RTEMS  5.1
Data Structures | Macros
struct  Dacc
 Dacc hardware registers. More...
#define DACC_CR_SWRST   (0x1u << 0)
 (DACC_CR) Software Reset
#define DACC_MR_MAXS0   (0x1u << 0)
 (DACC_MR) Max Speed Mode for Channel 0
#define DACC_MR_MAXS0_TRIG_EVENT   (0x0u << 0)
 (DACC_MR) External trigger mode or Free-running mode enabled. (See TRGENx.DACC_TRIGR.)
#define DACC_MR_MAXS0_MAXIMUM   (0x1u << 0)
 (DACC_MR) Max speed mode enabled.
#define DACC_MR_MAXS1   (0x1u << 1)
 (DACC_MR) Max Speed Mode for Channel 1
#define DACC_MR_MAXS1_TRIG_EVENT   (0x0u << 1)
#define DACC_MR_MAXS1_MAXIMUM   (0x1u << 1)
#define DACC_MR_WORD   (0x1u << 4)
 (DACC_MR) Word Transfer Mode
#define DACC_MR_WORD_DISABLED   (0x0u << 4)
 (DACC_MR) One data to convert is written to the FIFO per access to DACC.
#define DACC_MR_WORD_ENABLED   (0x1u << 4)
 (DACC_MR) Two data to convert are written to the FIFO per access to DACC (reduces the number of requests to DMA and the number of system bus accesses).
#define DACC_MR_ZERO   (0x1u << 5)
 (DACC_MR) Must always be written to 0.
#define DACC_MR_DIFF   (0x1u << 23)
 (DACC_MR) Differential Mode
#define DACC_MR_DIFF_DISABLED   (0x0u << 23)
 (DACC_MR) DAC0 and DAC1 are single-ended outputs.
#define DACC_MR_DIFF_ENABLED   (0x1u << 23)
 (DACC_MR) DACP and DACN are differential outputs. The differential level is configured by the channel 0 value.
#define DACC_MR_PRESCALER_Pos   24
#define DACC_MR_PRESCALER_Msk   (0xfu << DACC_MR_PRESCALER_Pos)
 (DACC_MR) Peripheral Clock to DAC Clock Ratio
#define DACC_MR_PRESCALER(value)   ((DACC_MR_PRESCALER_Msk & ((value) << DACC_MR_PRESCALER_Pos)))
#define DACC_TRIGR_TRGEN0   (0x1u << 0)
 (DACC_TRIGR) Trigger Enable of Channel 0
#define DACC_TRIGR_TRGEN0_DIS   (0x0u << 0)
 (DACC_TRIGR) External trigger mode disabled. DACC is in Free-running mode or Max speed mode.
#define DACC_TRIGR_TRGEN0_EN   (0x1u << 0)
 (DACC_TRIGR) External trigger mode enabled.
#define DACC_TRIGR_TRGEN1   (0x1u << 1)
 (DACC_TRIGR) Trigger Enable of Channel 1
#define DACC_TRIGR_TRGEN1_DIS   (0x0u << 1)
#define DACC_TRIGR_TRGEN1_EN   (0x1u << 1)
#define DACC_TRIGR_TRGSEL0_Pos   4
#define DACC_TRIGR_TRGSEL0_Msk   (0x7u << DACC_TRIGR_TRGSEL0_Pos)
 (DACC_TRIGR) Trigger Selection of Channel 0
#define DACC_TRIGR_TRGSEL0(value)   ((DACC_TRIGR_TRGSEL0_Msk & ((value) << DACC_TRIGR_TRGSEL0_Pos)))
#define DACC_TRIGR_TRGSEL0_TRGSEL0   (0x0u << 4)
 (DACC_TRIGR) TC0 output
#define DACC_TRIGR_TRGSEL0_TRGSEL1   (0x1u << 4)
 (DACC_TRIGR) TC1 output
#define DACC_TRIGR_TRGSEL0_TRGSEL2   (0x2u << 4)
 (DACC_TRIGR) TC2 output
#define DACC_TRIGR_TRGSEL0_TRGSEL3   (0x3u << 4)
 (DACC_TRIGR) PWM0 event 0
#define DACC_TRIGR_TRGSEL0_TRGSEL4   (0x4u << 4)
 (DACC_TRIGR) PWM0 event 1
#define DACC_TRIGR_TRGSEL0_TRGSEL5   (0x5u << 4)
 (DACC_TRIGR) PWM1 event 0
#define DACC_TRIGR_TRGSEL0_TRGSEL6   (0x6u << 4)
 (DACC_TRIGR) PWM1 event 1
#define DACC_TRIGR_TRGSEL1_Pos   8
#define DACC_TRIGR_TRGSEL1_Msk   (0x7u << DACC_TRIGR_TRGSEL1_Pos)
 (DACC_TRIGR) Trigger Selection of Channel 1
#define DACC_TRIGR_TRGSEL1(value)   ((DACC_TRIGR_TRGSEL1_Msk & ((value) << DACC_TRIGR_TRGSEL1_Pos)))
#define DACC_TRIGR_TRGSEL1_TRGSEL0   (0x0u << 8)
#define DACC_TRIGR_TRGSEL1_TRGSEL1   (0x1u << 8)
#define DACC_TRIGR_TRGSEL1_TRGSEL2   (0x2u << 8)
#define DACC_TRIGR_TRGSEL1_TRGSEL3   (0x3u << 8)
#define DACC_TRIGR_TRGSEL1_TRGSEL4   (0x4u << 8)
#define DACC_TRIGR_TRGSEL1_TRGSEL5   (0x5u << 8)
#define DACC_TRIGR_TRGSEL1_TRGSEL6   (0x6u << 8)
#define DACC_TRIGR_OSR0_Pos   16
#define DACC_TRIGR_OSR0_Msk   (0x7u << DACC_TRIGR_OSR0_Pos)
 (DACC_TRIGR) Over Sampling Ratio of Channel 0
#define DACC_TRIGR_OSR0(value)   ((DACC_TRIGR_OSR0_Msk & ((value) << DACC_TRIGR_OSR0_Pos)))
#define DACC_TRIGR_OSR0_OSR_1   (0x0u << 16)
 (DACC_TRIGR) OSR = 1
#define DACC_TRIGR_OSR0_OSR_2   (0x1u << 16)
 (DACC_TRIGR) OSR = 2
#define DACC_TRIGR_OSR0_OSR_4   (0x2u << 16)
 (DACC_TRIGR) OSR = 4
#define DACC_TRIGR_OSR0_OSR_8   (0x3u << 16)
 (DACC_TRIGR) OSR = 8
#define DACC_TRIGR_OSR0_OSR_16   (0x4u << 16)
 (DACC_TRIGR) OSR = 16
#define DACC_TRIGR_OSR0_OSR_32   (0x5u << 16)
 (DACC_TRIGR) OSR = 32
#define DACC_TRIGR_OSR1_Pos   20
#define DACC_TRIGR_OSR1_Msk   (0x7u << DACC_TRIGR_OSR1_Pos)
 (DACC_TRIGR) Over Sampling Ratio of Channel 1
#define DACC_TRIGR_OSR1(value)   ((DACC_TRIGR_OSR1_Msk & ((value) << DACC_TRIGR_OSR1_Pos)))
#define DACC_TRIGR_OSR1_OSR_1   (0x0u << 20)
#define DACC_TRIGR_OSR1_OSR_2   (0x1u << 20)
#define DACC_TRIGR_OSR1_OSR_4   (0x2u << 20)
#define DACC_TRIGR_OSR1_OSR_8   (0x3u << 20)
#define DACC_TRIGR_OSR1_OSR_16   (0x4u << 20)
#define DACC_TRIGR_OSR1_OSR_32   (0x5u << 20)
#define DACC_CHER_CH0   (0x1u << 0)
 (DACC_CHER) Channel 0 Enable
#define DACC_CHER_CH1   (0x1u << 1)
 (DACC_CHER) Channel 1 Enable
#define DACC_CHDR_CH0   (0x1u << 0)
 (DACC_CHDR) Channel 0 Disable
#define DACC_CHDR_CH1   (0x1u << 1)
 (DACC_CHDR) Channel 1 Disable
#define DACC_CHSR_CH0   (0x1u << 0)
 (DACC_CHSR) Channel 0 Status
#define DACC_CHSR_CH1   (0x1u << 1)
 (DACC_CHSR) Channel 1 Status
#define DACC_CHSR_DACRDY0   (0x1u << 8)
 (DACC_CHSR) DAC Ready Flag
#define DACC_CHSR_DACRDY1   (0x1u << 9)
#define DACC_CDR_DATA0_Pos   0
#define DACC_CDR_DATA0_Msk   (0xffffu << DACC_CDR_DATA0_Pos)
 (DACC_CDR[2]) Data to Convert for channel 0
#define DACC_CDR_DATA0(value)   ((DACC_CDR_DATA0_Msk & ((value) << DACC_CDR_DATA0_Pos)))
#define DACC_CDR_DATA1_Pos   16
#define DACC_CDR_DATA1_Msk   (0xffffu << DACC_CDR_DATA1_Pos)
 (DACC_CDR[2]) Data to Convert for channel 1
#define DACC_CDR_DATA1(value)   ((DACC_CDR_DATA1_Msk & ((value) << DACC_CDR_DATA1_Pos)))
#define DACC_IER_TXRDY0   (0x1u << 0)
 (DACC_IER) Transmit Ready Interrupt Enable of channel 0
#define DACC_IER_TXRDY1   (0x1u << 1)
 (DACC_IER) Transmit Ready Interrupt Enable of channel 1
#define DACC_IER_EOC0   (0x1u << 4)
 (DACC_IER) End of Conversion Interrupt Enable of channel 0
#define DACC_IER_EOC1   (0x1u << 5)
 (DACC_IER) End of Conversion Interrupt Enable of channel 1
#define DACC_IDR_TXRDY0   (0x1u << 0)
 (DACC_IDR) Transmit Ready Interrupt Disable of channel 0
#define DACC_IDR_TXRDY1   (0x1u << 1)
 (DACC_IDR) Transmit Ready Interrupt Disable of channel 1
#define DACC_IDR_EOC0   (0x1u << 4)
 (DACC_IDR) End of Conversion Interrupt Disable of channel 0
#define DACC_IDR_EOC1   (0x1u << 5)
 (DACC_IDR) End of Conversion Interrupt Disable of channel 1
#define DACC_IMR_TXRDY0   (0x1u << 0)
 (DACC_IMR) Transmit Ready Interrupt Mask of channel 0
#define DACC_IMR_TXRDY1   (0x1u << 1)
 (DACC_IMR) Transmit Ready Interrupt Mask of channel 1
#define DACC_IMR_EOC0   (0x1u << 4)
 (DACC_IMR) End of Conversion Interrupt Mask of channel 0
#define DACC_IMR_EOC1   (0x1u << 5)
 (DACC_IMR) End of Conversion Interrupt Mask of channel 1
#define DACC_ISR_TXRDY0   (0x1u << 0)
 (DACC_ISR) Transmit Ready Interrupt Flag of channel 0
#define DACC_ISR_TXRDY1   (0x1u << 1)
 (DACC_ISR) Transmit Ready Interrupt Flag of channel 1
#define DACC_ISR_EOC0   (0x1u << 4)
 (DACC_ISR) End of Conversion Interrupt Flag of channel 0
#define DACC_ISR_EOC1   (0x1u << 5)
 (DACC_ISR) End of Conversion Interrupt Flag of channel 1
#define DACC_ACR_IBCTLCH0_Pos   0
#define DACC_ACR_IBCTLCH0_Msk   (0x3u << DACC_ACR_IBCTLCH0_Pos)
 (DACC_ACR) Analog Output Current Control
#define DACC_ACR_IBCTLCH0(value)   ((DACC_ACR_IBCTLCH0_Msk & ((value) << DACC_ACR_IBCTLCH0_Pos)))
#define DACC_ACR_IBCTLCH1_Pos   2
#define DACC_ACR_IBCTLCH1_Msk   (0x3u << DACC_ACR_IBCTLCH1_Pos)
#define DACC_ACR_IBCTLCH1(value)   ((DACC_ACR_IBCTLCH1_Msk & ((value) << DACC_ACR_IBCTLCH1_Pos)))
#define DACC_WPMR_WPEN   (0x1u << 0)
 (DACC_WPMR) Write Protection Enable
#define DACC_WPMR_WPKEY_Pos   8
#define DACC_WPMR_WPKEY_Msk   (0xffffffu << DACC_WPMR_WPKEY_Pos)
 (DACC_WPMR) Write Protect Key
#define DACC_WPMR_WPKEY(value)   ((DACC_WPMR_WPKEY_Msk & ((value) << DACC_WPMR_WPKEY_Pos)))
#define DACC_WPMR_WPKEY_PASSWD   (0x444143u << 8)
 (DACC_WPMR) Writing any other value in this field aborts the write operation of bit WPEN.Always reads as 0.
#define DACC_WPSR_WPVS   (0x1u << 0)
 (DACC_WPSR) Write Protection Violation Status
#define DACC_WPSR_WPVSRC_Pos   8
#define DACC_WPSR_WPVSRC_Msk   (0xffu << DACC_WPSR_WPVSRC_Pos)
 (DACC_WPSR) Write Protection Violation Source
#define DACC_VERSION_VERSION_Pos   0
#define DACC_VERSION_VERSION_Msk   (0xfffu << DACC_VERSION_VERSION_Pos)
 (DACC_VERSION) Version
#define DACC_VERSION_MFN_Pos   16
#define DACC_VERSION_MFN_Msk   (0x7u << DACC_VERSION_MFN_Pos)
 (DACC_VERSION) Metal Fix Number
SOFTWARE API DEFINITION FOR Digital-to-Analog Converter Controller
