file | fat.c |
| Low-level Operations on a Volume with a DOSFS FAT filesystem.
file | fat.h [code] |
| Constants/Data Structures/Prototypes on a Volume with FAT Filesystem.
file | fat_fat_operations.c |
| General operations on File Allocation Table.
file | fat_fat_operations.h [code] |
| Constants/Data Structures/Prototypes for Files Allocation Table.
file | fat_file.c |
| General operations on "fat-file".
file | fat_file.h [code] |
| Constants/Data Structures/Prototypes for Operations on "fat-file".
file | msdos.h [code] |
| The MSDOS Filesystem Constants/Data Structures/Prototypes.
file | msdos_conv.c |
| MDOS Date Conversion.
file | msdos_conv_default.c |
| Default Converter.
file | msdos_conv_utf8.c |
| UTF-8 Converter.
file | msdos_create.c |
| Create a new MSDOS FileSystem node.
file | msdos_dir.c |
| MSDOS Directory Handlers Implementation.
file | msdos_eval.c |
| MSDOS Evaluation Routines.
file | msdos_file.c |
| MSDOS File Handlers Implementation.
file | msdos_format.c |
| RTEMS MSDOS Format Functionality.
file | msdos_free.c |
| Call Fat-File Close Routine.
file | msdos_fsunmount.c |
| Shut Down MSDOS FileSystem.
file | msdos_handlers_dir.c |
| Directory Handlers Table for MSDOS FileSystem.
file | msdos_handlers_file.c |
| File Operations Table for MSDOS FileSystem.
file | msdos_init.c |
| Init Routine for MSDOS.
file | msdos_initsupp.c |
| MSDOS Filesystem Initialization.
file | msdos_misc.c |
| Miscellaneous Routines Implementation for MSDOS FileSystem.
file | msdos_mknod.c |
| Routine for Node Creation in MSDOS Filesystem.
file | msdos_rename.c |
| Rename a MSDOS FileSystem Node.
file | msdos_rmnod.c |
| Remove Node from MSDOS Directory.
file | msdos_statvfs.c |
| Obtain MS-DOS filesystem information.
