RTEMS  5.1
Data Structures | Macros
struct  Afec
 Afec hardware registers. More...
#define AFEC_CR_SWRST   (0x1u << 0)
 (AFEC_CR) Software Reset
#define AFEC_CR_START   (0x1u << 1)
 (AFEC_CR) Start Conversion
#define AFEC_MR_TRGEN   (0x1u << 0)
 (AFEC_MR) Trigger Enable
#define AFEC_MR_TRGEN_DIS   (0x0u << 0)
 (AFEC_MR) Hardware triggers are disabled. Starting a conversion is only possible by software.
#define AFEC_MR_TRGEN_EN   (0x1u << 0)
 (AFEC_MR) Hardware trigger selected by TRGSEL field is enabled.
#define AFEC_MR_TRGSEL_Pos   1
#define AFEC_MR_TRGSEL_Msk   (0x7u << AFEC_MR_TRGSEL_Pos)
 (AFEC_MR) Trigger Selection
#define AFEC_MR_TRGSEL(value)   ((AFEC_MR_TRGSEL_Msk & ((value) << AFEC_MR_TRGSEL_Pos)))
#define AFEC_MR_TRGSEL_AFEC_TRIG0   (0x0u << 1)
 (AFEC_MR) AFE0_ADTRG for AFEC0 / AFE1_ADTRG for AFEC1
#define AFEC_MR_TRGSEL_AFEC_TRIG1   (0x1u << 1)
 (AFEC_MR) TIOA Output of the Timer Counter Channel 0 for AFEC0/TIOA Output of the Timer Counter Channel 3 for AFEC1
#define AFEC_MR_TRGSEL_AFEC_TRIG2   (0x2u << 1)
 (AFEC_MR) TIOA Output of the Timer Counter Channel 1 for AFEC0/TIOA Output of the Timer Counter Channel 4 for AFEC1
#define AFEC_MR_TRGSEL_AFEC_TRIG3   (0x3u << 1)
 (AFEC_MR) TIOA Output of the Timer Counter Channel 2 for AFEC0/TIOA Output of the Timer Counter Channel 5 for AFEC1
#define AFEC_MR_TRGSEL_AFEC_TRIG4   (0x4u << 1)
 (AFEC_MR) PWM0 event line 0 for AFEC0 / PWM1 event line 0 for AFEC1
#define AFEC_MR_TRGSEL_AFEC_TRIG5   (0x5u << 1)
 (AFEC_MR) PWM0 event line 1 for AFEC0 / PWM1 event line 1 for AFEC1
#define AFEC_MR_TRGSEL_AFEC_TRIG6   (0x6u << 1)
 (AFEC_MR) Analog Comparator
#define AFEC_MR_SLEEP   (0x1u << 5)
 (AFEC_MR) Sleep Mode
#define AFEC_MR_SLEEP_NORMAL   (0x0u << 5)
 (AFEC_MR) Normal mode: The AFE and reference voltage circuitry are kept ON between conversions.
#define AFEC_MR_SLEEP_SLEEP   (0x1u << 5)
 (AFEC_MR) Sleep mode: The AFE and reference voltage circuitry are OFF between conversions.
#define AFEC_MR_FWUP   (0x1u << 6)
 (AFEC_MR) Fast Wake-up
#define AFEC_MR_FWUP_OFF   (0x0u << 6)
 (AFEC_MR) Normal Sleep mode: The sleep mode is defined by the SLEEP bit.
#define AFEC_MR_FWUP_ON   (0x1u << 6)
 (AFEC_MR) Fast wake-up Sleep mode: The voltage reference is ON between conversions and AFE is OFF.
#define AFEC_MR_FREERUN   (0x1u << 7)
 (AFEC_MR) Free Run Mode
#define AFEC_MR_FREERUN_OFF   (0x0u << 7)
#define AFEC_MR_FREERUN_ON   (0x1u << 7)
 (AFEC_MR) Free Run mode: Never wait for any trigger.
#define AFEC_MR_PRESCAL_Pos   8
#define AFEC_MR_PRESCAL_Msk   (0xffu << AFEC_MR_PRESCAL_Pos)
 (AFEC_MR) Prescaler Rate Selection
#define AFEC_MR_PRESCAL(value)   ((AFEC_MR_PRESCAL_Msk & ((value) << AFEC_MR_PRESCAL_Pos)))
#define AFEC_MR_STARTUP_Pos   16
#define AFEC_MR_STARTUP_Msk   (0xfu << AFEC_MR_STARTUP_Pos)
 (AFEC_MR) Start-up Time
#define AFEC_MR_STARTUP(value)   ((AFEC_MR_STARTUP_Msk & ((value) << AFEC_MR_STARTUP_Pos)))
#define AFEC_MR_STARTUP_SUT0   (0x0u << 16)
 (AFEC_MR) 0 periods of AFE clock
#define AFEC_MR_STARTUP_SUT8   (0x1u << 16)
 (AFEC_MR) 8 periods of AFE clock
#define AFEC_MR_STARTUP_SUT16   (0x2u << 16)
 (AFEC_MR) 16 periods of AFE clock
#define AFEC_MR_STARTUP_SUT24   (0x3u << 16)
 (AFEC_MR) 24 periods of AFE clock
#define AFEC_MR_STARTUP_SUT64   (0x4u << 16)
 (AFEC_MR) 64 periods of AFE clock
#define AFEC_MR_STARTUP_SUT80   (0x5u << 16)
 (AFEC_MR) 80 periods of AFE clock
#define AFEC_MR_STARTUP_SUT96   (0x6u << 16)
 (AFEC_MR) 96 periods of AFE clock
#define AFEC_MR_STARTUP_SUT112   (0x7u << 16)
 (AFEC_MR) 112 periods of AFE clock
#define AFEC_MR_STARTUP_SUT512   (0x8u << 16)
 (AFEC_MR) 512 periods of AFE clock
#define AFEC_MR_STARTUP_SUT576   (0x9u << 16)
 (AFEC_MR) 576 periods of AFE clock
#define AFEC_MR_STARTUP_SUT640   (0xAu << 16)
 (AFEC_MR) 640 periods of AFE clock
#define AFEC_MR_STARTUP_SUT704   (0xBu << 16)
 (AFEC_MR) 704 periods of AFE clock
#define AFEC_MR_STARTUP_SUT768   (0xCu << 16)
 (AFEC_MR) 768 periods of AFE clock
#define AFEC_MR_STARTUP_SUT832   (0xDu << 16)
 (AFEC_MR) 832 periods of AFE clock
#define AFEC_MR_STARTUP_SUT896   (0xEu << 16)
 (AFEC_MR) 896 periods of AFE clock
#define AFEC_MR_STARTUP_SUT960   (0xFu << 16)
 (AFEC_MR) 960 periods of AFE clock
#define AFEC_MR_ONE   (0x1u << 23)
 (AFEC_MR) One
#define AFEC_MR_TRACKTIM_Pos   24
#define AFEC_MR_TRACKTIM_Msk   (0xfu << AFEC_MR_TRACKTIM_Pos)
 (AFEC_MR) Tracking Time
#define AFEC_MR_TRACKTIM(value)   ((AFEC_MR_TRACKTIM_Msk & ((value) << AFEC_MR_TRACKTIM_Pos)))
#define AFEC_MR_TRANSFER_Pos   28
#define AFEC_MR_TRANSFER_Msk   (0x3u << AFEC_MR_TRANSFER_Pos)
 (AFEC_MR) Transfer Period
#define AFEC_MR_TRANSFER(value)   ((AFEC_MR_TRANSFER_Msk & ((value) << AFEC_MR_TRANSFER_Pos)))
#define AFEC_MR_USEQ   (0x1u << 31)
 (AFEC_MR) User Sequence Enable
#define AFEC_MR_USEQ_NUM_ORDER   (0x0u << 31)
 (AFEC_MR) Normal mode: The controller converts channels in a simple numeric order.
#define AFEC_MR_USEQ_REG_ORDER   (0x1u << 31)
 (AFEC_MR) User Sequence mode: The sequence respects what is defined in AFEC_SEQ1R and AFEC_SEQ1R.
#define AFEC_EMR_CMPMODE_Pos   0
#define AFEC_EMR_CMPMODE_Msk   (0x3u << AFEC_EMR_CMPMODE_Pos)
 (AFEC_EMR) Comparison Mode
#define AFEC_EMR_CMPMODE(value)   ((AFEC_EMR_CMPMODE_Msk & ((value) << AFEC_EMR_CMPMODE_Pos)))
#define AFEC_EMR_CMPMODE_LOW   (0x0u << 0)
 (AFEC_EMR) Generates an event when the converted data is lower than the low threshold of the window.
#define AFEC_EMR_CMPMODE_HIGH   (0x1u << 0)
 (AFEC_EMR) Generates an event when the converted data is higher than the high threshold of the window.
#define AFEC_EMR_CMPMODE_IN   (0x2u << 0)
 (AFEC_EMR) Generates an event when the converted data is in the comparison window.
#define AFEC_EMR_CMPMODE_OUT   (0x3u << 0)
 (AFEC_EMR) Generates an event when the converted data is out of the comparison window.
#define AFEC_EMR_CMPSEL_Pos   3
#define AFEC_EMR_CMPSEL_Msk   (0x1fu << AFEC_EMR_CMPSEL_Pos)
 (AFEC_EMR) Comparison Selected Channel
#define AFEC_EMR_CMPSEL(value)   ((AFEC_EMR_CMPSEL_Msk & ((value) << AFEC_EMR_CMPSEL_Pos)))
#define AFEC_EMR_CMPALL   (0x1u << 9)
 (AFEC_EMR) Compare All Channels
#define AFEC_EMR_CMPFILTER_Pos   12
#define AFEC_EMR_CMPFILTER_Msk   (0x3u << AFEC_EMR_CMPFILTER_Pos)
 (AFEC_EMR) Compare Event Filtering
#define AFEC_EMR_CMPFILTER(value)   ((AFEC_EMR_CMPFILTER_Msk & ((value) << AFEC_EMR_CMPFILTER_Pos)))
#define AFEC_EMR_RES_Pos   16
#define AFEC_EMR_RES_Msk   (0x7u << AFEC_EMR_RES_Pos)
 (AFEC_EMR) Resolution
#define AFEC_EMR_RES(value)   ((AFEC_EMR_RES_Msk & ((value) << AFEC_EMR_RES_Pos)))
#define AFEC_EMR_RES_NO_AVERAGE   (0x0u << 16)
 (AFEC_EMR) 12-bit resolution, AFE sample rate is maximum (no averaging).
#define AFEC_EMR_RES_OSR4   (0x2u << 16)
 (AFEC_EMR) 13-bit resolution, AFE sample rate divided by 4 (averaging).
#define AFEC_EMR_RES_OSR16   (0x3u << 16)
 (AFEC_EMR) 14-bit resolution, AFE sample rate divided by 16 (averaging).
#define AFEC_EMR_RES_OSR64   (0x4u << 16)
 (AFEC_EMR) 15-bit resolution, AFE sample rate divided by 64 (averaging).
#define AFEC_EMR_RES_OSR256   (0x5u << 16)
 (AFEC_EMR) 16-bit resolution, AFE sample rate divided by 256 (averaging).
#define AFEC_EMR_TAG   (0x1u << 24)
 (AFEC_EMR) TAG of the AFEC_LDCR
#define AFEC_EMR_STM   (0x1u << 25)
 (AFEC_EMR) Single Trigger Mode
#define AFEC_EMR_SIGNMODE_Pos   28
#define AFEC_EMR_SIGNMODE_Msk   (0x3u << AFEC_EMR_SIGNMODE_Pos)
 (AFEC_EMR) Sign Mode
#define AFEC_EMR_SIGNMODE(value)   ((AFEC_EMR_SIGNMODE_Msk & ((value) << AFEC_EMR_SIGNMODE_Pos)))
#define AFEC_EMR_SIGNMODE_SE_UNSG_DF_SIGN   (0x0u << 28)
 (AFEC_EMR) Single-Ended channels: Unsigned conversions.Differential channels: Signed conversions.
#define AFEC_EMR_SIGNMODE_SE_SIGN_DF_UNSG   (0x1u << 28)
 (AFEC_EMR) Single-Ended channels: Signed conversions.Differential channels: Unsigned conversions.
#define AFEC_EMR_SIGNMODE_ALL_UNSIGNED   (0x2u << 28)
 (AFEC_EMR) All channels: Unsigned conversions.
#define AFEC_EMR_SIGNMODE_ALL_SIGNED   (0x3u << 28)
 (AFEC_EMR) All channels: Signed conversions.
#define AFEC_SEQ1R_USCH0_Pos   0
#define AFEC_SEQ1R_USCH0_Msk   (0xfu << AFEC_SEQ1R_USCH0_Pos)
 (AFEC_SEQ1R) User Sequence Number 0
#define AFEC_SEQ1R_USCH0(value)   ((AFEC_SEQ1R_USCH0_Msk & ((value) << AFEC_SEQ1R_USCH0_Pos)))
#define AFEC_SEQ1R_USCH1_Pos   4
#define AFEC_SEQ1R_USCH1_Msk   (0xfu << AFEC_SEQ1R_USCH1_Pos)
 (AFEC_SEQ1R) User Sequence Number 1
#define AFEC_SEQ1R_USCH1(value)   ((AFEC_SEQ1R_USCH1_Msk & ((value) << AFEC_SEQ1R_USCH1_Pos)))
#define AFEC_SEQ1R_USCH2_Pos   8
#define AFEC_SEQ1R_USCH2_Msk   (0xfu << AFEC_SEQ1R_USCH2_Pos)
 (AFEC_SEQ1R) User Sequence Number 2
#define AFEC_SEQ1R_USCH2(value)   ((AFEC_SEQ1R_USCH2_Msk & ((value) << AFEC_SEQ1R_USCH2_Pos)))
#define AFEC_SEQ1R_USCH3_Pos   12
#define AFEC_SEQ1R_USCH3_Msk   (0xfu << AFEC_SEQ1R_USCH3_Pos)
 (AFEC_SEQ1R) User Sequence Number 3
#define AFEC_SEQ1R_USCH3(value)   ((AFEC_SEQ1R_USCH3_Msk & ((value) << AFEC_SEQ1R_USCH3_Pos)))
#define AFEC_SEQ1R_USCH4_Pos   16
#define AFEC_SEQ1R_USCH4_Msk   (0xfu << AFEC_SEQ1R_USCH4_Pos)
 (AFEC_SEQ1R) User Sequence Number 4
#define AFEC_SEQ1R_USCH4(value)   ((AFEC_SEQ1R_USCH4_Msk & ((value) << AFEC_SEQ1R_USCH4_Pos)))
#define AFEC_SEQ1R_USCH5_Pos   20
#define AFEC_SEQ1R_USCH5_Msk   (0xfu << AFEC_SEQ1R_USCH5_Pos)
 (AFEC_SEQ1R) User Sequence Number 5
#define AFEC_SEQ1R_USCH5(value)   ((AFEC_SEQ1R_USCH5_Msk & ((value) << AFEC_SEQ1R_USCH5_Pos)))
#define AFEC_SEQ1R_USCH6_Pos   24
#define AFEC_SEQ1R_USCH6_Msk   (0xfu << AFEC_SEQ1R_USCH6_Pos)
 (AFEC_SEQ1R) User Sequence Number 6
#define AFEC_SEQ1R_USCH6(value)   ((AFEC_SEQ1R_USCH6_Msk & ((value) << AFEC_SEQ1R_USCH6_Pos)))
#define AFEC_SEQ1R_USCH7_Pos   28
#define AFEC_SEQ1R_USCH7_Msk   (0xfu << AFEC_SEQ1R_USCH7_Pos)
 (AFEC_SEQ1R) User Sequence Number 7
#define AFEC_SEQ1R_USCH7(value)   ((AFEC_SEQ1R_USCH7_Msk & ((value) << AFEC_SEQ1R_USCH7_Pos)))
#define AFEC_SEQ2R_USCH8_Pos   0
#define AFEC_SEQ2R_USCH8_Msk   (0xfu << AFEC_SEQ2R_USCH8_Pos)
 (AFEC_SEQ2R) User Sequence Number 8
#define AFEC_SEQ2R_USCH8(value)   ((AFEC_SEQ2R_USCH8_Msk & ((value) << AFEC_SEQ2R_USCH8_Pos)))
#define AFEC_SEQ2R_USCH9_Pos   4
#define AFEC_SEQ2R_USCH9_Msk   (0xfu << AFEC_SEQ2R_USCH9_Pos)
 (AFEC_SEQ2R) User Sequence Number 9
#define AFEC_SEQ2R_USCH9(value)   ((AFEC_SEQ2R_USCH9_Msk & ((value) << AFEC_SEQ2R_USCH9_Pos)))
#define AFEC_SEQ2R_USCH10_Pos   8
#define AFEC_SEQ2R_USCH10_Msk   (0xfu << AFEC_SEQ2R_USCH10_Pos)
 (AFEC_SEQ2R) User Sequence Number 10
#define AFEC_SEQ2R_USCH10(value)   ((AFEC_SEQ2R_USCH10_Msk & ((value) << AFEC_SEQ2R_USCH10_Pos)))
#define AFEC_SEQ2R_USCH11_Pos   12
#define AFEC_SEQ2R_USCH11_Msk   (0xfu << AFEC_SEQ2R_USCH11_Pos)
 (AFEC_SEQ2R) User Sequence Number 11
#define AFEC_SEQ2R_USCH11(value)   ((AFEC_SEQ2R_USCH11_Msk & ((value) << AFEC_SEQ2R_USCH11_Pos)))
#define AFEC_SEQ2R_USCH12_Pos   16
#define AFEC_SEQ2R_USCH12_Msk   (0xfu << AFEC_SEQ2R_USCH12_Pos)
 (AFEC_SEQ2R) User Sequence Number 12
#define AFEC_SEQ2R_USCH12(value)   ((AFEC_SEQ2R_USCH12_Msk & ((value) << AFEC_SEQ2R_USCH12_Pos)))
#define AFEC_SEQ2R_USCH13_Pos   20
#define AFEC_SEQ2R_USCH13_Msk   (0xfu << AFEC_SEQ2R_USCH13_Pos)
 (AFEC_SEQ2R) User Sequence Number 13
#define AFEC_SEQ2R_USCH13(value)   ((AFEC_SEQ2R_USCH13_Msk & ((value) << AFEC_SEQ2R_USCH13_Pos)))
#define AFEC_SEQ2R_USCH14_Pos   24
#define AFEC_SEQ2R_USCH14_Msk   (0xfu << AFEC_SEQ2R_USCH14_Pos)
 (AFEC_SEQ2R) User Sequence Number 14
#define AFEC_SEQ2R_USCH14(value)   ((AFEC_SEQ2R_USCH14_Msk & ((value) << AFEC_SEQ2R_USCH14_Pos)))
#define AFEC_SEQ2R_USCH15_Pos   28
#define AFEC_SEQ2R_USCH15_Msk   (0xfu << AFEC_SEQ2R_USCH15_Pos)
 (AFEC_SEQ2R) User Sequence Number 15
#define AFEC_SEQ2R_USCH15(value)   ((AFEC_SEQ2R_USCH15_Msk & ((value) << AFEC_SEQ2R_USCH15_Pos)))
#define AFEC_CHER_CH0   (0x1u << 0)
 (AFEC_CHER) Channel 0 Enable
#define AFEC_CHER_CH1   (0x1u << 1)
 (AFEC_CHER) Channel 1 Enable
#define AFEC_CHER_CH2   (0x1u << 2)
 (AFEC_CHER) Channel 2 Enable
#define AFEC_CHER_CH3   (0x1u << 3)
 (AFEC_CHER) Channel 3 Enable
#define AFEC_CHER_CH4   (0x1u << 4)
 (AFEC_CHER) Channel 4 Enable
#define AFEC_CHER_CH5   (0x1u << 5)
 (AFEC_CHER) Channel 5 Enable
#define AFEC_CHER_CH6   (0x1u << 6)
 (AFEC_CHER) Channel 6 Enable
#define AFEC_CHER_CH7   (0x1u << 7)
 (AFEC_CHER) Channel 7 Enable
#define AFEC_CHER_CH8   (0x1u << 8)
 (AFEC_CHER) Channel 8 Enable
#define AFEC_CHER_CH9   (0x1u << 9)
 (AFEC_CHER) Channel 9 Enable
#define AFEC_CHER_CH10   (0x1u << 10)
 (AFEC_CHER) Channel 10 Enable
#define AFEC_CHER_CH11   (0x1u << 11)
 (AFEC_CHER) Channel 11 Enable
#define AFEC_CHDR_CH0   (0x1u << 0)
 (AFEC_CHDR) Channel 0 Disable
#define AFEC_CHDR_CH1   (0x1u << 1)
 (AFEC_CHDR) Channel 1 Disable
#define AFEC_CHDR_CH2   (0x1u << 2)
 (AFEC_CHDR) Channel 2 Disable
#define AFEC_CHDR_CH3   (0x1u << 3)
 (AFEC_CHDR) Channel 3 Disable
#define AFEC_CHDR_CH4   (0x1u << 4)
 (AFEC_CHDR) Channel 4 Disable
#define AFEC_CHDR_CH5   (0x1u << 5)
 (AFEC_CHDR) Channel 5 Disable
#define AFEC_CHDR_CH6   (0x1u << 6)
 (AFEC_CHDR) Channel 6 Disable
#define AFEC_CHDR_CH7   (0x1u << 7)
 (AFEC_CHDR) Channel 7 Disable
#define AFEC_CHDR_CH8   (0x1u << 8)
 (AFEC_CHDR) Channel 8 Disable
#define AFEC_CHDR_CH9   (0x1u << 9)
 (AFEC_CHDR) Channel 9 Disable
#define AFEC_CHDR_CH10   (0x1u << 10)
 (AFEC_CHDR) Channel 10 Disable
#define AFEC_CHDR_CH11   (0x1u << 11)
 (AFEC_CHDR) Channel 11 Disable
#define AFEC_CHSR_CH0   (0x1u << 0)
 (AFEC_CHSR) Channel 0 Status
#define AFEC_CHSR_CH1   (0x1u << 1)
 (AFEC_CHSR) Channel 1 Status
#define AFEC_CHSR_CH2   (0x1u << 2)
 (AFEC_CHSR) Channel 2 Status
#define AFEC_CHSR_CH3   (0x1u << 3)
 (AFEC_CHSR) Channel 3 Status
#define AFEC_CHSR_CH4   (0x1u << 4)
 (AFEC_CHSR) Channel 4 Status
#define AFEC_CHSR_CH5   (0x1u << 5)
 (AFEC_CHSR) Channel 5 Status
#define AFEC_CHSR_CH6   (0x1u << 6)
 (AFEC_CHSR) Channel 6 Status
#define AFEC_CHSR_CH7   (0x1u << 7)
 (AFEC_CHSR) Channel 7 Status
#define AFEC_CHSR_CH8   (0x1u << 8)
 (AFEC_CHSR) Channel 8 Status
#define AFEC_CHSR_CH9   (0x1u << 9)
 (AFEC_CHSR) Channel 9 Status
#define AFEC_CHSR_CH10   (0x1u << 10)
 (AFEC_CHSR) Channel 10 Status
#define AFEC_CHSR_CH11   (0x1u << 11)
 (AFEC_CHSR) Channel 11 Status
#define AFEC_LCDR_LDATA_Pos   0
#define AFEC_LCDR_LDATA_Msk   (0xffffu << AFEC_LCDR_LDATA_Pos)
 (AFEC_LCDR) Last Data Converted
#define AFEC_LCDR_CHNB_Pos   24
#define AFEC_LCDR_CHNB_Msk   (0xfu << AFEC_LCDR_CHNB_Pos)
 (AFEC_LCDR) Channel Number
#define AFEC_IER_EOC0   (0x1u << 0)
 (AFEC_IER) End of Conversion Interrupt Enable 0
#define AFEC_IER_EOC1   (0x1u << 1)
 (AFEC_IER) End of Conversion Interrupt Enable 1
#define AFEC_IER_EOC2   (0x1u << 2)
 (AFEC_IER) End of Conversion Interrupt Enable 2
#define AFEC_IER_EOC3   (0x1u << 3)
 (AFEC_IER) End of Conversion Interrupt Enable 3
#define AFEC_IER_EOC4   (0x1u << 4)
 (AFEC_IER) End of Conversion Interrupt Enable 4
#define AFEC_IER_EOC5   (0x1u << 5)
 (AFEC_IER) End of Conversion Interrupt Enable 5
#define AFEC_IER_EOC6   (0x1u << 6)
 (AFEC_IER) End of Conversion Interrupt Enable 6
#define AFEC_IER_EOC7   (0x1u << 7)
 (AFEC_IER) End of Conversion Interrupt Enable 7
#define AFEC_IER_EOC8   (0x1u << 8)
 (AFEC_IER) End of Conversion Interrupt Enable 8
#define AFEC_IER_EOC9   (0x1u << 9)
 (AFEC_IER) End of Conversion Interrupt Enable 9
#define AFEC_IER_EOC10   (0x1u << 10)
 (AFEC_IER) End of Conversion Interrupt Enable 10
#define AFEC_IER_EOC11   (0x1u << 11)
 (AFEC_IER) End of Conversion Interrupt Enable 11
#define AFEC_IER_DRDY   (0x1u << 24)
 (AFEC_IER) Data Ready Interrupt Enable
#define AFEC_IER_GOVRE   (0x1u << 25)
 (AFEC_IER) General Overrun Error Interrupt Enable
#define AFEC_IER_COMPE   (0x1u << 26)
 (AFEC_IER) Comparison Event Interrupt Enable
#define AFEC_IER_TEMPCHG   (0x1u << 30)
 (AFEC_IER) Temperature Change Interrupt Enable
#define AFEC_IDR_EOC0   (0x1u << 0)
 (AFEC_IDR) End of Conversion Interrupt Disable 0
#define AFEC_IDR_EOC1   (0x1u << 1)
 (AFEC_IDR) End of Conversion Interrupt Disable 1
#define AFEC_IDR_EOC2   (0x1u << 2)
 (AFEC_IDR) End of Conversion Interrupt Disable 2
#define AFEC_IDR_EOC3   (0x1u << 3)
 (AFEC_IDR) End of Conversion Interrupt Disable 3
#define AFEC_IDR_EOC4   (0x1u << 4)
 (AFEC_IDR) End of Conversion Interrupt Disable 4
#define AFEC_IDR_EOC5   (0x1u << 5)
 (AFEC_IDR) End of Conversion Interrupt Disable 5
#define AFEC_IDR_EOC6   (0x1u << 6)
 (AFEC_IDR) End of Conversion Interrupt Disable 6
#define AFEC_IDR_EOC7   (0x1u << 7)
 (AFEC_IDR) End of Conversion Interrupt Disable 7
#define AFEC_IDR_EOC8   (0x1u << 8)
 (AFEC_IDR) End of Conversion Interrupt Disable 8
#define AFEC_IDR_EOC9   (0x1u << 9)
 (AFEC_IDR) End of Conversion Interrupt Disable 9
#define AFEC_IDR_EOC10   (0x1u << 10)
 (AFEC_IDR) End of Conversion Interrupt Disable 10
#define AFEC_IDR_EOC11   (0x1u << 11)
 (AFEC_IDR) End of Conversion Interrupt Disable 11
#define AFEC_IDR_DRDY   (0x1u << 24)
 (AFEC_IDR) Data Ready Interrupt Disable
#define AFEC_IDR_GOVRE   (0x1u << 25)
 (AFEC_IDR) General Overrun Error Interrupt Disable
#define AFEC_IDR_COMPE   (0x1u << 26)
 (AFEC_IDR) Comparison Event Interrupt Disable
#define AFEC_IDR_TEMPCHG   (0x1u << 30)
 (AFEC_IDR) Temperature Change Interrupt Disable
#define AFEC_IMR_EOC0   (0x1u << 0)
 (AFEC_IMR) End of Conversion Interrupt Mask 0
#define AFEC_IMR_EOC1   (0x1u << 1)
 (AFEC_IMR) End of Conversion Interrupt Mask 1
#define AFEC_IMR_EOC2   (0x1u << 2)
 (AFEC_IMR) End of Conversion Interrupt Mask 2
#define AFEC_IMR_EOC3   (0x1u << 3)
 (AFEC_IMR) End of Conversion Interrupt Mask 3
#define AFEC_IMR_EOC4   (0x1u << 4)
 (AFEC_IMR) End of Conversion Interrupt Mask 4
#define AFEC_IMR_EOC5   (0x1u << 5)
 (AFEC_IMR) End of Conversion Interrupt Mask 5
#define AFEC_IMR_EOC6   (0x1u << 6)
 (AFEC_IMR) End of Conversion Interrupt Mask 6
#define AFEC_IMR_EOC7   (0x1u << 7)
 (AFEC_IMR) End of Conversion Interrupt Mask 7
#define AFEC_IMR_EOC8   (0x1u << 8)
 (AFEC_IMR) End of Conversion Interrupt Mask 8
#define AFEC_IMR_EOC9   (0x1u << 9)
 (AFEC_IMR) End of Conversion Interrupt Mask 9
#define AFEC_IMR_EOC10   (0x1u << 10)
 (AFEC_IMR) End of Conversion Interrupt Mask 10
#define AFEC_IMR_EOC11   (0x1u << 11)
 (AFEC_IMR) End of Conversion Interrupt Mask 11
#define AFEC_IMR_DRDY   (0x1u << 24)
 (AFEC_IMR) Data Ready Interrupt Mask
#define AFEC_IMR_GOVRE   (0x1u << 25)
 (AFEC_IMR) General Overrun Error Interrupt Mask
#define AFEC_IMR_COMPE   (0x1u << 26)
 (AFEC_IMR) Comparison Event Interrupt Mask
#define AFEC_IMR_TEMPCHG   (0x1u << 30)
 (AFEC_IMR) Temperature Change Interrupt Mask
#define AFEC_ISR_EOC0   (0x1u << 0)
 (AFEC_ISR) End of Conversion 0 (cleared by reading AFEC_CDRx)
#define AFEC_ISR_EOC1   (0x1u << 1)
 (AFEC_ISR) End of Conversion 1 (cleared by reading AFEC_CDRx)
#define AFEC_ISR_EOC2   (0x1u << 2)
 (AFEC_ISR) End of Conversion 2 (cleared by reading AFEC_CDRx)
#define AFEC_ISR_EOC3   (0x1u << 3)
 (AFEC_ISR) End of Conversion 3 (cleared by reading AFEC_CDRx)
#define AFEC_ISR_EOC4   (0x1u << 4)
 (AFEC_ISR) End of Conversion 4 (cleared by reading AFEC_CDRx)
#define AFEC_ISR_EOC5   (0x1u << 5)
 (AFEC_ISR) End of Conversion 5 (cleared by reading AFEC_CDRx)
#define AFEC_ISR_EOC6   (0x1u << 6)
 (AFEC_ISR) End of Conversion 6 (cleared by reading AFEC_CDRx)
#define AFEC_ISR_EOC7   (0x1u << 7)
 (AFEC_ISR) End of Conversion 7 (cleared by reading AFEC_CDRx)
#define AFEC_ISR_EOC8   (0x1u << 8)
 (AFEC_ISR) End of Conversion 8 (cleared by reading AFEC_CDRx)
#define AFEC_ISR_EOC9   (0x1u << 9)
 (AFEC_ISR) End of Conversion 9 (cleared by reading AFEC_CDRx)
#define AFEC_ISR_EOC10   (0x1u << 10)
 (AFEC_ISR) End of Conversion 10 (cleared by reading AFEC_CDRx)
#define AFEC_ISR_EOC11   (0x1u << 11)
 (AFEC_ISR) End of Conversion 11 (cleared by reading AFEC_CDRx)
#define AFEC_ISR_DRDY   (0x1u << 24)
 (AFEC_ISR) Data Ready (cleared by reading AFEC_LCDR)
#define AFEC_ISR_GOVRE   (0x1u << 25)
 (AFEC_ISR) General Overrun Error (cleared by reading AFEC_ISR)
#define AFEC_ISR_COMPE   (0x1u << 26)
 (AFEC_ISR) Comparison Error (cleared by reading AFEC_ISR)
#define AFEC_ISR_TEMPCHG   (0x1u << 30)
 (AFEC_ISR) Temperature Change (cleared on read)
#define AFEC_OVER_OVRE0   (0x1u << 0)
 (AFEC_OVER) Overrun Error 0
#define AFEC_OVER_OVRE1   (0x1u << 1)
 (AFEC_OVER) Overrun Error 1
#define AFEC_OVER_OVRE2   (0x1u << 2)
 (AFEC_OVER) Overrun Error 2
#define AFEC_OVER_OVRE3   (0x1u << 3)
 (AFEC_OVER) Overrun Error 3
#define AFEC_OVER_OVRE4   (0x1u << 4)
 (AFEC_OVER) Overrun Error 4
#define AFEC_OVER_OVRE5   (0x1u << 5)
 (AFEC_OVER) Overrun Error 5
#define AFEC_OVER_OVRE6   (0x1u << 6)
 (AFEC_OVER) Overrun Error 6
#define AFEC_OVER_OVRE7   (0x1u << 7)
 (AFEC_OVER) Overrun Error 7
#define AFEC_OVER_OVRE8   (0x1u << 8)
 (AFEC_OVER) Overrun Error 8
#define AFEC_OVER_OVRE9   (0x1u << 9)
 (AFEC_OVER) Overrun Error 9
#define AFEC_OVER_OVRE10   (0x1u << 10)
 (AFEC_OVER) Overrun Error 10
#define AFEC_OVER_OVRE11   (0x1u << 11)
 (AFEC_OVER) Overrun Error 11
#define AFEC_CWR_LOWTHRES_Pos   0
#define AFEC_CWR_LOWTHRES_Msk   (0xffffu << AFEC_CWR_LOWTHRES_Pos)
 (AFEC_CWR) Low Threshold
#define AFEC_CWR_LOWTHRES(value)   ((AFEC_CWR_LOWTHRES_Msk & ((value) << AFEC_CWR_LOWTHRES_Pos)))
#define AFEC_CWR_HIGHTHRES_Pos   16
#define AFEC_CWR_HIGHTHRES_Msk   (0xffffu << AFEC_CWR_HIGHTHRES_Pos)
 (AFEC_CWR) High Threshold
#define AFEC_CWR_HIGHTHRES(value)   ((AFEC_CWR_HIGHTHRES_Msk & ((value) << AFEC_CWR_HIGHTHRES_Pos)))
#define AFEC_CGR_GAIN0_Pos   0
#define AFEC_CGR_GAIN0_Msk   (0x3u << AFEC_CGR_GAIN0_Pos)
 (AFEC_CGR) Gain for Channel 0
#define AFEC_CGR_GAIN0(value)   ((AFEC_CGR_GAIN0_Msk & ((value) << AFEC_CGR_GAIN0_Pos)))
#define AFEC_CGR_GAIN1_Pos   2
#define AFEC_CGR_GAIN1_Msk   (0x3u << AFEC_CGR_GAIN1_Pos)
 (AFEC_CGR) Gain for Channel 1
#define AFEC_CGR_GAIN1(value)   ((AFEC_CGR_GAIN1_Msk & ((value) << AFEC_CGR_GAIN1_Pos)))
#define AFEC_CGR_GAIN2_Pos   4
#define AFEC_CGR_GAIN2_Msk   (0x3u << AFEC_CGR_GAIN2_Pos)
 (AFEC_CGR) Gain for Channel 2
#define AFEC_CGR_GAIN2(value)   ((AFEC_CGR_GAIN2_Msk & ((value) << AFEC_CGR_GAIN2_Pos)))
#define AFEC_CGR_GAIN3_Pos   6
#define AFEC_CGR_GAIN3_Msk   (0x3u << AFEC_CGR_GAIN3_Pos)
 (AFEC_CGR) Gain for Channel 3
#define AFEC_CGR_GAIN3(value)   ((AFEC_CGR_GAIN3_Msk & ((value) << AFEC_CGR_GAIN3_Pos)))
#define AFEC_CGR_GAIN4_Pos   8
#define AFEC_CGR_GAIN4_Msk   (0x3u << AFEC_CGR_GAIN4_Pos)
 (AFEC_CGR) Gain for Channel 4
#define AFEC_CGR_GAIN4(value)   ((AFEC_CGR_GAIN4_Msk & ((value) << AFEC_CGR_GAIN4_Pos)))
#define AFEC_CGR_GAIN5_Pos   10
#define AFEC_CGR_GAIN5_Msk   (0x3u << AFEC_CGR_GAIN5_Pos)
 (AFEC_CGR) Gain for Channel 5
#define AFEC_CGR_GAIN5(value)   ((AFEC_CGR_GAIN5_Msk & ((value) << AFEC_CGR_GAIN5_Pos)))
#define AFEC_CGR_GAIN6_Pos   12
#define AFEC_CGR_GAIN6_Msk   (0x3u << AFEC_CGR_GAIN6_Pos)
 (AFEC_CGR) Gain for Channel 6
#define AFEC_CGR_GAIN6(value)   ((AFEC_CGR_GAIN6_Msk & ((value) << AFEC_CGR_GAIN6_Pos)))
#define AFEC_CGR_GAIN7_Pos   14
#define AFEC_CGR_GAIN7_Msk   (0x3u << AFEC_CGR_GAIN7_Pos)
 (AFEC_CGR) Gain for Channel 7
#define AFEC_CGR_GAIN7(value)   ((AFEC_CGR_GAIN7_Msk & ((value) << AFEC_CGR_GAIN7_Pos)))
#define AFEC_CGR_GAIN8_Pos   16
#define AFEC_CGR_GAIN8_Msk   (0x3u << AFEC_CGR_GAIN8_Pos)
 (AFEC_CGR) Gain for Channel 8
#define AFEC_CGR_GAIN8(value)   ((AFEC_CGR_GAIN8_Msk & ((value) << AFEC_CGR_GAIN8_Pos)))
#define AFEC_CGR_GAIN9_Pos   18
#define AFEC_CGR_GAIN9_Msk   (0x3u << AFEC_CGR_GAIN9_Pos)
 (AFEC_CGR) Gain for Channel 9
#define AFEC_CGR_GAIN9(value)   ((AFEC_CGR_GAIN9_Msk & ((value) << AFEC_CGR_GAIN9_Pos)))
#define AFEC_CGR_GAIN10_Pos   20
#define AFEC_CGR_GAIN10_Msk   (0x3u << AFEC_CGR_GAIN10_Pos)
 (AFEC_CGR) Gain for Channel 10
#define AFEC_CGR_GAIN10(value)   ((AFEC_CGR_GAIN10_Msk & ((value) << AFEC_CGR_GAIN10_Pos)))
#define AFEC_CGR_GAIN11_Pos   22
#define AFEC_CGR_GAIN11_Msk   (0x3u << AFEC_CGR_GAIN11_Pos)
 (AFEC_CGR) Gain for Channel 11
#define AFEC_CGR_GAIN11(value)   ((AFEC_CGR_GAIN11_Msk & ((value) << AFEC_CGR_GAIN11_Pos)))
#define AFEC_DIFFR_DIFF0   (0x1u << 0)
 (AFEC_DIFFR) Differential inputs for channel 0
#define AFEC_DIFFR_DIFF1   (0x1u << 1)
 (AFEC_DIFFR) Differential inputs for channel 1
#define AFEC_DIFFR_DIFF2   (0x1u << 2)
 (AFEC_DIFFR) Differential inputs for channel 2
#define AFEC_DIFFR_DIFF3   (0x1u << 3)
 (AFEC_DIFFR) Differential inputs for channel 3
#define AFEC_DIFFR_DIFF4   (0x1u << 4)
 (AFEC_DIFFR) Differential inputs for channel 4
#define AFEC_DIFFR_DIFF5   (0x1u << 5)
 (AFEC_DIFFR) Differential inputs for channel 5
#define AFEC_DIFFR_DIFF6   (0x1u << 6)
 (AFEC_DIFFR) Differential inputs for channel 6
#define AFEC_DIFFR_DIFF7   (0x1u << 7)
 (AFEC_DIFFR) Differential inputs for channel 7
#define AFEC_DIFFR_DIFF8   (0x1u << 8)
 (AFEC_DIFFR) Differential inputs for channel 8
#define AFEC_DIFFR_DIFF9   (0x1u << 9)
 (AFEC_DIFFR) Differential inputs for channel 9
#define AFEC_DIFFR_DIFF10   (0x1u << 10)
 (AFEC_DIFFR) Differential inputs for channel 10
#define AFEC_DIFFR_DIFF11   (0x1u << 11)
 (AFEC_DIFFR) Differential inputs for channel 11
#define AFEC_CSELR_CSEL_Pos   0
#define AFEC_CSELR_CSEL_Msk   (0xfu << AFEC_CSELR_CSEL_Pos)
 (AFEC_CSELR) Channel Selection
#define AFEC_CSELR_CSEL(value)   ((AFEC_CSELR_CSEL_Msk & ((value) << AFEC_CSELR_CSEL_Pos)))
#define AFEC_CDR_DATA_Pos   0
#define AFEC_CDR_DATA_Msk   (0xffffu << AFEC_CDR_DATA_Pos)
 (AFEC_CDR) Converted Data
#define AFEC_COCR_AOFF_Pos   0
#define AFEC_COCR_AOFF_Msk   (0x3ffu << AFEC_COCR_AOFF_Pos)
 (AFEC_COCR) Analog Offset
#define AFEC_COCR_AOFF(value)   ((AFEC_COCR_AOFF_Msk & ((value) << AFEC_COCR_AOFF_Pos)))
#define AFEC_TEMPMR_RTCT   (0x1u << 0)
 (AFEC_TEMPMR) Temperature Sensor RTC Trigger Mode
#define AFEC_TEMPMR_TEMPCMPMOD_Pos   4
#define AFEC_TEMPMR_TEMPCMPMOD_Msk   (0x3u << AFEC_TEMPMR_TEMPCMPMOD_Pos)
 (AFEC_TEMPMR) Temperature Comparison Mode
#define AFEC_TEMPMR_TEMPCMPMOD(value)   ((AFEC_TEMPMR_TEMPCMPMOD_Msk & ((value) << AFEC_TEMPMR_TEMPCMPMOD_Pos)))
#define AFEC_TEMPMR_TEMPCMPMOD_LOW   (0x0u << 4)
 (AFEC_TEMPMR) Generates an event when the converted data is lower than the low threshold of the window.
#define AFEC_TEMPMR_TEMPCMPMOD_HIGH   (0x1u << 4)
 (AFEC_TEMPMR) Generates an event when the converted data is higher than the high threshold of the window.
#define AFEC_TEMPMR_TEMPCMPMOD_IN   (0x2u << 4)
 (AFEC_TEMPMR) Generates an event when the converted data is in the comparison window.
#define AFEC_TEMPMR_TEMPCMPMOD_OUT   (0x3u << 4)
 (AFEC_TEMPMR) Generates an event when the converted data is out of the comparison window.
#define AFEC_TEMPCWR_TLOWTHRES_Pos   0
#define AFEC_TEMPCWR_TLOWTHRES_Msk   (0xffffu << AFEC_TEMPCWR_TLOWTHRES_Pos)
 (AFEC_TEMPCWR) Temperature Low Threshold
#define AFEC_TEMPCWR_TLOWTHRES(value)   ((AFEC_TEMPCWR_TLOWTHRES_Msk & ((value) << AFEC_TEMPCWR_TLOWTHRES_Pos)))
#define AFEC_TEMPCWR_THIGHTHRES_Pos   16
#define AFEC_TEMPCWR_THIGHTHRES_Msk   (0xffffu << AFEC_TEMPCWR_THIGHTHRES_Pos)
 (AFEC_TEMPCWR) Temperature High Threshold
#define AFEC_TEMPCWR_THIGHTHRES(value)   ((AFEC_TEMPCWR_THIGHTHRES_Msk & ((value) << AFEC_TEMPCWR_THIGHTHRES_Pos)))
#define AFEC_ACR_PGA0EN   (0x1u << 2)
 (AFEC_ACR) PGA0 Enable
#define AFEC_ACR_PGA1EN   (0x1u << 3)
 (AFEC_ACR) PGA1 Enable
#define AFEC_ACR_IBCTL_Pos   8
#define AFEC_ACR_IBCTL_Msk   (0x3u << AFEC_ACR_IBCTL_Pos)
 (AFEC_ACR) AFE Bias Current Control
#define AFEC_ACR_IBCTL(value)   ((AFEC_ACR_IBCTL_Msk & ((value) << AFEC_ACR_IBCTL_Pos)))
#define AFEC_SHMR_DUAL0   (0x1u << 0)
 (AFEC_SHMR) Dual Sample & Hold for channel 0
#define AFEC_SHMR_DUAL1   (0x1u << 1)
 (AFEC_SHMR) Dual Sample & Hold for channel 1
#define AFEC_SHMR_DUAL2   (0x1u << 2)
 (AFEC_SHMR) Dual Sample & Hold for channel 2
#define AFEC_SHMR_DUAL3   (0x1u << 3)
 (AFEC_SHMR) Dual Sample & Hold for channel 3
#define AFEC_SHMR_DUAL4   (0x1u << 4)
 (AFEC_SHMR) Dual Sample & Hold for channel 4
#define AFEC_SHMR_DUAL5   (0x1u << 5)
 (AFEC_SHMR) Dual Sample & Hold for channel 5
#define AFEC_SHMR_DUAL6   (0x1u << 6)
 (AFEC_SHMR) Dual Sample & Hold for channel 6
#define AFEC_SHMR_DUAL7   (0x1u << 7)
 (AFEC_SHMR) Dual Sample & Hold for channel 7
#define AFEC_SHMR_DUAL8   (0x1u << 8)
 (AFEC_SHMR) Dual Sample & Hold for channel 8
#define AFEC_SHMR_DUAL9   (0x1u << 9)
 (AFEC_SHMR) Dual Sample & Hold for channel 9
#define AFEC_SHMR_DUAL10   (0x1u << 10)
 (AFEC_SHMR) Dual Sample & Hold for channel 10
#define AFEC_SHMR_DUAL11   (0x1u << 11)
 (AFEC_SHMR) Dual Sample & Hold for channel 11
#define AFEC_COSR_CSEL   (0x1u << 0)
 (AFEC_COSR) Sample & Hold unit Correction Select
#define AFEC_CVR_OFFSETCORR_Pos   0
#define AFEC_CVR_OFFSETCORR_Msk   (0xffffu << AFEC_CVR_OFFSETCORR_Pos)
 (AFEC_CVR) Offset Correction
#define AFEC_CVR_OFFSETCORR(value)   ((AFEC_CVR_OFFSETCORR_Msk & ((value) << AFEC_CVR_OFFSETCORR_Pos)))
#define AFEC_CVR_GAINCORR_Pos   16
#define AFEC_CVR_GAINCORR_Msk   (0xffffu << AFEC_CVR_GAINCORR_Pos)
 (AFEC_CVR) Gain Correction
#define AFEC_CVR_GAINCORR(value)   ((AFEC_CVR_GAINCORR_Msk & ((value) << AFEC_CVR_GAINCORR_Pos)))
#define AFEC_CECR_ECORR0   (0x1u << 0)
 (AFEC_CECR) Error Correction Enable for channel 0
#define AFEC_CECR_ECORR1   (0x1u << 1)
 (AFEC_CECR) Error Correction Enable for channel 1
#define AFEC_CECR_ECORR2   (0x1u << 2)
 (AFEC_CECR) Error Correction Enable for channel 2
#define AFEC_CECR_ECORR3   (0x1u << 3)
 (AFEC_CECR) Error Correction Enable for channel 3
#define AFEC_CECR_ECORR4   (0x1u << 4)
 (AFEC_CECR) Error Correction Enable for channel 4
#define AFEC_CECR_ECORR5   (0x1u << 5)
 (AFEC_CECR) Error Correction Enable for channel 5
#define AFEC_CECR_ECORR6   (0x1u << 6)
 (AFEC_CECR) Error Correction Enable for channel 6
#define AFEC_CECR_ECORR7   (0x1u << 7)
 (AFEC_CECR) Error Correction Enable for channel 7
#define AFEC_CECR_ECORR8   (0x1u << 8)
 (AFEC_CECR) Error Correction Enable for channel 8
#define AFEC_CECR_ECORR9   (0x1u << 9)
 (AFEC_CECR) Error Correction Enable for channel 9
#define AFEC_CECR_ECORR10   (0x1u << 10)
 (AFEC_CECR) Error Correction Enable for channel 10
#define AFEC_CECR_ECORR11   (0x1u << 11)
 (AFEC_CECR) Error Correction Enable for channel 11
#define AFEC_WPMR_WPEN   (0x1u << 0)
 (AFEC_WPMR) Write Protection Enable
#define AFEC_WPMR_WPKEY_Pos   8
#define AFEC_WPMR_WPKEY_Msk   (0xffffffu << AFEC_WPMR_WPKEY_Pos)
 (AFEC_WPMR) Write Protect KEY
#define AFEC_WPMR_WPKEY(value)   ((AFEC_WPMR_WPKEY_Msk & ((value) << AFEC_WPMR_WPKEY_Pos)))
#define AFEC_WPMR_WPKEY_PASSWD   (0x414443u << 8)
 (AFEC_WPMR) Writing any other value in this field aborts the write operation of the WPEN bit. Always reads as 0.
#define AFEC_WPSR_WPVS   (0x1u << 0)
 (AFEC_WPSR) Write Protect Violation Status
#define AFEC_WPSR_WPVSRC_Pos   8
#define AFEC_WPSR_WPVSRC_Msk   (0xffffu << AFEC_WPSR_WPVSRC_Pos)
 (AFEC_WPSR) Write Protect Violation Source
#define AFEC_VERSION_VERSION_Pos   0
#define AFEC_VERSION_VERSION_Msk   (0xfffu << AFEC_VERSION_VERSION_Pos)
 (AFEC_VERSION) Version of the Hardware Module
#define AFEC_VERSION_MFN_Pos   16
#define AFEC_VERSION_MFN_Msk   (0x7u << AFEC_VERSION_MFN_Pos)
 (AFEC_VERSION) Metal Fix Number
SOFTWARE API DEFINITION FOR Analog Front-End Controller
