RTEMS  5.1
flashPgm.h
1 #ifndef BSP_FLASH_PGM_API_H
2 #define BSP_FLASH_PGM_API_H
3
4 /* Trivial Flash Programmer */
5
6 /* Author: Till Straumann <strauman@slac.stanford.edu>, 2006
7  * NOTE: copyright info at the bottom of this file
8  */
9
10 /* IMPORTANT NOTE
11  *
12  * The flash API is NOT THREAD SAFE. During the execution of any of the
13  * BSP_flashXXX() routines, flash (residing in the same device)
14  * MUST NOT be accessed by other threads in ANY way (NOT EVEN READ!).
15  * Read operations may return internal device register contents
16  * instead of memory array data when issued while a flash device
17  * is erased, written or queried by the library.
18  *
19  * The routines are intended for occasional maintenance use only
20  * (i.e., not for implementing a file system or similar).
21  *
22  * While polling for the completion of block erase operations the
23  * CPU is yielded to other threads. Busy waiting (interrupts and
24  * thread dispatching remain enabled) on write operations is employed.
25  */
26
27 #include <stdio.h>
28
29 #ifdef __cplusplus
30  extern "C" {
31 #endif
32
33 /* Disengage flash write protection. Write protection is implemented
34  * at the board or chipset level by disabling all write operations/bus cycles
35  * to the flash device(s).
36  * With write protection enabled, nothing but 'ordinary' (array) read operations
37  * are possible.
38  * Write protection must be disabled not only to erase and write contents
39  * but also in order to read ID, size, status etc.
40  * None of the operations (except for BSP_flashWriteEnable()) are possible
41  * on a write-protected device.
42  *
43  * 'bank': flash bank # (usually 0)
44  * RETURNS: 0 on success, nonzero on error (printing message to stderr).
45  *
46  * NOTES: - some boards (MVME5500) don't support 'bank' granularity but
47  * enable/disable write protection for all devices at once.
48  * - a jumper-based protection mechanism might be in place
49  * in addition to the software-based one. Consult the user's
50  * manual of your board for more information.
51  */
52 int
53 BSP_flashWriteEnable(int bank);
54
55 /* Engage flash write protection (see above)
56  */
57 int
58 BSP_flashWriteDisable(int bank);
59
60 /* Erase a region of flash memory.
61  * 'bank': flash bank # (usually 0).
62  * 'offset': destination address offset (from start of bank).
63  * 'size': number of bytes to erase.
64  * 'quiet': if non-zero, suppress confirmation message / prompt
65  * if > 1 also suppress the progress indicator.
66  *
67  * RETURNS: 0 on success, nonzero on error (printing messages to stderr).
68  *
69  * NOTES: - 'offset' and 'size' must be block-aligned. Common 16-bit devices
70  * have a block size of 0x20000 bytes. If two such devices are
71  * operated in parallel to form a 32-bit word then the 'effective'
72  * block size is 0x40000 bytes. The block size can be queried by
73  * BSP_flashBlockSize(int bank);
74  *
75  * - erase operation is verified.
76  */
77 int
78 BSP_flashErase(int bank, uint32_t offset, uint32_t size, int quiet);
79
80 /* Write data from a buffer to flash. The target area is erased if necessary.
81  *
82  * 'bank': flash bank # (usually 0).
83  * 'offset': destination address offset (from start of bank).
84  * 'src': data source block address (in memory).
85  *'n_bytes': number of bytes to copy.
86  * 'quiet': if non-zero, suppress confirmation message / prompt
87  * if > 1 also suppress the progress indicator.
88  *
89  * NOTES: - Erase operations are only performed where necessary. I.e.,
90  * if one or both of the boundaries of the destination region is/are
91  * not block-aligned then adjacent data are preserved provided that
92  * the relevant chunks of the destination are blank (erased).
93  *
94  * | <neighbour> fffffff |
95  * ^--- destination ----- ^
96  * | : block boundary
97  * f : blank/erased pieces
98  *
99  * (If the start of the destination region up to the next block boundary
100  * is blank then '<neighbour>'-data is preserved. The end of the
101  * destination is treated the same way.)
102  *
103  * - user confirmation is requested before changes are made
104  *
105  * - 'src' must not point into the destination bank (no copy
106  * within a flash bank).
107  *
108  * - erase and write operations are verified.
109  *
110  * RETURNS: 0 on success, nonzero on error (message printed to stderr).
111  */
112 int
113 BSP_flashWrite(int bank, uint32_t offset, const char *src, uint32_t n_bytes, int quiet);
114
115 /* Copy contents of a file to flash.
116  *
117  * 'fname': Path of a file.
118  * 'quiet': if non-zero, suppress confirmation message / prompt
119  * if > 1 also suppress the progress indicator.
120  *
121  * NOTES: Convenience wrapper around BSP_flashWrite(); see above for
122  * args and return value.
123  */
124 int
125 BSP_flashWriteFile(int bank, uint32_t offset, const char *path, int quiet);
126
127 /* Dump info about available flash to file
128  * (stdout is used if f==NULL).
129  *
130  * RETURNS: 0
131  * NOTES: Write protection must be disengaged (see above);
132  */
133 int
134 BSP_flashDumpInfo(FILE *f);
135
136 /*
137  * Obtain starting-address of flash bank (as seen from CPU)
138  * (returns ((uint32_t) -1) if the bank argument is invalid).
139  */
140
141 uint32_t
142 BSP_flashStart(int bank);
143
144 /*
145  * Obtain size of flash bank (returns ((uint32_t) -1) if the
146  * bank argument is invalid).
147  */
148 uint32_t
149 BSP_flashSize(int bank);
150
151 /*
152  * Obtain block size of flash bank (sector size times
153  * number of devices in parallel; the block size determines
154  * alignment and granularity accepted by BSP_flashErase()
155  * (returns ((uint32_t) -1) if the bank argument is invalid).
156  */
157 uint32_t
158 BSP_flashBlockSize(int bank);
159
160 #ifdef __cplusplus
161  }
162 #endif
163
164 /*
165  * Authorship
166  * ----------
167  * This software was created by
168  * Till Straumann <strauman@slac.stanford.edu>, 2005-2007,
169  * Stanford Linear Accelerator Center, Stanford University.
170  *
171  * Acknowledgement of sponsorship
172  * ------------------------------
173  * The software was produced by
174  * the Stanford Linear Accelerator Center, Stanford University,
175  * under Contract DE-AC03-76SFO0515 with the Department of Energy.
176  *
177  * Government disclaimer of liability
178  * ----------------------------------
179  * Neither the United States nor the United States Department of Energy,
180  * nor any of their employees, makes any warranty, express or implied, or
181  * assumes any legal liability or responsibility for the accuracy,
182  * completeness, or usefulness of any data, apparatus, product, or process
183  * disclosed, or represents that its use would not infringe privately owned
184  * rights.
185  *
186  * Stanford disclaimer of liability
187  * --------------------------------
188  * Stanford University makes no representations or warranties, express or
189  * implied, nor assumes any liability for the use of this software.
190  *
191  * Stanford disclaimer of copyright
192  * --------------------------------
193  * Stanford University, owner of the copyright, hereby disclaims its
194  * copyright and all other rights in this software. Hence, anyone may
195  * freely use it for any purpose without restriction.
196  *
197  * Maintenance of notices
198  * ----------------------
199  * In the interest of clarity regarding the origin and status of this
200  * SLAC software, this and all the preceding Stanford University notices
201  * are to remain affixed to any copy or derivative of this software made
202  * or distributed by the recipient and are to be affixed to any copy of
203  * software made or distributed by the recipient that contains a copy or
204  * derivative of this software.
205  *
206  * ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
207  */
208
209 #endif
unsigned size
Definition: tte.h:74
