RTEMS  5.1
flashPgmPvt.h
1 #ifndef FLASH_GLUE_INTERFACE_H
2 #define FLASH_GLUE_INTERFACE_H
3
4
5 /* Trivial flash programmer (for restrictions see below) */
6
7 /* Author: Till Straumann <strauman@slac.stanford.edu>, 2006 */
8
9 /* DO NOT INCLUDE THIS HEADER FROM APPLICATION CODE */
10
11 /*
12  * Glue interface -- to be used only internally by BSP
13  * and chip drivers:
14  * - BSP provides info about what chip drivers to use
15  * as well as 'wiring' info (how many devices are
16  * operated in parallel etc).
17  * - Chip drivers provide low-level 'methods' / 'ops'
18  * for performing basic operations which are used
19  * by the code in 'flash.c'.
20  */
21
22 /* To keep things simple, this API makes a few assumptions about the
23  * hardware:
24  *
25  * - devices operate with 16-bit data width
26  * - two devices are used in parallel (stride 4) to
27  * provide 32-bit data. I.e., the devices are
28  * organized like this:
29  * unsigned short flash[FLASH_SIZE][2];
30  * - no endianness issues (i.e., flash endianness == CPU endianness)
31  * - fixed block size
32  * - fixed buffer size
33  * - all devices in a bank are identical
34  * - NOT THREAD SAFE; no locking scheme is implemented.
35  * - cannot copy within same flash bank.
36  * - write-timeout uses polling/busy-wait
37  *
38  * FIXME: code should be revised to remove assumptions on stride and 16-bit
39  * width to make it more generic.
40  */
41
42 /*
43  * Authorship
44  * ----------
45  * This software was created by
46  * Till Straumann <strauman@slac.stanford.edu>, 2005-2007,
47  * Stanford Linear Accelerator Center, Stanford University.
48  *
49  * Acknowledgement of sponsorship
50  * ------------------------------
51  * The software was produced by
52  * the Stanford Linear Accelerator Center, Stanford University,
53  * under Contract DE-AC03-76SFO0515 with the Department of Energy.
54  *
55  * Government disclaimer of liability
56  * ----------------------------------
57  * Neither the United States nor the United States Department of Energy,
58  * nor any of their employees, makes any warranty, express or implied, or
59  * assumes any legal liability or responsibility for the accuracy,
60  * completeness, or usefulness of any data, apparatus, product, or process
61  * disclosed, or represents that its use would not infringe privately owned
62  * rights.
63  *
64  * Stanford disclaimer of liability
65  * --------------------------------
66  * Stanford University makes no representations or warranties, express or
67  * implied, nor assumes any liability for the use of this software.
68  *
69  * Stanford disclaimer of copyright
70  * --------------------------------
71  * Stanford University, owner of the copyright, hereby disclaims its
72  * copyright and all other rights in this software. Hence, anyone may
73  * freely use it for any purpose without restriction.
74  *
75  * Maintenance of notices
76  * ----------------------
77  * In the interest of clarity regarding the origin and status of this
78  * SLAC software, this and all the preceding Stanford University notices
79  * are to remain affixed to any copy or derivative of this software made
80  * or distributed by the recipient and are to be affixed to any copy of
81  * software made or distributed by the recipient that contains a copy or
82  * derivative of this software.
83  *
84  * ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
85  */
86
87 #include <stdint.h>
88
89 #define NumberOf(arr) (sizeof(arr)/sizeof(arr[0]))
90
91 #define FLASH_STRIDE(b) 4 /* bytes; currently fixed */
92 #define FLASH_WIDTH(b) ((b)->width)
93 #define FLASH_NDEVS(b) (FLASH_STRIDE(b)/FLASH_WIDTH(b))
94
95 /* Type declarations */
96
97 /* Registers */
98 typedef uint8_t _u8_a_t __attribute__((may_alias));
99 typedef uint16_t _u16_a_t __attribute__((may_alias));
100 typedef uint32_t _u32_a_t __attribute__((may_alias));
101
102 /* Register addresses */
103 typedef volatile _u8_a_t *A8;
104 typedef volatile _u16_a_t *A16;
105 typedef volatile _u32_a_t *A32;
106
107 struct flash_bank_ops;
108
109 /*
110  * Description of a flash bank. Multiple
111  * devices that are used in parallel to
112  * make up words of FLASH_STRIDE bytes
113  * are a 'physical' bank.
114  *
115  * A bank can even be a 'logical' bank
116  * if it includes chip-select logic, i.e.,
117  * int can contain multiple adjacent
118  * 'physical' banks
119  *
120  * The BSP must provide an array of 'bankdesc'
121  * structs and it must initialize the fields
122  *
123  * 'start'
124  * size of bank; may be set to zero to instruct
125  * the driver to scan a bank of 'max_size' for
126  * devices (i.e., bank may not be fully populated)
127  * 'max_size'
128  * size of fully populated bank (defines address range
129  * that is scanned for devices).
130  * If 'max_size' is negative then scanning starts from
131  * the top rather than from the bottom.
132  * 'width'
133  * width of a single device (in bytes). E.g., if
134  * 2 16-bit devices are used to form a (ATM fixed)
135  * stride of 4 then 'width = 2'. If four 8-bit
136  * devices are employed then 'width=1'.
137  * 'knownVendors'
138  * array of vendors descriptions to use for scanning
139  * the bank.
140  *
141  */
142 struct bankdesc {
143  uint32_t start; /* start of bank (CPU address) */
144  uint32_t size; /* in bytes (figured out automatically) */
145  int max_size; /* in case multiple banks are adjacent;
146  * if max_size < 0 then the bank is scanned
147  * backwards (from top->bottom) for devices
148  */
149  int width; /* FIXME there might be implicit assumptions still
150  * that width == 2
151  */
152  struct vendesc *knownVendors;
153  /* TODO: we assume identical devices within a bank... */
154
155  /* The next three variables cache information obtained
156  * from the applicable vendor and device descriptions.
157  * They are written by BSP_flashCheckId().
158  */
159  uint32_t fblksz; /* block size in bytes; includes counting
160  * parallel 16-bit devices, i.e., if a
161  * single device has a block-size of xxx
162  * then fblksz = xxx*ndevs.
163  */
164  struct devdesc *dd;
165  struct flash_bank_ops *ops;
166 };
167
168 struct devdesc {
169  uint32_t id; /* numerical ID (matched against
170  * ID read from device).
171  */
172  char *name; /* informational name */
173  uint32_t size; /* bytes */
174  uint32_t bufsz; /* size of write buffer (bytes) */
175  uint32_t fblksz; /* sector/block size (bytes) */
176 };
177
178 struct vendesc {
179  uint32_t id; /* numerical ID (matched against
180  * ID read from device).
181  */
182  char *name; /* informational name */
183
184  /* array of supported devices;
185  * the 'ops' specified below
186  * are used to access these devices
187  */
188  struct devdesc *known_devs;
189  /* access methods for talking to
190  * devices associated with this
191  * vendor description.
192  */
193  struct flash_bank_ops *ops;
194 };
195
196 /* Device Access Methods ('ops'); these must be
197  * implemented by low-level chip drivers
198  */
199
201 /* Read vendor/device ID; Return 0 on success, nonzero if unable to read id */
202  int (*get_id)(struct bankdesc *b, uint32_t addr, uint32_t *pVendorId, uint32_t *pDeviceId);
203 /* Unlock block holding 'addr'ess
204  *
205  * NOTES: - device switched back to array mode on exit.
206  * - 'addr' must be 32-bit aligned.
207  */
208
209  void (*unlock_block)(struct bankdesc *b, uint32_t addr);
210 /* Lock block holding 'addr'ess
211  *
212  * NOTES: - device switched back to array mode on exit.
213  * - 'addr' must be 32-bit aligned.
214  */
215
216  void (*lock_block)(struct bankdesc *b, uint32_t addr);
217 /* Erase single block holding 'addr'ess. The routine may
218  * assume that the address is block/sector aligned.
219  *
220  * RETURNS: zero on error, device status on failure.
221  *
222  * NOTES: - device switched back to array mode on exit.
223  * - 'addr' must be 32-bit aligned.
224  */
225  int (*erase_block)(struct bankdesc *b, uint32_t addr);
226 /* Query the status of the device and assert it's readiness
227  * leave off in array-reading mode.
228  *
229  * RETURNS: 0 on success, error status (result of status query) on error.
230  *
231  * NOTES: - error message is printed to stderr.
232  * - device switched back to array mode on exit.
233  * - 'addr' must be 32-bit aligned.
234  */
235  uint32_t (*check_ready)(struct bankdesc *b, uint32_t addr);
236 /* Dump status bits (F_CMD_RD_STA results);
237  * 'verbose' prints non-error bits, too
238  */
239  void (*print_stat)(struct bankdesc *b, uint32_t sta, int verbose);
240 /* Switch to array mode; 'addr' can be assumed to be stride-aligned */
241  void (*array_mode)(struct bankdesc *b, uint32_t addr);
242 /* Write N bytes from 'src' to flash:
243  * 'src[0] .. src[N-1]' -> addr[0]..addr[N-1].
244  * N may be assumed to be a multiple of 'stride'
245  * RETURNS: failure status or zero on success.
246  */
247  uint32_t (*write_line)(struct bankdesc *b, uint32_t addr, const char *src, uint32_t N);
248 };
249
250 /* BSP ops (detect banks, handle write-protection on board);
251  * these must be implemented by the BSP.
252  */
253
255 /* Return descriptor for bank # 'bank' or NULL (invalid arg) */
256  struct bankdesc *(*bankcheck)(int bank, int quiet);
257 /* set (enbl:1), clear (enbl:0) or query (enbl:-1)
258  * on-board write protection.
259  *
260  * RETURNS 0 on success, nonzero on error.
261  */
262  int (*flash_wp)(int bank, int enbl);
263 /* read a running us clock (for polling timeout) */
264  uint32_t (*read_us_timer)(void);
265 };
266
267 /* This must be provided by the BSP */
268 extern struct flash_bsp_ops BSP_flashBspOps;
269
270 /* Available low-level flash drivers, so far */
271 extern struct vendesc BSP_flash_vendor_intel[];
272 extern struct vendesc BSP_flash_vendor_spansion[];
273
274 #endif
Definition: flashPgmPvt.h:142
Definition: flashPgmPvt.h:200
typedef __attribute__
Disable IRQ Interrupts.
Definition: cmsis_gcc.h:69
Definition: flashPgmPvt.h:168
Definition: flashPgmPvt.h:254
Definition: flashPgmPvt.h:178
