit Buffer Queue Base Address
#define GMAC_TBQBAPQ_TXBQBA(value)   ((GMAC_TBQBAPQ_TXBQBA_Msk & ((value) << GMAC_TBQBAPQ_TXBQBA_Pos)))
#define GMAC_RBQBAPQ_RXBQBA_Pos   2
#define GMAC_RBQBAPQ_RXBQBA_Msk   (0x3fffffffu << GMAC_RBQBAPQ_RXBQBA_Pos)
 (GMAC_RBQBAPQ[2]) Receive Buffer Queue Base Address
#define GMAC_RBQBAPQ_RXBQBA(value)   ((GMAC_RBQBAPQ_RXBQBA_Msk & ((value) << GMAC_RBQBAPQ_RXBQBA_Pos)))
#define GMAC_RBSRPQ_RBS_Pos   0
#define GMAC_RBSRPQ_RBS_Msk   (0xffffu << GMAC_RBSRPQ_RBS_Pos)
 (GMAC_RBSRPQ[2]) Receive Buffer Size
#define GMAC_RBSRPQ_RBS(value)   ((GMAC_RBSRPQ_RBS_Msk & ((value) << GMAC_RBSRPQ_RBS_Pos)))
#define GMAC_CBSCR_QBE   (0x1u << 0)
 (GMAC_CBSCR) Queue B CBS Enable
#define GMAC_CBSCR_QAE   (0x1u << 1)
 (GMAC_CBSCR) Queue A CBS Enable
#define GMAC_CBSISQA_IS_Pos   0
#define GMAC_CBSISQA_IS_Msk   (0xffffffffu << GMAC_CBSISQA_IS_Pos)
 (GMAC_CBSISQA) IdleSlope
#define GMAC_CBSISQA_IS(value)   ((GMAC_CBSISQA_IS_Msk & ((value) << GMAC_CBSISQA_IS_Pos)))
#define GMAC_CBSISQB_IS_Pos   0
#define GMAC_CBSISQB_IS_Msk   (0xffffffffu << GMAC_CBSISQB_IS_Pos)
 (GMAC_CBSISQB) IdleSlope
#define GMAC_CBSISQB_IS(value)   ((GMAC_CBSISQB_IS_Msk & ((value) << GMAC_CBSISQB_IS_Pos)))
#define GMAC_ST1RPQ_QNB_Pos   0
#define GMAC_ST1RPQ_QNB_Msk   (0x7u << GMAC_ST1RPQ_QNB_Pos)
 (GMAC_ST1RPQ[4]) Queue Number (0-2)
#define GMAC_ST1RPQ_QNB(value)   ((GMAC_ST1RPQ_QNB_Msk & ((value) << GMAC_ST1RPQ_QNB_Pos)))
#define GMAC_ST1RPQ_DSTCM_Pos   4
#define GMAC_ST1RPQ_DSTCM_Msk   (0xffu << GMAC_ST1RPQ_DSTCM_Pos)
 (GMAC_ST1RPQ[4]) Differentiated Services or Traffic Class Match
#define GMAC_ST1RPQ_DSTCM(value)   ((GMAC_ST1RPQ_DSTCM_Msk & ((value) << GMAC_ST1RPQ_DSTCM_Pos)))
#define GMAC_ST1RPQ_UDPM_Pos   12
#define GMAC_ST1RPQ_UDPM_Msk   (0xffffu << GMAC_ST1RPQ_UDPM_Pos)
 (GMAC_ST1RPQ[4]) UDP Port Match
#define GMAC_ST1RPQ_UDPM(value)   ((GMAC_ST1RPQ_UDPM_Msk & ((value) << GMAC_ST1RPQ_UDPM_Pos)))
#define GMAC_ST1RPQ_DSTCE   (0x1u << 28)
 (GMAC_ST1RPQ[4]) Differentiated Services or Traffic Class Match Enable
#define GMAC_ST1RPQ_UDPE   (0x1u << 29)
 (GMAC_ST1RPQ[4]) UDP Port Match Enable
#define GMAC_ST2RPQ_QNB_Pos   0
#define GMAC_ST2RPQ_QNB_Msk   (0x7u << GMAC_ST2RPQ_QNB_Pos)
 (GMAC_ST2RPQ[8]) Queue Number (0-2)
#define GMAC_ST2RPQ_QNB(value)   ((GMAC_ST2RPQ_QNB_Msk & ((value) << GMAC_ST2RPQ_QNB_Pos)))
#define GMAC_ST2RPQ_VLANP_Pos   4
#define GMAC_ST2RPQ_VLANP_Msk   (0x7u << GMAC_ST2RPQ_VLANP_Pos)
 (GMAC_ST2RPQ[8]) VLAN Priority
#define GMAC_ST2RPQ_VLANP(value)   ((GMAC_ST2RPQ_VLANP_Msk & ((value) << GMAC_ST2RPQ_VLANP_Pos)))
#define GMAC_ST2RPQ_VLANE   (0x1u << 8)
 (GMAC_ST2RPQ[8]) VLAN Enable
#define GMAC_ST2RPQ_I2ETH_Pos   9
#define GMAC_ST2RPQ_I2ETH_Msk   (0x7u << GMAC_ST2RPQ_I2ETH_Pos)
 (GMAC_ST2RPQ[8]) Index of Screening Type 2 EtherType register x
#define GMAC_ST2RPQ_I2ETH(value)   ((GMAC_ST2RPQ_I2ETH_Msk & ((value) << GMAC_ST2RPQ_I2ETH_Pos)))
#define GMAC_ST2RPQ_ETHE   (0x1u << 12)
 (GMAC_ST2RPQ[8]) EtherType Enable
#define GMAC_ST2RPQ_COMPA_Pos   13
#define GMAC_ST2RPQ_COMPA_Msk   (0x1fu << GMAC_ST2RPQ_COMPA_Pos)
 (GMAC_ST2RPQ[8]) Index of Screening Type 2 Compare Word 0/Word 1 register x
#define GMAC_ST2RPQ_COMPA(value)   ((GMAC_ST2RPQ_COMPA_Msk & ((value) << GMAC_ST2RPQ_COMPA_Pos)))
#define GMAC_ST2RPQ_COMPAE   (0x1u << 18)
 (GMAC_ST2RPQ[8]) Compare A Enable
#define GMAC_ST2RPQ_COMPB_Pos   19
#define GMAC_ST2RPQ_COMPB_Msk   (0x1fu << GMAC_ST2RPQ_COMPB_Pos)
#define GMAC_ST2RPQ_COMPB(value)   ((GMAC_ST2RPQ_COMPB_Msk & ((value) << GMAC_ST2RPQ_COMPB_Pos)))
#define GMAC_ST2RPQ_COMPBE   (0x1u << 24)
 (GMAC_ST2RPQ[8]) Compare B Enable
#define GMAC_ST2RPQ_COMPC_Pos   25
#define GMAC_ST2RPQ_COMPC_Msk   (0x1fu << GMAC_ST2RPQ_COMPC_Pos)
#define GMAC_ST2RPQ_COMPC(value)   ((GMAC_ST2RPQ_COMPC_Msk & ((value) << GMAC_ST2RPQ_COMPC_Pos)))
#define GMAC_ST2RPQ_COMPCE   (0x1u << 30)
 (GMAC_ST2RPQ[8]) Compare C Enable
#define GMAC_IERPQ_RCOMP   (0x1u << 1)
 (GMAC_IERPQ[2]) Receive Complete
#define GMAC_IERPQ_RXUBR   (0x1u << 2)
 (GMAC_IERPQ[2]) RX Used Bit Read
#define GMAC_IERPQ_RLEX   (0x1u << 5)
 (GMAC_IERPQ[2]) Retry Limit Exceeded or Late Collision
#define GMAC_IERPQ_TFC   (0x1u << 6)
 (GMAC_IERPQ[2]) Transmit Frame Corruption Due to AHB Error
#define GMAC_IERPQ_TCOMP   (0x1u << 7)
 (GMAC_IERPQ[2]) Transmit Complete
#define GMAC_IERPQ_ROVR   (0x1u << 10)
 (GMAC_IERPQ[2]) Receive Overrun
#define GMAC_IERPQ_HRESP   (0x1u << 11)
 (GMAC_IERPQ[2]) HRESP Not OK
#define GMAC_IDRPQ_RCOMP   (0x1u << 1)
 (GMAC_IDRPQ[2]) Receive Complete
#define GMAC_IDRPQ_RXUBR   (0x1u << 2)
 (GMAC_IDRPQ[2]) RX Used Bit Read
#define GMAC_IDRPQ_RLEX   (0x1u << 5)
 (GMAC_IDRPQ[2]) Retry Limit Exceeded or Late Collision
#define GMAC_IDRPQ_TFC   (0x1u << 6)
 (GMAC_IDRPQ[2]) Transmit Frame Corruption Due to AHB Error
#define GMAC_IDRPQ_TCOMP   (0x1u << 7)
 (GMAC_IDRPQ[2]) Transmit Complete
#define GMAC_IDRPQ_ROVR   (0x1u << 10)
 (GMAC_IDRPQ[2]) Receive Overrun
#define GMAC_IDRPQ_HRESP   (0x1u << 11)
 (GMAC_IDRPQ[2]) HRESP Not OK
#define GMAC_IMRPQ_RCOMP   (0x1u << 1)
 (GMAC_IMRPQ[2]) Receive Complete
#define GMAC_IMRPQ_RXUBR   (0x1u << 2)
 (GMAC_IMRPQ[2]) RX Used Bit Read
#define GMAC_IMRPQ_RLEX   (0x1u << 5)
 (GMAC_IMRPQ[2]) Retry Limit Exceeded or Late Collision
#define GMAC_IMRPQ_AHB   (0x1u << 6)
 (GMAC_IMRPQ[2]) AHB Error
#define GMAC_IMRPQ_TCOMP   (0x1u << 7)
 (GMAC_IMRPQ[2]) Transmit Complete
#define GMAC_IMRPQ_ROVR   (0x1u << 10)
 (GMAC_IMRPQ[2]) Receive Overrun
#define GMAC_IMRPQ_HRESP   (0x1u << 11)
 (GMAC_IMRPQ[2]) HRESP Not OK
#define GMAC_ST2ER_COMPVAL_Pos   0
#define GMAC_ST2ER_COMPVAL_Msk   (0xffffu << GMAC_ST2ER_COMPVAL_Pos)
 (GMAC_ST2ER[4]) Ethertype Compare Value
#define GMAC_ST2ER_COMPVAL(value)   ((GMAC_ST2ER_COMPVAL_Msk & ((value) << GMAC_ST2ER_COMPVAL_Pos)))
#define GMAC_ST2CW00_MASKVAL_Pos   0
#define GMAC_ST2CW00_MASKVAL_Msk   (0xffffu << GMAC_ST2CW00_MASKVAL_Pos)
 (GMAC_ST2CW00) Mask Value
#define GMAC_ST2CW00_MASKVAL(value)   ((GMAC_ST2CW00_MASKVAL_Msk & ((value) << GMAC_ST2CW00_MASKVAL_Pos)))
#define GMAC_ST2CW00_COMPVAL_Pos   16
#define GMAC_ST2CW00_COMPVAL_Msk   (0xffffu << GMAC_ST2CW00_COMPVAL_Pos)
 (GMAC_ST2CW00) Compare Value
#define GMAC_ST2CW00_COMPVAL(value)   ((GMAC_ST2CW00_COMPVAL_Msk & ((value) << GMAC_ST2CW00_COMPVAL_Pos)))
#define GMAC_ST2CW10_OFFSVAL_Pos   0
#define GMAC_ST2CW10_OFFSVAL_Msk   (0x7fu << GMAC_ST2CW10_OFFSVAL_Pos)
 (GMAC_ST2CW10) Offset Value in Bytes
#define GMAC_ST2CW10_OFFSVAL(value)   ((GMAC_ST2CW10_OFFSVAL_Msk & ((value) << GMAC_ST2CW10_OFFSVAL_Pos)))
#define GMAC_ST2CW10_OFFSSTRT_Pos   7
#define GMAC_ST2CW10_OFFSSTRT_Msk   (0x3u << GMAC_ST2CW10_OFFSSTRT_Pos)
 (GMAC_ST2CW10) Ethernet Frame Offset Start
#define GMAC_ST2CW10_OFFSSTRT(value)   ((GMAC_ST2CW10_OFFSSTRT_Msk & ((value) << GMAC_ST2CW10_OFFSSTRT_Pos)))
#define GMAC_ST2CW10_OFFSSTRT_FRAMESTART   (0x0u << 7)
 (GMAC_ST2CW10) Offset from the start of the frame
#define GMAC_ST2CW10_OFFSSTRT_ETHERTYPE   (0x1u << 7)
 (GMAC_ST2CW10) Offset from the byte after the EtherType field
#define GMAC_ST2CW10_OFFSSTRT_IP   (0x2u << 7)
 (GMAC_ST2CW10) Offset from the byte after the IP header field
#define GMAC_ST2CW10_OFFSSTRT_TCP_UDP   (0x3u << 7)
 (GMAC_ST2CW10) Offset from the byte after the TCP/UDP header field
#define GMAC_ST2CW01_MASKVAL_Pos   0
#define GMAC_ST2CW01_MASKVAL_Msk   (0xffffu << GMAC_ST2CW01_MASKVAL_Pos)
 (GMAC_ST2CW01) Mask Value
#define GMAC_ST2CW01_MASKVAL(value)   ((GMAC_ST2CW01_MASKVAL_Msk & ((value) << GMAC_ST2CW01_MASKVAL_Pos)))
#define GMAC_ST2CW01_COMPVAL_Pos   16
#define GMAC_ST2CW01_COMPVAL_Msk   (0xffffu << GMAC_ST2CW01_COMPVAL_Pos)
 (GMAC_ST2CW01) Compare Value
#define GMAC_ST2CW01_COMPVAL(value)   ((GMAC_ST2CW01_COMPVAL_Msk & ((value) << GMAC_ST2CW01_COMPVAL_Pos)))
#define GMAC_ST2CW11_OFFSVAL_Pos   0
#define GMAC_ST2CW11_OFFSVAL_Msk   (0x7fu << GMAC_ST2CW11_OFFSVAL_Pos)
 (GMAC_ST2CW11) Offset Value in Bytes
#define GMAC_ST2CW11_OFFSVAL(value)   ((GMAC_ST2CW11_OFFSVAL_Msk & ((value) << GMAC_ST2CW11_OFFSVAL_Pos)))
#define GMAC_ST2CW11_OFFSSTRT_Pos   7
#define GMAC_ST2CW11_OFFSSTRT_Msk   (0x3u << GMAC_ST2CW11_OFFSSTRT_Pos)
 (GMAC_ST2CW11) Ethernet Frame Offset Start
#define GMAC_ST2CW11_OFFSSTRT(value)   ((GMAC_ST2CW11_OFFSSTRT_Msk & ((value) << GMAC_ST2CW11_OFFSSTRT_Pos)))
#define GMAC_ST2CW11_OFFSSTRT_FRAMESTART   (0x0u << 7)
 (GMAC_ST2CW11) Offset from the start of the frame
#define GMAC_ST2CW11_OFFSSTRT_ETHERTYPE   (0x1u << 7)
 (GMAC_ST2CW11) Offset from the byte after the EtherType field
#define GMAC_ST2CW11_OFFSSTRT_IP   (0x2u << 7)
 (GMAC_ST2CW11) Offset from the byte after the IP header field
#define GMAC_ST2CW11_OFFSSTRT_TCP_UDP   (0x3u << 7)
 (GMAC_ST2CW11) Offset from the byte after the TCP/UDP header field
#define GMAC_ST2CW02_MASKVAL_Pos   0
#define GMAC_ST2CW02_MASKVAL_Msk   (0xffffu << GMAC_ST2CW02_MASKVAL_Pos)
 (GMAC_ST2CW02) Mask Value
#define GMAC_ST2CW02_MASKVAL(value)   ((GMAC_ST2CW02_MASKVAL_Msk & ((value) << GMAC_ST2CW02_MASKVAL_Pos)))
#define GMAC_ST2CW02_COMPVAL_Pos   16
#define GMAC_ST2CW02_COMPVAL_Msk   (0xffffu << GMAC_ST2CW02_COMPVAL_Pos)
 (GMAC_ST2CW02) Compare Value
#define GMAC_ST2CW02_COMPVAL(value)   ((GMAC_ST2CW02_COMPVAL_Msk & ((value) << GMAC_ST2CW02_COMPVAL_Pos)))
#define GMAC_ST2CW12_OFFSVAL_Pos   0
#define GMAC_ST2CW12_OFFSVAL_Msk   (0x7fu << GMAC_ST2CW12_OFFSVAL_Pos)
 (GMAC_ST2CW12) Offset Value in Bytes
#define GMAC_ST2CW12_OFFSVAL(value)   ((GMAC_ST2CW12_OFFSVAL_Msk & ((value) << GMAC_ST2CW12_OFFSVAL_Pos)))
#define GMAC_ST2CW12_OFFSSTRT_Pos   7
#define GMAC_ST2CW12_OFFSSTRT_Msk   (0x3u << GMAC_ST2CW12_OFFSSTRT_Pos)
 (GMAC_ST2CW12) Ethernet Frame Offset Start
#define GMAC_ST2CW12_OFFSSTRT(value)   ((GMAC_ST2CW12_OFFSSTRT_Msk & ((value) << GMAC_ST2CW12_OFFSSTRT_Pos)))
#define GMAC_ST2CW12_OFFSSTRT_FRAMESTART   (0x0u << 7)
 (GMAC_ST2CW12) Offset from the start of the frame
#define GMAC_ST2CW12_OFFSSTRT_ETHERTYPE   (0x1u << 7)
 (GMAC_ST2CW12) Offset from the byte after the EtherType field
#define GMAC_ST2CW12_OFFSSTRT_IP   (0x2u << 7)
 (GMAC_ST2CW12) Offset from the byte after the IP header field
#define GMAC_ST2CW12_OFFSSTRT_TCP_UDP   (0x3u << 7)
 (GMAC_ST2CW12) Offset from the byte after the TCP/UDP header field
#define GMAC_ST2CW03_MASKVAL_Pos   0
#define GMAC_ST2CW03_MASKVAL_Msk   (0xffffu << GMAC_ST2CW03_MASKVAL_Pos)
 (GMAC_ST2CW03) Mask Value
#define GMAC_ST2CW03_MASKVAL(value)   ((GMAC_ST2CW03_MASKVAL_Msk & ((value) << GMAC_ST2CW03_MASKVAL_Pos)))
#define GMAC_ST2CW03_COMPVAL_Pos   16
#define GMAC_ST2CW03_COMPVAL_Msk   (0xffffu << GMAC_ST2CW03_COMPVAL_Pos)
 (GMAC_ST2CW03) Compare Value
#define GMAC_ST2CW03_COMPVAL(value)   ((GMAC_ST2CW03_COMPVAL_Msk & ((value) << GMAC_ST2CW03_COMPVAL_Pos)))
#define GMAC_ST2CW13_OFFSVAL_Pos   0
#define GMAC_ST2CW13_OFFSVAL_Msk   (0x7fu << GMAC_ST2CW13_OFFSVAL_Pos)
 (GMAC_ST2CW13) Offset Value in Bytes
#define GMAC_ST2CW13_OFFSVAL(value)   ((GMAC_ST2CW13_OFFSVAL_Msk & ((value) << GMAC_ST2CW13_OFFSVAL_Pos)))
#define GMAC_ST2CW13_OFFSSTRT_Pos   7
#define GMAC_ST2CW13_OFFSSTRT_Msk   (0x3u << GMAC_ST2CW13_OFFSSTRT_Pos)
 (GMAC_ST2CW13) Ethernet Frame Offset Start
#define GMAC_ST2CW13_OFFSSTRT(value)   ((GMAC_ST2CW13_OFFSSTRT_Msk & ((value) << GMAC_ST2CW13_OFFSSTRT_Pos)))
#define GMAC_ST2CW13_OFFSSTRT_FRAMESTART   (0x0u << 7)
 (GMAC_ST2CW13) Offset from the start of the frame
#define GMAC_ST2CW13_OFFSSTRT_ETHERTYPE   (0x1u << 7)
 (GMAC_ST2CW13) Offset from the byte after the EtherType field
#define GMAC_ST2CW13_OFFSSTRT_IP   (0x2u << 7)
 (GMAC_ST2CW13) Offset from the byte after the IP header field
#define GMAC_ST2CW13_OFFSSTRT_TCP_UDP   (0x3u << 7)
 (GMAC_ST2CW13) Offset from the byte after the TCP/UDP header field
#define GMAC_ST2CW04_MASKVAL_Pos   0
#define GMAC_ST2CW04_MASKVAL_Msk   (0xffffu << GMAC_ST2CW04_MASKVAL_Pos)
 (GMAC_ST2CW04) Mask Value
#define GMAC_ST2CW04_MASKVAL(value)   ((GMAC_ST2CW04_MASKVAL_Msk & ((value) << GMAC_ST2CW04_MASKVAL_Pos)))
#define GMAC_ST2CW04_COMPVAL_Pos   16
#define GMAC_ST2CW04_COMPVAL_Msk   (0xffffu << GMAC_ST2CW04_COMPVAL_Pos)
 (GMAC_ST2CW04) Compare Value
#define GMAC_ST2CW04_COMPVAL(value)   ((GMAC_ST2CW04_COMPVAL_Msk & ((value) << GMAC_ST2CW04_COMPVAL_Pos)))
#define GMAC_ST2CW14_OFFSVAL_Pos   0
#define GMAC_ST2CW14_OFFSVAL_Msk   (0x7fu << GMAC_ST2CW14_OFFSVAL_Pos)
 (GMAC_ST2CW14) Offset Value in Bytes
#define GMAC_ST2CW14_OFFSVAL(value)   ((GMAC_ST2CW14_OFFSVAL_Msk & ((value) << GMAC_ST2CW14_OFFSVAL_Pos)))
#define GMAC_ST2CW14_OFFSSTRT_Pos   7
#define GMAC_ST2CW14_OFFSSTRT_Msk   (0x3u << GMAC_ST2CW14_OFFSSTRT_Pos)
 (GMAC_ST2CW14) Ethernet Frame Offset Start
#define GMAC_ST2CW14_OFFSSTRT(value)   ((GMAC_ST2CW14_OFFSSTRT_Msk & ((value) << GMAC_ST2CW14_OFFSSTRT_Pos)))
#define GMAC_ST2CW14_OFFSSTRT_FRAMESTART   (0x0u << 7)
 (GMAC_ST2CW14) Offset from the start of the frame
#define GMAC_ST2CW14_OFFSSTRT_ETHERTYPE   (0x1u << 7)
 (GMAC_ST2CW14) Offset from the byte after the EtherType field
#define GMAC_ST2CW14_OFFSSTRT_IP   (0x2u << 7)
 (GMAC_ST2CW14) Offset from the byte after the IP header field
#define GMAC_ST2CW14_OFFSSTRT_TCP_UDP   (0x3u << 7)
 (GMAC_ST2CW14) Offset from the byte after the TCP/UDP header field
#define GMAC_ST2CW05_MASKVAL_Pos   0
#define GMAC_ST2CW05_MASKVAL_Msk   (0xffffu << GMAC_ST2CW05_MASKVAL_Pos)
 (GMAC_ST2CW05) Mask Value
#define GMAC_ST2CW05_MASKVAL(value)   ((GMAC_ST2CW05_MASKVAL_Msk & ((value) << GMAC_ST2CW05_MASKVAL_Pos)))
#define GMAC_ST2CW05_COMPVAL_Pos   16
#define GMAC_ST2CW05_COMPVAL_Msk   (0xffffu << GMAC_ST2CW05_COMPVAL_Pos)
 (GMAC_ST2CW05) Compare Value
#define GMAC_ST2CW05_COMPVAL(value)   ((GMAC_ST2CW05_COMPVAL_Msk & ((value) << GMAC_ST2CW05_COMPVAL_Pos)))
#define GMAC_ST2CW15_OFFSVAL_Pos   0
#define GMAC_ST2CW15_OFFSVAL_Msk   (0x7fu << GMAC_ST2CW15_OFFSVAL_Pos)
 (GMAC_ST2CW15) Offset Value in Bytes
#define GMAC_ST2CW15_OFFSVAL(value)   ((GMAC_ST2CW15_OFFSVAL_Msk & ((value) << GMAC_ST2CW15_OFFSVAL_Pos)))
#define GMAC_ST2CW15_OFFSSTRT_Pos   7
#define GMAC_ST2CW15_OFFSSTRT_Msk   (0x3u << GMAC_ST2CW15_OFFSSTRT_Pos)
 (GMAC_ST2CW15) Ethernet Frame Offset Start
#define GMAC_ST2CW15_OFFSSTRT(value)   ((GMAC_ST2CW15_OFFSSTRT_Msk & ((value) << GMAC_ST2CW15_OFFSSTRT_Pos)))
#define GMAC_ST2CW15_OFFSSTRT_FRAMESTART   (0x0u << 7)
 (GMAC_ST2CW15) Offset from the start of the frame
#define GMAC_ST2CW15_OFFSSTRT_ETHERTYPE   (0x1u << 7)
 (GMAC_ST2CW15) Offset from the byte after the EtherType field
#define GMAC_ST2CW15_OFFSSTRT_IP   (0x2u << 7)
 (GMAC_ST2CW15) Offset from the byte after the IP header field
#define GMAC_ST2CW15_OFFSSTRT_TCP_UDP   (0x3u << 7)
 (GMAC_ST2CW15) Offset from the byte after the TCP/UDP header field
#define GMAC_ST2CW06_MASKVAL_Pos   0
#define GMAC_ST2CW06_MASKVAL_Msk   (0xffffu << GMAC_ST2CW06_MASKVAL_Pos)
 (GMAC_ST2CW06) Mask Value
#define GMAC_ST2CW06_MASKVAL(value)   ((GMAC_ST2CW06_MASKVAL_Msk & ((value) << GMAC_ST2CW06_MASKVAL_Pos)))
#define GMAC_ST2CW06_COMPVAL_Pos   16
#define GMAC_ST2CW06_COMPVAL_Msk   (0xffffu << GMAC_ST2CW06_COMPVAL_Pos)
 (GMAC_ST2CW06) Compare Value
#define GMAC_ST2CW06_COMPVAL(value)   ((GMAC_ST2CW06_COMPVAL_Msk & ((value) << GMAC_ST2CW06_COMPVAL_Pos)))
#define GMAC_ST2CW16_OFFSVAL_Pos   0
#define GMAC_ST2CW16_OFFSVAL_Msk   (0x7fu << GMAC_ST2CW16_OFFSVAL_Pos)
 (GMAC_ST2CW16) Offset Value in Bytes
#define GMAC_ST2CW16_OFFSVAL(value)   ((GMAC_ST2CW16_OFFSVAL_Msk & ((value) << GMAC_ST2CW16_OFFSVAL_Pos)))
#define GMAC_ST2CW16_OFFSSTRT_Pos   7
#define GMAC_ST2CW16_OFFSSTRT_Msk   (0x3u << GMAC_ST2CW16_OFFSSTRT_Pos)
 (GMAC_ST2CW16) Ethernet Frame Offset Start
#define GMAC_ST2CW16_OFFSSTRT(value)   ((GMAC_ST2CW16_OFFSSTRT_Msk & ((value) << GMAC_ST2CW16_OFFSSTRT_Pos)))
#define GMAC_ST2CW16_OFFSSTRT_FRAMESTART   (0x0u << 7)
 (GMAC_ST2CW16) Offset from the start of the frame
#define GMAC_ST2CW16_OFFSSTRT_ETHERTYPE   (0x1u << 7)
 (GMAC_ST2CW16) Offset from the byte after the EtherType field
#define GMAC_ST2CW16_OFFSSTRT_IP   (0x2u << 7)
 (GMAC_ST2CW16) Offset from the byte after the IP header field
#define GMAC_ST2CW16_OFFSSTRT_TCP_UDP   (0x3u << 7)
 (GMAC_ST2CW16) Offset from the byte after the TCP/UDP header field
#define GMAC_ST2CW07_MASKVAL_Pos   0
#define GMAC_ST2CW07_MASKVAL_Msk   (0xffffu << GMAC_ST2CW07_MASKVAL_Pos)
 (GMAC_ST2CW07) Mask Value
#define GMAC_ST2CW07_MASKVAL(value)   ((GMAC_ST2CW07_MASKVAL_Msk & ((value) << GMAC_ST2CW07_MASKVAL_Pos)))
#define GMAC_ST2CW07_COMPVAL_Pos   16
#define GMAC_ST2CW07_COMPVAL_Msk   (0xffffu << GMAC_ST2CW07_COMPVAL_Pos)
 (GMAC_ST2CW07) Compare Value
#define GMAC_ST2CW07_COMPVAL(value)   ((GMAC_ST2CW07_COMPVAL_Msk & ((value) << GMAC_ST2CW07_COMPVAL_Pos)))
#define GMAC_ST2CW17_OFFSVAL_Pos   0
#define GMAC_ST2CW17_OFFSVAL_Msk   (0x7fu << GMAC_ST2CW17_OFFSVAL_Pos)
 (GMAC_ST2CW17) Offset Value in Bytes
#define GMAC_ST2CW17_OFFSVAL(value)   ((GMAC_ST2CW17_OFFSVAL_Msk & ((value) << GMAC_ST2CW17_OFFSVAL_Pos)))
#define GMAC_ST2CW17_OFFSSTRT_Pos   7
#define GMAC_ST2CW17_OFFSSTRT_Msk   (0x3u << GMAC_ST2CW17_OFFSSTRT_Pos)
 (GMAC_ST2CW17) Ethernet Frame Offset Start
#define GMAC_ST2CW17_OFFSSTRT(value)   ((GMAC_ST2CW17_OFFSSTRT_Msk & ((value) << GMAC_ST2CW17_OFFSSTRT_Pos)))
#define GMAC_ST2CW17_OFFSSTRT_FRAMESTART   (0x0u << 7)
 (GMAC_ST2CW17) Offset from the start of the frame
#define GMAC_ST2CW17_OFFSSTRT_ETHERTYPE   (0x1u << 7)
 (GMAC_ST2CW17) Offset from the byte after the EtherType field
#define GMAC_ST2CW17_OFFSSTRT_IP   (0x2u << 7)
 (GMAC_ST2CW17) Offset from the byte after the IP header field
#define GMAC_ST2CW17_OFFSSTRT_TCP_UDP   (0x3u << 7)
 (GMAC_ST2CW17) Offset from the byte after the TCP/UDP header field
#define GMAC_ST2CW08_MASKVAL_Pos   0
#define GMAC_ST2CW08_MASKVAL_Msk   (0xffffu << GMAC_ST2CW08_MASKVAL_Pos)
 (GMAC_ST2CW08) Mask Value
#define GMAC_ST2CW08_MASKVAL(value)   ((GMAC_ST2CW08_MASKVAL_Msk & ((value) << GMAC_ST2CW08_MASKVAL_Pos)))
#define GMAC_ST2CW08_COMPVAL_Pos   16
#define GMAC_ST2CW08_COMPVAL_Msk   (0xffffu << GMAC_ST2CW08_COMPVAL_Pos)
 (GMAC_ST2CW08) Compare Value
#define GMAC_ST2CW08_COMPVAL(value)   ((GMAC_ST2CW08_COMPVAL_Msk & ((value) << GMAC_ST2CW08_COMPVAL_Pos)))
#define GMAC_ST2CW18_OFFSVAL_Pos   0
#define GMAC_ST2CW18_OFFSVAL_Msk   (0x7fu << GMAC_ST2CW18_OFFSVAL_Pos)
 (GMAC_ST2CW18) Offset Value in Bytes
#define GMAC_ST2CW18_OFFSVAL(value)   ((GMAC_ST2CW18_OFFSVAL_Msk & ((value) << GMAC_ST2CW18_OFFSVAL_Pos)))
#define GMAC_ST2CW18_OFFSSTRT_Pos   7
#define GMAC_ST2CW18_OFFSSTRT_Msk   (0x3u << GMAC_ST2CW18_OFFSSTRT_Pos)
 (GMAC_ST2CW18) Ethernet Frame Offset Start
#define GMAC_ST2CW18_OFFSSTRT(value)   ((GMAC_ST2CW18_OFFSSTRT_Msk & ((value) << GMAC_ST2CW18_OFFSSTRT_Pos)))
#define GMAC_ST2CW18_OFFSSTRT_FRAMESTART   (0x0u << 7)
 (GMAC_ST2CW18) Offset from the start of the frame
#define GMAC_ST2CW18_OFFSSTRT_ETHERTYPE   (0x1u << 7)
 (GMAC_ST2CW18) Offset from the byte after the EtherType field
#define GMAC_ST2CW18_OFFSSTRT_IP   (0x2u << 7)
 (GMAC_ST2CW18) Offset from the byte after the IP header field
#define GMAC_ST2CW18_OFFSSTRT_TCP_UDP   (0x3u << 7)
 (GMAC_ST2CW18) Offset from the byte after the TCP/UDP header field
#define GMAC_ST2CW09_MASKVAL_Pos   0
#define GMAC_ST2CW09_MASKVAL_Msk   (0xffffu << GMAC_ST2CW09_MASKVAL_Pos)
 (GMAC_ST2CW09) Mask Value
#define GMAC_ST2CW09_MASKVAL(value)   ((GMAC_ST2CW09_MASKVAL_Msk & ((value) << GMAC_ST2CW09_MASKVAL_Pos)))
#define GMAC_ST2CW09_COMPVAL_Pos   16
#define GMAC_ST2CW09_COMPVAL_Msk   (0xffffu << GMAC_ST2CW09_COMPVAL_Pos)
 (GMAC_ST2CW09) Compare Value
#define GMAC_ST2CW09_COMPVAL(value)   ((GMAC_ST2CW09_COMPVAL_Msk & ((value) << GMAC_ST2CW09_COMPVAL_Pos)))
#define GMAC_ST2CW19_OFFSVAL_Pos   0
#define GMAC_ST2CW19_OFFSVAL_Msk   (0x7fu << GMAC_ST2CW19_OFFSVAL_Pos)
 (GMAC_ST2CW19) Offset Value in Bytes
#define GMAC_ST2CW19_OFFSVAL(value)   ((GMAC_ST2CW19_OFFSVAL_Msk & ((value) << GMAC_ST2CW19_OFFSVAL_Pos)))
#define GMAC_ST2CW19_OFFSSTRT_Pos   7
#define GMAC_ST2CW19_OFFSSTRT_Msk   (0x3u << GMAC_ST2CW19_OFFSSTRT_Pos)
 (GMAC_ST2CW19) Ethernet Frame Offset Start
#define GMAC_ST2CW19_OFFSSTRT(value)   ((GMAC_ST2CW19_OFFSSTRT_Msk & ((value) << GMAC_ST2CW19_OFFSSTRT_Pos)))
#define GMAC_ST2CW19_OFFSSTRT_FRAMESTART   (0x0u << 7)
 (GMAC_ST2CW19) Offset from the start of the frame
#define GMAC_ST2CW19_OFFSSTRT_ETHERTYPE   (0x1u << 7)
 (GMAC_ST2CW19) Offset from the byte after the EtherType field
#define GMAC_ST2CW19_OFFSSTRT_IP   (0x2u << 7)
 (GMAC_ST2CW19) Offset from the byte after the IP header field
#define GMAC_ST2CW19_OFFSSTRT_TCP_UDP   (0x3u << 7)
 (GMAC_ST2CW19) Offset from the byte after the TCP/UDP header field
#define GMAC_ST2CW010_MASKVAL_Pos   0
#define GMAC_ST2CW010_MASKVAL_Msk   (0xffffu << GMAC_ST2CW010_MASKVAL_Pos)
 (GMAC_ST2CW010) Mask Value
#define GMAC_ST2CW010_MASKVAL(value)   ((GMAC_ST2CW010_MASKVAL_Msk & ((value) << GMAC_ST2CW010_MASKVAL_Pos)))
#define GMAC_ST2CW010_COMPVAL_Pos   16
#define GMAC_ST2CW010_COMPVAL_Msk   (0xffffu << GMAC_ST2CW010_COMPVAL_Pos)
 (GMAC_ST2CW010) Compare Value
#define GMAC_ST2CW010_COMPVAL(value)   ((GMAC_ST2CW010_COMPVAL_Msk & ((value) << GMAC_ST2CW010_COMPVAL_Pos)))
#define GMAC_ST2CW110_OFFSVAL_Pos   0
#define GMAC_ST2CW110_OFFSVAL_Msk   (0x7fu << GMAC_ST2CW110_OFFSVAL_Pos)
 (GMAC_ST2CW110) Offset Value in Bytes
#define GMAC_ST2CW110_OFFSVAL(value)   ((GMAC_ST2CW110_OFFSVAL_Msk & ((value) << GMAC_ST2CW110_OFFSVAL_Pos)))
#define GMAC_ST2CW110_OFFSSTRT_Pos   7
#define GMAC_ST2CW110_OFFSSTRT_Msk   (0x3u << GMAC_ST2CW110_OFFSSTRT_Pos)
 (GMAC_ST2CW110) Ethernet Frame Offset Start
#define GMAC_ST2CW110_OFFSSTRT(value)   ((GMAC_ST2CW110_OFFSSTRT_Msk & ((value) << GMAC_ST2CW110_OFFSSTRT_Pos)))
#define GMAC_ST2CW110_OFFSSTRT_FRAMESTART   (0x0u << 7)
 (GMAC_ST2CW110) Offset from the start of the frame
#define GMAC_ST2CW110_OFFSSTRT_ETHERTYPE   (0x1u << 7)
 (GMAC_ST2CW110) Offset from the byte after the EtherType field
#define GMAC_ST2CW110_OFFSSTRT_IP   (0x2u << 7)
 (GMAC_ST2CW110) Offset from the byte after the IP header field
#define GMAC_ST2CW110_OFFSSTRT_TCP_UDP   (0x3u << 7)
 (GMAC_ST2CW110) Offset from the byte after the TCP/UDP header field
#define GMAC_ST2CW011_MASKVAL_Pos   0
#define GMAC_ST2CW011_MASKVAL_Msk   (0xffffu << GMAC_ST2CW011_MASKVAL_Pos)
 (GMAC_ST2CW011) Mask Value
#define GMAC_ST2CW011_MASKVAL(value)   ((GMAC_ST2CW011_MASKVAL_Msk & ((value) << GMAC_ST2CW011_MASKVAL_Pos)))
#define GMAC_ST2CW011_COMPVAL_Pos   16
#define GMAC_ST2CW011_COMPVAL_Msk   (0xffffu << GMAC_ST2CW011_COMPVAL_Pos)
 (GMAC_ST2CW011) Compare Value
#define GMAC_ST2CW011_COMPVAL(value)   ((GMAC_ST2CW011_COMPVAL_Msk & ((value) << GMAC_ST2CW011_COMPVAL_Pos)))
#define GMAC_ST2CW111_OFFSVAL_Pos   0
#define GMAC_ST2CW111_OFFSVAL_Msk   (0x7fu << GMAC_ST2CW111_OFFSVAL_Pos)
 (GMAC_ST2CW111) Offset Value in Bytes
#define GMAC_ST2CW111_OFFSVAL(value)   ((GMAC_ST2CW111_OFFSVAL_Msk & ((value) << GMAC_ST2CW111_OFFSVAL_Pos)))
#define GMAC_ST2CW111_OFFSSTRT_Pos   7
#define GMAC_ST2CW111_OFFSSTRT_Msk   (0x3u << GMAC_ST2CW111_OFFSSTRT_Pos)
 (GMAC_ST2CW111) Ethernet Frame Offset Start
#define GMAC_ST2CW111_OFFSSTRT(value)   ((GMAC_ST2CW111_OFFSSTRT_Msk & ((value) << GMAC_ST2CW111_OFFSSTRT_Pos)))
#define GMAC_ST2CW111_OFFSSTRT_FRAMESTART   (0x0u << 7)
 (GMAC_ST2CW111) Offset from the start of the frame
#define GMAC_ST2CW111_OFFSSTRT_ETHERTYPE   (0x1u << 7)
 (GMAC_ST2CW111) Offset from the byte after the EtherType field
#define GMAC_ST2CW111_OFFSSTRT_IP   (0x2u << 7)
 (GMAC_ST2CW111) Offset from the byte after the IP header field
#define GMAC_ST2CW111_OFFSSTRT_TCP_UDP   (0x3u << 7)
 (GMAC_ST2CW111) Offset from the byte after the TCP/UDP header field
#define GMAC_ST2CW012_MASKVAL_Pos   0
#define GMAC_ST2CW012_MASKVAL_Msk   (0xffffu << GMAC_ST2CW012_MASKVAL_Pos)
 (GMAC_ST2CW012) Mask Value
#define GMAC_ST2CW012_MASKVAL(value)   ((GMAC_ST2CW012_MASKVAL_Msk & ((value) << GMAC_ST2CW012_MASKVAL_Pos)))
#define GMAC_ST2CW012_COMPVAL_Pos   16
#define GMAC_ST2CW012_COMPVAL_Msk   (0xffffu << GMAC_ST2CW012_COMPVAL_Pos)
 (GMAC_ST2CW012) Compare Value
#define GMAC_ST2CW012_COMPVAL(value)   ((GMAC_ST2CW012_COMPVAL_Msk & ((value) << GMAC_ST2CW012_COMPVAL_Pos)))
#define GMAC_ST2CW112_OFFSVAL_Pos   0
#define GMAC_ST2CW112_OFFSVAL_Msk   (0x7fu << GMAC_ST2CW112_OFFSVAL_Pos)
 (GMAC_ST2CW112) Offset Value in Bytes
#define GMAC_ST2CW112_OFFSVAL(value)   ((GMAC_ST2CW112_OFFSVAL_Msk & ((value) << GMAC_ST2CW112_OFFSVAL_Pos)))
#define GMAC_ST2CW112_OFFSSTRT_Pos   7
#define GMAC_ST2CW112_OFFSSTRT_Msk   (0x3u << GMAC_ST2CW112_OFFSSTRT_Pos)
 (GMAC_ST2CW112) Ethernet Frame Offset Start
#define GMAC_ST2CW112_OFFSSTRT(value)   ((GMAC_ST2CW112_OFFSSTRT_Msk & ((value) << GMAC_ST2CW112_OFFSSTRT_Pos)))
#define GMAC_ST2CW112_OFFSSTRT_FRAMESTART   (0x0u << 7)
 (GMAC_ST2CW112) Offset from the start of the frame
#define GMAC_ST2CW112_OFFSSTRT_ETHERTYPE   (0x1u << 7)
 (GMAC_ST2CW112) Offset from the byte after the EtherType field
#define GMAC_ST2CW112_OFFSSTRT_IP   (0x2u << 7)
 (GMAC_ST2CW112) Offset from the byte after the IP header field
#define GMAC_ST2CW112_OFFSSTRT_TCP_UDP   (0x3u << 7)
 (GMAC_ST2CW112) Offset from the byte after the TCP/UDP header field
#define GMAC_ST2CW013_MASKVAL_Pos   0
#define GMAC_ST2CW013_MASKVAL_Msk   (0xffffu << GMAC_ST2CW013_MASKVAL_Pos)
 (GMAC_ST2CW013) Mask Value
#define GMAC_ST2CW013_MASKVAL(value)   ((GMAC_ST2CW013_MASKVAL_Msk & ((value) << GMAC_ST2CW013_MASKVAL_Pos)))
#define GMAC_ST2CW013_COMPVAL_Pos   16
#define GMAC_ST2CW013_COMPVAL_Msk   (0xffffu << GMAC_ST2CW013_COMPVAL_Pos)
 (GMAC_ST2CW013) Compare Value
#define GMAC_ST2CW013_COMPVAL(value)   ((GMAC_ST2CW013_COMPVAL_Msk & ((value) << GMAC_ST2CW013_COMPVAL_Pos)))
#define GMAC_ST2CW113_OFFSVAL_Pos   0
#define GMAC_ST2CW113_OFFSVAL_Msk   (0x7fu << GMAC_ST2CW113_OFFSVAL_Pos)
 (GMAC_ST2CW113) Offset Value in Bytes
#define GMAC_ST2CW113_OFFSVAL(value)   ((GMAC_ST2CW113_OFFSVAL_Msk & ((value) << GMAC_ST2CW113_OFFSVAL_Pos)))
#define GMAC_ST2CW113_OFFSSTRT_Pos   7
#define GMAC_ST2CW113_OFFSSTRT_Msk   (0x3u << GMAC_ST2CW113_OFFSSTRT_Pos)
 (GMAC_ST2CW113) Ethernet Frame Offset Start
#define GMAC_ST2CW113_OFFSSTRT(value)   ((GMAC_ST2CW113_OFFSSTRT_Msk & ((value) << GMAC_ST2CW113_OFFSSTRT_Pos)))
#define GMAC_ST2CW113_OFFSSTRT_FRAMESTART   (0x0u << 7)
 (GMAC_ST2CW113) Offset from the start of the frame
#define GMAC_ST2CW113_OFFSSTRT_ETHERTYPE   (0x1u << 7)
 (GMAC_ST2CW113) Offset from the byte after the EtherType field
#define GMAC_ST2CW113_OFFSSTRT_IP   (0x2u << 7)
 (GMAC_ST2CW113) Offset from the byte after the IP header field
#define GMAC_ST2CW113_OFFSSTRT_TCP_UDP   (0x3u << 7)
 (GMAC_ST2CW113) Offset from the byte after the TCP/UDP header field
#define GMAC_ST2CW014_MASKVAL_Pos   0
#define GMAC_ST2CW014_MASKVAL_Msk   (0xffffu << GMAC_ST2CW014_MASKVAL_Pos)
 (GMAC_ST2CW014) Mask Value
#define GMAC_ST2CW014_MASKVAL(value)   ((GMAC_ST2CW014_MASKVAL_Msk & ((value) << GMAC_ST2CW014_MASKVAL_Pos)))
#define GMAC_ST2CW014_COMPVAL_Pos   16
#define GMAC_ST2CW014_COMPVAL_Msk   (0xffffu << GMAC_ST2CW014_COMPVAL_Pos)
 (GMAC_ST2CW014) Compare Value
#define GMAC_ST2CW014_COMPVAL(value)   ((GMAC_ST2CW014_COMPVAL_Msk & ((value) << GMAC_ST2CW014_COMPVAL_Pos)))
#define GMAC_ST2CW114_OFFSVAL_Pos   0
#define GMAC_ST2CW114_OFFSVAL_Msk   (0x7fu << GMAC_ST2CW114_OFFSVAL_Pos)
 (GMAC_ST2CW114) Offset Value in Bytes
#define GMAC_ST2CW114_OFFSVAL(value)   ((GMAC_ST2CW114_OFFSVAL_Msk & ((value) << GMAC_ST2CW114_OFFSVAL_Pos)))
#define GMAC_ST2CW114_OFFSSTRT_Pos   7
#define GMAC_ST2CW114_OFFSSTRT_Msk   (0x3u << GMAC_ST2CW114_OFFSSTRT_Pos)
 (GMAC_ST2CW114) Ethernet Frame Offset Start
#define GMAC_ST2CW114_OFFSSTRT(value)   ((GMAC_ST2CW114_OFFSSTRT_Msk & ((value) << GMAC_ST2CW114_OFFSSTRT_Pos)))
#define GMAC_ST2CW114_OFFSSTRT_FRAMESTART   (0x0u << 7)
 (GMAC_ST2CW114) Offset from the start of the frame
#define GMAC_ST2CW114_OFFSSTRT_ETHERTYPE   (0x1u << 7)
 (GMAC_ST2CW114) Offset from the byte after the EtherType field
#define GMAC_ST2CW114_OFFSSTRT_IP   (0x2u << 7)
 (GMAC_ST2CW114) Offset from the byte after the IP header field
#define GMAC_ST2CW114_OFFSSTRT_TCP_UDP   (0x3u << 7)
 (GMAC_ST2CW114) Offset from the byte after the TCP/UDP header field
#define GMAC_ST2CW015_MASKVAL_Pos   0
#define GMAC_ST2CW015_MASKVAL_Msk   (0xffffu << GMAC_ST2CW015_MASKVAL_Pos)
 (GMAC_ST2CW015) Mask Value
#define GMAC_ST2CW015_MASKVAL(value)   ((GMAC_ST2CW015_MASKVAL_Msk & ((value) << GMAC_ST2CW015_MASKVAL_Pos)))
#define GMAC_ST2CW015_COMPVAL_Pos   16
#define GMAC_ST2CW015_COMPVAL_Msk   (0xffffu << GMAC_ST2CW015_COMPVAL_Pos)
 (GMAC_ST2CW015) Compare Value
#define GMAC_ST2CW015_COMPVAL(value)   ((GMAC_ST2CW015_COMPVAL_Msk & ((value) << GMAC_ST2CW015_COMPVAL_Pos)))
#define GMAC_ST2CW115_OFFSVAL_Pos   0
#define GMAC_ST2CW115_OFFSVAL_Msk   (0x7fu << GMAC_ST2CW115_OFFSVAL_Pos)
 (GMAC_ST2CW115) Offset Value in Bytes
#define GMAC_ST2CW115_OFFSVAL(value)   ((GMAC_ST2CW115_OFFSVAL_Msk & ((value) << GMAC_ST2CW115_OFFSVAL_Pos)))
#define GMAC_ST2CW115_OFFSSTRT_Pos   7
#define GMAC_ST2CW115_OFFSSTRT_Msk   (0x3u << GMAC_ST2CW115_OFFSSTRT_Pos)
 (GMAC_ST2CW115) Ethernet Frame Offset Start
#define GMAC_ST2CW115_OFFSSTRT(value)   ((GMAC_ST2CW115_OFFSSTRT_Msk & ((value) << GMAC_ST2CW115_OFFSSTRT_Pos)))
#define GMAC_ST2CW115_OFFSSTRT_FRAMESTART   (0x0u << 7)
 (GMAC_ST2CW115) Offset from the start of the frame
#define GMAC_ST2CW115_OFFSSTRT_ETHERTYPE   (0x1u << 7)
 (GMAC_ST2CW115) Offset from the byte after the EtherType field
#define GMAC_ST2CW115_OFFSSTRT_IP   (0x2u << 7)
 (GMAC_ST2CW115) Offset from the byte after the IP header field
#define GMAC_ST2CW115_OFFSSTRT_TCP_UDP   (0x3u << 7)
 (GMAC_ST2CW115) Offset from the byte after the TCP/UDP header field
#define GMAC_ST2CW016_MASKVAL_Pos   0
#define GMAC_ST2CW016_MASKVAL_Msk   (0xffffu << GMAC_ST2CW016_MASKVAL_Pos)
 (GMAC_ST2CW016) Mask Value
#define GMAC_ST2CW016_MASKVAL(value)   ((GMAC_ST2CW016_MASKVAL_Msk & ((value) << GMAC_ST2CW016_MASKVAL_Pos)))
#define GMAC_ST2CW016_COMPVAL_Pos   16
#define GMAC_ST2CW016_COMPVAL_Msk   (0xffffu << GMAC_ST2CW016_COMPVAL_Pos)
 (GMAC_ST2CW016) Compare Value
#define GMAC_ST2CW016_COMPVAL(value)   ((GMAC_ST2CW016_COMPVAL_Msk & ((value) << GMAC_ST2CW016_COMPVAL_Pos)))
#define GMAC_ST2CW116_OFFSVAL_Pos   0
#define GMAC_ST2CW116_OFFSVAL_Msk   (0x7fu << GMAC_ST2CW116_OFFSVAL_Pos)
 (GMAC_ST2CW116) Offset Value in Bytes
#define GMAC_ST2CW116_OFFSVAL(value)   ((GMAC_ST2CW116_OFFSVAL_Msk & ((value) << GMAC_ST2CW116_OFFSVAL_Pos)))
#define GMAC_ST2CW116_OFFSSTRT_Pos   7
#define GMAC_ST2CW116_OFFSSTRT_Msk   (0x3u << GMAC_ST2CW116_OFFSSTRT_Pos)
 (GMAC_ST2CW116) Ethernet Frame Offset Start
#define GMAC_ST2CW116_OFFSSTRT(value)   ((GMAC_ST2CW116_OFFSSTRT_Msk & ((value) << GMAC_ST2CW116_OFFSSTRT_Pos)))
#define GMAC_ST2CW116_OFFSSTRT_FRAMESTART   (0x0u << 7)
 (GMAC_ST2CW116) Offset from the start of the frame
#define GMAC_ST2CW116_OFFSSTRT_ETHERTYPE   (0x1u << 7)
 (GMAC_ST2CW116) Offset from the byte after the EtherType field
#define GMAC_ST2CW116_OFFSSTRT_IP   (0x2u << 7)
 (GMAC_ST2CW116) Offset from the byte after the IP header field
#define GMAC_ST2CW116_OFFSSTRT_TCP_UDP   (0x3u << 7)
 (GMAC_ST2CW116) Offset from the byte after the TCP/UDP header field
#define GMAC_ST2CW017_MASKVAL_Pos   0
#define GMAC_ST2CW017_MASKVAL_Msk   (0xffffu << GMAC_ST2CW017_MASKVAL_Pos)
 (GMAC_ST2CW017) Mask Value
#define GMAC_ST2CW017_MASKVAL(value)   ((GMAC_ST2CW017_MASKVAL_Msk & ((value) << GMAC_ST2CW017_MASKVAL_Pos)))
#define GMAC_ST2CW017_COMPVAL_Pos   16
#define GMAC_ST2CW017_COMPVAL_Msk   (0xffffu << GMAC_ST2CW017_COMPVAL_Pos)
 (GMAC_ST2CW017) Compare Value
#define GMAC_ST2CW017_COMPVAL(value)   ((GMAC_ST2CW017_COMPVAL_Msk & ((value) << GMAC_ST2CW017_COMPVAL_Pos)))
#define GMAC_ST2CW117_OFFSVAL_Pos   0
#define GMAC_ST2CW117_OFFSVAL_Msk   (0x7fu << GMAC_ST2CW117_OFFSVAL_Pos)
 (GMAC_ST2CW117) Offset Value in Bytes
#define GMAC_ST2CW117_OFFSVAL(value)   ((GMAC_ST2CW117_OFFSVAL_Msk & ((value) << GMAC_ST2CW117_OFFSVAL_Pos)))
#define GMAC_ST2CW117_OFFSSTRT_Pos   7
#define GMAC_ST2CW117_OFFSSTRT_Msk   (0x3u << GMAC_ST2CW117_OFFSSTRT_Pos)
 (GMAC_ST2CW117) Ethernet Frame Offset Start
#define GMAC_ST2CW117_OFFSSTRT(value)   ((GMAC_ST2CW117_OFFSSTRT_Msk & ((value) << GMAC_ST2CW117_OFFSSTRT_Pos)))
#define GMAC_ST2CW117_OFFSSTRT_FRAMESTART   (0x0u << 7)
 (GMAC_ST2CW117) Offset from the start of the frame
#define GMAC_ST2CW117_OFFSSTRT_ETHERTYPE   (0x1u << 7)
 (GMAC_ST2CW117) Offset from the byte after the EtherType field
#define GMAC_ST2CW117_OFFSSTRT_IP   (0x2u << 7)
 (GMAC_ST2CW117) Offset from the byte after the IP header field
#define GMAC_ST2CW117_OFFSSTRT_TCP_UDP   (0x3u << 7)
 (GMAC_ST2CW117) Offset from the byte after the TCP/UDP header field
#define GMAC_ST2CW018_MASKVAL_Pos   0
#define GMAC_ST2CW018_MASKVAL_Msk   (0xffffu << GMAC_ST2CW018_MASKVAL_Pos)
 (GMAC_ST2CW018) Mask Value
#define GMAC_ST2CW018_MASKVAL(value)   ((GMAC_ST2CW018_MASKVAL_Msk & ((value) << GMAC_ST2CW018_MASKVAL_Pos)))
#define GMAC_ST2CW018_COMPVAL_Pos   16
#define GMAC_ST2CW018_COMPVAL_Msk   (0xffffu << GMAC_ST2CW018_COMPVAL_Pos)
 (GMAC_ST2CW018) Compare Value
#define GMAC_ST2CW018_COMPVAL(value)   ((GMAC_ST2CW018_COMPVAL_Msk & ((value) << GMAC_ST2CW018_COMPVAL_Pos)))
#define GMAC_ST2CW118_OFFSVAL_Pos   0
#define GMAC_ST2CW118_OFFSVAL_Msk   (0x7fu << GMAC_ST2CW118_OFFSVAL_Pos)
 (GMAC_ST2CW118) Offset Value in Bytes
#define GMAC_ST2CW118_OFFSVAL(value)   ((GMAC_ST2CW118_OFFSVAL_Msk & ((value) << GMAC_ST2CW118_OFFSVAL_Pos)))
#define GMAC_ST2CW118_OFFSSTRT_Pos   7
#define GMAC_ST2CW118_OFFSSTRT_Msk   (0x3u << GMAC_ST2CW118_OFFSSTRT_Pos)
 (GMAC_ST2CW118) Ethernet Frame Offset Start
#define GMAC_ST2CW118_OFFSSTRT(value)   ((GMAC_ST2CW118_OFFSSTRT_Msk & ((value) << GMAC_ST2CW118_OFFSSTRT_Pos)))
#define GMAC_ST2CW118_OFFSSTRT_FRAMESTART   (0x0u << 7)
 (GMAC_ST2CW118) Offset from the start of the frame
#define GMAC_ST2CW118_OFFSSTRT_ETHERTYPE   (0x1u << 7)
 (GMAC_ST2CW118) Offset from the byte after the EtherType field
#define GMAC_ST2CW118_OFFSSTRT_IP   (0x2u << 7)
 (GMAC_ST2CW118) Offset from the byte after the IP header field
#define GMAC_ST2CW118_OFFSSTRT_TCP_UDP   (0x3u << 7)
 (GMAC_ST2CW118) Offset from the byte after the TCP/UDP header field
#define GMAC_ST2CW019_MASKVAL_Pos   0
#define GMAC_ST2CW019_MASKVAL_Msk   (0xffffu << GMAC_ST2CW019_MASKVAL_Pos)
 (GMAC_ST2CW019) Mask Value
#define GMAC_ST2CW019_MASKVAL(value)   ((GMAC_ST2CW019_MASKVAL_Msk & ((value) << GMAC_ST2CW019_MASKVAL_Pos)))
#define GMAC_ST2CW019_COMPVAL_Pos   16
#define GMAC_ST2CW019_COMPVAL_Msk   (0xffffu << GMAC_ST2CW019_COMPVAL_Pos)
 (GMAC_ST2CW019) Compare Value
#define GMAC_ST2CW019_COMPVAL(value)   ((GMAC_ST2CW019_COMPVAL_Msk & ((value) << GMAC_ST2CW019_COMPVAL_Pos)))
#define GMAC_ST2CW119_OFFSVAL_Pos   0
#define GMAC_ST2CW119_OFFSVAL_Msk   (0x7fu << GMAC_ST2CW119_OFFSVAL_Pos)
 (GMAC_ST2CW119) Offset Value in Bytes
#define GMAC_ST2CW119_OFFSVAL(value)   ((GMAC_ST2CW119_OFFSVAL_Msk & ((value) << GMAC_ST2CW119_OFFSVAL_Pos)))
#define GMAC_ST2CW119_OFFSSTRT_Pos   7
#define GMAC_ST2CW119_OFFSSTRT_Msk   (0x3u << GMAC_ST2CW119_OFFSSTRT_Pos)
 (GMAC_ST2CW119) Ethernet Frame Offset Start
#define GMAC_ST2CW119_OFFSSTRT(value)   ((GMAC_ST2CW119_OFFSSTRT_Msk & ((value) << GMAC_ST2CW119_OFFSSTRT_Pos)))
#define GMAC_ST2CW119_OFFSSTRT_FRAMESTART   (0x0u << 7)
 (GMAC_ST2CW119) Offset from the start of the frame
#define GMAC_ST2CW119_OFFSSTRT_ETHERTYPE   (0x1u << 7)
 (GMAC_ST2CW119) Offset from the byte after the EtherType field
#define GMAC_ST2CW119_OFFSSTRT_IP   (0x2u << 7)
 (GMAC_ST2CW119) Offset from the byte after the IP header field
#define GMAC_ST2CW119_OFFSSTRT_TCP_UDP   (0x3u << 7)
 (GMAC_ST2CW119) Offset from the byte after the TCP/UDP header field
#define GMAC_ST2CW020_MASKVAL_Pos   0
#define GMAC_ST2CW020_MASKVAL_Msk   (0xffffu << GMAC_ST2CW020_MASKVAL_Pos)
 (GMAC_ST2CW020) Mask Value
#define GMAC_ST2CW020_MASKVAL(value)   ((GMAC_ST2CW020_MASKVAL_Msk & ((value) << GMAC_ST2CW020_MASKVAL_Pos)))
#define GMAC_ST2CW020_COMPVAL_Pos   16
#define GMAC_ST2CW020_COMPVAL_Msk   (0xffffu << GMAC_ST2CW020_COMPVAL_Pos)
 (GMAC_ST2CW020) Compare Value
#define GMAC_ST2CW020_COMPVAL(value)   ((GMAC_ST2CW020_COMPVAL_Msk & ((value) << GMAC_ST2CW020_COMPVAL_Pos)))
#define GMAC_ST2CW120_OFFSVAL_Pos   0
#define GMAC_ST2CW120_OFFSVAL_Msk   (0x7fu << GMAC_ST2CW120_OFFSVAL_Pos)
 (GMAC_ST2CW120) Offset Value in Bytes
#define GMAC_ST2CW120_OFFSVAL(value)   ((GMAC_ST2CW120_OFFSVAL_Msk & ((value) << GMAC_ST2CW120_OFFSVAL_Pos)))
#define GMAC_ST2CW120_OFFSSTRT_Pos   7
#define GMAC_ST2CW120_OFFSSTRT_Msk   (0x3u << GMAC_ST2CW120_OFFSSTRT_Pos)
 (GMAC_ST2CW120) Ethernet Frame Offset Start
#define GMAC_ST2CW120_OFFSSTRT(value)   ((GMAC_ST2CW120_OFFSSTRT_Msk & ((value) << GMAC_ST2CW120_OFFSSTRT_Pos)))
#define GMAC_ST2CW120_OFFSSTRT_FRAMESTART   (0x0u << 7)
 (GMAC_ST2CW120) Offset from the start of the frame
#define GMAC_ST2CW120_OFFSSTRT_ETHERTYPE   (0x1u << 7)
 (GMAC_ST2CW120) Offset from the byte after the EtherType field
#define GMAC_ST2CW120_OFFSSTRT_IP   (0x2u << 7)
 (GMAC_ST2CW120) Offset from the byte after the IP header field
#define GMAC_ST2CW120_OFFSSTRT_TCP_UDP   (0x3u << 7)
 (GMAC_ST2CW120) Offset from the byte after the TCP/UDP header field
#define GMAC_ST2CW021_MASKVAL_Pos   0
#define GMAC_ST2CW021_MASKVAL_Msk   (0xffffu << GMAC_ST2CW021_MASKVAL_Pos)
 (GMAC_ST2CW021) Mask Value
#define GMAC_ST2CW021_MASKVAL(value)   ((GMAC_ST2CW021_MASKVAL_Msk & ((value) << GMAC_ST2CW021_MASKVAL_Pos)))
#define GMAC_ST2CW021_COMPVAL_Pos   16
#define GMAC_ST2CW021_COMPVAL_Msk   (0xffffu << GMAC_ST2CW021_COMPVAL_Pos)
 (GMAC_ST2CW021) Compare Value
#define GMAC_ST2CW021_COMPVAL(value)   ((GMAC_ST2CW021_COMPVAL_Msk & ((value) << GMAC_ST2CW021_COMPVAL_Pos)))
#define GMAC_ST2CW121_OFFSVAL_Pos   0
#define GMAC_ST2CW121_OFFSVAL_Msk   (0x7fu << GMAC_ST2CW121_OFFSVAL_Pos)
 (GMAC_ST2CW121) Offset Value in Bytes
#define GMAC_ST2CW121_OFFSVAL(value)   ((GMAC_ST2CW121_OFFSVAL_Msk & ((value) << GMAC_ST2CW121_OFFSVAL_Pos)))
#define GMAC_ST2CW121_OFFSSTRT_Pos   7
#define GMAC_ST2CW121_OFFSSTRT_Msk   (0x3u << GMAC_ST2CW121_OFFSSTRT_Pos)
 (GMAC_ST2CW121) Ethernet Frame Offset Start
#define GMAC_ST2CW121_OFFSSTRT(value)   ((GMAC_ST2CW121_OFFSSTRT_Msk & ((value) << GMAC_ST2CW121_OFFSSTRT_Pos)))
#define GMAC_ST2CW121_OFFSSTRT_FRAMESTART   (0x0u << 7)
 (GMAC_ST2CW121) Offset from the start of the frame
#define GMAC_ST2CW121_OFFSSTRT_ETHERTYPE   (0x1u << 7)
 (GMAC_ST2CW121) Offset from the byte after the EtherType field
#define GMAC_ST2CW121_OFFSSTRT_IP   (0x2u << 7)
 (GMAC_ST2CW121) Offset from the byte after the IP header field
#define GMAC_ST2CW121_OFFSSTRT_TCP_UDP   (0x3u << 7)
 (GMAC_ST2CW121) Offset from the byte after the TCP/UDP header field
#define GMAC_ST2CW022_MASKVAL_Pos   0
#define GMAC_ST2CW022_MASKVAL_Msk   (0xffffu << GMAC_ST2CW022_MASKVAL_Pos)
 (GMAC_ST2CW022) Mask Value
#define GMAC_ST2CW022_MASKVAL(value)   ((GMAC_ST2CW022_MASKVAL_Msk & ((value) << GMAC_ST2CW022_MASKVAL_Pos)))
#define GMAC_ST2CW022_COMPVAL_Pos   16
#define GMAC_ST2CW022_COMPVAL_Msk   (0xffffu << GMAC_ST2CW022_COMPVAL_Pos)
 (GMAC_ST2CW022) Compare Value
#define GMAC_ST2CW022_COMPVAL(value)   ((GMAC_ST2CW022_COMPVAL_Msk & ((value) << GMAC_ST2CW022_COMPVAL_Pos)))
#define GMAC_ST2CW122_OFFSVAL_Pos   0
#define GMAC_ST2CW122_OFFSVAL_Msk   (0x7fu << GMAC_ST2CW122_OFFSVAL_Pos)
 (GMAC_ST2CW122) Offset Value in Bytes
#define GMAC_ST2CW122_OFFSVAL(value)   ((GMAC_ST2CW122_OFFSVAL_Msk & ((value) << GMAC_ST2CW122_OFFSVAL_Pos)))
#define GMAC_ST2CW122_OFFSSTRT_Pos   7
#define GMAC_ST2CW122_OFFSSTRT_Msk   (0x3u << GMAC_ST2CW122_OFFSSTRT_Pos)
 (GMAC_ST2CW122) Ethernet Frame Offset Start
#define GMAC_ST2CW122_OFFSSTRT(value)   ((GMAC_ST2CW122_OFFSSTRT_Msk & ((value) << GMAC_ST2CW122_OFFSSTRT_Pos)))
#define GMAC_ST2CW122_OFFSSTRT_FRAMESTART   (0x0u << 7)
 (GMAC_ST2CW122) Offset from the start of the frame
#define GMAC_ST2CW122_OFFSSTRT_ETHERTYPE   (0x1u << 7)
 (GMAC_ST2CW122) Offset from the byte after the EtherType field
#define GMAC_ST2CW122_OFFSSTRT_IP   (0x2u << 7)
 (GMAC_ST2CW122) Offset from the byte after the IP header field
#define GMAC_ST2CW122_OFFSSTRT_TCP_UDP   (0x3u << 7)
 (GMAC_ST2CW122) Offset from the byte after the TCP/UDP header field
#define GMAC_ST2CW023_MASKVAL_Pos   0
#define GMAC_ST2CW023_MASKVAL_Msk   (0xffffu << GMAC_ST2CW023_MASKVAL_Pos)
 (GMAC_ST2CW023) Mask Value
#define GMAC_ST2CW023_MASKVAL(value)   ((GMAC_ST2CW023_MASKVAL_Msk & ((value) << GMAC_ST2CW023_MASKVAL_Pos)))
#define GMAC_ST2CW023_COMPVAL_Pos   16
#define GMAC_ST2CW023_COMPVAL_Msk   (0xffffu << GMAC_ST2CW023_COMPVAL_Pos)
 (GMAC_ST2CW023) Compare Value
#define GMAC_ST2CW023_COMPVAL(value)   ((GMAC_ST2CW023_COMPVAL_Msk & ((value) << GMAC_ST2CW023_COMPVAL_Pos)))
#define GMAC_ST2CW123_OFFSVAL_Pos   0
#define GMAC_ST2CW123_OFFSVAL_Msk   (0x7fu << GMAC_ST2CW123_OFFSVAL_Pos)
 (GMAC_ST2CW123) Offset Value in Bytes
#define GMAC_ST2CW123_OFFSVAL(value)   ((GMAC_ST2CW123_OFFSVAL_Msk & ((value) << GMAC_ST2CW123_OFFSVAL_Pos)))
#define GMAC_ST2CW123_OFFSSTRT_Pos   7
#define GMAC_ST2CW123_OFFSSTRT_Msk   (0x3u << GMAC_ST2CW123_OFFSSTRT_Pos)
 (GMAC_ST2CW123) Ethernet Frame Offset Start
#define GMAC_ST2CW123_OFFSSTRT(value)   ((GMAC_ST2CW123_OFFSSTRT_Msk & ((value) << GMAC_ST2CW123_OFFSSTRT_Pos)))
#define GMAC_ST2CW123_OFFSSTRT_FRAMESTART   (0x0u << 7)
 (GMAC_ST2CW123) Offset from the start of the frame
#define GMAC_ST2CW123_OFFSSTRT_ETHERTYPE   (0x1u << 7)
 (GMAC_ST2CW123) Offset from the byte after the EtherType field
#define GMAC_ST2CW123_OFFSSTRT_IP   (0x2u << 7)
 (GMAC_ST2CW123) Offset from the byte after the IP header field
#define GMAC_ST2CW123_OFFSSTRT_TCP_UDP   (0x3u << 7)
 (GMAC_ST2CW123) Offset from the byte after the TCP/UDP header field
SOFTWARE API DEFINITION FOR Gigabit Ethernet MAC
