RTEMS  5.1
griommu.h
1 /*
2  * GRIOMMU Driver Interface
3  *
4  * COPYRIGHT (c) 2017
5  * Cobham Gaisler AB
6  *
7  * The license and distribution terms for this file may be
8  * found in the file LICENSE in this distribution or at
9  * http://www.rtems.org/license/LICENSE.
10  *
11  * OVERVIEW
12  * ========
13  * This driver controls the GRIOMMU device located
14  * at an on-chip AMBA.
15  */
16
17 #ifndef __GRIOMMU_H__
18 #define __GRIOMMU_H__
19
20 #include <stdint.h>
21 #include <stdio.h>
22
23 #ifdef __cplusplus
24 extern "C" {
25 #endif
26
27 extern void griommu_register_drv(void);
28
29 #define GRIOMMU_ERR_OK 0
30 #define GRIOMMU_ERR_NOINIT -1
31 #define GRIOMMU_ERR_EINVAL -2
32 #define GRIOMMU_ERR_IMPLEMENTED -3
33 #define GRIOMMU_ERR_NOTFOUND -4
34
35 /* Size of APV (has to be divided by page size in bytes) */
36 #define GRIOMMU_APV_SIZE 0x20000000
37
38 /* Alignment of APV */
39 #define GRIOMMU_APV_ALIGN 0x10
40
41 /* IOMMU APV allocation helper functions */
42 extern void * griommu_apv_new(void);
43 extern void griommu_apv_delete(void * apv);
44
45 /* IOMMU Master Setup */
46
47 /* IOMMU Master find */
48 /*
49  * GRIOMMU MASTER register fields
50  */
51 #define MASTER_VENDOR (0xff << MASTER_VENDOR_BIT)
52 #define MASTER_DEVICE (0xfff << MASTER_DEVICE_BIT)
53 #define MASTER_BS (0x1 << MASTER_BS_BIT)
54 #define MASTER_GROUP (0xf << MASTER_GROUP_BIT)
55
56 #define MASTER_VENDOR_BIT 24
57 #define MASTER_DEVICE_BIT 12
58 #define MASTER_BS_BIT 4
59 #define MASTER_GROUP_BIT 0
60
61 #define GRIOMMU_OPTIONS_BUS0 0
62 #define GRIOMMU_OPTIONS_BUS1 1
63 extern int griommu_master_setup(int master, int group, int options);
64 extern int griommu_master_find(int vendor, int device, int instance);
65 extern int griommu_master_info(int master, uint32_t * info);
66 #define griommu_get_master_vendor(info) \
67  ((info & MASTER_VENDOR) >> MASTER_VENDOR_BIT)
68 #define griommu_get_master_device(info) \
69  ((info & MASTER_DEVICE) >> MASTER_DEVICE_BIT)
70 #define griommu_get_master_routing(info) \
71  ((info & MASTER_BS) >> MASTER_BS_BIT)
72 #define griommu_get_master_group(info) \
73  ((info & MASTER_GROUP) >> MASTER_GROUP_BIT)
74
75 /* IOMMU Group Setup */
76 #define GRIOMMU_OPTIONS_GROUP_PASSTHROUGH 2
77 #define GRIOMMU_OPTIONS_GROUP_ENABLE 1
78 #define GRIOMMU_OPTIONS_GROUP_DISABLE 0
79 extern int griommu_group_setup(int group, void * apv, int options);
80 extern int griommu_group_info(int group, uint32_t * info);
81 #define GRIOMMU_OPTIONS_APV_ALLOW 0x1
82 #define GRIOMMU_OPTIONS_APV_DONTALLOW 0x0
83 extern int griommu_group_apv_init(int group, int options);
84 extern int griommu_group_apv_address_set(int group, uint32_t addr, int size,
85  int options);
86 extern int griommu_group_apv_page_set(int group, int index, int size,
87  int options);
88 extern int griommu_group_apv_flush(int group);
89
90 /* IOMMU Setup */
91 /*
92  * GRIOMMU CTRL register fields
93  */
94 #define CTRL_PGSZ (0x7 << CTRL_PGSZ_BIT)
95 #define CTRL_LB (0x1 << CTRL_LB_BIT)
96 #define CTRL_SP (0x1 << CTRL_SP_BIT)
97 #define CTRL_ITR (0xf << CTRL_ITR_BIT)
98 #define CTRL_DP (0x1 << CTRL_DP_BIT)
99 #define CTRL_SIV (0x1 << CTRL_SIV_BIT)
100 #define CTRL_HPROT (0x3 << CTRL_HPROT_BIT)
101 #define CTRL_AU (0x1 << CTRL_AU_BIT)
102 #define CTRL_WP (0x1 << CTRL_WP_BIT)
103 #define CTRL_DM (0x1 << CTRL_DM_BIT)
104 #define CTRL_GS (0x1 << CTRL_GS_BIT)
105 #define CTRL_CE (0x1 << CTRL_CE_BIT)
106 #define CTRL_PM (0x3 << CTRL_PM_BIT)
107 #define CTRL_PM_APV (0x0 << CTRL_PM_BIT)
108 #define CTRL_PM_IOMMU (0x1 << CTRL_PM_BIT)
109 #define CTRL_EN (0x1 << CTRL_EN_BIT)
110
111 #define CTRL_PGSZ_BIT 18
112 #define CTRL_LB_BIT 17
113 #define CTRL_SP_BIT 16
114 #define CTRL_ITR_BIT 12
115 #define CTRL_DP_BIT 11
116 #define CTRL_SIV_BIT 10
117 #define CTRL_HPROT_BIT 8
118 #define CTRL_AU_BIT 7
119 #define CTRL_WP_BIT 6
120 #define CTRL_DM_BIT 5
121 #define CTRL_GS_BIT 4
122 #define CTRL_CE_BIT 3
123 #define CTRL_PM_BIT 1
124 #define CTRL_EN_BIT 0
125
126 #define GRIOMMU_OPTIONS_LOOKUPBUS_BUS0 0
127 #define GRIOMMU_OPTIONS_LOOKUPBUS_BUS1 CTRL_LB
128 #define GRIOMMU_OPTIONS_CACHE_DISABLE 0
129 #define GRIOMMU_OPTIONS_CACHE_ENABLE CTRL_CE
130 #define GRIOMMU_OPTIONS_GROUPADDRESSING_DISABLE 0
131 #define GRIOMMU_OPTIONS_GROUPADDRESSING_ENABLE CTRL_GS
132 #define GRIOMMU_OPTIONS_WPROTONLY_DISABLE 0
133 #define GRIOMMU_OPTIONS_WPROTONLY_ENABLE CTRL_WP
134 #define GRIOMMU_OPTIONS_AHBUPDATE_DISABLE 0
135 #define GRIOMMU_OPTIONS_AHBUPDATE_ENABLE CTRL_AU
136 #define GRIOMMU_OPTIONS_PREFETCH_DISABLE CTRL_DP
137 #define GRIOMMU_OPTIONS_PREFETCH_ENABLE 0
138 #define GRIOMMU_OPTIONS_PAGESIZE_4KIB 0
139 #define GRIOMMU_OPTIONS_PAGESIZE_8KIB (0x1 << CTRL_PGSZ_BIT)
140 #define GRIOMMU_OPTIONS_PAGESIZE_16KIB (0x2 << CTRL_PGSZ_BIT)
141 #define GRIOMMU_OPTIONS_PAGESIZE_32KIB (0x3 << CTRL_PGSZ_BIT)
142 #define GRIOMMU_OPTIONS_PAGESIZE_64KIB (0x4 << CTRL_PGSZ_BIT)
143 #define GRIOMMU_OPTIONS_PAGESIZE_128KIB (0x5 << CTRL_PGSZ_BIT)
144 #define GRIOMMU_OPTIONS_PAGESIZE_256KIB (0x6 << CTRL_PGSZ_BIT)
145 #define GRIOMMU_OPTIONS_PAGESIZE_512KIB (0x7 << CTRL_PGSZ_BIT)
146 extern int griommu_setup(int options);
147 extern int griommu_status(void);
148
149 #define GRIOMMU_MODE_IOMMU 1
150 #define GRIOMMU_MODE_GROUPAPV 0
151 extern int griommu_enable(int mode);
152 extern int griommu_disable(void);
153
154 /* IOMMU APV setup */
155 extern int griommu_apv_flush(void);
156 extern int griommu_apv_init(void * apv, int options);
157 extern int griommu_apv_address_set(void * apv, uint32_t addr, int size,
158  int options);
159 extern int griommu_apv_page_set(void * apv, int index, int size, int options);
160
161 /* GRIOMMU Interrupts */
162 /* Function Interrupt-Code ISR callback prototype.
163  * arg - Custom arg provided by user
164  * access - AHB Access that failed
165  * status - Error status register of the GRIOMMU core
166  */
167 typedef void (*griommu_isr_t)(void *arg, uint32_t access, uint32_t status);
168 #define GRIOMMU_INTERRUPT_ALL (0x2f << 0)
169 #define GRIOMMU_INTERRUPT_PARITY_ERROR (0x1 << 5)
170 #define GRIOMMU_INTERRUPT_FLUSH_COMPLETED (0x1 << 3)
171 #define GRIOMMU_INTERRUPT_FLUSH_START (0x1 << 2)
172 #define GRIOMMU_INTERRUPT_ACCESS_DENIED (0x1 << 1)
173 #define GRIOMMU_INTERRUPT_TRANSLATION_ERROR (0x1 << 0)
174 extern int griommu_isr_register(griommu_isr_t isr, void * arg, int options);
175 extern int griommu_isr_unregister(void);
176 extern int griommu_interrupt_unmask(int options);
177 extern int griommu_interrupt_mask(int options);
178
179 extern int griommu_error_status(uint32_t * access);
180
181 extern int griommu_print(void);
182
183 #ifdef __cplusplus
184 }
185 #endif
186
187 #endif /* __GRIOMMU_H__ */
Definition: rtemscompat1.h:15
unsigned size
Definition: tte.h:74
