RTEMS
5.1
Data Structure Index
Class Hierarchy
z
z
z
z
Pages
bsps
include
grlib
gr_rasta_tmtc.h
1
/* GR-RASTA-TMTC PCI Target driver.
2
3
* COPYRIGHT (c) 2008.
4
* Cobham Gaisler AB.
5
6
* Configures the GR-RASTA-TMTC interface PCI board.
7
* This driver provides a AMBA PnP bus by using the general part
8
* of the AMBA PnP bus driver (ambapp_bus.c).
9
10
* Driver resources for the AMBA PnP bus provided can be set using
11
* gr_rasta_tmtc_set_resources().
12
13
* The license and distribution terms for this file may be
14
* found in found in the file LICENSE in this distribution or at
15
* http://www.rtems.org/license/LICENSE.
16
17
18
#ifndef __GR_RASTA_TMTC_H__
19
#define __GR_RASTA_TMTC_H__
20
21
#include <drvmgr/drvmgr.h>
22
23
#ifdef __cplusplus
24
extern
"C"
25
#endif
26
27
/* GPIO TM/TC configuration pin definitions
28
* --31 PWRX (1=PW2APB, 0=TM VC3/4)
29
* --30 PWTC (1=APB2PW, 0=TC MAP1/2)
30
* --29 Redundant TM (1=enable, 0=disable)
31
* --28 Redundant TC (1=enable, 0=disable)
32
* --27 Select TM output (1=GRTM, 0=PTME)
33
* --26 Loop back PW (1=enable, 0=disable)
34
* --25 Transponder clock (1=PLL, 0=PLL bypass)
35
* --24 PWTX-SELECT (0=TX0-0, 1=TX0-1)
36
* --23 PDEC Map Switch (1=on, 0=off)
37
* --22 PDEC Ext CPDU (1=on, 0=off)
38
* --21 PDEC Super User (1=on, 0=off)
39
* --20 PDEC RM On (1=on, 0=off)
40
* --19 PDEC AU Enable (1=on, 0=off)
41
* --18 PDEC Dynamic Mode (1=on, 0=off)
42
* --17 PDEC Priority (1=on, 0=off)
43
* --16 TC PSS Support (1=on, 0=off)
44
* --15 TC Mark (1=on, 0=off)
45
* --14 TC Pseudo (1=on, 0=off)
46
* --13 TC Rising Clock (1=rise, 0=fall)
47
* --12 TC Active High (1=high, 0=low)
48
* --11 Bit Lock Positive (1=high, 0=low)
49
* --10 RF Avail Positive (1=high, 0=low)
50
* -- 9 : 0 SpaceCraft ID
51
52
53
#define GR_TMTC_GPIO_PWRX (1<<31)
54
#define GR_TMTC_GPIO_PWTC (1<<30)
55
#define GR_TMTC_GPIO_RED_TM (1<<29)
56
#define GR_TMTC_GPIO_RED_TC (1<<28)
57
#define GR_TMTC_GPIO_GRTM_SEL (1<<27)
58
#define GR_TMTC_GPIO_LB_PW (1<<26)
59
#define GR_TMTC_GPIO_TRANSP_CLK (1<<25)
60
#define GR_TMTC_GPIO_PWTX_SEL (1<<24)
61
#define GR_TMTC_GPIO_PDEC_MAP (1<<23)
62
#define GR_TMTC_GPIO_PDEC_CPDU (1<<22)
63
#define GR_TMTC_GPIO_PDEC_SU (1<<21)
64
#define GR_TMTC_GPIO_PDEC_RM (1<<20)
65
#define GR_TMTC_GPIO_PDEC_AU (1<<19)
66
#define GR_TMTC_GPIO_PDEC_DYN_MODE (1<<18)
67
#define GR_TMTC_GPIO_PDEC_PRIO (1<<17)
68
#define GR_TMTC_GPIO_TC_PSS (1<<16)
69
#define GR_TMTC_GPIO_TC_MARK (1<<15)
70
#define GR_TMTC_GPIO_TC_PSEUDO (1<<14)
71
#define GR_TMTC_GPIO_TC_RISING_CLK (1<<13)
72
#define GR_TMTC_GPIO_TC_ACTIVE_HIGH (1<<12)
73
#define GR_TMTC_GPIO_TC_BIT_LOCK (1<<11)
74
#define GR_TMTC_GPIO_TC_RF_AVAIL (1<<10)
75
#define GR_TMTC_GPIO_SCID (0x000003ff)
76
77
/* An array of pointers to GR-RASTA-TMTC bus resources. The resources will be
78
* used by the device drivers controlling the cores on the GR-RASTA-IO target
79
* AMBA bus.
80
81
* The array is defined weak, and defaults to no resources. The array must be
82
* terminated with a NULL resource.
83
84
extern
struct
drvmgr_bus_res
*gr_rasta_tmtc_resources[];
85
86
/* Options to gr_rasta_io_print function */
87
#define RASTA_TMTC_OPTIONS_AMBA 0x01
/* Print AMBA bus devices */
88
#define RASTA_TMTC_OPTIONS_IRQ 0x02
/* Print current IRQ setup */
89
90
/* Print information about GR-RASTA-TMTC PCI boards */
91
void
gr_rasta_tmtc_print(
int
options);
92
93
/* Print information about a GR-RASTA-TMTC PCI boards */
94
void
gr_rasta_tmtc_print_dev(
struct
drvmgr_dev
*dev,
int
options);
95
96
/* Register GR-RASTA-TMTC driver */
97
void
gr_rasta_tmtc_register_drv(
void
98
99
#ifdef __cplusplus
100
101
#endif
102
103
#endif
drvmgr_bus_res
Definition:
drvmgr.h:214
drvmgr_dev
Definition:
drvmgr.h:275
