RTEMS  5.1
cmsis_gcc.h
1 /**************************************************************************/
7 /* Copyright (c) 2009 - 2015 ARM LIMITED
8
9  All rights reserved.
10  Redistribution and use in source and binary forms, with or without
11  modification, are permitted provided that the following conditions are met:
12  - Redistributions of source code must retain the above copyright
13  notice, this list of conditions and the following disclaimer.
14  - Redistributions in binary form must reproduce the above copyright
15  notice, this list of conditions and the following disclaimer in the
16  documentation and/or other materials provided with the distribution.
17  - Neither the name of ARM nor the names of its contributors may be used
18  to endorse or promote products derived from this software without
19  specific prior written permission.
20  *
21  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22  AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23  IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24  ARE DISCLAIMED. IN NO EVENT SHALL COPYRIGHT HOLDERS AND CONTRIBUTORS BE
25  LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26  CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27  SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28  INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29  CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30  ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31  POSSIBILITY OF SUCH DAMAGE.
32  ---------------------------------------------------------------------------*/
33
34
35 #ifndef __CMSIS_GCC_H
36 #define __CMSIS_GCC_H
37
38 /* ignore some GCC warnings */
39 #if defined ( __GNUC__ )
40 #pragma GCC diagnostic push
41 #pragma GCC diagnostic ignored "-Wsign-conversion"
42 #pragma GCC diagnostic ignored "-Wconversion"
43 #pragma GCC diagnostic ignored "-Wunused-parameter"
44 #endif
45
46
47 /* ########################### Core Function Access ########################### */
58 __attribute__( ( always_inline ) ) __STATIC_INLINE void __enable_irq(void)
59 {
60  __ASM volatile ("cpsie i" : : : "memory");
61 }
62
63
69 __attribute__( ( always_inline ) ) __STATIC_INLINE void __disable_irq(void)
70 {
71  __ASM volatile ("cpsid i" : : : "memory");
72 }
73
74
80 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_CONTROL(void)
81 {
82  uint32_t result;
83
84  __ASM volatile ("MRS %0, control" : "=r" (result) );
85  return(result);
86 }
87
88
94 __attribute__( ( always_inline ) ) __STATIC_INLINE void __set_CONTROL(uint32_t control)
95 {
96  __ASM volatile ("MSR control, %0" : : "r" (control) : "memory");
97 }
98
99
105 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_IPSR(void)
106 {
107  uint32_t result;
108
109  __ASM volatile ("MRS %0, ipsr" : "=r" (result) );
110  return(result);
111 }
112
113
119 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_APSR(void)
120 {
121  uint32_t result;
122
123  __ASM volatile ("MRS %0, apsr" : "=r" (result) );
124  return(result);
125 }
126
127
134 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_xPSR(void)
135 {
136  uint32_t result;
137
138  __ASM volatile ("MRS %0, xpsr" : "=r" (result) );
139  return(result);
140 }
141
142
148 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_PSP(void)
149 {
150  register uint32_t result;
151
152  __ASM volatile ("MRS %0, psp\n" : "=r" (result) );
153  return(result);
154 }
155
156
162 __attribute__( ( always_inline ) ) __STATIC_INLINE void __set_PSP(uint32_t topOfProcStack)
163 {
164  __ASM volatile ("MSR psp, %0\n" : : "r" (topOfProcStack) : "sp");
165 }
166
167
173 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_MSP(void)
174 {
175  register uint32_t result;
176
177  __ASM volatile ("MRS %0, msp\n" : "=r" (result) );
178  return(result);
179 }
180
181
188 __attribute__( ( always_inline ) ) __STATIC_INLINE void __set_MSP(uint32_t topOfMainStack)
189 {
190  __ASM volatile ("MSR msp, %0\n" : : "r" (topOfMainStack) : "sp");
191 }
192
193
199 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_PRIMASK(void)
200 {
201  uint32_t result;
202
203  __ASM volatile ("MRS %0, primask" : "=r" (result) );
204  return(result);
205 }
206
207
213 __attribute__( ( always_inline ) ) __STATIC_INLINE void __set_PRIMASK(uint32_t priMask)
214 {
215  __ASM volatile ("MSR primask, %0" : : "r" (priMask) : "memory");
216 }
217
218
219 #if (__CORTEX_M >= 0x03U)
220
226 __attribute__( ( always_inline ) ) __STATIC_INLINE void __enable_fault_irq(void)
227 {
228  __ASM volatile ("cpsie f" : : : "memory");
229 }
230
231
237 __attribute__( ( always_inline ) ) __STATIC_INLINE void __disable_fault_irq(void)
238 {
239  __ASM volatile ("cpsid f" : : : "memory");
240 }
241
242
248 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_BASEPRI(void)
249 {
250  uint32_t result;
251
252  __ASM volatile ("MRS %0, basepri" : "=r" (result) );
253  return(result);
254 }
255
256
262 __attribute__( ( always_inline ) ) __STATIC_INLINE void __set_BASEPRI(uint32_t value)
263 {
264  __ASM volatile ("MSR basepri, %0" : : "r" (value) : "memory");
265 }
266
267
274 __attribute__( ( always_inline ) ) __STATIC_INLINE void __set_BASEPRI_MAX(uint32_t value)
275 {
276  __ASM volatile ("MSR basepri_max, %0" : : "r" (value) : "memory");
277 }
278
279
285 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_FAULTMASK(void)
286 {
287  uint32_t result;
288
289  __ASM volatile ("MRS %0, faultmask" : "=r" (result) );
290  return(result);
291 }
292
293
299 __attribute__( ( always_inline ) ) __STATIC_INLINE void __set_FAULTMASK(uint32_t faultMask)
300 {
301  __ASM volatile ("MSR faultmask, %0" : : "r" (faultMask) : "memory");
302 }
303
304 #endif /* (__CORTEX_M >= 0x03U) */
305
306
307 #if (__CORTEX_M == 0x04U) || (__CORTEX_M == 0x07U)
308
314 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_FPSCR(void)
315 {
316 #if (__FPU_PRESENT == 1U) && (__FPU_USED == 1U)
317  uint32_t result;
318
319  /* Empty asm statement works as a scheduling barrier */
320  __ASM volatile ("");
321  __ASM volatile ("VMRS %0, fpscr" : "=r" (result) );
322  __ASM volatile ("");
323  return(result);
324 #else
325  return(0);
326 #endif
327 }
328
329
335 __attribute__( ( always_inline ) ) __STATIC_INLINE void __set_FPSCR(uint32_t fpscr)
336 {
337 #if (__FPU_PRESENT == 1U) && (__FPU_USED == 1U)
338  /* Empty asm statement works as a scheduling barrier */
339  __ASM volatile ("");
340  __ASM volatile ("VMSR fpscr, %0" : : "r" (fpscr) : "vfpcc");
341  __ASM volatile ("");
342 #endif
343 }
344
345 #endif /* (__CORTEX_M == 0x04U) || (__CORTEX_M == 0x07U) */
346
347
348
352 /* ########################## Core Instruction Access ######################### */
359 /* Define macros for porting to both thumb1 and thumb2.
360  * For thumb1, use low register (r0-r7), specified by constraint "l"
361  * Otherwise, use general registers, specified by constraint "r" */
362 #if defined (__thumb__) && !defined (__thumb2__)
363 #define __CMSIS_GCC_OUT_REG(r) "=l" (r)
364 #define __CMSIS_GCC_USE_REG(r) "l" (r)
365 #else
366 #define __CMSIS_GCC_OUT_REG(r) "=r" (r)
367 #define __CMSIS_GCC_USE_REG(r) "r" (r)
368 #endif
369
374 __attribute__((always_inline)) __STATIC_INLINE void __NOP(void)
375 {
376  __ASM volatile ("nop");
377 }
378
379
384 __attribute__((always_inline)) __STATIC_INLINE void __WFI(void)
385 {
386  __ASM volatile ("wfi");
387 }
388
389
395 __attribute__((always_inline)) __STATIC_INLINE void __WFE(void)
396 {
397  __ASM volatile ("wfe");
398 }
399
400
405 __attribute__((always_inline)) __STATIC_INLINE void __SEV(void)
406 {
407  __ASM volatile ("sev");
408 }
409
410
417 __attribute__((always_inline)) __STATIC_INLINE void __ISB(void)
418 {
419  __ASM volatile ("isb 0xF":::"memory");
420 }
421
422
428 __attribute__((always_inline)) __STATIC_INLINE void __DSB(void)
429 {
430  __ASM volatile ("dsb 0xF":::"memory");
431 }
432
433
439 __attribute__((always_inline)) __STATIC_INLINE void __DMB(void)
440 {
441  __ASM volatile ("dmb 0xF":::"memory");
442 }
443
444
451 __attribute__((always_inline)) __STATIC_INLINE uint32_t __REV(uint32_t value)
452 {
453 #if (__GNUC__ > 4) || (__GNUC__ == 4 && __GNUC_MINOR__ >= 5)
454  return __builtin_bswap32(value);
455 #else
456  uint32_t result;
457
458  __ASM volatile ("rev %0, %1" : __CMSIS_GCC_OUT_REG (result) : __CMSIS_GCC_USE_REG (value) );
459  return(result);
460 #endif
461 }
462
463
470 __attribute__((always_inline)) __STATIC_INLINE uint32_t __REV16(uint32_t value)
471 {
472  uint32_t result;
473
474  __ASM volatile ("rev16 %0, %1" : __CMSIS_GCC_OUT_REG (result) : __CMSIS_GCC_USE_REG (value) );
475  return(result);
476 }
477
478
485 __attribute__((always_inline)) __STATIC_INLINE int32_t __REVSH(int32_t value)
486 {
487 #if (__GNUC__ > 4) || (__GNUC__ == 4 && __GNUC_MINOR__ >= 8)
488  return (short)__builtin_bswap16(value);
489 #else
490  int32_t result;
491
492  __ASM volatile ("revsh %0, %1" : __CMSIS_GCC_OUT_REG (result) : __CMSIS_GCC_USE_REG (value) );
493  return(result);
494 #endif
495 }
496
497
505 __attribute__((always_inline)) __STATIC_INLINE uint32_t __ROR(uint32_t op1, uint32_t op2)
506 {
507  return (op1 >> op2) | (op1 << (32U - op2));
508 }
509
510
518 #define __BKPT(value) __ASM volatile ("bkpt "#value)
519
520
527 __attribute__((always_inline)) __STATIC_INLINE uint32_t __RBIT(uint32_t value)
528 {
529  uint32_t result;
530
531 #if (__CORTEX_M >= 0x03U) || (__CORTEX_SC >= 300U)
532  __ASM volatile ("rbit %0, %1" : "=r" (result) : "r" (value) );
533 #else
534  int32_t s = 4 /*sizeof(v)*/ * 8 - 1; /* extra shift needed at end */
535
536  result = value; /* r will be reversed bits of v; first get LSB of v */
537  for (value >>= 1U; value; value >>= 1U)
538  {
539  result <<= 1U;
540  result |= value & 1U;
541  s--;
542  }
543  result <<= s; /* shift when v's highest bits are zero */
544 #endif
545  return(result);
546 }
547
548
555 #define __CLZ __builtin_clz
556
557
558 #if (__CORTEX_M >= 0x03U) || (__CORTEX_SC >= 300U)
559
566 __attribute__((always_inline)) __STATIC_INLINE uint8_t __LDREXB(volatile uint8_t *addr)
567 {
568  uint32_t result;
569
570 #if (__GNUC__ > 4) || (__GNUC__ == 4 && __GNUC_MINOR__ >= 8)
571  __ASM volatile ("ldrexb %0, %1" : "=r" (result) : "Q" (*addr) );
572 #else
573  /* Prior to GCC 4.8, "Q" will be expanded to [rx, #0] which is not
574  accepted by assembler. So has to use following less efficient pattern.
575  */
576  __ASM volatile ("ldrexb %0, [%1]" : "=r" (result) : "r" (addr) : "memory" );
577 #endif
578  return ((uint8_t) result); /* Add explicit type cast here */
579 }
580
581
588 __attribute__((always_inline)) __STATIC_INLINE uint16_t __LDREXH(volatile uint16_t *addr)
589 {
590  uint32_t result;
591
592 #if (__GNUC__ > 4) || (__GNUC__ == 4 && __GNUC_MINOR__ >= 8)
593  __ASM volatile ("ldrexh %0, %1" : "=r" (result) : "Q" (*addr) );
594 #else
595  /* Prior to GCC 4.8, "Q" will be expanded to [rx, #0] which is not
596  accepted by assembler. So has to use following less efficient pattern.
597  */
598  __ASM volatile ("ldrexh %0, [%1]" : "=r" (result) : "r" (addr) : "memory" );
599 #endif
600  return ((uint16_t) result); /* Add explicit type cast here */
601 }
602
603
610 __attribute__((always_inline)) __STATIC_INLINE uint32_t __LDREXW(volatile uint32_t *addr)
611 {
612  uint32_t result;
613
614  __ASM volatile ("ldrex %0, %1" : "=r" (result) : "Q" (*addr) );
615  return(result);
616 }
617
618
627 __attribute__((always_inline)) __STATIC_INLINE uint32_t __STREXB(uint8_t value, volatile uint8_t *addr)
628 {
629  uint32_t result;
630
631  __ASM volatile ("strexb %0, %2, %1" : "=&r" (result), "=Q" (*addr) : "r" ((uint32_t)value) );
632  return(result);
633 }
634
635
644 __attribute__((always_inline)) __STATIC_INLINE uint32_t __STREXH(uint16_t value, volatile uint16_t *addr)
645 {
646  uint32_t result;
647
648  __ASM volatile ("strexh %0, %2, %1" : "=&r" (result), "=Q" (*addr) : "r" ((uint32_t)value) );
649  return(result);
650 }
651
652
661 __attribute__((always_inline)) __STATIC_INLINE uint32_t __STREXW(uint32_t value, volatile uint32_t *addr)
662 {
663  uint32_t result;
664
665  __ASM volatile ("strex %0, %2, %1" : "=&r" (result), "=Q" (*addr) : "r" (value) );
666  return(result);
667 }
668
669
674 __attribute__((always_inline)) __STATIC_INLINE void __CLREX(void)
675 {
676  __ASM volatile ("clrex" ::: "memory");
677 }
678
679
687 #define __SSAT(ARG1,ARG2) \
688 ({ \
689  uint32_t __RES, __ARG1 = (ARG1); \
690  __ASM ("ssat %0, %1, %2" : "=r" (__RES) : "I" (ARG2), "r" (__ARG1) ); \
691  __RES; \
692  })
693
694
702 #define __USAT(ARG1,ARG2) \
703 ({ \
704  uint32_t __RES, __ARG1 = (ARG1); \
705  __ASM ("usat %0, %1, %2" : "=r" (__RES) : "I" (ARG2), "r" (__ARG1) ); \
706  __RES; \
707  })
708
709
717 __attribute__((always_inline)) __STATIC_INLINE uint32_t __RRX(uint32_t value)
718 {
719  uint32_t result;
720
721  __ASM volatile ("rrx %0, %1" : __CMSIS_GCC_OUT_REG (result) : __CMSIS_GCC_USE_REG (value) );
722  return(result);
723 }
724
725
732 __attribute__((always_inline)) __STATIC_INLINE uint8_t __LDRBT(volatile uint8_t *addr)
733 {
734  uint32_t result;
735
736 #if (__GNUC__ > 4) || (__GNUC__ == 4 && __GNUC_MINOR__ >= 8)
737  __ASM volatile ("ldrbt %0, %1" : "=r" (result) : "Q" (*addr) );
738 #else
739  /* Prior to GCC 4.8, "Q" will be expanded to [rx, #0] which is not
740  accepted by assembler. So has to use following less efficient pattern.
741  */
742  __ASM volatile ("ldrbt %0, [%1]" : "=r" (result) : "r" (addr) : "memory" );
743 #endif
744  return ((uint8_t) result); /* Add explicit type cast here */
745 }
746
747
754 __attribute__((always_inline)) __STATIC_INLINE uint16_t __LDRHT(volatile uint16_t *addr)
755 {
756  uint32_t result;
757
758 #if (__GNUC__ > 4) || (__GNUC__ == 4 && __GNUC_MINOR__ >= 8)
759  __ASM volatile ("ldrht %0, %1" : "=r" (result) : "Q" (*addr) );
760 #else
761  /* Prior to GCC 4.8, "Q" will be expanded to [rx, #0] which is not
762  accepted by assembler. So has to use following less efficient pattern.
763  */
764  __ASM volatile ("ldrht %0, [%1]" : "=r" (result) : "r" (addr) : "memory" );
765 #endif
766  return ((uint16_t) result); /* Add explicit type cast here */
767 }
768
769
776 __attribute__((always_inline)) __STATIC_INLINE uint32_t __LDRT(volatile uint32_t *addr)
777 {
778  uint32_t result;
779
780  __ASM volatile ("ldrt %0, %1" : "=r" (result) : "Q" (*addr) );
781  return(result);
782 }
783
784
791 __attribute__((always_inline)) __STATIC_INLINE void __STRBT(uint8_t value, volatile uint8_t *addr)
792 {
793  __ASM volatile ("strbt %1, %0" : "=Q" (*addr) : "r" ((uint32_t)value) );
794 }
795
796
803 __attribute__((always_inline)) __STATIC_INLINE void __STRHT(uint16_t value, volatile uint16_t *addr)
804 {
805  __ASM volatile ("strht %1, %0" : "=Q" (*addr) : "r" ((uint32_t)value) );
806 }
807
808
815 __attribute__((always_inline)) __STATIC_INLINE void __STRT(uint32_t value, volatile uint32_t *addr)
816 {
817  __ASM volatile ("strt %1, %0" : "=Q" (*addr) : "r" (value) );
818 }
819
820 #endif /* (__CORTEX_M >= 0x03U) || (__CORTEX_SC >= 300U) */
821  /* end of group CMSIS_Core_InstructionInterface */
823
824
825 /* ################### Compiler specific Intrinsics ########################### */
832 #if (__CORTEX_M >= 0x04U) /* only for Cortex-M4 and above */
833
834 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SADD8(uint32_t op1, uint32_t op2)
835 {
836  uint32_t result;
837
838  __ASM volatile ("sadd8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
839  return(result);
840 }
841
842 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __QADD8(uint32_t op1, uint32_t op2)
843 {
844  uint32_t result;
845
846  __ASM volatile ("qadd8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
847  return(result);
848 }
849
850 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SHADD8(uint32_t op1, uint32_t op2)
851 {
852  uint32_t result;
853
854  __ASM volatile ("shadd8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
855  return(result);
856 }
857
858 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UADD8(uint32_t op1, uint32_t op2)
859 {
860  uint32_t result;
861
862  __ASM volatile ("uadd8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
863  return(result);
864 }
865
866 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UQADD8(uint32_t op1, uint32_t op2)
867 {
868  uint32_t result;
869
870  __ASM volatile ("uqadd8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
871  return(result);
872 }
873
874 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UHADD8(uint32_t op1, uint32_t op2)
875 {
876  uint32_t result;
877
878  __ASM volatile ("uhadd8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
879  return(result);
880 }
881
882
883 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SSUB8(uint32_t op1, uint32_t op2)
884 {
885  uint32_t result;
886
887  __ASM volatile ("ssub8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
888  return(result);
889 }
890
891 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __QSUB8(uint32_t op1, uint32_t op2)
892 {
893  uint32_t result;
894
895  __ASM volatile ("qsub8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
896  return(result);
897 }
898
899 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SHSUB8(uint32_t op1, uint32_t op2)
900 {
901  uint32_t result;
902
903  __ASM volatile ("shsub8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
904  return(result);
905 }
906
907 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __USUB8(uint32_t op1, uint32_t op2)
908 {
909  uint32_t result;
910
911  __ASM volatile ("usub8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
912  return(result);
913 }
914
915 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UQSUB8(uint32_t op1, uint32_t op2)
916 {
917  uint32_t result;
918
919  __ASM volatile ("uqsub8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
920  return(result);
921 }
922
923 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UHSUB8(uint32_t op1, uint32_t op2)
924 {
925  uint32_t result;
926
927  __ASM volatile ("uhsub8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
928  return(result);
929 }
930
931
932 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SADD16(uint32_t op1, uint32_t op2)
933 {
934  uint32_t result;
935
936  __ASM volatile ("sadd16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
937  return(result);
938 }
939
940 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __QADD16(uint32_t op1, uint32_t op2)
941 {
942  uint32_t result;
943
944  __ASM volatile ("qadd16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
945  return(result);
946 }
947
948 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SHADD16(uint32_t op1, uint32_t op2)
949 {
950  uint32_t result;
951
952  __ASM volatile ("shadd16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
953  return(result);
954 }
955
956 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UADD16(uint32_t op1, uint32_t op2)
957 {
958  uint32_t result;
959
960  __ASM volatile ("uadd16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
961  return(result);
962 }
963
964 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UQADD16(uint32_t op1, uint32_t op2)
965 {
966  uint32_t result;
967
968  __ASM volatile ("uqadd16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
969  return(result);
970 }
971
972 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UHADD16(uint32_t op1, uint32_t op2)
973 {
974  uint32_t result;
975
976  __ASM volatile ("uhadd16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
977  return(result);
978 }
979
980 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SSUB16(uint32_t op1, uint32_t op2)
981 {
982  uint32_t result;
983
984  __ASM volatile ("ssub16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
985  return(result);
986 }
987
988 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __QSUB16(uint32_t op1, uint32_t op2)
989 {
990  uint32_t result;
991
992  __ASM volatile ("qsub16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
993  return(result);
994 }
995
996 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SHSUB16(uint32_t op1, uint32_t op2)
997 {
998  uint32_t result;
999
1000  __ASM volatile ("shsub16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
1001  return(result);
1002 }
1003
1004 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __USUB16(uint32_t op1, uint32_t op2)
1005 {
1006  uint32_t result;
1007
1008  __ASM volatile ("usub16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
1009  return(result);
1010 }
1011
1012 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UQSUB16(uint32_t op1, uint32_t op2)
1013 {
1014  uint32_t result;
1015
1016  __ASM volatile ("uqsub16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
1017  return(result);
1018 }
1019
1020 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UHSUB16(uint32_t op1, uint32_t op2)
1021 {
1022  uint32_t result;
1023
1024  __ASM volatile ("uhsub16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
1025  return(result);
1026 }
1027
1028 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SASX(uint32_t op1, uint32_t op2)
1029 {
1030  uint32_t result;
1031
1032  __ASM volatile ("sasx %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
1033  return(result);
1034 }
1035
1036 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __QASX(uint32_t op1, uint32_t op2)
1037 {
1038  uint32_t result;
1039
1040  __ASM volatile ("qasx %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
1041  return(result);
1042 }
1043
1044 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SHASX(uint32_t op1, uint32_t op2)
1045 {
1046  uint32_t result;
1047
1048  __ASM volatile ("shasx %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
1049  return(result);
1050 }
1051
1052 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UASX(uint32_t op1, uint32_t op2)
1053 {
1054  uint32_t result;
1055
1056  __ASM volatile ("uasx %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
1057  return(result);
1058 }
1059
1060 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UQASX(uint32_t op1, uint32_t op2)
1061 {
1062  uint32_t result;
1063
1064  __ASM volatile ("uqasx %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
1065  return(result);
1066 }
1067
1068 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UHASX(uint32_t op1, uint32_t op2)
1069 {
1070  uint32_t result;
1071
1072  __ASM volatile ("uhasx %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
1073  return(result);
1074 }
1075
1076 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SSAX(uint32_t op1, uint32_t op2)
1077 {
1078  uint32_t result;
1079
1080  __ASM volatile ("ssax %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
1081  return(result);
1082 }
1083
1084 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __QSAX(uint32_t op1, uint32_t op2)
1085 {
1086  uint32_t result;
1087
1088  __ASM volatile ("qsax %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
1089  return(result);
1090 }
1091
1092 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SHSAX(uint32_t op1, uint32_t op2)
1093 {
1094  uint32_t result;
1095
1096  __ASM volatile ("shsax %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
1097  return(result);
1098 }
1099
1100 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __USAX(uint32_t op1, uint32_t op2)
1101 {
1102  uint32_t result;
1103
1104  __ASM volatile ("usax %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
1105  return(result);
1106 }
1107
1108 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UQSAX(uint32_t op1, uint32_t op2)
1109 {
1110  uint32_t result;
1111
1112  __ASM volatile ("uqsax %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
1113  return(result);
1114 }
1115
1116 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UHSAX(uint32_t op1, uint32_t op2)
1117 {
1118  uint32_t result;
1119
1120  __ASM volatile ("uhsax %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
1121  return(result);
1122 }
1123
1124 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __USAD8(uint32_t op1, uint32_t op2)
1125 {
1126  uint32_t result;
1127
1128  __ASM volatile ("usad8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
1129  return(result);
1130 }
1131
1132 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __USADA8(uint32_t op1, uint32_t op2, uint32_t op3)
1133 {
1134  uint32_t result;
1135
1136  __ASM volatile ("usada8 %0, %1, %2, %3" : "=r" (result) : "r" (op1), "r" (op2), "r" (op3) );
1137  return(result);
1138 }
1139
1140 #define __SSAT16(ARG1,ARG2) \
1141 ({ \
1142  int32_t __RES, __ARG1 = (ARG1); \
1143  __ASM ("ssat16 %0, %1, %2" : "=r" (__RES) : "I" (ARG2), "r" (__ARG1) ); \
1144  __RES; \
1145  })
1146
1147 #define __USAT16(ARG1,ARG2) \
1148 ({ \
1149  uint32_t __RES, __ARG1 = (ARG1); \
1150  __ASM ("usat16 %0, %1, %2" : "=r" (__RES) : "I" (ARG2), "r" (__ARG1) ); \
1151  __RES; \
1152  })
1153
1154 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UXTB16(uint32_t op1)
1155 {
1156  uint32_t result;
1157
1158  __ASM volatile ("uxtb16 %0, %1" : "=r" (result) : "r" (op1));
1159  return(result);
1160 }
1161
1162 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UXTAB16(uint32_t op1, uint32_t op2)
1163 {
1164  uint32_t result;
1165
1166  __ASM volatile ("uxtab16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
1167  return(result);
1168 }
1169
1170 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SXTB16(uint32_t op1)
1171 {
1172  uint32_t result;
1173
1174  __ASM volatile ("sxtb16 %0, %1" : "=r" (result) : "r" (op1));
1175  return(result);
1176 }
1177
1178 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SXTAB16(uint32_t op1, uint32_t op2)
1179 {
1180  uint32_t result;
1181
1182  __ASM volatile ("sxtab16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
1183  return(result);
1184 }
1185
1186 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMUAD (uint32_t op1, uint32_t op2)
1187 {
1188  uint32_t result;
1189
1190  __ASM volatile ("smuad %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
1191  return(result);
1192 }
1193
1194 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMUADX (uint32_t op1, uint32_t op2)
1195 {
1196  uint32_t result;
1197
1198  __ASM volatile ("smuadx %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
1199  return(result);
1200 }
1201
1202 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMLAD (uint32_t op1, uint32_t op2, uint32_t op3)
1203 {
1204  uint32_t result;
1205
1206  __ASM volatile ("smlad %0, %1, %2, %3" : "=r" (result) : "r" (op1), "r" (op2), "r" (op3) );
1207  return(result);
1208 }
1209
1210 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMLADX (uint32_t op1, uint32_t op2, uint32_t op3)
1211 {
1212  uint32_t result;
1213
1214  __ASM volatile ("smladx %0, %1, %2, %3" : "=r" (result) : "r" (op1), "r" (op2), "r" (op3) );
1215  return(result);
1216 }
1217
1218 __attribute__( ( always_inline ) ) __STATIC_INLINE uint64_t __SMLALD (uint32_t op1, uint32_t op2, uint64_t acc)
1219 {
1220  union llreg_u{
1221  uint32_t w32[2];
1222  uint64_t w64;
1223  } llr;
1224  llr.w64 = acc;
1225
1226 #ifndef __ARMEB__ /* Little endian */
1227  __ASM volatile ("smlald %0, %1, %2, %3" : "=r" (llr.w32[0]), "=r" (llr.w32[1]): "r" (op1), "r" (op2) , "0" (llr.w32[0]), "1" (llr.w32[1]) );
1228 #else /* Big endian */
1229  __ASM volatile ("smlald %0, %1, %2, %3" : "=r" (llr.w32[1]), "=r" (llr.w32[0]): "r" (op1), "r" (op2) , "0" (llr.w32[1]), "1" (llr.w32[0]) );
1230 #endif
1231
1232  return(llr.w64);
1233 }
1234
1235 __attribute__( ( always_inline ) ) __STATIC_INLINE uint64_t __SMLALDX (uint32_t op1, uint32_t op2, uint64_t acc)
1236 {
1237  union llreg_u{
1238  uint32_t w32[2];
1239  uint64_t w64;
1240  } llr;
1241  llr.w64 = acc;
1242
1243 #ifndef __ARMEB__ /* Little endian */
1244  __ASM volatile ("smlaldx %0, %1, %2, %3" : "=r" (llr.w32[0]), "=r" (llr.w32[1]): "r" (op1), "r" (op2) , "0" (llr.w32[0]), "1" (llr.w32[1]) );
1245 #else /* Big endian */
1246  __ASM volatile ("smlaldx %0, %1, %2, %3" : "=r" (llr.w32[1]), "=r" (llr.w32[0]): "r" (op1), "r" (op2) , "0" (llr.w32[1]), "1" (llr.w32[0]) );
1247 #endif
1248
1249  return(llr.w64);
1250 }
1251
1252 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMUSD (uint32_t op1, uint32_t op2)
1253 {
1254  uint32_t result;
1255
1256  __ASM volatile ("smusd %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
1257  return(result);
1258 }
1259
1260 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMUSDX (uint32_t op1, uint32_t op2)
1261 {
1262  uint32_t result;
1263
1264  __ASM volatile ("smusdx %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
1265  return(result);
1266 }
1267
1268 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMLSD (uint32_t op1, uint32_t op2, uint32_t op3)
1269 {
1270  uint32_t result;
1271
1272  __ASM volatile ("smlsd %0, %1, %2, %3" : "=r" (result) : "r" (op1), "r" (op2), "r" (op3) );
1273  return(result);
1274 }
1275
1276 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMLSDX (uint32_t op1, uint32_t op2, uint32_t op3)
1277 {
1278  uint32_t result;
1279
1280  __ASM volatile ("smlsdx %0, %1, %2, %3" : "=r" (result) : "r" (op1), "r" (op2), "r" (op3) );
1281  return(result);
1282 }
1283
1284 __attribute__( ( always_inline ) ) __STATIC_INLINE uint64_t __SMLSLD (uint32_t op1, uint32_t op2, uint64_t acc)
1285 {
1286  union llreg_u{
1287  uint32_t w32[2];
1288  uint64_t w64;
1289  } llr;
1290  llr.w64 = acc;
1291
1292 #ifndef __ARMEB__ /* Little endian */
1293  __ASM volatile ("smlsld %0, %1, %2, %3" : "=r" (llr.w32[0]), "=r" (llr.w32[1]): "r" (op1), "r" (op2) , "0" (llr.w32[0]), "1" (llr.w32[1]) );
1294 #else /* Big endian */
1295  __ASM volatile ("smlsld %0, %1, %2, %3" : "=r" (llr.w32[1]), "=r" (llr.w32[0]): "r" (op1), "r" (op2) , "0" (llr.w32[1]), "1" (llr.w32[0]) );
1296 #endif
1297
1298  return(llr.w64);
1299 }
1300
1301 __attribute__( ( always_inline ) ) __STATIC_INLINE uint64_t __SMLSLDX (uint32_t op1, uint32_t op2, uint64_t acc)
1302 {
1303  union llreg_u{
1304  uint32_t w32[2];
1305  uint64_t w64;
1306  } llr;
1307  llr.w64 = acc;
1308
1309 #ifndef __ARMEB__ /* Little endian */
1310  __ASM volatile ("smlsldx %0, %1, %2, %3" : "=r" (llr.w32[0]), "=r" (llr.w32[1]): "r" (op1), "r" (op2) , "0" (llr.w32[0]), "1" (llr.w32[1]) );
1311 #else /* Big endian */
1312  __ASM volatile ("smlsldx %0, %1, %2, %3" : "=r" (llr.w32[1]), "=r" (llr.w32[0]): "r" (op1), "r" (op2) , "0" (llr.w32[1]), "1" (llr.w32[0]) );
1313 #endif
1314
1315  return(llr.w64);
1316 }
1317
1318 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SEL (uint32_t op1, uint32_t op2)
1319 {
1320  uint32_t result;
1321
1322  __ASM volatile ("sel %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
1323  return(result);
1324 }
1325
1326 __attribute__( ( always_inline ) ) __STATIC_INLINE int32_t __QADD( int32_t op1, int32_t op2)
1327 {
1328  int32_t result;
1329
1330  __ASM volatile ("qadd %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
1331  return(result);
1332 }
1333
1334 __attribute__( ( always_inline ) ) __STATIC_INLINE int32_t __QSUB( int32_t op1, int32_t op2)
1335 {
1336  int32_t result;
1337
1338  __ASM volatile ("qsub %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
1339  return(result);
1340 }
1341
1342 #define __PKHBT(ARG1,ARG2,ARG3) \
1343 ({ \
1344  uint32_t __RES, __ARG1 = (ARG1), __ARG2 = (ARG2); \
1345  __ASM ("pkhbt %0, %1, %2, lsl %3" : "=r" (__RES) : "r" (__ARG1), "r" (__ARG2), "I" (ARG3) ); \
1346  __RES; \
1347  })
1348
1349 #define __PKHTB(ARG1,ARG2,ARG3) \
1350 ({ \
1351  uint32_t __RES, __ARG1 = (ARG1), __ARG2 = (ARG2); \
1352  if (ARG3 == 0) \
1353  __ASM ("pkhtb %0, %1, %2" : "=r" (__RES) : "r" (__ARG1), "r" (__ARG2) ); \
1354  else \
1355  __ASM ("pkhtb %0, %1, %2, asr %3" : "=r" (__RES) : "r" (__ARG1), "r" (__ARG2), "I" (ARG3) ); \
1356  __RES; \
1357  })
1358
1359 __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMMLA (int32_t op1, int32_t op2, int32_t op3)
1360 {
1361  int32_t result;
1362
1363  __ASM volatile ("smmla %0, %1, %2, %3" : "=r" (result): "r" (op1), "r" (op2), "r" (op3) );
1364  return(result);
1365 }
1366
1367 #endif /* (__CORTEX_M >= 0x04) */
1368
1371 #if defined ( __GNUC__ )
1372 #pragma GCC diagnostic pop
1373 #endif
1374
1375 #endif /* __CMSIS_GCC_H */
__attribute__((always_inline)) __STATIC_INLINE void __enable_irq(void)
Enable IRQ Interrupts.
Definition: cmsis_gcc.h:58
Definition: intercom.c:74
