RTEMS  5.1
dspi.h
1
9 /*
10  * Copyright (c) 2008
11  * Embedded Brains GmbH
12  * Obere Lagerstr. 30
13  * D-82178 Puchheim
14  * Germany
15  * rtems@embedded-brains.de
16  *
17  * The license and distribution terms for this file may be
18  * found in the file LICENSE in this distribution or at
19  * http://www.rtems.org/license/LICENSE.
20  */
21
28 #ifndef LIBCPU_POWERPC_MPC55XX_DSPI_H
29 #define LIBCPU_POWERPC_MPC55XX_DSPI_H
30
31 #include <rtems/libi2c.h>
32
33 #include <mpc55xx/edma.h>
34
35 #ifdef __cplusplus
36 extern "C" {
37 #endif /* __cplusplus */
38
39 struct DSPI_tag;
40
41 typedef struct {
43  rtems_id id;
45
49 typedef struct {
54
58  unsigned table_index;
59
65  unsigned bus_number;
66
70  volatile struct DSPI_tag *regs;
71
75  bool master;
76
80  union DSPI_PUSHR_tag push_data;
81
88
95
102
106  uint32_t idle_char;
107
111  uint32_t baud;
113
117 #define MPC55XX_DSPI_NUMBER 4
118
122 extern mpc55xx_dspi_bus_entry mpc55xx_dspi_bus_table [ /* MPC55XX_DSPI_NUMBER */ ];
123
124 #ifdef __cplusplus
125 }
126 #endif /* __cplusplus */
127
128 #endif /* LIBCPU_POWERPC_MPC55XX_DSPI_H */
Definition: dspi.h:41
uint32_t idle_char
Idle character transmitted in read only mode.
Definition: dspi.h:106
Definition: libi2c.h:162
volatile struct DSPI_tag * regs
Hardware registers.
Definition: dspi.h:70
rtems_libi2c_bus_t bus
Standard bus driver fields.
Definition: dspi.h:53
mpc55xx_dspi_edma_entry edma_receive
eDMA entry for receiving.
Definition: dspi.h:101
Definition: edma.h:160
uint32_t baud
Current baud.
Definition: dspi.h:111
mpc55xx_dspi_bus_entry mpc55xx_dspi_bus_table[]
Table with bus driver entries.
Definition: dspi.c:670
Definition: fsl-mpc564xL.h:16678
Index in the bus table: mpc55xx_dspi_bus_table.
Definition: dspi.h:58
Definition: fsl-mpc551x.h:244
mpc55xx_dspi_edma_entry edma_push
eDMA entry for push data generation.
Definition: dspi.h:94
bool master
Selects SPI master or slave mode.
Definition: dspi.h:75
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
Enhanced Direct Memory Access (eDMA).
LibI2C bus driver entry.
Definition: dspi.h:49
unsigned bus_number
Bus number (available after rtems_libi2c_register_bus()).
Definition: dspi.h:65
mpc55xx_dspi_edma_entry edma_transmit
eDMA entry for transmission.
Definition: dspi.h:87
Legacy I2C Library.
