RTEMS  5.1
gr1553bc.h
1 /* GR1553B BC driver
2  *
3  * COPYRIGHT (c) 2010.
4  * Cobham Gaisler AB.
5  *
6  * The license and distribution terms for this file may be
7  * found in the file LICENSE in this distribution or at
8  * http://www.rtems.org/license/LICENSE.
9  *
10  * OVERVIEW
11  * ========
12  * This driver controls the BC device, located at an on-chip AMBA or an
13  * AMBA-over-PCI bus. The driver operates the BC device and provides you
14  * with interrupt services and core control. The driver start execution of
15  * a synchronuos and/or an asynchronous BC descriptor List. The list contains
16  * a descriptor table and a software description to make some operations
17  * possible, for example translate descriptor-address into descriptor-number.
18  *
19  * BC descriptors are generated by the list API, available in gr1553bc_list.h.
20  *
21  * See gr1553bc_list.h for more information.
22  */
23
24 #ifndef __GR1553BC_H__
25 #define __GR1553BC_H__
26
27 #ifdef __cplusplus
28 extern "C" {
29 #endif
30
31 /* Forward declaration */
32 struct gr1553bc_list;
33 struct gr1553bc_major;
34 struct gr1553bc_minor;
35 struct gr1553bc_minor_cfg;
36 struct gr1553bc_major_cfg;
37
38 #ifdef __cplusplus
39 }
40 #endif
41
42 #include <stdint.h>
43 #include "gr1553bc_list.h"
44
45 #ifdef __cplusplus
46 extern "C" {
47 #endif
48
49 /* Register GR1553B driver needed by BC driver */
50 extern void gr1553bc_register(void);
51
52 /* A BC descriptor accessed as is */
54  volatile uint32_t words[4];
55 };
56
57 /* A BC descriptor accessed as a transfer descriptor */
59  volatile uint32_t settings[2];
60  volatile uint32_t dptr;
61  volatile uint32_t status;
62 };
63
64 /* A BC descriptor accessed as a conditional descriptor */
66  volatile uint32_t cond;
67  volatile uint32_t bdptr;
68  volatile uint32_t padding[2];
69 };
70
71 /* A BC descriptor accessed any way */
72 union gr1553bc_bd {
73  struct gr1553bc_bd_raw raw;
74  struct gr1553bc_bd_tr tr;
75  struct gr1553bc_bd_cond cond;
76 };
77
78 /* Current state of the BC hardware */
80  unsigned int status;
81  unsigned int time;
82 };
83
84 #define KEEP_TIMESLOT 0x10
85 /* Initialize a BC descriptor. The words written is controllable by
86  * the flags argument.
87  *
88  * flags:
89  * bit[N=0..3]: 1 = set BD wordN according to argument wordN,
90  * 0 = do not modify BD wordN
91  *
92  * If bit KEEP_TIMESLOT is set the time slot of word0 is preserved,
93  * this bit only have an affect when the descriptor is a transfer
94  * descriptor.
95  */
96 extern void gr1553bc_bd_init(
97  union gr1553bc_bd *bd,
98  unsigned int flags,
99  uint32_t word0,
100  uint32_t word1,
101  uint32_t word2,
102  uint32_t word3
103  );
104
105 /* Initialize a Transfer descriptor
106  *
107  * Arguments:
108  * struct gr1553bc_bd_tr *bd
109  * uint32_t setting0
110  * uint32_t setting1
111  * uint32_t data
112  * uint32_t status
113  */
114 #define gr1553bc_bd_tr_init(bd, set0, set1, data, status) \
115  gr1553bc_bd_init((union gr1553bc_bd *)bd,\
116  0xf, set0, set1, data, status)
117 /* Initializa a Condition descriptor
118  *
119  * Arguments:
120  * struct gr1553bc_bd_cond *bd
121  * uint32_t cond
122  * uint32_t jump_adr
123  */
124 #define gr1553bc_bd_cond_init(bd, cond, jump_adr) \
125  gr1553bc_bd_init((union gr1553bc_bd *)bd, \
126  0xf, cond, jump_adr, 0, 0)
127
128 /* Size of a descriptor */
129 #define GR1553BC_BD_SIZE sizeof(struct gr1553bc_bd_raw)
130
131 /* Alignment of a descriptor */
132 #define GR1553BC_BD_ALIGN 16
133
134 /* End of list marker */
135 #define GR1553BC_TR_EOL 0x80ffffff
136
137 #define GR1553BC_BD_TYPE 0x80000000
138
139 /* Condition descriptor bits */
140 #define GR1553BC_UNCOND_JMP 0x820000ff
141 #define GR1553BC_UNCOND_IRQ 0x860000ff
142 #define GR1553BC_UNCOND_NOJMP 0x82000000
143
144 /* Transfer descriptor bits */
145 #define GR1553BC_TR_DUMMY_0 0x00000000
146 #define GR1553BC_TR_DUMMY_1 0x80000000
147
148 #define GR1553BC_TR_TIME 0x0000ffff
149
150 #define GR1553BC_TR_EXTTRIG 0x40000000
151
152 /* Take a GR1553BC hardware device identified by instance index (minor).
153  * A pointer is returned that is used internally by the GR1553BC
154  * driver, it is used as an input paramter 'bc' to all other
155  * functions that manipulate the hardware.
156  */
157 extern void *gr1553bc_open(int minor);
158
159 extern void gr1553bc_close(void *bc);
160
161 /* Stores Current Major/Minor frame number and the Slot number executing
162  * into the location indicated by 'mid'. There may be two lists executing
163  * in "parallel", the 'async' argument select for which list the MID is
164  * looked up, the Syncronous (async=0) list or the Asynchronous (async=1)
165  * list.
166  *
167  */
168 extern int gr1553bc_indication(void *bc, int async, int *mid);
169
170 /* Trigger external time sync by writing to the BC action register.
171  * This may be good for debugging or if the time management is
172  * implemented in software.
173  *
174  * if trig=0 the external trigger memory is cleared.
175  * if trig!=0 the external trigger memory is set.
176  */
177 extern void gr1553bc_ext_trig(void *bc, int trig);
178
179 /* Configure the GR1553BC driver */
180 /*extern int gr1553bc_config(struct gr1553bc_config *cfg);*/
181
182 /* Start major frame processing. At least one list pointer must be
183  * non-zero to affect BC operation. The BC communication is enabled
184  * depending on list and Interrupts are enabled. This function can
185  * be called multiple times.
186  *
187  * If a list is already executing it will be replaced with the new
188  * list.
189  *
190  * list - Schedule Transfer List
191  * list_async - Asynchronous list
192  */
193 extern int gr1553bc_start
194  (
195  void *bc,
196  struct gr1553bc_list *list,
197  struct gr1553bc_list *list_async
198  );
199
200 /* Pause GR1553B BC scheduled transfers.
201  *
202  * Does not affect asynchronous operation.
203  */
204 extern int gr1553bc_pause(void *bc);
205
206 /* Restart GR1553B BC scheduled transfers, after being paused
207  *
208  * Does not affect asynchronous operation.
209  */
210 extern int gr1553bc_restart(void *bc);
211
212 /* Stop BC transmission.
213  *
214  * OPTIONS
215  * bit0 - 1=STOP schedule list
216  * bit1 - 1=STOP asynchronous list
217  */
218 extern int gr1553bc_stop(void *bc, int options);
219
220 /* Standard IRQ function setup. IRQ can be generated by condition descriptors
221  * or by transfer descriptors or by errors.
222  *
223  * Condition descriptors are inserted into the list by user, each condition
224  * may have a custom function and data assigned to it, see
225  * gr1553bc_slot_irq_prepare(). IRQs generated by condition descriptors are
226  * not handled by this function.
227  *
228  * Transfer descriptors can generate IRQ if enabled by user.
229  *
230  * IRQs generated by transfer descriptors or by BC errors (DMA error etc.)
231  * is handled by this standard ISR handler.
232  */
233 extern int gr1553bc_irq_setup
234  (
235  void *bc,
236  bcirq_func_t func,
237  void *data
238  );
239
240 /* Get Current BC hardware state/status. The Status is stored into the
241  * area pointed to by status. See "struct gr1553bc_status" for more
242  * info.
243  */
244 extern void gr1553bc_status(void *bc, struct gr1553bc_status *status);
245
246 #ifdef __cplusplus
247 }
248 #endif
249
250 #endif /* __GR1553BC_H__ */
Definition: gr1553bc.h:72
Definition: gr1553bc.h:79
Definition: gr1553bc.h:65
Definition: gr1553bc_list.h:223
Definition: gr1553bc_list.h:340
Definition: gr1553bc_list.h:218
Definition: gr1553bc_list.h:333
Definition: gr1553bc.h:58
Definition: gr1553bc_list.h:241
Definition: gr1553bc.h:53
