RTEMS  5.1
Modules | Files | Macros | Functions | Variables
MCF548X Board Support Package. More...
 Interrupt Support
 Interrupt support.
file  bsp.h
 Global BSP definitions.
file  tm27.h
 Time Test 27 routines.
#define CONSOLE_PORT   0
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH   rtems_mcf548x_fec_driver_attach_detach
#define RTEMS_BSP_NETWORK_DRIVER_NAME   "fec1"
#define RTEMS_BSP_NETWORK_DRIVER_NAME2   "fec2"
uint32_t get_CPU_clock_speed (void)
rtems_isr_entry set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type)
 Install an interrupt handler. More...
int rtems_mcf548x_fec_driver_attach_detach (struct rtems_bsdnet_ifconfig *config, int attaching)
void bsp_cacr_set_flags (uint32_t flags)
void bsp_cacr_set_self_clear_flags (uint32_t flags)
void bsp_cacr_clear_flags (uint32_t flags)
const uint8_t mcf548x_intc_icr_init_values [64]
◆ CONSOLE_PORT
Hardware data structure headers User Definable configuration
◆ set_vector()
rtems_isr_entry set_vector ( rtems_isr_entry  handler,
int  type
This method installs an interrupt handle.
Parameters
[in]handleris the isr routine
[in]vectoris the vector number
[in]typeindicates whether RTEMS or RAW intr
Returns
returns old vector
