RTEMS
5.1
Go to the documentation of this file. 21 #define COMLOCV(x) (*(volatile unsigned char *)(x)) 23 #define COMLOC_DEBUG_PRODUCE COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1000) 24 #define COMLOC_DEBUG(offset) COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1001+offset) 25 #define COMLOC_MEVT_PRODUCE COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1101) 26 #define COMLOC_MEVT(offset) COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1102+offset) 27 #define COMLOC_KEVT_PRODUCE COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1142) 28 #define COMLOC_KEVT(offset) COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1143+offset) 29 #define COMLOC_MIDI_PRODUCE COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1183) 30 #define COMLOC_MIDI(offset) COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1184+offset)
