36 #ifndef _RTEMS_CONFDEFS_SIMPLECONSOLE_H 37 #define _RTEMS_CONFDEFS_SIMPLECONSOLE_H 39 #ifndef __CONFIGURATION_TEMPLATE_h 40 #error "Do not include this file directly, use <rtems/confdefs.h> instead" 45 #if defined(CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER) \ 46 && defined(CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER) 47 #error "CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER and CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER are mutually exclusive" 50 #if defined(CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER) \ 51 || defined(CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER) 54 #include <rtems/sysinit.h> 60 #ifdef CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER 63 RTEMS_SYSINIT_DEVICE_DRIVERS,
64 RTEMS_SYSINIT_ORDER_SECOND
68 #ifdef CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER 71 RTEMS_SYSINIT_DEVICE_DRIVERS,
72 RTEMS_SYSINIT_ORDER_SECOND
void _Console_simple_Initialize(void)
Initializes a simple console device.
Definition: consolesimple.c:91
void _Console_simple_task_Initialize(void)
Initializes a simple task console device.
Definition: consolesimpletask.c:217
Console Driver for all Boards.
