RTEMS
5.1
Data Structure Index
Class Hierarchy
z
z
z
z
Pages
include
pci
cfg_static.h
1
/* Static PCI Auto Configuration Library
2
3
* COPYRIGHT (c) 2010 Cobham Gaisler AB.
4
5
* The license and distribution terms for this file may be
6
* found in the file LICENSE in this distribution or at
7
* http://www.rtems.org/license/LICENSE.
8
9
10
#ifndef __PCI_CFG_STATIC_H__
11
#define __PCI_CFG_STATIC_H__
12
13
/* This function initializes all buses and device accorind to a user defined
14
* "static" configuration. The configuration can manually created with C
15
* data structures. Or it can be automatically created on a running target
16
* using the pci_cfg_print() routine after the AUTO or READ Configuration
17
* Library has setup the PCI bus
18
19
extern
int
pci_config_static(
void
20
21
#endif
