RTEMS
5.1
SMDK2410 Board Support Package. More...
Modules | |
SMC Disk Driver | |
SMC Disk Driver Support. | |
Files | |
file | bsp.h |
Global BSP definitons. | |
#define | BSP_FEATURE_IRQ_EXTENSION |
#define | BSP_OSC_FREQ 12000000 |
12 MHz oscillator | |
#define | M_MDIV 81 |
FCLK=133Mhz. | |
#define | M_PDIV 2 |
#define | M_SDIV 1 |
#define | M_CLKDIVN 2 |
HCLK=FCLK/2, PCLK=FCLK/2. | |
#define | REFEN 0x1 |
enable refresh | |
#define | TREFMD 0x0 |
CBR(CAS before RAS)/auto refresh. | |
#define | Trp 0x0 |
2 clk | |
#define | Trc 0x3 |
7 clk | |
#define | Tchr 0x2 |
3 clk | |
void * | bsp_idle_thread (uintptr_t ignored) |
This BSP provides its own IDLE thread to override the RTEMS one. More... | |
uint32_t | get_FCLK (void) |
functions to get the differents s3c2400 clks | |
uint32_t | get_HCLK (void) |
uint32_t | get_PCLK (void) |
uint32_t | get_UCLK (void) |
void* bsp_idle_thread | ( | uintptr_t | ignored | ) |
So we prototype it and define the constant confdefs.h expects to configure a BSP specific one.
This idle task sets the power mode to idle. This causes the processor clock to be stopped, while on-chip peripherals remain active. Any enabled interrupt from a peripheral or an external interrupt source will cause the processor to resume execution.
To enable the idle task use the following in the system configuration:
Optimized idle task.
The MSR[POW] bit is set to put the CPU into the low power mode defined in HID0. HID0 is set during starup in start.S.
