RTEMS  5.1
gmacd.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
60 #ifndef _GMACD_H_
61 #define _GMACD_H_
62
63 /*---------------------------------------------------------------------------
64  * Headers
65  *---------------------------------------------------------------------------*/
66
67 #include "chip.h"
68
69
70 /*---------------------------------------------------------------------------
71  * Definitions
72  *---------------------------------------------------------------------------*/
79 #define GMACD_OK 0
80 #define GMACD_TX_BUSY 1
81 #define GMACD_RX_NULL 1
83 #define GMACD_SIZE_TOO_SMALL 2
84
85 #define GMACD_PARAM 3
86
87 #define GMACD_NOT_INITIALIZED 4
88
92 /* Should be a power of 2.
93  - Buffer Length to store the timestamps of 1588 event messages
94 */
95 #define EFRS_BUFFER_LEN (1u)
96
97 /*---------------------------------------------------------------------------
98 * Types
99 *---------------------------------------------------------------------------*/
103 typedef enum ptpMsgType_t {
104  SYNC_MSG_TYPE = 0,
105  DELAY_REQ_MSG_TYPE = 1,
106  PDELAY_REQ_TYPE = 2,
107  PDELAY_RESP_TYPE = 3,
108  FOLLOW_UP_MSG_TYPE = 8,
109  DELAY_RESP_MSG_TYPE = 9
110 } ptpMsgType;
111
112
113
115 typedef void (*fGmacdTransferCallback)(uint32_t status);
117 typedef void (*fGmacdWakeupCallback)(void);
119 typedef void (*fGmacdTxPtpEvtCallBack) (ptpMsgType msg, uint32_t sec, \
120  uint32_t nanosec, uint16_t seqId);
121
125 typedef struct _GmacSG {
126  uint32_t size;
127  void *pBuffer;
128 } sGmacSG;
129
133 typedef struct _GmacSGList {
134  uint32_t len;
135  sGmacSG *sg;
136 } sGmacSGList;
137
141 typedef struct _GmacQueueDriver {
142  uint8_t *pTxBuffer;
144  uint8_t *pRxBuffer;
145
150
157
160
162  uint16_t wRxListSize;
164  uint16_t wRxI;
165
167  uint16_t wTxListSize;
169  uint16_t wTxHead;
171  uint16_t wTxTail;
172
175
177  uint16_t wTxBufferSize;
178  uint16_t wRxBufferSize;
179
180 } sGmacQd;
181
185 typedef struct _GmacDriver {
186
190  uint8_t bId;
192  sGmacQd queueList[NUM_GMAC_QUEUES];
193 } sGmacd;
194
198 typedef struct _GmacInit {
199  uint32_t bIsGem: 1;
200  uint32_t reserved: 31;
201
202  uint8_t bDmaBurstLength;
203
205  uint8_t *pRxBuffer;
211  uint16_t wRxBufferSize;
212  uint16_t wRxSize;
217  uint8_t *pTxBuffer;
222  uint16_t wTxBufferSize;
224  uint16_t wTxSize;
225
226  fGmacdTransferCallback *pTxCb;
227 } sGmacInit;
233 /*---------------------------------------------------------------------------
234  * GMAC Exported functions
235  *---------------------------------------------------------------------------*/
236
237 extern void GMACD_Handler(sGmacd *pGmacd , gmacQueList_t queIdx);
238
239 extern void GMACD_Init(sGmacd *pGmacd,
240  Gmac *pHw,
241  uint8_t bID,
242  uint8_t enableCAF,
243  uint8_t enableNBC);
244
245 extern uint8_t GMACD_InitTransfer(sGmacd *pGmacd,
246  const sGmacInit *pInit, gmacQueList_t queIdx);
247
248 extern void GMACD_Reset(sGmacd *pGmacd);
249
250 extern uint8_t GMACD_SendSG(sGmacd *pGmacd,
251  const sGmacSGList *sgl,
253  gmacQueList_t queIdx);
254
255 extern uint8_t GMACD_Send(sGmacd *pGmacd,
256  void *pBuffer,
257  uint32_t size,
259  gmacQueList_t queIdx);
260
261 extern uint32_t GMACD_TxLoad(sGmacd *pGmacd, gmacQueList_t queIdx);
262
263 extern uint8_t GMACD_Poll(sGmacd *pGmacd,
264  uint8_t *pFrame,
265  uint32_t frameSize,
266  uint32_t *pRcvSize,
267  gmacQueList_t queIdx);
268
270  fRxCb, gmacQueList_t queIdx);
271
272 extern uint8_t GMACD_SetTxWakeupCallback(sGmacd *pGmacd,
273  fGmacdWakeupCallback fWakeup,
274  uint8_t bThreshold,
275  gmacQueList_t queIdx);
276
277 extern void GMACD_TxPtpEvtMsgCBRegister (sGmacd *pGmacd,
278  fGmacdTxPtpEvtCallBack pTxPtpEvtCb,
279  gmacQueList_t queIdx);
280
283 #endif // #ifndef _GMACD_H_
sGmacTxDescriptor * pTxD
Definition: gmacd.h:149
uint16_t wTxTail
Definition: gmacd.h:171
fGmacdTransferCallback * fTxCbList
Definition: gmacd.h:156
uint8_t GMACD_SetTxWakeupCallback(sGmacd *pGmacd, fGmacdWakeupCallback fWakeup, uint8_t bThreshold, gmacQueList_t queIdx)
Definition: gmacd.c:1038
Definition: component_gmac.h:55
Definition: gmacd.c:679
Definition: gmacd.h:141
struct _GmacQueueDriver sGmacQd
uint8_t GMACD_InitTransfer(sGmacd *pGmacd, const sGmacInit *pInit, gmacQueList_t queIdx)
Definition: gmacd.c:551
uint8_t GMACD_SendSG(sGmacd *pGmacd, const sGmacSGList *sgl, fGmacdTransferCallback fTxCb, gmacQueList_t queIdx)
Send a frame split into buffers. If the frame size is larger than transfer buffer size error returned...
Definition: gmacd.c:705
fGmacdTxPtpEvtCallBack fTxPtpEvtCb
Definition: gmacd.h:159
Definition: gmacd.h:220
Definition: gmacd.h:222
Definition: gmacd.h:192
void GMACD_Handler(sGmacd *pGmacd, gmacQueList_t queIdx)
GMAC Interrupt handler.
Definition: gmacd.c:336
Definition: gmacd.h:211
uint8_t * pRxBuffer
Definition: gmacd.h:205
fGmacdTransferCallback fRxCb
Definition: gmacd.h:152
uint16_t wTxSize
Definition: gmacd.h:224
struct _GmacDriver sGmacd
Definition: gmacd.h:133
struct _GmacSGList sGmacSGList
Definition: gmacd.h:125
Definition: gmacd.h:162
uint8_t * pRxBuffer
Definition: gmacd.h:144
struct _GmacInit sGmacInit
void(* fGmacdWakeupCallback)(void)
Definition: gmacd.h:117
void(* fGmacdTransferCallback)(uint32_t status)
Definition: gmacd.h:115
struct _GmacSG sGmacSG
Definition: gmacd.h:177
uint8_t * pTxBuffer
Definition: gmacd.h:217
void(* fGmacdTxPtpEvtCallBack)(ptpMsgType msg, uint32_t sec, uint32_t nanosec, uint16_t seqId)
Definition: gmacd.h:119
void GMACD_SetRxCallback(sGmacd *pGmacd, fGmacdTransferCallback fRxCb, gmacQueList_t queIdx)
Registers pRxCb callback. Callback will be invoked after the next received frame. When GMAC_Poll() re...
Definition: gmacd.c:1006
uint16_t wTxHead
Definition: gmacd.h:169
uint16_t wRxI
Definition: gmacd.h:164
Definition: gmacd.c:868
sGmacRxDescriptor * pRxD
Definition: gmacd.h:208
fGmacdWakeupCallback fWakupCb
Definition: gmacd.h:154
uint8_t GMACD_Send(sGmacd *pGmacd, void *pBuffer, uint32_t size, fGmacdTransferCallback fTxCb, gmacQueList_t queIdx)
Send a packet with GMAC. If the packet size is larger than transfer buffer size error returned....
Definition: gmacd.c:815
uint8_t bWakeupThreshold
Definition: gmacd.h:174
Definition: b1553brm.c:75
Definition: gmacd.h:167
Definition: gmac.h:210
Gmac * pHw
Definition: gmacd.h:188
Definition: gmacd.h:185
Definition: gmac.h:172
uint8_t bId
Definition: gmacd.h:190
uint16_t wRxSize
Definition: gmacd.h:212
uint8_t GMACD_Poll(sGmacd *pGmacd, uint8_t *pFrame, uint32_t frameSize, uint32_t *pRcvSize, gmacQueList_t queIdx)
Receive a packet with GMAC. If not enough buffer for the packet, the remaining data is lost but right...
Definition: gmacd.c:885
unsigned size
Definition: tte.h:74
Definition: gmacd.h:198
Definition: gmacd.h:147
void GMACD_Init(sGmacd *pGmacd, Gmac *pHw, uint8_t bID, uint8_t enableCAF, uint8_t enableNBC)
Initialize the GMAC with the Gmac controller address.
Definition: gmacd.c:486
