RTEMS  5.1
genirq.h
1 /* General Shared Interrupt handling function interface
2  *
3  * The functions does not manipulate the IRQ controller or the
4  * interrupt level of the CPU. It simply helps the caller with
5  * managing shared interrupts where multiple interrupt routines
6  * share on interrupt vector/number.
7  *
8  * COPYRIGHT (c) 2008.
9  * Cobham Gaisler AB.
10  *
11  * The license and distribution terms for this file may be
12  * found in the file LICENSE in this distribution or at
13  * http://www.rtems.org/license/LICENSE.
14  */
15
16 #ifndef __GENIRQ_H__
17 #define __GENIRQ_H__
18
19 #ifdef __cplusplus
20 extern "C" {
21 #endif
22
23 typedef void (*genirq_handler)(void *arg);
24 typedef void* genirq_t;
25
26 struct genirq_stats {
27  unsigned int irq_cnt;
28 };
29
30 /* Initialize the genirq interface. Must be the first function
31  * called.
32  *
33  * Returns zero on success, otherwise failure.
34  */
35 extern genirq_t genirq_init(int number_of_irqs);
36
37 /* Free the dynamically allocated memory that the genirq interface has
38  * allocated. Also the handlers will be freed.
39  *
40  * Returns zero on success, otherwise failure.
41  */
42 extern void genirq_destroy(genirq_t d);
43
44 /* Check IRQ number validity
45  *
46  * Returns zero for valid IRQ numbers, -1 of invalid IRQ numbers.
47  */
48 extern int genirq_check(genirq_t d, int irq);
49
50 /* Allocate one ISR handler and initialize it. Input to genirq_register().
51  *
52  * \param isr The interrupt service routine called upon IRQ
53  * \param arg The argument given to isr() when called.
54  *
55  * Returns a pointer on success, on failure NULL is returned.
56  */
57 extern void *genirq_alloc_handler(genirq_handler isr, void *arg);
58
59 /* Free handler memory */
60 #define genirq_free_handler(handler) free(handler)
61
62 /* Register shared interrupt handler previously initialized with
63  * genirq_alloc_handler().
64  *
65  * NOTE: internal list structures are accessed and needs to be protected by
66  * spin-locks/IRQ disable by the user to guarantee a correct behaviour.
67  *
68  * \param irq The interrupt number to register ISR on
69  * \param handler Install the pre- allocated and initialized handler.
70  *
71  * Return Values
72  * -1 = Failed
73  * 0 = Handler registered Successfully, first handler on this IRQ
74  * 1 = Handler registered Successfully, _not_ first handler on this IRQ
75  */
76 extern int genirq_register(genirq_t d, int irq, void *handler);
77
78 /* Unregister an previous registered interrupt handler. It is the user's
79  * responsibility to free the handler returned by genirq_unregister().
80  *
81  * NOTE: internal list structures are accessed and needs to be protected by
82  * spin-locks/IRQ disable by the user to guarantee a correct behaviour.
83  *
84  * Return Values
85  * NULL = ISR not registered before or unable to unregister enabled ISR
86  * Pointer = ISR sucessfully unregistered. Returned is the handler pointer
87  * previously allocated with genirq_alloc_handler().
88  */
89 extern void *genirq_unregister(genirq_t d, int irq,
90  genirq_handler isr, void *arg);
91
92 /* Enables IRQ only for this isr[arg] combination. Records if this
93  * is the first interrupt enable, only then must interrupts be enabled
94  * on the interrupt controller.
95  *
96  * NOTE: internal list structures are accessed and needs to be protected by
97  * spin-locks/IRQ disable by the user to guarantee a correct behaviour.
98  *
99  * Return values
100  * -1 = Failure, for example isr[arg] not registered on this irq
101  * 0 = IRQ must be enabled, it is the first IRQ handler to be enabled
102  * 1 = IRQ has already been enabled, either by isr[arg] or by another handler
103  */
104 extern int genirq_enable(genirq_t d, int irq, genirq_handler isr, void *arg);
105
106 /* Disables IRQ only for this isr[arg] combination. Records if this
107  * is the only interrupt handler that is enabled on this IRQ, only then
108  * must interrupts be disabled on the interrupt controller.
109  *
110  * NOTE: internal list structures are accessed and needs to be protected by
111  * spin-locks/IRQ disable by the user to guarantee a correct behaviour.
112  *
113  * Return values
114  * -1 = Failure, for example isr[arg] not registered on this irq
115  * 0 = IRQ must be disabled, no ISR are enabled for this IRQ
116  * 1 = ISR has already been disabled, or other ISRs are still enabled
117  */
118 extern int genirq_disable(genirq_t d, int irq, genirq_handler isr, void *arg);
119
120 /* Must be called by user when an IRQ has fired, the argument 'irq'
121  * is the IRQ number of the IRQ which was fired.
122  *
123  * NOTE: internal list structures are accessed and needs to be protected by
124  * spin-locks/IRQ disable by the user to guarantee a correct behaviour.
125  */
126 extern void genirq_doirq(genirq_t d, int irq);
127
128 #ifdef __cplusplus
129 }
130 #endif
131
132 #endif
Definition: genirq.h:26
