RTEMS  5.1
crc.h
1 //==========================================================================
2 //
3 // crc.h
4 //
5 // Interface for the CRC algorithms.
6 //
7 //==========================================================================
8 // ####ECOSGPLCOPYRIGHTBEGIN####
9 // -------------------------------------------
10 // This file is part of eCos, the Embedded Configurable Operating System.
11 // Copyright (C) 2002, 2009 Free Software Foundation, Inc.
12 //
13 // eCos is free software; you can redistribute it and/or modify it under
14 // the terms of the GNU General Public License as published by the Free
15 // Software Foundation; either version 2 or (at your option) any later
16 // version.
17 //
18 // eCos is distributed in the hope that it will be useful, but WITHOUT
19 // ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
20 // FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License
21 // for more details.
22 //
23 // You should have received a copy of the GNU General Public License
24 // along with eCos; if not, write to the Free Software Foundation, Inc.,
25 // 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA.
26 //
27 // As a special exception, if other files instantiate templates or use
28 // macros or inline functions from this file, or you compile this file
29 // and link it with other works to produce a work based on this file,
30 // this file does not by itself cause the resulting work to be covered by
31 // the GNU General Public License. However the source code for this file
32 // must still be made available in accordance with section (3) of the GNU
33 // General Public License v2.
34 //
35 // This exception does not invalidate any other reasons why a work based
36 // on this file might be covered by the GNU General Public License.
37 // -------------------------------------------
38 // ####ECOSGPLCOPYRIGHTEND####
39 //==========================================================================
40 //#####DESCRIPTIONBEGIN####
41 //
42 // Author(s): Andrew Lunn
43 // Contributors: Andrew Lunn
44 // Date: 2002-08-06
45 // Purpose:
46 // Description:
47 //
48 // This code is part of eCos (tm).
49 //
50 //####DESCRIPTIONEND####
51 //
52 //==========================================================================
53
54 #ifndef _SERVICES_CRC_CRC_H_
55 #define _SERVICES_CRC_CRC_H_
56
57 #include <cyg/infra/cyg_type.h>
58
59 #ifndef __externC
60 # ifdef __cplusplus
61 # define __externC extern "C"
62 # else
63 # define __externC extern
64 # endif
65 #endif
66
67 // Compute a CRC, using the POSIX 1003 definition
68
69 __externC cyg_uint32
70 cyg_posix_crc32(unsigned char *s, int len);
71
72 // Gary S. Brown's 32 bit CRC
73
74 __externC cyg_uint32
75 cyg_crc32(unsigned char *s, int len);
76
77 // Gary S. Brown's 32 bit CRC, but accumulate the result from a
78 // previous CRC calculation
79
80 __externC cyg_uint32
81 cyg_crc32_accumulate(cyg_uint32 crc, unsigned char *s, int len);
82
83 // Ethernet FCS Algorithm
84
85 __externC cyg_uint32
86 cyg_ether_crc32(unsigned char *s, int len);
87
88 // Ethernet FCS algorithm, but accumulate the result from a previous
89 // CRC calculation.
90
91 __externC cyg_uint32
92 cyg_ether_crc32_accumulate(cyg_uint32 crc, unsigned char *s, int len);
93
94 // 16 bit CRC with polynomial x^16+x^12+x^5+1
95
96 __externC cyg_uint16
97 cyg_crc16(unsigned char *s, int len);
98
99 __externC cyg_uint16
100 cyg_crc16_accumulate(cyg_uint16 crc, unsigned char *s, int len);
101
102 #endif // _SERVICES_CRC_CRC_H_
103
104
105
