RTEMS  5.1
gr1553rt.h
1 /* GR1553B RT driver
2  *
3  * COPYRIGHT (c) 2010.
4  * Cobham Gaisler AB.
5  *
6  * The license and distribution terms for this file may be
7  * found in the file LICENSE in this distribution or at
8  * http://www.rtems.org/license/LICENSE.
9  */
10
11 #ifndef __GR1553RT_H__
12 #define __GR1553RT_H__
13
14 /* CONFIG OPTION: Maximum number of LIST IDs supported.
15  * There are two lists per RT subaddress, one for RX one
16  * for TX.
17  */
18 #define RTLISTID_MAX 64
19
20 /* CONFIG OPTION: Maximum number of Interrupt handlers per device supported
21  * max is 256 supported, and minimum is 1.
22  */
23 #define RTISR_MAX 64
24
25 /* CONFIG OPTION: Maximum number of transfer (RX/TX) descriptors supported.
26  *
27  * Set this option to zero to allow flexible number of descriptors,
28  * requires dynamically allocation of driver structures.
29  */
30 /*#define RTBD_MAX 4096*/
31 #define RTBD_MAX 0
32
33 #ifdef __cplusplus
34 extern "C" {
35 #endif
36
37 /* Register GR1553B driver needed by RT driver */
38 extern void gr1553rt_register(void);
39
40 struct gr1553rt_list;
41
42 /* Descriptor read/written by hardware.
43  *
44  * Must be aligned to 16 byte boundary
45  */
46 struct gr1553rt_bd {
47  volatile unsigned int ctrl; /* 0x00 Control/Status word */
48  volatile unsigned int dptr; /* 0x04 Data Pointer */
49  volatile unsigned int next; /* 0x08 Next Descriptor in list */
50  volatile unsigned int unused; /* 0x0C UNUSED BY HARDWARE */
51 };
52
53 /* Sub address table entry, the hardware access */
54 struct gr1553rt_sa {
55  volatile unsigned int ctrl; /* 0x00 SUBADDRESS CONTROL WORD */
56  volatile unsigned int txptr; /* 0x04 TRANSMIT BD POINTER */
57  volatile unsigned int rxptr; /* 0x08 RECEIVE BD POINTER */
58  volatile unsigned int unused; /* 0x0C UNUSED BY HARDWARE */
59 };
60
61 /* Configuration of a RT-SubAddress-List */
63  unsigned int bd_cnt; /* Number of hw-descriptors in list */
64 };
65
66 /* A TX or RX subaddress descriptor list */
67 struct gr1553rt_list {
68  short listid; /* ID/NUMBER of List. -1 unassigned */
69  short subadr; /* SubAddress. -1 when not scheduled */
70  void *rt; /* Scheduled on Device */
71  struct gr1553rt_list_cfg *cfg; /* List configuration */
72  int bd_cnt; /* Number of Descriptors */
73
74  /* !!Must be last in data structure!!
75  * !!Array must at least be of length bd_cnt!!
76  */
77  unsigned short bds[0]; /* Array of BDIDs */
78 };
79
80 /* GR1553B-RT Driver configuration options used when calling gr1553rt_config().
81  *
82  * Note that if not custom addresses are given the driver will dynamically
83  * allocate memory for buffers.
84  * Note that if custom addresses with the LSB set, the address will be
85  * interpreted as a address accessible by hardware, and translated
86  * into an address used by CPU.
87  */
88 struct gr1553rt_cfg {
89  unsigned char rtaddress; /* RT Address 0..30 */
90
91  /*** MODE CODE CONFIG ***/
92  unsigned int modecode; /* Mode codes enable/disable/IRQ/EV-Log.
93  * Each modecode has a 2-bit cfg field.
94  * See Mode Code Control Register in
95  * hardware manual.
96  */
97
98  /*** TIME CONFIG ***/
99  unsigned short time_res; /* Time tag resolution in us */
100
101  /*** SUBADDRESS TABLE CONFIG ***/
102  void *satab_buffer; /* Optional Custom buffer. Must be
103  * At least 16*32 bytes, and be aligned
104  * to 10-bit (1KB) boundary. Set to NULL
105  * to make driver allocate buffer.
106  */
107
108  /*** EVENT LOG CONFIG ***/
109  void *evlog_buffer; /* Optional Custom buffer */
110  int evlog_size; /* Length, must be a multiple of 2.
111  * If set to ZERO event log is disabled
112  */
113
114  /*** TRANSFER DESCRIPTOR CONFIG ***/
115  int bd_count; /* Number of transfer descriptors shared
116  * by all RX/TX sub-addresses */
117  void *bd_buffer; /* Optional Custom descriptor area.
118  * Must hold bd_count*32 bytes.
119  * If NULL, descriptors will be
120  * allocated dynamically. */
121 };
122
123 /* GR1553B-RT status indication, copied from the RT registers and stored
124  * here. Used when calling the gr1553rt_status() function.
125  */
127  unsigned int status; /* RT Status word */
128  unsigned int bus_status; /* BUS Status */
129  unsigned short synctime; /* Time Tag of last sync with data */
130  unsigned short syncword; /* Data of last mode code synchronize
131  * with data. */
132  unsigned short time_res; /* Time resolution (set by config) */
133  unsigned short time; /* Current Time Tag */
134 };
135
136 /* ISR callback definition for ERRORs detected in the GR1553B-RT interrupt
137  * handler.
138  *
139  * \param err Inidicate Error type. The IRQ flag register bit mask:
140  * Bit 9 - RT DMA ERROR
141  * Bit 10 - RT Table access error
142  * \param data Custom data assigned by user
143  */
144 typedef void (*gr1553rt_irqerr_t)(int err, void *data);
145
146 /* ISR callback definition for modecodes that are configured to generate
147  * an IRQ. The callback is called from within the GR1553B-RT interrupt
148  * handler.
149  *
150  * \param mcode Mode code that caused this IRQ
151  * \param entry The raw Eventlog Entry
152  * \param data Custom data assigned by user
153  */
154 typedef void (*gr1553rt_irqmc_t)(int mcode, unsigned int entry, void *data);
155
156 /* Transfer ISR callback definition. Called from GR1553B-RT interrupt handler
157  * when an interrupt has been generated and a event logged due to a 1553
158  * transfer to this RT.
159  *
160  * \param list List (Subaddress/TransferType) that caused IRQ
161  * \param entry The raw Eventlog Entry
162  * \param bd_next Next Descriptor-entry index in the list (Subaddress/tr-type)
163  * This can be used to process all descriptors upto entry_next.
164  * \param data Custom data assigned by user
165  */
166 typedef void (*gr1553rt_irq_t)(
167  struct gr1553rt_list *list,
168  unsigned int entry,
169  int bd_next,
170  void *data
171  );
172
173 /* Configure a list according to configuration. Assign the list
174  * to a device, however not to a RT sub address yet. The rt
175  * is stored within list.
176  *
177  * \param rt RT Device driver identification, stored within list.
178  * \param list The list to configure
179  * \param cfg Configuration for list. Pointer to configuration is
180  * stored within list for later use.
181  */
182 extern int gr1553rt_list_init
183  (
184  void *rt,
185  struct gr1553rt_list **plist,
186  struct gr1553rt_list_cfg *cfg
187  );
188
189 /* Assign an Error Interrupt handler. Before the handler is called the
190  * RT hardware is stopped/disabled. The handler is optional, if not assigned
191  * the ISR will still stop the RT upon error.
192  *
193  * Errors detected by the interrupt handler:
194  * - DMA error
195  * - Subaddress table access error
196  *
197  * \param func ISR called when an error causes an interrupt.
198  * \param data Custom data given as an argument when calling ISR
199  */
200 extern int gr1553rt_irq_err
201  (
202  void *rt,
203  gr1553rt_irqerr_t func,
204  void *data
205  );
206
207 /* Assign a ModeCode Interrupt handler callback. Called when a 1553 modecode
208  * transfer is logged and cause an IRQ. The modecode IRQ generation is
209  * configured from "struct gr1553rt_cfg" when calling gr1553rt_config().
210  *
211  * \param func ISR called when a modecode causes an interrupt.
212  * \param data Custom data given as an argument when calling ISR
213  */
214 extern int gr1553rt_irq_mc
215  (
216  void *rt,
217  gr1553rt_irqmc_t func,
218  void *data
219  );
220
221 /* Assign transfer interrupt handler callback. Called when a RX or TX
222  * transfer is logged and cause an interrupt, the function is called
223  * from the GR1553B-RT driver's ISR, in interrupt context.
224  *
225  * The callback can be installed per subaddress and transfer type.
226  * Subaddress 0 and 31 are not valid (gr1553rt_irq_mc() for modecodes).
227  *
228  * \param subadr Select subaddress (1-30)
229  * \param tx 1=TX subaddress, 0=RX subaddress
230  * \param func ISR called when subaddress of spcified transfer type
231  * causes an interrupt.
232  * \param data Custom data given as an argument when calling ISR
233  */
234 extern int gr1553rt_irq_sa
235  (
236  void *rt,
237  int subadr,
238  int tx,
239  gr1553rt_irq_t func,
240  void *data
241  );
242
243 #define GR1553RT_BD_FLAGS_IRQEN (1<<30)
244 /* Initialize a descriptor entry in a list. This is typically done
245  * prior to scheduling the list.
246  *
247  * \param entry_no Entry number in list (descriptor index in list)
248  * \param flags Enable IRQ when descriptor is accessed by setting
249  * argument GR1553RT_BD_FLAGS_IRQEN. Enabling IRQ on a
250  * descriptor basis will override SA-table IRQ config.
251  * \param dptr Data Pointer to RX or TX operation. The LSB indicate
252  * if the address must be translated into Hardware address
253  * - this is useful when a buffer close to CPU is used
254  * as a data pointer and the RT core is located over PCI.
255  * \param next Next Entry in list. Set to 0xffff for end of list. Set
256  * 0xfffe for next entry in list, wrap around to entry
257  * zero if entry_no is last descriptor in list (circular).
258  */
259 extern int gr1553rt_bd_init(
260  struct gr1553rt_list *list,
261  unsigned short entry_no,
262  unsigned int flags,
263  uint16_t *dptr,
264  unsigned short next
265  );
266
267 /* Manipulate/Read Control/Status and Data Pointer words of a buffer descriptor.
268  * If status is zero, the control/status word is accessed. If dptr is non-zero
269  * the data pointer word is accessed.
270  *
271  * \param list The list that the descriptor is located at
272  *
273  * \param entry_no The descriptor number accessed
274  *
275  * \param status IN/OUT. If zero no effect. If pointer is non-zero the
276  * value pointed to:
277  * IN: Written to Control/Status
278  * OUT: the value of the Control/Status word before writing.
279  *
280  * \param dptr IN/OUT. If zero no effect. If pointer is non-zero, the
281  * value pointed to:
282  * IN: non-zero: Descriptor data pointer will be updated with
283  * this value. Note that the LSB indicate if the address
284  * must be translated into hardware-aware address.
285  * OUT: The old data pointer is stored here.
286  */
287 extern int gr1553rt_bd_update(
288  struct gr1553rt_list *list,
289  int entry_no,
290  unsigned int *status,
291  uint16_t **dptr
292  );
293
294 /* Get the next/current descriptor processed of a RT sub-address.
295  *
296  * \param subadr RT Subaddress
297  * \param txeno Pointer to where TX descriptor number is stored.
298  * \param rxeno Pointer to where RX descriptor number is stored.
299  */
300 extern int gr1553rt_indication(void *rt, int subadr, int *txeno, int *rxeno);
301
302 /* Take a GR1553RT hardware device identified by minor.
303  * A pointer is returned that is used internally by the GR1553RT
304  * driver, it is used as an input parameter 'rt' to all other
305  * functions that manipulate the hardware.
306  *
307  * This function initializes the RT hardware to a stopped/disable level.
308  */
309 extern void *gr1553rt_open(int minor);
310
311 /* Close and stop/disable the RT hardware. */
312 extern void gr1553rt_close(void *rt);
313
314 /* Configure the RT. The RT device must be configured once before
315  * started. A started RT device can not be configured.
316  *
317  * \param rt The RT to configure
318  * \param cfg Configuration parameters
319  */
320 extern int gr1553rt_config(void *rt, struct gr1553rt_cfg *cfg);
321
322 /* Schedule a RX or TX list on a sub address. If a list has already been
323  * schduled on the subaddress and on the same transfer type (RX/TX), the
324  * old list is replaced with the list given here.
325  *
326  * \param subadr Subaddress to schedule list on
327  * \param tx Subaddress transfer type: 1=TX, 0=RX
328  * \param list Preconfigued RT list scheduled
329  */
330 extern void gr1553rt_sa_schedule(
331  void *rt,
332  int subadr,
333  int tx,
334  struct gr1553rt_list *list
335  );
336
337 /* Set SubAdress options. One may for example Enable or Disable a sub
338  * address RX and/or TX. See hardware manual for SA-Table configuration
339  * options.
340  *
341  * \param subadr SubAddress to configure
342  * \param mask Bit mask of option-bits written to subaddress config
343  * \param options The new options written to subaddress config.
344  *
345  */
346 extern void gr1553rt_sa_setopts(
347  void *rt,
348  int subadr,
349  unsigned int mask,
350  unsigned int options
351  );
352
353 /* Get The Subaddress and transfer type of a scheduled list. Normally the
354  * application knows which subaddress the list is for.
355  *
356  * \param list List to lookup information for
357  * \param subadr Pointer to where the subaddress is stored
358  * \param tx Transfer type is stored here. 1=TX, 0=RX.
359  */
360 extern void gr1553rt_list_sa(
361  struct gr1553rt_list *list,
362  int *subadr,
363  int *tx
364  );
365
366 /* Start RT Communication
367  *
368  * Interrupts will be enabled. The RT enabled and the "RT-run-time"
369  * part of the API will be opened for the user and parts that need the
370  * RT to be stopped are no longer available. After the RT has been
371  * started the configuration function can not be called.
372  */
373 extern int gr1553rt_start(void *rt);
374
375 /* Get Status of the RT core. See data structure gr1553rt_status for more
376  * information about the result. It can be used to read out:
377  * - time information
378  * - sync information
379  * - bus & RT status
380  *
381  * \param status Pointer to where the status words will be stored. They
382  * are stored according to the gr1553rt_status data structure.
383  */
384 extern void gr1553rt_status(void *rt, struct gr1553rt_status *status);
385
386 /* Stop RT communication. Only possible to stop an already started RT device.
387  * Interrupts are disabled and the RT Enable bit cleared.
388  */
389 extern void gr1553rt_stop(void *rt);
390
391 /* Set RT vector and/or bit word.
392  *
393  * - Vector Word is used in response to "Transmit vector word" BC commands
394  * - Bit Word is used in response to "Transmit bit word" BC commands
395  *
396  *
397  * \param mask Bit-Mask, bits that are 1 will result in that bit in the
398  * words register being overwritten with the value of words
399  * \param words Bits 31..16: Bit Word. Bits 15..0: Vector Word.
400  *
401  * Operation:
402  * hw_words = (hw_words & ~mask) | (words & mask)
403  */
404 extern void gr1553rt_set_vecword(
405  void *rt,
406  unsigned int mask,
407  unsigned int words
408  );
409
410 /* Set selectable bits of the "Bus Status Register". The bits written
411  * is determined by the "mask" bit-mask. Operation:
412  *
413  * bus_status = (bus_status & ~mask) | (sts & mask)
414  *
415  */
416 extern void gr1553rt_set_bussts(void *rt, unsigned int mask, unsigned int sts);
417
418 /* Read up to MAX number of entries in eventlog log.
419  *
420  * \param dst Destination address for event log entries
421  * \param max Maximal number of event log entries that an be stored into dst
422  *
423  * Return
424  * negative Failure
425  * zero No entries available at the moment
426  * positive Number of entries copied into dst
427  */
428 extern int gr1553rt_evlog_read(void *rt, unsigned int *dst, int max);
429
430 #ifdef __cplusplus
431 }
432 #endif
433
434 #endif
Definition: gr1553rt.h:88
Definition: gr1553rt.h:67
Definition: gr1553rt.h:62
Definition: gr1553rt.h:46
Definition: gr1553rt.h:126
Definition: mmu-config.c:40
Definition: gr1553rt.h:54
