RTEMS  5.1
libio.h
1 /* SPDX-License-Identifier: BSD-2-Clause */
2
11 /*
12  * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
13  *
14  * Redistribution and use in source and binary forms, with or without
15  * modification, are permitted provided that the following conditions
16  * are met:
17  * 1. Redistributions of source code must retain the above copyright
18  * notice, this list of conditions and the following disclaimer.
19  * 2. Redistributions in binary form must reproduce the above copyright
20  * notice, this list of conditions and the following disclaimer in the
21  * documentation and/or other materials provided with the distribution.
22  *
23  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26  * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27  * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28  * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29  * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30  * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31  * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32  * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33  * POSSIBILITY OF SUCH DAMAGE.
34  */
35
36 #ifndef _RTEMS_CONFDEFS_LIBIO_H
37 #define _RTEMS_CONFDEFS_LIBIO_H
38
39 #ifndef __CONFIGURATION_TEMPLATE_h
40 #error "Do not include this file directly, use <rtems/confdefs.h> instead"
41 #endif
42
43 #ifdef CONFIGURE_INIT
44
45 #include <rtems/confdefs/bsp.h>
46 #include <rtems/libio.h>
47 #include <rtems/sysinit.h>
48
49 #ifdef CONFIGURE_FILESYSTEM_ALL
50  #define CONFIGURE_FILESYSTEM_DOSFS
51  #define CONFIGURE_FILESYSTEM_FTPFS
52  #define CONFIGURE_FILESYSTEM_IMFS
53  #define CONFIGURE_FILESYSTEM_JFFS2
54  #define CONFIGURE_FILESYSTEM_NFS
55  #define CONFIGURE_FILESYSTEM_RFS
56  #define CONFIGURE_FILESYSTEM_TFTPFS
57 #endif
58
59 #ifdef CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM
60  #ifdef CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
61  #error "CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM cannot be used together with CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM"
62  #endif
63
64  #define CONFIGURE_IMFS_DISABLE_CHMOD
65  #define CONFIGURE_IMFS_DISABLE_CHOWN
66  #define CONFIGURE_IMFS_DISABLE_LINK
67  #define CONFIGURE_IMFS_DISABLE_READLINK
68  #define CONFIGURE_IMFS_DISABLE_RENAME
69  #define CONFIGURE_IMFS_DISABLE_SYMLINK
70  #define CONFIGURE_IMFS_DISABLE_UNMOUNT
71  #define CONFIGURE_IMFS_DISABLE_UTIME
72 #endif
73
74 #ifdef CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
75  #define CONFIGURE_IMFS_DISABLE_CHMOD
76  #define CONFIGURE_IMFS_DISABLE_CHOWN
77  #define CONFIGURE_IMFS_DISABLE_LINK
78  #define CONFIGURE_IMFS_DISABLE_MKNOD_FILE
79  #define CONFIGURE_IMFS_DISABLE_MOUNT
80  #define CONFIGURE_IMFS_DISABLE_READDIR
81  #define CONFIGURE_IMFS_DISABLE_READLINK
82  #define CONFIGURE_IMFS_DISABLE_RENAME
83  #define CONFIGURE_IMFS_DISABLE_RMNOD
84  #define CONFIGURE_IMFS_DISABLE_SYMLINK
85  #define CONFIGURE_IMFS_DISABLE_UNMOUNT
86  #define CONFIGURE_IMFS_DISABLE_UTIME
87 #endif
88
89 #ifdef CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
90  #ifdef CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
91  #error "CONFIGURE_APPLICATION_DISABLE_FILESYSTEM cannot be used together with CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM"
92  #endif
93
94  #ifdef CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM
95  #error "CONFIGURE_APPLICATION_DISABLE_FILESYSTEM cannot be used together with CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM"
96  #endif
97
98  #ifdef CONFIGURE_FILESYSTEM_DOSFS
99  #error "CONFIGURE_APPLICATION_DISABLE_FILESYSTEM cannot be used together with CONFIGURE_FILESYSTEM_DOSFS"
100  #endif
101
102  #ifdef CONFIGURE_FILESYSTEM_FTPFS
103  #error "CONFIGURE_APPLICATION_DISABLE_FILESYSTEM cannot be used together with CONFIGURE_FILESYSTEM_FTPFS"
104  #endif
105
106  #ifdef CONFIGURE_FILESYSTEM_IMFS
107  #error "CONFIGURE_APPLICATION_DISABLE_FILESYSTEM cannot be used together with CONFIGURE_FILESYSTEM_IMFS"
108  #endif
109
110  #ifdef CONFIGURE_FILESYSTEM_JFFS2
111  #error "CONFIGURE_APPLICATION_DISABLE_FILESYSTEM cannot be used together with CONFIGURE_FILESYSTEM_JFFS2"
112  #endif
113
114  #ifdef CONFIGURE_FILESYSTEM_NFS
115  #error "CONFIGURE_APPLICATION_DISABLE_FILESYSTEM cannot be used together with CONFIGURE_FILESYSTEM_NFS"
116  #endif
117
118  #ifdef CONFIGURE_FILESYSTEM_RFS
119  #error "CONFIGURE_APPLICATION_DISABLE_FILESYSTEM cannot be used together with CONFIGURE_FILESYSTEM_RFS"
120  #endif
121
122  #ifdef CONFIGURE_FILESYSTEM_TFTPFS
123  #error "CONFIGURE_APPLICATION_DISABLE_FILESYSTEM cannot be used together with CONFIGURE_FILESYSTEM_TFTPFS"
124  #endif
125 #endif
126
127 #include <rtems/imfs.h>
128
129 #ifdef CONFIGURE_FILESYSTEM_DOSFS
130 #include <rtems/dosfs.h>
131 #endif
132
133 #ifdef CONFIGURE_FILESYSTEM_FTPFS
134 #include <rtems/ftpfs.h>
135 #endif
136
137 #ifdef CONFIGURE_FILESYSTEM_JFFS2
138 #include <rtems/jffs2.h>
139 #endif
140
141 #ifdef CONFIGURE_FILESYSTEM_NFS
142 #include <librtemsNfs.h>
143 #endif
144
145 #ifdef CONFIGURE_FILESYSTEM_RFS
146 #include <rtems/rtems-rfs.h>
147 #endif
148
149 #ifdef CONFIGURE_FILESYSTEM_TFTPFS
150 #include <rtems/tftp.h>
151 #endif
152
153 #ifdef __cplusplus
154 extern "C" {
155 #endif
156
157 #ifndef CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
158
159 #ifndef CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK
160  #define CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK \
161  IMFS_MEMFILE_DEFAULT_BYTES_PER_BLOCK
162 #endif
163
164 #if CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK != 16 && \
165  CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK != 32 && \
166  CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK != 64 && \
167  CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK != 128 && \
168  CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK != 256 && \
169  CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK != 512
170  #error "CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK must be a power of two between 16 and 512"
171 #endif
172
173 const int imfs_memfile_bytes_per_block = CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK;
174
175 static IMFS_fs_info_t IMFS_root_fs_info;
176
177 static const rtems_filesystem_operations_table IMFS_root_ops = {
180  #ifdef CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
182  #else
184  #endif
185  #ifdef CONFIGURE_IMFS_DISABLE_LINK
187  #else
188  IMFS_link,
189  #endif
191  #ifdef CONFIGURE_IMFS_DISABLE_MKNOD
193  #else
194  IMFS_mknod,
195  #endif
196  #ifdef CONFIGURE_IMFS_DISABLE_RMNOD
198  #else
199  IMFS_rmnod,
200  #endif
201  #ifdef CONFIGURE_IMFS_DISABLE_CHMOD
203  #else
204  IMFS_fchmod,
205  #endif
206  #ifdef CONFIGURE_IMFS_DISABLE_CHOWN
208  #else
209  IMFS_chown,
210  #endif
213  #ifdef CONFIGURE_IMFS_DISABLE_MOUNT
215  #else
216  IMFS_mount,
217  #endif
218  #ifdef CONFIGURE_IMFS_DISABLE_UNMOUNT
220  #else
221  IMFS_unmount,
222  #endif
224  #ifdef CONFIGURE_IMFS_DISABLE_UTIME
226  #else
227  IMFS_utime,
228  #endif
229  #ifdef CONFIGURE_IMFS_DISABLE_SYMLINK
231  #else
232  IMFS_symlink,
233  #endif
234  #ifdef CONFIGURE_IMFS_DISABLE_READLINK
236  #else
238  #endif
239  #ifdef CONFIGURE_IMFS_DISABLE_RENAME
241  #else
242  IMFS_rename,
243  #endif
245 };
246
247 static const IMFS_mknod_controls IMFS_root_mknod_controls = {
248  #ifdef CONFIGURE_IMFS_DISABLE_READDIR
249  &IMFS_mknod_control_dir_minimal,
250  #else
251  &IMFS_mknod_control_dir_default,
252  #endif
253  #ifdef CONFIGURE_IMFS_DISABLE_MKNOD_DEVICE
254  &IMFS_mknod_control_enosys,
255  #else
256  &IMFS_mknod_control_device,
257  #endif
258  #ifdef CONFIGURE_IMFS_DISABLE_MKNOD_FILE
259  &IMFS_mknod_control_enosys,
260  #else
261  &IMFS_mknod_control_memfile,
262  #endif
263  #ifdef CONFIGURE_IMFS_ENABLE_MKFIFO
264  &IMFS_mknod_control_fifo
265  #else
266  &IMFS_mknod_control_enosys
267  #endif
268 };
269
270 static const IMFS_mount_data IMFS_root_mount_data = {
271  &IMFS_root_fs_info,
272  &IMFS_root_ops,
273  &IMFS_root_mknod_controls
274 };
275
277  { "/", IMFS_initialize_support },
278  #ifdef CONFIGURE_FILESYSTEM_DOSFS
279  { RTEMS_FILESYSTEM_TYPE_DOSFS, rtems_dosfs_initialize },
280  #endif
281  #ifdef CONFIGURE_FILESYSTEM_FTPFS
282  { RTEMS_FILESYSTEM_TYPE_FTPFS, rtems_ftpfs_initialize },
283  #endif
284  #ifdef CONFIGURE_FILESYSTEM_IMFS
285  { RTEMS_FILESYSTEM_TYPE_IMFS, IMFS_initialize },
286  #endif
287  #ifdef CONFIGURE_FILESYSTEM_JFFS2
288  { RTEMS_FILESYSTEM_TYPE_JFFS2, rtems_jffs2_initialize },
289  #endif
290  #ifdef CONFIGURE_FILESYSTEM_NFS
291  { RTEMS_FILESYSTEM_TYPE_NFS, rtems_nfs_initialize },
292  #endif
293  #ifdef CONFIGURE_FILESYSTEM_RFS
294  { RTEMS_FILESYSTEM_TYPE_RFS, rtems_rfs_rtems_initialise },
295  #endif
296  #ifdef CONFIGURE_FILESYSTEM_TFTPFS
297  { RTEMS_FILESYSTEM_TYPE_TFTPFS, rtems_tftpfs_initialize },
298  #endif
299  { NULL, NULL }
300 };
301
303 rtems_filesystem_root_configuration = {
304  NULL,
305  NULL,
306  "/",
307  RTEMS_FILESYSTEM_READ_WRITE,
308  &IMFS_root_mount_data
309 };
310
311 RTEMS_SYSINIT_ITEM(
313  RTEMS_SYSINIT_ROOT_FILESYSTEM,
314  RTEMS_SYSINIT_ORDER_MIDDLE
315 );
316
317 #endif /* !CONFIGURE_APPLICATION_DISABLE_FILESYSTEM */
318
319 #ifndef CONFIGURE_MAXIMUM_FILE_DESCRIPTORS
320  #define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 3
321 #endif
322
323 rtems_libio_t rtems_libio_iops[ CONFIGURE_MAXIMUM_FILE_DESCRIPTORS ];
324
325 const uint32_t rtems_libio_number_iops = RTEMS_ARRAY_SIZE( rtems_libio_iops );
326
327 #ifdef __cplusplus
328 }
329 #endif
330
331 #endif /* CONFIGURE_INIT */
332
333 #endif /* _RTEMS_CONFDEFS_LIBIO_H */
void rtems_filesystem_initialize(void)
Base File System Initialization.
Definition: base_fs.c:32
int rtems_filesystem_default_utime(const rtems_filesystem_location_info_t *loc, time_t actime, time_t modtime)
Definition: default_utime.c:25
RFS File system Initialization.
bool rtems_filesystem_default_are_nodes_equal(const rtems_filesystem_location_info_t *a, const rtems_filesystem_location_info_t *b)
Tests if the node access pointer of one location is equal to the node access pointer of the other loc...
Definition: default_are_nodes_equal.c:29
int rtems_filesystem_default_link(const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *targetloc, const char *name, size_t namelen)
Definition: default_link.c:23
Definition: imfs.h:399
Basic IO API.
int IMFS_link(const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *targetloc, const char *name, size_t namelen)
Create a new IMFS link node.
Definition: imfs_link.c:26
Header File for the In-Memory File System.
const rtems_filesystem_table_t rtems_filesystem_table[]
Static table of file systems.
int rtems_filesystem_default_unmount(rtems_filesystem_mount_table_entry_t *mt_entry)
Definition: default_unmount.c:22
int IMFS_mount(rtems_filesystem_mount_table_entry_t *mt_entry)
Mount an IMFS.
Definition: imfs_mount.c:27
void IMFS_node_free(const rtems_filesystem_location_info_t *loc)
Free an IMFS node.
Definition: imfs_node.c:88
void rtems_filesystem_default_unlock(const rtems_filesystem_mount_table_entry_t *mt_entry)
Releases the IO library mutex.
Definition: default_lock_and_unlock.c:36
File system table entry.
Definition: libio.h:1656
ssize_t rtems_filesystem_default_readlink(const rtems_filesystem_location_info_t *loc, char *buf, size_t bufsize)
Definition: default_readlink.c:25
int rtems_rfs_rtems_initialise(rtems_filesystem_mount_table_entry_t *mt_entry, const void *data)
Definition: rtems-rfs-rtems.c:750
int rtems_filesystem_default_fchmod(const rtems_filesystem_location_info_t *loc, mode_t mode)
Definition: default_fchmod.c:23
Definition: imfs.h:404
void IMFS_eval_path(rtems_filesystem_eval_path_context_t *ctx)
IMFS evaluation node support.
Definition: imfs_eval.c:176
int IMFS_node_clone(rtems_filesystem_location_info_t *loc)
Clone an IMFS node.
Definition: imfs_node.c:72
int rtems_filesystem_default_symlink(const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, const char *target)
Definition: default_symlink.c:25
int IMFS_mknod(const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, mode_t mode, dev_t dev)
Create an IMFS node.
Definition: imfs_mknod.c:44
int rtems_filesystem_default_rmnod(const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *loc)
Definition: default_rmnod.c:25
int IMFS_fchmod(const rtems_filesystem_location_info_t *loc, mode_t mode)
Change the IMFS file mode.
Definition: imfs_fchmod.c:24
int IMFS_chown(const rtems_filesystem_location_info_t *loc, uid_t owner, gid_t group)
Change the owner of IMFS.
Definition: imfs_chown.c:28
int IMFS_symlink(const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, const char *target)
Create a new IMFS symbolic link node.
Definition: imfs_symlink.c:28
Application Interface to FAT Filesystem.
int IMFS_unmount(rtems_filesystem_mount_table_entry_t *mt_entry)
Unmount an IMFS.
Definition: imfs_unmount.c:27
File system operations table.
Definition: libio.h:472
Definition: libio.h:1855
int IMFS_rmnod(const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *loc)
IMFS node removal handler.
Definition: imfs_rmnod.c:27
int rtems_filesystem_default_mount(rtems_filesystem_mount_table_entry_t *mt_entry)
Definition: default_mount.c:22
Evaluate BSP Related Configuration Options.
ssize_t IMFS_readlink(const rtems_filesystem_location_info_t *loc, char *buf, size_t bufsize)
Put IMFS symbolic link into buffer.
Definition: imfs_symlink.c:57
File Transfer Protocol file system (FTP client).
int IMFS_utime(const rtems_filesystem_location_info_t *loc, time_t actime, time_t modtime)
Set IMFS file access and modification times.
Definition: imfs_utime.c:26
Definition: imfs.h:392
void rtems_filesystem_default_fsunmount(rtems_filesystem_mount_table_entry_t *mt_entry)
Definition: default_fsunmount.c:20
int rtems_filesystem_default_statvfs(const rtems_filesystem_location_info_t *loc, struct statvfs *buf)
Definition: default_statvfs.c:23
An open file data structure.
Definition: libio.h:1320
int rtems_filesystem_default_rename(const rtems_filesystem_location_info_t *oldparentloc, const rtems_filesystem_location_info_t *oldloc, const rtems_filesystem_location_info_t *newparentloc, const char *name, size_t namelen)
Definition: default_rename.c:25
void IMFS_eval_path_devfs(rtems_filesystem_eval_path_context_t *ctx)
IMFS device filesystem evaluation node support.
Definition: imfs_eval_devfs.c:123
int rtems_ftpfs_initialize(rtems_filesystem_mount_table_entry_t *mt_entry, const void *data)
Do not call directly, use mount().
int rtems_filesystem_default_mknod(const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, mode_t mode, dev_t dev)
Definition: default_mknod.c:25
int rtems_filesystem_default_chown(const rtems_filesystem_location_info_t *loc, uid_t owner, gid_t group)
Definition: default_chown.c:23
void rtems_filesystem_default_lock(const rtems_filesystem_mount_table_entry_t *mt_entry)
Obtains the IO library mutex.
Definition: default_lock_and_unlock.c:29
int IMFS_rename(const rtems_filesystem_location_info_t *oldparentloc, const rtems_filesystem_location_info_t *oldloc, const rtems_filesystem_location_info_t *newparentloc, const char *name, size_t namelen)
Rename the IMFS.
Definition: imfs_rename.c:50
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
int rtems_jffs2_initialize(rtems_filesystem_mount_table_entry_t *mt_entry, const void *data)
Initialization handler of the JFFS2 file system.
Definition: fs-rtems.c:1216
