RTEMS  5.1
Macros | Functions
console.h File Reference
Console Driver for all Boards. More...
#include <rtems/io.h>
#define CONSOLE_DEVICE_NAME   "/dev/console"
#define CONSOLE_DRIVER_TABLE_ENTRY
rtems_device_driver console_initialize (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Console initialization entry point. More...
rtems_device_driver console_open (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Console open entry point. More...
rtems_device_driver console_close (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Console close entry point. More...
rtems_device_driver console_read (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Console read entry point. More...
rtems_device_driver console_write (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Console write entry point. More...
rtems_device_driver console_control (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Console IO control entry point. More...
void _Console_simple_Initialize (void)
 Initializes a simple console device. More...
void _Console_simple_task_Initialize (void)
 Initializes a simple task console device. More...
This file describes the Console Device Driver for all boards. This driver provides support for the standard C Library.
◆ CONSOLE_DEVICE_NAME
This macro defines the standard name for the console device that is available to applications.
◆ CONSOLE_DRIVER_TABLE_ENTRY
Value:
console_read, console_write, console_control }
rtems_device_driver console_close(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
Definition: uart.c:143
rtems_device_driver console_write(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
Definition: uart.c:161
rtems_device_driver console_control(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
Definition: uart.c:170
rtems_device_driver console_open(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
Definition: uart.c:126
rtems_device_driver console_initialize(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
Definition: console.c:477
This macro defines the standard device driver table entry for a console device driver.
◆ _Console_simple_Initialize()
void _Console_simple_Initialize ( void  )
See CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER documentation in the "RTEMS Classic API Guide".
◆ _Console_simple_task_Initialize()
void _Console_simple_task_Initialize ( void  )
See CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER documentation in the "RTEMS Classic API Guide".
◆ console_close()
rtems_device_driver console_close ( rtems_device_major_number  major,
void *  arg
This method closes a specific device supported by the console device driver.
Parameters
[in]majoris the device driver major number
[in]minoris the device driver minor number
[in]argis the parameters to this call
Return values
RTEMS_SUCCESSFULThe device driver is successfully closed.
◆ console_control()
rtems_device_driver console_control ( rtems_device_major_number  major,
void *  arg
This method performs an IO Control operation on a specific device supported by the console device driver.
Parameters
Return values
RTEMS_SUCCESSFULthe device driver IO control operation is successfully performed.
◆ console_initialize()
rtems_device_driver console_initialize ( rtems_device_major_number  major,
void *  arg
This method initializes the console device driver.
Parameters
[in]majoris the device driver major number.
[in]minoris the device driver minor number.
[in]argis the parameters to this call.
Return values
RTEMS_SUCCESSFULThe device driver is successfully initialized.
Initialize all serial drivers specified in driver_context_table
Parameters
[in]major
[in]minor
[in]arg
Return values
RTEMS_SUCCESSFULInitialization completed
This routine initializes the console IO driver.
Parameters
Parameters
majormajor number
minorminor number
Output parameters: NONE
Returns
void
◆ console_open()
rtems_device_driver console_open ( rtems_device_major_number  major,
void *  arg
This method opens a specific device supported by the console device driver.
Parameters
Return values
RTEMS_SUCCESSFULThe device driver is successfully opened.
◆ console_read()
rtems_device_driver console_read ( rtems_device_major_number  major,
void *  arg
This method reads from a specific device supported by the console device driver.
Parameters
Return values
RTEMS_SUCCESSFULThe device is successfully read from.
◆ console_write()
rtems_device_driver console_write ( rtems_device_major_number  major,
void *  arg
This method writes to a specific device supported by the console device driver.
Parameters
Return values
RTEMS_SUCCESSFULThe device is successfully written.
