RTEMS  5.1
fsl-mpc551x.h
1 /*
2  * Modifications of the original file provided by Freescale are:
3  *
4  * Copyright (c) 2011 embedded brains GmbH. All rights reserved.
5  *
6  * embedded brains GmbH
7  * Obere Lagerstr. 30
8  * 82178 Puchheim
9  * Germany
10  * <info@embedded-brains.de>
11  *
12  * Redistribution and use in source and binary forms, with or without
13  * modification, are permitted provided that the following conditions
14  * are met:
15  * 1. Redistributions of source code must retain the above copyright
16  * notice, this list of conditions and the following disclaimer.
17  * 2. Redistributions in binary form must reproduce the above copyright
18  * notice, this list of conditions and the following disclaimer in the
19  * documentation and/or other materials provided with the distribution.
20  *
21  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
22  * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
23  * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
24  * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
25  * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
26  * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
27  * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
28  * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
29  * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
30  * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
31  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
32  */
33
34 /**************************************************************************/
35 /* FILE NAME: mpc5510.h COPYRIGHT (c) Freescale 2008 */
36 /* REVISION: 2.2 All Rights Reserved */
37 /* */
38 /* DESCRIPTION: */
39 /* This file contain all of the register and bit field definitions for */
40 /* MPC5510. */
41 /**************************************************************************/
42 /*>>>>NOTE! this file is auto-generated please do not edit it!<<<<*/
43
44 /*************************************************/
45 /* Example register & bit field write: */
46 /* */
47 /* <MODULE>.<REGISTER>.B.<BIT> = 1; */
48 /* <MODULE>.<REGISTER>.R = 0x10000000; */
49 /* */
50 /*************************************************/
51
52 #ifndef _MPC5510_H_
53 #define _MPC5510_H_
54
55 #ifndef ASM
56
57 #include <stdint.h>
58
59 #include <mpc55xx/regs-edma.h>
60
61 #ifdef __cplusplus
62 extern "C" {
63 #endif
64
65 #ifdef __MWERKS__
66 #pragma push
67 #pragma ANSI_strict off
68 #endif
69
70 /****************************************************************************/
71 /* MODULE : CRP */
72 /****************************************************************************/
73  struct CRP_tag {
74
75  union {
76  uint32_t R;
77  struct {
78  uint32_t:12;
79  uint32_t IRC32KEN:1;
80  uint32_t XOSCEN:1;
81  uint32_t:1;
82  uint32_t OSC32KEN:1;
83  uint32_t TRIM32IRC:8;
84  uint32_t TRIMIRC:8;
85  } B;
86  } CLKSRC; /* Clock Source Register */
87
88  uint32_t crp_reserved1[3];
89
90  union {
91  uint32_t R;
92  struct {
93  uint32_t CNTEN:1;
94  uint32_t RTCIE:1;
95  uint32_t RTCF:1;
96  uint32_t ROVRF:1;
97  uint32_t RTCVAL:12;
98  uint32_t APIEN:1;
99  uint32_t APIIE:1;
100  uint32_t APIF:1;
101  uint32_t CLKSEL:2;
102  uint32_t ROVREN:1;
103  uint32_t APIVAL:10;
104  } B;
105  } RTCSC; /* RTC Status and Control Register */
106
107  union {
108  uint32_t R;
109  struct {
110  uint32_t RTCCNT:32;
111  } B;
112  } RTCCNT; /* RTC Counter Register */
113
114  uint32_t crp_reserved2[10];
115
116  union {
117  uint32_t R;
118  struct {
119  uint32_t:1;
120  uint32_t WKPSEL7:3;
121  uint32_t:1;
122  uint32_t WKPSEL6:3;
123  uint32_t:1;
124  uint32_t WKPSEL5:3;
125  uint32_t:1;
126  uint32_t WKPSEL4:3;
127  uint32_t:1;
128  uint32_t WKPSEL3:3;
129  uint32_t:1;
130  uint32_t WKPSEL2:3;
131  uint32_t:1;
132  uint32_t WKPSEL1:3;
133  uint32_t:1;
134  uint32_t WKPSEL0:3;
135  } B;
136  } WKPINSEL; /* Wakeup Pin Source Select Register */
137
138  union {
139  uint32_t R;
140  struct {
141  uint32_t WKPDET7:2;
142  uint32_t WKPDET6:2;
143  uint32_t WKPDET5:2;
144  uint32_t WKPDET4:2;
145  uint32_t WKPDET3:2;
146  uint32_t WKPDET2:2;
147  uint32_t WKPDET1:2;
148  uint32_t WKPDET0:2;
149  uint32_t:5;
150  uint32_t RTCOVREN:1;
151  uint32_t RTCWKEN:1;
152  uint32_t APIWKEN:1;
153  uint32_t:7;
154  uint32_t WKCLKSEL:1;
155  } B;
156  } WKSE; /* Wakeup Source Enable Register */
157
158  uint32_t crp_reserved3[2];
159
160  union {
161  uint32_t R;
162  struct {
163  uint32_t Z1VEC:30;
164  uint32_t Z1RST:1;
165  uint32_t VLE:1;
166  } B;
167  } Z1VEC; /* Z1 Reset Vector Register */
168
169  union {
170  uint32_t R;
171  struct {
172  uint32_t Z0VEC:30;
173  uint32_t Z0RST:1;
174  uint32_t:1;
175  } B;
176  } Z0VEC; /* Z0 Reset Vector Register */
177
178  union {
179  uint32_t R;
180  struct {
181  uint32_t RECPTR:30;
182  uint32_t FASTREC:1;
183  uint32_t:1;
184  } B;
185  } RECPTR; /* Reset Recovery Pointer Register */
186
187  uint32_t crp_reserved4;
188
189  union {
190  uint32_t R;
191  struct {
192  uint32_t SLEEPF:1;
193  uint32_t STOPF:1;
194  uint32_t:3;
195  uint32_t WKRLLOVRF:1;
196  uint32_t WKAPIF:1;
197  uint32_t WKRTCF:1;
198  uint32_t PWKSCRF:8;
199  uint32_t SLEEP:1;
200  uint32_t STOP:1;
201  uint32_t:1;
202  uint32_t PKREL:1;
203  uint32_t SLP12EN:1;
204  uint32_t RAMSEL:3;
205  uint32_t PWKSRIE:8;
206  } B;
207  } PSCR; /* Power Status and Control Register */
208
209  uint32_t crp_reserved5[3];
210
211  union {
212  uint32_t R;
213  struct {
214  uint32_t LVI5IE:1;
215  uint32_t LVI5HIE:1;
216  uint32_t LVI5F:1;
217  uint32_t LVI5HF:1;
218  uint32_t LVI5LOCK:1;
219  uint32_t LVI5RE:1;
220  uint32_t:9;
221  uint32_t BYPDIS:1;
222  uint32_t:16;
223  } B;
224  } SOCSC; /* LVI Status and Control Register */
225
226  };
227 /****************************************************************************/
228 /* MODULE : DMAMUX */
229 /****************************************************************************/
230  struct DMAMUX_tag {
231  union {
232  uint8_t R;
233  struct {
234  uint8_t ENBL:1;
235  uint8_t TRIG:1;
236  uint8_t SOURCE:6;
237  } B;
238  } CHCONFIG[16]; /* DMA Channel Configuration Register */
239
240  };
241 /****************************************************************************/
242 /* MODULE : DSPI */
243 /****************************************************************************/
244  struct DSPI_tag {
245  union DSPI_MCR_tag {
246  uint32_t R;
247  struct {
248  uint32_t MSTR:1;
249  uint32_t CONT_SCKE:1;
250  uint32_t DCONF:2;
251  uint32_t FRZ:1;
252  uint32_t MTFE:1;
253  uint32_t PCSSE:1;
254  uint32_t ROOE:1;
255  uint32_t:2;
256  uint32_t PCSIS5:1;
257  uint32_t PCSIS4:1;
258  uint32_t PCSIS3:1;
259  uint32_t PCSIS2:1;
260  uint32_t PCSIS1:1;
261  uint32_t PCSIS0:1;
262  uint32_t:1;
263  uint32_t MDIS:1;
264  uint32_t DIS_TXF:1;
265  uint32_t DIS_RXF:1;
266  uint32_t CLR_TXF:1;
267  uint32_t CLR_RXF:1;
268  uint32_t SMPL_PT:2;
269  uint32_t:7;
270  uint32_t HALT:1;
271  } B;
272  } MCR; /* Module Configuration Register */
273
274  uint32_t dspi_reserved1;
275
276  union {
277  uint32_t R;
278  struct {
279  uint32_t SPI_TCNT:16;
280  uint32_t:16;
281  } B;
282  } TCR;
283
285  uint32_t R;
286  struct {
287  uint32_t DBR:1;
288  uint32_t FMSZ:4;
289  uint32_t CPOL:1;
290  uint32_t CPHA:1;
291  uint32_t LSBFE:1;
292  uint32_t PCSSCK:2;
293  uint32_t PASC:2;
294  uint32_t PDT:2;
295  uint32_t PBR:2;
296  uint32_t CSSCK:4;
297  uint32_t ASC:4;
298  uint32_t DT:4;
299  uint32_t BR:4;
300  } B;
301  } CTAR[8]; /* Clock and Transfer Attributes Registers */
302
303  union DSPI_SR_tag {
304  uint32_t R;
305  struct {
306  uint32_t TCF:1;
307  uint32_t TXRXS:1;
308  uint32_t:1;
309  uint32_t EOQF:1;
310  uint32_t TFUF:1;
311  uint32_t:1;
312  uint32_t TFFF:1;
313  uint32_t:5;
314  uint32_t RFOF:1;
315  uint32_t:1;
316  uint32_t RFDF:1;
317  uint32_t:1;
318  uint32_t TXCTR:4;
319  uint32_t TXNXTPTR:4;
320  uint32_t RXCTR:4;
321  uint32_t POPNXTPTR:4;
322  } B;
323  } SR; /* Status Register */
324
326  uint32_t R;
327  struct {
328  uint32_t TCF_RE:1;
329  uint32_t:2;
330  uint32_t EOQFRE:1;
331  uint32_t TFUFRE:1;
332  uint32_t:1;
333  uint32_t TFFFRE:1;
334  uint32_t TFFFDIRS:1;
335  uint32_t:4;
336  uint32_t RFOFRE:1;
337  uint32_t:1;
338  uint32_t RFDFRE:1;
339  uint32_t RFDFDIRS:1;
340  uint32_t:16;
341  } B;
342  } RSER; /* DMA/Interrupt Request Select and Enable Register */
343
345  uint32_t R;
346  struct {
347  uint32_t CONT:1;
348  uint32_t CTAS:3;
349  uint32_t EOQ:1;
350  uint32_t CTCNT:1;
351  uint32_t:4;
352  uint32_t PCS5:1;
353  uint32_t PCS4:1;
354  uint32_t PCS3:1;
355  uint32_t PCS2:1;
356  uint32_t PCS1:1;
357  uint32_t PCS0:1;
358  uint32_t TXDATA:16;
359  } B;
360  } PUSHR; /* PUSH TX FIFO Register */
361
363  uint32_t R;
364  struct {
365  uint32_t:16;
366  uint32_t RXDATA:16;
367  } B;
368  } POPR; /* POP RX FIFO Register */
369
370  union {
371  uint32_t R;
372  struct {
373  uint32_t TXCMD:16;
374  uint32_t TXDATA:16;
375  } B;
376  } TXFR[4]; /* Transmit FIFO Registers */
377
378  uint32_t DSPI_reserved_txf[12];
379
380  union {
381  uint32_t R;
382  struct {
383  uint32_t:16;
384  uint32_t RXDATA:16;
385  } B;
386  } RXFR[4]; /* Transmit FIFO Registers */
387
388  uint32_t DSPI_reserved_rxf[12];
389
390  union {
391  uint32_t R;
392  struct {
393  uint32_t:12;
394  uint32_t TXSS:1;
395  uint32_t:2;
396  uint32_t CID:1;
397  uint32_t DCONT:1;
398  uint32_t DSICTAS:3;
399  uint32_t:6;
400  uint32_t DPCS5:1;
401  uint32_t DPCS4:1;
402  uint32_t DPCS3:1;
403  uint32_t DPCS2:1;
404  uint32_t DPCS1:1;
405  uint32_t DPCS0:1;
406  } B;
407  } DSICR; /* DSI Configuration Register */
408
409  union {
410  uint32_t R;
411  struct {
412  uint32_t:16;
413  uint32_t SER_DATA:16;
414  } B;
415  } SDR; /* DSI Serialization Data Register */
416
417  union {
418  uint32_t R;
419  struct {
420  uint32_t:16;
421  uint32_t ASER_DATA:16;
422  } B;
423  } ASDR; /* DSI Alternate Serialization Data Register */
424
425  union {
426  uint32_t R;
427  struct {
428  uint32_t:16;
429  uint32_t COMP_DATA:16;
430  } B;
431  } COMPR; /* DSI Transmit Comparison Register */
432
433  union {
434  uint32_t R;
435  struct {
436  uint32_t:16;
437  uint32_t DESER_DATA:16;
438  } B;
439  } DDR; /* DSI deserialization Data Register */
440
441  };
442 /****************************************************************************/
443 /* MODULE : External Bus Interface (EBI) */
444 /****************************************************************************/
445
446 /* CS_tag instantiated within EBI_tag */
447  struct EBI_CS_tag {
448  union { /* Base Register Bank */
449  uint32_t R;
450  struct {
451  uint32_t BA:17;
452  uint32_t:3;
453  uint32_t PS:1;
454  uint32_t:3;
455  uint32_t AD_MUX:1;
456  uint32_t BL:1;
457  uint32_t WEBS:1;
458  uint32_t TBDIP:1;
459  uint32_t:1;
460  uint32_t SETA:1;
461  uint32_t BI:1;
462  uint32_t V:1;
463  } B;
464  } BR;
465
466  union { /* Option Register Bank */
467  uint32_t R;
468  struct {
469  uint32_t AM:17;
470  uint32_t:7;
471  uint32_t SCY:4;
472  uint32_t:1;
473  uint32_t BSCY:2;
474  uint32_t:1;
475  } B;
476  } OR;
477  };
478
479  struct EBI_CAL_CS_tag {
480  uint32_t ebi_cal_cs_reserved [2];
481  };
482
483  struct EBI_tag {
484  union EBI_MCR_tag { /* Module Configuration Register */
485  uint32_t R;
486  struct {
487  uint32_t:16;
488  uint32_t ACGE:1;
489  uint32_t EXTM:1;
490  uint32_t EARB:1;
491  uint32_t:6;
492  uint32_t MDIS:1;
493  uint32_t:3;
494  uint32_t D16_31:1;
495  uint32_t AD_MUX:1;
496  uint32_t DBM:1;
497  } B;
498  } MCR;
499
500  uint32_t EBI_reserved1;
501
502  union { /* Transfer Error Status Register */
503  uint32_t R;
504  struct {
505  uint32_t:30;
506  uint32_t TEAF:1;
507  uint32_t BMTF:1;
508  } B;
509  } TESR;
510
511  union { /* Bus Monitor Control Register */
512  uint32_t R;
513  struct {
514  uint32_t:16;
515  uint32_t BMT:8;
516  uint32_t BME:1;
517  uint32_t:7;
518  } B;
519  } BMCR;
520
521  /* Roll in 3x CS registers */
522  struct EBI_CS_tag CS[4];
523
524  uint32_t EBI_reserved2[4];
525
526  struct EBI_CAL_CS_tag CAL_CS[4];
527  };
528 /****************************************************************************/
529 /* MODULE : EMIOS */
530 /****************************************************************************/
531  struct EMIOS_tag {
533  uint32_t R;
534  struct {
535  uint32_t:1;
536  uint32_t MDIS:1;
537  uint32_t FRZ:1;
538  uint32_t GTBE:1;
539  uint32_t:1;
540  uint32_t GPREN:1;
541  uint32_t:10;
542  uint32_t GPRE:8;
543  uint32_t:8;
544  } B;
545  } MCR; /* Module Configuration Register */
546
547  union {
548  uint32_t R;
549  struct {
550  uint32_t:8;
551  uint32_t F23:1;
552  uint32_t F22:1;
553  uint32_t F21:1;
554  uint32_t F20:1;
555  uint32_t F19:1;
556  uint32_t F18:1;
557  uint32_t F17:1;
558  uint32_t F16:1;
559  uint32_t F15:1;
560  uint32_t F14:1;
561  uint32_t F13:1;
562  uint32_t F12:1;
563  uint32_t F11:1;
564  uint32_t F10:1;
565  uint32_t F9:1;
566  uint32_t F8:1;
567  uint32_t F7:1;
568  uint32_t F6:1;
569  uint32_t F5:1;
570  uint32_t F4:1;
571  uint32_t F3:1;
572  uint32_t F2:1;
573  uint32_t F1:1;
574  uint32_t F0:1;
575  } B;
576  } GFG; /* Global FLAG Register */
577
578  union {
579  uint32_t R;
580  struct {
581  uint32_t:8;
582  uint32_t OU23:1;
583  uint32_t OU22:1;
584  uint32_t OU21:1;
585  uint32_t OU20:1;
586  uint32_t OU19:1;
587  uint32_t OU18:1;
588  uint32_t OU17:1;
589  uint32_t OU16:1;
590  uint32_t OU15:1;
591  uint32_t OU14:1;
592  uint32_t OU13:1;
593  uint32_t OU12:1;
594  uint32_t OU11:1;
595  uint32_t OU10:1;
596  uint32_t OU9:1;
597  uint32_t OU8:1;
598  uint32_t OU7:1;
599  uint32_t OU6:1;
600  uint32_t OU5:1;
601  uint32_t OU4:1;
602  uint32_t OU3:1;
603  uint32_t OU2:1;
604  uint32_t OU1:1;
605  uint32_t OU0:1;
606  } B;
607  } OUDR; /* Output Update Disable Register */
608
609  union {
610  uint32_t R;
611  struct {
612  uint32_t:8;
613  uint32_t UC23:1;
614  uint32_t UC22:1;
615  uint32_t UC21:1;
616  uint32_t UC20:1;
617  uint32_t UC19:1;
618  uint32_t UC18:1;
619  uint32_t UC17:1;
620  uint32_t UC16:1;
621  uint32_t UC15:1;
622  uint32_t UC14:1;
623  uint32_t UC13:1;
624  uint32_t UC12:1;
625  uint32_t UC11:1;
626  uint32_t UC10:1;
627  uint32_t UC9:1;
628  uint32_t UC8:1;
629  uint32_t UC7:1;
630  uint32_t UC6:1;
631  uint32_t UC5:1;
632  uint32_t UC4:1;
633  uint32_t UC3:1;
634  uint32_t UC2:1;
635  uint32_t UC1:1;
636  uint32_t UC0:1;
637  } B;
638  } UCDIS; /* Disable Channel Register */
639
640  uint32_t emios_reserved1[4];
641
642  struct EMIOS_CH_tag {
643  union {
644  uint32_t R;
645  struct {
646  uint32_t:16;
647  uint32_t A:16; /* Channel A Data Register */
648  } B;
649  } CADR;
650
651  union {
652  uint32_t R;
653  struct {
654  uint32_t:16;
655  uint32_t B:16; /* Channel B Data Register */
656  } B;
657  } CBDR;
658
659  union {
660  uint32_t R; /* Channel Counter Register */
661  struct {
662  uint32_t:16;
663  uint32_t C:16; /* Channel C Data Register */
664  } B;
665  } CCNTR;
666
668  uint32_t R;
669  struct {
670  uint32_t FREN:1;
671  uint32_t ODIS:1;
672  uint32_t ODISSL:2;
673  uint32_t UCPRE:2;
674  uint32_t UCPREN:1;
675  uint32_t DMA:1;
676  uint32_t:1;
677  uint32_t IF:4;
678  uint32_t FCK:1;
679  uint32_t FEN:1;
680  uint32_t:3;
681  uint32_t FORCMA:1;
682  uint32_t FORCMB:1;
683  uint32_t:1;
684  uint32_t BSL:2;
685  uint32_t EDSEL:1;
686  uint32_t EDPOL:1;
687  uint32_t MODE:7;
688  } B;
689  } CCR; /* Channel Control Register */
690
692  uint32_t R;
693  struct {
694  uint32_t OVR:1;
695  uint32_t:15;
696  uint32_t OVFL:1;
697  uint32_t:12;
698  uint32_t UCIN:1;
699  uint32_t UCOUT:1;
700  uint32_t FLAG:1;
701  } B;
702  } CSR; /* Channel Status Register */
703
704  union {
705  uint32_t R; /* Alternate Channel A Data Register */
706  } ALTA;
707
708  uint32_t emios_channel_reserved[2];
709
710  } CH[24];
711
712  };
713 /****************************************************************************/
714 /* MODULE : EQADC */
715 /****************************************************************************/
716  struct EQADC_tag {
717  union {
718  uint32_t R;
719  struct {
720  uint32_t:30;
721  uint32_t DBG:2;
722  } B;
723  } MCR; /* Module Configuration Register */
724
725  uint32_t eqadc_reserved0;
726
727  union {
728  uint32_t R;
729  struct {
730  uint32_t:6;
731  uint32_t NMF:26;
732  } B;
733  } NMSFR; /* Null Message Send Format Register */
734
735  union {
736  uint32_t R;
737  struct {
738  uint32_t:28;
739  uint32_t DFL:4;
740  } B;
741  } ETDFR; /* External Trigger Digital Filter Register */
742
743  union {
744  uint32_t R;
745  struct {
746  uint32_t CF_PUSH:32;
747  } B;
748  } CFPR[6]; /* CFIFO Push Registers */
749
750  uint32_t eqadc_reserved1;
751
752  uint32_t eqadc_reserved2;
753
754  union {
755  uint32_t R;
756  struct {
757  uint32_t:16;
758  uint32_t RF_POP:16;
759  } B;
760  } RFPR[6]; /* Result FIFO Pop Registers */
761
762  uint32_t eqadc_reserved3;
763
764  uint32_t eqadc_reserved4;
765
766  union {
767  uint16_t R;
768  struct {
769  uint16_t:5;
770  uint16_t SSE:1;
771  uint16_t CFINV:1;
772  uint16_t:1;
773  uint16_t MODE:4;
774  uint16_t:4;
775  } B;
776  } CFCR[6]; /* CFIFO Control Registers */
777
778  uint32_t eqadc_reserved5;
779
780  union {
781  uint16_t R;
782  struct {
783  uint16_t NCIE:1;
784  uint16_t TORIE:1;
785  uint16_t PIE:1;
786  uint16_t EOQIE:1;
787  uint16_t CFUIE:1;
788  uint16_t:1;
789  uint16_t CFFE:1;
790  uint16_t CFFS:1;
791  uint16_t:4;
792  uint16_t RFOIE:1;
793  uint16_t:1;
794  uint16_t RFDE:1;
795  uint16_t RFDS:1;
796  } B;
797  } IDCR[6]; /* Interrupt and DMA Control Registers */
798
799  uint32_t eqadc_reserved6;
800
801  union {
802  uint32_t R;
803  struct {
804  uint32_t NCF:1;
805  uint32_t TORF:1;
806  uint32_t PF:1;
807  uint32_t EOQF:1;
808  uint32_t CFUF:1;
809  uint32_t SSS:1;
810  uint32_t CFFF:1;
811  uint32_t:5;
812  uint32_t RFOF:1;
813  uint32_t:1;
814  uint32_t RFDF:1;
815  uint32_t:1;
816  uint32_t CFCTR:4;
817  uint32_t TNXTPTR:4;
818  uint32_t RFCTR:4;
819  uint32_t POPNXTPTR:4;
820  } B;
821  } FISR[6]; /* FIFO and Interrupt Status Registers */
822
823  uint32_t eqadc_reserved7;
824
825  uint32_t eqadc_reserved8;
826
827  union {
828  uint16_t R;
829  struct {
830  uint16_t:5;
831  uint16_t TC_CF:11;
832  } B;
833  } CFTCR[6]; /* CFIFO Transfer Counter Registers */
834
835  uint32_t eqadc_reserved9;
836
837  union {
838  uint32_t R;
839  struct {
840  uint32_t CFS0_T0:2;
841  uint32_t CFS1_T0:2;
842  uint32_t CFS2_T0:2;
843  uint32_t CFS3_T0:2;
844  uint32_t CFS4_T0:2;
845  uint32_t CFS5_T0:2;
846  uint32_t:5;
847  uint32_t LCFT0:4;
848  uint32_t TC_LCFT0:11;
849  } B;
850  } CFSSR0; /* CFIFO Status Register 0 */
851
852  uint32_t eqadc_reserved10[2];
853
854  union {
855  uint32_t R;
856  struct {
857  uint32_t CFS0:2;
858  uint32_t CFS1:2;
859  uint32_t CFS2:2;
860  uint32_t CFS3:2;
861  uint32_t CFS4:2;
862  uint32_t CFS5:2;
863  uint32_t:20;
864  } B;
865  } CFSR;
866
867  uint32_t eqadc_reserved11[20];
868
869  struct {
870  union {
871  uint32_t R;
872  struct {
873  uint32_t:32;
874  } B;
875  } R[4];
876
877  uint32_t eqadc_reserved12[12];
878
879  } CF[6];
880
881  uint32_t eqadc_reserved13[32];
882
883  struct {
884  union {
885  uint32_t R;
886  struct {
887  uint32_t:32;
888  } B;
889  } R[4];
890
891  uint32_t eqadc_reserved14[12];
892
893  } RF[6];
894
895  };
896 /****************************************************************************/
897 /* MODULE : eSCI */
898 /****************************************************************************/
899  struct ESCI_tag {
900  union ESCI_CR1_tag {
901  uint32_t R;
902  struct {
903  uint32_t:3;
904  uint32_t SBR:13;
905  uint32_t LOOPS:1;
906  uint32_t:1;
907  uint32_t RSRC:1;
908  uint32_t M:1;
909  uint32_t WAKE:1;
910  uint32_t ILT:1;
911  uint32_t PE:1;
912  uint32_t PT:1;
913  uint32_t TIE:1;
914  uint32_t TCIE:1;
915  uint32_t RIE:1;
916  uint32_t ILIE:1;
917  uint32_t TE:1;
918  uint32_t RE:1;
919  uint32_t RWU:1;
920  uint32_t SBK:1;
921  } B;
922  } CR1; /* Control Register 1 */
923
924  union ESCI_CR2_tag {
925  uint16_t R;
926  struct {
927  uint16_t MDIS:1;
928  uint16_t FBR:1;
929  uint16_t BSTP:1;
930  uint16_t IEBERR:1;
931  uint16_t RXDMA:1;
932  uint16_t TXDMA:1;
933  uint16_t BRK13:1;
934  uint16_t TXDIR:1;
935  uint16_t BESM13:1;
936  uint16_t SBSTP:1;
937  uint16_t:1;
938  uint16_t PMSK:1;
939  uint16_t ORIE:1;
940  uint16_t NFIE:1;
941  uint16_t FEIE:1;
942  uint16_t PFIE:1;
943  } B;
944  } CR2; /* Control Register 2 */
945
946  union ESCI_DR_tag {
947  uint16_t R;
948  struct {
949  uint16_t R8:1;
950  uint16_t T8:1;
951  uint16_t:6;
952  uint8_t D;
953  } B;
954  } DR; /* Data Register */
955
956  union ESCI_SR_tag {
957  uint32_t R;
958  struct {
959  uint32_t TDRE:1;
960  uint32_t TC:1;
961  uint32_t RDRF:1;
962  uint32_t IDLE:1;
963  uint32_t OR:1;
964  uint32_t NF:1;
965  uint32_t FE:1;
966  uint32_t PF:1;
967  uint32_t:3;
968  uint32_t BERR:1;
969  uint32_t:3;
970  uint32_t RAF:1;
971  uint32_t RXRDY:1;
972  uint32_t TXRDY:1;
973  uint32_t LWAKE:1;
974  uint32_t STO:1;
975  uint32_t PBERR:1;
976  uint32_t CERR:1;
977  uint32_t CKERR:1;
978  uint32_t FRC:1;
979  uint32_t:6;
980  uint32_t UREQ:1;
981  uint32_t OVFL:1;
982  } B;
983  } SR; /* Status Register */
984
985  union {
986  uint32_t R;
987  struct {
988  uint32_t LRES:1;
989  uint32_t WU:1;
990  uint32_t WUD0:1;
991  uint32_t WUD1:1;
992  uint32_t LDBG:1;
993  uint32_t DSF:1;
994  uint32_t PRTY:1;
995  uint32_t LIN:1;
996  uint32_t RXIE:1;
997  uint32_t TXIE:1;
998  uint32_t WUIE:1;
999  uint32_t STIE:1;
1000  uint32_t PBIE:1;
1001  uint32_t CIE:1;
1002  uint32_t CKIE:1;
1003  uint32_t FCIE:1;
1004  uint32_t:6;
1005  uint32_t UQIE:1;
1006  uint32_t OFIE:1;
1007  uint32_t:8;
1008  } B;
1009  } LCR; /* LIN Control Register */
1010
1011  union {
1012  uint32_t R;
1013  } LTR; /* LIN Transmit Register */
1014
1015  union {
1016  uint32_t R;
1017  } LRR; /* LIN Recieve Register */
1018
1019  union {
1020  uint32_t R;
1021  } LPR; /* LIN CRC Polynom Register */
1022
1023  };
1024 /****************************************************************************/
1025 /* MODULE : FLASH */
1026 /****************************************************************************/
1027  struct FLASH_tag {
1028  union { /* Module Configuration Register */
1029  uint32_t R;
1030  struct {
1031  uint32_t:3;
1032  uint32_t SFS:1;
1033  uint32_t SIZE:4;
1034  uint32_t:1;
1035  uint32_t LAS:3;
1036  uint32_t:3;
1037  uint32_t MAS:1;
1038  uint32_t EER:1;
1039  uint32_t RWE:1;
1040  uint32_t BBEPE:1;
1041  uint32_t EPE:1;
1042  uint32_t PEAS:1;
1043  uint32_t DONE:1;
1044  uint32_t PEG:1;
1045  uint32_t:1;
1046  uint32_t PRD:1;
1047  uint32_t STOP:1;
1048  uint32_t:1;
1049  uint32_t PGM:1;
1050  uint32_t PSUS:1;
1051  uint32_t ERS:1;
1052  uint32_t ESUS:1;
1053  uint32_t EHV:1;
1054  } B;
1055  } MCR;
1056
1057  union LMLR_tag { /* Low/Mid Address Space Block Locking Register */
1058  uint32_t R;
1059  struct {
1060  uint32_t LME:1;
1061  uint32_t:10;
1062  uint32_t SLOCK:1;
1063  uint32_t:2;
1064  uint32_t MLOCK:2;
1065  uint32_t:6;
1066  uint32_t LLOCK:10;
1067  } B;
1068  } LMLR; /* Legacy naming - refer to LML in Reference Manual */
1069
1070  union HLR_tag { /* High Address Space Block Locking Register */
1071  uint32_t R;
1072  struct {
1073  uint32_t HBE:1;
1074  uint32_t:23;
1075  uint32_t HBLOCK:8;
1076  } B;
1077  } HLR; /* Legacy naming - refer to HBL in Reference Manual */
1078
1079  union SLMLR_tag { /* Secondary Low/Mid Block Locking Register */
1080  uint32_t R;
1081  struct {
1082  uint32_t SLE:1;
1083  uint32_t:10;
1084  uint32_t SSLOCK:1;
1085  uint32_t:2;
1086  uint32_t SMLOCK:2;
1087  uint32_t:6;
1088  uint32_t SLLOCK:10;
1089  } B;
1090  } SLMLR; /* Legacy naming - refer to SLL in Reference Manual */
1091
1092  union { /* Low/Mid Address Space Block Select Register */
1093  uint32_t R;
1094  struct {
1095  uint32_t:14;
1096  uint32_t MSEL:2;
1097  uint32_t:6;
1098  uint32_t LSEL:10;
1099  } B;
1100  } LMSR; /* Legacy naming - refer to LMS in Reference Manual */
1101
1102  union { /* High Address Space Block Select Register */
1103  uint32_t R;
1104  struct {
1105  uint32_t:28;
1106  uint32_t HBSEL:4;
1107  } B;
1108  } HSR; /* Legacy naming - refer to HBS in Reference Manual */
1109
1110  union { /* Address Register */
1111  uint32_t R;
1112  struct {
1113  uint32_t:10;
1114  uint32_t ADDR:19;
1115  uint32_t:3;
1116  } B;
1117  } AR; /* Legacy naming - refer to ADR in Reference Manual */
1118
1119  union { /* Platform Flash Configuration Register for Port 0 */
1120  uint32_t R;
1121  struct {
1122  uint32_t LBCFG:4;
1123  uint32_t ARB:1;
1124  uint32_t PRI:1;
1125  uint32_t:5;
1126  uint32_t M4PFE:1;
1127  uint32_t M3PFE:1;
1128  uint32_t M2PFE:1;
1129  uint32_t M1PFE:1;
1130  uint32_t M0PFE:1;
1131  uint32_t APC:3;
1132  uint32_t WWSC:2;
1133  uint32_t RWSC:3;
1134  uint32_t:1;
1135  uint32_t DPFEN:1;
1136  uint32_t:1;
1137  uint32_t IPFEN:1;
1138  uint32_t:1;
1139  uint32_t PFLIM:2;
1140  uint32_t BFEN:1;
1141  } B;
1142  } PFCRP0;
1143
1144  union { /* Platform Flash Configuration Register for Port 1 */
1145  uint32_t R;
1146  struct {
1147  uint32_t LBCFG:4;
1148  uint32_t:7;
1149  uint32_t M4PFE:1;
1150  uint32_t M3PFE:1;
1151  uint32_t M2PFE:1;
1152  uint32_t M1PFE:1;
1153  uint32_t M0PFE:1;
1154  uint32_t APC:3;
1155  uint32_t WWSC:2;
1156  uint32_t RWSC:3;
1157  uint32_t:1;
1158  uint32_t DPFEN:1;
1159  uint32_t:1;
1160  uint32_t IPFEN:1;
1161  uint32_t:1;
1162  uint32_t PFLIM:2;
1163  uint32_t BFEN:1;
1164  } B;
1165  } PFCRP1;
1166
1167  };
1168 /****************************************************************************/
1169 /* MODULE : FlexCAN */
1170 /****************************************************************************/
1171  struct FLEXCAN_tag {
1172  union {
1173  uint32_t R;
1174  struct {
1175  uint32_t MDIS:1;
1176  uint32_t FRZ:1;
1177  uint32_t FEN:1;
1178  uint32_t HALT:1;
1179  uint32_t NOTRDY:1;
1180  uint32_t WAKMSK:1;
1181  uint32_t SOFTRST:1;
1182  uint32_t FRZACK:1;
1183  uint32_t SUPV:1;
1184  uint32_t SLFWAK:1;
1185  uint32_t WRNEN:1;
1186  uint32_t LPMACK:1;
1187  uint32_t WAKSRC:1;
1188  uint32_t DOZE:1;
1189  uint32_t SRXDIS:1;
1190  uint32_t BCC:1;
1191  uint32_t:2;
1192  uint32_t LPRIO_EN:1;
1193  uint32_t AEN:1;
1194  uint32_t:2;
1195  uint32_t IDAM:2;
1196  uint32_t:2;
1197  uint32_t MAXMB:6;
1198  } B;
1199  } MCR; /* Module Configuration Register */
1200
1201  union {
1202  uint32_t R;
1203  struct {
1204  uint32_t PRESDIV:8;
1205  uint32_t RJW:2;
1206  uint32_t PSEG1:3;
1207  uint32_t PSEG2:3;
1208  uint32_t BOFFMSK:1;
1209  uint32_t ERRMSK:1;
1210  uint32_t CLKSRC:1;
1211  uint32_t LPB:1;
1212  uint32_t TWRNMSK:1;
1213  uint32_t RWRNMSK:1;
1214  uint32_t:2;
1215  uint32_t SMP:1;
1216  uint32_t BOFFREC:1;
1217  uint32_t TSYN:1;
1218  uint32_t LBUF:1;
1219  uint32_t LOM:1;
1220  uint32_t PROPSEG:3;
1221  } B;
1222  } CTRL; /* Control Register */
1223
1224  union {
1225  uint32_t R;
1226  } TIMER; /* Free Running Timer */
1227
1228  uint32_t FLEXCAN_reserved1;
1229
1230  union {
1231  uint32_t R;
1232  struct {
1233  uint32_t MI:32;
1234  } B;
1235  } RXGMASK; /* RX Global Mask */
1236
1237  union {
1238  uint32_t R;
1239  struct {
1240  uint32_t MI:32;
1241  } B;
1242  } RX14MASK; /* RX 14 Mask */
1243
1244  union {
1245  uint32_t R;
1246  struct {
1247  uint32_t MI:32;
1248  } B;
1249  } RX15MASK; /* RX 15 Mask */
1250
1251  union {
1252  uint32_t R;
1253  struct {
1254  uint32_t:16;
1255  uint32_t RXECNT:8;
1256  uint32_t TXECNT:8;
1257  } B;
1258  } ECR; /* Error Counter Register */
1259
1260  union {
1261  uint32_t R;
1262  struct {
1263  uint32_t:14;
1264  uint32_t TWRNINT:1;
1265  uint32_t RWRNINT:1;
1266  uint32_t BIT1ERR:1;
1267  uint32_t BIT0ERR:1;
1268  uint32_t ACKERR:1;
1269  uint32_t CRCERR:1;
1270  uint32_t FRMERR:1;
1271  uint32_t STFERR:1;
1272  uint32_t TXWRN:1;
1273  uint32_t RXWRN:1;
1274  uint32_t IDLE:1;
1275  uint32_t TXRX:1;
1276  uint32_t FLTCONF:2;
1277  uint32_t:1;
1278  uint32_t BOFFINT:1;
1279  uint32_t ERRINT:1;
1280  uint32_t WAKINT:1;
1281  } B;
1282  } ESR; /* Error and Status Register */
1283
1284  union {
1285  uint32_t R;
1286  struct {
1287  uint32_t BUF63M:1;
1288  uint32_t BUF62M:1;
1289  uint32_t BUF61M:1;
1290  uint32_t BUF60M:1;
1291  uint32_t BUF59M:1;
1292  uint32_t BUF58M:1;
1293  uint32_t BUF57M:1;
1294  uint32_t BUF56M:1;
1295  uint32_t BUF55M:1;
1296  uint32_t BUF54M:1;
1297  uint32_t BUF53M:1;
1298  uint32_t BUF52M:1;
1299  uint32_t BUF51M:1;
1300  uint32_t BUF50M:1;
1301  uint32_t BUF49M:1;
1302  uint32_t BUF48M:1;
1303  uint32_t BUF47M:1;
1304  uint32_t BUF46M:1;
1305  uint32_t BUF45M:1;
1306  uint32_t BUF44M:1;
1307  uint32_t BUF43M:1;
1308  uint32_t BUF42M:1;
1309  uint32_t BUF41M:1;
1310  uint32_t BUF40M:1;
1311  uint32_t BUF39M:1;
1312  uint32_t BUF38M:1;
1313  uint32_t BUF37M:1;
1314  uint32_t BUF36M:1;
1315  uint32_t BUF35M:1;
1316  uint32_t BUF34M:1;
1317  uint32_t BUF33M:1;
1318  uint32_t BUF32M:1;
1319  } B;
1320  } IMASK2; /* Interruput Masks Register */
1321
1322  union {
1323  uint32_t R;
1324  struct {
1325  uint32_t BUF31M:1;
1326  uint32_t BUF30M:1;
1327  uint32_t BUF29M:1;
1328  uint32_t BUF28M:1;
1329  uint32_t BUF27M:1;
1330  uint32_t BUF26M:1;
1331  uint32_t BUF25M:1;
1332  uint32_t BUF24M:1;
1333  uint32_t BUF23M:1;
1334  uint32_t BUF22M:1;
1335  uint32_t BUF21M:1;
1336  uint32_t BUF20M:1;
1337  uint32_t BUF19M:1;
1338  uint32_t BUF18M:1;
1339  uint32_t BUF17M:1;
1340  uint32_t BUF16M:1;
1341  uint32_t BUF15M:1;
1342  uint32_t BUF14M:1;
1343  uint32_t BUF13M:1;
1344  uint32_t BUF12M:1;
1345  uint32_t BUF11M:1;
1346  uint32_t BUF10M:1;
1347  uint32_t BUF09M:1;
1348  uint32_t BUF08M:1;
1349  uint32_t BUF07M:1;
1350  uint32_t BUF06M:1;
1351  uint32_t BUF05M:1;
1352  uint32_t BUF04M:1;
1353  uint32_t BUF03M:1;
1354  uint32_t BUF02M:1;
1355  uint32_t BUF01M:1;
1356  uint32_t BUF00M:1;
1357  } B;
1358  } IMASK1; /* Interruput Masks Register */
1359
1360  union {
1361  uint32_t R;
1362  struct {
1363  uint32_t BUF63I:1;
1364  uint32_t BUF62I:1;
1365  uint32_t BUF61I:1;
1366  uint32_t BUF60I:1;
1367  uint32_t BUF59I:1;
1368  uint32_t BUF58I:1;
1369  uint32_t BUF57I:1;
1370  uint32_t BUF56I:1;
1371  uint32_t BUF55I:1;
1372  uint32_t BUF54I:1;
1373  uint32_t BUF53I:1;
1374  uint32_t BUF52I:1;
1375  uint32_t BUF51I:1;
1376  uint32_t BUF50I:1;
1377  uint32_t BUF49I:1;
1378  uint32_t BUF48I:1;
1379  uint32_t BUF47I:1;
1380  uint32_t BUF46I:1;
1381  uint32_t BUF45I:1;
1382  uint32_t BUF44I:1;
1383  uint32_t BUF43I:1;
1384  uint32_t BUF42I:1;
1385  uint32_t BUF41I:1;
1386  uint32_t BUF40I:1;
1387  uint32_t BUF39I:1;
1388  uint32_t BUF38I:1;
1389  uint32_t BUF37I:1;
1390  uint32_t BUF36I:1;
1391  uint32_t BUF35I:1;
1392  uint32_t BUF34I:1;
1393  uint32_t BUF33I:1;
1394  uint32_t BUF32I:1;
1395  } B;
1396  } IFLAG2; /* Interruput Flag Register */
1397
1398  union {
1399  uint32_t R;
1400  struct {
1401  uint32_t BUF31I:1;
1402  uint32_t BUF30I:1;
1403  uint32_t BUF29I:1;
1404  uint32_t BUF28I:1;
1405  uint32_t BUF27I:1;
1406  uint32_t BUF26I:1;
1407  uint32_t BUF25I:1;
1408  uint32_t BUF24I:1;
1409  uint32_t BUF23I:1;
1410  uint32_t BUF22I:1;
1411  uint32_t BUF21I:1;
1412  uint32_t BUF20I:1;
1413  uint32_t BUF19I:1;
1414  uint32_t BUF18I:1;
1415  uint32_t BUF17I:1;
1416  uint32_t BUF16I:1;
1417  uint32_t BUF15I:1;
1418  uint32_t BUF14I:1;
1419  uint32_t BUF13I:1;
1420  uint32_t BUF12I:1;
1421  uint32_t BUF11I:1;
1422  uint32_t BUF10I:1;
1423  uint32_t BUF09I:1;
1424  uint32_t BUF08I:1;
1425  uint32_t BUF07I:1;
1426  uint32_t BUF06I:1;
1427  uint32_t BUF05I:1;
1428  uint32_t BUF04I:1;
1429  uint32_t BUF03I:1;
1430  uint32_t BUF02I:1;
1431  uint32_t BUF01I:1;
1432  uint32_t BUF00I:1;
1433  } B;
1434  } IFLAG1; /* Interruput Flag Register */
1435
1436  uint32_t FLEXCAN_reserved2[19];
1437
1438  struct canbuf_t {
1439  union {
1440  uint32_t R;
1441  struct {
1442  uint32_t:4;
1443  uint32_t CODE:4;
1444  uint32_t:1;
1445  uint32_t SRR:1;
1446  uint32_t IDE:1;
1447  uint32_t RTR:1;
1448  uint32_t LENGTH:4;
1449  uint32_t TIMESTAMP:16;
1450  } B;
1451  } CS;
1452
1453  union {
1454  uint32_t R;
1455  struct {
1456  uint32_t PRIO:3;
1457  uint32_t STD_ID:11;
1458  uint32_t EXT_ID:18;
1459  } B;
1460  } ID;
1461
1462  union {
1463  uint8_t B[8]; /* Data buffer in Bytes (8 bits) */
1464  uint16_t H[4]; /* Data buffer in Half-words (16 bits) */
1465  uint32_t W[2]; /* Data buffer in words (32 bits) */
1466  uint32_t R[2]; /* Data buffer in words (32 bits) */
1467  } DATA;
1468
1469  } BUF[64];
1470
1471  uint32_t FLEXCAN_reserved3[256];
1472
1473  union {
1474  uint32_t R;
1475  struct {
1476  uint32_t MI:32;
1477  } B;
1478  } RXIMR[64]; /* RX Individual Mask Registers */
1479
1480  };
1481 /****************************************************************************/
1482 /* MODULE : FMPLL */
1483 /****************************************************************************/
1484  struct FMPLL_tag {
1485
1486  uint32_t FMPLL_reserved0;
1487
1488  union FMPLL_SYNSR_tag { /* Synthesiser Status Register */
1489  uint32_t R;
1490  struct {
1491  uint32_t:22;
1492  uint32_t LOLF:1;
1493  uint32_t LOC:1;
1494  uint32_t MODE:1;
1495  uint32_t PLLSEL:1;
1496  uint32_t PLLREF:1;
1497  uint32_t LOCKS:1;
1498  uint32_t LOCK:1;
1499  uint32_t LOCF:1;
1500  uint32_t CALDONE:1;
1501  uint32_t CALPASS:1;
1502  } B;
1503  } SYNSR;
1504
1506  uint32_t R;
1507  struct {
1508  uint32_t:1;
1509  uint32_t CLKCFG:3;
1510  uint32_t:8;
1511  uint32_t EPREDIV:4;
1512  uint32_t:8;
1513  uint32_t EMFD:8;
1514  } B;
1515  } ESYNCR1;
1516
1518  uint32_t R;
1519  struct {
1520  uint32_t:8;
1521  uint32_t LOCEN:1;
1522  uint32_t LOLRE:1;
1523  uint32_t LOCRE:1;
1524  uint32_t LOLIRQ:1;
1525  uint32_t LOCIRQ:1;
1526  uint32_t:1;
1527  uint32_t ERATE:2;
1528  uint32_t:5;
1529  uint32_t EDEPTH:3;
1530  uint32_t:2;
1531  uint32_t ERFD:6;
1532  } B;
1533  } ESYNCR2;
1534
1535  };
1536 /****************************************************************************/
1537 /* MODULE : i2c */
1538 /****************************************************************************/
1539  struct I2C_tag {
1540  union {
1541  uint8_t R;
1542  struct {
1543  uint8_t AD:7;
1544  uint8_t:1;
1545  } B;
1546  } IBAD; /* Module Bus Address Register */
1547
1548  union {
1549  uint8_t R;
1550  struct {
1551  uint8_t MULT:2;
1552  uint8_t ICR:6;
1553  } B;
1554  } IBFD; /* Module Bus Frequency Register */
1555
1556  union {
1557  uint8_t R;
1558  struct {
1559  uint8_t MDIS:1;
1560  uint8_t IBIE:1;
1561  uint8_t MS:1;
1562  uint8_t TX:1;
1563  uint8_t NOACK:1;
1564  uint8_t RSTA:1;
1565  uint8_t DMAEN:1;
1566  uint8_t:1;
1567  } B;
1568  } IBCR; /* Module Bus Control Register */
1569
1570  union {
1571  uint8_t R;
1572  struct {
1573  uint8_t TCF:1;
1574  uint8_t IAAS:1;
1575  uint8_t IBB:1;
1576  uint8_t IBAL:1;
1577  uint8_t:1;
1578  uint8_t SRW:1;
1579  uint8_t IBIF:1;
1580  uint8_t RXAK:1;
1581  } B;
1582  } IBSR; /* Module Status Register */
1583
1584  union {
1585  uint8_t R;
1586  struct {
1587  uint8_t DATA:8;
1588  } B;
1589  } IBDR; /* Module Data Register */
1590
1591  union {
1592  uint8_t R;
1593  struct {
1594  uint8_t BIIE:1;
1595  uint8_t:7;
1596  } B;
1597  } IBIC; /* Module Interrupt Configuration Register */
1598
1599  };
1600 /****************************************************************************/
1601 /* MODULE : INTC */
1602 /****************************************************************************/
1603  struct INTC_tag {
1604  union {
1605  uint32_t R;
1606  struct {
1607  uint32_t:18;
1608  uint32_t VTES_PRC1:1;
1609  uint32_t:4;
1610  uint32_t HVEN_PRC1:1;
1611  uint32_t:2;
1612  uint32_t VTES:1;
1613  uint32_t:4;
1614  uint32_t HVEN:1;
1615  } B;
1616  } MCR; /* Module Configuration Register */
1617
1618  int32_t INTC_reserved1;
1619
1620  union {
1621  uint32_t R;
1622  struct {
1623  uint32_t:28;
1624  uint32_t PRI:4;
1625  } B;
1626  } CPR; /* Processor 0 Current Priority Register */
1627
1628  union {
1629  uint32_t R;
1630  struct {
1631  uint32_t:28;
1632  uint32_t PRI:4;
1633  } B;
1634  } CPR_PRC1; /* Processor 1 Current Priority Register */
1635
1636  union {
1637  uint32_t R;
1638  struct {
1639  uint32_t VTBA:21;
1640  uint32_t INTVEC:9;
1641  uint32_t:2;
1642  } B;
1643  } IACKR; /* Processor 0 Interrupt Acknowledge Register */
1644
1645  union {
1646  uint32_t R;
1647  struct {
1648  uint32_t VTBA_PRC1:21;
1649  uint32_t INTVEC_PRC1:9;
1650  uint32_t:2;
1651  } B;
1652  } IACKR_PRC1; /* Processor 1 Interrupt Acknowledge Register */
1653
1654  union {
1655  uint32_t R;
1656  struct {
1657  uint32_t:32;
1658  } B;
1659  } EOIR; /* Processor 0 End of Interrupt Register */
1660
1661  union {
1662  uint32_t R;
1663  struct {
1664  uint32_t:32;
1665  } B;
1666  } EOIR_PRC1; /* Processor 1 End of Interrupt Register */
1667
1668  union {
1669  uint8_t R;
1670  struct {
1671  uint8_t:6;
1672  uint8_t SET:1;
1673  uint8_t CLR:1;
1674  } B;
1675  } SSCIR[8]; /* Software Set/Clear Interruput Register */
1676
1677  uint32_t intc_reserved2[6];
1678
1679  union {
1680  uint8_t R;
1681  struct {
1682  uint8_t PRC_SEL:2;
1683  uint8_t:2;
1684  uint8_t PRI:4;
1685  } B;
1686  } PSR[294]; /* Software Set/Clear Interrupt Register */
1687
1688  };
1689 /****************************************************************************/
1690 /* MODULE : MCM */
1691 /****************************************************************************/
1692  struct MCM_tag {
1693
1694  uint32_t mcm_reserved1[5];
1695
1696  uint16_t mcm_reserved2;
1697
1698  union {
1699  uint16_t R;
1700  struct {
1701  uint16_t RO:1;
1702  uint16_t:6;
1703  uint16_t SWRWH:1;
1704  uint16_t SWE:1;
1705  uint16_t SWRI:2;
1706  uint16_t SWT:5;
1707  } B;
1708  } SWTCR; /* Software Watchdog Timer Control */
1709
1710  uint8_t mcm_reserved3[3];
1711
1712  union {
1713  uint8_t R;
1714  } SWTSR; /* SWT Service Register */
1715
1716  uint8_t mcm_reserved4[3];
1717
1718  union {
1719  uint8_t R;
1720  struct {
1721  uint8_t:7;
1722  uint8_t SWTIC:1;
1723  } B;
1724  } SWTIR; /* SWT Interrupt Register */
1725
1726  uint32_t mcm_reserved5[1];
1727
1728  union {
1729  uint32_t R;
1730  struct {
1731  uint32_t PRI:1;
1732  uint32_t:31;
1733  } B;
1734  } MUDCR; /* Misc. User Defined Control Register */
1735
1736  uint32_t mcm_reserved6[6];
1737  uint8_t mcm_reserved7[3];
1738
1739  union {
1740  uint8_t R;
1741  struct {
1742  uint8_t:6;
1743  uint8_t ERNCR:1;
1744  uint8_t EFNCR:1;
1745  } B;
1746  } ECR; /* ECC Configuration Register */
1747
1748  uint8_t mcm_reserved8[3];
1749
1750  union {
1751  uint8_t R;
1752  struct {
1753  uint8_t:6;
1754  uint8_t RNCE:1;
1755  uint8_t FNCE:1;
1756  } B;
1757  } ESR; /* ECC Status Register */
1758
1759  uint16_t mcm_reserved9;
1760
1761  union {
1762  uint16_t R;
1763  struct {
1764  uint16_t:6;
1765  uint16_t FRCNCI:1;
1766  uint16_t FR1NCI:1;
1767  uint16_t:1;
1768  uint16_t ERRBIT:7;
1769  } B;
1770  } EEGR; /* ECC Error Generation Register */
1771
1772  uint32_t mcm_reserved10;
1773
1774  union {
1775  uint32_t R;
1776  } FEAR; /* Flash ECC Address Register */
1777
1778  uint16_t mcm_reserved11;
1779
1780  union {
1781  uint8_t R;
1782  struct {
1783  uint8_t:4;
1784  uint8_t FEMR:4;
1785  } B;
1786  } FEMR; /* Flash ECC Master Register */
1787
1788  union {
1789  uint8_t R;
1790  struct {
1791  uint8_t WRITE:1;
1792  uint8_t SIZE:3;
1793  uint8_t PROTECTION:4;
1794  } B;
1795  } FEAT; /* Flash ECC Attributes Register */
1796
1797  union {
1798  uint32_t R;
1799  } FEDRH; /* Flash ECC Data High Register */
1800
1801  union {
1802  uint32_t R;
1803  } FEDRL; /* Flash ECC Data Low Register */
1804
1805  union {
1806  uint32_t R;
1807  struct {
1808  uint32_t REAR:32;
1809  } B;
1810  } REAR; /* RAM ECC Address */
1811
1812  uint16_t mcm_reserved12;
1813
1814  union {
1815  uint8_t R;
1816  struct {
1817  uint8_t:4;
1818  uint8_t REMR:4;
1819  } B;
1820  } REMR; /* RAM ECC Master */
1821
1822  union {
1823  uint8_t R;
1824  struct {
1825  uint8_t WRITE:1;
1826  uint8_t SIZE:3;
1827  uint8_t PROTECTION:4;
1828  } B;
1829  } REAT; /* RAM ECC Attributes Register */
1830
1831  union {
1832  uint32_t R;
1833  } REDRH; /* RAM ECC Data High Register */
1834
1835  union {
1836  uint32_t R;
1837  } REDRL; /* RAMECC Data Low Register */
1838
1839  };
1840 /****************************************************************************/
1841 /* MODULE : MPU */
1842 /****************************************************************************/
1843  struct MPU_tag {
1844  union {
1845  uint32_t R;
1846  struct {
1847  uint32_t SPERR:8;
1848  uint32_t:4;
1849  uint32_t HRL:4;
1850  uint32_t NSP:4;
1851  uint32_t NGRD:4;
1852  uint32_t:7;
1853  uint32_t VLD:1;
1854  } B;
1855  } CESR; /* Module Control/Error Status Register */
1856
1857  uint32_t mpu_reserved1[3];
1858
1859  union {
1860  uint32_t R;
1861  struct {
1862  uint32_t EADDR:32;
1863  } B;
1864  } EAR0;
1865
1866  union {
1867  uint32_t R;
1868  struct {
1869  uint32_t EACD:16;
1870  uint32_t EPID:8;
1871  uint32_t EMN:4;
1872  uint32_t EATTR:3;
1873  uint32_t ERW:1;
1874  } B;
1875  } EDR0;
1876
1877  union {
1878  uint32_t R;
1879  struct {
1880  uint32_t EADDR:32;
1881  } B;
1882  } EAR1;
1883
1884  union {
1885  uint32_t R;
1886  struct {
1887  uint32_t EACD:16;
1888  uint32_t EPID:8;
1889  uint32_t EMN:4;
1890  uint32_t EATTR:3;
1891  uint32_t ERW:1;
1892  } B;
1893  } EDR1;
1894
1895  union {
1896  uint32_t R;
1897  struct {
1898  uint32_t EADDR:32;
1899  } B;
1900  } EAR2;
1901
1902  union {
1903  uint32_t R;
1904  struct {
1905  uint32_t EACD:16;
1906  uint32_t EPID:8;
1907  uint32_t EMN:4;
1908  uint32_t EATTR:3;
1909  uint32_t ERW:1;
1910  } B;
1911  } EDR2;
1912
1913  uint32_t mpu_reserved2[246];
1914
1915  struct {
1916  union {
1917  uint32_t R;
1918  struct {
1919  uint32_t SRTADDR:27;
1920  uint32_t:5;
1921  } B;
1922  } WORD0; /* Region Descriptor n Word 0 */
1923
1924  union {
1925  uint32_t R;
1926  struct {
1927  uint32_t ENDADDR:27;
1928  uint32_t:5;
1929  } B;
1930  } WORD1; /* Region Descriptor n Word 1 */
1931
1932  union {
1933  uint32_t R;
1934  struct {
1935  uint32_t:6;
1936  uint32_t M4RE0:1;
1937  uint32_t M4WE:1;
1938  uint32_t M3PE:1;
1939  uint32_t M3SM:2;
1940  uint32_t M3UM:3;
1941  uint32_t M2PE:1;
1942  uint32_t M2SM:2;
1943  uint32_t M2UM:3;
1944  uint32_t M1PE:1;
1945  uint32_t M1SM:2;
1946  uint32_t M1UM:3;
1947  uint32_t M0PE:1;
1948  uint32_t M0SM:2;
1949  uint32_t M0UM:3;
1950  } B;
1951  } WORD2; /* Region Descriptor n Word 2 */
1952
1953  union {
1954  uint32_t R;
1955  struct {
1956  uint32_t PID:8;
1957  uint32_t PIDMASK:8;
1958  uint32_t:15;
1959  uint32_t VLD:1;
1960  } B;
1961  } WORD3; /* Region Descriptor n Word 3 */
1962
1963  } RGD[16];
1964
1965  uint32_t mpu_reserved3[192];
1966
1967  union {
1968  uint32_t R;
1969  struct {
1970  uint32_t:6;
1971  uint32_t M4RE:1;
1972  uint32_t M4WE:1;
1973  uint32_t M3PE:1;
1974  uint32_t M3SM:2;
1975  uint32_t M3UM:3;
1976  uint32_t M2PE:1;
1977  uint32_t M2SM:2;
1978  uint32_t M2UM:3;
1979  uint32_t M1PE:1;
1980  uint32_t M1SM:2;
1981  uint32_t M1UM:3;
1982  uint32_t M0PE:1;
1983  uint32_t M0SM:2;
1984  uint32_t M0UM:3;
1985  } B;
1986  } RGDAAC[16]; /* Region Descriptor Alternate Access Control n */
1987  };
1988 /****************************************************************************/
1989 /* MODULE : pit */
1990 /****************************************************************************/
1991  struct PIT_tag {
1992  union {
1993  uint32_t R;
1994  struct {
1995  uint32_t TSV:32;
1996  } B;
1997  } TLVAL[9];
1998
1999  uint32_t pit_reserved1[23];
2000
2001  union {
2002  uint32_t R;
2003  struct {
2004  uint32_t TVL:32;
2005  } B;
2006  } TVAL[9];
2007
2008  uint32_t pit_reserved2[23];
2009
2010  union {
2011  uint32_t R;
2012  struct {
2013  uint32_t:23;
2014  uint32_t TIF8:1;
2015  uint32_t TIF7:1;
2016  uint32_t TIF6:1;
2017  uint32_t TIF5:1;
2018  uint32_t TIF4:1;
2019  uint32_t TIF3:1;
2020  uint32_t TIF2:1;
2021  uint32_t TIF1:1;
2022  uint32_t RTIF:1;
2023  } B;
2024  } PITFLG;
2025
2026  union {
2027  uint32_t R;
2028  struct {
2029  uint32_t:23;
2030  uint32_t TIE8:1;
2031  uint32_t TIE7:1;
2032  uint32_t TIE6:1;
2033  uint32_t TIE5:1;
2034  uint32_t TIE4:1;
2035  uint32_t TIE3:1;
2036  uint32_t TIE2:1;
2037  uint32_t TIE1:1;
2038  uint32_t RTIE:1;
2039  } B;
2040  } PITINTEN;
2041
2042  union {
2043  uint32_t R;
2044  struct {
2045  uint32_t:23;
2046  uint32_t ISEL8:1;
2047  uint32_t ISEL7:1;
2048  uint32_t ISEL6:1;
2049  uint32_t ISEL5:1;
2050  uint32_t ISEL4:1;
2051  uint32_t ISEL3:1;
2052  uint32_t ISEL2:1;
2053  uint32_t ISEL1:1;
2054  uint32_t:1;
2055  } B;
2056  } PITINTSEL;
2057
2058  union {
2059  uint32_t R;
2060  struct {
2061  uint32_t:23;
2062  uint32_t PEN8:1;
2063  uint32_t PEN7:1;
2064  uint32_t PEN6:1;
2065  uint32_t PEN5:1;
2066  uint32_t PEN4:1;
2067  uint32_t PEN3:1;
2068  uint32_t PEN2:1;
2069  uint32_t PEN1:1;
2070  uint32_t PEN0:1;
2071  } B;
2072  } PITEN;
2073
2074  union {
2075  uint32_t R;
2076  struct {
2077  uint32_t:7;
2078  uint32_t MDIS:1;
2079  uint32_t:24;
2080  } B;
2081  } PITCTRL;
2082
2083  };
2084 /****************************************************************************/
2085 /* MODULE : sem4 */
2086 /****************************************************************************/
2087  struct SEMA4_tag {
2088  union {
2089  uint8_t R;
2090  struct {
2091  uint8_t:6;
2092  uint8_t GTFSM:2;
2093  } B;
2094  } GATE[16]; /* Gate n Register */
2095
2096  uint32_t sema4_reserved1[12]; /* {0x40-0x10}/4 = 0x0C */
2097
2098  union {
2099  uint16_t R;
2100  struct {
2101  uint16_t INE0:1;
2102  uint16_t INE1:1;
2103  uint16_t INE2:1;
2104  uint16_t INE3:1;
2105  uint16_t INE4:1;
2106  uint16_t INE5:1;
2107  uint16_t INE6:1;
2108  uint16_t INE7:1;
2109  uint16_t INE8:1;
2110  uint16_t INE9:1;
2111  uint16_t INE10:1;
2112  uint16_t INE11:1;
2113  uint16_t INE12:1;
2114  uint16_t INE13:1;
2115  uint16_t INE14:1;
2116  uint16_t INE15:1;
2117  } B;
2118  } CP0INE;
2119
2120  uint16_t sema4_reserved2[3]; /* {0x48-0x42}/2 = 0x03 */
2121
2122  union {
2123  uint16_t R;
2124  struct {
2125  uint16_t INE0:1;
2126  uint16_t INE1:1;
2127  uint16_t INE2:1;
2128  uint16_t INE3:1;
2129  uint16_t INE4:1;
2130  uint16_t INE5:1;
2131  uint16_t INE6:1;
2132  uint16_t INE7:1;
2133  uint16_t INE8:1;
2134  uint16_t INE9:1;
2135  uint16_t INE10:1;
2136  uint16_t INE11:1;
2137  uint16_t INE12:1;
2138  uint16_t INE13:1;
2139  uint16_t INE14:1;
2140  uint16_t INE15:1;
2141  } B;
2142  } CP1INE;
2143
2144  uint16_t sema4_reserved3[27]; /* {0x80-0x4A}/2 = 0x1B */
2145
2146  union {
2147  uint16_t R;
2148  struct {
2149  uint16_t GN0:1;
2150  uint16_t GN1:1;
2151  uint16_t GN2:1;
2152  uint16_t GN3:1;
2153  uint16_t GN4:1;
2154  uint16_t GN5:1;
2155  uint16_t GN6:1;
2156  uint16_t GN7:1;
2157  uint16_t GN8:1;
2158  uint16_t GN9:1;
2159  uint16_t GN10:1;
2160  uint16_t GN11:1;
2161  uint16_t GN12:1;
2162  uint16_t GN13:1;
2163  uint16_t GN14:1;
2164  uint16_t GN15:1;
2165  } B;
2166  } CP0NTF;
2167
2168  uint16_t sema4_reserved4[3]; /* {0x88-0x82}/2 = 0x03 */
2169
2170  union {
2171  uint16_t R;
2172  struct {
2173  uint16_t GN0:1;
2174  uint16_t GN1:1;
2175  uint16_t GN2:1;
2176  uint16_t GN3:1;
2177  uint16_t GN4:1;
2178  uint16_t GN5:1;
2179  uint16_t GN6:1;
2180  uint16_t GN7:1;
2181  uint16_t GN8:1;
2182  uint16_t GN9:1;
2183  uint16_t GN10:1;
2184  uint16_t GN11:1;
2185  uint16_t GN12:1;
2186  uint16_t GN13:1;
2187  uint16_t GN14:1;
2188  uint16_t GN15:1;
2189  } B;
2190  } CP1NTF;
2191
2192  uint16_t sema4_reserved5[59]; /* {0x100-0x8A}/2 = 0x3B */
2193
2194  union {
2195  uint16_t R;
2196  struct {
2197  uint16_t:2;
2198  uint16_t RSTGSM:2;
2199  uint16_t:1;
2200  uint16_t RSTGMS:3;
2201  uint16_t RSTGTN:8;
2202  } B;
2203  } RSTGT;
2204
2205  uint16_t sema4_reserved6;
2206
2207  union {
2208  uint16_t R;
2209  struct {
2210  uint16_t:2;
2211  uint16_t RSTNSM:2;
2212  uint16_t:1;
2213  uint16_t RSTNMS:3;
2214  uint16_t RSTNTN:8;
2215  } B;
2216  } RSTNTF;
2217  };
2218 /****************************************************************************/
2219 /* MODULE : SIU */
2220 /****************************************************************************/
2221  struct SIU_tag {
2222
2223  int32_t SIU_reserved0;
2224
2225  union { /* MCU ID Register */
2226  uint32_t R;
2227  struct {
2228  uint32_t PARTNUM:16;
2229  uint32_t CSP:1;
2230  uint32_t PKG:5;
2231  uint32_t:2;
2232  uint32_t MASKNUM_MAJOR:4;
2233  uint32_t MASKNUM_MINOR:4;
2234  } B;
2235  } MIDR;
2236
2237  int32_t SIU_reserved1;
2238
2239  union { /* Reset Status Register */
2240  uint32_t R;
2241  struct {
2242  uint32_t PORS:1;
2243  uint32_t ERS:1;
2244  uint32_t LLRS:1;
2245  uint32_t LCRS:1;
2246  uint32_t WDRS:1;
2247  uint32_t CRS:1;
2248  uint32_t:8;
2249  uint32_t SSRS:1;
2250  uint32_t:15;
2251  uint32_t BOOTCFG:1;
2252  uint32_t:1;
2253  } B;
2254  } RSR;
2255
2256  union { /* System Reset Control Register */
2257  uint32_t R;
2258  struct {
2259  uint32_t SSR:1;
2260  uint32_t:15;
2261  uint32_t CRE0:1;
2262  uint32_t CRE1:1;
2263  uint32_t:6;
2264  uint32_t SSRL:1;
2265  uint32_t:7;
2266  } B;
2267  } SRCR;
2268
2269  union SIU_EISR_tag { /* External Interrupt Status Register */
2270  uint32_t R;
2271  struct {
2272  uint32_t NMI0:1;
2273  uint32_t NMI1:1;
2274  uint32_t:14;
2275  uint32_t EIF15:1;
2276  uint32_t EIF14:1;
2277  uint32_t EIF13:1;
2278  uint32_t EIF12:1;
2279  uint32_t EIF11:1;
2280  uint32_t EIF10:1;
2281  uint32_t EIF9:1;
2282  uint32_t EIF8:1;
2283  uint32_t EIF7:1;
2284  uint32_t EIF6:1;
2285  uint32_t EIF5:1;
2286  uint32_t EIF4:1;
2287  uint32_t EIF3:1;
2288  uint32_t EIF2:1;
2289  uint32_t EIF1:1;
2290  uint32_t EIF0:1;
2291  } B;
2292  } EISR;
2293
2294  union SIU_DIRER_tag { /* DMA/Interrupt Request Enable Register */
2295  uint32_t R;
2296  struct {
2297  uint32_t:16;
2298  uint32_t EIRE15:1;
2299  uint32_t EIRE14:1;
2300  uint32_t EIRE13:1;
2301  uint32_t EIRE12:1;
2302  uint32_t EIRE11:1;
2303  uint32_t EIRE10:1;
2304  uint32_t EIRE9:1;
2305  uint32_t EIRE8:1;
2306  uint32_t EIRE7:1;
2307  uint32_t EIRE6:1;
2308  uint32_t EIRE5:1;
2309  uint32_t EIRE4:1;
2310  uint32_t EIRE3:1;
2311  uint32_t EIRE2:1;
2312  uint32_t EIRE1:1;
2313  uint32_t EIRE0:1;
2314  } B;
2315  } DIRER;
2316
2317  union SIU_DIRSR_tag { /* DMA/Interrupt Select Register */
2318  uint32_t R;
2319  struct {
2320  uint32_t:27;
2321  uint32_t DIRS4:1;
2322  uint32_t DIRS3:1;
2323  uint32_t DIRS2:1;
2324  uint32_t DIRS1:1;
2325  uint32_t:1;
2326  } B;
2327  } DIRSR;
2328
2329  union { /* Overrun Status Register */
2330  uint32_t R;
2331  struct {
2332  uint32_t:16;
2333  uint32_t OVF15:1;
2334  uint32_t OVF14:1;
2335  uint32_t OVF13:1;
2336  uint32_t OVF12:1;
2337  uint32_t OVF11:1;
2338  uint32_t OVF10:1;
2339  uint32_t OVF9:1;
2340  uint32_t OVF8:1;
2341  uint32_t OVF7:1;
2342  uint32_t OVF6:1;
2343  uint32_t OVF5:1;
2344  uint32_t OVF4:1;
2345  uint32_t OVF3:1;
2346  uint32_t OVF2:1;
2347  uint32_t OVF1:1;
2348  uint32_t OVF0:1;
2349  } B;
2350  } OSR;
2351
2352  union SIU_ORER_tag { /* Overrun Request Enable Register */
2353  uint32_t R;
2354  struct {
2355  uint32_t:16;
2356  uint32_t ORE15:1;
2357  uint32_t ORE14:1;
2358  uint32_t ORE13:1;
2359  uint32_t ORE12:1;
2360  uint32_t ORE11:1;
2361  uint32_t ORE10:1;
2362  uint32_t ORE9:1;
2363  uint32_t ORE8:1;
2364  uint32_t ORE7:1;
2365  uint32_t ORE6:1;
2366  uint32_t ORE5:1;
2367  uint32_t ORE4:1;
2368  uint32_t ORE3:1;
2369  uint32_t ORE2:1;
2370  uint32_t ORE1:1;
2371  uint32_t ORE0:1;
2372  } B;
2373  } ORER;
2374
2375  union SIU_IREER_tag { /* External IRQ Rising-Edge Event Enable Register */
2376  uint32_t R;
2377  struct {
2378  uint32_t NREE0:1;
2379  uint32_t NREE1:1;
2380  uint32_t:14;
2381  uint32_t IREE15:1;
2382  uint32_t IREE14:1;
2383  uint32_t IREE13:1;
2384  uint32_t IREE12:1;
2385  uint32_t IREE11:1;
2386  uint32_t IREE10:1;
2387  uint32_t IREE9:1;
2388  uint32_t IREE8:1;
2389  uint32_t IREE7:1;
2390  uint32_t IREE6:1;
2391  uint32_t IREE5:1;
2392  uint32_t IREE4:1;
2393  uint32_t IREE3:1;
2394  uint32_t IREE2:1;
2395  uint32_t IREE1:1;
2396  uint32_t IREE0:1;
2397  } B;
2398  } IREER;
2399
2400  union SIU_IFEER_tag { /* External IRQ Falling-Edge Event Enable Register */
2401  uint32_t R;
2402  struct {
2403  uint32_t NFEE0:1;
2404  uint32_t NFEE1:1;
2405  uint32_t:14;
2406  uint32_t IFEE15:1;
2407  uint32_t IFEE14:1;
2408  uint32_t IFEE13:1;
2409  uint32_t IFEE12:1;
2410  uint32_t IFEE11:1;
2411  uint32_t IFEE10:1;
2412  uint32_t IFEE9:1;
2413  uint32_t IFEE8:1;
2414  uint32_t IFEE7:1;
2415  uint32_t IFEE6:1;
2416  uint32_t IFEE5:1;
2417  uint32_t IFEE4:1;
2418  uint32_t IFEE3:1;
2419  uint32_t IFEE2:1;
2420  uint32_t IFEE1:1;
2421  uint32_t IFEE0:1;
2422  } B;
2423  } IFEER;
2424
2425  union SIU_IDFR_tag { /* External IRQ Digital Filter Register */
2426  uint32_t R;
2427  struct {
2428  uint32_t:28;
2429  uint32_t DFL:4;
2430  } B;
2431  } IDFR;
2432
2433  union { /* External IRQ Filtered Input Register */
2434  uint32_t R;
2435  struct {
2436  uint32_t FNMI0:1;
2437  uint32_t FNMI1:1;
2438  uint32_t:14;
2439  uint32_t FI15:1;
2440  uint32_t FI14:1;
2441  uint32_t FI13:1;
2442  uint32_t FI12:1;
2443  uint32_t FI11:1;
2444  uint32_t FI10:1;
2445  uint32_t FI9:1;
2446  uint32_t FI8:1;
2447  uint32_t FI7:1;
2448  uint32_t FI6:1;
2449  uint32_t FI5:1;
2450  uint32_t FI4:1;
2451  uint32_t FI3:1;
2452  uint32_t FI2:1;
2453  uint32_t FI1:1;
2454  uint32_t FI0:1;
2455  } B;
2456  } IFIR;
2457
2458  int32_t SIU_reserved2[2];
2459
2460  union SIU_PCR_tag { /* Pad Configuration Registers */
2461  uint16_t R;
2462  struct {
2463  uint16_t:4;
2464  uint16_t PA:2;
2465  uint16_t OBE:1;
2466  uint16_t IBE:1;
2467  uint16_t:2;
2468  uint16_t ODE:1;
2469  uint16_t HYS:1;
2470  uint16_t SRC:2;
2471  uint16_t WPE:1;
2472  uint16_t WPS:1;
2473  } B;
2474  } PCR[146];
2475
2476  int32_t SIU_reserved3[295];
2477
2478  union { /* GPIO Pin Data Output Registers */
2479  uint8_t R;
2480  struct {
2481  uint8_t:7;
2482  uint8_t PDO:1;
2483  } B;
2484  } GPDO[146];
2485
2486  int32_t SIU_reserved4[91];
2487
2488  union { /* GPIO Pin Data Input Registers */
2489  uint8_t R;
2490  struct {
2491  uint8_t:7;
2492  uint8_t PDI:1;
2493  } B;
2494  } GPDI[146];
2495
2496  int32_t SIU_reserved5[27];
2497
2498  union { /* IMUX Register */
2499  uint32_t R;
2500  struct {
2501  uint32_t TSEL3:2;
2502  uint32_t TSEL2:2;
2503  uint32_t TSEL1:2;
2504  uint32_t TSEL0:2;
2505  uint32_t:24;
2506  } B;
2507  } ISEL0;
2508
2509  union { /* IMUX Register */
2510  uint32_t R;
2511  struct {
2512  uint32_t ESEL15:2;
2513  uint32_t ESEL14:2;
2514  uint32_t ESEL13:2;
2515  uint32_t ESEL12:2;
2516  uint32_t ESEL11:2;
2517  uint32_t ESEL10:2;
2518  uint32_t ESEL9:2;
2519  uint32_t ESEL8:2;
2520  uint32_t ESEL7:2;
2521  uint32_t ESEL6:2;
2522  uint32_t ESEL5:2;
2523  uint32_t ESEL4:2;
2524  uint32_t ESEL3:2;
2525  uint32_t ESEL2:2;
2526  uint32_t ESEL1:2;
2527  uint32_t ESEL0:2;
2528  } B;
2529  } ISEL1;
2530
2531  union { /* IMUX Register */
2532  uint32_t R;
2533  struct {
2534  uint32_t SELEMIOS15:2;
2535  uint32_t SELEMIOS14:2;
2536  uint32_t SELEMIOS13:2;
2537  uint32_t SELEMIOS12:2;
2538  uint32_t SELEMIOS11:2;
2539  uint32_t SELEMIOS10:2;
2540  uint32_t SELEMIOS9:2;
2541  uint32_t SELEMIOS8:2;
2542  uint32_t SELEMIOS7:2;
2543  uint32_t SELEMIOS6:2;
2544  uint32_t SELEMIOS5:2;
2545  uint32_t SELEMIOS4:2;
2546  uint32_t SELEMIOS3:2;
2547  uint32_t SELEMIOS2:2;
2548  uint32_t SELEMIOS1:2;
2549  uint32_t SELEMIOS0:2;
2550  } B;
2551  } ISEL2;
2552
2553  int32_t SIU_reserved6[29];
2554
2555  union { /* Chip Configuration Register Register */
2556  uint32_t R;
2557  struct {
2558  uint32_t:14;
2559  uint32_t MATCH:1;
2560  uint32_t DISNEX:1;
2561  uint32_t:16;
2562  } B;
2563  } CCR;
2564
2565  union { /* External Clock Configuration Register Register */
2566  uint32_t R;
2567  struct {
2568  uint32_t:30;
2569  uint32_t EBDF:2;
2570  } B;
2571  } ECCR;
2572
2573  union { /* Compare A High Register */
2574  uint32_t R;
2575  } CMPAH;
2576
2577  union { /* Compare A Low Register */
2578  uint32_t R;
2579  } CMPAL;
2580
2581  union { /* Compare B High Register */
2582  uint32_t R;
2583  } CMPBH;
2584
2585  union { /* Compare B Low Register */
2586  uint32_t R;
2587  } CMPBL;
2588
2589  int32_t SIU_reserved7[2];
2590
2591  union { /* System CLock Register */
2592  uint32_t R;
2593  struct {
2594  uint32_t SYSCLKSEL:2;
2595  uint32_t SYSCLKDIV:2;
2596  uint32_t SWTCLKSEL:1;
2597  uint32_t:11;
2598  uint32_t LPCLKDIV7:2;
2599  uint32_t LPCLKDIV6:2;
2600  uint32_t LPCLKDIV5:2;
2601  uint32_t LPCLKDIV4:2;
2602  uint32_t LPCLKDIV3:2;
2603  uint32_t LPCLKDIV2:2;
2604  uint32_t LPCLKDIV1:2;
2605  uint32_t LPCLKDIV0:2;
2606  } B;
2607  } SYSCLK;
2608
2609  union { /* Halt Register */
2610  uint32_t R;
2611  } HLT;
2612
2613  union { /* Halt Acknowledge Register */
2614  uint32_t R;
2615  } HLTACK;
2616
2617  int32_t SIU_reserved8[149];
2618
2619  union { /* Parallel GPIO Pin Data Output Register */
2620  uint32_t R;
2621  struct {
2622  uint32_t:16;
2623  uint32_t PB:16;
2624  } B;
2625  } PGPDO0;
2626
2627  union { /* Parallel GPIO Pin Data Output Register */
2628  uint32_t R;
2629  struct {
2630  uint32_t PC:16;
2631  uint32_t PD:16;
2632  } B;
2633  } PGPDO1;
2634
2635  union { /* Parallel GPIO Pin Data Output Register */
2636  uint32_t R;
2637  struct {
2638  uint32_t PE:16;
2639  uint32_t PF:16;
2640  } B;
2641  } PGPDO2;
2642
2643  union { /* Parallel GPIO Pin Data Output Register */
2644  uint32_t R;
2645  struct {
2646  uint32_t PG:16;
2647  uint32_t PH:16;
2648  } B;
2649  } PGPDO3;
2650
2651  union { /* Parallel GPIO Pin Data Output Register */
2652  uint32_t R;
2653  struct {
2654  uint32_t PJ:16;
2655  uint32_t:16;
2656  } B;
2657  } PGPDO4;
2658
2659  int32_t SIU_reserved9[11];
2660
2661  union { /* Parallel GPIO Pin Data Input Register */
2662  uint32_t R;
2663  struct {
2664  uint32_t PA:16;
2665  uint32_t PB:16;
2666  } B;
2667  } PGPDI0;
2668
2669  union { /* Parallel GPIO Pin Data Input Register */
2670  uint32_t R;
2671  struct {
2672  uint32_t PC:16;
2673  uint32_t PD:16;
2674  } B;
2675  } PGPDI1;
2676
2677  union { /* Parallel GPIO Pin Data Input Register */
2678  uint32_t R;
2679  struct {
2680  uint32_t PE:16;
2681  uint32_t PF:16;
2682  } B;
2683  } PGPDI2;
2684
2685  union { /* Parallel GPIO Pin Data Input Register */
2686  uint32_t R;
2687  struct {
2688  uint32_t PG:16;
2689  uint32_t PH:16;
2690  } B;
2691  } PGPDI3;
2692
2693  union { /* Parallel GPIO Pin Data Input Register */
2694  uint32_t R;
2695  struct {
2696  uint32_t PJ:16;
2697  uint32_t PK:2;
2698  uint32_t:14;
2699  } B;
2700  } PGPDI4;
2701
2702  int32_t SIU_reserved10[12];
2703
2704  union { /* Masked Parallel GPIO Pin Data Input Register */
2705  uint32_t R;
2706  struct {
2707  uint32_t PB_MASK:16;
2708  uint32_t PB:16;
2709  } B;
2710  } MPGPDO1;
2711
2712  union { /* Masked Parallel GPIO Pin Data Input Register */
2713  uint32_t R;
2714  struct {
2715  uint32_t PC_MASK:16;
2716  uint32_t PC:16;
2717  } B;
2718  } MPGPDO2;
2719
2720  union { /* Masked Parallel GPIO Pin Data Input Register */
2721  uint32_t R;
2722  struct {
2723  uint32_t PD_MASK:16;
2724  uint32_t PD:16;
2725  } B;
2726  } MPGPDO3;
2727
2728  union { /* Masked Parallel GPIO Pin Data Input Register */
2729  uint32_t R;
2730  struct {
2731  uint32_t PE_MASK:16;
2732  uint32_t PE:16;
2733  } B;
2734  } MPGPDO4;
2735
2736  union { /* Masked Parallel GPIO Pin Data Input Register */
2737  uint32_t R;
2738  struct {
2739  uint32_t PF_MASK:16;
2740  uint32_t PF:16;
2741  } B;
2742  } MPGPDO5;
2743
2744  union { /* Masked Parallel GPIO Pin Data Input Register */
2745  uint32_t R;
2746  struct {
2747  uint32_t PG_MASK:16;
2748  uint32_t PG:16;
2749  } B;
2750  } MPGPDO6;
2751
2752  union { /* Masked Parallel GPIO Pin Data Input Register */
2753  uint32_t R;
2754  struct {
2755  uint32_t PH_MASK:16;
2756  uint32_t PH:16;
2757  } B;
2758  } MPGPDO7;
2759
2760  union { /* Masked Parallel GPIO Pin Data Input Register */
2761  uint32_t R;
2762  struct {
2763  uint32_t PJ_MASK:16;
2764  uint32_t PJ:16;
2765  } B;
2766  } MPGPDO8;
2767
2768  };
2769 /****************************************************************************/
2770 /* MODULE : FlexRay */
2771 /****************************************************************************/
2772
2773  typedef union uMVR {
2774  uint16_t R;
2775  struct {
2776  uint16_t CHIVER:8; /* CHI Version Number */
2777  uint16_t PEVER:8; /* PE Version Number */
2778  } B;
2779  } MVR_t;
2780
2781  typedef union uMCR {
2782  uint16_t R;
2783  struct {
2784  uint16_t MEN:1; /* module enable */
2785  uint16_t:1;
2786  uint16_t SCMD:1; /* single channel mode */
2787  uint16_t CHB:1; /* channel B enable */
2788  uint16_t CHA:1; /* channel A enable */
2789  uint16_t SFFE:1; /* synchronization frame filter enable */
2790  uint16_t:5;
2791  uint16_t CLKSEL:1; /* protocol engine clock source select */
2792  uint16_t PRESCALE:3; /* protocol engine clock prescaler */
2793  uint16_t:1;
2794  } B;
2795  } MCR_t;
2796  typedef union uSTBSCR {
2797  uint16_t R;
2798  struct {
2799  uint16_t WMD:1; /* write mode */
2800  uint16_t STBSSEL:7; /* strobe signal select */
2801  uint16_t:3;
2802  uint16_t ENB:1; /* strobe signal enable */
2803  uint16_t:2;
2804  uint16_t STBPSEL:2; /* strobe port select */
2805  } B;
2806  } STBSCR_t;
2807  typedef union uMBDSR {
2808  uint16_t R;
2809  struct {
2810  uint16_t:1;
2811  uint16_t MBSEG2DS:7; /* message buffer segment 2 data size */
2812  uint16_t:1;
2813  uint16_t MBSEG1DS:7; /* message buffer segment 1 data size */
2814  } B;
2815  } MBDSR_t;
2816
2817  typedef union uMBSSUTR {
2818  uint16_t R;
2819  struct {
2820
2821  uint16_t:2;
2822  uint16_t LAST_MB_SEG1:6; /* last message buffer control register for message buffer segment 1 */
2823  uint16_t:2;
2824  uint16_t LAST_MB_UTIL:6; /* last message buffer utilized */
2825  } B;
2826  } MBSSUTR_t;
2827
2828  typedef union uPOCR {
2829  uint16_t R;
2830  uint8_t byte[2];
2831  struct {
2832  uint16_t WME:1; /* write mode external correction command */
2833  uint16_t:3;
2834  uint16_t EOC_AP:2; /* external offset correction application */
2835  uint16_t ERC_AP:2; /* external rate correction application */
2836  uint16_t BSY:1; /* command write busy / write mode command */
2837  uint16_t:3;
2838  uint16_t POCCMD:4; /* protocol command */
2839  } B;
2840  } POCR_t;
2841 /* protocol commands */
2842  typedef union uGIFER {
2843  uint16_t R;
2844  struct {
2845  uint16_t MIF:1; /* module interrupt flag */
2846  uint16_t PRIF:1; /* protocol interrupt flag */
2847  uint16_t CHIF:1; /* CHI interrupt flag */
2848  uint16_t WKUPIF:1; /* wakeup interrupt flag */
2849  uint16_t FNEBIF:1; /* receive FIFO channel B not empty interrupt flag */
2850  uint16_t FNEAIF:1; /* receive FIFO channel A not empty interrupt flag */
2851  uint16_t RBIF:1; /* receive message buffer interrupt flag */
2852  uint16_t TBIF:1; /* transmit buffer interrupt flag */
2853  uint16_t MIE:1; /* module interrupt enable */
2854  uint16_t PRIE:1; /* protocol interrupt enable */
2855  uint16_t CHIE:1; /* CHI interrupt enable */
2856  uint16_t WKUPIE:1; /* wakeup interrupt enable */
2857  uint16_t FNEBIE:1; /* receive FIFO channel B not empty interrupt enable */
2858  uint16_t FNEAIE:1; /* receive FIFO channel A not empty interrupt enable */
2859  uint16_t RBIE:1; /* receive message buffer interrupt enable */
2860  uint16_t TBIE:1; /* transmit buffer interrupt enable */
2861  } B;
2862  } GIFER_t;
2863  typedef union uPIFR0 {
2864  uint16_t R;
2865  struct {
2866  uint16_t FATLIF:1; /* fatal protocol error interrupt flag */
2867  uint16_t INTLIF:1; /* internal protocol error interrupt flag */
2868  uint16_t ILCFIF:1; /* illegal protocol configuration flag */
2869  uint16_t CSAIF:1; /* cold start abort interrupt flag */
2870  uint16_t MRCIF:1; /* missing rate correctio interrupt flag */
2871  uint16_t MOCIF:1; /* missing offset correctio interrupt flag */
2872  uint16_t CCLIF:1; /* clock correction limit reached interrupt flag */
2873  uint16_t MXSIF:1; /* max sync frames detected interrupt flag */
2874  uint16_t MTXIF:1; /* media access test symbol received flag */
2875  uint16_t LTXBIF:1; /* pdLatestTx violation on channel B interrupt flag */
2876  uint16_t LTXAIF:1; /* pdLatestTx violation on channel A interrupt flag */
2877  uint16_t TBVBIF:1; /* Transmission across boundary on channel B Interrupt Flag */
2878  uint16_t TBVAIF:1; /* Transmission across boundary on channel A Interrupt Flag */
2879  uint16_t TI2IF:1; /* timer 2 expired interrupt flag */
2880  uint16_t TI1IF:1; /* timer 1 expired interrupt flag */
2881  uint16_t CYSIF:1; /* cycle start interrupt flag */
2882  } B;
2883  } PIFR0_t;
2884  typedef union uPIFR1 {
2885  uint16_t R;
2886  struct {
2887  uint16_t EMCIF:1; /* error mode changed interrupt flag */
2888  uint16_t IPCIF:1; /* illegal protocol command interrupt flag */
2889  uint16_t PECFIF:1; /* protocol engine communication failure interrupt flag */
2890  uint16_t PSCIF:1; /* Protocol State Changed Interrupt Flag */
2891  uint16_t SSI3IF:1; /* slot status counter incremented interrupt flag */
2892  uint16_t SSI2IF:1; /* slot status counter incremented interrupt flag */
2893  uint16_t SSI1IF:1; /* slot status counter incremented interrupt flag */
2894  uint16_t SSI0IF:1; /* slot status counter incremented interrupt flag */
2895  uint16_t:2;
2896  uint16_t EVTIF:1; /* even cycle table written interrupt flag */
2897  uint16_t ODTIF:1; /* odd cycle table written interrupt flag */
2898  uint16_t:4;
2899  } B;
2900  } PIFR1_t;
2901  typedef union uPIER0 {
2902  uint16_t R;
2903  struct {
2904  uint16_t FATLIE:1; /* fatal protocol error interrupt enable */
2905  uint16_t INTLIE:1; /* internal protocol error interrupt interrupt enable */
2906  uint16_t ILCFIE:1; /* illegal protocol configuration interrupt enable */
2907  uint16_t CSAIE:1; /* cold start abort interrupt enable */
2908  uint16_t MRCIE:1; /* missing rate correctio interrupt enable */
2909  uint16_t MOCIE:1; /* missing offset correctio interrupt enable */
2910  uint16_t CCLIE:1; /* clock correction limit reached interrupt enable */
2911  uint16_t MXSIE:1; /* max sync frames detected interrupt enable */
2912  uint16_t MTXIE:1; /* media access test symbol received interrupt enable */
2913  uint16_t LTXBIE:1; /* pdLatestTx violation on channel B interrupt enable */
2914  uint16_t LTXAIE:1; /* pdLatestTx violation on channel A interrupt enable */
2915  uint16_t TBVBIE:1; /* Transmission across boundary on channel B Interrupt enable */
2916  uint16_t TBVAIE:1; /* Transmission across boundary on channel A Interrupt enable */
2917  uint16_t TI2IE:1; /* timer 2 expired interrupt enable */
2918  uint16_t TI1IE:1; /* timer 1 expired interrupt enable */
2919  uint16_t CYSIE:1; /* cycle start interrupt enable */
2920  } B;
2921  } PIER0_t;
2922  typedef union uPIER1 {
2923  uint16_t R;
2924  struct {
2925  uint16_t EMCIE:1; /* error mode changed interrupt enable */
2926  uint16_t IPCIE:1; /* illegal protocol command interrupt enable */
2927  uint16_t PECFIE:1; /* protocol engine communication failure interrupt enable */
2928  uint16_t PSCIE:1; /* Protocol State Changed Interrupt enable */
2929  uint16_t SSI3IE:1; /* slot status counter incremented interrupt enable */
2930  uint16_t SSI2IE:1; /* slot status counter incremented interrupt enable */
2931  uint16_t SSI1IE:1; /* slot status counter incremented interrupt enable */
2932  uint16_t SSI0IE:1; /* slot status counter incremented interrupt enable */
2933  uint16_t:2;
2934  uint16_t EVTIE:1; /* even cycle table written interrupt enable */
2935  uint16_t ODTIE:1; /* odd cycle table written interrupt enable */
2936  uint16_t:4;
2937  } B;
2938  } PIER1_t;
2939  typedef union uCHIERFR {
2940  uint16_t R;
2941  struct {
2942  uint16_t FRLBEF:1; /* flame lost channel B error flag */
2943  uint16_t FRLAEF:1; /* frame lost channel A error flag */
2944  uint16_t PCMIEF:1; /* command ignored error flag */
2945  uint16_t FOVBEF:1; /* receive FIFO overrun channel B error flag */
2946  uint16_t FOVAEF:1; /* receive FIFO overrun channel A error flag */
2947  uint16_t MSBEF:1; /* message buffer search error flag */
2948  uint16_t MBUEF:1; /* message buffer utilization error flag */
2949  uint16_t LCKEF:1; /* lock error flag */
2950  uint16_t DBLEF:1; /* double transmit message buffer lock error flag */
2951  uint16_t SBCFEF:1; /* system bus communication failure error flag */
2952  uint16_t FIDEF:1; /* frame ID error flag */
2953  uint16_t DPLEF:1; /* dynamic payload length error flag */
2954  uint16_t SPLEF:1; /* static payload length error flag */
2955  uint16_t NMLEF:1; /* network management length error flag */
2956  uint16_t NMFEF:1; /* network management frame error flag */
2957  uint16_t ILSAEF:1; /* illegal access error flag */
2958  } B;
2959  } CHIERFR_t;
2960  typedef union uMBIVEC {
2961  uint16_t R;
2962  struct {
2963
2964  uint16_t:2;
2965  uint16_t TBIVEC:6; /* transmit buffer interrupt vector */
2966  uint16_t:2;
2967  uint16_t RBIVEC:6; /* receive buffer interrupt vector */
2968  } B;
2969  } MBIVEC_t;
2970
2971  typedef union uPSR0 {
2972  uint16_t R;
2973  struct {
2974  uint16_t ERRMODE:2; /* error mode */
2975  uint16_t SLOTMODE:2; /* slot mode */
2976  uint16_t:1;
2977  uint16_t PROTSTATE:3; /* protocol state */
2978  uint16_t SUBSTATE:4; /* protocol sub state */
2979  uint16_t:1;
2980  uint16_t WAKEUPSTATUS:3; /* wakeup status */
2981  } B;
2982  } PSR0_t;
2983
2984 /* protocol states */
2985 /* protocol sub-states */
2986 /* wakeup status */
2987  typedef union uPSR1 {
2988  uint16_t R;
2989  struct {
2990  uint16_t CSAA:1; /* cold start attempt abort flag */
2991  uint16_t SCP:1; /* cold start path */
2992  uint16_t:1;
2993  uint16_t REMCSAT:5; /* remanining coldstart attempts */
2994  uint16_t CPN:1; /* cold start noise path */
2995  uint16_t HHR:1; /* host halt request pending */
2996  uint16_t FRZ:1; /* freeze occured */
2997  uint16_t APTAC:5; /* allow passive to active counter */
2998  } B;
2999  } PSR1_t;
3000  typedef union uPSR2 {
3001  uint16_t R;
3002  struct {
3003  uint16_t NBVB:1; /* NIT boundary violation on channel B */
3004  uint16_t NSEB:1; /* NIT syntax error on channel B */
3005  uint16_t STCB:1; /* symbol window transmit conflict on channel B */
3006  uint16_t SBVB:1; /* symbol window boundary violation on channel B */
3007  uint16_t SSEB:1; /* symbol window syntax error on channel B */
3008  uint16_t MTB:1; /* media access test symbol MTS received on channel B */
3009  uint16_t NBVA:1; /* NIT boundary violation on channel A */
3010  uint16_t NSEA:1; /* NIT syntax error on channel A */
3011  uint16_t STCA:1; /* symbol window transmit conflict on channel A */
3012  uint16_t SBVA:1; /* symbol window boundary violation on channel A */
3013  uint16_t SSEA:1; /* symbol window syntax error on channel A */
3014  uint16_t MTA:1; /* media access test symbol MTS received on channel A */
3015  uint16_t CLKCORRFAILCNT:4; /* clock correction failed counter */
3016  } B;
3017  } PSR2_t;
3018  typedef union uPSR3 {
3019  uint16_t R;
3020  struct {
3021  uint16_t:2;
3022  uint16_t WUB:1; /* wakeup symbol received on channel B */
3023  uint16_t ABVB:1; /* aggregated boundary violation on channel B */
3024  uint16_t AACB:1; /* aggregated additional communication on channel B */
3025  uint16_t ACEB:1; /* aggregated content error on channel B */
3026  uint16_t ASEB:1; /* aggregated syntax error on channel B */
3027  uint16_t AVFB:1; /* aggregated valid frame on channel B */
3028  uint16_t:2;
3029  uint16_t WUA:1; /* wakeup symbol received on channel A */
3030  uint16_t ABVA:1; /* aggregated boundary violation on channel A */
3031  uint16_t AACA:1; /* aggregated additional communication on channel A */
3032  uint16_t ACEA:1; /* aggregated content error on channel A */
3033  uint16_t ASEA:1; /* aggregated syntax error on channel A */
3034  uint16_t AVFA:1; /* aggregated valid frame on channel A */
3035  } B;
3036  } PSR3_t;
3037  typedef union uCIFRR {
3038  uint16_t R;
3039  struct {
3040  uint16_t:8;
3041  uint16_t MIFR:1; /* module interrupt flag */
3042  uint16_t PRIFR:1; /* protocol interrupt flag */
3043  uint16_t CHIFR:1; /* CHI interrupt flag */
3044  uint16_t WUPIFR:1; /* wakeup interrupt flag */
3045  uint16_t FNEBIFR:1; /* receive fifo channel B no empty interrupt flag */
3046  uint16_t FNEAIFR:1; /* receive fifo channel A no empty interrupt flag */
3047  uint16_t RBIFR:1; /* receive message buffer interrupt flag */
3048  uint16_t TBIFR:1; /* transmit buffer interrupt flag */
3049  } B;
3050  } CIFRR_t;
3051  typedef union uSYMATOR {
3052  uint16_t R;
3053  struct {
3054  uint16_t:11;
3055  uint16_t TIMEOUT:5; /* system memory time out value */
3056  } B;
3057  } SYMATOR_t;
3058
3059  typedef union uSFCNTR {
3060  uint16_t R;
3061  struct {
3062  uint16_t SFEVB:4; /* sync frames channel B, even cycle */
3063  uint16_t SFEVA:4; /* sync frames channel A, even cycle */
3064  uint16_t SFODB:4; /* sync frames channel B, odd cycle */
3065  uint16_t SFODA:4; /* sync frames channel A, odd cycle */
3066  } B;
3067  } SFCNTR_t;
3068
3069  typedef union uSFTCCSR {
3070  uint16_t R;
3071  struct {
3072  uint16_t ELKT:1; /* even cycle tables lock and unlock trigger */
3073  uint16_t OLKT:1; /* odd cycle tables lock and unlock trigger */
3074  uint16_t CYCNUM:6; /* cycle number */
3075  uint16_t ELKS:1; /* even cycle tables lock status */
3076  uint16_t OLKS:1; /* odd cycle tables lock status */
3077  uint16_t EVAL:1; /* even cycle tables valid */
3078  uint16_t OVAL:1; /* odd cycle tables valid */
3079  uint16_t:1;
3080  uint16_t OPT:1; /*one pair trigger */
3081  uint16_t SDVEN:1; /* sync frame deviation table enable */
3082  uint16_t SIDEN:1; /* sync frame ID table enable */
3083  } B;
3084  } SFTCCSR_t;
3085  typedef union uSFIDRFR {
3086  uint16_t R;
3087  struct {
3088  uint16_t:6;
3089  uint16_t SYNFRID:10; /* sync frame rejection ID */
3090  } B;
3091  } SFIDRFR_t;
3092
3093  typedef union uTICCR {
3094  uint16_t R;
3095  struct {
3096  uint16_t:2;
3097  uint16_t T2CFG:1; /* timer 2 configuration */
3098  uint16_t T2REP:1; /* timer 2 repetitive mode */
3099  uint16_t:1;
3100  uint16_t T2SP:1; /* timer 2 stop */
3101  uint16_t T2TR:1; /* timer 2 trigger */
3102  uint16_t T2ST:1; /* timer 2 state */
3103  uint16_t:3;
3104  uint16_t T1REP:1; /* timer 1 repetitive mode */
3105  uint16_t:1;
3106  uint16_t T1SP:1; /* timer 1 stop */
3107  uint16_t T1TR:1; /* timer 1 trigger */
3108  uint16_t T1ST:1; /* timer 1 state */
3109
3110  } B;
3111  } TICCR_t;
3112  typedef union uTI1CYSR {
3113  uint16_t R;
3114  struct {
3115  uint16_t:2;
3116  uint16_t TI1CYCVAL:6; /* timer 1 cycle filter value */
3117  uint16_t:2;
3118  uint16_t TI1CYCMSK:6; /* timer 1 cycle filter mask */
3119
3120  } B;
3121  } TI1CYSR_t;
3122
3123  typedef union uSSSR {
3124  uint16_t R;
3125  struct {
3126  uint16_t WMD:1; /* write mode */
3127  uint16_t:1;
3128  uint16_t SEL:2; /* static slot number */
3129  uint16_t:1;
3130  uint16_t SLOTNUMBER:11; /* selector */
3131  } B;
3132  } SSSR_t;
3133
3134  typedef union uSSCCR {
3135  uint16_t R;
3136  struct {
3137  uint16_t WMD:1; /* write mode */
3138  uint16_t:1;
3139  uint16_t SEL:2; /* selector */
3140  uint16_t:1;
3141  uint16_t CNTCFG:2; /* counter configuration */
3142  uint16_t MCY:1; /* multi cycle selection */
3143  uint16_t VFR:1; /* valid frame selection */
3144  uint16_t SYF:1; /* sync frame selection */
3145  uint16_t NUF:1; /* null frame selection */
3146  uint16_t SUF:1; /* startup frame selection */
3147  uint16_t STATUSMASK:4; /* slot status mask */
3148  } B;
3149  } SSCCR_t;
3150  typedef union uSSR {
3151  uint16_t R;
3152  struct {
3153  uint16_t VFB:1; /* valid frame on channel B */
3154  uint16_t SYB:1; /* valid sync frame on channel B */
3155  uint16_t NFB:1; /* valid null frame on channel B */
3156  uint16_t SUB:1; /* valid startup frame on channel B */
3157  uint16_t SEB:1; /* syntax error on channel B */
3158  uint16_t CEB:1; /* content error on channel B */
3159  uint16_t BVB:1; /* boundary violation on channel B */
3160  uint16_t TCB:1; /* tx conflict on channel B */
3161  uint16_t VFA:1; /* valid frame on channel A */
3162  uint16_t SYA:1; /* valid sync frame on channel A */
3163  uint16_t NFA:1; /* valid null frame on channel A */
3164  uint16_t SUA:1; /* valid startup frame on channel A */
3165  uint16_t SEA:1; /* syntax error on channel A */
3166  uint16_t CEA:1; /* content error on channel A */
3167  uint16_t BVA:1; /* boundary violation on channel A */
3168  uint16_t TCA:1; /* tx conflict on channel A */
3169  } B;
3170  } SSR_t;
3171  typedef union uMTSCFR {
3172  uint16_t R;
3173  struct {
3174  uint16_t MTE:1; /* media access test symbol transmission enable */
3175  uint16_t:1;
3176  uint16_t CYCCNTMSK:6; /* cycle counter mask */
3177  uint16_t:2;
3178  uint16_t CYCCNTVAL:6; /* cycle counter value */
3179  } B;
3180  } MTSCFR_t;
3181
3182  typedef union uRSBIR {
3183  uint16_t R;
3184  struct {
3185  uint16_t WMD:1; /* write mode */
3186  uint16_t:1;
3187  uint16_t SEL:2; /* selector */
3188  uint16_t:5;
3189  uint16_t RSBIDX:7; /* receive shadow buffer index */
3190  } B;
3191  } RSBIR_t;
3192
3193  typedef union uRFDSR {
3194  uint16_t R;
3195  struct {
3196  uint16_t FIFODEPTH:8; /* fifo depth */
3197  uint16_t:1;
3198  uint16_t ENTRYSIZE:7; /* entry size */
3199  } B;
3200  } RFDSR_t;
3201
3202  typedef union uRFRFCFR {
3203  uint16_t R;
3204  struct {
3205  uint16_t WMD:1; /* write mode */
3206  uint16_t IBD:1; /* interval boundary */
3207  uint16_t SEL:2; /* filter number */
3208  uint16_t:1;
3209  uint16_t SID:11; /* slot ID */
3210  } B;
3211  } RFRFCFR_t;
3212
3213  typedef union uRFRFCTR {
3214  uint16_t R;
3215  struct {
3216  uint16_t:4;
3217  uint16_t F3MD:1; /* filter mode */
3218  uint16_t F2MD:1; /* filter mode */
3219  uint16_t F1MD:1; /* filter mode */
3220  uint16_t F0MD:1; /* filter mode */
3221  uint16_t:4;
3222  uint16_t F3EN:1; /* filter enable */
3223  uint16_t F2EN:1; /* filter enable */
3224  uint16_t F1EN:1; /* filter enable */
3225  uint16_t F0EN:1; /* filter enable */
3226  } B;
3227  } RFRFCTR_t;
3228  typedef union uPCR0 {
3229  uint16_t R;
3230  struct {
3231  uint16_t ACTION_POINT_OFFSET:6;
3232  uint16_t STATIC_SLOT_LENGTH:10;
3233  } B;
3234  } PCR0_t;
3235
3236  typedef union uPCR1 {
3237  uint16_t R;
3238  struct {
3239  uint16_t:2;
3240  uint16_t MACRO_AFTER_FIRST_STATIC_SLOT:14;
3241  } B;
3242  } PCR1_t;
3243
3244  typedef union uPCR2 {
3245  uint16_t R;
3246  struct {
3247  uint16_t MINISLOT_AFTER_ACTION_POINT:6;
3248  uint16_t NUMBER_OF_STATIC_SLOTS:10;
3249  } B;
3250  } PCR2_t;
3251
3252  typedef union uPCR3 {
3253  uint16_t R;
3254  struct {
3255  uint16_t WAKEUP_SYMBOL_RX_LOW:6;
3256  uint16_t MINISLOT_ACTION_POINT_OFFSET:5;
3257  uint16_t COLDSTART_ATTEMPTS:5;
3258  } B;
3259  } PCR3_t;
3260
3261  typedef union uPCR4 {
3262  uint16_t R;
3263  struct {
3264  uint16_t CAS_RX_LOW_MAX:7;
3265  uint16_t WAKEUP_SYMBOL_RX_WINDOW:9;
3266  } B;
3267  } PCR4_t;
3268
3269  typedef union uPCR5 {
3270  uint16_t R;
3271  struct {
3272  uint16_t TSS_TRANSMITTER:4;
3273  uint16_t WAKEUP_SYMBOL_TX_LOW:6;
3274  uint16_t WAKEUP_SYMBOL_RX_IDLE:6;
3275  } B;
3276  } PCR5_t;
3277
3278  typedef union uPCR6 {
3279  uint16_t R;
3280  struct {
3281  uint16_t:1;
3282  uint16_t SYMBOL_WINDOW_AFTER_ACTION_POINT:8;
3283  uint16_t MACRO_INITIAL_OFFSET_A:7;
3284  } B;
3285  } PCR6_t;
3286
3287  typedef union uPCR7 {
3288  uint16_t R;
3289  struct {
3290  uint16_t DECODING_CORRECTION_B:9;
3291  uint16_t MICRO_PER_MACRO_NOM_HALF:7;
3292  } B;
3293  } PCR7_t;
3294
3295  typedef union uPCR8 {
3296  uint16_t R;
3297  struct {
3298  uint16_t MAX_WITHOUT_CLOCK_CORRECTION_FATAL:4;
3299  uint16_t MAX_WITHOUT_CLOCK_CORRECTION_PASSIVE:4;
3300  uint16_t WAKEUP_SYMBOL_TX_IDLE:8;
3301  } B;
3302  } PCR8_t;
3303
3304  typedef union uPCR9 {
3305  uint16_t R;
3306  struct {
3307  uint16_t MINISLOT_EXISTS:1;
3308  uint16_t SYMBOL_WINDOW_EXISTS:1;
3309  uint16_t OFFSET_CORRECTION_OUT:14;
3310  } B;
3311  } PCR9_t;
3312
3313  typedef union uPCR10 {
3314  uint16_t R;
3315  struct {
3316  uint16_t SINGLE_SLOT_ENABLED:1;
3317  uint16_t WAKEUP_CHANNEL:1;
3318  uint16_t MACRO_PER_CYCLE:14;
3319  } B;
3320  } PCR10_t;
3321
3322  typedef union uPCR11 {
3323  uint16_t R;
3324  struct {
3325  uint16_t KEY_SLOT_USED_FOR_STARTUP:1;
3326  uint16_t KEY_SLOT_USED_FOR_SYNC:1;
3327  uint16_t OFFSET_CORRECTION_START:14;
3328  } B;
3329  } PCR11_t;
3330
3331  typedef union uPCR12 {
3332  uint16_t R;
3333  struct {
3334  uint16_t ALLOW_PASSIVE_TO_ACTIVE:5;
3335  uint16_t KEY_SLOT_HEADER_CRC:11;
3336  } B;
3337  } PCR12_t;
3338
3339  typedef union uPCR13 {
3340  uint16_t R;
3341  struct {
3342  uint16_t FIRST_MINISLOT_ACTION_POINT_OFFSET:6;
3343  uint16_t STATIC_SLOT_AFTER_ACTION_POINT:10;
3344  } B;
3345  } PCR13_t;
3346
3347  typedef union uPCR14 {
3348  uint16_t R;
3349  struct {
3350  uint16_t RATE_CORRECTION_OUT:11;
3351  uint16_t LISTEN_TIMEOUT_H:5;
3352  } B;
3353  } PCR14_t;
3354
3355  typedef union uPCR15 {
3356  uint16_t R;
3357  struct {
3358  uint16_t LISTEN_TIMEOUT_L:16;
3359  } B;
3360  } PCR15_t;
3361
3362  typedef union uPCR16 {
3363  uint16_t R;
3364  struct {
3365  uint16_t MACRO_INITIAL_OFFSET_B:7;
3366  uint16_t NOISE_LISTEN_TIMEOUT_H:9;
3367  } B;
3368  } PCR16_t;
3369
3370  typedef union uPCR17 {
3371  uint16_t R;
3372  struct {
3373  uint16_t NOISE_LISTEN_TIMEOUT_L:16;
3374  } B;
3375  } PCR17_t;
3376
3377  typedef union uPCR18 {
3378  uint16_t R;
3379  struct {
3380  uint16_t WAKEUP_PATTERN:6;
3381  uint16_t KEY_SLOT_ID:10;
3382  } B;
3383  } PCR18_t;
3384
3385  typedef union uPCR19 {
3386  uint16_t R;
3387  struct {
3388  uint16_t DECODING_CORRECTION_A:9;
3389  uint16_t PAYLOAD_LENGTH_STATIC:7;
3390  } B;
3391  } PCR19_t;
3392
3393  typedef union uPCR20 {
3394  uint16_t R;
3395  struct {
3396  uint16_t MICRO_INITIAL_OFFSET_B:8;
3397  uint16_t MICRO_INITIAL_OFFSET_A:8;
3398  } B;
3399  } PCR20_t;
3400
3401  typedef union uPCR21 {
3402  uint16_t R;
3403  struct {
3404  uint16_t EXTERN_RATE_CORRECTION:3;
3405  uint16_t LATEST_TX:13;
3406  } B;
3407  } PCR21_t;
3408
3409  typedef union uPCR22 {
3410  uint16_t R;
3411  struct {
3412  uint16_t:1;
3413  uint16_t COMP_ACCEPTED_STARTUP_RANGE_A:11;
3414  uint16_t MICRO_PER_CYCLE_H:4;
3415  } B;
3416  } PCR22_t;
3417
3418  typedef union uPCR23 {
3419  uint16_t R;
3420  struct {
3421  uint16_t micro_per_cycle_l:16;
3422  } B;
3423  } PCR23_t;
3424
3425  typedef union uPCR24 {
3426  uint16_t R;
3427  struct {
3428  uint16_t CLUSTER_DRIFT_DAMPING:5;
3429  uint16_t MAX_PAYLOAD_LENGTH_DYNAMIC:7;
3430  uint16_t MICRO_PER_CYCLE_MIN_H:4;
3431  } B;
3432  } PCR24_t;
3433
3434  typedef union uPCR25 {
3435  uint16_t R;
3436  struct {
3437  uint16_t MICRO_PER_CYCLE_MIN_L:16;
3438  } B;
3439  } PCR25_t;
3440
3441  typedef union uPCR26 {
3442  uint16_t R;
3443  struct {
3444  uint16_t ALLOW_HALT_DUE_TO_CLOCK:1;
3445  uint16_t COMP_ACCEPTED_STARTUP_RANGE_B:11;
3446  uint16_t MICRO_PER_CYCLE_MAX_H:4;
3447  } B;
3448  } PCR26_t;
3449
3450  typedef union uPCR27 {
3451  uint16_t R;
3452  struct {
3453  uint16_t MICRO_PER_CYCLE_MAX_L:16;
3454  } B;
3455  } PCR27_t;
3456
3457  typedef union uPCR28 {
3458  uint16_t R;
3459  struct {
3460  uint16_t DYNAMIC_SLOT_IDLE_PHASE:2;
3461  uint16_t MACRO_AFTER_OFFSET_CORRECTION:14;
3462  } B;
3463  } PCR28_t;
3464
3465  typedef union uPCR29 {
3466  uint16_t R;
3467  struct {
3468  uint16_t EXTERN_OFFSET_CORRECTION:3;
3469  uint16_t MINISLOTS_MAX:13;
3470  } B;
3471  } PCR29_t;
3472
3473  typedef union uPCR30 {
3474  uint16_t R;
3475  struct {
3476  uint16_t:12;
3477  uint16_t SYNC_NODE_MAX:4;
3478  } B;
3479  } PCR30_t;
3480
3481  typedef struct uMSG_BUFF_CCS {
3482  union {
3483  uint16_t R;
3484  struct {
3485  uint16_t:1;
3486  uint16_t MCM:1; /* message buffer commit mode */
3487  uint16_t MBT:1; /* message buffer type */
3488  uint16_t MTD:1; /* message buffer direction */
3489  uint16_t CMT:1; /* commit for transmission */
3490  uint16_t EDT:1; /* enable / disable trigger */
3491  uint16_t LCKT:1; /* lock request trigger */
3492  uint16_t MBIE:1; /* message buffer interrupt enable */
3493  uint16_t:3;
3494  uint16_t DUP:1; /* data updated */
3495  uint16_t DVAL:1; /* data valid */
3496  uint16_t EDS:1; /* lock status */
3497  uint16_t LCKS:1; /* enable / disable status */
3498  uint16_t MBIF:1; /* message buffer interrupt flag */
3499  } B;
3500  } MBCCSR;
3501  union {
3502  uint16_t R;
3503  struct {
3504  uint16_t MTM:1; /* message buffer transmission mode */
3505  uint16_t CHNLA:1; /* channel assignement */
3506  uint16_t CHNLB:1; /* channel assignement */
3507  uint16_t CCFE:1; /* cycle counter filter enable */
3508  uint16_t CCFMSK:6; /* cycle counter filter mask */
3509  uint16_t CCFVAL:6; /* cycle counter filter value */
3510  } B;
3511  } MBCCFR;
3512  union {
3513  uint16_t R;
3514  struct {
3515  uint16_t:5;
3516  uint16_t FID:11; /* frame ID */
3517  } B;
3518  } MBFIDR;
3519
3520  union {
3521  uint16_t R;
3522  struct {
3523  uint16_t:9;
3524  uint16_t MBIDX:7; /* message buffer index */
3525  } B;
3526  } MBIDXR;
3527  } MSG_BUFF_CCS_t;
3528  typedef union uSYSBADHR {
3529  uint16_t R;
3530  } SYSBADHR_t;
3531  typedef union uSYSBADLR {
3532  uint16_t R;
3533  } SYSBADLR_t;
3534  typedef union uPADR {
3535  uint16_t R;
3536  } PADR_t;
3537  typedef union uPDAR {
3538  uint16_t R;
3539  } PDAR_t;
3540  typedef union uCASERCR {
3541  uint16_t R;
3542  } CASERCR_t;
3543  typedef union uCBSERCR {
3544  uint16_t R;
3545  } CBSERCR_t;
3546  typedef union uCYCTR {
3547  uint16_t R;
3548  } CYCTR_t;
3549  typedef union uMTCTR {
3550  uint16_t R;
3551  } MTCTR_t;
3552  typedef union uSLTCTAR {
3553  uint16_t R;
3554  } SLTCTAR_t;
3555  typedef union uSLTCTBR {
3556  uint16_t R;
3557  } SLTCTBR_t;
3558  typedef union uRTCORVR {
3559  uint16_t R;
3560  } RTCORVR_t;
3561  typedef union uOFCORVR {
3562  uint16_t R;
3563  } OFCORVR_t;
3564  typedef union uSFTOR {
3565  uint16_t R;
3566  } SFTOR_t;
3567  typedef union uSFIDAFVR {
3568  uint16_t R;
3569  } SFIDAFVR_t;
3570  typedef union uSFIDAFMR {
3571  uint16_t R;
3572  } SFIDAFMR_t;
3573  typedef union uNMVR {
3574  uint16_t R;
3575  } NMVR_t;
3576  typedef union uNMVLR {
3577  uint16_t R;
3578  } NMVLR_t;
3579  typedef union uT1MTOR {
3580  uint16_t R;
3581  } T1MTOR_t;
3582  typedef union uTI2CR0 {
3583  uint16_t R;
3584  } TI2CR0_t;
3585  typedef union uTI2CR1 {
3586  uint16_t R;
3587  } TI2CR1_t;
3588  typedef union uSSCR {
3589  uint16_t R;
3590  } SSCR_t;
3591  typedef union uRFSR {
3592  uint16_t R;
3593  } RFSR_t;
3594  typedef union uRFSIR {
3595  uint16_t R;
3596  } RFSIR_t;
3597  typedef union uRFARIR {
3598  uint16_t R;
3599  } RFARIR_t;
3600  typedef union uRFBRIR {
3601  uint16_t R;
3602  } RFBRIR_t;
3603  typedef union uRFMIDAFVR {
3604  uint16_t R;
3605  } RFMIDAFVR_t;
3606  typedef union uRFMIAFMR {
3607  uint16_t R;
3608  } RFMIAFMR_t;
3609  typedef union uRFFIDRFVR {
3610  uint16_t R;
3611  } RFFIDRFVR_t;
3612  typedef union uRFFIDRFMR {
3613  uint16_t R;
3614  } RFFIDRFMR_t;
3615  typedef union uLDTXSLAR {
3616  uint16_t R;
3617  } LDTXSLAR_t;
3618  typedef union uLDTXSLBR {
3619  uint16_t R;
3620  } LDTXSLBR_t;
3621
3622  typedef struct FR_tag {
3623  volatile MVR_t MVR; /*module version register *//*0 */
3624  volatile MCR_t MCR; /*module configuration register *//*2 */
3625  volatile SYSBADHR_t SYSBADHR; /*system memory base address high register *//*4 */
3626  volatile SYSBADLR_t SYSBADLR; /*system memory base address low register *//*6 */
3627  volatile STBSCR_t STBSCR; /*strobe signal control register *//*8 */
3628  uint16_t reserved0[1]; /*A */
3629  volatile MBDSR_t MBDSR; /*message buffer data size register *//*C */
3630  volatile MBSSUTR_t MBSSUTR; /*message buffer segment size and utilization register *//*E */
3631  uint16_t reserved1[1]; /*10 */
3632  uint16_t reserved2[1]; /*12 */
3633  volatile POCR_t POCR; /*Protocol operation control register *//*14 */
3634  volatile GIFER_t GIFER; /*global interrupt flag and enable register *//*16 */
3635  volatile PIFR0_t PIFR0; /*protocol interrupt flag register 0 *//*18 */
3636  volatile PIFR1_t PIFR1; /*protocol interrupt flag register 1 *//*1A */
3637  volatile PIER0_t PIER0; /*protocol interrupt enable register 0 *//*1C */
3638  volatile PIER1_t PIER1; /*protocol interrupt enable register 1 *//*1E */
3639  volatile CHIERFR_t CHIERFR; /*CHI error flag register *//*20 */
3640  volatile MBIVEC_t MBIVEC; /*message buffer interrupt vector register *//*22 */
3641  volatile CASERCR_t CASERCR; /*channel A status error counter register *//*24 */
3642  volatile CBSERCR_t CBSERCR; /*channel B status error counter register *//*26 */
3643  volatile PSR0_t PSR0; /*protocol status register 0 *//*28 */
3644  volatile PSR1_t PSR1; /*protocol status register 1 *//*2A */
3645  volatile PSR2_t PSR2; /*protocol status register 2 *//*2C */
3646  volatile PSR3_t PSR3; /*protocol status register 3 *//*2E */
3647  volatile MTCTR_t MTCTR; /*macrotick counter register *//*30 */
3648  volatile CYCTR_t CYCTR; /*cycle counter register *//*32 */
3649  volatile SLTCTAR_t SLTCTAR; /*slot counter channel A register *//*34 */
3650  volatile SLTCTBR_t SLTCTBR; /*slot counter channel B register *//*36 */
3651  volatile RTCORVR_t RTCORVR; /*rate correction value register *//*38 */
3652  volatile OFCORVR_t OFCORVR; /*offset correction value register *//*3A */
3653  volatile CIFRR_t CIFRR; /*combined interrupt flag register *//*3C */
3654  volatile SYMATOR_t SYMATOR; /*system memory acess time-out register *//*3E */
3655  volatile SFCNTR_t SFCNTR; /*sync frame counter register *//*40 */
3656  volatile SFTOR_t SFTOR; /*sync frame table offset register *//*42 */
3657  volatile SFTCCSR_t SFTCCSR; /*sync frame table configuration, control, status register *//*44 */
3658  volatile SFIDRFR_t SFIDRFR; /*sync frame ID rejection filter register *//*46 */
3659  volatile SFIDAFVR_t SFIDAFVR; /*sync frame ID acceptance filter value regiater *//*48 */
3660  volatile SFIDAFMR_t SFIDAFMR; /*sync frame ID acceptance filter mask register *//*4A */
3661  volatile NMVR_t NMVR[6]; /*network management vector registers (12 bytes) *//*4C */
3662  volatile NMVLR_t NMVLR; /*network management vector length register *//*58 */
3663  volatile TICCR_t TICCR; /*timer configuration and control register *//*5A */
3664  volatile TI1CYSR_t TI1CYSR; /*timer 1 cycle set register *//*5C */
3665  volatile T1MTOR_t T1MTOR; /*timer 1 macrotick offset register *//*5E */
3666  volatile TI2CR0_t TI2CR0; /*timer 2 configuration register 0 *//*60 */
3667  volatile TI2CR1_t TI2CR1; /*timer 2 configuration register 1 *//*62 */
3668  volatile SSSR_t SSSR; /*slot status selection register *//*64 */
3669  volatile SSCCR_t SSCCR; /*slot status counter condition register *//*66 */
3670  volatile SSR_t SSR[8]; /*slot status registers 0-7 *//*68 */
3671  volatile SSCR_t SSCR[4]; /*slot status counter registers 0-3 *//*78 */
3672  volatile MTSCFR_t MTSACFR; /*mts a config register *//*80 */
3673  volatile MTSCFR_t MTSBCFR; /*mts b config register *//*82 */
3674  volatile RSBIR_t RSBIR; /*receive shadow buffer index register *//*84 */
3675  volatile RFSR_t RFSR; /*receive fifo selection register *//*86 */
3676  volatile RFSIR_t RFSIR; /*receive fifo start index register *//*88 */
3677  volatile RFDSR_t RFDSR; /*receive fifo depth and size register *//*8A */
3678  volatile RFARIR_t RFARIR; /*receive fifo a read index register *//*8C */
3679  volatile RFBRIR_t RFBRIR; /*receive fifo b read index register *//*8E */
3680  volatile RFMIDAFVR_t RFMIDAFVR; /*receive fifo message ID acceptance filter value register *//*90 */
3681  volatile RFMIAFMR_t RFMIAFMR; /*receive fifo message ID acceptance filter mask register *//*92 */
3682  volatile RFFIDRFVR_t RFFIDRFVR; /*receive fifo frame ID rejection filter value register *//*94 */
3683  volatile RFFIDRFMR_t RFFIDRFMR; /*receive fifo frame ID rejection filter mask register *//*96 */
3684  volatile RFRFCFR_t RFRFCFR; /*receive fifo range filter configuration register *//*98 */
3685  volatile RFRFCTR_t RFRFCTR; /*receive fifo range filter control register *//*9A */
3686  volatile LDTXSLAR_t LDTXSLAR; /*last dynamic transmit slot channel A register *//*9C */
3687  volatile LDTXSLBR_t LDTXSLBR; /*last dynamic transmit slot channel B register *//*9E */
3688  volatile PCR0_t PCR0; /*protocol configuration register 0 *//*A0 */
3689  volatile PCR1_t PCR1; /*protocol configuration register 1 *//*A2 */
3690  volatile PCR2_t PCR2; /*protocol configuration register 2 *//*A4 */
3691  volatile PCR3_t PCR3; /*protocol configuration register 3 *//*A6 */
3692  volatile PCR4_t PCR4; /*protocol configuration register 4 *//*A8 */
3693  volatile PCR5_t PCR5; /*protocol configuration register 5 *//*AA */
3694  volatile PCR6_t PCR6; /*protocol configuration register 6 *//*AC */
3695  volatile PCR7_t PCR7; /*protocol configuration register 7 *//*AE */
3696  volatile PCR8_t PCR8; /*protocol configuration register 8 *//*B0 */
3697  volatile PCR9_t PCR9; /*protocol configuration register 9 *//*B2 */
3698  volatile PCR10_t PCR10; /*protocol configuration register 10 *//*B4 */
3699  volatile PCR11_t PCR11; /*protocol configuration register 11 *//*B6 */
3700  volatile PCR12_t PCR12; /*protocol configuration register 12 *//*B8 */
3701  volatile PCR13_t PCR13; /*protocol configuration register 13 *//*BA */
3702  volatile PCR14_t PCR14; /*protocol configuration register 14 *//*BC */
3703  volatile PCR15_t PCR15; /*protocol configuration register 15 *//*BE */
3704  volatile PCR16_t PCR16; /*protocol configuration register 16 *//*C0 */
3705  volatile PCR17_t PCR17; /*protocol configuration register 17 *//*C2 */
3706  volatile PCR18_t PCR18; /*protocol configuration register 18 *//*C4 */
3707  volatile PCR19_t PCR19; /*protocol configuration register 19 *//*C6 */
3708  volatile PCR20_t PCR20; /*protocol configuration register 20 *//*C8 */
3709  volatile PCR21_t PCR21; /*protocol configuration register 21 *//*CA */
3710  volatile PCR22_t PCR22; /*protocol configuration register 22 *//*CC */
3711  volatile PCR23_t PCR23; /*protocol configuration register 23 *//*CE */
3712  volatile PCR24_t PCR24; /*protocol configuration register 24 *//*D0 */
3713  volatile PCR25_t PCR25; /*protocol configuration register 25 *//*D2 */
3714  volatile PCR26_t PCR26; /*protocol configuration register 26 *//*D4 */
3715  volatile PCR27_t PCR27; /*protocol configuration register 27 *//*D6 */
3716  volatile PCR28_t PCR28; /*protocol configuration register 28 *//*D8 */
3717  volatile PCR29_t PCR29; /*protocol configuration register 29 *//*DA */
3718  volatile PCR30_t PCR30; /*protocol configuration register 30 *//*DC */
3719  uint16_t reserved3[17];
3720  volatile MSG_BUFF_CCS_t MBCCS[128]; /* message buffer configuration, control & status registers 0-31 *//*100 */
3721  } FR_tag_t;
3722
3723  typedef union uF_HEADER /* frame header */
3724  {
3725  struct {
3726  uint16_t:5;
3727  uint16_t HDCRC:11; /* Header CRC */
3728  uint16_t:2;
3729  uint16_t CYCCNT:6; /* Cycle Count */
3730  uint16_t:1;
3731  uint16_t PLDLEN:7; /* Payload Length */
3732  uint16_t:1;
3733  uint16_t PPI:1; /* Payload Preamble Indicator */
3734  uint16_t NUF:1; /* Null Frame Indicator */
3735  uint16_t SYF:1; /* Sync Frame Indicator */
3736  uint16_t SUF:1; /* Startup Frame Indicator */
3737  uint16_t FID:11; /* Frame ID */
3738  } B;
3739  uint16_t WORDS[3];
3740  } F_HEADER_t;
3741  typedef union uS_STSTUS /* slot status */
3742  {
3743  struct {
3744  uint16_t VFB:1; /* Valid Frame on channel B */
3745  uint16_t SYB:1; /* Sync Frame Indicator channel B */
3746  uint16_t NFB:1; /* Null Frame Indicator channel B */
3747  uint16_t SUB:1; /* Startup Frame Indicator channel B */
3748  uint16_t SEB:1; /* Syntax Error on channel B */
3749  uint16_t CEB:1; /* Content Error on channel B */
3750  uint16_t BVB:1; /* Boundary Violation on channel B */
3751  uint16_t CH:1; /* Channel */
3752  uint16_t VFA:1; /* Valid Frame on channel A */
3753  uint16_t SYA:1; /* Sync Frame Indicator channel A */
3754  uint16_t NFA:1; /* Null Frame Indicator channel A */
3755  uint16_t SUA:1; /* Startup Frame Indicator channel A */
3756  uint16_t SEA:1; /* Syntax Error on channel A */
3757  uint16_t CEA:1; /* Content Error on channel A */
3758  uint16_t BVA:1; /* Boundary Violation on channel A */
3759  uint16_t:1;
3760  } RX;
3761  struct {
3762  uint16_t VFB:1; /* Valid Frame on channel B */
3763  uint16_t SYB:1; /* Sync Frame Indicator channel B */
3764  uint16_t NFB:1; /* Null Frame Indicator channel B */
3765  uint16_t SUB:1; /* Startup Frame Indicator channel B */
3766  uint16_t SEB:1; /* Syntax Error on channel B */
3767  uint16_t CEB:1; /* Content Error on channel B */
3768  uint16_t BVB:1; /* Boundary Violation on channel B */
3769  uint16_t TCB:1; /* Tx Conflict on channel B */
3770  uint16_t VFA:1; /* Valid Frame on channel A */
3771  uint16_t SYA:1; /* Sync Frame Indicator channel A */
3772  uint16_t NFA:1; /* Null Frame Indicator channel A */
3773  uint16_t SUA:1; /* Startup Frame Indicator channel A */
3774  uint16_t SEA:1; /* Syntax Error on channel A */
3775  uint16_t CEA:1; /* Content Error on channel A */
3776  uint16_t BVA:1; /* Boundary Violation on channel A */
3777  uint16_t TCA:1; /* Tx Conflict on channel A */
3778  } TX;
3779  uint16_t R;
3780  } S_STATUS_t;
3781
3782  typedef struct uMB_HEADER /* message buffer header */
3783  {
3784  F_HEADER_t FRAME_HEADER;
3785  uint16_t DATA_OFFSET;
3786  S_STATUS_t SLOT_STATUS;
3787  } MB_HEADER_t;
3788 /****************************************************************************/
3789 /* MODULE : MLB */
3790 /****************************************************************************/
3791  struct MLB_tag {
3792
3793  union { /* MLB Module Configuration Register */
3794  uint32_t R;
3795  struct {
3796  uint32_t MDIS:1;
3797  uint32_t:15;
3798  uint32_t MDATOBSE:1;
3799  uint32_t MSIGOBS:1;
3800  uint32_t MSLOTE:1;
3801  uint32_t:2;
3802  uint32_t MSVRQIE:1;
3803  uint32_t MDATRQE:1;
3804  uint32_t:2;
3805  uint32_t MSVRQDL:3;
3806  uint32_t MSVRQCIE:1;
3807  uint32_t MIFSEL:1;
3808  uint32_t MSBFEPOL:1;
3809  uint32_t MDBFEPOL:1;
3810  } B;
3811  } MCR;
3812
3813  union { /* MLB Blank Register */
3814  uint32_t R;
3815  struct {
3816  uint32_t:31;
3817  uint32_t BLANK:1;
3818  } B;
3819  } MBR;
3820
3821  union { /* MLB Status Register */
3822  uint32_t R;
3823  struct {
3824  uint32_t:29;
3825  uint32_t MDATRQS:1;
3826  uint32_t MSYSS:1;
3827  uint32_t MSVRQS:1;
3828  } B;
3829  } MSR;
3830
3831  union { /* RX Control Channel Address Register */
3832  uint32_t R;
3833  struct {
3834  uint32_t RXCCHA_ACEN:1;
3835  uint32_t:25;
3836  uint32_t RXCCHA:5;
3837  uint32_t:1;
3838  } B;
3839  } RXCCHAR;
3840
3841  union { /* RX Async Channel Address Register */
3842  uint32_t R;
3843  struct {
3844  uint32_t RXACHA_ACEN:1;
3845  uint32_t:25;
3846  uint32_t RXACHA:5;
3847  uint32_t:1;
3848  } B;
3849  } RXACHAR;
3850
3851  union { /* TX Control Channel Address Register */
3852  uint32_t R;
3853  struct {
3854  uint32_t TXCCHA_ACEN:1;
3855  uint32_t:25;
3856  uint32_t TXCCHA:5;
3857  uint32_t:1;
3858  } B;
3859  } TXCCHAR;
3860
3861  union { /* TX Async Channel Address Register */
3862  uint32_t R;
3863  struct {
3864  uint32_t TXACHA_ACEN:1;
3865  uint32_t:25;
3866  uint32_t TXACHA:5;
3867  uint32_t:1;
3868  } B;
3869  } TXACHAR;
3870
3871  union { /* TX Sync Channel Address Register */
3872  uint32_t R;
3873  struct {
3874  uint32_t TXSCHA_ACEN:1;
3875  uint32_t:25;
3876  uint32_t TXSCHA:5;
3877  uint32_t:1;
3878  } B;
3879  } TXSCHAR;
3880
3881  union { /* TX Sync Channel Address Mask Register */
3882  uint32_t R;
3883  struct {
3884  uint32_t:26;
3885  uint32_t TXSCHAM:5;
3886  uint32_t:1;
3887  } B;
3888  } TXSCHAMR;
3889
3890  union { /* Clock Adjust Control Register */
3891  uint32_t R;
3892  struct {
3893  uint32_t:16;
3894  uint32_t PDLY:16;
3895  } B;
3896  } CLKACR;
3897
3898  union { /* RX Isochronous Channel Address Register */
3899  uint32_t R;
3900  struct {
3901  uint32_t RXICHA_ACEN:1;
3902  uint32_t:25;
3903  uint32_t RXICHA:5;
3904  uint32_t:1;
3905  } B;
3906  } RXICHAR;
3907
3908  union { /* TX Isochronous Channel Address Register */
3909  uint32_t R;
3910  struct {
3911  uint32_t TXICHA_ACEN:1;
3912  uint32_t:25;
3913  uint32_t TXICHA:5;
3914  uint32_t:1;
3915  } B;
3916  } TXICHAR;
3917
3918  };
3919
3920 /* Define memories */
3921
3922 #define SRAM_START 0x40000000UL
3923 #define SRAM_SIZE 0x14000UL
3924 #define SRAM_END 0x40013FFFUL
3925
3926 #define FLASH_START 0x0UL
3927 #define FLASH_SIZE 0x180000UL
3928 #define FLASH_END 0x17FFFFUL
3929
3930 /* Define instances of modules */
3931 #define SEMA4 (*(volatile struct SEMA4_tag *) 0xFFF10000UL)
3932 #define MPU (*(volatile struct MPU_tag *) 0xFFF14000UL)
3933 #define MCM (*(volatile struct MCM_tag *) 0xFFF40000UL)
3934 #define EDMA (*(volatile struct EDMA_tag *) 0xFFF44000UL)
3935 #define INTC (*(volatile struct INTC_tag *) 0xFFF48000UL)
3936 #define EQADC (*(volatile struct EQADC_tag *) 0xFFF80000UL)
3937 #define MLB (*(volatile struct MLB_tag *) 0xFFF84000UL)
3938 #define I2C (*(volatile struct I2C_tag *) 0xFFF88000UL)
3939 #define DSPI_A (*(volatile struct DSPI_tag *) 0xFFF90000UL)
3940 #define DSPI_B (*(volatile struct DSPI_tag *) 0xFFF94000UL)
3941 #define DSPI_C (*(volatile struct DSPI_tag *) 0xFFF98000UL)
3942 #define DSPI_D (*(volatile struct DSPI_tag *) 0xFFF9C000UL)
3943 #define ESCI_A (*(volatile struct ESCI_tag *) 0xFFFA0000UL)
3944 #define ESCI_B (*(volatile struct ESCI_tag *) 0xFFFA4000UL)
3945 #define ESCI_C (*(volatile struct ESCI_tag *) 0xFFFA8000UL)
3946 #define ESCI_D (*(volatile struct ESCI_tag *) 0xFFFAC000UL)
3947 #define ESCI_E (*(volatile struct ESCI_tag *) 0xFFFB0000UL)
3948 #define ESCI_F (*(volatile struct ESCI_tag *) 0xFFFB4000UL)
3949 #define ESCI_G (*(volatile struct ESCI_tag *) 0xFFFB8000UL)
3950 #define ESCI_H (*(volatile struct ESCI_tag *) 0xFFFBC000UL)
3951 #define CAN_A (*(volatile struct FLEXCAN_tag *) 0xFFFC0000UL)
3952 #define CAN_B (*(volatile struct FLEXCAN_tag *) 0xFFFC4000UL)
3953 #define CAN_C (*(volatile struct FLEXCAN_tag *) 0xFFFC8000UL)
3954 #define CAN_D (*(volatile struct FLEXCAN_tag *) 0xFFFCC000UL)
3955 #define CAN_E (*(volatile struct FLEXCAN_tag *) 0xFFFD0000UL)
3956 #define CAN_F (*(volatile struct FLEXCAN_tag *) 0xFFFD4000UL)
3957 #define FR (*(volatile struct FR_tag *) 0xFFFD8000UL)
3958 #define DMAMUX (*(volatile struct DMAMUX_tag *) 0xFFFDC000UL)
3959 #define PIT (*(volatile struct PIT_tag *) 0xFFFE0000UL)
3960 #define EMIOS (*(volatile struct EMIOS_tag *) 0xFFFE4000UL)
3961 #define SIU (*(volatile struct SIU_tag *) 0xFFFE8000UL)
3962 #define CRP (*(volatile struct CRP_tag *) 0xFFFEC000UL)
3963 #define FMPLL (*(volatile struct FMPLL_tag *) 0xFFFF0000UL)
3964 #define EBI (*(volatile struct EBI_tag *) 0xFFFF4000UL)
3965 #define FLASH (*(volatile struct FLASH_tag *) 0xFFFF8000UL)
3966
3967 #ifdef __MWERKS__
3968 #pragma pop
3969 #endif
3970
3971 #ifdef __cplusplus
3972 }
3973 #endif
3974 #endif /* ASM */
3975 #endif /* ifdef _MPC5510_H */
3976 /*********************************************************************
3977  *
3978  * Copyright:
3979  * Freescale Semiconductor, INC. All Rights Reserved.
3980  * You are hereby granted a copyright license to use, modify, and
3981  * distribute the SOFTWARE so long as this entire notice is
3982  * retained without alteration in any modified and/or redistributed
3983  * versions, and that such modified versions are clearly identified
3984  * as such. No licenses are granted by implication, estoppel or
3985  * otherwise under any patents or trademarks of Freescale
3986  * Semiconductor, Inc. This software is provided on an "AS IS"
3987  * basis and without warranty.
3988  *
3989  * To the maximum extent permitted by applicable law, Freescale
3990  * Semiconductor DISCLAIMS ALL WARRANTIES WHETHER EXPRESS OR IMPLIED,
3991  * INCLUDING IMPLIED WARRANTIES OF MERCHANTABILITY OR FITNESS FOR A
3992  * PARTICULAR PURPOSE AND ANY WARRANTY AGAINST INFRINGEMENT WITH
3993  * REGARD TO THE SOFTWARE (INCLUDING ANY MODIFIED VERSIONS THEREOF)
3994  * AND ANY ACCOMPANYING WRITTEN MATERIALS.
3995  *
3996  * To the maximum extent permitted by applicable law, IN NO EVENT
3997  * SHALL Freescale Semiconductor BE LIABLE FOR ANY DAMAGES WHATSOEVER
3998  * (INCLUDING WITHOUT LIMITATION, DAMAGES FOR LOSS OF BUSINESS PROFITS,
3999  * BUSINESS INTERRUPTION, LOSS OF BUSINESS INFORMATION, OR OTHER
4000  * PECUNIARY LOSS) ARISING OF THE USE OR INABILITY TO USE THE SOFTWARE.
4001  *
4002  * Freescale Semiconductor assumes no responsibility for the
4003  * maintenance and support of this software
4004  *
4005  ********************************************************************/
Definition: fsl-mpc551x.h:3093
Definition: fsl-mpc551x.h:3552
Definition: fsl-mpc551x.h:3182
Definition: fsl-mpc551x.h:2460
Definition: fsl-mpc551x.h:3576
Definition: fsl-mpc551x.h:1488
Definition: fsl-mpc551x.h:3295
Definition: fsl-mpc551x.h:3612
Definition: fsl-mpc551x.h:3570
Definition: fsl-mpc551x.h:3418
Definition: fsl-mpc551x.h:3213
Definition: fsl-mpc551x.h:3603
Definition: fsl-mpc551x.h:484
Definition: fsl-mpc551x.h:2294
Definition: fsl-mpc551x.h:3355
Definition: fsl-mpc551x.h:2884
Definition: fsl-mpc551x.h:2922
Definition: fsl-mpc551x.h:3609
Definition: fsl-mpc551x.h:667
Definition: fsl-mpc551x.h:899
Definition: fsl-mpc551x.h:362
Definition: fsl-mpc551x.h:3567
Definition: fsl-mpc551x.h:3134
Definition: fsl-mpc551x.h:3588
Definition: fsl-mpc551x.h:3069
Definition: fsl-mpc551x.h:3202
Definition: fsl-mpc551x.h:3457
Definition: fsl-mpc551x.h:3123
Definition: fsl-mpc551x.h:1438
Definition: fsl-mpc551x.h:3261
Definition: fsl-mpc551x.h:3546
Definition: fsl-mpc551x.h:230
Definition: fsl-mpc551x.h:3244
Definition: fsl-mpc551x.h:3597
Definition: fsl-mpc551x.h:3540
Definition: fsl-mpc551x.h:447
Definition: fsl-mpc551x.h:1484
Definition: fsl-mpc551x.h:3000
Definition: fsl-mpc551x.h:3401
Definition: fsl-mpc551x.h:3600
Definition: fsl-mpc551x.h:245
Definition: fsl-mpc551x.h:3473
Definition: fsl-mpc551x.h:532
Definition: fsl-mpc551x.h:3741
Definition: fsl-mpc551x.h:303
Definition: fsl-mpc551x.h:3287
Definition: fsl-mpc551x.h:2352
Definition: fsl-mpc551x.h:2960
Definition: fsl-mpc551x.h:3594
Definition: fsl-mpc551x.h:3425
Definition: fsl-mpc551x.h:2781
Definition: fsl-mpc551x.h:3362
Definition: fsl-mpc551x.h:2842
Definition: fsl-mpc551x.h:3606
Definition: fsl-mpc551x.h:3313
Definition: fsl-mpc551x.h:3150
Definition: fsl-mpc551x.h:3171
Definition: fsl-mpc551x.h:924
Definition: fsl-mpc551x.h:3622
Definition: fsl-mpc551x.h:3615
Definition: fsl-mpc551x.h:2425
Definition: fsl-mpc551x.h:3534
Definition: fsl-mpc551x.h:3370
Definition: fsl-mpc551x.h:3582
Definition: fsl-mpc551x.h:3252
Definition: fsl-mpc551x.h:344
Definition: fsl-mpc551x.h:716
Definition: fsl-mpc551x.h:3236
Definition: fsl-mpc551x.h:3018
Definition: fsl-mpc551x.h:3555
Definition: fsl-mpc551x.h:3531
Definition: fsl-mpc551x.h:2987
Definition: fsl-mpc551x.h:3409
Definition: fsl-mpc551x.h:1517
Definition: fsl-mpc551x.h:2269
Definition: fsl-mpc551x.h:2796
Definition: fsl-mpc551x.h:2939
Definition: fsl-mpc551x.h:244
Definition: fsl-mpc551x.h:3465
Definition: fsl-mpc551x.h:3481
Definition: fsl-mpc551x.h:3339
Definition: fsl-mpc551x.h:956
Definition: fsl-mpc551x.h:2807
Definition: fsl-mpc551x.h:2087
Definition: fsl-mpc551x.h:3564
Definition: fsl-mpc551x.h:3377
Definition: fsl-mpc551x.h:3193
Definition: fsl-mpc551x.h:3278
Definition: fsl-mpc551x.h:2221
Definition: fsl-mpc551x.h:3528
Definition: fsl-mpc551x.h:3434
Definition: fsl-mpc551x.h:3037
Definition: fsl-mpc551x.h:483
Definition: fsl-mpc551x.h:2375
Definition: fsl-mpc551x.h:3051
Definition: fsl-mpc551x.h:3549
Definition: fsl-mpc551x.h:3112
Definition: fsl-mpc551x.h:3322
Definition: fsl-mpc551x.h:3304
Definition: fsl-mpc551x.h:900
Definition: fsl-mpc551x.h:2400
Definition: fsl-mpc551x.h:1539
Definition: fsl-mpc551x.h:642
Definition: fsl-mpc551x.h:2317
Definition: fsl-mpc551x.h:3573
Definition: fsl-mpc551x.h:1079
Definition: fsl-mpc551x.h:3347
Definition: fsl-mpc551x.h:3585
Definition: fsl-mpc551x.h:2817
Definition: fsl-mpc551x.h:3537
Definition: fsl-mpc551x.h:2863
Definition: fsl-mpc551x.h:2901
Definition: fsl-mpc551x.h:3543
Definition: fsl-mpc551x.h:3228
Definition: fsl-mpc551x.h:3591
Definition: fsl-mpc551x.h:2971
Definition: fsl-mpc551x.h:1505
Definition: fsl-mpc551x.h:3723
Definition: fsl-mpc551x.h:3561
Definition: fsl-mpc551x.h:3579
Definition: fsl-mpc551x.h:946
Definition: fsl-mpc551x.h:1603
Definition: fsl-mpc551x.h:3269
Definition: fsl-mpc551x.h:2773
Definition: fsl-mpc551x.h:1171
Definition: fsl-mpc551x.h:3441
Definition: fsl-mpc551x.h:691
Definition: fsl-mpc551x.h:2828
Definition: fsl-mpc551x.h:73
Definition: fsl-mpc551x.h:1027
Definition: fsl-mpc551x.h:1692
Definition: fsl-mpc551x.h:3393
Definition: fsl-mpc551x.h:3791
Definition: fsl-mpc551x.h:3331
Definition: fsl-mpc551x.h:1843
Definition: fsl-mpc551x.h:479
Definition: fsl-mpc551x.h:3618
Definition: fsl-mpc551x.h:1070
Definition: fsl-mpc551x.h:3085
Definition: fsl-mpc551x.h:1991
Definition: fsl-mpc551x.h:3782
Definition: fsl-mpc551x.h:3450
Definition: fsl-mpc551x.h:1057
Definition: fsl-mpc551x.h:3558
Definition: fsl-mpc551x.h:3059
Definition: fsl-mpc551x.h:3385
Definition: fsl-mpc551x.h:531
