RTEMS  5.1
fsl-mpc564xL.h
1 /*
2  * Modifications of the original file provided by Freescale Semiconductor and
3  * ST Microelectronics are:
4  *
5  * Copyright (c) 2011 embedded brains GmbH. All rights reserved.
6  *
7  * embedded brains GmbH
8  * Obere Lagerstr. 30
9  * 82178 Puchheim
10  * Germany
11  * <info@embedded-brains.de>
12  *
13  * Redistribution and use in source and binary forms, with or without
14  * modification, are permitted provided that the following conditions
15  * are met:
16  * 1. Redistributions of source code must retain the above copyright
17  * notice, this list of conditions and the following disclaimer.
18  * 2. Redistributions in binary form must reproduce the above copyright
19  * notice, this list of conditions and the following disclaimer in the
20  * documentation and/or other materials provided with the distribution.
21  *
22  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
23  * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
24  * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
25  * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
26  * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
27  * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
28  * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
29  * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
30  * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
31  * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
32  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
33  */
34
35 /****************************************************************************\
36  * PROJECT : MPC5643L
37  * FILE : mpc5643l.h
38  *
39  * DESCRIPTION : This is the header file describing the register
40  * set for the named projects.
41  *
42  * COPYRIGHT : (c) 2009, Freescale Semiconductor & ST Microelectronics
43  *
44  * VERSION : 1.04
45  * RELEASE DATE : Tue Dec 1 2009
46  * CREATION DATE : Thu Oct 8 13:53:51 CEST 2009
47  * AUTHOR : generated from IP-XACT database
48  * HISTORY : Preliminary release.
49 \****************************************************************************/
50
51 /* >>>> NOTE! this file is auto-generated please do not edit it! <<<< */
52
53 /****************************************************************************\
54  * Example instantiation and use:
55  *
56  * <MODULE>.<REGISTER>.B.<BIT> = 1;
57  * <MODULE>.<REGISTER>.R = 0x10000000;
58  *
59 \****************************************************************************/
60
61 /*
62  * LICENSE:
63  * Copyright (c) 2006 Freescale Semiconductor
64  *
65  * Permission is hereby granted, free of charge, to any person
66  * obtaining a copy of this software and associated documentation
67  * files (the "Software"), to deal in the Software without
68  * restriction, including without limitation the rights to use,
69  * copy, modify, merge, publish, distribute, sublicense, and/or
70  * sell copies of the Software, and to permit persons to whom the
71  * Software is furnished to do so, subject to the following
72  * conditions:
73  *
74  * The above copyright notice and this permission notice
75  * shall be included in all copies or substantial portions
76  * of the Software.
77  *
78  * THIS SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
79  * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES
80  * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
81  * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
82  * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
83  * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
84  * OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
85  * DEALINGS IN THE SOFTWARE.
86  *
87  */
88
89 #ifndef _leopard_H_ /* prevents multiple inclusions of this file */
90 #define _leopard_H_
91
92 #ifndef ASM
93
94 #include <stdint.h>
95
96 #include <mpc55xx/regs-edma.h>
97
98 #ifdef __cplusplus
99 extern "C" {
100 #endif
101
102 #ifdef __MWERKS__
103 #pragma push
104 #pragma ANSI_strict off
105 #endif
106
107 //#define USE_FIELD_ALIASES_CFLASH
108 //#define USE_FIELD_ALIASES_SIUL
109 //#define USE_FIELD_ALIASES_SSCM
110 //#define USE_FIELD_ALIASES_ME
111 //#define USE_FIELD_ALIASES_RGM
112 //#define USE_FIELD_ALIASES_ADC
113 //#define USE_FIELD_ALIASES_CTU
114 //#define USE_FIELD_ALIASES_mcTIMER
115 //#define USE_FIELD_ALIASES_mcPWM
116 //#define USE_FIELD_ALIASES_LINFLEX
117 //#define USE_FIELD_ALIASES_SPP_MCM
118 #define USE_FIELD_ALIASES_INTC
119 #define USE_FIELD_ALIASES_DSPI
120 //#define USE_FIELD_ALIASES_FLEXCAN
121 //#define USE_FIELD_ALIASES_FR
122 //#define USE_FIELD_ALIASES_CMU
123 //#define USE_FIELD_ALIASES_PLLD
124 //#define USE_FIELD_ALIASES_SPP_DMA2
125
126 /* Define memories */
127
128 #define SRAM_START 0x40000000
129 #define SRAM_SIZE 0x20000
130 #define SRAM_END 0x4001FFFF
131
132 #define FLASH_START 0x0
133 #define FLASH_SIZE 0xC0000
134 #define FLASH_END 0xBFFFF
135
136 /****************************************************************/
137 /* */
138 /* Global definitions and aliases */
139 /* */
140 /****************************************************************/
141
142 /*
143  Platform blocks that are only accessible by the second core (core 1) when
144  the device is in DPM mode. The block definition is equivalent to the one
145  for the first core (core 0) and reuses the related block structure.
146
147  NOTE: the <block_name>_1 defines are the preferred method for programming
148  */
149 #define PBRIDGE_1 (*(volatile PBRIDGE_tag*) 0x8FF00000UL)
150 #define MAX_1 (*(volatile MAX_tag*) 0x8FF04000UL)
151 #define MPU_1 (*(volatile MPU_tag*) 0x8FF10000UL)
152 #define SEMA4_1 (*(volatile SEMA4_tag*) 0x8FF24000UL)
153 #define SWT_1 (*(volatile SWT_tag*) 0x8FF38000UL)
154 #define STM_1 (*(volatile STM_tag*) 0x8FF3C000UL)
155 #define SPP_MCM_1 (*(volatile SPP_MCM_tag*) 0x8FF40000UL)
156 #define SPP_DMA2_1 (*(volatile SPP_DMA2_tag*) 0x8FF44000UL)
157 #define INTC_1 (*(volatile INTC_tag*) 0x8FF48000UL)
158
159 /*
160  Platform blocks that are only accessible by the second core (core 1) when
161  the device is in DPM mode. The block definition is equivalent to the one
162  for the first core (core 0) and reuses the related block structure.
163
164  NOTE: the <block_name>_DPM defines are deprecated, use <block_name>_1 for
165  programming the corresponding blocks for new code instead.
166  */
167 #define PBRIDGE_DPM PBRIDGE_1
168 #define MAX_DPM MAX_1
169 #define MPU_DPM MPU_1
170 #define SEMA4_DPM SEMA4_1
171 #define SWT_DPM SWT_1
172 #define STM_DPM STM_1
173 #define SPP_MCM_DPM SPP_MCM_1
174 #define SPP_DMA2_DPM SPP_DMA2_1
175 #define INTC_DPM INTC_1
176
177 /* Aliases for Pictus Module names */
178 #define CAN_0 FLEXCAN_A
179 #define CAN_1 FLEXCAN_B
180 #define CTU_0 CTU
181 #define DFLASH CRC
182 #define DMAMUX DMA_CH_MUX
183 #define DSPI_0 DSPI_A
184 #define DSPI_1 DSPI_B
185 #define DSPI_2 DSPI_C
186 #define EDMA (*(volatile struct EDMA_tag *) 0xFFF44000UL)
187 #define ETIMER_0 mcTIMER0
188 #define ETIMER_1 mcTIMER1
189 #define FLEXPWM_0 mcPWM_A
190 #define FLEXPWM_1 mcPWM_B
191 #define LINFLEX_0 LINFLEX0
192 #define LINFLEX_1 LINFLEX1
193 #define MCM_ SPP_MCM
194 #define PIT PIT_RTI
195 #define SIU SIUL
196 #define WKUP WKPU
197 #define ADC_0 ADC0
198 #define ADC_1 ADC1
199
200 /* Other Aliases */
201 #define AIPS_DPM PBRIDGE_1
202 #define AIPS_1 PBRIDGE_1
203 #define AIPS PBRIDGE
204
205 /****************************************************************/
206 /* */
207 /* Module: CFLASH_SHADOW */
208 /* */
209 /****************************************************************/
210
211
212  /* Register layout for all registers NVPWD... */
213
214  typedef union { /* NVPWD0-1 - Non Volatile Private Censorship PassWorD Register */
215  uint32_t R;
216  struct {
217  uint32_t PWD:32; /* PassWorD */
218  } B;
220
221
222  /* Register layout for all registers NVSCI... */
223
224  typedef union { /* NVSCI - Non Volatile System Censoring Information Register */
225  uint32_t R;
226  struct {
227  uint32_t SC:16; /* Serial Censorship Control Word */
228  uint32_t CW:16; /* Censorship Control Word */
229  } B;
231
232  typedef union { /* Non Volatile LML Default Value */
233  uint32_t R;
235
236  typedef union { /* Non Volatile HBL Default Value */
237  uint32_t R;
239
240  typedef union { /* Non Volatile SLL Default Value */
241  uint32_t R;
243
244
245  /* Register layout for all registers NVBIU... */
246
247  typedef union { /* Non Volatile Bus Interface Unit Register */
248  uint32_t R;
249  struct {
250  uint32_t BI:32; /* Bus interface Unit */
251  } B;
253
254  typedef union { /* NVUSRO - Non Volatile USeR Options Register */
255  uint32_t R;
256  struct {
257  uint32_t UO:32; /* User Options */
258  } B;
260
261
263
264  /* Non Volatile Bus Interface Unit Register */
265  CFLASH_SHADOW_NVBIU_32B_tag NVBIU; /* relative offset: 0x0000 */
266  int8_t CFLASH_SHADOW_BIU_DEFAULTS_reserved_0004[4];
267
269
270
271  typedef struct CFLASH_SHADOW_struct_tag { /* start of CFLASH_SHADOW_tag */
272  int8_t CFLASH_SHADOW_reserved_0000_C[15832];
273  union {
274  /* NVPWD0-1 - Non Volatile Private Censorship PassWorD Register */
275  CFLASH_SHADOW_NVPWD_32B_tag NVPWD[2]; /* offset: 0x3DD8 (0x0004 x 2) */
276
277  struct {
278  /* NVPWD0-1 - Non Volatile Private Censorship PassWorD Register */
279  CFLASH_SHADOW_NVPWD_32B_tag NVPWD0; /* offset: 0x3DD8 size: 32 bit */
280  CFLASH_SHADOW_NVPWD_32B_tag NVPWD1; /* offset: 0x3DDC size: 32 bit */
281  };
282
283  };
284  union {
285  /* NVSCI - Non Volatile System Censoring Information Register */
286  CFLASH_SHADOW_NVSCI_32B_tag NVSCI[2]; /* offset: 0x3DE0 (0x0004 x 2) */
287
288  struct {
289  /* NVSCI - Non Volatile System Censoring Information Register */
290  CFLASH_SHADOW_NVSCI_32B_tag NVSCI0; /* offset: 0x3DE0 size: 32 bit */
291  CFLASH_SHADOW_NVSCI_32B_tag NVSCI1; /* offset: 0x3DE4 size: 32 bit */
292  };
293
294  };
295  /* Non Volatile LML Default Value */
296  CFLASH_SHADOW_NVLML_32B_tag NVLML; /* offset: 0x3DE8 size: 32 bit */
297  int8_t CFLASH_SHADOW_reserved_3DEC[4];
298  /* Non Volatile HBL Default Value */
299  CFLASH_SHADOW_NVHBL_32B_tag NVHBL; /* offset: 0x3DF0 size: 32 bit */
300  int8_t CFLASH_SHADOW_reserved_3DF4[4];
301  /* Non Volatile SLL Default Value */
302  CFLASH_SHADOW_NVSLL_32B_tag NVSLL; /* offset: 0x3DF8 size: 32 bit */
303  int8_t CFLASH_SHADOW_reserved_3DFC_C[4];
304  union {
305  /* Register set BIU_DEFAULTS */
306  CFLASH_SHADOW_BIU_DEFAULTS_tag BIU_DEFAULTS[3]; /* offset: 0x3E00 (0x0008 x 3) */
307
308  struct {
309  /* Non Volatile Bus Interface Unit Register */
310  CFLASH_SHADOW_NVBIU_32B_tag NVBIU2; /* offset: 0x3E00 size: 32 bit */
311  int8_t CFLASH_SHADOW_reserved_3E04_I1[4];
312  CFLASH_SHADOW_NVBIU_32B_tag NVBIU3; /* offset: 0x3E08 size: 32 bit */
313  int8_t CFLASH_SHADOW_reserved_3E0C_I1[4];
314  CFLASH_SHADOW_NVBIU_32B_tag NVBIU4; /* offset: 0x3E10 size: 32 bit */
315  int8_t CFLASH_SHADOW_reserved_3E14_E1[4];
316  };
317
318  };
319  /* NVUSRO - Non Volatile USeR Options Register */
320  CFLASH_SHADOW_NVUSRO_32B_tag NVUSRO; /* offset: 0x3E18 size: 32 bit */
322
323
324 #define CFLASH_SHADOW (*(volatile CFLASH_SHADOW_tag *) 0x00F00000UL)
325
326
327
328 /****************************************************************/
329 /* */
330 /* Module: CFLASH */
331 /* */
332 /****************************************************************/
333
334  typedef union { /* MCR - Module Configuration Register */
335  uint32_t R;
336  struct {
337  uint32_t:5;
338  uint32_t SIZE:3; /* Array Space Size */
339  uint32_t:1;
340  uint32_t LAS:3; /* Low Address Space */
341  uint32_t:3;
342  uint32_t MAS:1; /* Mid Address Space Configuration */
343  uint32_t EER:1; /* ECC Event Error */
344  uint32_t RWE:1; /* Read-while-Write Event Error */
345  uint32_t SBC:1; /* Single Bit Correction */
346  uint32_t:1;
347  uint32_t PEAS:1; /* Program/Erase Access Space */
348  uint32_t DONE:1; /* modify operation DONE */
349  uint32_t PEG:1; /* Program/Erase Good */
350  uint32_t:4;
351  uint32_t PGM:1; /* Program Bit */
352  uint32_t PSUS:1; /* Program Suspend */
353  uint32_t ERS:1; /* Erase Bit */
354  uint32_t ESUS:1; /* Erase Suspend */
355  uint32_t EHV:1; /* Enable High Voltage */
356  } B;
358
359  typedef union { /* LML - Low/Mid Address Space Block Locking Register */
360  uint32_t R;
361  struct {
362  uint32_t LME:1; /* Low/Mid Address Space Block Enable */
363  uint32_t:10;
364 #ifndef USE_FIELD_ALIASES_CFLASH
365  uint32_t SLOCK:1; /* Shadow Address Space Block Lock */
366 #else
367  uint32_t TSLK:1; /* deprecated name - please avoid */
368 #endif
369  uint32_t:2;
370 #ifndef USE_FIELD_ALIASES_CFLASH
371  uint32_t MLOCK:2; /* Mid Address Space Block Lock */
372 #else
373  uint32_t MLK:2; /* deprecated name - please avoid */
374 #endif
375  uint32_t:6;
376  uint32_t LLOCK:10; /* Low Address Space Block Lock */
377  } B;
379
380  typedef union { /* HBL - High Address Space Block Locking Register */
381  uint32_t R;
382  struct {
383  uint32_t HBE:1; /* High Address Space Block Enable */
384  uint32_t:25;
385  uint32_t HLOCK:6; /* High Address Space Block Lock */
386  } B;
388
389  typedef union { /* SLL - Secondary Low/Mid Address Space Block Locking Register */
390  uint32_t R;
391  struct {
392  uint32_t SLE:1; /* Secondary Low/Mid Address Space Block Enable */
393  uint32_t:10;
394 #ifndef USE_FIELD_ALIASES_CFLASH
395  uint32_t SSLOCK:1; /* Secondary Shadow Address Space Block Lock */
396 #else
397  uint32_t STSLK:1; /* deprecated name - please avoid */
398 #endif
399  uint32_t:2;
400 #ifndef USE_FIELD_ALIASES_CFLASH
401  uint32_t SMLOCK:2; /* Secondary Mid Address Space Block Lock */
402 #else
403  uint32_t SMK:2; /* deprecated name - please avoid */
404 #endif
405  uint32_t:6;
406  uint32_t SLLOCK:10; /* Secondary Low Address Space Block Lock */
407  } B;
409
410  typedef union { /* LMS - Low/Mid Address Space Block Select Register */
411  uint32_t R;
412  struct {
413  uint32_t:14;
414  uint32_t MSL:2; /* Mid Address Space Block Select */
415  uint32_t:6;
416  uint32_t LSL:10; /* Low Address Space Block Select */
417  } B;
419
420  typedef union { /* HBS - High Address Space Block Select Register */
421  uint32_t R;
422  struct {
423  uint32_t:26;
424  uint32_t HSL:6; /* High Address Space Block Select */
425  } B;
427
428  typedef union { /* ADR - Address Register */
429  uint32_t R;
430  struct {
431  uint32_t SAD:1; /* Shadow Address */
432  uint32_t:10;
433  uint32_t ADDR:18; /* Address */
434  uint32_t:3;
435  } B;
437
438  typedef union { /* PFLASH2P_LCA_PFCR0 - Platform Flash Configuration Register 0 */
439  uint32_t R;
440  struct {
441 #ifndef USE_FIELD_ALIASES_CFLASH
442  uint32_t B02_APC:5; /* Bank0+2 Address Pipelining Control */
443 #else
444  uint32_t BK0_APC:5; /* deprecated name - please avoid */
445 #endif
446 #ifndef USE_FIELD_ALIASES_CFLASH
447  uint32_t B02_WWSC:5; /* Bank0+2 Write Wait State Control */
448 #else
449  uint32_t BK0_WWSC:5; /* deprecated name - please avoid */
450 #endif
451 #ifndef USE_FIELD_ALIASES_CFLASH
452  uint32_t B02_RWSC:5; /* Bank0+2 Read Wait State Control */
453 #else
454  uint32_t BK0_RWSC:5; /* deprecated name - please avoid */
455 #endif
456 #ifndef USE_FIELD_ALIASES_CFLASH
457  uint32_t B02_RWWC2:1; /* Bank 0+2 Read While Write Control, bit 2 */
458 #else
459  uint32_t BK0_RWWC2:1; /* deprecated name - please avoid */
460 #endif
461 #ifndef USE_FIELD_ALIASES_CFLASH
462  uint32_t B02_RWWC1:1; /* Bank 0+2 Read While Write Control, bit 1 */
463 #else
464  uint32_t BK0_RWWC1:1; /* deprecated name - please avoid */
465 #endif
466 #ifndef USE_FIELD_ALIASES_CFLASH
467  uint32_t B02_P1_BCFG:2; /* Bank0+2 Port 1 Page Buffer Configuration */
468 #else
469  uint32_t B0_P1_BCFG:2; /* deprecated name - please avoid */
470 #endif
471 #ifndef USE_FIELD_ALIASES_CFLASH
472  uint32_t B02_P1_DPFE:1; /* Bank0+2 Port 1 Data Prefetch Enable */
473 #else
474  uint32_t B0_P1_DPFE:1; /* deprecated name - please avoid */
475 #endif
476 #ifndef USE_FIELD_ALIASES_CFLASH
477  uint32_t B02_P1_IPFE:1; /* Bank0+2 Port 1 Inst Prefetch Enable */
478 #else
479  uint32_t B0_P1_IPFE:1; /* deprecated name - please avoid */
480 #endif
481 #ifndef USE_FIELD_ALIASES_CFLASH
482  uint32_t B02_P1_PFLM:2; /* Bank0+2 Port 1 Prefetch Limit */
483 #else
484  uint32_t B0_P1_PFLM:2; /* deprecated name - please avoid */
485 #endif
486 #ifndef USE_FIELD_ALIASES_CFLASH
487  uint32_t B02_P1_BFE:1; /* Bank0+2 Port 1 Buffer Enable */
488 #else
489  uint32_t B0_P1_BFE:1; /* deprecated name - please avoid */
490 #endif
491 #ifndef USE_FIELD_ALIASES_CFLASH
492  uint32_t B02_RWWC0:1; /* Bank 0+2 Read While Write Control, bit 0 */
493 #else
494  uint32_t BK0_RWWC0:1; /* deprecated name - please avoid */
495 #endif
496 #ifndef USE_FIELD_ALIASES_CFLASH
497  uint32_t B02_P0_BCFG:2; /* Bank0+2 Port 0 Page Buffer Configuration */
498 #else
499  uint32_t B0_P0_BCFG:2; /* deprecated name - please avoid */
500 #endif
501 #ifndef USE_FIELD_ALIASES_CFLASH
502  uint32_t B02_P0_DPFE:1; /* Bank0+2 Port 0 Data Prefetch Enable */
503 #else
504  uint32_t B0_P0_DPFE:1; /* deprecated name - please avoid */
505 #endif
506 #ifndef USE_FIELD_ALIASES_CFLASH
507  uint32_t B02_P0_IPFE:1; /* Bank0+2 Port 0 Inst Prefetch Enable */
508 #else
509  uint32_t B0_P0_IPFE:1; /* deprecated name - please avoid */
510 #endif
511 #ifndef USE_FIELD_ALIASES_CFLASH
512  uint32_t B02_P0_PFLM:2; /* Bank0+2 Port 0 Prefetch Limit */
513 #else
514  uint32_t B0_P0_PFLM:2; /* deprecated name - please avoid */
515 #endif
516 #ifndef USE_FIELD_ALIASES_CFLASH
517  uint32_t B02_P0_BFE:1; /* Bank0+2 Port 0 Buffer Enable */
518 #else
519  uint32_t B0_P0_BFE:1; /* deprecated name - please avoid */
520 #endif
521  } B;
523
524
525  /* Register layout for all registers BIU... */
526
527  typedef union { /* Bus Interface Unit Register */
528  uint32_t R;
530
531  typedef union { /* PFLASH2P_LCA_PFCR1 - Platform Flash Configuration Register 1 */
532  uint32_t R;
533  struct {
534 #ifndef USE_FIELD_ALIASES_CFLASH
535  uint32_t B1_APC:5; /* Bank 1 Address Pipelining Control */
536  uint32_t B1_WWSC:5; /* Bank 1 Write Wait State Control */
537  uint32_t B1_RWSC:5; /* Bank 1 Read Wait State Control */
538  uint32_t B1_RWWC2:1; /* Bank1 Read While Write Control, bit 2 */
539  uint32_t B1_RWWC1:1; /* Bank1 Read While Write Control, bit 1 */
540  uint32_t:6;
541  uint32_t B1_P1_BFE:1; /* Bank 1 Port 1 Buffer Enable */
542  uint32_t B1_RWWC0:1; /* Bank1 Read While Write Control, bit 0 */
543  uint32_t:6;
544  uint32_t B1_P0_BFE:1; /* Bank 1 Port 0 Buffer Enable */
545 #else
546  uint32_t BK1_APC:5;
547  uint32_t BK1_WWSC:5;
548  uint32_t BK1_RWSC:5;
549  uint32_t BK1_RWWC2:1;
550  uint32_t BK1_RWWC1:1;
551  uint32_t:6;
552  uint32_t B0_P1_BFE:1;
553  uint32_t BK1_RWWC0:1;
554  uint32_t:6;
555  uint32_t B1_P0_BFE:1;
556 #endif
557  } B;
559
560  typedef union { /* PFLASH2P_LCA_PFAPR - Platform Flash Access Protection Register */
561  uint32_t R;
562  struct {
563  uint32_t:6;
564  uint32_t ARBM:2; /* Arbitration Mode */
565  uint32_t M7PFD:1; /* Master x Prefetch Disable */
566  uint32_t M6PFD:1; /* Master x Prefetch Disable */
567  uint32_t M5PFD:1; /* Master x Prefetch Disable */
568  uint32_t M4PFD:1; /* Master x Prefetch Disable */
569  uint32_t M3PFD:1; /* Master x Prefetch Disable */
570  uint32_t M2PFD:1; /* Master x Prefetch Disable */
571  uint32_t M1PFD:1; /* Master x Prefetch Disable */
572  uint32_t M0PFD:1; /* Master x Prefetch Disable */
573  uint32_t M7AP:2; /* Master 7 Access Protection */
574  uint32_t M6AP:2; /* Master 6 Access Protection */
575  uint32_t M5AP:2; /* Master 5 Access Protection */
576  uint32_t M4AP:2; /* Master 4 Access Protection */
577  uint32_t M3AP:2; /* Master 3 Access Protection */
578  uint32_t M2AP:2; /* Master 2 Access Protection */
579  uint32_t M1AP:2; /* Master 1 Access Protection */
580  uint32_t M0AP:2; /* Master 0 Access Protection */
581  } B;
583
584  typedef union { /* UT0 - User Test Register */
585  uint32_t R;
586  struct {
587  uint32_t UTE:1; /* User Test Enable */
588  uint32_t SBCE:1; /* Single Bit Correction Enable */
589  uint32_t:6;
590  uint32_t DSI:8; /* Data Syndrome Input */
591  uint32_t:10;
592  uint32_t MRE:1; /* Margin Read Enable */
593  uint32_t MRV:1; /* Margin Read Value */
594  uint32_t EIE:1; /* ECC Data Input Enable */
595  uint32_t AIS:1; /* Array Integrity Sequence */
596  uint32_t AIE:1; /* Array Integrity Enable */
597  uint32_t AID:1; /* Array Integrity Done */
598  } B;
600
601  typedef union { /* UT1 - User Test Register */
602  uint32_t R;
604
605  typedef union { /* UT2 - User Test Register */
606  uint32_t R;
608
609
610  /* Register layout for all registers UM... */
611
612  typedef union { /* UM - User Multiple Input Signature Register */
613  uint32_t R;
614  struct {
615 #ifndef USE_FIELD_ALIASES_CFLASH
616  uint32_t MISR:32; /* Multiple Input Signature */
617 #else
618  uint32_t MS:32; /* deprecated - please avoid */
619 #endif
620  } B;
622
623
624  /* Register layout for generated register(s) UT... */
625
626  typedef union { /* */
627  uint32_t R;
629
630
631  /* Register layout for generated register(s) PFCR... */
632
633  typedef union { /* */
634  uint32_t R;
636
637
638
639  typedef struct CFLASH_struct_tag { /* start of CFLASH_tag */
640  /* MCR - Module Configuration Register */
641  CFLASH_MCR_32B_tag MCR; /* offset: 0x0000 size: 32 bit */
642  /* LML - Low/Mid Address Space Block Locking Register */
643  CFLASH_LML_32B_tag LML; /* offset: 0x0004 size: 32 bit */
644  /* HBL - High Address Space Block Locking Register */
645  CFLASH_HBL_32B_tag HBL; /* offset: 0x0008 size: 32 bit */
646  /* SLL - Secondary Low/Mid Address Space Block Locking Register */
647  CFLASH_SLL_32B_tag SLL; /* offset: 0x000C size: 32 bit */
648  /* LMS - Low/Mid Address Space Block Select Register */
649  CFLASH_LMS_32B_tag LMS; /* offset: 0x0010 size: 32 bit */
650  /* HBS - High Address Space Block Select Register */
651  CFLASH_HBS_32B_tag HBS; /* offset: 0x0014 size: 32 bit */
652  /* ADR - Address Register */
653  CFLASH_ADR_32B_tag ADR; /* offset: 0x0018 size: 32 bit */
654  union {
655  struct {
656  /* */
657  CFLASH_PFCR_32B_tag PFCR[2]; /* offset: 0x001C (0x0004 x 2) */
658  int8_t CFLASH_reserved_0024_E0[12];
659  };
660
661  /* Bus Interface Unit Register */
662  CFLASH_BIU_32B_tag BIU[5]; /* offset: 0x001C (0x0004 x 5) */
663
664  struct {
665  /* Bus Interface Unit Register */
666  CFLASH_BIU_32B_tag BIU0; /* offset: 0x001C size: 32 bit */
667  CFLASH_BIU_32B_tag BIU1; /* offset: 0x0020 size: 32 bit */
668  CFLASH_BIU_32B_tag BIU2; /* offset: 0x0024 size: 32 bit */
669  CFLASH_BIU_32B_tag BIU3; /* offset: 0x0028 size: 32 bit */
670  CFLASH_BIU_32B_tag BIU4; /* offset: 0x002C size: 32 bit */
671  };
672
673  struct {
674  int8_t CFLASH_reserved_001C_I3[8];
675  CFLASH_PFAPR_32B_tag FAPR; /* deprecated - please avoid */
676  int8_t CFLASH_reserved_0028_E3[8];
677  };
678
679  struct {
680  /* PFLASH2P_LCA_PFCR0 - Platform Flash Configuration Register 0 */
681  CFLASH_PFCR0_32B_tag PFCR0; /* offset: 0x001C size: 32 bit */
682  /* PFLASH2P_LCA_PFCR1 - Platform Flash Configuration Register 1 */
683  CFLASH_PFCR1_32B_tag PFCR1; /* offset: 0x0020 size: 32 bit */
684  /* PFLASH2P_LCA_PFAPR - Platform Flash Access Protection Register */
685  CFLASH_PFAPR_32B_tag PFAPR; /* offset: 0x0024 size: 32 bit */
686  int8_t CFLASH_reserved_0028_E4[8];
687  };
688
689  };
690  int8_t CFLASH_reserved_0030_C[12];
691  union {
692  CFLASH_UT_32B_tag UT[3]; /* offset: 0x003C (0x0004 x 3) */
693
694  struct {
695  /* UT0 - User Test Register */
696  CFLASH_UT0_32B_tag UT0; /* offset: 0x003C size: 32 bit */
697  /* UT1 - User Test Register */
698  CFLASH_UT1_32B_tag UT1; /* offset: 0x0040 size: 32 bit */
699  /* UT2 - User Test Register */
700  CFLASH_UT2_32B_tag UT2; /* offset: 0x0044 size: 32 bit */
701  };
702
703  };
704  union {
705  CFLASH_UM_32B_tag UMISR[5]; /* offset: 0x0048 (0x0004 x 5) */
706
707  /* UM - User Multiple Input Signature Register */
708  CFLASH_UM_32B_tag UM[5]; /* offset: 0x0048 (0x0004 x 5) */
709
710  struct {
711  /* UM - User Multiple Input Signature Register */
712  CFLASH_UM_32B_tag UM0; /* offset: 0x0048 size: 32 bit */
713  CFLASH_UM_32B_tag UM1; /* offset: 0x004C size: 32 bit */
714  CFLASH_UM_32B_tag UM2; /* offset: 0x0050 size: 32 bit */
715  CFLASH_UM_32B_tag UM3; /* offset: 0x0054 size: 32 bit */
716  CFLASH_UM_32B_tag UM4; /* offset: 0x0058 size: 32 bit */
717  };
718
719  };
720  } CFLASH_tag;
721
722
723 #define CFLASH (*(volatile CFLASH_tag *) 0xC3F88000UL)
724
725
726
727 /****************************************************************/
728 /* */
729 /* Module: SIUL */
730 /* */
731 /****************************************************************/
732
733  typedef union { /* MIDR1 - MCU ID Register #1 */
734  uint32_t R;
735  struct {
736  uint32_t PARTNUM:16; /* MCU Part Number */
737  uint32_t CSP:1; /* CSP Package */
738  uint32_t PKG:5; /* Package Settings */
739  uint32_t:2;
740 #ifndef USE_FIELD_ALIASES_SIUL
741  uint32_t MAJOR_MASK:4; /* Major Mask Revision */
742 #else
743  uint32_t MAJORMASK:4; /* deprecated name - please avoid */
744 #endif
745 #ifndef USE_FIELD_ALIASES_SIUL
746  uint32_t MINOR_MASK:4; /* Minor Mask Revision */
747 #else
748  uint32_t MINORMASK:4; /* deprecated name - please avoid */
749 #endif
750  } B;
752
753  typedef union { /* MIDR2 - MCU ID Register #2 */
754  uint32_t R;
755  struct {
756  uint32_t SF:1; /* Manufacturer */
757  uint32_t FLASH_SIZE_1:4; /* Coarse Flash Memory Size */
758  uint32_t FLASH_SIZE_2:4; /* Fine Flash Memory Size */
759  uint32_t:7;
760 #ifndef USE_FIELD_ALIASES_SIUL
761  uint32_t PARTNUM2:8; /* MCU Part Number */
762 #else
763  uint32_t PARTNUM:8; /* deprecated name - please avoid */
764 #endif
765  uint32_t TBD:1; /* Optional Bit */
766  uint32_t:2;
767  uint32_t EE:1; /* Data Flash Present */
768  uint32_t:3;
769  uint32_t FR:1; /* Flexray Present */
770  } B;
772
773  typedef union { /* ISR - Interrupt Status Flag Register */
774  uint32_t R;
775  struct {
776  uint32_t EIF31:1; /* External Interrupt Status Flag */
777  uint32_t EIF30:1; /* External Interrupt Status Flag */
778  uint32_t EIF29:1; /* External Interrupt Status Flag */
779  uint32_t EIF28:1; /* External Interrupt Status Flag */
780  uint32_t EIF27:1; /* External Interrupt Status Flag */
781  uint32_t EIF26:1; /* External Interrupt Status Flag */
782  uint32_t EIF25:1; /* External Interrupt Status Flag */
783  uint32_t EIF24:1; /* External Interrupt Status Flag */
784  uint32_t EIF23:1; /* External Interrupt Status Flag */
785  uint32_t EIF22:1; /* External Interrupt Status Flag */
786  uint32_t EIF21:1; /* External Interrupt Status Flag */
787  uint32_t EIF20:1; /* External Interrupt Status Flag */
788  uint32_t EIF19:1; /* External Interrupt Status Flag */
789  uint32_t EIF18:1; /* External Interrupt Status Flag */
790  uint32_t EIF17:1; /* External Interrupt Status Flag */
791  uint32_t EIF16:1; /* External Interrupt Status Flag */
792  uint32_t EIF15:1; /* External Interrupt Status Flag */
793  uint32_t EIF14:1; /* External Interrupt Status Flag */
794  uint32_t EIF13:1; /* External Interrupt Status Flag */
795  uint32_t EIF12:1; /* External Interrupt Status Flag */
796  uint32_t EIF11:1; /* External Interrupt Status Flag */
797  uint32_t EIF10:1; /* External Interrupt Status Flag */
798  uint32_t EIF9:1; /* External Interrupt Status Flag */
799  uint32_t EIF8:1; /* External Interrupt Status Flag */
800  uint32_t EIF7:1; /* External Interrupt Status Flag */
801  uint32_t EIF6:1; /* External Interrupt Status Flag */
802  uint32_t EIF5:1; /* External Interrupt Status Flag */
803  uint32_t EIF4:1; /* External Interrupt Status Flag */
804  uint32_t EIF3:1; /* External Interrupt Status Flag */
805  uint32_t EIF2:1; /* External Interrupt Status Flag */
806  uint32_t EIF1:1; /* External Interrupt Status Flag */
807  uint32_t EIF0:1; /* External Interrupt Status Flag */
808  } B;
810
811  typedef union { /* IRER - Interrupt Request Enable Register */
812  uint32_t R;
813  struct {
814  uint32_t EIRE31:1; /* Enable External Interrupt Requests */
815  uint32_t EIRE30:1; /* Enable External Interrupt Requests */
816  uint32_t EIRE29:1; /* Enable External Interrupt Requests */
817  uint32_t EIRE28:1; /* Enable External Interrupt Requests */
818  uint32_t EIRE27:1; /* Enable External Interrupt Requests */
819  uint32_t EIRE26:1; /* Enable External Interrupt Requests */
820  uint32_t EIRE25:1; /* Enable External Interrupt Requests */
821  uint32_t EIRE24:1; /* Enable External Interrupt Requests */
822  uint32_t EIRE23:1; /* Enable External Interrupt Requests */
823  uint32_t EIRE22:1; /* Enable External Interrupt Requests */
824  uint32_t EIRE21:1; /* Enable External Interrupt Requests */
825  uint32_t EIRE20:1; /* Enable External Interrupt Requests */
826  uint32_t EIRE19:1; /* Enable External Interrupt Requests */
827  uint32_t EIRE18:1; /* Enable External Interrupt Requests */
828  uint32_t EIRE17:1; /* Enable External Interrupt Requests */
829  uint32_t EIRE16:1; /* Enable External Interrupt Requests */
830  uint32_t EIRE15:1; /* Enable External Interrupt Requests */
831  uint32_t EIRE14:1; /* Enable External Interrupt Requests */
832  uint32_t EIRE13:1; /* Enable External Interrupt Requests */
833  uint32_t EIRE12:1; /* Enable External Interrupt Requests */
834  uint32_t EIRE11:1; /* Enable External Interrupt Requests */
835  uint32_t EIRE10:1; /* Enable External Interrupt Requests */
836  uint32_t EIRE9:1; /* Enable External Interrupt Requests */
837  uint32_t EIRE8:1; /* Enable External Interrupt Requests */
838  uint32_t EIRE7:1; /* Enable External Interrupt Requests */
839  uint32_t EIRE6:1; /* Enable External Interrupt Requests */
840  uint32_t EIRE5:1; /* Enable External Interrupt Requests */
841  uint32_t EIRE4:1; /* Enable External Interrupt Requests */
842  uint32_t EIRE3:1; /* Enable External Interrupt Requests */
843  uint32_t EIRE2:1; /* Enable External Interrupt Requests */
844  uint32_t EIRE1:1; /* Enable External Interrupt Requests */
845  uint32_t EIRE0:1; /* Enable External Interrupt Requests */
846  } B;
848
849  typedef union { /* IREER - Interrupt Rising Edge Event Enable */
850  uint32_t R;
851  struct {
852  uint32_t IREE31:1; /* Enable rising-edge events */
853  uint32_t IREE30:1; /* Enable rising-edge events */
854  uint32_t IREE29:1; /* Enable rising-edge events */
855  uint32_t IREE28:1; /* Enable rising-edge events */
856  uint32_t IREE27:1; /* Enable rising-edge events */
857  uint32_t IREE26:1; /* Enable rising-edge events */
858  uint32_t IREE25:1; /* Enable rising-edge events */
859  uint32_t IREE24:1; /* Enable rising-edge events */
860  uint32_t IREE23:1; /* Enable rising-edge events */
861  uint32_t IREE22:1; /* Enable rising-edge events */
862  uint32_t IREE21:1; /* Enable rising-edge events */
863  uint32_t IREE20:1; /* Enable rising-edge events */
864  uint32_t IREE19:1; /* Enable rising-edge events */
865  uint32_t IREE18:1; /* Enable rising-edge events */
866  uint32_t IREE17:1; /* Enable rising-edge events */
867  uint32_t IREE16:1; /* Enable rising-edge events */
868  uint32_t IREE15:1; /* Enable rising-edge events */
869  uint32_t IREE14:1; /* Enable rising-edge events */
870  uint32_t IREE13:1; /* Enable rising-edge events */
871  uint32_t IREE12:1; /* Enable rising-edge events */
872  uint32_t IREE11:1; /* Enable rising-edge events */
873  uint32_t IREE10:1; /* Enable rising-edge events */
874  uint32_t IREE9:1; /* Enable rising-edge events */
875  uint32_t IREE8:1; /* Enable rising-edge events */
876  uint32_t IREE7:1; /* Enable rising-edge events */
877  uint32_t IREE6:1; /* Enable rising-edge events */
878  uint32_t IREE5:1; /* Enable rising-edge events */
879  uint32_t IREE4:1; /* Enable rising-edge events */
880  uint32_t IREE3:1; /* Enable rising-edge events */
881  uint32_t IREE2:1; /* Enable rising-edge events */
882  uint32_t IREE1:1; /* Enable rising-edge events */
883  uint32_t IREE0:1; /* Enable rising-edge events */
884  } B;
886
887  typedef union { /* IFEER - Interrupt Falling-Edge Event Enable */
888  uint32_t R;
889  struct {
890  uint32_t IFEE31:1; /* Enable Falling Edge Events */
891  uint32_t IFEE30:1; /* Enable Falling Edge Events */
892  uint32_t IFEE29:1; /* Enable Falling Edge Events */
893  uint32_t IFEE28:1; /* Enable Falling Edge Events */
894  uint32_t IFEE27:1; /* Enable Falling Edge Events */
895  uint32_t IFEE26:1; /* Enable Falling Edge Events */
896  uint32_t IFEE25:1; /* Enable Falling Edge Events */
897  uint32_t IFEE24:1; /* Enable Falling Edge Events */
898  uint32_t IFEE23:1; /* Enable Falling Edge Events */
899  uint32_t IFEE22:1; /* Enable Falling Edge Events */
900  uint32_t IFEE21:1; /* Enable Falling Edge Events */
901  uint32_t IFEE20:1; /* Enable Falling Edge Events */
902  uint32_t IFEE19:1; /* Enable Falling Edge Events */
903  uint32_t IFEE18:1; /* Enable Falling Edge Events */
904  uint32_t IFEE17:1; /* Enable Falling Edge Events */
905  uint32_t IFEE16:1; /* Enable Falling Edge Events */
906  uint32_t IFEE15:1; /* Enable Falling Edge Events */
907  uint32_t IFEE14:1; /* Enable Falling Edge Events */
908  uint32_t IFEE13:1; /* Enable Falling Edge Events */
909  uint32_t IFEE12:1; /* Enable Falling Edge Events */
910  uint32_t IFEE11:1; /* Enable Falling Edge Events */
911  uint32_t IFEE10:1; /* Enable Falling Edge Events */
912  uint32_t IFEE9:1; /* Enable Falling Edge Events */
913  uint32_t IFEE8:1; /* Enable Falling Edge Events */
914  uint32_t IFEE7:1; /* Enable Falling Edge Events */
915  uint32_t IFEE6:1; /* Enable Falling Edge Events */
916  uint32_t IFEE5:1; /* Enable Falling Edge Events */
917  uint32_t IFEE4:1; /* Enable Falling Edge Events */
918  uint32_t IFEE3:1; /* Enable Falling Edge Events */
919  uint32_t IFEE2:1; /* Enable Falling Edge Events */
920  uint32_t IFEE1:1; /* Enable Falling Edge Events */
921  uint32_t IFEE0:1; /* Enable Falling Edge Events */
922  } B;
924
925  typedef union { /* IFER Interrupt Filter Enable Register */
926  uint32_t R;
927  struct {
928  uint32_t IFE31:1; /* Enable Digital Glitch Filter */
929  uint32_t IFE30:1; /* Enable Digital Glitch Filter */
930  uint32_t IFE29:1; /* Enable Digital Glitch Filter */
931  uint32_t IFE28:1; /* Enable Digital Glitch Filter */
932  uint32_t IFE27:1; /* Enable Digital Glitch Filter */
933  uint32_t IFE26:1; /* Enable Digital Glitch Filter */
934  uint32_t IFE25:1; /* Enable Digital Glitch Filter */
935  uint32_t IFE24:1; /* Enable Digital Glitch Filter */
936  uint32_t IFE23:1; /* Enable Digital Glitch Filter */
937  uint32_t IFE22:1; /* Enable Digital Glitch Filter */
938  uint32_t IFE21:1; /* Enable Digital Glitch Filter */
939  uint32_t IFE20:1; /* Enable Digital Glitch Filter */
940  uint32_t IFE19:1; /* Enable Digital Glitch Filter */
941  uint32_t IFE18:1; /* Enable Digital Glitch Filter */
942  uint32_t IFE17:1; /* Enable Digital Glitch Filter */
943  uint32_t IFE16:1; /* Enable Digital Glitch Filter */
944  uint32_t IFE15:1; /* Enable Digital Glitch Filter */
945  uint32_t IFE14:1; /* Enable Digital Glitch Filter */
946  uint32_t IFE13:1; /* Enable Digital Glitch Filter */
947  uint32_t IFE12:1; /* Enable Digital Glitch Filter */
948  uint32_t IFE11:1; /* Enable Digital Glitch Filter */
949  uint32_t IFE10:1; /* Enable Digital Glitch Filter */
950  uint32_t IFE9:1; /* Enable Digital Glitch Filter */
951  uint32_t IFE8:1; /* Enable Digital Glitch Filter */
952  uint32_t IFE7:1; /* Enable Digital Glitch Filter */
953  uint32_t IFE6:1; /* Enable Digital Glitch Filter */
954  uint32_t IFE5:1; /* Enable Digital Glitch Filter */
955  uint32_t IFE4:1; /* Enable Digital Glitch Filter */
956  uint32_t IFE3:1; /* Enable Digital Glitch Filter */
957  uint32_t IFE2:1; /* Enable Digital Glitch Filter */
958  uint32_t IFE1:1; /* Enable Digital Glitch Filter */
959  uint32_t IFE0:1; /* Enable Digital Glitch Filter */
960  } B;
962
963
964  /* Register layout for all registers PCR... */
965
966  typedef union SIU_PCR_tag { /* PCR - Pad Configuration Register */
967  uint16_t R;
968  struct {
969  uint16_t:1;
970 #ifndef USE_FIELD_ALIASES_SIUL
971  uint16_t SMC:1; /* Safe Mode Control */
972 #else
973  uint16_t SME:1; /* deprecated name - please avoid */
974 #endif
975  uint16_t APC:1; /* Analog Pad Control */
976  uint16_t:1;
977  uint16_t PA:2; /* Pad Output Assignment */
978  uint16_t OBE:1; /* Output Buffer Enable */
979  uint16_t IBE:1; /* Input Buffer Enable */
980 #ifndef USE_FIELD_ALIASES_SIUL
981  uint16_t DSC:2; /* Drive Strength Control */
982 #else
983  uint16_t DCS:2; /* deprecated name - please avoid */
984 #endif
985  uint16_t ODE:1; /* Open Drain Output Enable */
986  uint16_t HYS:1; /* Input Hysteresis */
987  uint16_t SRC:2; /* Slew Rate Control */
988  uint16_t WPE:1; /* Weak Pull Up/Down Enable */
989  uint16_t WPS:1; /* Weak Pull Up/Down Select */
990  } B;
991  } SIU_PCR_tag;
992
993
994  /* Register layout for all registers PSMI... */
995
996  typedef union SIUL_PSMI_8B_tag { /* PSMI - Pad Selection for Multiplexed Inputs */
997  uint8_t R;
998  struct {
999  uint8_t:4;
1000  uint8_t PADSEL:4; /* Pad selection for pin */
1001  } B;
1002  } SIUL_PSMI_8B_tag;
1003
1004
1005  /* Register layout for all registers PSMI... */
1006
1007  typedef union { /* PSMI - Pad Selection for Multiplexed Inputs */
1008  uint32_t R;
1009  struct {
1010  uint32_t:4;
1011  uint32_t PADSEL0:4; /* Pad selection for pin */
1012  uint32_t:4;
1013  uint32_t PADSEL1:4; /* Pad selection for pin */
1014  uint32_t:4;
1015  uint32_t PADSEL2:4; /* Pad selection for pin */
1016  uint32_t:4;
1017  uint32_t PADSEL3:4; /* Pad selection for pin */
1018  } B;
1020
1021
1022  /* Register layout for all registers GPDO... */
1023
1024  typedef union { /* GPDO - GPIO Pad Data Output Register */
1025  uint8_t R;
1026  struct {
1027  uint8_t:7;
1028  uint8_t PDO:1; /* Pad Data Out */
1029  } B;
1030  } SIUL_GPDO_8B_tag;
1031
1032
1033  /* Register layout for all registers GPDO... */
1034
1035  typedef union { /* GPDO - GPIO Pad Data Output Register */
1036  uint32_t R;
1037  struct {
1038  uint32_t:7;
1039  uint32_t PDO0:1; /* Pad Data Out */
1040  uint32_t:7;
1041  uint32_t PDO1:1; /* Pad Data Out */
1042  uint32_t:7;
1043  uint32_t PDO2:1; /* Pad Data Out */
1044  uint32_t:7;
1045  uint32_t PDO3:1; /* Pad Data Out */
1046  } B;
1048
1049
1050  /* Register layout for all registers GPDI... */
1051
1052  typedef union { /* GPDI - GPIO Pad Data Input Register */
1053  uint8_t R;
1054  struct {
1055  uint8_t:7;
1056  uint8_t PDI:1; /* Pad Data In */
1057  } B;
1058  } SIUL_GPDI_8B_tag;
1059
1060
1061  /* Register layout for all registers GPDI... */
1062
1063  typedef union { /* GPDI - GPIO Pad Data Input Register */
1064  uint32_t R;
1065  struct {
1066  uint32_t:7;
1067  uint32_t PDI0:1; /* Pad Data In */
1068  uint32_t:7;
1069  uint32_t PDI1:1; /* Pad Data In */
1070  uint32_t:7;
1071  uint32_t PDI2:1; /* Pad Data In */
1072  uint32_t:7;
1073  uint32_t PDI3:1; /* Pad Data In */
1074  } B;
1076
1077
1078  /* Register layout for all registers PGPDO... */
1079
1080  typedef union { /* PGPDO - Parallel GPIO Pad Data Out Register */
1081  uint16_t R;
1083
1084
1085  /* Register layout for all registers PGPDI... */
1086
1087  typedef union { /* PGPDI - Parallel GPIO Pad Data In Register */
1088  uint16_t R;
1090
1091
1092  /* Register layout for all registers MPGPDO... */
1093
1094  typedef union { /* MPGPDO - Masked Parallel GPIO Pad Data Out Register */
1095  uint32_t R;
1096  struct {
1097  uint32_t MASK:16; /* Mask Field */
1098  uint32_t MPPDO:16; /* Masked Parallel Pad Data Out */
1099  } B;
1101
1102
1103  /* Register layout for all registers IFMC... */
1104
1105  typedef union { /* IFMC - Interrupt Filter Maximum Counter Register */
1106  uint32_t R;
1107  struct {
1108  uint32_t:28;
1109  uint32_t MAXCNT:4; /* Maximum Interrupt Filter Counter Setting */
1110  } B;
1112
1113  typedef union { /* IFCPR - Inerrupt Filter Clock Prescaler Register */
1114  uint32_t R;
1115  struct {
1116  uint32_t:28;
1117  uint32_t IFCP:4; /* Interrupt Filter Clock Prescaler Setting */
1118  } B;
1120
1121
1122
1123  typedef struct SIU_tag { /* start of SIUL_tag */
1124  int8_t SIUL_reserved_0000_C[4];
1125  union {
1126  SIUL_MIDR1_32B_tag MIDR; /* deprecated - please avoid */
1127
1128  /* MIDR1 - MCU ID Register #1 */
1129  SIUL_MIDR1_32B_tag MIDR1; /* offset: 0x0004 size: 32 bit */
1130
1131  };
1132  /* MIDR2 - MCU ID Register #2 */
1133  SIUL_MIDR2_32B_tag MIDR2; /* offset: 0x0008 size: 32 bit */
1134  int8_t SIUL_reserved_000C[8];
1135  /* ISR - Interrupt Status Flag Register */
1136  SIUL_ISR_32B_tag ISR; /* offset: 0x0014 size: 32 bit */
1137  /* IRER - Interrupt Request Enable Register */
1138  SIUL_IRER_32B_tag IRER; /* offset: 0x0018 size: 32 bit */
1139  int8_t SIUL_reserved_001C[12];
1140  /* IREER - Interrupt Rising Edge Event Enable */
1141  SIUL_IREER_32B_tag IREER; /* offset: 0x0028 size: 32 bit */
1142  /* IFEER - Interrupt Falling-Edge Event Enable */
1143  SIUL_IFEER_32B_tag IFEER; /* offset: 0x002C size: 32 bit */
1144  /* IFER Interrupt Filter Enable Register */
1145  SIUL_IFER_32B_tag IFER; /* offset: 0x0030 size: 32 bit */
1146  int8_t SIUL_reserved_0034_C[12];
1147  union {
1148  /* PCR - Pad Configuration Register */
1149  SIU_PCR_tag PCR[512]; /* offset: 0x0040 (0x0002 x 512) */
1150
1151  struct {
1152  /* PCR - Pad Configuration Register */
1153  SIU_PCR_tag PCR0; /* offset: 0x0040 size: 16 bit */
1154  SIU_PCR_tag PCR1; /* offset: 0x0042 size: 16 bit */
1155  SIU_PCR_tag PCR2; /* offset: 0x0044 size: 16 bit */
1156  SIU_PCR_tag PCR3; /* offset: 0x0046 size: 16 bit */
1157  SIU_PCR_tag PCR4; /* offset: 0x0048 size: 16 bit */
1158  SIU_PCR_tag PCR5; /* offset: 0x004A size: 16 bit */
1159  SIU_PCR_tag PCR6; /* offset: 0x004C size: 16 bit */
1160  SIU_PCR_tag PCR7; /* offset: 0x004E size: 16 bit */
1161  SIU_PCR_tag PCR8; /* offset: 0x0050 size: 16 bit */
1162  SIU_PCR_tag PCR9; /* offset: 0x0052 size: 16 bit */
1163  SIU_PCR_tag PCR10; /* offset: 0x0054 size: 16 bit */
1164  SIU_PCR_tag PCR11; /* offset: 0x0056 size: 16 bit */
1165  SIU_PCR_tag PCR12; /* offset: 0x0058 size: 16 bit */
1166  SIU_PCR_tag PCR13; /* offset: 0x005A size: 16 bit */
1167  SIU_PCR_tag PCR14; /* offset: 0x005C size: 16 bit */
1168  SIU_PCR_tag PCR15; /* offset: 0x005E size: 16 bit */
1169  SIU_PCR_tag PCR16; /* offset: 0x0060 size: 16 bit */
1170  SIU_PCR_tag PCR17; /* offset: 0x0062 size: 16 bit */
1171  SIU_PCR_tag PCR18; /* offset: 0x0064 size: 16 bit */
1172  SIU_PCR_tag PCR19; /* offset: 0x0066 size: 16 bit */
1173  SIU_PCR_tag PCR20; /* offset: 0x0068 size: 16 bit */
1174  SIU_PCR_tag PCR21; /* offset: 0x006A size: 16 bit */
1175  SIU_PCR_tag PCR22; /* offset: 0x006C size: 16 bit */
1176  SIU_PCR_tag PCR23; /* offset: 0x006E size: 16 bit */
1177  SIU_PCR_tag PCR24; /* offset: 0x0070 size: 16 bit */
1178  SIU_PCR_tag PCR25; /* offset: 0x0072 size: 16 bit */
1179  SIU_PCR_tag PCR26; /* offset: 0x0074 size: 16 bit */
1180  SIU_PCR_tag PCR27; /* offset: 0x0076 size: 16 bit */
1181  SIU_PCR_tag PCR28; /* offset: 0x0078 size: 16 bit */
1182  SIU_PCR_tag PCR29; /* offset: 0x007A size: 16 bit */
1183  SIU_PCR_tag PCR30; /* offset: 0x007C size: 16 bit */
1184  SIU_PCR_tag PCR31; /* offset: 0x007E size: 16 bit */
1185  SIU_PCR_tag PCR32; /* offset: 0x0080 size: 16 bit */
1186  SIU_PCR_tag PCR33; /* offset: 0x0082 size: 16 bit */
1187  SIU_PCR_tag PCR34; /* offset: 0x0084 size: 16 bit */
1188  SIU_PCR_tag PCR35; /* offset: 0x0086 size: 16 bit */
1189  SIU_PCR_tag PCR36; /* offset: 0x0088 size: 16 bit */
1190  SIU_PCR_tag PCR37; /* offset: 0x008A size: 16 bit */
1191  SIU_PCR_tag PCR38; /* offset: 0x008C size: 16 bit */
1192  SIU_PCR_tag PCR39; /* offset: 0x008E size: 16 bit */
1193  SIU_PCR_tag PCR40; /* offset: 0x0090 size: 16 bit */
1194  SIU_PCR_tag PCR41; /* offset: 0x0092 size: 16 bit */
1195  SIU_PCR_tag PCR42; /* offset: 0x0094 size: 16 bit */
1196  SIU_PCR_tag PCR43; /* offset: 0x0096 size: 16 bit */
1197  SIU_PCR_tag PCR44; /* offset: 0x0098 size: 16 bit */
1198  SIU_PCR_tag PCR45; /* offset: 0x009A size: 16 bit */
1199  SIU_PCR_tag PCR46; /* offset: 0x009C size: 16 bit */
1200  SIU_PCR_tag PCR47; /* offset: 0x009E size: 16 bit */
1201  SIU_PCR_tag PCR48; /* offset: 0x00A0 size: 16 bit */
1202  SIU_PCR_tag PCR49; /* offset: 0x00A2 size: 16 bit */
1203  SIU_PCR_tag PCR50; /* offset: 0x00A4 size: 16 bit */
1204  SIU_PCR_tag PCR51; /* offset: 0x00A6 size: 16 bit */
1205  SIU_PCR_tag PCR52; /* offset: 0x00A8 size: 16 bit */
1206  SIU_PCR_tag PCR53; /* offset: 0x00AA size: 16 bit */
1207  SIU_PCR_tag PCR54; /* offset: 0x00AC size: 16 bit */
1208  SIU_PCR_tag PCR55; /* offset: 0x00AE size: 16 bit */
1209  SIU_PCR_tag PCR56; /* offset: 0x00B0 size: 16 bit */
1210  SIU_PCR_tag PCR57; /* offset: 0x00B2 size: 16 bit */
1211  SIU_PCR_tag PCR58; /* offset: 0x00B4 size: 16 bit */
1212  SIU_PCR_tag PCR59; /* offset: 0x00B6 size: 16 bit */
1213  SIU_PCR_tag PCR60; /* offset: 0x00B8 size: 16 bit */
1214  SIU_PCR_tag PCR61; /* offset: 0x00BA size: 16 bit */
1215  SIU_PCR_tag PCR62; /* offset: 0x00BC size: 16 bit */
1216  SIU_PCR_tag PCR63; /* offset: 0x00BE size: 16 bit */
1217  SIU_PCR_tag PCR64; /* offset: 0x00C0 size: 16 bit */
1218  SIU_PCR_tag PCR65; /* offset: 0x00C2 size: 16 bit */
1219  SIU_PCR_tag PCR66; /* offset: 0x00C4 size: 16 bit */
1220  SIU_PCR_tag PCR67; /* offset: 0x00C6 size: 16 bit */
1221  SIU_PCR_tag PCR68; /* offset: 0x00C8 size: 16 bit */
1222  SIU_PCR_tag PCR69; /* offset: 0x00CA size: 16 bit */
1223  SIU_PCR_tag PCR70; /* offset: 0x00CC size: 16 bit */
1224  SIU_PCR_tag PCR71; /* offset: 0x00CE size: 16 bit */
1225  SIU_PCR_tag PCR72; /* offset: 0x00D0 size: 16 bit */
1226  SIU_PCR_tag PCR73; /* offset: 0x00D2 size: 16 bit */
1227  SIU_PCR_tag PCR74; /* offset: 0x00D4 size: 16 bit */
1228  SIU_PCR_tag PCR75; /* offset: 0x00D6 size: 16 bit */
1229  SIU_PCR_tag PCR76; /* offset: 0x00D8 size: 16 bit */
1230  SIU_PCR_tag PCR77; /* offset: 0x00DA size: 16 bit */
1231  SIU_PCR_tag PCR78; /* offset: 0x00DC size: 16 bit */
1232  SIU_PCR_tag PCR79; /* offset: 0x00DE size: 16 bit */
1233  SIU_PCR_tag PCR80; /* offset: 0x00E0 size: 16 bit */
1234  SIU_PCR_tag PCR81; /* offset: 0x00E2 size: 16 bit */
1235  SIU_PCR_tag PCR82; /* offset: 0x00E4 size: 16 bit */
1236  SIU_PCR_tag PCR83; /* offset: 0x00E6 size: 16 bit */
1237  SIU_PCR_tag PCR84; /* offset: 0x00E8 size: 16 bit */
1238  SIU_PCR_tag PCR85; /* offset: 0x00EA size: 16 bit */
1239  SIU_PCR_tag PCR86; /* offset: 0x00EC size: 16 bit */
1240  SIU_PCR_tag PCR87; /* offset: 0x00EE size: 16 bit */
1241  SIU_PCR_tag PCR88; /* offset: 0x00F0 size: 16 bit */
1242  SIU_PCR_tag PCR89; /* offset: 0x00F2 size: 16 bit */
1243  SIU_PCR_tag PCR90; /* offset: 0x00F4 size: 16 bit */
1244  SIU_PCR_tag PCR91; /* offset: 0x00F6 size: 16 bit */
1245  SIU_PCR_tag PCR92; /* offset: 0x00F8 size: 16 bit */
1246  SIU_PCR_tag PCR93; /* offset: 0x00FA size: 16 bit */
1247  SIU_PCR_tag PCR94; /* offset: 0x00FC size: 16 bit */
1248  SIU_PCR_tag PCR95; /* offset: 0x00FE size: 16 bit */
1249  SIU_PCR_tag PCR96; /* offset: 0x0100 size: 16 bit */
1250  SIU_PCR_tag PCR97; /* offset: 0x0102 size: 16 bit */
1251  SIU_PCR_tag PCR98; /* offset: 0x0104 size: 16 bit */
1252  SIU_PCR_tag PCR99; /* offset: 0x0106 size: 16 bit */
1253  SIU_PCR_tag PCR100; /* offset: 0x0108 size: 16 bit */
1254  SIU_PCR_tag PCR101; /* offset: 0x010A size: 16 bit */
1255  SIU_PCR_tag PCR102; /* offset: 0x010C size: 16 bit */
1256  SIU_PCR_tag PCR103; /* offset: 0x010E size: 16 bit */
1257  SIU_PCR_tag PCR104; /* offset: 0x0110 size: 16 bit */
1258  SIU_PCR_tag PCR105; /* offset: 0x0112 size: 16 bit */
1259  SIU_PCR_tag PCR106; /* offset: 0x0114 size: 16 bit */
1260  SIU_PCR_tag PCR107; /* offset: 0x0116 size: 16 bit */
1261  SIU_PCR_tag PCR108; /* offset: 0x0118 size: 16 bit */
1262  SIU_PCR_tag PCR109; /* offset: 0x011A size: 16 bit */
1263  SIU_PCR_tag PCR110; /* offset: 0x011C size: 16 bit */
1264  SIU_PCR_tag PCR111; /* offset: 0x011E size: 16 bit */
1265  SIU_PCR_tag PCR112; /* offset: 0x0120 size: 16 bit */
1266  SIU_PCR_tag PCR113; /* offset: 0x0122 size: 16 bit */
1267  SIU_PCR_tag PCR114; /* offset: 0x0124 size: 16 bit */
1268  SIU_PCR_tag PCR115; /* offset: 0x0126 size: 16 bit */
1269  SIU_PCR_tag PCR116; /* offset: 0x0128 size: 16 bit */
1270  SIU_PCR_tag PCR117; /* offset: 0x012A size: 16 bit */
1271  SIU_PCR_tag PCR118; /* offset: 0x012C size: 16 bit */
1272  SIU_PCR_tag PCR119; /* offset: 0x012E size: 16 bit */
1273  SIU_PCR_tag PCR120; /* offset: 0x0130 size: 16 bit */
1274  SIU_PCR_tag PCR121; /* offset: 0x0132 size: 16 bit */
1275  SIU_PCR_tag PCR122; /* offset: 0x0134 size: 16 bit */
1276  SIU_PCR_tag PCR123; /* offset: 0x0136 size: 16 bit */
1277  SIU_PCR_tag PCR124; /* offset: 0x0138 size: 16 bit */
1278  SIU_PCR_tag PCR125; /* offset: 0x013A size: 16 bit */
1279  SIU_PCR_tag PCR126; /* offset: 0x013C size: 16 bit */
1280  SIU_PCR_tag PCR127; /* offset: 0x013E size: 16 bit */
1281  SIU_PCR_tag PCR128; /* offset: 0x0140 size: 16 bit */
1282  SIU_PCR_tag PCR129; /* offset: 0x0142 size: 16 bit */
1283  SIU_PCR_tag PCR130; /* offset: 0x0144 size: 16 bit */
1284  SIU_PCR_tag PCR131; /* offset: 0x0146 size: 16 bit */
1285  SIU_PCR_tag PCR132; /* offset: 0x0148 size: 16 bit */
1286  SIU_PCR_tag PCR133; /* offset: 0x014A size: 16 bit */
1287  SIU_PCR_tag PCR134; /* offset: 0x014C size: 16 bit */
1288  SIU_PCR_tag PCR135; /* offset: 0x014E size: 16 bit */
1289  SIU_PCR_tag PCR136; /* offset: 0x0150 size: 16 bit */
1290  SIU_PCR_tag PCR137; /* offset: 0x0152 size: 16 bit */
1291  SIU_PCR_tag PCR138; /* offset: 0x0154 size: 16 bit */
1292  SIU_PCR_tag PCR139; /* offset: 0x0156 size: 16 bit */
1293  SIU_PCR_tag PCR140; /* offset: 0x0158 size: 16 bit */
1294  SIU_PCR_tag PCR141; /* offset: 0x015A size: 16 bit */
1295  SIU_PCR_tag PCR142; /* offset: 0x015C size: 16 bit */
1296  SIU_PCR_tag PCR143; /* offset: 0x015E size: 16 bit */
1297  SIU_PCR_tag PCR144; /* offset: 0x0160 size: 16 bit */
1298  SIU_PCR_tag PCR145; /* offset: 0x0162 size: 16 bit */
1299  SIU_PCR_tag PCR146; /* offset: 0x0164 size: 16 bit */
1300  SIU_PCR_tag PCR147; /* offset: 0x0166 size: 16 bit */
1301  SIU_PCR_tag PCR148; /* offset: 0x0168 size: 16 bit */
1302  SIU_PCR_tag PCR149; /* offset: 0x016A size: 16 bit */
1303  SIU_PCR_tag PCR150; /* offset: 0x016C size: 16 bit */
1304  SIU_PCR_tag PCR151; /* offset: 0x016E size: 16 bit */
1305  SIU_PCR_tag PCR152; /* offset: 0x0170 size: 16 bit */
1306  SIU_PCR_tag PCR153; /* offset: 0x0172 size: 16 bit */
1307  SIU_PCR_tag PCR154; /* offset: 0x0174 size: 16 bit */
1308  SIU_PCR_tag PCR155; /* offset: 0x0176 size: 16 bit */
1309  SIU_PCR_tag PCR156; /* offset: 0x0178 size: 16 bit */
1310  SIU_PCR_tag PCR157; /* offset: 0x017A size: 16 bit */
1311  SIU_PCR_tag PCR158; /* offset: 0x017C size: 16 bit */
1312  SIU_PCR_tag PCR159; /* offset: 0x017E size: 16 bit */
1313  SIU_PCR_tag PCR160; /* offset: 0x0180 size: 16 bit */
1314  SIU_PCR_tag PCR161; /* offset: 0x0182 size: 16 bit */
1315  SIU_PCR_tag PCR162; /* offset: 0x0184 size: 16 bit */
1316  SIU_PCR_tag PCR163; /* offset: 0x0186 size: 16 bit */
1317  SIU_PCR_tag PCR164; /* offset: 0x0188 size: 16 bit */
1318  SIU_PCR_tag PCR165; /* offset: 0x018A size: 16 bit */
1319  SIU_PCR_tag PCR166; /* offset: 0x018C size: 16 bit */
1320  SIU_PCR_tag PCR167; /* offset: 0x018E size: 16 bit */
1321  SIU_PCR_tag PCR168; /* offset: 0x0190 size: 16 bit */
1322  SIU_PCR_tag PCR169; /* offset: 0x0192 size: 16 bit */
1323  SIU_PCR_tag PCR170; /* offset: 0x0194 size: 16 bit */
1324  SIU_PCR_tag PCR171; /* offset: 0x0196 size: 16 bit */
1325  SIU_PCR_tag PCR172; /* offset: 0x0198 size: 16 bit */
1326  SIU_PCR_tag PCR173; /* offset: 0x019A size: 16 bit */
1327  SIU_PCR_tag PCR174; /* offset: 0x019C size: 16 bit */
1328  SIU_PCR_tag PCR175; /* offset: 0x019E size: 16 bit */
1329  SIU_PCR_tag PCR176; /* offset: 0x01A0 size: 16 bit */
1330  SIU_PCR_tag PCR177; /* offset: 0x01A2 size: 16 bit */
1331  SIU_PCR_tag PCR178; /* offset: 0x01A4 size: 16 bit */
1332  SIU_PCR_tag PCR179; /* offset: 0x01A6 size: 16 bit */
1333  SIU_PCR_tag PCR180; /* offset: 0x01A8 size: 16 bit */
1334  SIU_PCR_tag PCR181; /* offset: 0x01AA size: 16 bit */
1335  SIU_PCR_tag PCR182; /* offset: 0x01AC size: 16 bit */
1336  SIU_PCR_tag PCR183; /* offset: 0x01AE size: 16 bit */
1337  SIU_PCR_tag PCR184; /* offset: 0x01B0 size: 16 bit */
1338  SIU_PCR_tag PCR185; /* offset: 0x01B2 size: 16 bit */
1339  SIU_PCR_tag PCR186; /* offset: 0x01B4 size: 16 bit */
1340  SIU_PCR_tag PCR187; /* offset: 0x01B6 size: 16 bit */
1341  SIU_PCR_tag PCR188; /* offset: 0x01B8 size: 16 bit */
1342  SIU_PCR_tag PCR189; /* offset: 0x01BA size: 16 bit */
1343  SIU_PCR_tag PCR190; /* offset: 0x01BC size: 16 bit */
1344  SIU_PCR_tag PCR191; /* offset: 0x01BE size: 16 bit */
1345  SIU_PCR_tag PCR192; /* offset: 0x01C0 size: 16 bit */
1346  SIU_PCR_tag PCR193; /* offset: 0x01C2 size: 16 bit */
1347  SIU_PCR_tag PCR194; /* offset: 0x01C4 size: 16 bit */
1348  SIU_PCR_tag PCR195; /* offset: 0x01C6 size: 16 bit */
1349  SIU_PCR_tag PCR196; /* offset: 0x01C8 size: 16 bit */
1350  SIU_PCR_tag PCR197; /* offset: 0x01CA size: 16 bit */
1351  SIU_PCR_tag PCR198; /* offset: 0x01CC size: 16 bit */
1352  SIU_PCR_tag PCR199; /* offset: 0x01CE size: 16 bit */
1353  SIU_PCR_tag PCR200; /* offset: 0x01D0 size: 16 bit */
1354  SIU_PCR_tag PCR201; /* offset: 0x01D2 size: 16 bit */
1355  SIU_PCR_tag PCR202; /* offset: 0x01D4 size: 16 bit */
1356  SIU_PCR_tag PCR203; /* offset: 0x01D6 size: 16 bit */
1357  SIU_PCR_tag PCR204; /* offset: 0x01D8 size: 16 bit */
1358  SIU_PCR_tag PCR205; /* offset: 0x01DA size: 16 bit */
1359  SIU_PCR_tag PCR206; /* offset: 0x01DC size: 16 bit */
1360  SIU_PCR_tag PCR207; /* offset: 0x01DE size: 16 bit */
1361  SIU_PCR_tag PCR208; /* offset: 0x01E0 size: 16 bit */
1362  SIU_PCR_tag PCR209; /* offset: 0x01E2 size: 16 bit */
1363  SIU_PCR_tag PCR210; /* offset: 0x01E4 size: 16 bit */
1364  SIU_PCR_tag PCR211; /* offset: 0x01E6 size: 16 bit */
1365  SIU_PCR_tag PCR212; /* offset: 0x01E8 size: 16 bit */
1366  SIU_PCR_tag PCR213; /* offset: 0x01EA size: 16 bit */
1367  SIU_PCR_tag PCR214; /* offset: 0x01EC size: 16 bit */
1368  SIU_PCR_tag PCR215; /* offset: 0x01EE size: 16 bit */
1369  SIU_PCR_tag PCR216; /* offset: 0x01F0 size: 16 bit */
1370  SIU_PCR_tag PCR217; /* offset: 0x01F2 size: 16 bit */
1371  SIU_PCR_tag PCR218; /* offset: 0x01F4 size: 16 bit */
1372  SIU_PCR_tag PCR219; /* offset: 0x01F6 size: 16 bit */
1373  SIU_PCR_tag PCR220; /* offset: 0x01F8 size: 16 bit */
1374  SIU_PCR_tag PCR221; /* offset: 0x01FA size: 16 bit */
1375  SIU_PCR_tag PCR222; /* offset: 0x01FC size: 16 bit */
1376  SIU_PCR_tag PCR223; /* offset: 0x01FE size: 16 bit */
1377  SIU_PCR_tag PCR224; /* offset: 0x0200 size: 16 bit */
1378  SIU_PCR_tag PCR225; /* offset: 0x0202 size: 16 bit */
1379  SIU_PCR_tag PCR226; /* offset: 0x0204 size: 16 bit */
1380  SIU_PCR_tag PCR227; /* offset: 0x0206 size: 16 bit */
1381  SIU_PCR_tag PCR228; /* offset: 0x0208 size: 16 bit */
1382  SIU_PCR_tag PCR229; /* offset: 0x020A size: 16 bit */
1383  SIU_PCR_tag PCR230; /* offset: 0x020C size: 16 bit */
1384  SIU_PCR_tag PCR231; /* offset: 0x020E size: 16 bit */
1385  SIU_PCR_tag PCR232; /* offset: 0x0210 size: 16 bit */
1386  SIU_PCR_tag PCR233; /* offset: 0x0212 size: 16 bit */
1387  SIU_PCR_tag PCR234; /* offset: 0x0214 size: 16 bit */
1388  SIU_PCR_tag PCR235; /* offset: 0x0216 size: 16 bit */
1389  SIU_PCR_tag PCR236; /* offset: 0x0218 size: 16 bit */
1390  SIU_PCR_tag PCR237; /* offset: 0x021A size: 16 bit */
1391  SIU_PCR_tag PCR238; /* offset: 0x021C size: 16 bit */
1392  SIU_PCR_tag PCR239; /* offset: 0x021E size: 16 bit */
1393  SIU_PCR_tag PCR240; /* offset: 0x0220 size: 16 bit */
1394  SIU_PCR_tag PCR241; /* offset: 0x0222 size: 16 bit */
1395  SIU_PCR_tag PCR242; /* offset: 0x0224 size: 16 bit */
1396  SIU_PCR_tag PCR243; /* offset: 0x0226 size: 16 bit */
1397  SIU_PCR_tag PCR244; /* offset: 0x0228 size: 16 bit */
1398  SIU_PCR_tag PCR245; /* offset: 0x022A size: 16 bit */
1399  SIU_PCR_tag PCR246; /* offset: 0x022C size: 16 bit */
1400  SIU_PCR_tag PCR247; /* offset: 0x022E size: 16 bit */
1401  SIU_PCR_tag PCR248; /* offset: 0x0230 size: 16 bit */
1402  SIU_PCR_tag PCR249; /* offset: 0x0232 size: 16 bit */
1403  SIU_PCR_tag PCR250; /* offset: 0x0234 size: 16 bit */
1404  SIU_PCR_tag PCR251; /* offset: 0x0236 size: 16 bit */
1405  SIU_PCR_tag PCR252; /* offset: 0x0238 size: 16 bit */
1406  SIU_PCR_tag PCR253; /* offset: 0x023A size: 16 bit */
1407  SIU_PCR_tag PCR254; /* offset: 0x023C size: 16 bit */
1408  SIU_PCR_tag PCR255; /* offset: 0x023E size: 16 bit */
1409  SIU_PCR_tag PCR256; /* offset: 0x0240 size: 16 bit */
1410  SIU_PCR_tag PCR257; /* offset: 0x0242 size: 16 bit */
1411  SIU_PCR_tag PCR258; /* offset: 0x0244 size: 16 bit */
1412  SIU_PCR_tag PCR259; /* offset: 0x0246 size: 16 bit */
1413  SIU_PCR_tag PCR260; /* offset: 0x0248 size: 16 bit */
1414  SIU_PCR_tag PCR261; /* offset: 0x024A size: 16 bit */
1415  SIU_PCR_tag PCR262; /* offset: 0x024C size: 16 bit */
1416  SIU_PCR_tag PCR263; /* offset: 0x024E size: 16 bit */
1417  SIU_PCR_tag PCR264; /* offset: 0x0250 size: 16 bit */
1418  SIU_PCR_tag PCR265; /* offset: 0x0252 size: 16 bit */
1419  SIU_PCR_tag PCR266; /* offset: 0x0254 size: 16 bit */
1420  SIU_PCR_tag PCR267; /* offset: 0x0256 size: 16 bit */
1421  SIU_PCR_tag PCR268; /* offset: 0x0258 size: 16 bit */
1422  SIU_PCR_tag PCR269; /* offset: 0x025A size: 16 bit */
1423  SIU_PCR_tag PCR270; /* offset: 0x025C size: 16 bit */
1424  SIU_PCR_tag PCR271; /* offset: 0x025E size: 16 bit */
1425  SIU_PCR_tag PCR272; /* offset: 0x0260 size: 16 bit */
1426  SIU_PCR_tag PCR273; /* offset: 0x0262 size: 16 bit */
1427  SIU_PCR_tag PCR274; /* offset: 0x0264 size: 16 bit */
1428  SIU_PCR_tag PCR275; /* offset: 0x0266 size: 16 bit */
1429  SIU_PCR_tag PCR276; /* offset: 0x0268 size: 16 bit */
1430  SIU_PCR_tag PCR277; /* offset: 0x026A size: 16 bit */
1431  SIU_PCR_tag PCR278; /* offset: 0x026C size: 16 bit */
1432  SIU_PCR_tag PCR279; /* offset: 0x026E size: 16 bit */
1433  SIU_PCR_tag PCR280; /* offset: 0x0270 size: 16 bit */
1434  SIU_PCR_tag PCR281; /* offset: 0x0272 size: 16 bit */
1435  SIU_PCR_tag PCR282; /* offset: 0x0274 size: 16 bit */
1436  SIU_PCR_tag PCR283; /* offset: 0x0276 size: 16 bit */
1437  SIU_PCR_tag PCR284; /* offset: 0x0278 size: 16 bit */
1438  SIU_PCR_tag PCR285; /* offset: 0x027A size: 16 bit */
1439  SIU_PCR_tag PCR286; /* offset: 0x027C size: 16 bit */
1440  SIU_PCR_tag PCR287; /* offset: 0x027E size: 16 bit */
1441  SIU_PCR_tag PCR288; /* offset: 0x0280 size: 16 bit */
1442  SIU_PCR_tag PCR289; /* offset: 0x0282 size: 16 bit */
1443  SIU_PCR_tag PCR290; /* offset: 0x0284 size: 16 bit */
1444  SIU_PCR_tag PCR291; /* offset: 0x0286 size: 16 bit */
1445  SIU_PCR_tag PCR292; /* offset: 0x0288 size: 16 bit */
1446  SIU_PCR_tag PCR293; /* offset: 0x028A size: 16 bit */
1447  SIU_PCR_tag PCR294; /* offset: 0x028C size: 16 bit */
1448  SIU_PCR_tag PCR295; /* offset: 0x028E size: 16 bit */
1449  SIU_PCR_tag PCR296; /* offset: 0x0290 size: 16 bit */
1450  SIU_PCR_tag PCR297; /* offset: 0x0292 size: 16 bit */
1451  SIU_PCR_tag PCR298; /* offset: 0x0294 size: 16 bit */
1452  SIU_PCR_tag PCR299; /* offset: 0x0296 size: 16 bit */
1453  SIU_PCR_tag PCR300; /* offset: 0x0298 size: 16 bit */
1454  SIU_PCR_tag PCR301; /* offset: 0x029A size: 16 bit */
1455  SIU_PCR_tag PCR302; /* offset: 0x029C size: 16 bit */
1456  SIU_PCR_tag PCR303; /* offset: 0x029E size: 16 bit */
1457  SIU_PCR_tag PCR304; /* offset: 0x02A0 size: 16 bit */
1458  SIU_PCR_tag PCR305; /* offset: 0x02A2 size: 16 bit */
1459  SIU_PCR_tag PCR306; /* offset: 0x02A4 size: 16 bit */
1460  SIU_PCR_tag PCR307; /* offset: 0x02A6 size: 16 bit */
1461  SIU_PCR_tag PCR308; /* offset: 0x02A8 size: 16 bit */
1462  SIU_PCR_tag PCR309; /* offset: 0x02AA size: 16 bit */
1463  SIU_PCR_tag PCR310; /* offset: 0x02AC size: 16 bit */
1464  SIU_PCR_tag PCR311; /* offset: 0x02AE size: 16 bit */
1465  SIU_PCR_tag PCR312; /* offset: 0x02B0 size: 16 bit */
1466  SIU_PCR_tag PCR313; /* offset: 0x02B2 size: 16 bit */
1467  SIU_PCR_tag PCR314; /* offset: 0x02B4 size: 16 bit */
1468  SIU_PCR_tag PCR315; /* offset: 0x02B6 size: 16 bit */
1469  SIU_PCR_tag PCR316; /* offset: 0x02B8 size: 16 bit */
1470  SIU_PCR_tag PCR317; /* offset: 0x02BA size: 16 bit */
1471  SIU_PCR_tag PCR318; /* offset: 0x02BC size: 16 bit */
1472  SIU_PCR_tag PCR319; /* offset: 0x02BE size: 16 bit */
1473  SIU_PCR_tag PCR320; /* offset: 0x02C0 size: 16 bit */
1474  SIU_PCR_tag PCR321; /* offset: 0x02C2 size: 16 bit */
1475  SIU_PCR_tag PCR322; /* offset: 0x02C4 size: 16 bit */
1476  SIU_PCR_tag PCR323; /* offset: 0x02C6 size: 16 bit */
1477  SIU_PCR_tag PCR324; /* offset: 0x02C8 size: 16 bit */
1478  SIU_PCR_tag PCR325; /* offset: 0x02CA size: 16 bit */
1479  SIU_PCR_tag PCR326; /* offset: 0x02CC size: 16 bit */
1480  SIU_PCR_tag PCR327; /* offset: 0x02CE size: 16 bit */
1481  SIU_PCR_tag PCR328; /* offset: 0x02D0 size: 16 bit */
1482  SIU_PCR_tag PCR329; /* offset: 0x02D2 size: 16 bit */
1483  SIU_PCR_tag PCR330; /* offset: 0x02D4 size: 16 bit */
1484  SIU_PCR_tag PCR331; /* offset: 0x02D6 size: 16 bit */
1485  SIU_PCR_tag PCR332; /* offset: 0x02D8 size: 16 bit */
1486  SIU_PCR_tag PCR333; /* offset: 0x02DA size: 16 bit */
1487  SIU_PCR_tag PCR334; /* offset: 0x02DC size: 16 bit */
1488  SIU_PCR_tag PCR335; /* offset: 0x02DE size: 16 bit */
1489  SIU_PCR_tag PCR336; /* offset: 0x02E0 size: 16 bit */
1490  SIU_PCR_tag PCR337; /* offset: 0x02E2 size: 16 bit */
1491  SIU_PCR_tag PCR338; /* offset: 0x02E4 size: 16 bit */
1492  SIU_PCR_tag PCR339; /* offset: 0x02E6 size: 16 bit */
1493  SIU_PCR_tag PCR340; /* offset: 0x02E8 size: 16 bit */
1494  SIU_PCR_tag PCR341; /* offset: 0x02EA size: 16 bit */
1495  SIU_PCR_tag PCR342; /* offset: 0x02EC size: 16 bit */
1496  SIU_PCR_tag PCR343; /* offset: 0x02EE size: 16 bit */
1497  SIU_PCR_tag PCR344; /* offset: 0x02F0 size: 16 bit */
1498  SIU_PCR_tag PCR345; /* offset: 0x02F2 size: 16 bit */
1499  SIU_PCR_tag PCR346; /* offset: 0x02F4 size: 16 bit */
1500  SIU_PCR_tag PCR347; /* offset: 0x02F6 size: 16 bit */
1501  SIU_PCR_tag PCR348; /* offset: 0x02F8 size: 16 bit */
1502  SIU_PCR_tag PCR349; /* offset: 0x02FA size: 16 bit */
1503  SIU_PCR_tag PCR350; /* offset: 0x02FC size: 16 bit */
1504  SIU_PCR_tag PCR351; /* offset: 0x02FE size: 16 bit */
1505  SIU_PCR_tag PCR352; /* offset: 0x0300 size: 16 bit */
1506  SIU_PCR_tag PCR353; /* offset: 0x0302 size: 16 bit */
1507  SIU_PCR_tag PCR354; /* offset: 0x0304 size: 16 bit */
1508  SIU_PCR_tag PCR355; /* offset: 0x0306 size: 16 bit */
1509  SIU_PCR_tag PCR356; /* offset: 0x0308 size: 16 bit */
1510  SIU_PCR_tag PCR357; /* offset: 0x030A size: 16 bit */
1511  SIU_PCR_tag PCR358; /* offset: 0x030C size: 16 bit */
1512  SIU_PCR_tag PCR359; /* offset: 0x030E size: 16 bit */
1513  SIU_PCR_tag PCR360; /* offset: 0x0310 size: 16 bit */
1514  SIU_PCR_tag PCR361; /* offset: 0x0312 size: 16 bit */
1515  SIU_PCR_tag PCR362; /* offset: 0x0314 size: 16 bit */
1516  SIU_PCR_tag PCR363; /* offset: 0x0316 size: 16 bit */
1517  SIU_PCR_tag PCR364; /* offset: 0x0318 size: 16 bit */
1518  SIU_PCR_tag PCR365; /* offset: 0x031A size: 16 bit */
1519  SIU_PCR_tag PCR366; /* offset: 0x031C size: 16 bit */
1520  SIU_PCR_tag PCR367; /* offset: 0x031E size: 16 bit */
1521  SIU_PCR_tag PCR368; /* offset: 0x0320 size: 16 bit */
1522  SIU_PCR_tag PCR369; /* offset: 0x0322 size: 16 bit */
1523  SIU_PCR_tag PCR370; /* offset: 0x0324 size: 16 bit */
1524  SIU_PCR_tag PCR371; /* offset: 0x0326 size: 16 bit */
1525  SIU_PCR_tag PCR372; /* offset: 0x0328 size: 16 bit */
1526  SIU_PCR_tag PCR373; /* offset: 0x032A size: 16 bit */
1527  SIU_PCR_tag PCR374; /* offset: 0x032C size: 16 bit */
1528  SIU_PCR_tag PCR375; /* offset: 0x032E size: 16 bit */
1529  SIU_PCR_tag PCR376; /* offset: 0x0330 size: 16 bit */
1530  SIU_PCR_tag PCR377; /* offset: 0x0332 size: 16 bit */
1531  SIU_PCR_tag PCR378; /* offset: 0x0334 size: 16 bit */
1532  SIU_PCR_tag PCR379; /* offset: 0x0336 size: 16 bit */
1533  SIU_PCR_tag PCR380; /* offset: 0x0338 size: 16 bit */
1534  SIU_PCR_tag PCR381; /* offset: 0x033A size: 16 bit */
1535  SIU_PCR_tag PCR382; /* offset: 0x033C size: 16 bit */
1536  SIU_PCR_tag PCR383; /* offset: 0x033E size: 16 bit */
1537  SIU_PCR_tag PCR384; /* offset: 0x0340 size: 16 bit */
1538  SIU_PCR_tag PCR385; /* offset: 0x0342 size: 16 bit */
1539  SIU_PCR_tag PCR386; /* offset: 0x0344 size: 16 bit */
1540  SIU_PCR_tag PCR387; /* offset: 0x0346 size: 16 bit */
1541  SIU_PCR_tag PCR388; /* offset: 0x0348 size: 16 bit */
1542  SIU_PCR_tag PCR389; /* offset: 0x034A size: 16 bit */
1543  SIU_PCR_tag PCR390; /* offset: 0x034C size: 16 bit */
1544  SIU_PCR_tag PCR391; /* offset: 0x034E size: 16 bit */
1545  SIU_PCR_tag PCR392; /* offset: 0x0350 size: 16 bit */
1546  SIU_PCR_tag PCR393; /* offset: 0x0352 size: 16 bit */
1547  SIU_PCR_tag PCR394; /* offset: 0x0354 size: 16 bit */
1548  SIU_PCR_tag PCR395; /* offset: 0x0356 size: 16 bit */
1549  SIU_PCR_tag PCR396; /* offset: 0x0358 size: 16 bit */
1550  SIU_PCR_tag PCR397; /* offset: 0x035A size: 16 bit */
1551  SIU_PCR_tag PCR398; /* offset: 0x035C size: 16 bit */
1552  SIU_PCR_tag PCR399; /* offset: 0x035E size: 16 bit */
1553  SIU_PCR_tag PCR400; /* offset: 0x0360 size: 16 bit */
1554  SIU_PCR_tag PCR401; /* offset: 0x0362 size: 16 bit */
1555  SIU_PCR_tag PCR402; /* offset: 0x0364 size: 16 bit */
1556  SIU_PCR_tag PCR403; /* offset: 0x0366 size: 16 bit */
1557  SIU_PCR_tag PCR404; /* offset: 0x0368 size: 16 bit */
1558  SIU_PCR_tag PCR405; /* offset: 0x036A size: 16 bit */
1559  SIU_PCR_tag PCR406; /* offset: 0x036C size: 16 bit */
1560  SIU_PCR_tag PCR407; /* offset: 0x036E size: 16 bit */
1561  SIU_PCR_tag PCR408; /* offset: 0x0370 size: 16 bit */
1562  SIU_PCR_tag PCR409; /* offset: 0x0372 size: 16 bit */
1563  SIU_PCR_tag PCR410; /* offset: 0x0374 size: 16 bit */
1564  SIU_PCR_tag PCR411; /* offset: 0x0376 size: 16 bit */
1565  SIU_PCR_tag PCR412; /* offset: 0x0378 size: 16 bit */
1566  SIU_PCR_tag PCR413; /* offset: 0x037A size: 16 bit */
1567  SIU_PCR_tag PCR414; /* offset: 0x037C size: 16 bit */
1568  SIU_PCR_tag PCR415; /* offset: 0x037E size: 16 bit */
1569  SIU_PCR_tag PCR416; /* offset: 0x0380 size: 16 bit */
1570  SIU_PCR_tag PCR417; /* offset: 0x0382 size: 16 bit */
1571  SIU_PCR_tag PCR418; /* offset: 0x0384 size: 16 bit */
1572  SIU_PCR_tag PCR419; /* offset: 0x0386 size: 16 bit */
1573  SIU_PCR_tag PCR420; /* offset: 0x0388 size: 16 bit */
1574  SIU_PCR_tag PCR421; /* offset: 0x038A size: 16 bit */
1575  SIU_PCR_tag PCR422; /* offset: 0x038C size: 16 bit */
1576  SIU_PCR_tag PCR423; /* offset: 0x038E size: 16 bit */
1577  SIU_PCR_tag PCR424; /* offset: 0x0390 size: 16 bit */
1578  SIU_PCR_tag PCR425; /* offset: 0x0392 size: 16 bit */
1579  SIU_PCR_tag PCR426; /* offset: 0x0394 size: 16 bit */
1580  SIU_PCR_tag PCR427; /* offset: 0x0396 size: 16 bit */
1581  SIU_PCR_tag PCR428; /* offset: 0x0398 size: 16 bit */
1582  SIU_PCR_tag PCR429; /* offset: 0x039A size: 16 bit */
1583  SIU_PCR_tag PCR430; /* offset: 0x039C size: 16 bit */
1584  SIU_PCR_tag PCR431; /* offset: 0x039E size: 16 bit */
1585  SIU_PCR_tag PCR432; /* offset: 0x03A0 size: 16 bit */
1586  SIU_PCR_tag PCR433; /* offset: 0x03A2 size: 16 bit */
1587  SIU_PCR_tag PCR434; /* offset: 0x03A4 size: 16 bit */
1588  SIU_PCR_tag PCR435; /* offset: 0x03A6 size: 16 bit */
1589  SIU_PCR_tag PCR436; /* offset: 0x03A8 size: 16 bit */
1590  SIU_PCR_tag PCR437; /* offset: 0x03AA size: 16 bit */
1591  SIU_PCR_tag PCR438; /* offset: 0x03AC size: 16 bit */
1592  SIU_PCR_tag PCR439; /* offset: 0x03AE size: 16 bit */
1593  SIU_PCR_tag PCR440; /* offset: 0x03B0 size: 16 bit */
1594  SIU_PCR_tag PCR441; /* offset: 0x03B2 size: 16 bit */
1595  SIU_PCR_tag PCR442; /* offset: 0x03B4 size: 16 bit */
1596  SIU_PCR_tag PCR443; /* offset: 0x03B6 size: 16 bit */
1597  SIU_PCR_tag PCR444; /* offset: 0x03B8 size: 16 bit */
1598  SIU_PCR_tag PCR445; /* offset: 0x03BA size: 16 bit */
1599  SIU_PCR_tag PCR446; /* offset: 0x03BC size: 16 bit */
1600  SIU_PCR_tag PCR447; /* offset: 0x03BE size: 16 bit */
1601  SIU_PCR_tag PCR448; /* offset: 0x03C0 size: 16 bit */
1602  SIU_PCR_tag PCR449; /* offset: 0x03C2 size: 16 bit */
1603  SIU_PCR_tag PCR450; /* offset: 0x03C4 size: 16 bit */
1604  SIU_PCR_tag PCR451; /* offset: 0x03C6 size: 16 bit */
1605  SIU_PCR_tag PCR452; /* offset: 0x03C8 size: 16 bit */
1606  SIU_PCR_tag PCR453; /* offset: 0x03CA size: 16 bit */
1607  SIU_PCR_tag PCR454; /* offset: 0x03CC size: 16 bit */
1608  SIU_PCR_tag PCR455; /* offset: 0x03CE size: 16 bit */
1609  SIU_PCR_tag PCR456; /* offset: 0x03D0 size: 16 bit */
1610  SIU_PCR_tag PCR457; /* offset: 0x03D2 size: 16 bit */
1611  SIU_PCR_tag PCR458; /* offset: 0x03D4 size: 16 bit */
1612  SIU_PCR_tag PCR459; /* offset: 0x03D6 size: 16 bit */
1613  SIU_PCR_tag PCR460; /* offset: 0x03D8 size: 16 bit */
1614  SIU_PCR_tag PCR461; /* offset: 0x03DA size: 16 bit */
1615  SIU_PCR_tag PCR462; /* offset: 0x03DC size: 16 bit */
1616  SIU_PCR_tag PCR463; /* offset: 0x03DE size: 16 bit */
1617  SIU_PCR_tag PCR464; /* offset: 0x03E0 size: 16 bit */
1618  SIU_PCR_tag PCR465; /* offset: 0x03E2 size: 16 bit */
1619  SIU_PCR_tag PCR466; /* offset: 0x03E4 size: 16 bit */
1620  SIU_PCR_tag PCR467; /* offset: 0x03E6 size: 16 bit */
1621  SIU_PCR_tag PCR468; /* offset: 0x03E8 size: 16 bit */
1622  SIU_PCR_tag PCR469; /* offset: 0x03EA size: 16 bit */
1623  SIU_PCR_tag PCR470; /* offset: 0x03EC size: 16 bit */
1624  SIU_PCR_tag PCR471; /* offset: 0x03EE size: 16 bit */
1625  SIU_PCR_tag PCR472; /* offset: 0x03F0 size: 16 bit */
1626  SIU_PCR_tag PCR473; /* offset: 0x03F2 size: 16 bit */
1627  SIU_PCR_tag PCR474; /* offset: 0x03F4 size: 16 bit */
1628  SIU_PCR_tag PCR475; /* offset: 0x03F6 size: 16 bit */
1629  SIU_PCR_tag PCR476; /* offset: 0x03F8 size: 16 bit */
1630  SIU_PCR_tag PCR477; /* offset: 0x03FA size: 16 bit */
1631  SIU_PCR_tag PCR478; /* offset: 0x03FC size: 16 bit */
1632  SIU_PCR_tag PCR479; /* offset: 0x03FE size: 16 bit */
1633  SIU_PCR_tag PCR480; /* offset: 0x0400 size: 16 bit */
1634  SIU_PCR_tag PCR481; /* offset: 0x0402 size: 16 bit */
1635  SIU_PCR_tag PCR482; /* offset: 0x0404 size: 16 bit */
1636  SIU_PCR_tag PCR483; /* offset: 0x0406 size: 16 bit */
1637  SIU_PCR_tag PCR484; /* offset: 0x0408 size: 16 bit */
1638  SIU_PCR_tag PCR485; /* offset: 0x040A size: 16 bit */
1639  SIU_PCR_tag PCR486; /* offset: 0x040C size: 16 bit */
1640  SIU_PCR_tag PCR487; /* offset: 0x040E size: 16 bit */
1641  SIU_PCR_tag PCR488; /* offset: 0x0410 size: 16 bit */
1642  SIU_PCR_tag PCR489; /* offset: 0x0412 size: 16 bit */
1643  SIU_PCR_tag PCR490; /* offset: 0x0414 size: 16 bit */
1644  SIU_PCR_tag PCR491; /* offset: 0x0416 size: 16 bit */
1645  SIU_PCR_tag PCR492; /* offset: 0x0418 size: 16 bit */
1646  SIU_PCR_tag PCR493; /* offset: 0x041A size: 16 bit */
1647  SIU_PCR_tag PCR494; /* offset: 0x041C size: 16 bit */
1648  SIU_PCR_tag PCR495; /* offset: 0x041E size: 16 bit */
1649  SIU_PCR_tag PCR496; /* offset: 0x0420 size: 16 bit */
1650  SIU_PCR_tag PCR497; /* offset: 0x0422 size: 16 bit */
1651  SIU_PCR_tag PCR498; /* offset: 0x0424 size: 16 bit */
1652  SIU_PCR_tag PCR499; /* offset: 0x0426 size: 16 bit */
1653  SIU_PCR_tag PCR500; /* offset: 0x0428 size: 16 bit */
1654  SIU_PCR_tag PCR501; /* offset: 0x042A size: 16 bit */
1655  SIU_PCR_tag PCR502; /* offset: 0x042C size: 16 bit */
1656  SIU_PCR_tag PCR503; /* offset: 0x042E size: 16 bit */
1657  SIU_PCR_tag PCR504; /* offset: 0x0430 size: 16 bit */
1658  SIU_PCR_tag PCR505; /* offset: 0x0432 size: 16 bit */
1659  SIU_PCR_tag PCR506; /* offset: 0x0434 size: 16 bit */
1660  SIU_PCR_tag PCR507; /* offset: 0x0436 size: 16 bit */
1661  SIU_PCR_tag PCR508; /* offset: 0x0438 size: 16 bit */
1662  SIU_PCR_tag PCR509; /* offset: 0x043A size: 16 bit */
1663  SIU_PCR_tag PCR510; /* offset: 0x043C size: 16 bit */
1664  SIU_PCR_tag PCR511; /* offset: 0x043E size: 16 bit */
1665  };
1666
1667  };
1668  int8_t SIUL_reserved_0440_C[192];
1669  union {
1670  /* PSMI - Pad Selection for Multiplexed Inputs */
1671  SIUL_PSMI_32B_tag PSMI_32B[64]; /* offset: 0x0500 (0x0004 x 64) */
1672
1673  /* PSMI - Pad Selection for Multiplexed Inputs */
1674  SIUL_PSMI_8B_tag PSMI[256]; /* offset: 0x0500 (0x0001 x 256) */
1675
1676  struct {
1677  /* PSMI - Pad Selection for Multiplexed Inputs */
1678  SIUL_PSMI_32B_tag PSMI0_3; /* offset: 0x0500 size: 32 bit */
1679  SIUL_PSMI_32B_tag PSMI4_7; /* offset: 0x0504 size: 32 bit */
1680  SIUL_PSMI_32B_tag PSMI8_11; /* offset: 0x0508 size: 32 bit */
1681  SIUL_PSMI_32B_tag PSMI12_15; /* offset: 0x050C size: 32 bit */
1682  SIUL_PSMI_32B_tag PSMI16_19; /* offset: 0x0510 size: 32 bit */
1683  SIUL_PSMI_32B_tag PSMI20_23; /* offset: 0x0514 size: 32 bit */
1684  SIUL_PSMI_32B_tag PSMI24_27; /* offset: 0x0518 size: 32 bit */
1685  SIUL_PSMI_32B_tag PSMI28_31; /* offset: 0x051C size: 32 bit */
1686  SIUL_PSMI_32B_tag PSMI32_35; /* offset: 0x0520 size: 32 bit */
1687  SIUL_PSMI_32B_tag PSMI36_39; /* offset: 0x0524 size: 32 bit */
1688  SIUL_PSMI_32B_tag PSMI40_43; /* offset: 0x0528 size: 32 bit */
1689  SIUL_PSMI_32B_tag PSMI44_47; /* offset: 0x052C size: 32 bit */
1690  SIUL_PSMI_32B_tag PSMI48_51; /* offset: 0x0530 size: 32 bit */
1691  SIUL_PSMI_32B_tag PSMI52_55; /* offset: 0x0534 size: 32 bit */
1692  SIUL_PSMI_32B_tag PSMI56_59; /* offset: 0x0538 size: 32 bit */
1693  SIUL_PSMI_32B_tag PSMI60_63; /* offset: 0x053C size: 32 bit */
1694  SIUL_PSMI_32B_tag PSMI64_67; /* offset: 0x0540 size: 32 bit */
1695  SIUL_PSMI_32B_tag PSMI68_71; /* offset: 0x0544 size: 32 bit */
1696  SIUL_PSMI_32B_tag PSMI72_75; /* offset: 0x0548 size: 32 bit */
1697  SIUL_PSMI_32B_tag PSMI76_79; /* offset: 0x054C size: 32 bit */
1698  SIUL_PSMI_32B_tag PSMI80_83; /* offset: 0x0550 size: 32 bit */
1699  SIUL_PSMI_32B_tag PSMI84_87; /* offset: 0x0554 size: 32 bit */
1700  SIUL_PSMI_32B_tag PSMI88_91; /* offset: 0x0558 size: 32 bit */
1701  SIUL_PSMI_32B_tag PSMI92_95; /* offset: 0x055C size: 32 bit */
1702  SIUL_PSMI_32B_tag PSMI96_99; /* offset: 0x0560 size: 32 bit */
1703  SIUL_PSMI_32B_tag PSMI100_103; /* offset: 0x0564 size: 32 bit */
1704  SIUL_PSMI_32B_tag PSMI104_107; /* offset: 0x0568 size: 32 bit */
1705  SIUL_PSMI_32B_tag PSMI108_111; /* offset: 0x056C size: 32 bit */
1706  SIUL_PSMI_32B_tag PSMI112_115; /* offset: 0x0570 size: 32 bit */
1707  SIUL_PSMI_32B_tag PSMI116_119; /* offset: 0x0574 size: 32 bit */
1708  SIUL_PSMI_32B_tag PSMI120_123; /* offset: 0x0578 size: 32 bit */
1709  SIUL_PSMI_32B_tag PSMI124_127; /* offset: 0x057C size: 32 bit */
1710  SIUL_PSMI_32B_tag PSMI128_131; /* offset: 0x0580 size: 32 bit */
1711  SIUL_PSMI_32B_tag PSMI132_135; /* offset: 0x0584 size: 32 bit */
1712  SIUL_PSMI_32B_tag PSMI136_139; /* offset: 0x0588 size: 32 bit */
1713  SIUL_PSMI_32B_tag PSMI140_143; /* offset: 0x058C size: 32 bit */
1714  SIUL_PSMI_32B_tag PSMI144_147; /* offset: 0x0590 size: 32 bit */
1715  SIUL_PSMI_32B_tag PSMI148_151; /* offset: 0x0594 size: 32 bit */
1716  SIUL_PSMI_32B_tag PSMI152_155; /* offset: 0x0598 size: 32 bit */
1717  SIUL_PSMI_32B_tag PSMI156_159; /* offset: 0x059C size: 32 bit */
1718  SIUL_PSMI_32B_tag PSMI160_163; /* offset: 0x05A0 size: 32 bit */
1719  SIUL_PSMI_32B_tag PSMI164_167; /* offset: 0x05A4 size: 32 bit */
1720  SIUL_PSMI_32B_tag PSMI168_171; /* offset: 0x05A8 size: 32 bit */
1721  SIUL_PSMI_32B_tag PSMI172_175; /* offset: 0x05AC size: 32 bit */
1722  SIUL_PSMI_32B_tag PSMI176_179; /* offset: 0x05B0 size: 32 bit */
1723  SIUL_PSMI_32B_tag PSMI180_183; /* offset: 0x05B4 size: 32 bit */
1724  SIUL_PSMI_32B_tag PSMI184_187; /* offset: 0x05B8 size: 32 bit */
1725  SIUL_PSMI_32B_tag PSMI188_191; /* offset: 0x05BC size: 32 bit */
1726  SIUL_PSMI_32B_tag PSMI192_195; /* offset: 0x05C0 size: 32 bit */
1727  SIUL_PSMI_32B_tag PSMI196_199; /* offset: 0x05C4 size: 32 bit */
1728  SIUL_PSMI_32B_tag PSMI200_203; /* offset: 0x05C8 size: 32 bit */
1729  SIUL_PSMI_32B_tag PSMI204_207; /* offset: 0x05CC size: 32 bit */
1730  SIUL_PSMI_32B_tag PSMI208_211; /* offset: 0x05D0 size: 32 bit */
1731  SIUL_PSMI_32B_tag PSMI212_215; /* offset: 0x05D4 size: 32 bit */
1732  SIUL_PSMI_32B_tag PSMI216_219; /* offset: 0x05D8 size: 32 bit */
1733  SIUL_PSMI_32B_tag PSMI220_223; /* offset: 0x05DC size: 32 bit */
1734  SIUL_PSMI_32B_tag PSMI224_227; /* offset: 0x05E0 size: 32 bit */
1735  SIUL_PSMI_32B_tag PSMI228_231; /* offset: 0x05E4 size: 32 bit */
1736  SIUL_PSMI_32B_tag PSMI232_235; /* offset: 0x05E8 size: 32 bit */
1737  SIUL_PSMI_32B_tag PSMI236_239; /* offset: 0x05EC size: 32 bit */
1738  SIUL_PSMI_32B_tag PSMI240_243; /* offset: 0x05F0 size: 32 bit */
1739  SIUL_PSMI_32B_tag PSMI244_247; /* offset: 0x05F4 size: 32 bit */
1740  SIUL_PSMI_32B_tag PSMI248_251; /* offset: 0x05F8 size: 32 bit */
1741  SIUL_PSMI_32B_tag PSMI252_255; /* offset: 0x05FC size: 32 bit */
1742  };
1743
1744  struct {
1745  /* PSMI - Pad Selection for Multiplexed Inputs */
1746  SIUL_PSMI_8B_tag PSMI0; /* offset: 0x0500 size: 8 bit */
1747  SIUL_PSMI_8B_tag PSMI1; /* offset: 0x0501 size: 8 bit */
1748  SIUL_PSMI_8B_tag PSMI2; /* offset: 0x0502 size: 8 bit */
1749  SIUL_PSMI_8B_tag PSMI3; /* offset: 0x0503 size: 8 bit */
1750  SIUL_PSMI_8B_tag PSMI4; /* offset: 0x0504 size: 8 bit */
1751  SIUL_PSMI_8B_tag PSMI5; /* offset: 0x0505 size: 8 bit */
1752  SIUL_PSMI_8B_tag PSMI6; /* offset: 0x0506 size: 8 bit */
1753  SIUL_PSMI_8B_tag PSMI7; /* offset: 0x0507 size: 8 bit */
1754  SIUL_PSMI_8B_tag PSMI8; /* offset: 0x0508 size: 8 bit */
1755  SIUL_PSMI_8B_tag PSMI9; /* offset: 0x0509 size: 8 bit */
1756  SIUL_PSMI_8B_tag PSMI10; /* offset: 0x050A size: 8 bit */
1757  SIUL_PSMI_8B_tag PSMI11; /* offset: 0x050B size: 8 bit */
1758  SIUL_PSMI_8B_tag PSMI12; /* offset: 0x050C size: 8 bit */
1759  SIUL_PSMI_8B_tag PSMI13; /* offset: 0x050D size: 8 bit */
1760  SIUL_PSMI_8B_tag PSMI14; /* offset: 0x050E size: 8 bit */
1761  SIUL_PSMI_8B_tag PSMI15; /* offset: 0x050F size: 8 bit */
1762  SIUL_PSMI_8B_tag PSMI16; /* offset: 0x0510 size: 8 bit */
1763  SIUL_PSMI_8B_tag PSMI17; /* offset: 0x0511 size: 8 bit */
1764  SIUL_PSMI_8B_tag PSMI18; /* offset: 0x0512 size: 8 bit */
1765  SIUL_PSMI_8B_tag PSMI19; /* offset: 0x0513 size: 8 bit */
1766  SIUL_PSMI_8B_tag PSMI20; /* offset: 0x0514 size: 8 bit */
1767  SIUL_PSMI_8B_tag PSMI21; /* offset: 0x0515 size: 8 bit */
1768  SIUL_PSMI_8B_tag PSMI22; /* offset: 0x0516 size: 8 bit */
1769  SIUL_PSMI_8B_tag PSMI23; /* offset: 0x0517 size: 8 bit */
1770  SIUL_PSMI_8B_tag PSMI24; /* offset: 0x0518 size: 8 bit */
1771  SIUL_PSMI_8B_tag PSMI25; /* offset: 0x0519 size: 8 bit */
1772  SIUL_PSMI_8B_tag PSMI26; /* offset: 0x051A size: 8 bit */
1773  SIUL_PSMI_8B_tag PSMI27; /* offset: 0x051B size: 8 bit */
1774  SIUL_PSMI_8B_tag PSMI28; /* offset: 0x051C size: 8 bit */
1775  SIUL_PSMI_8B_tag PSMI29; /* offset: 0x051D size: 8 bit */
1776  SIUL_PSMI_8B_tag PSMI30; /* offset: 0x051E size: 8 bit */
1777  SIUL_PSMI_8B_tag PSMI31; /* offset: 0x051F size: 8 bit */
1778  SIUL_PSMI_8B_tag PSMI32; /* offset: 0x0520 size: 8 bit */
1779  SIUL_PSMI_8B_tag PSMI33; /* offset: 0x0521 size: 8 bit */
1780  SIUL_PSMI_8B_tag PSMI34; /* offset: 0x0522 size: 8 bit */
1781  SIUL_PSMI_8B_tag PSMI35; /* offset: 0x0523 size: 8 bit */
1782  SIUL_PSMI_8B_tag PSMI36; /* offset: 0x0524 size: 8 bit */
1783  SIUL_PSMI_8B_tag PSMI37; /* offset: 0x0525 size: 8 bit */
1784  SIUL_PSMI_8B_tag PSMI38; /* offset: 0x0526 size: 8 bit */
1785  SIUL_PSMI_8B_tag PSMI39; /* offset: 0x0527 size: 8 bit */
1786  SIUL_PSMI_8B_tag PSMI40; /* offset: 0x0528 size: 8 bit */
1787  SIUL_PSMI_8B_tag PSMI41; /* offset: 0x0529 size: 8 bit */
1788  SIUL_PSMI_8B_tag PSMI42; /* offset: 0x052A size: 8 bit */
1789  SIUL_PSMI_8B_tag PSMI43; /* offset: 0x052B size: 8 bit */
1790  SIUL_PSMI_8B_tag PSMI44; /* offset: 0x052C size: 8 bit */
1791  SIUL_PSMI_8B_tag PSMI45; /* offset: 0x052D size: 8 bit */
1792  SIUL_PSMI_8B_tag PSMI46; /* offset: 0x052E size: 8 bit */
1793  SIUL_PSMI_8B_tag PSMI47; /* offset: 0x052F size: 8 bit */
1794  SIUL_PSMI_8B_tag PSMI48; /* offset: 0x0530 size: 8 bit */
1795  SIUL_PSMI_8B_tag PSMI49; /* offset: 0x0531 size: 8 bit */
1796  SIUL_PSMI_8B_tag PSMI50; /* offset: 0x0532 size: 8 bit */
1797  SIUL_PSMI_8B_tag PSMI51; /* offset: 0x0533 size: 8 bit */
1798  SIUL_PSMI_8B_tag PSMI52; /* offset: 0x0534 size: 8 bit */
1799  SIUL_PSMI_8B_tag PSMI53; /* offset: 0x0535 size: 8 bit */
1800  SIUL_PSMI_8B_tag PSMI54; /* offset: 0x0536 size: 8 bit */
1801  SIUL_PSMI_8B_tag PSMI55; /* offset: 0x0537 size: 8 bit */
1802  SIUL_PSMI_8B_tag PSMI56; /* offset: 0x0538 size: 8 bit */
1803  SIUL_PSMI_8B_tag PSMI57; /* offset: 0x0539 size: 8 bit */
1804  SIUL_PSMI_8B_tag PSMI58; /* offset: 0x053A size: 8 bit */
1805  SIUL_PSMI_8B_tag PSMI59; /* offset: 0x053B size: 8 bit */
1806  SIUL_PSMI_8B_tag PSMI60; /* offset: 0x053C size: 8 bit */
1807  SIUL_PSMI_8B_tag PSMI61; /* offset: 0x053D size: 8 bit */
1808  SIUL_PSMI_8B_tag PSMI62; /* offset: 0x053E size: 8 bit */
1809  SIUL_PSMI_8B_tag PSMI63; /* offset: 0x053F size: 8 bit */
1810  SIUL_PSMI_8B_tag PSMI64; /* offset: 0x0540 size: 8 bit */
1811  SIUL_PSMI_8B_tag PSMI65; /* offset: 0x0541 size: 8 bit */
1812  SIUL_PSMI_8B_tag PSMI66; /* offset: 0x0542 size: 8 bit */
1813  SIUL_PSMI_8B_tag PSMI67; /* offset: 0x0543 size: 8 bit */
1814  SIUL_PSMI_8B_tag PSMI68; /* offset: 0x0544 size: 8 bit */
1815  SIUL_PSMI_8B_tag PSMI69; /* offset: 0x0545 size: 8 bit */
1816  SIUL_PSMI_8B_tag PSMI70; /* offset: 0x0546 size: 8 bit */
1817  SIUL_PSMI_8B_tag PSMI71; /* offset: 0x0547 size: 8 bit */
1818  SIUL_PSMI_8B_tag PSMI72; /* offset: 0x0548 size: 8 bit */
1819  SIUL_PSMI_8B_tag PSMI73; /* offset: 0x0549 size: 8 bit */
1820  SIUL_PSMI_8B_tag PSMI74; /* offset: 0x054A size: 8 bit */
1821  SIUL_PSMI_8B_tag PSMI75; /* offset: 0x054B size: 8 bit */
1822  SIUL_PSMI_8B_tag PSMI76; /* offset: 0x054C size: 8 bit */
1823  SIUL_PSMI_8B_tag PSMI77; /* offset: 0x054D size: 8 bit */
1824  SIUL_PSMI_8B_tag PSMI78; /* offset: 0x054E size: 8 bit */
1825  SIUL_PSMI_8B_tag PSMI79; /* offset: 0x054F size: 8 bit */
1826  SIUL_PSMI_8B_tag PSMI80; /* offset: 0x0550 size: 8 bit */
1827  SIUL_PSMI_8B_tag PSMI81; /* offset: 0x0551 size: 8 bit */
1828  SIUL_PSMI_8B_tag PSMI82; /* offset: 0x0552 size: 8 bit */
1829  SIUL_PSMI_8B_tag PSMI83; /* offset: 0x0553 size: 8 bit */
1830  SIUL_PSMI_8B_tag PSMI84; /* offset: 0x0554 size: 8 bit */
1831  SIUL_PSMI_8B_tag PSMI85; /* offset: 0x0555 size: 8 bit */
1832  SIUL_PSMI_8B_tag PSMI86; /* offset: 0x0556 size: 8 bit */
1833  SIUL_PSMI_8B_tag PSMI87; /* offset: 0x0557 size: 8 bit */
1834  SIUL_PSMI_8B_tag PSMI88; /* offset: 0x0558 size: 8 bit */
1835  SIUL_PSMI_8B_tag PSMI89; /* offset: 0x0559 size: 8 bit */
1836  SIUL_PSMI_8B_tag PSMI90; /* offset: 0x055A size: 8 bit */
1837  SIUL_PSMI_8B_tag PSMI91; /* offset: 0x055B size: 8 bit */
1838  SIUL_PSMI_8B_tag PSMI92; /* offset: 0x055C size: 8 bit */
1839  SIUL_PSMI_8B_tag PSMI93; /* offset: 0x055D size: 8 bit */
1840  SIUL_PSMI_8B_tag PSMI94; /* offset: 0x055E size: 8 bit */
1841  SIUL_PSMI_8B_tag PSMI95; /* offset: 0x055F size: 8 bit */
1842  SIUL_PSMI_8B_tag PSMI96; /* offset: 0x0560 size: 8 bit */
1843  SIUL_PSMI_8B_tag PSMI97; /* offset: 0x0561 size: 8 bit */
1844  SIUL_PSMI_8B_tag PSMI98; /* offset: 0x0562 size: 8 bit */
1845  SIUL_PSMI_8B_tag PSMI99; /* offset: 0x0563 size: 8 bit */
1846  SIUL_PSMI_8B_tag PSMI100; /* offset: 0x0564 size: 8 bit */
1847  SIUL_PSMI_8B_tag PSMI101; /* offset: 0x0565 size: 8 bit */
1848  SIUL_PSMI_8B_tag PSMI102; /* offset: 0x0566 size: 8 bit */
1849  SIUL_PSMI_8B_tag PSMI103; /* offset: 0x0567 size: 8 bit */
1850  SIUL_PSMI_8B_tag PSMI104; /* offset: 0x0568 size: 8 bit */
1851  SIUL_PSMI_8B_tag PSMI105; /* offset: 0x0569 size: 8 bit */
1852  SIUL_PSMI_8B_tag PSMI106; /* offset: 0x056A size: 8 bit */
1853  SIUL_PSMI_8B_tag PSMI107; /* offset: 0x056B size: 8 bit */
1854  SIUL_PSMI_8B_tag PSMI108; /* offset: 0x056C size: 8 bit */
1855  SIUL_PSMI_8B_tag PSMI109; /* offset: 0x056D size: 8 bit */
1856  SIUL_PSMI_8B_tag PSMI110; /* offset: 0x056E size: 8 bit */
1857  SIUL_PSMI_8B_tag PSMI111; /* offset: 0x056F size: 8 bit */
1858  SIUL_PSMI_8B_tag PSMI112; /* offset: 0x0570 size: 8 bit */
1859  SIUL_PSMI_8B_tag PSMI113; /* offset: 0x0571 size: 8 bit */
1860  SIUL_PSMI_8B_tag PSMI114; /* offset: 0x0572 size: 8 bit */
1861  SIUL_PSMI_8B_tag PSMI115; /* offset: 0x0573 size: 8 bit */
1862  SIUL_PSMI_8B_tag PSMI116; /* offset: 0x0574 size: 8 bit */
1863  SIUL_PSMI_8B_tag PSMI117; /* offset: 0x0575 size: 8 bit */
1864  SIUL_PSMI_8B_tag PSMI118; /* offset: 0x0576 size: 8 bit */
1865  SIUL_PSMI_8B_tag PSMI119; /* offset: 0x0577 size: 8 bit */
1866  SIUL_PSMI_8B_tag PSMI120; /* offset: 0x0578 size: 8 bit */
1867  SIUL_PSMI_8B_tag PSMI121; /* offset: 0x0579 size: 8 bit */
1868  SIUL_PSMI_8B_tag PSMI122; /* offset: 0x057A size: 8 bit */
1869  SIUL_PSMI_8B_tag PSMI123; /* offset: 0x057B size: 8 bit */
1870  SIUL_PSMI_8B_tag PSMI124; /* offset: 0x057C size: 8 bit */
1871  SIUL_PSMI_8B_tag PSMI125; /* offset: 0x057D size: 8 bit */
1872  SIUL_PSMI_8B_tag PSMI126; /* offset: 0x057E size: 8 bit */
1873  SIUL_PSMI_8B_tag PSMI127; /* offset: 0x057F size: 8 bit */
1874  SIUL_PSMI_8B_tag PSMI128; /* offset: 0x0580 size: 8 bit */
1875  SIUL_PSMI_8B_tag PSMI129; /* offset: 0x0581 size: 8 bit */
1876  SIUL_PSMI_8B_tag PSMI130; /* offset: 0x0582 size: 8 bit */
1877  SIUL_PSMI_8B_tag PSMI131; /* offset: 0x0583 size: 8 bit */
1878  SIUL_PSMI_8B_tag PSMI132; /* offset: 0x0584 size: 8 bit */
1879  SIUL_PSMI_8B_tag PSMI133; /* offset: 0x0585 size: 8 bit */
1880  SIUL_PSMI_8B_tag PSMI134; /* offset: 0x0586 size: 8 bit */
1881  SIUL_PSMI_8B_tag PSMI135; /* offset: 0x0587 size: 8 bit */
1882  SIUL_PSMI_8B_tag PSMI136; /* offset: 0x0588 size: 8 bit */
1883  SIUL_PSMI_8B_tag PSMI137; /* offset: 0x0589 size: 8 bit */
1884  SIUL_PSMI_8B_tag PSMI138; /* offset: 0x058A size: 8 bit */
1885  SIUL_PSMI_8B_tag PSMI139; /* offset: 0x058B size: 8 bit */
1886  SIUL_PSMI_8B_tag PSMI140; /* offset: 0x058C size: 8 bit */
1887  SIUL_PSMI_8B_tag PSMI141; /* offset: 0x058D size: 8 bit */
1888  SIUL_PSMI_8B_tag PSMI142; /* offset: 0x058E size: 8 bit */
1889  SIUL_PSMI_8B_tag PSMI143; /* offset: 0x058F size: 8 bit */
1890  SIUL_PSMI_8B_tag PSMI144; /* offset: 0x0590 size: 8 bit */
1891  SIUL_PSMI_8B_tag PSMI145; /* offset: 0x0591 size: 8 bit */
1892  SIUL_PSMI_8B_tag PSMI146; /* offset: 0x0592 size: 8 bit */
1893  SIUL_PSMI_8B_tag PSMI147; /* offset: 0x0593 size: 8 bit */
1894  SIUL_PSMI_8B_tag PSMI148; /* offset: 0x0594 size: 8 bit */
1895  SIUL_PSMI_8B_tag PSMI149; /* offset: 0x0595 size: 8 bit */
1896  SIUL_PSMI_8B_tag PSMI150; /* offset: 0x0596 size: 8 bit */
1897  SIUL_PSMI_8B_tag PSMI151; /* offset: 0x0597 size: 8 bit */
1898  SIUL_PSMI_8B_tag PSMI152; /* offset: 0x0598 size: 8 bit */
1899  SIUL_PSMI_8B_tag PSMI153; /* offset: 0x0599 size: 8 bit */
1900  SIUL_PSMI_8B_tag PSMI154; /* offset: 0x059A size: 8 bit */
1901  SIUL_PSMI_8B_tag PSMI155; /* offset: 0x059B size: 8 bit */
1902  SIUL_PSMI_8B_tag PSMI156; /* offset: 0x059C size: 8 bit */
1903  SIUL_PSMI_8B_tag PSMI157; /* offset: 0x059D size: 8 bit */
1904  SIUL_PSMI_8B_tag PSMI158; /* offset: 0x059E size: 8 bit */
1905  SIUL_PSMI_8B_tag PSMI159; /* offset: 0x059F size: 8 bit */
1906  SIUL_PSMI_8B_tag PSMI160; /* offset: 0x05A0 size: 8 bit */
1907  SIUL_PSMI_8B_tag PSMI161; /* offset: 0x05A1 size: 8 bit */
1908  SIUL_PSMI_8B_tag PSMI162; /* offset: 0x05A2 size: 8 bit */
1909  SIUL_PSMI_8B_tag PSMI163; /* offset: 0x05A3 size: 8 bit */
1910  SIUL_PSMI_8B_tag PSMI164; /* offset: 0x05A4 size: 8 bit */
1911  SIUL_PSMI_8B_tag PSMI165; /* offset: 0x05A5 size: 8 bit */
1912  SIUL_PSMI_8B_tag PSMI166; /* offset: 0x05A6 size: 8 bit */
1913  SIUL_PSMI_8B_tag PSMI167; /* offset: 0x05A7 size: 8 bit */
1914  SIUL_PSMI_8B_tag PSMI168; /* offset: 0x05A8 size: 8 bit */
1915  SIUL_PSMI_8B_tag PSMI169; /* offset: 0x05A9 size: 8 bit */
1916  SIUL_PSMI_8B_tag PSMI170; /* offset: 0x05AA size: 8 bit */
1917  SIUL_PSMI_8B_tag PSMI171; /* offset: 0x05AB size: 8 bit */
1918  SIUL_PSMI_8B_tag PSMI172; /* offset: 0x05AC size: 8 bit */
1919  SIUL_PSMI_8B_tag PSMI173; /* offset: 0x05AD size: 8 bit */
1920  SIUL_PSMI_8B_tag PSMI174; /* offset: 0x05AE size: 8 bit */
1921  SIUL_PSMI_8B_tag PSMI175; /* offset: 0x05AF size: 8 bit */
1922  SIUL_PSMI_8B_tag PSMI176; /* offset: 0x05B0 size: 8 bit */
1923  SIUL_PSMI_8B_tag PSMI177; /* offset: 0x05B1 size: 8 bit */
1924  SIUL_PSMI_8B_tag PSMI178; /* offset: 0x05B2 size: 8 bit */
1925  SIUL_PSMI_8B_tag PSMI179; /* offset: 0x05B3 size: 8 bit */
1926  SIUL_PSMI_8B_tag PSMI180; /* offset: 0x05B4 size: 8 bit */
1927  SIUL_PSMI_8B_tag PSMI181; /* offset: 0x05B5 size: 8 bit */
1928  SIUL_PSMI_8B_tag PSMI182; /* offset: 0x05B6 size: 8 bit */
1929  SIUL_PSMI_8B_tag PSMI183; /* offset: 0x05B7 size: 8 bit */
1930  SIUL_PSMI_8B_tag PSMI184; /* offset: 0x05B8 size: 8 bit */
1931  SIUL_PSMI_8B_tag PSMI185; /* offset: 0x05B9 size: 8 bit */
1932  SIUL_PSMI_8B_tag PSMI186; /* offset: 0x05BA size: 8 bit */
1933  SIUL_PSMI_8B_tag PSMI187; /* offset: 0x05BB size: 8 bit */
1934  SIUL_PSMI_8B_tag PSMI188; /* offset: 0x05BC size: 8 bit */
1935  SIUL_PSMI_8B_tag PSMI189; /* offset: 0x05BD size: 8 bit */
1936  SIUL_PSMI_8B_tag PSMI190; /* offset: 0x05BE size: 8 bit */
1937  SIUL_PSMI_8B_tag PSMI191; /* offset: 0x05BF size: 8 bit */
1938  SIUL_PSMI_8B_tag PSMI192; /* offset: 0x05C0 size: 8 bit */
1939  SIUL_PSMI_8B_tag PSMI193; /* offset: 0x05C1 size: 8 bit */
1940  SIUL_PSMI_8B_tag PSMI194; /* offset: 0x05C2 size: 8 bit */
1941  SIUL_PSMI_8B_tag PSMI195; /* offset: 0x05C3 size: 8 bit */
1942  SIUL_PSMI_8B_tag PSMI196; /* offset: 0x05C4 size: 8 bit */
1943  SIUL_PSMI_8B_tag PSMI197; /* offset: 0x05C5 size: 8 bit */
1944  SIUL_PSMI_8B_tag PSMI198; /* offset: 0x05C6 size: 8 bit */
1945  SIUL_PSMI_8B_tag PSMI199; /* offset: 0x05C7 size: 8 bit */
1946  SIUL_PSMI_8B_tag PSMI200; /* offset: 0x05C8 size: 8 bit */
1947  SIUL_PSMI_8B_tag PSMI201; /* offset: 0x05C9 size: 8 bit */
1948  SIUL_PSMI_8B_tag PSMI202; /* offset: 0x05CA size: 8 bit */
1949  SIUL_PSMI_8B_tag PSMI203; /* offset: 0x05CB size: 8 bit */
1950  SIUL_PSMI_8B_tag PSMI204; /* offset: 0x05CC size: 8 bit */
1951  SIUL_PSMI_8B_tag PSMI205; /* offset: 0x05CD size: 8 bit */
1952  SIUL_PSMI_8B_tag PSMI206; /* offset: 0x05CE size: 8 bit */
1953  SIUL_PSMI_8B_tag PSMI207; /* offset: 0x05CF size: 8 bit */
1954  SIUL_PSMI_8B_tag PSMI208; /* offset: 0x05D0 size: 8 bit */
1955  SIUL_PSMI_8B_tag PSMI209; /* offset: 0x05D1 size: 8 bit */
1956  SIUL_PSMI_8B_tag PSMI210; /* offset: 0x05D2 size: 8 bit */
1957  SIUL_PSMI_8B_tag PSMI211; /* offset: 0x05D3 size: 8 bit */
1958  SIUL_PSMI_8B_tag PSMI212; /* offset: 0x05D4 size: 8 bit */
1959  SIUL_PSMI_8B_tag PSMI213; /* offset: 0x05D5 size: 8 bit */
1960  SIUL_PSMI_8B_tag PSMI214; /* offset: 0x05D6 size: 8 bit */
1961  SIUL_PSMI_8B_tag PSMI215; /* offset: 0x05D7 size: 8 bit */
1962  SIUL_PSMI_8B_tag PSMI216; /* offset: 0x05D8 size: 8 bit */
1963  SIUL_PSMI_8B_tag PSMI217; /* offset: 0x05D9 size: 8 bit */
1964  SIUL_PSMI_8B_tag PSMI218; /* offset: 0x05DA size: 8 bit */
1965  SIUL_PSMI_8B_tag PSMI219; /* offset: 0x05DB size: 8 bit */
1966  SIUL_PSMI_8B_tag PSMI220; /* offset: 0x05DC size: 8 bit */
1967  SIUL_PSMI_8B_tag PSMI221; /* offset: 0x05DD size: 8 bit */
1968  SIUL_PSMI_8B_tag PSMI222; /* offset: 0x05DE size: 8 bit */
1969  SIUL_PSMI_8B_tag PSMI223; /* offset: 0x05DF size: 8 bit */
1970  SIUL_PSMI_8B_tag PSMI224; /* offset: 0x05E0 size: 8 bit */
1971  SIUL_PSMI_8B_tag PSMI225; /* offset: 0x05E1 size: 8 bit */
1972  SIUL_PSMI_8B_tag PSMI226; /* offset: 0x05E2 size: 8 bit */
1973  SIUL_PSMI_8B_tag PSMI227; /* offset: 0x05E3 size: 8 bit */
1974  SIUL_PSMI_8B_tag PSMI228; /* offset: 0x05E4 size: 8 bit */
1975  SIUL_PSMI_8B_tag PSMI229; /* offset: 0x05E5 size: 8 bit */
1976  SIUL_PSMI_8B_tag PSMI230; /* offset: 0x05E6 size: 8 bit */
1977  SIUL_PSMI_8B_tag PSMI231; /* offset: 0x05E7 size: 8 bit */
1978  SIUL_PSMI_8B_tag PSMI232; /* offset: 0x05E8 size: 8 bit */
1979  SIUL_PSMI_8B_tag PSMI233; /* offset: 0x05E9 size: 8 bit */
1980  SIUL_PSMI_8B_tag PSMI234; /* offset: 0x05EA size: 8 bit */
1981  SIUL_PSMI_8B_tag PSMI235; /* offset: 0x05EB size: 8 bit */
1982  SIUL_PSMI_8B_tag PSMI236; /* offset: 0x05EC size: 8 bit */
1983  SIUL_PSMI_8B_tag PSMI237; /* offset: 0x05ED size: 8 bit */
1984  SIUL_PSMI_8B_tag PSMI238; /* offset: 0x05EE size: 8 bit */
1985  SIUL_PSMI_8B_tag PSMI239; /* offset: 0x05EF size: 8 bit */
1986  SIUL_PSMI_8B_tag PSMI240; /* offset: 0x05F0 size: 8 bit */
1987  SIUL_PSMI_8B_tag PSMI241; /* offset: 0x05F1 size: 8 bit */
1988  SIUL_PSMI_8B_tag PSMI242; /* offset: 0x05F2 size: 8 bit */
1989  SIUL_PSMI_8B_tag PSMI243; /* offset: 0x05F3 size: 8 bit */
1990  SIUL_PSMI_8B_tag PSMI244; /* offset: 0x05F4 size: 8 bit */
1991  SIUL_PSMI_8B_tag PSMI245; /* offset: 0x05F5 size: 8 bit */
1992  SIUL_PSMI_8B_tag PSMI246; /* offset: 0x05F6 size: 8 bit */
1993  SIUL_PSMI_8B_tag PSMI247; /* offset: 0x05F7 size: 8 bit */
1994  SIUL_PSMI_8B_tag PSMI248; /* offset: 0x05F8 size: 8 bit */
1995  SIUL_PSMI_8B_tag PSMI249; /* offset: 0x05F9 size: 8 bit */
1996  SIUL_PSMI_8B_tag PSMI250; /* offset: 0x05FA size: 8 bit */
1997  SIUL_PSMI_8B_tag PSMI251; /* offset: 0x05FB size: 8 bit */
1998  SIUL_PSMI_8B_tag PSMI252; /* offset: 0x05FC size: 8 bit */
1999  SIUL_PSMI_8B_tag PSMI253; /* offset: 0x05FD size: 8 bit */
2000  SIUL_PSMI_8B_tag PSMI254; /* offset: 0x05FE size: 8 bit */
2001  SIUL_PSMI_8B_tag PSMI255; /* offset: 0x05FF size: 8 bit */
2002  };
2003
2004  };
2005  union {
2006  /* GPDO - GPIO Pad Data Output Register */
2007  SIUL_GPDO_32B_tag GPDO_32B[128]; /* offset: 0x0600 (0x0004 x 128) */
2008
2009  /* GPDO - GPIO Pad Data Output Register */
2010  SIUL_GPDO_8B_tag GPDO[512]; /* offset: 0x0600 (0x0001 x 512) */
2011
2012  struct {
2013  /* GPDO - GPIO Pad Data Output Register */
2014  SIUL_GPDO_32B_tag GPDO0_3; /* offset: 0x0600 size: 32 bit */
2015  SIUL_GPDO_32B_tag GPDO4_7; /* offset: 0x0604 size: 32 bit */
2016  SIUL_GPDO_32B_tag GPDO8_11; /* offset: 0x0608 size: 32 bit */
2017  SIUL_GPDO_32B_tag GPDO12_15; /* offset: 0x060C size: 32 bit */
2018  SIUL_GPDO_32B_tag GPDO16_19; /* offset: 0x0610 size: 32 bit */
2019  SIUL_GPDO_32B_tag GPDO20_23; /* offset: 0x0614 size: 32 bit */
2020  SIUL_GPDO_32B_tag GPDO24_27; /* offset: 0x0618 size: 32 bit */
2021  SIUL_GPDO_32B_tag GPDO28_31; /* offset: 0x061C size: 32 bit */
2022  SIUL_GPDO_32B_tag GPDO32_35; /* offset: 0x0620 size: 32 bit */
2023  SIUL_GPDO_32B_tag GPDO36_39; /* offset: 0x0624 size: 32 bit */
2024  SIUL_GPDO_32B_tag GPDO40_43; /* offset: 0x0628 size: 32 bit */
2025  SIUL_GPDO_32B_tag GPDO44_47; /* offset: 0x062C size: 32 bit */
2026  SIUL_GPDO_32B_tag GPDO48_51; /* offset: 0x0630 size: 32 bit */
2027  SIUL_GPDO_32B_tag GPDO52_55; /* offset: 0x0634 size: 32 bit */
2028  SIUL_GPDO_32B_tag GPDO56_59; /* offset: 0x0638 size: 32 bit */
2029  SIUL_GPDO_32B_tag GPDO60_63; /* offset: 0x063C size: 32 bit */
2030  SIUL_GPDO_32B_tag GPDO64_67; /* offset: 0x0640 size: 32 bit */
2031  SIUL_GPDO_32B_tag GPDO68_71; /* offset: 0x0644 size: 32 bit */
2032  SIUL_GPDO_32B_tag GPDO72_75; /* offset: 0x0648 size: 32 bit */
2033  SIUL_GPDO_32B_tag GPDO76_79; /* offset: 0x064C size: 32 bit */
2034  SIUL_GPDO_32B_tag GPDO80_83; /* offset: 0x0650 size: 32 bit */
2035  SIUL_GPDO_32B_tag GPDO84_87; /* offset: 0x0654 size: 32 bit */
2036  SIUL_GPDO_32B_tag GPDO88_91; /* offset: 0x0658 size: 32 bit */
2037  SIUL_GPDO_32B_tag GPDO92_95; /* offset: 0x065C size: 32 bit */
2038  SIUL_GPDO_32B_tag GPDO96_99; /* offset: 0x0660 size: 32 bit */
2039  SIUL_GPDO_32B_tag GPDO100_103; /* offset: 0x0664 size: 32 bit */
2040  SIUL_GPDO_32B_tag GPDO104_107; /* offset: 0x0668 size: 32 bit */
2041  SIUL_GPDO_32B_tag GPDO108_111; /* offset: 0x066C size: 32 bit */
2042  SIUL_GPDO_32B_tag GPDO112_115; /* offset: 0x0670 size: 32 bit */
2043  SIUL_GPDO_32B_tag GPDO116_119; /* offset: 0x0674 size: 32 bit */
2044  SIUL_GPDO_32B_tag GPDO120_123; /* offset: 0x0678 size: 32 bit */
2045  SIUL_GPDO_32B_tag GPDO124_127; /* offset: 0x067C size: 32 bit */
2046  SIUL_GPDO_32B_tag GPDO128_131; /* offset: 0x0680 size: 32 bit */
2047  SIUL_GPDO_32B_tag GPDO132_135; /* offset: 0x0684 size: 32 bit */
2048  SIUL_GPDO_32B_tag GPDO136_139; /* offset: 0x0688 size: 32 bit */
2049  SIUL_GPDO_32B_tag GPDO140_143; /* offset: 0x068C size: 32 bit */
2050  SIUL_GPDO_32B_tag GPDO144_147; /* offset: 0x0690 size: 32 bit */
2051  SIUL_GPDO_32B_tag GPDO148_151; /* offset: 0x0694 size: 32 bit */
2052  SIUL_GPDO_32B_tag GPDO152_155; /* offset: 0x0698 size: 32 bit */
2053  SIUL_GPDO_32B_tag GPDO156_159; /* offset: 0x069C size: 32 bit */
2054  SIUL_GPDO_32B_tag GPDO160_163; /* offset: 0x06A0 size: 32 bit */
2055  SIUL_GPDO_32B_tag GPDO164_167; /* offset: 0x06A4 size: 32 bit */
2056  SIUL_GPDO_32B_tag GPDO168_171; /* offset: 0x06A8 size: 32 bit */
2057  SIUL_GPDO_32B_tag GPDO172_175; /* offset: 0x06AC size: 32 bit */
2058  SIUL_GPDO_32B_tag GPDO176_179; /* offset: 0x06B0 size: 32 bit */
2059  SIUL_GPDO_32B_tag GPDO180_183; /* offset: 0x06B4 size: 32 bit */
2060  SIUL_GPDO_32B_tag GPDO184_187; /* offset: 0x06B8 size: 32 bit */
2061  SIUL_GPDO_32B_tag GPDO188_191; /* offset: 0x06BC size: 32 bit */
2062  SIUL_GPDO_32B_tag GPDO192_195; /* offset: 0x06C0 size: 32 bit */
2063  SIUL_GPDO_32B_tag GPDO196_199; /* offset: 0x06C4 size: 32 bit */
2064  SIUL_GPDO_32B_tag GPDO200_203; /* offset: 0x06C8 size: 32 bit */
2065  SIUL_GPDO_32B_tag GPDO204_207; /* offset: 0x06CC size: 32 bit */
2066  SIUL_GPDO_32B_tag GPDO208_211; /* offset: 0x06D0 size: 32 bit */
2067  SIUL_GPDO_32B_tag GPDO212_215; /* offset: 0x06D4 size: 32 bit */
2068  SIUL_GPDO_32B_tag GPDO216_219; /* offset: 0x06D8 size: 32 bit */
2069  SIUL_GPDO_32B_tag GPDO220_223; /* offset: 0x06DC size: 32 bit */
2070  SIUL_GPDO_32B_tag GPDO224_227; /* offset: 0x06E0 size: 32 bit */
2071  SIUL_GPDO_32B_tag GPDO228_231; /* offset: 0x06E4 size: 32 bit */
2072  SIUL_GPDO_32B_tag GPDO232_235; /* offset: 0x06E8 size: 32 bit */
2073  SIUL_GPDO_32B_tag GPDO236_239; /* offset: 0x06EC size: 32 bit */
2074  SIUL_GPDO_32B_tag GPDO240_243; /* offset: 0x06F0 size: 32 bit */
2075  SIUL_GPDO_32B_tag GPDO244_247; /* offset: 0x06F4 size: 32 bit */
2076  SIUL_GPDO_32B_tag GPDO248_251; /* offset: 0x06F8 size: 32 bit */
2077  SIUL_GPDO_32B_tag GPDO252_255; /* offset: 0x06FC size: 32 bit */
2078  SIUL_GPDO_32B_tag GPDO256_259; /* offset: 0x0700 size: 32 bit */
2079  SIUL_GPDO_32B_tag GPDO260_263; /* offset: 0x0704 size: 32 bit */
2080  SIUL_GPDO_32B_tag GPDO264_267; /* offset: 0x0708 size: 32 bit */
2081  SIUL_GPDO_32B_tag GPDO268_271; /* offset: 0x070C size: 32 bit */
2082  SIUL_GPDO_32B_tag GPDO272_275; /* offset: 0x0710 size: 32 bit */
2083  SIUL_GPDO_32B_tag GPDO276_279; /* offset: 0x0714 size: 32 bit */
2084  SIUL_GPDO_32B_tag GPDO280_283; /* offset: 0x0718 size: 32 bit */
2085  SIUL_GPDO_32B_tag GPDO284_287; /* offset: 0x071C size: 32 bit */
2086  SIUL_GPDO_32B_tag GPDO288_291; /* offset: 0x0720 size: 32 bit */
2087  SIUL_GPDO_32B_tag GPDO292_295; /* offset: 0x0724 size: 32 bit */
2088  SIUL_GPDO_32B_tag GPDO296_299; /* offset: 0x0728 size: 32 bit */
2089  SIUL_GPDO_32B_tag GPDO300_303; /* offset: 0x072C size: 32 bit */
2090  SIUL_GPDO_32B_tag GPDO304_307; /* offset: 0x0730 size: 32 bit */
2091  SIUL_GPDO_32B_tag GPDO308_311; /* offset: 0x0734 size: 32 bit */
2092  SIUL_GPDO_32B_tag GPDO312_315; /* offset: 0x0738 size: 32 bit */
2093  SIUL_GPDO_32B_tag GPDO316_319; /* offset: 0x073C size: 32 bit */
2094  SIUL_GPDO_32B_tag GPDO320_323; /* offset: 0x0740 size: 32 bit */
2095  SIUL_GPDO_32B_tag GPDO324_327; /* offset: 0x0744 size: 32 bit */
2096  SIUL_GPDO_32B_tag GPDO328_331; /* offset: 0x0748 size: 32 bit */
2097  SIUL_GPDO_32B_tag GPDO332_335; /* offset: 0x074C size: 32 bit */
2098  SIUL_GPDO_32B_tag GPDO336_339; /* offset: 0x0750 size: 32 bit */
2099  SIUL_GPDO_32B_tag GPDO340_343; /* offset: 0x0754 size: 32 bit */
2100  SIUL_GPDO_32B_tag GPDO344_347; /* offset: 0x0758 size: 32 bit */
2101  SIUL_GPDO_32B_tag GPDO348_351; /* offset: 0x075C size: 32 bit */
2102  SIUL_GPDO_32B_tag GPDO352_355; /* offset: 0x0760 size: 32 bit */
2103  SIUL_GPDO_32B_tag GPDO356_359; /* offset: 0x0764 size: 32 bit */
2104  SIUL_GPDO_32B_tag GPDO360_363; /* offset: 0x0768 size: 32 bit */
2105  SIUL_GPDO_32B_tag GPDO364_367; /* offset: 0x076C size: 32 bit */
2106  SIUL_GPDO_32B_tag GPDO368_371; /* offset: 0x0770 size: 32 bit */
2107  SIUL_GPDO_32B_tag GPDO372_375; /* offset: 0x0774 size: 32 bit */
2108  SIUL_GPDO_32B_tag GPDO376_379; /* offset: 0x0778 size: 32 bit */
2109  SIUL_GPDO_32B_tag GPDO380_383; /* offset: 0x077C size: 32 bit */
2110  SIUL_GPDO_32B_tag GPDO384_387; /* offset: 0x0780 size: 32 bit */
2111  SIUL_GPDO_32B_tag GPDO388_391; /* offset: 0x0784 size: 32 bit */
2112  SIUL_GPDO_32B_tag GPDO392_395; /* offset: 0x0788 size: 32 bit */
2113  SIUL_GPDO_32B_tag GPDO396_399; /* offset: 0x078C size: 32 bit */
2114  SIUL_GPDO_32B_tag GPDO400_403; /* offset: 0x0790 size: 32 bit */
2115  SIUL_GPDO_32B_tag GPDO404_407; /* offset: 0x0794 size: 32 bit */
2116  SIUL_GPDO_32B_tag GPDO408_411; /* offset: 0x0798 size: 32 bit */
2117  SIUL_GPDO_32B_tag GPDO412_415; /* offset: 0x079C size: 32 bit */
2118  SIUL_GPDO_32B_tag GPDO416_419; /* offset: 0x07A0 size: 32 bit */
2119  SIUL_GPDO_32B_tag GPDO420_423; /* offset: 0x07A4 size: 32 bit */
2120  SIUL_GPDO_32B_tag GPDO424_427; /* offset: 0x07A8 size: 32 bit */
2121  SIUL_GPDO_32B_tag GPDO428_431; /* offset: 0x07AC size: 32 bit */
2122  SIUL_GPDO_32B_tag GPDO432_435; /* offset: 0x07B0 size: 32 bit */
2123  SIUL_GPDO_32B_tag GPDO436_439; /* offset: 0x07B4 size: 32 bit */
2124  SIUL_GPDO_32B_tag GPDO440_443; /* offset: 0x07B8 size: 32 bit */
2125  SIUL_GPDO_32B_tag GPDO444_447; /* offset: 0x07BC size: 32 bit */
2126  SIUL_GPDO_32B_tag GPDO448_451; /* offset: 0x07C0 size: 32 bit */
2127  SIUL_GPDO_32B_tag GPDO452_455; /* offset: 0x07C4 size: 32 bit */
2128  SIUL_GPDO_32B_tag GPDO456_459; /* offset: 0x07C8 size: 32 bit */
2129  SIUL_GPDO_32B_tag GPDO460_463; /* offset: 0x07CC size: 32 bit */
2130  SIUL_GPDO_32B_tag GPDO464_467; /* offset: 0x07D0 size: 32 bit */
2131  SIUL_GPDO_32B_tag GPDO468_471; /* offset: 0x07D4 size: 32 bit */
2132  SIUL_GPDO_32B_tag GPDO472_475; /* offset: 0x07D8 size: 32 bit */
2133  SIUL_GPDO_32B_tag GPDO476_479; /* offset: 0x07DC size: 32 bit */
2134  SIUL_GPDO_32B_tag GPDO480_483; /* offset: 0x07E0 size: 32 bit */
2135  SIUL_GPDO_32B_tag GPDO484_487; /* offset: 0x07E4 size: 32 bit */
2136  SIUL_GPDO_32B_tag GPDO488_491; /* offset: 0x07E8 size: 32 bit */
2137  SIUL_GPDO_32B_tag GPDO492_495; /* offset: 0x07EC size: 32 bit */
2138  SIUL_GPDO_32B_tag GPDO496_499; /* offset: 0x07F0 size: 32 bit */
2139  SIUL_GPDO_32B_tag GPDO500_503; /* offset: 0x07F4 size: 32 bit */
2140  SIUL_GPDO_32B_tag GPDO504_507; /* offset: 0x07F8 size: 32 bit */
2141  SIUL_GPDO_32B_tag GPDO508_511; /* offset: 0x07FC size: 32 bit */
2142  };
2143
2144  struct {
2145  /* GPDO - GPIO Pad Data Output Register */
2146  SIUL_GPDO_8B_tag GPDO0; /* offset: 0x0600 size: 8 bit */
2147  SIUL_GPDO_8B_tag GPDO1; /* offset: 0x0601 size: 8 bit */
2148  SIUL_GPDO_8B_tag GPDO2; /* offset: 0x0602 size: 8 bit */
2149  SIUL_GPDO_8B_tag GPDO3; /* offset: 0x0603 size: 8 bit */
2150  SIUL_GPDO_8B_tag GPDO4; /* offset: 0x0604 size: 8 bit */
2151  SIUL_GPDO_8B_tag GPDO5; /* offset: 0x0605 size: 8 bit */
2152  SIUL_GPDO_8B_tag GPDO6; /* offset: 0x0606 size: 8 bit */
2153  SIUL_GPDO_8B_tag GPDO7; /* offset: 0x0607 size: 8 bit */
2154  SIUL_GPDO_8B_tag GPDO8; /* offset: 0x0608 size: 8 bit */
2155  SIUL_GPDO_8B_tag GPDO9; /* offset: 0x0609 size: 8 bit */
2156  SIUL_GPDO_8B_tag GPDO10; /* offset: 0x060A size: 8 bit */
2157  SIUL_GPDO_8B_tag GPDO11; /* offset: 0x060B size: 8 bit */
2158  SIUL_GPDO_8B_tag GPDO12; /* offset: 0x060C size: 8 bit */
2159  SIUL_GPDO_8B_tag GPDO13; /* offset: 0x060D size: 8 bit */
2160  SIUL_GPDO_8B_tag GPDO14; /* offset: 0x060E size: 8 bit */
2161  SIUL_GPDO_8B_tag GPDO15; /* offset: 0x060F size: 8 bit */
2162  SIUL_GPDO_8B_tag GPDO16; /* offset: 0x0610 size: 8 bit */
2163  SIUL_GPDO_8B_tag GPDO17; /* offset: 0x0611 size: 8 bit */
2164  SIUL_GPDO_8B_tag GPDO18; /* offset: 0x0612 size: 8 bit */
2165  SIUL_GPDO_8B_tag GPDO19; /* offset: 0x0613 size: 8 bit */
2166  SIUL_GPDO_8B_tag GPDO20; /* offset: 0x0614 size: 8 bit */
2167  SIUL_GPDO_8B_tag GPDO21; /* offset: 0x0615 size: 8 bit */
2168  SIUL_GPDO_8B_tag GPDO22; /* offset: 0x0616 size: 8 bit */
2169  SIUL_GPDO_8B_tag GPDO23; /* offset: 0x0617 size: 8 bit */
2170  SIUL_GPDO_8B_tag GPDO24; /* offset: 0x0618 size: 8 bit */
2171  SIUL_GPDO_8B_tag GPDO25; /* offset: 0x0619 size: 8 bit */
2172  SIUL_GPDO_8B_tag GPDO26; /* offset: 0x061A size: 8 bit */
2173  SIUL_GPDO_8B_tag GPDO27; /* offset: 0x061B size: 8 bit */
2174  SIUL_GPDO_8B_tag GPDO28; /* offset: 0x061C size: 8 bit */
2175  SIUL_GPDO_8B_tag GPDO29; /* offset: 0x061D size: 8 bit */
2176  SIUL_GPDO_8B_tag GPDO30; /* offset: 0x061E size: 8 bit */
2177  SIUL_GPDO_8B_tag GPDO31; /* offset: 0x061F size: 8 bit */
2178  SIUL_GPDO_8B_tag GPDO32; /* offset: 0x0620 size: 8 bit */
2179  SIUL_GPDO_8B_tag GPDO33; /* offset: 0x0621 size: 8 bit */
2180  SIUL_GPDO_8B_tag GPDO34; /* offset: 0x0622 size: 8 bit */
2181  SIUL_GPDO_8B_tag GPDO35; /* offset: 0x0623 size: 8 bit */
2182  SIUL_GPDO_8B_tag GPDO36; /* offset: 0x0624 size: 8 bit */
2183  SIUL_GPDO_8B_tag GPDO37; /* offset: 0x0625 size: 8 bit */
2184  SIUL_GPDO_8B_tag GPDO38; /* offset: 0x0626 size: 8 bit */
2185  SIUL_GPDO_8B_tag GPDO39; /* offset: 0x0627 size: 8 bit */
2186  SIUL_GPDO_8B_tag GPDO40; /* offset: 0x0628 size: 8 bit */
2187  SIUL_GPDO_8B_tag GPDO41; /* offset: 0x0629 size: 8 bit */
2188  SIUL_GPDO_8B_tag GPDO42; /* offset: 0x062A size: 8 bit */
2189  SIUL_GPDO_8B_tag GPDO43; /* offset: 0x062B size: 8 bit */
2190  SIUL_GPDO_8B_tag GPDO44; /* offset: 0x062C size: 8 bit */
2191  SIUL_GPDO_8B_tag GPDO45; /* offset: 0x062D size: 8 bit */
2192  SIUL_GPDO_8B_tag GPDO46; /* offset: 0x062E size: 8 bit */
2193  SIUL_GPDO_8B_tag GPDO47; /* offset: 0x062F size: 8 bit */
2194  SIUL_GPDO_8B_tag GPDO48; /* offset: 0x0630 size: 8 bit */
2195  SIUL_GPDO_8B_tag GPDO49; /* offset: 0x0631 size: 8 bit */
2196  SIUL_GPDO_8B_tag GPDO50; /* offset: 0x0632 size: 8 bit */
2197  SIUL_GPDO_8B_tag GPDO51; /* offset: 0x0633 size: 8 bit */
2198  SIUL_GPDO_8B_tag GPDO52; /* offset: 0x0634 size: 8 bit */
2199  SIUL_GPDO_8B_tag GPDO53; /* offset: 0x0635 size: 8 bit */
2200  SIUL_GPDO_8B_tag GPDO54; /* offset: 0x0636 size: 8 bit */
2201  SIUL_GPDO_8B_tag GPDO55; /* offset: 0x0637 size: 8 bit */
2202  SIUL_GPDO_8B_tag GPDO56; /* offset: 0x0638 size: 8 bit */
2203  SIUL_GPDO_8B_tag GPDO57; /* offset: 0x0639 size: 8 bit */
2204  SIUL_GPDO_8B_tag GPDO58; /* offset: 0x063A size: 8 bit */
2205  SIUL_GPDO_8B_tag GPDO59; /* offset: 0x063B size: 8 bit */
2206  SIUL_GPDO_8B_tag GPDO60; /* offset: 0x063C size: 8 bit */
2207  SIUL_GPDO_8B_tag GPDO61; /* offset: 0x063D size: 8 bit */
2208  SIUL_GPDO_8B_tag GPDO62; /* offset: 0x063E size: 8 bit */
2209  SIUL_GPDO_8B_tag GPDO63; /* offset: 0x063F size: 8 bit */
2210  SIUL_GPDO_8B_tag GPDO64; /* offset: 0x0640 size: 8 bit */
2211  SIUL_GPDO_8B_tag GPDO65; /* offset: 0x0641 size: 8 bit */
2212  SIUL_GPDO_8B_tag GPDO66; /* offset: 0x0642 size: 8 bit */
2213  SIUL_GPDO_8B_tag GPDO67; /* offset: 0x0643 size: 8 bit */
2214  SIUL_GPDO_8B_tag GPDO68; /* offset: 0x0644 size: 8 bit */
2215  SIUL_GPDO_8B_tag GPDO69; /* offset: 0x0645 size: 8 bit */
2216  SIUL_GPDO_8B_tag GPDO70; /* offset: 0x0646 size: 8 bit */
2217  SIUL_GPDO_8B_tag GPDO71; /* offset: 0x0647 size: 8 bit */
2218  SIUL_GPDO_8B_tag GPDO72; /* offset: 0x0648 size: 8 bit */
2219  SIUL_GPDO_8B_tag GPDO73; /* offset: 0x0649 size: 8 bit */
2220  SIUL_GPDO_8B_tag GPDO74; /* offset: 0x064A size: 8 bit */
2221  SIUL_GPDO_8B_tag GPDO75; /* offset: 0x064B size: 8 bit */
2222  SIUL_GPDO_8B_tag GPDO76; /* offset: 0x064C size: 8 bit */
2223  SIUL_GPDO_8B_tag GPDO77; /* offset: 0x064D size: 8 bit */
2224  SIUL_GPDO_8B_tag GPDO78; /* offset: 0x064E size: 8 bit */
2225  SIUL_GPDO_8B_tag GPDO79; /* offset: 0x064F size: 8 bit */
2226  SIUL_GPDO_8B_tag GPDO80; /* offset: 0x0650 size: 8 bit */
2227  SIUL_GPDO_8B_tag GPDO81; /* offset: 0x0651 size: 8 bit */
2228  SIUL_GPDO_8B_tag GPDO82; /* offset: 0x0652 size: 8 bit */
2229  SIUL_GPDO_8B_tag GPDO83; /* offset: 0x0653 size: 8 bit */
2230  SIUL_GPDO_8B_tag GPDO84; /* offset: 0x0654 size: 8 bit */
2231  SIUL_GPDO_8B_tag GPDO85; /* offset: 0x0655 size: 8 bit */
2232  SIUL_GPDO_8B_tag GPDO86; /* offset: 0x0656 size: 8 bit */
2233  SIUL_GPDO_8B_tag GPDO87; /* offset: 0x0657 size: 8 bit */
2234  SIUL_GPDO_8B_tag GPDO88; /* offset: 0x0658 size: 8 bit */
2235  SIUL_GPDO_8B_tag GPDO89; /* offset: 0x0659 size: 8 bit */
2236  SIUL_GPDO_8B_tag GPDO90; /* offset: 0x065A size: 8 bit */
2237  SIUL_GPDO_8B_tag GPDO91; /* offset: 0x065B size: 8 bit */
2238  SIUL_GPDO_8B_tag GPDO92; /* offset: 0x065C size: 8 bit */
2239  SIUL_GPDO_8B_tag GPDO93; /* offset: 0x065D size: 8 bit */
2240  SIUL_GPDO_8B_tag GPDO94; /* offset: 0x065E size: 8 bit */
2241  SIUL_GPDO_8B_tag GPDO95; /* offset: 0x065F size: 8 bit */
2242  SIUL_GPDO_8B_tag GPDO96; /* offset: 0x0660 size: 8 bit */
2243  SIUL_GPDO_8B_tag GPDO97; /* offset: 0x0661 size: 8 bit */
2244  SIUL_GPDO_8B_tag GPDO98; /* offset: 0x0662 size: 8 bit */
2245  SIUL_GPDO_8B_tag GPDO99; /* offset: 0x0663 size: 8 bit */
2246  SIUL_GPDO_8B_tag GPDO100; /* offset: 0x0664 size: 8 bit */
2247  SIUL_GPDO_8B_tag GPDO101; /* offset: 0x0665 size: 8 bit */
2248  SIUL_GPDO_8B_tag GPDO102; /* offset: 0x0666 size: 8 bit */
2249  SIUL_GPDO_8B_tag GPDO103; /* offset: 0x0667 size: 8 bit */
2250  SIUL_GPDO_8B_tag GPDO104; /* offset: 0x0668 size: 8 bit */
2251  SIUL_GPDO_8B_tag GPDO105; /* offset: 0x0669 size: 8 bit */
2252  SIUL_GPDO_8B_tag GPDO106; /* offset: 0x066A size: 8 bit */
2253  SIUL_GPDO_8B_tag GPDO107; /* offset: 0x066B size: 8 bit */
2254  SIUL_GPDO_8B_tag GPDO108; /* offset: 0x066C size: 8 bit */
2255  SIUL_GPDO_8B_tag GPDO109; /* offset: 0x066D size: 8 bit */
2256  SIUL_GPDO_8B_tag GPDO110; /* offset: 0x066E size: 8 bit */
2257  SIUL_GPDO_8B_tag GPDO111; /* offset: 0x066F size: 8 bit */
2258  SIUL_GPDO_8B_tag GPDO112; /* offset: 0x0670 size: 8 bit */
2259  SIUL_GPDO_8B_tag GPDO113; /* offset: 0x0671 size: 8 bit */
2260  SIUL_GPDO_8B_tag GPDO114; /* offset: 0x0672 size: 8 bit */
2261  SIUL_GPDO_8B_tag GPDO115; /* offset: 0x0673 size: 8 bit */
2262  SIUL_GPDO_8B_tag GPDO116; /* offset: 0x0674 size: 8 bit */
2263  SIUL_GPDO_8B_tag GPDO117; /* offset: 0x0675 size: 8 bit */
2264  SIUL_GPDO_8B_tag GPDO118; /* offset: 0x0676 size: 8 bit */
2265  SIUL_GPDO_8B_tag GPDO119; /* offset: 0x0677 size: 8 bit */
2266  SIUL_GPDO_8B_tag GPDO120; /* offset: 0x0678 size: 8 bit */
2267  SIUL_GPDO_8B_tag GPDO121; /* offset: 0x0679 size: 8 bit */
2268  SIUL_GPDO_8B_tag GPDO122; /* offset: 0x067A size: 8 bit */
2269  SIUL_GPDO_8B_tag GPDO123; /* offset: 0x067B size: 8 bit */
2270  SIUL_GPDO_8B_tag GPDO124; /* offset: 0x067C size: 8 bit */
2271  SIUL_GPDO_8B_tag GPDO125; /* offset: 0x067D size: 8 bit */
2272  SIUL_GPDO_8B_tag GPDO126; /* offset: 0x067E size: 8 bit */
2273  SIUL_GPDO_8B_tag GPDO127; /* offset: 0x067F size: 8 bit */
2274  SIUL_GPDO_8B_tag GPDO128; /* offset: 0x0680 size: 8 bit */
2275  SIUL_GPDO_8B_tag GPDO129; /* offset: 0x0681 size: 8 bit */
2276  SIUL_GPDO_8B_tag GPDO130; /* offset: 0x0682 size: 8 bit */
2277  SIUL_GPDO_8B_tag GPDO131; /* offset: 0x0683 size: 8 bit */
2278  SIUL_GPDO_8B_tag GPDO132; /* offset: 0x0684 size: 8 bit */
2279  SIUL_GPDO_8B_tag GPDO133; /* offset: 0x0685 size: 8 bit */
2280  SIUL_GPDO_8B_tag GPDO134; /* offset: 0x0686 size: 8 bit */
2281  SIUL_GPDO_8B_tag GPDO135; /* offset: 0x0687 size: 8 bit */
2282  SIUL_GPDO_8B_tag GPDO136; /* offset: 0x0688 size: 8 bit */
2283  SIUL_GPDO_8B_tag GPDO137; /* offset: 0x0689 size: 8 bit */
2284  SIUL_GPDO_8B_tag GPDO138; /* offset: 0x068A size: 8 bit */
2285  SIUL_GPDO_8B_tag GPDO139; /* offset: 0x068B size: 8 bit */
2286  SIUL_GPDO_8B_tag GPDO140; /* offset: 0x068C size: 8 bit */
2287  SIUL_GPDO_8B_tag GPDO141; /* offset: 0x068D size: 8 bit */
2288  SIUL_GPDO_8B_tag GPDO142; /* offset: 0x068E size: 8 bit */
2289  SIUL_GPDO_8B_tag GPDO143; /* offset: 0x068F size: 8 bit */
2290  SIUL_GPDO_8B_tag GPDO144; /* offset: 0x0690 size: 8 bit */
2291  SIUL_GPDO_8B_tag GPDO145; /* offset: 0x0691 size: 8 bit */
2292  SIUL_GPDO_8B_tag GPDO146; /* offset: 0x0692 size: 8 bit */
2293  SIUL_GPDO_8B_tag GPDO147; /* offset: 0x0693 size: 8 bit */
2294  SIUL_GPDO_8B_tag GPDO148; /* offset: 0x0694 size: 8 bit */
2295  SIUL_GPDO_8B_tag GPDO149; /* offset: 0x0695 size: 8 bit */
2296  SIUL_GPDO_8B_tag GPDO150; /* offset: 0x0696 size: 8 bit */
2297  SIUL_GPDO_8B_tag GPDO151; /* offset: 0x0697 size: 8 bit */
2298  SIUL_GPDO_8B_tag GPDO152; /* offset: 0x0698 size: 8 bit */
2299  SIUL_GPDO_8B_tag GPDO153; /* offset: 0x0699 size: 8 bit */
2300  SIUL_GPDO_8B_tag GPDO154; /* offset: 0x069A size: 8 bit */
2301  SIUL_GPDO_8B_tag GPDO155; /* offset: 0x069B size: 8 bit */
2302  SIUL_GPDO_8B_tag GPDO156; /* offset: 0x069C size: 8 bit */
2303  SIUL_GPDO_8B_tag GPDO157; /* offset: 0x069D size: 8 bit */
2304  SIUL_GPDO_8B_tag GPDO158; /* offset: 0x069E size: 8 bit */
2305  SIUL_GPDO_8B_tag GPDO159; /* offset: 0x069F size: 8 bit */
2306  SIUL_GPDO_8B_tag GPDO160; /* offset: 0x06A0 size: 8 bit */
2307  SIUL_GPDO_8B_tag GPDO161; /* offset: 0x06A1 size: 8 bit */
2308  SIUL_GPDO_8B_tag GPDO162; /* offset: 0x06A2 size: 8 bit */
2309  SIUL_GPDO_8B_tag GPDO163; /* offset: 0x06A3 size: 8 bit */
2310  SIUL_GPDO_8B_tag GPDO164; /* offset: 0x06A4 size: 8 bit */
2311  SIUL_GPDO_8B_tag GPDO165; /* offset: 0x06A5 size: 8 bit */
2312  SIUL_GPDO_8B_tag GPDO166; /* offset: 0x06A6 size: 8 bit */
2313  SIUL_GPDO_8B_tag GPDO167; /* offset: 0x06A7 size: 8 bit */
2314  SIUL_GPDO_8B_tag GPDO168; /* offset: 0x06A8 size: 8 bit */
2315  SIUL_GPDO_8B_tag GPDO169; /* offset: 0x06A9 size: 8 bit */
2316  SIUL_GPDO_8B_tag GPDO170; /* offset: 0x06AA size: 8 bit */
2317  SIUL_GPDO_8B_tag GPDO171; /* offset: 0x06AB size: 8 bit */
2318  SIUL_GPDO_8B_tag GPDO172; /* offset: 0x06AC size: 8 bit */
2319  SIUL_GPDO_8B_tag GPDO173; /* offset: 0x06AD size: 8 bit */
2320  SIUL_GPDO_8B_tag GPDO174; /* offset: 0x06AE size: 8 bit */
2321  SIUL_GPDO_8B_tag GPDO175; /* offset: 0x06AF size: 8 bit */
2322  SIUL_GPDO_8B_tag GPDO176; /* offset: 0x06B0 size: 8 bit */
2323  SIUL_GPDO_8B_tag GPDO177; /* offset: 0x06B1 size: 8 bit */
2324  SIUL_GPDO_8B_tag GPDO178; /* offset: 0x06B2 size: 8 bit */
2325  SIUL_GPDO_8B_tag GPDO179; /* offset: 0x06B3 size: 8 bit */
2326  SIUL_GPDO_8B_tag GPDO180; /* offset: 0x06B4 size: 8 bit */
2327  SIUL_GPDO_8B_tag GPDO181; /* offset: 0x06B5 size: 8 bit */
2328  SIUL_GPDO_8B_tag GPDO182; /* offset: 0x06B6 size: 8 bit */
2329  SIUL_GPDO_8B_tag GPDO183; /* offset: 0x06B7 size: 8 bit */
2330  SIUL_GPDO_8B_tag GPDO184; /* offset: 0x06B8 size: 8 bit */
2331  SIUL_GPDO_8B_tag GPDO185; /* offset: 0x06B9 size: 8 bit */
2332  SIUL_GPDO_8B_tag GPDO186; /* offset: 0x06BA size: 8 bit */
2333  SIUL_GPDO_8B_tag GPDO187; /* offset: 0x06BB size: 8 bit */
2334  SIUL_GPDO_8B_tag GPDO188; /* offset: 0x06BC size: 8 bit */
2335  SIUL_GPDO_8B_tag GPDO189; /* offset: 0x06BD size: 8 bit */
2336  SIUL_GPDO_8B_tag GPDO190; /* offset: 0x06BE size: 8 bit */
2337  SIUL_GPDO_8B_tag GPDO191; /* offset: 0x06BF size: 8 bit */
2338  SIUL_GPDO_8B_tag GPDO192; /* offset: 0x06C0 size: 8 bit */
2339  SIUL_GPDO_8B_tag GPDO193; /* offset: 0x06C1 size: 8 bit */
2340  SIUL_GPDO_8B_tag GPDO194; /* offset: 0x06C2 size: 8 bit */
2341  SIUL_GPDO_8B_tag GPDO195; /* offset: 0x06C3 size: 8 bit */
2342  SIUL_GPDO_8B_tag GPDO196; /* offset: 0x06C4 size: 8 bit */
2343  SIUL_GPDO_8B_tag GPDO197; /* offset: 0x06C5 size: 8 bit */
2344  SIUL_GPDO_8B_tag GPDO198; /* offset: 0x06C6 size: 8 bit */
2345  SIUL_GPDO_8B_tag GPDO199; /* offset: 0x06C7 size: 8 bit */
2346  SIUL_GPDO_8B_tag GPDO200; /* offset: 0x06C8 size: 8 bit */
2347  SIUL_GPDO_8B_tag GPDO201; /* offset: 0x06C9 size: 8 bit */
2348  SIUL_GPDO_8B_tag GPDO202; /* offset: 0x06CA size: 8 bit */
2349  SIUL_GPDO_8B_tag GPDO203; /* offset: 0x06CB size: 8 bit */
2350  SIUL_GPDO_8B_tag GPDO204; /* offset: 0x06CC size: 8 bit */
2351  SIUL_GPDO_8B_tag GPDO205; /* offset: 0x06CD size: 8 bit */
2352  SIUL_GPDO_8B_tag GPDO206; /* offset: 0x06CE size: 8 bit */
2353  SIUL_GPDO_8B_tag GPDO207; /* offset: 0x06CF size: 8 bit */
2354  SIUL_GPDO_8B_tag GPDO208; /* offset: 0x06D0 size: 8 bit */
2355  SIUL_GPDO_8B_tag GPDO209; /* offset: 0x06D1 size: 8 bit */
2356  SIUL_GPDO_8B_tag GPDO210; /* offset: 0x06D2 size: 8 bit */
2357  SIUL_GPDO_8B_tag GPDO211; /* offset: 0x06D3 size: 8 bit */
2358  SIUL_GPDO_8B_tag GPDO212; /* offset: 0x06D4 size: 8 bit */
2359  SIUL_GPDO_8B_tag GPDO213; /* offset: 0x06D5 size: 8 bit */
2360  SIUL_GPDO_8B_tag GPDO214; /* offset: 0x06D6 size: 8 bit */
2361  SIUL_GPDO_8B_tag GPDO215; /* offset: 0x06D7 size: 8 bit */
2362  SIUL_GPDO_8B_tag GPDO216; /* offset: 0x06D8 size: 8 bit */
2363  SIUL_GPDO_8B_tag GPDO217; /* offset: 0x06D9 size: 8 bit */
2364  SIUL_GPDO_8B_tag GPDO218; /* offset: 0x06DA size: 8 bit */
2365  SIUL_GPDO_8B_tag GPDO219; /* offset: 0x06DB size: 8 bit */
2366  SIUL_GPDO_8B_tag GPDO220; /* offset: 0x06DC size: 8 bit */
2367  SIUL_GPDO_8B_tag GPDO221; /* offset: 0x06DD size: 8 bit */
2368  SIUL_GPDO_8B_tag GPDO222; /* offset: 0x06DE size: 8 bit */
2369  SIUL_GPDO_8B_tag GPDO223; /* offset: 0x06DF size: 8 bit */
2370  SIUL_GPDO_8B_tag GPDO224; /* offset: 0x06E0 size: 8 bit */
2371  SIUL_GPDO_8B_tag GPDO225; /* offset: 0x06E1 size: 8 bit */
2372  SIUL_GPDO_8B_tag GPDO226; /* offset: 0x06E2 size: 8 bit */
2373  SIUL_GPDO_8B_tag GPDO227; /* offset: 0x06E3 size: 8 bit */
2374  SIUL_GPDO_8B_tag GPDO228; /* offset: 0x06E4 size: 8 bit */
2375  SIUL_GPDO_8B_tag GPDO229; /* offset: 0x06E5 size: 8 bit */
2376  SIUL_GPDO_8B_tag GPDO230; /* offset: 0x06E6 size: 8 bit */
2377  SIUL_GPDO_8B_tag GPDO231; /* offset: 0x06E7 size: 8 bit */
2378  SIUL_GPDO_8B_tag GPDO232; /* offset: 0x06E8 size: 8 bit */
2379  SIUL_GPDO_8B_tag GPDO233; /* offset: 0x06E9 size: 8 bit */
2380  SIUL_GPDO_8B_tag GPDO234; /* offset: 0x06EA size: 8 bit */
2381  SIUL_GPDO_8B_tag GPDO235; /* offset: 0x06EB size: 8 bit */
2382  SIUL_GPDO_8B_tag GPDO236; /* offset: 0x06EC size: 8 bit */
2383  SIUL_GPDO_8B_tag GPDO237; /* offset: 0x06ED size: 8 bit */
2384  SIUL_GPDO_8B_tag GPDO238; /* offset: 0x06EE size: 8 bit */
2385  SIUL_GPDO_8B_tag GPDO239; /* offset: 0x06EF size: 8 bit */
2386  SIUL_GPDO_8B_tag GPDO240; /* offset: 0x06F0 size: 8 bit */
2387  SIUL_GPDO_8B_tag GPDO241; /* offset: 0x06F1 size: 8 bit */
2388  SIUL_GPDO_8B_tag GPDO242; /* offset: 0x06F2 size: 8 bit */
2389  SIUL_GPDO_8B_tag GPDO243; /* offset: 0x06F3 size: 8 bit */
2390  SIUL_GPDO_8B_tag GPDO244; /* offset: 0x06F4 size: 8 bit */
2391  SIUL_GPDO_8B_tag GPDO245; /* offset: 0x06F5 size: 8 bit */
2392  SIUL_GPDO_8B_tag GPDO246; /* offset: 0x06F6 size: 8 bit */
2393  SIUL_GPDO_8B_tag GPDO247; /* offset: 0x06F7 size: 8 bit */
2394  SIUL_GPDO_8B_tag GPDO248; /* offset: 0x06F8 size: 8 bit */
2395  SIUL_GPDO_8B_tag GPDO249; /* offset: 0x06F9 size: 8 bit */
2396  SIUL_GPDO_8B_tag GPDO250; /* offset: 0x06FA size: 8 bit */
2397  SIUL_GPDO_8B_tag GPDO251; /* offset: 0x06FB size: 8 bit */
2398  SIUL_GPDO_8B_tag GPDO252; /* offset: 0x06FC size: 8 bit */
2399  SIUL_GPDO_8B_tag GPDO253; /* offset: 0x06FD size: 8 bit */
2400  SIUL_GPDO_8B_tag GPDO254; /* offset: 0x06FE size: 8 bit */
2401  SIUL_GPDO_8B_tag GPDO255; /* offset: 0x06FF size: 8 bit */
2402  SIUL_GPDO_8B_tag GPDO256; /* offset: 0x0700 size: 8 bit */
2403  SIUL_GPDO_8B_tag GPDO257; /* offset: 0x0701 size: 8 bit */
2404  SIUL_GPDO_8B_tag GPDO258; /* offset: 0x0702 size: 8 bit */
2405  SIUL_GPDO_8B_tag GPDO259; /* offset: 0x0703 size: 8 bit */
2406  SIUL_GPDO_8B_tag GPDO260; /* offset: 0x0704 size: 8 bit */
2407  SIUL_GPDO_8B_tag GPDO261; /* offset: 0x0705 size: 8 bit */
2408  SIUL_GPDO_8B_tag GPDO262; /* offset: 0x0706 size: 8 bit */
2409  SIUL_GPDO_8B_tag GPDO263; /* offset: 0x0707 size: 8 bit */
2410  SIUL_GPDO_8B_tag GPDO264; /* offset: 0x0708 size: 8 bit */
2411  SIUL_GPDO_8B_tag GPDO265; /* offset: 0x0709 size: 8 bit */
2412  SIUL_GPDO_8B_tag GPDO266; /* offset: 0x070A size: 8 bit */
2413  SIUL_GPDO_8B_tag GPDO267; /* offset: 0x070B size: 8 bit */
2414  SIUL_GPDO_8B_tag GPDO268; /* offset: 0x070C size: 8 bit */
2415  SIUL_GPDO_8B_tag GPDO269; /* offset: 0x070D size: 8 bit */
2416  SIUL_GPDO_8B_tag GPDO270; /* offset: 0x070E size: 8 bit */
2417  SIUL_GPDO_8B_tag GPDO271; /* offset: 0x070F size: 8 bit */
2418  SIUL_GPDO_8B_tag GPDO272; /* offset: 0x0710 size: 8 bit */
2419  SIUL_GPDO_8B_tag GPDO273; /* offset: 0x0711 size: 8 bit */
2420  SIUL_GPDO_8B_tag GPDO274; /* offset: 0x0712 size: 8 bit */
2421  SIUL_GPDO_8B_tag GPDO275; /* offset: 0x0713 size: 8 bit */
2422  SIUL_GPDO_8B_tag GPDO276; /* offset: 0x0714 size: 8 bit */
2423  SIUL_GPDO_8B_tag GPDO277; /* offset: 0x0715 size: 8 bit */
2424  SIUL_GPDO_8B_tag GPDO278; /* offset: 0x0716 size: 8 bit */
2425  SIUL_GPDO_8B_tag GPDO279; /* offset: 0x0717 size: 8 bit */
2426  SIUL_GPDO_8B_tag GPDO280; /* offset: 0x0718 size: 8 bit */
2427  SIUL_GPDO_8B_tag GPDO281; /* offset: 0x0719 size: 8 bit */
2428  SIUL_GPDO_8B_tag GPDO282; /* offset: 0x071A size: 8 bit */
2429  SIUL_GPDO_8B_tag GPDO283; /* offset: 0x071B size: 8 bit */
2430  SIUL_GPDO_8B_tag GPDO284; /* offset: 0x071C size: 8 bit */
2431  SIUL_GPDO_8B_tag GPDO285; /* offset: 0x071D size: 8 bit */
2432  SIUL_GPDO_8B_tag GPDO286; /* offset: 0x071E size: 8 bit */
2433  SIUL_GPDO_8B_tag GPDO287; /* offset: 0x071F size: 8 bit */
2434  SIUL_GPDO_8B_tag GPDO288; /* offset: 0x0720 size: 8 bit */
2435  SIUL_GPDO_8B_tag GPDO289; /* offset: 0x0721 size: 8 bit */
2436  SIUL_GPDO_8B_tag GPDO290; /* offset: 0x0722 size: 8 bit */
2437  SIUL_GPDO_8B_tag GPDO291; /* offset: 0x0723 size: 8 bit */
2438  SIUL_GPDO_8B_tag GPDO292; /* offset: 0x0724 size: 8 bit */
2439  SIUL_GPDO_8B_tag GPDO293; /* offset: 0x0725 size: 8 bit */
2440  SIUL_GPDO_8B_tag GPDO294; /* offset: 0x0726 size: 8 bit */
2441  SIUL_GPDO_8B_tag GPDO295; /* offset: 0x0727 size: 8 bit */
2442  SIUL_GPDO_8B_tag GPDO296; /* offset: 0x0728 size: 8 bit */
2443  SIUL_GPDO_8B_tag GPDO297; /* offset: 0x0729 size: 8 bit */
2444  SIUL_GPDO_8B_tag GPDO298; /* offset: 0x072A size: 8 bit */
2445  SIUL_GPDO_8B_tag GPDO299; /* offset: 0x072B size: 8 bit */
2446  SIUL_GPDO_8B_tag GPDO300; /* offset: 0x072C size: 8 bit */
2447  SIUL_GPDO_8B_tag GPDO301; /* offset: 0x072D size: 8 bit */
2448  SIUL_GPDO_8B_tag GPDO302; /* offset: 0x072E size: 8 bit */
2449  SIUL_GPDO_8B_tag GPDO303; /* offset: 0x072F size: 8 bit */
2450  SIUL_GPDO_8B_tag GPDO304; /* offset: 0x0730 size: 8 bit */
2451  SIUL_GPDO_8B_tag GPDO305; /* offset: 0x0731 size: 8 bit */
2452  SIUL_GPDO_8B_tag GPDO306; /* offset: 0x0732 size: 8 bit */
2453  SIUL_GPDO_8B_tag GPDO307; /* offset: 0x0733 size: 8 bit */
2454  SIUL_GPDO_8B_tag GPDO308; /* offset: 0x0734 size: 8 bit */
2455  SIUL_GPDO_8B_tag GPDO309; /* offset: 0x0735 size: 8 bit */
2456  SIUL_GPDO_8B_tag GPDO310; /* offset: 0x0736 size: 8 bit */
2457  SIUL_GPDO_8B_tag GPDO311; /* offset: 0x0737 size: 8 bit */
2458  SIUL_GPDO_8B_tag GPDO312; /* offset: 0x0738 size: 8 bit */
2459  SIUL_GPDO_8B_tag GPDO313; /* offset: 0x0739 size: 8 bit */
2460  SIUL_GPDO_8B_tag GPDO314; /* offset: 0x073A size: 8 bit */
2461  SIUL_GPDO_8B_tag GPDO315; /* offset: 0x073B size: 8 bit */
2462  SIUL_GPDO_8B_tag GPDO316; /* offset: 0x073C size: 8 bit */
2463  SIUL_GPDO_8B_tag GPDO317; /* offset: 0x073D size: 8 bit */
2464  SIUL_GPDO_8B_tag GPDO318; /* offset: 0x073E size: 8 bit */
2465  SIUL_GPDO_8B_tag GPDO319; /* offset: 0x073F size: 8 bit */
2466  SIUL_GPDO_8B_tag GPDO320; /* offset: 0x0740 size: 8 bit */
2467  SIUL_GPDO_8B_tag GPDO321; /* offset: 0x0741 size: 8 bit */
2468  SIUL_GPDO_8B_tag GPDO322; /* offset: 0x0742 size: 8 bit */
2469  SIUL_GPDO_8B_tag GPDO323; /* offset: 0x0743 size: 8 bit */
2470  SIUL_GPDO_8B_tag GPDO324; /* offset: 0x0744 size: 8 bit */
2471  SIUL_GPDO_8B_tag GPDO325; /* offset: 0x0745 size: 8 bit */
2472  SIUL_GPDO_8B_tag GPDO326; /* offset: 0x0746 size: 8 bit */
2473  SIUL_GPDO_8B_tag GPDO327; /* offset: 0x0747 size: 8 bit */
2474  SIUL_GPDO_8B_tag GPDO328; /* offset: 0x0748 size: 8 bit */
2475  SIUL_GPDO_8B_tag GPDO329; /* offset: 0x0749 size: 8 bit */
2476  SIUL_GPDO_8B_tag GPDO330; /* offset: 0x074A size: 8 bit */
2477  SIUL_GPDO_8B_tag GPDO331; /* offset: 0x074B size: 8 bit */
2478  SIUL_GPDO_8B_tag GPDO332; /* offset: 0x074C size: 8 bit */
2479  SIUL_GPDO_8B_tag GPDO333; /* offset: 0x074D size: 8 bit */
2480  SIUL_GPDO_8B_tag GPDO334; /* offset: 0x074E size: 8 bit */
2481  SIUL_GPDO_8B_tag GPDO335; /* offset: 0x074F size: 8 bit */
2482  SIUL_GPDO_8B_tag GPDO336; /* offset: 0x0750 size: 8 bit */
2483  SIUL_GPDO_8B_tag GPDO337; /* offset: 0x0751 size: 8 bit */
2484  SIUL_GPDO_8B_tag GPDO338; /* offset: 0x0752 size: 8 bit */
2485  SIUL_GPDO_8B_tag GPDO339; /* offset: 0x0753 size: 8 bit */
2486  SIUL_GPDO_8B_tag GPDO340; /* offset: 0x0754 size: 8 bit */
2487  SIUL_GPDO_8B_tag GPDO341; /* offset: 0x0755 size: 8 bit */
2488  SIUL_GPDO_8B_tag GPDO342; /* offset: 0x0756 size: 8 bit */
2489  SIUL_GPDO_8B_tag GPDO343; /* offset: 0x0757 size: 8 bit */
2490  SIUL_GPDO_8B_tag GPDO344; /* offset: 0x0758 size: 8 bit */
2491  SIUL_GPDO_8B_tag GPDO345; /* offset: 0x0759 size: 8 bit */
2492  SIUL_GPDO_8B_tag GPDO346; /* offset: 0x075A size: 8 bit */
2493  SIUL_GPDO_8B_tag GPDO347; /* offset: 0x075B size: 8 bit */
2494  SIUL_GPDO_8B_tag GPDO348; /* offset: 0x075C size: 8 bit */
2495  SIUL_GPDO_8B_tag GPDO349; /* offset: 0x075D size: 8 bit */
2496  SIUL_GPDO_8B_tag GPDO350; /* offset: 0x075E size: 8 bit */
2497  SIUL_GPDO_8B_tag GPDO351; /* offset: 0x075F size: 8 bit */
2498  SIUL_GPDO_8B_tag GPDO352; /* offset: 0x0760 size: 8 bit */
2499  SIUL_GPDO_8B_tag GPDO353; /* offset: 0x0761 size: 8 bit */
2500  SIUL_GPDO_8B_tag GPDO354; /* offset: 0x0762 size: 8 bit */
2501  SIUL_GPDO_8B_tag GPDO355; /* offset: 0x0763 size: 8 bit */
2502  SIUL_GPDO_8B_tag GPDO356; /* offset: 0x0764 size: 8 bit */
2503  SIUL_GPDO_8B_tag GPDO357; /* offset: 0x0765 size: 8 bit */
2504  SIUL_GPDO_8B_tag GPDO358; /* offset: 0x0766 size: 8 bit */
2505  SIUL_GPDO_8B_tag GPDO359; /* offset: 0x0767 size: 8 bit */
2506  SIUL_GPDO_8B_tag GPDO360; /* offset: 0x0768 size: 8 bit */
2507  SIUL_GPDO_8B_tag GPDO361; /* offset: 0x0769 size: 8 bit */
2508  SIUL_GPDO_8B_tag GPDO362; /* offset: 0x076A size: 8 bit */
2509  SIUL_GPDO_8B_tag GPDO363; /* offset: 0x076B size: 8 bit */
2510  SIUL_GPDO_8B_tag GPDO364; /* offset: 0x076C size: 8 bit */
2511  SIUL_GPDO_8B_tag GPDO365; /* offset: 0x076D size: 8 bit */
2512  SIUL_GPDO_8B_tag GPDO366; /* offset: 0x076E size: 8 bit */
2513  SIUL_GPDO_8B_tag GPDO367; /* offset: 0x076F size: 8 bit */
2514  SIUL_GPDO_8B_tag GPDO368; /* offset: 0x0770 size: 8 bit */
2515  SIUL_GPDO_8B_tag GPDO369; /* offset: 0x0771 size: 8 bit */
2516  SIUL_GPDO_8B_tag GPDO370; /* offset: 0x0772 size: 8 bit */
2517  SIUL_GPDO_8B_tag GPDO371; /* offset: 0x0773 size: 8 bit */
2518  SIUL_GPDO_8B_tag GPDO372; /* offset: 0x0774 size: 8 bit */
2519  SIUL_GPDO_8B_tag GPDO373; /* offset: 0x0775 size: 8 bit */
2520  SIUL_GPDO_8B_tag GPDO374; /* offset: 0x0776 size: 8 bit */
2521  SIUL_GPDO_8B_tag GPDO375; /* offset: 0x0777 size: 8 bit */
2522  SIUL_GPDO_8B_tag GPDO376; /* offset: 0x0778 size: 8 bit */
2523  SIUL_GPDO_8B_tag GPDO377; /* offset: 0x0779 size: 8 bit */
2524  SIUL_GPDO_8B_tag GPDO378; /* offset: 0x077A size: 8 bit */
2525  SIUL_GPDO_8B_tag GPDO379; /* offset: 0x077B size: 8 bit */
2526  SIUL_GPDO_8B_tag GPDO380; /* offset: 0x077C size: 8 bit */
2527  SIUL_GPDO_8B_tag GPDO381; /* offset: 0x077D size: 8 bit */
2528  SIUL_GPDO_8B_tag GPDO382; /* offset: 0x077E size: 8 bit */
2529  SIUL_GPDO_8B_tag GPDO383; /* offset: 0x077F size: 8 bit */
2530  SIUL_GPDO_8B_tag GPDO384; /* offset: 0x0780 size: 8 bit */
2531  SIUL_GPDO_8B_tag GPDO385; /* offset: 0x0781 size: 8 bit */
2532  SIUL_GPDO_8B_tag GPDO386; /* offset: 0x0782 size: 8 bit */
2533  SIUL_GPDO_8B_tag GPDO387; /* offset: 0x0783 size: 8 bit */
2534  SIUL_GPDO_8B_tag GPDO388; /* offset: 0x0784 size: 8 bit */
2535  SIUL_GPDO_8B_tag GPDO389; /* offset: 0x0785 size: 8 bit */
2536  SIUL_GPDO_8B_tag GPDO390; /* offset: 0x0786 size: 8 bit */
2537  SIUL_GPDO_8B_tag GPDO391; /* offset: 0x0787 size: 8 bit */
2538  SIUL_GPDO_8B_tag GPDO392; /* offset: 0x0788 size: 8 bit */
2539  SIUL_GPDO_8B_tag GPDO393; /* offset: 0x0789 size: 8 bit */
2540  SIUL_GPDO_8B_tag GPDO394; /* offset: 0x078A size: 8 bit */
2541  SIUL_GPDO_8B_tag GPDO395; /* offset: 0x078B size: 8 bit */
2542  SIUL_GPDO_8B_tag GPDO396; /* offset: 0x078C size: 8 bit */
2543  SIUL_GPDO_8B_tag GPDO397; /* offset: 0x078D size: 8 bit */
2544  SIUL_GPDO_8B_tag GPDO398; /* offset: 0x078E size: 8 bit */
2545  SIUL_GPDO_8B_tag GPDO399; /* offset: 0x078F size: 8 bit */
2546  SIUL_GPDO_8B_tag GPDO400; /* offset: 0x0790 size: 8 bit */
2547  SIUL_GPDO_8B_tag GPDO401; /* offset: 0x0791 size: 8 bit */
2548  SIUL_GPDO_8B_tag GPDO402; /* offset: 0x0792 size: 8 bit */
2549  SIUL_GPDO_8B_tag GPDO403; /* offset: 0x0793 size: 8 bit */
2550  SIUL_GPDO_8B_tag GPDO404; /* offset: 0x0794 size: 8 bit */
2551  SIUL_GPDO_8B_tag GPDO405; /* offset: 0x0795 size: 8 bit */
2552  SIUL_GPDO_8B_tag GPDO406; /* offset: 0x0796 size: 8 bit */
2553  SIUL_GPDO_8B_tag GPDO407; /* offset: 0x0797 size: 8 bit */
2554  SIUL_GPDO_8B_tag GPDO408; /* offset: 0x0798 size: 8 bit */
2555  SIUL_GPDO_8B_tag GPDO409; /* offset: 0x0799 size: 8 bit */
2556  SIUL_GPDO_8B_tag GPDO410; /* offset: 0x079A size: 8 bit */
2557  SIUL_GPDO_8B_tag GPDO411; /* offset: 0x079B size: 8 bit */
2558  SIUL_GPDO_8B_tag GPDO412; /* offset: 0x079C size: 8 bit */
2559  SIUL_GPDO_8B_tag GPDO413; /* offset: 0x079D size: 8 bit */
2560  SIUL_GPDO_8B_tag GPDO414; /* offset: 0x079E size: 8 bit */
2561  SIUL_GPDO_8B_tag GPDO415; /* offset: 0x079F size: 8 bit */
2562  SIUL_GPDO_8B_tag GPDO416; /* offset: 0x07A0 size: 8 bit */
2563  SIUL_GPDO_8B_tag GPDO417; /* offset: 0x07A1 size: 8 bit */
2564  SIUL_GPDO_8B_tag GPDO418; /* offset: 0x07A2 size: 8 bit */
2565  SIUL_GPDO_8B_tag GPDO419; /* offset: 0x07A3 size: 8 bit */
2566  SIUL_GPDO_8B_tag GPDO420; /* offset: 0x07A4 size: 8 bit */
2567  SIUL_GPDO_8B_tag GPDO421; /* offset: 0x07A5 size: 8 bit */
2568  SIUL_GPDO_8B_tag GPDO422; /* offset: 0x07A6 size: 8 bit */
2569  SIUL_GPDO_8B_tag GPDO423; /* offset: 0x07A7 size: 8 bit */
2570  SIUL_GPDO_8B_tag GPDO424; /* offset: 0x07A8 size: 8 bit */
2571  SIUL_GPDO_8B_tag GPDO425; /* offset: 0x07A9 size: 8 bit */
2572  SIUL_GPDO_8B_tag GPDO426; /* offset: 0x07AA size: 8 bit */
2573  SIUL_GPDO_8B_tag GPDO427; /* offset: 0x07AB size: 8 bit */
2574  SIUL_GPDO_8B_tag GPDO428; /* offset: 0x07AC size: 8 bit */
2575  SIUL_GPDO_8B_tag GPDO429; /* offset: 0x07AD size: 8 bit */
2576  SIUL_GPDO_8B_tag GPDO430; /* offset: 0x07AE size: 8 bit */
2577  SIUL_GPDO_8B_tag GPDO431; /* offset: 0x07AF size: 8 bit */
2578  SIUL_GPDO_8B_tag GPDO432; /* offset: 0x07B0 size: 8 bit */
2579  SIUL_GPDO_8B_tag GPDO433; /* offset: 0x07B1 size: 8 bit */
2580  SIUL_GPDO_8B_tag GPDO434; /* offset: 0x07B2 size: 8 bit */
2581  SIUL_GPDO_8B_tag GPDO435; /* offset: 0x07B3 size: 8 bit */
2582  SIUL_GPDO_8B_tag GPDO436; /* offset: 0x07B4 size: 8 bit */
2583  SIUL_GPDO_8B_tag GPDO437; /* offset: 0x07B5 size: 8 bit */
2584  SIUL_GPDO_8B_tag GPDO438; /* offset: 0x07B6 size: 8 bit */
2585  SIUL_GPDO_8B_tag GPDO439; /* offset: 0x07B7 size: 8 bit */
2586  SIUL_GPDO_8B_tag GPDO440; /* offset: 0x07B8 size: 8 bit */
2587  SIUL_GPDO_8B_tag GPDO441; /* offset: 0x07B9 size: 8 bit */
2588  SIUL_GPDO_8B_tag GPDO442; /* offset: 0x07BA size: 8 bit */
2589  SIUL_GPDO_8B_tag GPDO443; /* offset: 0x07BB size: 8 bit */
2590  SIUL_GPDO_8B_tag GPDO444; /* offset: 0x07BC size: 8 bit */
2591  SIUL_GPDO_8B_tag GPDO445; /* offset: 0x07BD size: 8 bit */
2592  SIUL_GPDO_8B_tag GPDO446; /* offset: 0x07BE size: 8 bit */
2593  SIUL_GPDO_8B_tag GPDO447; /* offset: 0x07BF size: 8 bit */
2594  SIUL_GPDO_8B_tag GPDO448; /* offset: 0x07C0 size: 8 bit */
2595  SIUL_GPDO_8B_tag GPDO449; /* offset: 0x07C1 size: 8 bit */
2596  SIUL_GPDO_8B_tag GPDO450; /* offset: 0x07C2 size: 8 bit */
2597  SIUL_GPDO_8B_tag GPDO451; /* offset: 0x07C3 size: 8 bit */
2598  SIUL_GPDO_8B_tag GPDO452; /* offset: 0x07C4 size: 8 bit */
2599  SIUL_GPDO_8B_tag GPDO453; /* offset: 0x07C5 size: 8 bit */
2600  SIUL_GPDO_8B_tag GPDO454; /* offset: 0x07C6 size: 8 bit */
2601  SIUL_GPDO_8B_tag GPDO455; /* offset: 0x07C7 size: 8 bit */
2602  SIUL_GPDO_8B_tag GPDO456; /* offset: 0x07C8 size: 8 bit */
2603  SIUL_GPDO_8B_tag GPDO457; /* offset: 0x07C9 size: 8 bit */
2604  SIUL_GPDO_8B_tag GPDO458; /* offset: 0x07CA size: 8 bit */
2605  SIUL_GPDO_8B_tag GPDO459; /* offset: 0x07CB size: 8 bit */
2606  SIUL_GPDO_8B_tag GPDO460; /* offset: 0x07CC size: 8 bit */
2607  SIUL_GPDO_8B_tag GPDO461; /* offset: 0x07CD size: 8 bit */
2608  SIUL_GPDO_8B_tag GPDO462; /* offset: 0x07CE size: 8 bit */
2609  SIUL_GPDO_8B_tag GPDO463; /* offset: 0x07CF size: 8 bit */
2610  SIUL_GPDO_8B_tag GPDO464; /* offset: 0x07D0 size: 8 bit */
2611  SIUL_GPDO_8B_tag GPDO465; /* offset: 0x07D1 size: 8 bit */
2612  SIUL_GPDO_8B_tag GPDO466; /* offset: 0x07D2 size: 8 bit */
2613  SIUL_GPDO_8B_tag GPDO467; /* offset: 0x07D3 size: 8 bit */
2614  SIUL_GPDO_8B_tag GPDO468; /* offset: 0x07D4 size: 8 bit */
2615  SIUL_GPDO_8B_tag GPDO469; /* offset: 0x07D5 size: 8 bit */
2616  SIUL_GPDO_8B_tag GPDO470; /* offset: 0x07D6 size: 8 bit */
2617  SIUL_GPDO_8B_tag GPDO471; /* offset: 0x07D7 size: 8 bit */
2618  SIUL_GPDO_8B_tag GPDO472; /* offset: 0x07D8 size: 8 bit */
2619  SIUL_GPDO_8B_tag GPDO473; /* offset: 0x07D9 size: 8 bit */
2620  SIUL_GPDO_8B_tag GPDO474; /* offset: 0x07DA size: 8 bit */
2621  SIUL_GPDO_8B_tag GPDO475; /* offset: 0x07DB size: 8 bit */
2622  SIUL_GPDO_8B_tag GPDO476; /* offset: 0x07DC size: 8 bit */
2623  SIUL_GPDO_8B_tag GPDO477; /* offset: 0x07DD size: 8 bit */
2624  SIUL_GPDO_8B_tag GPDO478; /* offset: 0x07DE size: 8 bit */
2625  SIUL_GPDO_8B_tag GPDO479; /* offset: 0x07DF size: 8 bit */
2626  SIUL_GPDO_8B_tag GPDO480; /* offset: 0x07E0 size: 8 bit */
2627  SIUL_GPDO_8B_tag GPDO481; /* offset: 0x07E1 size: 8 bit */
2628  SIUL_GPDO_8B_tag GPDO482; /* offset: 0x07E2 size: 8 bit */
2629  SIUL_GPDO_8B_tag GPDO483; /* offset: 0x07E3 size: 8 bit */
2630  SIUL_GPDO_8B_tag GPDO484; /* offset: 0x07E4 size: 8 bit */
2631  SIUL_GPDO_8B_tag GPDO485; /* offset: 0x07E5 size: 8 bit */
2632  SIUL_GPDO_8B_tag GPDO486; /* offset: 0x07E6 size: 8 bit */
2633  SIUL_GPDO_8B_tag GPDO487; /* offset: 0x07E7 size: 8 bit */
2634  SIUL_GPDO_8B_tag GPDO488; /* offset: 0x07E8 size: 8 bit */
2635  SIUL_GPDO_8B_tag GPDO489; /* offset: 0x07E9 size: 8 bit */
2636  SIUL_GPDO_8B_tag GPDO490; /* offset: 0x07EA size: 8 bit */
2637  SIUL_GPDO_8B_tag GPDO491; /* offset: 0x07EB size: 8 bit */
2638  SIUL_GPDO_8B_tag GPDO492; /* offset: 0x07EC size: 8 bit */
2639  SIUL_GPDO_8B_tag GPDO493; /* offset: 0x07ED size: 8 bit */
2640  SIUL_GPDO_8B_tag GPDO494; /* offset: 0x07EE size: 8 bit */
2641  SIUL_GPDO_8B_tag GPDO495; /* offset: 0x07EF size: 8 bit */
2642  SIUL_GPDO_8B_tag GPDO496; /* offset: 0x07F0 size: 8 bit */
2643  SIUL_GPDO_8B_tag GPDO497; /* offset: 0x07F1 size: 8 bit */
2644  SIUL_GPDO_8B_tag GPDO498; /* offset: 0x07F2 size: 8 bit */
2645  SIUL_GPDO_8B_tag GPDO499; /* offset: 0x07F3 size: 8 bit */
2646  SIUL_GPDO_8B_tag GPDO500; /* offset: 0x07F4 size: 8 bit */
2647  SIUL_GPDO_8B_tag GPDO501; /* offset: 0x07F5 size: 8 bit */
2648  SIUL_GPDO_8B_tag GPDO502; /* offset: 0x07F6 size: 8 bit */
2649  SIUL_GPDO_8B_tag GPDO503; /* offset: 0x07F7 size: 8 bit */
2650  SIUL_GPDO_8B_tag GPDO504; /* offset: 0x07F8 size: 8 bit */
2651  SIUL_GPDO_8B_tag GPDO505; /* offset: 0x07F9 size: 8 bit */
2652  SIUL_GPDO_8B_tag GPDO506; /* offset: 0x07FA size: 8 bit */
2653  SIUL_GPDO_8B_tag GPDO507; /* offset: 0x07FB size: 8 bit */
2654  SIUL_GPDO_8B_tag GPDO508; /* offset: 0x07FC size: 8 bit */
2655  SIUL_GPDO_8B_tag GPDO509; /* offset: 0x07FD size: 8 bit */
2656  SIUL_GPDO_8B_tag GPDO510; /* offset: 0x07FE size: 8 bit */
2657  SIUL_GPDO_8B_tag GPDO511; /* offset: 0x07FF size: 8 bit */
2658  };
2659
2660  };
2661  union {
2662  /* GPDI - GPIO Pad Data Input Register */
2663  SIUL_GPDI_32B_tag GPDI_32B[128]; /* offset: 0x0800 (0x0004 x 128) */
2664
2665  /* GPDI - GPIO Pad Data Input Register */
2666  SIUL_GPDI_8B_tag GPDI[512]; /* offset: 0x0800 (0x0001 x 512) */
2667
2668  struct {
2669  /* GPDI - GPIO Pad Data Input Register */
2670  SIUL_GPDI_32B_tag GPDI0_3; /* offset: 0x0800 size: 32 bit */
2671  SIUL_GPDI_32B_tag GPDI4_7; /* offset: 0x0804 size: 32 bit */
2672  SIUL_GPDI_32B_tag GPDI8_11; /* offset: 0x0808 size: 32 bit */
2673  SIUL_GPDI_32B_tag GPDI12_15; /* offset: 0x080C size: 32 bit */
2674  SIUL_GPDI_32B_tag GPDI16_19; /* offset: 0x0810 size: 32 bit */
2675  SIUL_GPDI_32B_tag GPDI20_23; /* offset: 0x0814 size: 32 bit */
2676  SIUL_GPDI_32B_tag GPDI24_27; /* offset: 0x0818 size: 32 bit */
2677  SIUL_GPDI_32B_tag GPDI28_31; /* offset: 0x081C size: 32 bit */
2678  SIUL_GPDI_32B_tag GPDI32_35; /* offset: 0x0820 size: 32 bit */
2679  SIUL_GPDI_32B_tag GPDI36_39; /* offset: 0x0824 size: 32 bit */
2680  SIUL_GPDI_32B_tag GPDI40_43; /* offset: 0x0828 size: 32 bit */
2681  SIUL_GPDI_32B_tag GPDI44_47; /* offset: 0x082C size: 32 bit */
2682  SIUL_GPDI_32B_tag GPDI48_51; /* offset: 0x0830 size: 32 bit */
2683  SIUL_GPDI_32B_tag GPDI52_55; /* offset: 0x0834 size: 32 bit */
2684  SIUL_GPDI_32B_tag GPDI56_59; /* offset: 0x0838 size: 32 bit */
2685  SIUL_GPDI_32B_tag GPDI60_63; /* offset: 0x083C size: 32 bit */
2686  SIUL_GPDI_32B_tag GPDI64_67; /* offset: 0x0840 size: 32 bit */
2687  SIUL_GPDI_32B_tag GPDI68_71; /* offset: 0x0844 size: 32 bit */
2688  SIUL_GPDI_32B_tag GPDI72_75; /* offset: 0x0848 size: 32 bit */
2689  SIUL_GPDI_32B_tag GPDI76_79; /* offset: 0x084C size: 32 bit */
2690  SIUL_GPDI_32B_tag GPDI80_83; /* offset: 0x0850 size: 32 bit */
2691  SIUL_GPDI_32B_tag GPDI84_87; /* offset: 0x0854 size: 32 bit */
2692  SIUL_GPDI_32B_tag GPDI88_91; /* offset: 0x0858 size: 32 bit */
2693  SIUL_GPDI_32B_tag GPDI92_95; /* offset: 0x085C size: 32 bit */
2694  SIUL_GPDI_32B_tag GPDI96_99; /* offset: 0x0860 size: 32 bit */
2695  SIUL_GPDI_32B_tag GPDI100_103; /* offset: 0x0864 size: 32 bit */
2696  SIUL_GPDI_32B_tag GPDI104_107; /* offset: 0x0868 size: 32 bit */
2697  SIUL_GPDI_32B_tag GPDI108_111; /* offset: 0x086C size: 32 bit */
2698  SIUL_GPDI_32B_tag GPDI112_115; /* offset: 0x0870 size: 32 bit */
2699  SIUL_GPDI_32B_tag GPDI116_119; /* offset: 0x0874 size: 32 bit */
2700  SIUL_GPDI_32B_tag GPDI120_123; /* offset: 0x0878 size: 32 bit */
2701  SIUL_GPDI_32B_tag GPDI124_127; /* offset: 0x087C size: 32 bit */
2702  SIUL_GPDI_32B_tag GPDI128_131; /* offset: 0x0880 size: 32 bit */
2703  SIUL_GPDI_32B_tag GPDI132_135; /* offset: 0x0884 size: 32 bit */
2704  SIUL_GPDI_32B_tag GPDI136_139; /* offset: 0x0888 size: 32 bit */
2705  SIUL_GPDI_32B_tag GPDI140_143; /* offset: 0x088C size: 32 bit */
2706  SIUL_GPDI_32B_tag GPDI144_147; /* offset: 0x0890 size: 32 bit */
2707  SIUL_GPDI_32B_tag GPDI148_151; /* offset: 0x0894 size: 32 bit */
2708  SIUL_GPDI_32B_tag GPDI152_155; /* offset: 0x0898 size: 32 bit */
2709  SIUL_GPDI_32B_tag GPDI156_159; /* offset: 0x089C size: 32 bit */
2710  SIUL_GPDI_32B_tag GPDI160_163; /* offset: 0x08A0 size: 32 bit */
2711  SIUL_GPDI_32B_tag GPDI164_167; /* offset: 0x08A4 size: 32 bit */
2712  SIUL_GPDI_32B_tag GPDI168_171; /* offset: 0x08A8 size: 32 bit */
2713  SIUL_GPDI_32B_tag GPDI172_175; /* offset: 0x08AC size: 32 bit */
2714  SIUL_GPDI_32B_tag GPDI176_179; /* offset: 0x08B0 size: 32 bit */
2715  SIUL_GPDI_32B_tag GPDI180_183; /* offset: 0x08B4 size: 32 bit */
2716  SIUL_GPDI_32B_tag GPDI184_187; /* offset: 0x08B8 size: 32 bit */
2717  SIUL_GPDI_32B_tag GPDI188_191; /* offset: 0x08BC size: 32 bit */
2718  SIUL_GPDI_32B_tag GPDI192_195; /* offset: 0x08C0 size: 32 bit */
2719  SIUL_GPDI_32B_tag GPDI196_199; /* offset: 0x08C4 size: 32 bit */
2720  SIUL_GPDI_32B_tag GPDI200_203; /* offset: 0x08C8 size: 32 bit */
2721  SIUL_GPDI_32B_tag GPDI204_207; /* offset: 0x08CC size: 32 bit */
2722  SIUL_GPDI_32B_tag GPDI208_211; /* offset: 0x08D0 size: 32 bit */
2723  SIUL_GPDI_32B_tag GPDI212_215; /* offset: 0x08D4 size: 32 bit */
2724  SIUL_GPDI_32B_tag GPDI216_219; /* offset: 0x08D8 size: 32 bit */
2725  SIUL_GPDI_32B_tag GPDI220_223; /* offset: 0x08DC size: 32 bit */
2726  SIUL_GPDI_32B_tag GPDI224_227; /* offset: 0x08E0 size: 32 bit */
2727  SIUL_GPDI_32B_tag GPDI228_231; /* offset: 0x08E4 size: 32 bit */
2728  SIUL_GPDI_32B_tag GPDI232_235; /* offset: 0x08E8 size: 32 bit */
2729  SIUL_GPDI_32B_tag GPDI236_239; /* offset: 0x08EC size: 32 bit */
2730  SIUL_GPDI_32B_tag GPDI240_243; /* offset: 0x08F0 size: 32 bit */
2731  SIUL_GPDI_32B_tag GPDI244_247; /* offset: 0x08F4 size: 32 bit */
2732  SIUL_GPDI_32B_tag GPDI248_251; /* offset: 0x08F8 size: 32 bit */
2733  SIUL_GPDI_32B_tag GPDI252_255; /* offset: 0x08FC size: 32 bit */
2734  SIUL_GPDI_32B_tag GPDI256_259; /* offset: 0x0900 size: 32 bit */
2735  SIUL_GPDI_32B_tag GPDI260_263; /* offset: 0x0904 size: 32 bit */
2736  SIUL_GPDI_32B_tag GPDI264_267; /* offset: 0x0908 size: 32 bit */
2737  SIUL_GPDI_32B_tag GPDI268_271; /* offset: 0x090C size: 32 bit */
2738  SIUL_GPDI_32B_tag GPDI272_275; /* offset: 0x0910 size: 32 bit */
2739  SIUL_GPDI_32B_tag GPDI276_279; /* offset: 0x0914 size: 32 bit */
2740  SIUL_GPDI_32B_tag GPDI280_283; /* offset: 0x0918 size: 32 bit */
2741  SIUL_GPDI_32B_tag GPDI284_287; /* offset: 0x091C size: 32 bit */
2742  SIUL_GPDI_32B_tag GPDI288_291; /* offset: 0x0920 size: 32 bit */
2743  SIUL_GPDI_32B_tag GPDI292_295; /* offset: 0x0924 size: 32 bit */
2744  SIUL_GPDI_32B_tag GPDI296_299; /* offset: 0x0928 size: 32 bit */
2745  SIUL_GPDI_32B_tag GPDI300_303; /* offset: 0x092C size: 32 bit */
2746  SIUL_GPDI_32B_tag GPDI304_307; /* offset: 0x0930 size: 32 bit */
2747  SIUL_GPDI_32B_tag GPDI308_311; /* offset: 0x0934 size: 32 bit */
2748  SIUL_GPDI_32B_tag GPDI312_315; /* offset: 0x0938 size: 32 bit */
2749  SIUL_GPDI_32B_tag GPDI316_319; /* offset: 0x093C size: 32 bit */
2750  SIUL_GPDI_32B_tag GPDI320_323; /* offset: 0x0940 size: 32 bit */
2751  SIUL_GPDI_32B_tag GPDI324_327; /* offset: 0x0944 size: 32 bit */
2752  SIUL_GPDI_32B_tag GPDI328_331; /* offset: 0x0948 size: 32 bit */
2753  SIUL_GPDI_32B_tag GPDI332_335; /* offset: 0x094C size: 32 bit */
2754  SIUL_GPDI_32B_tag GPDI336_339; /* offset: 0x0950 size: 32 bit */
2755  SIUL_GPDI_32B_tag GPDI340_343; /* offset: 0x0954 size: 32 bit */
2756  SIUL_GPDI_32B_tag GPDI344_347; /* offset: 0x0958 size: 32 bit */
2757  SIUL_GPDI_32B_tag GPDI348_351; /* offset: 0x095C size: 32 bit */
2758  SIUL_GPDI_32B_tag GPDI352_355; /* offset: 0x0960 size: 32 bit */
2759  SIUL_GPDI_32B_tag GPDI356_359; /* offset: 0x0964 size: 32 bit */
2760  SIUL_GPDI_32B_tag GPDI360_363; /* offset: 0x0968 size: 32 bit */
2761  SIUL_GPDI_32B_tag GPDI364_367; /* offset: 0x096C size: 32 bit */
2762  SIUL_GPDI_32B_tag GPDI368_371; /* offset: 0x0970 size: 32 bit */
2763  SIUL_GPDI_32B_tag GPDI372_375; /* offset: 0x0974 size: 32 bit */
2764  SIUL_GPDI_32B_tag GPDI376_379; /* offset: 0x0978 size: 32 bit */
2765  SIUL_GPDI_32B_tag GPDI380_383; /* offset: 0x097C size: 32 bit */
2766  SIUL_GPDI_32B_tag GPDI384_387; /* offset: 0x0980 size: 32 bit */
2767  SIUL_GPDI_32B_tag GPDI388_391; /* offset: 0x0984 size: 32 bit */
2768  SIUL_GPDI_32B_tag GPDI392_395; /* offset: 0x0988 size: 32 bit */
2769  SIUL_GPDI_32B_tag GPDI396_399; /* offset: 0x098C size: 32 bit */
2770  SIUL_GPDI_32B_tag GPDI400_403; /* offset: 0x0990 size: 32 bit */
2771  SIUL_GPDI_32B_tag GPDI404_407; /* offset: 0x0994 size: 32 bit */
2772  SIUL_GPDI_32B_tag GPDI408_411; /* offset: 0x0998 size: 32 bit */
2773  SIUL_GPDI_32B_tag GPDI412_415; /* offset: 0x099C size: 32 bit */
2774  SIUL_GPDI_32B_tag GPDI416_419; /* offset: 0x09A0 size: 32 bit */
2775  SIUL_GPDI_32B_tag GPDI420_423; /* offset: 0x09A4 size: 32 bit */
2776  SIUL_GPDI_32B_tag GPDI424_427; /* offset: 0x09A8 size: 32 bit */
2777  SIUL_GPDI_32B_tag GPDI428_431; /* offset: 0x09AC size: 32 bit */
2778  SIUL_GPDI_32B_tag GPDI432_435; /* offset: 0x09B0 size: 32 bit */
2779  SIUL_GPDI_32B_tag GPDI436_439; /* offset: 0x09B4 size: 32 bit */
2780  SIUL_GPDI_32B_tag GPDI440_443; /* offset: 0x09B8 size: 32 bit */
2781  SIUL_GPDI_32B_tag GPDI444_447; /* offset: 0x09BC size: 32 bit */
2782  SIUL_GPDI_32B_tag GPDI448_451; /* offset: 0x09C0 size: 32 bit */
2783  SIUL_GPDI_32B_tag GPDI452_455; /* offset: 0x09C4 size: 32 bit */
2784  SIUL_GPDI_32B_tag GPDI456_459; /* offset: 0x09C8 size: 32 bit */
2785  SIUL_GPDI_32B_tag GPDI460_463; /* offset: 0x09CC size: 32 bit */
2786  SIUL_GPDI_32B_tag GPDI464_467; /* offset: 0x09D0 size: 32 bit */
2787  SIUL_GPDI_32B_tag GPDI468_471; /* offset: 0x09D4 size: 32 bit */
2788  SIUL_GPDI_32B_tag GPDI472_475; /* offset: 0x09D8 size: 32 bit */
2789  SIUL_GPDI_32B_tag GPDI476_479; /* offset: 0x09DC size: 32 bit */
2790  SIUL_GPDI_32B_tag GPDI480_483; /* offset: 0x09E0 size: 32 bit */
2791  SIUL_GPDI_32B_tag GPDI484_487; /* offset: 0x09E4 size: 32 bit */
2792  SIUL_GPDI_32B_tag GPDI488_491; /* offset: 0x09E8 size: 32 bit */
2793  SIUL_GPDI_32B_tag GPDI492_495; /* offset: 0x09EC size: 32 bit */
2794  SIUL_GPDI_32B_tag GPDI496_499; /* offset: 0x09F0 size: 32 bit */
2795  SIUL_GPDI_32B_tag GPDI500_503; /* offset: 0x09F4 size: 32 bit */
2796  SIUL_GPDI_32B_tag GPDI504_507; /* offset: 0x09F8 size: 32 bit */
2797  SIUL_GPDI_32B_tag GPDI508_511; /* offset: 0x09FC size: 32 bit */
2798  };
2799
2800  struct {
2801  /* GPDI - GPIO Pad Data Input Register */
2802  SIUL_GPDI_8B_tag GPDI0; /* offset: 0x0800 size: 8 bit */
2803  SIUL_GPDI_8B_tag GPDI1; /* offset: 0x0801 size: 8 bit */
2804  SIUL_GPDI_8B_tag GPDI2; /* offset: 0x0802 size: 8 bit */
2805  SIUL_GPDI_8B_tag GPDI3; /* offset: 0x0803 size: 8 bit */
2806  SIUL_GPDI_8B_tag GPDI4; /* offset: 0x0804 size: 8 bit */
2807  SIUL_GPDI_8B_tag GPDI5; /* offset: 0x0805 size: 8 bit */
2808  SIUL_GPDI_8B_tag GPDI6; /* offset: 0x0806 size: 8 bit */
2809  SIUL_GPDI_8B_tag GPDI7; /* offset: 0x0807 size: 8 bit */
2810  SIUL_GPDI_8B_tag GPDI8; /* offset: 0x0808 size: 8 bit */
2811  SIUL_GPDI_8B_tag GPDI9; /* offset: 0x0809 size: 8 bit */
2812  SIUL_GPDI_8B_tag GPDI10; /* offset: 0x080A size: 8 bit */
2813  SIUL_GPDI_8B_tag GPDI11; /* offset: 0x080B size: 8 bit */
2814  SIUL_GPDI_8B_tag GPDI12; /* offset: 0x080C size: 8 bit */
2815  SIUL_GPDI_8B_tag GPDI13; /* offset: 0x080D size: 8 bit */
2816  SIUL_GPDI_8B_tag GPDI14; /* offset: 0x080E size: 8 bit */
2817  SIUL_GPDI_8B_tag GPDI15; /* offset: 0x080F size: 8 bit */
2818  SIUL_GPDI_8B_tag GPDI16; /* offset: 0x0810 size: 8 bit */
2819  SIUL_GPDI_8B_tag GPDI17; /* offset: 0x0811 size: 8 bit */
2820  SIUL_GPDI_8B_tag GPDI18; /* offset: 0x0812 size: 8 bit */
2821  SIUL_GPDI_8B_tag GPDI19; /* offset: 0x0813 size: 8 bit */
2822  SIUL_GPDI_8B_tag GPDI20; /* offset: 0x0814 size: 8 bit */
2823  SIUL_GPDI_8B_tag GPDI21; /* offset: 0x0815 size: 8 bit */
2824  SIUL_GPDI_8B_tag GPDI22; /* offset: 0x0816 size: 8 bit */
2825  SIUL_GPDI_8B_tag GPDI23; /* offset: 0x0817 size: 8 bit */
2826  SIUL_GPDI_8B_tag GPDI24; /* offset: 0x0818 size: 8 bit */
2827  SIUL_GPDI_8B_tag GPDI25; /* offset: 0x0819 size: 8 bit */
2828  SIUL_GPDI_8B_tag GPDI26; /* offset: 0x081A size: 8 bit */
2829  SIUL_GPDI_8B_tag GPDI27; /* offset: 0x081B size: 8 bit */
2830  SIUL_GPDI_8B_tag GPDI28; /* offset: 0x081C size: 8 bit */
2831  SIUL_GPDI_8B_tag GPDI29; /* offset: 0x081D size: 8 bit */
2832  SIUL_GPDI_8B_tag GPDI30; /* offset: 0x081E size: 8 bit */
2833  SIUL_GPDI_8B_tag GPDI31; /* offset: 0x081F size: 8 bit */
2834  SIUL_GPDI_8B_tag GPDI32; /* offset: 0x0820 size: 8 bit */
2835  SIUL_GPDI_8B_tag GPDI33; /* offset: 0x0821 size: 8 bit */
2836  SIUL_GPDI_8B_tag GPDI34; /* offset: 0x0822 size: 8 bit */
2837  SIUL_GPDI_8B_tag GPDI35; /* offset: 0x0823 size: 8 bit */
2838  SIUL_GPDI_8B_tag GPDI36; /* offset: 0x0824 size: 8 bit */
2839  SIUL_GPDI_8B_tag GPDI37; /* offset: 0x0825 size: 8 bit */
2840  SIUL_GPDI_8B_tag GPDI38; /* offset: 0x0826 size: 8 bit */
2841  SIUL_GPDI_8B_tag GPDI39; /* offset: 0x0827 size: 8 bit */
2842  SIUL_GPDI_8B_tag GPDI40; /* offset: 0x0828 size: 8 bit */
2843  SIUL_GPDI_8B_tag GPDI41; /* offset: 0x0829 size: 8 bit */
2844  SIUL_GPDI_8B_tag GPDI42; /* offset: 0x082A size: 8 bit */
2845  SIUL_GPDI_8B_tag GPDI43; /* offset: 0x082B size: 8 bit */
2846  SIUL_GPDI_8B_tag GPDI44; /* offset: 0x082C size: 8 bit */
2847  SIUL_GPDI_8B_tag GPDI45; /* offset: 0x082D size: 8 bit */
2848  SIUL_GPDI_8B_tag GPDI46; /* offset: 0x082E size: 8 bit */
2849  SIUL_GPDI_8B_tag GPDI47; /* offset: 0x082F size: 8 bit */
2850  SIUL_GPDI_8B_tag GPDI48; /* offset: 0x0830 size: 8 bit */
2851  SIUL_GPDI_8B_tag GPDI49; /* offset: 0x0831 size: 8 bit */
2852  SIUL_GPDI_8B_tag GPDI50; /* offset: 0x0832 size: 8 bit */
2853  SIUL_GPDI_8B_tag GPDI51; /* offset: 0x0833 size: 8 bit */
2854  SIUL_GPDI_8B_tag GPDI52; /* offset: 0x0834 size: 8 bit */
2855  SIUL_GPDI_8B_tag GPDI53; /* offset: 0x0835 size: 8 bit */
2856  SIUL_GPDI_8B_tag GPDI54; /* offset: 0x0836 size: 8 bit */
2857  SIUL_GPDI_8B_tag GPDI55; /* offset: 0x0837 size: 8 bit */
2858  SIUL_GPDI_8B_tag GPDI56; /* offset: 0x0838 size: 8 bit */
2859  SIUL_GPDI_8B_tag GPDI57; /* offset: 0x0839 size: 8 bit */
2860  SIUL_GPDI_8B_tag GPDI58; /* offset: 0x083A size: 8 bit */
2861  SIUL_GPDI_8B_tag GPDI59; /* offset: 0x083B size: 8 bit */
2862  SIUL_GPDI_8B_tag GPDI60; /* offset: 0x083C size: 8 bit */
2863  SIUL_GPDI_8B_tag GPDI61; /* offset: 0x083D size: 8 bit */
2864  SIUL_GPDI_8B_tag GPDI62; /* offset: 0x083E size: 8 bit */
2865  SIUL_GPDI_8B_tag GPDI63; /* offset: 0x083F size: 8 bit */
2866  SIUL_GPDI_8B_tag GPDI64; /* offset: 0x0840 size: 8 bit */
2867  SIUL_GPDI_8B_tag GPDI65; /* offset: 0x0841 size: 8 bit */
2868  SIUL_GPDI_8B_tag GPDI66; /* offset: 0x0842 size: 8 bit */
2869  SIUL_GPDI_8B_tag GPDI67; /* offset: 0x0843 size: 8 bit */
2870  SIUL_GPDI_8B_tag GPDI68; /* offset: 0x0844 size: 8 bit */
2871  SIUL_GPDI_8B_tag GPDI69; /* offset: 0x0845 size: 8 bit */
2872  SIUL_GPDI_8B_tag GPDI70; /* offset: 0x0846 size: 8 bit */
2873  SIUL_GPDI_8B_tag GPDI71; /* offset: 0x0847 size: 8 bit */
2874  SIUL_GPDI_8B_tag GPDI72; /* offset: 0x0848 size: 8 bit */
2875  SIUL_GPDI_8B_tag GPDI73; /* offset: 0x0849 size: 8 bit */
2876  SIUL_GPDI_8B_tag GPDI74; /* offset: 0x084A size: 8 bit */
2877  SIUL_GPDI_8B_tag GPDI75; /* offset: 0x084B size: 8 bit */
2878  SIUL_GPDI_8B_tag GPDI76; /* offset: 0x084C size: 8 bit */
2879  SIUL_GPDI_8B_tag GPDI77; /* offset: 0x084D size: 8 bit */
2880  SIUL_GPDI_8B_tag GPDI78; /* offset: 0x084E size: 8 bit */
2881  SIUL_GPDI_8B_tag GPDI79; /* offset: 0x084F size: 8 bit */
2882  SIUL_GPDI_8B_tag GPDI80; /* offset: 0x0850 size: 8 bit */
2883  SIUL_GPDI_8B_tag GPDI81; /* offset: 0x0851 size: 8 bit */
2884  SIUL_GPDI_8B_tag GPDI82; /* offset: 0x0852 size: 8 bit */
2885  SIUL_GPDI_8B_tag GPDI83; /* offset: 0x0853 size: 8 bit */
2886  SIUL_GPDI_8B_tag GPDI84; /* offset: 0x0854 size: 8 bit */
2887  SIUL_GPDI_8B_tag GPDI85; /* offset: 0x0855 size: 8 bit */
2888  SIUL_GPDI_8B_tag GPDI86; /* offset: 0x0856 size: 8 bit */
2889  SIUL_GPDI_8B_tag GPDI87; /* offset: 0x0857 size: 8 bit */
2890  SIUL_GPDI_8B_tag GPDI88; /* offset: 0x0858 size: 8 bit */
2891  SIUL_GPDI_8B_tag GPDI89; /* offset: 0x0859 size: 8 bit */
2892  SIUL_GPDI_8B_tag GPDI90; /* offset: 0x085A size: 8 bit */
2893  SIUL_GPDI_8B_tag GPDI91; /* offset: 0x085B size: 8 bit */
2894  SIUL_GPDI_8B_tag GPDI92; /* offset: 0x085C size: 8 bit */
2895  SIUL_GPDI_8B_tag GPDI93; /* offset: 0x085D size: 8 bit */
2896  SIUL_GPDI_8B_tag GPDI94; /* offset: 0x085E size: 8 bit */
2897  SIUL_GPDI_8B_tag GPDI95; /* offset: 0x085F size: 8 bit */
2898  SIUL_GPDI_8B_tag GPDI96; /* offset: 0x0860 size: 8 bit */
2899  SIUL_GPDI_8B_tag GPDI97; /* offset: 0x0861 size: 8 bit */
2900  SIUL_GPDI_8B_tag GPDI98; /* offset: 0x0862 size: 8 bit */
2901  SIUL_GPDI_8B_tag GPDI99; /* offset: 0x0863 size: 8 bit */
2902  SIUL_GPDI_8B_tag GPDI100; /* offset: 0x0864 size: 8 bit */
2903  SIUL_GPDI_8B_tag GPDI101; /* offset: 0x0865 size: 8 bit */
2904  SIUL_GPDI_8B_tag GPDI102; /* offset: 0x0866 size: 8 bit */
2905  SIUL_GPDI_8B_tag GPDI103; /* offset: 0x0867 size: 8 bit */
2906  SIUL_GPDI_8B_tag GPDI104; /* offset: 0x0868 size: 8 bit */
2907  SIUL_GPDI_8B_tag GPDI105; /* offset: 0x0869 size: 8 bit */
2908  SIUL_GPDI_8B_tag GPDI106; /* offset: 0x086A size: 8 bit */
2909  SIUL_GPDI_8B_tag GPDI107; /* offset: 0x086B size: 8 bit */
2910  SIUL_GPDI_8B_tag GPDI108; /* offset: 0x086C size: 8 bit */
2911  SIUL_GPDI_8B_tag GPDI109; /* offset: 0x086D size: 8 bit */
2912  SIUL_GPDI_8B_tag GPDI110; /* offset: 0x086E size: 8 bit */
2913  SIUL_GPDI_8B_tag GPDI111; /* offset: 0x086F size: 8 bit */
2914  SIUL_GPDI_8B_tag GPDI112; /* offset: 0x0870 size: 8 bit */
2915  SIUL_GPDI_8B_tag GPDI113; /* offset: 0x0871 size: 8 bit */
2916  SIUL_GPDI_8B_tag GPDI114; /* offset: 0x0872 size: 8 bit */
2917  SIUL_GPDI_8B_tag GPDI115; /* offset: 0x0873 size: 8 bit */
2918  SIUL_GPDI_8B_tag GPDI116; /* offset: 0x0874 size: 8 bit */
2919  SIUL_GPDI_8B_tag GPDI117; /* offset: 0x0875 size: 8 bit */
2920  SIUL_GPDI_8B_tag GPDI118; /* offset: 0x0876 size: 8 bit */
2921  SIUL_GPDI_8B_tag GPDI119; /* offset: 0x0877 size: 8 bit */
2922  SIUL_GPDI_8B_tag GPDI120; /* offset: 0x0878 size: 8 bit */
2923  SIUL_GPDI_8B_tag GPDI121; /* offset: 0x0879 size: 8 bit */
2924  SIUL_GPDI_8B_tag GPDI122; /* offset: 0x087A size: 8 bit */
2925  SIUL_GPDI_8B_tag GPDI123; /* offset: 0x087B size: 8 bit */
2926  SIUL_GPDI_8B_tag GPDI124; /* offset: 0x087C size: 8 bit */
2927  SIUL_GPDI_8B_tag GPDI125; /* offset: 0x087D size: 8 bit */
2928  SIUL_GPDI_8B_tag GPDI126; /* offset: 0x087E size: 8 bit */
2929  SIUL_GPDI_8B_tag GPDI127; /* offset: 0x087F size: 8 bit */
2930  SIUL_GPDI_8B_tag GPDI128; /* offset: 0x0880 size: 8 bit */
2931  SIUL_GPDI_8B_tag GPDI129; /* offset: 0x0881 size: 8 bit */
2932  SIUL_GPDI_8B_tag GPDI130; /* offset: 0x0882 size: 8 bit */
2933  SIUL_GPDI_8B_tag GPDI131; /* offset: 0x0883 size: 8 bit */
2934  SIUL_GPDI_8B_tag GPDI132; /* offset: 0x0884 size: 8 bit */
2935  SIUL_GPDI_8B_tag GPDI133; /* offset: 0x0885 size: 8 bit */
2936  SIUL_GPDI_8B_tag GPDI134; /* offset: 0x0886 size: 8 bit */
2937  SIUL_GPDI_8B_tag GPDI135; /* offset: 0x0887 size: 8 bit */
2938  SIUL_GPDI_8B_tag GPDI136; /* offset: 0x0888 size: 8 bit */
2939  SIUL_GPDI_8B_tag GPDI137; /* offset: 0x0889 size: 8 bit */
2940  SIUL_GPDI_8B_tag GPDI138; /* offset: 0x088A size: 8 bit */
2941  SIUL_GPDI_8B_tag GPDI139; /* offset: 0x088B size: 8 bit */
2942  SIUL_GPDI_8B_tag GPDI140; /* offset: 0x088C size: 8 bit */
2943  SIUL_GPDI_8B_tag GPDI141; /* offset: 0x088D size: 8 bit */
2944  SIUL_GPDI_8B_tag GPDI142; /* offset: 0x088E size: 8 bit */
2945  SIUL_GPDI_8B_tag GPDI143; /* offset: 0x088F size: 8 bit */
2946  SIUL_GPDI_8B_tag GPDI144; /* offset: 0x0890 size: 8 bit */
2947  SIUL_GPDI_8B_tag GPDI145; /* offset: 0x0891 size: 8 bit */
2948  SIUL_GPDI_8B_tag GPDI146; /* offset: 0x0892 size: 8 bit */
2949  SIUL_GPDI_8B_tag GPDI147; /* offset: 0x0893 size: 8 bit */
2950  SIUL_GPDI_8B_tag GPDI148; /* offset: 0x0894 size: 8 bit */
2951  SIUL_GPDI_8B_tag GPDI149; /* offset: 0x0895 size: 8 bit */
2952  SIUL_GPDI_8B_tag GPDI150; /* offset: 0x0896 size: 8 bit */
2953  SIUL_GPDI_8B_tag GPDI151; /* offset: 0x0897 size: 8 bit */
2954  SIUL_GPDI_8B_tag GPDI152; /* offset: 0x0898 size: 8 bit */
2955  SIUL_GPDI_8B_tag GPDI153; /* offset: 0x0899 size: 8 bit */
2956  SIUL_GPDI_8B_tag GPDI154; /* offset: 0x089A size: 8 bit */
2957  SIUL_GPDI_8B_tag GPDI155; /* offset: 0x089B size: 8 bit */
2958  SIUL_GPDI_8B_tag GPDI156; /* offset: 0x089C size: 8 bit */
2959  SIUL_GPDI_8B_tag GPDI157; /* offset: 0x089D size: 8 bit */
2960  SIUL_GPDI_8B_tag GPDI158; /* offset: 0x089E size: 8 bit */
2961  SIUL_GPDI_8B_tag GPDI159; /* offset: 0x089F size: 8 bit */
2962  SIUL_GPDI_8B_tag GPDI160; /* offset: 0x08A0 size: 8 bit */
2963  SIUL_GPDI_8B_tag GPDI161; /* offset: 0x08A1 size: 8 bit */
2964  SIUL_GPDI_8B_tag GPDI162; /* offset: 0x08A2 size: 8 bit */
2965  SIUL_GPDI_8B_tag GPDI163; /* offset: 0x08A3 size: 8 bit */
2966  SIUL_GPDI_8B_tag GPDI164; /* offset: 0x08A4 size: 8 bit */
2967  SIUL_GPDI_8B_tag GPDI165; /* offset: 0x08A5 size: 8 bit */
2968  SIUL_GPDI_8B_tag GPDI166; /* offset: 0x08A6 size: 8 bit */
2969  SIUL_GPDI_8B_tag GPDI167; /* offset: 0x08A7 size: 8 bit */
2970  SIUL_GPDI_8B_tag GPDI168; /* offset: 0x08A8 size: 8 bit */
2971  SIUL_GPDI_8B_tag GPDI169; /* offset: 0x08A9 size: 8 bit */
2972  SIUL_GPDI_8B_tag GPDI170; /* offset: 0x08AA size: 8 bit */
2973  SIUL_GPDI_8B_tag GPDI171; /* offset: 0x08AB size: 8 bit */
2974  SIUL_GPDI_8B_tag GPDI172; /* offset: 0x08AC size: 8 bit */
2975  SIUL_GPDI_8B_tag GPDI173; /* offset: 0x08AD size: 8 bit */
2976  SIUL_GPDI_8B_tag GPDI174; /* offset: 0x08AE size: 8 bit */
2977  SIUL_GPDI_8B_tag GPDI175; /* offset: 0x08AF size: 8 bit */
2978  SIUL_GPDI_8B_tag GPDI176; /* offset: 0x08B0 size: 8 bit */
2979  SIUL_GPDI_8B_tag GPDI177; /* offset: 0x08B1 size: 8 bit */
2980  SIUL_GPDI_8B_tag GPDI178; /* offset: 0x08B2 size: 8 bit */
2981  SIUL_GPDI_8B_tag GPDI179; /* offset: 0x08B3 size: 8 bit */
2982  SIUL_GPDI_8B_tag GPDI180; /* offset: 0x08B4 size: 8 bit */
2983  SIUL_GPDI_8B_tag GPDI181; /* offset: 0x08B5 size: 8 bit */
2984  SIUL_GPDI_8B_tag GPDI182; /* offset: 0x08B6 size: 8 bit */
2985  SIUL_GPDI_8B_tag GPDI183; /* offset: 0x08B7 size: 8 bit */
2986  SIUL_GPDI_8B_tag GPDI184; /* offset: 0x08B8 size: 8 bit */
2987  SIUL_GPDI_8B_tag GPDI185; /* offset: 0x08B9 size: 8 bit */
2988  SIUL_GPDI_8B_tag GPDI186; /* offset: 0x08BA size: 8 bit */
2989  SIUL_GPDI_8B_tag GPDI187; /* offset: 0x08BB size: 8 bit */
2990  SIUL_GPDI_8B_tag GPDI188; /* offset: 0x08BC size: 8 bit */
2991  SIUL_GPDI_8B_tag GPDI189; /* offset: 0x08BD size: 8 bit */
2992  SIUL_GPDI_8B_tag GPDI190; /* offset: 0x08BE size: 8 bit */
2993  SIUL_GPDI_8B_tag GPDI191; /* offset: 0x08BF size: 8 bit */
2994  SIUL_GPDI_8B_tag GPDI192; /* offset: 0x08C0 size: 8 bit */
2995  SIUL_GPDI_8B_tag GPDI193; /* offset: 0x08C1 size: 8 bit */
2996  SIUL_GPDI_8B_tag GPDI194; /* offset: 0x08C2 size: 8 bit */
2997  SIUL_GPDI_8B_tag GPDI195; /* offset: 0x08C3 size: 8 bit */
2998  SIUL_GPDI_8B_tag GPDI196; /* offset: 0x08C4 size: 8 bit */
2999  SIUL_GPDI_8B_tag GPDI197; /* offset: 0x08C5 size: 8 bit */
3000  SIUL_GPDI_8B_tag GPDI198; /* offset: 0x08C6 size: 8 bit */
3001  SIUL_GPDI_8B_tag GPDI199; /* offset: 0x08C7 size: 8 bit */
3002  SIUL_GPDI_8B_tag GPDI200; /* offset: 0x08C8 size: 8 bit */
3003  SIUL_GPDI_8B_tag GPDI201; /* offset: 0x08C9 size: 8 bit */
3004  SIUL_GPDI_8B_tag GPDI202; /* offset: 0x08CA size: 8 bit */
3005  SIUL_GPDI_8B_tag GPDI203; /* offset: 0x08CB size: 8 bit */
3006  SIUL_GPDI_8B_tag GPDI204; /* offset: 0x08CC size: 8 bit */
3007  SIUL_GPDI_8B_tag GPDI205; /* offset: 0x08CD size: 8 bit */
3008  SIUL_GPDI_8B_tag GPDI206; /* offset: 0x08CE size: 8 bit */
3009  SIUL_GPDI_8B_tag GPDI207; /* offset: 0x08CF size: 8 bit */
3010  SIUL_GPDI_8B_tag GPDI208; /* offset: 0x08D0 size: 8 bit */
3011  SIUL_GPDI_8B_tag GPDI209; /* offset: 0x08D1 size: 8 bit */
3012  SIUL_GPDI_8B_tag GPDI210; /* offset: 0x08D2 size: 8 bit */
3013  SIUL_GPDI_8B_tag GPDI211; /* offset: 0x08D3 size: 8 bit */
3014  SIUL_GPDI_8B_tag GPDI212; /* offset: 0x08D4 size: 8 bit */
3015  SIUL_GPDI_8B_tag GPDI213; /* offset: 0x08D5 size: 8 bit */
3016  SIUL_GPDI_8B_tag GPDI214; /* offset: 0x08D6 size: 8 bit */
3017  SIUL_GPDI_8B_tag GPDI215; /* offset: 0x08D7 size: 8 bit */
3018  SIUL_GPDI_8B_tag GPDI216; /* offset: 0x08D8 size: 8 bit */
3019  SIUL_GPDI_8B_tag GPDI217; /* offset: 0x08D9 size: 8 bit */
3020  SIUL_GPDI_8B_tag GPDI218; /* offset: 0x08DA size: 8 bit */
3021  SIUL_GPDI_8B_tag GPDI219; /* offset: 0x08DB size: 8 bit */
3022  SIUL_GPDI_8B_tag GPDI220; /* offset: 0x08DC size: 8 bit */
3023  SIUL_GPDI_8B_tag GPDI221; /* offset: 0x08DD size: 8 bit */
3024  SIUL_GPDI_8B_tag GPDI222; /* offset: 0x08DE size: 8 bit */
3025  SIUL_GPDI_8B_tag GPDI223; /* offset: 0x08DF size: 8 bit */
3026  SIUL_GPDI_8B_tag GPDI224; /* offset: 0x08E0 size: 8 bit */
3027  SIUL_GPDI_8B_tag GPDI225; /* offset: 0x08E1 size: 8 bit */
3028  SIUL_GPDI_8B_tag GPDI226; /* offset: 0x08E2 size: 8 bit */
3029  SIUL_GPDI_8B_tag GPDI227; /* offset: 0x08E3 size: 8 bit */
3030  SIUL_GPDI_8B_tag GPDI228; /* offset: 0x08E4 size: 8 bit */
3031  SIUL_GPDI_8B_tag GPDI229; /* offset: 0x08E5 size: 8 bit */
3032  SIUL_GPDI_8B_tag GPDI230; /* offset: 0x08E6 size: 8 bit */
3033  SIUL_GPDI_8B_tag GPDI231; /* offset: 0x08E7 size: 8 bit */
3034  SIUL_GPDI_8B_tag GPDI232; /* offset: 0x08E8 size: 8 bit */
3035  SIUL_GPDI_8B_tag GPDI233; /* offset: 0x08E9 size: 8 bit */
3036  SIUL_GPDI_8B_tag GPDI234; /* offset: 0x08EA size: 8 bit */
3037  SIUL_GPDI_8B_tag GPDI235; /* offset: 0x08EB size: 8 bit */
3038  SIUL_GPDI_8B_tag GPDI236; /* offset: 0x08EC size: 8 bit */
3039  SIUL_GPDI_8B_tag GPDI237; /* offset: 0x08ED size: 8 bit */
3040  SIUL_GPDI_8B_tag GPDI238; /* offset: 0x08EE size: 8 bit */
3041  SIUL_GPDI_8B_tag GPDI239; /* offset: 0x08EF size: 8 bit */
3042  SIUL_GPDI_8B_tag GPDI240; /* offset: 0x08F0 size: 8 bit */
3043  SIUL_GPDI_8B_tag GPDI241; /* offset: 0x08F1 size: 8 bit */
3044  SIUL_GPDI_8B_tag GPDI242; /* offset: 0x08F2 size: 8 bit */
3045  SIUL_GPDI_8B_tag GPDI243; /* offset: 0x08F3 size: 8 bit */
3046  SIUL_GPDI_8B_tag GPDI244; /* offset: 0x08F4 size: 8 bit */
3047  SIUL_GPDI_8B_tag GPDI245; /* offset: 0x08F5 size: 8 bit */
3048  SIUL_GPDI_8B_tag GPDI246; /* offset: 0x08F6 size: 8 bit */
3049  SIUL_GPDI_8B_tag GPDI247; /* offset: 0x08F7 size: 8 bit */
3050  SIUL_GPDI_8B_tag GPDI248; /* offset: 0x08F8 size: 8 bit */
3051  SIUL_GPDI_8B_tag GPDI249; /* offset: 0x08F9 size: 8 bit */
3052  SIUL_GPDI_8B_tag GPDI250; /* offset: 0x08FA size: 8 bit */
3053  SIUL_GPDI_8B_tag GPDI251; /* offset: 0x08FB size: 8 bit */
3054  SIUL_GPDI_8B_tag GPDI252; /* offset: 0x08FC size: 8 bit */
3055  SIUL_GPDI_8B_tag GPDI253; /* offset: 0x08FD size: 8 bit */
3056  SIUL_GPDI_8B_tag GPDI254; /* offset: 0x08FE size: 8 bit */
3057  SIUL_GPDI_8B_tag GPDI255; /* offset: 0x08FF size: 8 bit */
3058  SIUL_GPDI_8B_tag GPDI256; /* offset: 0x0900 size: 8 bit */
3059  SIUL_GPDI_8B_tag GPDI257; /* offset: 0x0901 size: 8 bit */
3060  SIUL_GPDI_8B_tag GPDI258; /* offset: 0x0902 size: 8 bit */
3061  SIUL_GPDI_8B_tag GPDI259; /* offset: 0x0903 size: 8 bit */
3062  SIUL_GPDI_8B_tag GPDI260; /* offset: 0x0904 size: 8 bit */
3063  SIUL_GPDI_8B_tag GPDI261; /* offset: 0x0905 size: 8 bit */
3064  SIUL_GPDI_8B_tag GPDI262; /* offset: 0x0906 size: 8 bit */
3065  SIUL_GPDI_8B_tag GPDI263; /* offset: 0x0907 size: 8 bit */
3066  SIUL_GPDI_8B_tag GPDI264; /* offset: 0x0908 size: 8 bit */
3067  SIUL_GPDI_8B_tag GPDI265; /* offset: 0x0909 size: 8 bit */
3068  SIUL_GPDI_8B_tag GPDI266; /* offset: 0x090A size: 8 bit */
3069  SIUL_GPDI_8B_tag GPDI267; /* offset: 0x090B size: 8 bit */
3070  SIUL_GPDI_8B_tag GPDI268; /* offset: 0x090C size: 8 bit */
3071  SIUL_GPDI_8B_tag GPDI269; /* offset: 0x090D size: 8 bit */
3072  SIUL_GPDI_8B_tag GPDI270; /* offset: 0x090E size: 8 bit */
3073  SIUL_GPDI_8B_tag GPDI271; /* offset: 0x090F size: 8 bit */
3074  SIUL_GPDI_8B_tag GPDI272; /* offset: 0x0910 size: 8 bit */
3075  SIUL_GPDI_8B_tag GPDI273; /* offset: 0x0911 size: 8 bit */
3076  SIUL_GPDI_8B_tag GPDI274; /* offset: 0x0912 size: 8 bit */
3077  SIUL_GPDI_8B_tag GPDI275; /* offset: 0x0913 size: 8 bit */
3078  SIUL_GPDI_8B_tag GPDI276; /* offset: 0x0914 size: 8 bit */
3079  SIUL_GPDI_8B_tag GPDI277; /* offset: 0x0915 size: 8 bit */
3080  SIUL_GPDI_8B_tag GPDI278; /* offset: 0x0916 size: 8 bit */
3081  SIUL_GPDI_8B_tag GPDI279; /* offset: 0x0917 size: 8 bit */
3082  SIUL_GPDI_8B_tag GPDI280; /* offset: 0x0918 size: 8 bit */
3083  SIUL_GPDI_8B_tag GPDI281; /* offset: 0x0919 size: 8 bit */
3084  SIUL_GPDI_8B_tag GPDI282; /* offset: 0x091A size: 8 bit */
3085  SIUL_GPDI_8B_tag GPDI283; /* offset: 0x091B size: 8 bit */
3086  SIUL_GPDI_8B_tag GPDI284; /* offset: 0x091C size: 8 bit */
3087  SIUL_GPDI_8B_tag GPDI285; /* offset: 0x091D size: 8 bit */
3088  SIUL_GPDI_8B_tag GPDI286; /* offset: 0x091E size: 8 bit */
3089  SIUL_GPDI_8B_tag GPDI287; /* offset: 0x091F size: 8 bit */
3090  SIUL_GPDI_8B_tag GPDI288; /* offset: 0x0920 size: 8 bit */
3091  SIUL_GPDI_8B_tag GPDI289; /* offset: 0x0921 size: 8 bit */
3092  SIUL_GPDI_8B_tag GPDI290; /* offset: 0x0922 size: 8 bit */
3093  SIUL_GPDI_8B_tag GPDI291; /* offset: 0x0923 size: 8 bit */
3094  SIUL_GPDI_8B_tag GPDI292; /* offset: 0x0924 size: 8 bit */
3095  SIUL_GPDI_8B_tag GPDI293; /* offset: 0x0925 size: 8 bit */
3096  SIUL_GPDI_8B_tag GPDI294; /* offset: 0x0926 size: 8 bit */
3097  SIUL_GPDI_8B_tag GPDI295; /* offset: 0x0927 size: 8 bit */
3098  SIUL_GPDI_8B_tag GPDI296; /* offset: 0x0928 size: 8 bit */
3099  SIUL_GPDI_8B_tag GPDI297; /* offset: 0x0929 size: 8 bit */
3100  SIUL_GPDI_8B_tag GPDI298; /* offset: 0x092A size: 8 bit */
3101  SIUL_GPDI_8B_tag GPDI299; /* offset: 0x092B size: 8 bit */
3102  SIUL_GPDI_8B_tag GPDI300; /* offset: 0x092C size: 8 bit */
3103  SIUL_GPDI_8B_tag GPDI301; /* offset: 0x092D size: 8 bit */
3104  SIUL_GPDI_8B_tag GPDI302; /* offset: 0x092E size: 8 bit */
3105  SIUL_GPDI_8B_tag GPDI303; /* offset: 0x092F size: 8 bit */
3106  SIUL_GPDI_8B_tag GPDI304; /* offset: 0x0930 size: 8 bit */
3107  SIUL_GPDI_8B_tag GPDI305; /* offset: 0x0931 size: 8 bit */
3108  SIUL_GPDI_8B_tag GPDI306; /* offset: 0x0932 size: 8 bit */
3109  SIUL_GPDI_8B_tag GPDI307; /* offset: 0x0933 size: 8 bit */
3110  SIUL_GPDI_8B_tag GPDI308; /* offset: 0x0934 size: 8 bit */
3111  SIUL_GPDI_8B_tag GPDI309; /* offset: 0x0935 size: 8 bit */
3112  SIUL_GPDI_8B_tag GPDI310; /* offset: 0x0936 size: 8 bit */
3113  SIUL_GPDI_8B_tag GPDI311; /* offset: 0x0937 size: 8 bit */
3114  SIUL_GPDI_8B_tag GPDI312; /* offset: 0x0938 size: 8 bit */
3115  SIUL_GPDI_8B_tag GPDI313; /* offset: 0x0939 size: 8 bit */
3116  SIUL_GPDI_8B_tag GPDI314; /* offset: 0x093A size: 8 bit */
3117  SIUL_GPDI_8B_tag GPDI315; /* offset: 0x093B size: 8 bit */
3118  SIUL_GPDI_8B_tag GPDI316; /* offset: 0x093C size: 8 bit */
3119  SIUL_GPDI_8B_tag GPDI317; /* offset: 0x093D size: 8 bit */
3120  SIUL_GPDI_8B_tag GPDI318; /* offset: 0x093E size: 8 bit */
3121  SIUL_GPDI_8B_tag GPDI319; /* offset: 0x093F size: 8 bit */
3122  SIUL_GPDI_8B_tag GPDI320; /* offset: 0x0940 size: 8 bit */
3123  SIUL_GPDI_8B_tag GPDI321; /* offset: 0x0941 size: 8 bit */
3124  SIUL_GPDI_8B_tag GPDI322; /* offset: 0x0942 size: 8 bit */
3125  SIUL_GPDI_8B_tag GPDI323; /* offset: 0x0943 size: 8 bit */
3126  SIUL_GPDI_8B_tag GPDI324; /* offset: 0x0944 size: 8 bit */
3127  SIUL_GPDI_8B_tag GPDI325; /* offset: 0x0945 size: 8 bit */
3128  SIUL_GPDI_8B_tag GPDI326; /* offset: 0x0946 size: 8 bit */
3129  SIUL_GPDI_8B_tag GPDI327; /* offset: 0x0947 size: 8 bit */
3130  SIUL_GPDI_8B_tag GPDI328; /* offset: 0x0948 size: 8 bit */
3131  SIUL_GPDI_8B_tag GPDI329; /* offset: 0x0949 size: 8 bit */
3132  SIUL_GPDI_8B_tag GPDI330; /* offset: 0x094A size: 8 bit */
3133  SIUL_GPDI_8B_tag GPDI331; /* offset: 0x094B size: 8 bit */
3134  SIUL_GPDI_8B_tag GPDI332; /* offset: 0x094C size: 8 bit */
3135  SIUL_GPDI_8B_tag GPDI333; /* offset: 0x094D size: 8 bit */
3136  SIUL_GPDI_8B_tag GPDI334; /* offset: 0x094E size: 8 bit */
3137  SIUL_GPDI_8B_tag GPDI335; /* offset: 0x094F size: 8 bit */
3138  SIUL_GPDI_8B_tag GPDI336; /* offset: 0x0950 size: 8 bit */
3139  SIUL_GPDI_8B_tag GPDI337; /* offset: 0x0951 size: 8 bit */
3140  SIUL_GPDI_8B_tag GPDI338; /* offset: 0x0952 size: 8 bit */
3141  SIUL_GPDI_8B_tag GPDI339; /* offset: 0x0953 size: 8 bit */
3142  SIUL_GPDI_8B_tag GPDI340; /* offset: 0x0954 size: 8 bit */
3143  SIUL_GPDI_8B_tag GPDI341; /* offset: 0x0955 size: 8 bit */
3144  SIUL_GPDI_8B_tag GPDI342; /* offset: 0x0956 size: 8 bit */
3145  SIUL_GPDI_8B_tag GPDI343; /* offset: 0x0957 size: 8 bit */
3146  SIUL_GPDI_8B_tag GPDI344; /* offset: 0x0958 size: 8 bit */
3147  SIUL_GPDI_8B_tag GPDI345; /* offset: 0x0959 size: 8 bit */
3148  SIUL_GPDI_8B_tag GPDI346; /* offset: 0x095A size: 8 bit */
3149  SIUL_GPDI_8B_tag GPDI347; /* offset: 0x095B size: 8 bit */
3150  SIUL_GPDI_8B_tag GPDI348; /* offset: 0x095C size: 8 bit */
3151  SIUL_GPDI_8B_tag GPDI349; /* offset: 0x095D size: 8 bit */
3152  SIUL_GPDI_8B_tag GPDI350; /* offset: 0x095E size: 8 bit */
3153  SIUL_GPDI_8B_tag GPDI351; /* offset: 0x095F size: 8 bit */
3154  SIUL_GPDI_8B_tag GPDI352; /* offset: 0x0960 size: 8 bit */
3155  SIUL_GPDI_8B_tag GPDI353; /* offset: 0x0961 size: 8 bit */
3156  SIUL_GPDI_8B_tag GPDI354; /* offset: 0x0962 size: 8 bit */
3157  SIUL_GPDI_8B_tag GPDI355; /* offset: 0x0963 size: 8 bit */
3158  SIUL_GPDI_8B_tag GPDI356; /* offset: 0x0964 size: 8 bit */
3159  SIUL_GPDI_8B_tag GPDI357; /* offset: 0x0965 size: 8 bit */
3160  SIUL_GPDI_8B_tag GPDI358; /* offset: 0x0966 size: 8 bit */
3161  SIUL_GPDI_8B_tag GPDI359; /* offset: 0x0967 size: 8 bit */
3162  SIUL_GPDI_8B_tag GPDI360; /* offset: 0x0968 size: 8 bit */
3163  SIUL_GPDI_8B_tag GPDI361; /* offset: 0x0969 size: 8 bit */
3164  SIUL_GPDI_8B_tag GPDI362; /* offset: 0x096A size: 8 bit */
3165  SIUL_GPDI_8B_tag GPDI363; /* offset: 0x096B size: 8 bit */
3166  SIUL_GPDI_8B_tag GPDI364; /* offset: 0x096C size: 8 bit */
3167  SIUL_GPDI_8B_tag GPDI365; /* offset: 0x096D size: 8 bit */
3168  SIUL_GPDI_8B_tag GPDI366; /* offset: 0x096E size: 8 bit */
3169  SIUL_GPDI_8B_tag GPDI367; /* offset: 0x096F size: 8 bit */
3170  SIUL_GPDI_8B_tag GPDI368; /* offset: 0x0970 size: 8 bit */
3171  SIUL_GPDI_8B_tag GPDI369; /* offset: 0x0971 size: 8 bit */
3172  SIUL_GPDI_8B_tag GPDI370; /* offset: 0x0972 size: 8 bit */
3173  SIUL_GPDI_8B_tag GPDI371; /* offset: 0x0973 size: 8 bit */
3174  SIUL_GPDI_8B_tag GPDI372; /* offset: 0x0974 size: 8 bit */
3175  SIUL_GPDI_8B_tag GPDI373; /* offset: 0x0975 size: 8 bit */
3176  SIUL_GPDI_8B_tag GPDI374; /* offset: 0x0976 size: 8 bit */
3177  SIUL_GPDI_8B_tag GPDI375; /* offset: 0x0977 size: 8 bit */
3178  SIUL_GPDI_8B_tag GPDI376; /* offset: 0x0978 size: 8 bit */
3179  SIUL_GPDI_8B_tag GPDI377; /* offset: 0x0979 size: 8 bit */
3180  SIUL_GPDI_8B_tag GPDI378; /* offset: 0x097A size: 8 bit */
3181  SIUL_GPDI_8B_tag GPDI379; /* offset: 0x097B size: 8 bit */
3182  SIUL_GPDI_8B_tag GPDI380; /* offset: 0x097C size: 8 bit */
3183  SIUL_GPDI_8B_tag GPDI381; /* offset: 0x097D size: 8 bit */
3184  SIUL_GPDI_8B_tag GPDI382; /* offset: 0x097E size: 8 bit */
3185  SIUL_GPDI_8B_tag GPDI383; /* offset: 0x097F size: 8 bit */
3186  SIUL_GPDI_8B_tag GPDI384; /* offset: 0x0980 size: 8 bit */
3187  SIUL_GPDI_8B_tag GPDI385; /* offset: 0x0981 size: 8 bit */
3188  SIUL_GPDI_8B_tag GPDI386; /* offset: 0x0982 size: 8 bit */
3189  SIUL_GPDI_8B_tag GPDI387; /* offset: 0x0983 size: 8 bit */
3190  SIUL_GPDI_8B_tag GPDI388; /* offset: 0x0984 size: 8 bit */
3191  SIUL_GPDI_8B_tag GPDI389; /* offset: 0x0985 size: 8 bit */
3192  SIUL_GPDI_8B_tag GPDI390; /* offset: 0x0986 size: 8 bit */
3193  SIUL_GPDI_8B_tag GPDI391; /* offset: 0x0987 size: 8 bit */
3194  SIUL_GPDI_8B_tag GPDI392; /* offset: 0x0988 size: 8 bit */
3195  SIUL_GPDI_8B_tag GPDI393; /* offset: 0x0989 size: 8 bit */
3196  SIUL_GPDI_8B_tag GPDI394; /* offset: 0x098A size: 8 bit */
3197  SIUL_GPDI_8B_tag GPDI395; /* offset: 0x098B size: 8 bit */
3198  SIUL_GPDI_8B_tag GPDI396; /* offset: 0x098C size: 8 bit */
3199  SIUL_GPDI_8B_tag GPDI397; /* offset: 0x098D size: 8 bit */
3200  SIUL_GPDI_8B_tag GPDI398; /* offset: 0x098E size: 8 bit */
3201  SIUL_GPDI_8B_tag GPDI399; /* offset: 0x098F size: 8 bit */
3202  SIUL_GPDI_8B_tag GPDI400; /* offset: 0x0990 size: 8 bit */
3203  SIUL_GPDI_8B_tag GPDI401; /* offset: 0x0991 size: 8 bit */
3204  SIUL_GPDI_8B_tag GPDI402; /* offset: 0x0992 size: 8 bit */
3205  SIUL_GPDI_8B_tag GPDI403; /* offset: 0x0993 size: 8 bit */
3206  SIUL_GPDI_8B_tag GPDI404; /* offset: 0x0994 size: 8 bit */
3207  SIUL_GPDI_8B_tag GPDI405; /* offset: 0x0995 size: 8 bit */
3208  SIUL_GPDI_8B_tag GPDI406; /* offset: 0x0996 size: 8 bit */
3209  SIUL_GPDI_8B_tag GPDI407; /* offset: 0x0997 size: 8 bit */
3210  SIUL_GPDI_8B_tag GPDI408; /* offset: 0x0998 size: 8 bit */
3211  SIUL_GPDI_8B_tag GPDI409; /* offset: 0x0999 size: 8 bit */
3212  SIUL_GPDI_8B_tag GPDI410; /* offset: 0x099A size: 8 bit */
3213  SIUL_GPDI_8B_tag GPDI411; /* offset: 0x099B size: 8 bit */
3214  SIUL_GPDI_8B_tag GPDI412; /* offset: 0x099C size: 8 bit */
3215  SIUL_GPDI_8B_tag GPDI413; /* offset: 0x099D size: 8 bit */
3216  SIUL_GPDI_8B_tag GPDI414; /* offset: 0x099E size: 8 bit */
3217  SIUL_GPDI_8B_tag GPDI415; /* offset: 0x099F size: 8 bit */
3218  SIUL_GPDI_8B_tag GPDI416; /* offset: 0x09A0 size: 8 bit */
3219  SIUL_GPDI_8B_tag GPDI417; /* offset: 0x09A1 size: 8 bit */
3220  SIUL_GPDI_8B_tag GPDI418; /* offset: 0x09A2 size: 8 bit */
3221  SIUL_GPDI_8B_tag GPDI419; /* offset: 0x09A3 size: 8 bit */
3222  SIUL_GPDI_8B_tag GPDI420; /* offset: 0x09A4 size: 8 bit */
3223  SIUL_GPDI_8B_tag GPDI421; /* offset: 0x09A5 size: 8 bit */
3224  SIUL_GPDI_8B_tag GPDI422; /* offset: 0x09A6 size: 8 bit */
3225  SIUL_GPDI_8B_tag GPDI423; /* offset: 0x09A7 size: 8 bit */
3226  SIUL_GPDI_8B_tag GPDI424; /* offset: 0x09A8 size: 8 bit */
3227  SIUL_GPDI_8B_tag GPDI425; /* offset: 0x09A9 size: 8 bit */
3228  SIUL_GPDI_8B_tag GPDI426; /* offset: 0x09AA size: 8 bit */
3229  SIUL_GPDI_8B_tag GPDI427; /* offset: 0x09AB size: 8 bit */
3230  SIUL_GPDI_8B_tag GPDI428; /* offset: 0x09AC size: 8 bit */
3231  SIUL_GPDI_8B_tag GPDI429; /* offset: 0x09AD size: 8 bit */
3232  SIUL_GPDI_8B_tag GPDI430; /* offset: 0x09AE size: 8 bit */
3233  SIUL_GPDI_8B_tag GPDI431; /* offset: 0x09AF size: 8 bit */
3234  SIUL_GPDI_8B_tag GPDI432; /* offset: 0x09B0 size: 8 bit */
3235  SIUL_GPDI_8B_tag GPDI433; /* offset: 0x09B1 size: 8 bit */
3236  SIUL_GPDI_8B_tag GPDI434; /* offset: 0x09B2 size: 8 bit */
3237  SIUL_GPDI_8B_tag GPDI435; /* offset: 0x09B3 size: 8 bit */
3238  SIUL_GPDI_8B_tag GPDI436; /* offset: 0x09B4 size: 8 bit */
3239  SIUL_GPDI_8B_tag GPDI437; /* offset: 0x09B5 size: 8 bit */
3240  SIUL_GPDI_8B_tag GPDI438; /* offset: 0x09B6 size: 8 bit */
3241  SIUL_GPDI_8B_tag GPDI439; /* offset: 0x09B7 size: 8 bit */
3242  SIUL_GPDI_8B_tag GPDI440; /* offset: 0x09B8 size: 8 bit */
3243  SIUL_GPDI_8B_tag GPDI441; /* offset: 0x09B9 size: 8 bit */
3244  SIUL_GPDI_8B_tag GPDI442; /* offset: 0x09BA size: 8 bit */
3245  SIUL_GPDI_8B_tag GPDI443; /* offset: 0x09BB size: 8 bit */
3246  SIUL_GPDI_8B_tag GPDI444; /* offset: 0x09BC size: 8 bit */
3247  SIUL_GPDI_8B_tag GPDI445; /* offset: 0x09BD size: 8 bit */
3248  SIUL_GPDI_8B_tag GPDI446; /* offset: 0x09BE size: 8 bit */
3249  SIUL_GPDI_8B_tag GPDI447; /* offset: 0x09BF size: 8 bit */
3250  SIUL_GPDI_8B_tag GPDI448; /* offset: 0x09C0 size: 8 bit */
3251  SIUL_GPDI_8B_tag GPDI449; /* offset: 0x09C1 size: 8 bit */
3252  SIUL_GPDI_8B_tag GPDI450; /* offset: 0x09C2 size: 8 bit */
3253  SIUL_GPDI_8B_tag GPDI451; /* offset: 0x09C3 size: 8 bit */
3254  SIUL_GPDI_8B_tag GPDI452; /* offset: 0x09C4 size: 8 bit */
3255  SIUL_GPDI_8B_tag GPDI453; /* offset: 0x09C5 size: 8 bit */
3256  SIUL_GPDI_8B_tag GPDI454; /* offset: 0x09C6 size: 8 bit */
3257  SIUL_GPDI_8B_tag GPDI455; /* offset: 0x09C7 size: 8 bit */
3258  SIUL_GPDI_8B_tag GPDI456; /* offset: 0x09C8 size: 8 bit */
3259  SIUL_GPDI_8B_tag GPDI457; /* offset: 0x09C9 size: 8 bit */
3260  SIUL_GPDI_8B_tag GPDI458; /* offset: 0x09CA size: 8 bit */
3261  SIUL_GPDI_8B_tag GPDI459; /* offset: 0x09CB size: 8 bit */
3262  SIUL_GPDI_8B_tag GPDI460; /* offset: 0x09CC size: 8 bit */
3263  SIUL_GPDI_8B_tag GPDI461; /* offset: 0x09CD size: 8 bit */
3264  SIUL_GPDI_8B_tag GPDI462; /* offset: 0x09CE size: 8 bit */
3265  SIUL_GPDI_8B_tag GPDI463; /* offset: 0x09CF size: 8 bit */
3266  SIUL_GPDI_8B_tag GPDI464; /* offset: 0x09D0 size: 8 bit */
3267  SIUL_GPDI_8B_tag GPDI465; /* offset: 0x09D1 size: 8 bit */
3268  SIUL_GPDI_8B_tag GPDI466; /* offset: 0x09D2 size: 8 bit */
3269  SIUL_GPDI_8B_tag GPDI467; /* offset: 0x09D3 size: 8 bit */
3270  SIUL_GPDI_8B_tag GPDI468; /* offset: 0x09D4 size: 8 bit */
3271  SIUL_GPDI_8B_tag GPDI469; /* offset: 0x09D5 size: 8 bit */
3272  SIUL_GPDI_8B_tag GPDI470; /* offset: 0x09D6 size: 8 bit */
3273  SIUL_GPDI_8B_tag GPDI471; /* offset: 0x09D7 size: 8 bit */
3274  SIUL_GPDI_8B_tag GPDI472; /* offset: 0x09D8 size: 8 bit */
3275  SIUL_GPDI_8B_tag GPDI473; /* offset: 0x09D9 size: 8 bit */
3276  SIUL_GPDI_8B_tag GPDI474; /* offset: 0x09DA size: 8 bit */
3277  SIUL_GPDI_8B_tag GPDI475; /* offset: 0x09DB size: 8 bit */
3278  SIUL_GPDI_8B_tag GPDI476; /* offset: 0x09DC size: 8 bit */
3279  SIUL_GPDI_8B_tag GPDI477; /* offset: 0x09DD size: 8 bit */
3280  SIUL_GPDI_8B_tag GPDI478; /* offset: 0x09DE size: 8 bit */
3281  SIUL_GPDI_8B_tag GPDI479; /* offset: 0x09DF size: 8 bit */
3282  SIUL_GPDI_8B_tag GPDI480; /* offset: 0x09E0 size: 8 bit */
3283  SIUL_GPDI_8B_tag GPDI481; /* offset: 0x09E1 size: 8 bit */
3284  SIUL_GPDI_8B_tag GPDI482; /* offset: 0x09E2 size: 8 bit */
3285  SIUL_GPDI_8B_tag GPDI483; /* offset: 0x09E3 size: 8 bit */
3286  SIUL_GPDI_8B_tag GPDI484; /* offset: 0x09E4 size: 8 bit */
3287  SIUL_GPDI_8B_tag GPDI485; /* offset: 0x09E5 size: 8 bit */
3288  SIUL_GPDI_8B_tag GPDI486; /* offset: 0x09E6 size: 8 bit */
3289  SIUL_GPDI_8B_tag GPDI487; /* offset: 0x09E7 size: 8 bit */
3290  SIUL_GPDI_8B_tag GPDI488; /* offset: 0x09E8 size: 8 bit */
3291  SIUL_GPDI_8B_tag GPDI489; /* offset: 0x09E9 size: 8 bit */
3292  SIUL_GPDI_8B_tag GPDI490; /* offset: 0x09EA size: 8 bit */
3293  SIUL_GPDI_8B_tag GPDI491; /* offset: 0x09EB size: 8 bit */
3294  SIUL_GPDI_8B_tag GPDI492; /* offset: 0x09EC size: 8 bit */
3295  SIUL_GPDI_8B_tag GPDI493; /* offset: 0x09ED size: 8 bit */
3296  SIUL_GPDI_8B_tag GPDI494; /* offset: 0x09EE size: 8 bit */
3297  SIUL_GPDI_8B_tag GPDI495; /* offset: 0x09EF size: 8 bit */
3298  SIUL_GPDI_8B_tag GPDI496; /* offset: 0x09F0 size: 8 bit */
3299  SIUL_GPDI_8B_tag GPDI497; /* offset: 0x09F1 size: 8 bit */
3300  SIUL_GPDI_8B_tag GPDI498; /* offset: 0x09F2 size: 8 bit */
3301  SIUL_GPDI_8B_tag GPDI499; /* offset: 0x09F3 size: 8 bit */
3302  SIUL_GPDI_8B_tag GPDI500; /* offset: 0x09F4 size: 8 bit */
3303  SIUL_GPDI_8B_tag GPDI501; /* offset: 0x09F5 size: 8 bit */
3304  SIUL_GPDI_8B_tag GPDI502; /* offset: 0x09F6 size: 8 bit */
3305  SIUL_GPDI_8B_tag GPDI503; /* offset: 0x09F7 size: 8 bit */
3306  SIUL_GPDI_8B_tag GPDI504; /* offset: 0x09F8 size: 8 bit */
3307  SIUL_GPDI_8B_tag GPDI505; /* offset: 0x09F9 size: 8 bit */
3308  SIUL_GPDI_8B_tag GPDI506; /* offset: 0x09FA size: 8 bit */
3309  SIUL_GPDI_8B_tag GPDI507; /* offset: 0x09FB size: 8 bit */
3310  SIUL_GPDI_8B_tag GPDI508; /* offset: 0x09FC size: 8 bit */
3311  SIUL_GPDI_8B_tag GPDI509; /* offset: 0x09FD size: 8 bit */
3312  SIUL_GPDI_8B_tag GPDI510; /* offset: 0x09FE size: 8 bit */
3313  SIUL_GPDI_8B_tag GPDI511; /* offset: 0x09FF size: 8 bit */
3314  };
3315
3316  };
3317  int8_t SIUL_reserved_0A00_C[512];
3318  union {
3319  /* PGPDO - Parallel GPIO Pad Data Out Register */
3320  SIUL_PGPDO_16B_tag PGPDO[32]; /* offset: 0x0C00 (0x0002 x 32) */
3321
3322  struct {
3323  /* PGPDO - Parallel GPIO Pad Data Out Register */
3324  SIUL_PGPDO_16B_tag PGPDO0; /* offset: 0x0C00 size: 16 bit */
3325  SIUL_PGPDO_16B_tag PGPDO1; /* offset: 0x0C02 size: 16 bit */
3326  SIUL_PGPDO_16B_tag PGPDO2; /* offset: 0x0C04 size: 16 bit */
3327  SIUL_PGPDO_16B_tag PGPDO3; /* offset: 0x0C06 size: 16 bit */
3328  SIUL_PGPDO_16B_tag PGPDO4; /* offset: 0x0C08 size: 16 bit */
3329  SIUL_PGPDO_16B_tag PGPDO5; /* offset: 0x0C0A size: 16 bit */
3330  SIUL_PGPDO_16B_tag PGPDO6; /* offset: 0x0C0C size: 16 bit */
3331  SIUL_PGPDO_16B_tag PGPDO7; /* offset: 0x0C0E size: 16 bit */
3332  SIUL_PGPDO_16B_tag PGPDO8; /* offset: 0x0C10 size: 16 bit */
3333  SIUL_PGPDO_16B_tag PGPDO9; /* offset: 0x0C12 size: 16 bit */
3334  SIUL_PGPDO_16B_tag PGPDO10; /* offset: 0x0C14 size: 16 bit */
3335  SIUL_PGPDO_16B_tag PGPDO11; /* offset: 0x0C16 size: 16 bit */
3336  SIUL_PGPDO_16B_tag PGPDO12; /* offset: 0x0C18 size: 16 bit */
3337  SIUL_PGPDO_16B_tag PGPDO13; /* offset: 0x0C1A size: 16 bit */
3338  SIUL_PGPDO_16B_tag PGPDO14; /* offset: 0x0C1C size: 16 bit */
3339  SIUL_PGPDO_16B_tag PGPDO15; /* offset: 0x0C1E size: 16 bit */
3340  SIUL_PGPDO_16B_tag PGPDO16; /* offset: 0x0C20 size: 16 bit */
3341  SIUL_PGPDO_16B_tag PGPDO17; /* offset: 0x0C22 size: 16 bit */
3342  SIUL_PGPDO_16B_tag PGPDO18; /* offset: 0x0C24 size: 16 bit */
3343  SIUL_PGPDO_16B_tag PGPDO19; /* offset: 0x0C26 size: 16 bit */
3344  SIUL_PGPDO_16B_tag PGPDO20; /* offset: 0x0C28 size: 16 bit */
3345  SIUL_PGPDO_16B_tag PGPDO21; /* offset: 0x0C2A size: 16 bit */
3346  SIUL_PGPDO_16B_tag PGPDO22; /* offset: 0x0C2C size: 16 bit */
3347  SIUL_PGPDO_16B_tag PGPDO23; /* offset: 0x0C2E size: 16 bit */
3348  SIUL_PGPDO_16B_tag PGPDO24; /* offset: 0x0C30 size: 16 bit */
3349  SIUL_PGPDO_16B_tag PGPDO25; /* offset: 0x0C32 size: 16 bit */
3350  SIUL_PGPDO_16B_tag PGPDO26; /* offset: 0x0C34 size: 16 bit */
3351  SIUL_PGPDO_16B_tag PGPDO27; /* offset: 0x0C36 size: 16 bit */
3352  SIUL_PGPDO_16B_tag PGPDO28; /* offset: 0x0C38 size: 16 bit */
3353  SIUL_PGPDO_16B_tag PGPDO29; /* offset: 0x0C3A size: 16 bit */
3354  SIUL_PGPDO_16B_tag PGPDO30; /* offset: 0x0C3C size: 16 bit */
3355  SIUL_PGPDO_16B_tag PGPDO31; /* offset: 0x0C3E size: 16 bit */
3356  };
3357
3358  };
3359  union {
3360  /* PGPDI - Parallel GPIO Pad Data In Register */
3361  SIUL_PGPDI_16B_tag PGPDI[32]; /* offset: 0x0C40 (0x0002 x 32) */
3362
3363  struct {
3364  /* PGPDI - Parallel GPIO Pad Data In Register */
3365  SIUL_PGPDI_16B_tag PGPDI0; /* offset: 0x0C40 size: 16 bit */
3366  SIUL_PGPDI_16B_tag PGPDI1; /* offset: 0x0C42 size: 16 bit */
3367  SIUL_PGPDI_16B_tag PGPDI2; /* offset: 0x0C44 size: 16 bit */
3368  SIUL_PGPDI_16B_tag PGPDI3; /* offset: 0x0C46 size: 16 bit */
3369  SIUL_PGPDI_16B_tag PGPDI4; /* offset: 0x0C48 size: 16 bit */
3370  SIUL_PGPDI_16B_tag PGPDI5; /* offset: 0x0C4A size: 16 bit */
3371  SIUL_PGPDI_16B_tag PGPDI6; /* offset: 0x0C4C size: 16 bit */
3372  SIUL_PGPDI_16B_tag PGPDI7; /* offset: 0x0C4E size: 16 bit */
3373  SIUL_PGPDI_16B_tag PGPDI8; /* offset: 0x0C50 size: 16 bit */
3374  SIUL_PGPDI_16B_tag PGPDI9; /* offset: 0x0C52 size: 16 bit */
3375  SIUL_PGPDI_16B_tag PGPDI10; /* offset: 0x0C54 size: 16 bit */
3376  SIUL_PGPDI_16B_tag PGPDI11; /* offset: 0x0C56 size: 16 bit */
3377  SIUL_PGPDI_16B_tag PGPDI12; /* offset: 0x0C58 size: 16 bit */
3378  SIUL_PGPDI_16B_tag PGPDI13; /* offset: 0x0C5A size: 16 bit */
3379  SIUL_PGPDI_16B_tag PGPDI14; /* offset: 0x0C5C size: 16 bit */
3380  SIUL_PGPDI_16B_tag PGPDI15; /* offset: 0x0C5E size: 16 bit */
3381  SIUL_PGPDI_16B_tag PGPDI16; /* offset: 0x0C60 size: 16 bit */
3382  SIUL_PGPDI_16B_tag PGPDI17; /* offset: 0x0C62 size: 16 bit */
3383  SIUL_PGPDI_16B_tag PGPDI18; /* offset: 0x0C64 size: 16 bit */
3384  SIUL_PGPDI_16B_tag PGPDI19; /* offset: 0x0C66 size: 16 bit */
3385  SIUL_PGPDI_16B_tag PGPDI20; /* offset: 0x0C68 size: 16 bit */
3386  SIUL_PGPDI_16B_tag PGPDI21; /* offset: 0x0C6A size: 16 bit */
3387  SIUL_PGPDI_16B_tag PGPDI22; /* offset: 0x0C6C size: 16 bit */
3388  SIUL_PGPDI_16B_tag PGPDI23; /* offset: 0x0C6E size: 16 bit */
3389  SIUL_PGPDI_16B_tag PGPDI24; /* offset: 0x0C70 size: 16 bit */
3390  SIUL_PGPDI_16B_tag PGPDI25; /* offset: 0x0C72 size: 16 bit */
3391  SIUL_PGPDI_16B_tag PGPDI26; /* offset: 0x0C74 size: 16 bit */
3392  SIUL_PGPDI_16B_tag PGPDI27; /* offset: 0x0C76 size: 16 bit */
3393  SIUL_PGPDI_16B_tag PGPDI28; /* offset: 0x0C78 size: 16 bit */
3394  SIUL_PGPDI_16B_tag PGPDI29; /* offset: 0x0C7A size: 16 bit */
3395  SIUL_PGPDI_16B_tag PGPDI30; /* offset: 0x0C7C size: 16 bit */
3396  SIUL_PGPDI_16B_tag PGPDI31; /* offset: 0x0C7E size: 16 bit */
3397  };
3398
3399  };
3400  union {
3401  /* MPGPDO - Masked Parallel GPIO Pad Data Out Register */
3402  SIUL_MPGPDO_32B_tag MPGPDO[32]; /* offset: 0x0C80 (0x0004 x 32) */
3403
3404  struct {
3405  /* MPGPDO - Masked Parallel GPIO Pad Data Out Register */
3406  SIUL_MPGPDO_32B_tag MPGPDO0; /* offset: 0x0C80 size: 32 bit */
3407  SIUL_MPGPDO_32B_tag MPGPDO1; /* offset: 0x0C84 size: 32 bit */
3408  SIUL_MPGPDO_32B_tag MPGPDO2; /* offset: 0x0C88 size: 32 bit */
3409  SIUL_MPGPDO_32B_tag MPGPDO3; /* offset: 0x0C8C size: 32 bit */
3410  SIUL_MPGPDO_32B_tag MPGPDO4; /* offset: 0x0C90 size: 32 bit */
3411  SIUL_MPGPDO_32B_tag MPGPDO5; /* offset: 0x0C94 size: 32 bit */
3412  SIUL_MPGPDO_32B_tag MPGPDO6; /* offset: 0x0C98 size: 32 bit */
3413  SIUL_MPGPDO_32B_tag MPGPDO7; /* offset: 0x0C9C size: 32 bit */
3414  SIUL_MPGPDO_32B_tag MPGPDO8; /* offset: 0x0CA0 size: 32 bit */
3415  SIUL_MPGPDO_32B_tag MPGPDO9; /* offset: 0x0CA4 size: 32 bit */
3416  SIUL_MPGPDO_32B_tag MPGPDO10; /* offset: 0x0CA8 size: 32 bit */
3417  SIUL_MPGPDO_32B_tag MPGPDO11; /* offset: 0x0CAC size: 32 bit */
3418  SIUL_MPGPDO_32B_tag MPGPDO12; /* offset: 0x0CB0 size: 32 bit */
3419  SIUL_MPGPDO_32B_tag MPGPDO13; /* offset: 0x0CB4 size: 32 bit */
3420  SIUL_MPGPDO_32B_tag MPGPDO14; /* offset: 0x0CB8 size: 32 bit */
3421  SIUL_MPGPDO_32B_tag MPGPDO15; /* offset: 0x0CBC size: 32 bit */
3422  SIUL_MPGPDO_32B_tag MPGPDO16; /* offset: 0x0CC0 size: 32 bit */
3423  SIUL_MPGPDO_32B_tag MPGPDO17; /* offset: 0x0CC4 size: 32 bit */
3424  SIUL_MPGPDO_32B_tag MPGPDO18; /* offset: 0x0CC8 size: 32 bit */
3425  SIUL_MPGPDO_32B_tag MPGPDO19; /* offset: 0x0CCC size: 32 bit */
3426  SIUL_MPGPDO_32B_tag MPGPDO20; /* offset: 0x0CD0 size: 32 bit */
3427  SIUL_MPGPDO_32B_tag MPGPDO21; /* offset: 0x0CD4 size: 32 bit */
3428  SIUL_MPGPDO_32B_tag MPGPDO22; /* offset: 0x0CD8 size: 32 bit */
3429  SIUL_MPGPDO_32B_tag MPGPDO23; /* offset: 0x0CDC size: 32 bit */
3430  SIUL_MPGPDO_32B_tag MPGPDO24; /* offset: 0x0CE0 size: 32 bit */
3431  SIUL_MPGPDO_32B_tag MPGPDO25; /* offset: 0x0CE4 size: 32 bit */
3432  SIUL_MPGPDO_32B_tag MPGPDO26; /* offset: 0x0CE8 size: 32 bit */
3433  SIUL_MPGPDO_32B_tag MPGPDO27; /* offset: 0x0CEC size: 32 bit */
3434  SIUL_MPGPDO_32B_tag MPGPDO28; /* offset: 0x0CF0 size: 32 bit */
3435  SIUL_MPGPDO_32B_tag MPGPDO29; /* offset: 0x0CF4 size: 32 bit */
3436  SIUL_MPGPDO_32B_tag MPGPDO30; /* offset: 0x0CF8 size: 32 bit */
3437  SIUL_MPGPDO_32B_tag MPGPDO31; /* offset: 0x0CFC size: 32 bit */
3438  };
3439
3440  };
3441  int8_t SIUL_reserved_0D00_C[768];
3442  union {
3443  /* IFMC - Interrupt Filter Maximum Counter Register */
3444  SIUL_IFMC_32B_tag IFMC[32]; /* offset: 0x1000 (0x0004 x 32) */
3445
3446  struct {
3447  /* IFMC - Interrupt Filter Maximum Counter Register */
3448  SIUL_IFMC_32B_tag IFMC0; /* offset: 0x1000 size: 32 bit */
3449  SIUL_IFMC_32B_tag IFMC1; /* offset: 0x1004 size: 32 bit */
3450  SIUL_IFMC_32B_tag IFMC2; /* offset: 0x1008 size: 32 bit */
3451  SIUL_IFMC_32B_tag IFMC3; /* offset: 0x100C size: 32 bit */
3452  SIUL_IFMC_32B_tag IFMC4; /* offset: 0x1010 size: 32 bit */
3453  SIUL_IFMC_32B_tag IFMC5; /* offset: 0x1014 size: 32 bit */
3454  SIUL_IFMC_32B_tag IFMC6; /* offset: 0x1018 size: 32 bit */
3455  SIUL_IFMC_32B_tag IFMC7; /* offset: 0x101C size: 32 bit */
3456  SIUL_IFMC_32B_tag IFMC8; /* offset: 0x1020 size: 32 bit */
3457  SIUL_IFMC_32B_tag IFMC9; /* offset: 0x1024 size: 32 bit */
3458  SIUL_IFMC_32B_tag IFMC10; /* offset: 0x1028 size: 32 bit */
3459  SIUL_IFMC_32B_tag IFMC11; /* offset: 0x102C size: 32 bit */
3460  SIUL_IFMC_32B_tag IFMC12; /* offset: 0x1030 size: 32 bit */
3461  SIUL_IFMC_32B_tag IFMC13; /* offset: 0x1034 size: 32 bit */
3462  SIUL_IFMC_32B_tag IFMC14; /* offset: 0x1038 size: 32 bit */
3463  SIUL_IFMC_32B_tag IFMC15; /* offset: 0x103C size: 32 bit */
3464  SIUL_IFMC_32B_tag IFMC16; /* offset: 0x1040 size: 32 bit */
3465  SIUL_IFMC_32B_tag IFMC17; /* offset: 0x1044 size: 32 bit */
3466  SIUL_IFMC_32B_tag IFMC18; /* offset: 0x1048 size: 32 bit */
3467  SIUL_IFMC_32B_tag IFMC19; /* offset: 0x104C size: 32 bit */
3468  SIUL_IFMC_32B_tag IFMC20; /* offset: 0x1050 size: 32 bit */
3469  SIUL_IFMC_32B_tag IFMC21; /* offset: 0x1054 size: 32 bit */
3470  SIUL_IFMC_32B_tag IFMC22; /* offset: 0x1058 size: 32 bit */
3471  SIUL_IFMC_32B_tag IFMC23; /* offset: 0x105C size: 32 bit */
3472  SIUL_IFMC_32B_tag IFMC24; /* offset: 0x1060 size: 32 bit */
3473  SIUL_IFMC_32B_tag IFMC25; /* offset: 0x1064 size: 32 bit */
3474  SIUL_IFMC_32B_tag IFMC26; /* offset: 0x1068 size: 32 bit */
3475  SIUL_IFMC_32B_tag IFMC27; /* offset: 0x106C size: 32 bit */
3476  SIUL_IFMC_32B_tag IFMC28; /* offset: 0x1070 size: 32 bit */
3477  SIUL_IFMC_32B_tag IFMC29; /* offset: 0x1074 size: 32 bit */
3478  SIUL_IFMC_32B_tag IFMC30; /* offset: 0x1078 size: 32 bit */
3479  SIUL_IFMC_32B_tag IFMC31; /* offset: 0x107C size: 32 bit */
3480  };
3481
3482  };
3483  /* IFCPR - Inerrupt Filter Clock Prescaler Register */
3484  SIUL_IFCPR_32B_tag IFCPR; /* offset: 0x1080 size: 32 bit */
3485  } SIU_tag;
3486
3487
3488 #define SIUL (*(volatile SIU_tag *) 0xC3F90000UL)
3489
3490
3491
3492 /****************************************************************/
3493 /* */
3494 /* Module: WKPU */
3495 /* */
3496 /****************************************************************/
3497
3498  typedef union { /* WKPU_NSR - NMI Status Flag Register */
3499  uint32_t R;
3500  struct {
3501  uint32_t NIF0:1; /* NMI Status Flag 0 */
3502  uint32_t NOVF0:1; /* NMI Overrun Status Flag 0 */
3503  uint32_t:6;
3504  uint32_t NIF1:1; /* NMI Status Flag 1 */
3505  uint32_t NOVF1:1; /* NMI Overrun Status Flag 1 */
3506  uint32_t:6;
3507  uint32_t NIF2:1; /* NMI Status Flag 2 */
3508  uint32_t NOVF2:1; /* NMI Overrun Status Flag 2 */
3509  uint32_t:6;
3510  uint32_t NIF3:1; /* NMI Status Flag 3 */
3511  uint32_t NOVF3:1; /* NMI Overrun Status Flag 3 */
3512  uint32_t:6;
3513  } B;
3514  } WKPU_NSR_32B_tag;
3515
3516  typedef union { /* WKPU_NCR - NMI Configuration Register */
3517  uint32_t R;
3518  struct {
3519  uint32_t NLOCK0:1; /* NMI Configuration Lock Register 0 */
3520  uint32_t NDSS0:2; /* NMI Desination Source Select 0 */
3521  uint32_t NWRE0:1; /* NMI Wakeup Request Enable 0 */
3522  uint32_t:1;
3523  uint32_t NREE0:1; /* NMI Rising Edge Events Enable 0 */
3524  uint32_t NFEE0:1; /* NMI Falling Edge Events Enable 0 */
3525  uint32_t NFE0:1; /* NMI Filter Enable 0 */
3526  uint32_t NLOCK1:1; /* NMI Configuration Lock Register 1 */
3527  uint32_t NDSS1:2; /* NMI Desination Source Select 1 */
3528  uint32_t NWRE1:1; /* NMI Wakeup Request Enable 1 */
3529  uint32_t:1;
3530  uint32_t NREE1:1; /* NMI Rising Edge Events Enable 1 */
3531  uint32_t NFEE1:1; /* NMI Falling Edge Events Enable 1 */
3532  uint32_t NFE1:1; /* NMI Filter Enable 1 */
3533  uint32_t NLOCK2:1; /* NMI Configuration Lock Register 2 */
3534  uint32_t NDSS2:2; /* NMI Desination Source Select 2 */
3535  uint32_t NWRE2:1; /* NMI Wakeup Request Enable 2 */
3536  uint32_t:1;
3537  uint32_t NREE2:1; /* NMI Rising Edge Events Enable 2 */
3538  uint32_t NFEE2:1; /* NMI Falling Edge Events Enable 2 */
3539  uint32_t NFE2:1; /* NMI Filter Enable 2 */
3540  uint32_t NLOCK3:1; /* NMI Configuration Lock Register 3 */
3541  uint32_t NDSS3:2; /* NMI Desination Source Select 3 */
3542  uint32_t NWRE3:1; /* NMI Wakeup Request Enable 3 */
3543  uint32_t:1;
3544  uint32_t NREE3:1; /* NMI Rising Edge Events Enable 3 */
3545  uint32_t NFEE3:1; /* NMI Falling Edge Events Enable 3 */
3546  uint32_t NFE3:1; /* NMI Filter Enable 3 */
3547  } B;
3548  } WKPU_NCR_32B_tag;
3549
3550  typedef union { /* WKPU_WISR - Wakeup/Interrupt Status Flag Register */
3551  uint32_t R;
3552  struct {
3553  uint32_t EIF:32; /* External Wakeup/Interrupt Status Flag */
3554  } B;
3556
3557  typedef union { /* WKPU_IRER - Interrupt Request Enable Register */
3558  uint32_t R;
3559  struct {
3560  uint32_t EIRE:32; /* Enable External Interrupt Requests */
3561  } B;
3563
3564  typedef union { /* WKPU_WRER - Wakeup Request Enable Register */
3565  uint32_t R;
3566  struct {
3567  uint32_t WRE:32; /* Enable Wakeup requests to the mode entry module */
3568  } B;
3570
3571  typedef union { /* WKPU_WIREER - Wakeup/Interrupt Rising-Edge Event Enable Register */
3572  uint32_t R;
3573  struct {
3574  uint32_t IREE:32; /* Enable rising-edge events to cause EIF[x] to be set */
3575  } B;
3577
3578  typedef union { /* WKPU_WIFEER - Wakeup/Interrupt Falling-Edge Event Enable Register */
3579  uint32_t R;
3580  struct {
3581  uint32_t IFEE:32; /* Enable Falling-edge events to cause EIF[x] to be set */
3582  } B;
3584
3585  typedef union { /* WKPU_WIFER - Wakeup/Interrupt Filter Enable Register */
3586  uint32_t R;
3587  struct {
3588  uint32_t IFE:32; /* Enable Digital glitch filter on the interrupt pad input */
3589  } B;
3591
3592  typedef union { /* WKPU_WIPUER - Wakeup/Interrupt Pullup Enable Register */
3593  uint32_t R;
3594  struct {
3595  uint32_t IPUE:32; /* Enable a pullup on the interrupt pad input */
3596  } B;
3598
3599
3600
3601  typedef struct WKPU_struct_tag { /* start of WKPU_tag */
3602  /* WKPU_NSR - NMI Status Flag Register */
3603  WKPU_NSR_32B_tag NSR; /* offset: 0x0000 size: 32 bit */
3604  int8_t WKPU_reserved_0004[4];
3605  /* WKPU_NCR - NMI Configuration Register */
3606  WKPU_NCR_32B_tag NCR; /* offset: 0x0008 size: 32 bit */
3607  int8_t WKPU_reserved_000C[8];
3608  /* WKPU_WISR - Wakeup/Interrupt Status Flag Register */
3609  WKPU_WISR_32B_tag WISR; /* offset: 0x0014 size: 32 bit */
3610  /* WKPU_IRER - Interrupt Request Enable Register */
3611  WKPU_IRER_32B_tag IRER; /* offset: 0x0018 size: 32 bit */
3612  /* WKPU_WRER - Wakeup Request Enable Register */
3613  WKPU_WRER_32B_tag WRER; /* offset: 0x001C size: 32 bit */
3614  int8_t WKPU_reserved_0020[8];
3615  /* WKPU_WIREER - Wakeup/Interrupt Rising-Edge Event Enable Register */
3616  WKPU_WIREER_32B_tag WIREER; /* offset: 0x0028 size: 32 bit */
3617  /* WKPU_WIFEER - Wakeup/Interrupt Falling-Edge Event Enable Register */
3618  WKPU_WIFEER_32B_tag WIFEER; /* offset: 0x002C size: 32 bit */
3619  /* WKPU_WIFER - Wakeup/Interrupt Filter Enable Register */
3620  WKPU_WIFER_32B_tag WIFER; /* offset: 0x0030 size: 32 bit */
3621  /* WKPU_WIPUER - Wakeup/Interrupt Pullup Enable Register */
3622  WKPU_WIPUER_32B_tag WIPUER; /* offset: 0x0034 size: 32 bit */
3623  } WKPU_tag;
3624
3625
3626 #define WKPU (*(volatile WKPU_tag *) 0xC3F94000UL)
3627
3628
3629
3630 /****************************************************************/
3631 /* */
3632 /* Module: SSCM */
3633 /* */
3634 /****************************************************************/
3635
3636  typedef union { /* SSCM_STATUS - System Status Register */
3637  uint16_t R;
3638  struct {
3639  uint16_t LSM:1; /* Lock Step Mode */
3640  uint16_t:2;
3641  uint16_t NXEN1:1; /* Processor 1 Nexus enabled */
3642  uint16_t NXEN:1; /* Processor 0 Nexus enabled */
3643  uint16_t PUB:1; /* Public Serial Access Status */
3644  uint16_t SEC:1; /* Security Status */
3645  uint16_t:1;
3646  uint16_t BMODE:3; /* Device Boot Mode */
3647  uint16_t VLE:1; /* Variable Length Instruction Mode */
3648  uint16_t ABD:1; /* Autobaud detection */
3649  uint16_t:3;
3650  } B;
3652
3653  typedef union { /* SSCM_MEMCONFIG - System Memory Configuration Register */
3654  uint16_t R;
3655  struct {
3656  uint16_t JPIN:10; /* JTAG Part ID Number */
3657  uint16_t IVLD:1; /* Instruction Flash Valid */
3658  uint16_t MREV:4; /* Minor Mask Revision */
3659  uint16_t DVLD:1; /* Data Flash Valid */
3660  } B;
3662
3663  typedef union { /* SSCM_ERROR - Error Configuration */
3664  uint16_t R;
3665  struct {
3666  uint16_t:14;
3667  uint16_t PAE:1; /* Peripheral Bus Abort Enable */
3668  uint16_t RAE:1; /* Register Bus Abort Enable */
3669  } B;
3671
3672  typedef union { /* SSCM_DEBUGPORT - Debug Status Port Register */
3673  uint16_t R;
3674  struct {
3675  uint16_t:13;
3676  uint16_t DEBUG_MODE:3; /* Debug Status Port Mode */
3677  } B;
3679
3680  typedef union { /* SSCM_PWCMPH - Password Comparison Register High */
3681  uint32_t R;
3682  struct {
3683  uint32_t PWD_HI:32; /* Password High */
3684  } B;
3686
3687  typedef union { /* SSCM_PWCMPL - Password Comparison Register Low */
3688  uint32_t R;
3689  struct {
3690  uint32_t PWD_LO:32; /* Password Low */
3691  } B;
3693
3694  typedef union { /* SSCM_DPMBOOT - Decoupled Parallel Boot Register */
3695  uint32_t R;
3696  struct {
3697  uint32_t P2BOOT:30; /* boot location 2nd processor */
3698  uint32_t DVLE:1; /* VLE mode for 2nd processor */
3699  uint32_t:1;
3700  } B;
3702
3703  typedef union { /* SSCM_DPMKEY - Boot Key Register */
3704  uint32_t R;
3705  struct {
3706  uint32_t KEY:32; /* Boot Control Key */
3707  } B;
3709
3710  typedef union { /* SSCM_UOPS - User Option Status Register */
3711  uint32_t R;
3712  struct {
3713  uint32_t UOPT:32; /* User Option Bits */
3714  } B;
3716
3717  typedef union { /* SSCM_SCTR - SSCM Control Register */
3718  uint32_t R;
3719  struct {
3720  uint32_t:29;
3721  uint32_t TFE:1; /* Test Flash Enable */
3722  uint32_t DSL:1; /* Disable Software-Controlled MBIST */
3723  uint32_t DSM:1; /* Disable Software-Controlled LBIST */
3724  } B;
3726
3727  typedef union { /* SSCM_TF_INFO0 - TestFlash Information Register 0 */
3728  uint32_t R;
3729  struct {
3730  uint32_t TINFO0:32; /* General purpose TestFlash word 0 */
3731  } B;
3733
3734  typedef union { /* SSCM_TF_INFO1 - TestFlash Information Register 1 */
3735  uint32_t R;
3736  struct {
3737  uint32_t TINFO1:32; /* General purpose TestFlash word 1 */
3738  } B;
3740
3741  typedef union { /* SSCM_TF_INFO2 - TestFlash Information Register 2 */
3742  uint32_t R;
3743  struct {
3744  uint32_t TINFO2:32; /* General purpose TestFlash word 2 */
3745  } B;
3747
3748  typedef union { /* SSCM_TF_INFO3 - TestFlash Information Register 3 */
3749  uint32_t R;
3750  struct {
3751  uint32_t TINFO3:32; /* General purpose TestFlash word */
3752  } B;
3754
3755
3756
3757  typedef struct SSCM_struct_tag { /* start of SSCM_tag */
3758  /* SSCM_STATUS - System Status Register */
3759  SSCM_STATUS_16B_tag STATUS; /* offset: 0x0000 size: 16 bit */
3760  /* SSCM_MEMCONFIG - System Memory Configuration Register */
3761  SSCM_MEMCONFIG_16B_tag MEMCONFIG; /* offset: 0x0002 size: 16 bit */
3762  int8_t SSCM_reserved_0004[2];
3763  /* SSCM_ERROR - Error Configuration */
3764  SSCM_ERROR_16B_tag ERROR; /* offset: 0x0006 size: 16 bit */
3765  /* SSCM_DEBUGPORT - Debug Status Port Register */
3766  SSCM_DEBUGPORT_16B_tag DEBUGPORT; /* offset: 0x0008 size: 16 bit */
3767  int8_t SSCM_reserved_000A[2];
3768  /* SSCM_PWCMPH - Password Comparison Register High */
3769  SSCM_PWCMPH_32B_tag PWCMPH; /* offset: 0x000C size: 32 bit */
3770  /* SSCM_PWCMPL - Password Comparison Register Low */
3771  SSCM_PWCMPL_32B_tag PWCMPL; /* offset: 0x0010 size: 32 bit */
3772  int8_t SSCM_reserved_0014[4];
3773  /* SSCM_DPMBOOT - Decoupled Parallel Boot Register */
3774  SSCM_DPMBOOT_32B_tag DPMBOOT; /* offset: 0x0018 size: 32 bit */
3775  /* SSCM_DPMKEY - Boot Key Register */
3776  SSCM_DPMKEY_32B_tag DPMKEY; /* offset: 0x001C size: 32 bit */
3777  /* SSCM_UOPS - User Option Status Register */
3778  SSCM_UOPS_32B_tag UOPS; /* offset: 0x0020 size: 32 bit */
3779  /* SSCM_SCTR - SSCM Control Register */
3780  SSCM_SCTR_32B_tag SCTR; /* offset: 0x0024 size: 32 bit */
3781  /* SSCM_TF_INFO0 - TestFlash Information Register 0 */
3782  SSCM_TF_INFO0_32B_tag TF_INFO0; /* offset: 0x0028 size: 32 bit */
3783  /* SSCM_TF_INFO1 - TestFlash Information Register 1 */
3784  SSCM_TF_INFO1_32B_tag TF_INFO1; /* offset: 0x002C size: 32 bit */
3785  /* SSCM_TF_INFO2 - TestFlash Information Register 2 */
3786  SSCM_TF_INFO2_32B_tag TF_INFO2; /* offset: 0x0030 size: 32 bit */
3787  /* SSCM_TF_INFO3 - TestFlash Information Register 3 */
3788  SSCM_TF_INFO3_32B_tag TF_INFO3; /* offset: 0x0034 size: 32 bit */
3789  } SSCM_tag;
3790
3791
3792 #define SSCM (*(volatile SSCM_tag *) 0xC3FD8000UL)
3793
3794
3795
3796 /****************************************************************/
3797 /* */
3798 /* Module: ME */
3799 /* */
3800 /****************************************************************/
3801
3802  typedef union { /* ME_GS - Global Status Register */
3803  uint32_t R;
3804  struct {
3805 #ifndef USE_FIELD_ALIASES_ME
3806  uint32_t S_CURRENT_MODE:4; /* Current device mode status */
3807 #else
3808  uint32_t S_CURRENTMODE:4; /* deprecated name - please avoid */
3809 #endif
3810  uint32_t S_MTRANS:1; /* Mode transition status */
3811  uint32_t:3;
3812  uint32_t S_PDO:1; /* Output power-down status */
3813  uint32_t:2;
3814  uint32_t S_MVR:1; /* Main voltage regulator status */
3815  uint32_t:2;
3816 #ifndef USE_FIELD_ALIASES_ME
3817  uint32_t S_FLA:2; /* Flash availability status */
3818 #else
3819  uint32_t S_CFLA:2; /* deprecated name - please avoid */
3820 #endif
3821  uint32_t:8;
3822  uint32_t S_PLL1:1; /* Secondary PLL status */
3823  uint32_t S_PLL0:1; /* System PLL status */
3824 #ifndef USE_FIELD_ALIASES_ME
3825  uint32_t S_XOSC:1; /* System crystal oscillator status */
3826 #else
3827  uint32_t S_OSC:1; /* deprecated name - please avoid */
3828 #endif
3829 #ifndef USE_FIELD_ALIASES_ME
3830  uint32_t S_IRCOSC:1; /* System RC oscillator status */
3831 #else
3832  uint32_t S_RC:1; /* deprecated name - please avoid */
3833 #endif
3834  uint32_t S_SYSCLK:4; /* System clock switch status */
3835  } B;
3836  } ME_GS_32B_tag;
3837
3838  typedef union { /* ME_MCTL - Mode Control Register */
3839  uint32_t R;
3840  struct {
3841  uint32_t TARGET_MODE:4; /* Target device mode */
3842  uint32_t:12;
3843  uint32_t KEY:16; /* Control key */
3844  } B;
3845  } ME_MCTL_32B_tag;
3846
3847  typedef union { /* ME_MEN - Mode Enable Register */
3848  uint32_t R;
3849  struct {
3850  uint32_t:21;
3851  uint32_t STOP0:1; /* STOP0 mode enable */
3852  uint32_t:1;
3853  uint32_t HALT0:1; /* HALT0 mode enable */
3854  uint32_t RUN3:1; /* RUN3 mode enable */
3855  uint32_t RUN2:1; /* RUN2 mode enable */
3856  uint32_t RUN1:1; /* RUN1 mode enable */
3857  uint32_t RUN0:1; /* RUN0 mode enable */
3858  uint32_t DRUN:1; /* DRUN mode enable */
3859  uint32_t SAFE:1; /* SAFE mode enable */
3860  uint32_t:1;
3861  uint32_t RESET:1; /* RESET mode enable */
3862  } B;
3863  } ME_MEN_32B_tag;
3864
3865  typedef union { /* ME_IS - Interrupt Status Register */
3866  uint32_t R;
3867  struct {
3868  uint32_t:28;
3869 #ifndef USE_FIELD_ALIASES_ME
3870  uint32_t I_ICONF:1; /* Invalid mode config interrupt */
3871 #else
3872  uint32_t I_CONF:1; /* deprecated name - please avoid */
3873 #endif
3874 #ifndef USE_FIELD_ALIASES_ME
3875  uint32_t I_IMODE:1; /* Invalid mode interrupt */
3876 #else
3877  uint32_t I_MODE:1; /* deprecated name - please avoid */
3878 #endif
3879  uint32_t I_SAFE:1; /* SAFE mode interrupt */
3880 #ifndef USE_FIELD_ALIASES_ME
3881  uint32_t I_MTC:1; /* Mode transition complete interrupt */
3882 #else
3883  uint32_t I_TC:1; /* deprecated name - please avoid */
3884 #endif
3885  } B;
3886  } ME_IS_32B_tag;
3887
3888  typedef union { /* ME_IM - Interrupt Mask Register */
3889  uint32_t R;
3890  struct {
3891  uint32_t:28;
3892 #ifndef USE_FIELD_ALIASES_ME
3893  uint32_t M_ICONF:1; /* Invalid mode config interrupt mask */
3894 #else
3895  uint32_t M_CONF:1; /* deprecated name - please avoid */
3896 #endif
3897 #ifndef USE_FIELD_ALIASES_ME
3898  uint32_t M_IMODE:1; /* Invalid mode interrupt mask */
3899 #else
3900  uint32_t M_MODE:1; /* deprecated name - please avoid */
3901 #endif
3902  uint32_t M_SAFE:1; /* SAFE mode interrupt mask */
3903 #ifndef USE_FIELD_ALIASES_ME
3904  uint32_t M_MTC:1; /* Mode transition complete interrupt mask */
3905 #else
3906  uint32_t M_TC:1; /* deprecated name - please avoid */
3907 #endif
3908  } B;
3909  } ME_IM_32B_tag;
3910
3911  typedef union { /* ME_IMTS - Invalid Mode Transition Status Register */
3912  uint32_t R;
3913  struct {
3914  uint32_t:27;
3915  uint32_t S_MTI:1; /* Mode Transition Illegal status */
3916  uint32_t S_MRI:1; /* Mode Request Illegal status */
3917  uint32_t S_DMA:1; /* Disabled Mode Access status */
3918  uint32_t S_NMA:1; /* Non-existing Mode Access status */
3919  uint32_t S_SEA:1; /* Safe Event Active status */
3920  } B;
3921  } ME_IMTS_32B_tag;
3922
3923  typedef union { /* ME_DMTS - Debug Mode Transition Status Register */
3924  uint32_t R;
3925  struct {
3926  uint32_t PREVIOUS_MODE:4; /* Previous Device Mode */
3927  uint32_t:4;
3928  uint32_t MPH_BUSY:1; /* MC_ME/MC_PCU Handshake Busy Indicator */
3929  uint32_t:2;
3930  uint32_t PMC_PROG:1; /* MC_PCU Mode Change in Process Indicator */
3931  uint32_t CORE_DBG:1; /* Processor is in Debug Mode Indicator */
3932  uint32_t:2;
3933  uint32_t SMR:1; /* SAFE Mode Request */
3934  uint32_t:1;
3935  uint32_t VREG_CSRC_SC:1; /* Main VREG Clock Source State Change Indicator */
3936  uint32_t CSRC_CSRC_SC:1; /* Other Clock Source State Change Indicator */
3937  uint32_t IRCOSC_SC:1; /* IRCOSC State Change Indicator */
3938  uint32_t SCSRC_SC:1; /* Secondary System Clock Sources State Change Indicator */
3939  uint32_t SYSCLK_SW:1; /* System Clock Switching pending Status Indicator */
3940  uint32_t:1;
3941  uint32_t FLASH_SC:1; /* FLASH State Change Indicator */
3942  uint32_t CDP_PRPH_0_143:1; /* Clock Disable Process Pending Status for Periph. 0-143 */
3943  uint32_t:4;
3944  uint32_t CDP_PRPH_64_95:1; /* Clock Disable Process Pending Status for Periph. 64-95 */
3945  uint32_t CDP_PRPH_32_63:1; /* Clock Disable Process Pending Status for Periph. 32-63 */
3946  uint32_t CDP_PRPH_0_31:1; /* Clock Disable Process Pending Status for Periph. 0-31 */
3947  } B;
3948  } ME_DMTS_32B_tag;
3949
3950  typedef union { /* ME_RESET_MC - RESET Mode Configuration Register */
3951  uint32_t R;
3952  struct {
3953  uint32_t:8;
3954  uint32_t PDO:1; /* IOs output power-down control */
3955  uint32_t:2;
3956  uint32_t MVRON:1; /* Main voltage regulator control */
3957  uint32_t:2;
3958  uint32_t FLAON:2; /* Flash power-down control */
3959  uint32_t:8;
3960 #ifndef USE_FIELD_ALIASES_ME
3961  uint32_t PLL1ON:1; /* Secondary system clock source [8..0] control */
3962 #else
3963  uint32_t PLL2ON:1; /* deprecated name - please avoid */
3964 #endif
3965 #ifndef USE_FIELD_ALIASES_ME
3966  uint32_t PLL0ON:1; /* System PLL control */
3967 #else
3968  uint32_t PLL1ON:1; /* deprecated name - please avoid */
3969 #endif
3970 #ifndef USE_FIELD_ALIASES_ME
3971  uint32_t XOSCON:1; /* System crystal oscillator control */
3972 #else
3973  uint32_t XOSC0ON:1; /* deprecated name - please avoid */
3974 #endif
3975 #ifndef USE_FIELD_ALIASES_ME
3976  uint32_t IRCOSCON:1; /* System RC oscillator control */
3977 #else
3978  uint32_t IRCON:1; /* deprecated name - please avoid */
3979 #endif
3980  uint32_t SYSCLK:4; /* System clock switch control */
3981  } B;
3983
3984  typedef union { /* ME_SAFE_MC - Mode Configuration Register */
3985  uint32_t R;
3986  struct {
3987  uint32_t:8;
3988  uint32_t PDO:1; /* IOs output power-down control */
3989  uint32_t:2;
3990  uint32_t MVRON:1; /* Main voltage regulator control */
3991  uint32_t:2;
3992  uint32_t FLAON:2; /* Flash power-down control */
3993  uint32_t:8;
3994 #ifndef USE_FIELD_ALIASES_ME
3995  uint32_t PLL1ON:1; /* Secondary system clock source [8..0] control */
3996 #else
3997  uint32_t PLL2ON:1; /* deprecated name - please avoid */
3998 #endif
3999 #ifndef USE_FIELD_ALIASES_ME
4000  uint32_t PLL0ON:1; /* System PLL control */
4001 #else
4002  uint32_t PLL1ON:1; /* deprecated name - please avoid */
4003 #endif
4004 #ifndef USE_FIELD_ALIASES_ME
4005  uint32_t XOSCON:1; /* System crystal oscillator control */
4006 #else
4007  uint32_t XOSC0ON:1; /* deprecated name - please avoid */
4008 #endif
4009 #ifndef USE_FIELD_ALIASES_ME
4010  uint32_t IRCOSCON:1; /* System RC oscillator control */
4011 #else
4012  uint32_t IRCON:1; /* deprecated name - please avoid */
4013 #endif
4014  uint32_t SYSCLK:4; /* System clock switch control */
4015  } B;
4017
4018  typedef union { /* ME_DRUN_MC - DRUN Mode Configuration Register */
4019  uint32_t R;
4020  struct {
4021  uint32_t:8;
4022  uint32_t PDO:1; /* IOs output power-down control */
4023  uint32_t:2;
4024  uint32_t MVRON:1; /* Main voltage regulator control */
4025  uint32_t:2;
4026  uint32_t FLAON:2; /* Flash power-down control */
4027  uint32_t:8;
4028 #ifndef USE_FIELD_ALIASES_ME
4029  uint32_t PLL1ON:1; /* Secondary system clock source [8..0] control */
4030 #else
4031  uint32_t PLL2ON:1; /* deprecated name - please avoid */
4032 #endif
4033 #ifndef USE_FIELD_ALIASES_ME
4034  uint32_t PLL0ON:1; /* System PLL control */
4035 #else
4036  uint32_t PLL1ON:1; /* deprecated name - please avoid */
4037 #endif
4038 #ifndef USE_FIELD_ALIASES_ME
4039  uint32_t XOSCON:1; /* System crystal oscillator control */
4040 #else
4041  uint32_t XOSC0ON:1; /* deprecated name - please avoid */
4042 #endif
4043 #ifndef USE_FIELD_ALIASES_ME
4044  uint32_t IRCOSCON:1; /* System RC oscillator control */
4045 #else
4046  uint32_t IRCON:1; /* deprecated name - please avoid */
4047 #endif
4048  uint32_t SYSCLK:4; /* System clock switch control */
4049  } B;
4051
4052
4053  /* Register layout for all registers RUN_MC... */
4054
4055  typedef union { /* ME_RUN[0..3]_MC - RUN[0..3] Mode Configuration Registers */
4056  uint32_t R;
4057  struct {
4058  uint32_t:8;
4059  uint32_t PDO:1; /* IOs output power-down control */
4060  uint32_t:2;
4061  uint32_t MVRON:1; /* Main voltage regulator control */
4062  uint32_t:2;
4063  uint32_t FLAON:2; /* Flash power-down control */
4064  uint32_t:8;
4065 #ifndef USE_FIELD_ALIASES_ME
4066  uint32_t PLL1ON:1; /* Secondary system clock source [8..0] control */
4067 #else
4068  uint32_t PLL2ON:1; /* deprecated name - please avoid */
4069 #endif
4070 #ifndef USE_FIELD_ALIASES_ME
4071  uint32_t PLL0ON:1; /* System PLL control */
4072 #else
4073  uint32_t PLL1ON:1; /* deprecated name - please avoid */
4074 #endif
4075 #ifndef USE_FIELD_ALIASES_ME
4076  uint32_t XOSCON:1; /* System crystal oscillator control */
4077 #else
4078  uint32_t XOSC0ON:1; /* deprecated name - please avoid */
4079 #endif
4080 #ifndef USE_FIELD_ALIASES_ME
4081  uint32_t IRCOSCON:1; /* System RC oscillator control */
4082 #else
4083  uint32_t IRCON:1; /* deprecated name - please avoid */
4084 #endif
4085  uint32_t SYSCLK:4; /* System clock switch control */
4086  } B;
4088
4089  typedef union { /* ME_HALT0_MC - HALT0 Mode Configuration Register */
4090  uint32_t R;
4091  struct {
4092  uint32_t:8;
4093  uint32_t PDO:1; /* IOs output power-down control */
4094  uint32_t:2;
4095  uint32_t MVRON:1; /* Main voltage regulator control */
4096  uint32_t:2;
4097  uint32_t FLAON:2; /* Flash power-down control */
4098  uint32_t:8;
4099 #ifndef USE_FIELD_ALIASES_ME
4100  uint32_t PLL1ON:1; /* Secondary system clock source [8..0] control */
4101 #else
4102  uint32_t PLL2ON:1; /* deprecated name - please avoid */
4103 #endif
4104 #ifndef USE_FIELD_ALIASES_ME
4105  uint32_t PLL0ON:1; /* System PLL control */
4106 #else
4107  uint32_t PLL1ON:1; /* deprecated name - please avoid */
4108 #endif
4109 #ifndef USE_FIELD_ALIASES_ME
4110  uint32_t XOSCON:1; /* System crystal oscillator control */
4111 #else
4112  uint32_t XOSC0ON:1; /* deprecated name - please avoid */
4113 #endif
4114 #ifndef USE_FIELD_ALIASES_ME
4115  uint32_t IRCOSCON:1; /* System RC oscillator control */
4116 #else
4117  uint32_t IRCON:1; /* deprecated name - please avoid */
4118 #endif
4119  uint32_t SYSCLK:4; /* System clock switch control */
4120  } B;
4122
4123  typedef union { /* ME_STOP0_MC - STOP0 Mode Configration Register */
4124  uint32_t R;
4125  struct {
4126  uint32_t:8;
4127  uint32_t PDO:1; /* IOs output power-down control */
4128  uint32_t:2;
4129  uint32_t MVRON:1; /* Main voltage regulator control */
4130  uint32_t:2;
4131  uint32_t FLAON:2; /* Flash power-down control */
4132  uint32_t:8;
4133 #ifndef USE_FIELD_ALIASES_ME
4134  uint32_t PLL1ON:1; /* Secondary system clock source [8..0] control */
4135 #else
4136  uint32_t PLL2ON:1; /* deprecated name - please avoid */
4137 #endif
4138 #ifndef USE_FIELD_ALIASES_ME
4139  uint32_t PLL0ON:1; /* System PLL control */
4140 #else
4141  uint32_t PLL1ON:1; /* deprecated name - please avoid */
4142 #endif
4143 #ifndef USE_FIELD_ALIASES_ME
4144  uint32_t XOSCON:1; /* System crystal oscillator control */
4145 #else
4146  uint32_t XOSC0ON:1; /* deprecated name - please avoid */
4147 #endif
4148 #ifndef USE_FIELD_ALIASES_ME
4149  uint32_t IRCOSCON:1; /* System RC oscillator control */
4150 #else
4151  uint32_t IRCON:1; /* deprecated name - please avoid */
4152 #endif
4153  uint32_t SYSCLK:4; /* System clock switch control */
4154  } B;
4156
4157  typedef union { /* ME_STANDBY0_MC - STANDBY0 Mode Configration Register */
4158  uint32_t R;
4159  struct {
4160  uint32_t:8;
4161  uint32_t PDO:1; /* IOs output power-down control */
4162  uint32_t:2;
4163  uint32_t MVRON:1; /* Main voltage regulator control */
4164  uint32_t:2;
4165  uint32_t FLAON:2; /* Flash power-down control */
4166  uint32_t:8;
4167 #ifndef USE_FIELD_ALIASES_ME
4168  uint32_t PLL1ON:1; /* Secondary system clock source [8..0] control */
4169 #else
4170  uint32_t PLL2ON:1; /* deprecated name - please avoid */
4171 #endif
4172 #ifndef USE_FIELD_ALIASES_ME
4173  uint32_t PLL0ON:1; /* System PLL control */
4174 #else
4175  uint32_t PLL1ON:1; /* deprecated name - please avoid */
4176 #endif
4177 #ifndef USE_FIELD_ALIASES_ME
4178  uint32_t XOSCON:1; /* System crystal oscillator control */
4179 #else
4180  uint32_t XOSC0ON:1; /* deprecated name - please avoid */
4181 #endif
4182 #ifndef USE_FIELD_ALIASES_ME
4183  uint32_t IRCOSCON:1; /* System RC oscillator control */
4184 #else
4185  uint32_t IRCON:1; /* deprecated name - please avoid */
4186 #endif
4187  uint32_t SYSCLK:4; /* System clock switch control */
4188  } B;
4190
4191  typedef union { /* ME_PS0 - Peripheral Status Register 0 */
4192  uint32_t R;
4193  struct {
4194  uint32_t:7;
4195  uint32_t S_FLEXRAY:1; /* FlexRay status */
4196  uint32_t:6;
4197  uint32_t S_FLEXCAN1:1; /* FlexCAN1 status */
4198  uint32_t S_FLEXCAN0:1; /* FlexCAN0 status */
4199  uint32_t:9;
4200  uint32_t S_DSPI2:1; /* DSPI2 status */
4201  uint32_t S_DSPI1:1; /* DSPI1 status */
4202  uint32_t S_DSPI0:1; /* DSPI0 status */
4203  uint32_t:4;
4204  } B;
4205  } ME_PS0_32B_tag;
4206
4207  typedef union { /* ME_PS1 - Peripheral Status Register 1 */
4208  uint32_t R;
4209  struct {
4210  uint32_t:1;
4211  uint32_t S_SWG:1; /* SWG status */
4212  uint32_t:3;
4213  uint32_t S_CRC:1; /* CRC status */
4214  uint32_t:8;
4215  uint32_t S_LIN_FLEX1:1; /* LinFlex1 status */
4216  uint32_t S_LIN_FLEX0:1; /* LinFlex0 status */
4217  uint32_t:5;
4218  uint32_t S_FLEXPWM1:1; /* FlexPWM1 status */
4219  uint32_t S_FLEXPWM0:1; /* FlexPWM0 status */
4220  uint32_t S_ETIMER2:1; /* eTimer2 status */
4221  uint32_t S_ETIMER1:1; /* eTimer1 status */
4222  uint32_t S_ETIMER0:1; /* eTimer0 status */
4223  uint32_t:2;
4224  uint32_t S_CTU:1; /* CTU status */
4225  uint32_t:1;
4226  uint32_t S_ADC1:1; /* ADC1 status */
4227  uint32_t S_ADC0:1; /* ADC0 status */
4228  } B;
4229  } ME_PS1_32B_tag;
4230
4231  typedef union { /* ME_PS2 - Peripheral Status Register 2 */
4232  uint32_t R;
4233  struct {
4234  uint32_t:3;
4235  uint32_t S_PIT:1; /* PIT status */
4236  uint32_t:28;
4237  } B;
4238  } ME_PS2_32B_tag;
4239
4240
4241  /* Register layout for all registers RUN_PC... */
4242
4243  typedef union { /* ME_RUN_PC[0...7] - RUN Peripheral Configuration Registers */
4244  uint32_t R;
4245  struct {
4246  uint32_t:24;
4247  uint32_t RUN3:1; /* Peripheral control during RUN3 */
4248  uint32_t RUN2:1; /* Peripheral control during RUN2 */
4249  uint32_t RUN1:1; /* Peripheral control during RUN1 */
4250  uint32_t RUN0:1; /* Peripheral control during RUN0 */
4251  uint32_t DRUN:1; /* Peripheral control during DRUN */
4252  uint32_t SAFE:1; /* Peripheral control during SAFE */
4253  uint32_t TEST:1; /* Peripheral control during TEST */
4254  uint32_t RESET:1; /* Peripheral control during RESET */
4255  } B;
4257
4258
4259  /* Register layout for all registers LP_PC... */
4260
4261  typedef union { /* ME_LP_PC[0...7] - Low Power Peripheral Configuration Registers */
4262  uint32_t R;
4263  struct {
4264  uint32_t:21;
4265  uint32_t STOP0:1; /* Peripheral control during STOP0 */
4266  uint32_t:1;
4267  uint32_t HALT0:1; /* Peripheral control during HALT0 */
4268  uint32_t:8;
4269  } B;
4270  } ME_LP_PC_32B_tag;
4271
4272
4273  /* Register layout for all registers PCTL... */
4274
4275  typedef union { /* ME_PCTL[0...143] - Peripheral Control Registers */
4276  uint8_t R;
4277  struct {
4278  uint8_t:1;
4279  uint8_t DBG_F:1; /* Peripheral control in debug mode */
4280  uint8_t LP_CFG:3; /* Peripheral configuration select for non-RUN modes */
4281  uint8_t RUN_CFG:3; /* Peripheral configuration select for RUN modes */
4282  } B;
4283  } ME_PCTL_8B_tag;
4284
4285
4286
4287
4288  /* Register layout for generated register(s) PS... */
4289
4290  typedef union { /* */
4291  uint32_t R;
4292  } ME_PS_32B_tag;
4293
4294
4295
4296
4297
4298
4299  typedef struct ME_struct_tag { /* start of ME_tag */
4300  /* ME_GS - Global Status Register */
4301  ME_GS_32B_tag GS; /* offset: 0x0000 size: 32 bit */
4302  /* ME_MCTL - Mode Control Register */
4303  ME_MCTL_32B_tag MCTL; /* offset: 0x0004 size: 32 bit */
4304  union {
4305  ME_MEN_32B_tag MER; /* deprecated - please avoid */
4306
4307  /* ME_MEN - Mode Enable Register */
4308  ME_MEN_32B_tag MEN; /* offset: 0x0008 size: 32 bit */
4309
4310  };
4311  /* ME_IS - Interrupt Status Register */
4312  ME_IS_32B_tag IS; /* offset: 0x000C size: 32 bit */
4313  /* ME_IM - Interrupt Mask Register */
4314  ME_IM_32B_tag IM; /* offset: 0x0010 size: 32 bit */
4315  /* ME_IMTS - Invalid Mode Transition Status Register */
4316  ME_IMTS_32B_tag IMTS; /* offset: 0x0014 size: 32 bit */
4317  /* ME_DMTS - Debug Mode Transition Status Register */
4318  ME_DMTS_32B_tag DMTS; /* offset: 0x0018 size: 32 bit */
4319  int8_t ME_reserved_001C_C[4];
4320  union {
4321  /* ME_RESET_MC - RESET Mode Configuration Register */
4322  ME_RESET_MC_32B_tag RESET_MC; /* offset: 0x0020 size: 32 bit */
4323
4324  ME_RESET_MC_32B_tag RESET; /* deprecated - please avoid */
4325
4326  };
4327  int8_t ME_reserved_0024_C[4];
4328  union {
4329  /* ME_SAFE_MC - Mode Configuration Register */
4330  ME_SAFE_MC_32B_tag SAFE_MC; /* offset: 0x0028 size: 32 bit */
4331
4332  ME_SAFE_MC_32B_tag SAFE; /* deprecated - please avoid */
4333
4334  };
4335  union {
4336  /* ME_DRUN_MC - DRUN Mode Configuration Register */
4337  ME_DRUN_MC_32B_tag DRUN_MC; /* offset: 0x002C size: 32 bit */
4338
4339  ME_DRUN_MC_32B_tag DRUN; /* deprecated - please avoid */
4340
4341  };
4342  union {
4343  /* ME_RUN[0..3]_MC - RUN[0..3] Mode Configuration Registers */
4344  ME_RUN_MC_32B_tag RUN_MC[4]; /* offset: 0x0030 (0x0004 x 4) */
4345
4346  ME_RUN_MC_32B_tag RUN[4]; /* offset: 0x0030 (0x0004 x 4) */ /* deprecated - please avoid */
4347
4348  struct {
4349  /* ME_RUN[0..3]_MC - RUN[0..3] Mode Configuration Registers */
4350  ME_RUN_MC_32B_tag RUN0_MC; /* offset: 0x0030 size: 32 bit */
4351  ME_RUN_MC_32B_tag RUN1_MC; /* offset: 0x0034 size: 32 bit */
4352  ME_RUN_MC_32B_tag RUN2_MC; /* offset: 0x0038 size: 32 bit */
4353  ME_RUN_MC_32B_tag RUN3_MC; /* offset: 0x003C size: 32 bit */
4354  };
4355
4356  };
4357  union {
4358  /* ME_HALT0_MC - HALT0 Mode Configuration Register */
4359  ME_HALT0_MC_32B_tag HALT0_MC; /* offset: 0x0040 size: 32 bit */
4360
4361  ME_HALT0_MC_32B_tag HALT0; /* deprecated - please avoid */
4362
4363  };
4364  int8_t ME_reserved_0044_C[4];
4365  union {
4366  /* ME_STOP0_MC - STOP0 Mode Configration Register */
4367  ME_STOP0_MC_32B_tag STOP0_MC; /* offset: 0x0048 size: 32 bit */
4368
4369  ME_STOP0_MC_32B_tag STOP0; /* deprecated - please avoid */
4370
4371  };
4372  int8_t ME_reserved_004C_C[8];
4373  union {
4374  /* ME_STANDBY0_MC - STANDBY0 Mode Configration Register */
4375  ME_STANDBY0_MC_32B_tag STANDBY0_MC; /* offset: 0x0054 size: 32 bit */
4376
4377  ME_STANDBY0_MC_32B_tag STANDBY0; /* deprecated - please avoid */
4378
4379  };
4380  int8_t ME_reserved_0058_C[8];
4381  union {
4382  ME_PS_32B_tag PS[3]; /* offset: 0x0060 (0x0004 x 3) */
4383
4384  struct {
4385  /* ME_PS0 - Peripheral Status Register 0 */
4386  ME_PS0_32B_tag PS0; /* offset: 0x0060 size: 32 bit */
4387  /* ME_PS1 - Peripheral Status Register 1 */
4388  ME_PS1_32B_tag PS1; /* offset: 0x0064 size: 32 bit */
4389  /* ME_PS2 - Peripheral Status Register 2 */
4390  ME_PS2_32B_tag PS2; /* offset: 0x0068 size: 32 bit */
4391  };
4392
4393  };
4394  int8_t ME_reserved_006C_C[20];
4395  union {
4396  ME_RUN_PC_32B_tag RUNPC[8]; /* offset: 0x0080 (0x0004 x 8) */
4397
4398  /* ME_RUN_PC[0...7] - RUN Peripheral Configuration Registers */
4399  ME_RUN_PC_32B_tag RUN_PC[8]; /* offset: 0x0080 (0x0004 x 8) */
4400
4401  struct {
4402  /* ME_RUN_PC[0...7] - RUN Peripheral Configuration Registers */
4403  ME_RUN_PC_32B_tag RUN_PC0; /* offset: 0x0080 size: 32 bit */
4404  ME_RUN_PC_32B_tag RUN_PC1; /* offset: 0x0084 size: 32 bit */
4405  ME_RUN_PC_32B_tag RUN_PC2; /* offset: 0x0088 size: 32 bit */
4406  ME_RUN_PC_32B_tag RUN_PC3; /* offset: 0x008C size: 32 bit */
4407  ME_RUN_PC_32B_tag RUN_PC4; /* offset: 0x0090 size: 32 bit */
4408  ME_RUN_PC_32B_tag RUN_PC5; /* offset: 0x0094 size: 32 bit */
4409  ME_RUN_PC_32B_tag RUN_PC6; /* offset: 0x0098 size: 32 bit */
4410  ME_RUN_PC_32B_tag RUN_PC7; /* offset: 0x009C size: 32 bit */
4411  };
4412
4413  };
4414  union {
4415  ME_LP_PC_32B_tag LPPC[8]; /* offset: 0x00A0 (0x0004 x 8) */
4416
4417  /* ME_LP_PC[0...7] - Low Power Peripheral Configuration Registers */
4418  ME_LP_PC_32B_tag LP_PC[8]; /* offset: 0x00A0 (0x0004 x 8) */
4419
4420  struct {
4421  /* ME_LP_PC[0...7] - Low Power Peripheral Configuration Registers */
4422  ME_LP_PC_32B_tag LP_PC0; /* offset: 0x00A0 size: 32 bit */
4423  ME_LP_PC_32B_tag LP_PC1; /* offset: 0x00A4 size: 32 bit */
4424  ME_LP_PC_32B_tag LP_PC2; /* offset: 0x00A8 size: 32 bit */
4425  ME_LP_PC_32B_tag LP_PC3; /* offset: 0x00AC size: 32 bit */
4426  ME_LP_PC_32B_tag LP_PC4; /* offset: 0x00B0 size: 32 bit */
4427  ME_LP_PC_32B_tag LP_PC5; /* offset: 0x00B4 size: 32 bit */
4428  ME_LP_PC_32B_tag LP_PC6; /* offset: 0x00B8 size: 32 bit */
4429  ME_LP_PC_32B_tag LP_PC7; /* offset: 0x00BC size: 32 bit */
4430  };
4431
4432  };
4433  union {
4434  /* ME_PCTL[0...143] - Peripheral Control Registers */
4435  ME_PCTL_8B_tag PCTL[144]; /* offset: 0x00C0 (0x0001 x 144) */
4436
4437  struct {
4438  /* ME_PCTL[0...143] - Peripheral Control Registers */
4439  ME_PCTL_8B_tag PCTL0; /* offset: 0x00C0 size: 8 bit */
4440  ME_PCTL_8B_tag PCTL1; /* offset: 0x00C1 size: 8 bit */
4441  ME_PCTL_8B_tag PCTL2; /* offset: 0x00C2 size: 8 bit */
4442  ME_PCTL_8B_tag PCTL3; /* offset: 0x00C3 size: 8 bit */
4443  ME_PCTL_8B_tag PCTL4; /* offset: 0x00C4 size: 8 bit */
4444  ME_PCTL_8B_tag PCTL5; /* offset: 0x00C5 size: 8 bit */
4445  ME_PCTL_8B_tag PCTL6; /* offset: 0x00C6 size: 8 bit */
4446  ME_PCTL_8B_tag PCTL7; /* offset: 0x00C7 size: 8 bit */
4447  ME_PCTL_8B_tag PCTL8; /* offset: 0x00C8 size: 8 bit */
4448  ME_PCTL_8B_tag PCTL9; /* offset: 0x00C9 size: 8 bit */
4449  ME_PCTL_8B_tag PCTL10; /* offset: 0x00CA size: 8 bit */
4450  ME_PCTL_8B_tag PCTL11; /* offset: 0x00CB size: 8 bit */
4451  ME_PCTL_8B_tag PCTL12; /* offset: 0x00CC size: 8 bit */
4452  ME_PCTL_8B_tag PCTL13; /* offset: 0x00CD size: 8 bit */
4453  ME_PCTL_8B_tag PCTL14; /* offset: 0x00CE size: 8 bit */
4454  ME_PCTL_8B_tag PCTL15; /* offset: 0x00CF size: 8 bit */
4455  ME_PCTL_8B_tag PCTL16; /* offset: 0x00D0 size: 8 bit */
4456  ME_PCTL_8B_tag PCTL17; /* offset: 0x00D1 size: 8 bit */
4457  ME_PCTL_8B_tag PCTL18; /* offset: 0x00D2 size: 8 bit */
4458  ME_PCTL_8B_tag PCTL19; /* offset: 0x00D3 size: 8 bit */
4459  ME_PCTL_8B_tag PCTL20; /* offset: 0x00D4 size: 8 bit */
4460  ME_PCTL_8B_tag PCTL21; /* offset: 0x00D5 size: 8 bit */
4461  ME_PCTL_8B_tag PCTL22; /* offset: 0x00D6 size: 8 bit */
4462  ME_PCTL_8B_tag PCTL23; /* offset: 0x00D7 size: 8 bit */
4463  ME_PCTL_8B_tag PCTL24; /* offset: 0x00D8 size: 8 bit */
4464  ME_PCTL_8B_tag PCTL25; /* offset: 0x00D9 size: 8 bit */
4465  ME_PCTL_8B_tag PCTL26; /* offset: 0x00DA size: 8 bit */
4466  ME_PCTL_8B_tag PCTL27; /* offset: 0x00DB size: 8 bit */
4467  ME_PCTL_8B_tag PCTL28; /* offset: 0x00DC size: 8 bit */
4468  ME_PCTL_8B_tag PCTL29; /* offset: 0x00DD size: 8 bit */
4469  ME_PCTL_8B_tag PCTL30; /* offset: 0x00DE size: 8 bit */
4470  ME_PCTL_8B_tag PCTL31; /* offset: 0x00DF size: 8 bit */
4471  ME_PCTL_8B_tag PCTL32; /* offset: 0x00E0 size: 8 bit */
4472  ME_PCTL_8B_tag PCTL33; /* offset: 0x00E1 size: 8 bit */
4473  ME_PCTL_8B_tag PCTL34; /* offset: 0x00E2 size: 8 bit */
4474  ME_PCTL_8B_tag PCTL35; /* offset: 0x00E3 size: 8 bit */
4475  ME_PCTL_8B_tag PCTL36; /* offset: 0x00E4 size: 8 bit */
4476  ME_PCTL_8B_tag PCTL37; /* offset: 0x00E5 size: 8 bit */
4477  ME_PCTL_8B_tag PCTL38; /* offset: 0x00E6 size: 8 bit */
4478  ME_PCTL_8B_tag PCTL39; /* offset: 0x00E7 size: 8 bit */
4479  ME_PCTL_8B_tag PCTL40; /* offset: 0x00E8 size: 8 bit */
4480  ME_PCTL_8B_tag PCTL41; /* offset: 0x00E9 size: 8 bit */
4481  ME_PCTL_8B_tag PCTL42; /* offset: 0x00EA size: 8 bit */
4482  ME_PCTL_8B_tag PCTL43; /* offset: 0x00EB size: 8 bit */
4483  ME_PCTL_8B_tag PCTL44; /* offset: 0x00EC size: 8 bit */
4484  ME_PCTL_8B_tag PCTL45; /* offset: 0x00ED size: 8 bit */
4485  ME_PCTL_8B_tag PCTL46; /* offset: 0x00EE size: 8 bit */
4486  ME_PCTL_8B_tag PCTL47; /* offset: 0x00EF size: 8 bit */
4487  ME_PCTL_8B_tag PCTL48; /* offset: 0x00F0 size: 8 bit */
4488  ME_PCTL_8B_tag PCTL49; /* offset: 0x00F1 size: 8 bit */
4489  ME_PCTL_8B_tag PCTL50; /* offset: 0x00F2 size: 8 bit */
4490  ME_PCTL_8B_tag PCTL51; /* offset: 0x00F3 size: 8 bit */
4491  ME_PCTL_8B_tag PCTL52; /* offset: 0x00F4 size: 8 bit */
4492  ME_PCTL_8B_tag PCTL53; /* offset: 0x00F5 size: 8 bit */
4493  ME_PCTL_8B_tag PCTL54; /* offset: 0x00F6 size: 8 bit */
4494  ME_PCTL_8B_tag PCTL55; /* offset: 0x00F7 size: 8 bit */
4495  ME_PCTL_8B_tag PCTL56; /* offset: 0x00F8 size: 8 bit */
4496  ME_PCTL_8B_tag PCTL57; /* offset: 0x00F9 size: 8 bit */
4497  ME_PCTL_8B_tag PCTL58; /* offset: 0x00FA size: 8 bit */
4498  ME_PCTL_8B_tag PCTL59; /* offset: 0x00FB size: 8 bit */
4499  ME_PCTL_8B_tag PCTL60; /* offset: 0x00FC size: 8 bit */
4500  ME_PCTL_8B_tag PCTL61; /* offset: 0x00FD size: 8 bit */
4501  ME_PCTL_8B_tag PCTL62; /* offset: 0x00FE size: 8 bit */
4502  ME_PCTL_8B_tag PCTL63; /* offset: 0x00FF size: 8 bit */
4503  ME_PCTL_8B_tag PCTL64; /* offset: 0x0100 size: 8 bit */
4504  ME_PCTL_8B_tag PCTL65; /* offset: 0x0101 size: 8 bit */
4505  ME_PCTL_8B_tag PCTL66; /* offset: 0x0102 size: 8 bit */
4506  ME_PCTL_8B_tag PCTL67; /* offset: 0x0103 size: 8 bit */
4507  ME_PCTL_8B_tag PCTL68; /* offset: 0x0104 size: 8 bit */
4508  ME_PCTL_8B_tag PCTL69; /* offset: 0x0105 size: 8 bit */
4509  ME_PCTL_8B_tag PCTL70; /* offset: 0x0106 size: 8 bit */
4510  ME_PCTL_8B_tag PCTL71; /* offset: 0x0107 size: 8 bit */
4511  ME_PCTL_8B_tag PCTL72; /* offset: 0x0108 size: 8 bit */
4512  ME_PCTL_8B_tag PCTL73; /* offset: 0x0109 size: 8 bit */
4513  ME_PCTL_8B_tag PCTL74; /* offset: 0x010A size: 8 bit */
4514  ME_PCTL_8B_tag PCTL75; /* offset: 0x010B size: 8 bit */
4515  ME_PCTL_8B_tag PCTL76; /* offset: 0x010C size: 8 bit */
4516  ME_PCTL_8B_tag PCTL77; /* offset: 0x010D size: 8 bit */
4517  ME_PCTL_8B_tag PCTL78; /* offset: 0x010E size: 8 bit */
4518  ME_PCTL_8B_tag PCTL79; /* offset: 0x010F size: 8 bit */
4519  ME_PCTL_8B_tag PCTL80; /* offset: 0x0110 size: 8 bit */
4520  ME_PCTL_8B_tag PCTL81; /* offset: 0x0111 size: 8 bit */
4521  ME_PCTL_8B_tag PCTL82; /* offset: 0x0112 size: 8 bit */
4522  ME_PCTL_8B_tag PCTL83; /* offset: 0x0113 size: 8 bit */
4523  ME_PCTL_8B_tag PCTL84; /* offset: 0x0114 size: 8 bit */
4524  ME_PCTL_8B_tag PCTL85; /* offset: 0x0115 size: 8 bit */
4525  ME_PCTL_8B_tag PCTL86; /* offset: 0x0116 size: 8 bit */
4526  ME_PCTL_8B_tag PCTL87; /* offset: 0x0117 size: 8 bit */
4527  ME_PCTL_8B_tag PCTL88; /* offset: 0x0118 size: 8 bit */
4528  ME_PCTL_8B_tag PCTL89; /* offset: 0x0119 size: 8 bit */
4529  ME_PCTL_8B_tag PCTL90; /* offset: 0x011A size: 8 bit */
4530  ME_PCTL_8B_tag PCTL91; /* offset: 0x011B size: 8 bit */
4531  ME_PCTL_8B_tag PCTL92; /* offset: 0x011C size: 8 bit */
4532  ME_PCTL_8B_tag PCTL93; /* offset: 0x011D size: 8 bit */
4533  ME_PCTL_8B_tag PCTL94; /* offset: 0x011E size: 8 bit */
4534  ME_PCTL_8B_tag PCTL95; /* offset: 0x011F size: 8 bit */
4535  ME_PCTL_8B_tag PCTL96; /* offset: 0x0120 size: 8 bit */
4536  ME_PCTL_8B_tag PCTL97; /* offset: 0x0121 size: 8 bit */
4537  ME_PCTL_8B_tag PCTL98; /* offset: 0x0122 size: 8 bit */
4538  ME_PCTL_8B_tag PCTL99; /* offset: 0x0123 size: 8 bit */
4539  ME_PCTL_8B_tag PCTL100; /* offset: 0x0124 size: 8 bit */
4540  ME_PCTL_8B_tag PCTL101; /* offset: 0x0125 size: 8 bit */
4541  ME_PCTL_8B_tag PCTL102; /* offset: 0x0126 size: 8 bit */
4542  ME_PCTL_8B_tag PCTL103; /* offset: 0x0127 size: 8 bit */
4543  ME_PCTL_8B_tag PCTL104; /* offset: 0x0128 size: 8 bit */
4544  ME_PCTL_8B_tag PCTL105; /* offset: 0x0129 size: 8 bit */
4545  ME_PCTL_8B_tag PCTL106; /* offset: 0x012A size: 8 bit */
4546  ME_PCTL_8B_tag PCTL107; /* offset: 0x012B size: 8 bit */
4547  ME_PCTL_8B_tag PCTL108; /* offset: 0x012C size: 8 bit */
4548  ME_PCTL_8B_tag PCTL109; /* offset: 0x012D size: 8 bit */
4549  ME_PCTL_8B_tag PCTL110; /* offset: 0x012E size: 8 bit */
4550  ME_PCTL_8B_tag PCTL111; /* offset: 0x012F size: 8 bit */
4551  ME_PCTL_8B_tag PCTL112; /* offset: 0x0130 size: 8 bit */
4552  ME_PCTL_8B_tag PCTL113; /* offset: 0x0131 size: 8 bit */
4553  ME_PCTL_8B_tag PCTL114; /* offset: 0x0132 size: 8 bit */
4554  ME_PCTL_8B_tag PCTL115; /* offset: 0x0133 size: 8 bit */
4555  ME_PCTL_8B_tag PCTL116; /* offset: 0x0134 size: 8 bit */
4556  ME_PCTL_8B_tag PCTL117; /* offset: 0x0135 size: 8 bit */
4557  ME_PCTL_8B_tag PCTL118; /* offset: 0x0136 size: 8 bit */
4558  ME_PCTL_8B_tag PCTL119; /* offset: 0x0137 size: 8 bit */
4559  ME_PCTL_8B_tag PCTL120; /* offset: 0x0138 size: 8 bit */
4560  ME_PCTL_8B_tag PCTL121; /* offset: 0x0139 size: 8 bit */
4561  ME_PCTL_8B_tag PCTL122; /* offset: 0x013A size: 8 bit */
4562  ME_PCTL_8B_tag PCTL123; /* offset: 0x013B size: 8 bit */
4563  ME_PCTL_8B_tag PCTL124; /* offset: 0x013C size: 8 bit */
4564  ME_PCTL_8B_tag PCTL125; /* offset: 0x013D size: 8 bit */
4565  ME_PCTL_8B_tag PCTL126; /* offset: 0x013E size: 8 bit */
4566  ME_PCTL_8B_tag PCTL127; /* offset: 0x013F size: 8 bit */
4567  ME_PCTL_8B_tag PCTL128; /* offset: 0x0140 size: 8 bit */
4568  ME_PCTL_8B_tag PCTL129; /* offset: 0x0141 size: 8 bit */
4569  ME_PCTL_8B_tag PCTL130; /* offset: 0x0142 size: 8 bit */
4570  ME_PCTL_8B_tag PCTL131; /* offset: 0x0143 size: 8 bit */
4571  ME_PCTL_8B_tag PCTL132; /* offset: 0x0144 size: 8 bit */
4572  ME_PCTL_8B_tag PCTL133; /* offset: 0x0145 size: 8 bit */
4573  ME_PCTL_8B_tag PCTL134; /* offset: 0x0146 size: 8 bit */
4574  ME_PCTL_8B_tag PCTL135; /* offset: 0x0147 size: 8 bit */
4575  ME_PCTL_8B_tag PCTL136; /* offset: 0x0148 size: 8 bit */
4576  ME_PCTL_8B_tag PCTL137; /* offset: 0x0149 size: 8 bit */
4577  ME_PCTL_8B_tag PCTL138; /* offset: 0x014A size: 8 bit */
4578  ME_PCTL_8B_tag PCTL139; /* offset: 0x014B size: 8 bit */
4579  ME_PCTL_8B_tag PCTL140; /* offset: 0x014C size: 8 bit */
4580  ME_PCTL_8B_tag PCTL141; /* offset: 0x014D size: 8 bit */
4581  ME_PCTL_8B_tag PCTL142; /* offset: 0x014E size: 8 bit */
4582  ME_PCTL_8B_tag PCTL143; /* offset: 0x014F size: 8 bit */
4583  };
4584
4585  };
4586  } ME_tag;
4587
4588
4589 #define ME (*(volatile ME_tag *) 0xC3FDC000UL)
4590
4591
4592
4593 /****************************************************************/
4594 /* */
4595 /* Module: OSC */
4596 /* */
4597 /****************************************************************/
4598
4599  typedef union { /* OSC_CTL - Control Register */
4600  uint32_t R;
4601  struct {
4602  uint32_t OSCBYP:1; /* High Frequency Oscillator Bypass */
4603  uint32_t:7;
4604  uint32_t EOCV:8; /* End of Count Value */
4605  uint32_t M_OSC:1; /* High Frequency Oscillator Clock Interrupt Mask */
4606  uint32_t:2;
4607  uint32_t OSCDIV:5; /* High Frequency Oscillator Division Factor */
4608  uint32_t I_OSC:1; /* High Frequency Oscillator Clock Interrupt */
4609  uint32_t:5;
4610  uint32_t S_OSC:1;
4611  uint32_t OSCON:1; } B;
4612  } OSC_CTL_32B_tag;
4613
4614
4615
4616  typedef struct OSC_struct_tag { /* start of OSC_tag */
4617  /* OSC_CTL - Control Register */
4618  OSC_CTL_32B_tag CTL; /* offset: 0x0000 size: 32 bit */
4619  } OSC_tag;
4620
4621
4622 #define OSC (*(volatile OSC_tag *) 0xC3FE0000UL)
4623
4624
4625
4626 /****************************************************************/
4627 /* */
4628 /* Module: RC */
4629 /* */
4630 /****************************************************************/
4631
4632  typedef union { /* RC_CTL - Control Register */
4633  uint32_t R;
4634  struct {
4635  uint32_t:10;
4636  uint32_t RCTRIM:6; /* Main RC Trimming Bits */
4637  uint32_t:3;
4638  uint32_t RCDIV:5; /* Main RC Clock Division Factor */
4639  uint32_t:2;
4640  uint32_t S_RC_STDBY:1; /* MRC Oscillator Powerdown Status */
4641  uint32_t:5;
4642  } B;
4643  } RC_CTL_32B_tag;
4644
4645
4646
4647  typedef struct RC_struct_tag { /* start of RC_tag */
4648  /* RC_CTL - Control Register */
4649  RC_CTL_32B_tag CTL; /* offset: 0x0000 size: 32 bit */
4650  } RC_tag;
4651
4652
4653 #define RC (*(volatile RC_tag *) 0xC3FE0060UL)
4654
4655
4656
4657 /****************************************************************/
4658 /* */
4659 /* Module: PLLD */
4660 /* */
4661 /****************************************************************/
4662
4663  typedef union { /* PLLD_CR - Control Register */
4664  uint32_t R;
4665  struct {
4666  uint32_t:2;
4667  uint32_t IDF:4; /* PLL Input Division Factor */
4668  uint32_t ODF:2; /* PLL Output Division Factor */
4669  uint32_t:1;
4670  uint32_t NDIV:7; /* PLL Loop Division Factor */
4671  uint32_t:7;
4672  uint32_t EN_PLL_SW:1; /* Enable Progressive Clock Switching */
4673  uint32_t MODE:1; /* Activate 1:1 Mode */
4674  uint32_t UNLOCK_ONCE:1; /* PLL Loss of Lock */
4675  uint32_t M_LOCK:1; /* Mask for the i_lock Output Interrupt */
4676  uint32_t I_LOCK:1; /* PLL Lock Signal Toggle Indicator */
4677  uint32_t S_LOCK:1; /* PLL has Aquired Lock */
4678  uint32_t PLL_FAIL_MASK:1; /* PLL Fail Mask */
4679  uint32_t PLL_FAIL_FLAG:1; /* PLL Fail Flag */
4680  uint32_t PLL_ON:1; /* PLL ON Bit */
4681  } B;
4682  } PLLD_CR_32B_tag;
4683
4684  typedef union { /* PLLD_MR - PLLD Modulation Register */
4685  uint32_t R;
4686  struct {
4687  uint32_t STRB_BYPASS:1; /* Strobe Bypass */
4688  uint32_t:1;
4689  uint32_t SPRD_SEL:1; /* Spread Type Selection */
4690  uint32_t MOD_PERIOD:13; /* Modulation Period */
4691 #ifndef USE_FIELD_ALIASES_PLLD
4692  uint32_t SSCG_EN:1; /* Spread Spectrum Clock Generation Enable */
4693 #else
4694  uint32_t FM_EN:1; /* deprecated name - please avoid */
4695 #endif
4696  uint32_t INC_STEP:15; /* Increment Step */
4697  } B;
4698  } PLLD_MR_32B_tag;
4699
4700
4701
4702  typedef struct PLLD_struct_tag { /* start of PLLD_tag */
4703  /* PLLD_CR - Control Register */
4704  PLLD_CR_32B_tag CR; /* offset: 0x0000 size: 32 bit */
4705  /* PLLD_MR - PLLD Modulation Register */
4706  PLLD_MR_32B_tag MR; /* offset: 0x0004 size: 32 bit */
4707
4708  uint32_t plld_reserved[6];
4709  } PLLD_tag;
4710
4711
4712 #define PLLD0 (*(volatile PLLD_tag *) 0xC3FE00A0UL)
4713 #define PLLD1 (*(volatile PLLD_tag *) 0xC3FE00C0UL)
4714
4715
4716
4717 /****************************************************************/
4718 /* */
4719 /* Module: CMU */
4720 /* */
4721 /****************************************************************/
4722
4723  typedef union { /* CMU_CSR - Control Status Register */
4724  uint32_t R;
4725  struct {
4726  uint32_t:8;
4727  uint32_t SFM:1; /* Start Frequency Measure */
4728  uint32_t:13;
4729 #ifndef USE_FIELD_ALIASES_RGM
4730  uint32_t CKSEL1:2; /* RC Oscillator(s) Selection Bit */
4731 #else
4732  uint32_t CLKSEL1:2; /* deprecated name - please avoid */
4733 #endif
4734  uint32_t:5;
4735  uint32_t RCDIV:2; /* RCfast Clock Division Factor */
4736  uint32_t CME_A:1; /* PLL_A Clock Monitor Enable */
4737  } B;
4738  } CMU_CSR_32B_tag;
4739
4740  typedef union { /* CMU_FDR - Frequency Display Register */
4741  uint32_t R;
4742  struct {
4743  uint32_t:12;
4744  uint32_t FD:20; /* Measured Frequency Bits */
4745  } B;
4746  } CMU_FDR_32B_tag;
4747
4748  typedef union { /* CMU_HFREFR_A - High Frequency Reference Register */
4749  uint32_t R;
4750  struct {
4751  uint32_t:20;
4752  uint32_t HFREF_A:12; /* High Frequency Reference Value */
4753  } B;
4755
4756  typedef union { /* CMU_LFREFR_A - Low Frequency Reference Register */
4757  uint32_t R;
4758  struct {
4759  uint32_t:20;
4760  uint32_t LFREF_A:12; /* Low Frequency Reference Value */
4761  } B;
4763
4764  typedef union { /* CMU_ISR - Interrupt Status Register */
4765  uint32_t R;
4766  struct {
4767  uint32_t:28;
4768  uint32_t FLCI_A:1; /* PLL_A Clock Frequency less than Reference Clock Interrupt */
4769 #ifndef USE_FIELD_ALIASES_RGM
4770  uint32_t FHH_AI:1; /* PLL_A Clock Frequency higher than high Reference Interrupt */
4771 #else
4772  uint32_t FHHI_A:1; /* deprecated name - please avoid */
4773 #endif
4774  uint32_t FLLI_A:1; /* PLL_A Clock Frequency less than low Reference Interrupt */
4775  uint32_t OLRI:1; /* Oscillator Frequency less than RC Frequency Interrupt */
4776  } B;
4777  } CMU_ISR_32B_tag;
4778
4779  typedef union { /* CMU_IMR - Interrupt Mask Register */
4780  uint32_t R;
4781  } CMU_IMR_32B_tag;
4782
4783  typedef union { /* CMU_MDR - Measurement Duration Register */
4784  uint32_t R;
4785  struct {
4786  uint32_t:12;
4787  uint32_t MD:20; /* Measurment Duration Bits */
4788  } B;
4789  } CMU_MDR_32B_tag;
4790
4791
4792
4793  typedef struct CMU_struct_tag { /* start of CMU_tag */
4794  /* CMU_CSR - Control Status Register */
4795  CMU_CSR_32B_tag CSR; /* offset: 0x0000 size: 32 bit */
4796  /* CMU_FDR - Frequency Display Register */
4797  CMU_FDR_32B_tag FDR; /* offset: 0x0004 size: 32 bit */
4798  /* CMU_HFREFR_A - High Frequency Reference Register */
4799  CMU_HFREFR_A_32B_tag HFREFR_A; /* offset: 0x0008 size: 32 bit */
4800  /* CMU_LFREFR_A - Low Frequency Reference Register */
4801  CMU_LFREFR_A_32B_tag LFREFR_A; /* offset: 0x000C size: 32 bit */
4802  /* CMU_ISR - Interrupt Status Register */
4803  CMU_ISR_32B_tag ISR; /* offset: 0x0010 size: 32 bit */
4804  /* CMU_IMR - Interrupt Mask Register */
4805  CMU_IMR_32B_tag IMR; /* offset: 0x0014 size: 32 bit */
4806  /* CMU_MDR - Measurement Duration Register */
4807  CMU_MDR_32B_tag MDR; /* offset: 0x0018 size: 32 bit */
4808  } CMU_tag;
4809
4810
4811 #define CMU0 (*(volatile CMU_tag *) 0xC3FE0100UL)
4812 #define CMU1 (*(volatile CMU_tag *) 0xC3FE0120UL)
4813 #define CMU2 (*(volatile CMU_tag *) 0xC3FE0140UL)
4814
4815
4816
4817 /****************************************************************/
4818 /* */
4819 /* Module: CGM */
4820 /* */
4821 /****************************************************************/
4822
4823  typedef union { /* Output Clock Enable Register */
4824  uint32_t R;
4825  uint8_t BYTE[4]; /* individual bytes can be accessed */
4826  uint16_t HALF[2]; /* individual halfwords can be accessed */
4827  uint32_t WORD; /* individual words can be accessed */
4828  struct {
4829  uint32_t:31;
4830  uint32_t EN:1; /* Clock Enable Bit */
4831  } B;
4833
4834  typedef union { /* Output Clock Division Select Register */
4835  uint32_t R;
4836  uint8_t BYTE[4]; /* individual bytes can be accessed */
4837  uint16_t HALF[2]; /* individual halfwords can be accessed */
4838  uint32_t WORD; /* individual words can be accessed */
4839  struct {
4840  uint32_t:2;
4841  uint32_t SELDIV:2; /* Output Clock Division Select */
4842  uint32_t SELCTL:4; /* Output Clock Source Selection Control */
4843  uint32_t:24;
4844  } B;
4846
4847  typedef union { /* System Clock Select Status Register */
4848  uint32_t R;
4849  uint8_t BYTE[4]; /* individual bytes can be accessed */
4850  uint16_t HALF[2]; /* individual halfwords can be accessed */
4851  uint32_t WORD; /* individual words can be accessed */
4852  struct {
4853  uint32_t:4;
4854  uint32_t SELSTAT:4; /* System Clock Source Selection Status */
4855  uint32_t:24;
4856  } B;
4858
4859  typedef union { /* System Clock Divider Configuration Register */
4860  uint32_t R;
4861  uint8_t BYTE[4]; /* individual bytes can be accessed */
4862  uint16_t HALF[2]; /* individual halfwords can be accessed */
4863  uint32_t WORD; /* individual words can be accessed */
4864  struct {
4865  uint32_t DE0:1; /* Divider 0 Enable */
4866  uint32_t:3;
4867  uint32_t DIV0:4; /* Divider 0 Value */
4868  uint32_t:24;
4869  } B;
4871
4872
4873  /* Register layout for all registers SC_DC... */
4874
4875  typedef union { /* System Clock Divider Configuration Register */
4876  uint8_t R;
4877  struct {
4878  uint8_t DE:1; /* Divider Enable */
4879  uint8_t:3;
4880  uint8_t DIV:4; /* Divider Division Value */
4881  } B;
4882  } CGM_SC_DC_8B_tag;
4883
4884
4885  /* Register layout for all registers AC_SC... */
4886
4887  typedef union { /* Auxiliary Clock Select Control Registers */
4888  uint32_t R;
4889  uint8_t BYTE[4]; /* individual bytes can be accessed */
4890  uint16_t HALF[2]; /* individual halfwords can be accessed */
4891  uint32_t WORD; /* individual words can be accessed */
4892  struct {
4893  uint32_t:4;
4894  uint32_t SELCTL:4; /* Auxliary Clock Source Selection Control */
4895  uint32_t:24;
4896  } B;
4898
4899
4900  /* Register layout for all registers AC_DC0_3... */
4901
4902  typedef union { /* Auxiliary Clock Divider Configuration Registers */
4903  uint32_t R;
4904  struct {
4905  uint32_t DE0:1; /* Divider 0 Enable */
4906  uint32_t:3;
4907  uint32_t DIV0:4; /* Divider 0 Value */
4908  uint32_t DE1:1; /* Divider 1 Enable */
4909  uint32_t:3;
4910  uint32_t DIV1:4; /* Divider 1 Value */
4911  uint32_t:16;
4912  } B;
4914
4915
4916  typedef struct CGM_AUXCLK_struct_tag {
4917
4918  /* Auxiliary Clock Select Control Registers */
4919  CGM_AC_SC_32B_tag AC_SC; /* relative offset: 0x0000 */
4920  /* Auxiliary Clock Divider Configuration Registers */
4921  CGM_AC_DC0_3_32B_tag AC_DC0_3; /* relative offset: 0x0004 */
4922
4923  } CGM_AUXCLK_tag;
4924
4925
4926  typedef struct CGM_struct_tag { /* start of CGM_tag */
4927  OSC_CTL_32B_tag OSC_CTL; /* offset: 0x0000 size: 32 bit */
4928  int8_t CGM_reserved_0004[92];
4929  RC_CTL_32B_tag RC_CTL; /* offset: 0x0060 size: 32 bit */
4930  int8_t CGM_reserved_0064[60];
4931  PLLD_tag FMPLL[2]; /* offset: 0x00A0 (0x0020 x 2) */
4932  int8_t CGM_reserved_00E0[32];
4933  CMU_CSR_32B_tag CMU_0_CSR; /* offset: 0x0100 size: 32 bit */
4934  CMU_FDR_32B_tag CMU_0_FDR; /* offset: 0x0104 size: 32 bit */
4935  CMU_HFREFR_A_32B_tag CMU_0_HFREFR_A; /* offset: 0x0108 size: 32 bit */
4936  CMU_LFREFR_A_32B_tag CMU_0_LFREFR_A; /* offset: 0x010C size: 32 bit */
4937  CMU_ISR_32B_tag CMU_0_ISR; /* offset: 0x0110 size: 32 bit */
4938  CMU_IMR_32B_tag CMU_0_IMR; /* offset: 0x0114 size: 32 bit */
4939  CMU_MDR_32B_tag CMU_0_MDR; /* offset: 0x0118 size: 32 bit */
4940  int8_t CGM_reserved_011C[4];
4941  CMU_CSR_32B_tag CMU_1_CSR; /* offset: 0x0120 size: 32 bit */
4942  int8_t CGM_reserved_0124[4];
4943  CMU_HFREFR_A_32B_tag CMU_1_HFREFR_A; /* offset: 0x0128 size: 32 bit */
4944  CMU_LFREFR_A_32B_tag CMU_1_LFREFR_A; /* offset: 0x012C size: 32 bit */
4945  CMU_ISR_32B_tag CMU_1_ISR; /* offset: 0x0130 size: 32 bit */
4946  int8_t CGM_reserved_0134[572];
4947  union {
4948  /* Output Clock Enable Register */
4949  CGM_OC_EN_32B_tag OC_EN; /* offset: 0x0370 size: 32 bit */
4950
4951  CGM_OC_EN_32B_tag OCEN; /* deprecated - please avoid */
4952
4953  };
4954  union {
4955  /* Output Clock Division Select Register */
4956  CGM_OCDS_SC_32B_tag OCDS_SC; /* offset: 0x0374 size: 32 bit */
4957
4958  CGM_OCDS_SC_32B_tag OCDSSC; /* deprecated - please avoid */
4959
4960  };
4961  union {
4962  /* Output Clock Division Select Register */
4963  CGM_SC_SS_32B_tag SC_SS; /* offset: 0x0378 size: 32 bit */
4964
4965  CGM_SC_SS_32B_tag SCSS; /* deprecated - please avoid */
4966
4967  }; /* System Clock Select Status Register */
4968  union {
4969  struct {
4970  /* System Clock Divider Configuration Register */
4971  CGM_SC_DC_8B_tag SC_DC[2]; /* offset: 0x037C (0x0001 x 2) */
4972  int8_t CGM_reserved_037E_E0[2];
4973  };
4974
4975  struct {
4976  /* System Clock Divider Configuration Register */
4977  CGM_SC_DC_8B_tag SC_DC0; /* offset: 0x037C size: 8 bit */
4978  CGM_SC_DC_8B_tag SC_DC1; /* offset: 0x037D size: 8 bit */
4979  int8_t CGM_reserved_037E_E1[2];
4980  };
4981
4982  /* System Clock Divider Configuration Register */
4983  union {
4984  CGM_SC_DC0_3_32B_tag SC_DC0_3; /* offset: 0x037C size: 32 bit */
4985  CGM_SC_DC0_3_32B_tag SCDC; /* deprecated - please avoid */
4986  };
4987  };
4988  union {
4989  /* Register set AUXCLK */
4990  CGM_AUXCLK_tag AUXCLK[6]; /* offset: 0x0380 (0x0008 x 6) */
4991
4992  struct {
4993  union {
4994  /* Auxiliary Clock Select Control Registers */
4995  CGM_AC_SC_32B_tag AC0_SC; /* offset: 0x0380 size: 32 bit */
4996
4997  CGM_AC_SC_32B_tag AC0SC; /* deprecated - please avoid */
4998
4999  };
5000  union {
5001  /* Auxiliary Clock Divider Configuration Registers */
5002  CGM_AC_DC0_3_32B_tag AC0_DC0_3; /* offset: 0x0384 size: 32 bit */
5003
5004  CGM_AC_DC0_3_32B_tag AC0DC; /* deprecated - please avoid */
5005
5006  };
5007  union {
5008  /* Auxiliary Clock Select Control Registers */
5009  CGM_AC_SC_32B_tag AC1_SC; /* offset: 0x0388 size: 32 bit */
5010
5011  CGM_AC_SC_32B_tag AC1SC; /* deprecated - please avoid */
5012
5013  };
5014  union {
5015  /* Auxiliary Clock Divider Configuration Registers */
5016  CGM_AC_DC0_3_32B_tag AC1_DC0_3; /* offset: 0x038C size: 32 bit */
5017
5018  CGM_AC_DC0_3_32B_tag AC1DC; /* deprecated - please avoid */
5019
5020  };
5021  union {
5022  /* Auxiliary Clock Select Control Registers */
5023  CGM_AC_SC_32B_tag AC2_SC; /* offset: 0x0390 size: 32 bit */
5024
5025  CGM_AC_SC_32B_tag AC2SC; /* deprecated - please avoid */
5026
5027  };
5028  union {
5029  /* Auxiliary Clock Divider Configuration Registers */
5030  CGM_AC_DC0_3_32B_tag AC2_DC0_3; /* offset: 0x0394 size: 32 bit */
5031
5032  CGM_AC_DC0_3_32B_tag AC2DC; /* deprecated - please avoid */
5033
5034  };
5035  union {
5036  /* Auxiliary Clock Select Control Registers */
5037  CGM_AC_SC_32B_tag AC3_SC; /* offset: 0x0398 size: 32 bit */
5038
5039  CGM_AC_SC_32B_tag AC3SC; /* deprecated - please avoid */
5040
5041  };
5042  union {
5043  /* Auxiliary Clock Divider Configuration Registers */
5044  CGM_AC_DC0_3_32B_tag AC3_DC0_3; /* offset: 0x039C size: 32 bit */
5045
5046  CGM_AC_DC0_3_32B_tag AC3DC; /* deprecated - please avoid */
5047
5048  };
5049  union {
5050  /* Auxiliary Clock Select Control Registers */
5051  CGM_AC_SC_32B_tag AC4_SC; /* offset: 0x03A0 size: 32 bit */
5052
5053  CGM_AC_SC_32B_tag AC4SC; /* deprecated - please avoid */
5054
5055  };
5056  union {
5057  /* Auxiliary Clock Divider Configuration Registers */
5058  CGM_AC_DC0_3_32B_tag AC4_DC0_3; /* offset: 0x03A4 size: 32 bit */
5059
5060  CGM_AC_DC0_3_32B_tag AC4DC; /* deprecated - please avoid */
5061  };
5062  union {
5063  /* Auxiliary Clock Select Control Registers */
5064  CGM_AC_SC_32B_tag AC5_SC; /* offset: 0x03A8 size: 32 bit */
5065
5066  CGM_AC_SC_32B_tag AC5SC; /* deprecated - please avoid */
5067
5068  };
5069  union {
5070  /* Auxiliary Clock Divider Configuration Registers */
5071  CGM_AC_DC0_3_32B_tag AC5_DC0_3; /* offset: 0x03AC size: 32 bit */
5072
5073  CGM_AC_DC0_3_32B_tag AC5DC; /* deprecated - please avoid */
5074
5075  };
5076  };
5077
5078  };
5079  } CGM_tag;
5080
5081
5082 #define CGM (*(volatile CGM_tag *) 0xC3FE0000UL)
5083
5084
5085
5086 /****************************************************************/
5087 /* */
5088 /* Module: RGM */
5089 /* */
5090 /****************************************************************/
5091
5092  typedef union { /* Functional Event Status Register */
5093  uint16_t R;
5094  struct {
5095  uint16_t F_EXR:1; /* Flag for External Reset */
5096  uint16_t F_FCCU_HARD:1; /* Flag for FCCU hard reaction request */
5097  uint16_t F_FCCU_SOFT:1; /* Flag for FCCU soft reaction request */
5098  uint16_t F_ST_DONE:1; /* Flag for self-test completed */
5099 #ifndef USE_FIELD_ALIASES_RGM
5100  uint16_t F_CMU12_FHL:1; /* Flag for CMU 1/2 clock freq. too high/low */
5101 #else
5102  uint16_t F_CMU1_FHL:1; /* deprecated name - please avoid */
5103 #endif
5104  uint16_t F_FL_ECC_RCC:1; /* Flag for Flash, ECC, or lock-step error */
5105  uint16_t F_PLL1:1; /* Flag for PLL1 fail */
5106  uint16_t F_SWT:1; /* Flag for Software Watchdog Timer */
5107  uint16_t F_FCCU_SAFE:1; /* Flag for FCCU SAFE mode request */
5108  uint16_t F_CMU0_FHL:1; /* Flag for CMU 0 clock freq. too high/low */
5109  uint16_t F_CMU0_OLR:1; /* Flag for oscillator freq. too low */
5110  uint16_t F_PLL0:1; /* Flag for PLL0 fail */
5111  uint16_t F_CWD:1; /* Flag for Core Watchdog Reset */
5112  uint16_t F_SOFT:1; /* Flag for software reset */
5113  uint16_t F_CORE:1; /* Flag for core reset */
5114  uint16_t F_JTAG:1; /* Flag for JTAG initiated reset */
5115  } B;
5116  } RGM_FES_16B_tag;
5117
5118  typedef union { /* Destructive Event Status Register */
5119  uint16_t R;
5120  struct {
5121 #ifndef USE_FIELD_ALIASES_RGM
5122  uint16_t F_POR:1; /* Flag for Power on Reset */
5123 #else
5124  uint16_t POR:1; /* deprecated name - please avoid */
5125 #endif
5126  uint16_t:7;
5127  uint16_t F_COMP:1; /* Flag for comparator error */
5128  uint16_t F_LVD27_IO:1; /* Flag for 2.7V low-voltage detected (I/O) */
5129  uint16_t F_LVD27_FLASH:1; /* Flag for 2.7V low-voltage detected (Flash) */
5130  uint16_t F_LVD27_VREG:1; /* Flag for 2.7V low-voltage detected (VREG) */
5131  uint16_t:2;
5132  uint16_t F_HVD12:1; /* Flag for 1.2V high-voltage detected */
5133 #ifndef USE_FIELD_ALIASES_RGM
5134  uint16_t F_LVD12:1; /* Flag for 1.2V low-voltage detected */
5135 #else
5136  uint16_t F_LVD12_PD0:1; /* deprecated name - please avoid */
5137 #endif
5138  } B;
5139  } RGM_DES_16B_tag;
5140
5141  typedef union { /* Functional Event Reset Disable Register */
5142  uint16_t R;
5143  struct {
5144  uint16_t D_EXR:1; /* Disable External Pad Event Reset */
5145  uint16_t D_FCCU_HARD:1; /* Disable FCCU hard reaction request */
5146  uint16_t D_FCCU_SOFT:1; /* Disable FCCU soft reaction request */
5147  uint16_t D_ST_DONE:1; /* Disable self-test completed */
5148 #ifndef USE_FIELD_ALIASES_RGM
5149  uint16_t D_CMU12_FHL:1; /* Disable CMU 1/2 clock freq. too high/low */
5150 #else
5151  uint16_t D_CMU1_FHL:1; /* deprecated name - please avoid */
5152 #endif
5153  uint16_t D_FL_ECC_RCC:1; /* Disable Flash, ECC, or lock-step error */
5154  uint16_t D_PLL1:1; /* Disable PLL1 fail */
5155  uint16_t D_SWT:1; /* Disable Software Watchdog Timer */
5156  uint16_t D_FCCU_SAFE:1; /* Disable FCCU SAFE mode request */
5157  uint16_t D_CMU0_FHL:1; /* Disable CMU 0 clock freq. too high/low */
5158  uint16_t D_CMU0_OLR:1; /* Disable oscillator freq. too low */
5159  uint16_t D_PLL0:1; /* Disable PLL0 fail */
5160  uint16_t D_CWD:1; /* Disable Core Watchdog Reset */
5161  uint16_t D_SOFT:1; /* Disable software reset */
5162  uint16_t D_CORE:1; /* Disable core reset */
5163  uint16_t D_JTAG:1; /* Disable JTAG initiated reset */
5164  } B;
5165  } RGM_FERD_16B_tag;
5166
5167  typedef union { /* Destructive Event Reset Disable Register */
5168  uint16_t R;
5169  struct {
5170  uint16_t:8;
5171  uint16_t D_COMP:1; /* Disable comparator error */
5172  uint16_t D_LVD27_IO:1; /* Disable 2.7V low-voltage detected (I/O) */
5173  uint16_t D_LVD27_FLASH:1; /* Disable 2.7V low-voltage detected (Flash) */
5174  uint16_t D_LVD27_VREG:1; /* Disable 2.7V low-voltage detected (VREG) */
5175  uint16_t:2;
5176  uint16_t D_HVD12:1; /* Disable 1.2V high-voltage detected */
5177 #ifndef USE_FIELD_ALIASES_RGM
5178  uint16_t D_LVD12:1; /* Disable 1.2V low-voltage detected */
5179 #else
5180  uint16_t D_LVD12_PD0:1; /* deprecated name - please avoid */
5181 #endif
5182  } B;
5183  } RGM_DERD_16B_tag;
5184
5185  typedef union { /* Functional Event Alternate Request Register */
5186  uint16_t R;
5187  struct {
5188  uint16_t:4;
5189 #ifndef USE_FIELD_ALIASES_RGM
5190  uint16_t AR_CMU12_FHL:1; /* Alternate Request for CMU1/2 clock freq. too high/low */
5191 #else
5192  uint16_t AR_CMU1_FHL:1; /* deprecated name - please avoid */
5193 #endif
5194  uint16_t:1;
5195  uint16_t AR_PLL1:1; /* Alternate Request for PLL1 fail */
5196  uint16_t:1;
5197  uint16_t AR_FCCU_SAVE:1; /* Alternate Request for FCCU SAFE mode request */
5198  uint16_t AR_CMU0_FHL:1; /* Alternate Request for CMU0 clock freq.
5199  too high/low */
5200  uint16_t AR_CMU0_OLR:1; /* Alternate Request for oscillator freq. too low */
5201  uint16_t AR_PLL0:1; /* Alternate Request for PLL0 fail */
5202  uint16_t AR_CWD:1; /* Alternate Request for core watchdog reset */
5203  uint16_t:3;
5204  } B;
5205  } RGM_FEAR_16B_tag;
5206
5207  typedef union { /* Functional Event Short Sequence Register */
5208  uint16_t R;
5209  struct {
5210  uint16_t SS_EXR:1; /* Short Sequence for External Reset */
5211  uint16_t SS_FCCU_HARD:1; /* Short Sequence for FCCU hard reaction request */
5212  uint16_t SS_FCCU_SOFT:1; /* Short Sequence for FCCU soft reaction request */
5213  uint16_t SS_ST_DONE:1; /* Short Sequence for self-test completed */
5214 #ifndef USE_FIELD_ALIASES_RGM
5215  uint16_t SS_CMU12_FHL:1; /* Short Sequence for CMU 1/2 clock freq. too high/low */
5216 #else
5217  uint16_t SS_CMU1_FHL:1; /* deprecated name - please avoid */
5218 #endif
5219  uint16_t SS_FL_ECC_RCC:1; /* Short Sequence for Flash, ECC, or lock-step error */
5220  uint16_t SS_PLL1:1; /* Short Sequence for PLL1 fail */
5221  uint16_t SS_SWT:1; /* Short Sequence for Software Watchdog Timer */
5222  uint16_t:1;
5223  uint16_t SS_CMU0_FHL:1; /* Short Sequence for CMU 0 clock freq. too high/low */
5224  uint16_t SS_CMU0_OLR:1; /* Short Sequence for oscillator freq. too low */
5225  uint16_t SS_PLL0:1; /* Short Sequence for PLL0 fail */
5226  uint16_t SS_CWD:1; /* Short Sequence for Core Watchdog Reset */
5227  uint16_t SS_SOFT:1; /* Short Sequence for software reset */
5228  uint16_t SS_CORE:1; /* Short Sequence for core reset */
5229  uint16_t SS_JTAG:1; /* Short Sequence for JTAG initiated reset */
5230  } B;
5231  } RGM_FESS_16B_tag;
5232
5233  typedef union { /* Functional Bidirectional Reset Enable Register */
5234  uint16_t R;
5235  struct {
5236  uint16_t BE_EXR:1; /* Bidirectional Reset Enable for External Reset */
5237  uint16_t BE_FCCU_HARD:1; /* Bidirectional Reset Enable for FCCU hard reaction request */
5238  uint16_t BE_FCCU_SOFT:1; /* Bidirectional Reset Enable for FCCU soft reaction request */
5239  uint16_t BE_ST_DONE:1; /* Bidirectional Reset Enable for self-test completed */
5240 #ifndef USE_FIELD_ALIASES_RGM
5241  uint16_t BE_CMU12_FHL:1; /* Bidirectional Reset Enable for CMU 1/2 clock freq. too high/low */
5242 #else
5243  uint16_t BE_CMU1_FHL:1; /* deprecated name - please avoid */
5244 #endif
5245  uint16_t BE_FL_ECC_RCC:1; /* Bidirectional Reset Enable for Flash, ECC, or lock-step error */
5246  uint16_t BE_PLL1:1; /* Bidirectional Reset Enable for PLL1 fail */
5247  uint16_t BE_SWT:1; /* Bidirectional Reset Enable for Software Watchdog Timer */
5248  uint16_t:1;
5249  uint16_t BE_CMU0_FHL:1; /* Bidirectional Reset Enable for CMU 0 clock freq. too high/low */
5250  uint16_t BE_CMU0_OLR:1; /* Bidirectional Reset Enable for oscillator freq. too low */
5251  uint16_t BE_PLL0:1; /* Bidirectional Reset Enable for PLL0 fail */
5252  uint16_t BE_CWD:1; /* Bidirectional Reset Enable for Core Watchdog Reset */
5253  uint16_t BE_SOFT:1; /* Bidirectional Reset Enable for software reset */
5254  uint16_t BE_CORE:1; /* Bidirectional Reset Enable for core reset */
5255  uint16_t BE_JTAG:1; /* Bidirectional Reset Enable for JTAG initiated reset */
5256  } B;
5257  } RGM_FBRE_16B_tag;
5258
5259
5260
5261  typedef struct RGM_struct_tag { /* start of RGM_tag */
5262  /* Functional Event Status Register */
5263  RGM_FES_16B_tag FES; /* offset: 0x0000 size: 16 bit */
5264  /* Destructive Event Status Register */
5265  RGM_DES_16B_tag DES; /* offset: 0x0002 size: 16 bit */
5266  /* Functional Event Reset Disable Register */
5267  RGM_FERD_16B_tag FERD; /* offset: 0x0004 size: 16 bit */
5268  /* Destructive Event Reset Disable Register */
5269  RGM_DERD_16B_tag DERD; /* offset: 0x0006 size: 16 bit */
5270  int8_t RGM_reserved_0008[8];
5271  /* Functional Event Alternate Request Register */
5272  RGM_FEAR_16B_tag FEAR; /* offset: 0x0010 size: 16 bit */
5273  int8_t RGM_reserved_0012[6];
5274  /* Functional Event Short Sequence Register */
5275  RGM_FESS_16B_tag FESS; /* offset: 0x0018 size: 16 bit */
5276  int8_t RGM_reserved_001A[2];
5277  /* Functional Bidirectional Reset Enable Register */
5278  RGM_FBRE_16B_tag FBRE; /* offset: 0x001C size: 16 bit */
5279  } RGM_tag;
5280
5281
5282 #define RGM (*(volatile RGM_tag *) 0xC3FE4000UL)
5283
5284
5285
5286 /****************************************************************/
5287 /* */
5288 /* Module: PCU */
5289 /* */
5290 /****************************************************************/
5291
5292
5293  /* Register layout for all registers PCONF... */
5294
5295  typedef union { /* PCU_PCONF[0..15] - Power Domain #0..#15 Configuration Register */
5296  uint32_t R;
5297  struct {
5298  uint32_t:18;
5299  uint32_t STBY0:1; /* Power domain control during STBY0 */
5300  uint32_t:2;
5301  uint32_t STOP0:1; /* Power domain control during STOP0 */
5302  uint32_t:1;
5303  uint32_t HALT0:1; /* Power domain control during HALT0 */
5304  uint32_t RUN3:1; /* Power domain control during RUN3 */
5305  uint32_t RUN2:1; /* Power domain control during RUN2 */
5306  uint32_t RUN1:1; /* Power domain control during RUN1 */
5307  uint32_t RUN0:1; /* Power domain control during RUN0 */
5308  uint32_t DRUN:1; /* Power domain control during DRUN */
5309  uint32_t SAFE:1; /* Power domain control during SAFE */
5310  uint32_t TEST:1; /* Power domain control during TEST */
5311  uint32_t RST:1; /* Power domain control during RST */
5312  } B;
5314
5315  typedef union { /* PCU_PSTAT - Power Domain Status Register */
5316  uint32_t R;
5317  struct {
5318  uint32_t:16;
5319  uint32_t PD15:1; /* Power Status for Power Domain 15 */
5320  uint32_t PD14:1; /* Power Status for Power Domain 14 */
5321  uint32_t PD13:1; /* Power Status for Power Domain 13 */
5322  uint32_t PD12:1; /* Power Status for Power Domain 12 */
5323  uint32_t PD11:1; /* Power Status for Power Domain 11 */
5324  uint32_t PD10:1; /* Power Status for Power Domain 10 */
5325  uint32_t PD9:1; /* Power Status for Power Domain 9 */
5326  uint32_t PD8:1; /* Power Status for Power Domain 8 */
5327  uint32_t PD7:1; /* Power Status for Power Domain 7 */
5328  uint32_t PD6:1; /* Power Status for Power Domain 6 */
5329  uint32_t PD5:1; /* Power Status for Power Domain 5 */
5330  uint32_t PD4:1; /* Power Status for Power Domain 4 */
5331  uint32_t PD3:1; /* Power Status for Power Domain 3 */
5332  uint32_t PD2:1; /* Power Status for Power Domain 2 */
5333  uint32_t PD1:1; /* Power Status for Power Domain 1 */
5334  uint32_t PD0:1; /* Power Status for Power Domain 0 */
5335  } B;
5337
5338
5339
5340  typedef struct PCU_struct_tag { /* start of PCU_tag */
5341  union {
5342  /* PCU_PCONF[0..15] - Power Domain #0..#15 Configuration Register */
5343  PCU_PCONF_32B_tag PCONF[16]; /* offset: 0x0000 (0x0004 x 16) */
5344
5345  struct {
5346  /* PCU_PCONF[0..15] - Power Domain #0..#15 Configuration Register */
5347  PCU_PCONF_32B_tag PCONF0; /* offset: 0x0000 size: 32 bit */
5348  PCU_PCONF_32B_tag PCONF1; /* offset: 0x0004 size: 32 bit */
5349  PCU_PCONF_32B_tag PCONF2; /* offset: 0x0008 size: 32 bit */
5350  PCU_PCONF_32B_tag PCONF3; /* offset: 0x000C size: 32 bit */
5351  PCU_PCONF_32B_tag PCONF4; /* offset: 0x0010 size: 32 bit */
5352  PCU_PCONF_32B_tag PCONF5; /* offset: 0x0014 size: 32 bit */
5353  PCU_PCONF_32B_tag PCONF6; /* offset: 0x0018 size: 32 bit */
5354  PCU_PCONF_32B_tag PCONF7; /* offset: 0x001C size: 32 bit */
5355  PCU_PCONF_32B_tag PCONF8; /* offset: 0x0020 size: 32 bit */
5356  PCU_PCONF_32B_tag PCONF9; /* offset: 0x0024 size: 32 bit */
5357  PCU_PCONF_32B_tag PCONF10; /* offset: 0x0028 size: 32 bit */
5358  PCU_PCONF_32B_tag PCONF11; /* offset: 0x002C size: 32 bit */
5359  PCU_PCONF_32B_tag PCONF12; /* offset: 0x0030 size: 32 bit */
5360  PCU_PCONF_32B_tag PCONF13; /* offset: 0x0034 size: 32 bit */
5361  PCU_PCONF_32B_tag PCONF14; /* offset: 0x0038 size: 32 bit */
5362  PCU_PCONF_32B_tag PCONF15; /* offset: 0x003C size: 32 bit */
5363  };
5364
5365  };
5366  /* PCU_PSTAT - Power Domain Status Register */
5367  PCU_PSTAT_32B_tag PSTAT; /* offset: 0x0040 size: 32 bit */
5368  } PCU_tag;
5369
5370
5371 #define PCU (*(volatile PCU_tag *) 0xC3FE8000UL)
5372
5373
5374
5375 /****************************************************************/
5376 /* */
5377 /* Module: PMUCTRL */
5378 /* */
5379 /****************************************************************/
5380
5381  typedef union { /* PMUCTRL_STATHVD - PMU Status Register HVD */
5382  uint32_t R;
5383  struct {
5384  uint32_t:11;
5385  uint32_t HVDT_LPB:5; /* High Voltage Detector trimming bits LPB bus */
5386  uint32_t:6;
5387  uint32_t HVD_M:1; /* High Voltage Detector Main */
5388  uint32_t HVD_B:1; /* High Voltage Detector Backup */
5389  uint32_t:4;
5390  uint32_t HVD_LP:4; /* High Voltage Detector trimming bits LP bus */
5391  } B;
5393
5394  typedef union { /* PMUCTRL_STATLVD - PMU Status Register LVD */
5395  uint32_t R;
5396  struct {
5397  uint32_t:11;
5398  uint32_t LVDT_LPB:5; /* Ligh Voltage Detector trimming bits LPB bus */
5399  uint32_t:6;
5400  uint32_t LVD_M:1; /* Ligh Voltage Detector Main */
5401  uint32_t LVD_B:1; /* Ligh Voltage Detector Backup */
5402  uint32_t:4;
5403  uint32_t LVD_LP:4; /* Ligh Voltage Detector trimming bits LP bus */
5404  } B;
5406
5407  typedef union { /* PMUCTRL_STATIREG - PMU Status Register IREG */
5408  uint32_t R;
5409  struct {
5410  uint32_t:28;
5411  uint32_t IIREG_HP:4; /* Internal ballast REGulator hpreg1 trimming bits */
5412  } B;
5414
5415  typedef union { /* PMUCTRL_STATEREG - PMU Status Register EREG */
5416  uint32_t R;
5417  struct {
5418  uint32_t:28;
5419  uint32_t EEREG_HP:4; /* Internal ballast REGulator hpreg1 trimming bits */
5420  } B;
5422
5423  typedef union { /* PMUCTRL_STATUS - PMU Status Register STATUS */
5424  uint32_t R;
5425  struct {
5426  uint32_t EBMM:1; /* External Ballast Management Mode */
5427  uint32_t AEBD:1; /* Automatic External Ballast Detection */
5428  uint32_t ENPN:1; /* External NPN status flag */
5429  uint32_t:13;
5430  uint32_t CTB:2; /* Configuration Trace Bits */
5431  uint32_t:6;
5432  uint32_t CBS:4; /* Current BIST Status */
5433  uint32_t CPCS:4; /* Current Pmu Configuration Status */
5434  } B;
5436
5437  typedef union { /* PMUCTRL_CTRL - PMU Control Register */
5438  uint32_t R;
5439  struct {
5440  uint32_t:30;
5441  uint32_t SILHT:2; /* Start Idle or LVD or HVD BIST Test */
5442  } B;
5444
5445  typedef union { /* PMUCTRL_MASKF - PMU Mask Fault Register */
5446  uint32_t R;
5447  struct {
5448  uint32_t MF_BB:4; /* Mask Fault Bypass Balast */
5449  uint32_t:28;
5450  } B;
5452
5453  typedef union { /* PMUCTRL_FAULT - PMU Fault Monitor Register */
5454  uint32_t R;
5455  struct {
5456  uint32_t BB_LV:4; /* Bypass Ballast Low Voltage */
5457  uint32_t:9;
5458  uint32_t FLNCF:1; /* FLash voltage monitor Non Critical Fault */
5459  uint32_t IONCF:1; /* IO voltage monitor Non Critical Fault */
5460  uint32_t RENCF:1; /* REgulator voltage monitor Non Critical Fault */
5461  uint32_t:13;
5462  uint32_t LHCF:1; /* Low High voltage detector Critical Fault */
5463  uint32_t LNCF:1; /* Low voltage detector Non Critical Fault */
5464  uint32_t HNCF:1; /* High voltage detector Non Critical Fault */
5465  } B;
5467
5468  typedef union { /* PMUCTRL_IRQS - PMU Interrupt Request Status Register */
5469  uint32_t R;
5470  struct {
5471  uint32_t:10;
5472  uint32_t MFVMP:1; /* Main Flash Voltage Monitor interrupt Pending */
5473  uint32_t BFVMP:1; /* Backup Flash Voltage Monitor interrupt Pending */
5474  uint32_t MIVMP:1; /* MAin IO Voltage Monitor interrupt Pending */
5475  uint32_t BIVMP:1; /* Backup IO Voltage Monitor interrupt Pending */
5476  uint32_t MRVMP:1; /* Main Regulator Voltage Monitor interrupt Pending */
5477  uint32_t BRVMP:1; /* Backup Regulator Voltage Monitor interrupt Pending */
5478  uint32_t:12;
5479  uint32_t MLVDP:1; /* Main Low Voltage Detector error interrupt Pending */
5480  uint32_t BLVDP:1; /* Backup Low Voltage Detector error interrupt Pending */
5481  uint32_t MHVDP:1; /* Main High Voltage Detector error interrupt Pending */
5482  uint32_t BHVDP:1; /* Backup High Voltage Detector error interrupt Pending */
5483  } B;
5485
5486  typedef union { /* PMUCTRL_IRQE - PMU Interrupt Request Enable Register */
5487  uint32_t R;
5488  struct {
5489  uint32_t:10;
5490  uint32_t MFVME:1; /* Main Flash Voltage Monitor interrupt Enable */
5491  uint32_t BFVME:1; /* Backup Flash Voltage Monitor interrupt Enable */
5492  uint32_t MIVME:1; /* MAin IO Voltage Monitor interrupt Enable */
5493  uint32_t BIVME:1; /* Backup IO Voltage Monitor interrupt Enable */
5494  uint32_t MRVME:1; /* Main Regulator Voltage Monitor interrupt Enable */
5495  uint32_t BRVME:1; /* Backup Regulator Voltage Monitor interrupt Enable */
5496  uint32_t:12;
5497  uint32_t MLVDE:1; /* Main Low Voltage Detector error interrupt Enable */
5498  uint32_t BLVDE:1; /* Backup Low Voltage Detector error interrupt Enable */
5499  uint32_t MHVDE:1; /* Main High Voltage Detector error interrupt Enable */
5500  uint32_t BHVDE:1; /* Backup High Voltage Detector error interrupt Enable */
5501  } B;
5503
5504
5505
5506  typedef struct PMUCTRL_struct_tag { /* start of PMUCTRL_tag */
5507  int8_t PMUCTRL_reserved_0000[4];
5508  /* PMUCTRL_STATHVD - PMU Status Register HVD */
5509  PMUCTRL_STATHVD_32B_tag STATHVD; /* offset: 0x0004 size: 32 bit */
5510  /* PMUCTRL_STATLVD - PMU Status Register LVD */
5511  PMUCTRL_STATLVD_32B_tag STATLVD; /* offset: 0x0008 size: 32 bit */
5512  int8_t PMUCTRL_reserved_000C[20];
5513  /* PMUCTRL_STATIREG - PMU Status Register IREG */
5514  PMUCTRL_STATIREG_32B_tag STATIREG; /* offset: 0x0020 size: 32 bit */
5515  /* PMUCTRL_STATEREG - PMU Status Register EREG */
5516  PMUCTRL_STATEREG_32B_tag STATEREG; /* offset: 0x0024 size: 32 bit */
5517  int8_t PMUCTRL_reserved_0028[24];
5518  /* PMUCTRL_STATUS - PMU Status Register STATUS */
5519  PMUCTRL_STATUS_32B_tag STATUS; /* offset: 0x0040 size: 32 bit */
5520  /* PMUCTRL_CTRL - PMU Control Register */
5521  PMUCTRL_CTRL_32B_tag CTRL; /* offset: 0x0044 size: 32 bit */
5522  int8_t PMUCTRL_reserved_0048[40];
5523  /* PMUCTRL_MASKF - PMU Mask Fault Register */
5524  PMUCTRL_MASKF_32B_tag MASKF; /* offset: 0x0070 size: 32 bit */
5525  /* PMUCTRL_FAULT - PMU Fault Monitor Register */
5526  PMUCTRL_FAULT_32B_tag FAULT; /* offset: 0x0074 size: 32 bit */
5527  /* PMUCTRL_IRQS - PMU Interrupt Request Status Register */
5528  PMUCTRL_IRQS_32B_tag IRQS; /* offset: 0x0078 size: 32 bit */
5529  /* PMUCTRL_IRQE - PMU Interrupt Request Enable Register */
5530  PMUCTRL_IRQE_32B_tag IRQE; /* offset: 0x007C size: 32 bit */
5531  } PMUCTRL_tag;
5532
5533
5534 #define PMUCTRL (*(volatile PMUCTRL_tag *) 0xC3FE8080UL)
5535
5536
5537
5538 /****************************************************************/
5539 /* */
5540 /* Module: PIT_RTI */
5541 /* */
5542 /****************************************************************/
5543
5544  typedef union { /* PIT_RTI_PITMCR - PIT Module Control Register */
5545  uint32_t R;
5546  struct {
5547  uint32_t:30;
5548  uint32_t MDIS:1; /* Module Disable. Disable the module clock */
5549  uint32_t FRZ:1; /* Freeze. Allows the timers to be stoppedwhen the device enters debug mode */
5550  } B;
5552
5553
5554  /* Register layout for all registers LDVAL... */
5555
5556  typedef union { /* PIT_RTI_LDVAL - Timer Load Value Register */
5557  uint32_t R;
5558  struct {
5559  uint32_t TSV:32; /* Time Start Value Bits */
5560  } B;
5562
5563
5564  /* Register layout for all registers CVAL... */
5565
5566  typedef union { /* PIT_RTI_CVAL - Current Timer Value Register */
5567  uint32_t R;
5568  struct {
5569  uint32_t TVL:32; /* Current Timer Value Bits */
5570  } B;
5572
5573
5574  /* Register layout for all registers TCTRL... */
5575
5576  typedef union { /* PIT_RTI_TCTRL - Timer Control Register */
5577  uint32_t R;
5578  struct {
5579  uint32_t:30;
5580  uint32_t TIE:1; /* Timer Interrupt Enable Bit */
5581  uint32_t TEN:1; /* Timer Enable Bit */
5582  } B;
5584
5585
5586  /* Register layout for all registers TFLG... */
5587
5588  typedef union { /* PIT_RTI_TFLG - Timer Flag Register */
5589  uint32_t R;
5590  struct {
5591  uint32_t:31;
5592  uint32_t TIF:1; /* Timer Interrupt Flag Bit */
5593  } B;
5595
5596
5598
5599  /* PIT_RTI_LDVAL - Timer Load Value Register */
5600  PIT_RTI_LDVAL_32B_tag LDVAL; /* relative offset: 0x0000 */
5601  /* PIT_RTI_CVAL - Current Timer Value Register */
5602  PIT_RTI_CVAL_32B_tag CVAL; /* relative offset: 0x0004 */
5603  /* PIT_RTI_TCTRL - Timer Control Register */
5604  PIT_RTI_TCTRL_32B_tag TCTRL; /* relative offset: 0x0008 */
5605  /* PIT_RTI_TFLG - Timer Flag Register */
5606  PIT_RTI_TFLG_32B_tag TFLG; /* relative offset: 0x000C */
5607
5609
5610
5611  typedef struct PIT_RTI_struct_tag { /* start of PIT_RTI_tag */
5612  /* PIT_RTI_PITMCR - PIT Module Control Register */
5613  PIT_RTI_PITMCR_32B_tag PITMCR; /* offset: 0x0000 size: 32 bit */
5614  int8_t PIT_RTI_reserved_0004_C[252];
5615  union {
5616  /* Register set CHANNEL */
5617  PIT_RTI_CHANNEL_tag CHANNEL[4]; /* offset: 0x0100 (0x0010 x 4) */
5618
5619  PIT_RTI_CHANNEL_tag CH[4]; /* offset: 0x0100 (0x0010 x 4) */
5620
5621  struct {
5622  /* PIT_RTI_LDVAL - Timer Load Value Register */
5623  PIT_RTI_LDVAL_32B_tag LDVAL0; /* offset: 0x0100 size: 32 bit */
5624  /* PIT_RTI_CVAL - Current Timer Value Register */
5625  PIT_RTI_CVAL_32B_tag CVAL0; /* offset: 0x0104 size: 32 bit */
5626  /* PIT_RTI_TCTRL - Timer Control Register */
5627  PIT_RTI_TCTRL_32B_tag TCTRL0; /* offset: 0x0108 size: 32 bit */
5628  /* PIT_RTI_TFLG - Timer Flag Register */
5629  PIT_RTI_TFLG_32B_tag TFLG0; /* offset: 0x010C size: 32 bit */
5630  /* PIT_RTI_LDVAL - Timer Load Value Register */
5631  PIT_RTI_LDVAL_32B_tag LDVAL1; /* offset: 0x0110 size: 32 bit */
5632  /* PIT_RTI_CVAL - Current Timer Value Register */
5633  PIT_RTI_CVAL_32B_tag CVAL1; /* offset: 0x0114 size: 32 bit */
5634  /* PIT_RTI_TCTRL - Timer Control Register */
5635  PIT_RTI_TCTRL_32B_tag TCTRL1; /* offset: 0x0118 size: 32 bit */
5636  /* PIT_RTI_TFLG - Timer Flag Register */
5637  PIT_RTI_TFLG_32B_tag TFLG1; /* offset: 0x011C size: 32 bit */
5638  /* PIT_RTI_LDVAL - Timer Load Value Register */
5639  PIT_RTI_LDVAL_32B_tag LDVAL2; /* offset: 0x0120 size: 32 bit */
5640  /* PIT_RTI_CVAL - Current Timer Value Register */
5641  PIT_RTI_CVAL_32B_tag CVAL2; /* offset: 0x0124 size: 32 bit */
5642  /* PIT_RTI_TCTRL - Timer Control Register */
5643  PIT_RTI_TCTRL_32B_tag TCTRL2; /* offset: 0x0128 size: 32 bit */
5644  /* PIT_RTI_TFLG - Timer Flag Register */
5645  PIT_RTI_TFLG_32B_tag TFLG2; /* offset: 0x012C size: 32 bit */
5646  /* PIT_RTI_LDVAL - Timer Load Value Register */
5647  PIT_RTI_LDVAL_32B_tag LDVAL3; /* offset: 0x0130 size: 32 bit */
5648  /* PIT_RTI_CVAL - Current Timer Value Register */
5649  PIT_RTI_CVAL_32B_tag CVAL3; /* offset: 0x0134 size: 32 bit */
5650  /* PIT_RTI_TCTRL - Timer Control Register */
5651  PIT_RTI_TCTRL_32B_tag TCTRL3; /* offset: 0x0138 size: 32 bit */
5652  /* PIT_RTI_TFLG - Timer Flag Register */
5653  PIT_RTI_TFLG_32B_tag TFLG3; /* offset: 0x013C size: 32 bit */
5654  };
5655
5656  };
5657  } PIT_RTI_tag;
5658
5659
5660 #define PIT_RTI (*(volatile PIT_RTI_tag *) 0xC3FF0000UL)
5661
5662
5663
5664 /****************************************************************/
5665 /* */
5666 /* Module: ADC */
5667 /* */
5668 /****************************************************************/
5669
5670  typedef union { /* module configuration register */
5671  uint32_t R;
5672  struct {
5673  uint32_t OWREN:1; /* Overwrite enable */
5674  uint32_t WLSIDE:1; /* Write Left/right Alligned */
5675  uint32_t MODE:1; /* One Shot/Scan Mode Selectiom */
5676  uint32_t EDGLEV:1; /* edge or level selection for external start trigger */
5677  uint32_t TRGEN:1; /* external trigger enable */
5678  uint32_t EDGE:1; /* start trigger egde /level detection */
5679  uint32_t XSTRTEN:1; /* EXTERNAL START ENABLE */
5680  uint32_t NSTART:1; /* start normal conversion */
5681  uint32_t:1;
5682  uint32_t JTRGEN:1; /* Injectin External Trigger Enable */
5683  uint32_t JEDGE:1; /* start trigger egde /level detection for injected */
5684  uint32_t JSTART:1; /* injected conversion start */
5685  uint32_t:2;
5686  uint32_t CTUEN:1; /* CTU enabaled */
5687  uint32_t:8;
5688  uint32_t ADCLKSEL:1; /* Select which clock for device */
5689  uint32_t ABORTCHAIN:1; /* abort chain conversion */
5690  uint32_t ABORT:1; /* abort current conversion */
5691 #ifndef USE_FIELD_ALIASES_ADC
5692  uint32_t ACKO:1; /* Auto Clock Off Enable */
5693 #else
5694  uint32_t ACK0:1; /* deprecated name - please avoid */
5695 #endif
5696  uint32_t OFFREFRESH:1; /* offset phase selection */
5697  uint32_t OFFCANC:1; /* offset phase cancellation selection */
5698  uint32_t:2;
5699  uint32_t PWDN:1; /* Power Down Enable */
5700  } B;
5701  } ADC_MCR_32B_tag;
5702
5703  typedef union { /* module status register */
5704  uint32_t R;
5705  struct {
5706  uint32_t:7;
5707  uint32_t NSTART:1; /* normal conversion status */
5708  uint32_t JABORT:1; /* Injection chain abort status */
5709  uint32_t:2;
5710  uint32_t JSTART:1; /* Injection Start status */
5711  uint32_t:3;
5712  uint32_t CTUSTART:1; /* ctu start status */
5713  uint32_t CHADDR:7; /* which address conv is goin on */
5714  uint32_t:3;
5715 #ifndef USE_FIELD_ALIASES_ADC
5716  uint32_t ACKO:1; /* Auto Clock Off Enable status */
5717 #else
5718  uint32_t ACK0:1; /* deprecated name - please avoid */
5719 #endif
5720  uint32_t OFFREFRESH:1; /* offset refresh status */
5721  uint32_t OFFCANC:1; /* offset phase cancellation status */
5722  uint32_t ADCSTATUS:3; /* status of ADC FSM */
5723  } B;
5724  } ADC_MSR_32B_tag;
5725
5726  typedef union { /* Interrupt status register */
5727  uint32_t R;
5728  struct {
5729  uint32_t:25;
5730  uint32_t OFFCANCOVR:1; /* Offset cancellation phase over */
5731  uint32_t EOFFSET:1; /* error in offset refresh */
5732  uint32_t EOCTU:1; /* end of CTU channel conversion */
5733  uint32_t JEOC:1; /* end of injected channel conversion */
5734  uint32_t JECH:1; /* end ofinjected chain conversion */
5735  uint32_t EOC:1; /* end of channel conversion */
5736  uint32_t ECH:1; /* end of chain conversion */
5737  } B;
5738  } ADC_ISR_32B_tag;
5739
5740  typedef union { /* CHANNEL PENDING REGISTER 0 */
5741  uint32_t R;
5742  struct {
5743 #ifndef USE_FIELD_ALIASES_ADC
5744  uint32_t EOC_CH31:1; /* Channel 31 conversion over */
5745 #else
5746  uint32_t EOC31:1; /* deprecated name - please avoid */
5747 #endif
5748 #ifndef USE_FIELD_ALIASES_ADC
5749  uint32_t EOC_CH30:1; /* Channel 30 conversion over */
5750 #else
5751  uint32_t EOC30:1; /* deprecated name - please avoid */
5752 #endif
5753 #ifndef USE_FIELD_ALIASES_ADC
5754  uint32_t EOC_CH29:1; /* Channel 29 conversion over */
5755 #else
5756  uint32_t EOC29:1; /* deprecated name - please avoid */
5757 #endif
5758 #ifndef USE_FIELD_ALIASES_ADC
5759  uint32_t EOC_CH28:1; /* Channel 28 conversion over */
5760 #else
5761  uint32_t EOC28:1; /* deprecated name - please avoid */
5762 #endif
5763 #ifndef USE_FIELD_ALIASES_ADC
5764  uint32_t EOC_CH27:1; /* Channel 27 conversion over */
5765 #else
5766  uint32_t EOC27:1; /* deprecated name - please avoid */
5767 #endif
5768 #ifndef USE_FIELD_ALIASES_ADC
5769  uint32_t EOC_CH26:1; /* Channel 26 conversion over */
5770 #else
5771  uint32_t EOC26:1; /* deprecated name - please avoid */
5772 #endif
5773 #ifndef USE_FIELD_ALIASES_ADC
5774  uint32_t EOC_CH25:1; /* Channel 25 conversion over */
5775 #else
5776  uint32_t EOC25:1; /* deprecated name - please avoid */
5777 #endif
5778 #ifndef USE_FIELD_ALIASES_ADC
5779  uint32_t EOC_CH24:1; /* Channel 24 conversion over */
5780 #else
5781  uint32_t EOC24:1; /* deprecated name - please avoid */
5782 #endif
5783 #ifndef USE_FIELD_ALIASES_ADC
5784  uint32_t EOC_CH23:1; /* Channel 23 conversion over */
5785 #else
5786  uint32_t EOC23:1; /* deprecated name - please avoid */
5787 #endif
5788 #ifndef USE_FIELD_ALIASES_ADC
5789  uint32_t EOC_CH22:1; /* Channel 22 conversion over */
5790 #else
5791  uint32_t EOC22:1; /* deprecated name - please avoid */
5792 #endif
5793 #ifndef USE_FIELD_ALIASES_ADC
5794  uint32_t EOC_CH21:1; /* Channel 21 conversion over */
5795 #else
5796  uint32_t EOC21:1; /* deprecated name - please avoid */
5797 #endif
5798 #ifndef USE_FIELD_ALIASES_ADC
5799  uint32_t EOC_CH20:1; /* Channel 20 conversion over */
5800 #else
5801  uint32_t EOC20:1; /* deprecated name - please avoid */
5802 #endif
5803 #ifndef USE_FIELD_ALIASES_ADC
5804  uint32_t EOC_CH19:1; /* Channel 19 conversion over */
5805 #else
5806  uint32_t EOC19:1; /* deprecated name - please avoid */
5807 #endif
5808 #ifndef USE_FIELD_ALIASES_ADC
5809  uint32_t EOC_CH18:1; /* Channel 18 conversion over */
5810 #else
5811  uint32_t EOC18:1; /* deprecated name - please avoid */
5812 #endif
5813 #ifndef USE_FIELD_ALIASES_ADC
5814  uint32_t EOC_CH17:1; /* Channel 17 conversion over */
5815 #else
5816  uint32_t EOC17:1; /* deprecated name - please avoid */
5817 #endif
5818 #ifndef USE_FIELD_ALIASES_ADC
5819  uint32_t EOC_CH16:1; /* Channel 16 conversion over */
5820 #else
5821  uint32_t EOC16:1; /* deprecated name - please avoid */
5822 #endif
5823 #ifndef USE_FIELD_ALIASES_ADC
5824  uint32_t EOC_CH15:1; /* Channel 15 conversion over */
5825 #else
5826  uint32_t EOC15:1; /* deprecated name - please avoid */
5827 #endif
5828 #ifndef USE_FIELD_ALIASES_ADC
5829  uint32_t EOC_CH14:1; /* Channel 14 conversion over */
5830 #else
5831  uint32_t EOC14:1; /* deprecated name - please avoid */
5832 #endif
5833 #ifndef USE_FIELD_ALIASES_ADC
5834  uint32_t EOC_CH13:1; /* Channel 13 conversion over */
5835 #else
5836  uint32_t EOC13:1; /* deprecated name - please avoid */
5837 #endif
5838 #ifndef USE_FIELD_ALIASES_ADC
5839  uint32_t EOC_CH12:1; /* Channel 12 conversion over */
5840 #else
5841  uint32_t EOC12:1; /* deprecated name - please avoid */
5842 #endif
5843 #ifndef USE_FIELD_ALIASES_ADC
5844  uint32_t EOC_CH11:1; /* Channel 11 conversion over */
5845 #else
5846  uint32_t EOC11:1; /* deprecated name - please avoid */
5847 #endif
5848 #ifndef USE_FIELD_ALIASES_ADC
5849  uint32_t EOC_CH10:1; /* Channel 10 conversion over */
5850 #else
5851  uint32_t EOC10:1; /* deprecated name - please avoid */
5852 #endif
5853 #ifndef USE_FIELD_ALIASES_ADC
5854  uint32_t EOC_CH9:1; /* Channel 9 conversion over */
5855 #else
5856  uint32_t EOC9:1; /* deprecated name - please avoid */
5857 #endif
5858 #ifndef USE_FIELD_ALIASES_ADC
5859  uint32_t EOC_CH8:1; /* Channel 8 conversion over */
5860 #else
5861  uint32_t EOC8:1; /* deprecated name - please avoid */
5862 #endif
5863 #ifndef USE_FIELD_ALIASES_ADC
5864  uint32_t EOC_CH7:1; /* Channel 7 conversion over */
5865 #else
5866  uint32_t EOC7:1; /* deprecated name - please avoid */
5867 #endif
5868 #ifndef USE_FIELD_ALIASES_ADC
5869  uint32_t EOC_CH6:1; /* Channel 6 conversion over */
5870 #else
5871  uint32_t EOC6:1; /* deprecated name - please avoid */
5872 #endif
5873 #ifndef USE_FIELD_ALIASES_ADC
5874  uint32_t EOC_CH5:1; /* Channel 5 conversion over */
5875 #else
5876  uint32_t EOC5:1; /* deprecated name - please avoid */
5877 #endif
5878 #ifndef USE_FIELD_ALIASES_ADC
5879  uint32_t EOC_CH4:1; /* Channel 4 conversion over */
5880 #else
5881  uint32_t EOC4:1; /* deprecated name - please avoid */
5882 #endif
5883 #ifndef USE_FIELD_ALIASES_ADC
5884  uint32_t EOC_CH3:1; /* Channel 3 conversion over */
5885 #else
5886  uint32_t EOC3:1; /* deprecated name - please avoid */
5887 #endif
5888 #ifndef USE_FIELD_ALIASES_ADC
5889  uint32_t EOC_CH2:1; /* Channel 2 conversion over */
5890 #else
5891  uint32_t EOC2:1; /* deprecated name - please avoid */
5892 #endif
5893 #ifndef USE_FIELD_ALIASES_ADC
5894  uint32_t EOC_CH1:1; /* Channel 1 conversion over */
5895 #else
5896  uint32_t EOC1:1; /* deprecated name - please avoid */
5897 #endif
5898 #ifndef USE_FIELD_ALIASES_ADC
5899  uint32_t EOC_CH0:1; /* Channel 0 conversion over */
5900 #else
5901  uint32_t EOC0:1; /* deprecated name - please avoid */
5902 #endif
5903  } B;
5905
5906  typedef union { /* CHANNEL PENDING REGISTER 1 */
5907  uint32_t R;
5908  struct {
5909  uint32_t EOC_CH63:1; /* Channel 63 conversion over */
5910  uint32_t EOC_CH62:1; /* Channel 62 conversion over */
5911  uint32_t EOC_CH61:1; /* Channel 61 conversion over */
5912  uint32_t EOC_CH60:1; /* Channel 60 conversion over */
5913  uint32_t EOC_CH59:1; /* Channel 59 conversion over */
5914  uint32_t EOC_CH58:1; /* Channel 58 conversion over */
5915  uint32_t EOC_CH57:1; /* Channel 57 conversion over */
5916  uint32_t EOC_CH56:1; /* Channel 56 conversion over */
5917  uint32_t EOC_CH55:1; /* Channel 55 conversion over */
5918  uint32_t EOC_CH54:1; /* Channel 54 conversion over */
5919  uint32_t EOC_CH53:1; /* Channel 53 conversion over */
5920  uint32_t EOC_CH52:1; /* Channel 52 conversion over */
5921  uint32_t EOC_CH51:1; /* Channel 51 conversion over */
5922  uint32_t EOC_CH50:1; /* Channel 50 conversion over */
5923  uint32_t EOC_CH49:1; /* Channel 49 conversion over */
5924  uint32_t EOC_CH48:1; /* Channel 48 conversion over */
5925  uint32_t EOC_CH47:1; /* Channel 47 conversion over */
5926  uint32_t EOC_CH46:1; /* Channel 46 conversion over */
5927  uint32_t EOC_CH45:1; /* Channel 45 conversion over */
5928  uint32_t EOC_CH44:1; /* Channel 44 conversion over */
5929  uint32_t EOC_CH43:1; /* Channel 43 conversion over */
5930  uint32_t EOC_CH42:1; /* Channel 42 conversion over */
5931  uint32_t EOC_CH41:1; /* Channel 41 conversion over */
5932  uint32_t EOC_CH40:1; /* Channel 40 conversion over */
5933  uint32_t EOC_CH39:1; /* Channel 39 conversion over */
5934  uint32_t EOC_CH38:1; /* Channel 38 conversion over */
5935  uint32_t EOC_CH37:1; /* Channel 37 conversion over */
5936  uint32_t EOC_CH36:1; /* Channel 36 conversion over */
5937  uint32_t EOC_CH35:1; /* Channel 35 conversion over */
5938  uint32_t EOC_CH34:1; /* Channel 34 conversion over */
5939  uint32_t EOC_CH33:1; /* Channel 33 conversion over */
5940  uint32_t EOC_CH32:1; /* Channel 32 conversion over */
5941  } B;
5943
5944  typedef union { /* CHANNEL PENDING REGISTER 2 */
5945  uint32_t R;
5946  struct {
5947  uint32_t EOC_CH95:1; /* Channel 95 conversion over */
5948  uint32_t EOC_CH94:1; /* Channel 94 conversion over */
5949  uint32_t EOC_CH93:1; /* Channel 93 conversion over */
5950  uint32_t EOC_CH92:1; /* Channel 92 conversion over */
5951  uint32_t EOC_CH91:1; /* Channel 91 conversion over */
5952  uint32_t EOC_CH90:1; /* Channel 90 conversion over */
5953  uint32_t EOC_CH89:1; /* Channel 89 conversion over */
5954  uint32_t EOC_CH88:1; /* Channel 88 conversion over */
5955  uint32_t EOC_CH87:1; /* Channel 87 conversion over */
5956  uint32_t EOC_CH86:1; /* Channel 86 conversion over */
5957  uint32_t EOC_CH85:1; /* Channel 85 conversion over */
5958  uint32_t EOC_CH84:1; /* Channel 84 conversion over */
5959  uint32_t EOC_CH83:1; /* Channel 83 conversion over */
5960  uint32_t EOC_CH82:1; /* Channel 82 conversion over */
5961  uint32_t EOC_CH81:1; /* Channel 81 conversion over */
5962  uint32_t EOC_CH80:1; /* Channel 80 conversion over */
5963  uint32_t EOC_CH79:1; /* Channel 79 conversion over */
5964  uint32_t EOC_CH78:1; /* Channel 78 conversion over */
5965  uint32_t EOC_CH77:1; /* Channel 77 conversion over */
5966  uint32_t EOC_CH76:1; /* Channel 76 conversion over */
5967  uint32_t EOC_CH75:1; /* Channel 75 conversion over */
5968  uint32_t EOC_CH74:1; /* Channel 74 conversion over */
5969  uint32_t EOC_CH73:1; /* Channel 73 conversion over */
5970  uint32_t EOC_CH72:1; /* Channel 72 conversion over */
5971  uint32_t EOC_CH71:1; /* Channel 71 conversion over */
5972  uint32_t EOC_CH70:1; /* Channel 70 conversion over */
5973  uint32_t EOC_CH69:1; /* Channel 69 conversion over */
5974  uint32_t EOC_CH68:1; /* Channel 68 conversion over */
5975  uint32_t EOC_CH67:1; /* Channel 67 conversion over */
5976  uint32_t EOC_CH66:1; /* Channel 66 conversion over */
5977  uint32_t EOC_CH65:1; /* Channel 65 conversion over */
5978  uint32_t EOC_CH64:1; /* Channel 64 conversion over */
5979  } B;
5981
5982  typedef union { /* interrupt mask register */
5983  uint32_t R;
5984  struct {
5985  uint32_t:25;
5986  uint32_t MSKOFFCANCOVR:1; /* mask bit for Calibration over */
5987  uint32_t MSKEOFFSET:1; /* mask bit for Error in offset refresh */
5988  uint32_t MSKEOCTU:1; /* mask bit for EOCTU */
5989  uint32_t MSKJEOC:1; /* mask bit for JEOC */
5990  uint32_t MSKJECH:1; /* mask bit for JECH */
5991  uint32_t MSKEOC:1; /* mask bit for EOC */
5992  uint32_t MSKECH:1; /* mask bit for ECH */
5993  } B;
5994  } ADC_IMR_32B_tag;
5995
5996  typedef union { /* CHANNEL INTERRUPT MASK REGISTER 0 */
5997  uint32_t R;
5998  struct {
5999  uint32_t CIM31:1; /* Channel 31 mask register */
6000  uint32_t CIM30:1; /* Channel 30 mask register */
6001  uint32_t CIM29:1; /* Channel 29 mask register */
6002  uint32_t CIM28:1; /* Channel 28 mask register */
6003  uint32_t CIM27:1; /* Channel 27 mask register */
6004  uint32_t CIM26:1; /* Channel 26 mask register */
6005  uint32_t CIM25:1; /* Channel 25 mask register */
6006  uint32_t CIM24:1; /* Channel 24 mask register */
6007  uint32_t CIM23:1; /* Channel 23 mask register */
6008  uint32_t CIM22:1; /* Channel 22 mask register */
6009  uint32_t CIM21:1; /* Channel 21 mask register */
6010  uint32_t CIM20:1; /* Channel 20 mask register */
6011  uint32_t CIM19:1; /* Channel 19 mask register */
6012  uint32_t CIM18:1; /* Channel 18 mask register */
6013  uint32_t CIM17:1; /* Channel 17 mask register */
6014  uint32_t CIM16:1; /* Channel 16 mask register */
6015  uint32_t CIM15:1; /* Channel 15 mask register */
6016  uint32_t CIM14:1; /* Channel 14 mask register */
6017  uint32_t CIM13:1; /* Channel 13 mask register */
6018  uint32_t CIM12:1; /* Channel 12 mask register */
6019  uint32_t CIM11:1; /* Channel 11 mask register */
6020  uint32_t CIM10:1; /* Channel 10 mask register */
6021  uint32_t CIM9:1; /* Channel 9 mask register */
6022  uint32_t CIM8:1; /* Channel 8 mask register */
6023  uint32_t CIM7:1; /* Channel 7 mask register */
6024  uint32_t CIM6:1; /* Channel 6 mask register */
6025  uint32_t CIM5:1; /* Channel 5 mask register */
6026  uint32_t CIM4:1; /* Channel 4 mask register */
6027  uint32_t CIM3:1; /* Channel 3 mask register */
6028  uint32_t CIM2:1; /* Channel 2 mask register */
6029  uint32_t CIM1:1; /* Channel 1 mask register */
6030  uint32_t CIM0:1; /* Channel 0 mask register */
6031  } B;
6033
6034  typedef union { /* CHANNEL INTERRUPT MASK REGISTER 1 */
6035  uint32_t R;
6036  struct {
6037  uint32_t CIM63:1; /* Channel 63 mask register */
6038  uint32_t CIM62:1; /* Channel 62 mask register */
6039  uint32_t CIM61:1; /* Channel 61 mask register */
6040  uint32_t CIM60:1; /* Channel 60 mask register */
6041  uint32_t CIM59:1; /* Channel 59 mask register */
6042  uint32_t CIM58:1; /* Channel 58 mask register */
6043  uint32_t CIM57:1; /* Channel 57 mask register */
6044  uint32_t CIM56:1; /* Channel 56 mask register */
6045  uint32_t CIM55:1; /* Channel 55 mask register */
6046  uint32_t CIM54:1; /* Channel 54 mask register */
6047  uint32_t CIM53:1; /* Channel 53 mask register */
6048  uint32_t CIM52:1; /* Channel 52 mask register */
6049  uint32_t CIM51:1; /* Channel 51 mask register */
6050  uint32_t CIM50:1; /* Channel 50 mask register */
6051  uint32_t CIM49:1; /* Channel 49 mask register */
6052  uint32_t CIM48:1; /* Channel 48 mask register */
6053  uint32_t CIM47:1; /* Channel 47 mask register */
6054  uint32_t CIM46:1; /* Channel 46 mask register */
6055  uint32_t CIM45:1; /* Channel 45 mask register */
6056  uint32_t CIM44:1; /* Channel 44 mask register */
6057  uint32_t CIM43:1; /* Channel 43 mask register */
6058  uint32_t CIM42:1; /* Channel 42 mask register */
6059  uint32_t CIM41:1; /* Channel 41 mask register */
6060  uint32_t CIM40:1; /* Channel 40 mask register */
6061  uint32_t CIM39:1; /* Channel 39 mask register */
6062  uint32_t CIM38:1; /* Channel 38 mask register */
6063  uint32_t CIM37:1; /* Channel 37 mask register */
6064  uint32_t CIM36:1; /* Channel 36 mask register */
6065  uint32_t CIM35:1; /* Channel 35 mask register */
6066  uint32_t CIM34:1; /* Channel 34 mask register */
6067  uint32_t CIM33:1; /* Channel 33 mask register */
6068  uint32_t CIM32:1; /* Channel 32 mask register */
6069  } B;
6071
6072  typedef union { /* CHANNEL INTERRUPT MASK REGISTER 2 */
6073  uint32_t R;
6074  struct {
6075  uint32_t CIM95:1; /* Channel 95 mask register */
6076  uint32_t CIM94:1; /* Channel 94 mask register */
6077  uint32_t CIM93:1; /* Channel 93 mask register */
6078  uint32_t CIM92:1; /* Channel 92 mask register */
6079  uint32_t CIM91:1; /* Channel 91 mask register */
6080  uint32_t CIM90:1; /* Channel 90 mask register */
6081  uint32_t CIM89:1; /* Channel 89 mask register */
6082  uint32_t CIM88:1; /* Channel 88 mask register */
6083  uint32_t CIM87:1; /* Channel 87 mask register */
6084  uint32_t CIM86:1; /* Channel 86 mask register */
6085  uint32_t CIM85:1; /* Channel 85 mask register */
6086  uint32_t CIM84:1; /* Channel 84 mask register */
6087  uint32_t CIM83:1; /* Channel 83 mask register */
6088  uint32_t CIM82:1; /* Channel 82 mask register */
6089  uint32_t CIM81:1; /* Channel 81 mask register */
6090  uint32_t CIM80:1; /* Channel 80 mask register */
6091  uint32_t CIM79:1; /* Channel 79 mask register */
6092  uint32_t CIM78:1; /* Channel 78 mask register */
6093  uint32_t CIM77:1; /* Channel 77 mask register */
6094  uint32_t CIM76:1; /* Channel 76 mask register */
6095  uint32_t CIM75:1; /* Channel 75 mask register */
6096  uint32_t CIM74:1; /* Channel 74 mask register */
6097  uint32_t CIM73:1; /* Channel 73 mask register */
6098  uint32_t CIM72:1; /* Channel 72 mask register */
6099  uint32_t CIM71:1; /* Channel 71 mask register */
6100  uint32_t CIM70:1; /* Channel 70 mask register */
6101  uint32_t CIM69:1; /* Channel 69 mask register */
6102  uint32_t CIM68:1; /* Channel 68 mask register */
6103  uint32_t CIM67:1; /* Channel 67 mask register */
6104  uint32_t CIM66:1; /* Channel 66 mask register */
6105  uint32_t CIM65:1; /* Channel 65 mask register */
6106  uint32_t CIM64:1; /* Channel 64 mask register */
6107  } B;
6109
6110  typedef union { /* Watchdog Threshold interrupt status register */
6111  uint32_t R;
6112  struct {
6113  uint32_t:24;
6114  uint32_t WDG3H:1; /* Interrupt generated on the value being higher than the HTHV 3 */
6115  uint32_t WDG2H:1; /* Interrupt generated on the value being higher than the HTHV 2 */
6116  uint32_t WDG1H:1; /* Interrupt generated on the value being higher than the HTHV 1 */
6117  uint32_t WDG0H:1; /* Interrupt generated on the value being higher than the HTHV 0 */
6118  uint32_t WDG3L:1; /* Interrupt generated on the value being lower than the LTHV 3 */
6119  uint32_t WDG2L:1; /* Interrupt generated on the value being lower than the LTHV 2 */
6120  uint32_t WDG1L:1; /* Interrupt generated on the value being lower than the LTHV 1 */
6121  uint32_t WDG0L:1; /* Interrupt generated on the value being lower than the LTHV 0 */
6122  } B;
6124
6125  typedef union { /* Watchdog interrupt MASK register */
6126  uint32_t R;
6127  struct {
6128  uint32_t:24;
6129  uint32_t MSKWDG3H:1; /* Mask enable for Interrupt generated on the value being higher than the HTHV 3 */
6130  uint32_t MSKWDG2H:1; /* Mask enable for Interrupt generated on the value being higher than the HTHV 2 */
6131  uint32_t MSKWDG1H:1; /* Mask enable for Interrupt generated on the value being higher than the HTHV 1 */
6132  uint32_t MSKWDG0H:1; /* Mask enable for Interrupt generated on the value being higher than the HTHV 0 */
6133  uint32_t MSKWDG3L:1; /* Mask enable for Interrupt generated on the value being lower than the LTHV 3 */
6134  uint32_t MSKWDG2L:1; /* Mask enable for Interrupt generated on the value being lower than the LTHV 2 */
6135  uint32_t MSKWDG1L:1; /* MAsk enable for Interrupt generated on the value being lower than the LTHV 1 */
6136  uint32_t MSKWDG0L:1; /* Mask enable for Interrupt generated on the value being lower than the LTHV 0 */
6137  } B;
6139
6140  typedef union { /* DMAE register */
6141  uint32_t R;
6142  struct {
6143  uint32_t:30;
6144  uint32_t DCLR:1; /* DMA clear sequence enable */
6145  uint32_t DMAEN:1; /* DMA global enable */
6146  } B;
6147  } ADC_DMAE_32B_tag;
6148
6149  typedef union { /* DMA REGISTER 0 */
6150  uint32_t R;
6151  struct {
6152  uint32_t DMA31:1; /* Channel 31 DMA Enable */
6153  uint32_t DMA30:1; /* Channel 30 DMA Enable */
6154  uint32_t DMA29:1; /* Channel 29 DMA Enable */
6155  uint32_t DMA28:1; /* Channel 28 DMA Enable */
6156  uint32_t DMA27:1; /* Channel 27 DMA Enable */
6157  uint32_t DMA26:1; /* Channel 26 DMA Enable */
6158  uint32_t DMA25:1; /* Channel 25 DMA Enable */
6159  uint32_t DMA24:1; /* Channel 24 DMA Enable */
6160  uint32_t DMA23:1; /* Channel 23 DMA Enable */
6161  uint32_t DMA22:1; /* Channel 22 DMA Enable */
6162  uint32_t DMA21:1; /* Channel 21 DMA Enable */
6163  uint32_t DMA20:1; /* Channel 20 DMA Enable */
6164  uint32_t DMA19:1; /* Channel 19 DMA Enable */
6165  uint32_t DMA18:1; /* Channel 18 DMA Enable */
6166  uint32_t DMA17:1; /* Channel 17 DMA Enable */
6167  uint32_t DMA16:1; /* Channel 16 DMA Enable */
6168  uint32_t DMA15:1; /* Channel 15 DMA Enable */
6169  uint32_t DMA14:1; /* Channel 14 DMA Enable */
6170  uint32_t DMA13:1; /* Channel 13 DMA Enable */
6171  uint32_t DMA12:1; /* Channel 12 DMA Enable */
6172  uint32_t DMA11:1; /* Channel 11 DMA Enable */
6173  uint32_t DMA10:1; /* Channel 10 DMA Enable */
6174  uint32_t DMA9:1; /* Channel 9 DMA Enable */
6175  uint32_t DMA8:1; /* Channel 8 DMA Enable */
6176  uint32_t DMA7:1; /* Channel 7 DMA Enable */
6177  uint32_t DMA6:1; /* Channel 6 DMA Enable */
6178  uint32_t DMA5:1; /* Channel 5 DMA Enable */
6179  uint32_t DMA4:1; /* Channel 4 DMA Enable */
6180  uint32_t DMA3:1; /* Channel 3 DMA Enable */
6181  uint32_t DMA2:1; /* Channel 2 DMA Enable */
6182  uint32_t DMA1:1; /* Channel 1 DMA Enable */
6183  uint32_t DMA0:1; /* Channel 0 DMA Enable */
6184  } B;
6186
6187  typedef union { /* DMA REGISTER 1 */
6188  uint32_t R;
6189  struct {
6190  uint32_t DMA63:1; /* Channel 63 DMA Enable */
6191  uint32_t DMA62:1; /* Channel 62 DMA Enable */
6192  uint32_t DMA61:1; /* Channel 61 DMA Enable */
6193  uint32_t DMA60:1; /* Channel 60 DMA Enable */
6194  uint32_t DMA59:1; /* Channel 59 DMA Enable */
6195  uint32_t DMA58:1; /* Channel 58 DMA Enable */
6196  uint32_t DMA57:1; /* Channel 57 DMA Enable */
6197  uint32_t DMA56:1; /* Channel 56 DMA Enable */
6198  uint32_t DMA55:1; /* Channel 55 DMA Enable */
6199  uint32_t DMA54:1; /* Channel 54 DMA Enable */
6200  uint32_t DMA53:1; /* Channel 53 DMA Enable */
6201  uint32_t DMA52:1; /* Channel 52 DMA Enable */
6202  uint32_t DMA51:1; /* Channel 51 DMA Enable */
6203  uint32_t DMA50:1; /* Channel 50 DMA Enable */
6204  uint32_t DMA49:1; /* Channel 49 DMA Enable */
6205  uint32_t DMA48:1; /* Channel 48 DMA Enable */
6206  uint32_t DMA47:1; /* Channel 47 DMA Enable */
6207  uint32_t DMA46:1; /* Channel 46 DMA Enable */
6208  uint32_t DMA45:1; /* Channel 45 DMA Enable */
6209  uint32_t DMA44:1; /* Channel 44 DMA Enable */
6210  uint32_t DMA43:1; /* Channel 43 DMA Enable */
6211  uint32_t DMA42:1; /* Channel 42 DMA Enable */
6212  uint32_t DMA41:1; /* Channel 41 DMA Enable */
6213  uint32_t DMA40:1; /* Channel 40 DMA Enable */
6214  uint32_t DMA39:1; /* Channel 39 DMA Enable */
6215  uint32_t DMA38:1; /* Channel 38 DMA Enable */
6216  uint32_t DMA37:1; /* Channel 37 DMA Enable */
6217  uint32_t DMA36:1; /* Channel 36 DMA Enable */
6218  uint32_t DMA35:1; /* Channel 35 DMA Enable */
6219  uint32_t DMA34:1; /* Channel 34 DMA Enable */
6220  uint32_t DMA33:1; /* Channel 33 DMA Enable */
6221  uint32_t DMA32:1; /* Channel 32 DMA Enable */
6222  } B;
6224
6225  typedef union { /* DMA REGISTER 2 */
6226  uint32_t R;
6227  struct {
6228  uint32_t DMA95:1; /* Channel 95 DMA Enable */
6229  uint32_t DMA94:1; /* Channel 94 DMA Enable */
6230  uint32_t DMA93:1; /* Channel 93 DMA Enable */
6231  uint32_t DMA92:1; /* Channel 92 DMA Enable */
6232  uint32_t DMA91:1; /* Channel 91 DMA Enable */
6233  uint32_t DMA90:1; /* Channel 90 DMA Enable */
6234  uint32_t DMA89:1; /* Channel 89 DMA Enable */
6235  uint32_t DMA88:1; /* Channel 88 DMA Enable */
6236  uint32_t DMA87:1; /* Channel 87 DMA Enable */
6237  uint32_t DMA86:1; /* Channel 86 DMA Enable */
6238  uint32_t DMA85:1; /* Channel 85 DMA Enable */
6239  uint32_t DMA84:1; /* Channel 84 DMA Enable */
6240  uint32_t DMA83:1; /* Channel 83 DMA Enable */
6241  uint32_t DMA82:1; /* Channel 82 DMA Enable */
6242  uint32_t DMA81:1; /* Channel 81 DMA Enable */
6243  uint32_t DMA80:1; /* Channel 80 DMA Enable */
6244  uint32_t DMA79:1; /* Channel 79 DMA Enable */
6245  uint32_t DMA78:1; /* Channel 78 DMA Enable */
6246  uint32_t DMA77:1; /* Channel 77 DMA Enable */
6247  uint32_t DMA76:1; /* Channel 76 DMA Enable */
6248  uint32_t DMA75:1; /* Channel 75 DMA Enable */
6249  uint32_t DMA74:1; /* Channel 74 DMA Enable */
6250  uint32_t DMA73:1; /* Channel 73 DMA Enable */
6251  uint32_t DMA72:1; /* Channel 72 DMA Enable */
6252  uint32_t DMA71:1; /* Channel 71 DMA Enable */
6253  uint32_t DMA70:1; /* Channel 70 DMA Enable */
6254  uint32_t DMA69:1; /* Channel 69 DMA Enable */
6255  uint32_t DMA68:1; /* Channel 68 DMA Enable */
6256  uint32_t DMA67:1; /* Channel 67 DMA Enable */
6257  uint32_t DMA66:1; /* Channel 66 DMA Enable */
6258  uint32_t DMA65:1; /* Channel 65 DMA Enable */
6259  uint32_t DMA64:1; /* Channel 64 DMA Enable */
6260  } B;
6262
6263
6264  /* Register layout for all registers TRC... */
6265
6266  typedef union { /* Threshold Control register C */
6267  uint32_t R;
6268  struct {
6269  uint32_t:16;
6270  uint32_t THREN:1; /* Threshold enable */
6271  uint32_t THRINV:1; /* invert the output pin */
6272  uint32_t THROP:1; /* output pin register */
6273  uint32_t:6;
6274  uint32_t THRCH:7; /* Choose channel for threshold register */
6275  } B;
6276  } ADC_TRC_32B_tag;
6277
6278
6279  /* Register layout for all registers THRHLR... */
6280
6281  typedef union { /* Upper Threshold register */
6282  uint32_t R;
6283  struct {
6284  uint32_t:4;
6285  uint32_t THRH:12; /* high threshold value s */
6286  uint32_t:4;
6287  uint32_t THRL:12; /* low threshold value s */
6288  } B;
6290
6291
6292  /* Register layout for all registers THRALT... */
6293
6294  typedef union { /* alternate Upper Threshold register */
6295  uint32_t R;
6296  struct {
6297  uint32_t:6;
6298  uint32_t THRH:10; /* high threshold value s */
6299  uint32_t:6;
6300  uint32_t THRL:10; /* low threshold value s */
6301  } B;
6303
6304  typedef union { /* PRESAMPLING CONTROL REGISTER */
6305  uint32_t R;
6306  struct {
6307  uint32_t:25;
6308  uint32_t PREVAL2:2; /* INternal Voltage selection for Presampling */
6309  uint32_t PREVAL1:2; /* INternal Voltage selection for Presampling */
6310  uint32_t PREVAL0:2; /* INternal Voltage selection for Presampling */
6311 #ifndef USE_FIELD_ALIASES_ADC
6312  uint32_t PRECONV:1; /* Presampled value */
6313 #else
6314  uint32_t PREONCE:1; /* deprecated name - please avoid */
6315 #endif
6316  } B;
6317  } ADC_PSCR_32B_tag;
6318
6319  typedef union { /* Presampling Register 0 */
6320  uint32_t R;
6321  struct {
6322  uint32_t PRES31:1; /* Channel 31 Presampling Enable */
6323  uint32_t PRES30:1; /* Channel 30 Presampling Enable */
6324  uint32_t PRES29:1; /* Channel 29 Presampling Enable */
6325  uint32_t PRES28:1; /* Channel 28 Presampling Enable */
6326  uint32_t PRES27:1; /* Channel 27 Presampling Enable */
6327  uint32_t PRES26:1; /* Channel 26 Presampling Enable */
6328  uint32_t PRES25:1; /* Channel 25 Presampling Enable */
6329  uint32_t PRES24:1; /* Channel 24 Presampling Enable */
6330  uint32_t PRES23:1; /* Channel 23 Presampling Enable */
6331  uint32_t PRES22:1; /* Channel 22 Presampling Enable */
6332  uint32_t PRES21:1; /* Channel 21 Presampling Enable */
6333  uint32_t PRES20:1; /* Channel 20 Presampling Enable */
6334  uint32_t PRES19:1; /* Channel 19 Presampling Enable */
6335  uint32_t PRES18:1; /* Channel 18 Presampling Enable */
6336  uint32_t PRES17:1; /* Channel 17 Presampling Enable */
6337  uint32_t PRES16:1; /* Channel 16 Presampling Enable */
6338  uint32_t PRES15:1; /* Channel 15 Presampling Enable */
6339  uint32_t PRES14:1; /* Channel 14 Presampling Enable */
6340  uint32_t PRES13:1; /* Channel 13 Presampling Enable */
6341  uint32_t PRES12:1; /* Channel 12 Presampling Enable */
6342  uint32_t PRES11:1; /* Channel 11 Presampling Enable */
6343  uint32_t PRES10:1; /* Channel 10 Presampling Enable */
6344  uint32_t PRES9:1; /* Channel 9 Presampling Enable */
6345  uint32_t PRES8:1; /* Channel 8 Presampling Enable */
6346  uint32_t PRES7:1; /* Channel 7 Presampling Enable */
6347  uint32_t PRES6:1; /* Channel 6 Presampling Enable */
6348  uint32_t PRES5:1; /* Channel 5 Presampling Enable */
6349  uint32_t PRES4:1; /* Channel 4 Presampling Enable */
6350  uint32_t PRES3:1; /* Channel 3 Presampling Enable */
6351  uint32_t PRES2:1; /* Channel 2 Presampling Enable */
6352  uint32_t PRES1:1; /* Channel 1presampling Enable */
6353  uint32_t PRES0:1; /* Channel 0 Presampling Enable */
6354  } B;
6355  } ADC_PSR0_32B_tag;
6356
6357  typedef union { /* Presampling REGISTER 1 */
6358  uint32_t R;
6359  struct {
6360  uint32_t PRES63:1; /* Channel 63 Presampling Enable */
6361  uint32_t PRES62:1; /* Channel 62 Presampling Enable */
6362  uint32_t PRES61:1; /* Channel 61 Presampling Enable */
6363  uint32_t PRES60:1; /* Channel 60 Presampling Enable */
6364  uint32_t PRES59:1; /* Channel 59 Presampling Enable */
6365  uint32_t PRES58:1; /* Channel 58 Presampling Enable */
6366  uint32_t PRES57:1; /* Channel 57 Presampling Enable */
6367  uint32_t PRES56:1; /* Channel 56 Presampling Enable */
6368  uint32_t PRES55:1; /* Channel 55 Presampling Enable */
6369  uint32_t PRES54:1; /* Channel 54 Presampling Enable */
6370  uint32_t PRES53:1; /* Channel 53 Presampling Enable */
6371  uint32_t PRES52:1; /* Channel 52 Presampling Enable */
6372  uint32_t PRES51:1; /* Channel 51 Presampling Enable */
6373  uint32_t PRES50:1; /* Channel 50 Presampling Enable */
6374  uint32_t PRES49:1; /* Channel 49 Presampling Enable */
6375  uint32_t PRES48:1; /* Channel 48 Presampling Enable */
6376  uint32_t PRES47:1; /* Channel 47 Presampling Enable */
6377  uint32_t PRES46:1; /* Channel 46 Presampling Enable */
6378  uint32_t PRES45:1; /* Channel 45 Presampling Enable */
6379  uint32_t PRES44:1; /* Channel 44 Presampling Enable */
6380  uint32_t PRES43:1; /* Channel 43 Presampling Enable */
6381  uint32_t PRES42:1; /* Channel 42 Presampling Enable */
6382  uint32_t PRES41:1; /* Channel 41 Presampling Enable */
6383  uint32_t PRES40:1; /* Channel 40 Presampling Enable */
6384  uint32_t PRES39:1; /* Channel 39 Presampling Enable */
6385  uint32_t PRES38:1; /* Channel 38 Presampling Enable */
6386  uint32_t PRES37:1; /* Channel 37 Presampling Enable */
6387  uint32_t PRES36:1; /* Channel 36 Presampling Enable */
6388  uint32_t PRES35:1; /* Channel 35 Presampling Enable */
6389  uint32_t PRES34:1; /* Channel 34 Presampling Enable */
6390  uint32_t PRES33:1; /* Channel 33 Presampling Enable */
6391  uint32_t PRES32:1; /* Channel 32 Presampling Enable */
6392  } B;
6393  } ADC_PSR1_32B_tag;
6394
6395  typedef union { /* Presampling REGISTER 2 */
6396  uint32_t R;
6397  struct {
6398  uint32_t PRES95:1; /* Channel 95 Presampling Enable */
6399  uint32_t PRES94:1; /* Channel 94 Presampling Enable */
6400  uint32_t PRES93:1; /* Channel 93 Presampling Enable */
6401  uint32_t PRES92:1; /* Channel 92 Presampling Enable */
6402  uint32_t PRES91:1; /* Channel 91 Presampling Enable */
6403  uint32_t PRES90:1; /* Channel 90 Presampling Enable */
6404  uint32_t PRES89:1; /* Channel 89 Presampling Enable */
6405  uint32_t PRES88:1; /* Channel 88 Presampling Enable */
6406  uint32_t PRES87:1; /* Channel 87 Presampling Enable */
6407  uint32_t PRES86:1; /* Channel 86 Presampling Enable */
6408  uint32_t PRES85:1; /* Channel 85 Presampling Enable */
6409  uint32_t PRES84:1; /* Channel 84 Presampling Enable */
6410  uint32_t PRES83:1; /* Channel 83 Presampling Enable */
6411  uint32_t PRES82:1; /* Channel 82 Presampling Enable */
6412  uint32_t PRES81:1; /* Channel 81 Presampling Enable */
6413  uint32_t PRES80:1; /* Channel 80 Presampling Enable */
6414  uint32_t PRES79:1; /* Channel 79 Presampling Enable */
6415  uint32_t PRES78:1; /* Channel 78 Presampling Enable */
6416  uint32_t PRES77:1; /* Channel 77 Presampling Enable */
6417  uint32_t PRES76:1; /* Channel 76 Presampling Enable */
6418  uint32_t PRES75:1; /* Channel 75 Presampling Enable */
6419  uint32_t PRES74:1; /* Channel 74 Presampling Enable */
6420  uint32_t PRES73:1; /* Channel 73 Presampling Enable */
6421  uint32_t PRES72:1; /* Channel 72 Presampling Enable */
6422  uint32_t PRES71:1; /* Channel 71 Presampling Enable */
6423  uint32_t PRES70:1; /* Channel 70 Presampling Enable */
6424  uint32_t PRES69:1; /* Channel 69 Presampling Enable */
6425  uint32_t PRES68:1; /* Channel 68 Presampling Enable */
6426  uint32_t PRES67:1; /* Channel 67 Presampling Enable */
6427  uint32_t PRES66:1; /* Channel 66 Presampling Enable */
6428  uint32_t PRES65:1; /* Channel 65 Presampling Enable */
6429  uint32_t PRES64:1; /* Channel 64 Presampling Enable */
6430  } B;
6431  } ADC_PSR2_32B_tag;
6432
6433
6434  /* Register layout for all registers CTR... */
6435
6436  typedef union { /* conversion timing register */
6437  uint32_t R;
6438  struct {
6439  uint32_t:16;
6440  uint32_t INPLATCH:1; /* configuration bits for the LATCHING PHASE duration */
6441  uint32_t:1;
6442  uint32_t OFFSHIFT:2; /* configuration for offset shift characteristics */
6443  uint32_t:1;
6444  uint32_t INPCMP:2; /* configuration bits for the COMPARISON duration */
6445  uint32_t:1;
6446 #ifndef USE_FIELD_ALIASES_ADC
6447  uint32_t INSAMP:8; /* configuration bits for the SAMPLING PHASE duration */
6448 #else
6449  uint32_t INPSAMP:8;
6450 #endif
6451  } B;
6452  } ADC_CTR_32B_tag;
6453
6454  typedef union { /* NORMAL CONVERSION MASK REGISTER 0 */
6455  uint32_t R;
6456  struct {
6457  uint32_t CH31:1; /* Channel 31 Normal Sampling Enable */
6458  uint32_t CH30:1; /* Channel 30 Normal Sampling Enable */
6459  uint32_t CH29:1; /* Channel 29 Normal Sampling Enable */
6460  uint32_t CH28:1; /* Channel 28 Normal Sampling Enable */
6461  uint32_t CH27:1; /* Channel 27 Normal Sampling Enable */
6462  uint32_t CH26:1; /* Channel 26 Normal Sampling Enable */
6463  uint32_t CH25:1; /* Channel 25 Normal Sampling Enable */
6464  uint32_t CH24:1; /* Channel 24 Normal Sampling Enable */
6465  uint32_t CH23:1; /* Channel 23 Normal Sampling Enable */
6466  uint32_t CH22:1; /* Channel 22 Normal Sampling Enable */
6467  uint32_t CH21:1; /* Channel 21 Normal Sampling Enable */
6468  uint32_t CH20:1; /* Channel 20 Normal Sampling Enable */
6469  uint32_t CH19:1; /* Channel 19 Normal Sampling Enable */
6470  uint32_t CH18:1; /* Channel 18 Normal Sampling Enable */
6471  uint32_t CH17:1; /* Channel 17 Normal Sampling Enable */
6472  uint32_t CH16:1; /* Channel 16 Normal Sampling Enable */
6473  uint32_t CH15:1; /* Channel 15 Normal Sampling Enable */
6474  uint32_t CH14:1; /* Channel 14 Normal Sampling Enable */
6475  uint32_t CH13:1; /* Channel 13 Normal Sampling Enable */
6476  uint32_t CH12:1; /* Channel 12 Normal Sampling Enable */
6477  uint32_t CH11:1; /* Channel 11 Normal Sampling Enable */
6478  uint32_t CH10:1; /* Channel 10 Normal Sampling Enable */
6479  uint32_t CH9:1; /* Channel 9 Normal Sampling Enable */
6480  uint32_t CH8:1; /* Channel 8 Normal Sampling Enable */
6481  uint32_t CH7:1; /* Channel 7 Normal Sampling Enable */
6482  uint32_t CH6:1; /* Channel 6 Normal Sampling Enable */
6483  uint32_t CH5:1; /* Channel 5 Normal Sampling Enable */
6484  uint32_t CH4:1; /* Channel 4 Normal Sampling Enable */
6485  uint32_t CH3:1; /* Channel 3 Normal Sampling Enable */
6486  uint32_t CH2:1; /* Channel 2 Normal Sampling Enable */
6487  uint32_t CH1:1; /* Channel 1 Normal Sampling Enable */
6488  uint32_t CH0:1; /* Channel 0 Normal Sampling Enable */
6489  } B;
6491
6492  typedef union { /* NORMAL CONVERSION MASK REGISTER 1 */
6493  uint32_t R;
6494  struct {
6495  uint32_t CH63:1; /* Channel 63 Normal Sampling Enable */
6496  uint32_t CH62:1; /* Channel 62 Normal Sampling Enable */
6497  uint32_t CH61:1; /* Channel 61 Normal Sampling Enable */
6498  uint32_t CH60:1; /* Channel 60 Normal Sampling Enable */
6499  uint32_t CH59:1; /* Channel 59 Normal Sampling Enable */
6500  uint32_t CH58:1; /* Channel 58 Normal Sampling Enable */
6501  uint32_t CH57:1; /* Channel 57 Normal Sampling Enable */
6502  uint32_t CH56:1; /* Channel 56 Normal Sampling Enable */
6503  uint32_t CH55:1; /* Channel 55 Normal Sampling Enable */
6504  uint32_t CH54:1; /* Channel 54 Normal Sampling Enable */
6505  uint32_t CH53:1; /* Channel 53 Normal Sampling Enable */
6506  uint32_t CH52:1; /* Channel 52 Normal Sampling Enable */
6507  uint32_t CH51:1; /* Channel 51 Normal Sampling Enable */
6508  uint32_t CH50:1; /* Channel 50 Normal Sampling Enable */
6509  uint32_t CH49:1; /* Channel 49 Normal Sampling Enable */
6510  uint32_t CH48:1; /* Channel 48 Normal Sampling Enable */
6511  uint32_t CH47:1; /* Channel 47 Normal Sampling Enable */
6512  uint32_t CH46:1; /* Channel 46 Normal Sampling Enable */
6513  uint32_t CH45:1; /* Channel 45 Normal Sampling Enable */
6514  uint32_t CH44:1; /* Channel 44 Normal Sampling Enable */
6515  uint32_t CH43:1; /* Channel 43 Normal Sampling Enable */
6516  uint32_t CH42:1; /* Channel 42 Normal Sampling Enable */
6517  uint32_t CH41:1; /* Channel 41 Normal Sampling Enable */
6518  uint32_t CH40:1; /* Channel 40 Normal Sampling Enable */
6519  uint32_t CH39:1; /* Channel 39 Normal Sampling Enable */
6520  uint32_t CH38:1; /* Channel 38 Normal Sampling Enable */
6521  uint32_t CH37:1; /* Channel 37 Normal Sampling Enable */
6522  uint32_t CH36:1; /* Channel 36 Normal Sampling Enable */
6523  uint32_t CH35:1; /* Channel 35 Normal Sampling Enable */
6524  uint32_t CH34:1; /* Channel 34 Normal Sampling Enable */
6525  uint32_t CH33:1; /* Channel 33 Normal Sampling Enable */
6526  uint32_t CH32:1; /* Channel 32 Normal Sampling Enable */
6527  } B;
6529
6530  typedef union { /* NORMAL CONVERSION MASK REGISTER 2 */
6531  uint32_t R;
6532  struct {
6533  uint32_t CH95:1; /* Channel 95 Normal Sampling Enable */
6534  uint32_t CH94:1; /* Channel 94 Normal Sampling Enable */
6535  uint32_t CH93:1; /* Channel 93 Normal Sampling Enable */
6536  uint32_t CH92:1; /* Channel 92 Normal Sampling Enable */
6537  uint32_t CH91:1; /* Channel 91 Normal Sampling Enable */
6538  uint32_t CH90:1; /* Channel 90 Normal Sampling Enable */
6539  uint32_t CH89:1; /* Channel 89 Normal Sampling Enable */
6540  uint32_t CH88:1; /* Channel 88 Normal Sampling Enable */
6541  uint32_t CH87:1; /* Channel 87 Normal Sampling Enable */
6542  uint32_t CH86:1; /* Channel 86 Normal Sampling Enable */
6543  uint32_t CH85:1; /* Channel 85 Normal Sampling Enable */
6544  uint32_t CH84:1; /* Channel 84 Normal Sampling Enable */
6545  uint32_t CH83:1; /* Channel 83 Normal Sampling Enable */
6546  uint32_t CH82:1; /* Channel 82 Normal Sampling Enable */
6547  uint32_t CH81:1; /* Channel 81 Normal Sampling Enable */
6548  uint32_t CH80:1; /* Channel 80 Normal Sampling Enable */
6549  uint32_t CH79:1; /* Channel 79 Normal Sampling Enable */
6550  uint32_t CH78:1; /* Channel 78 Normal Sampling Enable */
6551  uint32_t CH77:1; /* Channel 77 Normal Sampling Enable */
6552  uint32_t CH76:1; /* Channel 76 Normal Sampling Enable */
6553  uint32_t CH75:1; /* Channel 75 Normal Sampling Enable */
6554  uint32_t CH74:1; /* Channel 74 Normal Sampling Enable */
6555  uint32_t CH73:1; /* Channel 73 Normal Sampling Enable */
6556  uint32_t CH72:1; /* Channel 72 Normal Sampling Enable */
6557  uint32_t CH71:1; /* Channel 71 Normal Sampling Enable */
6558  uint32_t CH70:1; /* Channel 70 Normal Sampling Enable */
6559  uint32_t CH69:1; /* Channel 69 Normal Sampling Enable */
6560  uint32_t CH68:1; /* Channel 68 Normal Sampling Enable */
6561  uint32_t CH67:1; /* Channel 67 Normal Sampling Enable */
6562  uint32_t CH66:1; /* Channel 66 Normal Sampling Enable */
6563  uint32_t CH65:1; /* Channel 65 Normal Sampling Enable */
6564  uint32_t CH64:1; /* Channel 64 Normal Sampling Enable */
6565  } B;
6567
6568  typedef union { /* Injected Conversion Mask Register 0 */
6569  uint32_t R;
6570  struct {
6571  uint32_t CH31:1; /* Channel 31 Injected Sampling Enable */
6572  uint32_t CH30:1; /* Channel 30 Injected Sampling Enable */
6573  uint32_t CH29:1; /* Channel 29 Injected Sampling Enable */
6574  uint32_t CH28:1; /* Channel 28 Injected Sampling Enable */
6575  uint32_t CH27:1; /* Channel 27 Injected Sampling Enable */
6576  uint32_t CH26:1; /* Channel 26 Injected Sampling Enable */
6577  uint32_t CH25:1; /* Channel 25 Injected Sampling Enable */
6578  uint32_t CH24:1; /* Channel 24 Injected Sampling Enable */
6579  uint32_t CH23:1; /* Channel 23 Injected Sampling Enable */
6580  uint32_t CH22:1; /* Channel 22 Injected Sampling Enable */
6581  uint32_t CH21:1; /* Channel 21 Injected Sampling Enable */
6582  uint32_t CH20:1; /* Channel 20 Injected Sampling Enable */
6583  uint32_t CH19:1; /* Channel 19 Injected Sampling Enable */
6584  uint32_t CH18:1; /* Channel 18 Injected Sampling Enable */
6585  uint32_t CH17:1; /* Channel 17 Injected Sampling Enable */
6586  uint32_t CH16:1; /* Channel 16 Injected Sampling Enable */
6587  uint32_t CH15:1; /* Channel 15 Injected Sampling Enable */
6588  uint32_t CH14:1; /* Channel 14 Injected Sampling Enable */
6589  uint32_t CH13:1; /* Channel 13 Injected Sampling Enable */
6590  uint32_t CH12:1; /* Channel 12 Injected Sampling Enable */
6591  uint32_t CH11:1; /* Channel 11 Injected Sampling Enable */
6592  uint32_t CH10:1; /* Channel 10 Injected Sampling Enable */
6593  uint32_t CH9:1; /* Channel 9 Injected Sampling Enable */
6594  uint32_t CH8:1; /* Channel 8 Injected Sampling Enable */
6595  uint32_t CH7:1; /* Channel 7 Injected Sampling Enable */
6596  uint32_t CH6:1; /* Channel 6 Injected Sampling Enable */
6597  uint32_t CH5:1; /* Channel 5 Injected Sampling Enable */
6598  uint32_t CH4:1; /* Channel 4 Injected Sampling Enable */
6599  uint32_t CH3:1; /* Channel 3 Injected Sampling Enable */
6600  uint32_t CH2:1; /* Channel 2 Injected Sampling Enable */
6601  uint32_t CH1:1; /* Channel 1 injected Sampling Enable */
6602  uint32_t CH0:1; /* Channel 0 injected Sampling Enable */
6603  } B;
6605
6606  typedef union { /* INJECTED CONVERSION MASK REGISTER 1 */
6607  uint32_t R;
6608  struct {
6609  uint32_t CH63:1; /* Channel 63 Injected Sampling Enable */
6610  uint32_t CH62:1; /* Channel 62 Injected Sampling Enable */
6611  uint32_t CH61:1; /* Channel 61 Injected Sampling Enable */
6612  uint32_t CH60:1; /* Channel 60 Injected Sampling Enable */
6613  uint32_t CH59:1; /* Channel 59 Injected Sampling Enable */
6614  uint32_t CH58:1; /* Channel 58 Injected Sampling Enable */
6615  uint32_t CH57:1; /* Channel 57 Injected Sampling Enable */
6616  uint32_t CH56:1; /* Channel 56 Injected Sampling Enable */
6617  uint32_t CH55:1; /* Channel 55 Injected Sampling Enable */
6618  uint32_t CH54:1; /* Channel 54 Injected Sampling Enable */
6619  uint32_t CH53:1; /* Channel 53 Injected Sampling Enable */
6620  uint32_t CH52:1; /* Channel 52 Injected Sampling Enable */
6621  uint32_t CH51:1; /* Channel 51 Injected Sampling Enable */
6622  uint32_t CH50:1; /* Channel 50 Injected Sampling Enable */
6623  uint32_t CH49:1; /* Channel 49 Injected Sampling Enable */
6624  uint32_t CH48:1; /* Channel 48 Injected Sampling Enable */
6625  uint32_t CH47:1; /* Channel 47 Injected Sampling Enable */
6626  uint32_t CH46:1; /* Channel 46 Injected Sampling Enable */
6627  uint32_t CH45:1; /* Channel 45 Injected Sampling Enable */
6628  uint32_t CH44:1; /* Channel 44 Injected Sampling Enable */
6629  uint32_t CH43:1; /* Channel 43 Injected Sampling Enable */
6630  uint32_t CH42:1; /* Channel 42 Injected Sampling Enable */
6631  uint32_t CH41:1; /* Channel 41 Injected Sampling Enable */
6632  uint32_t CH40:1; /* Channel 40 Injected Sampling Enable */
6633  uint32_t CH39:1; /* Channel 39 Injected Sampling Enable */
6634  uint32_t CH38:1; /* Channel 38 Injected Sampling Enable */
6635  uint32_t CH37:1; /* Channel 37 Injected Sampling Enable */
6636  uint32_t CH36:1; /* Channel 36 Injected Sampling Enable */
6637  uint32_t CH35:1; /* Channel 35 Injected Sampling Enable */
6638  uint32_t CH34:1; /* Channel 34 Injected Sampling Enable */
6639  uint32_t CH33:1; /* Channel 33 Injected Sampling Enable */
6640  uint32_t CH32:1; /* Channel 32 Injected Sampling Enable */
6641  } B;
6643
6644  typedef union { /* INJECTED CONVERSION MASK REGISTER 2 */
6645  uint32_t R;
6646  struct {
6647  uint32_t CH95:1; /* Channel 95 Injected Sampling Enable */
6648  uint32_t CH94:1; /* Channel 94 Injected Sampling Enable */
6649  uint32_t CH93:1; /* Channel 93 Injected Sampling Enable */
6650  uint32_t CH92:1; /* Channel 92 Injected Sampling Enable */
6651  uint32_t CH91:1; /* Channel 91 Injected Sampling Enable */
6652  uint32_t CH90:1; /* Channel 90 Injected Sampling Enable */
6653  uint32_t CH89:1; /* Channel 89 Injected Sampling Enable */
6654  uint32_t CH88:1; /* Channel 88 Injected Sampling Enable */
6655  uint32_t CH87:1; /* Channel 87 Injected Sampling Enable */
6656  uint32_t CH86:1; /* Channel 86 Injected Sampling Enable */
6657  uint32_t CH85:1; /* Channel 85 Injected Sampling Enable */
6658  uint32_t CH84:1; /* Channel 84 Injected Sampling Enable */
6659  uint32_t CH83:1; /* Channel 83 Injected Sampling Enable */
6660  uint32_t CH82:1; /* Channel 82 Injected Sampling Enable */
6661  uint32_t CH81:1; /* Channel 81 Injected Sampling Enable */
6662  uint32_t CH80:1; /* Channel 80 Injected Sampling Enable */
6663  uint32_t CH79:1; /* Channel 79 Injected Sampling Enable */
6664  uint32_t CH78:1; /* Channel 78 Injected Sampling Enable */
6665  uint32_t CH77:1; /* Channel 77 Injected Sampling Enable */
6666  uint32_t CH76:1; /* Channel 76 Injected Sampling Enable */
6667  uint32_t CH75:1; /* Channel 75 Injected Sampling Enable */
6668  uint32_t CH74:1; /* Channel 74 Injected Sampling Enable */
6669  uint32_t CH73:1; /* Channel 73 Injected Sampling Enable */
6670  uint32_t CH72:1; /* Channel 72 Injected Sampling Enable */
6671  uint32_t CH71:1; /* Channel 71 Injected Sampling Enable */
6672  uint32_t CH70:1; /* Channel 70 Injected Sampling Enable */
6673  uint32_t CH69:1; /* Channel 69 Injected Sampling Enable */
6674  uint32_t CH68:1; /* Channel 68 Injected Sampling Enable */
6675  uint32_t CH67:1; /* Channel 67 Injected Sampling Enable */
6676  uint32_t CH66:1; /* Channel 66 Injected Sampling Enable */
6677  uint32_t CH65:1; /* Channel 65 Injected Sampling Enable */
6678  uint32_t CH64:1; /* Channel 64 Injected Sampling Enable */
6679  } B;
6681
6682  typedef union { /* Offset Word Regsiter */
6683  uint32_t R;
6684  struct {
6685  uint32_t:15;
6686  uint32_t OFFSETLOAD:1; /* load_offset */
6687  uint32_t:8;
6688 #ifndef USE_FIELD_ALIASES_ADC
6689  uint32_t OFFSET_WORD:8; /* OFFSET word coeff.generated at the end of offset cancellation is lathed int o this register */
6690 #else
6691  uint32_t OFFSETWORD:8;
6692 #endif
6693  } B;
6695
6696  typedef union { /* Decode Signal Delay Register */
6697  uint32_t R;
6698  struct {
6699  uint32_t:24;
6700  uint32_t DSD:8; /* take into account the settling time of the external mux */
6701  } B;
6702  } ADC_DSDR_32B_tag;
6703
6704  typedef union { /* Power Down Dealy Register */
6705  uint32_t R;
6706  struct {
6707  uint32_t:24;
6708  uint32_t PDED:8; /* The delay between the power down bit reset and the starting of conversion */
6709  } B;
6711
6712
6713  /* Register layout for all registers CDR... */
6714
6715  typedef union { /* CHANNEL DATA REGS */
6716  uint32_t R;
6717  struct {
6718  uint32_t:12;
6719  uint32_t VALID:1; /* validity of data */
6720  uint32_t OVERW:1; /* overwrite data */
6721  uint32_t RESULT:2; /* reflects mode conversion */
6722  uint32_t:6;
6723  uint32_t CDATA:10; /* Channel 0 converted data */
6724  } B;
6725  } ADC_CDR_32B_tag;
6726
6727  typedef union { /* Upper Threshold register 4 is not contiguous to 3 */
6728  uint32_t R;
6729  struct {
6730  uint32_t:4;
6731  uint32_t THRH:12; /* high threshold value s */
6732  uint32_t:4;
6733  uint32_t THRL:12; /* low threshold value s */
6734  } B;
6736
6737  typedef union { /* Upper Threshold register 5 */
6738  uint32_t R;
6739  struct {
6740  uint32_t:4;
6741  uint32_t THRH:12; /* high threshold value s */
6742  uint32_t:4;
6743  uint32_t THRL:12; /* low threshold value s */
6744  } B;
6746
6747  typedef union { /* Upper Threshold register 6 */
6748  uint32_t R;
6749  struct {
6750  uint32_t:4;
6751  uint32_t THRH:12; /* high threshold value s */
6752  uint32_t:4;
6753  uint32_t THRL:12; /* low threshold value s */
6754  } B;
6756
6757  typedef union { /* Upper Threshold register 7 */
6758  uint32_t R;
6759  struct {
6760  uint32_t:4;
6761  uint32_t THRH:12; /* high threshold value s */
6762  uint32_t:4;
6763  uint32_t THRL:12; /* low threshold value s */
6764  } B;
6766
6767  typedef union { /* Upper Threshold register 8 */
6768  uint32_t R;
6769  struct {
6770  uint32_t:4;
6771  uint32_t THRH:12; /* high threshold value s */
6772  uint32_t:4;
6773  uint32_t THRL:12; /* low threshold value s */
6774  } B;
6776
6777  typedef union { /* Upper Threshold register 9 */
6778  uint32_t R;
6779  struct {
6780  uint32_t:4;
6781  uint32_t THRH:12; /* high threshold value s */
6782  uint32_t:4;
6783  uint32_t THRL:12; /* low threshold value s */
6784  } B;
6786
6787  typedef union { /* Upper Threshold register 10 */
6788  uint32_t R;
6789  struct {
6790  uint32_t:4;
6791  uint32_t THRH:12; /* high threshold value s */
6792  uint32_t:4;
6793  uint32_t THRL:12; /* low threshold value s */
6794  } B;
6796
6797  typedef union { /* Upper Threshold register 11 */
6798  uint32_t R;
6799  struct {
6800  uint32_t:4;
6801  uint32_t THRH:12; /* high threshold value s */
6802  uint32_t:4;
6803  uint32_t THRL:12; /* low threshold value s */
6804  } B;
6806
6807  typedef union { /* Upper Threshold register 12 */
6808  uint32_t R;
6809  struct {
6810  uint32_t:4;
6811  uint32_t THRH:12; /* high threshold value s */
6812  uint32_t:4;
6813  uint32_t THRL:12; /* low threshold value s */
6814  } B;
6816
6817  typedef union { /* Upper Threshold register 13 */
6818  uint32_t R;
6819  struct {
6820  uint32_t:4;
6821  uint32_t THRH:12; /* high threshold value s */
6822  uint32_t:4;
6823  uint32_t THRL:12; /* low threshold value s */
6824  } B;
6826
6827  typedef union { /* Upper Threshold register 14 */
6828  uint32_t R;
6829  struct {
6830  uint32_t:4;
6831  uint32_t THRH:12; /* high threshold value s */
6832  uint32_t:4;
6833  uint32_t THRL:12; /* low threshold value s */
6834  } B;
6836
6837  typedef union { /* Upper Threshold register 15 */
6838  uint32_t R;
6839  struct {
6840  uint32_t:4;
6841  uint32_t THRH:12; /* high threshold value s */
6842  uint32_t:4;
6843  uint32_t THRL:12; /* low threshold value s */
6844  } B;
6846
6847
6848  /* Register layout for all registers CWSELR... */
6849
6850  typedef union { /* Channel Watchdog Select register */
6851  uint32_t R;
6852  struct {
6853  uint32_t WSEL_CH7:4; /* Channel Watchdog select for channel 7+R*8 */
6854  uint32_t WSEL_CH6:4; /* Channel Watchdog select for channel 6+R*8 */
6855  uint32_t WSEL_CH5:4; /* Channel Watchdog select for channel 5+R*8 */
6856  uint32_t WSEL_CH4:4; /* Channel Watchdog select for channel 4+R*8 */
6857  uint32_t WSEL_CH3:4; /* Channel Watchdog select for channel 3+R*8 */
6858  uint32_t WSEL_CH2:4; /* Channel Watchdog select for channel 2+R*8 */
6859  uint32_t WSEL_CH1:4; /* Channel Watchdog select for channel 1+R*8 */
6860  uint32_t WSEL_CH0:4; /* Channel Watchdog select for channel 0+R*8 */
6861  } B;
6863
6864
6865  /* Register layout for all registers CWENR... */
6866
6867  typedef union { /* Channel Watchdog Enable Register */
6868  uint32_t R;
6869  struct {
6870  uint32_t:16;
6871  uint32_t CWEN15PRT32:1; /* Channel Watchdog Enable 0+R*32 */
6872  uint32_t CWEN14PRT32:1; /* Channel Watchdog Enable 0+R*32 */
6873  uint32_t CWEN13PRT32:1; /* Channel Watchdog Enable 0+R*32 */
6874  uint32_t CWEN12PRT32:1; /* Channel Watchdog Enable 0+R*32 */
6875  uint32_t CWEN11PRT32:1; /* Channel Watchdog Enable 0+R*32 */
6876  uint32_t CWEN10PRT32:1; /* Channel Watchdog Enable 0+R*32 */
6877  uint32_t CWEN09PRT32:1; /* Channel Watchdog Enable 0+R*32 */
6878  uint32_t CWEN08PRT32:1; /* Channel Watchdog Enable 0+R*32 */
6879  uint32_t CWEN07PRT32:1; /* Channel Watchdog Enable 0+R*32 */
6880  uint32_t CWEN06PRT32:1; /* Channel Watchdog Enable 0+R*32 */
6881  uint32_t CWEN05PRT32:1; /* Channel Watchdog Enable 0+R*32 */
6882  uint32_t CWEN04PRT32:1; /* Channel Watchdog Enable 0+R*32 */
6883  uint32_t CWEN03PRT32:1; /* Channel Watchdog Enable 0+R*32 */
6884  uint32_t CWEN02PRT32:1; /* Channel Watchdog Enable 0+R*32 */
6885  uint32_t CWEN01PRT32:1; /* Channel Watchdog Enable 0+R*32 */
6886  uint32_t CWEN00PRT32:1; /* Channel Watchdog Enable 0+R*32 */
6887  } B;
6889
6890
6891  /* Register layout for all registers AWORR... */
6892
6893  typedef union { /* Analog Watchdog Out of Range Register */
6894  uint32_t R;
6895  struct {
6896  uint32_t AWOR_CH31:1; /* Channel 31+R*32 converted data out of range */
6897  uint32_t AWOR_CH30:1; /* Channel 30+R*32 converted data out of range */
6898  uint32_t AWOR_CH29:1; /* Channel 29+R*32 converted data out of range */
6899  uint32_t AWOR_CH28:1; /* Channel 28+R*32 converted data out of range */
6900  uint32_t AWOR_CH27:1; /* Channel 27+R*32 converted data out of range */
6901  uint32_t AWOR_CH26:1; /* Channel 26+R*32 converted data out of range */
6902  uint32_t AWOR_CH25:1; /* Channel 25+R*32 converted data out of range */
6903  uint32_t AWOR_CH24:1; /* Channel 24+R*32 converted data out of range */
6904  uint32_t AWOR_CH23:1; /* Channel 23+R*32 converted data out of range */
6905  uint32_t AWOR_CH22:1; /* Channel 22+R*32 converted data out of range */
6906  uint32_t AWOR_CH21:1; /* Channel 21+R*32 converted data out of range */
6907  uint32_t AWOR_CH20:1; /* Channel 20+R*32 converted data out of range */
6908  uint32_t AWOR_CH19:1; /* Channel 19+R*32 converted data out of range */
6909  uint32_t AWOR_CH18:1; /* Channel 18+R*32 converted data out of range */
6910  uint32_t AWOR_CH17:1; /* Channel 17+R*32 converted data out of range */
6911  uint32_t AWOR_CH16:1; /* Channel 16+R*32 converted data out of range */
6912  uint32_t AWOR_CH15:1; /* Channel 15+R*32 converted data out of range */
6913  uint32_t AWOR_CH14:1; /* Channel 14+R*32 converted data out of range */
6914  uint32_t AWOR_CH13:1; /* Channel 13+R*32 converted data out of range */
6915  uint32_t AWOR_CH12:1; /* Channel 12+R*32 converted data out of range */
6916  uint32_t AWOR_CH11:1; /* Channel 11+R*32 converted data out of range */
6917  uint32_t AWOR_CH10:1; /* Channel 10+R*32 converted data out of range */
6918  uint32_t AWOR_CH9:1; /* Channel 9+R*32 converted data out of range */
6919  uint32_t AWOR_CH8:1; /* Channel 8+R*32 converted data out of range */
6920  uint32_t AWOR_CH7:1; /* Channel 7+R*32 converted data out of range */
6921  uint32_t AWOR_CH6:1; /* Channel 6+R*32 converted data out of range */
6922  uint32_t AWOR_CH5:1; /* Channel 5+R*32 converted data out of range */
6923  uint32_t AWOR_CH4:1; /* Channel 4+R*32 converted data out of range */
6924  uint32_t AWOR_CH3:1; /* Channel 3+R*32 converted data out of range */
6925  uint32_t AWOR_CH2:1; /* Channel 2+R*32 converted data out of range */
6926  uint32_t AWOR_CH1:1; /* Channel 1+R*32 converted data out of range */
6927  uint32_t AWOR_CH0:1; /* Channel 0+R*32 converted data out of range */
6928  } B;
6930
6931  typedef union { /* SELF TEST CONFIGURATION REGISTER 1 */
6932  uint32_t R;
6933  struct {
6934  uint32_t INPSAMP_C:8; /* Sampling phase duration for the test conversions - algorithm C */
6935  uint32_t INPSAMP_RC:8; /* Sampling phase duration for the test conversions - algorithm RC */
6936  uint32_t INPSAMP_S:8; /* Sampling phase duration for the test conversions - algorithm S */
6937  uint32_t:5;
6938  uint32_t ST_INPCMP:2; /* Configuration bit for comparison phase duration for self test channel */
6939  uint32_t ST_INPLATCH:1; /* Configuration bit for Latching phase duration for self test channel */
6940  } B;
6942
6943  typedef union { /* SELF TEST CONFIGURATION REGISTER 2 */
6944  uint32_t R;
6945  struct {
6946  uint32_t:5;
6947  uint32_t SERR:1; /* Error fault injection bit (write only) */
6948  uint32_t MSKSTWDTERR:1; /* Interrupt enable (STSR2.WDTERR status bit) */
6949  uint32_t:1;
6950  uint32_t MSKST_EOC:1; /* Interrupt enable bit for STSR2.ST_EOC */
6951  uint32_t:4;
6952  uint32_t MSKWDG_EOA_C:1; /* Interrupt enable (WDG_EOA_C status bit) */
6953  uint32_t MSKWDG_EOA_RC:1; /* Interrupt enable (WDG_EOA_RC status bit) */
6954  uint32_t MSKWDG_EOA_S:1; /* Interrupt enable (WDG_EOA_S status bit) */
6955  uint32_t MSKERR_C:1; /* Interrupt enable (ERR_C status bit) */
6956  uint32_t MSKERR_RC:1; /* Interrupt enable (ERR_RC status bit) */
6957  uint32_t MSKERR_S2:1; /* Interrupt enable (ERR_S2 status bit) */
6958  uint32_t MSKERR_S1:1; /* Interrupt enable (ERR_S1 status bit) */
6959  uint32_t MSKERR_S0:1; /* Interrupt enable (ERR_S0 status bit) */
6960  uint32_t:3;
6961  uint32_t EN:1; /* Self testing channel enable */
6962  uint32_t:4;
6963  uint32_t FMA_C:1; /* Fault mapping for the algorithm C */
6964  uint32_t FMAR_C:1; /* Fault mapping for the algorithm RC */
6965  uint32_t FMA_S:1; /* Fault mapping for the algorithm BGAP */
6966  } B;
6968
6969  typedef union { /* SELF TEST CONFIGURATION REGISTER 3 */
6970  uint32_t R;
6971  struct {
6972  uint32_t:22;
6973  uint32_t ALG:2; /* Algorithm scheduling */
6974  uint32_t:8;
6975  } B;
6977
6978  typedef union { /* SELF TEST BAUD RATE REGISTER */
6979  uint32_t R;
6980  struct {
6981  uint32_t:13;
6982  uint32_t WDT:3; /* Watchdog timer value */
6983  uint32_t:8;
6984  uint32_t BR:8; /* Baud rate for the selected algorithm in SCAN mode */
6985  } B;
6987
6988  typedef union { /* SELF TEST STATUS REGISTER 1 */
6989  uint32_t R;
6990  struct {
6991  uint32_t:6;
6992  uint32_t WDTERR:1; /* Watchdog timer error */
6993  uint32_t OVERWR:1; /* Overwrite error */
6994  uint32_t ST_EOC:1; /* Self test EOC bit */
6995  uint32_t:4;
6996  uint32_t WDG_EOA_C:1; /* Algorithm C completed without error */
6997  uint32_t WDG_EOA_RC:1; /* Algorithm RC completed without error */
6998  uint32_t WDG_EOA_S:1; /* Algorithm S completed without error */
6999  uint32_t ERR_C:1; /* Error on the self testing channel (algorithm C) */
7000  uint32_t ERR_RC:1; /* Error on the self testing channel (algorithm RC) */
7001  uint32_t ERR_S2:1; /* Error on the self testing channel (algorithm SUPPLY, step 2) */
7002  uint32_t ERR_S1:1; /* Error on the self testing channel (algorithm SUPPLY, step 1) */
7003  uint32_t ERR_S0:1; /* Error on the self testing channel (algorithm SUPPLY, step 0) */
7004  uint32_t:1;
7005  uint32_t STEP_C:5; /* Step of algorithm C when ERR_C has occurred */
7006  uint32_t STEP_RC:5; /* Step of algorithm RC when ERR_RC has occurred */
7007  } B;
7009
7010  typedef union { /* SELF TEST STATUS REGISTER 2 */
7011  uint32_t R;
7012  struct {
7013  uint32_t OVFL:1; /* Overflow bit */
7014  uint32_t:3;
7015  uint32_t DATA1:12; /* Test channel converted data when ERR_S1 has occurred */
7016  uint32_t:4;
7017  uint32_t DATA0:12; /* Test channel converted data when ERR_S1 has occurred */
7018  } B;
7020
7021  typedef union { /* SELF TEST STATUS REGISTER 3 */
7022  uint32_t R;
7023  struct {
7024  uint32_t:4;
7025  uint32_t DATA1:12; /* Test channel converted data when ERR_S0 has occurred */
7026  uint32_t:4;
7027  uint32_t DATA0:12; /* Test channel converted data when ERR_S0 has occurred */
7028  } B;
7030
7031  typedef union { /* SELF TEST STATUS REGISTER 4 */
7032  uint32_t R;
7033  struct {
7034  uint32_t:4;
7035  uint32_t DATA1:12; /* Test channel converted data when ERR_C has occurred */
7036  uint32_t:4;
7037  uint32_t DATA0:12; /* Test channel converted data when ERR_C has occurred */
7038  } B;
7040
7041  typedef union { /* SELF TEST DATA REGISTER 1 */
7042  uint32_t R;
7043  struct {
7044  uint32_t:12;
7045  uint32_t VALID:1; /* Valid data */
7046  uint32_t OVERWR:1; /* Overwrite data */
7047  uint32_t:6;
7048  uint32_t TCDATA:12; /* Test channel converted data */
7049  } B;
7051
7052  typedef union { /* SELF TEST DATA REGISTER 2 */
7053  uint32_t R;
7054  struct {
7055  uint32_t FDATA:12; /* Fractional part of the ratio TEST for algorithm S */
7056  uint32_t VALID:1; /* Valid data */
7057  uint32_t OVERWR:1; /* Overwrite data */
7058  uint32_t:6;
7059  uint32_t IDATA:12; /* Integer part of the ratio TEST for algorithm S */
7060  } B;
7062
7063  typedef union { /* SELF TEST ANALOG WATCHDOG REGISTER 0 */
7064  uint32_t R;
7065  struct {
7066  uint32_t AWDE:1; /* Analog WatchDog Enable - algorithm S */
7067  uint32_t WDTE:1; /* WatchDog Timer Enable - algorithm S */
7068  uint32_t:2;
7069  uint32_t THRH:12; /* High threshold value for channel 0 */
7070  uint32_t:4;
7071  uint32_t THRL:12; /* Low threshold value for channel 0 */
7072  } B;
7074
7075  typedef union { /* SELF TEST ANALOG WATCHDOG REGISTER 1A */
7076  uint32_t R;
7077  struct {
7078  uint32_t AWDE:1; /* Analog WatchDog Enable - algorithm S */
7079  uint32_t:3;
7080  uint32_t THRH:12; /* High threshold value for test channel - algorithm S */
7081  uint32_t:4;
7082  uint32_t THRL:12; /* Low threshold value for test channel - algorithm S */
7083  } B;
7085
7086  typedef union { /* SELF TEST ANALOG WATCHDOG REGISTER 1B */
7087  uint32_t R;
7088  struct {
7089  uint32_t:4;
7090  uint32_t THRH:12; /* High threshold value for test channel - algorithm S */
7091  uint32_t:4;
7092  uint32_t THRL:12; /* Low threshold value for test channel - algorithm S */
7093  } B;
7095
7096  typedef union { /* SELF TEST ANALOG WATCHDOG REGISTER 2 */
7097  uint32_t R;
7098  struct {
7099  uint32_t AWDE:1; /* Analog WatchDog Enable - algorithm S */
7100  uint32_t:19;
7101  uint32_t THRL:12; /* Low threshold value for channel */
7102  } B;
7104
7105  typedef union { /* SELF TEST ANALOG WATCHDOG REGISTER 3 */
7106  uint32_t R;
7107  struct {
7108  uint32_t AWDE:1; /* Analog WatchDog Enable - algorithm RC */
7109  uint32_t WDTE:1; /* WatchDog Timer Enable - algorithm RC */
7110  uint32_t:2;
7111  uint32_t THRH:12; /* High threshold value for channel 3 */
7112  uint32_t:4;
7113  uint32_t THRL:12; /* Low threshold value for channel 3 */
7114  } B;
7116
7117  typedef union { /* SELF TEST ANALOG WATCHDOG REGISTER 4 */
7118  uint32_t R;
7119  struct {
7120  uint32_t AWDE:1; /* Analog WatchDog Enable - algorithm C */
7121  uint32_t WDTE:1; /* WatchDog Timer Enable - algorithm C */
7122  uint32_t:2;
7123  uint32_t THRH:12; /* High threshold value for channel 4 */
7124  uint32_t:4;
7125  uint32_t THRL:12; /* Low threshold value for channel 4 */
7126  } B;
7128
7129  typedef union { /* SELF TEST ANALOG WATCHDOG REGISTER 5 */
7130  uint32_t R;
7131  struct {
7132  uint32_t:4;
7133  uint32_t THRH:12; /* High threshold value for algorithm C */
7134  uint32_t:4;
7135  uint32_t THRL:12; /* Low threshold value for algorithm C */
7136  } B;
7138
7139
7140
7141  typedef struct ADC_struct_tag { /* start of ADC_tag */
7142  /* module configuration register */
7143  ADC_MCR_32B_tag MCR; /* offset: 0x0000 size: 32 bit */
7144  /* module status register */
7145  ADC_MSR_32B_tag MSR; /* offset: 0x0004 size: 32 bit */
7146  int8_t ADC_reserved_0008[8];
7147  /* Interrupt status register */
7148  ADC_ISR_32B_tag ISR; /* offset: 0x0010 size: 32 bit */
7149  union {
7150  ADC_CEOCFR0_32B_tag CEOCFR[3]; /* offset: 0x0014 (0x0004 x 3) */
7151
7152  struct {
7153  /* CHANNEL PENDING REGISTER 0 */
7154  ADC_CEOCFR0_32B_tag CEOCFR0; /* offset: 0x0014 size: 32 bit */
7155  /* CHANNEL PENDING REGISTER 1 */
7156  ADC_CEOCFR1_32B_tag CEOCFR1; /* offset: 0x0018 size: 32 bit */
7157  /* CHANNEL PENDING REGISTER 2 */
7158  ADC_CEOCFR2_32B_tag CEOCFR2; /* offset: 0x001C size: 32 bit */
7159  };
7160
7161  };
7162  /* interrupt mask register */
7163  ADC_IMR_32B_tag IMR; /* offset: 0x0020 size: 32 bit */
7164  union {
7165  ADC_CIMR0_32B_tag CIMR[3]; /* offset: 0x0024 (0x0004 x 3) */
7166
7167  struct {
7168  /* CHANNEL INTERRUPT MASK REGISTER 0 */
7169  ADC_CIMR0_32B_tag CIMR0; /* offset: 0x0024 size: 32 bit */
7170  /* CHANNEL INTERRUPT MASK REGISTER 1 */
7171  ADC_CIMR1_32B_tag CIMR1; /* offset: 0x0028 size: 32 bit */
7172  /* CHANNEL INTERRUPT MASK REGISTER 2 */
7173  ADC_CIMR2_32B_tag CIMR2; /* offset: 0x002C size: 32 bit */
7174  };
7175
7176  };
7177  /* Watchdog Threshold interrupt status register */
7178  ADC_WTISR_32B_tag WTISR; /* offset: 0x0030 size: 32 bit */
7179  /* Watchdog interrupt MASK register */
7180  ADC_WTIMR_32B_tag WTIMR; /* offset: 0x0034 size: 32 bit */
7181  int8_t ADC_reserved_0038[8];
7182  /* DMAE register */
7183  ADC_DMAE_32B_tag DMAE; /* offset: 0x0040 size: 32 bit */
7184  union {
7185  ADC_DMAR0_32B_tag DMAR[3]; /* offset: 0x0044 (0x0004 x 3) */
7186
7187  struct {
7188  /* DMA REGISTER 0 */
7189  ADC_DMAR0_32B_tag DMAR0; /* offset: 0x0044 size: 32 bit */
7190  /* DMA REGISTER 1 */
7191  ADC_DMAR1_32B_tag DMAR1; /* offset: 0x0048 size: 32 bit */
7192  /* DMA REGISTER 2 */
7193  ADC_DMAR2_32B_tag DMAR2; /* offset: 0x004C size: 32 bit */
7194  };
7195
7196  };
7197  union {
7198  /* Threshold Control register C */
7199  ADC_TRC_32B_tag TRC[4]; /* offset: 0x0050 (0x0004 x 4) */
7200
7201  struct {
7202  /* Threshold Control register C */
7203  ADC_TRC_32B_tag TRC0; /* offset: 0x0050 size: 32 bit */
7204  ADC_TRC_32B_tag TRC1; /* offset: 0x0054 size: 32 bit */
7205  ADC_TRC_32B_tag TRC2; /* offset: 0x0058 size: 32 bit */
7206  ADC_TRC_32B_tag TRC3; /* offset: 0x005C size: 32 bit */
7207  };
7208
7209  };
7210  union {
7211  /* Upper Threshold register */
7212  ADC_THRHLR_32B_tag THRHLR[4]; /* offset: 0x0060 (0x0004 x 4) */
7213
7214  struct {
7215  /* Upper Threshold register */
7216  ADC_THRHLR_32B_tag THRHLR0; /* offset: 0x0060 size: 32 bit */
7217  ADC_THRHLR_32B_tag THRHLR1; /* offset: 0x0064 size: 32 bit */
7218  ADC_THRHLR_32B_tag THRHLR2; /* offset: 0x0068 size: 32 bit */
7219  ADC_THRHLR_32B_tag THRHLR3; /* offset: 0x006C size: 32 bit */
7220  };
7221
7222  };
7223  union {
7224  /* alternate Upper Threshold register */
7225  ADC_THRALT_32B_tag THRALT[4]; /* offset: 0x0070 (0x0004 x 4) */
7226
7227  struct {
7228  /* alternate Upper Threshold register */
7229  ADC_THRALT_32B_tag THRALT0; /* offset: 0x0070 size: 32 bit */
7230  ADC_THRALT_32B_tag THRALT1; /* offset: 0x0074 size: 32 bit */
7231  ADC_THRALT_32B_tag THRALT2; /* offset: 0x0078 size: 32 bit */
7232  ADC_THRALT_32B_tag THRALT3; /* offset: 0x007C size: 32 bit */
7233  };
7234
7235  };
7236  /* PRESAMPLING CONTROL REGISTER */
7237  ADC_PSCR_32B_tag PSCR; /* offset: 0x0080 size: 32 bit */
7238  union {
7239  ADC_PSR0_32B_tag PSR[3]; /* offset: 0x0084 (0x0004 x 3) */
7240
7241  struct {
7242  /* Presampling Register 0 */
7243  ADC_PSR0_32B_tag PSR0; /* offset: 0x0084 size: 32 bit */
7244  /* Presampling REGISTER 1 */
7245  ADC_PSR1_32B_tag PSR1; /* offset: 0x0088 size: 32 bit */
7246  /* Presampling REGISTER 2 */
7247  ADC_PSR2_32B_tag PSR2; /* offset: 0x008C size: 32 bit */
7248  };
7249
7250  };
7251  int8_t ADC_reserved_0090_C[4];
7252  union {
7253  /* conversion timing register */
7254  ADC_CTR_32B_tag CTR[3]; /* offset: 0x0094 (0x0004 x 3) */
7255
7256  struct {
7257  /* conversion timing register */
7258  ADC_CTR_32B_tag CTR0; /* offset: 0x0094 size: 32 bit */
7259  ADC_CTR_32B_tag CTR1; /* offset: 0x0098 size: 32 bit */
7260  ADC_CTR_32B_tag CTR2; /* offset: 0x009C size: 32 bit */
7261  };
7262
7263  };
7264  int8_t ADC_reserved_00A0_C[4];
7265  union {
7266  ADC_NCMR0_32B_tag NCMR[3]; /* offset: 0x00A4 (0x0004 x 3) */
7267
7268  struct {
7269  /* NORMAL CONVERSION MASK REGISTER 0 */
7270  ADC_NCMR0_32B_tag NCMR0; /* offset: 0x00A4 size: 32 bit */
7271  /* NORMAL CONVERSION MASK REGISTER 1 */
7272  ADC_NCMR1_32B_tag NCMR1; /* offset: 0x00A8 size: 32 bit */
7273  /* NORMAL CONVERSION MASK REGISTER 2 */
7274  ADC_NCMR2_32B_tag NCMR2; /* offset: 0x00AC size: 32 bit */
7275  };
7276
7277  };
7278  int8_t ADC_reserved_00B0_C[4];
7279  union {
7280  ADC_JCMR0_32B_tag JCMR[3]; /* offset: 0x00B4 (0x0004 x 3) */
7281
7282  struct {
7283  /* Injected Conversion Mask Register 0 */
7284  ADC_JCMR0_32B_tag JCMR0; /* offset: 0x00B4 size: 32 bit */
7285  /* INJECTED CONVERSION MASK REGISTER 1 */
7286  ADC_JCMR1_32B_tag JCMR1; /* offset: 0x00B8 size: 32 bit */
7287  /* INJECTED CONVERSION MASK REGISTER 2 */
7288  ADC_JCMR2_32B_tag JCMR2; /* offset: 0x00BC size: 32 bit */
7289  };
7290
7291  };
7292  /* Offset Word Regsiter */
7293  ADC_OFFWR_32B_tag OFFWR; /* offset: 0x00C0 size: 32 bit */
7294  /* Decode Signal Delay Register */
7295  ADC_DSDR_32B_tag DSDR; /* offset: 0x00C4 size: 32 bit */
7296  /* Power Down Dealy Register */
7297  ADC_PDEDR_32B_tag PDEDR; /* offset: 0x00C8 size: 32 bit */
7298  int8_t ADC_reserved_00CC_C[52];
7299  union {
7300  /* CHANNEL DATA REGS */
7301  ADC_CDR_32B_tag CDR[96]; /* offset: 0x0100 (0x0004 x 96) */
7302
7303  struct {
7304  /* CHANNEL DATA REGS */
7305  ADC_CDR_32B_tag CDR0; /* offset: 0x0100 size: 32 bit */
7306  ADC_CDR_32B_tag CDR1; /* offset: 0x0104 size: 32 bit */
7307  ADC_CDR_32B_tag CDR2; /* offset: 0x0108 size: 32 bit */
7308  ADC_CDR_32B_tag CDR3; /* offset: 0x010C size: 32 bit */
7309  ADC_CDR_32B_tag CDR4; /* offset: 0x0110 size: 32 bit */
7310  ADC_CDR_32B_tag CDR5; /* offset: 0x0114 size: 32 bit */
7311  ADC_CDR_32B_tag CDR6; /* offset: 0x0118 size: 32 bit */
7312  ADC_CDR_32B_tag CDR7; /* offset: 0x011C size: 32 bit */
7313  ADC_CDR_32B_tag CDR8; /* offset: 0x0120 size: 32 bit */
7314  ADC_CDR_32B_tag CDR9; /* offset: 0x0124 size: 32 bit */
7315  ADC_CDR_32B_tag CDR10; /* offset: 0x0128 size: 32 bit */
7316  ADC_CDR_32B_tag CDR11; /* offset: 0x012C size: 32 bit */
7317  ADC_CDR_32B_tag CDR12; /* offset: 0x0130 size: 32 bit */
7318  ADC_CDR_32B_tag CDR13; /* offset: 0x0134 size: 32 bit */
7319  ADC_CDR_32B_tag CDR14; /* offset: 0x0138 size: 32 bit */
7320  ADC_CDR_32B_tag CDR15; /* offset: 0x013C size: 32 bit */
7321  ADC_CDR_32B_tag CDR16; /* offset: 0x0140 size: 32 bit */
7322  ADC_CDR_32B_tag CDR17; /* offset: 0x0144 size: 32 bit */
7323  ADC_CDR_32B_tag CDR18; /* offset: 0x0148 size: 32 bit */
7324  ADC_CDR_32B_tag CDR19; /* offset: 0x014C size: 32 bit */
7325  ADC_CDR_32B_tag CDR20; /* offset: 0x0150 size: 32 bit */
7326  ADC_CDR_32B_tag CDR21; /* offset: 0x0154 size: 32 bit */
7327  ADC_CDR_32B_tag CDR22; /* offset: 0x0158 size: 32 bit */
7328  ADC_CDR_32B_tag CDR23; /* offset: 0x015C size: 32 bit */
7329  ADC_CDR_32B_tag CDR24; /* offset: 0x0160 size: 32 bit */
7330  ADC_CDR_32B_tag CDR25; /* offset: 0x0164 size: 32 bit */
7331  ADC_CDR_32B_tag CDR26; /* offset: 0x0168 size: 32 bit */
7332  ADC_CDR_32B_tag CDR27; /* offset: 0x016C size: 32 bit */
7333  ADC_CDR_32B_tag CDR28; /* offset: 0x0170 size: 32 bit */
7334  ADC_CDR_32B_tag CDR29; /* offset: 0x0174 size: 32 bit */
7335  ADC_CDR_32B_tag CDR30; /* offset: 0x0178 size: 32 bit */
7336  ADC_CDR_32B_tag CDR31; /* offset: 0x017C size: 32 bit */
7337  ADC_CDR_32B_tag CDR32; /* offset: 0x0180 size: 32 bit */
7338  ADC_CDR_32B_tag CDR33; /* offset: 0x0184 size: 32 bit */
7339  ADC_CDR_32B_tag CDR34; /* offset: 0x0188 size: 32 bit */
7340  ADC_CDR_32B_tag CDR35; /* offset: 0x018C size: 32 bit */
7341  ADC_CDR_32B_tag CDR36; /* offset: 0x0190 size: 32 bit */
7342  ADC_CDR_32B_tag CDR37; /* offset: 0x0194 size: 32 bit */
7343  ADC_CDR_32B_tag CDR38; /* offset: 0x0198 size: 32 bit */
7344  ADC_CDR_32B_tag CDR39; /* offset: 0x019C size: 32 bit */
7345  ADC_CDR_32B_tag CDR40; /* offset: 0x01A0 size: 32 bit */
7346  ADC_CDR_32B_tag CDR41; /* offset: 0x01A4 size: 32 bit */
7347  ADC_CDR_32B_tag CDR42; /* offset: 0x01A8 size: 32 bit */
7348  ADC_CDR_32B_tag CDR43; /* offset: 0x01AC size: 32 bit */
7349  ADC_CDR_32B_tag CDR44; /* offset: 0x01B0 size: 32 bit */
7350  ADC_CDR_32B_tag CDR45; /* offset: 0x01B4 size: 32 bit */
7351  ADC_CDR_32B_tag CDR46; /* offset: 0x01B8 size: 32 bit */
7352  ADC_CDR_32B_tag CDR47; /* offset: 0x01BC size: 32 bit */
7353  ADC_CDR_32B_tag CDR48; /* offset: 0x01C0 size: 32 bit */
7354  ADC_CDR_32B_tag CDR49; /* offset: 0x01C4 size: 32 bit */
7355  ADC_CDR_32B_tag CDR50; /* offset: 0x01C8 size: 32 bit */
7356  ADC_CDR_32B_tag CDR51; /* offset: 0x01CC size: 32 bit */
7357  ADC_CDR_32B_tag CDR52; /* offset: 0x01D0 size: 32 bit */
7358  ADC_CDR_32B_tag CDR53; /* offset: 0x01D4 size: 32 bit */
7359  ADC_CDR_32B_tag CDR54; /* offset: 0x01D8 size: 32 bit */
7360  ADC_CDR_32B_tag CDR55; /* offset: 0x01DC size: 32 bit */
7361  ADC_CDR_32B_tag CDR56; /* offset: 0x01E0 size: 32 bit */
7362  ADC_CDR_32B_tag CDR57; /* offset: 0x01E4 size: 32 bit */
7363  ADC_CDR_32B_tag CDR58; /* offset: 0x01E8 size: 32 bit */
7364  ADC_CDR_32B_tag CDR59; /* offset: 0x01EC size: 32 bit */
7365  ADC_CDR_32B_tag CDR60; /* offset: 0x01F0 size: 32 bit */
7366  ADC_CDR_32B_tag CDR61; /* offset: 0x01F4 size: 32 bit */
7367  ADC_CDR_32B_tag CDR62; /* offset: 0x01F8 size: 32 bit */
7368  ADC_CDR_32B_tag CDR63; /* offset: 0x01FC size: 32 bit */
7369  ADC_CDR_32B_tag CDR64; /* offset: 0x0200 size: 32 bit */
7370  ADC_CDR_32B_tag CDR65; /* offset: 0x0204 size: 32 bit */
7371  ADC_CDR_32B_tag CDR66; /* offset: 0x0208 size: 32 bit */
7372  ADC_CDR_32B_tag CDR67; /* offset: 0x020C size: 32 bit */
7373  ADC_CDR_32B_tag CDR68; /* offset: 0x0210 size: 32 bit */
7374  ADC_CDR_32B_tag CDR69; /* offset: 0x0214 size: 32 bit */
7375  ADC_CDR_32B_tag CDR70; /* offset: 0x0218 size: 32 bit */
7376  ADC_CDR_32B_tag CDR71; /* offset: 0x021C size: 32 bit */
7377  ADC_CDR_32B_tag CDR72; /* offset: 0x0220 size: 32 bit */
7378  ADC_CDR_32B_tag CDR73; /* offset: 0x0224 size: 32 bit */
7379  ADC_CDR_32B_tag CDR74; /* offset: 0x0228 size: 32 bit */
7380  ADC_CDR_32B_tag CDR75; /* offset: 0x022C size: 32 bit */
7381  ADC_CDR_32B_tag CDR76; /* offset: 0x0230 size: 32 bit */
7382  ADC_CDR_32B_tag CDR77; /* offset: 0x0234 size: 32 bit */
7383  ADC_CDR_32B_tag CDR78; /* offset: 0x0238 size: 32 bit */
7384  ADC_CDR_32B_tag CDR79; /* offset: 0x023C size: 32 bit */
7385  ADC_CDR_32B_tag CDR80; /* offset: 0x0240 size: 32 bit */
7386  ADC_CDR_32B_tag CDR81; /* offset: 0x0244 size: 32 bit */
7387  ADC_CDR_32B_tag CDR82; /* offset: 0x0248 size: 32 bit */
7388  ADC_CDR_32B_tag CDR83; /* offset: 0x024C size: 32 bit */
7389  ADC_CDR_32B_tag CDR84; /* offset: 0x0250 size: 32 bit */
7390  ADC_CDR_32B_tag CDR85; /* offset: 0x0254 size: 32 bit */
7391  ADC_CDR_32B_tag CDR86; /* offset: 0x0258 size: 32 bit */
7392  ADC_CDR_32B_tag CDR87; /* offset: 0x025C size: 32 bit */
7393  ADC_CDR_32B_tag CDR88; /* offset: 0x0260 size: 32 bit */
7394  ADC_CDR_32B_tag CDR89; /* offset: 0x0264 size: 32 bit */
7395  ADC_CDR_32B_tag CDR90; /* offset: 0x0268 size: 32 bit */
7396  ADC_CDR_32B_tag CDR91; /* offset: 0x026C size: 32 bit */
7397  ADC_CDR_32B_tag CDR92; /* offset: 0x0270 size: 32 bit */
7398  ADC_CDR_32B_tag CDR93; /* offset: 0x0274 size: 32 bit */
7399  ADC_CDR_32B_tag CDR94; /* offset: 0x0278 size: 32 bit */
7400  ADC_CDR_32B_tag CDR95; /* offset: 0x027C size: 32 bit */
7401  };
7402
7403  };
7404  /* Upper Threshold register 4 is not contiguous to 3 */
7405  ADC_THRHLR4_32B_tag THRHLR4; /* offset: 0x0280 size: 32 bit */
7406  /* Upper Threshold register 5 */
7407  ADC_THRHLR5_32B_tag THRHLR5; /* offset: 0x0284 size: 32 bit */
7408  /* Upper Threshold register 6 */
7409  ADC_THRHLR6_32B_tag THRHLR6; /* offset: 0x0288 size: 32 bit */
7410  /* Upper Threshold register 7 */
7411  ADC_THRHLR7_32B_tag THRHLR7; /* offset: 0x028C size: 32 bit */
7412  /* Upper Threshold register 8 */
7413  ADC_THRHLR8_32B_tag THRHLR8; /* offset: 0x0290 size: 32 bit */
7414  /* Upper Threshold register 9 */
7415  ADC_THRHLR9_32B_tag THRHLR9; /* offset: 0x0294 size: 32 bit */
7416  /* Upper Threshold register 10 */
7417  ADC_THRHLR10_32B_tag THRHLR10; /* offset: 0x0298 size: 32 bit */
7418  /* Upper Threshold register 11 */
7419  ADC_THRHLR11_32B_tag THRHLR11; /* offset: 0x029C size: 32 bit */
7420  /* Upper Threshold register 12 */
7421  ADC_THRHLR12_32B_tag THRHLR12; /* offset: 0x02A0 size: 32 bit */
7422  /* Upper Threshold register 13 */
7423  ADC_THRHLR13_32B_tag THRHLR13; /* offset: 0x02A4 size: 32 bit */
7424  /* Upper Threshold register 14 */
7425  ADC_THRHLR14_32B_tag THRHLR14; /* offset: 0x02A8 size: 32 bit */
7426  /* Upper Threshold register 15 */
7427  ADC_THRHLR15_32B_tag THRHLR15; /* offset: 0x02AC size: 32 bit */
7428  union {
7429  /* Channel Watchdog Select register */
7430  ADC_CWSELR_32B_tag CWSELR[12]; /* offset: 0x02B0 (0x0004 x 12) */
7431
7432  struct {
7433  /* Channel Watchdog Select register */
7434  ADC_CWSELR_32B_tag CWSELR0; /* offset: 0x02B0 size: 32 bit */
7435  ADC_CWSELR_32B_tag CWSELR1; /* offset: 0x02B4 size: 32 bit */
7436  ADC_CWSELR_32B_tag CWSELR2; /* offset: 0x02B8 size: 32 bit */
7437  ADC_CWSELR_32B_tag CWSELR3; /* offset: 0x02BC size: 32 bit */
7438  ADC_CWSELR_32B_tag CWSELR4; /* offset: 0x02C0 size: 32 bit */
7439  ADC_CWSELR_32B_tag CWSELR5; /* offset: 0x02C4 size: 32 bit */
7440  ADC_CWSELR_32B_tag CWSELR6; /* offset: 0x02C8 size: 32 bit */
7441  ADC_CWSELR_32B_tag CWSELR7; /* offset: 0x02CC size: 32 bit */
7442  ADC_CWSELR_32B_tag CWSELR8; /* offset: 0x02D0 size: 32 bit */
7443  ADC_CWSELR_32B_tag CWSELR9; /* offset: 0x02D4 size: 32 bit */
7444  ADC_CWSELR_32B_tag CWSELR10; /* offset: 0x02D8 size: 32 bit */
7445  ADC_CWSELR_32B_tag CWSELR11; /* offset: 0x02DC size: 32 bit */
7446  };
7447
7448  };
7449  union {
7450  /* Channel Watchdog Enable Register */
7451  ADC_CWENR_32B_tag CWENR[3]; /* offset: 0x02E0 (0x0004 x 3) */
7452
7453  struct {
7454  /* Channel Watchdog Enable Register */
7455  ADC_CWENR_32B_tag CWENR0; /* offset: 0x02E0 size: 32 bit */
7456  ADC_CWENR_32B_tag CWENR1; /* offset: 0x02E4 size: 32 bit */
7457  ADC_CWENR_32B_tag CWENR2; /* offset: 0x02E8 size: 32 bit */
7458  };
7459
7460  };
7461  int8_t ADC_reserved_02EC_C[4];
7462  union {
7463  /* Analog Watchdog Out of Range Register */
7464  ADC_AWORR_32B_tag AWORR[3]; /* offset: 0x02F0 (0x0004 x 3) */
7465
7466  struct {
7467  /* Analog Watchdog Out of Range Register */
7468  ADC_AWORR_32B_tag AWORR0; /* offset: 0x02F0 size: 32 bit */
7469  ADC_AWORR_32B_tag AWORR1; /* offset: 0x02F4 size: 32 bit */
7470  ADC_AWORR_32B_tag AWORR2; /* offset: 0x02F8 size: 32 bit */
7471  };
7472
7473  };
7474  int8_t ADC_reserved_02FC[68];
7475  /* SELF TEST CONFIGURATION REGISTER 1 */
7476  ADC_STCR1_32B_tag STCR1; /* offset: 0x0340 size: 32 bit */
7477  /* SELF TEST CONFIGURATION REGISTER 2 */
7478  ADC_STCR2_32B_tag STCR2; /* offset: 0x0344 size: 32 bit */
7479  /* SELF TEST CONFIGURATION REGISTER 3 */
7480  ADC_STCR3_32B_tag STCR3; /* offset: 0x0348 size: 32 bit */
7481  /* SELF TEST BAUD RATE REGISTER */
7482  ADC_STBRR_32B_tag STBRR; /* offset: 0x034C size: 32 bit */
7483  /* SELF TEST STATUS REGISTER 1 */
7484  ADC_STSR1_32B_tag STSR1; /* offset: 0x0350 size: 32 bit */
7485  /* SELF TEST STATUS REGISTER 2 */
7486  ADC_STSR2_32B_tag STSR2; /* offset: 0x0354 size: 32 bit */
7487  /* SELF TEST STATUS REGISTER 3 */
7488  ADC_STSR3_32B_tag STSR3; /* offset: 0x0358 size: 32 bit */
7489  /* SELF TEST STATUS REGISTER 4 */
7490  ADC_STSR4_32B_tag STSR4; /* offset: 0x035C size: 32 bit */
7491  int8_t ADC_reserved_0360[16];
7492  /* SELF TEST DATA REGISTER 1 */
7493  ADC_STDR1_32B_tag STDR1; /* offset: 0x0370 size: 32 bit */
7494  /* SELF TEST DATA REGISTER 2 */
7495  ADC_STDR2_32B_tag STDR2; /* offset: 0x0374 size: 32 bit */
7496  int8_t ADC_reserved_0378[8];
7497  /* SELF TEST ANALOG WATCHDOG REGISTER 0 */
7498  ADC_STAW0R_32B_tag STAW0R; /* offset: 0x0380 size: 32 bit */
7499  /* SELF TEST ANALOG WATCHDOG REGISTER 1A */
7500  ADC_STAW1AR_32B_tag STAW1AR; /* offset: 0x0384 size: 32 bit */
7501  /* SELF TEST ANALOG WATCHDOG REGISTER 1B */
7502  ADC_STAW1BR_32B_tag STAW1BR; /* offset: 0x0388 size: 32 bit */
7503  /* SELF TEST ANALOG WATCHDOG REGISTER 2 */
7504  ADC_STAW2R_32B_tag STAW2R; /* offset: 0x038C size: 32 bit */
7505  /* SELF TEST ANALOG WATCHDOG REGISTER 3 */
7506  ADC_STAW3R_32B_tag STAW3R; /* offset: 0x0390 size: 32 bit */
7507  /* SELF TEST ANALOG WATCHDOG REGISTER 4 */
7508  ADC_STAW4R_32B_tag STAW4R; /* offset: 0x0394 size: 32 bit */
7509  /* SELF TEST ANALOG WATCHDOG REGISTER 5 */
7510  ADC_STAW5R_32B_tag STAW5R; /* offset: 0x0398 size: 32 bit */
7511  } ADC_tag;
7512
7513
7514 #define ADC0 (*(volatile ADC_tag *) 0xFFE00000UL)
7515 #define ADC1 (*(volatile ADC_tag *) 0xFFE04000UL)
7516
7517
7518
7519 /****************************************************************/
7520 /* */
7521 /* Module: CTU */
7522 /* */
7523 /****************************************************************/
7524
7525  typedef union { /* Trigger Generator Subunit Input Selection register */
7526  uint32_t R;
7527  struct {
7528  uint32_t I15_FE:1; /* ext_signal Falling Edge */
7529  uint32_t I15_RE:1; /* ext_signal Rising Edge */
7530  uint32_t I14_FE:1; /* eTimer2 Falling Edge Enable */
7531  uint32_t I14_RE:1; /* eTimer2 Rising Edge Enable */
7532  uint32_t I13_FE:1; /* eTimer1 Falling Edge Enable */
7533  uint32_t I13_RE:1; /* eTimer1 Rising Edge Enable */
7534  uint32_t I12_FE:1; /* RPWM ch3 Falling Edge Enable */
7535  uint32_t I12_RE:1; /* RPWM ch3 Rising Edge Enable */
7536  uint32_t I11_FE:1; /* RPWM ch2 Falling Edge Enable */
7537  uint32_t I11_RE:1; /* RPWM ch2 Rising Edge Enable */
7538  uint32_t I10_FE:1; /* RPWM ch1 Falling Edge Enable */
7539  uint32_t I10_RE:1; /* RPWM ch1 Rising Edge Enable */
7540  uint32_t I9_FE:1; /* RPWM ch0 Falling Edge Enable */
7541  uint32_t I9_RE:1; /* RPWM ch0 Rising Edge Enable */
7542  uint32_t I8_FE:1; /* PWM ch3 even trig Falling edge Enable */
7543  uint32_t I8_RE:1; /* PWM ch3 even trig Rising edge Enable */
7544  uint32_t I7_FE:1; /* PWM ch2 even trig Falling edge Enable */
7545  uint32_t I7_RE:1; /* PWM ch2 even trig Rising edge Enable */
7546  uint32_t I6_FE:1; /* PWM ch1 even trig Falling edge Enable */
7547  uint32_t I6_RE:1; /* PWM ch1 even trig Rising edge Enable */
7548  uint32_t I5_FE:1; /* PWM ch0 even trig Falling edge Enable */
7549  uint32_t I5_RE:1; /* PWM ch0 even trig Rising edge Enable */
7550  uint32_t I4_FE:1; /* PWM ch3 odd trig Falling edge Enable */
7551  uint32_t I4_RE:1; /* PWM ch3 odd trig Rising edge Enable */
7552  uint32_t I3_FE:1; /* PWM ch2 odd trig Falling edge Enable */
7553  uint32_t I3_RE:1; /* PWM ch2 odd trig Rising edge Enable */
7554  uint32_t I2_FE:1; /* PWM ch1 odd trig Falling edge Enable */
7555  uint32_t I2_RE:1; /* PWM ch1 odd trig Rising edge Enable */
7556  uint32_t I1_FE:1; /* PWM ch0 odd trig Falling edge Enable */
7557  uint32_t I1_RE:1; /* PWM ch0 odd trig Rising edge Enable */
7558  uint32_t I0_FE:1; /* PWM Reload Falling Edge Enable */
7559  uint32_t I0_RE:1; /* PWM Reload Rising Edge Enable */
7560  } B;
7562
7563  typedef union { /* Trigger Generator Subunit Control Register */
7564  uint16_t R;
7565  struct {
7566  uint16_t:7;
7567 #ifndef USE_FIELD_ALIASES_CTU
7568  uint16_t ET_TM:1; /* Toggle Mode Enable */
7569 #else
7570  uint16_t ETTM:1; /* deprecated name - please avoid */
7571 #endif
7572  uint16_t PRES:2; /* TGS Prescaler Selection */
7573 #ifndef USE_FIELD_ALIASES_CTU
7574  uint16_t MRS_SM:5; /* MRS Selection in Sequential Mode */
7575 #else
7576  uint16_t MRSSM:5; /* deprecated name - please avoid */
7577 #endif
7578 #ifndef USE_FIELD_ALIASES_CTU
7579  uint16_t TGS_M:1; /* Trigger Generator Subunit Mode */
7580 #else
7581  uint16_t TGSM:1; /* deprecated name - please avoid */
7582 #endif
7583  } B;
7585
7586  typedef union { /* */
7587  uint16_t R;
7588  } CTU_TCR_16B_tag;
7589
7590  typedef union { /* TGS Counter Compare Register */
7591  uint16_t R;
7592 #ifndef USE_FIELD_ALIASES_CTU
7593  struct {
7594  uint16_t TGSCCV:16; /* deprecated field -- do not use */
7595  } B;
7596 #endif
7598
7599  typedef union { /* TGS Counter Reload Register */
7600  uint16_t R;
7601 #ifndef USE_FIELD_ALIASES_CTU
7602  struct {
7603  uint16_t TGSCRV:16; /* deprecated field -- do not use */
7604  } B;
7605 #endif
7607
7608  typedef union { /* Commands List Control Register 1 */
7609  uint32_t R;
7610  struct {
7611  uint32_t:3;
7612  uint32_t T3INDEX:5; /* Trigger 3 First Command address */
7613  uint32_t:3;
7614  uint32_t T2INDEX:5; /* Trigger 2 First Command address */
7615  uint32_t:3;
7616  uint32_t T1INDEX:5; /* Trigger 1 First Command address */
7617  uint32_t:3;
7618  uint32_t T0INDEX:5; /* Trigger 0 First Command address */
7619  } B;
7621
7622  typedef union { /* Commands List Control Register 2 */
7623  uint32_t R;
7624  struct {
7625  uint32_t:3;
7626  uint32_t T7INDEX:5; /* Trigger 7 First Command address */
7627  uint32_t:3;
7628  uint32_t T6INDEX:5; /* Trigger 6 First Command address */
7629  uint32_t:3;
7630  uint32_t T5INDEX:5; /* Trigger 5 First Command address */
7631  uint32_t:3;
7632  uint32_t T4INDEX:5; /* Trigger 4 First Command address */
7633  } B;
7635
7636  typedef union { /* Trigger Handler Control Register 1 */
7637  uint32_t R;
7638  struct {
7639  uint32_t:1;
7640  uint32_t T3_E:1; /* Trigger 3 enable */
7641  uint32_t T3_ETE:1; /* Trigger 3 Ext Trigger output enable */
7642  uint32_t T3_T4E:1; /* Trigger 3 Timer4 output enable */
7643  uint32_t T3_T3E:1; /* Trigger 3 Timer3 output enable */
7644  uint32_t T3_T2E:1; /* Trigger 3 Timer2 output enable */
7645  uint32_t T3_T1E:1; /* Trigger 3 Timer1 output enable */
7646  uint32_t T3_ADCE:1; /* Trigger 3 ADC Command output enable */
7647  uint32_t:1;
7648  uint32_t T2_E:1; /* Trigger 2 enable */
7649  uint32_t T2_ETE:1; /* Trigger 2 Ext Trigger output enable */
7650  uint32_t T2_T4E:1; /* Trigger 2 Timer4 output enable */
7651  uint32_t T2_T3E:1; /* Trigger 2 Timer3 output enable */
7652  uint32_t T2_T2E:1; /* Trigger 2 Timer2 output enable */
7653  uint32_t T2_T1E:1; /* Trigger 2 Timer1 output enable */
7654  uint32_t T2_ADCE:1; /* Trigger 2 ADC Command output enable */
7655  uint32_t:1;
7656  uint32_t T1_E:1; /* Trigger 1 enable */
7657  uint32_t T1_ETE:1; /* Trigger 1 Ext Trigger output enable */
7658  uint32_t T1_T4E:1; /* Trigger 1 Timer4 output enable */
7659  uint32_t T1_T3E:1; /* Trigger 1 Timer3 output enable */
7660  uint32_t T1_T2E:1; /* Trigger 1 Timer2 output enable */
7661  uint32_t T1_T1E:1; /* Trigger 1 Timer1 output enable */
7662  uint32_t T1_ADCE:1; /* Trigger 1 ADC Command output enable */
7663  uint32_t:1;
7664  uint32_t T0_E:1; /* Trigger 0 enable */
7665  uint32_t T0_ETE:1; /* Trigger 0 Ext Trigger output enable */
7666  uint32_t T0_T4E:1; /* Trigger 0 Timer4 output enable */
7667  uint32_t T0_T3E:1; /* Trigger 0 Timer3 output enable */
7668  uint32_t T0_T2E:1; /* Trigger 0 Timer2 output enable */
7669  uint32_t T0_T1E:1; /* Trigger 0 Timer1 output enable */
7670  uint32_t T0_ADCE:1; /* Trigger 0 ADC Command output enable */
7671  } B;
7673
7674  typedef union { /* Trigger Handler Control Register 2 */
7675  uint32_t R;
7676  struct {
7677  uint32_t:1;
7678  uint32_t T7_E:1; /* Trigger 7 enable */
7679  uint32_t T7_ETE:1; /* Trigger 7 Ext Trigger output enable */
7680  uint32_t T7_T4E:1; /* Trigger 7 Timer4 output enable */
7681  uint32_t T7_T3E:1; /* Trigger 7 Timer3 output enable */
7682  uint32_t T7_T2E:1; /* Trigger 7 Timer2 output enable */
7683  uint32_t T7_T1E:1; /* Trigger 7 Timer1 output enable */
7684  uint32_t T7_ADCE:1; /* Trigger 7 ADC Command output enable */
7685  uint32_t:1;
7686  uint32_t T6_E:1; /* Trigger 6 enable */
7687  uint32_t T6_ETE:1; /* Trigger 6 Ext Trigger output enable */
7688  uint32_t T6_T4E:1; /* Trigger 6 Timer4 output enable */
7689  uint32_t T6_T3E:1; /* Trigger 6 Timer3 output enable */
7690  uint32_t T6_T2E:1; /* Trigger 6 Timer2 output enable */
7691  uint32_t T6_T1E:1; /* Trigger 6 Timer1 output enable */
7692  uint32_t T6_ADCE:1; /* Trigger 6 ADC Command output enable */
7693  uint32_t:1;
7694  uint32_t T5_E:1; /* Trigger 5 enable */
7695  uint32_t T5_ETE:1; /* Trigger 5 Ext Trigger output enable */
7696  uint32_t T5_T4E:1; /* Trigger 5 Timer4 output enable */
7697  uint32_t T5_T3E:1; /* Trigger 5 Timer3 output enable */
7698  uint32_t T5_T2E:1; /* Trigger 5 Timer2 output enable */
7699  uint32_t T5_T1E:1; /* Trigger 5 Timer1 output enable */
7700  uint32_t T5_ADCE:1; /* Trigger 5 ADC Command output enable */
7701  uint32_t:1;
7702  uint32_t T4_E:1; /* Trigger 4 enable */
7703  uint32_t T4_ETE:1; /* Trigger 4 Ext Trigger output enable */
7704  uint32_t T4_T4E:1; /* Trigger 4 Timer4 output enable */
7705  uint32_t T4_T3E:1; /* Trigger 4 Timer3 output enable */
7706  uint32_t T4_T2E:1; /* Trigger 4 Timer2 output enable */
7707  uint32_t T4_T1E:1; /* Trigger 4 Timer1 output enable */
7708  uint32_t T4_ADCE:1; /* Trigger 4 ADC Command output enable */
7709  } B;
7711
7712
7713  /* Register layout for all registers CLR_DCM... */
7714
7715  typedef union { /* Command List Register. View: (CMS=BIT13=)ST1 = 1, (BIT9=)ST0 = DONT CARE */
7716  uint16_t R;
7717  struct {
7718  uint16_t CIR:1; /* Command Interrupt Request */
7719  uint16_t LC:1; /* Last Command */
7720  uint16_t CMS:1; /* Conversion Mode Selection */
7721  uint16_t FIFO:3; /* FIFO for ADC A/B */
7722  uint16_t:1;
7723  uint16_t CHB:4; /* ADC unit B channel number */
7724  uint16_t:1;
7725  uint16_t CHA:4; /* ADC unit A channel number */
7726  } B;
7728
7729
7730  /* Register layout for all registers CLR_SCM... */
7731
7732  typedef union { /* Command List Register. View: (CMS=BIT13=)ST1 = 0, (BIT9=)ST0 = 0 */
7733  uint16_t R;
7734  struct {
7735  uint16_t CIR:1; /* Command Interrupt Request */
7736  uint16_t LC:1; /* Last Command */
7737  uint16_t CMS:1; /* Conversion Mode Selection */
7738  uint16_t FIFO:3; /* FIFO for ADC A/B */
7739  uint16_t:4;
7740  uint16_t SU:1; /* Selection ADC Unit */
7741  uint16_t:1;
7742  uint16_t CH:4; /* ADC unit channel number */
7743  } B;
7745
7746
7747  /* Register layout for all registers CLR... */
7748
7749
7750  typedef union { /* Control Register */
7751  uint16_t R;
7752  struct {
7753  uint16_t EMPTY_CLR7:1; /* Empty Clear 7 */
7754  uint16_t EMPTY_CLR6:1; /* Empty Clear 6 */
7755  uint16_t EMPTY_CLR5:1; /* Empty Clear 5 */
7756  uint16_t EMPTY_CLR4:1; /* Empty Clear 4 */
7757  uint16_t EMPTY_CLR3:1; /* Empty Clear 3 */
7758  uint16_t EMPTY_CLR2:1; /* Empty Clear 2 */
7759  uint16_t EMPTY_CLR1:1; /* Empty Clear 1 */
7760  uint16_t EMPTY_CLR0:1; /* Empty Clear 0 */
7761 #ifndef USE_FIELD_ALIASES_CTU
7762  uint16_t DMA_EN7:1; /* Enable DMA interface for FIFO 7 */
7763 #else
7764  uint16_t DMAEN7:1; /* Enable DMA interface for FIFO 7 */
7765 #endif
7766 #ifndef USE_FIELD_ALIASES_CTU
7767  uint16_t DMA_EN6:1; /* Enable DMA interface for FIFO 6 */
7768 #else
7769  uint16_t DMAEN6:1; /* Enable DMA interface for FIFO 6 */
7770 #endif
7771 #ifndef USE_FIELD_ALIASES_CTU
7772  uint16_t DMA_EN5:1; /* Enable DMA interface for FIFO 5 */
7773 #else
7774  uint16_t DMAEN5:1; /* Enable DMA interface for FIFO 5 */
7775 #endif
7776 #ifndef USE_FIELD_ALIASES_CTU
7777  uint16_t DMA_EN4:1; /* Enable DMA interface for FIFO 4 */
7778 #else
7779  uint16_t DMAEN4:1; /* Enable DMA interface for FIFO 4 */
7780 #endif
7781 #ifndef USE_FIELD_ALIASES_CTU
7782  uint16_t DMA_EN3:1; /* Enable DMA interface for FIFO 3 */
7783 #else
7784  uint16_t DMAEN3:1; /* Enable DMA interface for FIFO 3 */
7785 #endif
7786 #ifndef USE_FIELD_ALIASES_CTU
7787  uint16_t DMA_EN2:1; /* Enable DMA interface for FIFO 2 */
7788 #else
7789  uint16_t DMAEN2:1; /* Enable DMA interface for FIFO 2 */
7790 #endif
7791 #ifndef USE_FIELD_ALIASES_CTU
7792  uint16_t DMA_EN1:1; /* Enable DMA interface for FIFO 1 */
7793 #else
7794  uint16_t DMAEN1:1; /* Enable DMA interface for FIFO 1 */
7795 #endif
7796 #ifndef USE_FIELD_ALIASES_CTU
7797  uint16_t DMA_EN0:1; /* Enable DMA interface for FIFO 0 */
7798 #else
7799  uint16_t DMAEN0:1; /* Enable DMA interface for FIFO 0 */
7800 #endif
7801  } B;
7802  } CTU_CR_16B_tag;
7803
7804  typedef union { /* Control Register FIFO */
7805  uint32_t R;
7806  struct {
7807  uint32_t FIFO_OVERRUN_EN7:1; /* FIFO 7 OVERRUN Enable Interrupt */
7808  uint32_t FIFO_OVERFLOW_EN7:1; /* FIFO 7 OVERFLOW Enable Interrupt */
7809  uint32_t FIFO_EMPTY_EN7:1; /* FIFO 7 EMPTY Enable Interrupt */
7810  uint32_t FIFO_FULL_EN7:1; /* FIFO 7 FULL Enable Interrupt */
7811  uint32_t FIFO_OVERRUN_EN6:1; /* FIFO 6 OVERRUN Enable Interrupt */
7812  uint32_t FIFO_OVERFLOW_EN6:1; /* FIFO 6 OVERFLOW Enable Interrupt */
7813  uint32_t FIFO_EMPTY_EN6:1; /* FIFO 6 EMPTY Enable Interrupt */
7814  uint32_t FIFO_FULL_EN6:1; /* FIFO 6 FULL Enable Interrupt */
7815  uint32_t FIFO_OVERRUN_EN5:1; /* FIFO 5 OVERRUN Enable Interrupt */
7816  uint32_t FIFO_OVERFLOW_EN5:1; /* FIFO 5 OVERFLOW Enable Interrupt */
7817  uint32_t FIFO_EMPTY_EN5:1; /* FIFO 5 EMPTY Enable Interrupt */
7818  uint32_t FIFO_FULL_EN5:1; /* FIFO 5 FULL Enable Interrupt */
7819  uint32_t FIFO_OVERRUN_EN4:1; /* FIFO 4 OVERRUN Enable Interrupt */
7820  uint32_t FIFO_OVERFLOW_EN4:1; /* FIFO 4 OVERFLOW Enable Interrupt */
7821  uint32_t FIFO_EMPTY_EN4:1; /* FIFO 4 EMPTY Enable Interrupt */
7822  uint32_t FIFO_FULL_EN4:1; /* FIFO 4 FULL Enable Interrupt */
7823  uint32_t FIFO_OVERRUN_EN3:1; /* FIFO 3 OVERRUN Enable Interrupt */
7824  uint32_t FIFO_OVERFLOW_EN3:1; /* FIFO 3 OVERFLOW Enable Interrupt */
7825  uint32_t FIFO_EMPTY_EN3:1; /* FIFO 3 EMPTY Enable Interrupt */
7826  uint32_t FIFO_FULL_EN3:1; /* FIFO 3 FULL Enable Interrupt */
7827  uint32_t FIFO_OVERRUN_EN2:1; /* FIFO 2 OVERRUN Enable Interrupt */
7828  uint32_t FIFO_OVERFLOW_EN2:1; /* FIFO 2 OVERFLOW Enable Interrupt */
7829  uint32_t FIFO_EMPTY_EN2:1; /* FIFO 2 EMPTY Enable Interrupt */
7830  uint32_t FIFO_FULL_EN2:1; /* FIFO 2 FULL Enable Interrupt */
7831  uint32_t FIFO_OVERRUN_EN1:1; /* FIFO 1 OVERRUN Enable Interrupt */
7832  uint32_t FIFO_OVERFLOW_EN1:1; /* FIFO 1 OVERFLOW Enable Interrupt */
7833  uint32_t FIFO_EMPTY_EN1:1; /* FIFO 1 EMPTY Enable Interrupt */
7834  uint32_t FIFO_FULL_EN1:1; /* FIFO 1 FULL Enable Interrupt */
7835  uint32_t FIFO_OVERRUN_EN0:1; /* FIFO 0 OVERRUN Enable Interrupt */
7836  uint32_t FIFO_OVERFLOW_EN0:1; /* FIFO 0 OVERFLOW Enable Interrupt */
7837  uint32_t FIFO_EMPTY_EN0:1; /* FIFO 0 EMPTY Enable Interrupt */
7838  uint32_t FIFO_FULL_EN0:1; /* FIFO 0 FULL Enable Interrupt */
7839  } B;
7840  } CTU_FCR_32B_tag;
7841
7842  typedef union { /* Threshold 1 Register */
7843  uint32_t R;
7844  struct {
7845  uint32_t THRESHOLD3:8; /* Threshlod FIFO 3 */
7846  uint32_t THRESHOLD2:8; /* Threshlod FIFO 2 */
7847  uint32_t THRESHOLD1:8; /* Threshlod FIFO 1 */
7848  uint32_t THRESHOLD0:8; /* Threshlod FIFO 0 */
7849  } B;
7850  } CTU_TH1_32B_tag;
7851
7852  typedef union { /* Threshold 2 Register */
7853  uint32_t R;
7854  struct {
7855  uint32_t THRESHOLD7:8; /* Threshlod FIFO 7 */
7856  uint32_t THRESHOLD6:8; /* Threshlod FIFO 6 */
7857  uint32_t THRESHOLD5:8; /* Threshlod FIFO 5 */
7858  uint32_t THRESHOLD4:8; /* Threshlod FIFO 4 */
7859  } B;
7860  } CTU_TH2_32B_tag;
7861
7862  typedef union { /* Status Register */
7863  uint32_t R;
7864  struct {
7865  uint32_t FIFO_OVERRUN7:1; /* FIFO 7 OVERRUN Flag */
7866  uint32_t FIFO_OVERFLOW7:1; /* FIFO 7 OVERFLOW Flag */
7867  uint32_t FIFO_EMPTY7:1; /* FIFO 7 EMPTY Flag */
7868  uint32_t FIFO_FULL7:1; /* FIFO 7 FULL Flag */
7869  uint32_t FIFO_OVERRUN6:1; /* FIFO 6 OVERRUN Flag */
7870  uint32_t FIFO_OVERFLOW6:1; /* FIFO 6 OVERFLOW Flag */
7871  uint32_t FIFO_EMPTY6:1; /* FIFO 6 EMPTY Flag */
7872  uint32_t FIFO_FULL6:1; /* FIFO 6 FULL Flag */
7873  uint32_t FIFO_OVERRUN5:1; /* FIFO 5 OVERRUN Flag */
7874  uint32_t FIFO_OVERFLOW5:1; /* FIFO 5 OVERFLOW Flag */
7875  uint32_t FIFO_EMPTY5:1; /* FIFO 5 EMPTY Flag */
7876  uint32_t FIFO_FULL5:1; /* FIFO 5 FULL Flag */
7877  uint32_t FIFO_OVERRUN4:1; /* FIFO 4 OVERRUN Flag */
7878  uint32_t FIFO_OVERFLOW4:1; /* FIFO 4 OVERFLOW Flag */
7879  uint32_t FIFO_EMPTY4:1; /* FIFO 4 EMPTY Flag */
7880  uint32_t FIFO_FULL4:1; /* FIFO 4 FULL Flag */
7881  uint32_t FIFO_OVERRUN3:1; /* FIFO 3 OVERRUN Flag */
7882  uint32_t FIFO_OVERFLOW3:1; /* FIFO 3 OVERFLOW Flag */
7883  uint32_t FIFO_EMPTY3:1; /* FIFO 3 EMPTY Flag */
7884  uint32_t FIFO_FULL3:1; /* FIFO 3 FULL Flag */
7885  uint32_t FIFO_OVERRUN2:1; /* FIFO 2 OVERRUN Flag */
7886  uint32_t FIFO_OVERFLOW2:1; /* FIFO 2 OVERFLOW Flag */
7887  uint32_t FIFO_EMPTY2:1; /* FIFO 2 EMPTY Flag */
7888  uint32_t FIFO_FULL2:1; /* FIFO 2 FULL Flag */
7889  uint32_t FIFO_OVERRUN1:1; /* FIFO 1 OVERRUN Flag */
7890  uint32_t FIFO_OVERFLOW1:1; /* FIFO 1 OVERFLOW Flag */
7891  uint32_t FIFO_EMPTY1:1; /* FIFO 1 EMPTY Flag */
7892  uint32_t FIFO_FULL1:1; /* FIFO 1 FULL Flag */
7893  uint32_t FIFO_OVERRUN0:1; /* FIFO 0 OVERRUN Flag */
7894  uint32_t FIFO_OVERFLOW0:1; /* FIFO 0 OVERFLOW Flag */
7895  uint32_t FIFO_EMPTY0:1; /* FIFO 0 EMPTY Flag */
7896  uint32_t FIFO_FULL0:1; /* FIFO 0 FULL Flag */
7897  } B;
7898  } CTU_STS_32B_tag;
7899
7900
7901  /* Register layout for all registers FR... */
7902
7903  typedef union { /* FIFO Right Aligned register */
7904  uint32_t R;
7905  struct {
7906  uint32_t:11;
7907  uint32_t ADC:1; /* ADC Unit */
7908  uint32_t N_CH:4; /* Number Channel */
7909  uint32_t:4;
7910  uint32_t DATA:12; /* Data Fifo */
7911  } B;
7912  } CTU_FR_32B_tag;
7913
7914
7915  /* Register layout for all registers FL... */
7916
7917  typedef union { /* FIFO Left Aligned register */
7918  uint32_t R;
7919  struct {
7920  uint32_t:11;
7921  uint32_t ADC:1; /* ADC Unit */
7922  uint32_t N_CH:4; /* Number Channel */
7923  uint32_t:1;
7924  uint32_t DATA:12; /* Data Fifo */
7925  uint32_t:3;
7926  } B;
7927  } CTU_FL_32B_tag;
7928
7929  typedef union { /* CTU Error Flag Register */
7930  uint16_t R;
7931  struct {
7932  uint16_t:3;
7933  uint16_t CS:1; /* Counter Status */
7934  uint16_t ET_OE:1; /* ExtTrigger Generation Overrun */
7935  uint16_t ERR_CMP:1; /* Set if counter reaches TGSCCR register */
7936  uint16_t T4_OE:1; /* Timer4 Generation Overrun */
7937  uint16_t T3_OE:1; /* Timer3 Generation Overrun */
7938  uint16_t T2_OE:1; /* Timer2 Generation Overrun */
7939  uint16_t T1_OE:1; /* Timer1 Generation Overrun */
7940 #ifndef USE_FIELD_ALIASES_CTU
7941  uint16_t ADC_OE:1; /* ADC Command Generation Overrun */
7942 #else
7943  uint16_t ADCOE:1; /* ADC Command Generation Overrun */
7944 #endif
7945 #ifndef USE_FIELD_ALIASES_CTU
7946  uint16_t TGS_OSM:1; /* TGS Overrun */
7947 #else
7948  uint16_t TGSOSM:1; /* TGS Overrun */
7949 #endif
7950 #ifndef USE_FIELD_ALIASES_CTU
7951  uint16_t MRS_O:1; /* MRS Overrun */
7952 #else
7953  uint16_t MRSO:1; /* TGS Overrun */
7954 #endif
7955  uint16_t ICE:1; /* Invalid Command Error */
7956 #ifndef USE_FIELD_ALIASES_CTU
7957  uint16_t SM_TO:1; /* Trigger Overrun */
7958 #else
7959  uint16_t SMTO:1; /* Trigger Overrun */
7960 #endif
7961 #ifndef USE_FIELD_ALIASES_CTU
7962  uint16_t MRS_RE:1; /* MRS Reload Error */
7963 #else
7964  uint16_t MRSRE:1; /* MRS Reload Error */
7965 #endif
7966  } B;
7968
7969  typedef union { /* CTU Interrupt Flag Register */
7970  uint16_t R;
7971  struct {
7972  uint16_t:4;
7973  uint16_t S_E_B:1; /* Slice time OK */
7974  uint16_t S_E_A:1; /* Slice time OK */
7975 #ifndef USE_FIELD_ALIASES_CTU
7976  uint16_t ADC_I:1; /* ADC Command Interrupt Flag */
7977 #else
7978  uint16_t ADC:1;
7979 #endif
7980 #ifndef USE_FIELD_ALIASES_CTU
7981  uint16_t T7_I:1; /* Trigger 7 Interrupt Flag */
7982 #else
7983  uint16_t T7:1;
7984 #endif
7985 #ifndef USE_FIELD_ALIASES_CTU
7986  uint16_t T6_I:1; /* Trigger 6 Interrupt Flag */
7987 #else
7988  uint16_t T6:1;
7989 #endif
7990 #ifndef USE_FIELD_ALIASES_CTU
7991  uint16_t T5_I:1; /* Trigger 5 Interrupt Flag */
7992 #else
7993  uint16_t T5:1;
7994 #endif
7995 #ifndef USE_FIELD_ALIASES_CTU
7996  uint16_t T4_I:1; /* Trigger 4 Interrupt Flag */
7997 #else
7998  uint16_t T4:1;
7999 #endif
8000 #ifndef USE_FIELD_ALIASES_CTU
8001  uint16_t T3_I:1; /* Trigger 3 Interrupt Flag */
8002 #else
8003  uint16_t T3:1;
8004 #endif
8005 #ifndef USE_FIELD_ALIASES_CTU
8006  uint16_t T2_I:1; /* Trigger 2 Interrupt Flag */
8007 #else
8008  uint16_t T2:1;
8009 #endif
8010 #ifndef USE_FIELD_ALIASES_CTU
8011  uint16_t T1_I:1; /* Trigger 1 Interrupt Flag */
8012 #else
8013  uint16_t T1:1;
8014 #endif
8015 #ifndef USE_FIELD_ALIASES_CTU
8016  uint16_t T0_I:1; /* Trigger 0 Interrupt Flag */
8017 #else
8018  uint16_t T0:1;
8019 #endif
8020 #ifndef USE_FIELD_ALIASES_CTU
8021  uint16_t MRS_I:1; /* MRS Interrupt Flag */
8022 #else
8023  uint16_t MRS:1;
8024 #endif
8025  } B;
8027
8028  typedef union { /* CTU Interrupt/DMA Register */
8029  uint16_t R;
8030  struct {
8031 #ifndef USE_FIELD_ALIASES_CTU
8032  uint16_t T7_I:1; /* Trigger 7 Interrupt Enable */
8033 #else
8034  uint16_t T7IE:1;
8035 #endif
8036 #ifndef USE_FIELD_ALIASES_CTU
8037  uint16_t T6_I:1; /* Trigger 6 Interrupt Enable */
8038 #else
8039  uint16_t T6IE:1;
8040 #endif
8041 #ifndef USE_FIELD_ALIASES_CTU
8042  uint16_t T5_I:1; /* Trigger 5 Interrupt Enable */
8043 #else
8044  uint16_t T5IE:1;
8045 #endif
8046 #ifndef USE_FIELD_ALIASES_CTU
8047  uint16_t T4_I:1; /* Trigger 4 Interrupt Enable */
8048 #else
8049  uint16_t T4IE:1;
8050 #endif
8051 #ifndef USE_FIELD_ALIASES_CTU
8052  uint16_t T3_I:1; /* Trigger 3 Interrupt Enable */
8053 #else
8054  uint16_t T3IE:1;
8055 #endif
8056 #ifndef USE_FIELD_ALIASES_CTU
8057  uint16_t T2_I:1; /* Trigger 2 Interrupt Enable */
8058 #else
8059  uint16_t T2IE:1;
8060 #endif
8061 #ifndef USE_FIELD_ALIASES_CTU
8062  uint16_t T1_I:1; /* Trigger 1 Interrupt Enable */
8063 #else
8064  uint16_t T1IE:1;
8065 #endif
8066 #ifndef USE_FIELD_ALIASES_CTU
8067  uint16_t T0_I:1; /* Trigger 0 Interrupt Enable */
8068 #else
8069  uint16_t T0IE:1;
8070 #endif
8071  uint16_t:2;
8072  uint16_t SAF_CNT_B_EN:1; /* Conversion time counter enabled */
8073  uint16_t SAF_CNT_A_EN:1; /* Conversion time counter enabled */
8074  uint16_t DMA_DE:1; /* DMA and gre bit */
8075 #ifndef USE_FIELD_ALIASES_CTU
8076  uint16_t MRS_DMAE:1; /* DMA Transfer Enable */
8077 #else
8078  uint16_t MRSDMAE:1;
8079 #endif
8080 #ifndef USE_FIELD_ALIASES_CTU
8081  uint16_t MRS_IE:1; /* MRS Interrupt Enable */
8082 #else
8083  uint16_t MRSIE:1;
8084 #endif
8085  uint16_t IEE:1; /* Interrupt Error Enable */
8086  } B;
8088
8089  typedef union { /* Control On-Time Register */
8090  uint16_t R;
8091  struct {
8092  uint16_t:8;
8093 #ifndef USE_FIELD_ALIASES_CTU
8094  uint16_t COTR_COTR:8; /* Control On-Time Register and Guard Time */
8095 #else
8096  uint16_t COTR:8;
8097 #endif
8098  } B;
8099  } CTU_COTR_16B_tag;
8100
8101  typedef union { /* CTU Control Register */
8102  uint16_t R;
8103  struct {
8104 #ifndef USE_FIELD_ALIASES_CTU
8105  uint16_t T7_SG:1; /* Trigger 7 Software Generated */
8106 #else
8107  uint16_t T7SG:1;
8108 #endif
8109 #ifndef USE_FIELD_ALIASES_CTU
8110  uint16_t T6_SG:1; /* Trigger 6 Software Generated */
8111 #else
8112  uint16_t T6SG:1;
8113 #endif
8114 #ifndef USE_FIELD_ALIASES_CTU
8115  uint16_t T5_SG:1; /* Trigger 5 Software Generated */
8116 #else
8117  uint16_t T5SG:1;
8118 #endif
8119 #ifndef USE_FIELD_ALIASES_CTU
8120  uint16_t T4_SG:1; /* Trigger 4 Software Generated */
8121 #else
8122  uint16_t T4SG:1;
8123 #endif
8124 #ifndef USE_FIELD_ALIASES_CTU
8125  uint16_t T3_SG:1; /* Trigger 3 Software Generated */
8126 #else
8127  uint16_t T3SG:1;
8128 #endif
8129 #ifndef USE_FIELD_ALIASES_CTU
8130  uint16_t T2_SG:1; /* Trigger 2 Software Generated */
8131 #else
8132  uint16_t T2SG:1;
8133 #endif
8134 #ifndef USE_FIELD_ALIASES_CTU
8135  uint16_t T1_SG:1; /* Trigger 1 Software Generated */
8136 #else
8137  uint16_t T1SG:1;
8138 #endif
8139 #ifndef USE_FIELD_ALIASES_CTU
8140  uint16_t T0_SG:1; /* Trigger 0 Software Generated */
8141 #else
8142  uint16_t T0SG:1;
8143 #endif
8144 #ifndef USE_FIELD_ALIASES_CTU
8145  uint16_t CTU_ADC_RESET:1; /* CTU ADC State Machine Reset */
8146 #else
8147  uint16_t CTUADCRESET:1;
8148 #endif
8149 #ifndef USE_FIELD_ALIASES_CTU
8150  uint16_t CTU_ODIS:1; /* CTU Output Disable */
8151 #else
8152  uint16_t CTUODIS:1;
8153 #endif
8154 #ifndef USE_FIELD_ALIASES_CTU
8155  uint16_t FILTER_EN:1; /* Synchronize Filter Register value */
8156 #else
8157  uint16_t FILTERENABLE:1;
8158 #endif
8159  uint16_t CGRE:1; /* Clear GRE */
8160  uint16_t FGRE:1; /* GRE Flag */
8161 #ifndef USE_FIELD_ALIASES_CTU
8162  uint16_t MRS_SG:1; /* MRS Software Generated */
8163 #else
8164  uint16_t MRSSG:1;
8165 #endif
8166  uint16_t GRE:1; /* General Reload Enable */
8167 #ifndef USE_FIELD_ALIASES_CTU
8168  uint16_t TGSISR_RE:1; /* TGSISR Reload Enable */
8169 #else
8170  uint16_t TGSISRRE:1;
8171 #endif
8172  } B;
8174
8175  typedef union { /* CTU Digital Filter Register */
8176  uint16_t R;
8177  struct {
8178  uint16_t:8;
8179 #ifndef USE_FIELD_ALIASES_CTU
8180  uint16_t FILTER_VALUE:8; /* Filter Value */
8181 #else
8182  uint16_t FILTERVALUE:8; /* deprecated name - please avoid */
8183 #endif
8184  } B;
8186
8187  typedef union { /* CTU Expected A Value Register */
8188  uint16_t R;
8189  struct {
8190  uint16_t EXPECTED_A_VALUE:16; /* Expected A Value */
8191  } B;
8193
8194  typedef union { /* CTU Expected B Value Register */
8195  uint16_t R;
8196  struct {
8197  uint16_t EXPECTED_B_VALUE:16; /* Expected B Value */
8198  } B;
8200
8201  typedef union { /* CTU Counter Range Register */
8202  uint16_t R;
8203  struct {
8204  uint16_t:8;
8205  uint16_t CNT_RANGE_VALUE:8; /* Counter Range Value */
8206  } B;
8208
8209
8210  /* Register layout for generated register(s) FRA... */
8211
8212  typedef union { /* */
8213  uint32_t R;
8214  } CTU_FRA_32B_tag;
8215
8216
8217  /* Register layout for generated register(s) FLA... */
8218
8219  typedef union { /* */
8220  uint32_t R;
8221  } CTU_FLA_32B_tag;
8222
8223
8224
8225  typedef struct CTU_struct_tag { /* start of CTU_tag */
8226  /* Trigger Generator Subunit Input Selection register */
8227  CTU_TGSISR_32B_tag TGSISR; /* offset: 0x0000 size: 32 bit */
8228  /* Trigger Generator Subunit Control Register */
8229  CTU_TGSCR_16B_tag TGSCR; /* offset: 0x0004 size: 16 bit */
8230  union {
8231  CTU_TCR_16B_tag TCR[8]; /* offset: 0x0006 (0x0002 x 8) */
8232
8233  struct {
8234  CTU_TCR_16B_tag T0CR; /* offset: 0x0006 size: 16 bit */
8235  CTU_TCR_16B_tag T1CR; /* offset: 0x0008 size: 16 bit */
8236  CTU_TCR_16B_tag T2CR; /* offset: 0x000A size: 16 bit */
8237  CTU_TCR_16B_tag T3CR; /* offset: 0x000C size: 16 bit */
8238  CTU_TCR_16B_tag T4CR; /* offset: 0x000E size: 16 bit */
8239  CTU_TCR_16B_tag T5CR; /* offset: 0x0010 size: 16 bit */
8240  CTU_TCR_16B_tag T6CR; /* offset: 0x0012 size: 16 bit */
8241  CTU_TCR_16B_tag T7CR; /* offset: 0x0014 size: 16 bit */
8242  };
8243
8244  };
8245  /* TGS Counter Compare Register */
8246  CTU_TGSCCR_16B_tag TGSCCR; /* offset: 0x0016 size: 16 bit */
8247  /* TGS Counter Reload Register */
8248  CTU_TGSCRR_16B_tag TGSCRR; /* offset: 0x0018 size: 16 bit */
8249  int8_t CTU_reserved_001A[2];
8250  /* Commands List Control Register 1 */
8251  CTU_CLCR1_32B_tag CLCR1; /* offset: 0x001C size: 32 bit */
8252  /* Commands List Control Register 2 */
8253  CTU_CLCR2_32B_tag CLCR2; /* offset: 0x0020 size: 32 bit */
8254  /* Trigger Handler Control Register 1 */
8255  CTU_THCR1_32B_tag THCR1; /* offset: 0x0024 size: 32 bit */
8256  /* Trigger Handler Control Register 2 */
8257  CTU_THCR2_32B_tag THCR2; /* offset: 0x0028 size: 32 bit */
8258  union {
8259  /* Command List Register. View: BIT13, BIT9 */
8260  CTU_CLR_SCM_16B_tag CLR[24]; /* offset: 0x002C (0x0002 x 24) */ /* deprecated name - please avoid */
8261
8262  /* Command List Register. View: (CMS=BIT13=)ST1 = 0, (BIT9=)ST0 = 0 */
8263  CTU_CLR_SCM_16B_tag CLR_SCM[24]; /* offset: 0x002C (0x0002 x 24) */
8264
8265  /* Command List Register. View: (CMS=BIT13=)ST1 = 1, (BIT9=)ST0 = DONT CARE */
8266  CTU_CLR_DCM_16B_tag CLR_DCM[24]; /* offset: 0x002C (0x0002 x 24) */
8267
8268  struct {
8269  /* Command List Register. View: (CMS=BIT13=)ST1 = 0, (BIT9=)ST0 = 0 */
8270  CTU_CLR_SCM_16B_tag CLR_SCM1; /* offset: 0x002C size: 16 bit */
8271  CTU_CLR_SCM_16B_tag CLR_SCM2; /* offset: 0x002E size: 16 bit */
8272  CTU_CLR_SCM_16B_tag CLR_SCM3; /* offset: 0x0030 size: 16 bit */
8273  CTU_CLR_SCM_16B_tag CLR_SCM4; /* offset: 0x0032 size: 16 bit */
8274  CTU_CLR_SCM_16B_tag CLR_SCM5; /* offset: 0x0034 size: 16 bit */
8275  CTU_CLR_SCM_16B_tag CLR_SCM6; /* offset: 0x0036 size: 16 bit */
8276  CTU_CLR_SCM_16B_tag CLR_SCM7; /* offset: 0x0038 size: 16 bit */
8277  CTU_CLR_SCM_16B_tag CLR_SCM8; /* offset: 0x003A size: 16 bit */
8278  CTU_CLR_SCM_16B_tag CLR_SCM9; /* offset: 0x003C size: 16 bit */
8279  CTU_CLR_SCM_16B_tag CLR_SCM10; /* offset: 0x003E size: 16 bit */
8280  CTU_CLR_SCM_16B_tag CLR_SCM11; /* offset: 0x0040 size: 16 bit */
8281  CTU_CLR_SCM_16B_tag CLR_SCM12; /* offset: 0x0042 size: 16 bit */
8282  CTU_CLR_SCM_16B_tag CLR_SCM13; /* offset: 0x0044 size: 16 bit */
8283  CTU_CLR_SCM_16B_tag CLR_SCM14; /* offset: 0x0046 size: 16 bit */
8284  CTU_CLR_SCM_16B_tag CLR_SCM15; /* offset: 0x0048 size: 16 bit */
8285  CTU_CLR_SCM_16B_tag CLR_SCM16; /* offset: 0x004A size: 16 bit */
8286  CTU_CLR_SCM_16B_tag CLR_SCM17; /* offset: 0x004C size: 16 bit */
8287  CTU_CLR_SCM_16B_tag CLR_SCM18; /* offset: 0x004E size: 16 bit */
8288  CTU_CLR_SCM_16B_tag CLR_SCM19; /* offset: 0x0050 size: 16 bit */
8289  CTU_CLR_SCM_16B_tag CLR_SCM20; /* offset: 0x0052 size: 16 bit */
8290  CTU_CLR_SCM_16B_tag CLR_SCM21; /* offset: 0x0054 size: 16 bit */
8291  CTU_CLR_SCM_16B_tag CLR_SCM22; /* offset: 0x0056 size: 16 bit */
8292  CTU_CLR_SCM_16B_tag CLR_SCM23; /* offset: 0x0058 size: 16 bit */
8293  CTU_CLR_SCM_16B_tag CLR_SCM24; /* offset: 0x005A size: 16 bit */
8294  };
8295
8296  struct {
8297  /* Command List Register. View: (CMS=BIT13=)ST1 = 1, (BIT9=)ST0 = DONT CARE */
8298  CTU_CLR_DCM_16B_tag CLR_DCM1; /* offset: 0x002C size: 16 bit */
8299  CTU_CLR_DCM_16B_tag CLR_DCM2; /* offset: 0x002E size: 16 bit */
8300  CTU_CLR_DCM_16B_tag CLR_DCM3; /* offset: 0x0030 size: 16 bit */
8301  CTU_CLR_DCM_16B_tag CLR_DCM4; /* offset: 0x0032 size: 16 bit */
8302  CTU_CLR_DCM_16B_tag CLR_DCM5; /* offset: 0x0034 size: 16 bit */
8303  CTU_CLR_DCM_16B_tag CLR_DCM6; /* offset: 0x0036 size: 16 bit */
8304  CTU_CLR_DCM_16B_tag CLR_DCM7; /* offset: 0x0038 size: 16 bit */
8305  CTU_CLR_DCM_16B_tag CLR_DCM8; /* offset: 0x003A size: 16 bit */
8306  CTU_CLR_DCM_16B_tag CLR_DCM9; /* offset: 0x003C size: 16 bit */
8307  CTU_CLR_DCM_16B_tag CLR_DCM10; /* offset: 0x003E size: 16 bit */
8308  CTU_CLR_DCM_16B_tag CLR_DCM11; /* offset: 0x0040 size: 16 bit */
8309  CTU_CLR_DCM_16B_tag CLR_DCM12; /* offset: 0x0042 size: 16 bit */
8310  CTU_CLR_DCM_16B_tag CLR_DCM13; /* offset: 0x0044 size: 16 bit */
8311  CTU_CLR_DCM_16B_tag CLR_DCM14; /* offset: 0x0046 size: 16 bit */
8312  CTU_CLR_DCM_16B_tag CLR_DCM15; /* offset: 0x0048 size: 16 bit */
8313  CTU_CLR_DCM_16B_tag CLR_DCM16; /* offset: 0x004A size: 16 bit */
8314  CTU_CLR_DCM_16B_tag CLR_DCM17; /* offset: 0x004C size: 16 bit */
8315  CTU_CLR_DCM_16B_tag CLR_DCM18; /* offset: 0x004E size: 16 bit */
8316  CTU_CLR_DCM_16B_tag CLR_DCM19; /* offset: 0x0050 size: 16 bit */
8317  CTU_CLR_DCM_16B_tag CLR_DCM20; /* offset: 0x0052 size: 16 bit */
8318  CTU_CLR_DCM_16B_tag CLR_DCM21; /* offset: 0x0054 size: 16 bit */
8319  CTU_CLR_DCM_16B_tag CLR_DCM22; /* offset: 0x0056 size: 16 bit */
8320  CTU_CLR_DCM_16B_tag CLR_DCM23; /* offset: 0x0058 size: 16 bit */
8321  CTU_CLR_DCM_16B_tag CLR_DCM24; /* offset: 0x005A size: 16 bit */
8322  };
8323
8324  };
8325  int8_t CTU_reserved_005C[16];
8326  /* Control Register */
8327  CTU_CR_16B_tag CR; /* offset: 0x006C size: 16 bit */
8328  int8_t CTU_reserved_006E[2];
8329  /* Control Register FIFO */
8330  CTU_FCR_32B_tag FCR; /* offset: 0x0070 size: 32 bit */
8331  /* Threshold 1 Register */
8332  CTU_TH1_32B_tag TH1; /* offset: 0x0074 size: 32 bit */
8333  /* Threshold 2 Register */
8334  CTU_TH2_32B_tag TH2; /* offset: 0x0078 size: 32 bit */
8335  union {
8336  /* Status Register */
8337  CTU_STS_32B_tag STS; /* offset: 0x007C size: 32 bit */
8338
8339  CTU_STS_32B_tag STATUS; /* deprecated - please avoid */
8340
8341  };
8342  union {
8343  CTU_FRA_32B_tag FRA[8]; /* offset: 0x0080 (0x0004 x 8) */
8344
8345  /* FIFO Right Aligned register */
8346  CTU_FR_32B_tag FR[8]; /* offset: 0x0080 (0x0004 x 8) */
8347
8348  struct {
8349  /* FIFO Right Aligned register */
8350  CTU_FR_32B_tag FR0; /* offset: 0x0080 size: 32 bit */
8351  CTU_FR_32B_tag FR1; /* offset: 0x0084 size: 32 bit */
8352  CTU_FR_32B_tag FR2; /* offset: 0x0088 size: 32 bit */
8353  CTU_FR_32B_tag FR3; /* offset: 0x008C size: 32 bit */
8354  CTU_FR_32B_tag FR4; /* offset: 0x0090 size: 32 bit */
8355  CTU_FR_32B_tag FR5; /* offset: 0x0094 size: 32 bit */
8356  CTU_FR_32B_tag FR6; /* offset: 0x0098 size: 32 bit */
8357  CTU_FR_32B_tag FR7; /* offset: 0x009C size: 32 bit */
8358  };
8359
8360  };
8361  union {
8362  CTU_FLA_32B_tag FLA[8]; /* offset: 0x00A0 (0x0004 x 8) */
8363
8364  /* FIFO Left Aligned register */
8365  CTU_FL_32B_tag FL[8]; /* offset: 0x00A0 (0x0004 x 8) */
8366
8367  struct {
8368  /* FIFO Left Aligned register */
8369  CTU_FL_32B_tag FL0; /* offset: 0x00A0 size: 32 bit */
8370  CTU_FL_32B_tag FL1; /* offset: 0x00A4 size: 32 bit */
8371  CTU_FL_32B_tag FL2; /* offset: 0x00A8 size: 32 bit */
8372  CTU_FL_32B_tag FL3; /* offset: 0x00AC size: 32 bit */
8373  CTU_FL_32B_tag FL4; /* offset: 0x00B0 size: 32 bit */
8374  CTU_FL_32B_tag FL5; /* offset: 0x00B4 size: 32 bit */
8375  CTU_FL_32B_tag FL6; /* offset: 0x00B8 size: 32 bit */
8376  CTU_FL_32B_tag FL7; /* offset: 0x00BC size: 32 bit */
8377  };
8378
8379  };
8380  /* CTU Error Flag Register */
8381  CTU_CTUEFR_16B_tag CTUEFR; /* offset: 0x00C0 size: 16 bit */
8382  /* CTU Interrupt Flag Register */
8383  CTU_CTUIFR_16B_tag CTUIFR; /* offset: 0x00C2 size: 16 bit */
8384  /* CTU Interrupt/DMA Register */
8385  CTU_CTUIR_16B_tag CTUIR; /* offset: 0x00C4 size: 16 bit */
8386  /* Control On-Time Register */
8387  CTU_COTR_16B_tag COTR; /* offset: 0x00C6 size: 16 bit */
8388  /* CTU Control Register */
8389  CTU_CTUCR_16B_tag CTUCR; /* offset: 0x00C8 size: 16 bit */
8390  union {
8391  /* CTU Digital Filter Register */
8392  CTU_FILTER_16B_tag FILTER; /* offset: 0x00CA size: 16 bit */
8393
8394  CTU_FILTER_16B_tag CTUFILTER; /* deprecated - please avoid */
8395
8396  };
8397  /* CTU Expected A Value Register */
8398  CTU_EXPECTED_A_16B_tag EXPECTED_A; /* offset: 0x00CC size: 16 bit */
8399
8400  /* CTU Expected B Value Register */
8401  CTU_EXPECTED_B_16B_tag EXPECTED_B; /* offset: 0x00CE size: 16 bit */
8402  /* CTU Counter Range Register */
8403  CTU_CNT_RANGE_16B_tag CNT_RANGE; /* offset: 0x00D0 size: 16 bit */
8404  } CTU_tag;
8405
8406
8407 #define CTU (*(volatile CTU_tag *) 0xFFE0C000UL)
8408
8409
8410
8411 /****************************************************************/
8412 /* */
8413 /* Module: mcTIMER */
8414 /* */
8415 /****************************************************************/
8416
8417
8418  /* Register layout for all registers COMP1... */
8419
8420  typedef union { /* Compare Register 1 */
8421  uint16_t R;
8422  struct {
8423  uint16_t COMP1:16; /* deprecated definition -- do not use */
8424  } B;
8426
8427
8428  /* Register layout for all registers COMP2... */
8429
8430  typedef union { /* Compare Register 2 */
8431  uint16_t R;
8432  struct {
8433  uint16_t COMP2:16; /* deprecated definition -- do not use */
8434  } B;
8436
8437
8438  /* Register layout for all registers CAPT1... */
8439
8440  typedef union { /* Capture Register 1 */
8441  uint16_t R;
8442  struct {
8443  uint16_t CAPT1:16; /* deprecated definition -- do not use */
8444  } B;
8446
8447
8448  /* Register layout for all registers CAPT2... */
8449
8450  typedef union { /* Capture Register 2 */
8451  uint16_t R;
8452  struct {
8453  uint16_t CAPT2:16; /* deprecated definition -- do not use */
8454  } B;
8456
8457
8458  /* Register layout for all registers LOAD... */
8459
8460  typedef union { /* Load Register */
8461  uint16_t R;
8462  struct {
8463  uint16_t LOAD:16; /* deprecated definition -- do not use */
8464  } B;
8466
8467
8468  /* Register layout for all registers HOLD... */
8469
8470  typedef union { /* Hold Register */
8471  uint16_t R;
8472  struct {
8473  uint16_t HOLD:16; /* deprecated definition -- do not use */
8474  } B;
8476
8477
8478  /* Register layout for all registers CNTR... */
8479
8480  typedef union { /* Counter Register */
8481  uint16_t R;
8482  struct {
8483  uint16_t CNTR:16; /* deprecated definition -- do not use */
8484  } B;
8486
8487
8488  /* Register layout for all registers CTRL1... */
8489
8490  typedef union { /* Control Register */
8491  uint16_t R;
8492  struct {
8493  uint16_t CNTMODE:3; /* Count Mode */
8494  uint16_t PRISRC:5; /* Primary Count Source */
8495  uint16_t ONCE:1; /* Count Once */
8496  uint16_t LENGTH:1; /* Count Length */
8497  uint16_t DIR:1; /* Count Direction */
8498  uint16_t SECSRC:5; /* Secondary Count Source */
8499  } B;
8501
8502
8503  /* Register layout for all registers CTRL2... */
8504
8505  typedef union { /* Control Register 2 */
8506  uint16_t R;
8507  struct {
8508  uint16_t OEN:1; /* Output Enable */
8509  uint16_t RDNT:1; /* Redundant Channel Enable */
8510  uint16_t INPUT:1; /* External Input Signal */
8511  uint16_t VAL:1; /* Forced OFLAG Value */
8512  uint16_t FORCE:1; /* Force the OFLAG output */
8513  uint16_t COFRC:1; /* Co-channel OFLAG Force */
8514  uint16_t COINIT:2; /* Co-channel Initialization */
8515  uint16_t SIPS:1; /* Secondary Source Input Polarity Select */
8516  uint16_t PIPS:1; /* Primary Source Input Polarity Select */
8517  uint16_t OPS:1; /* Output Polarity Select */
8518  uint16_t MSTR:1; /* Master Mode */
8519  uint16_t OUTMODE:4; /* Output Mode */
8520  } B;
8522
8523
8524  /* Register layout for all registers CTRL3... */
8525
8526  typedef union { /* Control Register 3 */
8527  uint16_t R;
8528  struct {
8529  uint16_t STPEN:1; /* Stop Action Enable */
8530  uint16_t ROC:2; /* Reload On Capture */
8531  uint16_t FMODE:1; /* Fault Safing Mode */
8532  uint16_t FDIS:4; /* Fault Disable Mask */
8533  uint16_t C2FCNT:3; /* CAPT2 FIFO Word Count */
8534  uint16_t C1FCNT:3; /* CAPT1 FIFO Word Count */
8535  uint16_t DBGEN:2; /* Debug Actions Enable */
8536  } B;
8538
8539
8540  /* Register layout for all registers STS... */
8541
8542  typedef union { /* Status Register */
8543  uint16_t R;
8544  struct {
8545  uint16_t:6;
8546  uint16_t WDF:1; /* Watchdog Time-out Flag */
8547  uint16_t RCF:1; /* Redundant Channel Flag */
8548  uint16_t ICF2:1; /* Input Capture 2 Flag */
8549  uint16_t ICF1:1; /* Input Capture 1 Flag */
8550  uint16_t IEHF:1; /* Input Edge High Flag */
8551  uint16_t IELF:1; /* Input Edge Low Flag */
8552  uint16_t TOF:1; /* Timer Overflow Flag */
8553  uint16_t TCF2:1; /* Timer Compare 2 Flag */
8554  uint16_t TCF1:1; /* Timer Compare 1 Flag */
8555  uint16_t TCF:1; /* Timer Compare Flag */
8556  } B;
8558
8559
8560  /* Register layout for all registers INTDMA... */
8561
8562  typedef union { /* Interrupt and DMA Enable Register */
8563  uint16_t R;
8564  struct {
8565  uint16_t ICF2DE:1; /* Input Capture 2 Flag DMA Enable */
8566  uint16_t ICF1DE:1; /* Input Capture 1 Flag DMA Enable */
8567  uint16_t CMPLD2DE:1; /* Comparator Load Register 2 Flag DMA Enable */
8568  uint16_t CMPLD1DE:1; /* Comparator Load Register 1 Flag DMA Enable */
8569  uint16_t:2;
8570  uint16_t WDFIE:1; /* Watchdog Flag Interrupt Enable */
8571  uint16_t RCFIE:1; /* Redundant Channel Flag Interrupt Enable */
8572  uint16_t ICF2IE:1; /* Input Capture 2 Flag Interrupt Enable */
8573  uint16_t ICF1IE:1; /* Input Capture 1 Flag Interrupt Enable */
8574  uint16_t IEHFIE:1; /* Input Edge High Flag Interrupt Enable */
8575  uint16_t IELFIE:1; /* Input Edge Low Flag Interrupt Enable */
8576  uint16_t TOFIE:1; /* Timer Overflow Flag Interrupt Enable */
8577  uint16_t TCF2IE:1; /* Timer Compare 2 Flag Interrupt Enable */
8578  uint16_t TCF1IE:1; /* Timer Compare 1 Flag Interrupt Enable */
8579  uint16_t TCFIE:1; /* Timer Compare Flag Interrupt Enable */
8580  } B;
8582
8583
8584  /* Register layout for all registers CMPLD1... */
8585
8586  typedef union { /* Comparator Load Register 1 */
8587  uint16_t R;
8588  struct {
8589  uint16_t CMPLD1:16; /* deprecated definition -- do not use */
8590  } B;
8592
8593
8594  /* Register layout for all registers CMPLD2... */
8595
8596  typedef union { /* Comparator Load Register 2 */
8597  uint16_t R;
8598  struct {
8599  uint16_t CMPLD2:16; /* deprecated definition -- do not use */
8600  } B;
8602
8603
8604  /* Register layout for all registers CCCTRL... */
8605
8606  typedef union { /* Compare and Capture Control Register */
8607  uint16_t R;
8608  struct {
8609  uint16_t CLC2:3; /* Compare Load Control 2 */
8610  uint16_t CLC1:3; /* Compare Load Control 1 */
8611  uint16_t CMPMODE:2; /* Compare Mode */
8612  uint16_t CPT2MODE:2; /* Capture 2 Mode Control */
8613  uint16_t CPT1MODE:2; /* Capture 1 Mode Control */
8614  uint16_t CFWM:2; /* Capture FIFO Water Mark */
8615  uint16_t ONESHOT:1; /* One Shot Capture Mode */
8616  uint16_t ARM:1; /* Arm Capture */
8617  } B;
8619
8620
8621  /* Register layout for all registers FILT... */
8622
8623  typedef union { /* Input Filter Register */
8624  uint16_t R;
8625  struct {
8626  uint16_t:5;
8627 #ifndef USE_FIELD_ALIASES_mcTIMER
8628  uint16_t FILT_CNT:3; /* Input Filter Sample Count */
8629 #else
8630  uint16_t FILTCNT:3; /* deprecated name - please avoid */
8631 #endif
8632 #ifndef USE_FIELD_ALIASES_mcTIMER
8633  uint16_t FILT_PER:8; /* Input Filter Sample Period */
8634 #else
8635  uint16_t FILTPER:8; /* deprecated name - please avoid */
8636 #endif
8637  } B;
8639
8640  typedef union { /* Watchdog Time-out Register */
8641  uint16_t R;
8642  struct {
8643  uint16_t WDTOL:16; /* deprecated definition -- do not use */
8644  } B;
8646
8647  typedef union { /* Watchdog Time-out Register */
8648  uint16_t R;
8649  struct {
8650  uint16_t WDTOH:16; /* deprecated definition -- do not use */
8651  } B;
8653
8654  typedef union { /* Fault Control Register */
8655  uint16_t R;
8656  struct {
8657  uint16_t:3;
8658  uint16_t FTEST:1; /* Fault Test */
8659  uint16_t FIE:4; /* Fault Interrupt Enable */
8660  uint16_t:4;
8661  uint16_t FLVL:4; /* Fault Active Logic Level */
8662  } B;
8664
8665  typedef union { /* Fault Status Register */
8666  uint16_t R;
8667  struct {
8668  uint16_t:4;
8669  uint16_t FFPIN:4; /* Filtered Fault Pin */
8670  uint16_t:4;
8671  uint16_t FFLAG:4; /* Fault Flag */
8672  } B;
8674
8675  typedef union { /* Fault Filter Registers */
8676  uint16_t R;
8677  struct {
8678  uint16_t:5;
8679 #ifndef USE_FIELD_ALIASES_mcTIMER
8680  uint16_t FFPIN:3; /* Fault Filter Sample Count */
8681 #else
8682  uint16_t FFILTCNT:3; /* deprecated name - please avoid */
8683 #endif
8684 #ifndef USE_FIELD_ALIASES_mcTIMER
8685  uint16_t FFILT_PER:8; /* Fault Filter Sample Period */
8686 #else
8687  uint16_t FFILTPER:8; /* deprecated name - please avoid */
8688 #endif
8689  } B;
8691
8692  typedef union { /* Channel Enable Registers */
8693  uint16_t R;
8694  struct {
8695  uint16_t:8;
8696  uint16_t ENBL:8; /* Timer Channel Enable */
8697  } B;
8699
8700  typedef union { /* DMA Request 0 Select Registers */
8701  uint16_t R;
8702  struct {
8703  uint16_t:11;
8704  uint16_t DREQ0V:5; /* DMA Request Select */
8705  } B;
8707
8708  typedef union { /* DMA Request 1 Select Registers */
8709  uint16_t R;
8710  struct {
8711  uint16_t:11;
8712  uint16_t DREQ1V:5; /* DMA Request Select */
8713  } B;
8715
8716  typedef union { /* DMA Request 2 Select Registers */
8717  uint16_t R;
8718  struct {
8719  uint16_t:11;
8720  uint16_t DREQ2V:5; /* DMA Request Select */
8721  } B;
8723
8724  typedef union { /* DMA Request 3 Select Registers */
8725  uint16_t R;
8726  struct {
8727  uint16_t:11;
8728  uint16_t DREQ3V:5; /* DMA Request Select */
8729  } B;
8731
8732
8733  /* Register layout for generated register(s) DREQ... */
8734
8735  typedef union { /* */
8736  uint16_t R;
8738
8739
8741
8742  /* Compare Register 1 */
8743  mcTIMER_COMP1_16B_tag COMP1; /* relative offset: 0x0000 */
8744  /* Compare Register 2 */
8745  mcTIMER_COMP2_16B_tag COMP2; /* relative offset: 0x0002 */
8746  /* Capture Register 1 */
8747  mcTIMER_CAPT1_16B_tag CAPT1; /* relative offset: 0x0004 */
8748  /* Capture Register 2 */
8749  mcTIMER_CAPT2_16B_tag CAPT2; /* relative offset: 0x0006 */
8750  /* Load Register */
8751  mcTIMER_LOAD_16B_tag LOAD; /* relative offset: 0x0008 */
8752  /* Hold Register */
8753  mcTIMER_HOLD_16B_tag HOLD; /* relative offset: 0x000A */
8754  /* Counter Register */
8755  mcTIMER_CNTR_16B_tag CNTR; /* relative offset: 0x000C */
8756  union {
8757  /* Control Register */
8758  mcTIMER_CTRL1_16B_tag CTRL1; /* relative offset: 0x000E */
8759  mcTIMER_CTRL1_16B_tag CTRL; /* deprecated - please avoid */
8760  };
8761  /* Control Register 2 */
8762  mcTIMER_CTRL2_16B_tag CTRL2; /* relative offset: 0x0010 */
8763  /* Control Register 3 */
8764  mcTIMER_CTRL3_16B_tag CTRL3; /* relative offset: 0x0012 */
8765  /* Status Register */
8766  mcTIMER_STS_16B_tag STS; /* relative offset: 0x0014 */
8767  /* Interrupt and DMA Enable Register */
8768  mcTIMER_INTDMA_16B_tag INTDMA; /* relative offset: 0x0016 */
8769  /* Comparator Load Register 1 */
8770  mcTIMER_CMPLD1_16B_tag CMPLD1; /* relative offset: 0x0018 */
8771  /* Comparator Load Register 2 */
8772  mcTIMER_CMPLD2_16B_tag CMPLD2; /* relative offset: 0x001A */
8773  /* Compare and Capture Control Register */
8774  mcTIMER_CCCTRL_16B_tag CCCTRL; /* relative offset: 0x001C */
8775  /* Input Filter Register */
8776  mcTIMER_FILT_16B_tag FILT; /* relative offset: 0x001E */
8777
8779
8780
8781  typedef struct mcTIMER_struct_tag { /* start of mcTIMER_tag */
8782  union {
8783  /* Register set CHANNEL */
8784  mcTIMER_CHANNEL_tag CHANNEL[6]; /* offset: 0x0000 (0x0020 x 6) */
8785
8786  struct {
8787  /* Compare Register 1 */
8788  mcTIMER_COMP1_16B_tag COMP10; /* offset: 0x0000 size: 16 bit */
8789  /* Compare Register 2 */
8790  mcTIMER_COMP2_16B_tag COMP20; /* offset: 0x0002 size: 16 bit */
8791  /* Capture Register 1 */
8792  mcTIMER_CAPT1_16B_tag CAPT10; /* offset: 0x0004 size: 16 bit */
8793  /* Capture Register 2 */
8794  mcTIMER_CAPT2_16B_tag CAPT20; /* offset: 0x0006 size: 16 bit */
8795  /* Load Register */
8796  mcTIMER_LOAD_16B_tag LOAD0; /* offset: 0x0008 size: 16 bit */
8797  /* Hold Register */
8798  mcTIMER_HOLD_16B_tag HOLD0; /* offset: 0x000A size: 16 bit */
8799  /* Counter Register */
8800  mcTIMER_CNTR_16B_tag CNTR0; /* offset: 0x000C size: 16 bit */
8801  /* Control Register */
8802  mcTIMER_CTRL1_16B_tag CTRL10; /* offset: 0x000E size: 16 bit */
8803  /* Control Register 2 */
8804  mcTIMER_CTRL2_16B_tag CTRL20; /* offset: 0x0010 size: 16 bit */
8805  /* Control Register 3 */
8806  mcTIMER_CTRL3_16B_tag CTRL30; /* offset: 0x0012 size: 16 bit */
8807  /* Status Register */
8808  mcTIMER_STS_16B_tag STS0; /* offset: 0x0014 size: 16 bit */
8809  /* Interrupt and DMA Enable Register */
8810  mcTIMER_INTDMA_16B_tag INTDMA0; /* offset: 0x0016 size: 16 bit */
8811  /* Comparator Load Register 1 */
8812  mcTIMER_CMPLD1_16B_tag CMPLD10; /* offset: 0x0018 size: 16 bit */
8813  /* Comparator Load Register 2 */
8814  mcTIMER_CMPLD2_16B_tag CMPLD20; /* offset: 0x001A size: 16 bit */
8815  /* Compare and Capture Control Register */
8816  mcTIMER_CCCTRL_16B_tag CCCTRL0; /* offset: 0x001C size: 16 bit */
8817  /* Input Filter Register */
8818  mcTIMER_FILT_16B_tag FILT0; /* offset: 0x001E size: 16 bit */
8819  /* Compare Register 1 */
8820  mcTIMER_COMP1_16B_tag COMP11; /* offset: 0x0020 size: 16 bit */
8821  /* Compare Register 2 */
8822  mcTIMER_COMP2_16B_tag COMP21; /* offset: 0x0022 size: 16 bit */
8823  /* Capture Register 1 */
8824  mcTIMER_CAPT1_16B_tag CAPT11; /* offset: 0x0024 size: 16 bit */
8825  /* Capture Register 2 */
8826  mcTIMER_CAPT2_16B_tag CAPT21; /* offset: 0x0026 size: 16 bit */
8827  /* Load Register */
8828  mcTIMER_LOAD_16B_tag LOAD1; /* offset: 0x0028 size: 16 bit */
8829  /* Hold Register */
8830  mcTIMER_HOLD_16B_tag HOLD1; /* offset: 0x002A size: 16 bit */
8831  /* Counter Register */
8832  mcTIMER_CNTR_16B_tag CNTR1; /* offset: 0x002C size: 16 bit */
8833  /* Control Register */
8834  mcTIMER_CTRL1_16B_tag CTRL11; /* offset: 0x002E size: 16 bit */
8835  /* Control Register 2 */
8836  mcTIMER_CTRL2_16B_tag CTRL21; /* offset: 0x0030 size: 16 bit */
8837  /* Control Register 3 */
8838  mcTIMER_CTRL3_16B_tag CTRL31; /* offset: 0x0032 size: 16 bit */
8839  /* Status Register */
8840  mcTIMER_STS_16B_tag STS1; /* offset: 0x0034 size: 16 bit */
8841  /* Interrupt and DMA Enable Register */
8842  mcTIMER_INTDMA_16B_tag INTDMA1; /* offset: 0x0036 size: 16 bit */
8843  /* Comparator Load Register 1 */
8844  mcTIMER_CMPLD1_16B_tag CMPLD11; /* offset: 0x0038 size: 16 bit */
8845  /* Comparator Load Register 2 */
8846  mcTIMER_CMPLD2_16B_tag CMPLD21; /* offset: 0x003A size: 16 bit */
8847  /* Compare and Capture Control Register */
8848  mcTIMER_CCCTRL_16B_tag CCCTRL1; /* offset: 0x003C size: 16 bit */
8849  /* Input Filter Register */
8850  mcTIMER_FILT_16B_tag FILT1; /* offset: 0x003E size: 16 bit */
8851  /* Compare Register 1 */
8852  mcTIMER_COMP1_16B_tag COMP12; /* offset: 0x0040 size: 16 bit */
8853  /* Compare Register 2 */
8854  mcTIMER_COMP2_16B_tag COMP22; /* offset: 0x0042 size: 16 bit */
8855  /* Capture Register 1 */
8856  mcTIMER_CAPT1_16B_tag CAPT12; /* offset: 0x0044 size: 16 bit */
8857  /* Capture Register 2 */
8858  mcTIMER_CAPT2_16B_tag CAPT22; /* offset: 0x0046 size: 16 bit */
8859  /* Load Register */
8860  mcTIMER_LOAD_16B_tag LOAD2; /* offset: 0x0048 size: 16 bit */
8861  /* Hold Register */
8862  mcTIMER_HOLD_16B_tag HOLD2; /* offset: 0x004A size: 16 bit */
8863  /* Counter Register */
8864  mcTIMER_CNTR_16B_tag CNTR2; /* offset: 0x004C size: 16 bit */
8865  /* Control Register */
8866  mcTIMER_CTRL1_16B_tag CTRL12; /* offset: 0x004E size: 16 bit */
8867  /* Control Register 2 */
8868  mcTIMER_CTRL2_16B_tag CTRL22; /* offset: 0x0050 size: 16 bit */
8869  /* Control Register 3 */
8870  mcTIMER_CTRL3_16B_tag CTRL32; /* offset: 0x0052 size: 16 bit */
8871  /* Status Register */
8872  mcTIMER_STS_16B_tag STS2; /* offset: 0x0054 size: 16 bit */
8873  /* Interrupt and DMA Enable Register */
8874  mcTIMER_INTDMA_16B_tag INTDMA2; /* offset: 0x0056 size: 16 bit */
8875  /* Comparator Load Register 1 */
8876  mcTIMER_CMPLD1_16B_tag CMPLD12; /* offset: 0x0058 size: 16 bit */
8877  /* Comparator Load Register 2 */
8878  mcTIMER_CMPLD2_16B_tag CMPLD22; /* offset: 0x005A size: 16 bit */
8879  /* Compare and Capture Control Register */
8880  mcTIMER_CCCTRL_16B_tag CCCTRL2; /* offset: 0x005C size: 16 bit */
8881  /* Input Filter Register */
8882  mcTIMER_FILT_16B_tag FILT2; /* offset: 0x005E size: 16 bit */
8883  /* Compare Register 1 */
8884  mcTIMER_COMP1_16B_tag COMP13; /* offset: 0x0060 size: 16 bit */
8885  /* Compare Register 2 */
8886  mcTIMER_COMP2_16B_tag COMP23; /* offset: 0x0062 size: 16 bit */
8887  /* Capture Register 1 */
8888  mcTIMER_CAPT1_16B_tag CAPT13; /* offset: 0x0064 size: 16 bit */
8889  /* Capture Register 2 */
8890  mcTIMER_CAPT2_16B_tag CAPT23; /* offset: 0x0066 size: 16 bit */
8891  /* Load Register */
8892  mcTIMER_LOAD_16B_tag LOAD3; /* offset: 0x0068 size: 16 bit */
8893  /* Hold Register */
8894  mcTIMER_HOLD_16B_tag HOLD3; /* offset: 0x006A size: 16 bit */
8895  /* Counter Register */
8896  mcTIMER_CNTR_16B_tag CNTR3; /* offset: 0x006C size: 16 bit */
8897  /* Control Register */
8898  mcTIMER_CTRL1_16B_tag CTRL13; /* offset: 0x006E size: 16 bit */
8899  /* Control Register 2 */
8900  mcTIMER_CTRL2_16B_tag CTRL23; /* offset: 0x0070 size: 16 bit */
8901  /* Control Register 3 */
8902  mcTIMER_CTRL3_16B_tag CTRL33; /* offset: 0x0072 size: 16 bit */
8903  /* Status Register */
8904  mcTIMER_STS_16B_tag STS3; /* offset: 0x0074 size: 16 bit */
8905  /* Interrupt and DMA Enable Register */
8906  mcTIMER_INTDMA_16B_tag INTDMA3; /* offset: 0x0076 size: 16 bit */
8907  /* Comparator Load Register 1 */
8908  mcTIMER_CMPLD1_16B_tag CMPLD13; /* offset: 0x0078 size: 16 bit */
8909  /* Comparator Load Register 2 */
8910  mcTIMER_CMPLD2_16B_tag CMPLD23; /* offset: 0x007A size: 16 bit */
8911  /* Compare and Capture Control Register */
8912  mcTIMER_CCCTRL_16B_tag CCCTRL3; /* offset: 0x007C size: 16 bit */
8913  /* Input Filter Register */
8914  mcTIMER_FILT_16B_tag FILT3; /* offset: 0x007E size: 16 bit */
8915  /* Compare Register 1 */
8916  mcTIMER_COMP1_16B_tag COMP14; /* offset: 0x0080 size: 16 bit */
8917  /* Compare Register 2 */
8918  mcTIMER_COMP2_16B_tag COMP24; /* offset: 0x0082 size: 16 bit */
8919  /* Capture Register 1 */
8920  mcTIMER_CAPT1_16B_tag CAPT14; /* offset: 0x0084 size: 16 bit */
8921  /* Capture Register 2 */
8922  mcTIMER_CAPT2_16B_tag CAPT24; /* offset: 0x0086 size: 16 bit */
8923  /* Load Register */
8924  mcTIMER_LOAD_16B_tag LOAD4; /* offset: 0x0088 size: 16 bit */
8925  /* Hold Register */
8926  mcTIMER_HOLD_16B_tag HOLD4; /* offset: 0x008A size: 16 bit */
8927  /* Counter Register */
8928  mcTIMER_CNTR_16B_tag CNTR4; /* offset: 0x008C size: 16 bit */
8929  /* Control Register */
8930  mcTIMER_CTRL1_16B_tag CTRL14; /* offset: 0x008E size: 16 bit */
8931  /* Control Register 2 */
8932  mcTIMER_CTRL2_16B_tag CTRL24; /* offset: 0x0090 size: 16 bit */
8933  /* Control Register 3 */
8934  mcTIMER_CTRL3_16B_tag CTRL34; /* offset: 0x0092 size: 16 bit */
8935  /* Status Register */
8936  mcTIMER_STS_16B_tag STS4; /* offset: 0x0094 size: 16 bit */
8937  /* Interrupt and DMA Enable Register */
8938  mcTIMER_INTDMA_16B_tag INTDMA4; /* offset: 0x0096 size: 16 bit */
8939  /* Comparator Load Register 1 */
8940  mcTIMER_CMPLD1_16B_tag CMPLD14; /* offset: 0x0098 size: 16 bit */
8941  /* Comparator Load Register 2 */
8942  mcTIMER_CMPLD2_16B_tag CMPLD24; /* offset: 0x009A size: 16 bit */
8943  /* Compare and Capture Control Register */
8944  mcTIMER_CCCTRL_16B_tag CCCTRL4; /* offset: 0x009C size: 16 bit */
8945  /* Input Filter Register */
8946  mcTIMER_FILT_16B_tag FILT4; /* offset: 0x009E size: 16 bit */
8947  /* Compare Register 1 */
8948  mcTIMER_COMP1_16B_tag COMP15; /* offset: 0x00A0 size: 16 bit */
8949  /* Compare Register 2 */
8950  mcTIMER_COMP2_16B_tag COMP25; /* offset: 0x00A2 size: 16 bit */
8951  /* Capture Register 1 */
8952  mcTIMER_CAPT1_16B_tag CAPT15; /* offset: 0x00A4 size: 16 bit */
8953  /* Capture Register 2 */
8954  mcTIMER_CAPT2_16B_tag CAPT25; /* offset: 0x00A6 size: 16 bit */
8955  /* Load Register */
8956  mcTIMER_LOAD_16B_tag LOAD5; /* offset: 0x00A8 size: 16 bit */
8957  /* Hold Register */
8958  mcTIMER_HOLD_16B_tag HOLD5; /* offset: 0x00AA size: 16 bit */
8959  /* Counter Register */
8960  mcTIMER_CNTR_16B_tag CNTR5; /* offset: 0x00AC size: 16 bit */
8961  /* Control Register */
8962  mcTIMER_CTRL1_16B_tag CTRL15; /* offset: 0x00AE size: 16 bit */
8963  /* Control Register 2 */
8964  mcTIMER_CTRL2_16B_tag CTRL25; /* offset: 0x00B0 size: 16 bit */
8965  /* Control Register 3 */
8966  mcTIMER_CTRL3_16B_tag CTRL35; /* offset: 0x00B2 size: 16 bit */
8967  /* Status Register */
8968  mcTIMER_STS_16B_tag STS5; /* offset: 0x00B4 size: 16 bit */
8969  /* Interrupt and DMA Enable Register */
8970  mcTIMER_INTDMA_16B_tag INTDMA5; /* offset: 0x00B6 size: 16 bit */
8971  /* Comparator Load Register 1 */
8972  mcTIMER_CMPLD1_16B_tag CMPLD15; /* offset: 0x00B8 size: 16 bit */
8973  /* Comparator Load Register 2 */
8974  mcTIMER_CMPLD2_16B_tag CMPLD25; /* offset: 0x00BA size: 16 bit */
8975  /* Compare and Capture Control Register */
8976  mcTIMER_CCCTRL_16B_tag CCCTRL5; /* offset: 0x00BC size: 16 bit */
8977  /* Input Filter Register */
8978  mcTIMER_FILT_16B_tag FILT5; /* offset: 0x00BE size: 16 bit */
8979  };
8980
8981  };
8982  int8_t mcTIMER_reserved_00C0[64];
8983  /* Watchdog Time-out Register */
8984  mcTIMER_WDTOL_16B_tag WDTOL; /* offset: 0x0100 size: 16 bit */
8985  /* Watchdog Time-out Register */
8986  mcTIMER_WDTOH_16B_tag WDTOH; /* offset: 0x0102 size: 16 bit */
8987  /* Fault Control Register */
8988  mcTIMER_FCTRL_16B_tag FCTRL; /* offset: 0x0104 size: 16 bit */
8989  /* Fault Status Register */
8990  mcTIMER_FSTS_16B_tag FSTS; /* offset: 0x0106 size: 16 bit */
8991  /* Fault Filter Registers */
8992  mcTIMER_FFILT_16B_tag FFILT; /* offset: 0x0108 size: 16 bit */
8993  int8_t mcTIMER_reserved_010A[2];
8994  /* Channel Enable Registers */
8995  mcTIMER_ENBL_16B_tag ENBL; /* offset: 0x010C size: 16 bit */
8996  int8_t mcTIMER_reserved_010E_C[2];
8997  union {
8998  mcTIMER_DREQ_16B_tag DREQ[4]; /* offset: 0x0110 (0x0002 x 4) */
8999
9000  struct {
9001  /* DMA Request 0 Select Registers */
9002  mcTIMER_DREQ0_16B_tag DREQ0; /* offset: 0x0110 size: 16 bit */
9003  /* DMA Request 1 Select Registers */
9004  mcTIMER_DREQ1_16B_tag DREQ1; /* offset: 0x0112 size: 16 bit */
9005  /* DMA Request 2 Select Registers */
9006  mcTIMER_DREQ2_16B_tag DREQ2; /* offset: 0x0114 size: 16 bit */
9007  /* DMA Request 3 Select Registers */
9008  mcTIMER_DREQ3_16B_tag DREQ3; /* offset: 0x0116 size: 16 bit */
9009  };
9010
9011  };
9012  } mcTIMER_tag;
9013
9014
9015 #define mcTIMER0 (*(volatile mcTIMER_tag *) 0xFFE18000UL)
9016 #define mcTIMER1 (*(volatile mcTIMER_tag *) 0xFFE1C000UL)
9017 #define mcTIMER2 (*(volatile mcTIMER_tag *) 0xFFE20000UL)
9018
9019
9020
9021 /****************************************************************/
9022 /* */
9023 /* Module: mcPWM */
9024 /* */
9025 /****************************************************************/
9026
9027
9028  /* Register layout for all registers CNT... */
9029
9030  typedef union { /* Counter Register */
9031  uint16_t R;
9033
9034
9035  /* Register layout for all registers INIT... */
9036
9037  typedef union { /* Initial Counter Register */
9038  uint16_t R;
9040
9041
9042  /* Register layout for all registers CTRL2... */
9043
9044  typedef union { /* Control 2 Register */
9045  uint16_t R;
9046  struct {
9047  uint16_t DBGEN:1; /* Debug Enable */
9048  uint16_t WAITEN:1; /* Wait Enable */
9049  uint16_t INDEP:1; /* Independent or Complementary Pair Operation */
9050 #ifndef USE_FIELD_ALIASES_mcPWM
9051  uint16_t PWM23_INIT:1; /* PWM23 Initial Value */
9052 #else
9053  uint16_t PWMA_INIT:1; /* deprecated name - please avoid */
9054 #endif
9055 #ifndef USE_FIELD_ALIASES_mcPWM
9056  uint16_t PWM45_INIT:1; /* PWM23 Initial Value */
9057 #else
9058  uint16_t PWMB_INIT:1; /* deprecated name - please avoid */
9059 #endif
9060  uint16_t PWMX_INIT:1; /* PWMX Initial Value */
9061  uint16_t INIT_SEL:2; /* Initialization Control Select */
9062  uint16_t FRCEN:1; /* Force Initialization enable */
9063  uint16_t FORCE:1; /* Force Initialization */
9064  uint16_t FORCE_SEL:3; /* Force Source Select */
9065  uint16_t RELOAD_SEL:1; /* Reload Source Select */
9066  uint16_t CLK_SEL:2; /* Clock Source Select */
9067  } B;
9069
9070
9071  /* Register layout for all registers CTRL1... */
9072
9073  typedef union { /* Control Register */
9074  uint16_t R;
9075  struct {
9076  uint16_t LDFQ:4; /* Load Frequency */
9077  uint16_t HALF:1; /* Half Cycle Reload */
9078  uint16_t FULL:1; /* Full Cycle Reload */
9079  uint16_t DT:2; /* Deadtime */
9080  uint16_t:1;
9081  uint16_t PRSC:3; /* Prescaler */
9082  uint16_t:1;
9083  uint16_t LDMOD:1; /* Load Mode Select */
9084  uint16_t:1;
9085 #ifndef USE_FIELD_ALIASES_mcPWM
9086  uint16_t DBL_EN:1; /* Double Switching Enable */
9087 #else
9088  uint16_t DBLEN:1; /* deprecated name - please avoid */
9089 #endif
9090  } B;
9092
9093
9094  /* Register layout for all registers VAL_0... */
9095
9096  typedef union { /* Value Register 0 */
9097  uint16_t R;
9099
9100
9101  /* Register layout for all registers VAL_1... */
9102
9103  typedef union { /* Value Register 1 */
9104  uint16_t R;
9106
9107
9108  /* Register layout for all registers VAL_2... */
9109
9110  typedef union { /* Value Register 2 */
9111  uint16_t R;
9113
9114
9115  /* Register layout for all registers VAL_3... */
9116
9117  typedef union { /* Value Register 3 */
9118  uint16_t R;
9120
9121
9122  /* Register layout for all registers VAL_4... */
9123
9124  typedef union { /* Value Register 4 */
9125  uint16_t R;
9127
9128
9129  /* Register layout for all registers VAL_5... */
9130
9131  typedef union { /* Value Register 5 */
9132  uint16_t R;
9134
9135  /* Register layout for all registers OCTRL... */
9136
9137  typedef union { /* Output Control Register */
9138  uint16_t R;
9139  struct {
9140  uint16_t PWMA_IN:1; /* PWMA Input */
9141  uint16_t PWMB_IN:1; /* PWMB Input */
9142  uint16_t PWMX_IN:1; /* PWMX Input */
9143  uint16_t:2;
9144  uint16_t POLA:1; /* PWMA Output Polarity */
9145  uint16_t POLB:1; /* PWMB Output Polarity */
9146  uint16_t POLX:1; /* PWMX Output Polarity */
9147  uint16_t:2;
9148  uint16_t PWMAFS:2; /* PWMA Fault State */
9149  uint16_t PWMBFS:2; /* PWMB Fault State */
9150  uint16_t PWMXFS:2; /* PWMX Fault State */
9151  } B;
9153
9154
9155  /* Register layout for all registers STS... */
9156
9157  typedef union { /* Status Register */
9158  uint16_t R;
9159  struct {
9160  uint16_t:1;
9161  uint16_t RUF:1; /* Registers Updated Flag */
9162  uint16_t REF:1; /* Reload Error Flag */
9163  uint16_t RF:1; /* Reload Flag */
9164  uint16_t CFA1:1; /* Capture Flag A1 */
9165  uint16_t CFA0:1; /* Capture Flag A0 */
9166  uint16_t CFB1:1; /* Capture Flag B1 */
9167  uint16_t CFB0:1; /* Capture Flag B0 */
9168  uint16_t CFX1:1; /* Capture Flag X1 */
9169  uint16_t CFX0:1; /* Capture Flag X0 */
9170  uint16_t CMPF:6; /* Compare Flags */
9171  } B;
9173
9174
9175  /* Register layout for all registers INTEN... */
9176
9177  typedef union { /* Interrupt Enable Registers */
9178  uint16_t R;
9179  struct {
9180  uint16_t:2;
9181  uint16_t REIE:1; /* Reload Error Interrupt Enable */
9182  uint16_t RIE:1; /* Reload Interrupt Enable */
9183  uint16_t CA1IE:1; /* Capture A1 Interrupt Enable */
9184  uint16_t CA0IE:1; /* Capture A0 Interrupt Enable */
9185  uint16_t CB1IE:1; /* Capture B1 Interrupt Enable */
9186  uint16_t CB0IE:1; /* Capture B0 Interrupt Enable */
9187  uint16_t CX1IE:1; /* Capture X1 Interrupt Enable */
9188  uint16_t CX0IE:1; /* Capture X0 Interrupt Enable */
9189  uint16_t CMPIE:6; /* Compare Interrupt Enables */
9190  } B;
9192
9193
9194  /* Register layout for all registers DMAEN... */
9195
9196  typedef union { /* DMA Enable Registers */
9197  uint16_t R;
9198  struct {
9199  uint16_t:6;
9200  uint16_t VALDE:1; /* Value Register DMA Enable */
9201  uint16_t FAND:1; /* FIFO Watermark AND Control */
9202  uint16_t CAPTDE:2; /* Capture DMA Enable Source Select */
9203  uint16_t CA1DE:1; /* Capture A1 FIFO DMA Enable */
9204  uint16_t CA0DE:1; /* Capture A0 FIFO DMA Enable */
9205  uint16_t CB1DE:1; /* Capture B1 FIFO DMA Enable */
9206  uint16_t CB0DE:1; /* Capture B0 FIFO DMA Enable */
9207  uint16_t CX1DE:1; /* Capture X1 FIFO DMA Enable */
9208  uint16_t CX0DE:1; /* Capture X0 FIFO DMA Enable */
9209  } B;
9211
9212
9213  /* Register layout for all registers TCTRL... */
9214
9215  typedef union { /* Output Trigger Control Registers */
9216  uint16_t R;
9217  struct {
9218  uint16_t:10;
9219  uint16_t OUT_TRIG_EN:6; /* Output Trigger Enables */
9220  } B;
9222
9223
9224  /* Register layout for all registers DISMAP... */
9225
9226  typedef union { /* Fault Disable Mapping Registers */
9227  uint16_t R;
9228  struct {
9229  uint16_t:4;
9230  uint16_t DISX:4; /* PWMX Fault Disable Mask */
9231  uint16_t DISB:4; /* PWMB Fault Disable Mask */
9232  uint16_t DISA:4; /* PWMA Fault Disable Mask */
9233  } B;
9235
9236
9237  /* Register layout for all registers DTCNT0... */
9238
9239  typedef union { /* Deadtime Count Register 0 */
9240  uint16_t R;
9241  struct {
9242  uint16_t:5;
9243  uint16_t DTCNT0:11; /* Deadtime Count Register 0 */
9244  } B;
9246
9247
9248  /* Register layout for all registers DTCNT1... */
9249
9250  typedef union { /* Deadtime Count Register 1 */
9251  uint16_t R;
9252  struct {
9253  uint16_t:5;
9254  uint16_t DTCNT1:11; /* Deadtime Count Register 1 */
9255  } B;
9257
9258  /* Register layout for all registers CAPTCTRLX... */
9259
9260  typedef union { /* Capture Control X Register */
9261  uint16_t R;
9262  struct {
9263  uint16_t CX1CNT:3; /* Capture X1 FIFO Word Count */
9264  uint16_t CX0CNT:3; /* Capture X0 FIFO Word Count */
9265  uint16_t CFXWM:2; /* Capture X FIFOs Water Mark */
9266 #ifndef USE_FIELD_ALIASES_mcPWM
9267  uint16_t EDGCNTXEN:1; /* Edge Counter X Enable */
9268 #else
9269  uint16_t EDGCNTX_EN:1; /* deprecated name - please avoid */
9270 #endif
9271 #ifndef USE_FIELD_ALIASES_mcPWM
9272  uint16_t INPSELX:1; /* Input Select X */
9273 #else
9274  uint16_t INP_SELX:1; /* deprecated name - please avoid */
9275 #endif
9276  uint16_t EDGX1:2; /* Edge X 1 */
9277  uint16_t EDGX0:2; /* Edge X 0 */
9278  uint16_t ONESHOTX:1; /* One Shot Mode X */
9279  uint16_t ARMX:1; /* Arm X */
9280  } B;
9282
9283
9284  /* Register layout for all registers CAPTCMPX... */
9285
9286  typedef union { /* Capture Compare X Register */
9287  uint16_t R;
9288  struct {
9289  uint16_t EDGCNTX:8; /* Edge Counter X */
9290  uint16_t EDGCMPX:8; /* Edge Compare X */
9291  } B;
9293
9294
9295  /* Register layout for all registers CVAL0... */
9296
9297  typedef union { /* Capture Value 0 Register */
9298  uint16_t R;
9299  struct {
9300  uint16_t CAPTVAL0:16; /* Captured value from submodule counter */
9301  } B;
9303
9304
9305  /* Register layout for all registers CVAL0CYC... */
9306
9307  typedef union { /* Capture Value 0 Cycle Register */
9308  uint16_t R;
9309  struct {
9310  uint16_t:12;
9311  uint16_t CVAL0CYC:4; /* Capture Value 0 Cycle */
9312  } B;
9314
9315
9316  /* Register layout for all registers CVAL1... */
9317
9318  typedef union { /* Capture Value 1 Register */
9319  uint16_t R;
9320  struct {
9321  uint16_t CAPTVAL1:16; /* Captured value from submodule counter */
9322  } B;
9324
9325
9326  /* Register layout for all registers CVAL1CYC... */
9327
9328  typedef union { /* Capture Value 1 Cycle Register */
9329  uint16_t R;
9330  struct {
9331  uint16_t:12;
9332  uint16_t CVAL1CYC:4; /* Capture Value 1 Cycle */
9333  } B;
9335
9336
9337  /* Register layout for all registers CVAL3... */
9338
9339  typedef union { /* Capture Value 3 Register */
9340  uint16_t R;
9341  struct {
9342  uint16_t CAPTVAL3:16; /* Captured value from submodule counter */
9343  } B;
9345
9346
9347  /* Register layout for all registers CVAL3CYC... */
9348
9349  typedef union { /* Capture Value 3 Cycle Register */
9350  uint16_t R;
9351  struct {
9352  uint16_t:12;
9353  uint16_t CVAL3CYC:4; /* Capture Value 3 Cycle */
9354  } B;
9356
9357
9358  /* Register layout for all registers CVAL4... */
9359
9360  typedef union { /* Capture Value 4 Register */
9361  uint16_t R;
9362  struct {
9363  uint16_t CAPTVAL4:16; /* Captured value from submodule counter */
9364  } B;
9366
9367
9368  /* Register layout for all registers CVAL4CYC... */
9369
9370  typedef union { /* Capture Value 4 Cycle Register */
9371  uint16_t R;
9372  struct {
9373  uint16_t:12;
9374  uint16_t CVAL4CYC:4; /* Capture Value 4 Cycle */
9375  } B;
9377
9378
9379  /* Register layout for all registers CVAL5... */
9380
9381  typedef union { /* Capture Value 5 Register */
9382  uint16_t R;
9383  struct {
9384  uint16_t CAPTVAL5:16; /* Captured value from submodule counter */
9385  } B;
9387
9388
9389  /* Register layout for all registers CVAL5CYC... */
9390
9391  typedef union { /* Capture Value 5 Cycle Register */
9392  uint16_t R;
9393  struct {
9394  uint16_t:12;
9395  uint16_t CVAL5CYC:4; /* Capture Value 5 Cycle */
9396  } B;
9398
9399  typedef union { /* Output Enable Register */
9400  uint16_t R;
9401  struct {
9402  uint16_t:4;
9403  uint16_t PWMA_EN:4; /* PWMA Output Enables */
9404  uint16_t PWMB_EN:4; /* PWMB Output Enables */
9405  uint16_t PWMX_EN:4; /* PWMX Output Enables */
9406  } B;
9408
9409  typedef union { /* Mask Register */
9410  uint16_t R;
9411  struct {
9412  uint16_t:4;
9413  uint16_t MASKA:4; /* PWMA Masks */
9414  uint16_t MASKB:4; /* PWMB Masks */
9415  uint16_t MASKX:4; /* PWMX Masks */
9416  } B;
9418
9419  typedef union { /* Software Controlled Output Register */
9420  uint16_t R;
9421  struct {
9422  uint16_t:8;
9423 #ifndef USE_FIELD_ALIASES_mcPWM
9424  uint16_t OUT23_3:1; /* Software Controlled Output 23_3 */
9425 #else
9426  uint16_t OUTA_3:1; /* deprecated name - please avoid */
9427 #endif
9428 #ifndef USE_FIELD_ALIASES_mcPWM
9429  uint16_t OUT45_3:1; /* Software Controlled Output 45_3 */
9430 #else
9431  uint16_t OUTB_3:1; /* deprecated name - please avoid */
9432 #endif
9433 #ifndef USE_FIELD_ALIASES_mcPWM
9434  uint16_t OUT23_2:1; /* Software Controlled Output 23_2 */
9435 #else
9436  uint16_t OUTA_2:1; /* deprecated name - please avoid */
9437 #endif
9438 #ifndef USE_FIELD_ALIASES_mcPWM
9439  uint16_t OUT45_2:1; /* Software Controlled Output 45_2 */
9440 #else
9441  uint16_t OUTB_2:1; /* deprecated name - please avoid */
9442 #endif
9443 #ifndef USE_FIELD_ALIASES_mcPWM
9444  uint16_t OUT23_1:1; /* Software Controlled Output 23_1 */
9445 #else
9446  uint16_t OUTA_1:1; /* deprecated name - please avoid */
9447 #endif
9448 #ifndef USE_FIELD_ALIASES_mcPWM
9449  uint16_t OUT45_1:1; /* Software Controlled Output 45_1 */
9450 #else
9451  uint16_t OUTB_1:1; /* deprecated name - please avoid */
9452 #endif
9453 #ifndef USE_FIELD_ALIASES_mcPWM
9454  uint16_t OUT23_0:1; /* Software Controlled Output 23_0 */
9455 #else
9456  uint16_t OUTA_0:1; /* deprecated name - please avoid */
9457 #endif
9458 #ifndef USE_FIELD_ALIASES_mcPWM
9459  uint16_t OUT45_0:1; /* Software Controlled Output 45_0 */
9460 #else
9461  uint16_t OUTB_0:1; /* deprecated name - please avoid */
9462 #endif
9463  } B;
9465
9466  typedef union { /* Deadtime Source Select Register */
9467  uint16_t R;
9468  struct {
9469 #ifndef USE_FIELD_ALIASES_mcPWM
9470  uint16_t SEL23_3:2; /* PWM23_3 Control Select */
9471 #else
9472  uint16_t SELA_3:2; /* deprecated name - please avoid */
9473 #endif
9474 #ifndef USE_FIELD_ALIASES_mcPWM
9475  uint16_t SEL45_3:2; /* PWM45_3 Control Select */
9476 #else
9477  uint16_t SELB_3:2; /* deprecated name - please avoid */
9478 #endif
9479 #ifndef USE_FIELD_ALIASES_mcPWM
9480  uint16_t SEL23_2:2; /* PWM23_2 Control Select */
9481 #else
9482  uint16_t SELA_2:2; /* deprecated name - please avoid */
9483 #endif
9484 #ifndef USE_FIELD_ALIASES_mcPWM
9485  uint16_t SEL45_2:2; /* PWM45_2 Control Select */
9486 #else
9487  uint16_t SELB_2:2; /* deprecated name - please avoid */
9488 #endif
9489 #ifndef USE_FIELD_ALIASES_mcPWM
9490  uint16_t SEL23_1:2; /* PWM23_1 Control Select */
9491 #else
9492  uint16_t SELA_1:2; /* deprecated name - please avoid */
9493 #endif
9494 #ifndef USE_FIELD_ALIASES_mcPWM
9495  uint16_t SEL45_1:2; /* PWM45_1 Control Select */
9496 #else
9497  uint16_t SELB_1:2; /* deprecated name - please avoid */
9498 #endif
9499 #ifndef USE_FIELD_ALIASES_mcPWM
9500  uint16_t SEL23_0:2; /* PWM23_0 Control Select */
9501 #else
9502  uint16_t SELA_0:2; /* deprecated name - please avoid */
9503 #endif
9504 #ifndef USE_FIELD_ALIASES_mcPWM
9505  uint16_t SEL45_0:2; /* PWM45_0 Control Select */
9506 #else
9507  uint16_t SELB_0:2; /* deprecated name - please avoid */
9508 #endif
9509  } B;
9511
9512  typedef union { /* Master Control Register */
9513  uint16_t R;
9514  struct {
9515  uint16_t IPOL:4; /* Current Polarity */
9516  uint16_t RUN:4; /* Run */
9517 #ifndef USE_FIELD_ALIASES_mcPWM
9518  uint16_t CLOK:4; /* Clear Load Okay */
9519 #else
9520  uint16_t CLDOK:4; /* deprecated name - please avoid */
9521 #endif
9522  uint16_t LDOK:4; /* Load Okay */
9523  } B;
9525
9526  typedef union { /* Fault Control Register */
9527  uint16_t R;
9528  struct {
9529  uint16_t FLVL:4; /* Fault Level */
9530  uint16_t FAUTO:4; /* Automatic Fault Clearing */
9531  uint16_t FSAFE:4; /* Fault Safety Mode */
9532  uint16_t FIE:4; /* Fault Interrupt Enables */
9533  } B;
9535
9536  typedef union { /* Fault Status Register */
9537  uint16_t R;
9538  struct {
9539  uint16_t:3;
9540  uint16_t FTEST:1; /* Fault Test */
9541  uint16_t FFPIN:4; /* Filtered Fault Pins */
9542  uint16_t:4;
9543  uint16_t FFLAG:4; /* Fault Flags */
9544  } B;
9546
9547  typedef union { /* Fault Filter Register */
9548  uint16_t R;
9549  struct {
9550  uint16_t:5;
9551  uint16_t FILT_CNT:3; /* Fault Filter Count */
9552  uint16_t FILT_PER:8; /* Fault Filter Period */
9553  } B;
9555
9556
9557  /* Register layout for generated register(s) VAL... */
9558
9559  typedef union { /* */
9560  uint16_t R;
9562
9563
9564  typedef struct mcPWM_SUBMOD_struct_tag {
9565
9566  /* Counter Register */
9567  mcPWM_CNT_16B_tag CNT; /* relative offset: 0x0000 */
9568  /* Initial Counter Register */
9569  mcPWM_INIT_16B_tag INIT; /* relative offset: 0x0002 */
9570  /* Control 2 Register */
9571  mcPWM_CTRL2_16B_tag CTRL2; /* relative offset: 0x0004 */
9572  union {
9573  /* Control Register */
9574  mcPWM_CTRL1_16B_tag CTRL1; /* relative offset: 0x0006 */
9575  mcPWM_CTRL1_16B_tag CTRL; /* deprecated - please avoid */
9576  };
9577  /* Value Register 0 */
9578
9579  union {
9580
9581  struct {
9582
9583  mcPWM_VAL_0_16B_tag VAL_0; /* relative offset: 0x0008 */
9584  /* Value Register 1 */
9585  mcPWM_VAL_1_16B_tag VAL_1; /* relative offset: 0x000A */
9586  /* Value Register 2 */
9587  mcPWM_VAL_2_16B_tag VAL_2; /* relative offset: 0x000C */
9588  /* Value Register 3 */
9589  mcPWM_VAL_3_16B_tag VAL_3; /* relative offset: 0x000E */
9590  /* Value Register 4 */
9591  mcPWM_VAL_4_16B_tag VAL_4; /* relative offset: 0x0010 */
9592  /* Value Register 5 */
9593  mcPWM_VAL_5_16B_tag VAL_5; /* relative offset: 0x0012 */
9594
9595  };
9596
9597  mcPWM_VAL_0_16B_tag VAL[6]; /* offset: 0x0008 size: 16 bit */
9598
9599  };
9600  int8_t mcPWM_reserved_0014[4];
9601  /* Output Control Register */
9602  mcPWM_OCTRL_16B_tag OCTRL; /* relative offset: 0x0018 */
9603  /* Status Register */
9604  mcPWM_STS_16B_tag STS; /* relative offset: 0x001A */
9605  /* Interrupt Enable Registers */
9606  mcPWM_INTEN_16B_tag INTEN; /* relative offset: 0x001C */
9607  /* DMA Enable Registers */
9608  mcPWM_DMAEN_16B_tag DMAEN; /* relative offset: 0x001E */
9609  /* Output Trigger Control Registers */
9610  mcPWM_TCTRL_16B_tag TCTRL; /* relative offset: 0x0020 */
9611  /* Fault Disable Mapping Registers */
9612  mcPWM_DISMAP_16B_tag DISMAP; /* relative offset: 0x0022 */
9613  /* Deadtime Count Register 0 */
9614  mcPWM_DTCNT0_16B_tag DTCNT0; /* relative offset: 0x0024 */
9615  /* Deadtime Count Register 1 */
9616  mcPWM_DTCNT1_16B_tag DTCNT1; /* relative offset: 0x0026 */
9617  /* Capture Control A Register */
9618  int8_t mcPWM_reserved_0028[8];
9619  /* Capture Control X Register */
9620  mcPWM_CAPTCTRLX_16B_tag CAPTCTRLX; /* relative offset: 0x0030 */
9621  union {
9622  /* Capture Compare X Register */
9623  mcPWM_CAPTCMPX_16B_tag CAPTCMPX; /* relative offset: 0x0032 */
9624  mcPWM_CAPTCMPX_16B_tag CAPTCOMPX; /* deprecated - please avoid */
9625  };
9626  /* Capture Value 0 Register */
9627  mcPWM_CVAL0_16B_tag CVAL0; /* relative offset: 0x0034 */
9628  union {
9629  /* Capture Value 0 Cycle Register */
9630  mcPWM_CVAL0CYC_16B_tag CVAL0CYC; /* relative offset: 0x0036 */
9631  mcPWM_CVAL0CYC_16B_tag CVAL0C; /* deprecated - please avoid */
9632  };
9633  /* Capture Value 1 Register */
9634  mcPWM_CVAL1_16B_tag CVAL1; /* relative offset: 0x0038 */
9635  union {
9636  /* Capture Value 1 Cycle Register */
9637  mcPWM_CVAL1CYC_16B_tag CVAL1CYC; /* relative offset: 0x003A */
9638  mcPWM_CVAL1CYC_16B_tag CVAL1C; /* deprecated - please avoid */
9639  };
9640  /* Capture Value 2 Register */
9641  int8_t mcPWM_SUBMOD_reserved_003C[16];
9642  int8_t mcPWM_SUBMOD_reserved_004C[4];
9643
9644  } mcPWM_SUBMOD_tag;
9645
9646
9647  typedef struct mcPWM_struct_tag { /* start of mcPWM_tag */
9648  union {
9649  /* Register set SUBMOD */
9650  mcPWM_SUBMOD_tag SUBMOD[4]; /* offset: 0x0000 (0x0050 x 4) */
9651
9652  mcPWM_SUBMOD_tag SUB[4]; /* offset: 0x0000 (0x0050 x 4) */
9653
9654  struct {
9655  /* Counter Register */
9656  mcPWM_CNT_16B_tag CNT0; /* offset: 0x0000 size: 16 bit */
9657  /* Initial Counter Register */
9658  mcPWM_INIT_16B_tag INIT0; /* offset: 0x0002 size: 16 bit */
9659  /* Control 2 Register */
9660  mcPWM_CTRL2_16B_tag CTRL20; /* offset: 0x0004 size: 16 bit */
9661  /* Control Register */
9662  mcPWM_CTRL1_16B_tag CTRL10; /* offset: 0x0006 size: 16 bit */
9663  /* Value Register 0 */
9664  mcPWM_VAL_0_16B_tag VAL_00; /* offset: 0x0008 size: 16 bit */
9665  /* Value Register 1 */
9666  mcPWM_VAL_1_16B_tag VAL_10; /* offset: 0x000A size: 16 bit */
9667  /* Value Register 2 */
9668  mcPWM_VAL_2_16B_tag VAL_20; /* offset: 0x000C size: 16 bit */
9669  /* Value Register 3 */
9670  mcPWM_VAL_3_16B_tag VAL_30; /* offset: 0x000E size: 16 bit */
9671  /* Value Register 4 */
9672  mcPWM_VAL_4_16B_tag VAL_40; /* offset: 0x0010 size: 16 bit */
9673  /* Value Register 5 */
9674  mcPWM_VAL_5_16B_tag VAL_50; /* offset: 0x0012 size: 16 bit */
9675  int8_t mcPWM_reserved_0014[4];
9676  /* Output Control Register */
9677  mcPWM_OCTRL_16B_tag OCTRL0; /* offset: 0x0018 size: 16 bit */
9678  /* Status Register */
9679  mcPWM_STS_16B_tag STS0; /* offset: 0x001A size: 16 bit */
9680  /* Interrupt Enable Registers */
9681  mcPWM_INTEN_16B_tag INTEN0; /* offset: 0x001C size: 16 bit */
9682  /* DMA Enable Registers */
9683  mcPWM_DMAEN_16B_tag DMAEN0; /* offset: 0x001E size: 16 bit */
9684  /* Output Trigger Control Registers */
9685  mcPWM_TCTRL_16B_tag TCTRL0; /* offset: 0x0020 size: 16 bit */
9686  /* Fault Disable Mapping Registers */
9687  mcPWM_DISMAP_16B_tag DISMAP0; /* offset: 0x0022 size: 16 bit */
9688  /* Deadtime Count Register 0 */
9689  mcPWM_DTCNT0_16B_tag DTCNT00; /* offset: 0x0024 size: 16 bit */
9690  /* Deadtime Count Register 1 */
9691  mcPWM_DTCNT1_16B_tag DTCNT10; /* offset: 0x0026 size: 16 bit */
9692  int8_t mcPWM_reserved_0028[8];
9693  /* Capture Control X Register */
9694  mcPWM_CAPTCTRLX_16B_tag CAPTCTRLX0; /* offset: 0x0030 size: 16 bit */
9695  /* Capture Compare X Register */
9696  mcPWM_CAPTCMPX_16B_tag CAPTCMPX0; /* offset: 0x0032 size: 16 bit */
9697  /* Capture Value 0 Register */
9698  mcPWM_CVAL0_16B_tag CVAL00; /* offset: 0x0034 size: 16 bit */
9699  /* Capture Value 0 Cycle Register */
9700  mcPWM_CVAL0CYC_16B_tag CVAL0CYC0; /* offset: 0x0036 size: 16 bit */
9701  /* Capture Value 1 Register */
9702  mcPWM_CVAL1_16B_tag CVAL10; /* offset: 0x0038 size: 16 bit */
9703  /* Capture Value 1 Cycle Register */
9704  mcPWM_CVAL1CYC_16B_tag CVAL1CYC0; /* offset: 0x003A size: 16 bit */
9705  int8_t mcPWM_reserved_003c[16];
9706  int8_t mcPWM_reserved_004C_I2[4];
9707  /* Counter Register */
9708  mcPWM_CNT_16B_tag CNT1; /* offset: 0x0050 size: 16 bit */
9709  /* Initial Counter Register */
9710  mcPWM_INIT_16B_tag INIT1; /* offset: 0x0052 size: 16 bit */
9711  /* Control 2 Register */
9712  mcPWM_CTRL2_16B_tag CTRL21; /* offset: 0x0054 size: 16 bit */
9713  /* Control Register */
9714  mcPWM_CTRL1_16B_tag CTRL11; /* offset: 0x0056 size: 16 bit */
9715  /* Value Register 0 */
9716  mcPWM_VAL_0_16B_tag VAL_01; /* offset: 0x0058 size: 16 bit */
9717  /* Value Register 1 */
9718  mcPWM_VAL_1_16B_tag VAL_11; /* offset: 0x005A size: 16 bit */
9719  /* Value Register 2 */
9720  mcPWM_VAL_2_16B_tag VAL_21; /* offset: 0x005C size: 16 bit */
9721  /* Value Register 3 */
9722  mcPWM_VAL_3_16B_tag VAL_31; /* offset: 0x005E size: 16 bit */
9723  /* Value Register 4 */
9724  mcPWM_VAL_4_16B_tag VAL_41; /* offset: 0x0060 size: 16 bit */
9725  /* Value Register 5 */
9726  mcPWM_VAL_5_16B_tag VAL_51; /* offset: 0x0062 size: 16 bit */
9727  int8_t mcPWM_reserved_0064[4];
9728  /* Output Control Register */
9729  mcPWM_OCTRL_16B_tag OCTRL1; /* offset: 0x0068 size: 16 bit */
9730  /* Status Register */
9731  mcPWM_STS_16B_tag STS1; /* offset: 0x006A size: 16 bit */
9732  /* Interrupt Enable Registers */
9733  mcPWM_INTEN_16B_tag INTEN1; /* offset: 0x006C size: 16 bit */
9734  /* DMA Enable Registers */
9735  mcPWM_DMAEN_16B_tag DMAEN1; /* offset: 0x006E size: 16 bit */
9736  /* Output Trigger Control Registers */
9737  mcPWM_TCTRL_16B_tag TCTRL1; /* offset: 0x0070 size: 16 bit */
9738  /* Fault Disable Mapping Registers */
9739  mcPWM_DISMAP_16B_tag DISMAP1; /* offset: 0x0072 size: 16 bit */
9740  /* Deadtime Count Register 0 */
9741  mcPWM_DTCNT0_16B_tag DTCNT01; /* offset: 0x0074 size: 16 bit */
9742  /* Deadtime Count Register 1 */
9743  mcPWM_DTCNT1_16B_tag DTCNT11; /* offset: 0x0076 size: 16 bit */
9744  /* Capture Control A Register */
9745  int8_t mcPWM_reserved_0078[8];
9746  /* Capture Control X Register */
9747  mcPWM_CAPTCTRLX_16B_tag CAPTCTRLX1; /* offset: 0x0080 size: 16 bit */
9748  /* Capture Compare X Register */
9749  mcPWM_CAPTCMPX_16B_tag CAPTCMPX1; /* offset: 0x0082 size: 16 bit */
9750  /* Capture Value 0 Register */
9751  mcPWM_CVAL0_16B_tag CVAL01; /* offset: 0x0084 size: 16 bit */
9752  /* Capture Value 0 Cycle Register */
9753  mcPWM_CVAL0CYC_16B_tag CVAL0CYC1; /* offset: 0x0086 size: 16 bit */
9754  /* Capture Value 1 Register */
9755  mcPWM_CVAL1_16B_tag CVAL11; /* offset: 0x0088 size: 16 bit */
9756  /* Capture Value 1 Cycle Register */
9757  mcPWM_CVAL1CYC_16B_tag CVAL1CYC1; /* offset: 0x008A size: 16 bit */
9758  int8_t mcPWM_reserved_008c[16];
9759  int8_t mcPWM_reserved_009C_I2[4];
9760  /* Counter Register */
9761  mcPWM_CNT_16B_tag CNT2; /* offset: 0x00A0 size: 16 bit */
9762  /* Initial Counter Register */
9763  mcPWM_INIT_16B_tag INIT2; /* offset: 0x00A2 size: 16 bit */
9764  /* Control 2 Register */
9765  mcPWM_CTRL2_16B_tag CTRL22; /* offset: 0x00A4 size: 16 bit */
9766  /* Control Register */
9767  mcPWM_CTRL1_16B_tag CTRL12; /* offset: 0x00A6 size: 16 bit */
9768  /* Value Register 0 */
9769  mcPWM_VAL_0_16B_tag VAL_02; /* offset: 0x00A8 size: 16 bit */
9770  /* Value Register 1 */
9771  mcPWM_VAL_1_16B_tag VAL_12; /* offset: 0x00AA size: 16 bit */
9772  /* Value Register 2 */
9773  mcPWM_VAL_2_16B_tag VAL_22; /* offset: 0x00AC size: 16 bit */
9774  /* Value Register 3 */
9775  mcPWM_VAL_3_16B_tag VAL_32; /* offset: 0x00AE size: 16 bit */
9776  /* Value Register 4 */
9777  mcPWM_VAL_4_16B_tag VAL_42; /* offset: 0x00B0 size: 16 bit */
9778  /* Value Register 5 */
9779  mcPWM_VAL_5_16B_tag VAL_52; /* offset: 0x00B2 size: 16 bit */
9780  int8_t mcPWM_reserved_00b4[4];
9781  /* Output Control Register */
9782  mcPWM_OCTRL_16B_tag OCTRL2; /* offset: 0x00B8 size: 16 bit */
9783  /* Status Register */
9784  mcPWM_STS_16B_tag STS2; /* offset: 0x00BA size: 16 bit */
9785  /* Interrupt Enable Registers */
9786  mcPWM_INTEN_16B_tag INTEN2; /* offset: 0x00BC size: 16 bit */
9787  /* DMA Enable Registers */
9788  mcPWM_DMAEN_16B_tag DMAEN2; /* offset: 0x00BE size: 16 bit */
9789  /* Output Trigger Control Registers */
9790  mcPWM_TCTRL_16B_tag TCTRL2; /* offset: 0x00C0 size: 16 bit */
9791  /* Fault Disable Mapping Registers */
9792  mcPWM_DISMAP_16B_tag DISMAP2; /* offset: 0x00C2 size: 16 bit */
9793  /* Deadtime Count Register 0 */
9794  mcPWM_DTCNT0_16B_tag DTCNT02; /* offset: 0x00C4 size: 16 bit */
9795  /* Deadtime Count Register 1 */
9796  mcPWM_DTCNT1_16B_tag DTCNT12; /* offset: 0x00C6 size: 16 bit */
9797  /* Capture Control A Register */
9798  int8_t mcPWM_reserved_00c8[8];
9799  /* Capture Control X Register */
9800  mcPWM_CAPTCTRLX_16B_tag CAPTCTRLX2; /* offset: 0x00D0 size: 16 bit */
9801  /* Capture Compare X Register */
9802  mcPWM_CAPTCMPX_16B_tag CAPTCMPX2; /* offset: 0x00D2 size: 16 bit */
9803  /* Capture Value 0 Register */
9804  mcPWM_CVAL0_16B_tag CVAL02; /* offset: 0x00D4 size: 16 bit */
9805  /* Capture Value 0 Cycle Register */
9806  mcPWM_CVAL0CYC_16B_tag CVAL0CYC2; /* offset: 0x00D6 size: 16 bit */
9807  /* Capture Value 1 Register */
9808  mcPWM_CVAL1_16B_tag CVAL12; /* offset: 0x00D8 size: 16 bit */
9809  /* Capture Value 1 Cycle Register */
9810  mcPWM_CVAL1CYC_16B_tag CVAL1CYC2; /* offset: 0x00DA size: 16 bit */
9811  int8_t mcPWM_reserved_00dc[16];
9812  int8_t mcPWM_reserved_00EC_I2[4];
9813  /* Counter Register */
9814  mcPWM_CNT_16B_tag CNT3; /* offset: 0x00F0 size: 16 bit */
9815  /* Initial Counter Register */
9816  mcPWM_INIT_16B_tag INIT3; /* offset: 0x00F2 size: 16 bit */
9817  /* Control 2 Register */
9818  mcPWM_CTRL2_16B_tag CTRL23; /* offset: 0x00F4 size: 16 bit */
9819  /* Control Register */
9820  mcPWM_CTRL1_16B_tag CTRL13; /* offset: 0x00F6 size: 16 bit */
9821  /* Value Register 0 */
9822  mcPWM_VAL_0_16B_tag VAL_03; /* offset: 0x00F8 size: 16 bit */
9823  /* Value Register 1 */
9824  mcPWM_VAL_1_16B_tag VAL_13; /* offset: 0x00FA size: 16 bit */
9825  /* Value Register 2 */
9826  mcPWM_VAL_2_16B_tag VAL_23; /* offset: 0x00FC size: 16 bit */
9827  /* Value Register 3 */
9828  mcPWM_VAL_3_16B_tag VAL_33; /* offset: 0x00FE size: 16 bit */
9829  /* Value Register 4 */
9830  mcPWM_VAL_4_16B_tag VAL_43; /* offset: 0x0100 size: 16 bit */
9831  /* Value Register 5 */
9832  mcPWM_VAL_5_16B_tag VAL_53; /* offset: 0x0102 size: 16 bit */
9833  int8_t mcPWM_reserved_00104[4];
9834  /* Output Control Register */
9835  mcPWM_OCTRL_16B_tag OCTRL3; /* offset: 0x0108 size: 16 bit */
9836  /* Status Register */
9837  mcPWM_STS_16B_tag STS3; /* offset: 0x010A size: 16 bit */
9838  /* Interrupt Enable Registers */
9839  mcPWM_INTEN_16B_tag INTEN3; /* offset: 0x010C size: 16 bit */
9840  /* DMA Enable Registers */
9841  mcPWM_DMAEN_16B_tag DMAEN3; /* offset: 0x010E size: 16 bit */
9842  /* Output Trigger Control Registers */
9843  mcPWM_TCTRL_16B_tag TCTRL3; /* offset: 0x0110 size: 16 bit */
9844  /* Fault Disable Mapping Registers */
9845  mcPWM_DISMAP_16B_tag DISMAP3; /* offset: 0x0112 size: 16 bit */
9846  /* Deadtime Count Register 0 */
9847  mcPWM_DTCNT0_16B_tag DTCNT03; /* offset: 0x0114 size: 16 bit */
9848  /* Deadtime Count Register 1 */
9849  mcPWM_DTCNT1_16B_tag DTCNT13; /* offset: 0x0116 size: 16 bit */
9850  /* Capture Control A Register */
9851  int8_t mcPWM_reserved_00118[8];
9852  /* Capture Control X Register */
9853  mcPWM_CAPTCTRLX_16B_tag CAPTCTRLX3; /* offset: 0x0120 size: 16 bit */
9854  /* Capture Compare X Register */
9855  mcPWM_CAPTCMPX_16B_tag CAPTCMPX3; /* offset: 0x0122 size: 16 bit */
9856  /* Capture Value 0 Register */
9857  mcPWM_CVAL0_16B_tag CVAL03; /* offset: 0x0124 size: 16 bit */
9858  /* Capture Value 0 Cycle Register */
9859  mcPWM_CVAL0CYC_16B_tag CVAL0CYC3; /* offset: 0x0126 size: 16 bit */
9860  /* Capture Value 1 Register */
9861  mcPWM_CVAL1_16B_tag CVAL13; /* offset: 0x0128 size: 16 bit */
9862  /* Capture Value 1 Cycle Register */
9863  mcPWM_CVAL1CYC_16B_tag CVAL1CYC3; /* offset: 0x012A size: 16 bit */
9864  int8_t mcPWM_reserved_0012c[16];
9865  int8_t mcPWM_reserved_013C_E2[4];
9866  };
9867
9868  };
9869  /* Output Enable Register */
9870  mcPWM_OUTEN_16B_tag OUTEN; /* offset: 0x0140 size: 16 bit */
9871  /* Mask Register */
9872  mcPWM_MASK_16B_tag MASK; /* offset: 0x0142 size: 16 bit */
9873  /* Software Controlled Output Register */
9874  mcPWM_SWCOUT_16B_tag SWCOUT; /* offset: 0x0144 size: 16 bit */
9875  /* Deadtime Source Select Register */
9876  mcPWM_DTSRCSEL_16B_tag DTSRCSEL; /* offset: 0x0146 size: 16 bit */
9877  /* Master Control Register */
9878  mcPWM_MCTRL_16B_tag MCTRL; /* offset: 0x0148 size: 16 bit */
9879  int8_t mcPWM_reserved_014A[2];
9880  /* Fault Control Register */
9881  mcPWM_FCTRL_16B_tag FCTRL; /* offset: 0x014C size: 16 bit */
9882  /* Fault Status Register */
9883  mcPWM_FSTS_16B_tag FSTS; /* offset: 0x014E size: 16 bit */
9884  /* Fault Filter Register */
9885  mcPWM_FFILT_16B_tag FFILT; /* offset: 0x0150 size: 16 bit */
9886  } mcPWM_tag;
9887
9888
9889 #define mcPWM_A (*(volatile mcPWM_tag *) 0xFFE24000UL)
9890 #define mcPWM_B (*(volatile mcPWM_tag *) 0xFFE28000UL)
9891
9892
9893
9894 /****************************************************************/
9895 /* */
9896 /* Module: LINFLEX */
9897 /* */
9898 /****************************************************************/
9899
9900  typedef union { /* LIN Control Register */
9901  uint32_t R;
9902  struct {
9903  uint32_t:16;
9904  uint32_t CCD:1; /* Checksum Calculation Disable */
9905  uint32_t CFD:1; /* Checksum Field Disable */
9906  uint32_t LASE:1; /* LIN Auto Synchronization Enable */
9907 #ifndef USE_FIELD_ALIASES_LINFLEX
9908  uint32_t AUTOWU:1; /* Auto Wake Up */
9909 #else
9910  uint32_t AWUM:1; /* deprecated name - please avoid */
9911 #endif
9912  uint32_t MBL:4; /* Master Break Length */
9913  uint32_t BF:1; /* By-Pass Filter */
9914 #ifndef USE_FIELD_ALIASES_LINFLEX
9915  uint32_t SLFM:1; /* Selftest Mode */
9916 #else
9917  uint32_t SFTM:1; /* deprecated name - please avoid */
9918 #endif
9919  uint32_t LBKM:1; /* Loopback Mode */
9920  uint32_t MME:1; /* Master Mode Enable */
9921 #ifndef USE_FIELD_ALIASES_LINFLEX
9922  uint32_t SSBL:1; /* Slave Mode Synch Break Length */
9923 #else
9924  uint32_t SSDT:1; /* deprecated name - please avoid */
9925 #endif
9926  uint32_t RBLM:1; /* Receiver Buffer Locked Mode */
9927  uint32_t SLEEP:1; /* Sleep Mode Request */
9928  uint32_t INIT:1; /* Initialization Mode Request */
9929  } B;
9931
9932  typedef union { /* LIN Interrupt Enable Register */
9933  uint32_t R;
9934  struct {
9935  uint32_t:16;
9936  uint32_t SZIE:1; /* Stuck at Zero Interrupt Enable */
9937  uint32_t OCIE:1; /* Output Compare Interrupt Enable */
9938  uint32_t BEIE:1; /* Bit Error Interrupt Enable */
9939  uint32_t CEIE:1; /* Checksum Error Interrupt Enable */
9940  uint32_t HEIE:1; /* Header Error Interrupt Enable */
9941  uint32_t:2;
9942  uint32_t FEIE:1; /* Frame Error Interrupt Enable */
9943  uint32_t BOIE:1; /* Buffer Overrun Error Interrupt Enable */
9944  uint32_t LSIE:1; /* LIN State Interrupt Enable */
9945  uint32_t WUIE:1; /* Wakeup Interrupt Enable */
9946  uint32_t DBFIE:1; /* Data Buffer Full Interrupt Enable */
9947 #ifndef USE_FIELD_ALIASES_LINFLEX
9948  uint32_t DBEIE_TOIE:1; /* Data Buffer Empty Interrupt Enable */
9949 #else
9950  uint32_t DBEIE:1; /* deprecated name - please avoid */
9951 #endif
9952  uint32_t DRIE:1; /* Data Reception complete Interrupt Enable */
9953  uint32_t DTIE:1; /* Data Transmitted Interrupt Enable */
9954  uint32_t HRIE:1; /* Header Received Interrupt Enable */
9955  } B;
9957
9958  typedef union { /* LIN Status Register */
9959  uint32_t R;
9960  struct {
9961  uint32_t:16;
9962  uint32_t LINS:4; /* LIN State */
9963  uint32_t:2;
9964  uint32_t RMB:1; /* Release Message Buffer */
9965  uint32_t:1;
9966 #ifndef USE_FIELD_ALIASES_LINFLEX
9967  uint32_t RXBUSY:1; /* Receiver Busy Flag */
9968 #else
9969  uint32_t RBSY:1; /* deprecated name - please avoid */
9970 #endif
9971 #ifndef USE_FIELD_ALIASES_LINFLEX
9972  uint32_t RDI:1; /* LIN Receive Signal */
9973 #else
9974  uint32_t RPS:1; /* deprecated name - please avoid */
9975 #endif
9976  uint32_t WUF:1; /* Wake Up Flag */
9977  uint32_t DBFF:1; /* Data Buffer Full Flag */
9978  uint32_t DBEF:1; /* Data Buffer Empty Flag */
9979  uint32_t DRF:1; /* Data Reception Completed Flag */
9980  uint32_t DTF:1; /* Data Transmission Completed Flag */
9981  uint32_t HRF:1; /* Header Received Flag */
9982  } B;
9984
9985  typedef union { /* LIN Error Status Register */
9986  uint32_t R;
9987  struct {
9988  uint32_t:16;
9989  uint32_t SZF:1; /* Stuck at Zero Flag */
9990  uint32_t OCF:1; /* Output Compare Flag */
9991  uint32_t BEF:1; /* Bit Error Flag */
9992  uint32_t CEF:1; /* Checksum Error Flag */
9993  uint32_t SFEF:1; /* Sync Field Error Flag */
9994 #ifndef USE_FIELD_ALIASES_LINFLEX
9995  uint32_t SDEF:1; /* Sync Delimiter Error Flag */
9996 #else
9997  uint32_t BDEF:1; /* deprecated name - please avoid */
9998 #endif
9999  uint32_t IDPEF:1; /* ID Parity Error Flag */
10000  uint32_t FEF:1; /* Framing Error Flag */
10001  uint32_t BOF:1; /* Buffer Overrun Flag */
10002  uint32_t:6;
10003  uint32_t NF:1; /* Noise Flag */
10004  } B;
10006
10007  typedef union { /* UART Mode Control Register */
10008  uint32_t R;
10009  struct {
10010  uint32_t:16;
10011  uint32_t TDFL_TFC:3; /* Transmitter Data Field Length/TX FIFO Counter */
10012  uint32_t RDFL_RFC0:3; /* Reception Data Field Length/RX FIFO Counter */
10013  uint32_t RFBM:1; /* RX FIFO/ Buffer Mode */
10014  uint32_t TFBM:1; /* TX FIFO/ Buffer Mode */
10015  uint32_t WL1:1; /* Word Length in UART mode - bit 1 */
10016  uint32_t PC1:1; /* Parity Check - bit 1 */
10017  uint32_t RXEN:1; /* Receiver Enable */
10018  uint32_t TXEN:1; /* Transmitter Enable */
10019 #ifndef USE_FIELD_ALIASES_LINFLEX
10020  uint32_t PC0:1; /* Parity Check - bit 0 */
10021 #else
10022  uint32_t OP:1; /* deprecated name - please avoid */
10023 #endif
10024  uint32_t PCE:1; /* Parity Control Enable */
10025 #ifndef USE_FIELD_ALIASES_LINFLEX
10026  uint32_t WL0:1; /* Word Length in UART Mode - bit 0 */
10027 #else
10028  uint32_t WL:1; /* deprecated name - please avoid */
10029 #endif
10030  uint32_t UART:1; /* UART Mode */
10031  } B;
10033
10034  typedef union { /* UART Mode Status Register */
10035  uint32_t R;
10036  struct {
10037  uint32_t:16;
10038  uint32_t SZF:1; /* Stuck at Zero Flag */
10039  uint32_t OCF:1; /* Output Compare Flag */
10040  uint32_t PE:4; /* Parity Error Flag */
10041  uint32_t RMB:1; /* Release Message Buffer */
10042  uint32_t FEF:1; /* Framing Error Flag */
10043  uint32_t BOF:1; /* Buffer Overrun Flag */
10044  uint32_t RDI:1; /* Receiver Data Input Signal */
10045  uint32_t WUF:1; /* Wakeup Flag */
10046  uint32_t:1;
10047  uint32_t TO:1; /* Time Out */
10048 #ifndef USE_FIELD_ALIASES_LINFLEX
10049  uint32_t DRF_RFE:1; /* Data Reception Completed Flag/RX FIFO Empty Flag */
10050 #else
10051  uint32_t DRF:1; /* deprecated name - please avoid */
10052 #endif
10053 #ifndef USE_FIELD_ALIASES_LINFLEX
10054  uint32_t DTF_TFF:1; /* Data Transmission Completed Flag/TX FIFO Full Flag */
10055 #else
10056  uint32_t DTF:1; /* deprecated name - please avoid */
10057 #endif
10058  uint32_t NF:1; /* Noise Flag */
10059  } B;
10061
10062  typedef union { /* LIN Time-Out Control Status Register */
10063  uint32_t R;
10064  struct {
10065  uint32_t:21;
10066 #ifndef USE_FIELD_ALIASES_LINFLEX
10067  uint32_t MODE:1; /* Time-out Counter Mode */
10068 #else
10069  uint32_t LTOM:1; /* deprecated name - please avoid */
10070 #endif
10071  uint32_t IOT:1; /* Idle on Timeout */
10072  uint32_t TOCE:1; /* Time-Out Counter Enable */
10073  uint32_t CNT:8; /* Counter Value */
10074  } B;
10076
10077  typedef union { /* LIN Output Compare Register */
10078  uint32_t R;
10079  struct {
10080  uint32_t:16;
10081  uint32_t OC2:8; /* Output Compare Value 2 */
10082  uint32_t OC1:8; /* Output Compare Value 1 */
10083  } B;
10085
10086  typedef union { /* LIN Time-Out Control Register */
10087  uint32_t R;
10088  struct {
10089  uint32_t:20;
10090  uint32_t RTO:4; /* Response Time-Out Value */
10091  uint32_t:1;
10092  uint32_t HTO:7; /* Header Time-Out Value */
10093  } B;
10095
10096  typedef union { /* LIN Fractional Baud Rate Register */
10097  uint32_t R;
10098  struct {
10099  uint32_t:28;
10100 #ifndef USE_FIELD_ALIASES_LINFLEX
10101  uint32_t FBR:4; /* Fractional Baud Rates */
10102 #else
10103  uint32_t DIV_F:4; /* deprecated name - please avoid */
10104 #endif
10105  } B;
10107
10108  typedef union { /* LIN Integer Baud Rate Register */
10109  uint32_t R;
10110  struct {
10111  uint32_t:13;
10112 #ifndef USE_FIELD_ALIASES_LINFLEX
10113  uint32_t IBR:19; /* Integer Baud Rates */
10114 #else
10115  uint32_t DIV_M:19; /* deprecated name - please avoid */
10116 #endif
10117  } B;
10119
10120  typedef union { /* LIN Checksum Field Register */
10121  uint32_t R;
10122  struct {
10123  uint32_t:24;
10124  uint32_t CF:8; /* Checksum Bits */
10125  } B;
10127
10128  typedef union { /* LIN Control Register 2 */
10129  uint32_t R;
10130  struct {
10131  uint32_t:17;
10132  uint32_t IOBE:1; /* Idle on Bit Error */
10133  uint32_t IOPE:1; /* Idle on Identifier Parity Error */
10134  uint32_t WURQ:1; /* Wakeup Generate Request */
10135  uint32_t DDRQ:1; /* Data Discard Request */
10136  uint32_t DTRQ:1; /* Data Transmission Request */
10137  uint32_t ABRQ:1; /* Abort Request */
10138  uint32_t HTRQ:1; /* Header Transmission Request */
10139  uint32_t:8;
10140  } B;
10142
10143  typedef union { /* Buffer Identifier Register */
10144  uint32_t R;
10145  struct {
10146  uint32_t:16;
10147  uint32_t DFL:6; /* Data Field Length */
10148  uint32_t DIR:1; /* Direction */
10149  uint32_t CCS:1; /* Classic Checksum */
10150  uint32_t:2;
10151  uint32_t ID:6; /* Identifier */
10152  } B;
10154
10155  typedef union { /* Buffer Data Register Least Significant */
10156  uint32_t R;
10157  struct {
10158  uint32_t DATA3:8; /* Data3 */
10159  uint32_t DATA2:8; /* Data2 */
10160  uint32_t DATA1:8; /* Data1 */
10161  uint32_t DATA0:8; /* Data0 */
10162  } B;
10164
10165  typedef union { /* Buffer Data Register Most Significant */
10166  uint32_t R;
10167  struct {
10168  uint32_t DATA7:8; /* Data7 */
10169  uint32_t DATA6:8; /* Data6 */
10170  uint32_t DATA5:8; /* Data5 */
10171  uint32_t DATA4:8; /* Data4 */
10172  } B;
10174
10175  typedef union { /* Identifier Filter Enable Register */
10176  uint32_t R;
10177  struct {
10178  uint32_t:24;
10179  uint32_t FACT:8; /* Filter Active */
10180  } B;
10182
10183  typedef union { /* Identifier Filter Match Index */
10184  uint32_t R;
10185  struct {
10186  uint32_t:28;
10187  uint32_t IFMI_IFMI:4; /* Filter Match Index */
10188  } B;
10190
10191  typedef union { /* Identifier Filter Mode Register */
10192  uint32_t R;
10193  struct {
10194  uint32_t:28;
10195  uint32_t IFM:4; /* Filter Mode */
10196  } B;
10198
10199
10200  /* Register layout for all registers IFCR... */
10201
10202  typedef union { /* Identifier Filter Control Register */
10203  uint32_t R;
10204  struct {
10205  uint32_t:16;
10206  uint32_t DFL:6; /* Data Field Length */
10207  uint32_t DIR:1; /* Direction */
10208  uint32_t CCS:1; /* Classic Checksum */
10209  uint32_t:2;
10210  uint32_t ID:6; /* Identifier */
10211  } B;
10213
10214  typedef union { /* Global Control Register */
10215  uint32_t R;
10216  struct {
10217  uint32_t:26;
10218  uint32_t TDFBM:1; /* Transmit Data First Bit MSB */
10219  uint32_t RDFBM:1; /* Received Data First Bit MSB */
10220  uint32_t TDLIS:1; /* Transmit Data Level Inversion Selection */
10221  uint32_t RDLIS:1; /* Received Data Level Inversion Selection */
10222  uint32_t STOP:1; /* 1/2 stop bit configuration */
10223  uint32_t SR:1; /* Soft Reset */
10224  } B;
10226
10227  typedef union { /* UART Preset Time Out Register */
10228  uint32_t R;
10229  struct {
10230  uint32_t:20;
10231  uint32_t PTO:12; /* Preset Time Out */
10232  } B;
10234
10235  typedef union { /* UART Current Time Out Register */
10236  uint32_t R;
10237  struct {
10238  uint32_t:20;
10239  uint32_t CTO:12; /* Current Time Out */
10240  } B;
10242
10243  typedef union { /* DMA TX Enable Register */
10244  uint32_t R;
10245  struct {
10246  uint32_t:17;
10247  uint32_t DTE:15; /* DMA Tx channel Enable */
10248  } B;
10250
10251  typedef union { /* DMA RX Enable Register */
10252  uint32_t R;
10253  struct {
10254  uint32_t:17;
10255  uint32_t DRE:15; /* DMA Rx channel Enable */
10256  } B;
10258
10259
10260
10261  typedef struct LINFLEX_struct_tag { /* start of LINFLEX_tag */
10262  /* LIN Control Register */
10263  LINFLEX_LINCR1_32B_tag LINCR1; /* offset: 0x0000 size: 32 bit */
10264  /* LIN Interrupt Enable Register */
10265  LINFLEX_LINIER_32B_tag LINIER; /* offset: 0x0004 size: 32 bit */
10266  /* LIN Status Register */
10267  LINFLEX_LINSR_32B_tag LINSR; /* offset: 0x0008 size: 32 bit */
10268  /* LIN Error Status Register */
10269  LINFLEX_LINESR_32B_tag LINESR; /* offset: 0x000C size: 32 bit */
10270  /* UART Mode Control Register */
10271  LINFLEX_UARTCR_32B_tag UARTCR; /* offset: 0x0010 size: 32 bit */
10272  /* UART Mode Status Register */
10273  LINFLEX_UARTSR_32B_tag UARTSR; /* offset: 0x0014 size: 32 bit */
10274  /* LIN Time-Out Control Status Register */
10275  LINFLEX_LINTCSR_32B_tag LINTCSR; /* offset: 0x0018 size: 32 bit */
10276  /* LIN Output Compare Register */
10277  LINFLEX_LINOCR_32B_tag LINOCR; /* offset: 0x001C size: 32 bit */
10278  /* LIN Time-Out Control Register */
10279  LINFLEX_LINTOCR_32B_tag LINTOCR; /* offset: 0x0020 size: 32 bit */
10280  /* LIN Fractional Baud Rate Register */
10281  LINFLEX_LINFBRR_32B_tag LINFBRR; /* offset: 0x0024 size: 32 bit */
10282  /* LIN Integer Baud Rate Register */
10283  LINFLEX_LINIBRR_32B_tag LINIBRR; /* offset: 0x0028 size: 32 bit */
10284  /* LIN Checksum Field Register */
10285  LINFLEX_LINCFR_32B_tag LINCFR; /* offset: 0x002C size: 32 bit */
10286  /* LIN Control Register 2 */
10287  LINFLEX_LINCR2_32B_tag LINCR2; /* offset: 0x0030 size: 32 bit */
10288  /* Buffer Identifier Register */
10289  LINFLEX_BIDR_32B_tag BIDR; /* offset: 0x0034 size: 32 bit */
10290  /* Buffer Data Register Least Significant */
10291  LINFLEX_BDRL_32B_tag BDRL; /* offset: 0x0038 size: 32 bit */
10292  /* Buffer Data Register Most Significant */
10293  LINFLEX_BDRM_32B_tag BDRM; /* offset: 0x003C size: 32 bit */
10294  /* Identifier Filter Enable Register */
10295  LINFLEX_IFER_32B_tag IFER; /* offset: 0x0040 size: 32 bit */
10296  /* Identifier Filter Match Index */
10297  LINFLEX_IFMI_32B_tag IFMI; /* offset: 0x0044 size: 32 bit */
10298  /* Identifier Filter Mode Register */
10299  LINFLEX_IFMR_32B_tag IFMR; /* offset: 0x0048 size: 32 bit */
10300  union {
10301  /* Identifier Filter Control Register */
10302  LINFLEX_IFCR_32B_tag IFCR[8]; /* offset: 0x004C (0x0004 x 8) */
10303
10304  struct {
10305  /* Identifier Filter Control Register */
10306  LINFLEX_IFCR_32B_tag IFCR0; /* offset: 0x004C size: 32 bit */
10307  LINFLEX_IFCR_32B_tag IFCR1; /* offset: 0x0050 size: 32 bit */
10308  LINFLEX_IFCR_32B_tag IFCR2; /* offset: 0x0054 size: 32 bit */
10309  LINFLEX_IFCR_32B_tag IFCR3; /* offset: 0x0058 size: 32 bit */
10310  LINFLEX_IFCR_32B_tag IFCR4; /* offset: 0x005C size: 32 bit */
10311  LINFLEX_IFCR_32B_tag IFCR5; /* offset: 0x0060 size: 32 bit */
10312  LINFLEX_IFCR_32B_tag IFCR6; /* offset: 0x0064 size: 32 bit */
10313  LINFLEX_IFCR_32B_tag IFCR7; /* offset: 0x0068 size: 32 bit */
10314  };
10315
10316  };
10317  int8_t LINFLEX_reserved_006C[32];
10318  /* Global Control Register */
10319  LINFLEX_GCR_32B_tag GCR; /* offset: 0x008C size: 32 bit */
10320  /* UART Preset Time Out Register */
10321  LINFLEX_UARTPTO_32B_tag UARTPTO; /* offset: 0x0090 size: 32 bit */
10322  /* UART Current Time Out Register */
10323  LINFLEX_UARTCTO_32B_tag UARTCTO; /* offset: 0x0094 size: 32 bit */
10324  /* DMA TX Enable Register */
10325  LINFLEX_DMATXE_32B_tag DMATXE; /* offset: 0x0098 size: 32 bit */
10326  /* DMA RX Enable Register */
10327  LINFLEX_DMARXE_32B_tag DMARXE; /* offset: 0x009C size: 32 bit */
10328  } LINFLEX_tag;
10329
10330
10331 #define LINFLEX0 (*(volatile LINFLEX_tag *) 0xFFE40000UL)
10332 #define LINFLEX1 (*(volatile LINFLEX_tag *) 0xFFE44000UL)
10333
10334
10335
10336 /****************************************************************/
10337 /* */
10338 /* Module: CRC */
10339 /* */
10340 /****************************************************************/
10341
10342
10343  /* Register layout for all registers CFG... */
10344
10345  typedef union { /* CRC_CFG - CRC Configuration register */
10346  uint32_t R;
10347  uint8_t BYTE[4]; /* individual bytes can be accessed */
10348  uint16_t HALF[2]; /* individual halfwords can be accessed */
10349  uint32_t WORD; /* individual words can be accessed */
10350  struct {
10351  uint32_t:29;
10352  uint32_t POLYG:1; /* Polynomal selection 0- CRC-CCITT, 1- CRC-CRC-32 INV selection */
10353  uint32_t SWAP:1; /* SWAP selection */
10354  uint32_t INV:1; /* INV selection */
10355  } B;
10356  } CRC_CFG_32B_tag;
10357
10358
10359  /* Register layout for all registers INP... */
10360
10361  typedef union { /* CRC_INP - CRC Input register */
10362  uint32_t R;
10363  uint8_t BYTE[4]; /* individual bytes can be accessed */
10364  uint16_t HALF[2]; /* individual halfwords can be accessed */
10365  uint32_t WORD; /* individual words can be accessed */
10366  } CRC_INP_32B_tag;
10367
10368
10369  /* Register layout for all registers CSTAT... */
10370
10371  typedef union { /* CRC_STATUS - CRC Status register */
10372  uint32_t R;
10373  uint8_t BYTE[4]; /* individual bytes can be accessed */
10374  uint16_t HALF[2]; /* individual halfwords can be accessed */
10375  uint32_t WORD; /* individual words can be accessed */
10377
10378
10379  /* Register layout for all registers OUTP... */
10380
10381  typedef union { /* CRC_STATUS - CRC OUTPUT register */
10382  uint32_t R;
10383  uint8_t BYTE[4]; /* individual bytes can be accessed */
10384  uint16_t HALF[2]; /* individual halfwords can be accessed */
10385  uint32_t WORD; /* individual words can be accessed */
10386  } CRC_OUTP_32B_tag;
10387
10388
10389  typedef struct CRC_CNTX_struct_tag {
10390
10391  /* CRC_CFG - CRC Configuration register */
10392  CRC_CFG_32B_tag CFG; /* relative offset: 0x0000 */
10393  /* CRC_INP - CRC Input register */
10394  CRC_INP_32B_tag INP; /* relative offset: 0x0004 */
10395  /* CRC_STATUS - CRC Status register */
10396  CRC_CSTAT_32B_tag CSTAT; /* relative offset: 0x0008 */
10397  /* CRC_STATUS - CRC OUTPUT register */
10398  CRC_OUTP_32B_tag OUTP; /* relative offset: 0x000C */
10399
10400  } CRC_CNTX_tag;
10401
10402
10403  typedef struct CRC_struct_tag { /* start of CRC_tag */
10404  union {
10405  /* Register set CNTX */
10406  CRC_CNTX_tag CNTX[3]; /* offset: 0x0000 (0x0010 x 3) */
10407
10408  struct {
10409  /* CRC_CFG - CRC Configuration register */
10410  CRC_CFG_32B_tag CFG0; /* offset: 0x0000 size: 32 bit */
10411  /* CRC_INP - CRC Input register */
10412  CRC_INP_32B_tag INP0; /* offset: 0x0004 size: 32 bit */
10413  /* CRC_STATUS - CRC Status register */
10414  CRC_CSTAT_32B_tag CSTAT0; /* offset: 0x0008 size: 32 bit */
10415  /* CRC_STATUS - CRC OUTPUT register */
10416  CRC_OUTP_32B_tag OUTP0; /* offset: 0x000C size: 32 bit */
10417  /* CRC_CFG - CRC Configuration register */
10418  CRC_CFG_32B_tag CFG1; /* offset: 0x0010 size: 32 bit */
10419  /* CRC_INP - CRC Input register */
10420  CRC_INP_32B_tag INP1; /* offset: 0x0014 size: 32 bit */
10421  /* CRC_STATUS - CRC Status register */
10422  CRC_CSTAT_32B_tag CSTAT1; /* offset: 0x0018 size: 32 bit */
10423  /* CRC_STATUS - CRC OUTPUT register */
10424  CRC_OUTP_32B_tag OUTP1; /* offset: 0x001C size: 32 bit */
10425  /* CRC_CFG - CRC Configuration register */
10426  CRC_CFG_32B_tag CFG2; /* offset: 0x0020 size: 32 bit */
10427  /* CRC_INP - CRC Input register */
10428  CRC_INP_32B_tag INP2; /* offset: 0x0024 size: 32 bit */
10429  /* CRC_STATUS - CRC Status register */
10430  CRC_CSTAT_32B_tag CSTAT2; /* offset: 0x0028 size: 32 bit */
10431  /* CRC_STATUS - CRC OUTPUT register */
10432  CRC_OUTP_32B_tag OUTP2; /* offset: 0x002C size: 32 bit */
10433  };
10434
10435  };
10436  } CRC_tag;
10437
10438
10439 #define CRC (*(volatile CRC_tag *) 0xFFE68000UL)
10440
10441
10442
10443 /****************************************************************/
10444 /* */
10445 /* Module: FCCU */
10446 /* */
10447 /****************************************************************/
10448
10449  typedef union { /* FCCU Control Register */
10450  uint32_t R;
10451  struct {
10452  uint32_t:23;
10453  uint32_t NVML:1; /* NVM configuration loaded */
10454  uint32_t OPS:2; /* Operation status */
10455  uint32_t:1;
10456  uint32_t OPR:5; /* Operation run */
10457  } B;
10459
10460  typedef union { /* FCCU CTRL Key Register */
10461  uint32_t R;
10463
10464  typedef union { /* FCCU Configuration Register */
10465  uint32_t R;
10466  struct {
10467  uint32_t:10;
10468  uint32_t RCCE1:1; /* RCC1 enable */
10469  uint32_t RCCE0:1; /* RCC0 enable */
10470  uint32_t SMRT:4; /* Safe Mode Request Timer */
10471  uint32_t:4;
10472  uint32_t CM:1; /* Config mode */
10473  uint32_t SM:1; /* Switching mode */
10474  uint32_t PS:1; /* Polarity Selection */
10475  uint32_t FOM:3; /* Fault Output Mode Selection */
10476  uint32_t FOP:6; /* Fault Output Prescaler */
10477  } B;
10478  } FCCU_CFG_32B_tag;
10479
10480  typedef union { /* FCCU CF Configuration Register 0 */
10481  uint32_t R;
10482  struct {
10483  uint32_t CFC31:1; /* CF 31 configuration */
10484  uint32_t CFC30:1; /* CF 30 configuration */
10485  uint32_t CFC29:1; /* CF 29 configuration */
10486  uint32_t CFC28:1; /* CF 28 configuration */
10487  uint32_t CFC27:1; /* CF 27 configuration */
10488  uint32_t CFC26:1; /* CF 26 configuration */
10489  uint32_t CFC25:1; /* CF 25 configuration */
10490  uint32_t CFC24:1; /* CF 24 configuration */
10491  uint32_t CFC23:1; /* CF 23 configuration */
10492  uint32_t CFC22:1; /* CF 22 configuration */
10493  uint32_t CFC21:1; /* CF 21 configuration */
10494  uint32_t CFC20:1; /* CF 20 configuration */
10495  uint32_t CFC19:1; /* CF 19 configuration */
10496  uint32_t CFC18:1; /* CF 18 configuration */
10497  uint32_t CFC17:1; /* CF 17 configuration */
10498  uint32_t CFC16:1; /* CF 16 configuration */
10499  uint32_t CFC15:1; /* CF 15 configuration */
10500  uint32_t CFC14:1; /* CF 14 configuration */
10501  uint32_t CFC13:1; /* CF 13 configuration */
10502  uint32_t CFC12:1; /* CF 12 configuration */
10503  uint32_t CFC11:1; /* CF 11 configuration */
10504  uint32_t CFC10:1; /* CF 10 configuration */
10505  uint32_t CFC9:1; /* CF 9 configuration */
10506  uint32_t CFC8:1; /* CF 8 configuration */
10507  uint32_t CFC7:1; /* CF 7 configuration */
10508  uint32_t CFC6:1; /* CF 6 configuration */
10509  uint32_t CFC5:1; /* CF 5 configuration */
10510  uint32_t CFC4:1; /* CF 4 configuration */
10511  uint32_t CFC3:1; /* CF 3 configuration */
10512  uint32_t CFC2:1; /* CF 2 configuration */
10513  uint32_t CFC1:1; /* CF 1 configuration */
10514  uint32_t CFC0:1; /* CF 0 configuration */
10515  } B;
10517
10518  typedef union { /* FCCU CF Configuration Register 1 */
10519  uint32_t R;
10520  struct {
10521  uint32_t CFC63:1; /* CF 63 configuration */
10522  uint32_t CFC62:1; /* CF 62 configuration */
10523  uint32_t CFC61:1; /* CF 61 configuration */
10524  uint32_t CFC60:1; /* CF 60 configuration */
10525  uint32_t CFC59:1; /* CF 59 configuration */
10526  uint32_t CFC58:1; /* CF 58 configuration */
10527  uint32_t CFC57:1; /* CF 57 configuration */
10528  uint32_t CFC56:1; /* CF 56 configuration */
10529  uint32_t CFC55:1; /* CF 55 configuration */
10530  uint32_t CFC54:1; /* CF 54 configuration */
10531  uint32_t CFC53:1; /* CF 53 configuration */
10532  uint32_t CFC52:1; /* CF 52 configuration */
10533  uint32_t CFC51:1; /* CF 51 configuration */
10534  uint32_t CFC50:1; /* CF 50 configuration */
10535  uint32_t CFC49:1; /* CF 49 configuration */
10536  uint32_t CFC48:1; /* CF 48 configuration */
10537  uint32_t CFC47:1; /* CF 47 configuration */
10538  uint32_t CFC46:1; /* CF 46 configuration */
10539  uint32_t CFC45:1; /* CF 45 configuration */
10540  uint32_t CFC44:1; /* CF 44 configuration */
10541  uint32_t CFC43:1; /* CF 43 configuration */
10542  uint32_t CFC42:1; /* CF 42 configuration */
10543  uint32_t CFC41:1; /* CF 41 configuration */
10544  uint32_t CFC40:1; /* CF 40 configuration */
10545  uint32_t CFC39:1; /* CF 39 configuration */
10546  uint32_t CFC38:1; /* CF 38 configuration */
10547  uint32_t CFC37:1; /* CF 37 configuration */
10548  uint32_t CFC36:1; /* CF 36 configuration */
10549  uint32_t CFC35:1; /* CF 35 configuration */
10550  uint32_t CFC34:1; /* CF 34 configuration */
10551  uint32_t CFC33:1; /* CF 33 configuration */
10552  uint32_t CFC32:1; /* CF 32 configuration */
10553  } B;
10555
10556  typedef union { /* FCCU CF Configuration Register 2 */
10557  uint32_t R;
10558  struct {
10559  uint32_t CFC95:1; /* CF 95 configuration */
10560  uint32_t CFC94:1; /* CF 94 configuration */
10561  uint32_t CFC93:1; /* CF 93 configuration */
10562  uint32_t CFC92:1; /* CF 92 configuration */
10563  uint32_t CFC91:1; /* CF 91 configuration */
10564  uint32_t CFC90:1; /* CF 90 configuration */
10565  uint32_t CFC89:1; /* CF 89 configuration */
10566  uint32_t CFC88:1; /* CF 88 configuration */
10567  uint32_t CFC87:1; /* CF 87 configuration */
10568  uint32_t CFC86:1; /* CF 86 configuration */
10569  uint32_t CFC85:1; /* CF 85 configuration */
10570  uint32_t CFC84:1; /* CF 84 configuration */
10571  uint32_t CFC83:1; /* CF 83 configuration */
10572  uint32_t CFC82:1; /* CF 82 configuration */
10573  uint32_t CFC81:1; /* CF 81 configuration */
10574  uint32_t CFC80:1; /* CF 80 configuration */
10575  uint32_t CFC79:1; /* CF 79 configuration */
10576  uint32_t CFC78:1; /* CF 78 configuration */
10577  uint32_t CFC77:1; /* CF 77 configuration */
10578  uint32_t CFC76:1; /* CF 76 configuration */
10579  uint32_t CFC75:1; /* CF 75 configuration */
10580  uint32_t CFC74:1; /* CF 74 configuration */
10581  uint32_t CFC73:1; /* CF 73 configuration */
10582  uint32_t CFC72:1; /* CF 72 configuration */
10583  uint32_t CFC71:1; /* CF 71 configuration */
10584  uint32_t CFC70:1; /* CF 70 configuration */
10585  uint32_t CFC69:1; /* CF 69 configuration */
10586  uint32_t CFC68:1; /* CF 68 configuration */
10587  uint32_t CFC67:1; /* CF 67 configuration */
10588  uint32_t CFC66:1; /* CF 66 configuration */
10589  uint32_t CFC65:1; /* CF 65 configuration */
10590  uint32_t CFC64:1; /* CF 64 configuration */
10591  } B;
10593
10594  typedef union { /* FCCU CF Configuration Register 3 */
10595  uint32_t R;
10596  struct {
10597  uint32_t CFC127:1; /* CF 127 configuration */
10598  uint32_t CFC126:1; /* CF 126 configuration */
10599  uint32_t CFC125:1; /* CF 125 configuration */
10600  uint32_t CFC124:1; /* CF 124 configuration */
10601  uint32_t CFC123:1; /* CF 123 configuration */
10602  uint32_t CFC122:1; /* CF 122 configuration */
10603  uint32_t CFC121:1; /* CF 121 configuration */
10604  uint32_t CFC120:1; /* CF 120 configuration */
10605  uint32_t CFC119:1; /* CF 119 configuration */
10606  uint32_t CFC118:1; /* CF 118 configuration */
10607  uint32_t CFC117:1; /* CF 117 configuration */
10608  uint32_t CFC116:1; /* CF 116 configuration */
10609  uint32_t CFC115:1; /* CF 115 configuration */
10610  uint32_t CFC114:1; /* CF 114 configuration */
10611  uint32_t CFC113:1; /* CF 113 configuration */
10612  uint32_t CFC112:1; /* CF 112 configuration */
10613  uint32_t CFC111:1; /* CF 111 configuration */
10614  uint32_t CFC110:1; /* CF 110 configuration */
10615  uint32_t CFC109:1; /* CF 109 configuration */
10616  uint32_t CFC108:1; /* CF 108 configuration */
10617  uint32_t CFC107:1; /* CF 107 configuration */
10618  uint32_t CFC106:1; /* CF 106 configuration */
10619  uint32_t CFC105:1; /* CF 105 configuration */
10620  uint32_t CFC104:1; /* CF 104 configuration */
10621  uint32_t CFC103:1; /* CF 103 configuration */
10622  uint32_t CFC102:1; /* CF 102 configuration */
10623  uint32_t CFC101:1; /* CF 101 configuration */
10624  uint32_t CFC100:1; /* CF 100 configuration */
10625  uint32_t CFC99:1; /* CF 99 configuration */
10626  uint32_t CFC98:1; /* CF 98 configuration */
10627  uint32_t CFC97:1; /* CF 97 configuration */
10628  uint32_t CFC96:1; /* CF 96 configuration */
10629  } B;
10631
10632  typedef union { /* FCCU NCF Configuration Register 0 */
10633  uint32_t R;
10634  struct {
10635  uint32_t NCFC31:1; /* NCF 31 configuration */
10636  uint32_t NCFC30:1; /* NCF 30 configuration */
10637  uint32_t NCFC29:1; /* NCF 29 configuration */
10638  uint32_t NCFC28:1; /* NCF 28 configuration */
10639  uint32_t NCFC27:1; /* NCF 27 configuration */
10640  uint32_t NCFC26:1; /* NCF 26 configuration */
10641  uint32_t NCFC25:1; /* NCF 25 configuration */
10642  uint32_t NCFC24:1; /* NCF 24 configuration */
10643  uint32_t NCFC23:1; /* NCF 23 configuration */
10644  uint32_t NCFC22:1; /* NCF 22 configuration */
10645  uint32_t NCFC21:1; /* NCF 21 configuration */
10646  uint32_t NCFC20:1; /* NCF 20 configuration */
10647  uint32_t NCFC19:1; /* NCF 19 configuration */
10648  uint32_t NCFC18:1; /* NCF 18 configuration */
10649  uint32_t NCFC17:1; /* NCF 17 configuration */
10650  uint32_t NCFC16:1; /* NCF 16 configuration */
10651  uint32_t NCFC15:1; /* NCF 15 configuration */
10652  uint32_t NCFC14:1; /* NCF 14 configuration */
10653  uint32_t NCFC13:1; /* NCF 13 configuration */
10654  uint32_t NCFC12:1; /* NCF 12 configuration */
10655  uint32_t NCFC11:1; /* NCF 11 configuration */
10656  uint32_t NCFC10:1; /* NCF 10 configuration */
10657  uint32_t NCFC9:1; /* NCF 9 configuration */
10658  uint32_t NCFC8:1; /* NCF 8 configuration */
10659  uint32_t NCFC7:1; /* NCF 7 configuration */
10660  uint32_t NCFC6:1; /* NCF 6 configuration */
10661  uint32_t NCFC5:1; /* NCF 5 configuration */
10662  uint32_t NCFC4:1; /* NCF 4 configuration */
10663  uint32_t NCFC3:1; /* NCF 3 configuration */
10664  uint32_t NCFC2:1; /* NCF 2 configuration */
10665  uint32_t NCFC1:1; /* NCF 1 configuration */
10666  uint32_t NCFC0:1; /* NCF 0 configuration */
10667  } B;
10669
10670  typedef union { /* FCCU NCF Configuration Register 1 */
10671  uint32_t R;
10672  struct {
10673  uint32_t NCFC63:1; /* NCF 63 configuration */
10674  uint32_t NCFC62:1; /* NCF 62 configuration */
10675  uint32_t NCFC61:1; /* NCF 61 configuration */
10676  uint32_t NCFC60:1; /* NCF 60 configuration */
10677  uint32_t NCFC59:1; /* NCF 59 configuration */
10678  uint32_t NCFC58:1; /* NCF 58 configuration */
10679  uint32_t NCFC57:1; /* NCF 57 configuration */
10680  uint32_t NCFC56:1; /* NCF 56 configuration */
10681  uint32_t NCFC55:1; /* NCF 55 configuration */
10682  uint32_t NCFC54:1; /* NCF 54 configuration */
10683  uint32_t NCFC53:1; /* NCF 53 configuration */
10684  uint32_t NCFC52:1; /* NCF 52 configuration */
10685  uint32_t NCFC51:1; /* NCF 51 configuration */
10686  uint32_t NCFC50:1; /* NCF 50 configuration */
10687  uint32_t NCFC49:1; /* NCF 49 configuration */
10688  uint32_t NCFC48:1; /* NCF 48 configuration */
10689  uint32_t NCFC47:1; /* NCF 47 configuration */
10690  uint32_t NCFC46:1; /* NCF 46 configuration */
10691  uint32_t NCFC45:1; /* NCF 45 configuration */
10692  uint32_t NCFC44:1; /* NCF 44 configuration */
10693  uint32_t NCFC43:1; /* NCF 43 configuration */
10694  uint32_t NCFC42:1; /* NCF 42 configuration */
10695  uint32_t NCFC41:1; /* NCF 41 configuration */
10696  uint32_t NCFC40:1; /* NCF 40 configuration */
10697  uint32_t NCFC39:1; /* NCF 39 configuration */
10698  uint32_t NCFC38:1; /* NCF 38 configuration */
10699  uint32_t NCFC37:1; /* NCF 37 configuration */
10700  uint32_t NCFC36:1; /* NCF 36 configuration */
10701  uint32_t NCFC35:1; /* NCF 35 configuration */
10702  uint32_t NCFC34:1; /* NCF 34 configuration */
10703  uint32_t NCFC33:1; /* NCF 33 configuration */
10704  uint32_t NCFC32:1; /* NCF 32 configuration */
10705  } B;
10707
10708  typedef union { /* FCCU NCF Configuration Register 2 */
10709  uint32_t R;
10710  struct {
10711  uint32_t NCFC95:1; /* NCF 95 configuration */
10712  uint32_t NCFC94:1; /* NCF 94 configuration */
10713  uint32_t NCFC93:1; /* NCF 93 configuration */
10714  uint32_t NCFC92:1; /* NCF 92 configuration */
10715  uint32_t NCFC91:1; /* NCF 91 configuration */
10716  uint32_t NCFC90:1; /* NCF 90 configuration */
10717  uint32_t NCFC89:1; /* NCF 89 configuration */
10718  uint32_t NCFC88:1; /* NCF 88 configuration */
10719  uint32_t NCFC87:1; /* NCF 87 configuration */
10720  uint32_t NCFC86:1; /* NCF 86 configuration */
10721  uint32_t NCFC85:1; /* NCF 85 configuration */
10722  uint32_t NCFC84:1; /* NCF 84 configuration */
10723  uint32_t NCFC83:1; /* NCF 83 configuration */
10724  uint32_t NCFC82:1; /* NCF 82 configuration */
10725  uint32_t NCFC81:1; /* NCF 81 configuration */
10726  uint32_t NCFC80:1; /* NCF 80 configuration */
10727  uint32_t NCFC79:1; /* NCF 79 configuration */
10728  uint32_t NCFC78:1; /* NCF 78 configuration */
10729  uint32_t NCFC77:1; /* NCF 77 configuration */
10730  uint32_t NCFC76:1; /* NCF 76 configuration */
10731  uint32_t NCFC75:1; /* NCF 75 configuration */
10732  uint32_t NCFC74:1; /* NCF 74 configuration */
10733  uint32_t NCFC73:1; /* NCF 73 configuration */
10734  uint32_t NCFC72:1; /* NCF 72 configuration */
10735  uint32_t NCFC71:1; /* NCF 71 configuration */
10736  uint32_t NCFC70:1; /* NCF 70 configuration */
10737  uint32_t NCFC69:1; /* NCF 69 configuration */
10738  uint32_t NCFC68:1; /* NCF 68 configuration */
10739  uint32_t NCFC67:1; /* NCF 67 configuration */
10740  uint32_t NCFC66:1; /* NCF 66 configuration */
10741  uint32_t NCFC65:1; /* NCF 65 configuration */
10742  uint32_t NCFC64:1; /* NCF 64 configuration */
10743  } B;
10745
10746  typedef union { /* FCCU NCF Configuration Register 3 */
10747  uint32_t R;
10748  struct {
10749  uint32_t NCFC127:1; /* NCF 127 configuration */
10750  uint32_t NCFC126:1; /* NCF 126 configuration */
10751  uint32_t NCFC125:1; /* NCF 125 configuration */
10752  uint32_t NCFC124:1; /* NCF 124 configuration */
10753  uint32_t NCFC123:1; /* NCF 123 configuration */
10754  uint32_t NCFC122:1; /* NCF 122 configuration */
10755  uint32_t NCFC121:1; /* NCF 121 configuration */
10756  uint32_t NCFC120:1; /* NCF 120 configuration */
10757  uint32_t NCFC119:1; /* NCF 119 configuration */
10758  uint32_t NCFC118:1; /* NCF 118 configuration */
10759  uint32_t NCFC117:1; /* NCF 117 configuration */
10760  uint32_t NCFC116:1; /* NCF 116 configuration */
10761  uint32_t NCFC115:1; /* NCF 115 configuration */
10762  uint32_t NCFC114:1; /* NCF 114 configuration */
10763  uint32_t NCFC113:1; /* NCF 113 configuration */
10764  uint32_t NCFC112:1; /* NCF 112 configuration */
10765  uint32_t NCFC111:1; /* NCF 111 configuration */
10766  uint32_t NCFC110:1; /* NCF 110 configuration */
10767  uint32_t NCFC109:1; /* NCF 109 configuration */
10768  uint32_t NCFC108:1; /* NCF 108 configuration */
10769  uint32_t NCFC107:1; /* NCF 107 configuration */
10770  uint32_t NCFC106:1; /* NCF 106 configuration */
10771  uint32_t NCFC105:1; /* NCF 105 configuration */
10772  uint32_t NCFC104:1; /* NCF 104 configuration */
10773  uint32_t NCFC103:1; /* NCF 103 configuration */
10774  uint32_t NCFC102:1; /* NCF 102 configuration */
10775  uint32_t NCFC101:1; /* NCF 101 configuration */
10776  uint32_t NCFC100:1; /* NCF 100 configuration */
10777  uint32_t NCFC99:1; /* NCF 99 configuration */
10778  uint32_t NCFC98:1; /* NCF 98 configuration */
10779  uint32_t NCFC97:1; /* NCF 97 configuration */
10780  uint32_t NCFC96:1; /* NCF 96 configuration */
10781  } B;
10783
10784  typedef union { /* FCCU CFS Configuration Register 0 */
10785  uint32_t R;
10786  struct {
10787  uint32_t CFSC15:2; /* CF 15 state configuration */
10788  uint32_t CFSC14:2; /* CF 14 state configuration */
10789  uint32_t CFSC13:2; /* CF 13 state configuration */
10790  uint32_t CFSC12:2; /* CF 12 state configuration */
10791  uint32_t CFSC11:2; /* CF 11 state configuration */
10792  uint32_t CFSC10:2; /* CF 10 state configuration */
10793  uint32_t CFSC9:2; /* CF 9 state configuration */
10794  uint32_t CFSC8:2; /* CF 8 state configuration */
10795  uint32_t CFSC7:2; /* CF 7 state configuration */
10796  uint32_t CFSC6:2; /* CF 6 state configuration */
10797  uint32_t CFSC5:2; /* CF 5 state configuration */
10798  uint32_t CFSC4:2; /* CF 4 state configuration */
10799  uint32_t CFSC3:2; /* CF 3 state configuration */
10800  uint32_t CFSC2:2; /* CF 2 state configuration */
10801  uint32_t CFSC1:2; /* CF 1 state configuration */
10802  uint32_t CFSC0:2; /* CF 0 state configuration */
10803  } B;
10805
10806  typedef union { /* FCCU CFS Configuration Register 1 */
10807  uint32_t R;
10808  struct {
10809  uint32_t CFSC31:2; /* CF 31 state configuration */
10810  uint32_t CFSC30:2; /* CF 30 state configuration */
10811  uint32_t CFSC29:2; /* CF 29 state configuration */
10812  uint32_t CFSC28:2; /* CF 28 state configuration */
10813  uint32_t CFSC27:2; /* CF 27 state configuration */
10814  uint32_t CFSC26:2; /* CF 26 state configuration */
10815  uint32_t CFSC25:2; /* CF 25 state configuration */
10816  uint32_t CFSC24:2; /* CF 24 state configuration */
10817  uint32_t CFSC23:2; /* CF 23 state configuration */
10818  uint32_t CFSC22:2; /* CF 22 state configuration */
10819  uint32_t CFSC21:2; /* CF 21 state configuration */
10820  uint32_t CFSC20:2; /* CF 20 state configuration */
10821  uint32_t CFSC19:2; /* CF 19 state configuration */
10822  uint32_t CFSC18:2; /* CF 18 state configuration */
10823  uint32_t CFSC17:2; /* CF 17 state configuration */
10824  uint32_t CFSC16:2; /* CF 16 state configuration */
10825  } B;
10827
10828  typedef union { /* FCCU CFS Configuration Register 2 */
10829  uint32_t R;
10830  struct {
10831  uint32_t CFSC47:2; /* CF 47 state configuration */
10832  uint32_t CFSC46:2; /* CF 46 state configuration */
10833  uint32_t CFSC45:2; /* CF 45 state configuration */
10834  uint32_t CFSC44:2; /* CF 44 state configuration */
10835  uint32_t CFSC43:2; /* CF 43 state configuration */
10836  uint32_t CFSC42:2; /* CF 42 state configuration */
10837  uint32_t CFSC41:2; /* CF 41 state configuration */
10838  uint32_t CFSC40:2; /* CF 40 state configuration */
10839  uint32_t CFSC39:2; /* CF 39 state configuration */
10840  uint32_t CFSC38:2; /* CF 38 state configuration */
10841  uint32_t CFSC37:2; /* CF 37 state configuration */
10842  uint32_t CFSC36:2; /* CF 36 state configuration */
10843  uint32_t CFSC35:2; /* CF 35 state configuration */
10844  uint32_t CFSC34:2; /* CF 34 state configuration */
10845  uint32_t CFSC33:2; /* CF 33 state configuration */
10846  uint32_t CFSC32:2; /* CF 32 state configuration */
10847  } B;
10849
10850  typedef union { /* FCCU CFS Configuration Register 3 */
10851  uint32_t R;
10852  struct {
10853  uint32_t CFSC63:2; /* CF 63 state configuration */
10854  uint32_t CFSC62:2; /* CF 62 state configuration */
10855  uint32_t CFSC61:2; /* CF 61 state configuration */
10856  uint32_t CFSC60:2; /* CF 60 state configuration */
10857  uint32_t CFSC59:2; /* CF 59 state configuration */
10858  uint32_t CFSC58:2; /* CF 58 state configuration */
10859  uint32_t CFSC57:2; /* CF 57 state configuration */
10860  uint32_t CFSC56:2; /* CF 56 state configuration */
10861  uint32_t CFSC55:2; /* CF 55 state configuration */
10862  uint32_t CFSC54:2; /* CF 54 state configuration */
10863  uint32_t CFSC53:2; /* CF 53 state configuration */
10864  uint32_t CFSC52:2; /* CF 52 state configuration */
10865  uint32_t CFSC51:2; /* CF 51 state configuration */
10866  uint32_t CFSC50:2; /* CF 50 state configuration */
10867  uint32_t CFSC49:2; /* CF 49 state configuration */
10868  uint32_t CFSC48:2; /* CF 48 state configuration */
10869  } B;
10871
10872  typedef union { /* FCCU CFS Configuration Register 4 */
10873  uint32_t R;
10874  struct {
10875  uint32_t CFSC79:2; /* CF 79 state configuration */
10876  uint32_t CFSC78:2; /* CF 78 state configuration */
10877  uint32_t CFSC77:2; /* CF 77 state configuration */
10878  uint32_t CFSC76:2; /* CF 76 state configuration */
10879  uint32_t CFSC75:2; /* CF 75 state configuration */
10880  uint32_t CFSC74:2; /* CF 74 state configuration */
10881  uint32_t CFSC73:2; /* CF 73 state configuration */
10882  uint32_t CFSC72:2; /* CF 72 state configuration */
10883  uint32_t CFSC71:2; /* CF 71 state configuration */
10884  uint32_t CFSC70:2; /* CF 70 state configuration */
10885  uint32_t CFSC69:2; /* CF 69 state configuration */
10886  uint32_t CFSC68:2; /* CF 68 state configuration */
10887  uint32_t CFSC67:2; /* CF 67 state configuration */
10888  uint32_t CFSC66:2; /* CF 66 state configuration */
10889  uint32_t CFSC65:2; /* CF 65 state configuration */
10890  uint32_t CFSC64:2; /* CF 64 state configuration */
10891  } B;
10893
10894  typedef union { /* FCCU CFS Configuration Register 5 */
10895  uint32_t R;
10896  struct {
10897  uint32_t CFSC95:2; /* CF 95 state configuration */
10898  uint32_t CFSC94:2; /* CF 94 state configuration */
10899  uint32_t CFSC93:2; /* CF 93 state configuration */
10900  uint32_t CFSC92:2; /* CF 92 state configuration */
10901  uint32_t CFSC91:2; /* CF 91 state configuration */
10902  uint32_t CFSC90:2; /* CF 90 state configuration */
10903  uint32_t CFSC89:2; /* CF 89 state configuration */
10904  uint32_t CFSC88:2; /* CF 88 state configuration */
10905  uint32_t CFSC87:2; /* CF 87 state configuration */
10906  uint32_t CFSC86:2; /* CF 86 state configuration */
10907  uint32_t CFSC85:2; /* CF 85 state configuration */
10908  uint32_t CFSC84:2; /* CF 84 state configuration */
10909  uint32_t CFSC83:2; /* CF 83 state configuration */
10910  uint32_t CFSC82:2; /* CF 82 state configuration */
10911  uint32_t CFSC81:2; /* CF 81 state configuration */
10912  uint32_t CFSC80:2; /* CF 80 state configuration */
10913  } B;
10915
10916  typedef union { /* FCCU CFS Configuration Register 6 */
10917  uint32_t R;
10918  struct {
10919  uint32_t CFSC111:2; /* CF 111 state configuration */
10920  uint32_t CFSC110:2; /* CF 110 state configuration */
10921  uint32_t CFSC109:2; /* CF 109 state configuration */
10922  uint32_t CFSC108:2; /* CF 108 state configuration */
10923  uint32_t CFSC107:2; /* CF 107 state configuration */
10924  uint32_t CFSC106:2; /* CF 106 state configuration */
10925  uint32_t CFSC105:2; /* CF 105 state configuration */
10926  uint32_t CFSC104:2; /* CF 104 state configuration */
10927  uint32_t CFSC103:2; /* CF 103 state configuration */
10928  uint32_t CFSC102:2; /* CF 102 state configuration */
10929  uint32_t CFSC101:2; /* CF 101 state configuration */
10930  uint32_t CFSC100:2; /* CF 100 state configuration */
10931  uint32_t CFSC99:2; /* CF 99 state configuration */
10932  uint32_t CFSC98:2; /* CF 98 state configuration */
10933  uint32_t CFSC97:2; /* CF 97 state configuration */
10934  uint32_t CFSC96:2; /* CF 96 state configuration */
10935  } B;
10937
10938  typedef union { /* FCCU CFS Configuration Register 7 */
10939  uint32_t R;
10940  struct {
10941  uint32_t CFSC127:2; /* CF 127 state configuration */
10942  uint32_t CFSC126:2; /* CF 126 state configuration */
10943  uint32_t CFSC125:2; /* CF 125 state configuration */
10944  uint32_t CFSC124:2; /* CF 124 state configuration */
10945  uint32_t CFSC123:2; /* CF 123 state configuration */
10946  uint32_t CFSC122:2; /* CF 122 state configuration */
10947  uint32_t CFSC121:2; /* CF 121 state configuration */
10948  uint32_t CFSC120:2; /* CF 120 state configuration */
10949  uint32_t CFSC119:2; /* CF 119 state configuration */
10950  uint32_t CFSC118:2; /* CF 118 state configuration */
10951  uint32_t CFSC117:2; /* CF 117 state configuration */
10952  uint32_t CFSC116:2; /* CF 116 state configuration */
10953  uint32_t CFSC115:2; /* CF 115 state configuration */
10954  uint32_t CFSC114:2; /* CF 114 state configuration */
10955  uint32_t CFSC113:2; /* CF 113 state configuration */
10956  uint32_t CFSC112:2; /* CF 112 state configuration */
10957  } B;
10959
10960  typedef union { /* FCCU NCFS Configuration Register 0 */
10961  uint32_t R;
10962  struct {
10963  uint32_t NCFSC15:2; /* NCF 15 state configuration */
10964  uint32_t NCFSC14:2; /* NCF 14 state configuration */
10965  uint32_t NCFSC13:2; /* NCF 13 state configuration */
10966  uint32_t NCFSC12:2; /* NCF 12 state configuration */
10967  uint32_t NCFSC11:2; /* NCF 11 state configuration */
10968  uint32_t NCFSC10:2; /* NCF 10 state configuration */
10969  uint32_t NCFSC9:2; /* NCF 9 state configuration */
10970  uint32_t NCFSC8:2; /* NCF 8 state configuration */
10971  uint32_t NCFSC7:2; /* NCF 7 state configuration */
10972  uint32_t NCFSC6:2; /* NCF 6 state configuration */
10973  uint32_t NCFSC5:2; /* NCF 5 state configuration */
10974  uint32_t NCFSC4:2; /* NCF 4 state configuration */
10975  uint32_t NCFSC3:2; /* NCF 3 state configuration */
10976  uint32_t NCFSC2:2; /* NCF 2 state configuration */
10977  uint32_t NCFSC1:2; /* NCF 1 state configuration */
10978  uint32_t NCFSC0:2; /* NCF 0 state configuration */
10979  } B;
10981
10982  typedef union { /* FCCU NCFS Configuration Register 1 */
10983  uint32_t R;
10984  struct {
10985  uint32_t NCFSC31:2; /* NCF 31 state configuration */
10986  uint32_t NCFSC30:2; /* NCF 30 state configuration */
10987  uint32_t NCFSC29:2; /* NCF 29 state configuration */
10988  uint32_t NCFSC28:2; /* NCF 28 state configuration */
10989  uint32_t NCFSC27:2; /* NCF 27 state configuration */
10990  uint32_t NCFSC26:2; /* NCF 26 state configuration */
10991  uint32_t NCFSC25:2; /* NCF 25 state configuration */
10992  uint32_t NCFSC24:2; /* NCF 24 state configuration */
10993  uint32_t NCFSC23:2; /* NCF 23 state configuration */
10994  uint32_t NCFSC22:2; /* NCF 22 state configuration */
10995  uint32_t NCFSC21:2; /* NCF 21 state configuration */
10996  uint32_t NCFSC20:2; /* NCF 20 state configuration */
10997  uint32_t NCFSC19:2; /* NCF 19 state configuration */
10998  uint32_t NCFSC18:2; /* NCF 18 state configuration */
10999  uint32_t NCFSC17:2; /* NCF 17 state configuration */
11000  uint32_t NCFSC16:2; /* NCF 16 state configuration */
11001  } B;
11003
11004  typedef union { /* FCCU NCFS Configuration Register 2 */
11005  uint32_t R;
11006  struct {
11007  uint32_t NCFSC47:2; /* NCF 47 state configuration */
11008  uint32_t NCFSC46:2; /* NCF 46 state configuration */
11009  uint32_t NCFSC45:2; /* NCF 45 state configuration */
11010  uint32_t NCFSC44:2; /* NCF 44 state configuration */
11011  uint32_t NCFSC43:2; /* NCF 43 state configuration */
11012  uint32_t NCFSC42:2; /* NCF 42 state configuration */
11013  uint32_t NCFSC41:2; /* NCF 41 state configuration */
11014  uint32_t NCFSC40:2; /* NCF 40 state configuration */
11015  uint32_t NCFSC39:2; /* NCF 39 state configuration */
11016  uint32_t NCFSC38:2; /* NCF 38 state configuration */
11017  uint32_t NCFSC37:2; /* NCF 37 state configuration */
11018  uint32_t NCFSC36:2; /* NCF 36 state configuration */
11019  uint32_t NCFSC35:2; /* NCF 35 state configuration */
11020  uint32_t NCFSC34:2; /* NCF 34 state configuration */
11021  uint32_t NCFSC33:2; /* NCF 33 state configuration */
11022  uint32_t NCFSC32:2; /* NCF 32 state configuration */
11023  } B;
11025
11026  typedef union { /* FCCU NCFS Configuration Register 3 */
11027  uint32_t R;
11028  struct {
11029  uint32_t NCFSC63:2; /* NCF 63 state configuration */
11030  uint32_t NCFSC62:2; /* NCF 62 state configuration */
11031  uint32_t NCFSC61:2; /* NCF 61 state configuration */
11032  uint32_t NCFSC60:2; /* NCF 60 state configuration */
11033  uint32_t NCFSC59:2; /* NCF 59 state configuration */
11034  uint32_t NCFSC58:2; /* NCF 58 state configuration */
11035  uint32_t NCFSC57:2; /* NCF 57 state configuration */
11036  uint32_t NCFSC56:2; /* NCF 56 state configuration */
11037  uint32_t NCFSC55:2; /* NCF 55 state configuration */
11038  uint32_t NCFSC54:2; /* NCF 54 state configuration */
11039  uint32_t NCFSC53:2; /* NCF 53 state configuration */
11040  uint32_t NCFSC52:2; /* NCF 52 state configuration */
11041  uint32_t NCFSC51:2; /* NCF 51 state configuration */
11042  uint32_t NCFSC50:2; /* NCF 50 state configuration */
11043  uint32_t NCFSC49:2; /* NCF 49 state configuration */
11044  uint32_t NCFSC48:2; /* NCF 48 state configuration */
11045  } B;
11047
11048  typedef union { /* FCCU NCFS Configuration Register 4 */
11049  uint32_t R;
11050  struct {
11051  uint32_t NCFSC79:2; /* NCF 79 state configuration */
11052  uint32_t NCFSC78:2; /* NCF 78 state configuration */
11053  uint32_t NCFSC77:2; /* NCF 77 state configuration */
11054  uint32_t NCFSC76:2; /* NCF 76 state configuration */
11055  uint32_t NCFSC75:2; /* NCF 75 state configuration */
11056  uint32_t NCFSC74:2; /* NCF 74 state configuration */
11057  uint32_t NCFSC73:2; /* NCF 73 state configuration */
11058  uint32_t NCFSC72:2; /* NCF 72 state configuration */
11059  uint32_t NCFSC71:2; /* NCF 71 state configuration */
11060  uint32_t NCFSC70:2; /* NCF 70 state configuration */
11061  uint32_t NCFSC69:2; /* NCF 69 state configuration */
11062  uint32_t NCFSC68:2; /* NCF 68 state configuration */
11063  uint32_t NCFSC67:2; /* NCF 67 state configuration */
11064  uint32_t NCFSC66:2; /* NCF 66 state configuration */
11065  uint32_t NCFSC65:2; /* NCF 65 state configuration */
11066  uint32_t NCFSC64:2; /* NCF 64 state configuration */
11067  } B;
11069
11070  typedef union { /* FCCU NCFS Configuration Register 5 */
11071  uint32_t R;
11072  struct {
11073  uint32_t NCFSC95:2; /* NCF 95 state configuration */
11074  uint32_t NCFSC94:2; /* NCF 94 state configuration */
11075  uint32_t NCFSC93:2; /* NCF 93 state configuration */
11076  uint32_t NCFSC92:2; /* NCF 92 state configuration */
11077  uint32_t NCFSC91:2; /* NCF 91 state configuration */
11078  uint32_t NCFSC90:2; /* NCF 90 state configuration */
11079  uint32_t NCFSC89:2; /* NCF 89 state configuration */
11080  uint32_t NCFSC88:2; /* NCF 88 state configuration */
11081  uint32_t NCFSC87:2; /* NCF 87 state configuration */
11082  uint32_t NCFSC86:2; /* NCF 86 state configuration */
11083  uint32_t NCFSC85:2; /* NCF 85 state configuration */
11084  uint32_t NCFSC84:2; /* NCF 84 state configuration */
11085  uint32_t NCFSC83:2; /* NCF 83 state configuration */
11086  uint32_t NCFSC82:2; /* NCF 82 state configuration */
11087  uint32_t NCFSC81:2; /* NCF 81 state configuration */
11088  uint32_t NCFSC80:2; /* NCF 80 state configuration */
11089  } B;
11091
11092  typedef union { /* FCCU NCFS Configuration Register 6 */
11093  uint32_t R;
11094  struct {
11095  uint32_t NCFSC111:2; /* NCF 111 state configuration */
11096  uint32_t NCFSC110:2; /* NCF 110 state configuration */
11097  uint32_t NCFSC109:2; /* NCF 109 state configuration */
11098  uint32_t NCFSC108:2; /* NCF 108 state configuration */
11099  uint32_t NCFSC107:2; /* NCF 107 state configuration */
11100  uint32_t NCFSC106:2; /* NCF 106 state configuration */
11101  uint32_t NCFSC105:2; /* NCF 105 state configuration */
11102  uint32_t NCFSC104:2; /* NCF 104 state configuration */
11103  uint32_t NCFSC103:2; /* NCF 103 state configuration */
11104  uint32_t NCFSC102:2; /* NCF 102 state configuration */
11105  uint32_t NCFSC101:2; /* NCF 101 state configuration */
11106  uint32_t NCFSC100:2; /* NCF 100 state configuration */
11107  uint32_t NCFSC99:2; /* NCF 99 state configuration */
11108  uint32_t NCFSC98:2; /* NCF 98 state configuration */
11109  uint32_t NCFSC97:2; /* NCF 97 state configuration */
11110  uint32_t NCFSC96:2; /* NCF 96 state configuration */
11111  } B;
11113
11114  typedef union { /* FCCU NCFS Configuration Register 7 */
11115  uint32_t R;
11116  struct {
11117  uint32_t NCFSC127:2; /* NCF 127 state configuration */
11118  uint32_t NCFSC126:2; /* NCF 126 state configuration */
11119  uint32_t NCFSC125:2; /* NCF 125 state configuration */
11120  uint32_t NCFSC124:2; /* NCF 124 state configuration */
11121  uint32_t NCFSC123:2; /* NCF 123 state configuration */
11122  uint32_t NCFSC122:2; /* NCF 122 state configuration */
11123  uint32_t NCFSC121:2; /* NCF 121 state configuration */
11124  uint32_t NCFSC120:2; /* NCF 120 state configuration */
11125  uint32_t NCFSC119:2; /* NCF 119 state configuration */
11126  uint32_t NCFSC118:2; /* NCF 118 state configuration */
11127  uint32_t NCFSC117:2; /* NCF 117 state configuration */
11128  uint32_t NCFSC116:2; /* NCF 116 state configuration */
11129  uint32_t NCFSC115:2; /* NCF 115 state configuration */
11130  uint32_t NCFSC114:2; /* NCF 114 state configuration */
11131  uint32_t NCFSC113:2; /* NCF 113 state configuration */
11132  uint32_t NCFSC112:2; /* NCF 112 state configuration */
11133  } B;
11135
11136  typedef union { /* FCCU CF Status Register 0 */
11137  uint32_t R;
11138  struct {
11139  uint32_t CFS31:1; /* CF 31 status */
11140  uint32_t CFS30:1; /* CF 30 status */
11141  uint32_t CFS29:1; /* CF 29 status */
11142  uint32_t CFS28:1; /* CF 28 status */
11143  uint32_t CFS27:1; /* CF 27 status */
11144  uint32_t CFS26:1; /* CF 26 status */
11145  uint32_t CFS25:1; /* CF 25 status */
11146  uint32_t CFS24:1; /* CF 24 status */
11147  uint32_t CFS23:1; /* CF 23 status */
11148  uint32_t CFS22:1; /* CF 22 status */
11149  uint32_t CFS21:1; /* CF 21 status */
11150  uint32_t CFS20:1; /* CF 20 status */
11151  uint32_t CFS19:1; /* CF 19 status */
11152  uint32_t CFS18:1; /* CF 18 status */
11153  uint32_t CFS17:1; /* CF 17 status */
11154  uint32_t CFS16:1; /* CF 16 status */
11155  uint32_t CFS15:1; /* CF 15 status */
11156  uint32_t CFS14:1; /* CF 14 status */
11157  uint32_t CFS13:1; /* CF 13 status */
11158  uint32_t CFS12:1; /* CF 12 status */
11159  uint32_t CFS11:1; /* CF 11 status */
11160  uint32_t CFS10:1; /* CF 10 status */
11161  uint32_t CFS9:1; /* CF 9 status */
11162  uint32_t CFS8:1; /* CF 8 status */
11163  uint32_t CFS7:1; /* CF 7 status */
11164  uint32_t CFS6:1; /* CF 6 status */
11165  uint32_t CFS5:1; /* CF 5 status */
11166  uint32_t CFS4:1; /* CF 4 status */
11167  uint32_t CFS3:1; /* CF 3 status */
11168  uint32_t CFS2:1; /* CF 2 status */
11169  uint32_t CFS1:1; /* CF 1 status */
11170  uint32_t CFS0:1; /* CF 0 status */
11171  } B;
11173
11174  typedef union { /* FCCU CF Status Register 1 */
11175  uint32_t R;
11176  struct {
11177  uint32_t CFS63:1; /* CF 63 status */
11178  uint32_t CFS62:1; /* CF 62 status */
11179  uint32_t CFS61:1; /* CF 61 status */
11180  uint32_t CFS60:1; /* CF 60 status */
11181  uint32_t CFS59:1; /* CF 59 status */
11182  uint32_t CFS58:1; /* CF 58 status */
11183  uint32_t CFS57:1; /* CF 57 status */
11184  uint32_t CFS56:1; /* CF 56 status */
11185  uint32_t CFS55:1; /* CF 55 status */
11186  uint32_t CFS54:1; /* CF 54 status */
11187  uint32_t CFS53:1; /* CF 53 status */
11188  uint32_t CFS52:1; /* CF 52 status */
11189  uint32_t CFS51:1; /* CF 51 status */
11190  uint32_t CFS50:1; /* CF 50 status */
11191  uint32_t CFS49:1; /* CF 49 status */
11192  uint32_t CFS48:1; /* CF 48 status */
11193  uint32_t CFS47:1; /* CF 47 status */
11194  uint32_t CFS46:1; /* CF 46 status */
11195  uint32_t CFS45:1; /* CF 45 status */
11196  uint32_t CFS44:1; /* CF 44 status */
11197  uint32_t CFS43:1; /* CF 43 status */
11198  uint32_t CFS42:1; /* CF 42 status */
11199  uint32_t CFS41:1; /* CF 41 status */
11200  uint32_t CFS40:1; /* CF 40 status */
11201  uint32_t CFS39:1; /* CF 39 status */
11202  uint32_t CFS38:1; /* CF 38 status */
11203  uint32_t CFS37:1; /* CF 37 status */
11204  uint32_t CFS36:1; /* CF 36 status */
11205  uint32_t CFS35:1; /* CF 35 status */
11206  uint32_t CFS34:1; /* CF 34 status */
11207  uint32_t CFS33:1; /* CF 33 status */
11208  uint32_t CFS32:1; /* CF 32 status */
11209  } B;
11211
11212  typedef union { /* FCCU CF Status Register 2 */
11213  uint32_t R;
11214  struct {
11215  uint32_t CFS95:1; /* CF 95 status */
11216  uint32_t CFS94:1; /* CF 94 status */
11217  uint32_t CFS93:1; /* CF 93 status */
11218  uint32_t CFS92:1; /* CF 92 status */
11219  uint32_t CFS91:1; /* CF 91 status */
11220  uint32_t CFS90:1; /* CF 90 status */
11221  uint32_t CFS89:1; /* CF 89 status */
11222  uint32_t CFS88:1; /* CF 88 status */
11223  uint32_t CFS87:1; /* CF 87 status */
11224  uint32_t CFS86:1; /* CF 86 status */
11225  uint32_t CFS85:1; /* CF 85 status */
11226  uint32_t CFS84:1; /* CF 84 status */
11227  uint32_t CFS83:1; /* CF 83 status */
11228  uint32_t CFS82:1; /* CF 82 status */
11229  uint32_t CFS81:1; /* CF 81 status */
11230  uint32_t CFS80:1; /* CF 80 status */
11231  uint32_t CFS79:1; /* CF 79 status */
11232  uint32_t CFS78:1; /* CF 78 status */
11233  uint32_t CFS77:1; /* CF 77 status */
11234  uint32_t CFS76:1; /* CF 76 status */
11235  uint32_t CFS75:1; /* CF 75 status */
11236  uint32_t CFS74:1; /* CF 74 status */
11237  uint32_t CFS73:1; /* CF 73 status */
11238  uint32_t CFS72:1; /* CF 72 status */
11239  uint32_t CFS71:1; /* CF 71 status */
11240  uint32_t CFS70:1; /* CF 70 status */
11241  uint32_t CFS69:1; /* CF 69 status */
11242  uint32_t CFS68:1; /* CF 68 status */
11243  uint32_t CFS67:1; /* CF 67 status */
11244  uint32_t CFS66:1; /* CF 66 status */
11245  uint32_t CFS65:1; /* CF 65 status */
11246  uint32_t CFS64:1; /* CF 64 status */
11247  } B;
11249
11250  typedef union { /* FCCU CF Status Register 3 */
11251  uint32_t R;
11252  struct {
11253  uint32_t CFS127:1; /* CF 127 status */
11254  uint32_t CFS126:1; /* CF 126 status */
11255  uint32_t CFS125:1; /* CF 125 status */
11256  uint32_t CFS124:1; /* CF 124 status */
11257  uint32_t CFS123:1; /* CF 123 status */
11258  uint32_t CFS122:1; /* CF 122 status */
11259  uint32_t CFS121:1; /* CF 121 status */
11260  uint32_t CFS120:1; /* CF 120 status */
11261  uint32_t CFS119:1; /* CF 119 status */
11262  uint32_t CFS118:1; /* CF 118 status */
11263  uint32_t CFS117:1; /* CF 117 status */
11264  uint32_t CFS116:1; /* CF 116 status */
11265  uint32_t CFS115:1; /* CF 115 status */
11266  uint32_t CFS114:1; /* CF 114 status */
11267  uint32_t CFS113:1; /* CF 113 status */
11268  uint32_t CFS112:1; /* CF 112 status */
11269  uint32_t CFS111:1; /* CF 111 status */
11270  uint32_t CFS110:1; /* CF 110 status */
11271  uint32_t CFS109:1; /* CF 109 status */
11272  uint32_t CFS108:1; /* CF 108 status */
11273  uint32_t CFS107:1; /* CF 107 status */
11274  uint32_t CFS106:1; /* CF 106 status */
11275  uint32_t CFS105:1; /* CF 105 status */
11276  uint32_t CFS104:1; /* CF 104 status */
11277  uint32_t CFS103:1; /* CF 103 status */
11278  uint32_t CFS102:1; /* CF 102 status */
11279  uint32_t CFS101:1; /* CF 101 status */
11280  uint32_t CFS100:1; /* CF 100 status */
11281  uint32_t CFS99:1; /* CF 99 status */
11282  uint32_t CFS98:1; /* CF 98 status */
11283  uint32_t CFS97:1; /* CF 97 status */
11284  uint32_t CFS96:1; /* CF 96 status */
11285  } B;
11287
11288  typedef union { /* FCCU_CFK - FCCU CF Key Register */
11289  uint32_t R;
11290  } FCCU_CFK_32B_tag;
11291
11292  typedef union { /* FCCU NCF Status Register 0 */
11293  uint32_t R;
11294  struct {
11295  uint32_t NCFS31:1; /* NCF 31 status */
11296  uint32_t NCFS30:1; /* NCF 30 status */
11297  uint32_t NCFS29:1; /* NCF 29 status */
11298  uint32_t NCFS28:1; /* NCF 28 status */
11299  uint32_t NCFS27:1; /* NCF 27 status */
11300  uint32_t NCFS26:1; /* NCF 26 status */
11301  uint32_t NCFS25:1; /* NCF 25 status */
11302  uint32_t NCFS24:1; /* NCF 24 status */
11303  uint32_t NCFS23:1; /* NCF 23 status */
11304  uint32_t NCFS22:1; /* NCF 22 status */
11305  uint32_t NCFS21:1; /* NCF 21 status */
11306  uint32_t NCFS20:1; /* NCF 20 status */
11307  uint32_t NCFS19:1; /* NCF 19 status */
11308  uint32_t NCFS18:1; /* NCF 18 status */
11309  uint32_t NCFS17:1; /* NCF 17 status */
11310  uint32_t NCFS16:1; /* NCF 16 status */
11311  uint32_t NCFS15:1; /* NCF 15 status */
11312  uint32_t NCFS14:1; /* NCF 14 status */
11313  uint32_t NCFS13:1; /* NCF 13 status */
11314  uint32_t NCFS12:1; /* NCF 12 status */
11315  uint32_t NCFS11:1; /* NCF 11 status */
11316  uint32_t NCFS10:1; /* NCF 10 status */
11317  uint32_t NCFS9:1; /* NCF 9 status */
11318  uint32_t NCFS8:1; /* NCF 8 status */
11319  uint32_t NCFS7:1; /* NCF 7 status */
11320  uint32_t NCFS6:1; /* NCF 6 status */
11321  uint32_t NCFS5:1; /* NCF 5 status */
11322  uint32_t NCFS4:1; /* NCF 4 status */
11323  uint32_t NCFS3:1; /* NCF 3 status */
11324  uint32_t NCFS2:1; /* NCF 2 status */
11325  uint32_t NCFS1:1; /* NCF 1 status */
11326  uint32_t NCFS0:1; /* NCF 0 status */
11327  } B;
11329
11330  typedef union { /* FCCU NCF Status Register 1 */
11331  uint32_t R;
11332  struct {
11333  uint32_t NCFS63:1; /* NCF 63 status */
11334  uint32_t NCFS62:1; /* NCF 62 status */
11335  uint32_t NCFS61:1; /* NCF 61 status */
11336  uint32_t NCFS60:1; /* NCF 60 status */
11337  uint32_t NCFS59:1; /* NCF 59 status */
11338  uint32_t NCFS58:1; /* NCF 58 status */
11339  uint32_t NCFS57:1; /* NCF 57 status */
11340  uint32_t NCFS56:1; /* NCF 56 status */
11341  uint32_t NCFS55:1; /* NCF 55 status */
11342  uint32_t NCFS54:1; /* NCF 54 status */
11343  uint32_t NCFS53:1; /* NCF 53 status */
11344  uint32_t NCFS52:1; /* NCF 52 status */
11345  uint32_t NCFS51:1; /* NCF 51 status */
11346  uint32_t NCFS50:1; /* NCF 50 status */
11347  uint32_t NCFS49:1; /* NCF 49 status */
11348  uint32_t NCFS48:1; /* NCF 48 status */
11349  uint32_t NCFS47:1; /* NCF 47 status */
11350  uint32_t NCFS46:1; /* NCF 46 status */
11351  uint32_t NCFS45:1; /* NCF 45 status */
11352  uint32_t NCFS44:1; /* NCF 44 status */
11353  uint32_t NCFS43:1; /* NCF 43 status */
11354  uint32_t NCFS42:1; /* NCF 42 status */
11355  uint32_t NCFS41:1; /* NCF 41 status */
11356  uint32_t NCFS40:1; /* NCF 40 status */
11357  uint32_t NCFS39:1; /* NCF 39 status */
11358  uint32_t NCFS38:1; /* NCF 38 status */
11359  uint32_t NCFS37:1; /* NCF 37 status */
11360  uint32_t NCFS36:1; /* NCF 36 status */
11361  uint32_t NCFS35:1; /* NCF 35 status */
11362  uint32_t NCFS34:1; /* NCF 34 status */
11363  uint32_t NCFS33:1; /* NCF 33 status */
11364  uint32_t NCFS32:1; /* NCF 32 status */
11365  } B;
11367
11368  typedef union { /* FCCU NCF Status Register 2 */
11369  uint32_t R;
11370  struct {
11371  uint32_t NCFS95:1; /* NCF 95 status */
11372  uint32_t NCFS94:1; /* NCF 94 status */
11373  uint32_t NCFS93:1; /* NCF 93 status */
11374  uint32_t NCFS92:1; /* NCF 92 status */
11375  uint32_t NCFS91:1; /* NCF 91 status */
11376  uint32_t NCFS90:1; /* NCF 90 status */
11377  uint32_t NCFS89:1; /* NCF 89 status */
11378  uint32_t NCFS88:1; /* NCF 88 status */
11379  uint32_t NCFS87:1; /* NCF 87 status */
11380  uint32_t NCFS86:1; /* NCF 86 status */
11381  uint32_t NCFS85:1; /* NCF 85 status */
11382  uint32_t NCFS84:1; /* NCF 84 status */
11383  uint32_t NCFS83:1; /* NCF 83 status */
11384  uint32_t NCFS82:1; /* NCF 82 status */
11385  uint32_t NCFS81:1; /* NCF 81 status */
11386  uint32_t NCFS80:1; /* NCF 80 status */
11387  uint32_t NCFS79:1; /* NCF 79 status */
11388  uint32_t NCFS78:1; /* NCF 78 status */
11389  uint32_t NCFS77:1; /* NCF 77 status */
11390  uint32_t NCFS76:1; /* NCF 76 status */
11391  uint32_t NCFS75:1; /* NCF 75 status */
11392  uint32_t NCFS74:1; /* NCF 74 status */
11393  uint32_t NCFS73:1; /* NCF 73 status */
11394  uint32_t NCFS72:1; /* NCF 72 status */
11395  uint32_t NCFS71:1; /* NCF 71 status */
11396  uint32_t NCFS70:1; /* NCF 70 status */
11397  uint32_t NCFS69:1; /* NCF 69 status */
11398  uint32_t NCFS68:1; /* NCF 68 status */
11399  uint32_t NCFS67:1; /* NCF 67 status */
11400  uint32_t NCFS66:1; /* NCF 66 status */
11401  uint32_t NCFS65:1; /* NCF 65 status */
11402  uint32_t NCFS64:1; /* NCF 64 status */
11403  } B;
11405
11406  typedef union { /* FCCU NCF Status Register 3 */
11407  uint32_t R;
11408  struct {
11409  uint32_t NCFS127:1; /* NCF 127 status */
11410  uint32_t NCFS126:1; /* NCF 126 status */
11411  uint32_t NCFS125:1; /* NCF 125 status */
11412  uint32_t NCFS124:1; /* NCF 124 status */
11413  uint32_t NCFS123:1; /* NCF 123 status */
11414  uint32_t NCFS122:1; /* NCF 122 status */
11415  uint32_t NCFS121:1; /* NCF 121 status */
11416  uint32_t NCFS120:1; /* NCF 120 status */
11417  uint32_t NCFS119:1; /* NCF 119 status */
11418  uint32_t NCFS118:1; /* NCF 118 status */
11419  uint32_t NCFS117:1; /* NCF 117 status */
11420  uint32_t NCFS116:1; /* NCF 116 status */
11421  uint32_t NCFS115:1; /* NCF 115 status */
11422  uint32_t NCFS114:1; /* NCF 114 status */
11423  uint32_t NCFS113:1; /* NCF 113 status */
11424  uint32_t NCFS112:1; /* NCF 112 status */
11425  uint32_t NCFS111:1; /* NCF 111 status */
11426  uint32_t NCFS110:1; /* NCF 110 status */
11427  uint32_t NCFS109:1; /* NCF 109 status */
11428  uint32_t NCFS108:1; /* NCF 108 status */
11429  uint32_t NCFS107:1; /* NCF 107 status */
11430  uint32_t NCFS106:1; /* NCF 106 status */
11431  uint32_t NCFS105:1; /* NCF 105 status */
11432  uint32_t NCFS104:1; /* NCF 104 status */
11433  uint32_t NCFS103:1; /* NCF 103 status */
11434  uint32_t NCFS102:1; /* NCF 102 status */
11435  uint32_t NCFS101:1; /* NCF 101 status */
11436  uint32_t NCFS100:1; /* NCF 100 status */
11437  uint32_t NCFS99:1; /* NCF 99 status */
11438  uint32_t NCFS98:1; /* NCF 98 status */
11439  uint32_t NCFS97:1; /* NCF 97 status */
11440  uint32_t NCFS96:1; /* NCF 96 status */
11441  } B;
11443
11444  typedef union { /* FCCU_NCFK - FCCU NCF Key Register */
11445  uint32_t R;
11447
11448  typedef union { /* FCCU NCF Enable Register 0 */
11449  uint32_t R;
11450  struct {
11451  uint32_t NCFE31:1; /* NCF 31 enable */
11452  uint32_t NCFE30:1; /* NCF 30 enable */
11453  uint32_t NCFE29:1; /* NCF 29 enable */
11454  uint32_t NCFE28:1; /* NCF 28 enable */
11455  uint32_t NCFE27:1; /* NCF 27 enable */
11456  uint32_t NCFE26:1; /* NCF 26 enable */
11457  uint32_t NCFE25:1; /* NCF 25 enable */
11458  uint32_t NCFE24:1; /* NCF 24 enable */
11459  uint32_t NCFE23:1; /* NCF 23 enable */
11460  uint32_t NCFE22:1; /* NCF 22 enable */
11461  uint32_t NCFE21:1; /* NCF 21 enable */
11462  uint32_t NCFE20:1; /* NCF 20 enable */
11463  uint32_t NCFE19:1; /* NCF 19 enable */
11464  uint32_t NCFE18:1; /* NCF 18 enable */
11465  uint32_t NCFE17:1; /* NCF 17 enable */
11466  uint32_t NCFE16:1; /* NCF 16 enable */
11467  uint32_t NCFE15:1; /* NCF 15 enable */
11468  uint32_t NCFE14:1; /* NCF 14 enable */
11469  uint32_t NCFE13:1; /* NCF 13 enable */
11470  uint32_t NCFE12:1; /* NCF 12 enable */
11471  uint32_t NCFE11:1; /* NCF 11 enable */
11472  uint32_t NCFE10:1; /* NCF 10 enable */
11473  uint32_t NCFE9:1; /* NCF 9 enable */
11474  uint32_t NCFE8:1; /* NCF 8 enable */
11475  uint32_t NCFE7:1; /* NCF 7 enable */
11476  uint32_t NCFE6:1; /* NCF 6 enable */
11477  uint32_t NCFE5:1; /* NCF 5 enable */
11478  uint32_t NCFE4:1; /* NCF 4 enable */
11479  uint32_t NCFE3:1; /* NCF 3 enable */
11480  uint32_t NCFE2:1; /* NCF 2 enable */
11481  uint32_t NCFE1:1; /* NCF 1 enable */
11482  uint32_t NCFE0:1; /* NCF 0 enable */
11483  } B;
11485
11486  typedef union { /* FCCU NCF Enable Register 1 */
11487  uint32_t R;
11488  struct {
11489  uint32_t NCFE63:1; /* NCF 63 enable */
11490  uint32_t NCFE62:1; /* NCF 62 enable */
11491  uint32_t NCFE61:1; /* NCF 61 enable */
11492  uint32_t NCFE60:1; /* NCF 60 enable */
11493  uint32_t NCFE59:1; /* NCF 59 enable */
11494  uint32_t NCFE58:1; /* NCF 58 enable */
11495  uint32_t NCFE57:1; /* NCF 57 enable */
11496  uint32_t NCFE56:1; /* NCF 56 enable */
11497  uint32_t NCFE55:1; /* NCF 55 enable */
11498  uint32_t NCFE54:1; /* NCF 54 enable */
11499  uint32_t NCFE53:1; /* NCF 53 enable */
11500  uint32_t NCFE52:1; /* NCF 52 enable */
11501  uint32_t NCFE51:1; /* NCF 51 enable */
11502  uint32_t NCFE50:1; /* NCF 50 enable */
11503  uint32_t NCFE49:1; /* NCF 49 enable */
11504  uint32_t NCFE48:1; /* NCF 48 enable */
11505  uint32_t NCFE47:1; /* NCF 47 enable */
11506  uint32_t NCFE46:1; /* NCF 46 enable */
11507  uint32_t NCFE45:1; /* NCF 45 enable */
11508  uint32_t NCFE44:1; /* NCF 44 enable */
11509  uint32_t NCFE43:1; /* NCF 43 enable */
11510  uint32_t NCFE42:1; /* NCF 42 enable */
11511  uint32_t NCFE41:1; /* NCF 41 enable */
11512  uint32_t NCFE40:1; /* NCF 40 enable */
11513  uint32_t NCFE39:1; /* NCF 39 enable */
11514  uint32_t NCFE38:1; /* NCF 38 enable */
11515  uint32_t NCFE37:1; /* NCF 37 enable */
11516  uint32_t NCFE36:1; /* NCF 36 enable */
11517  uint32_t NCFE35:1; /* NCF 35 enable */
11518  uint32_t NCFE34:1; /* NCF 34 enable */
11519  uint32_t NCFE33:1; /* NCF 33 enable */
11520  uint32_t NCFE32:1; /* NCF 32 enable */
11521  } B;
11523
11524  typedef union { /* FCCU NCF Enable Register 2 */
11525  uint32_t R;
11526  struct {
11527  uint32_t NCFE95:1; /* NCF 95 enable */
11528  uint32_t NCFE94:1; /* NCF 94 enable */
11529  uint32_t NCFE93:1; /* NCF 93 enable */
11530  uint32_t NCFE92:1; /* NCF 92 enable */
11531  uint32_t NCFE91:1; /* NCF 91 enable */
11532  uint32_t NCFE90:1; /* NCF 90 enable */
11533  uint32_t NCFE89:1; /* NCF 89 enable */
11534  uint32_t NCFE88:1; /* NCF 88 enable */
11535  uint32_t NCFE87:1; /* NCF 87 enable */
11536  uint32_t NCFE86:1; /* NCF 86 enable */
11537  uint32_t NCFE85:1; /* NCF 85 enable */
11538  uint32_t NCFE84:1; /* NCF 84 enable */
11539  uint32_t NCFE83:1; /* NCF 83 enable */
11540  uint32_t NCFE82:1; /* NCF 82 enable */
11541  uint32_t NCFE81:1; /* NCF 81 enable */
11542  uint32_t NCFE80:1; /* NCF 80 enable */
11543  uint32_t NCFE79:1; /* NCF 79 enable */
11544  uint32_t NCFE78:1; /* NCF 78 enable */
11545  uint32_t NCFE77:1; /* NCF 77 enable */
11546  uint32_t NCFE76:1; /* NCF 76 enable */
11547  uint32_t NCFE75:1; /* NCF 75 enable */
11548  uint32_t NCFE74:1; /* NCF 74 enable */
11549  uint32_t NCFE73:1; /* NCF 73 enable */
11550  uint32_t NCFE72:1; /* NCF 72 enable */
11551  uint32_t NCFE71:1; /* NCF 71 enable */
11552  uint32_t NCFE70:1; /* NCF 70 enable */
11553  uint32_t NCFE69:1; /* NCF 69 enable */
11554  uint32_t NCFE68:1; /* NCF 68 enable */
11555  uint32_t NCFE67:1; /* NCF 67 enable */
11556  uint32_t NCFE66:1; /* NCF 66 enable */
11557  uint32_t NCFE65:1; /* NCF 65 enable */
11558  uint32_t NCFE64:1; /* NCF 64 enable */
11559  } B;
11561
11562  typedef union { /* FCCU NCF Enable Register 3 */
11563  uint32_t R;
11564  struct {
11565  uint32_t NCFE127:1; /* NCF 127 enable */
11566  uint32_t NCFE126:1; /* NCF 126 enable */
11567  uint32_t NCFE125:1; /* NCF 125 enable */
11568  uint32_t NCFE124:1; /* NCF 124 enable */
11569  uint32_t NCFE123:1; /* NCF 123 enable */
11570  uint32_t NCFE122:1; /* NCF 122 enable */
11571  uint32_t NCFE121:1; /* NCF 121 enable */
11572  uint32_t NCFE120:1; /* NCF 120 enable */
11573  uint32_t NCFE119:1; /* NCF 119 enable */
11574  uint32_t NCFE118:1; /* NCF 118 enable */
11575  uint32_t NCFE117:1; /* NCF 117 enable */
11576  uint32_t NCFE116:1; /* NCF 116 enable */
11577  uint32_t NCFE115:1; /* NCF 115 enable */
11578  uint32_t NCFE114:1; /* NCF 114 enable */
11579  uint32_t NCFE113:1; /* NCF 113 enable */
11580  uint32_t NCFE112:1; /* NCF 112 enable */
11581  uint32_t NCFE111:1; /* NCF 111 enable */
11582  uint32_t NCFE110:1; /* NCF 110 enable */
11583  uint32_t NCFE109:1; /* NCF 109 enable */
11584  uint32_t NCFE108:1; /* NCF 108 enable */
11585  uint32_t NCFE107:1; /* NCF 107 enable */
11586  uint32_t NCFE106:1; /* NCF 106 enable */
11587  uint32_t NCFE105:1; /* NCF 105 enable */
11588  uint32_t NCFE104:1; /* NCF 104 enable */
11589  uint32_t NCFE103:1; /* NCF 103 enable */
11590  uint32_t NCFE102:1; /* NCF 102 enable */
11591  uint32_t NCFE101:1; /* NCF 101 enable */
11592  uint32_t NCFE100:1; /* NCF 100 enable */
11593  uint32_t NCFE99:1; /* NCF 99 enable */
11594  uint32_t NCFE98:1; /* NCF 98 enable */
11595  uint32_t NCFE97:1; /* NCF 97 enable */
11596  uint32_t NCFE96:1; /* NCF 96 enable */
11597  } B;
11599
11600  typedef union { /* FCCU NCF Time-out Enable Register 0 */
11601  uint32_t R;
11602  struct {
11603  uint32_t NCFTOE31:1; /* NCF 31 time-out enable */
11604  uint32_t NCFTOE30:1; /* NCF 30 time-out enable */
11605  uint32_t NCFTOE29:1; /* NCF 29 time-out enable */
11606  uint32_t NCFTOE28:1; /* NCF 28 time-out enable */
11607  uint32_t NCFTOE27:1; /* NCF 27 time-out enable */
11608  uint32_t NCFTOE26:1; /* NCF 26 time-out enable */
11609  uint32_t NCFTOE25:1; /* NCF 25 time-out enable */
11610  uint32_t NCFTOE24:1; /* NCF 24 time-out enable */
11611  uint32_t NCFTOE23:1; /* NCF 23 time-out enable */
11612  uint32_t NCFTOE22:1; /* NCF 22 time-out enable */
11613  uint32_t NCFTOE21:1; /* NCF 21 time-out enable */
11614  uint32_t NCFTOE20:1; /* NCF 20 time-out enable */
11615  uint32_t NCFTOE19:1; /* NCF 19 time-out enable */
11616  uint32_t NCFTOE18:1; /* NCF 18 time-out enable */
11617  uint32_t NCFTOE17:1; /* NCF 17 time-out enable */
11618  uint32_t NCFTOE16:1; /* NCF 16 time-out enable */
11619  uint32_t NCFTOE15:1; /* NCF 15 time-out enable */
11620  uint32_t NCFTOE14:1; /* NCF 14 time-out enable */
11621  uint32_t NCFTOE13:1; /* NCF 13 time-out enable */
11622  uint32_t NCFTOE12:1; /* NCF 12 time-out enable */
11623  uint32_t NCFTOE11:1; /* NCF 11 time-out enable */
11624  uint32_t NCFTOE10:1; /* NCF 10 time-out enable */
11625  uint32_t NCFTOE9:1; /* NCF 9 time-out enable */
11626  uint32_t NCFTOE8:1; /* NCF 8 time-out enable */
11627  uint32_t NCFTOE7:1; /* NCF 7 time-out enable */
11628  uint32_t NCFTOE6:1; /* NCF 6 time-out enable */
11629  uint32_t NCFTOE5:1; /* NCF 5 time-out enable */
11630  uint32_t NCFTOE4:1; /* NCF 4 time-out enable */
11631  uint32_t NCFTOE3:1; /* NCF 3 time-out enable */
11632  uint32_t NCFTOE2:1; /* NCF 2 time-out enable */
11633  uint32_t NCFTOE1:1; /* NCF 1 time-out enable */
11634  uint32_t NCFTOE0:1; /* NCF 0 time-out enable */
11635  } B;
11637
11638  typedef union { /* FCCU NCF Time-out Enable Register 1 */
11639  uint32_t R;
11640  struct {
11641  uint32_t NCFTOE63:1; /* NCF 63 time-out enable */
11642  uint32_t NCFTOE62:1; /* NCF 62 time-out enable */
11643  uint32_t NCFTOE61:1; /* NCF 61 time-out enable */
11644  uint32_t NCFTOE60:1; /* NCF 60 time-out enable */
11645  uint32_t NCFTOE59:1; /* NCF 59 time-out enable */
11646  uint32_t NCFTOE58:1; /* NCF 58 time-out enable */
11647  uint32_t NCFTOE57:1; /* NCF 57 time-out enable */
11648  uint32_t NCFTOE56:1; /* NCF 56 time-out enable */
11649  uint32_t NCFTOE55:1; /* NCF 55 time-out enable */
11650  uint32_t NCFTOE54:1; /* NCF 54 time-out enable */
11651  uint32_t NCFTOE53:1; /* NCF 53 time-out enable */
11652  uint32_t NCFTOE52:1; /* NCF 52 time-out enable */
11653  uint32_t NCFTOE51:1; /* NCF 51 time-out enable */
11654  uint32_t NCFTOE50:1; /* NCF 50 time-out enable */
11655  uint32_t NCFTOE49:1; /* NCF 49 time-out enable */
11656  uint32_t NCFTOE48:1; /* NCF 48 time-out enable */
11657  uint32_t NCFTOE47:1; /* NCF 47 time-out enable */
11658  uint32_t NCFTOE46:1; /* NCF 46 time-out enable */
11659  uint32_t NCFTOE45:1; /* NCF 45 time-out enable */
11660  uint32_t NCFTOE44:1; /* NCF 44 time-out enable */
11661  uint32_t NCFTOE43:1; /* NCF 43 time-out enable */
11662  uint32_t NCFTOE42:1; /* NCF 42 time-out enable */
11663  uint32_t NCFTOE41:1; /* NCF 41 time-out enable */
11664  uint32_t NCFTOE40:1; /* NCF 40 time-out enable */
11665  uint32_t NCFTOE39:1; /* NCF 39 time-out enable */
11666  uint32_t NCFTOE38:1; /* NCF 38 time-out enable */
11667  uint32_t NCFTOE37:1; /* NCF 37 time-out enable */
11668  uint32_t NCFTOE36:1; /* NCF 36 time-out enable */
11669  uint32_t NCFTOE35:1; /* NCF 35 time-out enable */
11670  uint32_t NCFTOE34:1; /* NCF 34 time-out enable */
11671  uint32_t NCFTOE33:1; /* NCF 33 time-out enable */
11672  uint32_t NCFTOE32:1; /* NCF 32 time-out enable */
11673  } B;
11675
11676  typedef union { /* FCCU NCF Time-out Enable Register 2 */
11677  uint32_t R;
11678  struct {
11679  uint32_t NCFTOE95:1; /* NCF 95 time-out enable */
11680  uint32_t NCFTOE94:1; /* NCF 94 time-out enable */
11681  uint32_t NCFTOE93:1; /* NCF 93 time-out enable */
11682  uint32_t NCFTOE92:1; /* NCF 92 time-out enable */
11683  uint32_t NCFTOE91:1; /* NCF 91 time-out enable */
11684  uint32_t NCFTOE90:1; /* NCF 90 time-out enable */
11685  uint32_t NCFTOE89:1; /* NCF 89 time-out enable */
11686  uint32_t NCFTOE88:1; /* NCF 88 time-out enable */
11687  uint32_t NCFTOE87:1; /* NCF 87 time-out enable */
11688  uint32_t NCFTOE86:1; /* NCF 86 time-out enable */
11689  uint32_t NCFTOE85:1; /* NCF 85 time-out enable */
11690  uint32_t NCFTOE84:1; /* NCF 84 time-out enable */
11691  uint32_t NCFTOE83:1; /* NCF 83 time-out enable */
11692  uint32_t NCFTOE82:1; /* NCF 82 time-out enable */
11693  uint32_t NCFTOE81:1; /* NCF 81 time-out enable */
11694  uint32_t NCFTOE80:1; /* NCF 80 time-out enable */
11695  uint32_t NCFTOE79:1; /* NCF 79 time-out enable */
11696  uint32_t NCFTOE78:1; /* NCF 78 time-out enable */
11697  uint32_t NCFTOE77:1; /* NCF 77 time-out enable */
11698  uint32_t NCFTOE76:1; /* NCF 76 time-out enable */
11699  uint32_t NCFTOE75:1; /* NCF 75 time-out enable */
11700  uint32_t NCFTOE74:1; /* NCF 74 time-out enable */
11701  uint32_t NCFTOE73:1; /* NCF 73 time-out enable */
11702  uint32_t NCFTOE72:1; /* NCF 72 time-out enable */
11703  uint32_t NCFTOE71:1; /* NCF 71 time-out enable */
11704  uint32_t NCFTOE70:1; /* NCF 70 time-out enable */
11705  uint32_t NCFTOE69:1; /* NCF 69 time-out enable */
11706  uint32_t NCFTOE68:1; /* NCF 68 time-out enable */
11707  uint32_t NCFTOE67:1; /* NCF 67 time-out enable */
11708  uint32_t NCFTOE66:1; /* NCF 66 time-out enable */
11709  uint32_t NCFTOE65:1; /* NCF 65 time-out enable */
11710  uint32_t NCFTOE64:1; /* NCF 64 time-out enable */
11711  } B;
11713
11714  typedef union { /* FCCU NCF Time-out Enable Register 3 */
11715  uint32_t R;
11716  struct {
11717  uint32_t NCFTOE127:1; /* NCF 127 time-out enable */
11718  uint32_t NCFTOE126:1; /* NCF 126 time-out enable */
11719  uint32_t NCFTOE125:1; /* NCF 125 time-out enable */
11720  uint32_t NCFTOE124:1; /* NCF 124 time-out enable */
11721  uint32_t NCFTOE123:1; /* NCF 123 time-out enable */
11722  uint32_t NCFTOE122:1; /* NCF 122 time-out enable */
11723  uint32_t NCFTOE121:1; /* NCF 121 time-out enable */
11724  uint32_t NCFTOE120:1; /* NCF 120 time-out enable */
11725  uint32_t NCFTOE119:1; /* NCF 119 time-out enable */
11726  uint32_t NCFTOE118:1; /* NCF 118 time-out enable */
11727  uint32_t NCFTOE117:1; /* NCF 117 time-out enable */
11728  uint32_t NCFTOE116:1; /* NCF 116 time-out enable */
11729  uint32_t NCFTOE115:1; /* NCF 115 time-out enable */
11730  uint32_t NCFTOE114:1; /* NCF 114 time-out enable */
11731  uint32_t NCFTOE113:1; /* NCF 113 time-out enable */
11732  uint32_t NCFTOE112:1; /* NCF 112 time-out enable */
11733  uint32_t NCFTOE111:1; /* NCF 111 time-out enable */
11734  uint32_t NCFTOE110:1; /* NCF 110 time-out enable */
11735  uint32_t NCFTOE109:1; /* NCF 109 time-out enable */
11736  uint32_t NCFTOE108:1; /* NCF 108 time-out enable */
11737  uint32_t NCFTOE107:1; /* NCF 107 time-out enable */
11738  uint32_t NCFTOE106:1; /* NCF 106 time-out enable */
11739  uint32_t NCFTOE105:1; /* NCF 105 time-out enable */
11740  uint32_t NCFTOE104:1; /* NCF 104 time-out enable */
11741  uint32_t NCFTOE103:1; /* NCF 103 time-out enable */
11742  uint32_t NCFTOE102:1; /* NCF 102 time-out enable */
11743  uint32_t NCFTOE101:1; /* NCF 101 time-out enable */
11744  uint32_t NCFTOE100:1; /* NCF 100 time-out enable */
11745  uint32_t NCFTOE99:1; /* NCF 99 time-out enable */
11746  uint32_t NCFTOE98:1; /* NCF 98 time-out enable */
11747  uint32_t NCFTOE97:1; /* NCF 97 time-out enable */
11748  uint32_t NCFTOE96:1; /* NCF 96 time-out enable */
11749  } B;
11751
11752  typedef union { /* FCCU_NCF_TO - FCCU NCF Time-out Register */
11753  uint32_t R;
11755
11756  typedef union { /* FCCU_CFG_TO - FCCU CFG Timeout Register */
11757  uint32_t R;
11758  struct {
11759  uint32_t:29;
11760  uint32_t TO:3; /* Configuration time-out */
11761  } B;
11763
11764  typedef union { /* FCCU_EINOUT - FCCU IO Control Register */
11765  uint32_t R;
11766  struct {
11767  uint32_t:26;
11768  uint32_t EIN1:1; /* Error input 1 */
11769  uint32_t EIN0:1; /* Error input 0 */
11770  uint32_t:2;
11771  uint32_t EOUT1:1; /* Error out 1 */
11772  uint32_t EOUT0:1; /* Error out 0 */
11773  } B;
11775
11776  typedef union { /* FCCU_STAT - FCCU Status Register */
11777  uint32_t R;
11778  struct {
11779  uint32_t:29;
11780  uint32_t STATUS:3; /* FCCU status */
11781  } B;
11783
11784  typedef union { /* FCCU_NAFS - FCCU NA Freeze Status Register */
11785  uint32_t R;
11786  struct {
11787  uint32_t:24;
11788  uint32_t N2AFSTATUS:8; /* Normal to Alarm Frozen Status */
11789  } B;
11791
11792  typedef union { /* FCCU_AFFS - FCCU AF Freeze Status Register */
11793  uint32_t R;
11794  struct {
11795  uint32_t:22;
11796  uint32_t AFFS_SRC:2; /* Fault source */
11797  uint32_t A2AFSTATUS:8; /* Alarm to Fault Frozen Status */
11798  } B;
11800
11801  typedef union { /* FCCU_NFFS - FCCU NF Freeze Status Register */
11802  uint32_t R;
11803  struct {
11804  uint32_t:22;
11805  uint32_t NFFS_SRC:2; /* Fault source */
11806  uint32_t NFFS_NFFS:8; /* Normal to Fault Frozen Status */
11807  } B;
11809
11810  typedef union { /* FCCU_FAFS - FCCU FA Freeze Status Register */
11811  uint32_t R;
11812  struct {
11813  uint32_t:24;
11814  uint32_t FAFS_FAFS:8; /* Fault to Normal Frozen Status */
11815  } B;
11817
11818  typedef union { /* FCCU_SCFS - FCCU SC Freeze Status Register */
11819  uint32_t R;
11820  struct {
11821  uint32_t:30;
11822  uint32_t RCCS1:1; /* RCC1 Status */
11823  uint32_t RCCS0:1; /* RCC0 Status */
11824  } B;
11826
11827  typedef union { /* FCCU_CFF - FCCU CF Fake Register */
11828  uint32_t R;
11829  struct {
11830  uint32_t:25;
11831  uint32_t FCFC:7; /* Fake critical fault code */
11832  } B;
11833  } FCCU_CFF_32B_tag;
11834
11835  typedef union { /* FCCU_NCFF - FCCU NCF Fake Register */
11836  uint32_t R;
11837  struct {
11838  uint32_t:25;
11839  uint32_t FNCFC:7; /* Fake non-critical fault code */
11840  } B;
11842
11843  typedef union { /* FCCU_IRQ_STAT - FCCU IRQ Status Register */
11844  uint32_t R;
11845  struct {
11846  uint32_t:29;
11847  uint32_t NMI_STAT:1; /* NMI Interrupt Status */
11848  uint32_t ALRM_STAT:1; /* Alarm Interrupt Status */
11849  uint32_t CFG_TO_STAT:1; /* Configuration Time-out Status */
11850  } B;
11852
11853  typedef union { /* FCCU_IRQ_EN - FCCU IRQ Enable Register */
11854  uint32_t R;
11855  struct {
11856  uint32_t:31;
11857  uint32_t CFG_TO_IEN:1; /* Configuration Time-out Interrupt Enable */
11858  } B;
11860
11861  typedef union { /* FCCU_XTMR - FCCU XTMR Register */
11862  uint32_t R;
11863  struct {
11864  uint32_t XTMR_XTMR:32; /* Alarm/Watchdog/safe request timer */
11865  } B;
11867
11868  typedef union { /* FCCU_MCS - FCCU MCS Register */
11869  uint32_t R;
11870  struct {
11871  uint32_t VL3:1; /* Valid */
11872  uint32_t FS3:1; /* Fault Status */
11873  uint32_t:2;
11874  uint32_t MCS3:4; /* Magic Carpet oldest state */
11875  uint32_t VL2:1; /* Valid */
11876  uint32_t FS2:1; /* Fault Status */
11877  uint32_t:2;
11878  uint32_t MCS2:4; /* Magic Carpet previous-previous state */
11879  uint32_t VL1:1; /* Valid */
11880  uint32_t FS1:1; /* Fault Status */
11881  uint32_t:2;
11882  uint32_t MCS1:4; /* Magic Carpet previous state */
11883  uint32_t VL0:1; /* Valid */
11884  uint32_t FS0:1; /* Fault Status */
11885  uint32_t:2;
11886  uint32_t MCS0:4; /* Magic Carpet latest state */
11887  } B;
11888  } FCCU_MCS_32B_tag;
11889
11890
11891  /* Register layout for generated register(s) CF_CFG... */
11892
11893  typedef union { /* */
11894  uint32_t R;
11896
11897
11898  /* Register layout for generated register(s) NCF_CFG... */
11899
11900  typedef union { /* */
11901  uint32_t R;
11903
11904
11905  /* Register layout for generated register(s) CFS_CFG... */
11906
11907  typedef union { /* */
11908  uint32_t R;
11910
11911
11912  /* Register layout for generated register(s) NCFS_CFG... */
11913
11914  typedef union { /* */
11915  uint32_t R;
11917
11918
11919  /* Register layout for generated register(s) CFS... */
11920
11921  typedef union { /* */
11922  uint32_t R;
11923  } FCCU_CFS_32B_tag;
11924
11925
11926  /* Register layout for generated register(s) NCFS... */
11927
11928  typedef union { /* */
11929  uint32_t R;
11931
11932
11933  /* Register layout for generated register(s) NCFE... */
11934
11935  typedef union { /* */
11936  uint32_t R;
11938
11939
11940  /* Register layout for generated register(s) NCF_TOE... */
11941
11942  typedef union { /* */
11943  uint32_t R;
11945
11946
11947
11948  typedef struct FCCU_struct_tag { /* start of FCCU_tag */
11949  /* FCCU Control Register */
11950  FCCU_CTRL_32B_tag CTRL; /* offset: 0x0000 size: 32 bit */
11951  /* FCCU CTRL Key Register */
11952  FCCU_CTRLK_32B_tag CTRLK; /* offset: 0x0004 size: 32 bit */
11953  /* FCCU Configuration Register */
11954  FCCU_CFG_32B_tag CFG; /* offset: 0x0008 size: 32 bit */
11955  union {
11956  FCCU_CF_CFG_32B_tag CF_CFG[4]; /* offset: 0x000C (0x0004 x 4) */
11957
11958  struct {
11959  /* FCCU CF Configuration Register 0 */
11960  FCCU_CF_CFG0_32B_tag CF_CFG0; /* offset: 0x000C size: 32 bit */
11961  /* FCCU CF Configuration Register 1 */
11962  FCCU_CF_CFG1_32B_tag CF_CFG1; /* offset: 0x0010 size: 32 bit */
11963  /* FCCU CF Configuration Register 2 */
11964  FCCU_CF_CFG2_32B_tag CF_CFG2; /* offset: 0x0014 size: 32 bit */
11965  /* FCCU CF Configuration Register 3 */
11966  FCCU_CF_CFG3_32B_tag CF_CFG3; /* offset: 0x0018 size: 32 bit */
11967  };
11968
11969  };
11970  union {
11971  FCCU_NCF_CFG_32B_tag NCF_CFG[4]; /* offset: 0x001C (0x0004 x 4) */
11972
11973  struct {
11974  /* FCCU NCF Configuration Register 0 */
11975  FCCU_NCF_CFG0_32B_tag NCF_CFG0; /* offset: 0x001C size: 32 bit */
11976  /* FCCU NCF Configuration Register 1 */
11977  FCCU_NCF_CFG1_32B_tag NCF_CFG1; /* offset: 0x0020 size: 32 bit */
11978  /* FCCU NCF Configuration Register 2 */
11979  FCCU_NCF_CFG2_32B_tag NCF_CFG2; /* offset: 0x0024 size: 32 bit */
11980  /* FCCU NCF Configuration Register 3 */
11981  FCCU_NCF_CFG3_32B_tag NCF_CFG3; /* offset: 0x0028 size: 32 bit */
11982  };
11983
11984  };
11985  union {
11986  FCCU_CFS_CFG_32B_tag CFS_CFG[8]; /* offset: 0x002C (0x0004 x 8) */
11987
11988  struct {
11989  /* FCCU CFS Configuration Register 0 */
11990  FCCU_CFS_CFG0_32B_tag CFS_CFG0; /* offset: 0x002C size: 32 bit */
11991  /* FCCU CFS Configuration Register 1 */
11992  FCCU_CFS_CFG1_32B_tag CFS_CFG1; /* offset: 0x0030 size: 32 bit */
11993  /* FCCU CFS Configuration Register 2 */
11994  FCCU_CFS_CFG2_32B_tag CFS_CFG2; /* offset: 0x0034 size: 32 bit */
11995  /* FCCU CFS Configuration Register 3 */
11996  FCCU_CFS_CFG3_32B_tag CFS_CFG3; /* offset: 0x0038 size: 32 bit */
11997  /* FCCU CFS Configuration Register 4 */
11998  FCCU_CFS_CFG4_32B_tag CFS_CFG4; /* offset: 0x003C size: 32 bit */
11999  /* FCCU CFS Configuration Register 5 */
12000  FCCU_CFS_CFG5_32B_tag CFS_CFG5; /* offset: 0x0040 size: 32 bit */
12001  /* FCCU CFS Configuration Register 6 */
12002  FCCU_CFS_CFG6_32B_tag CFS_CFG6; /* offset: 0x0044 size: 32 bit */
12003  /* FCCU CFS Configuration Register 7 */
12004  FCCU_CFS_CFG7_32B_tag CFS_CFG7; /* offset: 0x0048 size: 32 bit */
12005  };
12006
12007  };
12008  union {
12009  FCCU_NCFS_CFG_32B_tag NCFS_CFG[8]; /* offset: 0x004C (0x0004 x 8) */
12010
12011  struct {
12012  /* FCCU NCFS Configuration Register 0 */
12013  FCCU_NCFS_CFG0_32B_tag NCFS_CFG0; /* offset: 0x004C size: 32 bit */
12014  /* FCCU NCFS Configuration Register 1 */
12015  FCCU_NCFS_CFG1_32B_tag NCFS_CFG1; /* offset: 0x0050 size: 32 bit */
12016  /* FCCU NCFS Configuration Register 2 */
12017  FCCU_NCFS_CFG2_32B_tag NCFS_CFG2; /* offset: 0x0054 size: 32 bit */
12018  /* FCCU NCFS Configuration Register 3 */
12019  FCCU_NCFS_CFG3_32B_tag NCFS_CFG3; /* offset: 0x0058 size: 32 bit */
12020  /* FCCU NCFS Configuration Register 4 */
12021  FCCU_NCFS_CFG4_32B_tag NCFS_CFG4; /* offset: 0x005C size: 32 bit */
12022  /* FCCU NCFS Configuration Register 5 */
12023  FCCU_NCFS_CFG5_32B_tag NCFS_CFG5; /* offset: 0x0060 size: 32 bit */
12024  /* FCCU NCFS Configuration Register 6 */
12025  FCCU_NCFS_CFG6_32B_tag NCFS_CFG6; /* offset: 0x0064 size: 32 bit */
12026  /* FCCU NCFS Configuration Register 7 */
12027  FCCU_NCFS_CFG7_32B_tag NCFS_CFG7; /* offset: 0x0068 size: 32 bit */
12028  };
12029
12030  };
12031  union {
12032  FCCU_CFS_32B_tag CFS[4]; /* offset: 0x006C (0x0004 x 4) */
12033
12034  struct {
12035  /* FCCU CF Status Register 0 */
12036  FCCU_CFS0_32B_tag CFS0; /* offset: 0x006C size: 32 bit */
12037  /* FCCU CF Status Register 1 */
12038  FCCU_CFS1_32B_tag CFS1; /* offset: 0x0070 size: 32 bit */
12039  /* FCCU CF Status Register 2 */
12040  FCCU_CFS2_32B_tag CFS2; /* offset: 0x0074 size: 32 bit */
12041  /* FCCU CF Status Register 3 */
12042  FCCU_CFS3_32B_tag CFS3; /* offset: 0x0078 size: 32 bit */
12043  };
12044
12045  };
12046  /* FCCU_CFK - FCCU CF Key Register */
12047  FCCU_CFK_32B_tag CFK; /* offset: 0x007C size: 32 bit */
12048  union {
12049  FCCU_NCFS_32B_tag NCFS[4]; /* offset: 0x0080 (0x0004 x 4) */
12050
12051  struct {
12052  /* FCCU NCF Status Register 0 */
12053  FCCU_NCFS0_32B_tag NCFS0; /* offset: 0x0080 size: 32 bit */
12054  /* FCCU NCF Status Register 1 */
12055  FCCU_NCFS1_32B_tag NCFS1; /* offset: 0x0084 size: 32 bit */
12056  /* FCCU NCF Status Register 2 */
12057  FCCU_NCFS2_32B_tag NCFS2; /* offset: 0x0088 size: 32 bit */
12058  /* FCCU NCF Status Register 3 */
12059  FCCU_NCFS3_32B_tag NCFS3; /* offset: 0x008C size: 32 bit */
12060  };
12061
12062  };
12063  /* FCCU_NCFK - FCCU NCF Key Register */
12064  FCCU_NCFK_32B_tag NCFK; /* offset: 0x0090 size: 32 bit */
12065  union {
12066  FCCU_NCFE_32B_tag NCFE[4]; /* offset: 0x0094 (0x0004 x 4) */
12067
12068  struct {
12069  /* FCCU NCF Enable Register 0 */
12070  FCCU_NCFE0_32B_tag NCFE0; /* offset: 0x0094 size: 32 bit */
12071  /* FCCU NCF Enable Register 1 */
12072  FCCU_NCFE1_32B_tag NCFE1; /* offset: 0x0098 size: 32 bit */
12073  /* FCCU NCF Enable Register 2 */
12074  FCCU_NCFE2_32B_tag NCFE2; /* offset: 0x009C size: 32 bit */
12075  /* FCCU NCF Enable Register 3 */
12076  FCCU_NCFE3_32B_tag NCFE3; /* offset: 0x00A0 size: 32 bit */
12077  };
12078
12079  };
12080  union {
12081  FCCU_NCF_TOE_32B_tag NCF_TOE[4]; /* offset: 0x00A4 (0x0004 x 4) */
12082
12083  struct {
12084  /* FCCU NCF Time-out Enable Register 0 */
12085  FCCU_NCF_TOE0_32B_tag NCF_TOE0; /* offset: 0x00A4 size: 32 bit */
12086  /* FCCU NCF Time-out Enable Register 1 */
12087  FCCU_NCF_TOE1_32B_tag NCF_TOE1; /* offset: 0x00A8 size: 32 bit */
12088  /* FCCU NCF Time-out Enable Register 2 */
12089  FCCU_NCF_TOE2_32B_tag NCF_TOE2; /* offset: 0x00AC size: 32 bit */
12090  /* FCCU NCF Time-out Enable Register 3 */
12091  FCCU_NCF_TOE3_32B_tag NCF_TOE3; /* offset: 0x00B0 size: 32 bit */
12092  };
12093
12094  };
12095  /* FCCU_NCF_TO - FCCU NCF Time-out Register */
12096  FCCU_NCF_TO_32B_tag NCF_TO; /* offset: 0x00B4 size: 32 bit */
12097  /* FCCU_CFG_TO - FCCU CFG Timeout Register */
12098  FCCU_CFG_TO_32B_tag CFG_TO; /* offset: 0x00B8 size: 32 bit */
12099  /* FCCU_EINOUT - FCCU IO Control Register */
12100  FCCU_EINOUT_32B_tag EINOUT; /* offset: 0x00BC size: 32 bit */
12101  /* FCCU_STAT - FCCU Status Register */
12102  FCCU_STAT_32B_tag STAT; /* offset: 0x00C0 size: 32 bit */
12103  /* FCCU_NAFS - FCCU NA Freeze Status Register */
12104  FCCU_NAFS_32B_tag NAFS; /* offset: 0x00C4 size: 32 bit */
12105  /* FCCU_AFFS - FCCU AF Freeze Status Register */
12106  FCCU_AFFS_32B_tag AFFS; /* offset: 0x00C8 size: 32 bit */
12107  /* FCCU_NFFS - FCCU NF Freeze Status Register */
12108  FCCU_NFFS_32B_tag NFFS; /* offset: 0x00CC size: 32 bit */
12109  /* FCCU_FAFS - FCCU FA Freeze Status Register */
12110  FCCU_FAFS_32B_tag FAFS; /* offset: 0x00D0 size: 32 bit */
12111  /* FCCU_SCFS - FCCU SC Freeze Status Register */
12112  FCCU_SCFS_32B_tag SCFS; /* offset: 0x00D4 size: 32 bit */
12113  /* FCCU_CFF - FCCU CF Fake Register */
12114  FCCU_CFF_32B_tag CFF; /* offset: 0x00D8 size: 32 bit */
12115  /* FCCU_NCFF - FCCU NCF Fake Register */
12116  FCCU_NCFF_32B_tag NCFF; /* offset: 0x00DC size: 32 bit */
12117  /* FCCU_IRQ_STAT - FCCU IRQ Status Register */
12118  FCCU_IRQ_STAT_32B_tag IRQ_STAT; /* offset: 0x00E0 size: 32 bit */
12119  /* FCCU_IRQ_EN - FCCU IRQ Enable Register */
12120  FCCU_IRQ_EN_32B_tag IRQ_EN; /* offset: 0x00E4 size: 32 bit */
12121  /* FCCU_XTMR - FCCU XTMR Register */
12122  FCCU_XTMR_32B_tag XTMR; /* offset: 0x00E8 size: 32 bit */
12123  /* FCCU_MCS - FCCU MCS Register */
12124  FCCU_MCS_32B_tag MCS; /* offset: 0x00EC size: 32 bit */
12125  } FCCU_tag;
12126
12127
12128 #define FCCU (*(volatile FCCU_tag *) 0xFFE6C000UL)
12129
12130
12131
12132 /****************************************************************/
12133 /* */
12134 /* Module: SGENDIG */
12135 /* */
12136 /****************************************************************/
12137
12138  typedef union { /* SGENDIG_CTRL - SGENDIG Control Register */
12139  uint32_t R;
12140  struct {
12141  uint32_t LDOS:1; /* Operation Status */
12142  uint32_t IOAMPL:5; /* Define the AMPLitude value on I/O pad */
12143  uint32_t:2;
12144  uint32_t SEMASK:1; /* Sine wave generator Error MASK interrupt register */
12145  uint32_t:5;
12146  uint32_t S0H1:1; /* Operation Status */
12147  uint32_t PDS:1; /* Operation Status */
12148  uint32_t IOFREQ:16; /* Define the FREQuency value on I/O pad */
12149  } B;
12151
12152  typedef union { /* SGENDIG_IRQE - SGENDIG Interrupt Request Enable Register */
12153  uint32_t R;
12154  struct {
12155  uint32_t:8;
12156  uint32_t SERR:1; /* Sine wave generator Error bit */
12157  uint32_t:3;
12158  uint32_t FERR:1; /* Sine wave generator Force Error bit */
12159  uint32_t:19;
12160  } B;
12162
12163
12164
12165  typedef struct SGENDIG_struct_tag { /* start of SGENDIG_tag */
12166  /* SGENDIG_CTRL - SGENDIG Control Register */
12167  SGENDIG_CTRL_32B_tag CTRL; /* offset: 0x0000 size: 32 bit */
12168  /* SGENDIG_IRQE - SGENDIG Interrupt Request Enable Register */
12169  SGENDIG_IRQE_32B_tag IRQE; /* offset: 0x0004 size: 32 bit */
12170  } SGENDIG_tag;
12171
12172
12173 #define SGENDIG (*(volatile SGENDIG_tag *) 0xFFE78000UL)
12174
12175
12176
12177 /****************************************************************/
12178 /* */
12179 /* Module: PBRIDGE */
12180 /* */
12181 /****************************************************************/
12182
12183  typedef union { /* MPROT - Master Privilege Registers */
12184  uint32_t R;
12185  struct {
12186  uint32_t MPROT0_MBW:1; /* Master 0 Buffer Writes */
12187  uint32_t MPROT0_MTR:1; /* Master 0 Trusted for Reads */
12188  uint32_t MPROT0_MTW:1; /* Master 0 Trusted for Writes */
12189  uint32_t MPROT0_MPL:1; /* Master 0 Priviledge Level */
12190  uint32_t MPROT1_MBW:1; /* Master 1 Buffer Writes */
12191  uint32_t MPROT1_MTR:1; /* Master 1 Trusted for Reads */
12192  uint32_t MPROT1_MTW:1; /* Master 1 Trusted for Writes */
12193  uint32_t MPROT1_MPL:1; /* Master 1 Priviledge Level */
12194  uint32_t MPROT2_MBW:1; /* Master 2 Buffer Writes */
12195  uint32_t MPROT2_MTR:1; /* Master 2 Trusted for Reads */
12196  uint32_t MPROT2_MTW:1; /* Master 2 Trusted for Writes */
12197  uint32_t MPROT2_MPL:1; /* Master 2 Priviledge Level */
12198  uint32_t MPROT3_MBW:1; /* Master 3 Buffer Writes */
12199  uint32_t MPROT3_MTR:1; /* Master 3 Trusted for Reads */
12200  uint32_t MPROT3_MTW:1; /* Master 3 Trusted for Writes */
12201  uint32_t MPROT3_MPL:1; /* Master 3 Priviledge Level */
12202  uint32_t MPROT4_MBW:1; /* Master 4 Buffer Writes */
12203  uint32_t MPROT4_MTR:1; /* Master 4 Trusted for Reads */
12204  uint32_t MPROT4_MTW:1; /* Master 4 Trusted for Writes */
12205  uint32_t MPROT4_MPL:1; /* Master 4 Priviledge Level */
12206  uint32_t MPROT5_MBW:1; /* Master 5 Buffer Writes */
12207  uint32_t MPROT5_MTR:1; /* Master 5 Trusted for Reads */
12208  uint32_t MPROT5_MTW:1; /* Master 5 Trusted for Writes */
12209  uint32_t MPROT5_MPL:1; /* Master 5 Priviledge Level */
12210  uint32_t MPROT6_MBW:1; /* Master 6 Buffer Writes */
12211  uint32_t MPROT6_MTR:1; /* Master 6 Trusted for Reads */
12212  uint32_t MPROT6_MTW:1; /* Master 6 Trusted for Writes */
12213  uint32_t MPROT6_MPL:1; /* Master 6 Priviledge Level */
12214  uint32_t MPROT7_MBW:1; /* Master 7 Buffer Writes */
12215  uint32_t MPROT7_MTR:1; /* Master 7 Trusted for Reads */
12216  uint32_t MPROT7_MTW:1; /* Master 7 Trusted for Writes */
12217  uint32_t MPROT7_MPL:1; /* Master 7 Priviledge Level */
12218  } B;
12220
12221  typedef union { /* PACR0_7 - Peripheral Access Control Registers */
12222  uint32_t R;
12223  struct {
12224  uint32_t PACR0_BW:1; /* Buffer Writes */
12225  uint32_t PACR0_SP:1; /* Supervisor Protect */
12226  uint32_t PACR0_WP:1; /* Write Protect */
12227  uint32_t PACR0_TP:1; /* Trusted Protect */
12228  uint32_t PACR1_BW:1; /* Buffer Writes */
12229  uint32_t PACR1_SP:1; /* Supervisor Protect */
12230  uint32_t PACR1_WP:1; /* Write Protect */
12231  uint32_t PACR1_TP:1; /* Trusted Protect */
12232  uint32_t PACR2_BW:1; /* Buffer Writes */
12233  uint32_t PACR2_SP:1; /* Supervisor Protect */
12234  uint32_t PACR2_WP:1; /* Write Protect */
12235  uint32_t PACR2_TP:1; /* Trusted Protect */
12236  uint32_t PACR3_BW:1; /* Buffer Writes */
12237  uint32_t PACR3_SP:1; /* Supervisor Protect */
12238  uint32_t PACR3_WP:1; /* Write Protect */
12239  uint32_t PACR3_TP:1; /* Trusted Protect */
12240  uint32_t PACR4_BW:1; /* Buffer Writes */
12241  uint32_t PACR4_SP:1; /* Supervisor Protect */
12242  uint32_t PACR4_WP:1; /* Write Protect */
12243  uint32_t PACR4_TP:1; /* Trusted Protect */
12244  uint32_t PACR5_BW:1; /* Buffer Writes */
12245  uint32_t PACR5_SP:1; /* Supervisor Protect */
12246  uint32_t PACR5_WP:1; /* Write Protect */
12247  uint32_t PACR5_TP:1; /* Trusted Protect */
12248  uint32_t PACR6_BW:1; /* Buffer Writes */
12249  uint32_t PACR6_SP:1; /* Supervisor Protect */
12250  uint32_t PACR6_WP:1; /* Write Protect */
12251  uint32_t PACR6_TP:1; /* Trusted Protect */
12252  uint32_t PACR7_BW:1; /* Buffer Writes */
12253  uint32_t PACR7_SP:1; /* Supervisor Protect */
12254  uint32_t PACR7_WP:1; /* Write Protect */
12255  uint32_t PACR7_TP:1; /* Trusted Protect */
12256  } B;
12258
12259  typedef union { /* PACR8_15 - Peripheral Access Control Registers */
12260  uint32_t R;
12261  struct {
12262  uint32_t PACR8_BW:1; /* Buffer Writes */
12263  uint32_t PACR8_SP:1; /* Supervisor Protect */
12264  uint32_t PACR8_WP:1; /* Write Protect */
12265  uint32_t PACR8_TP:1; /* Trusted Protect */
12266  uint32_t PACR9_BW:1; /* Buffer Writes */
12267  uint32_t PACR9_SP:1; /* Supervisor Protect */
12268  uint32_t PACR9_WP:1; /* Write Protect */
12269  uint32_t PACR9_TP:1; /* Trusted Protect */
12270  uint32_t PACR10_BW:1; /* Buffer Writes */
12271  uint32_t PACR10_SP:1; /* Supervisor Protect */
12272  uint32_t PACR10_WP:1; /* Write Protect */
12273  uint32_t PACR10_TP:1; /* Trusted Protect */
12274  uint32_t PACR11_BW:1; /* Buffer Writes */
12275  uint32_t PACR11_SP:1; /* Supervisor Protect */
12276  uint32_t PACR11_WP:1; /* Write Protect */
12277  uint32_t PACR11_TP:1; /* Trusted Protect */
12278  uint32_t PACR12_BW:1; /* Buffer Writes */
12279  uint32_t PACR12_SP:1; /* Supervisor Protect */
12280  uint32_t PACR12_WP:1; /* Write Protect */
12281  uint32_t PACR12_TP:1; /* Trusted Protect */
12282  uint32_t PACR13_BW:1; /* Buffer Writes */
12283  uint32_t PACR13_SP:1; /* Supervisor Protect */
12284  uint32_t PACR13_WP:1; /* Write Protect */
12285  uint32_t PACR13_TP:1; /* Trusted Protect */
12286  uint32_t PACR14_BW:1; /* Buffer Writes */
12287  uint32_t PACR14_SP:1; /* Supervisor Protect */
12288  uint32_t PACR14_WP:1; /* Write Protect */
12289  uint32_t PACR14_TP:1; /* Trusted Protect */
12290  uint32_t PACR15_BW:1; /* Buffer Writes */
12291  uint32_t PACR15_SP:1; /* Supervisor Protect */
12292  uint32_t PACR15_WP:1; /* Write Protect */
12293  uint32_t PACR15_TP:1; /* Trusted Protect */
12294  } B;
12296
12297  typedef union { /* PACR16_23 - Peripheral Access Control Registers */
12298  uint32_t R;
12299  struct {
12300  uint32_t PACR16_BW:1; /* Buffer Writes */
12301  uint32_t PACR16_SP:1; /* Supervisor Protect */
12302  uint32_t PACR16_WP:1; /* Write Protect */
12303  uint32_t PACR16_TP:1; /* Trusted Protect */
12304  uint32_t PACR17_BW:1; /* Buffer Writes */
12305  uint32_t PACR17_SP:1; /* Supervisor Protect */
12306  uint32_t PACR17_WP:1; /* Write Protect */
12307  uint32_t PACR17_TP:1; /* Trusted Protect */
12308  uint32_t PACR18_BW:1; /* Buffer Writes */
12309  uint32_t PACR18_SP:1; /* Supervisor Protect */
12310  uint32_t PACR18_WP:1; /* Write Protect */
12311  uint32_t PACR18_TP:1; /* Trusted Protect */
12312  uint32_t PACR19_BW:1; /* Buffer Writes */
12313  uint32_t PACR19_SP:1; /* Supervisor Protect */
12314  uint32_t PACR19_WP:1; /* Write Protect */
12315  uint32_t PACR19_TP:1; /* Trusted Protect */
12316  uint32_t PACR20_BW:1; /* Buffer Writes */
12317  uint32_t PACR20_SP:1; /* Supervisor Protect */
12318  uint32_t PACR20_WP:1; /* Write Protect */
12319  uint32_t PACR20_TP:1; /* Trusted Protect */
12320  uint32_t PACR21_BW:1; /* Buffer Writes */
12321  uint32_t PACR21_SP:1; /* Supervisor Protect */
12322  uint32_t PACR21_WP:1; /* Write Protect */
12323  uint32_t PACR21_TP:1; /* Trusted Protect */
12324  uint32_t PACR22_BW:1; /* Buffer Writes */
12325  uint32_t PACR22_SP:1; /* Supervisor Protect */
12326  uint32_t PACR22_WP:1; /* Write Protect */
12327  uint32_t PACR22_TP:1; /* Trusted Protect */
12328  uint32_t PACR23_BW:1; /* Buffer Writes */
12329  uint32_t PACR23_SP:1; /* Supervisor Protect */
12330  uint32_t PACR23_WP:1; /* Write Protect */
12331  uint32_t PACR23_TP:1; /* Trusted Protect */
12332  } B;
12334
12335  typedef union { /* PACR24_31 - Peripheral Access Control Registers */
12336  uint32_t R;
12337  struct {
12338  uint32_t PACR24_BW:1; /* Buffer Writes */
12339  uint32_t PACR24_SP:1; /* Supervisor Protect */
12340  uint32_t PACR24_WP:1; /* Write Protect */
12341  uint32_t PACR24_TP:1; /* Trusted Protect */
12342  uint32_t PACR25_BW:1; /* Buffer Writes */
12343  uint32_t PACR25_SP:1; /* Supervisor Protect */
12344  uint32_t PACR25_WP:1; /* Write Protect */
12345  uint32_t PACR25_TP:1; /* Trusted Protect */
12346  uint32_t PACR26_BW:1; /* Buffer Writes */
12347  uint32_t PACR26_SP:1; /* Supervisor Protect */
12348  uint32_t PACR26_WP:1; /* Write Protect */
12349  uint32_t PACR26_TP:1; /* Trusted Protect */
12350  uint32_t PACR27_BW:1; /* Buffer Writes */
12351  uint32_t PACR27_SP:1; /* Supervisor Protect */
12352  uint32_t PACR27_WP:1; /* Write Protect */
12353  uint32_t PACR27_TP:1; /* Trusted Protect */
12354  uint32_t PACR28_BW:1; /* Buffer Writes */
12355  uint32_t PACR28_SP:1; /* Supervisor Protect */
12356  uint32_t PACR28_WP:1; /* Write Protect */
12357  uint32_t PACR28_TP:1; /* Trusted Protect */
12358  uint32_t PACR29_BW:1; /* Buffer Writes */
12359  uint32_t PACR29_SP:1; /* Supervisor Protect */
12360  uint32_t PACR29_WP:1; /* Write Protect */
12361  uint32_t PACR29_TP:1; /* Trusted Protect */
12362  uint32_t PACR30_BW:1; /* Buffer Writes */
12363  uint32_t PACR30_SP:1; /* Supervisor Protect */
12364  uint32_t PACR30_WP:1; /* Write Protect */
12365  uint32_t PACR30_TP:1; /* Trusted Protect */
12366  uint32_t PACR31_BW:1; /* Buffer Writes */
12367  uint32_t PACR31_SP:1; /* Supervisor Protect */
12368  uint32_t PACR31_WP:1; /* Write Protect */
12369  uint32_t PACR31_TP:1; /* Trusted Protect */
12370  } B;
12372
12373  typedef union { /* OPACR0_7 - Off-Platform Peripheral Access Control Registers */
12374  uint32_t R;
12375  struct {
12376  uint32_t OPACR0_BW:1; /* Buffer Writes */
12377  uint32_t OPACR0_SP:1; /* Supervisor Protect */
12378  uint32_t OPACR0_WP:1; /* Write Protect */
12379  uint32_t OPACR0_TP:1; /* Trusted Protect */
12380  uint32_t OPACR1_BW:1; /* Buffer Writes */
12381  uint32_t OPACR1_SP:1; /* Supervisor Protect */
12382  uint32_t OPACR1_WP:1; /* Write Protect */
12383  uint32_t OPACR1_TP:1; /* Trusted Protect */
12384  uint32_t OPACR2_BW:1; /* Buffer Writes */
12385  uint32_t OPACR2_SP:1; /* Supervisor Protect */
12386  uint32_t OPACR2_WP:1; /* Write Protect */
12387  uint32_t OPACR2_TP:1; /* Trusted Protect */
12388  uint32_t OPACR3_BW:1; /* Buffer Writes */
12389  uint32_t OPACR3_SP:1; /* Supervisor Protect */
12390  uint32_t OPACR3_WP:1; /* Write Protect */
12391  uint32_t OPACR3_TP:1; /* Trusted Protect */
12392  uint32_t OPACR4_BW:1; /* Buffer Writes */
12393  uint32_t OPACR4_SP:1; /* Supervisor Protect */
12394  uint32_t OPACR4_WP:1; /* Write Protect */
12395  uint32_t OPACR4_TP:1; /* Trusted Protect */
12396  uint32_t OPACR5_BW:1; /* Buffer Writes */
12397  uint32_t OPACR5_SP:1; /* Supervisor Protect */
12398  uint32_t OPACR5_WP:1; /* Write Protect */
12399  uint32_t OPACR5_TP:1; /* Trusted Protect */
12400  uint32_t OPACR6_BW:1; /* Buffer Writes */
12401  uint32_t OPACR6_SP:1; /* Supervisor Protect */
12402  uint32_t OPACR6_WP:1; /* Write Protect */
12403  uint32_t OPACR6_TP:1; /* Trusted Protect */
12404  uint32_t OPACR7_BW:1; /* Buffer Writes */
12405  uint32_t OPACR7_SP:1; /* Supervisor Protect */
12406  uint32_t OPACR7_WP:1; /* Write Protect */
12407  uint32_t OPACR7_TP:1; /* Trusted Protect */
12408  } B;
12410
12411  typedef union { /* OPACR8_15 - Off-Platform Peripheral Access Control Registers */
12412  uint32_t R;
12413  struct {
12414  uint32_t OPACR8_BW:1; /* Buffer Writes */
12415  uint32_t OPACR8_SP:1; /* Supervisor Protect */
12416  uint32_t OPACR8_WP:1; /* Write Protect */
12417  uint32_t OPACR8_TP:1; /* Trusted Protect */
12418  uint32_t OPACR9_BW:1; /* Buffer Writes */
12419  uint32_t OPACR9_SP:1; /* Supervisor Protect */
12420  uint32_t OPACR9_WP:1; /* Write Protect */
12421  uint32_t OPACR9_TP:1; /* Trusted Protect */
12422  uint32_t OPACR10_BW:1; /* Buffer Writes */
12423  uint32_t OPACR10_SP:1; /* Supervisor Protect */
12424  uint32_t OPACR10_WP:1; /* Write Protect */
12425  uint32_t OPACR10_TP:1; /* Trusted Protect */
12426  uint32_t OPACR11_BW:1; /* Buffer Writes */
12427  uint32_t OPACR11_SP:1; /* Supervisor Protect */
12428  uint32_t OPACR11_WP:1; /* Write Protect */
12429  uint32_t OPACR11_TP:1; /* Trusted Protect */
12430  uint32_t OPACR12_BW:1; /* Buffer Writes */
12431  uint32_t OPACR12_SP:1; /* Supervisor Protect */
12432  uint32_t OPACR12_WP:1; /* Write Protect */
12433  uint32_t OPACR12_TP:1; /* Trusted Protect */
12434  uint32_t OPACR13_BW:1; /* Buffer Writes */
12435  uint32_t OPACR13_SP:1; /* Supervisor Protect */
12436  uint32_t OPACR13_WP:1; /* Write Protect */
12437  uint32_t OPACR13_TP:1; /* Trusted Protect */
12438  uint32_t OPACR14_BW:1; /* Buffer Writes */
12439  uint32_t OPACR14_SP:1; /* Supervisor Protect */
12440  uint32_t OPACR14_WP:1; /* Write Protect */
12441  uint32_t OPACR14_TP:1; /* Trusted Protect */
12442  uint32_t OPACR15_BW:1; /* Buffer Writes */
12443  uint32_t OPACR15_SP:1; /* Supervisor Protect */
12444  uint32_t OPACR15_WP:1; /* Write Protect */
12445  uint32_t OPACR15_TP:1; /* Trusted Protect */
12446  } B;
12448
12449  typedef union { /* OPACR16_23 - Off-Platform Peripheral Access Control Registers */
12450  uint32_t R;
12451  struct {
12452  uint32_t OPACR16_BW:1; /* Buffer Writes */
12453  uint32_t OPACR16_SP:1; /* Supervisor Protect */
12454  uint32_t OPACR16_WP:1; /* Write Protect */
12455  uint32_t OPACR16_TP:1; /* Trusted Protect */
12456  uint32_t OPACR17_BW:1; /* Buffer Writes */
12457  uint32_t OPACR17_SP:1; /* Supervisor Protect */
12458  uint32_t OPACR17_WP:1; /* Write Protect */
12459  uint32_t OPACR17_TP:1; /* Trusted Protect */
12460  uint32_t OPACR18_BW:1; /* Buffer Writes */
12461  uint32_t OPACR18_SP:1; /* Supervisor Protect */
12462  uint32_t OPACR18_WP:1; /* Write Protect */
12463  uint32_t OPACR18_TP:1; /* Trusted Protect */
12464  uint32_t OPACR19_BW:1; /* Buffer Writes */
12465  uint32_t OPACR19_SP:1; /* Supervisor Protect */
12466  uint32_t OPACR19_WP:1; /* Write Protect */
12467  uint32_t OPACR19_TP:1; /* Trusted Protect */
12468  uint32_t OPACR20_BW:1; /* Buffer Writes */
12469  uint32_t OPACR20_SP:1; /* Supervisor Protect */
12470  uint32_t OPACR20_WP:1; /* Write Protect */
12471  uint32_t OPACR20_TP:1; /* Trusted Protect */
12472  uint32_t OPACR21_BW:1; /* Buffer Writes */
12473  uint32_t OPACR21_SP:1; /* Supervisor Protect */
12474  uint32_t OPACR21_WP:1; /* Write Protect */
12475  uint32_t OPACR21_TP:1; /* Trusted Protect */
12476  uint32_t OPACR22_BW:1; /* Buffer Writes */
12477  uint32_t OPACR22_SP:1; /* Supervisor Protect */
12478  uint32_t OPACR22_WP:1; /* Write Protect */
12479  uint32_t OPACR22_TP:1; /* Trusted Protect */
12480  uint32_t OPACR23_BW:1; /* Buffer Writes */
12481  uint32_t OPACR23_SP:1; /* Supervisor Protect */
12482  uint32_t OPACR23_WP:1; /* Write Protect */
12483  uint32_t OPACR23_TP:1; /* Trusted Protect */
12484  } B;
12486
12487  typedef union { /* OPACR24_31 - Off-Platform Peripheral Access Control Registers */
12488  uint32_t R;
12489  struct {
12490  uint32_t OPACR24_BW:1; /* Buffer Writes */
12491  uint32_t OPACR24_SP:1; /* Supervisor Protect */
12492  uint32_t OPACR24_WP:1; /* Write Protect */
12493  uint32_t OPACR24_TP:1; /* Trusted Protect */
12494  uint32_t OPACR25_BW:1; /* Buffer Writes */
12495  uint32_t OPACR25_SP:1; /* Supervisor Protect */
12496  uint32_t OPACR25_WP:1; /* Write Protect */
12497  uint32_t OPACR25_TP:1; /* Trusted Protect */
12498  uint32_t OPACR26_BW:1; /* Buffer Writes */
12499  uint32_t OPACR26_SP:1; /* Supervisor Protect */
12500  uint32_t OPACR26_WP:1; /* Write Protect */
12501  uint32_t OPACR26_TP:1; /* Trusted Protect */
12502  uint32_t OPACR27_BW:1; /* Buffer Writes */
12503  uint32_t OPACR27_SP:1; /* Supervisor Protect */
12504  uint32_t OPACR27_WP:1; /* Write Protect */
12505  uint32_t OPACR27_TP:1; /* Trusted Protect */
12506  uint32_t OPACR28_BW:1; /* Buffer Writes */
12507  uint32_t OPACR28_SP:1; /* Supervisor Protect */
12508  uint32_t OPACR28_WP:1; /* Write Protect */
12509  uint32_t OPACR28_TP:1; /* Trusted Protect */
12510  uint32_t OPACR29_BW:1; /* Buffer Writes */
12511  uint32_t OPACR29_SP:1; /* Supervisor Protect */
12512  uint32_t OPACR29_WP:1; /* Write Protect */
12513  uint32_t OPACR29_TP:1; /* Trusted Protect */
12514  uint32_t OPACR30_BW:1; /* Buffer Writes */
12515  uint32_t OPACR30_SP:1; /* Supervisor Protect */
12516  uint32_t OPACR30_WP:1; /* Write Protect */
12517  uint32_t OPACR30_TP:1; /* Trusted Protect */
12518  uint32_t OPACR31_BW:1; /* Buffer Writes */
12519  uint32_t OPACR31_SP:1; /* Supervisor Protect */
12520  uint32_t OPACR31_WP:1; /* Write Protect */
12521  uint32_t OPACR31_TP:1; /* Trusted Protect */
12522  } B;
12524
12525  typedef union { /* OPACR32_39 - Off-Platform Peripheral Access Control Registers */
12526  uint32_t R;
12527  struct {
12528  uint32_t OPACR32_BW:1; /* Buffer Writes */
12529  uint32_t OPACR32_SP:1; /* Supervisor Protect */
12530  uint32_t OPACR32_WP:1; /* Write Protect */
12531  uint32_t OPACR32_TP:1; /* Trusted Protect */
12532  uint32_t OPACR33_BW:1; /* Buffer Writes */
12533  uint32_t OPACR33_SP:1; /* Supervisor Protect */
12534  uint32_t OPACR33_WP:1; /* Write Protect */
12535  uint32_t OPACR33_TP:1; /* Trusted Protect */
12536  uint32_t OPACR34_BW:1; /* Buffer Writes */
12537  uint32_t OPACR34_SP:1; /* Supervisor Protect */
12538  uint32_t OPACR34_WP:1; /* Write Protect */
12539  uint32_t OPACR34_TP:1; /* Trusted Protect */
12540  uint32_t OPACR35_BW:1; /* Buffer Writes */
12541  uint32_t OPACR35_SP:1; /* Supervisor Protect */
12542  uint32_t OPACR35_WP:1; /* Write Protect */
12543  uint32_t OPACR35_TP:1; /* Trusted Protect */
12544  uint32_t OPACR36_BW:1; /* Buffer Writes */
12545  uint32_t OPACR36_SP:1; /* Supervisor Protect */
12546  uint32_t OPACR36_WP:1; /* Write Protect */
12547  uint32_t OPACR36_TP:1; /* Trusted Protect */
12548  uint32_t OPACR37_BW:1; /* Buffer Writes */
12549  uint32_t OPACR37_SP:1; /* Supervisor Protect */
12550  uint32_t OPACR37_WP:1; /* Write Protect */
12551  uint32_t OPACR37_TP:1; /* Trusted Protect */
12552  uint32_t OPACR38_BW:1; /* Buffer Writes */
12553  uint32_t OPACR38_SP:1; /* Supervisor Protect */
12554  uint32_t OPACR38_WP:1; /* Write Protect */
12555  uint32_t OPACR38_TP:1; /* Trusted Protect */
12556  uint32_t OPACR39_BW:1; /* Buffer Writes */
12557  uint32_t OPACR39_SP:1; /* Supervisor Protect */
12558  uint32_t OPACR39_WP:1; /* Write Protect */
12559  uint32_t OPACR39_TP:1; /* Trusted Protect */
12560  } B;
12562
12563  typedef union { /* OPACR40_47 - Off-Platform Peripheral Access Control Registers */
12564  uint32_t R;
12565  struct {
12566  uint32_t OPACR40_BW:1; /* Buffer Writes */
12567  uint32_t OPACR40_SP:1; /* Supervisor Protect */
12568  uint32_t OPACR40_WP:1; /* Write Protect */
12569  uint32_t OPACR40_TP:1; /* Trusted Protect */
12570  uint32_t OPACR41_BW:1; /* Buffer Writes */
12571  uint32_t OPACR41_SP:1; /* Supervisor Protect */
12572  uint32_t OPACR41_WP:1; /* Write Protect */
12573  uint32_t OPACR41_TP:1; /* Trusted Protect */
12574  uint32_t OPACR42_BW:1; /* Buffer Writes */
12575  uint32_t OPACR42_SP:1; /* Supervisor Protect */
12576  uint32_t OPACR42_WP:1; /* Write Protect */
12577  uint32_t OPACR42_TP:1; /* Trusted Protect */
12578  uint32_t OPACR43_BW:1; /* Buffer Writes */
12579  uint32_t OPACR43_SP:1; /* Supervisor Protect */
12580  uint32_t OPACR43_WP:1; /* Write Protect */
12581  uint32_t OPACR43_TP:1; /* Trusted Protect */
12582  uint32_t OPACR44_BW:1; /* Buffer Writes */
12583  uint32_t OPACR44_SP:1; /* Supervisor Protect */
12584  uint32_t OPACR44_WP:1; /* Write Protect */
12585  uint32_t OPACR44_TP:1; /* Trusted Protect */
12586  uint32_t OPACR45_BW:1; /* Buffer Writes */
12587  uint32_t OPACR45_SP:1; /* Supervisor Protect */
12588  uint32_t OPACR45_WP:1; /* Write Protect */
12589  uint32_t OPACR45_TP:1; /* Trusted Protect */
12590  uint32_t OPACR46_BW:1; /* Buffer Writes */
12591  uint32_t OPACR46_SP:1; /* Supervisor Protect */
12592  uint32_t OPACR46_WP:1; /* Write Protect */
12593  uint32_t OPACR46_TP:1; /* Trusted Protect */
12594  uint32_t OPACR47_BW:1; /* Buffer Writes */
12595  uint32_t OPACR47_SP:1; /* Supervisor Protect */
12596  uint32_t OPACR47_WP:1; /* Write Protect */
12597  uint32_t OPACR47_TP:1; /* Trusted Protect */
12598  } B;
12600
12601  typedef union { /* OPACR48_55 - Off-Platform Peripheral Access Control Registers */
12602  uint32_t R;
12603  struct {
12604  uint32_t OPACR48_BW:1; /* Buffer Writes */
12605  uint32_t OPACR48_SP:1; /* Supervisor Protect */
12606  uint32_t OPACR48_WP:1; /* Write Protect */
12607  uint32_t OPACR48_TP:1; /* Trusted Protect */
12608  uint32_t OPACR49_BW:1; /* Buffer Writes */
12609  uint32_t OPACR49_SP:1; /* Supervisor Protect */
12610  uint32_t OPACR49_WP:1; /* Write Protect */
12611  uint32_t OPACR49_TP:1; /* Trusted Protect */
12612  uint32_t OPACR50_BW:1; /* Buffer Writes */
12613  uint32_t OPACR50_SP:1; /* Supervisor Protect */
12614  uint32_t OPACR50_WP:1; /* Write Protect */
12615  uint32_t OPACR50_TP:1; /* Trusted Protect */
12616  uint32_t OPACR51_BW:1; /* Buffer Writes */
12617  uint32_t OPACR51_SP:1; /* Supervisor Protect */
12618  uint32_t OPACR51_WP:1; /* Write Protect */
12619  uint32_t OPACR51_TP:1; /* Trusted Protect */
12620  uint32_t OPACR52_BW:1; /* Buffer Writes */
12621  uint32_t OPACR52_SP:1; /* Supervisor Protect */
12622  uint32_t OPACR52_WP:1; /* Write Protect */
12623  uint32_t OPACR52_TP:1; /* Trusted Protect */
12624  uint32_t OPACR53_BW:1; /* Buffer Writes */
12625  uint32_t OPACR53_SP:1; /* Supervisor Protect */
12626  uint32_t OPACR53_WP:1; /* Write Protect */
12627  uint32_t OPACR53_TP:1; /* Trusted Protect */
12628  uint32_t OPACR54_BW:1; /* Buffer Writes */
12629  uint32_t OPACR54_SP:1; /* Supervisor Protect */
12630  uint32_t OPACR54_WP:1; /* Write Protect */
12631  uint32_t OPACR54_TP:1; /* Trusted Protect */
12632  uint32_t OPACR55_BW:1; /* Buffer Writes */
12633  uint32_t OPACR55_SP:1; /* Supervisor Protect */
12634  uint32_t OPACR55_WP:1; /* Write Protect */
12635  uint32_t OPACR55_TP:1; /* Trusted Protect */
12636  } B;
12638
12639  typedef union { /* OPACR56_63 - Off-Platform Peripheral Access Control Registers */
12640  uint32_t R;
12641  struct {
12642  uint32_t OPACR56_BW:1; /* Buffer Writes */
12643  uint32_t OPACR56_SP:1; /* Supervisor Protect */
12644  uint32_t OPACR56_WP:1; /* Write Protect */
12645  uint32_t OPACR56_TP:1; /* Trusted Protect */
12646  uint32_t OPACR57_BW:1; /* Buffer Writes */
12647  uint32_t OPACR57_SP:1; /* Supervisor Protect */
12648  uint32_t OPACR57_WP:1; /* Write Protect */
12649  uint32_t OPACR57_TP:1; /* Trusted Protect */
12650  uint32_t OPACR58_BW:1; /* Buffer Writes */
12651  uint32_t OPACR58_SP:1; /* Supervisor Protect */
12652  uint32_t OPACR58_WP:1; /* Write Protect */
12653  uint32_t OPACR58_TP:1; /* Trusted Protect */
12654  uint32_t OPACR59_BW:1; /* Buffer Writes */
12655  uint32_t OPACR59_SP:1; /* Supervisor Protect */
12656  uint32_t OPACR59_WP:1; /* Write Protect */
12657  uint32_t OPACR59_TP:1; /* Trusted Protect */
12658  uint32_t OPACR60_BW:1; /* Buffer Writes */
12659  uint32_t OPACR60_SP:1; /* Supervisor Protect */
12660  uint32_t OPACR60_WP:1; /* Write Protect */
12661  uint32_t OPACR60_TP:1; /* Trusted Protect */
12662  uint32_t OPACR61_BW:1; /* Buffer Writes */
12663  uint32_t OPACR61_SP:1; /* Supervisor Protect */
12664  uint32_t OPACR61_WP:1; /* Write Protect */
12665  uint32_t OPACR61_TP:1; /* Trusted Protect */
12666  uint32_t OPACR62_BW:1; /* Buffer Writes */
12667  uint32_t OPACR62_SP:1; /* Supervisor Protect */
12668  uint32_t OPACR62_WP:1; /* Write Protect */
12669  uint32_t OPACR62_TP:1; /* Trusted Protect */
12670  uint32_t OPACR63_BW:1; /* Buffer Writes */
12671  uint32_t OPACR63_SP:1; /* Supervisor Protect */
12672  uint32_t OPACR63_WP:1; /* Write Protect */
12673  uint32_t OPACR63_TP:1; /* Trusted Protect */
12674  } B;
12676
12677  typedef union { /* OPACR64_71 - Off-Platform Peripheral Access Control Registers */
12678  uint32_t R;
12679  struct {
12680  uint32_t OPACR64_BW:1; /* Buffer Writes */
12681  uint32_t OPACR64_SP:1; /* Supervisor Protect */
12682  uint32_t OPACR64_WP:1; /* Write Protect */
12683  uint32_t OPACR64_TP:1; /* Trusted Protect */
12684  uint32_t OPACR65_BW:1; /* Buffer Writes */
12685  uint32_t OPACR65_SP:1; /* Supervisor Protect */
12686  uint32_t OPACR65_WP:1; /* Write Protect */
12687  uint32_t OPACR65_TP:1; /* Trusted Protect */
12688  uint32_t OPACR66_BW:1; /* Buffer Writes */
12689  uint32_t OPACR66_SP:1; /* Supervisor Protect */
12690  uint32_t OPACR66_WP:1; /* Write Protect */
12691  uint32_t OPACR66_TP:1; /* Trusted Protect */
12692  uint32_t OPACR67_BW:1; /* Buffer Writes */
12693  uint32_t OPACR67_SP:1; /* Supervisor Protect */
12694  uint32_t OPACR67_WP:1; /* Write Protect */
12695  uint32_t OPACR67_TP:1; /* Trusted Protect */
12696  uint32_t OPACR68_BW:1; /* Buffer Writes */
12697  uint32_t OPACR68_SP:1; /* Supervisor Protect */
12698  uint32_t OPACR68_WP:1; /* Write Protect */
12699  uint32_t OPACR68_TP:1; /* Trusted Protect */
12700  uint32_t OPACR69_BW:1; /* Buffer Writes */
12701  uint32_t OPACR69_SP:1; /* Supervisor Protect */
12702  uint32_t OPACR69_WP:1; /* Write Protect */
12703  uint32_t OPACR69_TP:1; /* Trusted Protect */
12704  uint32_t OPACR70_BW:1; /* Buffer Writes */
12705  uint32_t OPACR70_SP:1; /* Supervisor Protect */
12706  uint32_t OPACR70_WP:1; /* Write Protect */
12707  uint32_t OPACR70_TP:1; /* Trusted Protect */
12708  uint32_t OPACR71_BW:1; /* Buffer Writes */
12709  uint32_t OPACR71_SP:1; /* Supervisor Protect */
12710  uint32_t OPACR71_WP:1; /* Write Protect */
12711  uint32_t OPACR71_TP:1; /* Trusted Protect */
12712  } B;
12714
12715  typedef union { /* OPACR72_79 - Off-Platform Peripheral Access Control Registers */
12716  uint32_t R;
12717  struct {
12718  uint32_t OPACR72_BW:1; /* Buffer Writes */
12719  uint32_t OPACR72_SP:1; /* Supervisor Protect */
12720  uint32_t OPACR72_WP:1; /* Write Protect */
12721  uint32_t OPACR72_TP:1; /* Trusted Protect */
12722  uint32_t OPACR73_BW:1; /* Buffer Writes */
12723  uint32_t OPACR73_SP:1; /* Supervisor Protect */
12724  uint32_t OPACR73_WP:1; /* Write Protect */
12725  uint32_t OPACR73_TP:1; /* Trusted Protect */
12726  uint32_t OPACR74_BW:1; /* Buffer Writes */
12727  uint32_t OPACR74_SP:1; /* Supervisor Protect */
12728  uint32_t OPACR74_WP:1; /* Write Protect */
12729  uint32_t OPACR74_TP:1; /* Trusted Protect */
12730  uint32_t OPACR75_BW:1; /* Buffer Writes */
12731  uint32_t OPACR75_SP:1; /* Supervisor Protect */
12732  uint32_t OPACR75_WP:1; /* Write Protect */
12733  uint32_t OPACR75_TP:1; /* Trusted Protect */
12734  uint32_t OPACR76_BW:1; /* Buffer Writes */
12735  uint32_t OPACR76_SP:1; /* Supervisor Protect */
12736  uint32_t OPACR76_WP:1; /* Write Protect */
12737  uint32_t OPACR76_TP:1; /* Trusted Protect */
12738  uint32_t OPACR77_BW:1; /* Buffer Writes */
12739  uint32_t OPACR77_SP:1; /* Supervisor Protect */
12740  uint32_t OPACR77_WP:1; /* Write Protect */
12741  uint32_t OPACR77_TP:1; /* Trusted Protect */
12742  uint32_t OPACR78_BW:1; /* Buffer Writes */
12743  uint32_t OPACR78_SP:1; /* Supervisor Protect */
12744  uint32_t OPACR78_WP:1; /* Write Protect */
12745  uint32_t OPACR78_TP:1; /* Trusted Protect */
12746  uint32_t OPACR79_BW:1; /* Buffer Writes */
12747  uint32_t OPACR79_SP:1; /* Supervisor Protect */
12748  uint32_t OPACR79_WP:1; /* Write Protect */
12749  uint32_t OPACR79_TP:1; /* Trusted Protect */
12750  } B;
12752
12753  typedef union { /* OPACR80_87 - Off-Platform Peripheral Access Control Registers */
12754  uint32_t R;
12755  struct {
12756  uint32_t OPACR80_BW:1; /* Buffer Writes */
12757  uint32_t OPACR80_SP:1; /* Supervisor Protect */
12758  uint32_t OPACR80_WP:1; /* Write Protect */
12759  uint32_t OPACR80_TP:1; /* Trusted Protect */
12760  uint32_t OPACR81_BW:1; /* Buffer Writes */
12761  uint32_t OPACR81_SP:1; /* Supervisor Protect */
12762  uint32_t OPACR81_WP:1; /* Write Protect */
12763  uint32_t OPACR81_TP:1; /* Trusted Protect */
12764  uint32_t OPACR82_BW:1; /* Buffer Writes */
12765  uint32_t OPACR82_SP:1; /* Supervisor Protect */
12766  uint32_t OPACR82_WP:1; /* Write Protect */
12767  uint32_t OPACR82_TP:1; /* Trusted Protect */
12768  uint32_t OPACR83_BW:1; /* Buffer Writes */
12769  uint32_t OPACR83_SP:1; /* Supervisor Protect */
12770  uint32_t OPACR83_WP:1; /* Write Protect */
12771  uint32_t OPACR83_TP:1; /* Trusted Protect */
12772  uint32_t OPACR84_BW:1; /* Buffer Writes */
12773  uint32_t OPACR84_SP:1; /* Supervisor Protect */
12774  uint32_t OPACR84_WP:1; /* Write Protect */
12775  uint32_t OPACR84_TP:1; /* Trusted Protect */
12776  uint32_t OPACR85_BW:1; /* Buffer Writes */
12777  uint32_t OPACR85_SP:1; /* Supervisor Protect */
12778  uint32_t OPACR85_WP:1; /* Write Protect */
12779  uint32_t OPACR85_TP:1; /* Trusted Protect */
12780  uint32_t OPACR86_BW:1; /* Buffer Writes */
12781  uint32_t OPACR86_SP:1; /* Supervisor Protect */
12782  uint32_t OPACR86_WP:1; /* Write Protect */
12783  uint32_t OPACR86_TP:1; /* Trusted Protect */
12784  uint32_t OPACR87_BW:1; /* Buffer Writes */
12785  uint32_t OPACR87_SP:1; /* Supervisor Protect */
12786  uint32_t OPACR87_WP:1; /* Write Protect */
12787  uint32_t OPACR87_TP:1; /* Trusted Protect */
12788  } B;
12790
12791  typedef union { /* OPACR88_95 - Off-Platform Peripheral Access Control Registers */
12792  uint32_t R;
12793  struct {
12794  uint32_t OPACR88_BW:1; /* Buffer Writes */
12795  uint32_t OPACR88_SP:1; /* Supervisor Protect */
12796  uint32_t OPACR88_WP:1; /* Write Protect */
12797  uint32_t OPACR88_TP:1; /* Trusted Protect */
12798  uint32_t OPACR89_BW:1; /* Buffer Writes */
12799  uint32_t OPACR89_SP:1; /* Supervisor Protect */
12800  uint32_t OPACR89_WP:1; /* Write Protect */
12801  uint32_t OPACR89_TP:1; /* Trusted Protect */
12802  uint32_t OPACR90_BW:1; /* Buffer Writes */
12803  uint32_t OPACR90_SP:1; /* Supervisor Protect */
12804  uint32_t OPACR90_WP:1; /* Write Protect */
12805  uint32_t OPACR90_TP:1; /* Trusted Protect */
12806  uint32_t OPACR91_BW:1; /* Buffer Writes */
12807  uint32_t OPACR91_SP:1; /* Supervisor Protect */
12808  uint32_t OPACR91_WP:1; /* Write Protect */
12809  uint32_t OPACR91_TP:1; /* Trusted Protect */
12810  uint32_t OPACR92_BW:1; /* Buffer Writes */
12811  uint32_t OPACR92_SP:1; /* Supervisor Protect */
12812  uint32_t OPACR92_WP:1; /* Write Protect */
12813  uint32_t OPACR92_TP:1; /* Trusted Protect */
12814  uint32_t OPACR93_BW:1; /* Buffer Writes */
12815  uint32_t OPACR93_SP:1; /* Supervisor Protect */
12816  uint32_t OPACR93_WP:1; /* Write Protect */
12817  uint32_t OPACR93_TP:1; /* Trusted Protect */
12818  uint32_t OPACR94_BW:1; /* Buffer Writes */
12819  uint32_t OPACR94_SP:1; /* Supervisor Protect */
12820  uint32_t OPACR94_WP:1; /* Write Protect */
12821  uint32_t OPACR94_TP:1; /* Trusted Protect */
12822  uint32_t OPACR95_BW:1; /* Buffer Writes */
12823  uint32_t OPACR95_SP:1; /* Supervisor Protect */
12824  uint32_t OPACR95_WP:1; /* Write Protect */
12825  uint32_t OPACR95_TP:1; /* Trusted Protect */
12826  } B;
12828
12829
12830
12831  typedef struct PBRIDGE_struct_tag { /* start of PBRIDGE_tag */
12832  /* MPROT - Master Privilege Registers */
12833  PBRIDGE_MPROT_32B_tag MPROT; /* offset: 0x0000 size: 32 bit */
12834  int8_t PBRIDGE_reserved_0004[28];
12835  /* PACR0_7 - Peripheral Access Control Registers */
12836  PBRIDGE_PACR0_7_32B_tag PACR0_7; /* offset: 0x0020 size: 32 bit */
12837  /* PACR8_15 - Peripheral Access Control Registers */
12838  PBRIDGE_PACR8_15_32B_tag PACR8_15; /* offset: 0x0024 size: 32 bit */
12839  /* PACR16_23 - Peripheral Access Control Registers */
12840  PBRIDGE_PACR16_23_32B_tag PACR16_23; /* offset: 0x0028 size: 32 bit */
12841  /* PACR24_31 - Peripheral Access Control Registers */
12842  PBRIDGE_PACR24_31_32B_tag PACR24_31; /* offset: 0x002C size: 32 bit */
12843  int8_t PBRIDGE_reserved_0030[16];
12844  /* OPACR0_7 - Off-Platform Peripheral Access Control Registers */
12845  PBRIDGE_OPACR0_7_32B_tag OPACR0_7; /* offset: 0x0040 size: 32 bit */
12846  /* OPACR8_15 - Off-Platform Peripheral Access Control Registers */
12847  PBRIDGE_OPACR8_15_32B_tag OPACR8_15; /* offset: 0x0044 size: 32 bit */
12848  /* OPACR16_23 - Off-Platform Peripheral Access Control Registers */
12849  PBRIDGE_OPACR16_23_32B_tag OPACR16_23; /* offset: 0x0048 size: 32 bit */
12850  /* OPACR24_31 - Off-Platform Peripheral Access Control Registers */
12851  PBRIDGE_OPACR24_31_32B_tag OPACR24_31; /* offset: 0x004C size: 32 bit */
12852  /* OPACR32_39 - Off-Platform Peripheral Access Control Registers */
12853  PBRIDGE_OPACR32_39_32B_tag OPACR32_39; /* offset: 0x0050 size: 32 bit */
12854  /* OPACR40_47 - Off-Platform Peripheral Access Control Registers */
12855  PBRIDGE_OPACR40_47_32B_tag OPACR40_47; /* offset: 0x0054 size: 32 bit */
12856  /* OPACR48_55 - Off-Platform Peripheral Access Control Registers */
12857  PBRIDGE_OPACR48_55_32B_tag OPACR48_55; /* offset: 0x0058 size: 32 bit */
12858  /* OPACR56_63 - Off-Platform Peripheral Access Control Registers */
12859  PBRIDGE_OPACR56_63_32B_tag OPACR56_63; /* offset: 0x005C size: 32 bit */
12860  /* OPACR64_71 - Off-Platform Peripheral Access Control Registers */
12861  PBRIDGE_OPACR64_71_32B_tag OPACR64_71; /* offset: 0x0060 size: 32 bit */
12862  /* OPACR72_79 - Off-Platform Peripheral Access Control Registers */
12863  PBRIDGE_OPACR72_79_32B_tag OPACR72_79; /* offset: 0x0064 size: 32 bit */
12864  /* OPACR80_87 - Off-Platform Peripheral Access Control Registers */
12865  PBRIDGE_OPACR80_87_32B_tag OPACR80_87; /* offset: 0x0068 size: 32 bit */
12866  /* OPACR88_95 - Off-Platform Peripheral Access Control Registers */
12867  PBRIDGE_OPACR88_95_32B_tag OPACR88_95; /* offset: 0x006C size: 32 bit */
12868  } PBRIDGE_tag;
12869
12870
12871 #define PBRIDGE (*(volatile PBRIDGE_tag *) 0xFFF00000UL)
12872
12873
12874
12875 /****************************************************************/
12876 /* */
12877 /* Module: MAX */
12878 /* */
12879 /****************************************************************/
12880
12881
12882  /* Register layout for all registers MPR... */
12883
12884  typedef union { /* Master Priority Register for slave port n */
12885  uint32_t R;
12886  struct {
12887  uint32_t:1;
12888  uint32_t MSTR_7:3; /* Master 7 Priority */
12889  uint32_t:1;
12890  uint32_t MSTR_6:3; /* Master 6 Priority */
12891  uint32_t:1;
12892  uint32_t MSTR_5:3; /* Master 5 Priority */
12893  uint32_t:1;
12894  uint32_t MSTR_4:3; /* Master 4 Priority */
12895  uint32_t:1;
12896  uint32_t MSTR_3:3; /* Master 3 Priority */
12897  uint32_t:1;
12898  uint32_t MSTR_2:3; /* Master 2 Priority */
12899  uint32_t:1;
12900  uint32_t MSTR_1:3; /* Master 1 Priority */
12901  uint32_t:1;
12902  uint32_t MSTR_0:3; /* Master 0 Priority */
12903  } B;
12904  } MAX_MPR_32B_tag;
12905
12906
12907  /* Register layout for all registers AMPR matches xxx */
12908
12909
12910  /* Register layout for all registers SGPCR... */
12911
12912  typedef union { /* MAX_SGPCRn - MAX General Purpose Control Register for Slave Port n */
12913  uint32_t R;
12914  struct {
12915  uint32_t RO:1; /* Read Only */
12916  uint32_t HLP:1; /* Halt Low Priority */
12917  uint32_t:6;
12918  uint32_t HPE7:1; /* High Priority Enable */
12919  uint32_t HPE6:1; /* High Priority Enable */
12920  uint32_t HPE5:1; /* High Priority Enable */
12921  uint32_t HPE4:1; /* High Priority Enable */
12922  uint32_t HPE3:1; /* High Priority Enable */
12923  uint32_t HPE2:1; /* High Priority Enable */
12924  uint32_t HPE1:1; /* High Priority Enable */
12925  uint32_t HPE0:1; /* High Priority Enable */
12926  uint32_t:6;
12927  uint32_t ARB:2; /* Arbitration Mode */
12928  uint32_t:2;
12929  uint32_t PCTL:2; /* Parking Control */
12930  uint32_t:1;
12931  uint32_t PARK:3; /* Park */
12932  } B;
12934
12935
12936  /* Register layout for all registers ASGPCR... */
12937
12938  typedef union { /* MAX_ASGPCRn - MAX Alternate General Purpose Control Register n */
12939  uint32_t R;
12940  struct {
12941  uint32_t:1;
12942  uint32_t HLP:1; /* Halt Low Priority */
12943  uint32_t:6;
12944  uint32_t HPE7:1; /* High Priority Enable */
12945  uint32_t HPE6:1; /* High Priority Enable */
12946  uint32_t HPE5:1; /* High Priority Enable */
12947  uint32_t HPE4:1; /* High Priority Enable */
12948  uint32_t HPE3:1; /* High Priority Enable */
12949  uint32_t HPE2:1; /* High Priority Enable */
12950  uint32_t HPE1:1; /* High Priority Enable */
12951  uint32_t HPE0:1; /* High Priority Enable */
12952  uint32_t:6;
12953  uint32_t ARB:2; /* Arbitration Mode */
12954  uint32_t:2;
12955  uint32_t PCTL:2; /* Parking Control */
12956  uint32_t:1;
12957  uint32_t PARK:3; /* Park */
12958  } B;
12960
12961
12962  /* Register layout for all registers MGPCR... */
12963
12964  typedef union { /* MAX_MGPCRn - Master General Purpose Control Register n */
12965  uint32_t R;
12966  struct {
12967  uint32_t:29;
12968  uint32_t AULB:3; /* Arbitrate on Undefined Length Bursts */
12969  } B;
12971
12972
12973  typedef struct MAX_SLAVE_PORT_struct_tag {
12974
12975  /* Master Priority Register for slave port n */
12976  MAX_MPR_32B_tag MPR; /* relative offset: 0x0000 */
12977  /* Alternate Master Priority Register for slave port n */
12978  MAX_MPR_32B_tag AMPR; /* relative offset: 0x0004 */
12979  int8_t MAX_SLAVE_PORT_reserved_0008[8];
12980  /* MAX_SGPCRn - MAX General Purpose Control Register for Slave Port n */
12981  MAX_SGPCR_32B_tag SGPCR; /* relative offset: 0x0010 */
12982  /* MAX_ASGPCRn - MAX Alternate General Purpose Control Register n */
12983  MAX_ASGPCR_32B_tag ASGPCR; /* relative offset: 0x0014 */
12984  int8_t MAX_SLAVE_PORT_reserved_0018[232];
12985
12987
12989
12990  /* MAX_MGPCRn - Master General Purpose Control Register n */
12991  MAX_MGPCR_32B_tag MGPCR; /* relative offset: 0x0000 */
12992  int8_t MAX_MASTER_PORT_reserved_0004[252];
12993
12995
12996
12997  typedef struct MAX_struct_tag { /* start of MAX_tag */
12998  union {
12999  /* Register set SLAVE_PORT */
13000  MAX_SLAVE_PORT_tag SLAVE_PORT[8]; /* offset: 0x0000 (0x0100 x 8) */
13001
13002  struct {
13003  /* Master Priority Register for slave port n */
13004  MAX_MPR_32B_tag MPR0; /* offset: 0x0000 size: 32 bit */
13005  /* Alternate Master Priority Register for slave port n */
13006  MAX_MPR_32B_tag AMPR0; /* offset: 0x0004 size: 32 bit */
13007  int8_t MAX_reserved_0008_I1[8];
13008  /* MAX_SGPCRn - MAX General Purpose Control Register for Slave Port n */
13009  MAX_SGPCR_32B_tag SGPCR0; /* offset: 0x0010 size: 32 bit */
13010  /* MAX_ASGPCRn - MAX Alternate General Purpose Control Register n */
13011  MAX_ASGPCR_32B_tag ASGPCR0; /* offset: 0x0014 size: 32 bit */
13012  int8_t MAX_reserved_0018_I1[232];
13013  /* Master Priority Register for slave port n */
13014  MAX_MPR_32B_tag MPR1; /* offset: 0x0100 size: 32 bit */
13015  /* Alternate Master Priority Register for slave port n */
13016  MAX_MPR_32B_tag AMPR1; /* offset: 0x0104 size: 32 bit */
13017  int8_t MAX_reserved_0108_I1[8];
13018  /* MAX_SGPCRn - MAX General Purpose Control Register for Slave Port n */
13019  MAX_SGPCR_32B_tag SGPCR1; /* offset: 0x0110 size: 32 bit */
13020  /* MAX_ASGPCRn - MAX Alternate General Purpose Control Register n */
13021  MAX_ASGPCR_32B_tag ASGPCR1; /* offset: 0x0114 size: 32 bit */
13022  int8_t MAX_reserved_0118_I1[232];
13023  /* Master Priority Register for slave port n */
13024  MAX_MPR_32B_tag MPR2; /* offset: 0x0200 size: 32 bit */
13025  /* Alternate Master Priority Register for slave port n */
13026  MAX_MPR_32B_tag AMPR2; /* offset: 0x0204 size: 32 bit */
13027  int8_t MAX_reserved_0208_I1[8];
13028  /* MAX_SGPCRn - MAX General Purpose Control Register for Slave Port n */
13029  MAX_SGPCR_32B_tag SGPCR2; /* offset: 0x0210 size: 32 bit */
13030  /* MAX_ASGPCRn - MAX Alternate General Purpose Control Register n */
13031  MAX_ASGPCR_32B_tag ASGPCR2; /* offset: 0x0214 size: 32 bit */
13032  int8_t MAX_reserved_0218_I1[232];
13033  /* Master Priority Register for slave port n */
13034  MAX_MPR_32B_tag MPR3; /* offset: 0x0300 size: 32 bit */
13035  /* Alternate Master Priority Register for slave port n */
13036  MAX_MPR_32B_tag AMPR3; /* offset: 0x0304 size: 32 bit */
13037  int8_t MAX_reserved_0308_I1[8];
13038  /* MAX_SGPCRn - MAX General Purpose Control Register for Slave Port n */
13039  MAX_SGPCR_32B_tag SGPCR3; /* offset: 0x0310 size: 32 bit */
13040  /* MAX_ASGPCRn - MAX Alternate General Purpose Control Register n */
13041  MAX_ASGPCR_32B_tag ASGPCR3; /* offset: 0x0314 size: 32 bit */
13042  int8_t MAX_reserved_0318_I1[232];
13043  /* Master Priority Register for slave port n */
13044  MAX_MPR_32B_tag MPR4; /* offset: 0x0400 size: 32 bit */
13045  /* Alternate Master Priority Register for slave port n */
13046  MAX_MPR_32B_tag AMPR4; /* offset: 0x0404 size: 32 bit */
13047  int8_t MAX_reserved_0408_I1[8];
13048  /* MAX_SGPCRn - MAX General Purpose Control Register for Slave Port n */
13049  MAX_SGPCR_32B_tag SGPCR4; /* offset: 0x0410 size: 32 bit */
13050  /* MAX_ASGPCRn - MAX Alternate General Purpose Control Register n */
13051  MAX_ASGPCR_32B_tag ASGPCR4; /* offset: 0x0414 size: 32 bit */
13052  int8_t MAX_reserved_0418_I1[232];
13053  /* Master Priority Register for slave port n */
13054  MAX_MPR_32B_tag MPR5; /* offset: 0x0500 size: 32 bit */
13055  /* Alternate Master Priority Register for slave port n */
13056  MAX_MPR_32B_tag AMPR5; /* offset: 0x0504 size: 32 bit */
13057  int8_t MAX_reserved_0508_I1[8];
13058  /* MAX_SGPCRn - MAX General Purpose Control Register for Slave Port n */
13059  MAX_SGPCR_32B_tag SGPCR5; /* offset: 0x0510 size: 32 bit */
13060  /* MAX_ASGPCRn - MAX Alternate General Purpose Control Register n */
13061  MAX_ASGPCR_32B_tag ASGPCR5; /* offset: 0x0514 size: 32 bit */
13062  int8_t MAX_reserved_0518_I1[232];
13063  /* Master Priority Register for slave port n */
13064  MAX_MPR_32B_tag MPR6; /* offset: 0x0600 size: 32 bit */
13065  /* Alternate Master Priority Register for slave port n */
13066  MAX_MPR_32B_tag AMPR6; /* offset: 0x0604 size: 32 bit */
13067  int8_t MAX_reserved_0608_I1[8];
13068  /* MAX_SGPCRn - MAX General Purpose Control Register for Slave Port n */
13069  MAX_SGPCR_32B_tag SGPCR6; /* offset: 0x0610 size: 32 bit */
13070  /* MAX_ASGPCRn - MAX Alternate General Purpose Control Register n */
13071  MAX_ASGPCR_32B_tag ASGPCR6; /* offset: 0x0614 size: 32 bit */
13072  int8_t MAX_reserved_0618_I1[232];
13073  /* Master Priority Register for slave port n */
13074  MAX_MPR_32B_tag MPR7; /* offset: 0x0700 size: 32 bit */
13075  /* Alternate Master Priority Register for slave port n */
13076  MAX_MPR_32B_tag AMPR7; /* offset: 0x0704 size: 32 bit */
13077  int8_t MAX_reserved_0708_I1[8];
13078  /* MAX_SGPCRn - MAX General Purpose Control Register for Slave Port n */
13079  MAX_SGPCR_32B_tag SGPCR7; /* offset: 0x0710 size: 32 bit */
13080  /* MAX_ASGPCRn - MAX Alternate General Purpose Control Register n */
13081  MAX_ASGPCR_32B_tag ASGPCR7; /* offset: 0x0714 size: 32 bit */
13082  int8_t MAX_reserved_0718_E1[232];
13083  };
13084
13085  };
13086  union {
13087  /* Register set MASTER_PORT */
13088  MAX_MASTER_PORT_tag MASTER_PORT[8]; /* offset: 0x0800 (0x0100 x 8) */
13089
13090  struct {
13091  /* MAX_MGPCRn - Master General Purpose Control Register n */
13092  MAX_MGPCR_32B_tag MGPCR0; /* offset: 0x0800 size: 32 bit */
13093  int8_t MAX_reserved_0804_I1[252];
13094  MAX_MGPCR_32B_tag MGPCR1; /* offset: 0x0900 size: 32 bit */
13095  int8_t MAX_reserved_0904_I1[252];
13096  MAX_MGPCR_32B_tag MGPCR2; /* offset: 0x0A00 size: 32 bit */
13097  int8_t MAX_reserved_0A04_I1[252];
13098  MAX_MGPCR_32B_tag MGPCR3; /* offset: 0x0B00 size: 32 bit */
13099  int8_t MAX_reserved_0B04_I1[252];
13100  MAX_MGPCR_32B_tag MGPCR4; /* offset: 0x0C00 size: 32 bit */
13101  int8_t MAX_reserved_0C04_I1[252];
13102  MAX_MGPCR_32B_tag MGPCR5; /* offset: 0x0D00 size: 32 bit */
13103  int8_t MAX_reserved_0D04_I1[252];
13104  MAX_MGPCR_32B_tag MGPCR6; /* offset: 0x0E00 size: 32 bit */
13105  int8_t MAX_reserved_0E04_I1[252];
13106  MAX_MGPCR_32B_tag MGPCR7; /* offset: 0x0F00 size: 32 bit */
13107  int8_t MAX_reserved_0F04_E1[252];
13108  };
13109
13110  };
13111  } MAX_tag;
13112
13113
13114 #define MAX (*(volatile MAX_tag *) 0xFFF04000UL)
13115
13116
13117
13118 /****************************************************************/
13119 /* */
13120 /* Module: MPU */
13121 /* */
13122 /****************************************************************/
13123
13124  typedef union { /* MPU_CESR - MPU Control/Error Status Register */
13125  uint32_t R;
13126  struct {
13127  uint32_t SPERR:8; /* Slave Port n Error */
13128  uint32_t:4;
13129  uint32_t HRL:4; /* Hardware Revision Level */
13130  uint32_t NSP:4; /* Number of Slave Ports */
13131  uint32_t NRGD:4; /* Number of Region Descriptors */
13132  uint32_t:7;
13133  uint32_t VLD:1; /* Valid bit */
13134  } B;
13135  } MPU_CESR_32B_tag;
13136
13137
13138  /* Register layout for all registers EAR... */
13139
13140  typedef union { /* MPU_EARn - MPU Error Address Register, Slave Port n */
13141  uint32_t R;
13142  struct {
13143  uint32_t EADDR:32; /* Error Address */
13144  } B;
13145  } MPU_EAR_32B_tag;
13146
13147
13148  /* Register layout for all registers EDR... */
13149
13150  typedef union { /* MPU_EDRn - MPU Error Detail Register, Slave Port n */
13151  uint32_t R;
13152  struct {
13153  uint32_t EACD:16; /* Error Access Control Detail */
13154  uint32_t EPID:8; /* Error Process Identification */
13155  uint32_t EMN:4; /* Error Master Number */
13156  uint32_t EATTR:3; /* Error Attributes */
13157  uint32_t ERW:1; /* Error Read/Write */
13158  } B;
13159  } MPU_EDR_32B_tag;
13160
13161
13162  /* Register layout for all registers RGD_WORD0... */
13163
13164  typedef union { /* MPU_RGDn_Word0 - MPU Region Descriptor */
13165  uint32_t R;
13166  struct {
13167  uint32_t SRTADDR:27; /* Start Address */
13168  uint32_t:5;
13169  } B;
13171
13172
13173  /* Register layout for all registers RGD_WORD1... */
13174
13175  typedef union { /* MPU_RGDn_Word1 - MPU Region Descriptor */
13176  uint32_t R;
13177  struct {
13178  uint32_t ENDADDR:27; /* End Address */
13179  uint32_t:5;
13180  } B;
13182
13183
13184  /* Register layout for all registers RGD_WORD2... */
13185
13186  typedef union { /* MPU_RGDn_Word2 - MPU Region Descriptor */
13187  uint32_t R;
13188  struct {
13189  uint32_t M7RE:1; /* Bus Master 7 Read Enable */
13190  uint32_t M7WE:1; /* Bus Master 7 Write Enable */
13191  uint32_t M6RE:1; /* Bus Master 6 Read Enable */
13192  uint32_t M6WE:1; /* Bus Master 7 Write Enable */
13193  uint32_t M5RE:1; /* Bus Master 5 Read Enable */
13194  uint32_t M5WE:1; /* Bus Master 5 Write Enable */
13195  uint32_t M4RE:1; /* Bus Master 4 Read Enable */
13196  uint32_t M4WE:1; /* Bus Master 4 Write Enable */
13197  uint32_t M3PE:1; /* Bus Master 3 Process Identifier Enable */
13198  uint32_t M3SM:2; /* Bus Master 3 Supervisor Mode Access Control */
13199  uint32_t M3UM:3; /* Bus Master 3 User Mode Access Control */
13200  uint32_t M2PE:1; /* Bus Master 2 Process Identifier Enable */
13201  uint32_t M2SM:2; /* Bus Master 2 Supervisor Mode Access Control */
13202  uint32_t M2UM:3; /* Bus Master 2 User Mode Access Control */
13203  uint32_t M1PE:1; /* Bus Master 1 Process Identifier Enable */
13204  uint32_t M1SM:2; /* Bus Master 1 Supervisor Mode Access Control */
13205  uint32_t M1UM:3; /* Bus Master 1 User Mode Access Control */
13206  uint32_t M0PE:1; /* Bus Master 0 Process Identifier Enable */
13207  uint32_t M0SM:2; /* Bus Master 0 Supervisor Mode Access Control */
13208  uint32_t M0UM:3; /* Bus Master 0 User Mode Access Control */
13209  } B;
13211
13212
13213  /* Register layout for all registers RGD_WORD3... */
13214
13215  typedef union { /* MPU_RGDn_Word3 - MPU Region Descriptor */
13216  uint32_t R;
13217  struct {
13218  uint32_t PID:8; /* Process Identifier */
13219  uint32_t PIDMASK:8; /* Process Identifier Mask */
13220  uint32_t:15;
13221  uint32_t VLD:1; /* Valid */
13222  } B;
13224
13225
13226  /* Register layout for all registers RGDAAC... */
13227
13228  typedef union { /* MPU_RGDAACn - MPU Region Descriptor Alternate Access Control */
13229  uint32_t R;
13230  struct {
13231  uint32_t M7RE:1; /* Bus Master 7 Read Enable */
13232  uint32_t M7WE:1; /* Bus Master 7 Write Enable */
13233  uint32_t M6RE:1; /* Bus Master 6 Read Enable */
13234  uint32_t M6WE:1; /* Bus Master 7 Write Enable */
13235  uint32_t M5RE:1; /* Bus Master 5 Read Enable */
13236  uint32_t M5WE:1; /* Bus Master 5 Write Enable */
13237  uint32_t M4RE:1; /* Bus Master 4 Read Enable */
13238  uint32_t M4WE:1; /* Bus Master 4 Write Enable */
13239  uint32_t M3PE:1; /* Bus Master 3 Process Identifier Enable */
13240  uint32_t M3SM:2; /* Bus Master 3 Supervisor Mode Access Control */
13241  uint32_t M3UM:3; /* Bus Master 3 User Mode Access Control */
13242  uint32_t M2PE:1; /* Bus Master 2 Process Identifier Enable */
13243  uint32_t M2SM:2; /* Bus Master 2 Supervisor Mode Access Control */
13244  uint32_t M2UM:3; /* Bus Master 2 User Mode Access Control */
13245  uint32_t M1PE:1; /* Bus Master 1 Process Identifier Enable */
13246  uint32_t M1SM:2; /* Bus Master 1 Supervisor Mode Access Control */
13247  uint32_t M1UM:3; /* Bus Master 1 User Mode Access Control */
13248  uint32_t M0PE:1; /* Bus Master 0 Process Identifier Enable */
13249  uint32_t M0SM:2; /* Bus Master 0 Supervisor Mode Access Control */
13250  uint32_t M0UM:3; /* Bus Master 0 User Mode Access Control */
13251  } B;
13253
13254
13255  typedef struct MPU_SLAVE_PORT_struct_tag {
13256
13257  /* MPU_EARn - MPU Error Address Register, Slave Port n */
13258  MPU_EAR_32B_tag EAR; /* relative offset: 0x0000 */
13259  /* MPU_EDRn - MPU Error Detail Register, Slave Port n */
13260  MPU_EDR_32B_tag EDR; /* relative offset: 0x0004 */
13261
13263
13264  typedef struct MPU_REGION_struct_tag {
13265
13266  /* MPU_RGDn_Word0 - MPU Region Descriptor */
13267  MPU_RGD_WORD0_32B_tag RGD_WORD0; /* relative offset: 0x0000 */
13268  /* MPU_RGDn_Word1 - MPU Region Descriptor */
13269  MPU_RGD_WORD1_32B_tag RGD_WORD1; /* relative offset: 0x0004 */
13270  /* MPU_RGDn_Word2 - MPU Region Descriptor */
13271  MPU_RGD_WORD2_32B_tag RGD_WORD2; /* relative offset: 0x0008 */
13272  /* MPU_RGDn_Word3 - MPU Region Descriptor */
13273  MPU_RGD_WORD3_32B_tag RGD_WORD3; /* relative offset: 0x000C */
13274
13275  } MPU_REGION_tag;
13276
13277
13278  typedef struct MPU_struct_tag { /* start of MPU_tag */
13279  /* MPU_CESR - MPU Control/Error Status Register */
13280  MPU_CESR_32B_tag CESR; /* offset: 0x0000 size: 32 bit */
13281  int8_t MPU_reserved_0004_C[12];
13282  union {
13283  /* Register set SLAVE_PORT */
13284  MPU_SLAVE_PORT_tag SLAVE_PORT[4]; /* offset: 0x0010 (0x0008 x 4) */
13285
13286  struct {
13287  /* MPU_EARn - MPU Error Address Register, Slave Port n */
13288  MPU_EAR_32B_tag EAR0; /* offset: 0x0010 size: 32 bit */
13289  /* MPU_EDRn - MPU Error Detail Register, Slave Port n */
13290  MPU_EDR_32B_tag EDR0; /* offset: 0x0014 size: 32 bit */
13291  /* MPU_EARn - MPU Error Address Register, Slave Port n */
13292  MPU_EAR_32B_tag EAR1; /* offset: 0x0018 size: 32 bit */
13293  /* MPU_EDRn - MPU Error Detail Register, Slave Port n */
13294  MPU_EDR_32B_tag EDR1; /* offset: 0x001C size: 32 bit */
13295  /* MPU_EARn - MPU Error Address Register, Slave Port n */
13296  MPU_EAR_32B_tag EAR2; /* offset: 0x0020 size: 32 bit */
13297  /* MPU_EDRn - MPU Error Detail Register, Slave Port n */
13298  MPU_EDR_32B_tag EDR2; /* offset: 0x0024 size: 32 bit */
13299  /* MPU_EARn - MPU Error Address Register, Slave Port n */
13300  MPU_EAR_32B_tag EAR3; /* offset: 0x0028 size: 32 bit */
13301  /* MPU_EDRn - MPU Error Detail Register, Slave Port n */
13302  MPU_EDR_32B_tag EDR3; /* offset: 0x002C size: 32 bit */
13303  };
13304
13305  };
13306  int8_t MPU_reserved_0030_C[976];
13307  union {
13308  /* Register set REGION */
13309  MPU_REGION_tag REGION[16]; /* offset: 0x0400 (0x0010 x 16) */
13310
13311  struct {
13312  /* MPU_RGDn_Word0 - MPU Region Descriptor */
13313  MPU_RGD_WORD0_32B_tag RGD0_WORD0; /* offset: 0x0400 size: 32 bit */
13314  /* MPU_RGDn_Word1 - MPU Region Descriptor */
13315  MPU_RGD_WORD1_32B_tag RGD0_WORD1; /* offset: 0x0404 size: 32 bit */
13316  /* MPU_RGDn_Word2 - MPU Region Descriptor */
13317  MPU_RGD_WORD2_32B_tag RGD0_WORD2; /* offset: 0x0408 size: 32 bit */
13318  /* MPU_RGDn_Word3 - MPU Region Descriptor */
13319  MPU_RGD_WORD3_32B_tag RGD0_WORD3; /* offset: 0x040C size: 32 bit */
13320  /* MPU_RGDn_Word0 - MPU Region Descriptor */
13321  MPU_RGD_WORD0_32B_tag RGD1_WORD0; /* offset: 0x0410 size: 32 bit */
13322  /* MPU_RGDn_Word1 - MPU Region Descriptor */
13323  MPU_RGD_WORD1_32B_tag RGD1_WORD1; /* offset: 0x0414 size: 32 bit */
13324  /* MPU_RGDn_Word2 - MPU Region Descriptor */
13325  MPU_RGD_WORD2_32B_tag RGD1_WORD2; /* offset: 0x0418 size: 32 bit */
13326  /* MPU_RGDn_Word3 - MPU Region Descriptor */
13327  MPU_RGD_WORD3_32B_tag RGD1_WORD3; /* offset: 0x041C size: 32 bit */
13328  /* MPU_RGDn_Word0 - MPU Region Descriptor */
13329  MPU_RGD_WORD0_32B_tag RGD2_WORD0; /* offset: 0x0420 size: 32 bit */
13330  /* MPU_RGDn_Word1 - MPU Region Descriptor */
13331  MPU_RGD_WORD1_32B_tag RGD2_WORD1; /* offset: 0x0424 size: 32 bit */
13332  /* MPU_RGDn_Word2 - MPU Region Descriptor */
13333  MPU_RGD_WORD2_32B_tag RGD2_WORD2; /* offset: 0x0428 size: 32 bit */
13334  /* MPU_RGDn_Word3 - MPU Region Descriptor */
13335  MPU_RGD_WORD3_32B_tag RGD2_WORD3; /* offset: 0x042C size: 32 bit */
13336  /* MPU_RGDn_Word0 - MPU Region Descriptor */
13337  MPU_RGD_WORD0_32B_tag RGD3_WORD0; /* offset: 0x0430 size: 32 bit */
13338  /* MPU_RGDn_Word1 - MPU Region Descriptor */
13339  MPU_RGD_WORD1_32B_tag RGD3_WORD1; /* offset: 0x0434 size: 32 bit */
13340  /* MPU_RGDn_Word2 - MPU Region Descriptor */
13341  MPU_RGD_WORD2_32B_tag RGD3_WORD2; /* offset: 0x0438 size: 32 bit */
13342  /* MPU_RGDn_Word3 - MPU Region Descriptor */
13343  MPU_RGD_WORD3_32B_tag RGD3_WORD3; /* offset: 0x043C size: 32 bit */
13344  /* MPU_RGDn_Word0 - MPU Region Descriptor */
13345  MPU_RGD_WORD0_32B_tag RGD4_WORD0; /* offset: 0x0440 size: 32 bit */
13346  /* MPU_RGDn_Word1 - MPU Region Descriptor */
13347  MPU_RGD_WORD1_32B_tag RGD4_WORD1; /* offset: 0x0444 size: 32 bit */
13348  /* MPU_RGDn_Word2 - MPU Region Descriptor */
13349  MPU_RGD_WORD2_32B_tag RGD4_WORD2; /* offset: 0x0448 size: 32 bit */
13350  /* MPU_RGDn_Word3 - MPU Region Descriptor */
13351  MPU_RGD_WORD3_32B_tag RGD4_WORD3; /* offset: 0x044C size: 32 bit */
13352  /* MPU_RGDn_Word0 - MPU Region Descriptor */
13353  MPU_RGD_WORD0_32B_tag RGD5_WORD0; /* offset: 0x0450 size: 32 bit */
13354  /* MPU_RGDn_Word1 - MPU Region Descriptor */
13355  MPU_RGD_WORD1_32B_tag RGD5_WORD1; /* offset: 0x0454 size: 32 bit */
13356  /* MPU_RGDn_Word2 - MPU Region Descriptor */
13357  MPU_RGD_WORD2_32B_tag RGD5_WORD2; /* offset: 0x0458 size: 32 bit */
13358  /* MPU_RGDn_Word3 - MPU Region Descriptor */
13359  MPU_RGD_WORD3_32B_tag RGD5_WORD3; /* offset: 0x045C size: 32 bit */
13360  /* MPU_RGDn_Word0 - MPU Region Descriptor */
13361  MPU_RGD_WORD0_32B_tag RGD6_WORD0; /* offset: 0x0460 size: 32 bit */
13362  /* MPU_RGDn_Word1 - MPU Region Descriptor */
13363  MPU_RGD_WORD1_32B_tag RGD6_WORD1; /* offset: 0x0464 size: 32 bit */
13364  /* MPU_RGDn_Word2 - MPU Region Descriptor */
13365  MPU_RGD_WORD2_32B_tag RGD6_WORD2; /* offset: 0x0468 size: 32 bit */
13366  /* MPU_RGDn_Word3 - MPU Region Descriptor */
13367  MPU_RGD_WORD3_32B_tag RGD6_WORD3; /* offset: 0x046C size: 32 bit */
13368  /* MPU_RGDn_Word0 - MPU Region Descriptor */
13369  MPU_RGD_WORD0_32B_tag RGD7_WORD0; /* offset: 0x0470 size: 32 bit */
13370  /* MPU_RGDn_Word1 - MPU Region Descriptor */
13371  MPU_RGD_WORD1_32B_tag RGD7_WORD1; /* offset: 0x0474 size: 32 bit */
13372  /* MPU_RGDn_Word2 - MPU Region Descriptor */
13373  MPU_RGD_WORD2_32B_tag RGD7_WORD2; /* offset: 0x0478 size: 32 bit */
13374  /* MPU_RGDn_Word3 - MPU Region Descriptor */
13375  MPU_RGD_WORD3_32B_tag RGD7_WORD3; /* offset: 0x047C size: 32 bit */
13376  /* MPU_RGDn_Word0 - MPU Region Descriptor */
13377  MPU_RGD_WORD0_32B_tag RGD8_WORD0; /* offset: 0x0480 size: 32 bit */
13378  /* MPU_RGDn_Word1 - MPU Region Descriptor */
13379  MPU_RGD_WORD1_32B_tag RGD8_WORD1; /* offset: 0x0484 size: 32 bit */
13380  /* MPU_RGDn_Word2 - MPU Region Descriptor */
13381  MPU_RGD_WORD2_32B_tag RGD8_WORD2; /* offset: 0x0488 size: 32 bit */
13382  /* MPU_RGDn_Word3 - MPU Region Descriptor */
13383  MPU_RGD_WORD3_32B_tag RGD8_WORD3; /* offset: 0x048C size: 32 bit */
13384  /* MPU_RGDn_Word0 - MPU Region Descriptor */
13385  MPU_RGD_WORD0_32B_tag RGD9_WORD0; /* offset: 0x0490 size: 32 bit */
13386  /* MPU_RGDn_Word1 - MPU Region Descriptor */
13387  MPU_RGD_WORD1_32B_tag RGD9_WORD1; /* offset: 0x0494 size: 32 bit */
13388  /* MPU_RGDn_Word2 - MPU Region Descriptor */
13389  MPU_RGD_WORD2_32B_tag RGD9_WORD2; /* offset: 0x0498 size: 32 bit */
13390  /* MPU_RGDn_Word3 - MPU Region Descriptor */
13391  MPU_RGD_WORD3_32B_tag RGD9_WORD3; /* offset: 0x049C size: 32 bit */
13392  /* MPU_RGDn_Word0 - MPU Region Descriptor */
13393  MPU_RGD_WORD0_32B_tag RGD10_WORD0; /* offset: 0x04A0 size: 32 bit */
13394  /* MPU_RGDn_Word1 - MPU Region Descriptor */
13395  MPU_RGD_WORD1_32B_tag RGD10_WORD1; /* offset: 0x04A4 size: 32 bit */
13396  /* MPU_RGDn_Word2 - MPU Region Descriptor */
13397  MPU_RGD_WORD2_32B_tag RGD10_WORD2; /* offset: 0x04A8 size: 32 bit */
13398  /* MPU_RGDn_Word3 - MPU Region Descriptor */
13399  MPU_RGD_WORD3_32B_tag RGD10_WORD3; /* offset: 0x04AC size: 32 bit */
13400  /* MPU_RGDn_Word0 - MPU Region Descriptor */
13401  MPU_RGD_WORD0_32B_tag RGD11_WORD0; /* offset: 0x04B0 size: 32 bit */
13402  /* MPU_RGDn_Word1 - MPU Region Descriptor */
13403  MPU_RGD_WORD1_32B_tag RGD11_WORD1; /* offset: 0x04B4 size: 32 bit */
13404  /* MPU_RGDn_Word2 - MPU Region Descriptor */
13405  MPU_RGD_WORD2_32B_tag RGD11_WORD2; /* offset: 0x04B8 size: 32 bit */
13406  /* MPU_RGDn_Word3 - MPU Region Descriptor */
13407  MPU_RGD_WORD3_32B_tag RGD11_WORD3; /* offset: 0x04BC size: 32 bit */
13408  /* MPU_RGDn_Word0 - MPU Region Descriptor */
13409  MPU_RGD_WORD0_32B_tag RGD12_WORD0; /* offset: 0x04C0 size: 32 bit */
13410  /* MPU_RGDn_Word1 - MPU Region Descriptor */
13411  MPU_RGD_WORD1_32B_tag RGD12_WORD1; /* offset: 0x04C4 size: 32 bit */
13412  /* MPU_RGDn_Word2 - MPU Region Descriptor */
13413  MPU_RGD_WORD2_32B_tag RGD12_WORD2; /* offset: 0x04C8 size: 32 bit */
13414  /* MPU_RGDn_Word3 - MPU Region Descriptor */
13415  MPU_RGD_WORD3_32B_tag RGD12_WORD3; /* offset: 0x04CC size: 32 bit */
13416  /* MPU_RGDn_Word0 - MPU Region Descriptor */
13417  MPU_RGD_WORD0_32B_tag RGD13_WORD0; /* offset: 0x04D0 size: 32 bit */
13418  /* MPU_RGDn_Word1 - MPU Region Descriptor */
13419  MPU_RGD_WORD1_32B_tag RGD13_WORD1; /* offset: 0x04D4 size: 32 bit */
13420  /* MPU_RGDn_Word2 - MPU Region Descriptor */
13421  MPU_RGD_WORD2_32B_tag RGD13_WORD2; /* offset: 0x04D8 size: 32 bit */
13422  /* MPU_RGDn_Word3 - MPU Region Descriptor */
13423  MPU_RGD_WORD3_32B_tag RGD13_WORD3; /* offset: 0x04DC size: 32 bit */
13424  /* MPU_RGDn_Word0 - MPU Region Descriptor */
13425  MPU_RGD_WORD0_32B_tag RGD14_WORD0; /* offset: 0x04E0 size: 32 bit */
13426  /* MPU_RGDn_Word1 - MPU Region Descriptor */
13427  MPU_RGD_WORD1_32B_tag RGD14_WORD1; /* offset: 0x04E4 size: 32 bit */
13428  /* MPU_RGDn_Word2 - MPU Region Descriptor */
13429  MPU_RGD_WORD2_32B_tag RGD14_WORD2; /* offset: 0x04E8 size: 32 bit */
13430  /* MPU_RGDn_Word3 - MPU Region Descriptor */
13431  MPU_RGD_WORD3_32B_tag RGD14_WORD3; /* offset: 0x04EC size: 32 bit */
13432  /* MPU_RGDn_Word0 - MPU Region Descriptor */
13433  MPU_RGD_WORD0_32B_tag RGD15_WORD0; /* offset: 0x04F0 size: 32 bit */
13434  /* MPU_RGDn_Word1 - MPU Region Descriptor */
13435  MPU_RGD_WORD1_32B_tag RGD15_WORD1; /* offset: 0x04F4 size: 32 bit */
13436  /* MPU_RGDn_Word2 - MPU Region Descriptor */
13437  MPU_RGD_WORD2_32B_tag RGD15_WORD2; /* offset: 0x04F8 size: 32 bit */
13438  /* MPU_RGDn_Word3 - MPU Region Descriptor */
13439  MPU_RGD_WORD3_32B_tag RGD15_WORD3; /* offset: 0x04FC size: 32 bit */
13440  };
13441
13442  };
13443  int8_t MPU_reserved_0500_C[768];
13444  union {
13445  /* MPU_RGDAACn - MPU Region Descriptor Alternate Access Control */
13446  MPU_RGDAAC_32B_tag RGDAAC[16]; /* offset: 0x0800 (0x0004 x 16) */
13447
13448  struct {
13449  /* MPU_RGDAACn - MPU Region Descriptor Alternate Access Control */
13450  MPU_RGDAAC_32B_tag RGDAAC0; /* offset: 0x0800 size: 32 bit */
13451  MPU_RGDAAC_32B_tag RGDAAC1; /* offset: 0x0804 size: 32 bit */
13452  MPU_RGDAAC_32B_tag RGDAAC2; /* offset: 0x0808 size: 32 bit */
13453  MPU_RGDAAC_32B_tag RGDAAC3; /* offset: 0x080C size: 32 bit */
13454  MPU_RGDAAC_32B_tag RGDAAC4; /* offset: 0x0810 size: 32 bit */
13455  MPU_RGDAAC_32B_tag RGDAAC5; /* offset: 0x0814 size: 32 bit */
13456  MPU_RGDAAC_32B_tag RGDAAC6; /* offset: 0x0818 size: 32 bit */
13457  MPU_RGDAAC_32B_tag RGDAAC7; /* offset: 0x081C size: 32 bit */
13458  MPU_RGDAAC_32B_tag RGDAAC8; /* offset: 0x0820 size: 32 bit */
13459  MPU_RGDAAC_32B_tag RGDAAC9; /* offset: 0x0824 size: 32 bit */
13460  MPU_RGDAAC_32B_tag RGDAAC10; /* offset: 0x0828 size: 32 bit */
13461  MPU_RGDAAC_32B_tag RGDAAC11; /* offset: 0x082C size: 32 bit */
13462  MPU_RGDAAC_32B_tag RGDAAC12; /* offset: 0x0830 size: 32 bit */
13463  MPU_RGDAAC_32B_tag RGDAAC13; /* offset: 0x0834 size: 32 bit */
13464  MPU_RGDAAC_32B_tag RGDAAC14; /* offset: 0x0838 size: 32 bit */
13465  MPU_RGDAAC_32B_tag RGDAAC15; /* offset: 0x083C size: 32 bit */
13466  };
13467
13468  };
13469  } MPU_tag;
13470
13471
13472 #define MPU (*(volatile MPU_tag *) 0xFFF10000UL)
13473
13474
13475
13476 /****************************************************************/
13477 /* */
13478 /* Module: SEMA4 */
13479 /* */
13480 /****************************************************************/
13481
13482
13483  /* Register layout for all registers GATE... */
13484
13485  typedef union { /* SEMA4_GATEn - Semephores Gate Register */
13486  uint8_t R;
13487  struct {
13488  uint8_t:6;
13489  uint8_t GTFSM:2; /* Gate Finite State machine */
13490  } B;
13492
13493  typedef union { /* SEMA4_CP0INE - Semaphores Processor IRQ Notification Enable */
13494  uint16_t R;
13495  struct {
13496  uint16_t INE:16; /* Interrupt Request Notification Enable */
13497  } B;
13499
13500  typedef union { /* SEMA4_CP1INE - Semaphores Processor IRQ Notification Enable */
13501  uint16_t R;
13502  struct {
13503  uint16_t INE:16; /* Interrupt Request Notification Enable */
13504  } B;
13506
13507  typedef union { /* SEMA4_CP0NTF - Semaphores Processor IRQ Notification */
13508  uint16_t R;
13509  struct {
13510  uint16_t GN:16; /* Gate 0 Notification */
13511  } B;
13513
13514  typedef union { /* SEMA4_CP1NTF - Semaphores Processor IRQ Notification */
13515  uint16_t R;
13516  struct {
13517  uint16_t GN:16; /* Gate 1 Notification */
13518  } B;
13520
13521  typedef union { /* SEMA4_RSTGT - Semaphores Reset Gate */
13522  uint16_t R;
13523  struct {
13524  uint16_t:2;
13525  uint16_t RSTGSM:2; /* Reset Gate Finite State Machine */
13526  uint16_t RSTGDP:7; /* Reset Gate Data Pattern */
13527  uint16_t RSTGMS:3; /* Reset Gate Bus Master */
13528  uint16_t RSTGTN:8; /* Reset Gate Number */
13529  } B;
13531
13532  typedef union { /* SEMA4_RSTNTF - Semaphores Reset Reset IRQ Notification */
13533  uint16_t R;
13534  struct {
13535  uint16_t:2;
13536  uint16_t RSTNSM:2; /* Reset Gate Finite State Machine */
13537  uint16_t RSTNDP:7; /* Reset Gate Data Pattern */
13538  uint16_t RSTNMS:3; /* Reset Gate Bus Master */
13539  uint16_t RSTNTN:8; /* Reset Gate Number */
13540  } B;
13542
13543
13544
13545  typedef struct SEMA4_struct_tag { /* start of SEMA4_tag */
13546  union {
13547  /* SEMA4_GATEn - Semephores Gate Register */
13548  SEMA4_GATE_8B_tag GATE[16]; /* offset: 0x0000 (0x0001 x 16) */
13549
13550  struct {
13551  /* SEMA4_GATEn - Semephores Gate Register */
13552  SEMA4_GATE_8B_tag GATE0; /* offset: 0x0000 size: 8 bit */
13553  SEMA4_GATE_8B_tag GATE1; /* offset: 0x0001 size: 8 bit */
13554  SEMA4_GATE_8B_tag GATE2; /* offset: 0x0002 size: 8 bit */
13555  SEMA4_GATE_8B_tag GATE3; /* offset: 0x0003 size: 8 bit */
13556  SEMA4_GATE_8B_tag GATE4; /* offset: 0x0004 size: 8 bit */
13557  SEMA4_GATE_8B_tag GATE5; /* offset: 0x0005 size: 8 bit */
13558  SEMA4_GATE_8B_tag GATE6; /* offset: 0x0006 size: 8 bit */
13559  SEMA4_GATE_8B_tag GATE7; /* offset: 0x0007 size: 8 bit */
13560  SEMA4_GATE_8B_tag GATE8; /* offset: 0x0008 size: 8 bit */
13561  SEMA4_GATE_8B_tag GATE9; /* offset: 0x0009 size: 8 bit */
13562  SEMA4_GATE_8B_tag GATE10; /* offset: 0x000A size: 8 bit */
13563  SEMA4_GATE_8B_tag GATE11; /* offset: 0x000B size: 8 bit */
13564  SEMA4_GATE_8B_tag GATE12; /* offset: 0x000C size: 8 bit */
13565  SEMA4_GATE_8B_tag GATE13; /* offset: 0x000D size: 8 bit */
13566  SEMA4_GATE_8B_tag GATE14; /* offset: 0x000E size: 8 bit */
13567  SEMA4_GATE_8B_tag GATE15; /* offset: 0x000F size: 8 bit */
13568  };
13569
13570  };
13571  int8_t SEMA4_reserved_0010[48];
13572  /* SEMA4_CP0INE - Semaphores Processor IRQ Notification Enable */
13573  SEMA4_CP0INE_16B_tag CP0INE; /* offset: 0x0040 size: 16 bit */
13574  int8_t SEMA4_reserved_0042[6];
13575  /* SEMA4_CP1INE - Semaphores Processor IRQ Notification Enable */
13576  SEMA4_CP1INE_16B_tag CP1INE; /* offset: 0x0048 size: 16 bit */
13577  int8_t SEMA4_reserved_004A[54];
13578  /* SEMA4_CP0NTF - Semaphores Processor IRQ Notification */
13579  SEMA4_CP0NTF_16B_tag CP0NTF; /* offset: 0x0080 size: 16 bit */
13580  int8_t SEMA4_reserved_0082[6];
13581  /* SEMA4_CP1NTF - Semaphores Processor IRQ Notification */
13582  SEMA4_CP1NTF_16B_tag CP1NTF; /* offset: 0x0088 size: 16 bit */
13583  int8_t SEMA4_reserved_008A[118];
13584  /* SEMA4_RSTGT - Semaphores Reset Gate */
13585  SEMA4_RSTGT_16B_tag RSTGT; /* offset: 0x0100 size: 16 bit */
13586  int8_t SEMA4_reserved_0102[2];
13587  /* SEMA4_RSTNTF - Semaphores Reset Reset IRQ Notification */
13588  SEMA4_RSTNTF_16B_tag RSTNTF; /* offset: 0x0104 size: 16 bit */
13589  } SEMA4_tag;
13590
13591
13592 #define SEMA4 (*(volatile SEMA4_tag *) 0xFFF24000UL)
13593
13594
13595
13596 /****************************************************************/
13597 /* */
13598 /* Module: SWT */
13599 /* */
13600 /****************************************************************/
13601
13602  typedef union { /* SWT_CR - Control Register */
13603  uint32_t R;
13604  struct {
13605  uint32_t MAP0:1; /* Master Acces Protection for Master 0 */
13606  uint32_t MAP1:1; /* Master Acces Protection for Master 1 */
13607  uint32_t MAP2:1; /* Master Acces Protection for Master 2 */
13608  uint32_t MAP3:1; /* Master Acces Protection for Master 3 */
13609  uint32_t MAP4:1; /* Master Acces Protection for Master 4 */
13610  uint32_t MAP5:1; /* Master Acces Protection for Master 5 */
13611  uint32_t MAP6:1; /* Master Acces Protection for Master 6 */
13612  uint32_t MAP7:1; /* Master Acces Protection for Master 7 */
13613  uint32_t:14;
13614  uint32_t KEY:1; /* Keyed Service Mode */
13615  uint32_t RIA:1; /* Reset on Invalid Access */
13616  uint32_t WND:1; /* Window Mode */
13617  uint32_t ITR:1; /* Interrupt Then Reset */
13618  uint32_t HLK:1; /* Hard Lock */
13619  uint32_t SLK:1; /* Soft Lock */
13620  uint32_t:1;
13621  uint32_t STP:1; /* Stop Mode Control */
13622  uint32_t FRZ:1; /* Debug Mode Control */
13623  uint32_t WEN:1; /* Watchdog Enabled */
13624  } B;
13625  } SWT_CR_32B_tag;
13626
13627  typedef union { /* SWT_IR - SWT Interrupt Register */
13628  uint32_t R;
13629  struct {
13630  uint32_t:31;
13631  uint32_t TIF:1; /* Time Out Interrupt Flag */
13632  } B;
13633  } SWT_IR_32B_tag;
13634
13635  typedef union { /* SWT_TO - SWT Time-Out Register */
13636  uint32_t R;
13637  struct {
13638  uint32_t WTO:32; /* Watchdog Time Out Period */
13639  } B;
13640  } SWT_TO_32B_tag;
13641
13642  typedef union { /* SWT_WN - SWT Window Register */
13643  uint32_t R;
13644  struct {
13645  uint32_t WST:32; /* Watchdog Time Out Period */
13646  } B;
13647  } SWT_WN_32B_tag;
13648
13649  typedef union { /* SWT_SR - SWT Service Register */
13650  uint32_t R;
13651  struct {
13652  uint32_t:16;
13653  uint32_t WSC:16; /* Watchdog Service Code */
13654  } B;
13655  } SWT_SR_32B_tag;
13656
13657  typedef union { /* SWT_CO - SWT Counter Output Register */
13658  uint32_t R;
13659  struct {
13660  uint32_t CNT:32; /* Watchdog Count */
13661  } B;
13662  } SWT_CO_32B_tag;
13663
13664  typedef union { /* SWT_SK - SWT Service Key Register */
13665  uint32_t R;
13666  struct {
13667  uint32_t:16;
13668  uint32_t SERVICEKEY:16; /* Service Key */
13669  } B;
13670  } SWT_SK_32B_tag;
13671
13672
13673
13674  typedef struct SWT_struct_tag { /* start of SWT_tag */
13675  /* SWT_CR - Control Register */
13676  SWT_CR_32B_tag CR; /* offset: 0x0000 size: 32 bit */
13677  /* SWT_IR - SWT Interrupt Register */
13678  SWT_IR_32B_tag IR; /* offset: 0x0004 size: 32 bit */
13679  /* SWT_TO - SWT Time-Out Register */
13680  SWT_TO_32B_tag TO; /* offset: 0x0008 size: 32 bit */
13681  /* SWT_WN - SWT Window Register */
13682  SWT_WN_32B_tag WN; /* offset: 0x000C size: 32 bit */
13683  /* SWT_SR - SWT Service Register */
13684  SWT_SR_32B_tag SR; /* offset: 0x0010 size: 32 bit */
13685  /* SWT_CO - SWT Counter Output Register */
13686  SWT_CO_32B_tag CO; /* offset: 0x0014 size: 32 bit */
13687  /* SWT_SK - SWT Service Key Register */
13688  SWT_SK_32B_tag SK; /* offset: 0x0018 size: 32 bit */
13689  } SWT_tag;
13690
13691
13692 #define SWT (*(volatile SWT_tag *) 0xFFF38000UL)
13693
13694
13695
13696 /****************************************************************/
13697 /* */
13698 /* Module: STM */
13699 /* */
13700 /****************************************************************/
13701
13702  typedef union { /* STM_CR - Control Register */
13703  uint32_t R;
13704  struct {
13705  uint32_t:16;
13706  uint32_t CPS:8; /* Counter Prescaler */
13707  uint32_t:6;
13708  uint32_t FRZ:1; /* Freeze Control */
13709  uint32_t TEN:1; /* Timer Counter Enabled */
13710  } B;
13711  } STM_CR_32B_tag;
13712
13713  typedef union { /* STM_CNT - STM Count Register */
13714  uint32_t R;
13715  } STM_CNT_32B_tag;
13716
13717
13718  /* Register layout for all registers CCR... */
13719
13720  typedef union { /* STM_CCRn - STM Channel Control Register */
13721  uint32_t R;
13722  struct {
13723  uint32_t:31;
13724  uint32_t CEN:1; /* Channel Enable */
13725  } B;
13726  } STM_CCR_32B_tag;
13727
13728
13729  /* Register layout for all registers CIR... */
13730
13731  typedef union { /* STM_CIRn - STM Channel Interrupt Register */
13732  uint32_t R;
13733  struct {
13734  uint32_t:31;
13735  uint32_t CIF:1; /* Channel Interrupt Flag */
13736  } B;
13737  } STM_CIR_32B_tag;
13738
13739
13740  /* Register layout for all registers CMP... */
13741
13742  typedef union { /* STM_CMPn - STM Channel Compare Register */
13743  uint32_t R;
13744  } STM_CMP_32B_tag;
13745
13746
13747  typedef struct STM_CHANNEL_struct_tag {
13748
13749  /* STM_CCRn - STM Channel Control Register */
13750  STM_CCR_32B_tag CCR; /* relative offset: 0x0000 */
13751  /* STM_CIRn - STM Channel Interrupt Register */
13752  STM_CIR_32B_tag CIR; /* relative offset: 0x0004 */
13753  /* STM_CMPn - STM Channel Compare Register */
13754  STM_CMP_32B_tag CMP; /* relative offset: 0x0008 */
13755  int8_t STM_CHANNEL_reserved_000C[4];
13756
13757  } STM_CHANNEL_tag;
13758
13759
13760  typedef struct STM_struct_tag { /* start of STM_tag */
13761  union {
13762  STM_CR_32B_tag CR0; /* deprecated - please avoid */
13763
13764  /* STM_CR - Control Register */
13765  STM_CR_32B_tag CR; /* offset: 0x0000 size: 32 bit */
13766
13767  };
13768  union {
13769  STM_CNT_32B_tag CNT0; /* deprecated - please avoid */
13770
13771  /* STM_CNT - STM Count Register */
13772  STM_CNT_32B_tag CNT; /* offset: 0x0004 size: 32 bit */
13773
13774  };
13775  int8_t STM_reserved_0008_C[8];
13776  union {
13777  /* Register set CHANNEL */
13778  STM_CHANNEL_tag CHANNEL[4]; /* offset: 0x0010 (0x0010 x 4) */
13779
13780  struct {
13781  /* STM_CCRn - STM Channel Control Register */
13782  STM_CCR_32B_tag CCR0; /* offset: 0x0010 size: 32 bit */
13783  /* STM_CIRn - STM Channel Interrupt Register */
13784  STM_CIR_32B_tag CIR0; /* offset: 0x0014 size: 32 bit */
13785  /* STM_CMPn - STM Channel Compare Register */
13786  STM_CMP_32B_tag CMP0; /* offset: 0x0018 size: 32 bit */
13787  int8_t STM_reserved_001C_I1[4];
13788  /* STM_CCRn - STM Channel Control Register */
13789  STM_CCR_32B_tag CCR1; /* offset: 0x0020 size: 32 bit */
13790  /* STM_CIRn - STM Channel Interrupt Register */
13791  STM_CIR_32B_tag CIR1; /* offset: 0x0024 size: 32 bit */
13792  /* STM_CMPn - STM Channel Compare Register */
13793  STM_CMP_32B_tag CMP1; /* offset: 0x0028 size: 32 bit */
13794  int8_t STM_reserved_002C_I1[4];
13795  /* STM_CCRn - STM Channel Control Register */
13796  STM_CCR_32B_tag CCR2; /* offset: 0x0030 size: 32 bit */
13797  /* STM_CIRn - STM Channel Interrupt Register */
13798  STM_CIR_32B_tag CIR2; /* offset: 0x0034 size: 32 bit */
13799  /* STM_CMPn - STM Channel Compare Register */
13800  STM_CMP_32B_tag CMP2; /* offset: 0x0038 size: 32 bit */
13801  int8_t STM_reserved_003C_I1[4];
13802  /* STM_CCRn - STM Channel Control Register */
13803  STM_CCR_32B_tag CCR3; /* offset: 0x0040 size: 32 bit */
13804  /* STM_CIRn - STM Channel Interrupt Register */
13805  STM_CIR_32B_tag CIR3; /* offset: 0x0044 size: 32 bit */
13806  /* STM_CMPn - STM Channel Compare Register */
13807  STM_CMP_32B_tag CMP3; /* offset: 0x0048 size: 32 bit */
13808  int8_t STM_reserved_004C_E1[4];
13809  };
13810
13811  };
13812  } STM_tag;
13813
13814
13815 #define STM (*(volatile STM_tag *) 0xFFF3C000UL)
13816
13817
13818
13819 /****************************************************************/
13820 /* */
13821 /* Module: SPP_MCM */
13822 /* */
13823 /****************************************************************/
13824
13825  typedef union { /* SPP_MCM_PCT - Processor Core Type */
13826  uint16_t R;
13827  struct {
13828  uint16_t PCTYPE:16; /* Processor Core Type */
13829  } B;
13831
13832  typedef union { /* SPP_MCM_PLREV - SOC-Defined Platform Revision */
13833  uint16_t R;
13834  struct {
13835  uint16_t PLREVISION:16; /* Platform Revision */
13836  } B;
13838
13839  typedef union { /* SPP_MCM_IOPMC - IPS On-Platform Module Configuration */
13840  uint32_t R;
13841  struct {
13842  uint32_t PMC:32; /* IPS Module Configuration */
13843  } B;
13845
13846  typedef union { /* SPP_MCM_MRSR - Miscellaneous Reset Status Register */
13847  uint8_t R;
13848  struct {
13849  uint8_t POR:1; /* Power on Reset */
13850 #ifndef USE_FIELD_ALIASES_SPP_MCM
13851  uint8_t OFPLR:1; /* Off-Platform Reset */
13852 #else
13853  uint8_t DIR:1; /* deprecated name - please avoid */
13854 #endif
13855  uint8_t:6;
13856  } B;
13858
13859  typedef union { /* SPP_MCM_MWCR - Miscellaneous Wakeup Control Register */
13860  uint8_t R;
13861  struct {
13862  uint8_t ENBWCR:1; /* Enable WCR */
13863  uint8_t:3;
13864  uint8_t PRILVL:4; /* Interrupt Priority Level */
13865  } B;
13867
13868  typedef union { /* SPP_MCM_MIR - Miscellaneous Interrupt Register */
13869  uint8_t R;
13870  struct {
13871  uint8_t FB0AI:1; /* Flash Bank 0 Abort Interrupt */
13872  uint8_t FB0SI:1; /* Flash Bank 0 Stall Interrupt */
13873  uint8_t FB1AI:1; /* Flash Bank 1 Abort Interrupt */
13874  uint8_t FB1SI:1; /* Flash Bank 1 Stall Interrupt */
13875  uint8_t FB2AI:1; /* Flash Bank 2 Abort Interrupt */
13876  uint8_t FB2SI:1; /* Flash Bank 2 Stall Interrupt */
13877  uint8_t:2;
13878  } B;
13880
13881  typedef union { /* SPP_MCM_MUDCR - Miscellaneous User Defined Control Register */
13882  uint32_t R;
13883  struct {
13884  uint32_t MUSERDCR:32; /* User Defined Control Register */
13885  } B;
13887
13888  typedef union { /* SPP_MCM_ECR - ECC Configuration Register */
13889  uint8_t R;
13890  struct {
13891  uint8_t:2;
13892 #ifndef USE_FIELD_ALIASES_SPP_MCM
13893  uint8_t EPR1BR:1; /* Enable Platform RAM 1-bit Reporting */
13894 #else
13895  uint8_t ER1BR:1; /* deprecated name - please avoid */
13896 #endif
13897 #ifndef USE_FIELD_ALIASES_SPP_MCM
13898  uint8_t EPF1BR:1; /* Enable Platform FLASH 1-bit Reporting */
13899 #else
13900  uint8_t EF1BR:1; /* deprecated name - please avoid */
13901 #endif
13902  uint8_t:2;
13903 #ifndef USE_FIELD_ALIASES_SPP_MCM
13904  uint8_t EPRNCR:1; /* Enable Platform RAM Non-Correctable Reporting */
13905 #else
13906  uint8_t ERNCR:1; /* deprecated name - please avoid */
13907 #endif
13908 #ifndef USE_FIELD_ALIASES_SPP_MCM
13909  uint8_t EPFNCR:1; /* Enable Platform FLASH Non-Correctable Reporting */
13910 #else
13911  uint8_t EFNCR:1; /* deprecated name - please avoid */
13912 #endif
13913  } B;
13915
13916  typedef union { /* SPP_MCM_ESR - ECC Status Register */
13917  uint8_t R;
13918  struct {
13919  uint8_t:2;
13920 #ifndef USE_FIELD_ALIASES_SPP_MCM
13921  uint8_t PR1BC:1; /* Platform RAM 1-bit Correction */
13922 #else
13923  uint8_t R1BC:1; /* deprecated name - please avoid */
13924 #endif
13925 #ifndef USE_FIELD_ALIASES_SPP_MCM
13926  uint8_t PF1BC:1; /* Platform FLASH 1-bit Correction */
13927 #else
13928  uint8_t F1BC:1; /* deprecated name - please avoid */
13929 #endif
13930  uint8_t:2;
13931 #ifndef USE_FIELD_ALIASES_SPP_MCM
13932  uint8_t PRNCE:1; /* Platform RAM Non-Correctable Error */
13933 #else
13934  uint8_t RNCE:1; /* deprecated name - please avoid */
13935 #endif
13936 #ifndef USE_FIELD_ALIASES_SPP_MCM
13937  uint8_t PFNCE:1; /* Platform FLASH Non-Correctable Error */
13938 #else
13939  uint8_t FNCE:1; /* deprecated name - please avoid */
13940 #endif
13941  } B;
13943
13944  typedef union { /* SPP_MCM_EEGR - ECC Error Generation Register */
13945  uint16_t R;
13946  struct {
13947  uint16_t FRCAP:1; /* Force Platform RAM Error Injection Access Protection */
13948  uint16_t:1;
13949  uint16_t FRC1BI:1; /* Force Platform RAM Continuous 1-Bit Data Inversions */
13950  uint16_t FR11BI:1; /* Force Platform RAM One 1-Bit Data Inversion */
13951  uint16_t:2;
13952  uint16_t FRCNCI:1; /* Force Platform RAM Continuous Noncorrectable Data Inversions */
13953  uint16_t FR1NCI:1; /* Force Platform RAM One Noncorrectable Data Inversions */
13954  uint16_t:1;
13955  uint16_t ERRBIT:7; /* Error Bit Position */
13956  } B;
13958
13959  typedef union { /* SPP_MCM_PFEAR - Platform Flash ECC Error Address Register */
13960  uint32_t R;
13962
13963  typedef union { /* SPP_MCM_PFEMR - Platform Flash ECC Master Number Register */
13964  uint8_t R;
13966
13967  typedef union { /* SPP_MCM_PFEAT - Platform Flash ECC Attributes Register */
13968  uint8_t R;
13969  struct {
13970 #ifndef USE_FIELD_ALIASES_SPP_MCM
13971  uint8_t F_WRITE:1; /* AMBA-AHBH Write */
13972 #else
13973  uint8_t WRITE:1; /* deprecated name - please avoid */
13974 #endif
13975 #ifndef USE_FIELD_ALIASES_SPP_MCM
13976  uint8_t F_SIZE:3; /* AMBA-AHBH Size */
13977 #else
13978  uint8_t SIZE:3; /* deprecated name - please avoid */
13979 #endif
13980 #ifndef USE_FIELD_ALIASES_SPP_MCM
13981  uint8_t F_PROTECT:4; /* AMBA-AHBH PROT */
13982 #else
13983  uint8_t PROTECTION:4; /* deprecated name - please avoid */
13984 #endif
13985  } B;
13987
13988  typedef union { /* SPP_MCM_PFEDRH - Platform Flash ECC Data Register High Word */
13989  uint32_t R;
13991
13992  typedef union { /* SPP_MCM_PFEDR - Platform Flash ECC Data Register */
13993  uint32_t R;
13995
13996  typedef union { /* SPP_MCM_PREAR - Platform RAM ECC Address Register */
13997  uint32_t R;
13999
14000  typedef union { /* SPP_MCM_PRESR - Platform RAM ECC Syndrome Register */
14001  uint8_t R;
14003
14004  typedef union { /* SPP_MCM_PREMR - Platform RAM ECC Master Number Register */
14005  uint8_t R;
14006  struct {
14007  uint8_t:4;
14008 #ifndef USE_FIELD_ALIASES_SPP_MCM
14009  uint8_t PR_EMR:4; /* Platform RAM ECC Master Number */
14010 #else
14011  uint8_t REMR:4; /* deprecated name - please avoid */
14012 #endif
14013  } B;
14015
14016  typedef union { /* SPP_MCM_PREAT - Platform RAM ECC Attributes Register */
14017  uint8_t R;
14018  struct {
14019 #ifndef USE_FIELD_ALIASES_SPP_MCM
14020  uint8_t R_WRITE:1; /* AMBA-AHBH Write */
14021 #else
14022  uint8_t WRITE:1; /* deprecated name - please avoid */
14023 #endif
14024 #ifndef USE_FIELD_ALIASES_SPP_MCM
14025  uint8_t R_SIZE:3; /* AMBA-AHBH Size */
14026 #else
14027  uint8_t SIZE:3; /* deprecated name - please avoid */
14028 #endif
14029 #ifndef USE_FIELD_ALIASES_SPP_MCM
14030  uint8_t R_PROTECT:4; /* AMBA-AHBH PROT */
14031 #else
14032  uint8_t PROTECTION:4; /* deprecated name - please avoid */
14033 #endif
14034  } B;
14036
14037  typedef union { /* SPP_MCM_PREDR - Platform RAM ECC Data Register High Word */
14038  uint32_t R;
14040
14041  typedef union { /* SPP_MCM_PREDR - Platform RAM ECC Data Register */
14042  uint32_t R;
14044
14045
14046
14047  typedef struct SPP_MCM_struct_tag { /* start of SPP_MCM_tag */
14048  /* SPP_MCM_PCT - Processor Core Type */
14049  SPP_MCM_PCT_16B_tag PCT; /* offset: 0x0000 size: 16 bit */
14050  union {
14051  SPP_MCM_PLREV_16B_tag REV; /* deprecated - please avoid */
14052
14053  /* SPP_MCM_PLREV - SOC-Defined Platform Revision */
14054  SPP_MCM_PLREV_16B_tag PLREV; /* offset: 0x0002 size: 16 bit */
14055
14056  };
14057  int8_t SPP_MCM_reserved_0004_C[4];
14058  union {
14059  SPP_MCM_IOPMC_32B_tag MC; /* deprecated - please avoid */
14060
14061  /* SPP_MCM_IOPMC - IPS On-Platform Module Configuration */
14062  SPP_MCM_IOPMC_32B_tag IOPMC; /* offset: 0x0008 size: 32 bit */
14063
14064  };
14065  int8_t SPP_MCM_reserved_000C[3];
14066  /* SPP_MCM_MRSR - Miscellaneous Reset Status Register */
14067  SPP_MCM_MRSR_8B_tag MRSR; /* offset: 0x000F size: 8 bit */
14068  int8_t SPP_MCM_reserved_0010[3];
14069  /* SPP_MCM_MWCR - Miscellaneous Wakeup Control Register */
14070  SPP_MCM_MWCR_8B_tag MWCR; /* offset: 0x0013 size: 8 bit */
14071  int8_t SPP_MCM_reserved_0014[11];
14072  /* SPP_MCM_MIR - Miscellaneous Interrupt Register */
14073  SPP_MCM_MIR_8B_tag MIR; /* offset: 0x001F size: 8 bit */
14074  int8_t SPP_MCM_reserved_0020[4];
14075  /* SPP_MCM_MUDCR - Miscellaneous User Defined Control Register */
14076  SPP_MCM_MUDCR_32B_tag MUDCR; /* offset: 0x0024 size: 32 bit */
14077  int8_t SPP_MCM_reserved_0028[27];
14078  /* SPP_MCM_ECR - ECC Configuration Register */
14079  SPP_MCM_ECR_8B_tag ECR; /* offset: 0x0043 size: 8 bit */
14080  int8_t SPP_MCM_reserved_0044[3];
14081  /* SPP_MCM_ESR - ECC Status Register */
14082  SPP_MCM_ESR_8B_tag ESR; /* offset: 0x0047 size: 8 bit */
14083  int8_t SPP_MCM_reserved_0048[2];
14084  /* SPP_MCM_EEGR - ECC Error Generation Register */
14085  SPP_MCM_EEGR_16B_tag EEGR; /* offset: 0x004A size: 16 bit */
14086  int8_t SPP_MCM_reserved_004C_C[4];
14087  union {
14088  /* SPP_MCM_PFEAR - Platform Flash ECC Error Address Register */
14089  SPP_MCM_PFEAR_32B_tag PFEAR; /* offset: 0x0050 size: 32 bit */
14090
14091  SPP_MCM_PFEAR_32B_tag FEAR; /* deprecated - please avoid */
14092
14093  };
14094  int8_t SPP_MCM_reserved_0054_C[2];
14095  union {
14096  /* SPP_MCM_PFEMR - Platform Flash ECC Master Number Register */
14097  SPP_MCM_PFEMR_8B_tag PFEMR; /* offset: 0x0056 size: 8 bit */
14098
14099  SPP_MCM_PFEMR_8B_tag FEMR; /* deprecated - please avoid */
14100
14101  };
14102  union {
14103  /* SPP_MCM_PFEAT - Platform Flash ECC Attributes Register */
14104  SPP_MCM_PFEAT_8B_tag PFEAT; /* offset: 0x0057 size: 8 bit */
14105
14106  SPP_MCM_PFEAT_8B_tag FEAT; /* deprecated - please avoid */
14107
14108  };
14109  /* SPP_MCM_PFEDRH - Platform Flash ECC Data Register High Word */
14110  SPP_MCM_PFEDRH_32B_tag PFEDRH; /* offset: 0x0058 size: 32 bit */
14111  union {
14112  /* SPP_MCM_PFEDR - Platform Flash ECC Data Register */
14113  SPP_MCM_PFEDR_32B_tag PFEDR; /* offset: 0x005C size: 32 bit */
14114
14115  SPP_MCM_PFEDR_32B_tag FEDR; /* deprecated - please avoid */
14116
14117  };
14118  union {
14119  SPP_MCM_PREAR_32B_tag REAR; /* deprecated - please avoid */
14120
14121  /* SPP_MCM_PREAR - Platform RAM ECC Address Register */
14122  SPP_MCM_PREAR_32B_tag PREAR; /* offset: 0x0060 size: 32 bit */
14123
14124  };
14125  int8_t SPP_MCM_reserved_0064_C;
14126  union {
14127  SPP_MCM_PRESR_8B_tag RESR; /* deprecated - please avoid */
14128
14129  /* SPP_MCM_PRESR - Platform RAM ECC Syndrome Register */
14130  SPP_MCM_PRESR_8B_tag PRESR; /* offset: 0x0065 size: 8 bit */
14131
14132  };
14133  union {
14134  SPP_MCM_PREMR_8B_tag REMR; /* deprecated - please avoid */
14135
14136  /* SPP_MCM_PREMR - Platform RAM ECC Master Number Register */
14137  SPP_MCM_PREMR_8B_tag PREMR; /* offset: 0x0066 size: 8 bit */
14138
14139  };
14140  union {
14141  SPP_MCM_PREAT_8B_tag REAT; /* deprecated - please avoid */
14142
14143  /* SPP_MCM_PREAT - Platform RAM ECC Attributes Register */
14144  SPP_MCM_PREAT_8B_tag PREAT; /* offset: 0x0067 size: 8 bit */
14145
14146  };
14147  /* SPP_MCM_PREDR - Platform RAM ECC Data Register High Word */
14148  SPP_MCM_PREDRH_32B_tag PREDRH; /* offset: 0x0068 size: 32 bit */
14149  union {
14150  SPP_MCM_PREDR_32B_tag REDR; /* deprecated - please avoid */
14151
14152  /* SPP_MCM_PREDR - Platform RAM ECC Data Register */
14153  SPP_MCM_PREDR_32B_tag PREDR; /* offset: 0x006C size: 32 bit */
14154
14155  };
14156  } SPP_MCM_tag;
14157
14158
14159 #define SPP_MCM (*(volatile SPP_MCM_tag *) 0xFFF40000UL)
14160
14161
14162
14163 /****************************************************************/
14164 /* */
14165 /* Module: SPP_DMA2 */
14166 /* */
14167 /****************************************************************/
14168
14169  typedef union { /* SPP_DMA2_DMACR - DMA Control Register */
14170  uint32_t R;
14171  struct {
14172  uint32_t:14;
14173  uint32_t CX:1; /* Cancel Transfer */
14174  uint32_t ECX:1; /* Error Cancel Transfer */
14175  uint32_t GRP3PRI:2; /* Channel Group 3 Priority */
14176  uint32_t GRP2PRI:2; /* Channel Group 2 Priority */
14177  uint32_t GRP1PRI:2; /* Channel Group 1 Priority */
14178  uint32_t GRP0PRI:2; /* Channel Group 0 Priority */
14179  uint32_t EMLM:1; /* Enable Minor Loop Mapping */
14180  uint32_t CLM:1; /* Continuous Link Mode */
14181  uint32_t HALT:1; /* Halt DMA Operations */
14182  uint32_t HOE:1; /* Halt on Error */
14183  uint32_t ERGA:1; /* Enable Round Robin Group Arbitration */
14184  uint32_t ERCA:1; /* Enable Round Robin Channel Arbitration */
14185  uint32_t EDBG:1; /* Enable Debug */
14186  uint32_t EBW:1; /* Enable Buffered Writes */
14187  } B;
14189
14190  typedef union { /* SPP_DMA2_DMAES - DMA Error Status Register */
14191  uint32_t R;
14192  struct {
14193  uint32_t VLD:1; /* Logical OR of DMAERRH and DMAERRL status bits */
14194  uint32_t:14;
14195  uint32_t ECX:1; /* Transfer Cancelled */
14196  uint32_t GPE:1; /* Group Priority Error */
14197  uint32_t CPE:1; /* Channel Priority Error */
14198  uint32_t ERRCHN:6; /* Error Channel Number or Cancelled Channel Number */
14199  uint32_t SAE:1; /* Source Address Error */
14200  uint32_t SOE:1; /* Source Offset Error */
14201  uint32_t DAE:1; /* Destination Address Error */
14202  uint32_t DOE:1; /* Destination Offset Error */
14203  uint32_t NCE:1; /* Nbytes/Citer Configuration Error */
14204  uint32_t SGE:1; /* Scatter/Gather Configuration Error */
14205  uint32_t SBE:1; /* Source Bus Error */
14206  uint32_t DBE:1; /* Destination Bus Error */
14207  } B;
14209
14210  typedef union { /* SPP_DMA2_DMAERQH - DMA Enable Request Register */
14211  uint32_t R;
14212  struct {
14213  uint32_t ERQ:32; /* DMA Enable Request */
14214  } B;
14216
14217  typedef union { /* SPP_DMA2_DMAERQL - DMA Enable Request Register */
14218  uint32_t R;
14219  struct {
14220  uint32_t ERQ:32; /* DMA Enable Request */
14221  } B;
14223
14224  typedef union { /* SPP_DMA2_DMAEEIH - DMA Enable Error Interrupt Register */
14225  uint32_t R;
14226  struct {
14227  uint32_t EEI:32; /* DMA Enable Error Interrupt */
14228  } B;
14230
14231  typedef union { /* SPP_DMA2_DMAEEIL - DMA Enable Error Interrupt Register */
14232  uint32_t R;
14233  struct {
14234  uint32_t EEI:32; /* DMA Enable Error Interrupt */
14235  } B;
14237
14238  typedef union { /* SPP_DMA2_DMASERQ - DMA Set Enable Request Register */
14239  uint8_t R;
14240  struct {
14241  uint8_t:1;
14242  uint8_t SERQ:7; /* Set Enable Request */
14243  } B;
14245
14246  typedef union { /* SPP_DMA2_DMACERQ - DMA Clear Enable Request Register */
14247  uint8_t R;
14248  struct {
14249  uint8_t:1;
14250  uint8_t CERQ:7; /* Clear Enable Request */
14251  } B;
14253
14254  typedef union { /* SPP_DMA2_DMASEEI - DMA Set Enable Error Interrupt Register */
14255  uint8_t R;
14256  struct {
14257  uint8_t:1;
14258  uint8_t SEEI:7; /* Set Enable Error Interrupt */
14259  } B;
14261
14262  typedef union { /* SPP_DMA2_DMACEEI - DMA Clear Enable Error Interrupt Register */
14263  uint8_t R;
14264  struct {
14265  uint8_t:1;
14266  uint8_t CEEI:7; /* Clear Enable Error Interrupt */
14267  } B;
14269
14270  typedef union { /* SPP_DMA2_DMACINT - DMA Clear Interrupt Request */
14271  uint8_t R;
14272  struct {
14273  uint8_t:1;
14274  uint8_t CINT:7; /* Clear Interrupt Request */
14275  } B;
14277
14278  typedef union { /* SPP_DMA2_DMACERR - DMA Clear Error */
14279  uint8_t R;
14280  struct {
14281  uint8_t:1;
14282  uint8_t CERR:7; /* Clear Error Indicator */
14283  } B;
14285
14286  typedef union { /* SPP_DMA2_DMASSRT - DMA Set START Bit */
14287  uint8_t R;
14288  struct {
14289  uint8_t:1;
14290  uint8_t SSRT:7; /* Set START Bit */
14291  } B;
14293
14294  typedef union { /* SPP_DMA2_DMACDNE - DMA Clear DONE Status */
14295  uint8_t R;
14296  struct {
14297  uint8_t:1;
14298  uint8_t CDNE:7; /* Clear DONE Status Bit */
14299  } B;
14301
14302  typedef union { /* SPP_DMA2_DMAINTH - DMA Interrupt Request Register */
14303  uint32_t R;
14304  struct {
14305  uint32_t INT:32; /* DMA Interrupt Request */
14306  } B;
14308
14309  typedef union { /* SPP_DMA2_DMAINTL - DMA Interrupt Request Register */
14310  uint32_t R;
14311  struct {
14312  uint32_t INT:32; /* DMA Interrupt Request */
14313  } B;
14315
14316  typedef union { /* SPP_DMA2_DMAERRH - DMA Error Register */
14317  uint32_t R;
14318  struct {
14319  uint32_t ERR:32; /* DMA Error n */
14320  } B;
14322
14323  typedef union { /* SPP_DMA2_DMAERRL - DMA Error Register */
14324  uint32_t R;
14325  struct {
14326  uint32_t ERR:32; /* DMA Error n */
14327  } B;
14329
14330  typedef union { /* SPP_DMA2_DMAHRSH - DMA Hardware Request Status Register */
14331  uint32_t R;
14332  struct {
14333  uint32_t HRS:32; /* DMA Hardware Request Status */
14334  } B;
14336
14337  typedef union { /* SPP_DMA2_DMAHRSL - DMA Hardware Request Status Register */
14338  uint32_t R;
14339  struct {
14340  uint32_t HRS:32; /* DMA Hardware Request Status */
14341  } B;
14343
14344  typedef union { /* SPP_DMA2_DMAGPOR - DMA General Purpose Output Register */
14345  uint32_t R;
14346  struct {
14347  uint32_t GPOR:32; /* DMA General Purpose Output */
14348  } B;
14350
14351
14352  /* Register layout for all registers DCHPRI... */
14353
14354  typedef union { /* SPP_DMA2_DCHPRIn - DMA Channel n Priority */
14355  uint8_t R;
14356  struct {
14357  uint8_t ECP:1; /* Enable Channel Preemption */
14358  uint8_t DPA:1; /* Disable Preempt Ability */
14359  uint8_t GRPPRI:2; /* Channel n Current Group Priority */
14360  uint8_t CHPRI:4; /* Channel n Arbitration Priority */
14361  } B;
14363
14364
14365  /* Register layout for all registers TCDWORD0_... */
14366
14367  typedef union { /* SPP_DMA2_TCDn Word0 - Source Address */
14368  uint32_t R;
14369  struct {
14370  uint32_t SADDR:32; /* Source Address */
14371  } B;
14373
14374
14375  /* Register layout for all registers TCDWORD4_... */
14376
14377  typedef union { /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
14378  uint32_t R;
14379  struct {
14380  uint32_t SMOD:5; /* Source Address Modulo */
14381  uint32_t SSIZE:3; /* Source Data Transfer Size */
14382  uint32_t DMOD:5; /* Destination Address Module */
14383  uint32_t DSIZE:3; /* Destination Data Transfer Size */
14384  uint32_t SOFF:16; /* Source Address Signed Offset */
14385  } B;
14387
14388
14389  /* Register layout for all registers TCDWORD8_... */
14390
14391  typedef union { /* SPP_DMA2_TCDn Word2 - nbytes */
14392  uint32_t R;
14393  struct {
14394  uint32_t SMLOE:1; /* Source Minor Loop Offset Enable */
14395  uint32_t DMLOE:1; /* Destination Minor Loop Offset Enable */
14396  uint32_t MLOFF:20; /* Minor Loop Offset */
14397  uint32_t NBYTES:10; /* Inner Minor byte transfer Count */
14398  } B;
14400
14401
14402  /* Register layout for all registers TCDWORD12_... */
14403
14404  typedef union { /* SPP_DMA2_TCDn Word3 - slast */
14405  uint32_t R;
14406  struct {
14407  uint32_t SLAST:32; /* Last Source Address Adjustment */
14408  } B;
14410
14411
14412  /* Register layout for all registers TCDWORD16_... */
14413
14414  typedef union { /* SPP_DMA2_TCDn Word4 - daddr */
14415  uint32_t R;
14416  struct {
14417  uint32_t DADDR:32; /* Destination Address */
14418  } B;
14420
14421
14422  /* Register layout for all registers TCDWORD20_... */
14423
14424  typedef union { /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
14425  uint32_t R;
14426  struct {
14427  uint32_t CITER_E_LINK:1; /* Enable Channel to channel linking on minor loop complete */
14428  uint32_t CITER_LINKCH:6; /* Link Channel Number */
14429  uint32_t CITER:9; /* Current Major Iteration Count */
14430  uint32_t DOFF:16; /* Destination Address Signed Offset */
14431  } B;
14433
14434
14435  /* Register layout for all registers TCDWORD24_... */
14436
14437  typedef union { /* SPP_DMA2_TCDn Word6 - dlast_sga */
14438  uint32_t R;
14439  struct {
14440  uint32_t DLAST_SGA:32; /* Last destination address adjustment */
14441  } B;
14443
14444
14445  /* Register layout for all registers TCDWORD28_... */
14446
14447  typedef union { /* SPP_DMA2_TCDn Word7 - biter, etc. */
14448  uint32_t R;
14449  struct {
14450
14451 #ifndef USE_FIELD_ALIASES_SPP_DMA2
14452  uint32_t BITER_E_LINK:1; /* beginning ("major") iteration count */
14453 #else
14454  uint32_t BITERE_LINK:1; /* deprecated name - please avoid */
14455 #endif
14456  uint32_t BITER:15; /* Enable Channel to Channel linking on minor loop complete */
14457  uint32_t BWC:2; /* Bandwidth Control */
14458  uint32_t MAJOR_LINKCH:6; /* Link Channel Number */
14459  uint32_t DONE:1; /* channel done */
14460  uint32_t ACTIVE:1; /* Channel Active */
14461  uint32_t MAJOR_E_LINK:1; /* Enable Channel to Channel Linking on major loop complete */
14462  uint32_t E_SG:1; /* Enable Scatter/Gather Processing */
14463  uint32_t D_REQ:1; /* Disable Request */
14464  uint32_t INT_HALF:1; /* Enable an Interrupt when Major Counter is half complete */
14465  uint32_t INT_MAJ:1; /* Enable an Interrupt when Major Iteration count completes */
14466  uint32_t START:1; /* Channel Start */
14467  } B;
14469
14470
14472
14473  /* SPP_DMA2_TCDn Word0 - Source Address */
14474  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_; /* relative offset: 0x0000 */
14475  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
14476  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_; /* relative offset: 0x0004 */
14477  /* SPP_DMA2_TCDn Word2 - nbytes */
14478  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_; /* relative offset: 0x0008 */
14479  /* SPP_DMA2_TCDn Word3 - slast */
14480  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_; /* relative offset: 0x000C */
14481  /* SPP_DMA2_TCDn Word4 - daddr */
14482  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_; /* relative offset: 0x0010 */
14483  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
14484  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_; /* relative offset: 0x0014 */
14485  /* SPP_DMA2_TCDn Word6 - dlast_sga */
14486  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_; /* relative offset: 0x0018 */
14487  /* SPP_DMA2_TCDn Word7 - biter, etc. */
14488  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_; /* relative offset: 0x001C */
14489
14491
14492
14493  typedef struct SPP_DMA2_struct_tag { /* start of SPP_DMA2_tag */
14494  /* SPP_DMA2_DMACR - DMA Control Register */
14495  SPP_DMA2_DMACR_32B_tag DMACR; /* offset: 0x0000 size: 32 bit */
14496  /* SPP_DMA2_DMAES - DMA Error Status Register */
14497  SPP_DMA2_DMAES_32B_tag DMAES; /* offset: 0x0004 size: 32 bit */
14498  /* SPP_DMA2_DMAERQH - DMA Enable Request Register */
14499  SPP_DMA2_DMAERQH_32B_tag DMAERQH; /* offset: 0x0008 size: 32 bit */
14500  /* SPP_DMA2_DMAERQL - DMA Enable Request Register */
14501  SPP_DMA2_DMAERQL_32B_tag DMAERQL; /* offset: 0x000C size: 32 bit */
14502  /* SPP_DMA2_DMAEEIH - DMA Enable Error Interrupt Register */
14503  SPP_DMA2_DMAEEIH_32B_tag DMAEEIH; /* offset: 0x0010 size: 32 bit */
14504  /* SPP_DMA2_DMAEEIL - DMA Enable Error Interrupt Register */
14505  SPP_DMA2_DMAEEIL_32B_tag DMAEEIL; /* offset: 0x0014 size: 32 bit */
14506  /* SPP_DMA2_DMASERQ - DMA Set Enable Request Register */
14507  SPP_DMA2_DMASERQ_8B_tag DMASERQ; /* offset: 0x0018 size: 8 bit */
14508  /* SPP_DMA2_DMACERQ - DMA Clear Enable Request Register */
14509  SPP_DMA2_DMACERQ_8B_tag DMACERQ; /* offset: 0x0019 size: 8 bit */
14510  /* SPP_DMA2_DMASEEI - DMA Set Enable Error Interrupt Register */
14511  SPP_DMA2_DMASEEI_8B_tag DMASEEI; /* offset: 0x001A size: 8 bit */
14512  /* SPP_DMA2_DMACEEI - DMA Clear Enable Error Interrupt Register */
14513  SPP_DMA2_DMACEEI_8B_tag DMACEEI; /* offset: 0x001B size: 8 bit */
14514  /* SPP_DMA2_DMACINT - DMA Clear Interrupt Request */
14515  SPP_DMA2_DMACINT_8B_tag DMACINT; /* offset: 0x001C size: 8 bit */
14516  /* SPP_DMA2_DMACERR - DMA Clear Error */
14517  SPP_DMA2_DMACERR_8B_tag DMACERR; /* offset: 0x001D size: 8 bit */
14518  /* SPP_DMA2_DMASSRT - DMA Set START Bit */
14519  SPP_DMA2_DMASSRT_8B_tag DMASSRT; /* offset: 0x001E size: 8 bit */
14520  /* SPP_DMA2_DMACDNE - DMA Clear DONE Status */
14521  SPP_DMA2_DMACDNE_8B_tag DMACDNE; /* offset: 0x001F size: 8 bit */
14522  /* SPP_DMA2_DMAINTH - DMA Interrupt Request Register */
14523  SPP_DMA2_DMAINTH_32B_tag DMAINTH; /* offset: 0x0020 size: 32 bit */
14524  /* SPP_DMA2_DMAINTL - DMA Interrupt Request Register */
14525  SPP_DMA2_DMAINTL_32B_tag DMAINTL; /* offset: 0x0024 size: 32 bit */
14526  /* SPP_DMA2_DMAERRH - DMA Error Register */
14527  SPP_DMA2_DMAERRH_32B_tag DMAERRH; /* offset: 0x0028 size: 32 bit */
14528  /* SPP_DMA2_DMAERRL - DMA Error Register */
14529  SPP_DMA2_DMAERRL_32B_tag DMAERRL; /* offset: 0x002C size: 32 bit */
14530  /* SPP_DMA2_DMAHRSH - DMA Hardware Request Status Register */
14531  SPP_DMA2_DMAHRSH_32B_tag DMAHRSH; /* offset: 0x0030 size: 32 bit */
14532  /* SPP_DMA2_DMAHRSL - DMA Hardware Request Status Register */
14533  SPP_DMA2_DMAHRSL_32B_tag DMAHRSL; /* offset: 0x0034 size: 32 bit */
14534  /* SPP_DMA2_DMAGPOR - DMA General Purpose Output Register */
14535  SPP_DMA2_DMAGPOR_32B_tag DMAGPOR; /* offset: 0x0038 size: 32 bit */
14536  int8_t SPP_DMA2_reserved_003C_C[196];
14537  union {
14538  /* SPP_DMA2_DCHPRIn - DMA Channel n Priority */
14539  SPP_DMA2_DCHPRI_8B_tag DCHPRI[64]; /* offset: 0x0100 (0x0001 x 64) */
14540
14541  struct {
14542  /* SPP_DMA2_DCHPRIn - DMA Channel n Priority */
14543  SPP_DMA2_DCHPRI_8B_tag DCHPRI0; /* offset: 0x0100 size: 8 bit */
14544  SPP_DMA2_DCHPRI_8B_tag DCHPRI1; /* offset: 0x0101 size: 8 bit */
14545  SPP_DMA2_DCHPRI_8B_tag DCHPRI2; /* offset: 0x0102 size: 8 bit */
14546  SPP_DMA2_DCHPRI_8B_tag DCHPRI3; /* offset: 0x0103 size: 8 bit */
14547  SPP_DMA2_DCHPRI_8B_tag DCHPRI4; /* offset: 0x0104 size: 8 bit */
14548  SPP_DMA2_DCHPRI_8B_tag DCHPRI5; /* offset: 0x0105 size: 8 bit */
14549  SPP_DMA2_DCHPRI_8B_tag DCHPRI6; /* offset: 0x0106 size: 8 bit */
14550  SPP_DMA2_DCHPRI_8B_tag DCHPRI7; /* offset: 0x0107 size: 8 bit */
14551  SPP_DMA2_DCHPRI_8B_tag DCHPRI8; /* offset: 0x0108 size: 8 bit */
14552  SPP_DMA2_DCHPRI_8B_tag DCHPRI9; /* offset: 0x0109 size: 8 bit */
14553  SPP_DMA2_DCHPRI_8B_tag DCHPRI10; /* offset: 0x010A size: 8 bit */
14554  SPP_DMA2_DCHPRI_8B_tag DCHPRI11; /* offset: 0x010B size: 8 bit */
14555  SPP_DMA2_DCHPRI_8B_tag DCHPRI12; /* offset: 0x010C size: 8 bit */
14556  SPP_DMA2_DCHPRI_8B_tag DCHPRI13; /* offset: 0x010D size: 8 bit */
14557  SPP_DMA2_DCHPRI_8B_tag DCHPRI14; /* offset: 0x010E size: 8 bit */
14558  SPP_DMA2_DCHPRI_8B_tag DCHPRI15; /* offset: 0x010F size: 8 bit */
14559  SPP_DMA2_DCHPRI_8B_tag DCHPRI16; /* offset: 0x0110 size: 8 bit */
14560  SPP_DMA2_DCHPRI_8B_tag DCHPRI17; /* offset: 0x0111 size: 8 bit */
14561  SPP_DMA2_DCHPRI_8B_tag DCHPRI18; /* offset: 0x0112 size: 8 bit */
14562  SPP_DMA2_DCHPRI_8B_tag DCHPRI19; /* offset: 0x0113 size: 8 bit */
14563  SPP_DMA2_DCHPRI_8B_tag DCHPRI20; /* offset: 0x0114 size: 8 bit */
14564  SPP_DMA2_DCHPRI_8B_tag DCHPRI21; /* offset: 0x0115 size: 8 bit */
14565  SPP_DMA2_DCHPRI_8B_tag DCHPRI22; /* offset: 0x0116 size: 8 bit */
14566  SPP_DMA2_DCHPRI_8B_tag DCHPRI23; /* offset: 0x0117 size: 8 bit */
14567  SPP_DMA2_DCHPRI_8B_tag DCHPRI24; /* offset: 0x0118 size: 8 bit */
14568  SPP_DMA2_DCHPRI_8B_tag DCHPRI25; /* offset: 0x0119 size: 8 bit */
14569  SPP_DMA2_DCHPRI_8B_tag DCHPRI26; /* offset: 0x011A size: 8 bit */
14570  SPP_DMA2_DCHPRI_8B_tag DCHPRI27; /* offset: 0x011B size: 8 bit */
14571  SPP_DMA2_DCHPRI_8B_tag DCHPRI28; /* offset: 0x011C size: 8 bit */
14572  SPP_DMA2_DCHPRI_8B_tag DCHPRI29; /* offset: 0x011D size: 8 bit */
14573  SPP_DMA2_DCHPRI_8B_tag DCHPRI30; /* offset: 0x011E size: 8 bit */
14574  SPP_DMA2_DCHPRI_8B_tag DCHPRI31; /* offset: 0x011F size: 8 bit */
14575  SPP_DMA2_DCHPRI_8B_tag DCHPRI32; /* offset: 0x0120 size: 8 bit */
14576  SPP_DMA2_DCHPRI_8B_tag DCHPRI33; /* offset: 0x0121 size: 8 bit */
14577  SPP_DMA2_DCHPRI_8B_tag DCHPRI34; /* offset: 0x0122 size: 8 bit */
14578  SPP_DMA2_DCHPRI_8B_tag DCHPRI35; /* offset: 0x0123 size: 8 bit */
14579  SPP_DMA2_DCHPRI_8B_tag DCHPRI36; /* offset: 0x0124 size: 8 bit */
14580  SPP_DMA2_DCHPRI_8B_tag DCHPRI37; /* offset: 0x0125 size: 8 bit */
14581  SPP_DMA2_DCHPRI_8B_tag DCHPRI38; /* offset: 0x0126 size: 8 bit */
14582  SPP_DMA2_DCHPRI_8B_tag DCHPRI39; /* offset: 0x0127 size: 8 bit */
14583  SPP_DMA2_DCHPRI_8B_tag DCHPRI40; /* offset: 0x0128 size: 8 bit */
14584  SPP_DMA2_DCHPRI_8B_tag DCHPRI41; /* offset: 0x0129 size: 8 bit */
14585  SPP_DMA2_DCHPRI_8B_tag DCHPRI42; /* offset: 0x012A size: 8 bit */
14586  SPP_DMA2_DCHPRI_8B_tag DCHPRI43; /* offset: 0x012B size: 8 bit */
14587  SPP_DMA2_DCHPRI_8B_tag DCHPRI44; /* offset: 0x012C size: 8 bit */
14588  SPP_DMA2_DCHPRI_8B_tag DCHPRI45; /* offset: 0x012D size: 8 bit */
14589  SPP_DMA2_DCHPRI_8B_tag DCHPRI46; /* offset: 0x012E size: 8 bit */
14590  SPP_DMA2_DCHPRI_8B_tag DCHPRI47; /* offset: 0x012F size: 8 bit */
14591  SPP_DMA2_DCHPRI_8B_tag DCHPRI48; /* offset: 0x0130 size: 8 bit */
14592  SPP_DMA2_DCHPRI_8B_tag DCHPRI49; /* offset: 0x0131 size: 8 bit */
14593  SPP_DMA2_DCHPRI_8B_tag DCHPRI50; /* offset: 0x0132 size: 8 bit */
14594  SPP_DMA2_DCHPRI_8B_tag DCHPRI51; /* offset: 0x0133 size: 8 bit */
14595  SPP_DMA2_DCHPRI_8B_tag DCHPRI52; /* offset: 0x0134 size: 8 bit */
14596  SPP_DMA2_DCHPRI_8B_tag DCHPRI53; /* offset: 0x0135 size: 8 bit */
14597  SPP_DMA2_DCHPRI_8B_tag DCHPRI54; /* offset: 0x0136 size: 8 bit */
14598  SPP_DMA2_DCHPRI_8B_tag DCHPRI55; /* offset: 0x0137 size: 8 bit */
14599  SPP_DMA2_DCHPRI_8B_tag DCHPRI56; /* offset: 0x0138 size: 8 bit */
14600  SPP_DMA2_DCHPRI_8B_tag DCHPRI57; /* offset: 0x0139 size: 8 bit */
14601  SPP_DMA2_DCHPRI_8B_tag DCHPRI58; /* offset: 0x013A size: 8 bit */
14602  SPP_DMA2_DCHPRI_8B_tag DCHPRI59; /* offset: 0x013B size: 8 bit */
14603  SPP_DMA2_DCHPRI_8B_tag DCHPRI60; /* offset: 0x013C size: 8 bit */
14604  SPP_DMA2_DCHPRI_8B_tag DCHPRI61; /* offset: 0x013D size: 8 bit */
14605  SPP_DMA2_DCHPRI_8B_tag DCHPRI62; /* offset: 0x013E size: 8 bit */
14606  SPP_DMA2_DCHPRI_8B_tag DCHPRI63; /* offset: 0x013F size: 8 bit */
14607  };
14608
14609  };
14610  int8_t SPP_DMA2_reserved_0140_C[3776];
14611  union {
14612  /* Register set CHANNEL */
14613  SPP_DMA2_CHANNEL_tag CHANNEL[64]; /* offset: 0x1000 (0x0020 x 64) */
14614
14615  struct {
14616  /* SPP_DMA2_TCDn Word0 - Source Address */
14617  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_0; /* offset: 0x1000 size: 32 bit */
14618  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
14619  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_0; /* offset: 0x1004 size: 32 bit */
14620  /* SPP_DMA2_TCDn Word2 - nbytes */
14621  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_0; /* offset: 0x1008 size: 32 bit */
14622  /* SPP_DMA2_TCDn Word3 - slast */
14623  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_0; /* offset: 0x100C size: 32 bit */
14624  /* SPP_DMA2_TCDn Word4 - daddr */
14625  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_0; /* offset: 0x1010 size: 32 bit */
14626  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
14627  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_0; /* offset: 0x1014 size: 32 bit */
14628  /* SPP_DMA2_TCDn Word6 - dlast_sga */
14629  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_0; /* offset: 0x1018 size: 32 bit */
14630  /* SPP_DMA2_TCDn Word7 - biter, etc. */
14631  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_0; /* offset: 0x101C size: 32 bit */
14632  /* SPP_DMA2_TCDn Word0 - Source Address */
14633  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_1; /* offset: 0x1020 size: 32 bit */
14634  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
14635  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_1; /* offset: 0x1024 size: 32 bit */
14636  /* SPP_DMA2_TCDn Word2 - nbytes */
14637  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_1; /* offset: 0x1028 size: 32 bit */
14638  /* SPP_DMA2_TCDn Word3 - slast */
14639  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_1; /* offset: 0x102C size: 32 bit */
14640  /* SPP_DMA2_TCDn Word4 - daddr */
14641  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_1; /* offset: 0x1030 size: 32 bit */
14642  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
14643  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_1; /* offset: 0x1034 size: 32 bit */
14644  /* SPP_DMA2_TCDn Word6 - dlast_sga */
14645  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_1; /* offset: 0x1038 size: 32 bit */
14646  /* SPP_DMA2_TCDn Word7 - biter, etc. */
14647  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_1; /* offset: 0x103C size: 32 bit */
14648  /* SPP_DMA2_TCDn Word0 - Source Address */
14649  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_2; /* offset: 0x1040 size: 32 bit */
14650  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
14651  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_2; /* offset: 0x1044 size: 32 bit */
14652  /* SPP_DMA2_TCDn Word2 - nbytes */
14653  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_2; /* offset: 0x1048 size: 32 bit */
14654  /* SPP_DMA2_TCDn Word3 - slast */
14655  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_2; /* offset: 0x104C size: 32 bit */
14656  /* SPP_DMA2_TCDn Word4 - daddr */
14657  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_2; /* offset: 0x1050 size: 32 bit */
14658  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
14659  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_2; /* offset: 0x1054 size: 32 bit */
14660  /* SPP_DMA2_TCDn Word6 - dlast_sga */
14661  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_2; /* offset: 0x1058 size: 32 bit */
14662  /* SPP_DMA2_TCDn Word7 - biter, etc. */
14663  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_2; /* offset: 0x105C size: 32 bit */
14664  /* SPP_DMA2_TCDn Word0 - Source Address */
14665  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_3; /* offset: 0x1060 size: 32 bit */
14666  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
14667  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_3; /* offset: 0x1064 size: 32 bit */
14668  /* SPP_DMA2_TCDn Word2 - nbytes */
14669  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_3; /* offset: 0x1068 size: 32 bit */
14670  /* SPP_DMA2_TCDn Word3 - slast */
14671  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_3; /* offset: 0x106C size: 32 bit */
14672  /* SPP_DMA2_TCDn Word4 - daddr */
14673  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_3; /* offset: 0x1070 size: 32 bit */
14674  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
14675  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_3; /* offset: 0x1074 size: 32 bit */
14676  /* SPP_DMA2_TCDn Word6 - dlast_sga */
14677  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_3; /* offset: 0x1078 size: 32 bit */
14678  /* SPP_DMA2_TCDn Word7 - biter, etc. */
14679  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_3; /* offset: 0x107C size: 32 bit */
14680  /* SPP_DMA2_TCDn Word0 - Source Address */
14681  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_4; /* offset: 0x1080 size: 32 bit */
14682  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
14683  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_4; /* offset: 0x1084 size: 32 bit */
14684  /* SPP_DMA2_TCDn Word2 - nbytes */
14685  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_4; /* offset: 0x1088 size: 32 bit */
14686  /* SPP_DMA2_TCDn Word3 - slast */
14687  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_4; /* offset: 0x108C size: 32 bit */
14688  /* SPP_DMA2_TCDn Word4 - daddr */
14689  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_4; /* offset: 0x1090 size: 32 bit */
14690  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
14691  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_4; /* offset: 0x1094 size: 32 bit */
14692  /* SPP_DMA2_TCDn Word6 - dlast_sga */
14693  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_4; /* offset: 0x1098 size: 32 bit */
14694  /* SPP_DMA2_TCDn Word7 - biter, etc. */
14695  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_4; /* offset: 0x109C size: 32 bit */
14696  /* SPP_DMA2_TCDn Word0 - Source Address */
14697  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_5; /* offset: 0x10A0 size: 32 bit */
14698  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
14699  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_5; /* offset: 0x10A4 size: 32 bit */
14700  /* SPP_DMA2_TCDn Word2 - nbytes */
14701  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_5; /* offset: 0x10A8 size: 32 bit */
14702  /* SPP_DMA2_TCDn Word3 - slast */
14703  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_5; /* offset: 0x10AC size: 32 bit */
14704  /* SPP_DMA2_TCDn Word4 - daddr */
14705  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_5; /* offset: 0x10B0 size: 32 bit */
14706  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
14707  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_5; /* offset: 0x10B4 size: 32 bit */
14708  /* SPP_DMA2_TCDn Word6 - dlast_sga */
14709  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_5; /* offset: 0x10B8 size: 32 bit */
14710  /* SPP_DMA2_TCDn Word7 - biter, etc. */
14711  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_5; /* offset: 0x10BC size: 32 bit */
14712  /* SPP_DMA2_TCDn Word0 - Source Address */
14713  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_6; /* offset: 0x10C0 size: 32 bit */
14714  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
14715  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_6; /* offset: 0x10C4 size: 32 bit */
14716  /* SPP_DMA2_TCDn Word2 - nbytes */
14717  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_6; /* offset: 0x10C8 size: 32 bit */
14718  /* SPP_DMA2_TCDn Word3 - slast */
14719  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_6; /* offset: 0x10CC size: 32 bit */
14720  /* SPP_DMA2_TCDn Word4 - daddr */
14721  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_6; /* offset: 0x10D0 size: 32 bit */
14722  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
14723  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_6; /* offset: 0x10D4 size: 32 bit */
14724  /* SPP_DMA2_TCDn Word6 - dlast_sga */
14725  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_6; /* offset: 0x10D8 size: 32 bit */
14726  /* SPP_DMA2_TCDn Word7 - biter, etc. */
14727  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_6; /* offset: 0x10DC size: 32 bit */
14728  /* SPP_DMA2_TCDn Word0 - Source Address */
14729  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_7; /* offset: 0x10E0 size: 32 bit */
14730  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
14731  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_7; /* offset: 0x10E4 size: 32 bit */
14732  /* SPP_DMA2_TCDn Word2 - nbytes */
14733  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_7; /* offset: 0x10E8 size: 32 bit */
14734  /* SPP_DMA2_TCDn Word3 - slast */
14735  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_7; /* offset: 0x10EC size: 32 bit */
14736  /* SPP_DMA2_TCDn Word4 - daddr */
14737  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_7; /* offset: 0x10F0 size: 32 bit */
14738  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
14739  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_7; /* offset: 0x10F4 size: 32 bit */
14740  /* SPP_DMA2_TCDn Word6 - dlast_sga */
14741  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_7; /* offset: 0x10F8 size: 32 bit */
14742  /* SPP_DMA2_TCDn Word7 - biter, etc. */
14743  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_7; /* offset: 0x10FC size: 32 bit */
14744  /* SPP_DMA2_TCDn Word0 - Source Address */
14745  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_8; /* offset: 0x1100 size: 32 bit */
14746  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
14747  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_8; /* offset: 0x1104 size: 32 bit */
14748  /* SPP_DMA2_TCDn Word2 - nbytes */
14749  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_8; /* offset: 0x1108 size: 32 bit */
14750  /* SPP_DMA2_TCDn Word3 - slast */
14751  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_8; /* offset: 0x110C size: 32 bit */
14752  /* SPP_DMA2_TCDn Word4 - daddr */
14753  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_8; /* offset: 0x1110 size: 32 bit */
14754  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
14755  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_8; /* offset: 0x1114 size: 32 bit */
14756  /* SPP_DMA2_TCDn Word6 - dlast_sga */
14757  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_8; /* offset: 0x1118 size: 32 bit */
14758  /* SPP_DMA2_TCDn Word7 - biter, etc. */
14759  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_8; /* offset: 0x111C size: 32 bit */
14760  /* SPP_DMA2_TCDn Word0 - Source Address */
14761  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_9; /* offset: 0x1120 size: 32 bit */
14762  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
14763  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_9; /* offset: 0x1124 size: 32 bit */
14764  /* SPP_DMA2_TCDn Word2 - nbytes */
14765  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_9; /* offset: 0x1128 size: 32 bit */
14766  /* SPP_DMA2_TCDn Word3 - slast */
14767  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_9; /* offset: 0x112C size: 32 bit */
14768  /* SPP_DMA2_TCDn Word4 - daddr */
14769  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_9; /* offset: 0x1130 size: 32 bit */
14770  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
14771  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_9; /* offset: 0x1134 size: 32 bit */
14772  /* SPP_DMA2_TCDn Word6 - dlast_sga */
14773  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_9; /* offset: 0x1138 size: 32 bit */
14774  /* SPP_DMA2_TCDn Word7 - biter, etc. */
14775  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_9; /* offset: 0x113C size: 32 bit */
14776  /* SPP_DMA2_TCDn Word0 - Source Address */
14777  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_10; /* offset: 0x1140 size: 32 bit */
14778  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
14779  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_10; /* offset: 0x1144 size: 32 bit */
14780  /* SPP_DMA2_TCDn Word2 - nbytes */
14781  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_10; /* offset: 0x1148 size: 32 bit */
14782  /* SPP_DMA2_TCDn Word3 - slast */
14783  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_10; /* offset: 0x114C size: 32 bit */
14784  /* SPP_DMA2_TCDn Word4 - daddr */
14785  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_10; /* offset: 0x1150 size: 32 bit */
14786  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
14787  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_10; /* offset: 0x1154 size: 32 bit */
14788  /* SPP_DMA2_TCDn Word6 - dlast_sga */
14789  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_10; /* offset: 0x1158 size: 32 bit */
14790  /* SPP_DMA2_TCDn Word7 - biter, etc. */
14791  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_10; /* offset: 0x115C size: 32 bit */
14792  /* SPP_DMA2_TCDn Word0 - Source Address */
14793  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_11; /* offset: 0x1160 size: 32 bit */
14794  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
14795  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_11; /* offset: 0x1164 size: 32 bit */
14796  /* SPP_DMA2_TCDn Word2 - nbytes */
14797  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_11; /* offset: 0x1168 size: 32 bit */
14798  /* SPP_DMA2_TCDn Word3 - slast */
14799  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_11; /* offset: 0x116C size: 32 bit */
14800  /* SPP_DMA2_TCDn Word4 - daddr */
14801  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_11; /* offset: 0x1170 size: 32 bit */
14802  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
14803  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_11; /* offset: 0x1174 size: 32 bit */
14804  /* SPP_DMA2_TCDn Word6 - dlast_sga */
14805  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_11; /* offset: 0x1178 size: 32 bit */
14806  /* SPP_DMA2_TCDn Word7 - biter, etc. */
14807  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_11; /* offset: 0x117C size: 32 bit */
14808  /* SPP_DMA2_TCDn Word0 - Source Address */
14809  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_12; /* offset: 0x1180 size: 32 bit */
14810  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
14811  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_12; /* offset: 0x1184 size: 32 bit */
14812  /* SPP_DMA2_TCDn Word2 - nbytes */
14813  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_12; /* offset: 0x1188 size: 32 bit */
14814  /* SPP_DMA2_TCDn Word3 - slast */
14815  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_12; /* offset: 0x118C size: 32 bit */
14816  /* SPP_DMA2_TCDn Word4 - daddr */
14817  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_12; /* offset: 0x1190 size: 32 bit */
14818  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
14819  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_12; /* offset: 0x1194 size: 32 bit */
14820  /* SPP_DMA2_TCDn Word6 - dlast_sga */
14821  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_12; /* offset: 0x1198 size: 32 bit */
14822  /* SPP_DMA2_TCDn Word7 - biter, etc. */
14823  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_12; /* offset: 0x119C size: 32 bit */
14824  /* SPP_DMA2_TCDn Word0 - Source Address */
14825  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_13; /* offset: 0x11A0 size: 32 bit */
14826  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
14827  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_13; /* offset: 0x11A4 size: 32 bit */
14828  /* SPP_DMA2_TCDn Word2 - nbytes */
14829  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_13; /* offset: 0x11A8 size: 32 bit */
14830  /* SPP_DMA2_TCDn Word3 - slast */
14831  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_13; /* offset: 0x11AC size: 32 bit */
14832  /* SPP_DMA2_TCDn Word4 - daddr */
14833  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_13; /* offset: 0x11B0 size: 32 bit */
14834  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
14835  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_13; /* offset: 0x11B4 size: 32 bit */
14836  /* SPP_DMA2_TCDn Word6 - dlast_sga */
14837  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_13; /* offset: 0x11B8 size: 32 bit */
14838  /* SPP_DMA2_TCDn Word7 - biter, etc. */
14839  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_13; /* offset: 0x11BC size: 32 bit */
14840  /* SPP_DMA2_TCDn Word0 - Source Address */
14841  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_14; /* offset: 0x11C0 size: 32 bit */
14842  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
14843  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_14; /* offset: 0x11C4 size: 32 bit */
14844  /* SPP_DMA2_TCDn Word2 - nbytes */
14845  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_14; /* offset: 0x11C8 size: 32 bit */
14846  /* SPP_DMA2_TCDn Word3 - slast */
14847  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_14; /* offset: 0x11CC size: 32 bit */
14848  /* SPP_DMA2_TCDn Word4 - daddr */
14849  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_14; /* offset: 0x11D0 size: 32 bit */
14850  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
14851  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_14; /* offset: 0x11D4 size: 32 bit */
14852  /* SPP_DMA2_TCDn Word6 - dlast_sga */
14853  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_14; /* offset: 0x11D8 size: 32 bit */
14854  /* SPP_DMA2_TCDn Word7 - biter, etc. */
14855  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_14; /* offset: 0x11DC size: 32 bit */
14856  /* SPP_DMA2_TCDn Word0 - Source Address */
14857  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_15; /* offset: 0x11E0 size: 32 bit */
14858  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
14859  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_15; /* offset: 0x11E4 size: 32 bit */
14860  /* SPP_DMA2_TCDn Word2 - nbytes */
14861  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_15; /* offset: 0x11E8 size: 32 bit */
14862  /* SPP_DMA2_TCDn Word3 - slast */
14863  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_15; /* offset: 0x11EC size: 32 bit */
14864  /* SPP_DMA2_TCDn Word4 - daddr */
14865  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_15; /* offset: 0x11F0 size: 32 bit */
14866  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
14867  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_15; /* offset: 0x11F4 size: 32 bit */
14868  /* SPP_DMA2_TCDn Word6 - dlast_sga */
14869  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_15; /* offset: 0x11F8 size: 32 bit */
14870  /* SPP_DMA2_TCDn Word7 - biter, etc. */
14871  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_15; /* offset: 0x11FC size: 32 bit */
14872  /* SPP_DMA2_TCDn Word0 - Source Address */
14873  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_16; /* offset: 0x1200 size: 32 bit */
14874  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
14875  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_16; /* offset: 0x1204 size: 32 bit */
14876  /* SPP_DMA2_TCDn Word2 - nbytes */
14877  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_16; /* offset: 0x1208 size: 32 bit */
14878  /* SPP_DMA2_TCDn Word3 - slast */
14879  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_16; /* offset: 0x120C size: 32 bit */
14880  /* SPP_DMA2_TCDn Word4 - daddr */
14881  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_16; /* offset: 0x1210 size: 32 bit */
14882  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
14883  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_16; /* offset: 0x1214 size: 32 bit */
14884  /* SPP_DMA2_TCDn Word6 - dlast_sga */
14885  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_16; /* offset: 0x1218 size: 32 bit */
14886  /* SPP_DMA2_TCDn Word7 - biter, etc. */
14887  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_16; /* offset: 0x121C size: 32 bit */
14888  /* SPP_DMA2_TCDn Word0 - Source Address */
14889  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_17; /* offset: 0x1220 size: 32 bit */
14890  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
14891  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_17; /* offset: 0x1224 size: 32 bit */
14892  /* SPP_DMA2_TCDn Word2 - nbytes */
14893  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_17; /* offset: 0x1228 size: 32 bit */
14894  /* SPP_DMA2_TCDn Word3 - slast */
14895  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_17; /* offset: 0x122C size: 32 bit */
14896  /* SPP_DMA2_TCDn Word4 - daddr */
14897  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_17; /* offset: 0x1230 size: 32 bit */
14898  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
14899  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_17; /* offset: 0x1234 size: 32 bit */
14900  /* SPP_DMA2_TCDn Word6 - dlast_sga */
14901  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_17; /* offset: 0x1238 size: 32 bit */
14902  /* SPP_DMA2_TCDn Word7 - biter, etc. */
14903  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_17; /* offset: 0x123C size: 32 bit */
14904  /* SPP_DMA2_TCDn Word0 - Source Address */
14905  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_18; /* offset: 0x1240 size: 32 bit */
14906  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
14907  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_18; /* offset: 0x1244 size: 32 bit */
14908  /* SPP_DMA2_TCDn Word2 - nbytes */
14909  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_18; /* offset: 0x1248 size: 32 bit */
14910  /* SPP_DMA2_TCDn Word3 - slast */
14911  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_18; /* offset: 0x124C size: 32 bit */
14912  /* SPP_DMA2_TCDn Word4 - daddr */
14913  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_18; /* offset: 0x1250 size: 32 bit */
14914  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
14915  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_18; /* offset: 0x1254 size: 32 bit */
14916  /* SPP_DMA2_TCDn Word6 - dlast_sga */
14917  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_18; /* offset: 0x1258 size: 32 bit */
14918  /* SPP_DMA2_TCDn Word7 - biter, etc. */
14919  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_18; /* offset: 0x125C size: 32 bit */
14920  /* SPP_DMA2_TCDn Word0 - Source Address */
14921  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_19; /* offset: 0x1260 size: 32 bit */
14922  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
14923  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_19; /* offset: 0x1264 size: 32 bit */
14924  /* SPP_DMA2_TCDn Word2 - nbytes */
14925  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_19; /* offset: 0x1268 size: 32 bit */
14926  /* SPP_DMA2_TCDn Word3 - slast */
14927  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_19; /* offset: 0x126C size: 32 bit */
14928  /* SPP_DMA2_TCDn Word4 - daddr */
14929  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_19; /* offset: 0x1270 size: 32 bit */
14930  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
14931  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_19; /* offset: 0x1274 size: 32 bit */
14932  /* SPP_DMA2_TCDn Word6 - dlast_sga */
14933  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_19; /* offset: 0x1278 size: 32 bit */
14934  /* SPP_DMA2_TCDn Word7 - biter, etc. */
14935  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_19; /* offset: 0x127C size: 32 bit */
14936  /* SPP_DMA2_TCDn Word0 - Source Address */
14937  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_20; /* offset: 0x1280 size: 32 bit */
14938  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
14939  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_20; /* offset: 0x1284 size: 32 bit */
14940  /* SPP_DMA2_TCDn Word2 - nbytes */
14941  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_20; /* offset: 0x1288 size: 32 bit */
14942  /* SPP_DMA2_TCDn Word3 - slast */
14943  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_20; /* offset: 0x128C size: 32 bit */
14944  /* SPP_DMA2_TCDn Word4 - daddr */
14945  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_20; /* offset: 0x1290 size: 32 bit */
14946  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
14947  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_20; /* offset: 0x1294 size: 32 bit */
14948  /* SPP_DMA2_TCDn Word6 - dlast_sga */
14949  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_20; /* offset: 0x1298 size: 32 bit */
14950  /* SPP_DMA2_TCDn Word7 - biter, etc. */
14951  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_20; /* offset: 0x129C size: 32 bit */
14952  /* SPP_DMA2_TCDn Word0 - Source Address */
14953  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_21; /* offset: 0x12A0 size: 32 bit */
14954  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
14955  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_21; /* offset: 0x12A4 size: 32 bit */
14956  /* SPP_DMA2_TCDn Word2 - nbytes */
14957  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_21; /* offset: 0x12A8 size: 32 bit */
14958  /* SPP_DMA2_TCDn Word3 - slast */
14959  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_21; /* offset: 0x12AC size: 32 bit */
14960  /* SPP_DMA2_TCDn Word4 - daddr */
14961  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_21; /* offset: 0x12B0 size: 32 bit */
14962  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
14963  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_21; /* offset: 0x12B4 size: 32 bit */
14964  /* SPP_DMA2_TCDn Word6 - dlast_sga */
14965  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_21; /* offset: 0x12B8 size: 32 bit */
14966  /* SPP_DMA2_TCDn Word7 - biter, etc. */
14967  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_21; /* offset: 0x12BC size: 32 bit */
14968  /* SPP_DMA2_TCDn Word0 - Source Address */
14969  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_22; /* offset: 0x12C0 size: 32 bit */
14970  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
14971  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_22; /* offset: 0x12C4 size: 32 bit */
14972  /* SPP_DMA2_TCDn Word2 - nbytes */
14973  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_22; /* offset: 0x12C8 size: 32 bit */
14974  /* SPP_DMA2_TCDn Word3 - slast */
14975  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_22; /* offset: 0x12CC size: 32 bit */
14976  /* SPP_DMA2_TCDn Word4 - daddr */
14977  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_22; /* offset: 0x12D0 size: 32 bit */
14978  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
14979  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_22; /* offset: 0x12D4 size: 32 bit */
14980  /* SPP_DMA2_TCDn Word6 - dlast_sga */
14981  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_22; /* offset: 0x12D8 size: 32 bit */
14982  /* SPP_DMA2_TCDn Word7 - biter, etc. */
14983  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_22; /* offset: 0x12DC size: 32 bit */
14984  /* SPP_DMA2_TCDn Word0 - Source Address */
14985  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_23; /* offset: 0x12E0 size: 32 bit */
14986  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
14987  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_23; /* offset: 0x12E4 size: 32 bit */
14988  /* SPP_DMA2_TCDn Word2 - nbytes */
14989  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_23; /* offset: 0x12E8 size: 32 bit */
14990  /* SPP_DMA2_TCDn Word3 - slast */
14991  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_23; /* offset: 0x12EC size: 32 bit */
14992  /* SPP_DMA2_TCDn Word4 - daddr */
14993  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_23; /* offset: 0x12F0 size: 32 bit */
14994  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
14995  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_23; /* offset: 0x12F4 size: 32 bit */
14996  /* SPP_DMA2_TCDn Word6 - dlast_sga */
14997  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_23; /* offset: 0x12F8 size: 32 bit */
14998  /* SPP_DMA2_TCDn Word7 - biter, etc. */
14999  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_23; /* offset: 0x12FC size: 32 bit */
15000  /* SPP_DMA2_TCDn Word0 - Source Address */
15001  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_24; /* offset: 0x1300 size: 32 bit */
15002  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15003  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_24; /* offset: 0x1304 size: 32 bit */
15004  /* SPP_DMA2_TCDn Word2 - nbytes */
15005  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_24; /* offset: 0x1308 size: 32 bit */
15006  /* SPP_DMA2_TCDn Word3 - slast */
15007  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_24; /* offset: 0x130C size: 32 bit */
15008  /* SPP_DMA2_TCDn Word4 - daddr */
15009  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_24; /* offset: 0x1310 size: 32 bit */
15010  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15011  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_24; /* offset: 0x1314 size: 32 bit */
15012  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15013  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_24; /* offset: 0x1318 size: 32 bit */
15014  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15015  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_24; /* offset: 0x131C size: 32 bit */
15016  /* SPP_DMA2_TCDn Word0 - Source Address */
15017  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_25; /* offset: 0x1320 size: 32 bit */
15018  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15019  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_25; /* offset: 0x1324 size: 32 bit */
15020  /* SPP_DMA2_TCDn Word2 - nbytes */
15021  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_25; /* offset: 0x1328 size: 32 bit */
15022  /* SPP_DMA2_TCDn Word3 - slast */
15023  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_25; /* offset: 0x132C size: 32 bit */
15024  /* SPP_DMA2_TCDn Word4 - daddr */
15025  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_25; /* offset: 0x1330 size: 32 bit */
15026  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15027  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_25; /* offset: 0x1334 size: 32 bit */
15028  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15029  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_25; /* offset: 0x1338 size: 32 bit */
15030  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15031  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_25; /* offset: 0x133C size: 32 bit */
15032  /* SPP_DMA2_TCDn Word0 - Source Address */
15033  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_26; /* offset: 0x1340 size: 32 bit */
15034  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15035  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_26; /* offset: 0x1344 size: 32 bit */
15036  /* SPP_DMA2_TCDn Word2 - nbytes */
15037  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_26; /* offset: 0x1348 size: 32 bit */
15038  /* SPP_DMA2_TCDn Word3 - slast */
15039  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_26; /* offset: 0x134C size: 32 bit */
15040  /* SPP_DMA2_TCDn Word4 - daddr */
15041  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_26; /* offset: 0x1350 size: 32 bit */
15042  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15043  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_26; /* offset: 0x1354 size: 32 bit */
15044  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15045  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_26; /* offset: 0x1358 size: 32 bit */
15046  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15047  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_26; /* offset: 0x135C size: 32 bit */
15048  /* SPP_DMA2_TCDn Word0 - Source Address */
15049  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_27; /* offset: 0x1360 size: 32 bit */
15050  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15051  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_27; /* offset: 0x1364 size: 32 bit */
15052  /* SPP_DMA2_TCDn Word2 - nbytes */
15053  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_27; /* offset: 0x1368 size: 32 bit */
15054  /* SPP_DMA2_TCDn Word3 - slast */
15055  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_27; /* offset: 0x136C size: 32 bit */
15056  /* SPP_DMA2_TCDn Word4 - daddr */
15057  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_27; /* offset: 0x1370 size: 32 bit */
15058  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15059  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_27; /* offset: 0x1374 size: 32 bit */
15060  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15061  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_27; /* offset: 0x1378 size: 32 bit */
15062  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15063  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_27; /* offset: 0x137C size: 32 bit */
15064  /* SPP_DMA2_TCDn Word0 - Source Address */
15065  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_28; /* offset: 0x1380 size: 32 bit */
15066  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15067  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_28; /* offset: 0x1384 size: 32 bit */
15068  /* SPP_DMA2_TCDn Word2 - nbytes */
15069  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_28; /* offset: 0x1388 size: 32 bit */
15070  /* SPP_DMA2_TCDn Word3 - slast */
15071  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_28; /* offset: 0x138C size: 32 bit */
15072  /* SPP_DMA2_TCDn Word4 - daddr */
15073  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_28; /* offset: 0x1390 size: 32 bit */
15074  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15075  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_28; /* offset: 0x1394 size: 32 bit */
15076  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15077  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_28; /* offset: 0x1398 size: 32 bit */
15078  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15079  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_28; /* offset: 0x139C size: 32 bit */
15080  /* SPP_DMA2_TCDn Word0 - Source Address */
15081  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_29; /* offset: 0x13A0 size: 32 bit */
15082  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15083  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_29; /* offset: 0x13A4 size: 32 bit */
15084  /* SPP_DMA2_TCDn Word2 - nbytes */
15085  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_29; /* offset: 0x13A8 size: 32 bit */
15086  /* SPP_DMA2_TCDn Word3 - slast */
15087  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_29; /* offset: 0x13AC size: 32 bit */
15088  /* SPP_DMA2_TCDn Word4 - daddr */
15089  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_29; /* offset: 0x13B0 size: 32 bit */
15090  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15091  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_29; /* offset: 0x13B4 size: 32 bit */
15092  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15093  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_29; /* offset: 0x13B8 size: 32 bit */
15094  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15095  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_29; /* offset: 0x13BC size: 32 bit */
15096  /* SPP_DMA2_TCDn Word0 - Source Address */
15097  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_30; /* offset: 0x13C0 size: 32 bit */
15098  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15099  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_30; /* offset: 0x13C4 size: 32 bit */
15100  /* SPP_DMA2_TCDn Word2 - nbytes */
15101  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_30; /* offset: 0x13C8 size: 32 bit */
15102  /* SPP_DMA2_TCDn Word3 - slast */
15103  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_30; /* offset: 0x13CC size: 32 bit */
15104  /* SPP_DMA2_TCDn Word4 - daddr */
15105  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_30; /* offset: 0x13D0 size: 32 bit */
15106  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15107  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_30; /* offset: 0x13D4 size: 32 bit */
15108  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15109  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_30; /* offset: 0x13D8 size: 32 bit */
15110  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15111  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_30; /* offset: 0x13DC size: 32 bit */
15112  /* SPP_DMA2_TCDn Word0 - Source Address */
15113  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_31; /* offset: 0x13E0 size: 32 bit */
15114  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15115  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_31; /* offset: 0x13E4 size: 32 bit */
15116  /* SPP_DMA2_TCDn Word2 - nbytes */
15117  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_31; /* offset: 0x13E8 size: 32 bit */
15118  /* SPP_DMA2_TCDn Word3 - slast */
15119  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_31; /* offset: 0x13EC size: 32 bit */
15120  /* SPP_DMA2_TCDn Word4 - daddr */
15121  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_31; /* offset: 0x13F0 size: 32 bit */
15122  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15123  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_31; /* offset: 0x13F4 size: 32 bit */
15124  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15125  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_31; /* offset: 0x13F8 size: 32 bit */
15126  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15127  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_31; /* offset: 0x13FC size: 32 bit */
15128  /* SPP_DMA2_TCDn Word0 - Source Address */
15129  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_32; /* offset: 0x1400 size: 32 bit */
15130  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15131  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_32; /* offset: 0x1404 size: 32 bit */
15132  /* SPP_DMA2_TCDn Word2 - nbytes */
15133  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_32; /* offset: 0x1408 size: 32 bit */
15134  /* SPP_DMA2_TCDn Word3 - slast */
15135  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_32; /* offset: 0x140C size: 32 bit */
15136  /* SPP_DMA2_TCDn Word4 - daddr */
15137  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_32; /* offset: 0x1410 size: 32 bit */
15138  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15139  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_32; /* offset: 0x1414 size: 32 bit */
15140  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15141  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_32; /* offset: 0x1418 size: 32 bit */
15142  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15143  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_32; /* offset: 0x141C size: 32 bit */
15144  /* SPP_DMA2_TCDn Word0 - Source Address */
15145  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_33; /* offset: 0x1420 size: 32 bit */
15146  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15147  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_33; /* offset: 0x1424 size: 32 bit */
15148  /* SPP_DMA2_TCDn Word2 - nbytes */
15149  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_33; /* offset: 0x1428 size: 32 bit */
15150  /* SPP_DMA2_TCDn Word3 - slast */
15151  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_33; /* offset: 0x142C size: 32 bit */
15152  /* SPP_DMA2_TCDn Word4 - daddr */
15153  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_33; /* offset: 0x1430 size: 32 bit */
15154  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15155  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_33; /* offset: 0x1434 size: 32 bit */
15156  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15157  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_33; /* offset: 0x1438 size: 32 bit */
15158  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15159  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_33; /* offset: 0x143C size: 32 bit */
15160  /* SPP_DMA2_TCDn Word0 - Source Address */
15161  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_34; /* offset: 0x1440 size: 32 bit */
15162  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15163  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_34; /* offset: 0x1444 size: 32 bit */
15164  /* SPP_DMA2_TCDn Word2 - nbytes */
15165  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_34; /* offset: 0x1448 size: 32 bit */
15166  /* SPP_DMA2_TCDn Word3 - slast */
15167  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_34; /* offset: 0x144C size: 32 bit */
15168  /* SPP_DMA2_TCDn Word4 - daddr */
15169  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_34; /* offset: 0x1450 size: 32 bit */
15170  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15171  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_34; /* offset: 0x1454 size: 32 bit */
15172  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15173  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_34; /* offset: 0x1458 size: 32 bit */
15174  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15175  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_34; /* offset: 0x145C size: 32 bit */
15176  /* SPP_DMA2_TCDn Word0 - Source Address */
15177  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_35; /* offset: 0x1460 size: 32 bit */
15178  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15179  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_35; /* offset: 0x1464 size: 32 bit */
15180  /* SPP_DMA2_TCDn Word2 - nbytes */
15181  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_35; /* offset: 0x1468 size: 32 bit */
15182  /* SPP_DMA2_TCDn Word3 - slast */
15183  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_35; /* offset: 0x146C size: 32 bit */
15184  /* SPP_DMA2_TCDn Word4 - daddr */
15185  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_35; /* offset: 0x1470 size: 32 bit */
15186  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15187  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_35; /* offset: 0x1474 size: 32 bit */
15188  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15189  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_35; /* offset: 0x1478 size: 32 bit */
15190  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15191  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_35; /* offset: 0x147C size: 32 bit */
15192  /* SPP_DMA2_TCDn Word0 - Source Address */
15193  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_36; /* offset: 0x1480 size: 32 bit */
15194  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15195  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_36; /* offset: 0x1484 size: 32 bit */
15196  /* SPP_DMA2_TCDn Word2 - nbytes */
15197  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_36; /* offset: 0x1488 size: 32 bit */
15198  /* SPP_DMA2_TCDn Word3 - slast */
15199  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_36; /* offset: 0x148C size: 32 bit */
15200  /* SPP_DMA2_TCDn Word4 - daddr */
15201  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_36; /* offset: 0x1490 size: 32 bit */
15202  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15203  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_36; /* offset: 0x1494 size: 32 bit */
15204  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15205  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_36; /* offset: 0x1498 size: 32 bit */
15206  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15207  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_36; /* offset: 0x149C size: 32 bit */
15208  /* SPP_DMA2_TCDn Word0 - Source Address */
15209  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_37; /* offset: 0x14A0 size: 32 bit */
15210  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15211  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_37; /* offset: 0x14A4 size: 32 bit */
15212  /* SPP_DMA2_TCDn Word2 - nbytes */
15213  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_37; /* offset: 0x14A8 size: 32 bit */
15214  /* SPP_DMA2_TCDn Word3 - slast */
15215  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_37; /* offset: 0x14AC size: 32 bit */
15216  /* SPP_DMA2_TCDn Word4 - daddr */
15217  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_37; /* offset: 0x14B0 size: 32 bit */
15218  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15219  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_37; /* offset: 0x14B4 size: 32 bit */
15220  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15221  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_37; /* offset: 0x14B8 size: 32 bit */
15222  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15223  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_37; /* offset: 0x14BC size: 32 bit */
15224  /* SPP_DMA2_TCDn Word0 - Source Address */
15225  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_38; /* offset: 0x14C0 size: 32 bit */
15226  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15227  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_38; /* offset: 0x14C4 size: 32 bit */
15228  /* SPP_DMA2_TCDn Word2 - nbytes */
15229  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_38; /* offset: 0x14C8 size: 32 bit */
15230  /* SPP_DMA2_TCDn Word3 - slast */
15231  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_38; /* offset: 0x14CC size: 32 bit */
15232  /* SPP_DMA2_TCDn Word4 - daddr */
15233  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_38; /* offset: 0x14D0 size: 32 bit */
15234  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15235  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_38; /* offset: 0x14D4 size: 32 bit */
15236  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15237  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_38; /* offset: 0x14D8 size: 32 bit */
15238  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15239  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_38; /* offset: 0x14DC size: 32 bit */
15240  /* SPP_DMA2_TCDn Word0 - Source Address */
15241  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_39; /* offset: 0x14E0 size: 32 bit */
15242  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15243  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_39; /* offset: 0x14E4 size: 32 bit */
15244  /* SPP_DMA2_TCDn Word2 - nbytes */
15245  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_39; /* offset: 0x14E8 size: 32 bit */
15246  /* SPP_DMA2_TCDn Word3 - slast */
15247  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_39; /* offset: 0x14EC size: 32 bit */
15248  /* SPP_DMA2_TCDn Word4 - daddr */
15249  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_39; /* offset: 0x14F0 size: 32 bit */
15250  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15251  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_39; /* offset: 0x14F4 size: 32 bit */
15252  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15253  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_39; /* offset: 0x14F8 size: 32 bit */
15254  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15255  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_39; /* offset: 0x14FC size: 32 bit */
15256  /* SPP_DMA2_TCDn Word0 - Source Address */
15257  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_40; /* offset: 0x1500 size: 32 bit */
15258  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15259  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_40; /* offset: 0x1504 size: 32 bit */
15260  /* SPP_DMA2_TCDn Word2 - nbytes */
15261  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_40; /* offset: 0x1508 size: 32 bit */
15262  /* SPP_DMA2_TCDn Word3 - slast */
15263  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_40; /* offset: 0x150C size: 32 bit */
15264  /* SPP_DMA2_TCDn Word4 - daddr */
15265  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_40; /* offset: 0x1510 size: 32 bit */
15266  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15267  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_40; /* offset: 0x1514 size: 32 bit */
15268  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15269  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_40; /* offset: 0x1518 size: 32 bit */
15270  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15271  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_40; /* offset: 0x151C size: 32 bit */
15272  /* SPP_DMA2_TCDn Word0 - Source Address */
15273  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_41; /* offset: 0x1520 size: 32 bit */
15274  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15275  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_41; /* offset: 0x1524 size: 32 bit */
15276  /* SPP_DMA2_TCDn Word2 - nbytes */
15277  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_41; /* offset: 0x1528 size: 32 bit */
15278  /* SPP_DMA2_TCDn Word3 - slast */
15279  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_41; /* offset: 0x152C size: 32 bit */
15280  /* SPP_DMA2_TCDn Word4 - daddr */
15281  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_41; /* offset: 0x1530 size: 32 bit */
15282  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15283  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_41; /* offset: 0x1534 size: 32 bit */
15284  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15285  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_41; /* offset: 0x1538 size: 32 bit */
15286  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15287  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_41; /* offset: 0x153C size: 32 bit */
15288  /* SPP_DMA2_TCDn Word0 - Source Address */
15289  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_42; /* offset: 0x1540 size: 32 bit */
15290  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15291  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_42; /* offset: 0x1544 size: 32 bit */
15292  /* SPP_DMA2_TCDn Word2 - nbytes */
15293  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_42; /* offset: 0x1548 size: 32 bit */
15294  /* SPP_DMA2_TCDn Word3 - slast */
15295  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_42; /* offset: 0x154C size: 32 bit */
15296  /* SPP_DMA2_TCDn Word4 - daddr */
15297  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_42; /* offset: 0x1550 size: 32 bit */
15298  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15299  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_42; /* offset: 0x1554 size: 32 bit */
15300  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15301  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_42; /* offset: 0x1558 size: 32 bit */
15302  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15303  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_42; /* offset: 0x155C size: 32 bit */
15304  /* SPP_DMA2_TCDn Word0 - Source Address */
15305  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_43; /* offset: 0x1560 size: 32 bit */
15306  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15307  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_43; /* offset: 0x1564 size: 32 bit */
15308  /* SPP_DMA2_TCDn Word2 - nbytes */
15309  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_43; /* offset: 0x1568 size: 32 bit */
15310  /* SPP_DMA2_TCDn Word3 - slast */
15311  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_43; /* offset: 0x156C size: 32 bit */
15312  /* SPP_DMA2_TCDn Word4 - daddr */
15313  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_43; /* offset: 0x1570 size: 32 bit */
15314  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15315  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_43; /* offset: 0x1574 size: 32 bit */
15316  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15317  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_43; /* offset: 0x1578 size: 32 bit */
15318  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15319  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_43; /* offset: 0x157C size: 32 bit */
15320  /* SPP_DMA2_TCDn Word0 - Source Address */
15321  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_44; /* offset: 0x1580 size: 32 bit */
15322  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15323  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_44; /* offset: 0x1584 size: 32 bit */
15324  /* SPP_DMA2_TCDn Word2 - nbytes */
15325  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_44; /* offset: 0x1588 size: 32 bit */
15326  /* SPP_DMA2_TCDn Word3 - slast */
15327  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_44; /* offset: 0x158C size: 32 bit */
15328  /* SPP_DMA2_TCDn Word4 - daddr */
15329  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_44; /* offset: 0x1590 size: 32 bit */
15330  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15331  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_44; /* offset: 0x1594 size: 32 bit */
15332  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15333  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_44; /* offset: 0x1598 size: 32 bit */
15334  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15335  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_44; /* offset: 0x159C size: 32 bit */
15336  /* SPP_DMA2_TCDn Word0 - Source Address */
15337  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_45; /* offset: 0x15A0 size: 32 bit */
15338  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15339  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_45; /* offset: 0x15A4 size: 32 bit */
15340  /* SPP_DMA2_TCDn Word2 - nbytes */
15341  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_45; /* offset: 0x15A8 size: 32 bit */
15342  /* SPP_DMA2_TCDn Word3 - slast */
15343  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_45; /* offset: 0x15AC size: 32 bit */
15344  /* SPP_DMA2_TCDn Word4 - daddr */
15345  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_45; /* offset: 0x15B0 size: 32 bit */
15346  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15347  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_45; /* offset: 0x15B4 size: 32 bit */
15348  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15349  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_45; /* offset: 0x15B8 size: 32 bit */
15350  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15351  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_45; /* offset: 0x15BC size: 32 bit */
15352  /* SPP_DMA2_TCDn Word0 - Source Address */
15353  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_46; /* offset: 0x15C0 size: 32 bit */
15354  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15355  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_46; /* offset: 0x15C4 size: 32 bit */
15356  /* SPP_DMA2_TCDn Word2 - nbytes */
15357  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_46; /* offset: 0x15C8 size: 32 bit */
15358  /* SPP_DMA2_TCDn Word3 - slast */
15359  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_46; /* offset: 0x15CC size: 32 bit */
15360  /* SPP_DMA2_TCDn Word4 - daddr */
15361  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_46; /* offset: 0x15D0 size: 32 bit */
15362  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15363  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_46; /* offset: 0x15D4 size: 32 bit */
15364  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15365  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_46; /* offset: 0x15D8 size: 32 bit */
15366  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15367  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_46; /* offset: 0x15DC size: 32 bit */
15368  /* SPP_DMA2_TCDn Word0 - Source Address */
15369  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_47; /* offset: 0x15E0 size: 32 bit */
15370  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15371  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_47; /* offset: 0x15E4 size: 32 bit */
15372  /* SPP_DMA2_TCDn Word2 - nbytes */
15373  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_47; /* offset: 0x15E8 size: 32 bit */
15374  /* SPP_DMA2_TCDn Word3 - slast */
15375  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_47; /* offset: 0x15EC size: 32 bit */
15376  /* SPP_DMA2_TCDn Word4 - daddr */
15377  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_47; /* offset: 0x15F0 size: 32 bit */
15378  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15379  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_47; /* offset: 0x15F4 size: 32 bit */
15380  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15381  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_47; /* offset: 0x15F8 size: 32 bit */
15382  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15383  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_47; /* offset: 0x15FC size: 32 bit */
15384  /* SPP_DMA2_TCDn Word0 - Source Address */
15385  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_48; /* offset: 0x1600 size: 32 bit */
15386  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15387  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_48; /* offset: 0x1604 size: 32 bit */
15388  /* SPP_DMA2_TCDn Word2 - nbytes */
15389  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_48; /* offset: 0x1608 size: 32 bit */
15390  /* SPP_DMA2_TCDn Word3 - slast */
15391  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_48; /* offset: 0x160C size: 32 bit */
15392  /* SPP_DMA2_TCDn Word4 - daddr */
15393  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_48; /* offset: 0x1610 size: 32 bit */
15394  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15395  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_48; /* offset: 0x1614 size: 32 bit */
15396  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15397  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_48; /* offset: 0x1618 size: 32 bit */
15398  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15399  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_48; /* offset: 0x161C size: 32 bit */
15400  /* SPP_DMA2_TCDn Word0 - Source Address */
15401  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_49; /* offset: 0x1620 size: 32 bit */
15402  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15403  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_49; /* offset: 0x1624 size: 32 bit */
15404  /* SPP_DMA2_TCDn Word2 - nbytes */
15405  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_49; /* offset: 0x1628 size: 32 bit */
15406  /* SPP_DMA2_TCDn Word3 - slast */
15407  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_49; /* offset: 0x162C size: 32 bit */
15408  /* SPP_DMA2_TCDn Word4 - daddr */
15409  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_49; /* offset: 0x1630 size: 32 bit */
15410  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15411  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_49; /* offset: 0x1634 size: 32 bit */
15412  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15413  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_49; /* offset: 0x1638 size: 32 bit */
15414  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15415  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_49; /* offset: 0x163C size: 32 bit */
15416  /* SPP_DMA2_TCDn Word0 - Source Address */
15417  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_50; /* offset: 0x1640 size: 32 bit */
15418  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15419  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_50; /* offset: 0x1644 size: 32 bit */
15420  /* SPP_DMA2_TCDn Word2 - nbytes */
15421  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_50; /* offset: 0x1648 size: 32 bit */
15422  /* SPP_DMA2_TCDn Word3 - slast */
15423  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_50; /* offset: 0x164C size: 32 bit */
15424  /* SPP_DMA2_TCDn Word4 - daddr */
15425  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_50; /* offset: 0x1650 size: 32 bit */
15426  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15427  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_50; /* offset: 0x1654 size: 32 bit */
15428  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15429  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_50; /* offset: 0x1658 size: 32 bit */
15430  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15431  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_50; /* offset: 0x165C size: 32 bit */
15432  /* SPP_DMA2_TCDn Word0 - Source Address */
15433  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_51; /* offset: 0x1660 size: 32 bit */
15434  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15435  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_51; /* offset: 0x1664 size: 32 bit */
15436  /* SPP_DMA2_TCDn Word2 - nbytes */
15437  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_51; /* offset: 0x1668 size: 32 bit */
15438  /* SPP_DMA2_TCDn Word3 - slast */
15439  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_51; /* offset: 0x166C size: 32 bit */
15440  /* SPP_DMA2_TCDn Word4 - daddr */
15441  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_51; /* offset: 0x1670 size: 32 bit */
15442  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15443  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_51; /* offset: 0x1674 size: 32 bit */
15444  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15445  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_51; /* offset: 0x1678 size: 32 bit */
15446  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15447  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_51; /* offset: 0x167C size: 32 bit */
15448  /* SPP_DMA2_TCDn Word0 - Source Address */
15449  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_52; /* offset: 0x1680 size: 32 bit */
15450  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15451  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_52; /* offset: 0x1684 size: 32 bit */
15452  /* SPP_DMA2_TCDn Word2 - nbytes */
15453  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_52; /* offset: 0x1688 size: 32 bit */
15454  /* SPP_DMA2_TCDn Word3 - slast */
15455  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_52; /* offset: 0x168C size: 32 bit */
15456  /* SPP_DMA2_TCDn Word4 - daddr */
15457  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_52; /* offset: 0x1690 size: 32 bit */
15458  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15459  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_52; /* offset: 0x1694 size: 32 bit */
15460  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15461  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_52; /* offset: 0x1698 size: 32 bit */
15462  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15463  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_52; /* offset: 0x169C size: 32 bit */
15464  /* SPP_DMA2_TCDn Word0 - Source Address */
15465  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_53; /* offset: 0x16A0 size: 32 bit */
15466  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15467  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_53; /* offset: 0x16A4 size: 32 bit */
15468  /* SPP_DMA2_TCDn Word2 - nbytes */
15469  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_53; /* offset: 0x16A8 size: 32 bit */
15470  /* SPP_DMA2_TCDn Word3 - slast */
15471  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_53; /* offset: 0x16AC size: 32 bit */
15472  /* SPP_DMA2_TCDn Word4 - daddr */
15473  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_53; /* offset: 0x16B0 size: 32 bit */
15474  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15475  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_53; /* offset: 0x16B4 size: 32 bit */
15476  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15477  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_53; /* offset: 0x16B8 size: 32 bit */
15478  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15479  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_53; /* offset: 0x16BC size: 32 bit */
15480  /* SPP_DMA2_TCDn Word0 - Source Address */
15481  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_54; /* offset: 0x16C0 size: 32 bit */
15482  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15483  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_54; /* offset: 0x16C4 size: 32 bit */
15484  /* SPP_DMA2_TCDn Word2 - nbytes */
15485  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_54; /* offset: 0x16C8 size: 32 bit */
15486  /* SPP_DMA2_TCDn Word3 - slast */
15487  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_54; /* offset: 0x16CC size: 32 bit */
15488  /* SPP_DMA2_TCDn Word4 - daddr */
15489  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_54; /* offset: 0x16D0 size: 32 bit */
15490  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15491  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_54; /* offset: 0x16D4 size: 32 bit */
15492  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15493  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_54; /* offset: 0x16D8 size: 32 bit */
15494  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15495  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_54; /* offset: 0x16DC size: 32 bit */
15496  /* SPP_DMA2_TCDn Word0 - Source Address */
15497  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_55; /* offset: 0x16E0 size: 32 bit */
15498  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15499  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_55; /* offset: 0x16E4 size: 32 bit */
15500  /* SPP_DMA2_TCDn Word2 - nbytes */
15501  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_55; /* offset: 0x16E8 size: 32 bit */
15502  /* SPP_DMA2_TCDn Word3 - slast */
15503  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_55; /* offset: 0x16EC size: 32 bit */
15504  /* SPP_DMA2_TCDn Word4 - daddr */
15505  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_55; /* offset: 0x16F0 size: 32 bit */
15506  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15507  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_55; /* offset: 0x16F4 size: 32 bit */
15508  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15509  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_55; /* offset: 0x16F8 size: 32 bit */
15510  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15511  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_55; /* offset: 0x16FC size: 32 bit */
15512  /* SPP_DMA2_TCDn Word0 - Source Address */
15513  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_56; /* offset: 0x1700 size: 32 bit */
15514  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15515  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_56; /* offset: 0x1704 size: 32 bit */
15516  /* SPP_DMA2_TCDn Word2 - nbytes */
15517  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_56; /* offset: 0x1708 size: 32 bit */
15518  /* SPP_DMA2_TCDn Word3 - slast */
15519  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_56; /* offset: 0x170C size: 32 bit */
15520  /* SPP_DMA2_TCDn Word4 - daddr */
15521  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_56; /* offset: 0x1710 size: 32 bit */
15522  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15523  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_56; /* offset: 0x1714 size: 32 bit */
15524  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15525  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_56; /* offset: 0x1718 size: 32 bit */
15526  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15527  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_56; /* offset: 0x171C size: 32 bit */
15528  /* SPP_DMA2_TCDn Word0 - Source Address */
15529  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_57; /* offset: 0x1720 size: 32 bit */
15530  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15531  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_57; /* offset: 0x1724 size: 32 bit */
15532  /* SPP_DMA2_TCDn Word2 - nbytes */
15533  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_57; /* offset: 0x1728 size: 32 bit */
15534  /* SPP_DMA2_TCDn Word3 - slast */
15535  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_57; /* offset: 0x172C size: 32 bit */
15536  /* SPP_DMA2_TCDn Word4 - daddr */
15537  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_57; /* offset: 0x1730 size: 32 bit */
15538  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15539  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_57; /* offset: 0x1734 size: 32 bit */
15540  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15541  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_57; /* offset: 0x1738 size: 32 bit */
15542  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15543  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_57; /* offset: 0x173C size: 32 bit */
15544  /* SPP_DMA2_TCDn Word0 - Source Address */
15545  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_58; /* offset: 0x1740 size: 32 bit */
15546  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15547  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_58; /* offset: 0x1744 size: 32 bit */
15548  /* SPP_DMA2_TCDn Word2 - nbytes */
15549  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_58; /* offset: 0x1748 size: 32 bit */
15550  /* SPP_DMA2_TCDn Word3 - slast */
15551  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_58; /* offset: 0x174C size: 32 bit */
15552  /* SPP_DMA2_TCDn Word4 - daddr */
15553  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_58; /* offset: 0x1750 size: 32 bit */
15554  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15555  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_58; /* offset: 0x1754 size: 32 bit */
15556  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15557  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_58; /* offset: 0x1758 size: 32 bit */
15558  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15559  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_58; /* offset: 0x175C size: 32 bit */
15560  /* SPP_DMA2_TCDn Word0 - Source Address */
15561  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_59; /* offset: 0x1760 size: 32 bit */
15562  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15563  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_59; /* offset: 0x1764 size: 32 bit */
15564  /* SPP_DMA2_TCDn Word2 - nbytes */
15565  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_59; /* offset: 0x1768 size: 32 bit */
15566  /* SPP_DMA2_TCDn Word3 - slast */
15567  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_59; /* offset: 0x176C size: 32 bit */
15568  /* SPP_DMA2_TCDn Word4 - daddr */
15569  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_59; /* offset: 0x1770 size: 32 bit */
15570  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15571  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_59; /* offset: 0x1774 size: 32 bit */
15572  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15573  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_59; /* offset: 0x1778 size: 32 bit */
15574  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15575  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_59; /* offset: 0x177C size: 32 bit */
15576  /* SPP_DMA2_TCDn Word0 - Source Address */
15577  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_60; /* offset: 0x1780 size: 32 bit */
15578  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15579  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_60; /* offset: 0x1784 size: 32 bit */
15580  /* SPP_DMA2_TCDn Word2 - nbytes */
15581  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_60; /* offset: 0x1788 size: 32 bit */
15582  /* SPP_DMA2_TCDn Word3 - slast */
15583  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_60; /* offset: 0x178C size: 32 bit */
15584  /* SPP_DMA2_TCDn Word4 - daddr */
15585  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_60; /* offset: 0x1790 size: 32 bit */
15586  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15587  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_60; /* offset: 0x1794 size: 32 bit */
15588  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15589  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_60; /* offset: 0x1798 size: 32 bit */
15590  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15591  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_60; /* offset: 0x179C size: 32 bit */
15592  /* SPP_DMA2_TCDn Word0 - Source Address */
15593  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_61; /* offset: 0x17A0 size: 32 bit */
15594  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15595  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_61; /* offset: 0x17A4 size: 32 bit */
15596  /* SPP_DMA2_TCDn Word2 - nbytes */
15597  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_61; /* offset: 0x17A8 size: 32 bit */
15598  /* SPP_DMA2_TCDn Word3 - slast */
15599  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_61; /* offset: 0x17AC size: 32 bit */
15600  /* SPP_DMA2_TCDn Word4 - daddr */
15601  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_61; /* offset: 0x17B0 size: 32 bit */
15602  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15603  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_61; /* offset: 0x17B4 size: 32 bit */
15604  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15605  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_61; /* offset: 0x17B8 size: 32 bit */
15606  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15607  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_61; /* offset: 0x17BC size: 32 bit */
15608  /* SPP_DMA2_TCDn Word0 - Source Address */
15609  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_62; /* offset: 0x17C0 size: 32 bit */
15610  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15611  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_62; /* offset: 0x17C4 size: 32 bit */
15612  /* SPP_DMA2_TCDn Word2 - nbytes */
15613  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_62; /* offset: 0x17C8 size: 32 bit */
15614  /* SPP_DMA2_TCDn Word3 - slast */
15615  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_62; /* offset: 0x17CC size: 32 bit */
15616  /* SPP_DMA2_TCDn Word4 - daddr */
15617  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_62; /* offset: 0x17D0 size: 32 bit */
15618  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15619  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_62; /* offset: 0x17D4 size: 32 bit */
15620  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15621  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_62; /* offset: 0x17D8 size: 32 bit */
15622  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15623  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_62; /* offset: 0x17DC size: 32 bit */
15624  /* SPP_DMA2_TCDn Word0 - Source Address */
15625  SPP_DMA2_TCDWORD0__32B_tag TCDWORD0_63; /* offset: 0x17E0 size: 32 bit */
15626  /* SPP_DMA2_TCDn Word1 - smod, ssize, dmod, dsize, soff */
15627  SPP_DMA2_TCDWORD4__32B_tag TCDWORD4_63; /* offset: 0x17E4 size: 32 bit */
15628  /* SPP_DMA2_TCDn Word2 - nbytes */
15629  SPP_DMA2_TCDWORD8__32B_tag TCDWORD8_63; /* offset: 0x17E8 size: 32 bit */
15630  /* SPP_DMA2_TCDn Word3 - slast */
15631  SPP_DMA2_TCDWORD12__32B_tag TCDWORD12_63; /* offset: 0x17EC size: 32 bit */
15632  /* SPP_DMA2_TCDn Word4 - daddr */
15633  SPP_DMA2_TCDWORD16__32B_tag TCDWORD16_63; /* offset: 0x17F0 size: 32 bit */
15634  /* SPP_DMA2_TCDn Word5 - citer.e_link, citer, doff */
15635  SPP_DMA2_TCDWORD20__32B_tag TCDWORD20_63; /* offset: 0x17F4 size: 32 bit */
15636  /* SPP_DMA2_TCDn Word6 - dlast_sga */
15637  SPP_DMA2_TCDWORD24__32B_tag TCDWORD24_63; /* offset: 0x17F8 size: 32 bit */
15638  /* SPP_DMA2_TCDn Word7 - biter, etc. */
15639  SPP_DMA2_TCDWORD28__32B_tag TCDWORD28_63; /* offset: 0x17FC size: 32 bit */
15640  };
15641
15642  };
15643  } SPP_DMA2_tag;
15644
15645
15646 #define SPP_DMA2 (*(volatile SPP_DMA2_tag *) 0xFFF44000UL)
15647
15648
15649
15650 /****************************************************************/
15651 /* */
15652 /* Module: INTC */
15653 /* */
15654 /****************************************************************/
15655
15656  typedef union { /* BCR - Block Configuration Register */
15657  uint32_t R;
15658  struct {
15659  uint32_t:18;
15660  uint32_t VTES_PRC1:1; /* Vector Table Entry Size - Processor 1 */
15661  uint32_t:4;
15662  uint32_t HVEN_PRC1:1; /* Hardware Vector Enable - Processor 1 */
15663  uint32_t:2;
15664 #ifndef USE_FIELD_ALIASES_INTC
15665  uint32_t VTES_PRC0:1; /* Vector Table Entry Size - Processor 0 */
15666 #else
15667  uint32_t VTES:1; /* deprecated name - please avoid */
15668 #endif
15669  uint32_t:4;
15670 #ifndef USE_FIELD_ALIASES_INTC
15671  uint32_t HVEN_PRC0:1; /* Hardware Vector Enable - Processor 0 */
15672 #else
15673  uint32_t HVEN:1; /* deprecated name - please avoid */
15674 #endif
15675  } B;
15676  } INTC_BCR_32B_tag;
15677
15678  typedef union { /* CPR - Current Priority Register - Processor 0 */
15679  uint32_t R;
15680  struct {
15681  uint32_t:28;
15682  uint32_t PRI:4; /* Priority Bits */
15683  } B;
15685
15686  typedef union { /* CPR - Current Priority Register - Processor 1 */
15687  uint32_t R;
15688  struct {
15689  uint32_t:28;
15690  uint32_t PRI:4; /* Priority Bits */
15691  } B;
15693
15694  typedef union { /* IACKR- Interrupt Acknowledge Register - Processor 0 */
15695  uint32_t R;
15696  struct {
15697 #ifndef USE_FIELD_ALIASES_INTC
15698  uint32_t VTBA_PRC0:21; /* Vector Table Base Address - Processor 0 */
15699 #else
15700  uint32_t VTBA:21; /* deprecated name - please avoid */
15701 #endif
15702 #ifndef USE_FIELD_ALIASES_INTC
15703  uint32_t INTEC_PRC0:9; /* Interrupt Vector - Processor 0 */
15704 #else
15705  uint32_t INTVEC:9; /* deprecated name - please avoid */
15706 #endif
15707  uint32_t:2;
15708  } B;
15710
15711  typedef union { /* IACKR- Interrupt Acknowledge Register - Processor 1 */
15712  uint32_t R;
15713  struct {
15714  uint32_t VTBA_PRC1:21; /* Vector Table Base Address - Processor 1 */
15715  uint32_t INTEC_PRC1:9; /* Interrupt Vector - Processor 1 */
15716  uint32_t:2;
15717  } B;
15719
15720  typedef union { /* EOIR- End of Interrupt Register - Processor 0 */
15721  uint32_t R;
15723
15724  typedef union { /* EOIR- End of Interrupt Register - Processor 1 */
15725  uint32_t R;
15727
15728
15729  /* Register layout for all registers SSCIR... */
15730
15731  typedef union { /* SSCIR0-7 INTC Software Set/Clear Interrupt Registers */
15732  uint8_t R;
15733  struct {
15734  uint8_t:6;
15735  uint8_t SET:1; /* Set Flag bit */
15736  uint8_t CLR:1; /* Clear Flag bit */
15737  } B;
15739
15740  typedef union { /* SSCIR0_3 - Software Set/Clear Interrupt Registers */
15741  uint32_t R;
15742  struct {
15743  uint32_t:6;
15744  uint32_t SET0:1; /* Set Flag 0 bit */
15745  uint32_t CLR0:1; /* Clear Flag 0 bit */
15746  uint32_t:6;
15747  uint32_t SET1:1; /* Set Flag 1 bit */
15748  uint32_t CLR1:1; /* Clear Flag 1 bit */
15749  uint32_t:6;
15750  uint32_t SET2:1; /* Set Flag 2 bit */
15751  uint32_t CLR2:1; /* Clear Flag 2 bit */
15752  uint32_t:6;
15753  uint32_t SET3:1; /* Set Flag 3 bit */
15754  uint32_t CLR3:1; /* Clear Flag 3 bit */
15755  } B;
15757
15758  typedef union { /* SSCIR4_7 - Software Set/Clear Interrupt Registers */
15759  uint32_t R;
15760  struct {
15761  uint32_t:6;
15762  uint32_t SET4:1; /* Set Flag 4 bit */
15763  uint32_t CLR4:1; /* Clear Flag 4 bit */
15764  uint32_t:6;
15765  uint32_t SET5:1; /* Set Flag 5 bit */
15766  uint32_t CLR5:1; /* Clear Flag 5 bit */
15767  uint32_t:6;
15768  uint32_t SET6:1; /* Set Flag 6 bit */
15769  uint32_t CLR6:1; /* Clear Flag 6 bit */
15770  uint32_t:6;
15771  uint32_t SET7:1; /* Set Flag 7 bit */
15772  uint32_t CLR7:1; /* Clear Flag 7 bit */
15773  } B;
15775
15776
15777  /* Register layout for all registers PSR... */
15778
15779  typedef union { /* PSR0-511 - Priority Select Registers */
15780  uint8_t R;
15781  struct {
15782  uint8_t PRC_SEL:2; /* Processor Select */
15783  uint8_t:2;
15784  uint8_t PRI:4; /* Priority Select */
15785  } B;
15786  } INTC_PSR_8B_tag;
15787
15788
15789  /* Register layout for all registers PSR... */
15790
15791  typedef union { /* PSR0_3 - 508_511 - Priority Select Registers */
15792  uint32_t R;
15793  struct {
15794  uint32_t PRC_SEL0:2; /* Processor Select - Entry 0 */
15795  uint32_t:2;
15796  uint32_t PRI0:4; /* Priority Select - Entry 0 */
15797  uint32_t PRC_SEL1:2; /* Processor Select - Entry 1 */
15798  uint32_t:2;
15799  uint32_t PRI1:4; /* Priority Select - Entry 1 */
15800  uint32_t PRC_SEL2:2; /* Processor Select - Entry 2 */
15801  uint32_t:2;
15802  uint32_t PRI2:4; /* Priority Select - Entry 2 */
15803  uint32_t PRC_SEL3:2; /* Processor Select - Entry 3 */
15804  uint32_t:2;
15805  uint32_t PRI3:4; /* Priority Select - Entry 3 */
15806  } B;
15807  } INTC_PSR_32B_tag;
15808
15809
15810
15811  typedef struct INTC_struct_tag { /* start of INTC_tag */
15812  union {
15813  INTC_BCR_32B_tag MCR; /* deprecated - please avoid */
15814
15815  /* BCR - Block Configuration Register */
15816  INTC_BCR_32B_tag BCR; /* offset: 0x0000 size: 32 bit */
15817
15818  };
15819  int8_t INTC_reserved_0004_C[4];
15820  union {
15821  /* CPR - Current Priority Register - Processor 0 */
15822  INTC_CPR_PRC0_32B_tag CPR_PRC0; /* offset: 0x0008 size: 32 bit */
15823
15824  INTC_CPR_PRC0_32B_tag CPR; /* deprecated - please avoid */
15825
15826  };
15827  /* CPR - Current Priority Register - Processor 1 */
15828  INTC_CPR_PRC1_32B_tag CPR_PRC1; /* offset: 0x000C size: 32 bit */
15829  union {
15830  /* IACKR- Interrupt Acknowledge Register - Processor 0 */
15831  INTC_IACKR_PRC0_32B_tag IACKR_PRC0; /* offset: 0x0010 size: 32 bit */
15832
15833  INTC_IACKR_PRC0_32B_tag IACKR; /* deprecated - please avoid */
15834
15835  };
15836  /* IACKR- Interrupt Acknowledge Register - Processor 1 */
15837  INTC_IACKR_PRC1_32B_tag IACKR_PRC1; /* offset: 0x0014 size: 32 bit */
15838  union {
15839  /* EOIR- End of Interrupt Register - Processor 0 */
15840  INTC_EOIR_PRC0_32B_tag EOIR_PRC0; /* offset: 0x0018 size: 32 bit */
15841
15842  INTC_EOIR_PRC0_32B_tag EOIR; /* deprecated - please avoid */
15843
15844  };
15845  /* EOIR- End of Interrupt Register - Processor 1 */
15846  INTC_EOIR_PRC1_32B_tag EOIR_PRC1; /* offset: 0x001C size: 32 bit */
15847  union {
15848  /* SSCIR0-7 INTC Software Set/Clear Interrupt Registers */
15849  INTC_SSCIR_8B_tag SSCIR[8]; /* offset: 0x0020 (0x0001 x 8) */
15850
15851  struct {
15852  /* SSCIR0-7 INTC Software Set/Clear Interrupt Registers */
15853  INTC_SSCIR_8B_tag SSCIR0; /* offset: 0x0020 size: 8 bit */
15854  INTC_SSCIR_8B_tag SSCIR1; /* offset: 0x0021 size: 8 bit */
15855  INTC_SSCIR_8B_tag SSCIR2; /* offset: 0x0022 size: 8 bit */
15856  INTC_SSCIR_8B_tag SSCIR3; /* offset: 0x0023 size: 8 bit */
15857  INTC_SSCIR_8B_tag SSCIR4; /* offset: 0x0024 size: 8 bit */
15858  INTC_SSCIR_8B_tag SSCIR5; /* offset: 0x0025 size: 8 bit */
15859  INTC_SSCIR_8B_tag SSCIR6; /* offset: 0x0026 size: 8 bit */
15860  INTC_SSCIR_8B_tag SSCIR7; /* offset: 0x0027 size: 8 bit */
15861  };
15862
15863  struct {
15864  /* SSCIR0_3 - Software Set/Clear Interrupt Registers */
15865  INTC_SSCIR0_3_32B_tag SSCIR0_3; /* offset: 0x0020 size: 32 bit */
15866  /* SSCIR4_7 - Software Set/Clear Interrupt Registers */
15867  INTC_SSCIR4_7_32B_tag SSCIR4_7; /* offset: 0x0024 size: 32 bit */
15868  };
15869
15870  };
15871  int8_t INTC_reserved_0028_C[24];
15872  union {
15873  /* PSR0_3 - 508_511 - Priority Select Registers */
15874  INTC_PSR_32B_tag PSR_32B[128]; /* offset: 0x0040 (0x0004 x 128) */
15875
15876  /* PSR0-511 - Priority Select Registers */
15877  INTC_PSR_8B_tag PSR[512]; /* offset: 0x0040 (0x0001 x 512) */
15878
15879  struct {
15880  /* PSR0_3 - 508_511 - Priority Select Registers */
15881  INTC_PSR_32B_tag PSR0_3; /* offset: 0x0040 size: 32 bit */
15882  INTC_PSR_32B_tag PSR4_7; /* offset: 0x0044 size: 32 bit */
15883  INTC_PSR_32B_tag PSR8_11; /* offset: 0x0048 size: 32 bit */
15884  INTC_PSR_32B_tag PSR12_15; /* offset: 0x004C size: 32 bit */
15885  INTC_PSR_32B_tag PSR16_19; /* offset: 0x0050 size: 32 bit */
15886  INTC_PSR_32B_tag PSR20_23; /* offset: 0x0054 size: 32 bit */
15887  INTC_PSR_32B_tag PSR24_27; /* offset: 0x0058 size: 32 bit */
15888  INTC_PSR_32B_tag PSR28_31; /* offset: 0x005C size: 32 bit */
15889  INTC_PSR_32B_tag PSR32_35; /* offset: 0x0060 size: 32 bit */
15890  INTC_PSR_32B_tag PSR36_39; /* offset: 0x0064 size: 32 bit */
15891  INTC_PSR_32B_tag PSR40_43; /* offset: 0x0068 size: 32 bit */
15892  INTC_PSR_32B_tag PSR44_47; /* offset: 0x006C size: 32 bit */
15893  INTC_PSR_32B_tag PSR48_51; /* offset: 0x0070 size: 32 bit */
15894  INTC_PSR_32B_tag PSR52_55; /* offset: 0x0074 size: 32 bit */
15895  INTC_PSR_32B_tag PSR56_59; /* offset: 0x0078 size: 32 bit */
15896  INTC_PSR_32B_tag PSR60_63; /* offset: 0x007C size: 32 bit */
15897  INTC_PSR_32B_tag PSR64_67; /* offset: 0x0080 size: 32 bit */
15898  INTC_PSR_32B_tag PSR68_71; /* offset: 0x0084 size: 32 bit */
15899  INTC_PSR_32B_tag PSR72_75; /* offset: 0x0088 size: 32 bit */
15900  INTC_PSR_32B_tag PSR76_79; /* offset: 0x008C size: 32 bit */
15901  INTC_PSR_32B_tag PSR80_83; /* offset: 0x0090 size: 32 bit */
15902  INTC_PSR_32B_tag PSR84_87; /* offset: 0x0094 size: 32 bit */
15903  INTC_PSR_32B_tag PSR88_91; /* offset: 0x0098 size: 32 bit */
15904  INTC_PSR_32B_tag PSR92_95; /* offset: 0x009C size: 32 bit */
15905  INTC_PSR_32B_tag PSR96_99; /* offset: 0x00A0 size: 32 bit */
15906  INTC_PSR_32B_tag PSR100_103; /* offset: 0x00A4 size: 32 bit */
15907  INTC_PSR_32B_tag PSR104_107; /* offset: 0x00A8 size: 32 bit */
15908  INTC_PSR_32B_tag PSR108_111; /* offset: 0x00AC size: 32 bit */
15909  INTC_PSR_32B_tag PSR112_115; /* offset: 0x00B0 size: 32 bit */
15910  INTC_PSR_32B_tag PSR116_119; /* offset: 0x00B4 size: 32 bit */
15911  INTC_PSR_32B_tag PSR120_123; /* offset: 0x00B8 size: 32 bit */
15912  INTC_PSR_32B_tag PSR124_127; /* offset: 0x00BC size: 32 bit */
15913  INTC_PSR_32B_tag PSR128_131; /* offset: 0x00C0 size: 32 bit */
15914  INTC_PSR_32B_tag PSR132_135; /* offset: 0x00C4 size: 32 bit */
15915  INTC_PSR_32B_tag PSR136_139; /* offset: 0x00C8 size: 32 bit */
15916  INTC_PSR_32B_tag PSR140_143; /* offset: 0x00CC size: 32 bit */
15917  INTC_PSR_32B_tag PSR144_147; /* offset: 0x00D0 size: 32 bit */
15918  INTC_PSR_32B_tag PSR148_151; /* offset: 0x00D4 size: 32 bit */
15919  INTC_PSR_32B_tag PSR152_155; /* offset: 0x00D8 size: 32 bit */
15920  INTC_PSR_32B_tag PSR156_159; /* offset: 0x00DC size: 32 bit */
15921  INTC_PSR_32B_tag PSR160_163; /* offset: 0x00E0 size: 32 bit */
15922  INTC_PSR_32B_tag PSR164_167; /* offset: 0x00E4 size: 32 bit */
15923  INTC_PSR_32B_tag PSR168_171; /* offset: 0x00E8 size: 32 bit */
15924  INTC_PSR_32B_tag PSR172_175; /* offset: 0x00EC size: 32 bit */
15925  INTC_PSR_32B_tag PSR176_179; /* offset: 0x00F0 size: 32 bit */
15926  INTC_PSR_32B_tag PSR180_183; /* offset: 0x00F4 size: 32 bit */
15927  INTC_PSR_32B_tag PSR184_187; /* offset: 0x00F8 size: 32 bit */
15928  INTC_PSR_32B_tag PSR188_191; /* offset: 0x00FC size: 32 bit */
15929  INTC_PSR_32B_tag PSR192_195; /* offset: 0x0100 size: 32 bit */
15930  INTC_PSR_32B_tag PSR196_199; /* offset: 0x0104 size: 32 bit */
15931  INTC_PSR_32B_tag PSR200_203; /* offset: 0x0108 size: 32 bit */
15932  INTC_PSR_32B_tag PSR204_207; /* offset: 0x010C size: 32 bit */
15933  INTC_PSR_32B_tag PSR208_211; /* offset: 0x0110 size: 32 bit */
15934  INTC_PSR_32B_tag PSR212_215; /* offset: 0x0114 size: 32 bit */
15935  INTC_PSR_32B_tag PSR216_219; /* offset: 0x0118 size: 32 bit */
15936  INTC_PSR_32B_tag PSR220_223; /* offset: 0x011C size: 32 bit */
15937  INTC_PSR_32B_tag PSR224_227; /* offset: 0x0120 size: 32 bit */
15938  INTC_PSR_32B_tag PSR228_231; /* offset: 0x0124 size: 32 bit */
15939  INTC_PSR_32B_tag PSR232_235; /* offset: 0x0128 size: 32 bit */
15940  INTC_PSR_32B_tag PSR236_239; /* offset: 0x012C size: 32 bit */
15941  INTC_PSR_32B_tag PSR240_243; /* offset: 0x0130 size: 32 bit */
15942  INTC_PSR_32B_tag PSR244_247; /* offset: 0x0134 size: 32 bit */
15943  INTC_PSR_32B_tag PSR248_251; /* offset: 0x0138 size: 32 bit */
15944  INTC_PSR_32B_tag PSR252_255; /* offset: 0x013C size: 32 bit */
15945  INTC_PSR_32B_tag PSR256_259; /* offset: 0x0140 size: 32 bit */
15946  INTC_PSR_32B_tag PSR260_263; /* offset: 0x0144 size: 32 bit */
15947  INTC_PSR_32B_tag PSR264_267; /* offset: 0x0148 size: 32 bit */
15948  INTC_PSR_32B_tag PSR268_271; /* offset: 0x014C size: 32 bit */
15949  INTC_PSR_32B_tag PSR272_275; /* offset: 0x0150 size: 32 bit */
15950  INTC_PSR_32B_tag PSR276_279; /* offset: 0x0154 size: 32 bit */
15951  INTC_PSR_32B_tag PSR280_283; /* offset: 0x0158 size: 32 bit */
15952  INTC_PSR_32B_tag PSR284_287; /* offset: 0x015C size: 32 bit */
15953  INTC_PSR_32B_tag PSR288_291; /* offset: 0x0160 size: 32 bit */
15954  INTC_PSR_32B_tag PSR292_295; /* offset: 0x0164 size: 32 bit */
15955  INTC_PSR_32B_tag PSR296_299; /* offset: 0x0168 size: 32 bit */
15956  INTC_PSR_32B_tag PSR300_303; /* offset: 0x016C size: 32 bit */
15957  INTC_PSR_32B_tag PSR304_307; /* offset: 0x0170 size: 32 bit */
15958  INTC_PSR_32B_tag PSR308_311; /* offset: 0x0174 size: 32 bit */
15959  INTC_PSR_32B_tag PSR312_315; /* offset: 0x0178 size: 32 bit */
15960  INTC_PSR_32B_tag PSR316_319; /* offset: 0x017C size: 32 bit */
15961  INTC_PSR_32B_tag PSR320_323; /* offset: 0x0180 size: 32 bit */
15962  INTC_PSR_32B_tag PSR324_327; /* offset: 0x0184 size: 32 bit */
15963  INTC_PSR_32B_tag PSR328_331; /* offset: 0x0188 size: 32 bit */
15964  INTC_PSR_32B_tag PSR332_335; /* offset: 0x018C size: 32 bit */
15965  INTC_PSR_32B_tag PSR336_339; /* offset: 0x0190 size: 32 bit */
15966  INTC_PSR_32B_tag PSR340_343; /* offset: 0x0194 size: 32 bit */
15967  INTC_PSR_32B_tag PSR344_347; /* offset: 0x0198 size: 32 bit */
15968  INTC_PSR_32B_tag PSR348_351; /* offset: 0x019C size: 32 bit */
15969  INTC_PSR_32B_tag PSR352_355; /* offset: 0x01A0 size: 32 bit */
15970  INTC_PSR_32B_tag PSR356_359; /* offset: 0x01A4 size: 32 bit */
15971  INTC_PSR_32B_tag PSR360_363; /* offset: 0x01A8 size: 32 bit */
15972  INTC_PSR_32B_tag PSR364_367; /* offset: 0x01AC size: 32 bit */
15973  INTC_PSR_32B_tag PSR368_371; /* offset: 0x01B0 size: 32 bit */
15974  INTC_PSR_32B_tag PSR372_375; /* offset: 0x01B4 size: 32 bit */
15975  INTC_PSR_32B_tag PSR376_379; /* offset: 0x01B8 size: 32 bit */
15976  INTC_PSR_32B_tag PSR380_383; /* offset: 0x01BC size: 32 bit */
15977  INTC_PSR_32B_tag PSR384_387; /* offset: 0x01C0 size: 32 bit */
15978  INTC_PSR_32B_tag PSR388_391; /* offset: 0x01C4 size: 32 bit */
15979  INTC_PSR_32B_tag PSR392_395; /* offset: 0x01C8 size: 32 bit */
15980  INTC_PSR_32B_tag PSR396_399; /* offset: 0x01CC size: 32 bit */
15981  INTC_PSR_32B_tag PSR400_403; /* offset: 0x01D0 size: 32 bit */
15982  INTC_PSR_32B_tag PSR404_407; /* offset: 0x01D4 size: 32 bit */
15983  INTC_PSR_32B_tag PSR408_411; /* offset: 0x01D8 size: 32 bit */
15984  INTC_PSR_32B_tag PSR412_415; /* offset: 0x01DC size: 32 bit */
15985  INTC_PSR_32B_tag PSR416_419; /* offset: 0x01E0 size: 32 bit */
15986  INTC_PSR_32B_tag PSR420_423; /* offset: 0x01E4 size: 32 bit */
15987  INTC_PSR_32B_tag PSR424_427; /* offset: 0x01E8 size: 32 bit */
15988  INTC_PSR_32B_tag PSR428_431; /* offset: 0x01EC size: 32 bit */
15989  INTC_PSR_32B_tag PSR432_435; /* offset: 0x01F0 size: 32 bit */
15990  INTC_PSR_32B_tag PSR436_439; /* offset: 0x01F4 size: 32 bit */
15991  INTC_PSR_32B_tag PSR440_443; /* offset: 0x01F8 size: 32 bit */
15992  INTC_PSR_32B_tag PSR444_447; /* offset: 0x01FC size: 32 bit */
15993  INTC_PSR_32B_tag PSR448_451; /* offset: 0x0200 size: 32 bit */
15994  INTC_PSR_32B_tag PSR452_455; /* offset: 0x0204 size: 32 bit */
15995  INTC_PSR_32B_tag PSR456_459; /* offset: 0x0208 size: 32 bit */
15996  INTC_PSR_32B_tag PSR460_463; /* offset: 0x020C size: 32 bit */
15997  INTC_PSR_32B_tag PSR464_467; /* offset: 0x0210 size: 32 bit */
15998  INTC_PSR_32B_tag PSR468_471; /* offset: 0x0214 size: 32 bit */
15999  INTC_PSR_32B_tag PSR472_475; /* offset: 0x0218 size: 32 bit */
16000  INTC_PSR_32B_tag PSR476_479; /* offset: 0x021C size: 32 bit */
16001  INTC_PSR_32B_tag PSR480_483; /* offset: 0x0220 size: 32 bit */
16002  INTC_PSR_32B_tag PSR484_487; /* offset: 0x0224 size: 32 bit */
16003  INTC_PSR_32B_tag PSR488_491; /* offset: 0x0228 size: 32 bit */
16004  INTC_PSR_32B_tag PSR492_495; /* offset: 0x022C size: 32 bit */
16005  INTC_PSR_32B_tag PSR496_499; /* offset: 0x0230 size: 32 bit */
16006  INTC_PSR_32B_tag PSR500_503; /* offset: 0x0234 size: 32 bit */
16007  INTC_PSR_32B_tag PSR504_507; /* offset: 0x0238 size: 32 bit */
16008  INTC_PSR_32B_tag PSR508_511; /* offset: 0x023C size: 32 bit */
16009  };
16010
16011  struct {
16012  /* PSR0-511 - Priority Select Registers */
16013  INTC_PSR_8B_tag PSR0; /* offset: 0x0040 size: 8 bit */
16014  INTC_PSR_8B_tag PSR1; /* offset: 0x0041 size: 8 bit */
16015  INTC_PSR_8B_tag PSR2; /* offset: 0x0042 size: 8 bit */
16016  INTC_PSR_8B_tag PSR3; /* offset: 0x0043 size: 8 bit */
16017  INTC_PSR_8B_tag PSR4; /* offset: 0x0044 size: 8 bit */
16018  INTC_PSR_8B_tag PSR5; /* offset: 0x0045 size: 8 bit */
16019  INTC_PSR_8B_tag PSR6; /* offset: 0x0046 size: 8 bit */
16020  INTC_PSR_8B_tag PSR7; /* offset: 0x0047 size: 8 bit */
16021  INTC_PSR_8B_tag PSR8; /* offset: 0x0048 size: 8 bit */
16022  INTC_PSR_8B_tag PSR9; /* offset: 0x0049 size: 8 bit */
16023  INTC_PSR_8B_tag PSR10; /* offset: 0x004A size: 8 bit */
16024  INTC_PSR_8B_tag PSR11; /* offset: 0x004B size: 8 bit */
16025  INTC_PSR_8B_tag PSR12; /* offset: 0x004C size: 8 bit */
16026  INTC_PSR_8B_tag PSR13; /* offset: 0x004D size: 8 bit */
16027  INTC_PSR_8B_tag PSR14; /* offset: 0x004E size: 8 bit */
16028  INTC_PSR_8B_tag PSR15; /* offset: 0x004F size: 8 bit */
16029  INTC_PSR_8B_tag PSR16; /* offset: 0x0050 size: 8 bit */
16030  INTC_PSR_8B_tag PSR17; /* offset: 0x0051 size: 8 bit */
16031  INTC_PSR_8B_tag PSR18; /* offset: 0x0052 size: 8 bit */
16032  INTC_PSR_8B_tag PSR19; /* offset: 0x0053 size: 8 bit */
16033  INTC_PSR_8B_tag PSR20; /* offset: 0x0054 size: 8 bit */
16034  INTC_PSR_8B_tag PSR21; /* offset: 0x0055 size: 8 bit */
16035  INTC_PSR_8B_tag PSR22; /* offset: 0x0056 size: 8 bit */
16036  INTC_PSR_8B_tag PSR23; /* offset: 0x0057 size: 8 bit */
16037  INTC_PSR_8B_tag PSR24; /* offset: 0x0058 size: 8 bit */
16038  INTC_PSR_8B_tag PSR25; /* offset: 0x0059 size: 8 bit */
16039  INTC_PSR_8B_tag PSR26; /* offset: 0x005A size: 8 bit */
16040  INTC_PSR_8B_tag PSR27; /* offset: 0x005B size: 8 bit */
16041  INTC_PSR_8B_tag PSR28; /* offset: 0x005C size: 8 bit */
16042  INTC_PSR_8B_tag PSR29; /* offset: 0x005D size: 8 bit */
16043  INTC_PSR_8B_tag PSR30; /* offset: 0x005E size: 8 bit */
16044  INTC_PSR_8B_tag PSR31; /* offset: 0x005F size: 8 bit */
16045  INTC_PSR_8B_tag PSR32; /* offset: 0x0060 size: 8 bit */
16046  INTC_PSR_8B_tag PSR33; /* offset: 0x0061 size: 8 bit */
16047  INTC_PSR_8B_tag PSR34; /* offset: 0x0062 size: 8 bit */
16048  INTC_PSR_8B_tag PSR35; /* offset: 0x0063 size: 8 bit */
16049  INTC_PSR_8B_tag PSR36; /* offset: 0x0064 size: 8 bit */
16050  INTC_PSR_8B_tag PSR37; /* offset: 0x0065 size: 8 bit */
16051  INTC_PSR_8B_tag PSR38; /* offset: 0x0066 size: 8 bit */
16052  INTC_PSR_8B_tag PSR39; /* offset: 0x0067 size: 8 bit */
16053  INTC_PSR_8B_tag PSR40; /* offset: 0x0068 size: 8 bit */
16054  INTC_PSR_8B_tag PSR41; /* offset: 0x0069 size: 8 bit */
16055  INTC_PSR_8B_tag PSR42; /* offset: 0x006A size: 8 bit */
16056  INTC_PSR_8B_tag PSR43; /* offset: 0x006B size: 8 bit */
16057  INTC_PSR_8B_tag PSR44; /* offset: 0x006C size: 8 bit */
16058  INTC_PSR_8B_tag PSR45; /* offset: 0x006D size: 8 bit */
16059  INTC_PSR_8B_tag PSR46; /* offset: 0x006E size: 8 bit */
16060  INTC_PSR_8B_tag PSR47; /* offset: 0x006F size: 8 bit */
16061  INTC_PSR_8B_tag PSR48; /* offset: 0x0070 size: 8 bit */
16062  INTC_PSR_8B_tag PSR49; /* offset: 0x0071 size: 8 bit */
16063  INTC_PSR_8B_tag PSR50; /* offset: 0x0072 size: 8 bit */
16064  INTC_PSR_8B_tag PSR51; /* offset: 0x0073 size: 8 bit */
16065  INTC_PSR_8B_tag PSR52; /* offset: 0x0074 size: 8 bit */
16066  INTC_PSR_8B_tag PSR53; /* offset: 0x0075 size: 8 bit */
16067  INTC_PSR_8B_tag PSR54; /* offset: 0x0076 size: 8 bit */
16068  INTC_PSR_8B_tag PSR55; /* offset: 0x0077 size: 8 bit */
16069  INTC_PSR_8B_tag PSR56; /* offset: 0x0078 size: 8 bit */
16070  INTC_PSR_8B_tag PSR57; /* offset: 0x0079 size: 8 bit */
16071  INTC_PSR_8B_tag PSR58; /* offset: 0x007A size: 8 bit */
16072  INTC_PSR_8B_tag PSR59; /* offset: 0x007B size: 8 bit */
16073  INTC_PSR_8B_tag PSR60; /* offset: 0x007C size: 8 bit */
16074  INTC_PSR_8B_tag PSR61; /* offset: 0x007D size: 8 bit */
16075  INTC_PSR_8B_tag PSR62; /* offset: 0x007E size: 8 bit */
16076  INTC_PSR_8B_tag PSR63; /* offset: 0x007F size: 8 bit */
16077  INTC_PSR_8B_tag PSR64; /* offset: 0x0080 size: 8 bit */
16078  INTC_PSR_8B_tag PSR65; /* offset: 0x0081 size: 8 bit */
16079  INTC_PSR_8B_tag PSR66; /* offset: 0x0082 size: 8 bit */
16080  INTC_PSR_8B_tag PSR67; /* offset: 0x0083 size: 8 bit */
16081  INTC_PSR_8B_tag PSR68; /* offset: 0x0084 size: 8 bit */
16082  INTC_PSR_8B_tag PSR69; /* offset: 0x0085 size: 8 bit */
16083  INTC_PSR_8B_tag PSR70; /* offset: 0x0086 size: 8 bit */
16084  INTC_PSR_8B_tag PSR71; /* offset: 0x0087 size: 8 bit */
16085  INTC_PSR_8B_tag PSR72; /* offset: 0x0088 size: 8 bit */
16086  INTC_PSR_8B_tag PSR73; /* offset: 0x0089 size: 8 bit */
16087  INTC_PSR_8B_tag PSR74; /* offset: 0x008A size: 8 bit */
16088  INTC_PSR_8B_tag PSR75; /* offset: 0x008B size: 8 bit */
16089  INTC_PSR_8B_tag PSR76; /* offset: 0x008C size: 8 bit */
16090  INTC_PSR_8B_tag PSR77; /* offset: 0x008D size: 8 bit */
16091  INTC_PSR_8B_tag PSR78; /* offset: 0x008E size: 8 bit */
16092  INTC_PSR_8B_tag PSR79; /* offset: 0x008F size: 8 bit */
16093  INTC_PSR_8B_tag PSR80; /* offset: 0x0090 size: 8 bit */
16094  INTC_PSR_8B_tag PSR81; /* offset: 0x0091 size: 8 bit */
16095  INTC_PSR_8B_tag PSR82; /* offset: 0x0092 size: 8 bit */
16096  INTC_PSR_8B_tag PSR83; /* offset: 0x0093 size: 8 bit */
16097  INTC_PSR_8B_tag PSR84; /* offset: 0x0094 size: 8 bit */
16098  INTC_PSR_8B_tag PSR85; /* offset: 0x0095 size: 8 bit */
16099  INTC_PSR_8B_tag PSR86; /* offset: 0x0096 size: 8 bit */
16100  INTC_PSR_8B_tag PSR87; /* offset: 0x0097 size: 8 bit */
16101  INTC_PSR_8B_tag PSR88; /* offset: 0x0098 size: 8 bit */
16102  INTC_PSR_8B_tag PSR89; /* offset: 0x0099 size: 8 bit */
16103  INTC_PSR_8B_tag PSR90; /* offset: 0x009A size: 8 bit */
16104  INTC_PSR_8B_tag PSR91; /* offset: 0x009B size: 8 bit */
16105  INTC_PSR_8B_tag PSR92; /* offset: 0x009C size: 8 bit */
16106  INTC_PSR_8B_tag PSR93; /* offset: 0x009D size: 8 bit */
16107  INTC_PSR_8B_tag PSR94; /* offset: 0x009E size: 8 bit */
16108  INTC_PSR_8B_tag PSR95; /* offset: 0x009F size: 8 bit */
16109  INTC_PSR_8B_tag PSR96; /* offset: 0x00A0 size: 8 bit */
16110  INTC_PSR_8B_tag PSR97; /* offset: 0x00A1 size: 8 bit */
16111  INTC_PSR_8B_tag PSR98; /* offset: 0x00A2 size: 8 bit */
16112  INTC_PSR_8B_tag PSR99; /* offset: 0x00A3 size: 8 bit */
16113  INTC_PSR_8B_tag PSR100; /* offset: 0x00A4 size: 8 bit */
16114  INTC_PSR_8B_tag PSR101; /* offset: 0x00A5 size: 8 bit */
16115  INTC_PSR_8B_tag PSR102; /* offset: 0x00A6 size: 8 bit */
16116  INTC_PSR_8B_tag PSR103; /* offset: 0x00A7 size: 8 bit */
16117  INTC_PSR_8B_tag PSR104; /* offset: 0x00A8 size: 8 bit */
16118  INTC_PSR_8B_tag PSR105; /* offset: 0x00A9 size: 8 bit */
16119  INTC_PSR_8B_tag PSR106; /* offset: 0x00AA size: 8 bit */
16120  INTC_PSR_8B_tag PSR107; /* offset: 0x00AB size: 8 bit */
16121  INTC_PSR_8B_tag PSR108; /* offset: 0x00AC size: 8 bit */
16122  INTC_PSR_8B_tag PSR109; /* offset: 0x00AD size: 8 bit */
16123  INTC_PSR_8B_tag PSR110; /* offset: 0x00AE size: 8 bit */
16124  INTC_PSR_8B_tag PSR111; /* offset: 0x00AF size: 8 bit */
16125  INTC_PSR_8B_tag PSR112; /* offset: 0x00B0 size: 8 bit */
16126  INTC_PSR_8B_tag PSR113; /* offset: 0x00B1 size: 8 bit */
16127  INTC_PSR_8B_tag PSR114; /* offset: 0x00B2 size: 8 bit */
16128  INTC_PSR_8B_tag PSR115; /* offset: 0x00B3 size: 8 bit */
16129  INTC_PSR_8B_tag PSR116; /* offset: 0x00B4 size: 8 bit */
16130  INTC_PSR_8B_tag PSR117; /* offset: 0x00B5 size: 8 bit */
16131  INTC_PSR_8B_tag PSR118; /* offset: 0x00B6 size: 8 bit */
16132  INTC_PSR_8B_tag PSR119; /* offset: 0x00B7 size: 8 bit */
16133  INTC_PSR_8B_tag PSR120; /* offset: 0x00B8 size: 8 bit */
16134  INTC_PSR_8B_tag PSR121; /* offset: 0x00B9 size: 8 bit */
16135  INTC_PSR_8B_tag PSR122; /* offset: 0x00BA size: 8 bit */
16136  INTC_PSR_8B_tag PSR123; /* offset: 0x00BB size: 8 bit */
16137  INTC_PSR_8B_tag PSR124; /* offset: 0x00BC size: 8 bit */
16138  INTC_PSR_8B_tag PSR125; /* offset: 0x00BD size: 8 bit */
16139  INTC_PSR_8B_tag PSR126; /* offset: 0x00BE size: 8 bit */
16140  INTC_PSR_8B_tag PSR127; /* offset: 0x00BF size: 8 bit */
16141  INTC_PSR_8B_tag PSR128; /* offset: 0x00C0 size: 8 bit */
16142  INTC_PSR_8B_tag PSR129; /* offset: 0x00C1 size: 8 bit */
16143  INTC_PSR_8B_tag PSR130; /* offset: 0x00C2 size: 8 bit */
16144  INTC_PSR_8B_tag PSR131; /* offset: 0x00C3 size: 8 bit */
16145  INTC_PSR_8B_tag PSR132; /* offset: 0x00C4 size: 8 bit */
16146  INTC_PSR_8B_tag PSR133; /* offset: 0x00C5 size: 8 bit */
16147  INTC_PSR_8B_tag PSR134; /* offset: 0x00C6 size: 8 bit */
16148  INTC_PSR_8B_tag PSR135; /* offset: 0x00C7 size: 8 bit */
16149  INTC_PSR_8B_tag PSR136; /* offset: 0x00C8 size: 8 bit */
16150  INTC_PSR_8B_tag PSR137; /* offset: 0x00C9 size: 8 bit */
16151  INTC_PSR_8B_tag PSR138; /* offset: 0x00CA size: 8 bit */
16152  INTC_PSR_8B_tag PSR139; /* offset: 0x00CB size: 8 bit */
16153  INTC_PSR_8B_tag PSR140; /* offset: 0x00CC size: 8 bit */
16154  INTC_PSR_8B_tag PSR141; /* offset: 0x00CD size: 8 bit */
16155  INTC_PSR_8B_tag PSR142; /* offset: 0x00CE size: 8 bit */
16156  INTC_PSR_8B_tag PSR143; /* offset: 0x00CF size: 8 bit */
16157  INTC_PSR_8B_tag PSR144; /* offset: 0x00D0 size: 8 bit */
16158  INTC_PSR_8B_tag PSR145; /* offset: 0x00D1 size: 8 bit */
16159  INTC_PSR_8B_tag PSR146; /* offset: 0x00D2 size: 8 bit */
16160  INTC_PSR_8B_tag PSR147; /* offset: 0x00D3 size: 8 bit */
16161  INTC_PSR_8B_tag PSR148; /* offset: 0x00D4 size: 8 bit */
16162  INTC_PSR_8B_tag PSR149; /* offset: 0x00D5 size: 8 bit */
16163  INTC_PSR_8B_tag PSR150; /* offset: 0x00D6 size: 8 bit */
16164  INTC_PSR_8B_tag PSR151; /* offset: 0x00D7 size: 8 bit */
16165  INTC_PSR_8B_tag PSR152; /* offset: 0x00D8 size: 8 bit */
16166  INTC_PSR_8B_tag PSR153; /* offset: 0x00D9 size: 8 bit */
16167  INTC_PSR_8B_tag PSR154; /* offset: 0x00DA size: 8 bit */
16168  INTC_PSR_8B_tag PSR155; /* offset: 0x00DB size: 8 bit */
16169  INTC_PSR_8B_tag PSR156; /* offset: 0x00DC size: 8 bit */
16170  INTC_PSR_8B_tag PSR157; /* offset: 0x00DD size: 8 bit */
16171  INTC_PSR_8B_tag PSR158; /* offset: 0x00DE size: 8 bit */
16172  INTC_PSR_8B_tag PSR159; /* offset: 0x00DF size: 8 bit */
16173  INTC_PSR_8B_tag PSR160; /* offset: 0x00E0 size: 8 bit */
16174  INTC_PSR_8B_tag PSR161; /* offset: 0x00E1 size: 8 bit */
16175  INTC_PSR_8B_tag PSR162; /* offset: 0x00E2 size: 8 bit */
16176  INTC_PSR_8B_tag PSR163; /* offset: 0x00E3 size: 8 bit */
16177  INTC_PSR_8B_tag PSR164; /* offset: 0x00E4 size: 8 bit */
16178  INTC_PSR_8B_tag PSR165; /* offset: 0x00E5 size: 8 bit */
16179  INTC_PSR_8B_tag PSR166; /* offset: 0x00E6 size: 8 bit */
16180  INTC_PSR_8B_tag PSR167; /* offset: 0x00E7 size: 8 bit */
16181  INTC_PSR_8B_tag PSR168; /* offset: 0x00E8 size: 8 bit */
16182  INTC_PSR_8B_tag PSR169; /* offset: 0x00E9 size: 8 bit */
16183  INTC_PSR_8B_tag PSR170; /* offset: 0x00EA size: 8 bit */
16184  INTC_PSR_8B_tag PSR171; /* offset: 0x00EB size: 8 bit */
16185  INTC_PSR_8B_tag PSR172; /* offset: 0x00EC size: 8 bit */
16186  INTC_PSR_8B_tag PSR173; /* offset: 0x00ED size: 8 bit */
16187  INTC_PSR_8B_tag PSR174; /* offset: 0x00EE size: 8 bit */
16188  INTC_PSR_8B_tag PSR175; /* offset: 0x00EF size: 8 bit */
16189  INTC_PSR_8B_tag PSR176; /* offset: 0x00F0 size: 8 bit */
16190  INTC_PSR_8B_tag PSR177; /* offset: 0x00F1 size: 8 bit */
16191  INTC_PSR_8B_tag PSR178; /* offset: 0x00F2 size: 8 bit */
16192  INTC_PSR_8B_tag PSR179; /* offset: 0x00F3 size: 8 bit */
16193  INTC_PSR_8B_tag PSR180; /* offset: 0x00F4 size: 8 bit */
16194  INTC_PSR_8B_tag PSR181; /* offset: 0x00F5 size: 8 bit */
16195  INTC_PSR_8B_tag PSR182; /* offset: 0x00F6 size: 8 bit */
16196  INTC_PSR_8B_tag PSR183; /* offset: 0x00F7 size: 8 bit */
16197  INTC_PSR_8B_tag PSR184; /* offset: 0x00F8 size: 8 bit */
16198  INTC_PSR_8B_tag PSR185; /* offset: 0x00F9 size: 8 bit */
16199  INTC_PSR_8B_tag PSR186; /* offset: 0x00FA size: 8 bit */
16200  INTC_PSR_8B_tag PSR187; /* offset: 0x00FB size: 8 bit */
16201  INTC_PSR_8B_tag PSR188; /* offset: 0x00FC size: 8 bit */
16202  INTC_PSR_8B_tag PSR189; /* offset: 0x00FD size: 8 bit */
16203  INTC_PSR_8B_tag PSR190; /* offset: 0x00FE size: 8 bit */
16204  INTC_PSR_8B_tag PSR191; /* offset: 0x00FF size: 8 bit */
16205  INTC_PSR_8B_tag PSR192; /* offset: 0x0100 size: 8 bit */
16206  INTC_PSR_8B_tag PSR193; /* offset: 0x0101 size: 8 bit */
16207  INTC_PSR_8B_tag PSR194; /* offset: 0x0102 size: 8 bit */
16208  INTC_PSR_8B_tag PSR195; /* offset: 0x0103 size: 8 bit */
16209  INTC_PSR_8B_tag PSR196; /* offset: 0x0104 size: 8 bit */
16210  INTC_PSR_8B_tag PSR197; /* offset: 0x0105 size: 8 bit */
16211  INTC_PSR_8B_tag PSR198; /* offset: 0x0106 size: 8 bit */
16212  INTC_PSR_8B_tag PSR199; /* offset: 0x0107 size: 8 bit */
16213  INTC_PSR_8B_tag PSR200; /* offset: 0x0108 size: 8 bit */
16214  INTC_PSR_8B_tag PSR201; /* offset: 0x0109 size: 8 bit */
16215  INTC_PSR_8B_tag PSR202; /* offset: 0x010A size: 8 bit */
16216  INTC_PSR_8B_tag PSR203; /* offset: 0x010B size: 8 bit */
16217  INTC_PSR_8B_tag PSR204; /* offset: 0x010C size: 8 bit */
16218  INTC_PSR_8B_tag PSR205; /* offset: 0x010D size: 8 bit */
16219  INTC_PSR_8B_tag PSR206; /* offset: 0x010E size: 8 bit */
16220  INTC_PSR_8B_tag PSR207; /* offset: 0x010F size: 8 bit */
16221  INTC_PSR_8B_tag PSR208; /* offset: 0x0110 size: 8 bit */
16222  INTC_PSR_8B_tag PSR209; /* offset: 0x0111 size: 8 bit */
16223  INTC_PSR_8B_tag PSR210; /* offset: 0x0112 size: 8 bit */
16224  INTC_PSR_8B_tag PSR211; /* offset: 0x0113 size: 8 bit */
16225  INTC_PSR_8B_tag PSR212; /* offset: 0x0114 size: 8 bit */
16226  INTC_PSR_8B_tag PSR213; /* offset: 0x0115 size: 8 bit */
16227  INTC_PSR_8B_tag PSR214; /* offset: 0x0116 size: 8 bit */
16228  INTC_PSR_8B_tag PSR215; /* offset: 0x0117 size: 8 bit */
16229  INTC_PSR_8B_tag PSR216; /* offset: 0x0118 size: 8 bit */
16230  INTC_PSR_8B_tag PSR217; /* offset: 0x0119 size: 8 bit */
16231  INTC_PSR_8B_tag PSR218; /* offset: 0x011A size: 8 bit */
16232  INTC_PSR_8B_tag PSR219; /* offset: 0x011B size: 8 bit */
16233  INTC_PSR_8B_tag PSR220; /* offset: 0x011C size: 8 bit */
16234  INTC_PSR_8B_tag PSR221; /* offset: 0x011D size: 8 bit */
16235  INTC_PSR_8B_tag PSR222; /* offset: 0x011E size: 8 bit */
16236  INTC_PSR_8B_tag PSR223; /* offset: 0x011F size: 8 bit */
16237  INTC_PSR_8B_tag PSR224; /* offset: 0x0120 size: 8 bit */
16238  INTC_PSR_8B_tag PSR225; /* offset: 0x0121 size: 8 bit */
16239  INTC_PSR_8B_tag PSR226; /* offset: 0x0122 size: 8 bit */
16240  INTC_PSR_8B_tag PSR227; /* offset: 0x0123 size: 8 bit */
16241  INTC_PSR_8B_tag PSR228; /* offset: 0x0124 size: 8 bit */
16242  INTC_PSR_8B_tag PSR229; /* offset: 0x0125 size: 8 bit */
16243  INTC_PSR_8B_tag PSR230; /* offset: 0x0126 size: 8 bit */
16244  INTC_PSR_8B_tag PSR231; /* offset: 0x0127 size: 8 bit */
16245  INTC_PSR_8B_tag PSR232; /* offset: 0x0128 size: 8 bit */
16246  INTC_PSR_8B_tag PSR233; /* offset: 0x0129 size: 8 bit */
16247  INTC_PSR_8B_tag PSR234; /* offset: 0x012A size: 8 bit */
16248  INTC_PSR_8B_tag PSR235; /* offset: 0x012B size: 8 bit */
16249  INTC_PSR_8B_tag PSR236; /* offset: 0x012C size: 8 bit */
16250  INTC_PSR_8B_tag PSR237; /* offset: 0x012D size: 8 bit */
16251  INTC_PSR_8B_tag PSR238; /* offset: 0x012E size: 8 bit */
16252  INTC_PSR_8B_tag PSR239; /* offset: 0x012F size: 8 bit */
16253  INTC_PSR_8B_tag PSR240; /* offset: 0x0130 size: 8 bit */
16254  INTC_PSR_8B_tag PSR241; /* offset: 0x0131 size: 8 bit */
16255  INTC_PSR_8B_tag PSR242; /* offset: 0x0132 size: 8 bit */
16256  INTC_PSR_8B_tag PSR243; /* offset: 0x0133 size: 8 bit */
16257  INTC_PSR_8B_tag PSR244; /* offset: 0x0134 size: 8 bit */
16258  INTC_PSR_8B_tag PSR245; /* offset: 0x0135 size: 8 bit */
16259  INTC_PSR_8B_tag PSR246; /* offset: 0x0136 size: 8 bit */
16260  INTC_PSR_8B_tag PSR247; /* offset: 0x0137 size: 8 bit */
16261  INTC_PSR_8B_tag PSR248; /* offset: 0x0138 size: 8 bit */
16262  INTC_PSR_8B_tag PSR249; /* offset: 0x0139 size: 8 bit */
16263  INTC_PSR_8B_tag PSR250; /* offset: 0x013A size: 8 bit */
16264  INTC_PSR_8B_tag PSR251; /* offset: 0x013B size: 8 bit */
16265  INTC_PSR_8B_tag PSR252; /* offset: 0x013C size: 8 bit */
16266  INTC_PSR_8B_tag PSR253; /* offset: 0x013D size: 8 bit */
16267  INTC_PSR_8B_tag PSR254; /* offset: 0x013E size: 8 bit */
16268  INTC_PSR_8B_tag PSR255; /* offset: 0x013F size: 8 bit */
16269  INTC_PSR_8B_tag PSR256; /* offset: 0x0140 size: 8 bit */
16270  INTC_PSR_8B_tag PSR257; /* offset: 0x0141 size: 8 bit */
16271  INTC_PSR_8B_tag PSR258; /* offset: 0x0142 size: 8 bit */
16272  INTC_PSR_8B_tag PSR259; /* offset: 0x0143 size: 8 bit */
16273  INTC_PSR_8B_tag PSR260; /* offset: 0x0144 size: 8 bit */
16274  INTC_PSR_8B_tag PSR261; /* offset: 0x0145 size: 8 bit */
16275  INTC_PSR_8B_tag PSR262; /* offset: 0x0146 size: 8 bit */
16276  INTC_PSR_8B_tag PSR263; /* offset: 0x0147 size: 8 bit */
16277  INTC_PSR_8B_tag PSR264; /* offset: 0x0148 size: 8 bit */
16278  INTC_PSR_8B_tag PSR265; /* offset: 0x0149 size: 8 bit */
16279  INTC_PSR_8B_tag PSR266; /* offset: 0x014A size: 8 bit */
16280  INTC_PSR_8B_tag PSR267; /* offset: 0x014B size: 8 bit */
16281  INTC_PSR_8B_tag PSR268; /* offset: 0x014C size: 8 bit */
16282  INTC_PSR_8B_tag PSR269; /* offset: 0x014D size: 8 bit */
16283  INTC_PSR_8B_tag PSR270; /* offset: 0x014E size: 8 bit */
16284  INTC_PSR_8B_tag PSR271; /* offset: 0x014F size: 8 bit */
16285  INTC_PSR_8B_tag PSR272; /* offset: 0x0150 size: 8 bit */
16286  INTC_PSR_8B_tag PSR273; /* offset: 0x0151 size: 8 bit */
16287  INTC_PSR_8B_tag PSR274; /* offset: 0x0152 size: 8 bit */
16288  INTC_PSR_8B_tag PSR275; /* offset: 0x0153 size: 8 bit */
16289  INTC_PSR_8B_tag PSR276; /* offset: 0x0154 size: 8 bit */
16290  INTC_PSR_8B_tag PSR277; /* offset: 0x0155 size: 8 bit */
16291  INTC_PSR_8B_tag PSR278; /* offset: 0x0156 size: 8 bit */
16292  INTC_PSR_8B_tag PSR279; /* offset: 0x0157 size: 8 bit */
16293  INTC_PSR_8B_tag PSR280; /* offset: 0x0158 size: 8 bit */
16294  INTC_PSR_8B_tag PSR281; /* offset: 0x0159 size: 8 bit */
16295  INTC_PSR_8B_tag PSR282; /* offset: 0x015A size: 8 bit */
16296  INTC_PSR_8B_tag PSR283; /* offset: 0x015B size: 8 bit */
16297  INTC_PSR_8B_tag PSR284; /* offset: 0x015C size: 8 bit */
16298  INTC_PSR_8B_tag PSR285; /* offset: 0x015D size: 8 bit */
16299  INTC_PSR_8B_tag PSR286; /* offset: 0x015E size: 8 bit */
16300  INTC_PSR_8B_tag PSR287; /* offset: 0x015F size: 8 bit */
16301  INTC_PSR_8B_tag PSR288; /* offset: 0x0160 size: 8 bit */
16302  INTC_PSR_8B_tag PSR289; /* offset: 0x0161 size: 8 bit */
16303  INTC_PSR_8B_tag PSR290; /* offset: 0x0162 size: 8 bit */
16304  INTC_PSR_8B_tag PSR291; /* offset: 0x0163 size: 8 bit */
16305  INTC_PSR_8B_tag PSR292; /* offset: 0x0164 size: 8 bit */
16306  INTC_PSR_8B_tag PSR293; /* offset: 0x0165 size: 8 bit */
16307  INTC_PSR_8B_tag PSR294; /* offset: 0x0166 size: 8 bit */
16308  INTC_PSR_8B_tag PSR295; /* offset: 0x0167 size: 8 bit */
16309  INTC_PSR_8B_tag PSR296; /* offset: 0x0168 size: 8 bit */
16310  INTC_PSR_8B_tag PSR297; /* offset: 0x0169 size: 8 bit */
16311  INTC_PSR_8B_tag PSR298; /* offset: 0x016A size: 8 bit */
16312  INTC_PSR_8B_tag PSR299; /* offset: 0x016B size: 8 bit */
16313  INTC_PSR_8B_tag PSR300; /* offset: 0x016C size: 8 bit */
16314  INTC_PSR_8B_tag PSR301; /* offset: 0x016D size: 8 bit */
16315  INTC_PSR_8B_tag PSR302; /* offset: 0x016E size: 8 bit */
16316  INTC_PSR_8B_tag PSR303; /* offset: 0x016F size: 8 bit */
16317  INTC_PSR_8B_tag PSR304; /* offset: 0x0170 size: 8 bit */
16318  INTC_PSR_8B_tag PSR305; /* offset: 0x0171 size: 8 bit */
16319  INTC_PSR_8B_tag PSR306; /* offset: 0x0172 size: 8 bit */
16320  INTC_PSR_8B_tag PSR307; /* offset: 0x0173 size: 8 bit */
16321  INTC_PSR_8B_tag PSR308; /* offset: 0x0174 size: 8 bit */
16322  INTC_PSR_8B_tag PSR309; /* offset: 0x0175 size: 8 bit */
16323  INTC_PSR_8B_tag PSR310; /* offset: 0x0176 size: 8 bit */
16324  INTC_PSR_8B_tag PSR311; /* offset: 0x0177 size: 8 bit */
16325  INTC_PSR_8B_tag PSR312; /* offset: 0x0178 size: 8 bit */
16326  INTC_PSR_8B_tag PSR313; /* offset: 0x0179 size: 8 bit */
16327  INTC_PSR_8B_tag PSR314; /* offset: 0x017A size: 8 bit */
16328  INTC_PSR_8B_tag PSR315; /* offset: 0x017B size: 8 bit */
16329  INTC_PSR_8B_tag PSR316; /* offset: 0x017C size: 8 bit */
16330  INTC_PSR_8B_tag PSR317; /* offset: 0x017D size: 8 bit */
16331  INTC_PSR_8B_tag PSR318; /* offset: 0x017E size: 8 bit */
16332  INTC_PSR_8B_tag PSR319; /* offset: 0x017F size: 8 bit */
16333  INTC_PSR_8B_tag PSR320; /* offset: 0x0180 size: 8 bit */
16334  INTC_PSR_8B_tag PSR321; /* offset: 0x0181 size: 8 bit */
16335  INTC_PSR_8B_tag PSR322; /* offset: 0x0182 size: 8 bit */
16336  INTC_PSR_8B_tag PSR323; /* offset: 0x0183 size: 8 bit */
16337  INTC_PSR_8B_tag PSR324; /* offset: 0x0184 size: 8 bit */
16338  INTC_PSR_8B_tag PSR325; /* offset: 0x0185 size: 8 bit */
16339  INTC_PSR_8B_tag PSR326; /* offset: 0x0186 size: 8 bit */
16340  INTC_PSR_8B_tag PSR327; /* offset: 0x0187 size: 8 bit */
16341  INTC_PSR_8B_tag PSR328; /* offset: 0x0188 size: 8 bit */
16342  INTC_PSR_8B_tag PSR329; /* offset: 0x0189 size: 8 bit */
16343  INTC_PSR_8B_tag PSR330; /* offset: 0x018A size: 8 bit */
16344  INTC_PSR_8B_tag PSR331; /* offset: 0x018B size: 8 bit */
16345  INTC_PSR_8B_tag PSR332; /* offset: 0x018C size: 8 bit */
16346  INTC_PSR_8B_tag PSR333; /* offset: 0x018D size: 8 bit */
16347  INTC_PSR_8B_tag PSR334; /* offset: 0x018E size: 8 bit */
16348  INTC_PSR_8B_tag PSR335; /* offset: 0x018F size: 8 bit */
16349  INTC_PSR_8B_tag PSR336; /* offset: 0x0190 size: 8 bit */
16350  INTC_PSR_8B_tag PSR337; /* offset: 0x0191 size: 8 bit */
16351  INTC_PSR_8B_tag PSR338; /* offset: 0x0192 size: 8 bit */
16352  INTC_PSR_8B_tag PSR339; /* offset: 0x0193 size: 8 bit */
16353  INTC_PSR_8B_tag PSR340; /* offset: 0x0194 size: 8 bit */
16354  INTC_PSR_8B_tag PSR341; /* offset: 0x0195 size: 8 bit */
16355  INTC_PSR_8B_tag PSR342; /* offset: 0x0196 size: 8 bit */
16356  INTC_PSR_8B_tag PSR343; /* offset: 0x0197 size: 8 bit */
16357  INTC_PSR_8B_tag PSR344; /* offset: 0x0198 size: 8 bit */
16358  INTC_PSR_8B_tag PSR345; /* offset: 0x0199 size: 8 bit */
16359  INTC_PSR_8B_tag PSR346; /* offset: 0x019A size: 8 bit */
16360  INTC_PSR_8B_tag PSR347; /* offset: 0x019B size: 8 bit */
16361  INTC_PSR_8B_tag PSR348; /* offset: 0x019C size: 8 bit */
16362  INTC_PSR_8B_tag PSR349; /* offset: 0x019D size: 8 bit */
16363  INTC_PSR_8B_tag PSR350; /* offset: 0x019E size: 8 bit */
16364  INTC_PSR_8B_tag PSR351; /* offset: 0x019F size: 8 bit */
16365  INTC_PSR_8B_tag PSR352; /* offset: 0x01A0 size: 8 bit */
16366  INTC_PSR_8B_tag PSR353; /* offset: 0x01A1 size: 8 bit */
16367  INTC_PSR_8B_tag PSR354; /* offset: 0x01A2 size: 8 bit */
16368  INTC_PSR_8B_tag PSR355; /* offset: 0x01A3 size: 8 bit */
16369  INTC_PSR_8B_tag PSR356; /* offset: 0x01A4 size: 8 bit */
16370  INTC_PSR_8B_tag PSR357; /* offset: 0x01A5 size: 8 bit */
16371  INTC_PSR_8B_tag PSR358; /* offset: 0x01A6 size: 8 bit */
16372  INTC_PSR_8B_tag PSR359; /* offset: 0x01A7 size: 8 bit */
16373  INTC_PSR_8B_tag PSR360; /* offset: 0x01A8 size: 8 bit */
16374  INTC_PSR_8B_tag PSR361; /* offset: 0x01A9 size: 8 bit */
16375  INTC_PSR_8B_tag PSR362; /* offset: 0x01AA size: 8 bit */
16376  INTC_PSR_8B_tag PSR363; /* offset: 0x01AB size: 8 bit */
16377  INTC_PSR_8B_tag PSR364; /* offset: 0x01AC size: 8 bit */
16378  INTC_PSR_8B_tag PSR365; /* offset: 0x01AD size: 8 bit */
16379  INTC_PSR_8B_tag PSR366; /* offset: 0x01AE size: 8 bit */
16380  INTC_PSR_8B_tag PSR367; /* offset: 0x01AF size: 8 bit */
16381  INTC_PSR_8B_tag PSR368; /* offset: 0x01B0 size: 8 bit */
16382  INTC_PSR_8B_tag PSR369; /* offset: 0x01B1 size: 8 bit */
16383  INTC_PSR_8B_tag PSR370; /* offset: 0x01B2 size: 8 bit */
16384  INTC_PSR_8B_tag PSR371; /* offset: 0x01B3 size: 8 bit */
16385  INTC_PSR_8B_tag PSR372; /* offset: 0x01B4 size: 8 bit */
16386  INTC_PSR_8B_tag PSR373; /* offset: 0x01B5 size: 8 bit */
16387  INTC_PSR_8B_tag PSR374; /* offset: 0x01B6 size: 8 bit */
16388  INTC_PSR_8B_tag PSR375; /* offset: 0x01B7 size: 8 bit */
16389  INTC_PSR_8B_tag PSR376; /* offset: 0x01B8 size: 8 bit */
16390  INTC_PSR_8B_tag PSR377; /* offset: 0x01B9 size: 8 bit */
16391  INTC_PSR_8B_tag PSR378; /* offset: 0x01BA size: 8 bit */
16392  INTC_PSR_8B_tag PSR379; /* offset: 0x01BB size: 8 bit */
16393  INTC_PSR_8B_tag PSR380; /* offset: 0x01BC size: 8 bit */
16394  INTC_PSR_8B_tag PSR381; /* offset: 0x01BD size: 8 bit */
16395  INTC_PSR_8B_tag PSR382; /* offset: 0x01BE size: 8 bit */
16396  INTC_PSR_8B_tag PSR383; /* offset: 0x01BF size: 8 bit */
16397  INTC_PSR_8B_tag PSR384; /* offset: 0x01C0 size: 8 bit */
16398  INTC_PSR_8B_tag PSR385; /* offset: 0x01C1 size: 8 bit */
16399  INTC_PSR_8B_tag PSR386; /* offset: 0x01C2 size: 8 bit */
16400  INTC_PSR_8B_tag PSR387; /* offset: 0x01C3 size: 8 bit */
16401  INTC_PSR_8B_tag PSR388; /* offset: 0x01C4 size: 8 bit */
16402  INTC_PSR_8B_tag PSR389; /* offset: 0x01C5 size: 8 bit */
16403  INTC_PSR_8B_tag PSR390; /* offset: 0x01C6 size: 8 bit */
16404  INTC_PSR_8B_tag PSR391; /* offset: 0x01C7 size: 8 bit */
16405  INTC_PSR_8B_tag PSR392; /* offset: 0x01C8 size: 8 bit */
16406  INTC_PSR_8B_tag PSR393; /* offset: 0x01C9 size: 8 bit */
16407  INTC_PSR_8B_tag PSR394; /* offset: 0x01CA size: 8 bit */
16408  INTC_PSR_8B_tag PSR395; /* offset: 0x01CB size: 8 bit */
16409  INTC_PSR_8B_tag PSR396; /* offset: 0x01CC size: 8 bit */
16410  INTC_PSR_8B_tag PSR397; /* offset: 0x01CD size: 8 bit */
16411  INTC_PSR_8B_tag PSR398; /* offset: 0x01CE size: 8 bit */
16412  INTC_PSR_8B_tag PSR399; /* offset: 0x01CF size: 8 bit */
16413  INTC_PSR_8B_tag PSR400; /* offset: 0x01D0 size: 8 bit */
16414  INTC_PSR_8B_tag PSR401; /* offset: 0x01D1 size: 8 bit */
16415  INTC_PSR_8B_tag PSR402; /* offset: 0x01D2 size: 8 bit */
16416  INTC_PSR_8B_tag PSR403; /* offset: 0x01D3 size: 8 bit */
16417  INTC_PSR_8B_tag PSR404; /* offset: 0x01D4 size: 8 bit */
16418  INTC_PSR_8B_tag PSR405; /* offset: 0x01D5 size: 8 bit */
16419  INTC_PSR_8B_tag PSR406; /* offset: 0x01D6 size: 8 bit */
16420  INTC_PSR_8B_tag PSR407; /* offset: 0x01D7 size: 8 bit */
16421  INTC_PSR_8B_tag PSR408; /* offset: 0x01D8 size: 8 bit */
16422  INTC_PSR_8B_tag PSR409; /* offset: 0x01D9 size: 8 bit */
16423  INTC_PSR_8B_tag PSR410; /* offset: 0x01DA size: 8 bit */
16424  INTC_PSR_8B_tag PSR411; /* offset: 0x01DB size: 8 bit */
16425  INTC_PSR_8B_tag PSR412; /* offset: 0x01DC size: 8 bit */
16426  INTC_PSR_8B_tag PSR413; /* offset: 0x01DD size: 8 bit */
16427  INTC_PSR_8B_tag PSR414; /* offset: 0x01DE size: 8 bit */
16428  INTC_PSR_8B_tag PSR415; /* offset: 0x01DF size: 8 bit */
16429  INTC_PSR_8B_tag PSR416; /* offset: 0x01E0 size: 8 bit */
16430  INTC_PSR_8B_tag PSR417; /* offset: 0x01E1 size: 8 bit */
16431  INTC_PSR_8B_tag PSR418; /* offset: 0x01E2 size: 8 bit */
16432  INTC_PSR_8B_tag PSR419; /* offset: 0x01E3 size: 8 bit */
16433  INTC_PSR_8B_tag PSR420; /* offset: 0x01E4 size: 8 bit */
16434  INTC_PSR_8B_tag PSR421; /* offset: 0x01E5 size: 8 bit */
16435  INTC_PSR_8B_tag PSR422; /* offset: 0x01E6 size: 8 bit */
16436  INTC_PSR_8B_tag PSR423; /* offset: 0x01E7 size: 8 bit */
16437  INTC_PSR_8B_tag PSR424; /* offset: 0x01E8 size: 8 bit */
16438  INTC_PSR_8B_tag PSR425; /* offset: 0x01E9 size: 8 bit */
16439  INTC_PSR_8B_tag PSR426; /* offset: 0x01EA size: 8 bit */
16440  INTC_PSR_8B_tag PSR427; /* offset: 0x01EB size: 8 bit */
16441  INTC_PSR_8B_tag PSR428; /* offset: 0x01EC size: 8 bit */
16442  INTC_PSR_8B_tag PSR429; /* offset: 0x01ED size: 8 bit */
16443  INTC_PSR_8B_tag PSR430; /* offset: 0x01EE size: 8 bit */
16444  INTC_PSR_8B_tag PSR431; /* offset: 0x01EF size: 8 bit */
16445  INTC_PSR_8B_tag PSR432; /* offset: 0x01F0 size: 8 bit */
16446  INTC_PSR_8B_tag PSR433; /* offset: 0x01F1 size: 8 bit */
16447  INTC_PSR_8B_tag PSR434; /* offset: 0x01F2 size: 8 bit */
16448  INTC_PSR_8B_tag PSR435; /* offset: 0x01F3 size: 8 bit */
16449  INTC_PSR_8B_tag PSR436; /* offset: 0x01F4 size: 8 bit */
16450  INTC_PSR_8B_tag PSR437; /* offset: 0x01F5 size: 8 bit */
16451  INTC_PSR_8B_tag PSR438; /* offset: 0x01F6 size: 8 bit */
16452  INTC_PSR_8B_tag PSR439; /* offset: 0x01F7 size: 8 bit */
16453  INTC_PSR_8B_tag PSR440; /* offset: 0x01F8 size: 8 bit */
16454  INTC_PSR_8B_tag PSR441; /* offset: 0x01F9 size: 8 bit */
16455  INTC_PSR_8B_tag PSR442; /* offset: 0x01FA size: 8 bit */
16456  INTC_PSR_8B_tag PSR443; /* offset: 0x01FB size: 8 bit */
16457  INTC_PSR_8B_tag PSR444; /* offset: 0x01FC size: 8 bit */
16458  INTC_PSR_8B_tag PSR445; /* offset: 0x01FD size: 8 bit */
16459  INTC_PSR_8B_tag PSR446; /* offset: 0x01FE size: 8 bit */
16460  INTC_PSR_8B_tag PSR447; /* offset: 0x01FF size: 8 bit */
16461  INTC_PSR_8B_tag PSR448; /* offset: 0x0200 size: 8 bit */
16462  INTC_PSR_8B_tag PSR449; /* offset: 0x0201 size: 8 bit */
16463  INTC_PSR_8B_tag PSR450; /* offset: 0x0202 size: 8 bit */
16464  INTC_PSR_8B_tag PSR451; /* offset: 0x0203 size: 8 bit */
16465  INTC_PSR_8B_tag PSR452; /* offset: 0x0204 size: 8 bit */
16466  INTC_PSR_8B_tag PSR453; /* offset: 0x0205 size: 8 bit */
16467  INTC_PSR_8B_tag PSR454; /* offset: 0x0206 size: 8 bit */
16468  INTC_PSR_8B_tag PSR455; /* offset: 0x0207 size: 8 bit */
16469  INTC_PSR_8B_tag PSR456; /* offset: 0x0208 size: 8 bit */
16470  INTC_PSR_8B_tag PSR457; /* offset: 0x0209 size: 8 bit */
16471  INTC_PSR_8B_tag PSR458; /* offset: 0x020A size: 8 bit */
16472  INTC_PSR_8B_tag PSR459; /* offset: 0x020B size: 8 bit */
16473  INTC_PSR_8B_tag PSR460; /* offset: 0x020C size: 8 bit */
16474  INTC_PSR_8B_tag PSR461; /* offset: 0x020D size: 8 bit */
16475  INTC_PSR_8B_tag PSR462; /* offset: 0x020E size: 8 bit */
16476  INTC_PSR_8B_tag PSR463; /* offset: 0x020F size: 8 bit */
16477  INTC_PSR_8B_tag PSR464; /* offset: 0x0210 size: 8 bit */
16478  INTC_PSR_8B_tag PSR465; /* offset: 0x0211 size: 8 bit */
16479  INTC_PSR_8B_tag PSR466; /* offset: 0x0212 size: 8 bit */
16480  INTC_PSR_8B_tag PSR467; /* offset: 0x0213 size: 8 bit */
16481  INTC_PSR_8B_tag PSR468; /* offset: 0x0214 size: 8 bit */
16482  INTC_PSR_8B_tag PSR469; /* offset: 0x0215 size: 8 bit */
16483  INTC_PSR_8B_tag PSR470; /* offset: 0x0216 size: 8 bit */
16484  INTC_PSR_8B_tag PSR471; /* offset: 0x0217 size: 8 bit */
16485  INTC_PSR_8B_tag PSR472; /* offset: 0x0218 size: 8 bit */
16486  INTC_PSR_8B_tag PSR473; /* offset: 0x0219 size: 8 bit */
16487  INTC_PSR_8B_tag PSR474; /* offset: 0x021A size: 8 bit */
16488  INTC_PSR_8B_tag PSR475; /* offset: 0x021B size: 8 bit */
16489  INTC_PSR_8B_tag PSR476; /* offset: 0x021C size: 8 bit */
16490  INTC_PSR_8B_tag PSR477; /* offset: 0x021D size: 8 bit */
16491  INTC_PSR_8B_tag PSR478; /* offset: 0x021E size: 8 bit */
16492  INTC_PSR_8B_tag PSR479; /* offset: 0x021F size: 8 bit */
16493  INTC_PSR_8B_tag PSR480; /* offset: 0x0220 size: 8 bit */
16494  INTC_PSR_8B_tag PSR481; /* offset: 0x0221 size: 8 bit */
16495  INTC_PSR_8B_tag PSR482; /* offset: 0x0222 size: 8 bit */
16496  INTC_PSR_8B_tag PSR483; /* offset: 0x0223 size: 8 bit */
16497  INTC_PSR_8B_tag PSR484; /* offset: 0x0224 size: 8 bit */
16498  INTC_PSR_8B_tag PSR485; /* offset: 0x0225 size: 8 bit */
16499  INTC_PSR_8B_tag PSR486; /* offset: 0x0226 size: 8 bit */
16500  INTC_PSR_8B_tag PSR487; /* offset: 0x0227 size: 8 bit */
16501  INTC_PSR_8B_tag PSR488; /* offset: 0x0228 size: 8 bit */
16502  INTC_PSR_8B_tag PSR489; /* offset: 0x0229 size: 8 bit */
16503  INTC_PSR_8B_tag PSR490; /* offset: 0x022A size: 8 bit */
16504  INTC_PSR_8B_tag PSR491; /* offset: 0x022B size: 8 bit */
16505  INTC_PSR_8B_tag PSR492; /* offset: 0x022C size: 8 bit */
16506  INTC_PSR_8B_tag PSR493; /* offset: 0x022D size: 8 bit */
16507  INTC_PSR_8B_tag PSR494; /* offset: 0x022E size: 8 bit */
16508  INTC_PSR_8B_tag PSR495; /* offset: 0x022F size: 8 bit */
16509  INTC_PSR_8B_tag PSR496; /* offset: 0x0230 size: 8 bit */
16510  INTC_PSR_8B_tag PSR497; /* offset: 0x0231 size: 8 bit */
16511  INTC_PSR_8B_tag PSR498; /* offset: 0x0232 size: 8 bit */
16512  INTC_PSR_8B_tag PSR499; /* offset: 0x0233 size: 8 bit */
16513  INTC_PSR_8B_tag PSR500; /* offset: 0x0234 size: 8 bit */
16514  INTC_PSR_8B_tag PSR501; /* offset: 0x0235 size: 8 bit */
16515  INTC_PSR_8B_tag PSR502; /* offset: 0x0236 size: 8 bit */
16516  INTC_PSR_8B_tag PSR503; /* offset: 0x0237 size: 8 bit */
16517  INTC_PSR_8B_tag PSR504; /* offset: 0x0238 size: 8 bit */
16518  INTC_PSR_8B_tag PSR505; /* offset: 0x0239 size: 8 bit */
16519  INTC_PSR_8B_tag PSR506; /* offset: 0x023A size: 8 bit */
16520  INTC_PSR_8B_tag PSR507; /* offset: 0x023B size: 8 bit */
16521  INTC_PSR_8B_tag PSR508; /* offset: 0x023C size: 8 bit */
16522  INTC_PSR_8B_tag PSR509; /* offset: 0x023D size: 8 bit */
16523  INTC_PSR_8B_tag PSR510; /* offset: 0x023E size: 8 bit */
16524  INTC_PSR_8B_tag PSR511; /* offset: 0x023F size: 8 bit */
16525  };
16526
16527  };
16528  } INTC_tag;
16529
16530
16531 #define INTC (*(volatile INTC_tag *) 0xFFF48000UL)
16532
16533
16534
16535 /****************************************************************/
16536 /* */
16537 /* Module: DSPI */
16538 /* */
16539 /****************************************************************/
16540
16541  typedef union DSPI_MCR_tag { /* MCR - Module Configuration Register */
16542  uint32_t R;
16543  struct {
16544  uint32_t MSTR:1; /* Master/Slave mode select */
16545  uint32_t CONT_SCKE:1; /* Continuous SCK Enable */
16546  uint32_t DCONF:2; /* DSPI Configuration */
16547  uint32_t FRZ:1; /* Freeze */
16548  uint32_t MTFE:1; /* Modified Timing Format Enable */
16549  uint32_t PCSSE:1; /* Peripheral Chip Select Strobe Enable */
16550  uint32_t ROOE:1; /* Receive FIFO Overflow Overwrite Enable */
16551  uint32_t PCSIS7:1; /* Peripheral Chip Select 7 Inactive State */
16552  uint32_t PCSIS6:1; /* Peripheral Chip Select 6 Inactive State */
16553  uint32_t PCSIS5:1; /* Peripheral Chip Select 5 Inactive State */
16554  uint32_t PCSIS4:1; /* Peripheral Chip Select 4 Inactive State */
16555  uint32_t PCSIS3:1; /* Peripheral Chip Select 3 Inactive State */
16556  uint32_t PCSIS2:1; /* Peripheral Chip Select 2 Inactive State */
16557  uint32_t PCSIS1:1; /* Peripheral Chip Select 1 Inactive State */
16558  uint32_t PCSIS0:1; /* Peripheral Chip Select 0 Inactive State */
16559  uint32_t DOZE:1; /* Doze Enable */
16560  uint32_t MDIS:1; /* Module Disable */
16561  uint32_t DIS_TXF:1; /* Disable Transmit FIFO */
16562  uint32_t DIS_RXF:1; /* Disable Receive FIFO */
16563  uint32_t CLR_TXF:1; /* Clear TX FIFO */
16564  uint32_t CLR_RXF:1; /* Clear RX FIFO */
16565  uint32_t SMPL_PT:2; /* Sample Point */
16566  uint32_t:7;
16567  uint32_t HALT:1; /* Halt */
16568  } B;
16569  } DSPI_MCR_32B_tag;
16570
16571  typedef union { /* TCR - Transfer Count Register */
16572  uint32_t R;
16573  struct {
16574 #ifndef USE_FIELD_ALIASES_DSPI
16575  uint32_t SPI_TCNT:16; /* SPI Transfer Counter */
16576 #else
16577  uint32_t TCNT:16; /* deprecated name - please avoid */
16578 #endif
16579  uint32_t:16;
16580  } B;
16581  } DSPI_TCR_32B_tag;
16582
16583
16584  /* Register layout for all registers CTAR... */
16585
16586  typedef union DSPI_CTAR_tag { /* CTAR0-7 - Clock and Transfer Attribute Registers */
16587  uint32_t R;
16588  struct {
16589  uint32_t DBR:1; /* Double Baud Rate */
16590  uint32_t FMSZ:4; /* Frame Size */
16591  uint32_t CPOL:1; /* Clock Polarity */
16592  uint32_t CPHA:1; /* Clock Phase */
16593  uint32_t LSBFE:1; /* LSB First Enable */
16594  uint32_t PCSSCK:2; /* PCS to SCK Delay Prescaler */
16595  uint32_t PASC:2; /* After SCK Delay Prescaler */
16596  uint32_t PDT:2; /* Delay after Transfer Prescaler */
16597  uint32_t PBR:2; /* Baud Rate Prescaler */
16598  uint32_t CSSCK:4; /* PCS to SCK Delay Scaler */
16599  uint32_t ASC:4; /* After SCK Delay Scaler */
16600  uint32_t DT:4; /* Delay after Transfer Scaler */
16601  uint32_t BR:4; /* Baud Rate Scaler */
16602  } B;
16604
16605  typedef union DSPI_SR_tag { /* SR - Status Register */
16606  uint32_t R;
16607  struct {
16608  uint32_t TCF:1; /* Transfer Complete Flag */
16609  uint32_t TXRXS:1; /* TX & RX Status */
16610  uint32_t:1;
16611  uint32_t EOQF:1; /* End of queue Flag */
16612  uint32_t TFUF:1; /* Transmit FIFO Underflow Flag */
16613  uint32_t:1;
16614  uint32_t TFFF:1; /* Transmit FIFO FIll Flag */
16615  uint32_t:5;
16616  uint32_t RFOF:1; /* Receive FIFO Overflow Flag */
16617  uint32_t:1;
16618  uint32_t RFDF:1; /* Receive FIFO Drain Flag */
16619  uint32_t:1;
16620  uint32_t TXCTR:4; /* TX FIFO Counter */
16621  uint32_t TXNXTPTR:4; /* Transmit Next Pointer */
16622  uint32_t RXCTR:4; /* RX FIFO Counter */
16623  uint32_t POPNXTPTR:4; /* Pop Next Pointer */
16624  } B;
16625  } DSPI_SR_32B_tag;
16626
16627  typedef union DSPI_RSER_tag { /* RSER - DMA/Interrupt Request Register */
16628  uint32_t R;
16629  struct {
16630 #ifndef USE_FIELD_ALIASES_DSPI
16631  uint32_t TCF_RE:1; /* Transmission Complete Request Enable */
16632 #else
16633  uint32_t TCFRE:1; /* deprecated name - please avoid */
16634 #endif
16635  uint32_t:2;
16636 #ifndef USE_FIELD_ALIASES_DSPI
16637  uint32_t EOQF_RE:1; /* DSPI Finished Request Enable */
16638 #else
16639  uint32_t EOQFRE:1; /* deprecated name - please avoid */
16640 #endif
16641 #ifndef USE_FIELD_ALIASES_DSPI
16642  uint32_t TFUF_RE:1; /* Transmit FIFO Underflow Request Enable */
16643 #else
16644  uint32_t TFUFRE:1; /* deprecated name - please avoid */
16645 #endif
16646  uint32_t:1;
16647 #ifndef USE_FIELD_ALIASES_DSPI
16648  uint32_t TFFF_RE:1; /* Transmit FIFO Fill Request Enable */
16649 #else
16650  uint32_t TFFFRE:1; /* deprecated name - please avoid */
16651 #endif
16652 #ifndef USE_FIELD_ALIASES_DSPI
16653  uint32_t TFFF_DIRS:1; /* Transmit FIFO Fill DMA or Interrupt Request Select */
16654 #else
16655  uint32_t TFFFDIRS:1; /* deprecated name - please avoid */
16656 #endif
16657  uint32_t:4;
16658 #ifndef USE_FIELD_ALIASES_DSPI
16659  uint32_t RFOF_RE:1; /* Receive FIFO overflow Request Enable */
16660 #else
16661  uint32_t RFOFRE:1; /* deprecated name - please avoid */
16662 #endif
16663  uint32_t:1;
16664 #ifndef USE_FIELD_ALIASES_DSPI
16665  uint32_t RFDF_RE:1; /* Receive FIFO Drain Request Enable */
16666 #else
16667  uint32_t RFDFRE:1; /* deprecated name - please avoid */
16668 #endif
16669 #ifndef USE_FIELD_ALIASES_DSPI
16670  uint32_t RFDF_DIRS:1; /* Receive FIFO Drain DMA or Interrupt Request Select */
16671 #else
16672  uint32_t RFDFDIRS:1; /* deprecated name - please avoid */
16673 #endif
16674  uint32_t:16;
16675  } B;
16677
16678  typedef union DSPI_PUSHR_tag { /* PUSHR - PUSH TX FIFO Register */
16679  uint32_t R;
16680  struct {
16681  uint32_t CONT:1; /* Continuous Peripheral Chip Select Enable */
16682  uint32_t CTAS:3; /* Clock and Transfer Attributes Select */
16683  uint32_t EOQ:1; /* End of Queue */
16684  uint32_t CTCNT:1; /* Clear SPI_TCNT */
16685  uint32_t:2;
16686  uint32_t PCS7:1; /* Peripheral Chip Select 7 */
16687  uint32_t PCS6:1; /* Peripheral Chip Select 6 */
16688  uint32_t PCS5:1; /* Peripheral Chip Select 5 */
16689  uint32_t PCS4:1; /* Peripheral Chip Select 4 */
16690  uint32_t PCS3:1; /* Peripheral Chip Select 3 */
16691  uint32_t PCS2:1; /* Peripheral Chip Select 2 */
16692  uint32_t PCS1:1; /* Peripheral Chip Select 1 */
16693  uint32_t PCS0:1; /* Peripheral Chip Select 0 */
16694  uint32_t TXDATA:16; /* Transmit Data */
16695  } B;
16697
16698  typedef union DSPI_POPR_tag { /* POPR - POP RX FIFO Register */
16699  uint32_t R;
16700  struct {
16701  uint32_t:16;
16702  uint32_t RXDATA:16; /* Receive Data */
16703  } B;
16705
16706
16707  /* Register layout for all registers TXFR... */
16708
16709  typedef union { /* Transmit FIFO Registers */
16710  uint32_t R;
16711  struct {
16712 #ifndef USE_FIELD_ALIASES_DSPI
16713  uint32_t FIFO_TXCMD:16; /* Transmit Command */
16714 #else
16715  uint32_t TXCMD:16; /* deprecated name - please avoid */
16716 #endif
16717 #ifndef USE_FIELD_ALIASES_DSPI
16718  uint32_t FIFO_TXDATA:16; /* Transmit Data */
16719 #else
16720  uint32_t TXDATA:16; /* deprecated name - please avoid */
16721 #endif
16722  } B;
16724
16725
16726  /* Register layout for all registers RXFR... */
16727
16728  typedef union { /* Receive FIFO Registers */
16729  uint32_t R;
16730  struct {
16731  uint32_t:16;
16732 #ifndef USE_FIELD_ALIASES_DSPI
16733  uint32_t FIFO_RXDATA:16; /* Transmit Data */
16734 #else
16735  uint32_t RXDATA:16; /* deprecated name - please avoid */
16736 #endif
16737  } B;
16739
16740  typedef union { /* DSICR - DSI Configuration Register */
16741  uint32_t R;
16742  struct {
16743  uint32_t MTOE:1; /* Multiple Transfer Operation Enable */
16744  uint32_t:1;
16745  uint32_t MTOCNT:6; /* Multiple Transfer Operation Count */
16746  uint32_t:4;
16747  uint32_t TXSS:1; /* Transmit Data Source Select */
16748  uint32_t TPOL:1; /* Trigger Polarity */
16749  uint32_t TRRE:1; /* Trigger Reception Enable */
16750  uint32_t CID:1; /* Change in Data Transfer Enable */
16751  uint32_t DCONT:1; /* DSI Continuous Peripheral Chip Select Enable */
16752  uint32_t DSICTAS:3; /* DSI CLock and Transfer Attributes Select */
16753  uint32_t:4;
16754  uint32_t DPCS7:1; /* DSI Peripheral Chip Select 7 */
16755  uint32_t DPCS6:1; /* DSI Peripheral Chip Select 6 */
16756  uint32_t DPCS5:1; /* DSI Peripheral Chip Select 5 */
16757  uint32_t DPCS4:1; /* DSI Peripheral Chip Select 4 */
16758  uint32_t DPCS3:1; /* DSI Peripheral Chip Select 3 */
16759  uint32_t DPCS2:1; /* DSI Peripheral Chip Select 2 */
16760  uint32_t DPCS1:1; /* DSI Peripheral Chip Select 1 */
16761  uint32_t DPCS0:1; /* DSI Peripheral Chip Select 0 */
16762  } B;
16764
16765  typedef union { /* SDR - DSI Serialization Data Register */
16766  uint32_t R;
16767  struct {
16768  uint32_t:16;
16769  uint32_t SER_DATA:16; /* Serialized Data */
16770  } B;
16771  } DSPI_SDR_32B_tag;
16772
16773  typedef union { /* ASDR - DSI Alternate Serialization Data Register */
16774  uint32_t R;
16775  struct {
16776  uint32_t:16;
16777  uint32_t ASER_DATA:16; /* Alternate Serialized Data */
16778  } B;
16780
16781  typedef union { /* COMPR - DSI Transmit Comparison Register */
16782  uint32_t R;
16783  struct {
16784  uint32_t:16;
16785  uint32_t COMP_DATA:16; /* Compare Data */
16786  } B;
16788
16789  typedef union { /* DDR - DSI Deserialization Data Register */
16790  uint32_t R;
16791  struct {
16792  uint32_t:16;
16793  uint32_t DESER_DATA:16; /* Deserialized Data */
16794  } B;
16795  } DSPI_DDR_32B_tag;
16796
16797  typedef union { /* DSICR1 - DSI Configuration Register 1 */
16798  uint32_t R;
16800
16801
16802
16803  typedef struct DSPI_tag { /* start of DSPI_tag */
16804  /* MCR - Module Configuration Register */
16805  DSPI_MCR_32B_tag MCR; /* offset: 0x0000 size: 32 bit */
16806  int8_t DSPI_reserved_0004[4];
16807  /* TCR - Transfer Count Register */
16808  DSPI_TCR_32B_tag TCR; /* offset: 0x0008 size: 32 bit */
16809  union {
16810  /* CTAR0-7 - Clock and Transfer Attribute Registers */
16811  DSPI_CTAR_32B_tag CTAR[8]; /* offset: 0x000C (0x0004 x 8) */
16812
16813  struct {
16814  /* CTAR0-7 - Clock and Transfer Attribute Registers */
16815  DSPI_CTAR_32B_tag CTAR0; /* offset: 0x000C size: 32 bit */
16816  DSPI_CTAR_32B_tag CTAR1; /* offset: 0x0010 size: 32 bit */
16817  DSPI_CTAR_32B_tag CTAR2; /* offset: 0x0014 size: 32 bit */
16818  DSPI_CTAR_32B_tag CTAR3; /* offset: 0x0018 size: 32 bit */
16819  DSPI_CTAR_32B_tag CTAR4; /* offset: 0x001C size: 32 bit */
16820  DSPI_CTAR_32B_tag CTAR5; /* offset: 0x0020 size: 32 bit */
16821  DSPI_CTAR_32B_tag CTAR6; /* offset: 0x0024 size: 32 bit */
16822  DSPI_CTAR_32B_tag CTAR7; /* offset: 0x0028 size: 32 bit */
16823  };
16824
16825  };
16826  /* SR - Status Register */
16827  DSPI_SR_32B_tag SR; /* offset: 0x002C size: 32 bit */
16828  /* RSER - DMA/Interrupt Request Register */
16829  DSPI_RSER_32B_tag RSER; /* offset: 0x0030 size: 32 bit */
16830  /* PUSHR - PUSH TX FIFO Register */
16831  DSPI_PUSHR_32B_tag PUSHR; /* offset: 0x0034 size: 32 bit */
16832  /* POPR - POP RX FIFO Register */
16833  DSPI_POPR_32B_tag POPR; /* offset: 0x0038 size: 32 bit */
16834  union {
16835  /* Transmit FIFO Registers */
16836  DSPI_TXFR_32B_tag TXFR[5]; /* offset: 0x003C (0x0004 x 5) */
16837
16838  struct {
16839  /* Transmit FIFO Registers */
16840  DSPI_TXFR_32B_tag TXFR0; /* offset: 0x003C size: 32 bit */
16841  DSPI_TXFR_32B_tag TXFR1; /* offset: 0x0040 size: 32 bit */
16842  DSPI_TXFR_32B_tag TXFR2; /* offset: 0x0044 size: 32 bit */
16843  DSPI_TXFR_32B_tag TXFR3; /* offset: 0x0048 size: 32 bit */
16844  DSPI_TXFR_32B_tag TXFR4; /* offset: 0x004C size: 32 bit */
16845  };
16846
16847  };
16848  int8_t DSPI_reserved_0050_C[44];
16849  union {
16850  /* Receive FIFO Registers */
16851  DSPI_RXFR_32B_tag RXFR[5]; /* offset: 0x007C (0x0004 x 5) */
16852
16853  struct {
16854  /* Receive FIFO Registers */
16855  DSPI_RXFR_32B_tag RXFR0; /* offset: 0x007C size: 32 bit */
16856  DSPI_RXFR_32B_tag RXFR1; /* offset: 0x0080 size: 32 bit */
16857  DSPI_RXFR_32B_tag RXFR2; /* offset: 0x0084 size: 32 bit */
16858  DSPI_RXFR_32B_tag RXFR3; /* offset: 0x0088 size: 32 bit */
16859  DSPI_RXFR_32B_tag RXFR4; /* offset: 0x008C size: 32 bit */
16860  };
16861
16862  };
16863  int8_t DSPI_reserved_0090[44];
16864  /* DSICR - DSI Configuration Register */
16865  DSPI_DSICR_32B_tag DSICR; /* offset: 0x00BC size: 32 bit */
16866  /* SDR - DSI Serialization Data Register */
16867  DSPI_SDR_32B_tag SDR; /* offset: 0x00C0 size: 32 bit */
16868  /* ASDR - DSI Alternate Serialization Data Register */
16869  DSPI_ASDR_32B_tag ASDR; /* offset: 0x00C4 size: 32 bit */
16870  /* COMPR - DSI Transmit Comparison Register */
16871  DSPI_COMPR_32B_tag COMPR; /* offset: 0x00C8 size: 32 bit */
16872  /* DDR - DSI Deserialization Data Register */
16873  DSPI_DDR_32B_tag DDR; /* offset: 0x00CC size: 32 bit */
16874  /* DSICR1 - DSI Configuration Register 1 */
16875  DSPI_DSICR1_32B_tag DSICR1; /* offset: 0x00D0 size: 32 bit */
16876  } DSPI_tag;
16877
16878
16879 #define DSPI_A (*(volatile DSPI_tag *) 0xFFF90000UL)
16880 #define DSPI_B (*(volatile DSPI_tag *) 0xFFF94000UL)
16881 #define DSPI_C (*(volatile DSPI_tag *) 0xFFF98000UL)
16882
16883
16884
16885 /****************************************************************/
16886 /* */
16887 /* Module: FLEXCAN */
16888 /* */
16889 /****************************************************************/
16890
16891  typedef union { /* MCR - Module Configuration Register */
16892  uint32_t R;
16893  struct {
16894  uint32_t MDIS:1; /* Module Disable */
16895  uint32_t FRZ:1; /* Freeze Enable */
16896  uint32_t FEN:1; /* FIFO Enable */
16897  uint32_t HALT:1; /* Halt Flexcan */
16898 #ifndef USE_FIELD_ALIASES_FLEXCAN
16899  uint32_t NOT_RDY:1; /* Flexcan Not Ready */
16900 #else
16901  uint32_t NOTRDY:1; /* deprecated name - please avoid */
16902 #endif
16903 #ifndef USE_FIELD_ALIASES_FLEXCAN
16904  uint32_t WAK_MSK:1; /* Wake Up Interrupt Mask */
16905 #else
16906  uint32_t WAKMSK:1; /* deprecated name - please avoid */
16907 #endif
16908 #ifndef USE_FIELD_ALIASES_FLEXCAN
16909  uint32_t SOFT_RST:1; /* Soft Reset */
16910 #else
16911  uint32_t SOFTRST:1; /* deprecated name - please avoid */
16912 #endif
16913 #ifndef USE_FIELD_ALIASES_FLEXCAN
16914  uint32_t FRZ_ACK:1; /* Freeze Mode Acknowledge */
16915 #else
16916  uint32_t FRZACK:1; /* deprecated name - please avoid */
16917 #endif
16918  uint32_t SUPV:1; /* Supervisor Mode */
16919 #ifndef USE_FIELD_ALIASES_FLEXCAN
16920  uint32_t SLF_WAK:1; /* Self Wake Up */
16921 #else
16922  uint32_t SLFWAK:1; /* deprecated name - please avoid */
16923 #endif
16924 #ifndef USE_FIELD_ALIASES_FLEXCAN
16925  uint32_t WRN_EN:1; /* Warning Interrupt Enable */
16926 #else
16927  uint32_t WRNEN:1; /* deprecated name - please avoid */
16928 #endif
16929 #ifndef USE_FIELD_ALIASES_FLEXCAN
16930  uint32_t LPM_ACK:1; /* Low Power Mode Acknowledge */
16931 #else
16932  uint32_t LPMACK:1; /* deprecated name - please avoid */
16933 #endif
16934 #ifndef USE_FIELD_ALIASES_FLEXCAN
16935  uint32_t WAK_SRC:1; /* Wake Up Source */
16936 #else
16937  uint32_t WAKSRC:1; /* deprecated name - please avoid */
16938 #endif
16939  uint32_t DOZE:1; /* Doze Mode Enable */
16940 #ifndef USE_FIELD_ALIASES_FLEXCAN
16941  uint32_t SRX_DIS:1; /* Self Reception Disable */
16942 #else
16943  uint32_t SRXDIS:1; /* deprecated name - please avoid */
16944 #endif
16945  uint32_t BCC:1; /* Backwards Compatibility Configuration */
16946  uint32_t:2;
16947  uint32_t LPRIO_EN:1; /* Local Priority Enable */
16948  uint32_t AEN:1; /* Abort Enable */
16949  uint32_t:2;
16950  uint32_t IDAM:2; /* ID Acceptance Mode */
16951  uint32_t:2;
16952  uint32_t MAXMB:6; /* Maximum Number of Message Buffers */
16953  } B;
16955
16956  typedef union { /* CTRL - Control Register */
16957  uint32_t R;
16958  struct {
16959  uint32_t PRESDIV:8; /* Prescaler Divsion Factor */
16960  uint32_t RJW:2; /* Resync Jump Width */
16961  uint32_t PSEG1:3; /* Phase Segment 1 */
16962  uint32_t PSEG2:3; /* Phase Segment 2 */
16963 #ifndef USE_FIELD_ALIASES_FLEXCAN
16964  uint32_t BOFF_MSK:1; /* Bus Off Mask */
16965 #else
16966  uint32_t BOFFMSK:1; /* deprecated name - please avoid */
16967 #endif
16968 #ifndef USE_FIELD_ALIASES_FLEXCAN
16969  uint32_t ERR_MSK:1; /* Error Mask */
16970 #else
16971  uint32_t ERRMSK:1; /* deprecated name - please avoid */
16972 #endif
16973 #ifndef USE_FIELD_ALIASES_FLEXCAN
16974  uint32_t CLK_SRC:1; /* CAN Engine Clock Source */
16975 #else
16976  uint32_t CLKSRC:1; /* deprecated name - please avoid */
16977 #endif
16978  uint32_t LPB:1; /* Loop Back */
16979 #ifndef USE_FIELD_ALIASES_FLEXCAN
16980  uint32_t TWRN_MSK:1; /* Tx Warning Interrupt Mask */
16981 #else
16982  uint32_t TWRNMSK:1; /* deprecated name - please avoid */
16983 #endif
16984 #ifndef USE_FIELD_ALIASES_FLEXCAN
16985  uint32_t RWRN_MSK:1; /* Rx Warning Interrupt Mask */
16986 #else
16987  uint32_t RWRNMSK:1; /* deprecated name - please avoid */
16988 #endif
16989  uint32_t:2;
16990  uint32_t SMP:1; /* Sampling Mode */
16991 #ifndef USE_FIELD_ALIASES_FLEXCAN
16992  uint32_t BOFF_REC:1; /* Bus Off Recovery Mode */
16993 #else
16994  uint32_t BOFFREC:1; /* deprecated name - please avoid */
16995 #endif
16996  uint32_t TSYN:1; /* Timer Sync Mode */
16997  uint32_t LBUF:1; /* Lowest Buffer Transmitted First */
16998  uint32_t LOM:1; /* Listen-Only Mode */
16999  uint32_t PROPSEG:3; /* Propagation Segment */
17000  } B;
17002
17003  typedef union { /* TIMER - Free Running Timer */
17004  uint32_t R;
17006
17007  typedef union { /* RXGMASK - Rx Global Mask Register */
17008  uint32_t R;
17009 #ifndef USE_FIELD_ALIASES_FLEXCAN
17010  struct {
17011  uint32_t MI:32; /* deprecated field -- do not use */
17012  } B;
17013 #endif
17015
17016  typedef union { /* RX14MASK - Rx 14 Mask Register */
17017  uint32_t R;
17018 #ifndef USE_FIELD_ALIASES_FLEXCAN
17019  struct {
17020  uint32_t MI:32; /* deprecated field -- do not use */
17021  } B;
17022 #endif
17024
17025  typedef union { /* RX15MASK - Rx 15 Mask Register */
17026  uint32_t R;
17027 #ifndef USE_FIELD_ALIASES_FLEXCAN
17028  struct {
17029  uint32_t MI:32; /* deprecated field -- do not use */
17030  } B;
17031 #endif
17033
17034  typedef union { /* ECR - Error Counter Register */
17035  uint32_t R;
17036  struct {
17037  uint32_t:16;
17038 #ifndef USE_FIELD_ALIASES_FLEXCAN
17039  uint32_t RX_ERR_COUNTER:8; /* Rx Error Counter */
17040 #else
17041  uint32_t RXECNT:8; /* deprecated name - please avoid */
17042 #endif
17043 #ifndef USE_FIELD_ALIASES_FLEXCAN
17044  uint32_t TX_ERR_COUNTER:8; /* Tx Error Counter */
17045 #else
17046  uint32_t TXECNT:8; /* deprecated name - please avoid */
17047 #endif
17048  } B;
17050
17051  typedef union { /* ESR - Error and Status Register */
17052  uint32_t R;
17053  struct {
17054  uint32_t:14;
17055 #ifndef USE_FIELD_ALIASES_FLEXCAN
17056  uint32_t TWRN_INT:1; /* Tx Warning Interrupt Flag */
17057 #else
17058  uint32_t TWRNINT:1; /* deprecated name - please avoid */
17059 #endif
17060 #ifndef USE_FIELD_ALIASES_FLEXCAN
17061  uint32_t RWRN_INT:1; /* Rx Warning Interrupt Flag */
17062 #else
17063  uint32_t RWRNINT:1; /* deprecated name - please avoid */
17064 #endif
17065 #ifndef USE_FIELD_ALIASES_FLEXCAN
17066  uint32_t BIT1_ERR:1; /* Bit 1 Error */
17067 #else
17068  uint32_t BIT1ERR:1; /* deprecated name - please avoid */
17069 #endif
17070 #ifndef USE_FIELD_ALIASES_FLEXCAN
17071  uint32_t BIT0_ERR:1; /* Bit 0 Error */
17072 #else
17073  uint32_t BIT0ERR:1; /* deprecated name - please avoid */
17074 #endif
17075 #ifndef USE_FIELD_ALIASES_FLEXCAN
17076  uint32_t ACK_ERR:1; /* Acknowledge Error */
17077 #else
17078  uint32_t ACKERR:1; /* deprecated name - please avoid */
17079 #endif
17080 #ifndef USE_FIELD_ALIASES_FLEXCAN
17081  uint32_t CRC_ERR:1; /* Cyclic Redundancy Check Error */
17082 #else
17083  uint32_t CRCERR:1; /* deprecated name - please avoid */
17084 #endif
17085 #ifndef USE_FIELD_ALIASES_FLEXCAN
17086  uint32_t FRM_ERR:1; /* Form Error */
17087 #else
17088  uint32_t FRMERR:1; /* deprecated name - please avoid */
17089 #endif
17090 #ifndef USE_FIELD_ALIASES_FLEXCAN
17091  uint32_t STF_ERR:1; /* Stuffing Error */
17092 #else
17093  uint32_t STFERR:1; /* deprecated name - please avoid */
17094 #endif
17095 #ifndef USE_FIELD_ALIASES_FLEXCAN
17096  uint32_t TX_WRN:1; /* Tx Error Counter */
17097 #else
17098  uint32_t TXWRN:1; /* deprecated name - please avoid */
17099 #endif
17100 #ifndef USE_FIELD_ALIASES_FLEXCAN
17101  uint32_t RX_WRN:1; /* Rx Error Counter */
17102 #else
17103  uint32_t RXWRN:1; /* deprecated name - please avoid */
17104 #endif
17105  uint32_t IDLE:1; /* CAN bus Idle State */
17106  uint32_t TXRX:1; /* Current Flexcan Status */
17107 #ifndef USE_FIELD_ALIASES_FLEXCAN
17108  uint32_t FLT_CONF:2; /* Fault Confinement State */
17109 #else
17110  uint32_t FLTCONF:2; /* deprecated name - please avoid */
17111 #endif
17112  uint32_t:1;
17113 #ifndef USE_FIELD_ALIASES_FLEXCAN
17114  uint32_t BOFF_INT:1; /* Bus Off Interrupt */
17115 #else
17116  uint32_t BOFFINT:1; /* deprecated name - please avoid */
17117 #endif
17118 #ifndef USE_FIELD_ALIASES_FLEXCAN
17119  uint32_t ERR_INT:1; /* Error Interrupt */
17120 #else
17121  uint32_t ERRINT:1; /* deprecated name - please avoid */
17122 #endif
17123 #ifndef USE_FIELD_ALIASES_FLEXCAN
17124  uint32_t WAK_INT:1; /* Wake-Up Interrupt */
17125 #else
17126  uint32_t WAKINT:1; /* deprecated name - please avoid */
17127 #endif
17128  } B;
17130
17131  typedef union { /* IMASK2 - Interrupt Masks 2 Register */
17132  uint32_t R;
17133  struct {
17134  uint32_t BUF63M:1; /* Buffer MB Mask 63 Bit */
17135  uint32_t BUF62M:1; /* Buffer MB Mask 62 Bit */
17136  uint32_t BUF61M:1; /* Buffer MB Mask 61 Bit */
17137  uint32_t BUF60M:1; /* Buffer MB Mask 60 Bit */
17138  uint32_t BUF59M:1; /* Buffer MB Mask 59 Bit */
17139  uint32_t BUF58M:1; /* Buffer MB Mask 58 Bit */
17140  uint32_t BUF57M:1; /* Buffer MB Mask 57 Bit */
17141  uint32_t BUF56M:1; /* Buffer MB Mask 56 Bit */
17142  uint32_t BUF55M:1; /* Buffer MB Mask 55 Bit */
17143  uint32_t BUF54M:1; /* Buffer MB Mask 54 Bit */
17144  uint32_t BUF53M:1; /* Buffer MB Mask 53 Bit */
17145  uint32_t BUF52M:1; /* Buffer MB Mask 52 Bit */
17146  uint32_t BUF51M:1; /* Buffer MB Mask 51 Bit */
17147  uint32_t BUF50M:1; /* Buffer MB Mask 50 Bit */
17148  uint32_t BUF49M:1; /* Buffer MB Mask 49 Bit */
17149  uint32_t BUF48M:1; /* Buffer MB Mask 48 Bit */
17150  uint32_t BUF47M:1; /* Buffer MB Mask 47 Bit */
17151  uint32_t BUF46M:1; /* Buffer MB Mask 46 Bit */
17152  uint32_t BUF45M:1; /* Buffer MB Mask 45 Bit */
17153  uint32_t BUF44M:1; /* Buffer MB Mask 44 Bit */
17154  uint32_t BUF43M:1; /* Buffer MB Mask 43 Bit */
17155  uint32_t BUF42M:1; /* Buffer MB Mask 42 Bit */
17156  uint32_t BUF41M:1; /* Buffer MB Mask 41 Bit */
17157  uint32_t BUF40M:1; /* Buffer MB Mask 40 Bit */
17158  uint32_t BUF39M:1; /* Buffer MB Mask 39 Bit */
17159  uint32_t BUF38M:1; /* Buffer MB Mask 38 Bit */
17160  uint32_t BUF37M:1; /* Buffer MB Mask 37 Bit */
17161  uint32_t BUF36M:1; /* Buffer MB Mask 36 Bit */
17162  uint32_t BUF35M:1; /* Buffer MB Mask 35 Bit */
17163  uint32_t BUF34M:1; /* Buffer MB Mask 34 Bit */
17164  uint32_t BUF33M:1; /* Buffer MB Mask 33 Bit */
17165  uint32_t BUF32M:1; /* Buffer MB Mask 32 Bit */
17166  } B;
17168
17169  typedef union { /* IMASK1 - Interrupt Masks 1 Register */
17170  uint32_t R;
17171  struct {
17172  uint32_t BUF31M:1; /* Buffer MB Mask 31 Bit */
17173  uint32_t BUF30M:1; /* Buffer MB Mask 30 Bit */
17174  uint32_t BUF29M:1; /* Buffer MB Mask 29 Bit */
17175  uint32_t BUF28M:1; /* Buffer MB Mask 28 Bit */
17176  uint32_t BUF27M:1; /* Buffer MB Mask 27 Bit */
17177  uint32_t BUF26M:1; /* Buffer MB Mask 26 Bit */
17178  uint32_t BUF25M:1; /* Buffer MB Mask 25 Bit */
17179  uint32_t BUF24M:1; /* Buffer MB Mask 24 Bit */
17180  uint32_t BUF23M:1; /* Buffer MB Mask 23 Bit */
17181  uint32_t BUF22M:1; /* Buffer MB Mask 22 Bit */
17182  uint32_t BUF21M:1; /* Buffer MB Mask 21 Bit */
17183  uint32_t BUF20M:1; /* Buffer MB Mask 20 Bit */
17184  uint32_t BUF19M:1; /* Buffer MB Mask 19 Bit */
17185  uint32_t BUF18M:1; /* Buffer MB Mask 18 Bit */
17186  uint32_t BUF17M:1; /* Buffer MB Mask 17 Bit */
17187  uint32_t BUF16M:1; /* Buffer MB Mask 16 Bit */
17188  uint32_t BUF15M:1; /* Buffer MB Mask 15 Bit */
17189  uint32_t BUF14M:1; /* Buffer MB Mask 14 Bit */
17190  uint32_t BUF13M:1; /* Buffer MB Mask 13 Bit */
17191  uint32_t BUF12M:1; /* Buffer MB Mask 12 Bit */
17192  uint32_t BUF11M:1; /* Buffer MB Mask 11 Bit */
17193  uint32_t BUF10M:1; /* Buffer MB Mask 10 Bit */
17194 #ifndef USE_FIELD_ALIASES_FLEXCAN
17195  uint32_t BUF9M:1; /* Buffer MB Mask 9 Bit */
17196 #else
17197  uint32_t BUF09M:1; /* deprecated name - please avoid */
17198 #endif
17199 #ifndef USE_FIELD_ALIASES_FLEXCAN
17200  uint32_t BUF8M:1; /* Buffer MB Mask 8 Bit */
17201 #else
17202  uint32_t BUF08M:1; /* deprecated name - please avoid */
17203 #endif
17204 #ifndef USE_FIELD_ALIASES_FLEXCAN
17205  uint32_t BUF7M:1; /* Buffer MB Mask 7 Bit */
17206 #else
17207  uint32_t BUF07M:1; /* deprecated name - please avoid */
17208 #endif
17209 #ifndef USE_FIELD_ALIASES_FLEXCAN
17210  uint32_t BUF6M:1; /* Buffer MB Mask 6 Bit */
17211 #else
17212  uint32_t BUF06M:1; /* deprecated name - please avoid */
17213 #endif
17214 #ifndef USE_FIELD_ALIASES_FLEXCAN
17215  uint32_t BUF5M:1; /* Buffer MB Mask 5 Bit */
17216 #else
17217  uint32_t BUF05M:1; /* deprecated name - please avoid */
17218 #endif
17219 #ifndef USE_FIELD_ALIASES_FLEXCAN
17220  uint32_t BUF4M:1; /* Buffer MB Mask 4 Bit */
17221 #else
17222  uint32_t BUF04M:1; /* deprecated name - please avoid */
17223 #endif
17224 #ifndef USE_FIELD_ALIASES_FLEXCAN
17225  uint32_t BUF3M:1; /* Buffer MB Mask 3 Bit */
17226 #else
17227  uint32_t BUF03M:1; /* deprecated name - please avoid */
17228 #endif
17229 #ifndef USE_FIELD_ALIASES_FLEXCAN
17230  uint32_t BUF2M:1; /* Buffer MB Mask 2 Bit */
17231 #else
17232  uint32_t BUF02M:1; /* deprecated name - please avoid */
17233 #endif
17234 #ifndef USE_FIELD_ALIASES_FLEXCAN
17235  uint32_t BUF1M:1; /* Buffer MB Mask 1 Bit */
17236 #else
17237  uint32_t BUF01M:1; /* deprecated name - please avoid */
17238 #endif
17239 #ifndef USE_FIELD_ALIASES_FLEXCAN
17240  uint32_t BUF0M:1; /* Buffer MB Mask 0 Bit */
17241 #else
17242  uint32_t BUF00M:1; /* deprecated name - please avoid */
17243 #endif
17244  } B;
17246
17247  typedef union { /* IFLAG2 - Interrupt Flags 2 Register */
17248  uint32_t R;
17249  struct {
17250  uint32_t BUF63I:1; /* Buffer MB Interrupt 63 Bit */
17251  uint32_t BUF62I:1; /* Buffer MB Interrupt 62 Bit */
17252  uint32_t BUF61I:1; /* Buffer MB Interrupt 61 Bit */
17253  uint32_t BUF60I:1; /* Buffer MB Interrupt 60 Bit */
17254  uint32_t BUF59I:1; /* Buffer MB Interrupt 59 Bit */
17255  uint32_t BUF58I:1; /* Buffer MB Interrupt 58 Bit */
17256  uint32_t BUF57I:1; /* Buffer MB Interrupt 57 Bit */
17257  uint32_t BUF56I:1; /* Buffer MB Interrupt 56 Bit */
17258  uint32_t BUF55I:1; /* Buffer MB Interrupt 55 Bit */
17259  uint32_t BUF54I:1; /* Buffer MB Interrupt 54 Bit */
17260  uint32_t BUF53I:1; /* Buffer MB Interrupt 53 Bit */
17261  uint32_t BUF52I:1; /* Buffer MB Interrupt 52 Bit */
17262  uint32_t BUF51I:1; /* Buffer MB Interrupt 51 Bit */
17263  uint32_t BUF50I:1; /* Buffer MB Interrupt 50 Bit */
17264  uint32_t BUF49I:1; /* Buffer MB Interrupt 49 Bit */
17265  uint32_t BUF48I:1; /* Buffer MB Interrupt 48 Bit */
17266  uint32_t BUF47I:1; /* Buffer MB Interrupt 47 Bit */
17267  uint32_t BUF46I:1; /* Buffer MB Interrupt 46 Bit */
17268  uint32_t BUF45I:1; /* Buffer MB Interrupt 45 Bit */
17269  uint32_t BUF44I:1; /* Buffer MB Interrupt 44 Bit */
17270  uint32_t BUF43I:1; /* Buffer MB Interrupt 43 Bit */
17271  uint32_t BUF42I:1; /* Buffer MB Interrupt 42 Bit */
17272  uint32_t BUF41I:1; /* Buffer MB Interrupt 41 Bit */
17273  uint32_t BUF40I:1; /* Buffer MB Interrupt 40 Bit */
17274  uint32_t BUF39I:1; /* Buffer MB Interrupt 39 Bit */
17275  uint32_t BUF38I:1; /* Buffer MB Interrupt 38 Bit */
17276  uint32_t BUF37I:1; /* Buffer MB Interrupt 37 Bit */
17277  uint32_t BUF36I:1; /* Buffer MB Interrupt 36 Bit */
17278  uint32_t BUF35I:1; /* Buffer MB Interrupt 35 Bit */
17279  uint32_t BUF34I:1; /* Buffer MB Interrupt 34 Bit */
17280  uint32_t BUF33I:1; /* Buffer MB Interrupt 33 Bit */
17281  uint32_t BUF32I:1; /* Buffer MB Interrupt 32 Bit */
17282  } B;
17284
17285  typedef union { /* IFLAG1 - Interrupt Flags 1 Register */
17286  uint32_t R;
17287  struct {
17288  uint32_t BUF31I:1; /* Buffer MB Interrupt 31 Bit */
17289  uint32_t BUF30I:1; /* Buffer MB Interrupt 30 Bit */
17290  uint32_t BUF29I:1; /* Buffer MB Interrupt 29 Bit */
17291  uint32_t BUF28I:1; /* Buffer MB Interrupt 28 Bit */
17292  uint32_t BUF27I:1; /* Buffer MB Interrupt 27 Bit */
17293  uint32_t BUF26I:1; /* Buffer MB Interrupt 26 Bit */
17294  uint32_t BUF25I:1; /* Buffer MB Interrupt 25 Bit */
17295  uint32_t BUF24I:1; /* Buffer MB Interrupt 24 Bit */
17296  uint32_t BUF23I:1; /* Buffer MB Interrupt 23 Bit */
17297  uint32_t BUF22I:1; /* Buffer MB Interrupt 22 Bit */
17298  uint32_t BUF21I:1; /* Buffer MB Interrupt 21 Bit */
17299  uint32_t BUF20I:1; /* Buffer MB Interrupt 20 Bit */
17300  uint32_t BUF19I:1; /* Buffer MB Interrupt 19 Bit */
17301  uint32_t BUF18I:1; /* Buffer MB Interrupt 18 Bit */
17302  uint32_t BUF17I:1; /* Buffer MB Interrupt 17 Bit */
17303  uint32_t BUF16I:1; /* Buffer MB Interrupt 16 Bit */
17304  uint32_t BUF15I:1; /* Buffer MB Interrupt 15 Bit */
17305  uint32_t BUF14I:1; /* Buffer MB Interrupt 14 Bit */
17306  uint32_t BUF13I:1; /* Buffer MB Interrupt 13 Bit */
17307  uint32_t BUF12I:1; /* Buffer MB Interrupt 12 Bit */
17308  uint32_t BUF11I:1; /* Buffer MB Interrupt 11 Bit */
17309  uint32_t BUF10I:1; /* Buffer MB Interrupt 10 Bit */
17310 #ifndef USE_FIELD_ALIASES_FLEXCAN
17311  uint32_t BUF9I:1; /* Buffer MB Interrupt 9 Bit */
17312 #else
17313  uint32_t BUF09I:1; /* deprecated name - please avoid */
17314 #endif
17315 #ifndef USE_FIELD_ALIASES_FLEXCAN
17316  uint32_t BUF8I:1; /* Buffer MB Interrupt 8 Bit */
17317 #else
17318  uint32_t BUF08I:1; /* deprecated name - please avoid */
17319 #endif
17320 #ifndef USE_FIELD_ALIASES_FLEXCAN
17321  uint32_t BUF7I:1; /* Buffer MB Interrupt 7 Bit */
17322 #else
17323  uint32_t BUF07I:1; /* deprecated name - please avoid */
17324 #endif
17325 #ifndef USE_FIELD_ALIASES_FLEXCAN
17326  uint32_t BUF6I:1; /* Buffer MB Interrupt 6 Bit */
17327 #else
17328  uint32_t BUF06I:1; /* deprecated name - please avoid */
17329 #endif
17330 #ifndef USE_FIELD_ALIASES_FLEXCAN
17331  uint32_t BUF5I:1; /* Buffer MB Interrupt 5 Bit */
17332 #else
17333  uint32_t BUF05I:1; /* deprecated name - please avoid */
17334 #endif
17335 #ifndef USE_FIELD_ALIASES_FLEXCAN
17336  uint32_t BUF4I:1; /* Buffer MB Interrupt 4 Bit */
17337 #else
17338  uint32_t BUF04I:1; /* deprecated name - please avoid */
17339 #endif
17340 #ifndef USE_FIELD_ALIASES_FLEXCAN
17341  uint32_t BUF3I:1; /* Buffer MB Interrupt 3 Bit */
17342 #else
17343  uint32_t BUF03I:1; /* deprecated name - please avoid */
17344 #endif
17345 #ifndef USE_FIELD_ALIASES_FLEXCAN
17346  uint32_t BUF2I:1; /* Buffer MB Interrupt 2 Bit */
17347 #else
17348  uint32_t BUF02I:1; /* deprecated name - please avoid */
17349 #endif
17350 #ifndef USE_FIELD_ALIASES_FLEXCAN
17351  uint32_t BUF1I:1; /* Buffer MB Interrupt 1 Bit */
17352 #else
17353  uint32_t BUF01I:1; /* deprecated name - please avoid */
17354 #endif
17355 #ifndef USE_FIELD_ALIASES_FLEXCAN
17356  uint32_t BUF0I:1; /* Buffer MB Interrupt 0 Bit */
17357 #else
17358  uint32_t BUF00I:1; /* deprecated name - please avoid */
17359 #endif
17360  } B;
17362
17363
17364  /* Register layout for all registers MSG_CS... */
17365
17366  typedef union { /* Message Buffer Control and Status */
17367  uint32_t R;
17368  struct {
17369  uint32_t:4;
17370  uint32_t CODE:4; /* Message Buffer Code */
17371  uint32_t:1;
17372  uint32_t SRR:1; /* Substitute Remote Request */
17373  uint32_t IDE:1; /* ID Extended Bit */
17374  uint32_t RTR:1; /* Remote Transmission Request */
17375  uint32_t LENGTH:4; /* Length of Data in Bytes */
17376  uint32_t TIMESTAMP:16; /* Free-Running Counter Time Stamp */
17377  } B;
17379
17380
17381  /* Register layout for all registers MSG_ID... */
17382
17383  typedef union { /* Message Buffer Identifier Field */
17384  uint32_t R;
17385  struct {
17386  uint32_t PRIO:3; /* Local Priority */
17387  uint32_t STD_ID:11;
17388  uint32_t EXT_ID:18;
17389  } B;
17391
17392
17393  /* Register layout for all registers MSG_BYTE0_3... */
17394
17395  typedef union { /* Message Buffer Data Register */
17396  uint32_t R;
17397  uint8_t BYTE[4]; /* individual bytes can be accessed */
17398  uint32_t WORD; /* individual words can be accessed */
17400
17401  typedef union {
17402  uint8_t B[8]; /* Data buffer in Bytes (8 bits) */
17403  uint16_t H[4]; /* Data buffer in Half-words (16 bits) */
17404  uint32_t W[2]; /* Data buffer in words (32 bits) */
17405  uint32_t R[2]; /* Data buffer in words (32 bits) */
17407
17408  /* Register layout for all registers MSG_BYTE4_7 matches xxx */
17409
17410
17411  /* Register layout for all registers RXIMR... */
17412
17413  typedef union { /* FLEXCAN_RXIMR0 - FLEXCAN_RXIMR63 - RX Individual Mask Registers */
17414  uint32_t R;
17416
17417
17418  typedef struct FLEXCAN_MB_struct_tag {
17419
17420  union {
17421  /* Message Buffer Control and Status */
17422  FLEXCAN_MSG_CS_32B_tag MSG_CS; /* relative offset: 0x0000 */
17423  FLEXCAN_MSG_CS_32B_tag CS; /* deprecated - please avoid */
17424  };
17425  union {
17426  /* Message Buffer Identifier Field */
17427  FLEXCAN_MSG_ID_32B_tag MSG_ID; /* relative offset: 0x0004 */
17428  FLEXCAN_MSG_ID_32B_tag ID; /* deprecated - please avoid */
17429  };
17430  union { /* Message Buffer Data Register */
17431
17432  struct {
17433  FLEXCAN_MSG_DATA_32B_tag MSG_BYTE0_3; /* relative offset: 0x0008 */
17434  /* Message Buffer Data Register */
17435  FLEXCAN_MSG_DATA_32B_tag MSG_BYTE4_7; /* relative offset: 0x000C */
17436  };
17437
17438  FLEXCAN_MSG_DATA2_32B_tag DATA; /* relative offset: 0x000C */
17439
17440  };
17441
17442  } FLEXCAN_MB_tag;
17443
17444
17445  typedef struct FLEXCAN_struct_tag { /* start of FLEXCAN_tag */
17446  /* MCR - Module Configuration Register */
17447  FLEXCAN_MCR_32B_tag MCR; /* offset: 0x0000 size: 32 bit */
17448  union {
17449  /* CTRL - Control Register */
17450  FLEXCAN_CTRL_32B_tag CTRL; /* offset: 0x0004 size: 32 bit */
17451
17452  FLEXCAN_CTRL_32B_tag CR; /* deprecated - please avoid */
17453
17454  };
17455  /* TIMER - Free Running Timer */
17456  FLEXCAN_TIMER_32B_tag TIMER; /* offset: 0x0008 size: 32 bit */
17457  int8_t FLEXCAN_reserved_000C[4];
17458  /* RXGMASK - Rx Global Mask Register */
17459  FLEXCAN_RXGMASK_32B_tag RXGMASK; /* offset: 0x0010 size: 32 bit */
17460  /* RX14MASK - Rx 14 Mask Register */
17461  FLEXCAN_RX14MASK_32B_tag RX14MASK; /* offset: 0x0014 size: 32 bit */
17462  /* RX15MASK - Rx 15 Mask Register */
17463  FLEXCAN_RX15MASK_32B_tag RX15MASK; /* offset: 0x0018 size: 32 bit */
17464  /* ECR - Error Counter Register */
17465  FLEXCAN_ECR_32B_tag ECR; /* offset: 0x001C size: 32 bit */
17466  /* ESR - Error and Status Register */
17467  FLEXCAN_ESR_32B_tag ESR; /* offset: 0x0020 size: 32 bit */
17468  union {
17469  FLEXCAN_IMASK2_32B_tag IMRH; /* deprecated - please avoid */
17470
17471  /* IMASK2 - Interrupt Masks 2 Register */
17472  FLEXCAN_IMASK2_32B_tag IMASK2; /* offset: 0x0024 size: 32 bit */
17473
17474  };
17475  union {
17476  FLEXCAN_IMASK1_32B_tag IMRL; /* deprecated - please avoid */
17477
17478  /* IMASK1 - Interrupt Masks 1 Register */
17479  FLEXCAN_IMASK1_32B_tag IMASK1; /* offset: 0x0028 size: 32 bit */
17480
17481  };
17482  union {
17483  FLEXCAN_IFLAG2_32B_tag IFRH; /* deprecated - please avoid */
17484
17485  /* IFLAG2 - Interrupt Flags 2 Register */
17486  FLEXCAN_IFLAG2_32B_tag IFLAG2; /* offset: 0x002C size: 32 bit */
17487
17488  };
17489  union {
17490  FLEXCAN_IFLAG1_32B_tag IFRL; /* deprecated - please avoid */
17491
17492  /* IFLAG1 - Interrupt Flags 1 Register */
17493  FLEXCAN_IFLAG1_32B_tag IFLAG1; /* offset: 0x0030 size: 32 bit */
17494
17495  };
17496  int8_t FLEXCAN_reserved_0034_C[76];
17497  union {
17498  /* Register set MB */
17499  FLEXCAN_MB_tag MB[64]; /* offset: 0x0080 (0x0010 x 64) */
17500
17501  /* Alias name for MB */
17502  FLEXCAN_MB_tag BUF[64]; /* deprecated - please avoid */
17503
17504  struct {
17505  /* Message Buffer Control and Status */
17506  FLEXCAN_MSG_CS_32B_tag MSG0_CS; /* offset: 0x0080 size: 32 bit */
17507  /* Message Buffer Identifier Field */
17508  FLEXCAN_MSG_ID_32B_tag MSG0_ID; /* offset: 0x0084 size: 32 bit */
17509  /* Message Buffer Data Register */
17510  FLEXCAN_MSG_DATA_32B_tag MSG0_BYTE0_3; /* offset: 0x0088 size: 32 bit */
17511  /* Message Buffer Data Register */
17512  FLEXCAN_MSG_DATA_32B_tag MSG0_BYTE4_7; /* offset: 0x008C size: 32 bit */
17513  /* Message Buffer Control and Status */
17514  FLEXCAN_MSG_CS_32B_tag MSG1_CS; /* offset: 0x0090 size: 32 bit */
17515  /* Message Buffer Identifier Field */
17516  FLEXCAN_MSG_ID_32B_tag MSG1_ID; /* offset: 0x0094 size: 32 bit */
17517  /* Message Buffer Data Register */
17518  FLEXCAN_MSG_DATA_32B_tag MSG1_BYTE0_3; /* offset: 0x0098 size: 32 bit */
17519  /* Message Buffer Data Register */
17520  FLEXCAN_MSG_DATA_32B_tag MSG1_BYTE4_7; /* offset: 0x009C size: 32 bit */
17521  /* Message Buffer Control and Status */
17522  FLEXCAN_MSG_CS_32B_tag MSG2_CS; /* offset: 0x00A0 size: 32 bit */
17523  /* Message Buffer Identifier Field */
17524  FLEXCAN_MSG_ID_32B_tag MSG2_ID; /* offset: 0x00A4 size: 32 bit */
17525  /* Message Buffer Data Register */
17526  FLEXCAN_MSG_DATA_32B_tag MSG2_BYTE0_3; /* offset: 0x00A8 size: 32 bit */
17527  /* Message Buffer Data Register */
17528  FLEXCAN_MSG_DATA_32B_tag MSG2_BYTE4_7; /* offset: 0x00AC size: 32 bit */
17529  /* Message Buffer Control and Status */
17530  FLEXCAN_MSG_CS_32B_tag MSG3_CS; /* offset: 0x00B0 size: 32 bit */
17531  /* Message Buffer Identifier Field */
17532  FLEXCAN_MSG_ID_32B_tag MSG3_ID; /* offset: 0x00B4 size: 32 bit */
17533  /* Message Buffer Data Register */
17534  FLEXCAN_MSG_DATA_32B_tag MSG3_BYTE0_3; /* offset: 0x00B8 size: 32 bit */
17535  /* Message Buffer Data Register */
17536  FLEXCAN_MSG_DATA_32B_tag MSG3_BYTE4_7; /* offset: 0x00BC size: 32 bit */
17537  /* Message Buffer Control and Status */
17538  FLEXCAN_MSG_CS_32B_tag MSG4_CS; /* offset: 0x00C0 size: 32 bit */
17539  /* Message Buffer Identifier Field */
17540  FLEXCAN_MSG_ID_32B_tag MSG4_ID; /* offset: 0x00C4 size: 32 bit */
17541  /* Message Buffer Data Register */
17542  FLEXCAN_MSG_DATA_32B_tag MSG4_BYTE0_3; /* offset: 0x00C8 size: 32 bit */
17543  /* Message Buffer Data Register */
17544  FLEXCAN_MSG_DATA_32B_tag MSG4_BYTE4_7; /* offset: 0x00CC size: 32 bit */
17545  /* Message Buffer Control and Status */
17546  FLEXCAN_MSG_CS_32B_tag MSG5_CS; /* offset: 0x00D0 size: 32 bit */
17547  /* Message Buffer Identifier Field */
17548  FLEXCAN_MSG_ID_32B_tag MSG5_ID; /* offset: 0x00D4 size: 32 bit */
17549  /* Message Buffer Data Register */
17550  FLEXCAN_MSG_DATA_32B_tag MSG5_BYTE0_3; /* offset: 0x00D8 size: 32 bit */
17551  /* Message Buffer Data Register */
17552  FLEXCAN_MSG_DATA_32B_tag MSG5_BYTE4_7; /* offset: 0x00DC size: 32 bit */
17553  /* Message Buffer Control and Status */
17554  FLEXCAN_MSG_CS_32B_tag MSG6_CS; /* offset: 0x00E0 size: 32 bit */
17555  /* Message Buffer Identifier Field */
17556  FLEXCAN_MSG_ID_32B_tag MSG6_ID; /* offset: 0x00E4 size: 32 bit */
17557  /* Message Buffer Data Register */
17558  FLEXCAN_MSG_DATA_32B_tag MSG6_BYTE0_3; /* offset: 0x00E8 size: 32 bit */
17559  /* Message Buffer Data Register */
17560  FLEXCAN_MSG_DATA_32B_tag MSG6_BYTE4_7; /* offset: 0x00EC size: 32 bit */
17561  /* Message Buffer Control and Status */
17562  FLEXCAN_MSG_CS_32B_tag MSG7_CS; /* offset: 0x00F0 size: 32 bit */
17563  /* Message Buffer Identifier Field */
17564  FLEXCAN_MSG_ID_32B_tag MSG7_ID; /* offset: 0x00F4 size: 32 bit */
17565  /* Message Buffer Data Register */
17566  FLEXCAN_MSG_DATA_32B_tag MSG7_BYTE0_3; /* offset: 0x00F8 size: 32 bit */
17567  /* Message Buffer Data Register */
17568  FLEXCAN_MSG_DATA_32B_tag MSG7_BYTE4_7; /* offset: 0x00FC size: 32 bit */
17569  /* Message Buffer Control and Status */
17570  FLEXCAN_MSG_CS_32B_tag MSG8_CS; /* offset: 0x0100 size: 32 bit */
17571  /* Message Buffer Identifier Field */
17572  FLEXCAN_MSG_ID_32B_tag MSG8_ID; /* offset: 0x0104 size: 32 bit */
17573  /* Message Buffer Data Register */
17574  FLEXCAN_MSG_DATA_32B_tag MSG8_BYTE0_3; /* offset: 0x0108 size: 32 bit */
17575  /* Message Buffer Data Register */
17576  FLEXCAN_MSG_DATA_32B_tag MSG8_BYTE4_7; /* offset: 0x010C size: 32 bit */
17577  /* Message Buffer Control and Status */
17578  FLEXCAN_MSG_CS_32B_tag MSG9_CS; /* offset: 0x0110 size: 32 bit */
17579  /* Message Buffer Identifier Field */
17580  FLEXCAN_MSG_ID_32B_tag MSG9_ID; /* offset: 0x0114 size: 32 bit */
17581  /* Message Buffer Data Register */
17582  FLEXCAN_MSG_DATA_32B_tag MSG9_BYTE0_3; /* offset: 0x0118 size: 32 bit */
17583  /* Message Buffer Data Register */
17584  FLEXCAN_MSG_DATA_32B_tag MSG9_BYTE4_7; /* offset: 0x011C size: 32 bit */
17585  /* Message Buffer Control and Status */
17586  FLEXCAN_MSG_CS_32B_tag MSG10_CS; /* offset: 0x0120 size: 32 bit */
17587  /* Message Buffer Identifier Field */
17588  FLEXCAN_MSG_ID_32B_tag MSG10_ID; /* offset: 0x0124 size: 32 bit */
17589  /* Message Buffer Data Register */
17590  FLEXCAN_MSG_DATA_32B_tag MSG10_BYTE0_3; /* offset: 0x0128 size: 32 bit */
17591  /* Message Buffer Data Register */
17592  FLEXCAN_MSG_DATA_32B_tag MSG10_BYTE4_7; /* offset: 0x012C size: 32 bit */
17593  /* Message Buffer Control and Status */
17594  FLEXCAN_MSG_CS_32B_tag MSG11_CS; /* offset: 0x0130 size: 32 bit */
17595  /* Message Buffer Identifier Field */
17596  FLEXCAN_MSG_ID_32B_tag MSG11_ID; /* offset: 0x0134 size: 32 bit */
17597  /* Message Buffer Data Register */
17598  FLEXCAN_MSG_DATA_32B_tag MSG11_BYTE0_3; /* offset: 0x0138 size: 32 bit */
17599  /* Message Buffer Data Register */
17600  FLEXCAN_MSG_DATA_32B_tag MSG11_BYTE4_7; /* offset: 0x013C size: 32 bit */
17601  /* Message Buffer Control and Status */
17602  FLEXCAN_MSG_CS_32B_tag MSG12_CS; /* offset: 0x0140 size: 32 bit */
17603  /* Message Buffer Identifier Field */
17604  FLEXCAN_MSG_ID_32B_tag MSG12_ID; /* offset: 0x0144 size: 32 bit */
17605  /* Message Buffer Data Register */
17606  FLEXCAN_MSG_DATA_32B_tag MSG12_BYTE0_3; /* offset: 0x0148 size: 32 bit */
17607  /* Message Buffer Data Register */
17608  FLEXCAN_MSG_DATA_32B_tag MSG12_BYTE4_7; /* offset: 0x014C size: 32 bit */
17609  /* Message Buffer Control and Status */
17610  FLEXCAN_MSG_CS_32B_tag MSG13_CS; /* offset: 0x0150 size: 32 bit */
17611  /* Message Buffer Identifier Field */
17612  FLEXCAN_MSG_ID_32B_tag MSG13_ID; /* offset: 0x0154 size: 32 bit */
17613  /* Message Buffer Data Register */
17614  FLEXCAN_MSG_DATA_32B_tag MSG13_BYTE0_3; /* offset: 0x0158 size: 32 bit */
17615  /* Message Buffer Data Register */
17616  FLEXCAN_MSG_DATA_32B_tag MSG13_BYTE4_7; /* offset: 0x015C size: 32 bit */
17617  /* Message Buffer Control and Status */
17618  FLEXCAN_MSG_CS_32B_tag MSG14_CS; /* offset: 0x0160 size: 32 bit */
17619  /* Message Buffer Identifier Field */
17620  FLEXCAN_MSG_ID_32B_tag MSG14_ID; /* offset: 0x0164 size: 32 bit */
17621  /* Message Buffer Data Register */
17622  FLEXCAN_MSG_DATA_32B_tag MSG14_BYTE0_3; /* offset: 0x0168 size: 32 bit */
17623  /* Message Buffer Data Register */
17624  FLEXCAN_MSG_DATA_32B_tag MSG14_BYTE4_7; /* offset: 0x016C size: 32 bit */
17625  /* Message Buffer Control and Status */
17626  FLEXCAN_MSG_CS_32B_tag MSG15_CS; /* offset: 0x0170 size: 32 bit */
17627  /* Message Buffer Identifier Field */
17628  FLEXCAN_MSG_ID_32B_tag MSG15_ID; /* offset: 0x0174 size: 32 bit */
17629  /* Message Buffer Data Register */
17630  FLEXCAN_MSG_DATA_32B_tag MSG15_BYTE0_3; /* offset: 0x0178 size: 32 bit */
17631  /* Message Buffer Data Register */
17632  FLEXCAN_MSG_DATA_32B_tag MSG15_BYTE4_7; /* offset: 0x017C size: 32 bit */
17633  /* Message Buffer Control and Status */
17634  FLEXCAN_MSG_CS_32B_tag MSG16_CS; /* offset: 0x0180 size: 32 bit */
17635  /* Message Buffer Identifier Field */
17636  FLEXCAN_MSG_ID_32B_tag MSG16_ID; /* offset: 0x0184 size: 32 bit */
17637  /* Message Buffer Data Register */
17638  FLEXCAN_MSG_DATA_32B_tag MSG16_BYTE0_3; /* offset: 0x0188 size: 32 bit */
17639  /* Message Buffer Data Register */
17640  FLEXCAN_MSG_DATA_32B_tag MSG16_BYTE4_7; /* offset: 0x018C size: 32 bit */
17641  /* Message Buffer Control and Status */
17642  FLEXCAN_MSG_CS_32B_tag MSG17_CS; /* offset: 0x0190 size: 32 bit */
17643  /* Message Buffer Identifier Field */
17644  FLEXCAN_MSG_ID_32B_tag MSG17_ID; /* offset: 0x0194 size: 32 bit */
17645  /* Message Buffer Data Register */
17646  FLEXCAN_MSG_DATA_32B_tag MSG17_BYTE0_3; /* offset: 0x0198 size: 32 bit */
17647  /* Message Buffer Data Register */
17648  FLEXCAN_MSG_DATA_32B_tag MSG17_BYTE4_7; /* offset: 0x019C size: 32 bit */
17649  /* Message Buffer Control and Status */
17650  FLEXCAN_MSG_CS_32B_tag MSG18_CS; /* offset: 0x01A0 size: 32 bit */
17651  /* Message Buffer Identifier Field */
17652  FLEXCAN_MSG_ID_32B_tag MSG18_ID; /* offset: 0x01A4 size: 32 bit */
17653  /* Message Buffer Data Register */
17654  FLEXCAN_MSG_DATA_32B_tag MSG18_BYTE0_3; /* offset: 0x01A8 size: 32 bit */
17655  /* Message Buffer Data Register */
17656  FLEXCAN_MSG_DATA_32B_tag MSG18_BYTE4_7; /* offset: 0x01AC size: 32 bit */
17657  /* Message Buffer Control and Status */
17658  FLEXCAN_MSG_CS_32B_tag MSG19_CS; /* offset: 0x01B0 size: 32 bit */
17659  /* Message Buffer Identifier Field */
17660  FLEXCAN_MSG_ID_32B_tag MSG19_ID; /* offset: 0x01B4 size: 32 bit */
17661  /* Message Buffer Data Register */
17662  FLEXCAN_MSG_DATA_32B_tag MSG19_BYTE0_3; /* offset: 0x01B8 size: 32 bit */
17663  /* Message Buffer Data Register */
17664  FLEXCAN_MSG_DATA_32B_tag MSG19_BYTE4_7; /* offset: 0x01BC size: 32 bit */
17665  /* Message Buffer Control and Status */
17666  FLEXCAN_MSG_CS_32B_tag MSG20_CS; /* offset: 0x01C0 size: 32 bit */
17667  /* Message Buffer Identifier Field */
17668  FLEXCAN_MSG_ID_32B_tag MSG20_ID; /* offset: 0x01C4 size: 32 bit */
17669  /* Message Buffer Data Register */
17670  FLEXCAN_MSG_DATA_32B_tag MSG20_BYTE0_3; /* offset: 0x01C8 size: 32 bit */
17671  /* Message Buffer Data Register */
17672  FLEXCAN_MSG_DATA_32B_tag MSG20_BYTE4_7; /* offset: 0x01CC size: 32 bit */
17673  /* Message Buffer Control and Status */
17674  FLEXCAN_MSG_CS_32B_tag MSG21_CS; /* offset: 0x01D0 size: 32 bit */
17675  /* Message Buffer Identifier Field */
17676  FLEXCAN_MSG_ID_32B_tag MSG21_ID; /* offset: 0x01D4 size: 32 bit */
17677  /* Message Buffer Data Register */
17678  FLEXCAN_MSG_DATA_32B_tag MSG21_BYTE0_3; /* offset: 0x01D8 size: 32 bit */
17679  /* Message Buffer Data Register */
17680  FLEXCAN_MSG_DATA_32B_tag MSG21_BYTE4_7; /* offset: 0x01DC size: 32 bit */
17681  /* Message Buffer Control and Status */
17682  FLEXCAN_MSG_CS_32B_tag MSG22_CS; /* offset: 0x01E0 size: 32 bit */
17683  /* Message Buffer Identifier Field */
17684  FLEXCAN_MSG_ID_32B_tag MSG22_ID; /* offset: 0x01E4 size: 32 bit */
17685  /* Message Buffer Data Register */
17686  FLEXCAN_MSG_DATA_32B_tag MSG22_BYTE0_3; /* offset: 0x01E8 size: 32 bit */
17687  /* Message Buffer Data Register */
17688  FLEXCAN_MSG_DATA_32B_tag MSG22_BYTE4_7; /* offset: 0x01EC size: 32 bit */
17689  /* Message Buffer Control and Status */
17690  FLEXCAN_MSG_CS_32B_tag MSG23_CS; /* offset: 0x01F0 size: 32 bit */
17691  /* Message Buffer Identifier Field */
17692  FLEXCAN_MSG_ID_32B_tag MSG23_ID; /* offset: 0x01F4 size: 32 bit */
17693  /* Message Buffer Data Register */
17694  FLEXCAN_MSG_DATA_32B_tag MSG23_BYTE0_3; /* offset: 0x01F8 size: 32 bit */
17695  /* Message Buffer Data Register */
17696  FLEXCAN_MSG_DATA_32B_tag MSG23_BYTE4_7; /* offset: 0x01FC size: 32 bit */
17697  /* Message Buffer Control and Status */
17698  FLEXCAN_MSG_CS_32B_tag MSG24_CS; /* offset: 0x0200 size: 32 bit */
17699  /* Message Buffer Identifier Field */
17700  FLEXCAN_MSG_ID_32B_tag MSG24_ID; /* offset: 0x0204 size: 32 bit */
17701  /* Message Buffer Data Register */
17702  FLEXCAN_MSG_DATA_32B_tag MSG24_BYTE0_3; /* offset: 0x0208 size: 32 bit */
17703  /* Message Buffer Data Register */
17704  FLEXCAN_MSG_DATA_32B_tag MSG24_BYTE4_7; /* offset: 0x020C size: 32 bit */
17705  /* Message Buffer Control and Status */
17706  FLEXCAN_MSG_CS_32B_tag MSG25_CS; /* offset: 0x0210 size: 32 bit */
17707  /* Message Buffer Identifier Field */
17708  FLEXCAN_MSG_ID_32B_tag MSG25_ID; /* offset: 0x0214 size: 32 bit */
17709  /* Message Buffer Data Register */
17710  FLEXCAN_MSG_DATA_32B_tag MSG25_BYTE0_3; /* offset: 0x0218 size: 32 bit */
17711  /* Message Buffer Data Register */
17712  FLEXCAN_MSG_DATA_32B_tag MSG25_BYTE4_7; /* offset: 0x021C size: 32 bit */
17713  /* Message Buffer Control and Status */
17714  FLEXCAN_MSG_CS_32B_tag MSG26_CS; /* offset: 0x0220 size: 32 bit */
17715  /* Message Buffer Identifier Field */
17716  FLEXCAN_MSG_ID_32B_tag MSG26_ID; /* offset: 0x0224 size: 32 bit */
17717  /* Message Buffer Data Register */
17718  FLEXCAN_MSG_DATA_32B_tag MSG26_BYTE0_3; /* offset: 0x0228 size: 32 bit */
17719  /* Message Buffer Data Register */
17720  FLEXCAN_MSG_DATA_32B_tag MSG26_BYTE4_7; /* offset: 0x022C size: 32 bit */
17721  /* Message Buffer Control and Status */
17722  FLEXCAN_MSG_CS_32B_tag MSG27_CS; /* offset: 0x0230 size: 32 bit */
17723  /* Message Buffer Identifier Field */
17724  FLEXCAN_MSG_ID_32B_tag MSG27_ID; /* offset: 0x0234 size: 32 bit */
17725  /* Message Buffer Data Register */
17726  FLEXCAN_MSG_DATA_32B_tag MSG27_BYTE0_3; /* offset: 0x0238 size: 32 bit */
17727  /* Message Buffer Data Register */
17728  FLEXCAN_MSG_DATA_32B_tag MSG27_BYTE4_7; /* offset: 0x023C size: 32 bit */
17729  /* Message Buffer Control and Status */
17730  FLEXCAN_MSG_CS_32B_tag MSG28_CS; /* offset: 0x0240 size: 32 bit */
17731  /* Message Buffer Identifier Field */
17732  FLEXCAN_MSG_ID_32B_tag MSG28_ID; /* offset: 0x0244 size: 32 bit */
17733  /* Message Buffer Data Register */
17734  FLEXCAN_MSG_DATA_32B_tag MSG28_BYTE0_3; /* offset: 0x0248 size: 32 bit */
17735  /* Message Buffer Data Register */
17736  FLEXCAN_MSG_DATA_32B_tag MSG28_BYTE4_7; /* offset: 0x024C size: 32 bit */
17737  /* Message Buffer Control and Status */
17738  FLEXCAN_MSG_CS_32B_tag MSG29_CS; /* offset: 0x0250 size: 32 bit */
17739  /* Message Buffer Identifier Field */
17740  FLEXCAN_MSG_ID_32B_tag MSG29_ID; /* offset: 0x0254 size: 32 bit */
17741  /* Message Buffer Data Register */
17742  FLEXCAN_MSG_DATA_32B_tag MSG29_BYTE0_3; /* offset: 0x0258 size: 32 bit */
17743  /* Message Buffer Data Register */
17744  FLEXCAN_MSG_DATA_32B_tag MSG29_BYTE4_7; /* offset: 0x025C size: 32 bit */
17745  /* Message Buffer Control and Status */
17746  FLEXCAN_MSG_CS_32B_tag MSG30_CS; /* offset: 0x0260 size: 32 bit */
17747  /* Message Buffer Identifier Field */
17748  FLEXCAN_MSG_ID_32B_tag MSG30_ID; /* offset: 0x0264 size: 32 bit */
17749  /* Message Buffer Data Register */
17750  FLEXCAN_MSG_DATA_32B_tag MSG30_BYTE0_3; /* offset: 0x0268 size: 32 bit */
17751  /* Message Buffer Data Register */
17752  FLEXCAN_MSG_DATA_32B_tag MSG30_BYTE4_7; /* offset: 0x026C size: 32 bit */
17753  /* Message Buffer Control and Status */
17754  FLEXCAN_MSG_CS_32B_tag MSG31_CS; /* offset: 0x0270 size: 32 bit */
17755  /* Message Buffer Identifier Field */
17756  FLEXCAN_MSG_ID_32B_tag MSG31_ID; /* offset: 0x0274 size: 32 bit */
17757  /* Message Buffer Data Register */
17758  FLEXCAN_MSG_DATA_32B_tag MSG31_BYTE0_3; /* offset: 0x0278 size: 32 bit */
17759  /* Message Buffer Data Register */
17760  FLEXCAN_MSG_DATA_32B_tag MSG31_BYTE4_7; /* offset: 0x027C size: 32 bit */
17761  /* Message Buffer Control and Status */
17762  FLEXCAN_MSG_CS_32B_tag MSG32_CS; /* offset: 0x0280 size: 32 bit */
17763  /* Message Buffer Identifier Field */
17764  FLEXCAN_MSG_ID_32B_tag MSG32_ID; /* offset: 0x0284 size: 32 bit */
17765  /* Message Buffer Data Register */
17766  FLEXCAN_MSG_DATA_32B_tag MSG32_BYTE0_3; /* offset: 0x0288 size: 32 bit */
17767  /* Message Buffer Data Register */
17768  FLEXCAN_MSG_DATA_32B_tag MSG32_BYTE4_7; /* offset: 0x028C size: 32 bit */
17769  /* Message Buffer Control and Status */
17770  FLEXCAN_MSG_CS_32B_tag MSG33_CS; /* offset: 0x0290 size: 32 bit */
17771  /* Message Buffer Identifier Field */
17772  FLEXCAN_MSG_ID_32B_tag MSG33_ID; /* offset: 0x0294 size: 32 bit */
17773  /* Message Buffer Data Register */
17774  FLEXCAN_MSG_DATA_32B_tag MSG33_BYTE0_3; /* offset: 0x0298 size: 32 bit */
17775  /* Message Buffer Data Register */
17776  FLEXCAN_MSG_DATA_32B_tag MSG33_BYTE4_7; /* offset: 0x029C size: 32 bit */
17777  /* Message Buffer Control and Status */
17778  FLEXCAN_MSG_CS_32B_tag MSG34_CS; /* offset: 0x02A0 size: 32 bit */
17779  /* Message Buffer Identifier Field */
17780  FLEXCAN_MSG_ID_32B_tag MSG34_ID; /* offset: 0x02A4 size: 32 bit */
17781  /* Message Buffer Data Register */
17782  FLEXCAN_MSG_DATA_32B_tag MSG34_BYTE0_3; /* offset: 0x02A8 size: 32 bit */
17783  /* Message Buffer Data Register */
17784  FLEXCAN_MSG_DATA_32B_tag MSG34_BYTE4_7; /* offset: 0x02AC size: 32 bit */
17785  /* Message Buffer Control and Status */
17786  FLEXCAN_MSG_CS_32B_tag MSG35_CS; /* offset: 0x02B0 size: 32 bit */
17787  /* Message Buffer Identifier Field */
17788  FLEXCAN_MSG_ID_32B_tag MSG35_ID; /* offset: 0x02B4 size: 32 bit */
17789  /* Message Buffer Data Register */
17790  FLEXCAN_MSG_DATA_32B_tag MSG35_BYTE0_3; /* offset: 0x02B8 size: 32 bit */
17791  /* Message Buffer Data Register */
17792  FLEXCAN_MSG_DATA_32B_tag MSG35_BYTE4_7; /* offset: 0x02BC size: 32 bit */
17793  /* Message Buffer Control and Status */
17794  FLEXCAN_MSG_CS_32B_tag MSG36_CS; /* offset: 0x02C0 size: 32 bit */
17795  /* Message Buffer Identifier Field */
17796  FLEXCAN_MSG_ID_32B_tag MSG36_ID; /* offset: 0x02C4 size: 32 bit */
17797  /* Message Buffer Data Register */
17798  FLEXCAN_MSG_DATA_32B_tag MSG36_BYTE0_3; /* offset: 0x02C8 size: 32 bit */
17799  /* Message Buffer Data Register */
17800  FLEXCAN_MSG_DATA_32B_tag MSG36_BYTE4_7; /* offset: 0x02CC size: 32 bit */
17801  /* Message Buffer Control and Status */
17802  FLEXCAN_MSG_CS_32B_tag MSG37_CS; /* offset: 0x02D0 size: 32 bit */
17803  /* Message Buffer Identifier Field */
17804  FLEXCAN_MSG_ID_32B_tag MSG37_ID; /* offset: 0x02D4 size: 32 bit */
17805  /* Message Buffer Data Register */
17806  FLEXCAN_MSG_DATA_32B_tag MSG37_BYTE0_3; /* offset: 0x02D8 size: 32 bit */
17807  /* Message Buffer Data Register */
17808  FLEXCAN_MSG_DATA_32B_tag MSG37_BYTE4_7; /* offset: 0x02DC size: 32 bit */
17809  /* Message Buffer Control and Status */
17810  FLEXCAN_MSG_CS_32B_tag MSG38_CS; /* offset: 0x02E0 size: 32 bit */
17811  /* Message Buffer Identifier Field */
17812  FLEXCAN_MSG_ID_32B_tag MSG38_ID; /* offset: 0x02E4 size: 32 bit */
17813  /* Message Buffer Data Register */
17814  FLEXCAN_MSG_DATA_32B_tag MSG38_BYTE0_3; /* offset: 0x02E8 size: 32 bit */
17815  /* Message Buffer Data Register */
17816  FLEXCAN_MSG_DATA_32B_tag MSG38_BYTE4_7; /* offset: 0x02EC size: 32 bit */
17817  /* Message Buffer Control and Status */
17818  FLEXCAN_MSG_CS_32B_tag MSG39_CS; /* offset: 0x02F0 size: 32 bit */
17819  /* Message Buffer Identifier Field */
17820  FLEXCAN_MSG_ID_32B_tag MSG39_ID; /* offset: 0x02F4 size: 32 bit */
17821  /* Message Buffer Data Register */
17822  FLEXCAN_MSG_DATA_32B_tag MSG39_BYTE0_3; /* offset: 0x02F8 size: 32 bit */
17823  /* Message Buffer Data Register */
17824  FLEXCAN_MSG_DATA_32B_tag MSG39_BYTE4_7; /* offset: 0x02FC size: 32 bit */
17825  /* Message Buffer Control and Status */
17826  FLEXCAN_MSG_CS_32B_tag MSG40_CS; /* offset: 0x0300 size: 32 bit */
17827  /* Message Buffer Identifier Field */
17828  FLEXCAN_MSG_ID_32B_tag MSG40_ID; /* offset: 0x0304 size: 32 bit */
17829  /* Message Buffer Data Register */
17830  FLEXCAN_MSG_DATA_32B_tag MSG40_BYTE0_3; /* offset: 0x0308 size: 32 bit */
17831  /* Message Buffer Data Register */
17832  FLEXCAN_MSG_DATA_32B_tag MSG40_BYTE4_7; /* offset: 0x030C size: 32 bit */
17833  /* Message Buffer Control and Status */
17834  FLEXCAN_MSG_CS_32B_tag MSG41_CS; /* offset: 0x0310 size: 32 bit */
17835  /* Message Buffer Identifier Field */
17836  FLEXCAN_MSG_ID_32B_tag MSG41_ID; /* offset: 0x0314 size: 32 bit */
17837  /* Message Buffer Data Register */
17838  FLEXCAN_MSG_DATA_32B_tag MSG41_BYTE0_3; /* offset: 0x0318 size: 32 bit */
17839  /* Message Buffer Data Register */
17840  FLEXCAN_MSG_DATA_32B_tag MSG41_BYTE4_7; /* offset: 0x031C size: 32 bit */
17841  /* Message Buffer Control and Status */
17842  FLEXCAN_MSG_CS_32B_tag MSG42_CS; /* offset: 0x0320 size: 32 bit */
17843  /* Message Buffer Identifier Field */
17844  FLEXCAN_MSG_ID_32B_tag MSG42_ID; /* offset: 0x0324 size: 32 bit */
17845  /* Message Buffer Data Register */
17846  FLEXCAN_MSG_DATA_32B_tag MSG42_BYTE0_3; /* offset: 0x0328 size: 32 bit */
17847  /* Message Buffer Data Register */
17848  FLEXCAN_MSG_DATA_32B_tag MSG42_BYTE4_7; /* offset: 0x032C size: 32 bit */
17849  /* Message Buffer Control and Status */
17850  FLEXCAN_MSG_CS_32B_tag MSG43_CS; /* offset: 0x0330 size: 32 bit */
17851  /* Message Buffer Identifier Field */
17852  FLEXCAN_MSG_ID_32B_tag MSG43_ID; /* offset: 0x0334 size: 32 bit */
17853  /* Message Buffer Data Register */
17854  FLEXCAN_MSG_DATA_32B_tag MSG43_BYTE0_3; /* offset: 0x0338 size: 32 bit */
17855  /* Message Buffer Data Register */
17856  FLEXCAN_MSG_DATA_32B_tag MSG43_BYTE4_7; /* offset: 0x033C size: 32 bit */
17857  /* Message Buffer Control and Status */
17858  FLEXCAN_MSG_CS_32B_tag MSG44_CS; /* offset: 0x0340 size: 32 bit */
17859  /* Message Buffer Identifier Field */
17860  FLEXCAN_MSG_ID_32B_tag MSG44_ID; /* offset: 0x0344 size: 32 bit */
17861  /* Message Buffer Data Register */
17862  FLEXCAN_MSG_DATA_32B_tag MSG44_BYTE0_3; /* offset: 0x0348 size: 32 bit */
17863  /* Message Buffer Data Register */
17864  FLEXCAN_MSG_DATA_32B_tag MSG44_BYTE4_7; /* offset: 0x034C size: 32 bit */
17865  /* Message Buffer Control and Status */
17866  FLEXCAN_MSG_CS_32B_tag MSG45_CS; /* offset: 0x0350 size: 32 bit */
17867  /* Message Buffer Identifier Field */
17868  FLEXCAN_MSG_ID_32B_tag MSG45_ID; /* offset: 0x0354 size: 32 bit */
17869  /* Message Buffer Data Register */
17870  FLEXCAN_MSG_DATA_32B_tag MSG45_BYTE0_3; /* offset: 0x0358 size: 32 bit */
17871  /* Message Buffer Data Register */
17872  FLEXCAN_MSG_DATA_32B_tag MSG45_BYTE4_7; /* offset: 0x035C size: 32 bit */
17873  /* Message Buffer Control and Status */
17874  FLEXCAN_MSG_CS_32B_tag MSG46_CS; /* offset: 0x0360 size: 32 bit */
17875  /* Message Buffer Identifier Field */
17876  FLEXCAN_MSG_ID_32B_tag MSG46_ID; /* offset: 0x0364 size: 32 bit */
17877  /* Message Buffer Data Register */
17878  FLEXCAN_MSG_DATA_32B_tag MSG46_BYTE0_3; /* offset: 0x0368 size: 32 bit */
17879  /* Message Buffer Data Register */
17880  FLEXCAN_MSG_DATA_32B_tag MSG46_BYTE4_7; /* offset: 0x036C size: 32 bit */
17881  /* Message Buffer Control and Status */
17882  FLEXCAN_MSG_CS_32B_tag MSG47_CS; /* offset: 0x0370 size: 32 bit */
17883  /* Message Buffer Identifier Field */
17884  FLEXCAN_MSG_ID_32B_tag MSG47_ID; /* offset: 0x0374 size: 32 bit */
17885  /* Message Buffer Data Register */
17886  FLEXCAN_MSG_DATA_32B_tag MSG47_BYTE0_3; /* offset: 0x0378 size: 32 bit */
17887  /* Message Buffer Data Register */
17888  FLEXCAN_MSG_DATA_32B_tag MSG47_BYTE4_7; /* offset: 0x037C size: 32 bit */
17889  /* Message Buffer Control and Status */
17890  FLEXCAN_MSG_CS_32B_tag MSG48_CS; /* offset: 0x0380 size: 32 bit */
17891  /* Message Buffer Identifier Field */
17892  FLEXCAN_MSG_ID_32B_tag MSG48_ID; /* offset: 0x0384 size: 32 bit */
17893  /* Message Buffer Data Register */
17894  FLEXCAN_MSG_DATA_32B_tag MSG48_BYTE0_3; /* offset: 0x0388 size: 32 bit */
17895  /* Message Buffer Data Register */
17896  FLEXCAN_MSG_DATA_32B_tag MSG48_BYTE4_7; /* offset: 0x038C size: 32 bit */
17897  /* Message Buffer Control and Status */
17898  FLEXCAN_MSG_CS_32B_tag MSG49_CS; /* offset: 0x0390 size: 32 bit */
17899  /* Message Buffer Identifier Field */
17900  FLEXCAN_MSG_ID_32B_tag MSG49_ID; /* offset: 0x0394 size: 32 bit */
17901  /* Message Buffer Data Register */
17902  FLEXCAN_MSG_DATA_32B_tag MSG49_BYTE0_3; /* offset: 0x0398 size: 32 bit */
17903  /* Message Buffer Data Register */
17904  FLEXCAN_MSG_DATA_32B_tag MSG49_BYTE4_7; /* offset: 0x039C size: 32 bit */
17905  /* Message Buffer Control and Status */
17906  FLEXCAN_MSG_CS_32B_tag MSG50_CS; /* offset: 0x03A0 size: 32 bit */
17907  /* Message Buffer Identifier Field */
17908  FLEXCAN_MSG_ID_32B_tag MSG50_ID; /* offset: 0x03A4 size: 32 bit */
17909  /* Message Buffer Data Register */
17910  FLEXCAN_MSG_DATA_32B_tag MSG50_BYTE0_3; /* offset: 0x03A8 size: 32 bit */
17911  /* Message Buffer Data Register */
17912  FLEXCAN_MSG_DATA_32B_tag MSG50_BYTE4_7; /* offset: 0x03AC size: 32 bit */
17913  /* Message Buffer Control and Status */
17914  FLEXCAN_MSG_CS_32B_tag MSG51_CS; /* offset: 0x03B0 size: 32 bit */
17915  /* Message Buffer Identifier Field */
17916  FLEXCAN_MSG_ID_32B_tag MSG51_ID; /* offset: 0x03B4 size: 32 bit */
17917  /* Message Buffer Data Register */
17918  FLEXCAN_MSG_DATA_32B_tag MSG51_BYTE0_3; /* offset: 0x03B8 size: 32 bit */
17919  /* Message Buffer Data Register */
17920  FLEXCAN_MSG_DATA_32B_tag MSG51_BYTE4_7; /* offset: 0x03BC size: 32 bit */
17921  /* Message Buffer Control and Status */
17922  FLEXCAN_MSG_CS_32B_tag MSG52_CS; /* offset: 0x03C0 size: 32 bit */
17923  /* Message Buffer Identifier Field */
17924  FLEXCAN_MSG_ID_32B_tag MSG52_ID; /* offset: 0x03C4 size: 32 bit */
17925  /* Message Buffer Data Register */
17926  FLEXCAN_MSG_DATA_32B_tag MSG52_BYTE0_3; /* offset: 0x03C8 size: 32 bit */
17927  /* Message Buffer Data Register */
17928  FLEXCAN_MSG_DATA_32B_tag MSG52_BYTE4_7; /* offset: 0x03CC size: 32 bit */
17929  /* Message Buffer Control and Status */
17930  FLEXCAN_MSG_CS_32B_tag MSG53_CS; /* offset: 0x03D0 size: 32 bit */
17931  /* Message Buffer Identifier Field */
17932  FLEXCAN_MSG_ID_32B_tag MSG53_ID; /* offset: 0x03D4 size: 32 bit */
17933  /* Message Buffer Data Register */
17934  FLEXCAN_MSG_DATA_32B_tag MSG53_BYTE0_3; /* offset: 0x03D8 size: 32 bit */
17935  /* Message Buffer Data Register */
17936  FLEXCAN_MSG_DATA_32B_tag MSG53_BYTE4_7; /* offset: 0x03DC size: 32 bit */
17937  /* Message Buffer Control and Status */
17938  FLEXCAN_MSG_CS_32B_tag MSG54_CS; /* offset: 0x03E0 size: 32 bit */
17939  /* Message Buffer Identifier Field */
17940  FLEXCAN_MSG_ID_32B_tag MSG54_ID; /* offset: 0x03E4 size: 32 bit */
17941  /* Message Buffer Data Register */
17942  FLEXCAN_MSG_DATA_32B_tag MSG54_BYTE0_3; /* offset: 0x03E8 size: 32 bit */
17943  /* Message Buffer Data Register */
17944  FLEXCAN_MSG_DATA_32B_tag MSG54_BYTE4_7; /* offset: 0x03EC size: 32 bit */
17945  /* Message Buffer Control and Status */
17946  FLEXCAN_MSG_CS_32B_tag MSG55_CS; /* offset: 0x03F0 size: 32 bit */
17947  /* Message Buffer Identifier Field */
17948  FLEXCAN_MSG_ID_32B_tag MSG55_ID; /* offset: 0x03F4 size: 32 bit */
17949  /* Message Buffer Data Register */
17950  FLEXCAN_MSG_DATA_32B_tag MSG55_BYTE0_3; /* offset: 0x03F8 size: 32 bit */
17951  /* Message Buffer Data Register */
17952  FLEXCAN_MSG_DATA_32B_tag MSG55_BYTE4_7; /* offset: 0x03FC size: 32 bit */
17953  /* Message Buffer Control and Status */
17954  FLEXCAN_MSG_CS_32B_tag MSG56_CS; /* offset: 0x0400 size: 32 bit */
17955  /* Message Buffer Identifier Field */
17956  FLEXCAN_MSG_ID_32B_tag MSG56_ID; /* offset: 0x0404 size: 32 bit */
17957  /* Message Buffer Data Register */
17958  FLEXCAN_MSG_DATA_32B_tag MSG56_BYTE0_3; /* offset: 0x0408 size: 32 bit */
17959  /* Message Buffer Data Register */
17960  FLEXCAN_MSG_DATA_32B_tag MSG56_BYTE4_7; /* offset: 0x040C size: 32 bit */
17961  /* Message Buffer Control and Status */
17962  FLEXCAN_MSG_CS_32B_tag MSG57_CS; /* offset: 0x0410 size: 32 bit */
17963  /* Message Buffer Identifier Field */
17964  FLEXCAN_MSG_ID_32B_tag MSG57_ID; /* offset: 0x0414 size: 32 bit */
17965  /* Message Buffer Data Register */
17966  FLEXCAN_MSG_DATA_32B_tag MSG57_BYTE0_3; /* offset: 0x0418 size: 32 bit */
17967  /* Message Buffer Data Register */
17968  FLEXCAN_MSG_DATA_32B_tag MSG57_BYTE4_7; /* offset: 0x041C size: 32 bit */
17969  /* Message Buffer Control and Status */
17970  FLEXCAN_MSG_CS_32B_tag MSG58_CS; /* offset: 0x0420 size: 32 bit */
17971  /* Message Buffer Identifier Field */
17972  FLEXCAN_MSG_ID_32B_tag MSG58_ID; /* offset: 0x0424 size: 32 bit */
17973  /* Message Buffer Data Register */
17974  FLEXCAN_MSG_DATA_32B_tag MSG58_BYTE0_3; /* offset: 0x0428 size: 32 bit */
17975  /* Message Buffer Data Register */
17976  FLEXCAN_MSG_DATA_32B_tag MSG58_BYTE4_7; /* offset: 0x042C size: 32 bit */
17977  /* Message Buffer Control and Status */
17978  FLEXCAN_MSG_CS_32B_tag MSG59_CS; /* offset: 0x0430 size: 32 bit */
17979  /* Message Buffer Identifier Field */
17980  FLEXCAN_MSG_ID_32B_tag MSG59_ID; /* offset: 0x0434 size: 32 bit */
17981  /* Message Buffer Data Register */
17982  FLEXCAN_MSG_DATA_32B_tag MSG59_BYTE0_3; /* offset: 0x0438 size: 32 bit */
17983  /* Message Buffer Data Register */
17984  FLEXCAN_MSG_DATA_32B_tag MSG59_BYTE4_7; /* offset: 0x043C size: 32 bit */
17985  /* Message Buffer Control and Status */
17986  FLEXCAN_MSG_CS_32B_tag MSG60_CS; /* offset: 0x0440 size: 32 bit */
17987  /* Message Buffer Identifier Field */
17988  FLEXCAN_MSG_ID_32B_tag MSG60_ID; /* offset: 0x0444 size: 32 bit */
17989  /* Message Buffer Data Register */
17990  FLEXCAN_MSG_DATA_32B_tag MSG60_BYTE0_3; /* offset: 0x0448 size: 32 bit */
17991  /* Message Buffer Data Register */
17992  FLEXCAN_MSG_DATA_32B_tag MSG60_BYTE4_7; /* offset: 0x044C size: 32 bit */
17993  /* Message Buffer Control and Status */
17994  FLEXCAN_MSG_CS_32B_tag MSG61_CS; /* offset: 0x0450 size: 32 bit */
17995  /* Message Buffer Identifier Field */
17996  FLEXCAN_MSG_ID_32B_tag MSG61_ID; /* offset: 0x0454 size: 32 bit */
17997  /* Message Buffer Data Register */
17998  FLEXCAN_MSG_DATA_32B_tag MSG61_BYTE0_3; /* offset: 0x0458 size: 32 bit */
17999  /* Message Buffer Data Register */
18000  FLEXCAN_MSG_DATA_32B_tag MSG61_BYTE4_7; /* offset: 0x045C size: 32 bit */
18001  /* Message Buffer Control and Status */
18002  FLEXCAN_MSG_CS_32B_tag MSG62_CS; /* offset: 0x0460 size: 32 bit */
18003  /* Message Buffer Identifier Field */
18004  FLEXCAN_MSG_ID_32B_tag MSG62_ID; /* offset: 0x0464 size: 32 bit */
18005  /* Message Buffer Data Register */
18006  FLEXCAN_MSG_DATA_32B_tag MSG62_BYTE0_3; /* offset: 0x0468 size: 32 bit */
18007  /* Message Buffer Data Register */
18008  FLEXCAN_MSG_DATA_32B_tag MSG62_BYTE4_7; /* offset: 0x046C size: 32 bit */
18009  /* Message Buffer Control and Status */
18010  FLEXCAN_MSG_CS_32B_tag MSG63_CS; /* offset: 0x0470 size: 32 bit */
18011  /* Message Buffer Identifier Field */
18012  FLEXCAN_MSG_ID_32B_tag MSG63_ID; /* offset: 0x0474 size: 32 bit */
18013  /* Message Buffer Data Register */
18014  FLEXCAN_MSG_DATA_32B_tag MSG63_BYTE0_3; /* offset: 0x0478 size: 32 bit */
18015  /* Message Buffer Data Register */
18016  FLEXCAN_MSG_DATA_32B_tag MSG63_BYTE4_7; /* offset: 0x047C size: 32 bit */
18017  };
18018
18019  };
18020  int8_t FLEXCAN_reserved_0480_C[1024];
18021  union {
18022  /* FLEXCAN_RXIMR0 - FLEXCAN_RXIMR63 - RX Individual Mask Registers */
18023  FLEXCAN_RXIMR_32B_tag RXIMR[64]; /* offset: 0x0880 (0x0004 x 64) */
18024
18025  struct {
18026  /* FLEXCAN_RXIMR0 - FLEXCAN_RXIMR63 - RX Individual Mask Registers */
18027  FLEXCAN_RXIMR_32B_tag RXIMR0; /* offset: 0x0880 size: 32 bit */
18028  FLEXCAN_RXIMR_32B_tag RXIMR1; /* offset: 0x0884 size: 32 bit */
18029  FLEXCAN_RXIMR_32B_tag RXIMR2; /* offset: 0x0888 size: 32 bit */
18030  FLEXCAN_RXIMR_32B_tag RXIMR3; /* offset: 0x088C size: 32 bit */
18031  FLEXCAN_RXIMR_32B_tag RXIMR4; /* offset: 0x0890 size: 32 bit */
18032  FLEXCAN_RXIMR_32B_tag RXIMR5; /* offset: 0x0894 size: 32 bit */
18033  FLEXCAN_RXIMR_32B_tag RXIMR6; /* offset: 0x0898 size: 32 bit */
18034  FLEXCAN_RXIMR_32B_tag RXIMR7; /* offset: 0x089C size: 32 bit */
18035  FLEXCAN_RXIMR_32B_tag RXIMR8; /* offset: 0x08A0 size: 32 bit */
18036  FLEXCAN_RXIMR_32B_tag RXIMR9; /* offset: 0x08A4 size: 32 bit */
18037  FLEXCAN_RXIMR_32B_tag RXIMR10; /* offset: 0x08A8 size: 32 bit */
18038  FLEXCAN_RXIMR_32B_tag RXIMR11; /* offset: 0x08AC size: 32 bit */
18039  FLEXCAN_RXIMR_32B_tag RXIMR12; /* offset: 0x08B0 size: 32 bit */
18040  FLEXCAN_RXIMR_32B_tag RXIMR13; /* offset: 0x08B4 size: 32 bit */
18041  FLEXCAN_RXIMR_32B_tag RXIMR14; /* offset: 0x08B8 size: 32 bit */
18042  FLEXCAN_RXIMR_32B_tag RXIMR15; /* offset: 0x08BC size: 32 bit */
18043  FLEXCAN_RXIMR_32B_tag RXIMR16; /* offset: 0x08C0 size: 32 bit */
18044  FLEXCAN_RXIMR_32B_tag RXIMR17; /* offset: 0x08C4 size: 32 bit */
18045  FLEXCAN_RXIMR_32B_tag RXIMR18; /* offset: 0x08C8 size: 32 bit */
18046  FLEXCAN_RXIMR_32B_tag RXIMR19; /* offset: 0x08CC size: 32 bit */
18047  FLEXCAN_RXIMR_32B_tag RXIMR20; /* offset: 0x08D0 size: 32 bit */
18048  FLEXCAN_RXIMR_32B_tag RXIMR21; /* offset: 0x08D4 size: 32 bit */
18049  FLEXCAN_RXIMR_32B_tag RXIMR22; /* offset: 0x08D8 size: 32 bit */
18050  FLEXCAN_RXIMR_32B_tag RXIMR23; /* offset: 0x08DC size: 32 bit */
18051  FLEXCAN_RXIMR_32B_tag RXIMR24; /* offset: 0x08E0 size: 32 bit */
18052  FLEXCAN_RXIMR_32B_tag RXIMR25; /* offset: 0x08E4 size: 32 bit */
18053  FLEXCAN_RXIMR_32B_tag RXIMR26; /* offset: 0x08E8 size: 32 bit */
18054  FLEXCAN_RXIMR_32B_tag RXIMR27; /* offset: 0x08EC size: 32 bit */
18055  FLEXCAN_RXIMR_32B_tag RXIMR28; /* offset: 0x08F0 size: 32 bit */
18056  FLEXCAN_RXIMR_32B_tag RXIMR29; /* offset: 0x08F4 size: 32 bit */
18057  FLEXCAN_RXIMR_32B_tag RXIMR30; /* offset: 0x08F8 size: 32 bit */
18058  FLEXCAN_RXIMR_32B_tag RXIMR31; /* offset: 0x08FC size: 32 bit */
18059  FLEXCAN_RXIMR_32B_tag RXIMR32; /* offset: 0x0900 size: 32 bit */
18060  FLEXCAN_RXIMR_32B_tag RXIMR33; /* offset: 0x0904 size: 32 bit */
18061  FLEXCAN_RXIMR_32B_tag RXIMR34; /* offset: 0x0908 size: 32 bit */
18062  FLEXCAN_RXIMR_32B_tag RXIMR35; /* offset: 0x090C size: 32 bit */
18063  FLEXCAN_RXIMR_32B_tag RXIMR36; /* offset: 0x0910 size: 32 bit */
18064  FLEXCAN_RXIMR_32B_tag RXIMR37; /* offset: 0x0914 size: 32 bit */
18065  FLEXCAN_RXIMR_32B_tag RXIMR38; /* offset: 0x0918 size: 32 bit */
18066  FLEXCAN_RXIMR_32B_tag RXIMR39; /* offset: 0x091C size: 32 bit */
18067  FLEXCAN_RXIMR_32B_tag RXIMR40; /* offset: 0x0920 size: 32 bit */
18068  FLEXCAN_RXIMR_32B_tag RXIMR41; /* offset: 0x0924 size: 32 bit */
18069  FLEXCAN_RXIMR_32B_tag RXIMR42; /* offset: 0x0928 size: 32 bit */
18070  FLEXCAN_RXIMR_32B_tag RXIMR43; /* offset: 0x092C size: 32 bit */
18071  FLEXCAN_RXIMR_32B_tag RXIMR44; /* offset: 0x0930 size: 32 bit */
18072  FLEXCAN_RXIMR_32B_tag RXIMR45; /* offset: 0x0934 size: 32 bit */
18073  FLEXCAN_RXIMR_32B_tag RXIMR46; /* offset: 0x0938 size: 32 bit */
18074  FLEXCAN_RXIMR_32B_tag RXIMR47; /* offset: 0x093C size: 32 bit */
18075  FLEXCAN_RXIMR_32B_tag RXIMR48; /* offset: 0x0940 size: 32 bit */
18076  FLEXCAN_RXIMR_32B_tag RXIMR49; /* offset: 0x0944 size: 32 bit */
18077  FLEXCAN_RXIMR_32B_tag RXIMR50; /* offset: 0x0948 size: 32 bit */
18078  FLEXCAN_RXIMR_32B_tag RXIMR51; /* offset: 0x094C size: 32 bit */
18079  FLEXCAN_RXIMR_32B_tag RXIMR52; /* offset: 0x0950 size: 32 bit */
18080  FLEXCAN_RXIMR_32B_tag RXIMR53; /* offset: 0x0954 size: 32 bit */
18081  FLEXCAN_RXIMR_32B_tag RXIMR54; /* offset: 0x0958 size: 32 bit */
18082  FLEXCAN_RXIMR_32B_tag RXIMR55; /* offset: 0x095C size: 32 bit */
18083  FLEXCAN_RXIMR_32B_tag RXIMR56; /* offset: 0x0960 size: 32 bit */
18084  FLEXCAN_RXIMR_32B_tag RXIMR57; /* offset: 0x0964 size: 32 bit */
18085  FLEXCAN_RXIMR_32B_tag RXIMR58; /* offset: 0x0968 size: 32 bit */
18086  FLEXCAN_RXIMR_32B_tag RXIMR59; /* offset: 0x096C size: 32 bit */
18087  FLEXCAN_RXIMR_32B_tag RXIMR60; /* offset: 0x0970 size: 32 bit */
18088  FLEXCAN_RXIMR_32B_tag RXIMR61; /* offset: 0x0974 size: 32 bit */
18089  FLEXCAN_RXIMR_32B_tag RXIMR62; /* offset: 0x0978 size: 32 bit */
18090  FLEXCAN_RXIMR_32B_tag RXIMR63; /* offset: 0x097C size: 32 bit */
18091  };
18092
18093  };
18094  } FLEXCAN_tag;
18095
18096
18097 #define FLEXCAN_A (*(volatile FLEXCAN_tag *) 0xFFFC0000UL)
18098 #define FLEXCAN_B (*(volatile FLEXCAN_tag *) 0xFFFC4000UL)
18099
18100
18101
18102 /****************************************************************/
18103 /* */
18104 /* Module: DMA_CH_MUX */
18105 /* */
18106 /****************************************************************/
18107
18108
18109  /* Register layout for all registers CHCONFIG... */
18110
18111  typedef union { /* CHCONFIG[0-15] - Channel Configuration Registers */
18112  uint8_t R;
18113  struct {
18114  uint8_t ENBL:1; /* DMA Channel Enable */
18115  uint8_t TRIG:1; /* DMA Channel Trigger Enable */
18116  uint8_t SOURCE:6; /* DMA Channel Source */
18117  } B;
18119
18120
18121
18122  typedef struct DMA_CH_MUX_struct_tag { /* start of DMA_CH_MUX_tag */
18123  union {
18124  /* CHCONFIG[0-15] - Channel Configuration Registers */
18125  DMA_CH_MUX_CHCONFIG_8B_tag CHCONFIG[16]; /* offset: 0x0000 (0x0001 x 16) */
18126
18127  struct {
18128  /* CHCONFIG[0-15] - Channel Configuration Registers */
18129  DMA_CH_MUX_CHCONFIG_8B_tag CHCONFIG0; /* offset: 0x0000 size: 8 bit */
18130  DMA_CH_MUX_CHCONFIG_8B_tag CHCONFIG1; /* offset: 0x0001 size: 8 bit */
18131  DMA_CH_MUX_CHCONFIG_8B_tag CHCONFIG2; /* offset: 0x0002 size: 8 bit */
18132  DMA_CH_MUX_CHCONFIG_8B_tag CHCONFIG3; /* offset: 0x0003 size: 8 bit */
18133  DMA_CH_MUX_CHCONFIG_8B_tag CHCONFIG4; /* offset: 0x0004 size: 8 bit */
18134  DMA_CH_MUX_CHCONFIG_8B_tag CHCONFIG5; /* offset: 0x0005 size: 8 bit */
18135  DMA_CH_MUX_CHCONFIG_8B_tag CHCONFIG6; /* offset: 0x0006 size: 8 bit */
18136  DMA_CH_MUX_CHCONFIG_8B_tag CHCONFIG7; /* offset: 0x0007 size: 8 bit */
18137  DMA_CH_MUX_CHCONFIG_8B_tag CHCONFIG8; /* offset: 0x0008 size: 8 bit */
18138  DMA_CH_MUX_CHCONFIG_8B_tag CHCONFIG9; /* offset: 0x0009 size: 8 bit */
18139  DMA_CH_MUX_CHCONFIG_8B_tag CHCONFIG10; /* offset: 0x000A size: 8 bit */
18140  DMA_CH_MUX_CHCONFIG_8B_tag CHCONFIG11; /* offset: 0x000B size: 8 bit */
18141  DMA_CH_MUX_CHCONFIG_8B_tag CHCONFIG12; /* offset: 0x000C size: 8 bit */
18142  DMA_CH_MUX_CHCONFIG_8B_tag CHCONFIG13; /* offset: 0x000D size: 8 bit */
18143  DMA_CH_MUX_CHCONFIG_8B_tag CHCONFIG14; /* offset: 0x000E size: 8 bit */
18144  DMA_CH_MUX_CHCONFIG_8B_tag CHCONFIG15; /* offset: 0x000F size: 8 bit */
18145  };
18146
18147  };
18148  } DMA_CH_MUX_tag;
18149
18150
18151 #define DMA_CH_MUX (*(volatile DMA_CH_MUX_tag *) 0xFFFDC000UL)
18152
18153
18154
18155 /****************************************************************/
18156 /* */
18157 /* Module: FR */
18158 /* */
18159 /****************************************************************/
18160
18161  typedef union { /* Module Version Number */
18162  uint16_t R;
18163  struct {
18164  uint16_t CHIVER:8; /* VERSION NUMBER OF CHI */
18165  uint16_t PEVER:8; /* VERSION NUMBER OF PE */
18166  } B;
18167  } FR_MVR_16B_tag;
18168
18169  typedef union { /* Module Configuration Register */
18170  uint16_t R;
18171  struct {
18172  uint16_t MEN:1; /* Module Enable */
18173  uint16_t SBFF:1; /* System Bus Failure Freeze */
18174 #ifndef USE_FIELD_ALIASES_FR
18175  uint16_t SCM:1; /* single channel device mode */
18176 #else
18177  uint16_t SCMD:1; /* deprecated name - please avoid */
18178 #endif
18179  uint16_t CHB:1; /* Channel B enable */
18180  uint16_t CHA:1; /* channel A enable */
18181  uint16_t SFFE:1; /* Sync. frame filter Enable */
18182  uint16_t ECCE:1; /* ECC Functionlity Enable */
18183  uint16_t TMODER:1; /* Functional Test mode */
18184  uint16_t FUM:1; /* FIFO Update Mode */
18185  uint16_t FAM:1; /* FIFO Address Mode */
18186  uint16_t:1;
18187  uint16_t CLKSEL:1; /* Protocol Engine clock source select */
18188  uint16_t BITRATE:3; /* Bus bit rate */
18189  uint16_t:1;
18190  } B;
18191  } FR_MCR_16B_tag;
18192
18193  typedef union { /* SYSTEM MEMORY BASE ADD HIGH REG */
18194  uint16_t R;
18195  struct {
18196  uint16_t SMBA_31_16:16; /* SYS_MEM_BASE_ADDR[31:16] */
18197  } B;
18199
18200  typedef union { /* SYSTEM MEMORY BASE ADD LOW REG */
18201  uint16_t R;
18202  struct {
18203  uint16_t SMBA_15_4:12; /* SYS_MEM_BASE_ADDR[15:4] */
18204  uint16_t:4;
18205  } B;
18207
18208  typedef union { /* STROBE SIGNAL CONTROL REGISTER */
18209  uint16_t R;
18210  struct {
18211  uint16_t WMD:1; /* DEFINES WRITE MODE OF REG */
18212  uint16_t:3;
18213  uint16_t SEL:4; /* STROBE SIGNSL SELECT */
18214  uint16_t:3;
18215  uint16_t ENB:1; /* STROBE SIGNAL ENABLE */
18216  uint16_t:2;
18217  uint16_t STBPSEL:2; /* STROBE PORT SELECT */
18218  } B;
18220
18221  typedef union { /* MESSAGE BUFFER DATA SIZE REGISTER */
18222  uint16_t R;
18223  struct {
18224  uint16_t:1;
18225  uint16_t MBSEG2DS:7; /* MESSAGE BUFFER SEGMENT 2 DATA SIZE */
18226  uint16_t:1;
18227  uint16_t MBSEG1DS:7; /* MESSAGE BUFFER SEGMENT 1 DATA SIZE */
18228  } B;
18229  } FR_MBDSR_16B_tag;
18230
18231  typedef union { /* MESS. BUFFER SEG. SIZE & UTILISATION REG */
18232  uint16_t R;
18233  struct {
18234  uint16_t:2;
18235  uint16_t LAST_MB_SEG1:6; /* LAST MESS BUFFER IN SEG 1 */
18236  uint16_t:2;
18237  uint16_t LAST_MB_UTIL:6; /* LAST MESSAGE BUFFER UTILISED */
18238  } B;
18240
18241  typedef union { /* PE DRAM ACCESS REGISTER */
18242  uint16_t R;
18243  struct {
18244  uint16_t INST:4; /* PE DRAM ACCESS INSTRUCTION */
18245  uint16_t ADDR:11; /* PE DRAM ACCESS ADDRESS */
18246  uint16_t DAD:1; /* PE DRAM ACCESS DONE */
18247  } B;
18249
18250  typedef union { /* PE DRAM DATA REGISTER */
18251  uint16_t R;
18252  struct {
18253  uint16_t DATA:16; /* DATA TO BE READ OR WRITTEN */
18254  } B;
18256
18257  typedef union { /* PROTOCOL OPERATION CONTROL REG */
18258  uint16_t R;
18259  struct {
18260  uint16_t WME:1; /* WRITE MODE EXTERNAL CORRECTION */
18261  uint16_t:3;
18262  uint16_t EOC_AP:2; /* EXTERNAL OFFSET CORRECTION APPLICATION */
18263  uint16_t ERC_AP:2; /* EXTERNAL RATE CORRECTION APPLICATION */
18264  uint16_t BSY:1; /* PROTOCOL CONTROL COMMAND WRITE BUSY */
18265  uint16_t:3;
18266  uint16_t POCCMD:4; /* PROTOCOL CONTROL COMMAND */
18267  } B;
18268  } FR_POCR_16B_tag;
18269
18270  typedef union { /* GLOBAL INTERRUPT FLAG & ENABLE REG */
18271  uint16_t R;
18272  struct {
18273  uint16_t MIF:1; /* MODULE INTERRUPT FLAG */
18274  uint16_t PRIF:1; /* PROTOCOL INTERRUPT FLAG */
18275  uint16_t CHIF:1; /* CHI INTERRUPT FLAG */
18276 #ifndef USE_FIELD_ALIASES_FR
18277  uint16_t WUPIF:1; /* WAKEUP INTERRUPT FLAG */
18278 #else
18279  uint16_t WKUPIF:1; /* deprecated name - please avoid */
18280 #endif
18281 #ifndef USE_FIELD_ALIASES_FR
18282  uint16_t FAFBIF:1; /* RECEIVE FIFO CHANNEL B ALMOST FULL INTERRUPT FLAG */
18283 #else
18284  uint16_t FNEBIF:1; /* deprecated name - please avoid */
18285 #endif
18286 #ifndef USE_FIELD_ALIASES_FR
18287  uint16_t FAFAIF:1; /* RECEIVE FIFO CHANNEL A ALMOST FULL INTERRUPT FLAG */
18288 #else
18289  uint16_t FNEAIF:1; /* deprecated name - please avoid */
18290 #endif
18291  uint16_t RBIF:1; /* RECEIVE MESSAGE BUFFER INTERRUPT FLAG */
18292  uint16_t TBIF:1; /* TRANSMIT BUFFER INTERRUPT FLAG */
18293  uint16_t MIE:1; /* MODULE INTERRUPT ENABLE */
18294  uint16_t PRIE:1; /* PROTOCOL INTERRUPT ENABLE */
18295  uint16_t CHIE:1; /* CHI INTERRUPT ENABLE */
18296 #ifndef USE_FIELD_ALIASES_FR
18297  uint16_t WUPIE:1; /* WAKEUP INTERRUPT ENABLE */
18298 #else
18299  uint16_t WKUPIE:1; /* deprecated name - please avoid */
18300 #endif
18301  uint16_t FNEBIE:1; /* RECEIVE FIFO CHANNEL B NOT EMPTY INTERRUPT ENABLE */
18302  uint16_t FNEAIE:1; /* RECEIVE FIFO CHANNEL A NOT EMPTY INTERRUPT ENABLE */
18303  uint16_t RBIE:1; /* RECEIVE BUFFER INTERRUPT ENABLE */
18304  uint16_t TBIE:1; /* TRANSMIT BUFFER INTERRUPT ENABLE */
18305  } B;
18306  } FR_GIFER_16B_tag;
18307
18308  typedef union { /* PROTOCOL INTERRUPT FLAG REGISTER 0 */
18309  uint16_t R;
18310  struct {
18311 #ifndef USE_FIELD_ALIASES_FR
18312  uint16_t FATL_IF:1; /* FATAL PROTOCOL ERROR INTERRUPT FLAG */
18313 #else
18314  uint16_t FATLIF:1; /* deprecated name - please avoid */
18315 #endif
18316 #ifndef USE_FIELD_ALIASES_FR
18317  uint16_t INTL_IF:1; /* INTERNAL PROTOCOL ERROR INTERRUPT FLAG */
18318 #else
18319  uint16_t INTLIF:1; /* deprecated name - please avoid */
18320 #endif
18321 #ifndef USE_FIELD_ALIASES_FR
18322  uint16_t ILCF_IF:1; /* ILLEGAL PROTOCOL CONFIGURATION INTERRUPT FLAG */
18323 #else
18324  uint16_t ILCFIF:1; /* deprecated name - please avoid */
18325 #endif
18326 #ifndef USE_FIELD_ALIASES_FR
18327  uint16_t CSA_IF:1; /* COLDSTART ABORT INTERRUPT FLAG */
18328 #else
18329  uint16_t CSAIF:1; /* deprecated name - please avoid */
18330 #endif
18331 #ifndef USE_FIELD_ALIASES_FR
18332  uint16_t MRC_IF:1; /* MISSING RATE CORRECTION INTERRUPT FLAG */
18333 #else
18334  uint16_t MRCIF:1; /* deprecated name - please avoid */
18335 #endif
18336 #ifndef USE_FIELD_ALIASES_FR
18337  uint16_t MOC_IF:1; /* MISSING OFFSET CORRECTION INTERRUPT FLAG */
18338 #else
18339  uint16_t MOCIF:1; /* deprecated name - please avoid */
18340 #endif
18341 #ifndef USE_FIELD_ALIASES_FR
18342  uint16_t CCL_IF:1; /* CLOCK CORRECTION LIMIT REACHED INTERRUPT FLAG */
18343 #else
18344  uint16_t CCLIF:1; /* deprecated name - please avoid */
18345 #endif
18346 #ifndef USE_FIELD_ALIASES_FR
18347  uint16_t MXS_IF:1; /* MAX SYNC FRAMES DETECTED INTERRUPT FLAG */
18348 #else
18349  uint16_t MXSIF:1; /* deprecated name - please avoid */
18350 #endif
18351 #ifndef USE_FIELD_ALIASES_FR
18352  uint16_t MTX_IF:1; /* MEDIA ACCESS TEST SYMBOL RECEIVED INTERRUPT FLAG */
18353 #else
18354  uint16_t MTXIF:1; /* deprecated name - please avoid */
18355 #endif
18356 #ifndef USE_FIELD_ALIASES_FR
18357  uint16_t LTXB_IF:1; /* pLATESTTX VIOLATION ON CHANNEL B INTERRUPT FLAG */
18358 #else
18359  uint16_t LTXBIF:1; /* deprecated name - please avoid */
18360 #endif
18361 #ifndef USE_FIELD_ALIASES_FR
18362  uint16_t LTXA_IF:1; /* pLATESTTX VIOLATION ON CHANNEL A INTERRUPT FLAG */
18363 #else
18364  uint16_t LTXAIF:1; /* deprecated name - please avoid */
18365 #endif
18366 #ifndef USE_FIELD_ALIASES_FR
18367  uint16_t TBVB_IF:1; /* TRANSMISSION ACROSS BOUNDARY ON CHANNEL B INTERRUPT FLAG */
18368 #else
18369  uint16_t TBVBIF:1; /* deprecated name - please avoid */
18370 #endif
18371 #ifndef USE_FIELD_ALIASES_FR
18372  uint16_t TBVA_IF:1; /* TRANSMISSION ACROSS BOUNDARY ON CHANNEL A INTERRUPT FLAG */
18373 #else
18374  uint16_t TBVAIF:1; /* deprecated name - please avoid */
18375 #endif
18376 #ifndef USE_FIELD_ALIASES_FR
18377  uint16_t TI2_IF:1; /* TIMER 2 EXPIRED INTERRUPT FLAG */
18378 #else
18379  uint16_t TI2IF:1; /* deprecated name - please avoid */
18380 #endif
18381 #ifndef USE_FIELD_ALIASES_FR
18382  uint16_t TI1_IF:1; /* TIMER 1 EXPIRED INTERRUPT FLAG */
18383 #else
18384  uint16_t TI1IF:1; /* deprecated name - please avoid */
18385 #endif
18386 #ifndef USE_FIELD_ALIASES_FR
18387  uint16_t CYS_IF:1; /* CYCLE START INTERRUPT FLAG */
18388 #else
18389  uint16_t CYSIF:1; /* deprecated name - please avoid */
18390 #endif
18391  } B;
18392  } FR_PIFR0_16B_tag;
18393
18394  typedef union { /* PROTOCOL INTERRUPT FLAG REGISTER 1 */
18395  uint16_t R;
18396  struct {
18397 #ifndef USE_FIELD_ALIASES_FR
18398  uint16_t EMC_IF:1; /* ERROR MODE CHANGED INTERRUPT FLAG */
18399 #else
18400  uint16_t EMCIF:1; /* deprecated name - please avoid */
18401 #endif
18402 #ifndef USE_FIELD_ALIASES_FR
18403  uint16_t IPC_IF:1; /* ILLEGAL PROTOCOL CONTROL COMMAND INTERRUPT FLAG */
18404 #else
18405  uint16_t IPCIF:1; /* deprecated name - please avoid */
18406 #endif
18407 #ifndef USE_FIELD_ALIASES_FR
18408  uint16_t PECF_IF:1; /* PROTOCOL ENGINE COMMUNICATION FAILURE INTERRUPT FLAG */
18409 #else
18410  uint16_t PECFIF:1; /* deprecated name - please avoid */
18411 #endif
18412 #ifndef USE_FIELD_ALIASES_FR
18413  uint16_t PSC_IF:1; /* PROTOCOL STATE CHANGED INTERRUPT FLAG */
18414 #else
18415  uint16_t PSCIF:1; /* deprecated name - please avoid */
18416 #endif
18417 #ifndef USE_FIELD_ALIASES_FR
18418  uint16_t SSI3_IF:1; /* SLOT STATUS COUNTER 3 INCREMENTED INTERRUPT FLAG */
18419 #else
18420  uint16_t SSI3IF:1; /* deprecated name - please avoid */
18421 #endif
18422 #ifndef USE_FIELD_ALIASES_FR
18423  uint16_t SSI2_IF:1; /* SLOT STATUS COUNTER 2 INCREMENTED INTERRUPT FLAG */
18424 #else
18425  uint16_t SSI2IF:1; /* deprecated name - please avoid */
18426 #endif
18427 #ifndef USE_FIELD_ALIASES_FR
18428  uint16_t SSI1_IF:1; /* SLOT STATUS COUNTER 1 INCREMENTED INTERRUPT FLAG */
18429 #else
18430  uint16_t SSI1IF:1; /* deprecated name - please avoid */
18431 #endif
18432 #ifndef USE_FIELD_ALIASES_FR
18433  uint16_t SSI0_IF:1; /* SLOT STATUS COUNTER 0 INCREMENTED INTERRUPT FLAG */
18434 #else
18435  uint16_t SSI0IF:1; /* deprecated name - please avoid */
18436 #endif
18437  uint16_t:2;
18438 #ifndef USE_FIELD_ALIASES_FR
18439  uint16_t EVT_IF:1; /* EVEN CYCLE TABLE WRITTEN INTERRUPT FLAG */
18440 #else
18441  uint16_t EVTIF:1; /* deprecated name - please avoid */
18442 #endif
18443 #ifndef USE_FIELD_ALIASES_FR
18444  uint16_t ODT_IF:1; /* ODD CYCLE TABLE WRITTEN INTERRUPT FLAG */
18445 #else
18446  uint16_t ODTIF:1; /* deprecated name - please avoid */
18447 #endif
18448  uint16_t:4;
18449  } B;
18450  } FR_PIFR1_16B_tag;
18451
18452  typedef union { /* PROTOCOL INTERRUPT ENABLE REGISTER 0 */
18453  uint16_t R;
18454  struct {
18455 #ifndef USE_FIELD_ALIASES_FR
18456  uint16_t FATL_IE:1; /* FATAL PROTOCOL ERROR INTERRUPT ENABLE */
18457 #else
18458  uint16_t FATLIE:1; /* deprecated name - please avoid */
18459 #endif
18460 #ifndef USE_FIELD_ALIASES_FR
18461  uint16_t INTL_IE:1; /* INTERNAL PROTOCOL ERROR INTERRUPT ENABLE */
18462 #else
18463  uint16_t INTLIE:1; /* deprecated name - please avoid */
18464 #endif
18465 #ifndef USE_FIELD_ALIASES_FR
18466  uint16_t ILCF_IE:1; /* ILLEGAL PROTOCOL CONFIGURATION INTERRUPT ENABLE */
18467 #else
18468  uint16_t ILCFIE:1; /* deprecated name - please avoid */
18469 #endif
18470 #ifndef USE_FIELD_ALIASES_FR
18471  uint16_t CSA_IE:1; /* COLDSTART ABORT INTERRUPT ENABLE */
18472 #else
18473  uint16_t CSAIE:1; /* deprecated name - please avoid */
18474 #endif
18475 #ifndef USE_FIELD_ALIASES_FR
18476  uint16_t MRC_IE:1; /* MISSING RATE CORRECTION INTERRUPT ENABLE */
18477 #else
18478  uint16_t MRCIE:1; /* deprecated name - please avoid */
18479 #endif
18480 #ifndef USE_FIELD_ALIASES_FR
18481  uint16_t MOC_IE:1; /* MISSING OFFSET CORRECTION INTERRUPT ENABLE */
18482 #else
18483  uint16_t MOCIE:1; /* deprecated name - please avoid */
18484 #endif
18485 #ifndef USE_FIELD_ALIASES_FR
18486  uint16_t CCL_IE:1; /* CLOCK CORRECTION LIMIT REACHED */
18487 #else
18488  uint16_t CCLIE:1; /* deprecated name - please avoid */
18489 #endif
18490 #ifndef USE_FIELD_ALIASES_FR
18491  uint16_t MXS_IE:1; /* MAX SYNC FRAMES DETECTED INTERRUPT ENABLE */
18492 #else
18493  uint16_t MXSIE:1; /* deprecated name - please avoid */
18494 #endif
18495 #ifndef USE_FIELD_ALIASES_FR
18496  uint16_t MTX_IE:1; /* MEDIA ACCESS TEST SYMBOL RECEIVED INTERRUPT ENABLE */
18497 #else
18498  uint16_t MTXIE:1; /* deprecated name - please avoid */
18499 #endif
18500 #ifndef USE_FIELD_ALIASES_FR
18501  uint16_t LTXB_IE:1; /* pLATESTTX VIOLATION ON CHANNEL B INTERRUPT ENABLE */
18502 #else
18503  uint16_t LTXBIE:1; /* deprecated name - please avoid */
18504 #endif
18505 #ifndef USE_FIELD_ALIASES_FR
18506  uint16_t LTXA_IE:1; /* pLATESTTX VIOLATION ON CHANNEL A INTERRUPT ENABLE */
18507 #else
18508  uint16_t LTXAIE:1; /* deprecated name - please avoid */
18509 #endif
18510 #ifndef USE_FIELD_ALIASES_FR
18511  uint16_t TBVB_IE:1; /* TRANSMISSION ACROSS BOUNDARY ON CHANNEL B INTERRUPT ENABLE */
18512 #else
18513  uint16_t TBVBIE:1; /* deprecated name - please avoid */
18514 #endif
18515 #ifndef USE_FIELD_ALIASES_FR
18516  uint16_t TBVA_IE:1; /* TRANSMISSION ACROSS BOUNDARY ON CHANNEL A INTERRUPT ENABLE */
18517 #else
18518  uint16_t TBVAIE:1; /* deprecated name - please avoid */
18519 #endif
18520 #ifndef USE_FIELD_ALIASES_FR
18521  uint16_t TI2_IE:1; /* TIMER 2 EXPIRED INTERRUPT ENABLE */
18522 #else
18523  uint16_t TI2IE:1; /* deprecated name - please avoid */
18524 #endif
18525 #ifndef USE_FIELD_ALIASES_FR
18526  uint16_t TI1_IE:1; /* TIMER 1 EXPIRED INTERRUPT ENABLE */
18527 #else
18528  uint16_t TI1IE:1; /* deprecated name - please avoid */
18529 #endif
18530 #ifndef USE_FIELD_ALIASES_FR
18531  uint16_t CYS_IE:1; /* CYCLE START INTERRUPT ENABLE */
18532 #else
18533  uint16_t CYSIE:1; /* deprecated name - please avoid */
18534 #endif
18535  } B;
18536  } FR_PIER0_16B_tag;
18537
18538  typedef union { /* PROTOCOL INTERRUPT ENABLE REGISTER 1 */
18539  uint16_t R;
18540  struct {
18541 #ifndef USE_FIELD_ALIASES_FR
18542  uint16_t EMC_IE:1; /* ERROR MODE CHANGED INTERRUPT Enable */
18543 #else
18544  uint16_t EMCIE:1; /* deprecated name - please avoid */
18545 #endif
18546 #ifndef USE_FIELD_ALIASES_FR
18547  uint16_t IPC_IE:1; /* ILLEGAL PROTOCOL CONTROL COMMAND INTERRUPT Enable */
18548 #else
18549  uint16_t IPCIE:1; /* deprecated name - please avoid */
18550 #endif
18551 #ifndef USE_FIELD_ALIASES_FR
18552  uint16_t PECF_IE:1; /* PROTOCOL ENGINE COMMUNICATION FAILURE INTERRUPT Enable */
18553 #else
18554  uint16_t PECFIE:1; /* deprecated name - please avoid */
18555 #endif
18556 #ifndef USE_FIELD_ALIASES_FR
18557  uint16_t PSC_IE:1; /* PROTOCOL STATE CHANGED INTERRUPT Enable */
18558 #else
18559  uint16_t PSCIE:1; /* deprecated name - please avoid */
18560 #endif
18561 #ifndef USE_FIELD_ALIASES_FR
18562  uint16_t SSI_3_0_IE:4; /* SLOT STATUS COUNTER INCREMENTED INTERRUPT Enable */
18563 #else
18564  uint16_t SSI3IE:1;
18565  uint16_t SSI2IE:1;
18566  uint16_t SSI1IE:1;
18567  uint16_t SSI0IE:1;
18568 #endif
18569
18570  uint16_t:2;
18571 #ifndef USE_FIELD_ALIASES_FR
18572  uint16_t EVT_IE:1; /* EVEN CYCLE TABLE WRITTEN INTERRUPT Enable */
18573 #else
18574  uint16_t EVTIE:1; /* deprecated name - please avoid */
18575 #endif
18576 #ifndef USE_FIELD_ALIASES_FR
18577  uint16_t ODT_IE:1; /* ODD CYCLE TABLE WRITTEN INTERRUPT Enable */
18578 #else
18579  uint16_t ODTIE:1; /* deprecated name - please avoid */
18580 #endif
18581  uint16_t:4;
18582  } B;
18583  } FR_PIER1_16B_tag;
18584
18585  typedef union { /* CHI ERROR FLAG REGISTER */
18586  uint16_t R;
18587  struct {
18588 #ifndef USE_FIELD_ALIASES_FR
18589  uint16_t FRLB_EF:1; /* FRAME LOST CHANNEL B ERROR FLAG */
18590 #else
18591  uint16_t FRLBEF:1; /* deprecated name - please avoid */
18592 #endif
18593 #ifndef USE_FIELD_ALIASES_FR
18594  uint16_t FRLA_EF:1; /* FRAME LOST CHANNEL A ERROR FLAG */
18595 #else
18596  uint16_t FRLAEF:1; /* deprecated name - please avoid */
18597 #endif
18598 #ifndef USE_FIELD_ALIASES_FR
18599  uint16_t PCMI_EF:1; /* PROTOCOL COMMAND IGNORED ERROR FLAG */
18600 #else
18601  uint16_t PCMIEF:1; /* deprecated name - please avoid */
18602 #endif
18603 #ifndef USE_FIELD_ALIASES_FR
18604  uint16_t FOVB_EF:1; /* RECEIVE FIFO OVERRUN CHANNEL B ERROR FLAG */
18605 #else
18606  uint16_t FOVBEF:1; /* deprecated name - please avoid */
18607 #endif
18608 #ifndef USE_FIELD_ALIASES_FR
18609  uint16_t FOVA_EF:1; /* RECEIVE FIFO OVERRUN CHANNEL A ERROR FLAG */
18610 #else
18611  uint16_t FOVAEF:1; /* deprecated name - please avoid */
18612 #endif
18613 #ifndef USE_FIELD_ALIASES_FR
18614  uint16_t MBS_EF:1; /* MESSAGE BUFFER SEARCH ERROR FLAG */
18615 #else
18616  uint16_t MSBEF:1; /* deprecated name - please avoid */
18617 #endif
18618 #ifndef USE_FIELD_ALIASES_FR
18619  uint16_t MBU_EF:1; /* MESSAGE BUFFER UTILIZATION ERROR FLAG */
18620 #else
18621  uint16_t MBUEF:1; /* deprecated name - please avoid */
18622 #endif
18623 #ifndef USE_FIELD_ALIASES_FR
18624  uint16_t LCK_EF:1; /* LOCK ERROR FLAG */
18625 #else
18626  uint16_t LCKEF:1; /* deprecated name - please avoid */
18627 #endif
18628 #ifndef USE_FIELD_ALIASES_FR
18629  uint16_t DBL_EF:1; /* DOUBLE TRANSMIT MESSAGE BUFFER LOCK ERROR FLAG */
18630 #else
18631  uint16_t DBLEF:1; /* deprecated name - please avoid */
18632 #endif
18633 #ifndef USE_FIELD_ALIASES_FR
18634  uint16_t SBCF_EF:1; /* SYSTEM BUS COMMUNICATION FAILURE ERROR FLAG */
18635 #else
18636  uint16_t SBCFEF:1; /* deprecated name - please avoid */
18637 #endif
18638 #ifndef USE_FIELD_ALIASES_FR
18639  uint16_t FID_EF:1; /* FRAME ID ERROR FLAG */
18640 #else
18641  uint16_t FIDEF:1; /* deprecated name - please avoid */
18642 #endif
18643 #ifndef USE_FIELD_ALIASES_FR
18644  uint16_t DPL_EF:1; /* DYNAMIC PAYLOAD LENGTH ERROR FLAG */
18645 #else
18646  uint16_t DPLEF:1; /* deprecated name - please avoid */
18647 #endif
18648 #ifndef USE_FIELD_ALIASES_FR
18649  uint16_t SPL_EF:1; /* STATIC PAYLOAD LENGTH ERROR FLAG */
18650 #else
18651  uint16_t SPLEF:1; /* deprecated name - please avoid */
18652 #endif
18653 #ifndef USE_FIELD_ALIASES_FR
18654  uint16_t NML_EF:1; /* NETWORK MANAGEMENT LENGTH ERROR FLAG */
18655 #else
18656  uint16_t NMLEF:1; /* deprecated name - please avoid */
18657 #endif
18658 #ifndef USE_FIELD_ALIASES_FR
18659  uint16_t NMF_EF:1; /* NETWORK MANAGEMENT FRAME ERROR FLAG */
18660 #else
18661  uint16_t NMFEF:1; /* deprecated name - please avoid */
18662 #endif
18663 #ifndef USE_FIELD_ALIASES_FR
18664  uint16_t ILSA_EF:1; /* ILLEGAL SYSTEM MEMORY ACCESS ERROR FLAG */
18665 #else
18666  uint16_t ILSAEF:1; /* deprecated name - please avoid */
18667 #endif
18668  } B;
18670
18671  typedef union { /* Message Buffer Interrupt Vector Register */
18672  uint16_t R;
18673  struct {
18674  uint16_t:2;
18675  uint16_t TBIVEC:6; /* Transmit Buffer Interrupt Vector */
18676  uint16_t:2;
18677  uint16_t RBIVEC:6; /* Receive Buffer Interrupt Vector */
18678  } B;
18680
18681  typedef union { /* Channel A Status Error Counter Register */
18682  uint16_t R;
18683  struct {
18684  uint16_t STATUS_ERR_CNT:16; /* Channel Status Error Counter */
18685  } B;
18687
18688  typedef union { /* Channel B Status Error Counter Register */
18689  uint16_t R;
18690  struct {
18691  uint16_t STATUS_ERR_CNT:16; /* Channel Status Error Counter */
18692  } B;
18694
18695  typedef union { /* Protocol Status Register 0 */
18696  uint16_t R;
18697  struct {
18698  uint16_t ERRMODE:2; /* Error Mode */
18699  uint16_t SLOTMODE:2; /* Slot Mode */
18700  uint16_t:1;
18701  uint16_t PROTSTATE:3; /* Protocol State */
18702 #ifndef USE_FIELD_ALIASES_FR
18703  uint16_t STARTUPSTATE:4; /* Startup State */
18704 #else
18705  uint16_t SUBSTATE:4; /* deprecated name - please avoid */
18706 #endif
18707  uint16_t WAKEUPSTATE:4; /* Wakeup Status */
18708  } B;
18709  } FR_PSR0_16B_tag;
18710
18711  typedef union { /* Protocol Status Register 1 */
18712  uint16_t R;
18713  struct {
18714  uint16_t CSAA:1; /* Coldstart Attempt Aborted Flag */
18715  uint16_t CSP:1; /* Leading Coldstart Path */
18716  uint16_t:1;
18717  uint16_t REMCSAT:5; /* Remaining Coldstart Attempts */
18718  uint16_t CPN:1; /* Leading Coldstart Path Noise */
18719  uint16_t HHR:1; /* Host Halt Request Pending */
18720  uint16_t FRZ:1; /* Freeze Occurred */
18721  uint16_t APTAC:5; /* Allow Passive to Active Counter */
18722  } B;
18723  } FR_PSR1_16B_tag;
18724
18725  typedef union { /* Protocol Status Register 2 */
18726  uint16_t R;
18727  struct {
18728  uint16_t NBVB:1; /* NIT Boundary Violation on Channel B */
18729  uint16_t NSEB:1; /* NIT Syntax Error on Channel B */
18730  uint16_t STCB:1; /* Symbol Window Transmit Conflict on Channel B */
18731 #ifndef USE_FIELD_ALIASES_FR
18732  uint16_t SSVB:1; /* Symbol Window Boundary Violation on Channel B */
18733 #else
18734  uint16_t SBVB:1; /* deprecated name - please avoid */
18735 #endif
18736  uint16_t SSEB:1; /* Symbol Window Syntax Error on Channel B */
18737  uint16_t MTB:1; /* Media Access Test Symbol MTS Received on Channel B */
18738  uint16_t NBVA:1; /* NIT Boundary Violation on Channel A */
18739  uint16_t NSEA:1; /* NIT Syntax Error on Channel A */
18740  uint16_t STCA:1; /* Symbol Window Transmit Conflict on Channel A */
18741  uint16_t SBVA:1; /* Symbol Window Boundary Violation on Channel A */
18742  uint16_t SSEA:1; /* Symbol Window Syntax Error on Channel A */
18743  uint16_t MTA:1; /* Media Access Test Symbol MTS Received on Channel A */
18744  uint16_t CLKCORRFAILCNT:4; /* Clock Correction Failed Counter */
18745  } B;
18746  } FR_PSR2_16B_tag;
18747
18748  typedef union { /* Protocol Status Register 3 */
18749  uint16_t R;
18750  struct {
18751  uint16_t:2;
18752  uint16_t WUB:1; /* Wakeup Symbol Received on Channel B */
18753  uint16_t ABVB:1; /* Aggregated Boundary Violation on Channel B */
18754  uint16_t AACB:1; /* Aggregated Additional Communication on Channel B */
18755  uint16_t ACEB:1; /* Aggregated Content Error on Channel B */
18756  uint16_t ASEB:1; /* Aggregated Syntax Error on Channel B */
18757  uint16_t AVFB:1; /* Aggregated Valid Frame on Channel B */
18758  uint16_t:2;
18759  uint16_t WUA:1; /* Wakeup Symbol Received on Channel A */
18760  uint16_t ABVA:1; /* Aggregated Boundary Violation on Channel A */
18761  uint16_t AACA:1; /* Aggregated Additional Communication on Channel A */
18762  uint16_t ACEA:1; /* Aggregated Content Error on Channel A */
18763  uint16_t ASEA:1; /* Aggregated Syntax Error on Channel A */
18764  uint16_t AVFA:1; /* Aggregated Valid Frame on Channel A */
18765  } B;
18766  } FR_PSR3_16B_tag;
18767
18768  typedef union { /* Macrotick Counter Register */
18769  uint16_t R;
18770  struct {
18771  uint16_t:2;
18772  uint16_t MTCT:14; /* Macrotick Counter */
18773  } B;
18774  } FR_MTCTR_16B_tag;
18775
18776  typedef union { /* Cycle Counter Register */
18777  uint16_t R;
18778  struct {
18779  uint16_t:10;
18780  uint16_t CYCCNT:6; /* Cycle Counter */
18781  } B;
18782  } FR_CYCTR_16B_tag;
18783
18784  typedef union { /* Slot Counter Channel A Register */
18785  uint16_t R;
18786  struct {
18787  uint16_t:5;
18788  uint16_t SLOTCNTA:11; /* Slot Counter Value for Channel A */
18789  } B;
18791
18792  typedef union { /* Slot Counter Channel B Register */
18793  uint16_t R;
18794  struct {
18795  uint16_t:5;
18796  uint16_t SLOTCNTB:11; /* Slot Counter Value for Channel B */
18797  } B;
18799
18800  typedef union { /* Rate Correction Value Register */
18801  uint16_t R;
18802  struct {
18803  uint16_t RATECORR:16; /* Rate Correction Value */
18804  } B;
18806
18807  typedef union { /* Offset Correction Value Register */
18808  uint16_t R;
18809  struct {
18810  uint16_t:6;
18811  uint16_t OFFSETCORR:10; /* Offset Correction Value */
18812  } B;
18814
18815  typedef union { /* Combined Interrupt Flag Register */
18816  uint16_t R;
18817  struct {
18818  uint16_t:8;
18819 #ifndef USE_FIELD_ALIASES_FR
18820  uint16_t MIF:1; /* Module Interrupt Flag */
18821 #else
18822  uint16_t MIFR:1; /* deprecated name - please avoid */
18823 #endif
18824 #ifndef USE_FIELD_ALIASES_FR
18825  uint16_t PRIF:1; /* Protocol Interrupt Flag */
18826 #else
18827  uint16_t PRIFR:1; /* deprecated name - please avoid */
18828 #endif
18829 #ifndef USE_FIELD_ALIASES_FR
18830  uint16_t CHIF:1; /* CHI Interrupt Flag */
18831 #else
18832  uint16_t CHIFR:1; /* deprecated name - please avoid */
18833 #endif
18834 #ifndef USE_FIELD_ALIASES_FR
18835  uint16_t WUPIF:1; /* Wakeup Interrupt Flag */
18836 #else
18837  uint16_t WUPIFR:1; /* deprecated name - please avoid */
18838 #endif
18839 #ifndef USE_FIELD_ALIASES_FR
18840  uint16_t FAFBIF:1; /* Receive FIFO channel B Almost Full Interrupt Flag */
18841 #else
18842  uint16_t FNEBIFR:1; /* deprecated name - please avoid */
18843 #endif
18844 #ifndef USE_FIELD_ALIASES_FR
18845  uint16_t FAFAIF:1; /* Receive FIFO channel A Almost Full Interrupt Flag */
18846 #else
18847  uint16_t FNEAIFR:1; /* deprecated name - please avoid */
18848 #endif
18849 #ifndef USE_FIELD_ALIASES_FR
18850  uint16_t RBIF:1; /* Receive Message Buffer Interrupt Flag */
18851 #else
18852  uint16_t RBIFR:1; /* deprecated name - please avoid */
18853 #endif
18854 #ifndef USE_FIELD_ALIASES_FR
18855  uint16_t TBIF:1; /* Transmit Message Buffer Interrupt Flag */
18856 #else
18857  uint16_t TBIFR:1; /* deprecated name - please avoid */
18858 #endif
18859  } B;
18860  } FR_CIFR_16B_tag;
18861
18862  typedef union { /* System Memory Access Time-Out Register */
18863  uint16_t R;
18864  struct {
18865  uint16_t:8;
18866  uint16_t TIMEOUT:8; /* Time-Out */
18867  } B;
18869
18870  typedef union { /* Sync Frame Counter Register */
18871  uint16_t R;
18872  struct {
18873  uint16_t SFEVB:4; /* Sync Frames Channel B, even cycle */
18874  uint16_t SFEVA:4; /* Sync Frames Channel A, even cycle */
18875  uint16_t SFODB:4; /* Sync Frames Channel B, odd cycle */
18876  uint16_t SFODA:4; /* Sync Frames Channel A, odd cycle */
18877  } B;
18879
18880  typedef union { /* Sync Frame Table Offset Register */
18881  uint16_t R;
18882  struct {
18883  uint16_t SFT_OFFSET_15_1:15; /* Sync Frame Table Offset */
18884  uint16_t:1;
18885  } B;
18886  } FR_SFTOR_16B_tag;
18887
18888  typedef union { /* Sync Frame Table Configuration, Control, Status Register */
18889  uint16_t R;
18890  struct {
18891  uint16_t ELKT:1; /* Even Cycle Tables Lock/Unlock Trigger */
18892  uint16_t OLKT:1; /* Odd Cycle Tables Lock/Unlock Trigger */
18893  uint16_t CYCNUM:6; /* Cycle Number */
18894  uint16_t ELKS:1; /* Even Cycle Tables Lock Status */
18895  uint16_t OLKS:1; /* Odd Cycle Tables Lock Status */
18896  uint16_t EVAL:1; /* Even Cycle Tables Valid */
18897  uint16_t OVAL:1; /* Odd Cycle Tables Valid */
18898  uint16_t:1;
18899  uint16_t OPT:1; /* One Pair Trigger */
18900  uint16_t SDVEN:1; /* Sync Frame Deviation Table Enable */
18901 #ifndef USE_FIELD_ALIASES_FR
18902  uint16_t SIVEN:1; /* Sync Frame ID Table Enable */
18903 #else
18904  uint16_t SIDEN:1; /* deprecated name - please avoid */
18905 #endif
18906  } B;
18908
18909  typedef union { /* Sync Frame ID Rejection Filter */
18910  uint16_t R;
18911  struct {
18912  uint16_t:6;
18913  uint16_t SYNFRID:10; /* Sync Frame Rejection ID */
18914  } B;
18916
18917  typedef union { /* Sync Frame ID Acceptance Filter Value Register */
18918  uint16_t R;
18919  struct {
18920  uint16_t:6;
18921  uint16_t FVAL:10; /* Filter Value */
18922  } B;
18924
18925  typedef union { /* Sync Frame ID Acceptance Filter Mask Register */
18926  uint16_t R;
18927  struct {
18928  uint16_t:6;
18929  uint16_t FMSK:10; /* Filter Mask */
18930  } B;
18932
18933  typedef union { /* Network Management Vector Register0 */
18934  uint16_t R;
18935  struct {
18936  uint16_t NMVP_15_8:8; /* Network Management Vector Part */
18937  uint16_t NMVP_7_0:8; /* Network Management Vector Part */
18938  } B;
18939  } FR_NMVR0_16B_tag;
18940
18941  typedef union { /* Network Management Vector Register1 */
18942  uint16_t R;
18943  struct {
18944  uint16_t NMVP_15_8:8; /* Network Management Vector Part */
18945  uint16_t NMVP_7_0:8; /* Network Management Vector Part */
18946  } B;
18947  } FR_NMVR1_16B_tag;
18948
18949  typedef union { /* Network Management Vector Register2 */
18950  uint16_t R;
18951  struct {
18952  uint16_t NMVP_15_8:8; /* Network Management Vector Part */
18953  uint16_t NMVP_7_0:8; /* Network Management Vector Part */
18954  } B;
18955  } FR_NMVR2_16B_tag;
18956
18957  typedef union { /* Network Management Vector Register3 */
18958  uint16_t R;
18959  struct {
18960  uint16_t NMVP_15_8:8; /* Network Management Vector Part */
18961  uint16_t NMVP_7_0:8; /* Network Management Vector Part */
18962  } B;
18963  } FR_NMVR3_16B_tag;
18964
18965  typedef union { /* Network Management Vector Register4 */
18966  uint16_t R;
18967  struct {
18968  uint16_t NMVP_15_8:8; /* Network Management Vector Part */
18969  uint16_t NMVP_7_0:8; /* Network Management Vector Part */
18970  } B;
18971  } FR_NMVR4_16B_tag;
18972
18973  typedef union { /* Network Management Vector Register5 */
18974  uint16_t R;
18975  struct {
18976  uint16_t NMVP_15_8:8; /* Network Management Vector Part */
18977  uint16_t NMVP_7_0:8; /* Network Management Vector Part */
18978  } B;
18979  } FR_NMVR5_16B_tag;
18980
18981  typedef union { /* Network Management Vector Length Register */
18982  uint16_t R;
18983  struct {
18984  uint16_t:12;
18985  uint16_t NMVL:4; /* Network Management Vector Length */
18986  } B;
18987  } FR_NMVLR_16B_tag;
18988
18989  typedef union { /* Timer Configuration and Control Register */
18990  uint16_t R;
18991  struct {
18992  uint16_t:2;
18993 #ifndef USE_FIELD_ALIASES_FR
18994  uint16_t T2_CFG:1; /* Timer T2 Configuration */
18995 #else
18996  uint16_t T2CFG:1; /* Timer T2 Configuration */
18997 #endif
18998 #ifndef USE_FIELD_ALIASES_FR
18999  uint16_t T2_REP:1; /* Timer T2 Repetitive Mode */
19000 #else
19001  uint16_t T2REP:1; /* Timer T2 Configuration */
19002 #endif
19003  uint16_t:1;
19004  uint16_t T2SP:1; /* Timer T2 Stop */
19005  uint16_t T2TR:1; /* Timer T2 Trigger */
19006  uint16_t T2ST:1; /* Timer T2 State */
19007  uint16_t:3;
19008 #ifndef USE_FIELD_ALIASES_FR
19009  uint16_t T1_REP:1; /* Timer T1 Repetitive Mode */
19010 #else
19011  uint16_t T1REP:1;
19012 #endif
19013  uint16_t:1;
19014  uint16_t T1SP:1; /* Timer T1 Stop */
19015  uint16_t T1TR:1; /* Timer T1 Trigger */
19016  uint16_t T1ST:1; /* Timer T1 State */
19017  } B;
19018  } FR_TICCR_16B_tag;
19019
19020  typedef union { /* Timer 1 Cycle Set Register */
19021  uint16_t R;
19022  struct {
19023  uint16_t:2;
19024 #ifndef USE_FIELD_ALIASES_FR
19025  uint16_t T1_CYC_VAL:6; /* Timer T1 Cycle Filter Value */
19026 #else
19027  uint16_t TI1CYCVAL:1; /* Timer T1 Cycle Filter Value */
19028 #endif
19029  uint16_t:2;
19030 #ifndef USE_FIELD_ALIASES_FR
19031  uint16_t T1_CYC_MSK:6; /* Timer T1 Cycle Filter Mask */
19032 #else
19033  uint16_t TI1CYCMSK:1; /* Timer T1 Cycle Filter Mask */
19034 #endif
19035  } B;
19037
19038  typedef union { /* Timer 1 Macrotick Offset Register */
19039  uint16_t R;
19040  struct {
19041  uint16_t:2;
19042  uint16_t T1_MTOFFSET:14; /* Timer 1 Macrotick Offset */
19043  } B;
19045
19046  typedef union { /* Timer 2 Configuration Register 0 */
19047  uint16_t R;
19048  struct {
19049  uint16_t:2;
19050  uint16_t T2_CYC_VAL:6; /* Timer T2 Cycle Filter Value */
19051  uint16_t:2;
19052  uint16_t T2_CYC_MSK:6; /* Timer T2 Cycle Filter Mask */
19053  } B;
19055
19056  typedef union { /* Timer 2 Configuration Register 1 */
19057  uint16_t R;
19058  struct {
19059  uint16_t T2_MTCNT:16; /* Timer T2 Macrotick Offset */
19060  } B;
19062
19063  typedef union { /* Slot Status Selection Register */
19064  uint16_t R;
19065  struct {
19066  uint16_t WMD:1; /* Write Mode */
19067  uint16_t:1;
19068  uint16_t SEL:2; /* Selector */
19069  uint16_t:1;
19070  uint16_t SLOTNUMBER:11; /* Slot Number */
19071  } B;
19072  } FR_SSSR_16B_tag;
19073
19074  typedef union { /* Slot Status Counter Condition Register */
19075  uint16_t R;
19076  struct {
19077  uint16_t WMD:1; /* Write Mode */
19078  uint16_t:1;
19079  uint16_t SEL:2; /* Selector */
19080  uint16_t:1;
19081  uint16_t CNTCFG:2; /* Counter Configuration */
19082  uint16_t MCY:1; /* Multi Cycle Selection */
19083  uint16_t VFR:1; /* Valid Frame Restriction */
19084  uint16_t SYF:1; /* Sync Frame Restriction */
19085  uint16_t NUF:1; /* Null Frame Restriction */
19086  uint16_t SUF:1; /* Startup Frame Restriction */
19087  uint16_t STATUSMASK:4; /* Slot Status Mask */
19088  } B;
19089  } FR_SSCCR_16B_tag;
19090
19091  typedef union { /* Slot Status Register0 */
19092  uint16_t R;
19093  struct {
19094  uint16_t VFB:1; /* Valid Frame on Channel B */
19095  uint16_t SYB:1; /* Sync Frame Indicator Channel B */
19096  uint16_t NFB:1; /* Null Frame Indicator Channel B */
19097  uint16_t SUB:1; /* Startup Frame Indicator Channel B */
19098  uint16_t SEB:1; /* Syntax Error on Channel B */
19099  uint16_t CEB:1; /* Content Error on Channel B */
19100  uint16_t BVB:1; /* Boundary Violation on Channel B */
19101  uint16_t TCB:1; /* Transmission Conflict on Channel B */
19102  uint16_t VFA:1; /* Valid Frame on Channel A */
19103  uint16_t SYA:1; /* Sync Frame Indicator Channel A */
19104  uint16_t NFA:1; /* Null Frame Indicator Channel A */
19105  uint16_t SUA:1; /* Startup Frame Indicator Channel A */
19106  uint16_t SEA:1; /* Syntax Error on Channel A */
19107  uint16_t CEA:1; /* Content Error on Channel A */
19108  uint16_t BVA:1; /* Boundary Violation on Channel A */
19109  uint16_t TCA:1; /* Transmission Conflict on Channel A */
19110  } B;
19111  } FR_SSR_16B_tag;
19112
19113
19114
19115  typedef union { /* Slot Status Counter Register0 */
19116  uint16_t R;
19117  struct {
19118  uint16_t SLOTSTSTUSCNT:16; /* Slot Status Counter */
19119  } B;
19120  } FR_SSCR0_16B_tag;
19121
19122  typedef union { /* Slot Status Counter Register1 */
19123  uint16_t R;
19124  struct {
19125  uint16_t SLOTSTSTUSCNT:16; /* Slot Status Counter */
19126  } B;
19127  } FR_SSCR1_16B_tag;
19128
19129  typedef union { /* Slot Status Counter Register2 */
19130  uint16_t R;
19131  struct {
19132  uint16_t SLOTSTSTUSCNT:16; /* Slot Status Counter */
19133  } B;
19134  } FR_SSCR2_16B_tag;
19135
19136  typedef union { /* Slot Status Counter Register3 */
19137  uint16_t R;
19138  struct {
19139  uint16_t SLOTSTSTUSCNT:16; /* Slot Status Counter */
19140  } B;
19141  } FR_SSCR3_16B_tag;
19142
19143  typedef union { /* MTS A Configuration Register */
19144  uint16_t R;
19145  struct {
19146  uint16_t MTE:1; /* Media Access Test Symbol Transmission Enable */
19147  uint16_t:1;
19148  uint16_t CYCCNTMSK:6; /* Cycle Counter Mask */
19149  uint16_t:2;
19150  uint16_t CYCCNTVAL:6; /* Cycle Counter Value */
19151  } B;
19153
19154  typedef union { /* MTS B Configuration Register */
19155  uint16_t R;
19156  struct {
19157  uint16_t MTE:1; /* Media Access Test Symbol Transmission Enable */
19158  uint16_t:1;
19159  uint16_t CYCCNTMSK:6; /* Cycle Counter Mask */
19160  uint16_t:2;
19161  uint16_t CYCCNTVAL:6; /* Cycle Counter Value */
19162  } B;
19164
19165  typedef union { /* Receive Shadow Buffer Index Register */
19166  uint16_t R;
19167  struct {
19168  uint16_t WMD:1; /* Write Mode */
19169  uint16_t:1;
19170  uint16_t SEL:2; /* Selector */
19171  uint16_t:5;
19172  uint16_t RSBIDX:7; /* Receive Shadow Buffer Index */
19173  } B;
19174  } FR_RSBIR_16B_tag;
19175
19176  typedef union { /* Receive FIFO Watermark and Selection Register */
19177  uint16_t R;
19178  struct {
19179  uint16_t WM:8; /* Watermark Value */
19180  uint16_t:7;
19181  uint16_t SEL:1; /* Select */
19182  } B;
19184
19185  typedef union { /* Receive FIFO Start Index Register */
19186  uint16_t R;
19187  struct {
19188  uint16_t:6;
19189  uint16_t SIDX:10; /* Start Index */
19190  } B;
19192
19193  typedef union { /* Receive FIFO Depth and Size Register */
19194  uint16_t R;
19195  struct {
19196 #ifndef USE_FIELD_ALIASES_FR
19197  uint16_t FIFO_DEPTH:8; /* FIFO Depth */
19198 #else
19199  uint16_t FIFODEPTH:8; /* deprecated name - please avoid */
19200 #endif
19201  uint16_t:1;
19202 #ifndef USE_FIELD_ALIASES_FR
19203  uint16_t ENTRY_SIZE:7; /* Entry Size */
19204 #else
19205  uint16_t ENTRYSIZE:7; /* deprecated name - please avoid */
19206 #endif
19207  } B;
19208  } FR_RFDSR_16B_tag;
19209
19210  typedef union { /* Receive FIFO A Read Index Register */
19211  uint16_t R;
19212  struct {
19213  uint16_t:6;
19214  uint16_t RDIDX:10; /* Read Index */
19215  } B;
19217
19218  typedef union { /* Receive FIFO B Read Index Register */
19219  uint16_t R;
19220  struct {
19221  uint16_t:6;
19222  uint16_t RDIDX:10; /* Read Index */
19223  } B;
19225
19226  typedef union { /* Receive FIFO Message ID Acceptance Filter Value Register */
19227  uint16_t R;
19228  struct {
19229  uint16_t MIDAFVAL:16; /* Message ID Acceptance Filter Value */
19230  } B;
19232
19233  typedef union { /* Receive FIFO Message ID Acceptance Filter Mask Register */
19234  uint16_t R;
19235  struct {
19236  uint16_t MIDAFMSK:16; /* Message ID Acceptance Filter Mask */
19237  } B;
19239
19240  typedef union { /* Receive FIFO Frame ID Rejection Filter Value Register */
19241  uint16_t R;
19242  struct {
19243  uint16_t:5;
19244  uint16_t FIDRFVAL:11; /* Frame ID Rejection Filter Value */
19245  } B;
19247
19248  typedef union { /* Receive FIFO Frame ID Rejection Filter Mask Register */
19249  uint16_t R;
19250  struct {
19251  uint16_t:5;
19252  uint16_t FIDRFMSK:11; /* Frame ID Rejection Filter Mask */
19253  } B;
19255
19256  typedef union { /* Receive FIFO Range Filter Configuration Register */
19257  uint16_t R;
19258  struct {
19259  uint16_t WMD:1; /* Write Mode */
19260  uint16_t IBD:1; /* Interval Boundary */
19261  uint16_t SEL:2; /* Filter Selector */
19262  uint16_t:1;
19263  uint16_t SID:11; /* Slot ID */
19264  } B;
19266
19267  typedef union { /* Receive FIFO Range Filter Control Register */
19268  uint16_t R;
19269  struct {
19270  uint16_t:4;
19271  uint16_t F3MD:1; /* Range Filter 3 Mode */
19272  uint16_t F2MD:1; /* Range Filter 2 Mode */
19273  uint16_t F1MD:1; /* Range Filter 1 Mode */
19274  uint16_t F0MD:1; /* Range Filter 0 Mode */
19275  uint16_t:4;
19276  uint16_t F3EN:1; /* Range Filter 3 Enable */
19277  uint16_t F2EN:1; /* Range Filter 2 Enable */
19278  uint16_t F1EN:1; /* Range Filter 1 Enable */
19279  uint16_t F0EN:1; /* Range Filter 0 Enable */
19280  } B;
19282
19283  typedef union { /* Last Dynamic Transmit Slot Channel A Register */
19284  uint16_t R;
19285  struct {
19286  uint16_t:5;
19287  uint16_t LASTDYNTXSLOTA:11; /* Last Dynamic Transmission Slot Channel A */
19288  } B;
19290
19291  typedef union { /* Last Dynamic Transmit Slot Channel B Register */
19292  uint16_t R;
19293  struct {
19294  uint16_t:5;
19295  uint16_t LASTDYNTXSLOTB:11; /* Last Dynamic Transmission Slot Channel B */
19296  } B;
19298
19299  typedef union { /* Protocol Configuration Register 0 */
19300  uint16_t R;
19301  struct {
19302  uint16_t ACTION_POINT_OFFSET:6; /* gdActionPointOffset - 1 */
19303  uint16_t STATIC_SLOT_LENGTH:10; /* gdStaticSlot */
19304  } B;
19305  } FR_PCR0_16B_tag;
19306
19307  typedef union { /* Protocol Configuration Register 1 */
19308  uint16_t R;
19309  struct {
19310  uint16_t:2;
19311  uint16_t MACRO_AFTER_FIRST_STATIC_SLOT:14; /* gMacroPerCycle - gdStaticSlot */
19312  } B;
19313  } FR_PCR1_16B_tag;
19314
19315  typedef union { /* Protocol Configuration Register 2 */
19316  uint16_t R;
19317  struct {
19318  uint16_t MINISLOT_AFTER_ACTION_POINT:6; /* gdMinislot - gdMinislotActionPointOffset - 1 */
19319  uint16_t NUMBER_OF_STATIC_SLOTS:10; /* gNumberOfStaticSlots */
19320  } B;
19321  } FR_PCR2_16B_tag;
19322
19323  typedef union { /* Protocol Configuration Register 3 */
19324  uint16_t R;
19325  struct {
19326  uint16_t WAKEUP_SYMBOL_RX_LOW:6; /* gdWakeupSymbolRxLow */
19327 #ifndef USE_FIELD_ALIASES_FR
19328  uint16_t MINISLOT_ACTION_POINT_OFFSET_4_0:5; /* gdMinislotActionPointOffset - 1 */
19329 #else
19330  uint16_t MINISLOT_ACTION_POINT_OFFSET:5; /* deprecated name - please avoid */
19331 #endif
19332  uint16_t COLDSTART_ATTEMPTS:5; /* gColdstartAttempts */
19333  } B;
19334  } FR_PCR3_16B_tag;
19335
19336  typedef union { /* Protocol Configuration Register 4 */
19337  uint16_t R;
19338  struct {
19339  uint16_t CAS_RX_LOW_MAX:7; /* gdCASRxLowMax - 1 */
19340  uint16_t WAKEUP_SYMBOL_RX_WINDOW:9; /* gdWakeupSymbolRxWindow */
19341  } B;
19342  } FR_PCR4_16B_tag;
19343
19344  typedef union { /* Protocol Configuration Register 5 */
19345  uint16_t R;
19346  struct {
19347  uint16_t TSS_TRANSMITTER:4; /* gdTSSTransmitter */
19348  uint16_t WAKEUP_SYMBOL_TX_LOW:6; /* gdWakeupSymbolTxLow */
19349  uint16_t WAKEUP_SYMBOL_RX_IDLE:6; /* gdWakeupSymbolRxIdle */
19350  } B;
19351  } FR_PCR5_16B_tag;
19352
19353  typedef union { /* Protocol Configuration Register 6 */
19354  uint16_t R;
19355  struct {
19356  uint16_t:1;
19357  uint16_t SYMBOL_WINDOW_AFTER_ACTION_POINT:8; /* gdSymbolWindow - gdActionPointOffset - 1 */
19358  uint16_t MACRO_INITIAL_OFFSET_A:7; /* pMacroInitialOffset[A] */
19359  } B;
19360  } FR_PCR6_16B_tag;
19361
19362  typedef union { /* Protocol Configuration Register 7 */
19363  uint16_t R;
19364  struct {
19365  uint16_t DECODING_CORRECTION_B:9; /* pDecodingCorrection + pDelayCompensation[B] + 2 */
19366  uint16_t MICRO_PER_MACRO_NOM_HALF:7; /* round(pMicroPerMacroNom / 2) */
19367  } B;
19368  } FR_PCR7_16B_tag;
19369
19370  typedef union { /* Protocol Configuration Register 8 */
19371  uint16_t R;
19372  struct {
19373  uint16_t MAX_WITHOUT_CLOCK_CORRECTION_FATAL:4; /* gMaxWithoutClockCorrectionFatal */
19374  uint16_t MAX_WITHOUT_CLOCK_CORRECTION_PASSIVE:4; /* gMaxWithoutClockCorrectionPassive */
19375  uint16_t WAKEUP_SYMBOL_TX_IDLE:8; /* gdWakeupSymbolTxIdle */
19376  } B;
19377  } FR_PCR8_16B_tag;
19378
19379  typedef union { /* Protocol Configuration Register 9 */
19380  uint16_t R;
19381  struct {
19382  uint16_t MINISLOT_EXISTS:1; /* gNumberOfMinislots!=0 */
19383  uint16_t SYMBOL_WINDOW_EXISTS:1; /* gdSymbolWindow!=0 */
19384  uint16_t OFFSET_CORRECTION_OUT:14; /* pOffsetCorrectionOut */
19385  } B;
19386  } FR_PCR9_16B_tag;
19387
19388  typedef union { /* Protocol Configuration Register 10 */
19389  uint16_t R;
19390  struct {
19391  uint16_t SINGLE_SLOT_ENABLED:1; /* pSingleSlotEnabled */
19392  uint16_t WAKEUP_CHANNEL:1; /* pWakeupChannel */
19393  uint16_t MACRO_PER_CYCLE:14; /* pMicroPerCycle */
19394  } B;
19395  } FR_PCR10_16B_tag;
19396
19397  typedef union { /* Protocol Configuration Register 11 */
19398  uint16_t R;
19399  struct {
19400  uint16_t KEY_SLOT_USED_FOR_STARTUP:1; /* pKeySlotUsedForStartup */
19401  uint16_t KEY_SLOT_USED_FOR_SYNC:1; /* pKeySlotUsedForSync */
19402  uint16_t OFFSET_CORRECTION_START:14; /* gOffsetCorrectionStart */
19403  } B;
19404  } FR_PCR11_16B_tag;
19405
19406  typedef union { /* Protocol Configuration Register 12 */
19407  uint16_t R;
19408  struct {
19409  uint16_t ALLOW_PASSIVE_TO_ACTIVE:5; /* pAllowPassiveToActive */
19410  uint16_t KEY_SLOT_HEADER_CRC:11; /* header CRC for key slot */
19411  } B;
19412  } FR_PCR12_16B_tag;
19413
19414  typedef union { /* Protocol Configuration Register 13 */
19415  uint16_t R;
19416  struct {
19417  uint16_t FIRST_MINISLOT_ACTION_POINT_OFFSET:6; /* max(gdActionPointOffset,gdMinislotActionPointOffset) - 1 */
19418  uint16_t STATIC_SLOT_AFTER_ACTION_POINT:10; /* gdStaticSlot - gdActionPointOffset - 1 */
19419  } B;
19420  } FR_PCR13_16B_tag;
19421
19422  typedef union { /* Protocol Configuration Register 14 */
19423  uint16_t R;
19424  struct {
19425  uint16_t RATE_CORRECTION_OUT:11; /* pRateCorrectionOut */
19426 #ifndef USE_FIELD_ALIASES_FR
19427  uint16_t LISTEN_TIMEOUT_20_16:5; /* pdListenTimeout - 1 */
19428 #else
19429  uint16_t LISTEN_TIMEOUT_H:5; /* deprecated name - please avoid */
19430 #endif
19431  } B;
19432  } FR_PCR14_16B_tag;
19433
19434  typedef union { /* Protocol Configuration Register 15 */
19435  uint16_t R;
19436  struct {
19437 #ifndef USE_FIELD_ALIASES_FR
19438  uint16_t LISTEN_TIMEOUT_15_0:16; /* pdListenTimeout - 1 */
19439 #else
19440  uint16_t LISTEN_TIMEOUT_L:16; /* deprecated name - please avoid */
19441 #endif
19442  } B;
19443  } FR_PCR15_16B_tag;
19444
19445  typedef union { /* Protocol Configuration Register 16 */
19446  uint16_t R;
19447  struct {
19448  uint16_t MACRO_INITIAL_OFFSET_B:7; /* pMacroInitialOffset[B] */
19449 #ifndef USE_FIELD_ALIASES_FR
19450  uint16_t NOISE_LISTEN_TIMEOUT_24_16:9; /* (gListenNoise * pdListenTimeout) - 1 */
19451 #else
19452  uint16_t NOISE_LISTEN_TIMEOUT_H:9; /* deprecated name - please avoid */
19453 #endif
19454  } B;
19455  } FR_PCR16_16B_tag;
19456
19457  typedef union { /* Protocol Configuration Register 17 */
19458  uint16_t R;
19459  struct {
19460 #ifndef USE_FIELD_ALIASES_FR
19461  uint16_t NOISE_LISTEN_TIMEOUT_15_0:16; /* (gListenNoise * pdListenTimeout) - 1 */
19462 #else
19463  uint16_t NOISE_LISTEN_TIMEOUT_L:16; /* deprecated name - please avoid */
19464 #endif
19465  } B;
19466  } FR_PCR17_16B_tag;
19467
19468  typedef union { /* Protocol Configuration Register 18 */
19469  uint16_t R;
19470  struct {
19471  uint16_t WAKEUP_PATTERN:6; /* pWakeupPattern */
19472  uint16_t KEY_SLOT_ID:10; /* pKeySlotId */
19473  } B;
19474  } FR_PCR18_16B_tag;
19475
19476  typedef union { /* Protocol Configuration Register 19 */
19477  uint16_t R;
19478  struct {
19479  uint16_t DECODING_CORRECTION_A:9; /* pDecodingCorrection + pDelayCompensation[A] + 2 */
19480  uint16_t PAYLOAD_LENGTH_STATIC:7; /* gPayloadLengthStatic */
19481  } B;
19482  } FR_PCR19_16B_tag;
19483
19484  typedef union { /* Protocol Configuration Register 20 */
19485  uint16_t R;
19486  struct {
19487  uint16_t MICRO_INITIAL_OFFSET_B:8; /* pMicroInitialOffset[B] */
19488  uint16_t MICRO_INITIAL_OFFSET_A:8; /* pMicroInitialOffset[A] */
19489  } B;
19490  } FR_PCR20_16B_tag;
19491
19492  typedef union { /* Protocol Configuration Register 21 */
19493  uint16_t R;
19494  struct {
19495  uint16_t EXTERN_RATE_CORRECTION:3; /* pExternRateCorrection */
19496  uint16_t LATEST_TX:13; /* gNumberOfMinislots - pLatestTx */
19497  } B;
19498  } FR_PCR21_16B_tag;
19499
19500  typedef union { /* Protocol Configuration Register 22 */
19501  uint16_t R;
19502  struct {
19503  uint16_t R:1; /* Reserved bit */
19504 #ifndef USE_FIELD_ALIASES_FR
19505  uint16_t COMP_ACCEPTED_STARRUP_RANGE_A:11; /* pdAcceptedStartupRange - pDelayCompensationChA */
19506 #else
19507  uint16_t COMP_ACCEPTED_STARTUP_RANGE_A:11; /* deprecated name - please avoid */
19508 #endif
19509 #ifndef USE_FIELD_ALIASES_FR
19510  uint16_t MICRO_PER_CYCLE_19_16:4; /* gMicroPerCycle */
19511 #else
19512  uint16_t MICRO_PER_CYCLE_H:4; /* deprecated name - please avoid */
19513 #endif
19514  } B;
19515  } FR_PCR22_16B_tag;
19516
19517  typedef union { /* Protocol Configuration Register 23 */
19518  uint16_t R;
19519  struct {
19520 #ifndef USE_FIELD_ALIASES_FR
19521  uint16_t MICRO_PER_CYCLE_15_0:16; /* pMicroPerCycle */
19522 #else
19523  uint16_t micro_per_cycle_l:16; /* deprecated name - please avoid */
19524 #endif
19525  } B;
19526  } FR_PCR23_16B_tag;
19527
19528  typedef union { /* Protocol Configuration Register 24 */
19529  uint16_t R;
19530  struct {
19531  uint16_t CLUSTER_DRIFT_DAMPING:5; /* pClusterDriftDamping */
19532  uint16_t MAX_PAYLOAD_LENGTH_DYNAMIC:7; /* pPayloadLengthDynMax */
19533 #ifndef USE_FIELD_ALIASES_FR
19534  uint16_t MICRO_PER_CYCLE_MIN_19_16:4; /* pMicroPerCycle - pdMaxDrift */
19535 #else
19536  uint16_t MICRO_PER_CYCLE_MIN_H:4; /* deprecated name - please avoid */
19537 #endif
19538  } B;
19539  } FR_PCR24_16B_tag;
19540
19541  typedef union { /* Protocol Configuration Register 25 */
19542  uint16_t R;
19543  struct {
19544 #ifndef USE_FIELD_ALIASES_FR
19545  uint16_t MICRO_PER_CYCLE_MIN_15_0:16; /* pMicroPerCycle - pdMaxDrift */
19546 #else
19547  uint16_t MICRO_PER_CYCLE_MIN_L:16; /* deprecated name - please avoid */
19548 #endif
19549  } B;
19550  } FR_PCR25_16B_tag;
19551
19552  typedef union { /* Protocol Configuration Register 26 */
19553  uint16_t R;
19554  struct {
19555  uint16_t ALLOW_HALT_DUE_TO_CLOCK:1; /* pAllowHaltDueToClock */
19556  uint16_t COMP_ACCEPTED_STARTUP_RANGE_B:11; /* pdAcceptedStartupRange - pDelayCompensationChB */
19557 #ifndef USE_FIELD_ALIASES_FR
19558  uint16_t MICRO_PER_CYCLE_MAX_19_16:4; /* pMicroPerCycle + pdMaxDrift */
19559 #else
19560  uint16_t MICRO_PER_CYCLE_MAX_H:4; /* deprecated name - please avoid */
19561 #endif
19562  } B;
19563  } FR_PCR26_16B_tag;
19564
19565  typedef union { /* Protocol Configuration Register 27 */
19566  uint16_t R;
19567  struct {
19568 #ifndef USE_FIELD_ALIASES_FR
19569  uint16_t MICRO_PER_CYCLE_MAX_15_0:16; /* pMicroPerCycle + pdMaxDrift */
19570 #else
19571  uint16_t MICRO_PER_CYCLE_MAX_L:16; /* deprecated name - please avoid */
19572 #endif
19573  } B;
19574  } FR_PCR27_16B_tag;
19575
19576  typedef union { /* Protocol Configuration Register 28 */
19577  uint16_t R;
19578  struct {
19579  uint16_t DYNAMIC_SLOT_IDLE_PHASE:2; /* gdDynamicSlotIdlePhase */
19580  uint16_t MACRO_AFTER_OFFSET_CORRECTION:14; /* gMacroPerCycle - gOffsetCorrectionStart */
19581  } B;
19582  } FR_PCR28_16B_tag;
19583
19584  typedef union { /* Protocol Configuration Register 29 */
19585  uint16_t R;
19586  struct {
19587  uint16_t EXTERN_OFFSET_CORRECTION:3; /* pExternOffsetCorrection */
19588  uint16_t MINISLOTS_MAX:13; /* gNumberOfMinislots - 1 */
19589  } B;
19590  } FR_PCR29_16B_tag;
19591
19592  typedef union { /* Protocol Configuration Register 30 */
19593  uint16_t R;
19594  struct {
19595  uint16_t:12;
19596  uint16_t SYNC_NODE_MAX:4; /* gSyncNodeMax */
19597  } B;
19598  } FR_PCR30_16B_tag;
19599
19600  typedef union { /* Receive FIFO System Memory Base Address High Register */
19601  uint16_t R;
19602  struct {
19603  uint16_t SMBA_31_16:16; /* System Memory Base Address */
19604  } B;
19606
19607  typedef union { /* Receive FIFO System Memory Base Address Low Register */
19608  uint16_t R;
19609  struct {
19610  uint16_t:4;
19611  uint16_t SMBA_15_4:12; /* System Memory Base Address */
19612  } B;
19614
19615  typedef union { /* Receive FIFO Periodic Timer Register */
19616  uint16_t R;
19617  struct {
19618  uint16_t:2;
19619  uint16_t PTD:14; /* Periodic Timer Duration */
19620  } B;
19621  } FR_RFPTR_16B_tag;
19622
19623  typedef union { /* Receive FIFO Fill Level and Pop Count Register */
19624  uint16_t R;
19625  struct {
19626  uint16_t FLPCB:8; /* Fill Level and Pop Count Channel B */
19627  uint16_t FLPCA:8; /* Fill Level and Pop Count Channel A */
19628  } B;
19630
19631  typedef union { /* ECC Error Interrupt Flag and Enable Register */
19632  uint16_t R;
19633  struct {
19634  uint16_t LRNE_OF:1; /* LRAM Non-Corrected Error Overflow Flag */
19635  uint16_t LRCE_OF:1; /* LRAM Corrected Error Overflow Flag */
19636  uint16_t DRNE_OF:1; /* DRAM Non-Corrected Error Overflow Flag */
19637  uint16_t DRCE_OF:1; /* DRAM Corrected Error Overflow Flag */
19638  uint16_t LRNE_IF:1; /* LRAM Non-Corrected Error Interrupt Flag */
19639  uint16_t LRCE_IF:1; /* LRAM Corrected Error Interrupt Flag */
19640  uint16_t DRNE_IF:1; /* DRAM Non-Corrected Error Interrupt Flag */
19641  uint16_t DRCE_IF:1; /* DRAM Corrected Error Interrupt Flag */
19642  uint16_t:4;
19643  uint16_t LRNE_IE:1; /* LRAM Non-Corrected Error Interrupt Enable */
19644  uint16_t LRCE_IE:1; /* LRAM Corrected Error Interrupt Enable */
19645  uint16_t DRNE_IE:1; /* DRAM Non-Corrected Error Interrupt Enable */
19646  uint16_t DRCE_IE:1; /* DRAM Corrected Error Interrupt Enable */
19647  } B;
19649
19650  typedef union { /* ECC Error Report and Injection Control Register */
19651  uint16_t R;
19652  struct {
19653  uint16_t BSY:1; /* Register Update Busy */
19654  uint16_t:5;
19655  uint16_t ERS:2; /* Error Report Select */
19656  uint16_t:3;
19657  uint16_t ERM:1; /* Error Report Mode */
19658  uint16_t:2;
19659  uint16_t EIM:1; /* Error Injection Mode */
19660  uint16_t EIE:1; /* Error Injection Enable */
19661  } B;
19663
19664  typedef union { /* ECC Error Report Adress Register */
19665  uint16_t R;
19666  struct {
19667  uint16_t MID:1; /* Memory Identifier */
19668  uint16_t BANK:3; /* Memory Bank */
19669  uint16_t ADDR:12; /* Memory Address */
19670  } B;
19671  } FR_EERAR_16B_tag;
19672
19673  typedef union { /* ECC Error Report Data Register */
19674  uint16_t R;
19675  struct {
19676  uint16_t DATA:16; /* Data */
19677  } B;
19678  } FR_EERDR_16B_tag;
19679
19680  typedef union { /* ECC Error Report Code Register */
19681  uint16_t R;
19682  struct {
19683  uint16_t:11;
19684  uint16_t CODE:5; /* Code */
19685  } B;
19686  } FR_EERCR_16B_tag;
19687
19688  typedef union { /* ECC Error Injection Address Register */
19689  uint16_t R;
19690  struct {
19691  uint16_t MID:1; /* Memory Identifier */
19692  uint16_t BANK:3; /* Memory Bank */
19693  uint16_t ADDR:12; /* Memory Address */
19694  } B;
19695  } FR_EEIAR_16B_tag;
19696
19697  typedef union { /* ECC Error Injection Data Register */
19698  uint16_t R;
19699  struct {
19700  uint16_t DATA:16; /* Data */
19701  } B;
19702  } FR_EEIDR_16B_tag;
19703
19704  typedef union { /* ECC Error Injection Code Register */
19705  uint16_t R;
19706  struct {
19707  uint16_t:11;
19708  uint16_t CODE:5; /* Code */
19709  } B;
19710  } FR_EEICR_16B_tag;
19711
19712
19713  /* Register layout for all registers MBCCSR... */
19714
19715  typedef union { /* Message Buffer Configuration Control Status Register */
19716  uint16_t R;
19717  struct {
19718  uint16_t:1;
19719  uint16_t MCM:1; /* Message Buffer Commit Mode */
19720  uint16_t MBT:1; /* Message Buffer Type */
19721  uint16_t MTD:1; /* Message Buffer Transfer Direction */
19722  uint16_t CMT:1; /* Commit for Transmission */
19723  uint16_t EDT:1; /* Enable/Disable Trigger */
19724  uint16_t LCKT:1; /* Lock/Unlock Trigger */
19725  uint16_t MBIE:1; /* Message Buffer Interrupt Enable */
19726  uint16_t:3;
19727  uint16_t DUP:1; /* Data Updated */
19728  uint16_t DVAL:1; /* DataValid */
19729  uint16_t EDS:1; /* Enable/Disable Status */
19730  uint16_t LCKS:1; /* LockStatus */
19731  uint16_t MBIF:1; /* Message Buffer Interrupt Flag */
19732  } B;
19734
19735
19736  /* Register layout for all registers MBCCFR... */
19737
19738  typedef union { /* Message Buffer Cycle Counter Filter Register */
19739  uint16_t R;
19740  struct {
19741  uint16_t MTM:1; /* Message Buffer Transmission Mode */
19742 #ifndef USE_FIELD_ALIASES_FR
19743  uint16_t CHA:1; /* Channel Assignment */
19744 #else
19745  uint16_t CHNLA:1; /* deprecated name - please avoid */
19746 #endif
19747 #ifndef USE_FIELD_ALIASES_FR
19748  uint16_t CHB:1; /* Channel Assignment */
19749 #else
19750  uint16_t CHNLB:1; /* deprecated name - please avoid */
19751 #endif
19752  uint16_t CCFE:1; /* Cycle Counter Filtering Enable */
19753  uint16_t CCFMSK:6; /* Cycle Counter Filtering Mask */
19754  uint16_t CCFVAL:6; /* Cycle Counter Filtering Value */
19755  } B;
19757
19758
19759  /* Register layout for all registers MBFIDR... */
19760
19761  typedef union { /* Message Buffer Frame ID Register */
19762  uint16_t R;
19763  struct {
19764  uint16_t:5;
19765  uint16_t FID:11; /* Frame ID */
19766  } B;
19768
19769
19770  /* Register layout for all registers MBIDXR... */
19771
19772  typedef union { /* Message Buffer Index Register */
19773  uint16_t R;
19774  struct {
19775  uint16_t:9;
19776  uint16_t MBIDX:7; /* Message Buffer Index */
19777  } B;
19779
19780
19781  /* Register layout for generated register(s) NMVR... */
19782
19783  typedef union { /* */
19784  uint16_t R;
19785  } FR_NMVR_16B_tag;
19786
19787
19788
19789
19790  /* Register layout for generated register(s) SSCR... */
19791
19792  typedef union { /* */
19793  uint16_t R;
19794  } FR_SSCR_16B_tag;
19795
19796
19797  typedef struct FR_MB_struct_tag {
19798
19799  /* Message Buffer Configuration Control Status Register */
19800  FR_MBCCSR_16B_tag MBCCSR; /* relative offset: 0x0000 */
19801  /* Message Buffer Cycle Counter Filter Register */
19802  FR_MBCCFR_16B_tag MBCCFR; /* relative offset: 0x0002 */
19803  /* Message Buffer Frame ID Register */
19804  FR_MBFIDR_16B_tag MBFIDR; /* relative offset: 0x0004 */
19805  /* Message Buffer Index Register */
19806  FR_MBIDXR_16B_tag MBIDXR; /* relative offset: 0x0006 */
19807
19808  } FR_MB_tag;
19809
19810
19811  typedef struct FR_struct_tag { /* start of FR_tag */
19812  /* Module Version Number */
19813  FR_MVR_16B_tag MVR; /* offset: 0x0000 size: 16 bit */
19814  /* Module Configuration Register */
19815  FR_MCR_16B_tag MCR; /* offset: 0x0002 size: 16 bit */
19816  union {
19817  FR_SYMBADHR_16B_tag SYSBADHR; /* deprecated - please avoid */
19818
19819  /* SYSTEM MEMORY BASE ADD HIGH REG */
19820  FR_SYMBADHR_16B_tag SYMBADHR; /* offset: 0x0004 size: 16 bit */
19821
19822  };
19823  union {
19824  FR_SYMBADLR_16B_tag SYSBADLR; /* deprecated - please avoid */
19825
19826  /* SYSTEM MEMORY BASE ADD LOW REG */
19827  FR_SYMBADLR_16B_tag SYMBADLR; /* offset: 0x0006 size: 16 bit */
19828
19829  };
19830  /* STROBE SIGNAL CONTROL REGISTER */
19831  FR_STBSCR_16B_tag STBSCR; /* offset: 0x0008 size: 16 bit */
19832  int8_t FR_reserved_000A[2];
19833  /* MESSAGE BUFFER DATA SIZE REGISTER */
19834  FR_MBDSR_16B_tag MBDSR; /* offset: 0x000C size: 16 bit */
19835  /* MESS. BUFFER SEG. SIZE & UTILISATION REG */
19836  FR_MBSSUTR_16B_tag MBSSUTR; /* offset: 0x000E size: 16 bit */
19837  union {
19838  /* PE DRAM ACCESS REGISTER */
19839  FR_PEDRAR_16B_tag PEDRAR; /* offset: 0x0010 size: 16 bit */
19840
19841  FR_PEDRAR_16B_tag PADR; /* deprecated - please avoid */
19842
19843  };
19844  union {
19845  /* PE DRAM DATA REGISTER */
19846  FR_PEDRDR_16B_tag PEDRDR; /* offset: 0x0012 size: 16 bit */
19847
19848  FR_PEDRDR_16B_tag PDAR; /* deprecated - please avoid */
19849
19850  };
19851  /* PROTOCOL OPERATION CONTROL REG */
19852  FR_POCR_16B_tag POCR; /* offset: 0x0014 size: 16 bit */
19853  /* GLOBAL INTERRUPT FLAG & ENABLE REG */
19854  FR_GIFER_16B_tag GIFER; /* offset: 0x0016 size: 16 bit */
19855  /* PROTOCOL INTERRUPT FLAG REGISTER 0 */
19856  FR_PIFR0_16B_tag PIFR0; /* offset: 0x0018 size: 16 bit */
19857  /* PROTOCOL INTERRUPT FLAG REGISTER 1 */
19858  FR_PIFR1_16B_tag PIFR1; /* offset: 0x001A size: 16 bit */
19859  /* PROTOCOL INTERRUPT ENABLE REGISTER 0 */
19860  FR_PIER0_16B_tag PIER0; /* offset: 0x001C size: 16 bit */
19861  /* PROTOCOL INTERRUPT ENABLE REGISTER 1 */
19862  FR_PIER1_16B_tag PIER1; /* offset: 0x001E size: 16 bit */
19863  /* CHI ERROR FLAG REGISTER */
19864  FR_CHIERFR_16B_tag CHIERFR; /* offset: 0x0020 size: 16 bit */
19865  /* Message Buffer Interrupt Vector Register */
19866  FR_MBIVEC_16B_tag MBIVEC; /* offset: 0x0022 size: 16 bit */
19867  /* Channel A Status Error Counter Register */
19868  FR_CASERCR_16B_tag CASERCR; /* offset: 0x0024 size: 16 bit */
19869  /* Channel B Status Error Counter Register */
19870  FR_CBSERCR_16B_tag CBSERCR; /* offset: 0x0026 size: 16 bit */
19871  /* Protocol Status Register 0 */
19872  FR_PSR0_16B_tag PSR0; /* offset: 0x0028 size: 16 bit */
19873  /* Protocol Status Register 1 */
19874  FR_PSR1_16B_tag PSR1; /* offset: 0x002A size: 16 bit */
19875  /* Protocol Status Register 2 */
19876  FR_PSR2_16B_tag PSR2; /* offset: 0x002C size: 16 bit */
19877  /* Protocol Status Register 3 */
19878  FR_PSR3_16B_tag PSR3; /* offset: 0x002E size: 16 bit */
19879  /* Macrotick Counter Register */
19880  FR_MTCTR_16B_tag MTCTR; /* offset: 0x0030 size: 16 bit */
19881  /* Cycle Counter Register */
19882  FR_CYCTR_16B_tag CYCTR; /* offset: 0x0032 size: 16 bit */
19883  /* Slot Counter Channel A Register */
19884  FR_SLTCTAR_16B_tag SLTCTAR; /* offset: 0x0034 size: 16 bit */
19885  /* Slot Counter Channel B Register */
19886  FR_SLTCTBR_16B_tag SLTCTBR; /* offset: 0x0036 size: 16 bit */
19887  /* Rate Correction Value Register */
19888  FR_RTCORVR_16B_tag RTCORVR; /* offset: 0x0038 size: 16 bit */
19889  /* Offset Correction Value Register */
19890  FR_OFCORVR_16B_tag OFCORVR; /* offset: 0x003A size: 16 bit */
19891  union {
19892  FR_CIFR_16B_tag CIFRR; /* deprecated - please avoid */
19893
19894  /* Combined Interrupt Flag Register */
19895  FR_CIFR_16B_tag CIFR; /* offset: 0x003C size: 16 bit */
19896
19897  };
19898  /* System Memory Access Time-Out Register */
19899  FR_SYMATOR_16B_tag SYMATOR; /* offset: 0x003E size: 16 bit */
19900  /* Sync Frame Counter Register */
19901  FR_SFCNTR_16B_tag SFCNTR; /* offset: 0x0040 size: 16 bit */
19902  /* Sync Frame Table Offset Register */
19903  FR_SFTOR_16B_tag SFTOR; /* offset: 0x0042 size: 16 bit */
19904  /* Sync Frame Table Configuration, Control, Status Register */
19905  FR_SFTCCSR_16B_tag SFTCCSR; /* offset: 0x0044 size: 16 bit */
19906  /* Sync Frame ID Rejection Filter */
19907  FR_SFIDRFR_16B_tag SFIDRFR; /* offset: 0x0046 size: 16 bit */
19908  /* Sync Frame ID Acceptance Filter Value Register */
19909  FR_SFIDAFVR_16B_tag SFIDAFVR; /* offset: 0x0048 size: 16 bit */
19910  /* Sync Frame ID Acceptance Filter Mask Register */
19911  FR_SFIDAFMR_16B_tag SFIDAFMR; /* offset: 0x004A size: 16 bit */
19912  union {
19913  FR_NMVR_16B_tag NMVR[6]; /* offset: 0x004C (0x0002 x 6) */
19914
19915  struct {
19916  /* Network Management Vector Register0 */
19917  FR_NMVR0_16B_tag NMVR0; /* offset: 0x004C size: 16 bit */
19918  /* Network Management Vector Register1 */
19919  FR_NMVR1_16B_tag NMVR1; /* offset: 0x004E size: 16 bit */
19920  /* Network Management Vector Register2 */
19921  FR_NMVR2_16B_tag NMVR2; /* offset: 0x0050 size: 16 bit */
19922  /* Network Management Vector Register3 */
19923  FR_NMVR3_16B_tag NMVR3; /* offset: 0x0052 size: 16 bit */
19924  /* Network Management Vector Register4 */
19925  FR_NMVR4_16B_tag NMVR4; /* offset: 0x0054 size: 16 bit */
19926  /* Network Management Vector Register5 */
19927  FR_NMVR5_16B_tag NMVR5; /* offset: 0x0056 size: 16 bit */
19928  };
19929
19930  };
19931  /* Network Management Vector Length Register */
19932  FR_NMVLR_16B_tag NMVLR; /* offset: 0x0058 size: 16 bit */
19933  /* Timer Configuration and Control Register */
19934  FR_TICCR_16B_tag TICCR; /* offset: 0x005A size: 16 bit */
19935  /* Timer 1 Cycle Set Register */
19936  FR_TI1CYSR_16B_tag TI1CYSR; /* offset: 0x005C size: 16 bit */
19937  union {
19938  /* Timer 1 Macrotick Offset Register */
19939  FR_TI1MTOR_16B_tag TI1MTOR; /* offset: 0x005E size: 16 bit */
19940
19941  FR_TI1MTOR_16B_tag T1MTOR; /* deprecated - please avoid */
19942
19943  };
19944  /* Timer 2 Configuration Register 0 */
19945  FR_TI2CR0_16B_tag TI2CR0; /* offset: 0x0060 size: 16 bit */
19946  /* Timer 2 Configuration Register 1 */
19947  FR_TI2CR1_16B_tag TI2CR1; /* offset: 0x0062 size: 16 bit */
19948  /* Slot Status Selection Register */
19949  FR_SSSR_16B_tag SSSR; /* offset: 0x0064 size: 16 bit */
19950  /* Slot Status Counter Condition Register */
19951  FR_SSCCR_16B_tag SSCCR; /* offset: 0x0066 size: 16 bit */
19952  union {
19953  FR_SSR_16B_tag SSR[8]; /* offset: 0x0068 (0x0002 x 8) */
19954
19955  struct {
19956  /* Slot Status Register0 */
19957  FR_SSR_16B_tag SSR0; /* offset: 0x0068 size: 16 bit */
19958  /* Slot Status Register1 */
19959  FR_SSR_16B_tag SSR1; /* offset: 0x006A size: 16 bit */
19960  /* Slot Status Register2 */
19961  FR_SSR_16B_tag SSR2; /* offset: 0x006C size: 16 bit */
19962  /* Slot Status Register3 */
19963  FR_SSR_16B_tag SSR3; /* offset: 0x006E size: 16 bit */
19964  /* Slot Status Register4 */
19965  FR_SSR_16B_tag SSR4; /* offset: 0x0070 size: 16 bit */
19966  /* Slot Status Register5 */
19967  FR_SSR_16B_tag SSR5; /* offset: 0x0072 size: 16 bit */
19968  /* Slot Status Register6 */
19969  FR_SSR_16B_tag SSR6; /* offset: 0x0074 size: 16 bit */
19970  /* Slot Status Register7 */
19971  FR_SSR_16B_tag SSR7; /* offset: 0x0076 size: 16 bit */
19972  };
19973
19974  };
19975  union {
19976  FR_SSCR_16B_tag SSCR[4]; /* offset: 0x0078 (0x0002 x 4) */
19977
19978  struct {
19979  /* Slot Status Counter Register0 */
19980  FR_SSCR0_16B_tag SSCR0; /* offset: 0x0078 size: 16 bit */
19981  /* Slot Status Counter Register1 */
19982  FR_SSCR1_16B_tag SSCR1; /* offset: 0x007A size: 16 bit */
19983  /* Slot Status Counter Register2 */
19984  FR_SSCR2_16B_tag SSCR2; /* offset: 0x007C size: 16 bit */
19985  /* Slot Status Counter Register3 */
19986  FR_SSCR3_16B_tag SSCR3; /* offset: 0x007E size: 16 bit */
19987  };
19988
19989  };
19990  /* MTS A Configuration Register */
19991  FR_MTSACFR_16B_tag MTSACFR; /* offset: 0x0080 size: 16 bit */
19992  /* MTS B Configuration Register */
19993  FR_MTSBCFR_16B_tag MTSBCFR; /* offset: 0x0082 size: 16 bit */
19994  /* Receive Shadow Buffer Index Register */
19995  FR_RSBIR_16B_tag RSBIR; /* offset: 0x0084 size: 16 bit */
19996  union {
19997  /* Receive FIFO Watermark and Selection Register */
19998  FR_RFWMSR_16B_tag RFWMSR; /* offset: 0x0086 size: 16 bit */
19999
20000  FR_RFWMSR_16B_tag RFSR; /* deprecated - please avoid */
20001
20002  };
20003  union {
20004  FR_RF_RFSIR_16B_tag RFSIR; /* deprecated - please avoid */
20005
20006  /* Receive FIFO Start Index Register */
20007  FR_RF_RFSIR_16B_tag RF_RFSIR; /* offset: 0x0088 size: 16 bit */
20008
20009  };
20010  /* Receive FIFO Depth and Size Register */
20011  FR_RFDSR_16B_tag RFDSR; /* offset: 0x008A size: 16 bit */
20012  /* Receive FIFO A Read Index Register */
20013  FR_RFARIR_16B_tag RFARIR; /* offset: 0x008C size: 16 bit */
20014  /* Receive FIFO B Read Index Register */
20015  FR_RFBRIR_16B_tag RFBRIR; /* offset: 0x008E size: 16 bit */
20016  /* Receive FIFO Message ID Acceptance Filter Value Register */
20017  FR_RFMIDAFVR_16B_tag RFMIDAFVR; /* offset: 0x0090 size: 16 bit */
20018  union {
20019  /* Receive FIFO Message ID Acceptance Filter Mask Register */
20020  FR_RFMIDAFMR_16B_tag RFMIDAFMR; /* offset: 0x0092 size: 16 bit */
20021
20022  FR_RFMIDAFMR_16B_tag RFMIAFMR; /* deprecated - please avoid */
20023
20024  };
20025  /* Receive FIFO Frame ID Rejection Filter Value Register */
20026  FR_RFFIDRFVR_16B_tag RFFIDRFVR; /* offset: 0x0094 size: 16 bit */
20027  /* Receive FIFO Frame ID Rejection Filter Mask Register */
20028  FR_RFFIDRFMR_16B_tag RFFIDRFMR; /* offset: 0x0096 size: 16 bit */
20029  /* Receive FIFO Range Filter Configuration Register */
20030  FR_RFRFCFR_16B_tag RFRFCFR; /* offset: 0x0098 size: 16 bit */
20031  /* Receive FIFO Range Filter Control Register */
20032  FR_RFRFCTR_16B_tag RFRFCTR; /* offset: 0x009A size: 16 bit */
20033  /* Last Dynamic Transmit Slot Channel A Register */
20034  FR_LDTXSLAR_16B_tag LDTXSLAR; /* offset: 0x009C size: 16 bit */
20035  /* Last Dynamic Transmit Slot Channel B Register */
20036  FR_LDTXSLBR_16B_tag LDTXSLBR; /* offset: 0x009E size: 16 bit */
20037  /* Protocol Configuration Register 0 */
20038  FR_PCR0_16B_tag PCR0; /* offset: 0x00A0 size: 16 bit */
20039  /* Protocol Configuration Register 1 */
20040  FR_PCR1_16B_tag PCR1; /* offset: 0x00A2 size: 16 bit */
20041  /* Protocol Configuration Register 2 */
20042  FR_PCR2_16B_tag PCR2; /* offset: 0x00A4 size: 16 bit */
20043  /* Protocol Configuration Register 3 */
20044  FR_PCR3_16B_tag PCR3; /* offset: 0x00A6 size: 16 bit */
20045  /* Protocol Configuration Register 4 */
20046  FR_PCR4_16B_tag PCR4; /* offset: 0x00A8 size: 16 bit */
20047  /* Protocol Configuration Register 5 */
20048  FR_PCR5_16B_tag PCR5; /* offset: 0x00AA size: 16 bit */
20049  /* Protocol Configuration Register 6 */
20050  FR_PCR6_16B_tag PCR6; /* offset: 0x00AC size: 16 bit */
20051  /* Protocol Configuration Register 7 */
20052  FR_PCR7_16B_tag PCR7; /* offset: 0x00AE size: 16 bit */
20053  /* Protocol Configuration Register 8 */
20054  FR_PCR8_16B_tag PCR8; /* offset: 0x00B0 size: 16 bit */
20055  /* Protocol Configuration Register 9 */
20056  FR_PCR9_16B_tag PCR9; /* offset: 0x00B2 size: 16 bit */
20057  /* Protocol Configuration Register 10 */
20058  FR_PCR10_16B_tag PCR10; /* offset: 0x00B4 size: 16 bit */
20059  /* Protocol Configuration Register 11 */
20060  FR_PCR11_16B_tag PCR11; /* offset: 0x00B6 size: 16 bit */
20061  /* Protocol Configuration Register 12 */
20062  FR_PCR12_16B_tag PCR12; /* offset: 0x00B8 size: 16 bit */
20063  /* Protocol Configuration Register 13 */
20064  FR_PCR13_16B_tag PCR13; /* offset: 0x00BA size: 16 bit */
20065  /* Protocol Configuration Register 14 */
20066  FR_PCR14_16B_tag PCR14; /* offset: 0x00BC size: 16 bit */
20067  /* Protocol Configuration Register 15 */
20068  FR_PCR15_16B_tag PCR15; /* offset: 0x00BE size: 16 bit */
20069  /* Protocol Configuration Register 16 */
20070  FR_PCR16_16B_tag PCR16; /* offset: 0x00C0 size: 16 bit */
20071  /* Protocol Configuration Register 17 */
20072  FR_PCR17_16B_tag PCR17; /* offset: 0x00C2 size: 16 bit */
20073  /* Protocol Configuration Register 18 */
20074  FR_PCR18_16B_tag PCR18; /* offset: 0x00C4 size: 16 bit */
20075  /* Protocol Configuration Register 19 */
20076  FR_PCR19_16B_tag PCR19; /* offset: 0x00C6 size: 16 bit */
20077  /* Protocol Configuration Register 20 */
20078  FR_PCR20_16B_tag PCR20; /* offset: 0x00C8 size: 16 bit */
20079  /* Protocol Configuration Register 21 */
20080  FR_PCR21_16B_tag PCR21; /* offset: 0x00CA size: 16 bit */
20081  /* Protocol Configuration Register 22 */
20082  FR_PCR22_16B_tag PCR22; /* offset: 0x00CC size: 16 bit */
20083  /* Protocol Configuration Register 23 */
20084  FR_PCR23_16B_tag PCR23; /* offset: 0x00CE size: 16 bit */
20085  /* Protocol Configuration Register 24 */
20086  FR_PCR24_16B_tag PCR24; /* offset: 0x00D0 size: 16 bit */
20087  /* Protocol Configuration Register 25 */
20088  FR_PCR25_16B_tag PCR25; /* offset: 0x00D2 size: 16 bit */
20089  /* Protocol Configuration Register 26 */
20090  FR_PCR26_16B_tag PCR26; /* offset: 0x00D4 size: 16 bit */
20091  /* Protocol Configuration Register 27 */
20092  FR_PCR27_16B_tag PCR27; /* offset: 0x00D6 size: 16 bit */
20093  /* Protocol Configuration Register 28 */
20094  FR_PCR28_16B_tag PCR28; /* offset: 0x00D8 size: 16 bit */
20095  /* Protocol Configuration Register 29 */
20096  FR_PCR29_16B_tag PCR29; /* offset: 0x00DA size: 16 bit */
20097  /* Protocol Configuration Register 30 */
20098  FR_PCR30_16B_tag PCR30; /* offset: 0x00DC size: 16 bit */
20099  int8_t FR_reserved_00DE[10];
20100  /* Receive FIFO System Memory Base Address High Register */
20101  FR_RFSYMBHADR_16B_tag RFSYMBHADR; /* offset: 0x00E8 size: 16 bit */
20102  /* Receive FIFO System Memory Base Address Low Register */
20103  FR_RFSYMBLADR_16B_tag RFSYMBLADR; /* offset: 0x00EA size: 16 bit */
20104  /* Receive FIFO Periodic Timer Register */
20105  FR_RFPTR_16B_tag RFPTR; /* offset: 0x00EC size: 16 bit */
20106  /* Receive FIFO Fill Level and Pop Count Register */
20107  FR_RFFLPCR_16B_tag RFFLPCR; /* offset: 0x00EE size: 16 bit */
20108  /* ECC Error Interrupt Flag and Enable Register */
20109  FR_EEIFER_16B_tag EEIFER; /* offset: 0x00F0 size: 16 bit */
20110  /* ECC Error Report and Injection Control Register */
20111  FR_EERICR_16B_tag EERICR; /* offset: 0x00F2 size: 16 bit */
20112  /* ECC Error Report Adress Register */
20113  FR_EERAR_16B_tag EERAR; /* offset: 0x00F4 size: 16 bit */
20114  /* ECC Error Report Data Register */
20115  FR_EERDR_16B_tag EERDR; /* offset: 0x00F6 size: 16 bit */
20116  /* ECC Error Report Code Register */
20117  FR_EERCR_16B_tag EERCR; /* offset: 0x00F8 size: 16 bit */
20118  /* ECC Error Injection Address Register */
20119  FR_EEIAR_16B_tag EEIAR; /* offset: 0x00FA size: 16 bit */
20120  /* ECC Error Injection Data Register */
20121  FR_EEIDR_16B_tag EEIDR; /* offset: 0x00FC size: 16 bit */
20122  /* ECC Error Injection Code Register */
20123  FR_EEICR_16B_tag EEICR; /* offset: 0x00FE size: 16 bit */
20124  union {
20125  /* Register set MB */
20126  FR_MB_tag MB[64]; /* offset: 0x0100 (0x0008 x 64) */
20127
20128  FR_MB_tag MBCCS[64]; /* offset: 0x0100 (0x0008 x 64) */
20129
20130  struct {
20131  /* Message Buffer Configuration Control Status Register */
20132  FR_MBCCSR_16B_tag MBCCSR0; /* offset: 0x0100 size: 16 bit */
20133  /* Message Buffer Cycle Counter Filter Register */
20134  FR_MBCCFR_16B_tag MBCCFR0; /* offset: 0x0102 size: 16 bit */
20135  /* Message Buffer Frame ID Register */
20136  FR_MBFIDR_16B_tag MBFIDR0; /* offset: 0x0104 size: 16 bit */
20137  /* Message Buffer Index Register */
20138  FR_MBIDXR_16B_tag MBIDXR0; /* offset: 0x0106 size: 16 bit */
20139  /* Message Buffer Configuration Control Status Register */
20140  FR_MBCCSR_16B_tag MBCCSR1; /* offset: 0x0108 size: 16 bit */
20141  /* Message Buffer Cycle Counter Filter Register */
20142  FR_MBCCFR_16B_tag MBCCFR1; /* offset: 0x010A size: 16 bit */
20143  /* Message Buffer Frame ID Register */
20144  FR_MBFIDR_16B_tag MBFIDR1; /* offset: 0x010C size: 16 bit */
20145  /* Message Buffer Index Register */
20146  FR_MBIDXR_16B_tag MBIDXR1; /* offset: 0x010E size: 16 bit */
20147  /* Message Buffer Configuration Control Status Register */
20148  FR_MBCCSR_16B_tag MBCCSR2; /* offset: 0x0110 size: 16 bit */
20149  /* Message Buffer Cycle Counter Filter Register */
20150  FR_MBCCFR_16B_tag MBCCFR2; /* offset: 0x0112 size: 16 bit */
20151  /* Message Buffer Frame ID Register */
20152  FR_MBFIDR_16B_tag MBFIDR2; /* offset: 0x0114 size: 16 bit */
20153  /* Message Buffer Index Register */
20154  FR_MBIDXR_16B_tag MBIDXR2; /* offset: 0x0116 size: 16 bit */
20155  /* Message Buffer Configuration Control Status Register */
20156  FR_MBCCSR_16B_tag MBCCSR3; /* offset: 0x0118 size: 16 bit */
20157  /* Message Buffer Cycle Counter Filter Register */
20158  FR_MBCCFR_16B_tag MBCCFR3; /* offset: 0x011A size: 16 bit */
20159  /* Message Buffer Frame ID Register */
20160  FR_MBFIDR_16B_tag MBFIDR3; /* offset: 0x011C size: 16 bit */
20161  /* Message Buffer Index Register */
20162  FR_MBIDXR_16B_tag MBIDXR3; /* offset: 0x011E size: 16 bit */
20163  /* Message Buffer Configuration Control Status Register */
20164  FR_MBCCSR_16B_tag MBCCSR4; /* offset: 0x0120 size: 16 bit */
20165  /* Message Buffer Cycle Counter Filter Register */
20166  FR_MBCCFR_16B_tag MBCCFR4; /* offset: 0x0122 size: 16 bit */
20167  /* Message Buffer Frame ID Register */
20168  FR_MBFIDR_16B_tag MBFIDR4; /* offset: 0x0124 size: 16 bit */
20169  /* Message Buffer Index Register */
20170  FR_MBIDXR_16B_tag MBIDXR4; /* offset: 0x0126 size: 16 bit */
20171  /* Message Buffer Configuration Control Status Register */
20172  FR_MBCCSR_16B_tag MBCCSR5; /* offset: 0x0128 size: 16 bit */
20173  /* Message Buffer Cycle Counter Filter Register */
20174  FR_MBCCFR_16B_tag MBCCFR5; /* offset: 0x012A size: 16 bit */
20175  /* Message Buffer Frame ID Register */
20176  FR_MBFIDR_16B_tag MBFIDR5; /* offset: 0x012C size: 16 bit */
20177  /* Message Buffer Index Register */
20178  FR_MBIDXR_16B_tag MBIDXR5; /* offset: 0x012E size: 16 bit */
20179  /* Message Buffer Configuration Control Status Register */
20180  FR_MBCCSR_16B_tag MBCCSR6; /* offset: 0x0130 size: 16 bit */
20181  /* Message Buffer Cycle Counter Filter Register */
20182  FR_MBCCFR_16B_tag MBCCFR6; /* offset: 0x0132 size: 16 bit */
20183  /* Message Buffer Frame ID Register */
20184  FR_MBFIDR_16B_tag MBFIDR6; /* offset: 0x0134 size: 16 bit */
20185  /* Message Buffer Index Register */
20186  FR_MBIDXR_16B_tag MBIDXR6; /* offset: 0x0136 size: 16 bit */
20187  /* Message Buffer Configuration Control Status Register */
20188  FR_MBCCSR_16B_tag MBCCSR7; /* offset: 0x0138 size: 16 bit */
20189  /* Message Buffer Cycle Counter Filter Register */
20190  FR_MBCCFR_16B_tag MBCCFR7; /* offset: 0x013A size: 16 bit */
20191  /* Message Buffer Frame ID Register */
20192  FR_MBFIDR_16B_tag MBFIDR7; /* offset: 0x013C size: 16 bit */
20193  /* Message Buffer Index Register */
20194  FR_MBIDXR_16B_tag MBIDXR7; /* offset: 0x013E size: 16 bit */
20195  /* Message Buffer Configuration Control Status Register */
20196  FR_MBCCSR_16B_tag MBCCSR8; /* offset: 0x0140 size: 16 bit */
20197  /* Message Buffer Cycle Counter Filter Register */
20198  FR_MBCCFR_16B_tag MBCCFR8; /* offset: 0x0142 size: 16 bit */
20199  /* Message Buffer Frame ID Register */
20200  FR_MBFIDR_16B_tag MBFIDR8; /* offset: 0x0144 size: 16 bit */
20201  /* Message Buffer Index Register */
20202  FR_MBIDXR_16B_tag MBIDXR8; /* offset: 0x0146 size: 16 bit */
20203  /* Message Buffer Configuration Control Status Register */
20204  FR_MBCCSR_16B_tag MBCCSR9; /* offset: 0x0148 size: 16 bit */
20205  /* Message Buffer Cycle Counter Filter Register */
20206  FR_MBCCFR_16B_tag MBCCFR9; /* offset: 0x014A size: 16 bit */
20207  /* Message Buffer Frame ID Register */
20208  FR_MBFIDR_16B_tag MBFIDR9; /* offset: 0x014C size: 16 bit */
20209  /* Message Buffer Index Register */
20210  FR_MBIDXR_16B_tag MBIDXR9; /* offset: 0x014E size: 16 bit */
20211  /* Message Buffer Configuration Control Status Register */
20212  FR_MBCCSR_16B_tag MBCCSR10; /* offset: 0x0150 size: 16 bit */
20213  /* Message Buffer Cycle Counter Filter Register */
20214  FR_MBCCFR_16B_tag MBCCFR10; /* offset: 0x0152 size: 16 bit */
20215  /* Message Buffer Frame ID Register */
20216  FR_MBFIDR_16B_tag MBFIDR10; /* offset: 0x0154 size: 16 bit */
20217  /* Message Buffer Index Register */
20218  FR_MBIDXR_16B_tag MBIDXR10; /* offset: 0x0156 size: 16 bit */
20219  /* Message Buffer Configuration Control Status Register */
20220  FR_MBCCSR_16B_tag MBCCSR11; /* offset: 0x0158 size: 16 bit */
20221  /* Message Buffer Cycle Counter Filter Register */
20222  FR_MBCCFR_16B_tag MBCCFR11; /* offset: 0x015A size: 16 bit */
20223  /* Message Buffer Frame ID Register */
20224  FR_MBFIDR_16B_tag MBFIDR11; /* offset: 0x015C size: 16 bit */
20225  /* Message Buffer Index Register */
20226  FR_MBIDXR_16B_tag MBIDXR11; /* offset: 0x015E size: 16 bit */
20227  /* Message Buffer Configuration Control Status Register */
20228  FR_MBCCSR_16B_tag MBCCSR12; /* offset: 0x0160 size: 16 bit */
20229  /* Message Buffer Cycle Counter Filter Register */
20230  FR_MBCCFR_16B_tag MBCCFR12; /* offset: 0x0162 size: 16 bit */
20231  /* Message Buffer Frame ID Register */
20232  FR_MBFIDR_16B_tag MBFIDR12; /* offset: 0x0164 size: 16 bit */
20233  /* Message Buffer Index Register */
20234  FR_MBIDXR_16B_tag MBIDXR12; /* offset: 0x0166 size: 16 bit */
20235  /* Message Buffer Configuration Control Status Register */
20236  FR_MBCCSR_16B_tag MBCCSR13; /* offset: 0x0168 size: 16 bit */
20237  /* Message Buffer Cycle Counter Filter Register */
20238  FR_MBCCFR_16B_tag MBCCFR13; /* offset: 0x016A size: 16 bit */
20239  /* Message Buffer Frame ID Register */
20240  FR_MBFIDR_16B_tag MBFIDR13; /* offset: 0x016C size: 16 bit */
20241  /* Message Buffer Index Register */
20242  FR_MBIDXR_16B_tag MBIDXR13; /* offset: 0x016E size: 16 bit */
20243  /* Message Buffer Configuration Control Status Register */
20244  FR_MBCCSR_16B_tag MBCCSR14; /* offset: 0x0170 size: 16 bit */
20245  /* Message Buffer Cycle Counter Filter Register */
20246  FR_MBCCFR_16B_tag MBCCFR14; /* offset: 0x0172 size: 16 bit */
20247  /* Message Buffer Frame ID Register */
20248  FR_MBFIDR_16B_tag MBFIDR14; /* offset: 0x0174 size: 16 bit */
20249  /* Message Buffer Index Register */
20250  FR_MBIDXR_16B_tag MBIDXR14; /* offset: 0x0176 size: 16 bit */
20251  /* Message Buffer Configuration Control Status Register */
20252  FR_MBCCSR_16B_tag MBCCSR15; /* offset: 0x0178 size: 16 bit */
20253  /* Message Buffer Cycle Counter Filter Register */
20254  FR_MBCCFR_16B_tag MBCCFR15; /* offset: 0x017A size: 16 bit */
20255  /* Message Buffer Frame ID Register */
20256  FR_MBFIDR_16B_tag MBFIDR15; /* offset: 0x017C size: 16 bit */
20257  /* Message Buffer Index Register */
20258  FR_MBIDXR_16B_tag MBIDXR15; /* offset: 0x017E size: 16 bit */
20259  /* Message Buffer Configuration Control Status Register */
20260  FR_MBCCSR_16B_tag MBCCSR16; /* offset: 0x0180 size: 16 bit */
20261  /* Message Buffer Cycle Counter Filter Register */
20262  FR_MBCCFR_16B_tag MBCCFR16; /* offset: 0x0182 size: 16 bit */
20263  /* Message Buffer Frame ID Register */
20264  FR_MBFIDR_16B_tag MBFIDR16; /* offset: 0x0184 size: 16 bit */
20265  /* Message Buffer Index Register */
20266  FR_MBIDXR_16B_tag MBIDXR16; /* offset: 0x0186 size: 16 bit */
20267  /* Message Buffer Configuration Control Status Register */
20268  FR_MBCCSR_16B_tag MBCCSR17; /* offset: 0x0188 size: 16 bit */
20269  /* Message Buffer Cycle Counter Filter Register */
20270  FR_MBCCFR_16B_tag MBCCFR17; /* offset: 0x018A size: 16 bit */
20271  /* Message Buffer Frame ID Register */
20272  FR_MBFIDR_16B_tag MBFIDR17; /* offset: 0x018C size: 16 bit */
20273  /* Message Buffer Index Register */
20274  FR_MBIDXR_16B_tag MBIDXR17; /* offset: 0x018E size: 16 bit */
20275  /* Message Buffer Configuration Control Status Register */
20276  FR_MBCCSR_16B_tag MBCCSR18; /* offset: 0x0190 size: 16 bit */
20277  /* Message Buffer Cycle Counter Filter Register */
20278  FR_MBCCFR_16B_tag MBCCFR18; /* offset: 0x0192 size: 16 bit */
20279  /* Message Buffer Frame ID Register */
20280  FR_MBFIDR_16B_tag MBFIDR18; /* offset: 0x0194 size: 16 bit */
20281  /* Message Buffer Index Register */
20282  FR_MBIDXR_16B_tag MBIDXR18; /* offset: 0x0196 size: 16 bit */
20283  /* Message Buffer Configuration Control Status Register */
20284  FR_MBCCSR_16B_tag MBCCSR19; /* offset: 0x0198 size: 16 bit */
20285  /* Message Buffer Cycle Counter Filter Register */
20286  FR_MBCCFR_16B_tag MBCCFR19; /* offset: 0x019A size: 16 bit */
20287  /* Message Buffer Frame ID Register */
20288  FR_MBFIDR_16B_tag MBFIDR19; /* offset: 0x019C size: 16 bit */
20289  /* Message Buffer Index Register */
20290  FR_MBIDXR_16B_tag MBIDXR19; /* offset: 0x019E size: 16 bit */
20291  /* Message Buffer Configuration Control Status Register */
20292  FR_MBCCSR_16B_tag MBCCSR20; /* offset: 0x01A0 size: 16 bit */
20293  /* Message Buffer Cycle Counter Filter Register */
20294  FR_MBCCFR_16B_tag MBCCFR20; /* offset: 0x01A2 size: 16 bit */
20295  /* Message Buffer Frame ID Register */
20296  FR_MBFIDR_16B_tag MBFIDR20; /* offset: 0x01A4 size: 16 bit */
20297  /* Message Buffer Index Register */
20298  FR_MBIDXR_16B_tag MBIDXR20; /* offset: 0x01A6 size: 16 bit */
20299  /* Message Buffer Configuration Control Status Register */
20300  FR_MBCCSR_16B_tag MBCCSR21; /* offset: 0x01A8 size: 16 bit */
20301  /* Message Buffer Cycle Counter Filter Register */
20302  FR_MBCCFR_16B_tag MBCCFR21; /* offset: 0x01AA size: 16 bit */
20303  /* Message Buffer Frame ID Register */
20304  FR_MBFIDR_16B_tag MBFIDR21; /* offset: 0x01AC size: 16 bit */
20305  /* Message Buffer Index Register */
20306  FR_MBIDXR_16B_tag MBIDXR21; /* offset: 0x01AE size: 16 bit */
20307  /* Message Buffer Configuration Control Status Register */
20308  FR_MBCCSR_16B_tag MBCCSR22; /* offset: 0x01B0 size: 16 bit */
20309  /* Message Buffer Cycle Counter Filter Register */
20310  FR_MBCCFR_16B_tag MBCCFR22; /* offset: 0x01B2 size: 16 bit */
20311  /* Message Buffer Frame ID Register */
20312  FR_MBFIDR_16B_tag MBFIDR22; /* offset: 0x01B4 size: 16 bit */
20313  /* Message Buffer Index Register */
20314  FR_MBIDXR_16B_tag MBIDXR22; /* offset: 0x01B6 size: 16 bit */
20315  /* Message Buffer Configuration Control Status Register */
20316  FR_MBCCSR_16B_tag MBCCSR23; /* offset: 0x01B8 size: 16 bit */
20317  /* Message Buffer Cycle Counter Filter Register */
20318  FR_MBCCFR_16B_tag MBCCFR23; /* offset: 0x01BA size: 16 bit */
20319  /* Message Buffer Frame ID Register */
20320  FR_MBFIDR_16B_tag MBFIDR23; /* offset: 0x01BC size: 16 bit */
20321  /* Message Buffer Index Register */
20322  FR_MBIDXR_16B_tag MBIDXR23; /* offset: 0x01BE size: 16 bit */
20323  /* Message Buffer Configuration Control Status Register */
20324  FR_MBCCSR_16B_tag MBCCSR24; /* offset: 0x01C0 size: 16 bit */
20325  /* Message Buffer Cycle Counter Filter Register */
20326  FR_MBCCFR_16B_tag MBCCFR24; /* offset: 0x01C2 size: 16 bit */
20327  /* Message Buffer Frame ID Register */
20328  FR_MBFIDR_16B_tag MBFIDR24; /* offset: 0x01C4 size: 16 bit */
20329  /* Message Buffer Index Register */
20330  FR_MBIDXR_16B_tag MBIDXR24; /* offset: 0x01C6 size: 16 bit */
20331  /* Message Buffer Configuration Control Status Register */
20332  FR_MBCCSR_16B_tag MBCCSR25; /* offset: 0x01C8 size: 16 bit */
20333  /* Message Buffer Cycle Counter Filter Register */
20334  FR_MBCCFR_16B_tag MBCCFR25; /* offset: 0x01CA size: 16 bit */
20335  /* Message Buffer Frame ID Register */
20336  FR_MBFIDR_16B_tag MBFIDR25; /* offset: 0x01CC size: 16 bit */
20337  /* Message Buffer Index Register */
20338  FR_MBIDXR_16B_tag MBIDXR25; /* offset: 0x01CE size: 16 bit */
20339  /* Message Buffer Configuration Control Status Register */
20340  FR_MBCCSR_16B_tag MBCCSR26; /* offset: 0x01D0 size: 16 bit */
20341  /* Message Buffer Cycle Counter Filter Register */
20342  FR_MBCCFR_16B_tag MBCCFR26; /* offset: 0x01D2 size: 16 bit */
20343  /* Message Buffer Frame ID Register */
20344  FR_MBFIDR_16B_tag MBFIDR26; /* offset: 0x01D4 size: 16 bit */
20345  /* Message Buffer Index Register */
20346  FR_MBIDXR_16B_tag MBIDXR26; /* offset: 0x01D6 size: 16 bit */
20347  /* Message Buffer Configuration Control Status Register */
20348  FR_MBCCSR_16B_tag MBCCSR27; /* offset: 0x01D8 size: 16 bit */
20349  /* Message Buffer Cycle Counter Filter Register */
20350  FR_MBCCFR_16B_tag MBCCFR27; /* offset: 0x01DA size: 16 bit */
20351  /* Message Buffer Frame ID Register */
20352  FR_MBFIDR_16B_tag MBFIDR27; /* offset: 0x01DC size: 16 bit */
20353  /* Message Buffer Index Register */
20354  FR_MBIDXR_16B_tag MBIDXR27; /* offset: 0x01DE size: 16 bit */
20355  /* Message Buffer Configuration Control Status Register */
20356  FR_MBCCSR_16B_tag MBCCSR28; /* offset: 0x01E0 size: 16 bit */
20357  /* Message Buffer Cycle Counter Filter Register */
20358  FR_MBCCFR_16B_tag MBCCFR28; /* offset: 0x01E2 size: 16 bit */
20359  /* Message Buffer Frame ID Register */
20360  FR_MBFIDR_16B_tag MBFIDR28; /* offset: 0x01E4 size: 16 bit */
20361  /* Message Buffer Index Register */
20362  FR_MBIDXR_16B_tag MBIDXR28; /* offset: 0x01E6 size: 16 bit */
20363  /* Message Buffer Configuration Control Status Register */
20364  FR_MBCCSR_16B_tag MBCCSR29; /* offset: 0x01E8 size: 16 bit */
20365  /* Message Buffer Cycle Counter Filter Register */
20366  FR_MBCCFR_16B_tag MBCCFR29; /* offset: 0x01EA size: 16 bit */
20367  /* Message Buffer Frame ID Register */
20368  FR_MBFIDR_16B_tag MBFIDR29; /* offset: 0x01EC size: 16 bit */
20369  /* Message Buffer Index Register */
20370  FR_MBIDXR_16B_tag MBIDXR29; /* offset: 0x01EE size: 16 bit */
20371  /* Message Buffer Configuration Control Status Register */
20372  FR_MBCCSR_16B_tag MBCCSR30; /* offset: 0x01F0 size: 16 bit */
20373  /* Message Buffer Cycle Counter Filter Register */
20374  FR_MBCCFR_16B_tag MBCCFR30; /* offset: 0x01F2 size: 16 bit */
20375  /* Message Buffer Frame ID Register */
20376  FR_MBFIDR_16B_tag MBFIDR30; /* offset: 0x01F4 size: 16 bit */
20377  /* Message Buffer Index Register */
20378  FR_MBIDXR_16B_tag MBIDXR30; /* offset: 0x01F6 size: 16 bit */
20379  /* Message Buffer Configuration Control Status Register */
20380  FR_MBCCSR_16B_tag MBCCSR31; /* offset: 0x01F8 size: 16 bit */
20381  /* Message Buffer Cycle Counter Filter Register */
20382  FR_MBCCFR_16B_tag MBCCFR31; /* offset: 0x01FA size: 16 bit */
20383  /* Message Buffer Frame ID Register */
20384  FR_MBFIDR_16B_tag MBFIDR31; /* offset: 0x01FC size: 16 bit */
20385  /* Message Buffer Index Register */
20386  FR_MBIDXR_16B_tag MBIDXR31; /* offset: 0x01FE size: 16 bit */
20387  /* Message Buffer Configuration Control Status Register */
20388  FR_MBCCSR_16B_tag MBCCSR32; /* offset: 0x0200 size: 16 bit */
20389  /* Message Buffer Cycle Counter Filter Register */
20390  FR_MBCCFR_16B_tag MBCCFR32; /* offset: 0x0202 size: 16 bit */
20391  /* Message Buffer Frame ID Register */
20392  FR_MBFIDR_16B_tag MBFIDR32; /* offset: 0x0204 size: 16 bit */
20393  /* Message Buffer Index Register */
20394  FR_MBIDXR_16B_tag MBIDXR32; /* offset: 0x0206 size: 16 bit */
20395  /* Message Buffer Configuration Control Status Register */
20396  FR_MBCCSR_16B_tag MBCCSR33; /* offset: 0x0208 size: 16 bit */
20397  /* Message Buffer Cycle Counter Filter Register */
20398  FR_MBCCFR_16B_tag MBCCFR33; /* offset: 0x020A size: 16 bit */
20399  /* Message Buffer Frame ID Register */
20400  FR_MBFIDR_16B_tag MBFIDR33; /* offset: 0x020C size: 16 bit */
20401  /* Message Buffer Index Register */
20402  FR_MBIDXR_16B_tag MBIDXR33; /* offset: 0x020E size: 16 bit */
20403  /* Message Buffer Configuration Control Status Register */
20404  FR_MBCCSR_16B_tag MBCCSR34; /* offset: 0x0210 size: 16 bit */
20405  /* Message Buffer Cycle Counter Filter Register */
20406  FR_MBCCFR_16B_tag MBCCFR34; /* offset: 0x0212 size: 16 bit */
20407  /* Message Buffer Frame ID Register */
20408  FR_MBFIDR_16B_tag MBFIDR34; /* offset: 0x0214 size: 16 bit */
20409  /* Message Buffer Index Register */
20410  FR_MBIDXR_16B_tag MBIDXR34; /* offset: 0x0216 size: 16 bit */
20411  /* Message Buffer Configuration Control Status Register */
20412  FR_MBCCSR_16B_tag MBCCSR35; /* offset: 0x0218 size: 16 bit */
20413  /* Message Buffer Cycle Counter Filter Register */
20414  FR_MBCCFR_16B_tag MBCCFR35; /* offset: 0x021A size: 16 bit */
20415  /* Message Buffer Frame ID Register */
20416  FR_MBFIDR_16B_tag MBFIDR35; /* offset: 0x021C size: 16 bit */
20417  /* Message Buffer Index Register */
20418  FR_MBIDXR_16B_tag MBIDXR35; /* offset: 0x021E size: 16 bit */
20419  /* Message Buffer Configuration Control Status Register */
20420  FR_MBCCSR_16B_tag MBCCSR36; /* offset: 0x0220 size: 16 bit */
20421  /* Message Buffer Cycle Counter Filter Register */
20422  FR_MBCCFR_16B_tag MBCCFR36; /* offset: 0x0222 size: 16 bit */
20423  /* Message Buffer Frame ID Register */
20424  FR_MBFIDR_16B_tag MBFIDR36; /* offset: 0x0224 size: 16 bit */
20425  /* Message Buffer Index Register */
20426  FR_MBIDXR_16B_tag MBIDXR36; /* offset: 0x0226 size: 16 bit */
20427  /* Message Buffer Configuration Control Status Register */
20428  FR_MBCCSR_16B_tag MBCCSR37; /* offset: 0x0228 size: 16 bit */
20429  /* Message Buffer Cycle Counter Filter Register */
20430  FR_MBCCFR_16B_tag MBCCFR37; /* offset: 0x022A size: 16 bit */
20431  /* Message Buffer Frame ID Register */
20432  FR_MBFIDR_16B_tag MBFIDR37; /* offset: 0x022C size: 16 bit */
20433  /* Message Buffer Index Register */
20434  FR_MBIDXR_16B_tag MBIDXR37; /* offset: 0x022E size: 16 bit */
20435  /* Message Buffer Configuration Control Status Register */
20436  FR_MBCCSR_16B_tag MBCCSR38; /* offset: 0x0230 size: 16 bit */
20437  /* Message Buffer Cycle Counter Filter Register */
20438  FR_MBCCFR_16B_tag MBCCFR38; /* offset: 0x0232 size: 16 bit */
20439  /* Message Buffer Frame ID Register */
20440  FR_MBFIDR_16B_tag MBFIDR38; /* offset: 0x0234 size: 16 bit */
20441  /* Message Buffer Index Register */
20442  FR_MBIDXR_16B_tag MBIDXR38; /* offset: 0x0236 size: 16 bit */
20443  /* Message Buffer Configuration Control Status Register */
20444  FR_MBCCSR_16B_tag MBCCSR39; /* offset: 0x0238 size: 16 bit */
20445  /* Message Buffer Cycle Counter Filter Register */
20446  FR_MBCCFR_16B_tag MBCCFR39; /* offset: 0x023A size: 16 bit */
20447  /* Message Buffer Frame ID Register */
20448  FR_MBFIDR_16B_tag MBFIDR39; /* offset: 0x023C size: 16 bit */
20449  /* Message Buffer Index Register */
20450  FR_MBIDXR_16B_tag MBIDXR39; /* offset: 0x023E size: 16 bit */
20451  /* Message Buffer Configuration Control Status Register */
20452  FR_MBCCSR_16B_tag MBCCSR40; /* offset: 0x0240 size: 16 bit */
20453  /* Message Buffer Cycle Counter Filter Register */
20454  FR_MBCCFR_16B_tag MBCCFR40; /* offset: 0x0242 size: 16 bit */
20455  /* Message Buffer Frame ID Register */
20456  FR_MBFIDR_16B_tag MBFIDR40; /* offset: 0x0244 size: 16 bit */
20457  /* Message Buffer Index Register */
20458  FR_MBIDXR_16B_tag MBIDXR40; /* offset: 0x0246 size: 16 bit */
20459  /* Message Buffer Configuration Control Status Register */
20460  FR_MBCCSR_16B_tag MBCCSR41; /* offset: 0x0248 size: 16 bit */
20461  /* Message Buffer Cycle Counter Filter Register */
20462  FR_MBCCFR_16B_tag MBCCFR41; /* offset: 0x024A size: 16 bit */
20463  /* Message Buffer Frame ID Register */
20464  FR_MBFIDR_16B_tag MBFIDR41; /* offset: 0x024C size: 16 bit */
20465  /* Message Buffer Index Register */
20466  FR_MBIDXR_16B_tag MBIDXR41; /* offset: 0x024E size: 16 bit */
20467  /* Message Buffer Configuration Control Status Register */
20468  FR_MBCCSR_16B_tag MBCCSR42; /* offset: 0x0250 size: 16 bit */
20469  /* Message Buffer Cycle Counter Filter Register */
20470  FR_MBCCFR_16B_tag MBCCFR42; /* offset: 0x0252 size: 16 bit */
20471  /* Message Buffer Frame ID Register */
20472  FR_MBFIDR_16B_tag MBFIDR42; /* offset: 0x0254 size: 16 bit */
20473  /* Message Buffer Index Register */
20474  FR_MBIDXR_16B_tag MBIDXR42; /* offset: 0x0256 size: 16 bit */
20475  /* Message Buffer Configuration Control Status Register */
20476  FR_MBCCSR_16B_tag MBCCSR43; /* offset: 0x0258 size: 16 bit */
20477  /* Message Buffer Cycle Counter Filter Register */
20478  FR_MBCCFR_16B_tag MBCCFR43; /* offset: 0x025A size: 16 bit */
20479  /* Message Buffer Frame ID Register */
20480  FR_MBFIDR_16B_tag MBFIDR43; /* offset: 0x025C size: 16 bit */
20481  /* Message Buffer Index Register */
20482  FR_MBIDXR_16B_tag MBIDXR43; /* offset: 0x025E size: 16 bit */
20483  /* Message Buffer Configuration Control Status Register */
20484  FR_MBCCSR_16B_tag MBCCSR44; /* offset: 0x0260 size: 16 bit */
20485  /* Message Buffer Cycle Counter Filter Register */
20486  FR_MBCCFR_16B_tag MBCCFR44; /* offset: 0x0262 size: 16 bit */
20487  /* Message Buffer Frame ID Register */
20488  FR_MBFIDR_16B_tag MBFIDR44; /* offset: 0x0264 size: 16 bit */
20489  /* Message Buffer Index Register */
20490  FR_MBIDXR_16B_tag MBIDXR44; /* offset: 0x0266 size: 16 bit */
20491  /* Message Buffer Configuration Control Status Register */
20492  FR_MBCCSR_16B_tag MBCCSR45; /* offset: 0x0268 size: 16 bit */
20493  /* Message Buffer Cycle Counter Filter Register */
20494  FR_MBCCFR_16B_tag MBCCFR45; /* offset: 0x026A size: 16 bit */
20495  /* Message Buffer Frame ID Register */
20496  FR_MBFIDR_16B_tag MBFIDR45; /* offset: 0x026C size: 16 bit */
20497  /* Message Buffer Index Register */
20498  FR_MBIDXR_16B_tag MBIDXR45; /* offset: 0x026E size: 16 bit */
20499  /* Message Buffer Configuration Control Status Register */
20500  FR_MBCCSR_16B_tag MBCCSR46; /* offset: 0x0270 size: 16 bit */
20501  /* Message Buffer Cycle Counter Filter Register */
20502  FR_MBCCFR_16B_tag MBCCFR46; /* offset: 0x0272 size: 16 bit */
20503  /* Message Buffer Frame ID Register */
20504  FR_MBFIDR_16B_tag MBFIDR46; /* offset: 0x0274 size: 16 bit */
20505  /* Message Buffer Index Register */
20506  FR_MBIDXR_16B_tag MBIDXR46; /* offset: 0x0276 size: 16 bit */
20507  /* Message Buffer Configuration Control Status Register */
20508  FR_MBCCSR_16B_tag MBCCSR47; /* offset: 0x0278 size: 16 bit */
20509  /* Message Buffer Cycle Counter Filter Register */
20510  FR_MBCCFR_16B_tag MBCCFR47; /* offset: 0x027A size: 16 bit */
20511  /* Message Buffer Frame ID Register */
20512  FR_MBFIDR_16B_tag MBFIDR47; /* offset: 0x027C size: 16 bit */
20513  /* Message Buffer Index Register */
20514  FR_MBIDXR_16B_tag MBIDXR47; /* offset: 0x027E size: 16 bit */
20515  /* Message Buffer Configuration Control Status Register */
20516  FR_MBCCSR_16B_tag MBCCSR48; /* offset: 0x0280 size: 16 bit */
20517  /* Message Buffer Cycle Counter Filter Register */
20518  FR_MBCCFR_16B_tag MBCCFR48; /* offset: 0x0282 size: 16 bit */
20519  /* Message Buffer Frame ID Register */
20520  FR_MBFIDR_16B_tag MBFIDR48; /* offset: 0x0284 size: 16 bit */
20521  /* Message Buffer Index Register */
20522  FR_MBIDXR_16B_tag MBIDXR48; /* offset: 0x0286 size: 16 bit */
20523  /* Message Buffer Configuration Control Status Register */
20524  FR_MBCCSR_16B_tag MBCCSR49; /* offset: 0x0288 size: 16 bit */
20525  /* Message Buffer Cycle Counter Filter Register */
20526  FR_MBCCFR_16B_tag MBCCFR49; /* offset: 0x028A size: 16 bit */
20527  /* Message Buffer Frame ID Register */
20528  FR_MBFIDR_16B_tag MBFIDR49; /* offset: 0x028C size: 16 bit */
20529  /* Message Buffer Index Register */
20530  FR_MBIDXR_16B_tag MBIDXR49; /* offset: 0x028E size: 16 bit */
20531  /* Message Buffer Configuration Control Status Register */
20532  FR_MBCCSR_16B_tag MBCCSR50; /* offset: 0x0290 size: 16 bit */
20533  /* Message Buffer Cycle Counter Filter Register */
20534  FR_MBCCFR_16B_tag MBCCFR50; /* offset: 0x0292 size: 16 bit */
20535  /* Message Buffer Frame ID Register */
20536  FR_MBFIDR_16B_tag MBFIDR50; /* offset: 0x0294 size: 16 bit */
20537  /* Message Buffer Index Register */
20538  FR_MBIDXR_16B_tag MBIDXR50; /* offset: 0x0296 size: 16 bit */
20539  /* Message Buffer Configuration Control Status Register */
20540  FR_MBCCSR_16B_tag MBCCSR51; /* offset: 0x0298 size: 16 bit */
20541  /* Message Buffer Cycle Counter Filter Register */
20542  FR_MBCCFR_16B_tag MBCCFR51; /* offset: 0x029A size: 16 bit */
20543  /* Message Buffer Frame ID Register */
20544  FR_MBFIDR_16B_tag MBFIDR51; /* offset: 0x029C size: 16 bit */
20545  /* Message Buffer Index Register */
20546  FR_MBIDXR_16B_tag MBIDXR51; /* offset: 0x029E size: 16 bit */
20547  /* Message Buffer Configuration Control Status Register */
20548  FR_MBCCSR_16B_tag MBCCSR52; /* offset: 0x02A0 size: 16 bit */
20549  /* Message Buffer Cycle Counter Filter Register */
20550  FR_MBCCFR_16B_tag MBCCFR52; /* offset: 0x02A2 size: 16 bit */
20551  /* Message Buffer Frame ID Register */
20552  FR_MBFIDR_16B_tag MBFIDR52; /* offset: 0x02A4 size: 16 bit */
20553  /* Message Buffer Index Register */
20554  FR_MBIDXR_16B_tag MBIDXR52; /* offset: 0x02A6 size: 16 bit */
20555  /* Message Buffer Configuration Control Status Register */
20556  FR_MBCCSR_16B_tag MBCCSR53; /* offset: 0x02A8 size: 16 bit */
20557  /* Message Buffer Cycle Counter Filter Register */
20558  FR_MBCCFR_16B_tag MBCCFR53; /* offset: 0x02AA size: 16 bit */
20559  /* Message Buffer Frame ID Register */
20560  FR_MBFIDR_16B_tag MBFIDR53; /* offset: 0x02AC size: 16 bit */
20561  /* Message Buffer Index Register */
20562  FR_MBIDXR_16B_tag MBIDXR53; /* offset: 0x02AE size: 16 bit */
20563  /* Message Buffer Configuration Control Status Register */
20564  FR_MBCCSR_16B_tag MBCCSR54; /* offset: 0x02B0 size: 16 bit */
20565  /* Message Buffer Cycle Counter Filter Register */
20566  FR_MBCCFR_16B_tag MBCCFR54; /* offset: 0x02B2 size: 16 bit */
20567  /* Message Buffer Frame ID Register */
20568  FR_MBFIDR_16B_tag MBFIDR54; /* offset: 0x02B4 size: 16 bit */
20569  /* Message Buffer Index Register */
20570  FR_MBIDXR_16B_tag MBIDXR54; /* offset: 0x02B6 size: 16 bit */
20571  /* Message Buffer Configuration Control Status Register */
20572  FR_MBCCSR_16B_tag MBCCSR55; /* offset: 0x02B8 size: 16 bit */
20573  /* Message Buffer Cycle Counter Filter Register */
20574  FR_MBCCFR_16B_tag MBCCFR55; /* offset: 0x02BA size: 16 bit */
20575  /* Message Buffer Frame ID Register */
20576  FR_MBFIDR_16B_tag MBFIDR55; /* offset: 0x02BC size: 16 bit */
20577  /* Message Buffer Index Register */
20578  FR_MBIDXR_16B_tag MBIDXR55; /* offset: 0x02BE size: 16 bit */
20579  /* Message Buffer Configuration Control Status Register */
20580  FR_MBCCSR_16B_tag MBCCSR56; /* offset: 0x02C0 size: 16 bit */
20581  /* Message Buffer Cycle Counter Filter Register */
20582  FR_MBCCFR_16B_tag MBCCFR56; /* offset: 0x02C2 size: 16 bit */
20583  /* Message Buffer Frame ID Register */
20584  FR_MBFIDR_16B_tag MBFIDR56; /* offset: 0x02C4 size: 16 bit */
20585  /* Message Buffer Index Register */
20586  FR_MBIDXR_16B_tag MBIDXR56; /* offset: 0x02C6 size: 16 bit */
20587  /* Message Buffer Configuration Control Status Register */
20588  FR_MBCCSR_16B_tag MBCCSR57; /* offset: 0x02C8 size: 16 bit */
20589  /* Message Buffer Cycle Counter Filter Register */
20590  FR_MBCCFR_16B_tag MBCCFR57; /* offset: 0x02CA size: 16 bit */
20591  /* Message Buffer Frame ID Register */
20592  FR_MBFIDR_16B_tag MBFIDR57; /* offset: 0x02CC size: 16 bit */
20593  /* Message Buffer Index Register */
20594  FR_MBIDXR_16B_tag MBIDXR57; /* offset: 0x02CE size: 16 bit */
20595  /* Message Buffer Configuration Control Status Register */
20596  FR_MBCCSR_16B_tag MBCCSR58; /* offset: 0x02D0 size: 16 bit */
20597  /* Message Buffer Cycle Counter Filter Register */
20598  FR_MBCCFR_16B_tag MBCCFR58; /* offset: 0x02D2 size: 16 bit */
20599  /* Message Buffer Frame ID Register */
20600  FR_MBFIDR_16B_tag MBFIDR58; /* offset: 0x02D4 size: 16 bit */
20601  /* Message Buffer Index Register */
20602  FR_MBIDXR_16B_tag MBIDXR58; /* offset: 0x02D6 size: 16 bit */
20603  /* Message Buffer Configuration Control Status Register */
20604  FR_MBCCSR_16B_tag MBCCSR59; /* offset: 0x02D8 size: 16 bit */
20605  /* Message Buffer Cycle Counter Filter Register */
20606  FR_MBCCFR_16B_tag MBCCFR59; /* offset: 0x02DA size: 16 bit */
20607  /* Message Buffer Frame ID Register */
20608  FR_MBFIDR_16B_tag MBFIDR59; /* offset: 0x02DC size: 16 bit */
20609  /* Message Buffer Index Register */
20610  FR_MBIDXR_16B_tag MBIDXR59; /* offset: 0x02DE size: 16 bit */
20611  /* Message Buffer Configuration Control Status Register */
20612  FR_MBCCSR_16B_tag MBCCSR60; /* offset: 0x02E0 size: 16 bit */
20613  /* Message Buffer Cycle Counter Filter Register */
20614  FR_MBCCFR_16B_tag MBCCFR60; /* offset: 0x02E2 size: 16 bit */
20615  /* Message Buffer Frame ID Register */
20616  FR_MBFIDR_16B_tag MBFIDR60; /* offset: 0x02E4 size: 16 bit */
20617  /* Message Buffer Index Register */
20618  FR_MBIDXR_16B_tag MBIDXR60; /* offset: 0x02E6 size: 16 bit */
20619  /* Message Buffer Configuration Control Status Register */
20620  FR_MBCCSR_16B_tag MBCCSR61; /* offset: 0x02E8 size: 16 bit */
20621  /* Message Buffer Cycle Counter Filter Register */
20622  FR_MBCCFR_16B_tag MBCCFR61; /* offset: 0x02EA size: 16 bit */
20623  /* Message Buffer Frame ID Register */
20624  FR_MBFIDR_16B_tag MBFIDR61; /* offset: 0x02EC size: 16 bit */
20625  /* Message Buffer Index Register */
20626  FR_MBIDXR_16B_tag MBIDXR61; /* offset: 0x02EE size: 16 bit */
20627  /* Message Buffer Configuration Control Status Register */
20628  FR_MBCCSR_16B_tag MBCCSR62; /* offset: 0x02F0 size: 16 bit */
20629  /* Message Buffer Cycle Counter Filter Register */
20630  FR_MBCCFR_16B_tag MBCCFR62; /* offset: 0x02F2 size: 16 bit */
20631  /* Message Buffer Frame ID Register */
20632  FR_MBFIDR_16B_tag MBFIDR62; /* offset: 0x02F4 size: 16 bit */
20633  /* Message Buffer Index Register */
20634  FR_MBIDXR_16B_tag MBIDXR62; /* offset: 0x02F6 size: 16 bit */
20635  /* Message Buffer Configuration Control Status Register */
20636  FR_MBCCSR_16B_tag MBCCSR63; /* offset: 0x02F8 size: 16 bit */
20637  /* Message Buffer Cycle Counter Filter Register */
20638  FR_MBCCFR_16B_tag MBCCFR63; /* offset: 0x02FA size: 16 bit */
20639  /* Message Buffer Frame ID Register */
20640  FR_MBFIDR_16B_tag MBFIDR63; /* offset: 0x02FC size: 16 bit */
20641  /* Message Buffer Index Register */
20642  FR_MBIDXR_16B_tag MBIDXR63; /* offset: 0x02FE size: 16 bit */
20643  };
20644
20645  };
20646  } FR_tag;
20647
20648
20649 #define FR (*(volatile FR_tag *) 0xFFFE0000UL)
20650
20651
20652
20653
20654
20655 #ifdef __MWERKS__
20656 #pragma pop
20657 #endif
20658
20659 #ifdef __cplusplus
20660 }
20661 #endif
20662 #endif /* ASM */
20663 #endif /* _leopard_H_*/
20664
20665 /* End of file */
20666
Definition: fsl-mpc564xL.h:9131
Definition: fsl-mpc564xL.h:1024
Definition: fsl-mpc564xL.h:12335
Definition: fsl-mpc564xL.h:10982
Definition: fsl-mpc564xL.h:8450
Definition: fsl-mpc564xL.h:19193
Definition: fsl-mpc564xL.h:14344
Definition: fsl-mpc564xL.h:14286
Definition: fsl-mpc564xL.h:10872
Definition: fsl-mpc564xL.h:11288
Definition: fsl-mpc564xL.h:8201
Definition: fsl-mpc564xL.h:16797
Definition: fsl-mpc564xL.h:3516
Definition: fsl-mpc564xL.h:19607
Definition: fsl-mpc564xL.h:7129
Definition: fsl-mpc564xL.h:17034
Definition: fsl-mpc564xL.h:3727
Definition: fsl-mpc564xL.h:18695
Definition: fsl-mpc564xL.h:4243
Definition: fsl-mpc564xL.h:3564
Definition: fsl-mpc564xL.h:3741
Definition: fsl-mpc564xL.h:5597
Definition: fsl-mpc564xL.h:12753
Definition: fsl-mpc564xL.h:11948
Definition: fsl-mpc564xL.h:19406
Definition: fsl-mpc564xL.h:19315
Definition: fsl-mpc564xL.h:11638
Definition: fsl-mpc564xL.h:7608
Definition: fsl-mpc564xL.h:13507
Definition: fsl-mpc564xL.h:6319
Definition: fsl-mpc564xL.h:14217
Definition: fsl-mpc564xL.h:18671
Definition: fsl-mpc564xL.h:4823
Definition: fsl-mpc564xL.h:12988
Definition: fsl-mpc564xL.h:438
Definition: fsl-mpc564xL.h:14377
Definition: fsl-mpc564xL.h:3672
Definition: fsl-mpc564xL.h:6266
Definition: fsl-mpc564xL.h:13846
Definition: fsl-mpc564xL.h:13963
Definition: fsl-mpc564xL.h:7732
Definition: fsl-mpc564xL.h:4632
Definition: fsl-mpc564xL.h:18452
Definition: fsl-mpc564xL.h:10128
Definition: fsl-mpc564xL.h:11827
Definition: fsl-mpc564xL.h:10806
#define PMC
(PMC ) Base Address
Definition: same70j19.h:530
Definition: fsl-mpc564xL.h:13642
Definition: fsl-mpc564xL.h:10556
Definition: fsl-mpc564xL.h:14447
Definition: fsl-mpc564xL.h:6281
Definition: fsl-mpc564xL.h:3748
Definition: fsl-mpc564xL.h:19210
Definition: fsl-mpc564xL.h:5340
Definition: fsl-mpc564xL.h:11792
Definition: fsl-mpc564xL.h:12938
Definition: fsl-mpc564xL.h:12183
Definition: fsl-mpc564xL.h:7903
Definition: fsl-mpc564xL.h:19344
Definition: fsl-mpc564xL.h:12373
Definition: fsl-mpc564xL.h:18169
Definition: fsl-mpc564xL.h:8028
Definition: fsl-mpc564xL.h:18241
Definition: fsl-mpc564xL.h:7096
Definition: fsl-mpc564xL.h:12221
Definition: fsl-mpc564xL.h:9328
Definition: fsl-mpc564xL.h:531
Definition: fsl-mpc564xL.h:4261
Definition: fsl-mpc564xL.h:14231
Definition: fsl-mpc564xL.h:9318
Definition: fsl-mpc564xL.h:19240
Definition: fsl-mpc564xL.h:6943
Definition: fsl-mpc564xL.h:10670
Definition: fsl-mpc564xL.h:11756
Definition: fsl-mpc564xL.h:605
Definition: fsl-mpc564xL.h:6715
Definition: fsl-mpc564xL.h:15686
Definition: fsl-mpc564xL.h:13720
Definition: fsl-mpc564xL.h:13839
Definition: fsl-mpc564xL.h:10464
Definition: fsl-mpc564xL.h:6817
Definition: fsl-mpc564xL.h:19074
Definition: fsl-mpc564xL.h:18792
Definition: fsl-mpc564xL.h:11861
Definition: fsl-mpc564xL.h:9547
Definition: fsl-mpc564xL.h:8716
#define PE
Parity Error.
Definition: uart.h:125
Definition: fsl-mpc564xL.h:3703
Definition: fsl-mpc564xL.h:13627
Definition: fsl-mpc564xL.h:19445
Definition: fsl-mpc564xL.h:15811
Definition: fsl-mpc564xL.h:8490
Definition: fsl-mpc564xL.h:10460
Definition: fsl-mpc564xL.h:7105
Definition: fsl-mpc564xL.h:14254
Definition: fsl-mpc564xL.h:3557
Definition: fsl-mpc564xL.h:14330
Definition: fsl-mpc564xL.h:19176
Definition: fsl-mpc564xL.h:6696
Definition: fsl-mpc564xL.h:19248
Definition: fsl-mpc564xL.h:17401
Definition: fsl-mpc564xL.h:3757
Definition: fsl-mpc564xL.h:18888
Definition: fsl-mpc564xL.h:3888
Definition: fsl-mpc564xL.h:5415
#define RESET
Issue a read for reset.
Definition: wd80x3.h:31
Definition: fsl-mpc564xL.h:10077
Definition: fsl-mpc564xL.h:4157
Definition: fsl-mpc564xL.h:11900
Definition: fsl-mpc564xL.h:389
Definition: fsl-mpc564xL.h:12639
Definition: fsl-mpc564xL.h:428
Definition: fsl-mpc564xL.h:8480
Definition: fsl-mpc564xL.h:6140
Definition: fsl-mpc564xL.h:9226
Definition: fsl-mpc564xL.h:11914
Definition: fsl-mpc564xL.h:4779
Definition: fsl-mpc564xL.h:1052
Definition: fsl-mpc564xL.h:996
Definition: fsl-mpc564xL.h:4723
Definition: fsl-mpc564xL.h:19476
Definition: fsl-mpc564xL.h:7622
Definition: fsl-mpc564xL.h:18880
Definition: fsl-mpc564xL.h:10251
Definition: fsl-mpc564xL.h:15731
Definition: fsl-mpc564xL.h:19484
Definition: fsl-mpc564xL.h:5486
Definition: fsl-mpc564xL.h:3984
Definition: fsl-mpc564xL.h:13959
Definition: fsl-mpc564xL.h:9381
Definition: fsl-mpc564xL.h:14391
Definition: fsl-mpc564xL.h:8740
Definition: fsl-mpc564xL.h:9349
Definition: fsl-mpc564xL.h:13485
Definition: fsl-mpc564xL.h:7715
Definition: fsl-mpc564xL.h:11907
Definition: fsl-mpc564xL.h:6304
Definition: fsl-mpc564xL.h:13916
Definition: fsl-mpc564xL.h:5556
Definition: fsl-mpc564xL.h:11026
Definition: fsl-mpc564xL.h:925
Definition: fsl-mpc564xL.h:13742
Definition: fsl-mpc564xL.h:11835
Definition: fsl-mpc564xL.h:6837
Definition: fsl-mpc564xL.h:16891
Definition: fsl-mpc564xL.h:18981
Definition: fsl-mpc564xL.h:560
Definition: fsl-mpc564xL.h:14437
Definition: fsl-mpc564xL.h:18711
Definition: fsl-mpc564xL.h:16956
Definition: fsl-mpc564xL.h:16765
Definition: fsl-mpc564xL.h:8640
Definition: fsl-mpc564xL.h:16627
Definition: fsl-mpc564xL.h:14270
Definition: fsl-mpc564xL.h:7969
Definition: fsl-mpc564xL.h:3653
Definition: fsl-mpc564xL.h:9360
Definition: fsl-mpc564xL.h:4875
Definition: fsl-mpc564xL.h:13521
Definition: fsl-mpc564xL.h:10850
Definition: fsl-mpc564xL.h:5611
Definition: fsl-mpc564xL.h:5996
Definition: fsl-mpc564xL.h:3498
Definition: fsl-mpc564xL.h:9110
Definition: fsl-mpc564xL.h:14041
Definition: fsl-mpc564xL.h:8647
Definition: fsl-mpc564xL.h:11330
Definition: fsl-mpc564xL.h:10938
Definition: fsl-mpc564xL.h:13859
Definition: fsl-mpc564xL.h:9409
Definition: fsl-mpc564xL.h:811
Definition: fsl-mpc564xL.h:11212
Definition: fsl-mpc564xL.h:16709
Definition: fsl-mpc564xL.h:10165
Definition: fsl-mpc564xL.h:11818
Definition: fsl-mpc564xL.h:6867
Definition: fsl-mpc564xL.h:12912
Definition: fsl-mpc564xL.h:10381
Definition: fsl-mpc564xL.h:6294
Definition: fsl-mpc564xL.h:19517
Definition: fsl-mpc564xL.h:19362
Definition: fsl-mpc564xL.h:15740
Definition: fsl-mpc564xL.h:17247
Definition: fsl-mpc564xL.h:753
Definition: fsl-mpc564xL.h:18270
Definition: fsl-mpc564xL.h:19704
Definition: fsl-mpc564xL.h:12715
Definition: fsl-mpc564xL.h:19500
Definition: fsl-mpc564xL.h:12449
Definition: fsl-mpc564xL.h:18957
Definition: fsl-mpc564xL.h:9286
Definition: fsl-mpc564xL.h:1113
Definition: fsl-mpc564xL.h:4089
Definition: fsl-mpc564xL.h:13747
Definition: fsl-mpc564xL.h:3847
Definition: fsl-mpc564xL.h:9391
Definition: fsl-mpc564xL.h:6034
Definition: fsl-mpc564xL.h:18776
Definition: fsl-mpc564xL.h:8654
Definition: fsl-mpc564xL.h:13215
Definition: fsl-mpc564xL.h:6797
Definition: fsl-mpc564xL.h:16586
Definition: fsl-mpc564xL.h:9073
Definition: fsl-mpc564xL.h:3838
Definition: fsl-mpc564xL.h:5167
Definition: fsl-mpc564xL.h:3923
Definition: fsl-mpc564xL.h:8606
Definition: fsl-mpc564xL.h:3717
Definition: fsl-mpc564xL.h:8781
Definition: fsl-mpc564xL.h:19623
Definition: fsl-mpc564xL.h:966
Definition: fsl-mpc564xL.h:4926
Definition: fsl-mpc564xL.h:4834
Definition: fsl-mpc564xL.h:11444
Definition: fsl-mpc564xL.h:8526
Definition: fsl-mpc564xL.h:4290
Definition: fsl-mpc564xL.h:12831
Definition: fsl-mpc564xL.h:7804
Definition: fsl-mpc564xL.h:14016
Definition: fsl-mpc564xL.h:3694
Definition: fsl-mpc564xL.h:10007
Definition: fsl-mpc564xL.h:5740
Definition: fsl-mpc564xL.h:7750
Definition: fsl-mpc564xL.h:10708
Definition: fsl-mpc564xL.h:18161
Definition: fsl-mpc564xL.h:10371
Definition: fsl-mpc564xL.h:7021
Definition: fsl-mpc564xL.h:19664
Definition: fsl-mpc564xL.h:11784
Definition: fsl-mpc564xL.h:8665
Definition: fsl-mpc564xL.h:8675
Definition: fsl-mpc564xL.h:10108
Definition: fsl-mpc564xL.h:5423
Definition: fsl-mpc564xL.h:5381
Definition: fsl-mpc564xL.h:19154
Definition: fsl-mpc564xL.h:13228
Definition: fsl-mpc564xL.h:13532
Definition: fsl-mpc564xL.h:9399
Definition: fsl-mpc564xL.h:19115
Definition: fsl-mpc564xL.h:13649
Definition: fsl-mpc564xL.h:13124
Definition: fsl-mpc564xL.h:8440
Definition: fsl-mpc564xL.h:13164
Definition: fsl-mpc564xL.h:9096
Definition: fsl-mpc564xL.h:12165
Definition: fsl-mpc564xL.h:5407
Definition: fsl-mpc564xL.h:12997
Definition: fsl-mpc5668.h:6576
Definition: fsl-mpc564xL.h:6436
Definition: fsl-mpc564xL.h:4684
Definition: fsl-mpc564xL.h:9564
Definition: fsl-mpc564xL.h:18394
Definition: fsl-mpc564xL.h:11486
Definition: fsl-mpc564xL.h:14424
Definition: fsl-mpc564xL.h:5185
Definition: fsl-mpc564xL.h:17131
Definition: fsl-mpc564xL.h:16728
Definition: fsl-mpc564xL.h:19457
Definition: fsl-mpc564xL.h:12964
Definition: fsl-mpc564xL.h:18748
#define WDT
(WDT ) Base Address
Definition: same70j19.h:541
Definition: fsl-mpc564xL.h:18208
Definition: fsl-mpc564xL.h:19552
Definition: fsl-mpc564xL.h:18585
Definition: fsl-mpc564xL.h:18681
Definition: fsl-mpc564xL.h:12563
Definition: fsl-mpc564xL.h:5906
Definition: fsl-mpc564xL.h:15656
Definition: fsl-mpc564xL.h:14000
Definition: fsl-mpc564xL.h:9239
Definition: fsl-mpc564xL.h:7929
Definition: fsl-mpc564xL.h:7636
Definition: fsl-mpc564xL.h:5394
Definition: fsl-mpc564xL.h:9339
Definition: fsl-mpc564xL.h:14004
Definition: fsl-mpc564xL.h:14246
Definition: fsl-mpc564xL.h:13264
Definition: fsl-mpc564xL.h:19256
Definition: fsl-mpc564xL.h:8101
Definition: fsl-mpc564xL.h:5445
Definition: fsl-mpc564xL.h:11070
Definition: fsl-mpc564xL.h:12525
Definition: fsl-mpc564xL.h:7117
Definition: fsl-mpc564xL.h:4123
Definition: fsl-mpc564xL.h:13175
Definition: fsl-mpc564xL.h:612
Definition: fsl-mpc564xL.h:11942
Definition: fsl-mpc564xL.h:18800
Definition: fsl-mpc564xL.h:214
Definition: fsl-mpc564xL.h:6747
Definition: fsl-mpc564xL.h:18688
Definition: fsl-mpc564xL.h:10518
Definition: fsl-mpc564xL.h:5295
Definition: fsl-mpc551x.h:3622
Definition: fsl-mpc564xL.h:5141
Definition: fsl-mpc564xL.h:1094
Definition: fsl-mpc564xL.h:18231
Definition: fsl-mpc564xL.h:7590
Definition: fsl-mpc564xL.h:334
Definition: fsl-mpc564xL.h:13255
Definition: fsl-mpc564xL.h:18989
Definition: fsl-mpc564xL.h:15720
Definition: fsl-mpc564xL.h:19353
Definition: fsl-mpc564xL.h:19584
Definition: fsl-mpc564xL.h:14047
Definition: fsl-mpc564xL.h:1105
Definition: fsl-mpc564xL.h:19761
Definition: fsl-mpc564xL.h:10086
Definition: fsl-mpc564xL.h:4231
Definition: fsl-mpc564xL.h:10214
Definition: fsl-mpc564xL.h:6988
Definition: fsl-mpc564xL.h:16740
Definition: fsl-mpc564xL.h:18941
Definition: fsl-mpc564xL.h:6072
Definition: fsl-mpc564xL.h:8692
Definition: fsl-mpc564xL.h:9124
Definition: fsl-mpc564xL.h:19129
Definition: fsl-mpc564xL.h:10227
Definition: fsl-mpc564xL.h:3802
Definition: fsl-mpc564xL.h:10960
Definition: fsl-mpc564xL.h:10894
Definition: fsl-mpc564xL.h:8708
Definition: fsl-mpc564xL.h:14471
Definition: fsl-mpc564xL.h:7086
Definition: fsl-mpc564xL.h:19165
Definition: fsl-mpc564xL.h:6777
Definition: fsl-mpc564xL.h:5118
Definition: fsl-mpc564xL.h:13493
Definition: fsl-mpc564xL.h:16781
Definition: fsl-mpc564xL.h:6893
Definition: fsl-mpc564xL.h:11136
Definition: fsl-mpc564xL.h:16789
Definition: fsl-mpc564xL.h:13992
Definition: fsl-mpc564xL.h:19397
Definition: fsl-mpc564xL.h:19379
Definition: fsl-mpc564xL.h:11600
Definition: fsl-mpc564xL.h:14037
Definition: fsl-mpc564xL.h:420
Definition: fsl-mpc564xL.h:17395
Definition: fsl-mpc564xL.h:9932
Definition: fsl-mpc564xL.h:19468
Definition: fsl-mpc564xL.h:16678
Definition: fsl-mpc564xL.h:3710
Definition: fsl-mpc564xL.h:11776
Definition: fsl-mpc564xL.h:4859
Definition: fsl-mpc564xL.h:17025
Definition: fsl-mpc564xL.h:19038
Definition: dd.h:66
Definition: fsl-mpc564xL.h:13664
Definition: fsl-mpc564xL.h:3585
Definition: fsl-mpc564xL.h:12411
Definition: fsl-mpc564xL.h:17003
Definition: fsl-mpc564xL.h:10828
Definition: fsl-mpc564xL.h:5703
Definition: fsl-mpc564xL.h:17016
Definition: fsl-mpc564xL.h:18193
Definition: fsl-mpc564xL.h:10361
Definition: fsl-mpc564xL.h:18870
#define BI
Break Interrupt.
Definition: uart.h:127
Definition: fsl-mpc564xL.h:18725
Definition: fsl-mpc564xL.h:8175
Definition: fsl-mpc564xL.h:10096
Definition: fsl-mpc564xL.h:19336
Definition: fsl-mpc564xL.h:18111
Definition: fsl-mpc564xL.h:11714
Definition: fsl-mpc564xL.h:8187
Definition: fsl-mpc564xL.h:9157
Definition: fsl-mpc564xL.h:5944
Definition: fsl-mpc564xL.h:3687
Definition: fsl-mpc564xL.h:3950
Definition: fsl-mpc564xL.h:7674
Definition: fsl-mpc564xL.h:14404
Definition: fsl-mpc564xL.h:7586
Definition: fsl-mpc564xL.h:3571
Definition: fsl-mpc564xL.h:18973
Definition: fsl-mpc564xL.h:17366
Definition: fsl-mpc564xL.h:10632
Definition: fsl-mpc564xL.h:9466
Definition: fsl-mpc564xL.h:601
Definition: fsl-mpc564xL.h:13545
Definition: fsl-mpc564xL.h:13186
Definition: fsl-mpc564xL.h:6568
Definition: fsl-mpc564xL.h:10235
Definition: fsl-mpc564xL.h:19218
Definition: fsl-mpc564xL.h:11853
Definition: fsl-mpc564xL.h:10034
Definition: fsl-mpc564xL.h:16571
Definition: fsl-mpc564xL.h:224
Definition: fsl-mpc564xL.h:9137
Definition: fsl-mpc564xL.h:11764
Definition: fsl-mpc564xL.h:19434
Definition: fsl-mpc564xL.h:9512
Definition: fsl-mpc564xL.h:19267
Definition: fsl-mpc564xL.h:5588
Definition: fsl-mpc564xL.h:4599
Definition: fsl-mpc5668.h:6467
Definition: fsl-mpc564xL.h:12297
Definition: fsl-mpc551x.h:244
Definition: fsl-mpc564xL.h:16605
Definition: fsl-mpc564xL.h:4902
Definition: fsl-mpc564xL.h:12791
Definition: fsl-mpc564xL.h:3601
Definition: fsl-mpc564xL.h:7852
Definition: fsl-mpc564xL.h:10183
Definition: fsl-mpc564xL.h:8562
Definition: fsl-mpc564xL.h:254
Definition: fsl-mpc564xL.h:8089
Definition: fsl-mpc564xL.h:7599
Definition: fsl-mpc564xL.h:4847
Definition: fsl-mpc564xL.h:11752
Definition: fsl-mpc564xL.h:6454
Definition: fsl-mpc564xL.h:6978
Definition: fsl-mpc564xL.h:9647
Definition: fsl-mpc564xL.h:7010
Definition: fsl-mpc564xL.h:19233
Definition: fsl-mpc564xL.h:14190
Definition: fsl-mpc564xL.h:14278
Definition: fsl-mpc564xL.h:18965
Definition: fsl-mpc564xL.h:12973
Definition: fsl-mpc564xL.h:10746
Definition: fsl-mpc564xL.h:8596
Definition: fsl-mpc564xL.h:18538
Definition: fsl-mpc564xL.h:11114
Definition: fsl-mpc564xL.h:9177
Definition: fsl-mpc564xL.h:8225
Definition: fsl-mpc564xL.h:4702
Definition: fsl-mpc564xL.h:6606
Definition: fsl-mpc564xL.h:10594
Definition: fsl-mpc564xL.h:9985
Definition: fsl-mpc5668.h:73
Definition: fsl-mpc564xL.h:19091
Definition: fsl-mpc564xL.h:5982
Definition: fsl-mpc564xL.h:19056
Definition: fsl-mpc564xL.h:7063
Definition: fsl-mpc564xL.h:14262
Definition: fsl-mpc564xL.h:19673
Definition: fsl-mpc564xL.h:19422
Definition: fsl-mpc564xL.h:14210
Definition: fsl-mpc564xL.h:19299
Definition: fsl-mpc564xL.h:14302
Definition: fsl-mpc564xL.h:240
Definition: fsl-mpc564xL.h:6395
Definition: fsl-mpc564xL.h:19565
Definition: fsl-mpc564xL.h:13514
Definition: fsl-mpc564xL.h:14323
Definition: fsl-mpc564xL.h:14337
Definition: fsl-mpc564xL.h:13760
Definition: fsl-mpc564xL.h:6682
Definition: fsl-mpc564xL.h:9297
Definition: fsl-mpc564xL.h:17285
Definition: fsl-mpc564xL.h:9559
Definition: fsl-mpc564xL.h:6492
Definition: fsl-mpc564xL.h:10143
Definition: fsl-mpc564xL.h:4887
Definition: fsl-mpc564xL.h:19600
Definition: fsl-mpc564xL.h:11843
Definition: fsl-mpc564xL.h:5437
Definition: fsl-mpc564xL.h:13988
Definition: fsl-mpc564xL.h:8724
Definition: fsl-mpc564xL.h:19226
Definition: fsl-mpc564xL.h:19650
Definition: fsl-mpc564xL.h:19792
Definition: fsl-mpc564xL.h:9536
Definition: fsl-mpc564xL.h:6757
Definition: fsl-mpc564xL.h:3734
Definition: fsl-mpc564xL.h:8430
Definition: fsl-mpc564xL.h:9260
Definition: fsl-mpc564xL.h:19615
Definition: fsl-mpc564xL.h:18257
Definition: fsl-mpc551x.h:2087
Definition: fsl-mpc564xL.h:17445
Definition: fsl-mpc564xL.h:19020
Definition: fsl-mpc564xL.h:8194
Definition: fsl-mpc564xL.h:6149
Definition: fsl-mpc564xL.h:13832
Definition: fsl-mpc564xL.h:3550
Definition: fsl-mpc564xL.h:17418
Definition: fsl-mpc564xL.h:14224
Definition: fsl-mpc564xL.h:9307
Definition: fsl-mpc564xL.h:10175
Definition: fsl-mpc564xL.h:11676
Definition: fsl-mpc564xL.h:16698
Definition: fsl-mpc564xL.h:7525
Definition: fsl-mpc564xL.h:9900
Definition: fsl-mpc564xL.h:4299
Definition: fsl-mpc564xL.h:19291
Definition: fsl-mpc564xL.h:4663
Definition: fsl-mpc564xL.h:11368
Definition: fsl-mpc564xL.h:10784
Definition: fsl-mpc564xL.h:15694
Definition: fsl-mpc564xL.h:8470
Definition: fsl-mpc564xL.h:17383
Definition: fsl-mpc551x.h:2221
Definition: fsl-mpc564xL.h:19063
Definition: fsl-mpc564xL.h:17051
Definition: fsl-mpc564xL.h:4793
Definition: fsl-mpc564xL.h:6187
Definition: fsl-mpc564xL.h:19492
Definition: fsl-mpc564xL.h:17169
Definition: fsl-mpc564xL.h:12677
Definition: fsl-mpc564xL.h:7075
Definition: fsl-mpc564xL.h:13868
Definition: fsl-mpc564xL.h:5670
Definition: fsl-mpc564xL.h:19136
Definition: fsl-mpc564xL.h:19283
Definition: fsl-mpc564xL.h:5726
Definition: fsl-mpc564xL.h:18807
Definition: fsl-mpc564xL.h:15678
Definition: fsl-mpc564xL.h:9526
Definition: fsl-mpc564xL.h:6644
Definition: fsl-mpc564xL.h:6807
Definition: fsl-mpc564xL.h:3578
Definition: fsl-mpc564xL.h:5207
Definition: fsl-mpc564xL.h:15711
Definition: fsl-mpc564xL.h:10062
Definition: fsl-mpc564xL.h:6704
Definition: fsl-mpc564xL.h:15758
Definition: fsl-mpc564xL.h:8542
Definition: fsl-mpc564xL.h:19414
Definition: fsl-mpc564xL.h:14316
Definition: fsl-mpc564xL.h:7563
Definition: fsl-mpc564xL.h:13674
Definition: fsl-mpc564xL.h:3680
Definition: fsl-mpc564xL.h:5566
Definition: fsl-mpc564xL.h:19592
Definition: fsl-mpc564xL.h:9215
Definition: fsl-mpc564xL.h:10261
Definition: fsl-mpc564xL.h:14493
Definition: fsl-mpc564xL.h:6530
Definition: fsl-mpc564xL.h:7031
Definition: fsl-mpc564xL.h:5468
Definition: fsl-mpc564xL.h:17007
Definition: fsl-mpc564xL.h:18862
Definition: fsl-mpc564xL.h:5261
Definition: fsl-mpc564xL.h:10202
Definition: fsl-mpc564xL.h:262
Definition: fsl-mpc564xL.h:10243
Definition: fsl-mpc564xL.h:15779
Definition: fsl-mpc564xL.h:3911
Definition: fsl-mpc564xL.h:7041
Definition: fsl-mpc564xL.h:13944
Definition: fsl-mpc564xL.h:11524
Definition: fsl-mpc564xL.h:18784
Definition: fsl-mpc564xL.h:19307
Definition: fsl-mpc564xL.h:19688
Definition: fsl-mpc564xL.h:633
Definition: fsl-mpc564xL.h:19541
Definition: fsl-mpc564xL.h:13657
Definition: fsl-mpc564xL.h:5453
Definition: fsl-mpc564xL.h:19631
Definition: fsl-mpc564xL.h:9250
Definition: fsl-mpc564xL.h:19715
Definition: fsl-mpc564xL.h:19783
Definition: fsl-mpc564xL.h:4740
Definition: fsl-mpc564xL.h:10345
Definition: fsl-mpc564xL.h:11921
Definition: fsl-mpc564xL.h:5233
Definition: fsl-mpc564xL.h:4916
Definition: fsl-mpc564xL.h:11048
Definition: fsl-mpc564xL.h:11935
Definition: fsl-mpc564xL.h:11406
Definition: fsl-mpc564xL.h:12487
Definition: fsl-mpc564xL.h:6827
Definition: fsl-mpc564xL.h:7862
Definition: fsl-mpc564xL.h:6737
Definition: fsl-mpc564xL.h:8212
Definition: fsl-mpc564xL.h:5506
Definition: fsl-mpc564xL.h:5544
Definition: fsl-mpc564xL.h:8505
Definition: fsl-mpc564xL.h:6225
Definition: fsl-mpc564xL.h:18909
Definition: fsl-mpc564xL.h:19528
Definition: fsl-mpc564xL.h:11801
Definition: fsl-mpc564xL.h:527
Definition: fsl-mpc564xL.h:3663
Definition: fsl-mpc564xL.h:13713
Definition: fsl-mpc564xL.h:10191
Definition: fsl-mpc564xL.h:4207
Definition: fsl-mpc564xL.h:410
Definition: fsl-mpc564xL.h:19772
Definition: fsl-mpc564xL.h:13602
Definition: fsl-mpc564xL.h:4647
Definition: fsl-mpc564xL.h:1035
Definition: fsl-mpc564xL.h:18221
Definition: fsl-mpc564xL.h:887
Definition: fsl-mpc564xL.h:9370
Definition: fsl-mpc564xL.h:9117
Definition: fsl-mpc564xL.h:19122
Definition: fsl-mpc564xL.h:19680
Definition: fsl-mpc564xL.h:11292
Definition: fsl-mpc564xL.h:10916
Definition: fsl-mpc564xL.h:13888
Definition: fsl-mpc564xL.h:18917
Definition: fsl-mpc564xL.h:18308
Definition: fsl-mpc564xL.h:6727
Definition: fsl-mpc564xL.h:11174
Definition: fsl-mpc564xL.h:10155
Definition: fsl-mpc564xL.h:15791
Definition: fsl-mpc564xL.h:14309
Definition: fsl-mpc5668.h:1542
Definition: fsl-mpc564xL.h:13150
Definition: fsl-mpc564xL.h:6110
Definition: fsl-mpc564xL.h:18200
Definition: fsl-mpc564xL.h:12152
Definition: fsl-mpc564xL.h:19738
Definition: fsl-mpc564xL.h:19370
Definition: fsl-mpc564xL.h:4055
Definition: fsl-mpc564xL.h:4756
Definition: fsl-mpc564xL.h:733
Definition: fsl-mpc564xL.h:236
Definition: fsl-mpc564xL.h:12601
Definition: fsl-mpc564xL.h:9196
Definition: fsl-mpc564xL.h:3592
Definition: fsl-mpc564xL.h:4018
Definition: fsl-mpc564xL.h:4275
Definition: fsl-mpc564xL.h:4191
Definition: fsl-mpc564xL.h:10403
Definition: fsl-mpc551x.h:1603
Definition: fsl-mpc564xL.h:13278
Definition: fsl-mpc564xL.h:9030
Definition: fsl-mpc564xL.h:6969
Definition: fsl-mpc564xL.h:16773
Definition: fsl-mpc564xL.h:232
Definition: fsl-mpc564xL.h:247
Definition: fsl-mpc564xL.h:3636
Definition: fsl-mpc564xL.h:19143
Definition: fsl-mpc564xL.h:4764
Definition: fsl-mpc564xL.h:5576
Definition: fsl-mpc564xL.h:6787
Definition: fsl-mpc564xL.h:11004
Definition: fsl-mpc564xL.h:9044
Definition: fsl-mpc564xL.h:7052
Definition: fsl-mpc564xL.h:18768
Definition: fsl-mpc564xL.h:11562
Definition: fsl-mpc564xL.h:9037
Definition: fsl-mpc564xL.h:11893
Definition: fsl-mpc564xL.h:10480
Definition: fsl-mpc551x.h:1171
Definition: fsl-mpc564xL.h:11928
Definition: fsl-mpc564xL.h:8219
Definition: fsl-mpc564xL.h:4748
Definition: fsl-mpc564xL.h:17413
Definition: fsl-mpc564xL.h:7917
Definition: fsl-mpc564xL.h:19323
Definition: fsl-mpc564xL.h:13140
Definition: fsl-mpc564xL.h:18122
Definition: fsl-mpc564xL.h:8460
Definition: fsl-mpc564xL.h:4783
Definition: fsl-mpc564xL.h:12259
Definition: fsl-mpc564xL.h:14367
#define FIFO
Definition: wd80x3.h:55
Definition: fsl-mpc564xL.h:3865
Definition: fsl-mpc564xL.h:18933
Definition: fsl-mpc564xL.h:9419
Definition: fsl-mpc564xL.h:14354
Definition: fsl-mpc564xL.h:14238
Definition: fsl-mpc564xL.h:271
Definition: fsl-mpc564xL.h:18815
Definition: fsl-mpc564xL.h:12138
Definition: fsl-mpc564xL.h:9103
Definition: fsl-mpc564xL.h:13635
Definition: fsl-mpc564xL.h:18250
Definition: fsl-mpc564xL.h:7141
Definition: fsl-mpc564xL.h:6767
Definition: fsl-mpc564xL.h:13825
Definition: fsl-mpc564xL.h:8735
Definition: fsl-mpc564xL.h:8700
Definition: fsl-mpc564xL.h:11448
Definition: fsl-mpc564xL.h:8420
Definition: fsl-mpc564xL.h:16541
Definition: fsl-mpc564xL.h:11250
Definition: fsl-mpc564xL.h:10449
#define WL
Word length mask.
Definition: uart.h:149
Definition: fsl-mpc564xL.h:19388
Definition: fsl-mpc564xL.h:11810
Definition: fsl-mpc564xL.h:10389
Definition: fsl-mpc564xL.h:13702
Definition: fsl-mpc564xL.h:19811
Definition: fsl-mpc551x.h:1843
Definition: fsl-mpc564xL.h:6125
Definition: fsl-mpc564xL.h:7842
Definition: fsl-mpc564xL.h:6931
Definition: fsl-mpc564xL.h:19797
Definition: fsl-mpc564xL.h:8586
Definition: fsl-mpc564xL.h:14169
Definition: fsl-mpc564xL.h:14294
Definition: fsl-mpc564xL.h:13500
Definition: fsl-mpc564xL.h:19046
Definition: fsl-mpc564xL.h:13881
Definition: fsl-mpc564xL.h:5315
Definition: fsl-mpc564xL.h:6850
Definition: fsl-mpc564xL.h:11092
Definition: fsl-mpc564xL.h:13996
Definition: fsl-mpc564xL.h:9958
Definition: fsl-mpc564xL.h:8623
Definition: fsl-mpc564xL.h:6357
Definition: fsl-mpc564xL.h:13967
Definition: fsl-mpc564xL.h:11868
Definition: fsl-mpc564xL.h:18925
Definition: fsl-mpc564xL.h:12884
Definition: fsl-mpc564xL.h:19576
Definition: fsl-mpc564xL.h:4616
Definition: fsl-mpc564xL.h:10120
Definition: fsl-mpc564xL.h:5092
Definition: fsl-mpc564xL.h:15724
Definition: fsl-mpc564xL.h:13731
Definition: fsl-mpc564xL.h:14414
Definition: fsl-mpc564xL.h:18949
Definition: fsl-mpc564xL.h:584
Definition: fsl-mpc564xL.h:19185
Definition: fsl-mpc564xL.h:19697
