RTEMS
5.1
Data Structure Index
Class Hierarchy
z
z
z
z
Pages
bsps
include
grlib
gr_tmtc_1553.h
1
/* GR-TMTC-1553 PCI Target driver.
2
3
* COPYRIGHT (c) 2010.
4
* Cobham Gaisler AB.
5
6
* Configures the GR-TMTC-1553 interface PCI board.
7
* This driver provides a AMBA PnP bus by using the general part
8
* of the AMBA PnP bus driver (ambapp_bus.c).
9
10
* Driver resources for the AMBA PnP bus provided can be set using
11
* gr_tmtc_1553_set_resources().
12
13
* The license and distribution terms for this file may be
14
* found in found in the file LICENSE in this distribution or at
15
* http://www.rtems.org/license/LICENSE.
16
17
18
#ifndef __GR_TMTC_1553_H__
19
#define __GR_TMTC_1553_H__
20
21
#include <drvmgr/drvmgr.h>
22
23
#ifdef __cplusplus
24
extern
"C"
25
#endif
26
27
/* An array of pointers to GR-TMTC-1553 resources. The resources will be
28
* used by the drivers controlling the cores on the GR-TMTC-1553 target AMBA bus.
29
30
* The gr_rasta_io_resources is declared weak so that the user can override the
31
* default configuration. The array must be terminated with a NULL resource.
32
33
extern
struct
drvmgr_bus_res
*gr_tmtc_1553_resources[];
34
35
/* Options to gr_rasta_io_print function */
36
#define TMTC_1553_OPTIONS_AMBA 0x01
/* Print AMBA bus devices */
37
#define TMTC_1553_OPTIONS_IRQ 0x02
/* Print current IRQ setup */
38
39
/* Print information about GR-RASTA-IO PCI board */
40
void
gr_tmtc_1553_print(
int
options);
41
42
/* Register GR-RASTA-IO driver */
43
void
gr_tmtc_1553_register_drv(
void
44
45
/* Print information about all GR-TMTC-1553 devices registered to this driver */
46
void
gr_tmtc_1553_print(
int
options);
47
48
/* Print information about one GR-TMTC-1553 device */
49
void
gr_tmtc_1553_print_dev(
struct
drvmgr_dev
*dev,
int
options);
50
51
#ifdef __cplusplus
52
53
#endif
54
55
#endif
drvmgr_bus_res
Definition:
drvmgr.h:214
drvmgr_dev
Definition:
drvmgr.h:275
