RTEMS  5.1
wkspace.h
1 /* SPDX-License-Identifier: BSD-2-Clause */
2
11 /*
12  * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
13  *
14  * Redistribution and use in source and binary forms, with or without
15  * modification, are permitted provided that the following conditions
16  * are met:
17  * 1. Redistributions of source code must retain the above copyright
18  * notice, this list of conditions and the following disclaimer.
19  * 2. Redistributions in binary form must reproduce the above copyright
20  * notice, this list of conditions and the following disclaimer in the
21  * documentation and/or other materials provided with the distribution.
22  *
23  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26  * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27  * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28  * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29  * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30  * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31  * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32  * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33  * POSSIBILITY OF SUCH DAMAGE.
34  */
35
36 #ifndef _RTEMS_CONFDEFS_WKSPACE_H
37 #define _RTEMS_CONFDEFS_WKSPACE_H
38
39 #ifndef __CONFIGURATION_TEMPLATE_h
40 #error "Do not include this file directly, use <rtems/confdefs.h> instead"
41 #endif
42
43 #ifdef CONFIGURE_INIT
44
45 #include <rtems/confdefs/bdbuf.h>
49 #include <rtems/confdefs/threads.h>
51 #include <rtems/score/coremsg.h>
52 #include <rtems/score/context.h>
53 #include <rtems/score/memory.h>
54 #include <rtems/score/stack.h>
55 #include <rtems/sysinit.h>
56
57 #ifdef CONFIGURE_TASK_STACK_FROM_ALLOCATOR
58  #define _Configure_From_stackspace( _stack_size ) \
59  CONFIGURE_TASK_STACK_FROM_ALLOCATOR( _stack_size + CONTEXT_FP_SIZE )
60 #else
61  #define _Configure_From_stackspace( _stack_size ) \
62  _Configure_From_workspace( _stack_size + CONTEXT_FP_SIZE )
63 #endif
64
65 #ifndef CONFIGURE_EXTRA_TASK_STACKS
66  #define CONFIGURE_EXTRA_TASK_STACKS 0
67 #endif
68
69 #ifndef CONFIGURE_EXECUTIVE_RAM_SIZE
70
71 #define CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( _messages, _size ) \
72  _Configure_From_workspace( \
73  ( _messages ) * ( _Configure_Align_up( _size, sizeof( uintptr_t ) ) \
74  + sizeof( CORE_message_queue_Buffer_control ) ) )
75
76 #ifndef CONFIGURE_MESSAGE_BUFFER_MEMORY
77  #define CONFIGURE_MESSAGE_BUFFER_MEMORY 0
78 #endif
79
80 #ifndef CONFIGURE_MEMORY_OVERHEAD
81  #define CONFIGURE_MEMORY_OVERHEAD 0
82 #endif
83
84 /*
85  * We must be able to split the free block used for the second last allocation
86  * into two parts so that we have a free block for the last allocation. See
87  * _Heap_Block_split().
88  */
89 #define _CONFIGURE_HEAP_HANDLER_OVERHEAD \
90  _Configure_Align_up( HEAP_BLOCK_HEADER_SIZE, CPU_HEAP_ALIGNMENT )
91
92 #define CONFIGURE_EXECUTIVE_RAM_SIZE \
93  ( _CONFIGURE_MEMORY_FOR_POSIX_OBJECTS \
94  + CONFIGURE_MESSAGE_BUFFER_MEMORY \
95  + 1024 * CONFIGURE_MEMORY_OVERHEAD \
96  + _CONFIGURE_HEAP_HANDLER_OVERHEAD )
97
98 #define _CONFIGURE_STACK_SPACE_SIZE \
99  ( _CONFIGURE_INIT_TASK_STACK_EXTRA \
100  + _CONFIGURE_POSIX_INIT_THREAD_STACK_EXTRA \
101  + _CONFIGURE_LIBBLOCK_TASKS_STACK_EXTRA \
102  + CONFIGURE_EXTRA_TASK_STACKS \
103  + rtems_resource_maximum_per_allocation( _CONFIGURE_TASKS ) \
104  * _Configure_From_stackspace( CONFIGURE_MINIMUM_TASK_STACK_SIZE ) \
105  + rtems_resource_maximum_per_allocation( CONFIGURE_MAXIMUM_POSIX_THREADS ) \
106  * _Configure_From_stackspace( CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE ) \
107  + _CONFIGURE_HEAP_HANDLER_OVERHEAD )
108
109 #else /* CONFIGURE_EXECUTIVE_RAM_SIZE */
110
111 #if CONFIGURE_EXTRA_TASK_STACKS != 0
112  #error "CONFIGURE_EXECUTIVE_RAM_SIZE defined with request for CONFIGURE_EXTRA_TASK_STACKS"
113 #endif
114
115 #define _CONFIGURE_STACK_SPACE_SIZE 0
116
117 #endif /* CONFIGURE_EXECUTIVE_RAM_SIZE */
118
119 #ifdef __cplusplus
120 extern "C" {
121 #endif
122
123 const uintptr_t _Workspace_Size = CONFIGURE_EXECUTIVE_RAM_SIZE;
124
125 #ifdef CONFIGURE_UNIFIED_WORK_AREAS
126  const bool _Workspace_Is_unified = true;
127 #endif
128
129 uint32_t rtems_minimum_stack_size = CONFIGURE_MINIMUM_TASK_STACK_SIZE;
130
131 const uintptr_t _Stack_Space_size = _CONFIGURE_STACK_SPACE_SIZE;
132
133 #if defined(CONFIGURE_TASK_STACK_ALLOCATOR) \
134  && defined(CONFIGURE_TASK_STACK_DEALLOCATOR)
135  #ifdef CONFIGURE_TASK_STACK_ALLOCATOR_AVOIDS_WORK_SPACE
136  const bool _Stack_Allocator_avoids_workspace = true;
137  #else
138  const bool _Stack_Allocator_avoids_workspace = false;
139  #endif
140
141  #ifdef CONFIGURE_TASK_STACK_ALLOCATOR_INIT
144  #else
146  #endif
147
150
153 #elif defined(CONFIGURE_TASK_STACK_ALLOCATOR) \
154  || defined(CONFIGURE_TASK_STACK_DEALLOCATOR)
155  #error "CONFIGURE_TASK_STACK_ALLOCATOR and CONFIGURE_TASK_STACK_DEALLOCATOR must be both defined or both undefined"
156 #endif
157
158 #ifdef CONFIGURE_DIRTY_MEMORY
159  RTEMS_SYSINIT_ITEM(
161  RTEMS_SYSINIT_DIRTY_MEMORY,
162  RTEMS_SYSINIT_ORDER_MIDDLE
163  );
164 #endif
165
166 #ifdef CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY
167  const bool _Memory_Zero_before_use = true;
168
169  RTEMS_SYSINIT_ITEM(
171  RTEMS_SYSINIT_ZERO_MEMORY,
172  RTEMS_SYSINIT_ORDER_MIDDLE
173  );
174 #endif
175
176 #ifdef __cplusplus
177 }
178 #endif
179
180 #endif /* CONFIGURE_INIT */
181
182 #endif /* _RTEMS_CONFDEFS_WKSPACE_H */
Indicates if the stack allocator avoids the workspace.
Definition: stackallocator.c:35
Configuration Options Workspace Support Macros.
Indicates if the memory is zeroed during system initialization.
Definition: memoryzerobeforeuse.c:34
const Stack_Allocator_initialize _Stack_Allocator_initialize
The stack allocator initialization handler.
Definition: stackallocator.c:37
Information About the Thread Stack Handler.
Information About Each Thread's Context.
#define CONFIGURE_TASK_STACK_ALLOCATOR
Task stack allocator configuration option.
Definition: stackalloc.h:81
Memory Handler API.
The configured stack space size.
Evaluate Thread Configuration Options.
void _Memory_Zero_free_areas(void)
Zeros all free memory areas of the system.
Definition: memoryzerofreeareas.c:34
#define CONFIGURE_TASK_STACK_ALLOCATOR_INIT
Task stack allocator initialization configuration option.
Definition: stackalloc.h:76
Indicates if the workspace and C program heap are unified.
Definition: wkspaceisunifieddefault.c:34
The minimum stack size.
Evaluate POSIX Initialization Thread Configuration Options.
#define CONFIGURE_TASK_STACK_DEALLOCATOR
Task stack deallocator configuration option.
Definition: stackalloc.h:86
const Stack_Allocator_free _Stack_Allocator_free
The stack allocator free handler.
Definition: stackallocator.c:41
void(* Stack_Allocator_initialize)(size_t stack_space_size)
Definition: stack.h:65
Evaluate POSIX API Objects Configuration Options.
void(* Stack_Allocator_free)(void *addr)
Stack allocator free handler.
Definition: stack.h:82
Constants and Structures Associated with the Message Queue Handler.
The workspace size in bytes.
const Stack_Allocator_allocate _Stack_Allocator_allocate
The stack allocator allocate handler.
Definition: stackallocator.c:39
Evaluate Block Device Cache Configuration Options.
Evaluate User Initialization Task Configuration Options.
void *(* Stack_Allocator_allocate)(size_t stack_size)
Stack allocator allocate handler.
Definition: stack.h:75
void _Memory_Dirty_free_areas(void)
Dirty all free memory areas of the system.
Definition: memorydirtyfreeareas.c:34
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
