RTEMS  5.1
component_mlb.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
30 #ifndef _SAMV71_MLB_COMPONENT_
31 #define _SAMV71_MLB_COMPONENT_
32
33 /* ============================================================================= */
35 /* ============================================================================= */
38
39 #if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
40
41 typedef struct {
42  __IO uint32_t MLB_MLBC0;
43  __I uint32_t Reserved1[2];
44  __IO uint32_t MLB_MS0;
45  __I uint32_t Reserved2[1];
46  __IO uint32_t MLB_MS1;
47  __I uint32_t Reserved3[2];
48  __IO uint32_t MLB_MSS;
49  __I uint32_t MLB_MSD;
50  __I uint32_t Reserved4[1];
51  __IO uint32_t MLB_MIEN;
52  __I uint32_t Reserved5[3];
53  __IO uint32_t MLB_MLBC1;
54  __I uint32_t Reserved6[1];
55  __I uint32_t Reserved7[15];
56  __IO uint32_t MLB_HCTL;
57  __I uint32_t Reserved8[1];
58  __IO uint32_t MLB_HCMR[2];
59  __I uint32_t MLB_HCER[2];
60  __I uint32_t MLB_HCBR[2];
61  __I uint32_t Reserved9[8];
62  __IO uint32_t MLB_MDAT[4];
63  __IO uint32_t MLB_MDWE[4];
64  __IO uint32_t MLB_MCTL;
65  __IO uint32_t MLB_MADR;
66  __I uint32_t Reserved10[182];
67  __IO uint32_t MLB_ACTL;
68  __I uint32_t Reserved11[3];
69  __IO uint32_t MLB_ACSR[2];
70  __IO uint32_t MLB_ACMR[2];
71 } Mlb;
72 #endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
73 /* -------- MLB_MLBC0 : (MLB Offset: 0x000) MediaLB Control 0 Register -------- */
74 #define MLB_MLBC0_MLBEN (0x1u << 0)
75 #define MLB_MLBC0_MLBCLK_Pos 2
76 #define MLB_MLBC0_MLBCLK_Msk (0x7u << MLB_MLBC0_MLBCLK_Pos)
77 #define MLB_MLBC0_MLBCLK(value) ((MLB_MLBC0_MLBCLK_Msk & ((value) << MLB_MLBC0_MLBCLK_Pos)))
78 #define MLB_MLBC0_MLBCLK_256_FS (0x0u << 2)
79 #define MLB_MLBC0_MLBCLK_512_FS (0x1u << 2)
80 #define MLB_MLBC0_MLBCLK_1024_FS (0x2u << 2)
81 #define MLB_MLBC0_ZERO (0x1u << 5)
82 #define MLB_MLBC0_MLBLK (0x1u << 7)
83 #define MLB_MLBC0_ASYRETRY (0x1u << 12)
84 #define MLB_MLBC0_CTLRETRY (0x1u << 14)
85 #define MLB_MLBC0_FCNT_Pos 15
86 #define MLB_MLBC0_FCNT_Msk (0x7u << MLB_MLBC0_FCNT_Pos)
87 #define MLB_MLBC0_FCNT(value) ((MLB_MLBC0_FCNT_Msk & ((value) << MLB_MLBC0_FCNT_Pos)))
88 #define MLB_MLBC0_FCNT_1_FRAME (0x0u << 15)
89 #define MLB_MLBC0_FCNT_2_FRAMES (0x1u << 15)
90 #define MLB_MLBC0_FCNT_4_FRAMES (0x2u << 15)
91 #define MLB_MLBC0_FCNT_8_FRAMES (0x3u << 15)
92 #define MLB_MLBC0_FCNT_16_FRAMES (0x4u << 15)
93 #define MLB_MLBC0_FCNT_32_FRAMES (0x5u << 15)
94 #define MLB_MLBC0_FCNT_64_FRAMES (0x6u << 15)
95 /* -------- MLB_MS0 : (MLB Offset: 0x00C) MediaLB Channel Status 0 Register -------- */
96 #define MLB_MS0_MCS_Pos 0
97 #define MLB_MS0_MCS_Msk (0xffffffffu << MLB_MS0_MCS_Pos)
98 #define MLB_MS0_MCS(value) ((MLB_MS0_MCS_Msk & ((value) << MLB_MS0_MCS_Pos)))
99 /* -------- MLB_MS1 : (MLB Offset: 0x014) MediaLB Channel Status1 Register -------- */
100 #define MLB_MS1_MCS_Pos 0
101 #define MLB_MS1_MCS_Msk (0xffffffffu << MLB_MS1_MCS_Pos)
102 #define MLB_MS1_MCS(value) ((MLB_MS1_MCS_Msk & ((value) << MLB_MS1_MCS_Pos)))
103 /* -------- MLB_MSS : (MLB Offset: 0x020) MediaLB System Status Register -------- */
104 #define MLB_MSS_RSTSYSCMD (0x1u << 0)
105 #define MLB_MSS_LKSYSCMD (0x1u << 1)
106 #define MLB_MSS_ULKSYSCMD (0x1u << 2)
107 #define MLB_MSS_CSSYSCMD (0x1u << 3)
108 #define MLB_MSS_SWSYSCMD (0x1u << 4)
109 #define MLB_MSS_SERVREQ (0x1u << 5)
110 /* -------- MLB_MSD : (MLB Offset: 0x024) MediaLB System Data Register -------- */
111 #define MLB_MSD_SD0_Pos 0
112 #define MLB_MSD_SD0_Msk (0xffu << MLB_MSD_SD0_Pos)
113 #define MLB_MSD_SD1_Pos 8
114 #define MLB_MSD_SD1_Msk (0xffu << MLB_MSD_SD1_Pos)
115 #define MLB_MSD_SD2_Pos 16
116 #define MLB_MSD_SD2_Msk (0xffu << MLB_MSD_SD2_Pos)
117 #define MLB_MSD_SD3_Pos 24
118 #define MLB_MSD_SD3_Msk (0xffu << MLB_MSD_SD3_Pos)
119 /* -------- MLB_MIEN : (MLB Offset: 0x02C) MediaLB Interrupt Enable Register -------- */
120 #define MLB_MIEN_ISOC_PE (0x1u << 0)
121 #define MLB_MIEN_ISOC_BUFO (0x1u << 1)
122 #define MLB_MIEN_SYNC_PE (0x1u << 16)
123 #define MLB_MIEN_ARX_DONE (0x1u << 17)
124 #define MLB_MIEN_ARX_PE (0x1u << 18)
125 #define MLB_MIEN_ARX_BREAK (0x1u << 19)
126 #define MLB_MIEN_ATX_DONE (0x1u << 20)
127 #define MLB_MIEN_ATX_PE (0x1u << 21)
128 #define MLB_MIEN_ATX_BREAK (0x1u << 22)
129 #define MLB_MIEN_CRX_DONE (0x1u << 24)
130 #define MLB_MIEN_CRX_PE (0x1u << 25)
131 #define MLB_MIEN_CRX_BREAK (0x1u << 26)
132 #define MLB_MIEN_CTX_DONE (0x1u << 27)
133 #define MLB_MIEN_CTX_PE (0x1u << 28)
134 #define MLB_MIEN_CTX_BREAK (0x1u << 29)
135 /* -------- MLB_MLBC1 : (MLB Offset: 0x03C) MediaLB Control 1 Register -------- */
136 #define MLB_MLBC1_LOCK (0x1u << 6)
137 #define MLB_MLBC1_CLKM (0x1u << 7)
138 #define MLB_MLBC1_NDA_Pos 8
139 #define MLB_MLBC1_NDA_Msk (0xffu << MLB_MLBC1_NDA_Pos)
140 #define MLB_MLBC1_NDA(value) ((MLB_MLBC1_NDA_Msk & ((value) << MLB_MLBC1_NDA_Pos)))
141 /* -------- MLB_HCTL : (MLB Offset: 0x080) HBI Control Register -------- */
142 #define MLB_HCTL_RST0 (0x1u << 0)
143 #define MLB_HCTL_RST1 (0x1u << 1)
144 #define MLB_HCTL_EN (0x1u << 15)
145 /* -------- MLB_HCMR[2] : (MLB Offset: 0x088) HBI Channel Mask 0 Register -------- */
146 #define MLB_HCMR_CHM_Pos 0
147 #define MLB_HCMR_CHM_Msk (0xffffffffu << MLB_HCMR_CHM_Pos)
148 #define MLB_HCMR_CHM(value) ((MLB_HCMR_CHM_Msk & ((value) << MLB_HCMR_CHM_Pos)))
149 /* -------- MLB_HCER[2] : (MLB Offset: 0x090) HBI Channel Error 0 Register -------- */
150 #define MLB_HCER_CERR_Pos 0
151 #define MLB_HCER_CERR_Msk (0xffffffffu << MLB_HCER_CERR_Pos)
152 /* -------- MLB_HCBR[2] : (MLB Offset: 0x098) HBI Channel Busy 0 Register -------- */
153 #define MLB_HCBR_CHB_Pos 0
154 #define MLB_HCBR_CHB_Msk (0xffffffffu << MLB_HCBR_CHB_Pos)
155 /* -------- MLB_MDAT[4] : (MLB Offset: 0x0C0) MIF Data 0 Register -------- */
156 #define MLB_MDAT_DATA_Pos 0
157 #define MLB_MDAT_DATA_Msk (0xffffffffu << MLB_MDAT_DATA_Pos)
158 #define MLB_MDAT_DATA(value) ((MLB_MDAT_DATA_Msk & ((value) << MLB_MDAT_DATA_Pos)))
159 /* -------- MLB_MDWE[4] : (MLB Offset: 0x0D0) MIF Data Write Enable 0 Register -------- */
160 #define MLB_MDWE_MASK_Pos 0
161 #define MLB_MDWE_MASK_Msk (0xffffffffu << MLB_MDWE_MASK_Pos)
162 #define MLB_MDWE_MASK(value) ((MLB_MDWE_MASK_Msk & ((value) << MLB_MDWE_MASK_Pos)))
163 /* -------- MLB_MCTL : (MLB Offset: 0x0E0) MIF Control Register -------- */
164 #define MLB_MCTL_XCMP (0x1u << 0)
165 /* -------- MLB_MADR : (MLB Offset: 0x0E4) MIF Address Register -------- */
166 #define MLB_MADR_ADDR_Pos 0
167 #define MLB_MADR_ADDR_Msk (0x3fffu << MLB_MADR_ADDR_Pos)
168 #define MLB_MADR_ADDR(value) ((MLB_MADR_ADDR_Msk & ((value) << MLB_MADR_ADDR_Pos)))
169 #define MLB_MADR_TB (0x1u << 30)
170 #define MLB_MADR_TB_CTR (0x0u << 30)
171 #define MLB_MADR_TB_DBR (0x1u << 30)
172 #define MLB_MADR_WNR (0x1u << 31)
173 /* -------- MLB_ACTL : (MLB Offset: 0x3C0) AHB Control Register -------- */
174 #define MLB_ACTL_SCE (0x1u << 0)
175 #define MLB_ACTL_SMX (0x1u << 1)
176 #define MLB_ACTL_DMA_MODE (0x1u << 2)
177 #define MLB_ACTL_MPB (0x1u << 4)
178 #define MLB_ACTL_MPB_SINGLE_PACKET (0x0u << 4)
179 #define MLB_ACTL_MPB_MULTIPLE_PACKET (0x1u << 4)
180 /* -------- MLB_ACSR[2] : (MLB Offset: 0x3D0) AHB Channel Status 0 Register -------- */
181 #define MLB_ACSR_CHS_Pos 0
182 #define MLB_ACSR_CHS_Msk (0xffffffffu << MLB_ACSR_CHS_Pos)
183 #define MLB_ACSR_CHS(value) ((MLB_ACSR_CHS_Msk & ((value) << MLB_ACSR_CHS_Pos)))
184 /* -------- MLB_ACMR[2] : (MLB Offset: 0x3D8) AHB Channel Mask 0 Register -------- */
185 #define MLB_ACMR_CHM_Pos 0
186 #define MLB_ACMR_CHM_Msk (0xffffffffu << MLB_ACMR_CHM_Pos)
187 #define MLB_ACMR_CHM(value) ((MLB_ACMR_CHM_Msk & ((value) << MLB_ACMR_CHM_Pos)))
188
192 #endif /* _SAMV71_MLB_COMPONENT_ */
(Mlb Offset: 0x0E0) MIF Control Register
Definition: component_mlb.h:64
#define __IO
Definition: core_cm7.h:287
(Mlb Offset: 0x02C) MediaLB Interrupt Enable Register
Definition: component_mlb.h:51
(Mlb Offset: 0x3C0) AHB Control Register
Definition: component_mlb.h:67
Mlb hardware registers.
Definition: component_mlb.h:41
(Mlb Offset: 0x03C) MediaLB Control 1 Register
Definition: component_mlb.h:53
(Mlb Offset: 0x00C) MediaLB Channel Status 0 Register
Definition: component_mlb.h:44
(Mlb Offset: 0x014) MediaLB Channel Status1 Register
Definition: component_mlb.h:46
(Mlb Offset: 0x020) MediaLB System Status Register
Definition: component_mlb.h:48
(Mlb Offset: 0x000) MediaLB Control 0 Register
Definition: component_mlb.h:42
(Mlb Offset: 0x0E4) MIF Address Register
Definition: component_mlb.h:65
#define __I
Definition: core_cm7.h:284
(Mlb Offset: 0x080) HBI Control Register
Definition: component_mlb.h:56
(Mlb Offset: 0x024) MediaLB System Data Register
Definition: component_mlb.h:49
