RTEMS  5.1
e500_mmu.h
1 #ifndef RTEMS_E500_MMU_DRIVER_H
2 #define RTEMS_E500_MMU_DRIVER_H
3
4 /*
5  * Routines to manipulate e500 TLBs; TLB0 (fixed 4k page size)
6  * is not very useful so we mostly focus on TLB1 (variable page size)
7  */
8
9 /*
10  * Authorship
11  * ----------
12  * This software was created by
13  * Till Straumann <strauman@slac.stanford.edu>, 2005-2007,
14  * Stanford Linear Accelerator Center, Stanford University.
15  *
16  * Acknowledgement of sponsorship
17  * ------------------------------
18  * This software was produced by
19  * the Stanford Linear Accelerator Center, Stanford University,
20  * under Contract DE-AC03-76SFO0515 with the Department of Energy.
21  *
22  * Government disclaimer of liability
23  * ----------------------------------
24  * Neither the United States nor the United States Department of Energy,
25  * nor any of their employees, makes any warranty, express or implied, or
26  * assumes any legal liability or responsibility for the accuracy,
27  * completeness, or usefulness of any data, apparatus, product, or process
28  * disclosed, or represents that its use would not infringe privately owned
29  * rights.
30  *
31  * Stanford disclaimer of liability
32  * --------------------------------
33  * Stanford University makes no representations or warranties, express or
34  * implied, nor assumes any liability for the use of this software.
35  *
36  * Stanford disclaimer of copyright
37  * --------------------------------
38  * Stanford University, owner of the copyright, hereby disclaims its
39  * copyright and all other rights in this software. Hence, anyone may
40  * freely use it for any purpose without restriction.
41  *
42  * Maintenance of notices
43  * ----------------------
44  * In the interest of clarity regarding the origin and status of this
45  * SLAC software, this and all the preceding Stanford University notices
46  * are to remain affixed to any copy or derivative of this software made
47  * or distributed by the recipient and are to be affixed to any copy of
48  * software made or distributed by the recipient that contains a copy or
49  * derivative of this software.
50  *
51  * ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
52  */
53
54 #include <rtems.h>
55 #include <inttypes.h>
56 #include <stdio.h>
57
58 #ifdef __cplusplus
59 extern "C" {
60 #endif
61
62 /* Some routines require or return a index 'key'. This
63  * is simply the TLB entry # ORed with E500_SELTLB_0
64  * or E500_SELTLB_1 specifying an entry in TLB0 or TLB1,
65  * respectively.
66  */
67 typedef int rtems_e500_tlb_idx;
68 #define E500_SELTLB_0 0x0000
69 #define E500_SELTLB_1 0x1000
70
71 /* Cache the relevant TLB1 entries so that we can
72  * make sure the user cannot create conflicting
73  * (overlapping) entries.
74  * Keep them public for informational purposes.
75  */
76 typedef struct {
77  struct {
78  uint32_t va_epn: 20;
79  uint32_t va_tid: 12;
80  } va;
81  uint32_t rpn;
82  struct {
83  uint32_t sz: 4;
84  uint32_t ts: 1;
85  uint32_t v: 1;
86  uint32_t perm: 10;
87  uint32_t wimge: 7;
88  } att;
90
91 extern E500_tlb_va_cache_t rtems_e500_tlb_va_cache[16];
92
93 /*
94  * Dump (cleartext) content info from cached TLB entries
95  * to a file (stdout if f==NULL).
96  */
97 void
98 rtems_e500_dmptlbc(FILE *f);
99
100 /*
101  * Read a TLB entry from the hardware; if it is a TLB1 entry
102  * then the current settings are stored in the
103  * rtems_e500_tlb_va_cache[] structure.
104  *
105  * The routine can perform this operation quietly or
106  * print information to a file.
107  *
108  * 'key': TLB entry index ORed with selector bit
109  * (E500_SELTLB_0 for TLB0, E500_SELTLB_1 for TLB1).
110  * 'quiet': perform operation silently (no info printed)
111  * if nonzero.
112  * 'f': open FILE where to print information. May be
113  * NULL in which case 'stdout' is used.
114  *
115  * RETURNS:
116  * 0: success; TLB entry is VALID
117  * +1: success but TLB entry is INVALID
118  * < 0: error (-1: invalid argument)
119  */
120 int
121 rtems_e500_prtlb(rtems_e500_tlb_idx key, int quiet, FILE *f);
122
123 /* Initialize cache; verify that TLB0 is unused;
124  *
125  * RETURNS: zero on success, nonzero on error (TLB0
126  * seems to be in use); in this case the
127  * driver will refuse to change TLB1 entries
128  * (other than disabling them).
129  */
130 int
131 rtems_e500_initlb(void);
132
133 /*
134  * Write TLB1 entry (can also be used to disable an entry).
135  *
136  * The routine checks against the cached data in
137  * rtems_e500_tlb_va[] to prevent the user from generating
138  * overlapping entries.
139  *
140  * 'idx': TLB 1 entry # to manipulate
141  * 'ea': Effective address (must be page aligned)
142  * 'pa': Physical address (must be page aligned)
143  * 'sz': Page size selector; page size is
144  * 1024 * 2^(2*sz) bytes.
145  * 'sz' may also be one of the following:
146  * - page size in bytes ( >= 1024 ); the selector
147  * value is then computed by this routine.
148  * However, 'sz' must be a valid page size
149  * or -1 will be returned.
150  * - a value < 0 to invalidate/disable the
151  * TLB entry.
152  * 'attr': Page attributes; ORed combination of WIMGE,
153  * PERMissions, TID and TS. Use ATTR_xxx macros
154  *
155  * RETURNS: 0 on success, nonzero on error:
156  *
157  * >0: requested mapping would overlap with
158  * existing mapping in other entry. Return
159  * value gives conflicting entry + 1; i.e.,
160  * if a value of 4 is returned then the request
161  * conflicts with existing mapping in entry 3.
162  * -1: invalid argument
163  * -3: driver not initialized (or initialization
164  * failed because TLB0 is in use).
165  * <0: other error
166  *
167  */
168 #define E500_TLB_ATTR_WIMGE(x) ((x)&0x7f) /* includes user bits */
169 #define E500_TLB_ATTR_WIMGE_GET(x) ((x)&0x7f)
170 #define E500_TLB_ATTR_TS (1<<7)
171 #define E500_TLB_ATTR_PERM(x) (((x)&0x3ff)<<8)
172 #define E500_TLB_ATTR_PERM_GET(x) (((x)>>8)&0x3ff)
173 #define E500_TLB_ATTR_TID(x) (((x)&0xfff)<<20)
174 #define E500_TLB_ATTR_TID_GET(x) (((x)>>20)&0xfff)
175
176 int
177 rtems_e500_wrtlb(int idx, uint32_t ea, uint32_t pa, int sz, uint32_t attr);
178
179 /*
180  * Check if a ts/tid/ea/sz mapping overlaps
181  * with an existing entry.
182  *
183  * ASSUMPTION: all TLB0 (fixed 4k pages) are invalid and always unused.
184  *
185  * NOTE: 'sz' is the 'logarithmic' size selector; the page size
186  * is 1024*2^(2*sz).
187  *
188  * RETURNS:
189  * >= 0: index of TLB1 entry that already provides a mapping
190  * which overlaps within the ea range.
191  * -1: SUCCESS (no conflicting entry found)
192  * <=-2: ERROR (invalid input)
193  */
194 int
195 rtems_e500_matchtlb(uint32_t ea, uint32_t tid, int ts, int sz);
196
197 /* Find TLB index that maps 'ea/as' combination
198  *
199  * RETURNS: index 'key'; i.e., the index number plus
200  * a bit (E500_SELTLB_1) which indicates whether
201  * the mapping was found in TLB0 (4k fixed page
202  * size) or in TLB1 (variable page size).
203  *
204  * On error (no mapping) -1 is returned.
205  */
206 rtems_e500_tlb_idx
207 rtems_e500_ftlb(uint32_t ea, int as);
208
209 /* Mark TLB entry as invalid ('disabled'). Unlike
210  * rtems_e500_wrtlb() with a negative size argument
211  * this routine also can disable TLB0 entries.
212  *
213  * 'key': TLB entry index ORed with selector bit
214  * (E500_SELTLB_0 for TLB0, E500_SELTLB_1 for TLB1).
215  *
216  * RETURNS: zero on success, nonzero on error (TLB
217  * unchanged).
218  *
219  * NOTE: If a TLB1 entry is disabled the associated
220  * entry in rtems_e500_va_cache[] is also
221  * marked as disabled.
222  */
223 int
224 rtems_e500_clrtlb(rtems_e500_tlb_idx key);
225
226 #ifdef __cplusplus
227 };
228 #endif
229
230 #endif
Provide printf() PRIxxx Constante Beyond Standards.
unsigned v
Definition: tte.h:73
Definition: e500_mmu.h:76
