RTEMS  5.1
start Directory Reference
file  bspgetworkarea.c
file  bspreset.c
 BSP reset.
file  bspstart.c
 BSP startup code.
file  edma.c
 Enhanced Direct Memory Access (eDMA).
file  emios.c
 Enhanced Modular Input Output Subsystem (eMIOS).
file  flash_support.c
 MPC55XX flash memory support.
file  get-system-clock.c
 System clock calculation.
file  idle-thread.c
 bsp_idle_thread() implementation.
file  irq.c
 Source file for MPC55XX interrupt support.
file  sd-card-init.c
 SD Card initialization code.
file  siu.c
 System Integration Unit Access (SIU).
file  start-clock.c
 Clock and FMPLL initialization code.
file  start-config-clock.c
 Clock and FMPLL configuration.
file  start-config-ebi-cs-cal.c
 EBI calibration chip-select configuration.
file  start-config-ebi-cs.c
 EBI chip-select configuration.
file  start-config-ebi.c
 EBI configuration.
file  start-config-mmu-early.c
 MMU early configuration.
file  start-config-mmu.c
 MMU configuration.
file  start-config-siu-pcr.c
 SIU PCR configuration.
file  start-early.c
 Early initialization code.
file  start-prologue.c
 Start prologue.
file  start-watchdog.c
 Watchdog initialization code.
